J721S2XSOMXEVM: strange boot problems for custom board with 4G ram
Part Number: J721S2XSOMXEVM
Hi there,
Recently we encountered a strange boot problem. We are using the XJ721S2GALZ chip in a customer board which is the same as the j721s2-som-evm. In this board we use a single MT53E1G32D2FW-046-AUT-A ddr chip and only one ddr controller on J721S2. The total physical memory is 4G bytes.
We have made corresponding modifications in 'board/ti/j721s2/evm.c' and 'arch/arm/dts/k3-j721s2-som-p0.dtsi' in the uboot source to set the memory to be 4G byte. And we can successfully boot the board in u-boot and can see the ram is 4G byte.
However, when the linux kernel is booting, it will always stuck in random places if we use a cutomized defconfig file (defconfig-custom-board.txt in attachment) to configurate the kernel, which is very similar to j721s2 sdk's default tisdk_j721s2-evm_defconfig. The kernel will also stuck if we directly use tisdk_j721s2-evm_defconfig (tisdk_j721s2-evm_defconfig.txt in attachment).
For the linux kernel, If we config the kernel using the default defconfig (defconfig.txt in attachment) located in linux-ti-staging/5.10.120+gitAUTOINC+95b90aa828-r0b.arago5_psdkla_63/git/arch/arm64/configs/defconfig, then compile the kernel and boot the board, the kernel will encounter a bunch of 'BUG: Bad page state in process swapper' errors but can finally boot successfully, although many of the kernel components are missing since this defconfig is a very short one. And linux can recognize the memory size as 4G bytes. We also attach the boot log in the attachment: bootlog.txt.
If we set the memory to 2G byte in uboot (modify evm.c and k3-j721s2-som-p0.dtsi), which only occupies the first ddr space 0x80000000-0xffffffff, all the kernels mentioned above will boot normally.
We guess this is related to the above 2G memory usage.  defconfig.txt  is far shorter than tisdk_j721s2-evm_defconfig but can successfully boot with errors. Which options in the defconfig file leads to the observations above? Or did we just miss something in configurating the uboot and kernel to make the 4G memory work? What should we do to boot the board with 4G memory and the normal defconfig file?
Thanks!
CONFIG_SYSVIPC=y
CONFIG_POSIX_MQUEUE=y
CONFIG_AUDIT=y
CONFIG_NO_HZ_IDLE=y
CONFIG_HIGH_RES_TIMERS=y
CONFIG_PREEMPT=y
CONFIG_IRQ_TIME_ACCOUNTING=y
CONFIG_BSD_PROCESS_ACCT=y
CONFIG_BSD_PROCESS_ACCT_V3=y
CONFIG_TASK_XACCT=y
CONFIG_TASK_IO_ACCOUNTING=y
CONFIG_IKCONFIG=y
CONFIG_IKCONFIG_PROC=y
CONFIG_NUMA_BALANCING=y
CONFIG_MEMCG=y
CONFIG_MEMCG_SWAP=y
CONFIG_BLK_CGROUP=y
CONFIG_CGROUP_PIDS=y
CONFIG_CGROUP_HUGETLB=y
CONFIG_CPUSETS=y
CONFIG_CGROUP_DEVICE=y
CONFIG_CGROUP_CPUACCT=y
CONFIG_CGROUP_PERF=y
CONFIG_USER_NS=y
CONFIG_SCHED_AUTOGROUP=y
CONFIG_BLK_DEV_INITRD=y
CONFIG_KALLSYMS_ALL=y
# CONFIG_COMPAT_BRK is not set
CONFIG_PROFILING=y
