Part Number: PROCESSOR-SDK-J721E
Hi Ti experts,
I'm trying to use SBL EMMC boot on sdk 8.06, but failed on kernel boot, the boot log is attached, I've modified the bootargs in dts file,like this
- bootargs = "console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000";
+ bootargs = "console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=/dev/mmcblk1p2 rw rootfstype=ext4 rootwait";
NOTICE: BL31: v2.8(release):v2.8-226-g2fcd408bb3-dirty NOTICE: BL31: Built : 22:56:45, Mar 3 2023 ERROR: GTC_CNTFID0 is 0! Assuming 200000000 Hz. Fix Bootloader I/TC: I/TC: OP-TEE version: 3.20.0 (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10))) #1 Fri Mar 3 22:59:24 UTC 202 I/TC: WARNING: This OP-TEE configuration might be insecure! I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html I/TC: Primary CPU initializing I/TC: SYSFW ABI: 3.1 (firmware rev 0x0008 '8.6.3--v08.06.03 (Chill Capybar') I/TC: HUK Initialized I/TC: Activated SA2UL device I/TC: Fixing SA2UL firewall owner for GP device I/TC: Enabled firewalls for SA2UL TRNG device I/TC: SA2UL TRNG initialized I/TC: SA2UL Drivers initialized I/TC: Primary CPU switching to normal world boot [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080] [ 0.000000] Linux version 5.10.162-g76b3e88d56 (andy@ubuntu) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.1e A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT Tue Apr 25 15:27:37 CST 2023 [ 0.000000] Machine model: Texas Instruments K3 J721E SoC [ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '') [ 0.000000] printk: bootconsole [ns16550a0] enabled [ 0.000000] efi: UEFI not found. [ 0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader! [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a0100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 31 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a6100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a8000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a8100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a9000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a9100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a9100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 96 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@ac000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b2000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@b2000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b2100000, size 95 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c71-memory@b2100000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000d8000000, size 192 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@d8000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000e4000000, size 8 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-queues@e4000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000e4800000, size 24 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-buffers@e4800000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 624 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created CMA memory pool at 0x00000008a7000000, size 512 MiB [ 0.000000] OF: reserved mem: initialized node linux-cma-buffers@8a7000000, compatible id shared-dma-pool [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal [mem 0x0000000100000000-0x00000008ffffffff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000080000000-0x000000009e7fffff] [ 0.000000] node 0: [mem 0x000000009e800000-0x00000000b7ffffff] [ 0.000000] node 0: [mem 0x00000000b8000000-0x00000000d7ffffff] [ 0.000000] node 0: [mem 0x00000000d8000000-0x00000000e5ffffff] [ 0.000000] node 0: [mem 0x00000000e6000000-0x00000000ffffffff] [ 0.000000] node 0: [mem 0x0000000880000000-0x00000008a6ffffff] [ 0.000000] node 0: [mem 0x00000008a7000000-0x00000008ffffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff] [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: Trusted OS migration not required [ 0.000000] psci: SMC Calling Convention v1.2 [ 0.000000] percpu: Embedded 22 pages/cpu s50392 r8192 d31528 u90112 [ 0.000000] Detected PIPT I-cache on CPU0 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] CPU features: detected: EL2 vector hardening [ 