Part Number: SK-TDA4VM
I have connected raspicam v2 camera connected via MIPI port to the device and it was loaded successfully:
CSI Camera 1 detected
device = /dev/video2
name = imx219
format = [fmt:SRGGB8_1X8/1920x1080]
subdev_id = /dev/v4l-subdev2
isp_required = yes
I was able to read the video stream from it and save it to the mp4 file using:
$ sudo gst-launch-1.0 v4l2src num-buffers=200 device=/dev/video2 ! video/x-bayer, width=1920, height=1080, format=rggb, framerate=\(fraction\)25/1 ! bayer2rgb ! videoconvert ! x264enc tune=zerolatency ! mp4mux ! filesink location=a.mp4
I want to utilize tda's video codec to encode efficiently in h264 using the next command:
sudo gst-launch-1.0 -vvv v4l2src device=/dev/video2 io-mode=dmabuf ! video/x-bayer,width=1920,height=1080, framerate=30/1, format=bggr ! \ tiovxisp sensor-name=SENSOR_SONY_IMX219_RPI \ dcc-isp-file=/opt/imaging/imx219/dcc_viss_1920x1080.bin \ sink_0::dcc-2a-file=/opt/imaging/imx219/dcc_2a_1920x1080.bin \ sink_0::device=/dev/v4l-subdev2 ! \ video/x-raw,format=NV12 ! \ v4l2h264enc output-io-mode=dmabuf-import extra-controls="controls,h264_i_frame_period=60" ! \ rtph264pay ! fakesink
However, I am getting the next error:
APP: Init ... !!! MEM: Init ... !!! MEM: Initialized DMA HEAP (fd=5) !!! MEM: Init ... Done !!! IPC: Init ... !!! IPC: Init ... Done !!! REMOTE_SERVICE: Init ... !!! REMOTE_SERVICE: Init ... Done !!! 913.528686 s: GTC Frequency = 200 MHz APP: Init ... Done !!! 913.528751 s: VX_ZONE_INIT:Enabled 913.528760 s: VX_ZONE_ERROR:Enabled 913.528769 s: VX_ZONE_WARNING:Enabled 913.530261 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!! 913.531523 s: VX_ZONE_INIT:[tivxHostInitLocal:93] Initialization Done for HOST !!! Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Setting pipeline to PLAYING ... /GstPipeline:pipeline0/GstV4l2Src:v4l2src0.GstPad:src: caps = video/x-bayer, width=(int)1920, height=(int)1080, framerate=(fraction)30/1, format=(string)bggr, colorimetry=(string)sRGB, interlace-mode=(string)progressive New clock: GstSystemClock /GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-bayer, width=(int)1920, height=(int)1080, framerate=(fraction)30/1, format=(string)bggr, colorimetry=(string)sRGB, interlace-mode=(string)progressive /GstPipeline:pipeline0/GstTIOVXISP:tiovxisp0.GstTIOVXIspPad:sink_0: caps = video/x-bayer, width=(int)1920, height=(int)1080, framerate=(fraction)30/1, format=(string)bggr, colorimetry=(string)sRGB, interlace-mode=(string)progressive /GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-bayer, width=(int)1920, height=(int)1080, framerate=(fraction)30/1, format=(string)bggr, colorimetry=(string)sRGB, interlace-mode=(string)progressive /GstPipeline:pipeline0/GstTIOVXISP:tiovxisp0.GstTIOVXMisoPad:src: caps = video/x-raw, format=(string)NV12, width=(int)1920, height=(int)1080, framerate=(fraction)1/1, interlace-mode=(string)progressive, colorimetry=(string)bt601 /GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:src: caps = video/x-raw, format=(string)NV12, width=(int)1920, height=(int)1080, framerate=(fraction)1/1, interlace-mode=(string)progressive, colorimetry=(string)bt601 /GstPipeline:pipeline0/v4l2h264enc:v4l2h264enc0.GstPad:src: caps = video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, profile=(string)baseline, level=(string)1, width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)1/1, interlace-mode=(string)progressive, colorimetry=(string)bt601 /GstPipeline:pipeline0/GstRtpH264Pay:rtph264pay0.GstPad:sink: caps = video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, profile=(string)baseline, level=(string)1, width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)1/1, interlace-mode=(string)progressive, colorimetry=(string)bt601 Redistribute latency... /GstPipeline:pipeline0/v4l2h264enc:v4l2h264enc0.GstPad:sink: caps = video/x-raw, format=(string)NV12, width=(int)1920, height=(int)1080, framerate=(fraction)1/1, interlace-mode=(string)progressive, colorimetry=(string)bt601 /GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:sink: caps = video/x-raw, format=(string)NV12, width=(int)1920, height=(int)1080, framerate=(fraction)1/1, interlace-mode=(string)progressive, colorimetry=(string)bt601 /GstPipeline:pipeline0/GstTIOVXISP:tiovxisp0.GstTIOVXMisoPad:src: caps = video/x-raw, format=(string)NV12, width=(int)1920, height=(int)1080, framerate=(fraction)1/1, interlace-mode=(string)progressive, colorimetry=(string)bt601 /GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:sink: caps = video/x-raw, format=(string)NV12, width=(int)1920, height=(int)1080, framerate=(fraction)1/1, interlace-mode=(string)progressive, colorimetry=(string)bt601 ERROR: from element /GstPipeline:pipeline0/v4l2h264enc:v4l2h264enc0: Failed to process frame. Additional debug info: ../gst-plugins-good-1.16.3/sys/v4l2/gstv4l2videoenc.c(810): gst_v4l2_video_enc_handle_frame (): /GstPipeline:pipeline0/v4l2h264enc:v4l2h264enc0: Maybe be due to not enough memory or failing driver Execution ended after 0:00:00.187052413 Setting pipeline to NULL ... Freeing pipeline ... 913.795456 s: VX_ZONE_WARNING:[vxReleaseContext:1055] Found a reference 0xffffb9e741a0 of type 0000080f at external count 1, internal count 0, releasing it 913.795482 s: VX_ZONE_WARNING:[vxReleaseContext:1057] Releasing reference (name=image_113) now as a part of garbage collection 913.795495 s: VX_ZONE_WARNING:[vxReleaseContext:1055] Found a reference 0xffffb9ee1710 of type 00000813 at external count 1, internal count 0, releasing it 913.795506 s: VX_ZONE_WARNING:[vxReleaseContext:1057] Releasing reference (name=object_array_115) now as a part of garbage collection 913.796000 s: VX_ZONE_WARNING:[vxReleaseContext:1055] Found a reference 0xffffb9ee18b0 of type 00000813 at external count 1, internal count 0, releasing it 913.796011 s: VX_ZONE_WARNING:[vxReleaseContext:1057] Releasing reference (name=object_array_117) now as a part of garbage collection 913.796490 s: VX_ZONE_INIT:[tivxHostDeInitLocal:107] De-Initialization Done for HOST !!! 913.800848 s: VX_ZONE_INIT:[tivxDeInitLocal:193] De-Initialization Done !!! APP: Deinit ... !!! REMOTE_SERVICE: Deinit ... !!! REMOTE_SERVICE: Deinit ... Done !!! IPC: Deinit ... !!! IPC: DeInit ... Done !!! MEM: Deinit ... !!! DDR_SHARED_MEM: Alloc's: 23 alloc's of 15976187 bytes DDR_SHARED_MEM: Free's : 23 free's of 15976187 bytes DDR_SHARED_MEM: Open's : 0 allocs of 0 bytes DDR_SHARED_MEM: Total size: 536870912 bytes MEM: Deinit ... Done !!! APP: Deinit ... Done !!!
What can the source of problem ? I am using the latest processor sdk image