0.000000] CPU features: kernel page table isolation forced ON by KASLR [ 0.000000] CPU features: detected: Kernel page table isolation (KPTI) [ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923 [ 0.000000] CPU features: detected: Spectre-BHB [ 0.000000] CPU features: detected: ARM erratum 1742098 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1032192 [ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=/dev/mmcblk0p2 rw rootfstype=ext4 rootwait [ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) [ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] software IO TLB: mapped [mem 0x00000000fbfff000-0x00000000fffff000] (64MB) [ 0.000000] Memory: 1696364K/4194304K available (11200K kernel code, 1160K rwdata, 4300K rodata, 1856K init, 433K bss, 1973652K reserved, 524288K cma-reser [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] Tracing variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 960 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] GICv3: Distributor has no Range Selector support [ 0.000000] GICv3: 16 PPIs implemented [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000 [ 0.000000] ITS [mem 0x01820000-0x0182ffff] [ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS [ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19 [ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @8c7800000 (flat, esz 8, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GICv3: using LPI property table @0x00000008c7030000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008c7040000 [ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns [ 0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns [ 0.008446] Console: colour dummy device 80x25 [ 0.013011] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000) [ 0.023681] pid_max: default: 32768 minimum: 301 [ 0.028440] LSM: Security Framework initializing [ 0.033198] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.040775] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.049617] rcu: Hierarchical SRCU implementation. [ 0.054685] Platform MSI: msi-controller@1820000 domain created [ 0.060951] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created [ 0.070263] EFI services will not be available. [ 0.074991] smp: Bringing up secondary CPUs ... ERROR: GTC_CNTFID0 is 0! Assuming 200000000 Hz. Fix Bootloader I/TC: Secondary CPU 1 initializing I/TC: Secondary CPU 1 switching to normal world boot [ 0.093980] Detected PIPT I-cache on CPU1 [ 0.094005] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000 [ 0.094016] GICv3: CPU1: using allocated LPI pending table @0x00000008c7050000 [ 0.094051] CPU1: Booted secondary processor 0x0000000001 [0x411fd080] [ 0.094103] smp: Brought up 1 node, 2 CPUs [ 0.123451] SMP: Total of 2 processors activated. [ 0.128256] CPU features: detected: 32-bit EL0 Support [ 0.133511] CPU features: detected: CRC32 instructions [ 0.147672] CPU: All CPU(s) started at EL2 [ 0.151868] alternatives: patching kernel code [ 0.156964] devtmpfs: initialized [ 0.166282] KASLR disabled due to lack of seed [ 0.170935] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.180899] futex hash table entries: 512 (order: 3, 32768 bytes, linear) [ 0.194299] pinctrl core: initialized pinctrl subsystem [ 0.199960] DMI not present or invalid. [ 0.204208] NET: Registered protocol family 16 [ 0.209636] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations [ 0.216952] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 0.224959] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 0.233309] thermal_sys: Registered thermal governor 'step_wise' [ 0.233312] thermal_sys: Registered thermal governor 'power_allocator' [ 0.239893] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.253531] ASID allocator initialised with 32768 entries [ 0.277887] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages [ 0.284746] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages [ 0.291593] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [ 0.298439] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages [ 0.305911] cryptd: max_cpu_qlen set to 1000 [ 0.312023] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected [ 0.320866] vsys_3v3: supplied by evm_12v0 [ 0.325243] vsys_5v0: supplied by evm_12v0 [ 0.330052] iommu: Default domain type: Translated [ 0.335188] SCSI subsystem initialized [ 0.339342] mc: Linux media interface: v0.10 [ 0.343727] videodev: Linux video capture interface: v2.00 [ 0.349364] pps_core: LinuxPPS API ver. 1 registered [ 0.354436] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.363773] PTP clock support registered [ 0.367791] EDAC MC: Ver: 3.0.0 [ 0.371612] FPGA manager framework [ 0.375130] Advanced Linux Sound Architecture Driver Initialized. [ 0.381730] clocksource: Switched to clocksource arch_sys_counter [ 0.388062] VFS: Disk quotas dquot_6.6.0 [ 0.392093] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 0.401767] Carveout Heap: Exported 512 MiB at 0x00000000b8000000 [ 0.408056] NET: Registered protocol family 2 [ 0.412797] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear) [ 0.421385] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear) [ 0.430142] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear) [ 0.438346] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear) [ 0.446158] TCP: Hash tables configured (established 32768 bind 32768) [ 0.452960] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear) [ 0.459855] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear) [ 0.467253] NET: Registered protocol family 1 [ 0.471983] RPC: Registered named UNIX socket transport module. [ 0.478039] RPC: Registered udp transport module. [ 0.482856] RPC: Registered tcp transport module. [ 0.487661] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.494242] NET: Registered protocol family 44 [ 0.498790] PCI: CLS 0 bytes, default 64 [ 0.503137] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available [ 0.513578] Initialise system trusted keyrings [ 0.518219] workingset: timestamp_bits=46 max_order=20 bucket_order=0 [ 0.526370] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.532580] NFS: Registering the id_resolver key type [ 0.537771] Key type id_resolver registered [ 0.542044] Key type id_legacy registered [ 0.546166] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.553013] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [ 0.560656] 9p: Installing v9fs 9p2000 file system support [ 0.586167] Key type asymmetric registered [ 0.590354] Asymmetric key parser 'x509' registered [ 0.595351] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243) [ 0.602910] io scheduler mq-deadline registered [ 0.607535] io scheduler kyber registered [ 0.613315] pinctrl-single 4301c000.pinctrl: 94 pins, size 376 [ 0.619520] pinctrl-single 11c000.pinctrl: 173 pins, size 692 [ 0.628530] ti-pat 31010000.pat: Found PAT Rev 1.0 with 16384 pages [ 0.634964] debugfs: Directory '31010000.pat' with parent 'regmap' already present! [ 0.642959] ti-pat 31011000.pat: Found PAT Rev 1.0 with 16384 pages [ 0.649381] debugfs: Directory '31011000.pat' with parent 'regmap' already present! [ 0.657329] ti-pat 31012000.pat: Found PAT Rev 1.0 with 16384 pages [ 0.663749] debugfs: Directory '31012000.pat' with parent 'regmap' already present! [ 0.671677] ti-pat 31013000.pat: Found PAT Rev 1.0 with 2048 pages [ 0.678005] debugfs: Directory '31013000.pat' with parent 'regmap' already present! [ 0.685958] ti-pat 31014000.pat: Found PAT Rev 1.0 with 2048 pages [ 0.692284] debugfs: Directory '31014000.pat' with parent 'regmap' already present! [ 0.702052] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled [ 0.710377] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf) [ 0.718594] arm-smmu-v3 36600000.iommu: allocated 65536 entries for cmdq [ 0.725777] arm-smmu-v3 36600000.iommu: allocated 32768 entries for evtq [ 0.734392] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs [ 0.747827] brd: module loaded [ 0.754400] loop: module loaded [ 0.758120] megasas: 07.714.04.00-rc1 [ 0.763927] tun: Universal TUN/TAP device driver, 1.6 [ 0.769430] igbvf: Intel(R) Gigabit Virtual Function Network Driver [ 0.775837] igbvf: Copyright (c) 2009 - 2012 Intel Corporation. [ 0.781911] sky2: driver version 1.30 [ 0.786278] VFIO - User Level meta-driver version: 0.3 [ 0.792079] i2c /dev entries driver [ 0.796584] sdhci: Secure Digital Host Controller Interface driver [ 0.802909] sdhci: Copyright(c) Pierre Ossman [ 0.807571] sdhci-pltfm: SDHCI platform and OF driver helper [ 0.814001] ledtrig-cpu: registered to indicate activity on CPUs [ 0.820345] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 0.827742] optee: probing for conduit method. I/TC: Reserved shared memory is enabled I/TC: Dynamic shared memory is enabled I/TC: Normal World virtualization support is disabled I/TC: Asynchronous notifications are disabled [ 0.832307] optee: revision 3.20 (8e74d476) [ 0.848718] optee: dynamic shared memory is enabled [ 0.858179] optee: initialized driver [ 0.863476] NET: Registered protocol family 17 [ 0.868103] 9pnet: Installing 9P2000 support [ 0.872500] Key type dns_resolver registered [ 0.876952] Loading compiled-in X.509 certificates [ 0.890504] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0008 '8.6.3--v08.06.03 (Chill Capybar') [ 0.944708] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 0.952385] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz [ 0.958476] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz [ 0.964723] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz [ 0.970994] pca953x 3-0020: supply vcc not found, using dummy regulator [ 0.977837] pca953x 3-0020: using no AI [ 1.006497] pca953x 3-0022: supply vcc not found, using dummy regulator [ 1.013303] pca953x 3-0022: using AI [ 1.017572] gpio-480 (CTRL_PM_I2C_OE): hogged as output/high [ 1.023549] gpio-481 (MCASP/TRACE_MUX_S0): hogged as output/low [ 1.029792] gpio-482 (MCASP/TRACE_MUX_S1): hogged as output/high [ 1.036286] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz [ 1.042628] omap_i2c 2010000.i2c: bus 4 rev0.12 at 400 kHz [ 1.050802] omap_i2c 2020000.i2c: bus 5 rev0.12 at 400 kHz [ 1.056996] pca953x 6-0020: supply vcc not found, using dummy regulator [ 1.063814] pca953x 6-0020: using no AI [ 1.090371] omap_i2c 2030000.i2c: bus 6 rev0.12 at 400 kHz [ 1.096490] omap_i2c 2040000.i2c: bus 7 rev0.12 at 100 kHz [ 1.102456] omap_i2c 2050000.i2c: bus 8 rev0.12 at 100 kHz [ 1.108580] pca953x 9-0020: supply vcc not found, using dummy regulator [ 1.115407] pca953x 9-0020: using no AI [ 1.142074] omap_i2c 2060000.i2c: bus 9 rev0.12 at 400 kHz [ 1.148560] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created [ 1.158520] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created [ 1.167315] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created [ 1.177144] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created [ 1.198694] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235 [ 1.208577] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled [ 1.215336] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64 [ 1.224329] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211 [ 1.234483] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled [ 1.241243] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64 [ 1.249189] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 15, base_baud = 6000000) is a 8250 [ 1.258587] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 30, base_baud = 3000000) is a 8250 [ 1.267337] printk: console [ttyS2] enabled [ 1.267337] printk: console [ttyS2] enabled [ 1.275774] printk: bootconsole [ns16550a0] disabled [ 1.275774] printk: bootconsole [ns16550a0] disabled [ 1.286224] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 31, base_baud = 3000000) is a 8250 [ 1.295160] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 32, base_baud = 3000000) is a 8250 [ 1.305619] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled [ 1.316130] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled [ 1.326283] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled [ 1.336522] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled [ 1.347352] scsi host0: ufshcd [ 1.355952] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode [ 1.369245] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[1, 1], lane[1, 1], pwr[SLOWAUTO_MODE, SLOWAUTO_MODE], rate = 0 [ 1.401733] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 1.410310] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867 [ 1.418567] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[3, 3], lane[2, 2], pwr[FAST MODE, FAST MODE], rate = 2 [ 1.430198] cdns-ufshcd 4e84000.ufs: ufshcd_find_max_sup_active_icc_level: Regulator capability was not set, actvIccLevel=0 [ 1.430244] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000 [ 1.454190] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4 [ 1.454205] scsi 0:0:0:49488: Well-known LUN TOSHIBA THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6 [ 1.461398] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64 [ 1.461771] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0 [ 1.485048] scsi 0:0:0:49476: Well-known LUN TOSHIBA THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6 [ 1.493775] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0 [ 1.501989] cdns-ufshcd 4e84000.ufs: ufshcd_scsi_add_wlus: BOOT WLUN not found [ 1.603536] mmc0: CQHCI version 5.10 [ 1.605842] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 1.618480] vdd_mmc1: supplied by vsys_3v3 [ 1.623323] pca953x 4-0020: supply vcc not found, using dummy regulator [ 1.629981] pca953x 4-0020: using no AI [ 1.645747] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit [ 1.658754] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100 [ 1.665683] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100 [ 1.672538] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100 [ 1.679390] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100 [ 1.686224] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100 [ 1.696858] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8) [ 1.707420] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16) [ 1.721671] spi-nor spi7.0: mt35xu512aba (65536 Kbytes) [ 1.726949] 8 fixed-partitions partitions found on MTD device 47040000.spi.0 [ 1.733994] Creating 8 MTD partitions on "47040000.spi.0": [ 1.739472] 0x000000000000-0x000000080000 : "ospi.tiboot3" [ 1.745482] 0x000000080000-0x000000280000 : "ospi.tispl" [ 1.751219] 0x000000280000-0x000000680000 : "ospi.u-boot" [ 1.757004] 0x000000680000-0x0000006a0000 : "ospi.env" [ 1.762550] 0x0000006a0000-0x0000006c0000 : "ospi.env.backup" [ 1.768769] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw" [ 1.774507] 0x000000800000-0x000003fc0000 : "ospi.rootfs" [ 1.780306] 0x000003fe0000-0x000004000000 : "ospi.phypattern" [ 1.788852] spi-nor spi8.0: mt25qu512a (65536 Kbytes) [ 1.795180] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode [ 1.806553] mmc0: Command Queue Engine enabled [ 1.810996] mmc0: new HS200 MMC card at address 0001 [ 1.816271] mmcblk0: mmc0:0001 S0J56X 14.8 GiB [ 1.820912] mmcblk0boot0: mmc0:0001 S0J56X partition 1 31.5 MiB [ 1.826943] mmcblk0boot1: mmc0:0001 S0J56X partition 2 31.5 MiB [ 1.832938] mmcblk0rpmb: mmc0:0001 S0J56X partition 3 4.00 MiB, chardev (237:0) [ 1.841071] mmcblk0: p1 p2 [ 1.843871] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 1.853684] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867 [ 1.862000] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000 [ 1.874869] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4 [ 1.882075] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64 [ 1.888330] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0 [ 1.898558] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48 [ 1.906683] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 1.912626] mmc1: CQHCI version 5.10 [ 1.924313] debugfs: Directory 'pd:27' with parent 'pm_genpd' already present! [ 1.931571] debugfs: Directory 'pd:26' with parent 'pm_genpd' already present! [ 1.939993] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present! [ 1.947308] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present! [ 1.954620] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present! [ 1.961936] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present! [ 1.970324] input: gpio-keys as /devices/platform/gpio-keys/input/input0 [ 1.986768] ALSA device list: [ 1.989738] No soundcards found. [ 2.974514] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit [ 2.985991] EXT4-fs (mmcblk0p2): warning: mounting fs with errors, running e2fsck is recommended [ 2.995795] EXT4-fs (mmcblk0p2): recovery complete [ 3.000610] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null) [ 3.008730] VFS: Mounted root (ext4 filesystem) on device 179:2. [ 3.016418] devtmpfs: mounted [ 3.020278] Freeing unused kernel memory: 1856K [ 3.024903] Run /sbin/init as init process [ 3.030924] mmc0: running CQE recovery [ 3.036138] mmc0: running CQE recovery [ 3.041332] mmc0: running CQE recovery [ 3.045229] blk_update_request: I/O error, dev mmcblk0, sector 4323608 op 0x0:(READ) flags 0x80700 phys_seg 30 prio class 0 [ 3.056354] blk_update_request: I/O error, dev mmcblk0, sector 4388648 op 0x0:(READ) flags 0x3000 phys_seg 1 prio class 0 [ 3.067292] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1580: inode #130088: comm swapper/0: reading directory lblock 0 [ 3.079359] Starting init: /sbin/init exists but couldn't execute it (error -5) [ 3.086668] Run /etc/init as init process [ 3.092831] mmc0: running CQE recovery [ 3.098640] mmc0: running CQE recovery [ 3.104443] mmc0: running CQE recovery [ 3.108336] blk_update_request: I/O error, dev mmcblk0, sector 12712200 op 0x0:(READ) flags 0x80700 phys_seg 32 prio class 0 [ 3.119545] blk_update_request: I/O error, dev mmcblk0, sector 12712192 op 0x0:(READ) flags 0x3000 phys_seg 1 prio class 0 [ 3.130571] EXT4-fs error (device mmcblk0p2): __ext4_get_inode_loc_noinmem:4506: inode #390145: block 1572896: comm swapper/0: unable to read itable block [ 3.144965] Starting init: /etc/init exists but couldn't execute it (error -5) [ 3.152180] Run /bin/init as init process [ 3.158444] mmc0: running CQE recovery [ 3.164374] mmc0: running CQE recovery [ 3.170298] mmc0: running CQE recovery [ 3.174191] blk_update_request: I/O error, dev mmcblk0, sector 16906504 op 0x0:(READ) flags 0x80700 phys_seg 32 prio class 0 [ 3.185400] blk_update_request: I/O error, dev mmcblk0, sector 16906496 op 0x0:(READ) flags 0x3000 phys_seg 1 prio class 0 [ 3.196425] EXT4-fs error (device mmcblk0p2): __ext4_get_inode_loc_noinmem:4506: inode #520193: block 2097184: comm swapper/0: unable to read itable block [ 3.210821] Starting init: /bin/init exists but couldn't execute it (error -5) [ 3.218038] Run /bin/sh as init process [ 3.223965] mmc0: running CQE recovery [ 3.230019] mmc0: running CQE recovery [ 3.235942] mmc0: running CQE recovery [ 3.239834] blk_update_request: I/O error, dev mmcblk0, sector 16906504 op 0x0:(READ) flags 0x80700 phys_seg 32 prio class 0 [ 3.253348] mmc0: running CQE recovery [ 3.258912] mmc0: running CQE recovery [ 3.264465] mmc0: running CQE recovery [ 3.268355] blk_update_request: I/O error, dev mmcblk0, sector 16906552 op 0x0:(READ) flags 0x80700 phys_seg 26 prio class 0 [ 3.279562] blk_update_request: I/O error, dev mmcblk0, sector 17168384 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0 [ 3.292566] mmc0: running CQE recovery [ 3.297923] mmc0: running CQE recovery [ 3.303276] mmc0: running CQE recovery [ 3.307170] blk_update_request: I/O error, dev mmcblk0, sector 16906576 op 0x0:(READ) flags 0x80700 phys_seg 23 prio class 0 [ 3.318380] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1580: inode #520345: comm swapper/0: reading directory lblock 0 [ 3.330439] Starting init: /bin/sh exists but couldn't execute it (error -5) [ 3.337484] Kernel panic - not syncing: No working init found. Try passing init= option to kernel. See Linux Documentation/admin-guide/init.rst for guidan [ 3.351621] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.10.162-g76b3e88d56 #1 [ 3.358735] Hardware name: Texas Instruments K3 J721E SoC (DT) [ 3.364549] Call trace: [ 3.366992] dump_backtrace+0x0/0x1a0 [ 3.370642] show_stack+0x18/0x68 [ 3.373946] dump_stack+0xd0/0x12c [ 3.377334] panic+0x16c/0x334 [ 3.380379] kernel_init+0xf8/0x114 [ 3.383853] ret_from_fork+0x10/0x34 [ 3.387417] SMP: stopping secondary CPUs [ 3.391329] Kernel Offset: 0x80000 from 0xffff800010000000 [ 3.396796] PHYS_OFFSET: 0x80000000 [ 3.400271] CPU features: 0x28040022,20806008 [ 3.404611] Memory Limit: none [ 3.407657] ---[ end Kernel panic - not syncing: No working init found. Try passing init= option to kernel. See Linux Documentation/admin-guide/init.rst f
I've tried to use spl boot with same kernel image and dtb, it could boot successfully, here is the log