CONFIG_ARCH_ACTIONS=y
CONFIG_ARCH_AGILEX=y
CONFIG_ARCH_SUNXI=y
CONFIG_ARCH_ALPINE=y
CONFIG_ARCH_BCM2835=y
CONFIG_ARCH_BCM_IPROC=y
CONFIG_ARCH_BERLIN=y
CONFIG_ARCH_BRCMSTB=y
CONFIG_ARCH_EXYNOS=y
CONFIG_ARCH_K3=y
CONFIG_ARCH_LAYERSCAPE=y
CONFIG_ARCH_LG1K=y
CONFIG_ARCH_HISI=y
CONFIG_ARCH_MEDIATEK=y
CONFIG_ARCH_MESON=y
CONFIG_ARCH_MVEBU=y
CONFIG_ARCH_MXC=y
CONFIG_ARCH_QCOM=y
CONFIG_ARCH_RENESAS=y
CONFIG_ARCH_ROCKCHIP=y
CONFIG_ARCH_S32=y
CONFIG_ARCH_SEATTLE=y
CONFIG_ARCH_STRATIX10=y
CONFIG_ARCH_SYNQUACER=y
CONFIG_ARCH_TEGRA=y
CONFIG_ARCH_SPRD=y
CONFIG_ARCH_THUNDER=y
CONFIG_ARCH_THUNDER2=y
CONFIG_ARCH_UNIPHIER=y
CONFIG_ARCH_VEXPRESS=y
CONFIG_ARCH_VISCONTI=y
CONFIG_ARCH_XGENE=y
CONFIG_ARCH_ZX=y
CONFIG_ARCH_ZYNQMP=y
CONFIG_ARM64_VA_BITS_48=y
CONFIG_SCHED_MC=y
CONFIG_SCHED_SMT=y
CONFIG_NUMA=y
CONFIG_SECCOMP=y
CONFIG_KEXEC=y
CONFIG_KEXEC_FILE=y
CONFIG_CRASH_DUMP=y
CONFIG_XEN=y
CONFIG_COMPAT=y
CONFIG_RANDOMIZE_BASE=y
CONFIG_HIBERNATION=y
CONFIG_WQ_POWER_EFFICIENT_DEFAULT=y
CONFIG_ENERGY_MODEL=y
CONFIG_ARM_CPUIDLE=y
CONFIG_ARM_PSCI_CPUIDLE=y
CONFIG_CPU_FREQ=y
CONFIG_CPU_FREQ_STAT=y
CONFIG_CPU_FREQ_GOV_POWERSAVE=m
CONFIG_CPU_FREQ_GOV_USERSPACE=y
CONFIG_CPU_FREQ_GOV_ONDEMAND=y
CONFIG_CPU_FREQ_GOV_CONSERVATIVE=m
CONFIG_CPU_FREQ_GOV_SCHEDUTIL=y
CONFIG_CPUFREQ_DT=y
CONFIG_ACPI_CPPC_CPUFREQ=m
CONFIG_ARM_ALLWINNER_SUN50I_CPUFREQ_NVMEM=m
CONFIG_ARM_ARMADA_37XX_CPUFREQ=y
CONFIG_ARM_SCPI_CPUFREQ=y
CONFIG_ARM_IMX_CPUFREQ_DT=m
CONFIG_ARM_QCOM_CPUFREQ_NVMEM=y
CONFIG_ARM_QCOM_CPUFREQ_HW=y
CONFIG_ARM_RASPBERRYPI_CPUFREQ=m
CONFIG_ARM_TEGRA186_CPUFREQ=y
CONFIG_QORIQ_CPUFREQ=y
CONFIG_ARM_SCPI_PROTOCOL=y
CONFIG_RASPBERRYPI_FIRMWARE=y
CONFIG_INTEL_STRATIX10_SERVICE=y
CONFIG_INTEL_STRATIX10_RSU=m
CONFIG_EFI_CAPSULE_LOADER=y
CONFIG_IMX_SCU=y
CONFIG_IMX_SCU_PD=y
CONFIG_ACPI=y
CONFIG_ACPI_APEI=y
CONFIG_ACPI_APEI_GHES=y
CONFIG_ACPI_APEI_PCIEAER=y
CONFIG_ACPI_APEI_MEMORY_FAILURE=y
CONFIG_ACPI_APEI_EINJ=y
CONFIG_VIRTUALIZATION=y
CONFIG_KVM=y
CONFIG_ARM64_CRYPTO=y
CONFIG_CRYPTO_SHA1_ARM64_CE=y
CONFIG_CRYPTO_SHA2_ARM64_CE=y
CONFIG_CRYPTO_SHA512_ARM64_CE=m
CONFIG_CRYPTO_SHA3_ARM64=m
CONFIG_CRYPTO_SM3_ARM64_CE=m
CONFIG_CRYPTO_GHASH_ARM64_CE=y
CONFIG_CRYPTO_CRCT10DIF_ARM64_CE=m
CONFIG_CRYPTO_AES_ARM64_CE_CCM=y
CONFIG_CRYPTO_AES_ARM64_CE_BLK=y
CONFIG_CRYPTO_CHACHA20_NEON=m
CONFIG_CRYPTO_AES_ARM64_BS=m
CONFIG_JUMP_LABEL=y
CONFIG_MODULES=y
CONFIG_MODULE_UNLOAD=y
# CONFIG_CORE_DUMP_DEFAULT_ELF_HEADERS is not set
CONFIG_KSM=y
CONFIG_MEMORY_FAILURE=y
CONFIG_TRANSPARENT_HUGEPAGE=y
CONFIG_NET=y
CONFIG_PACKET=y
CONFIG_UNIX=y
CONFIG_INET=y
CONFIG_IP_MULTICAST=y
CONFIG_IP_PNP=y
CONFIG_IP_PNP_DHCP=y
CONFIG_IP_PNP_BOOTP=y
CONFIG_IPV6=m
CONFIG_NETFILTER=y
CONFIG_NF_CONNTRACK=m
CONFIG_NF_CONNTRACK_EVENTS=y
CONFIG_NETFILTER_XT_TARGET_CHECKSUM=m
CONFIG_NETFILTER_XT_TARGET_LOG=m
CONFIG_NETFILTER_XT_MATCH_ADDRTYPE=m
CONFIG_NETFILTER_XT_MATCH_CONNTRACK=m
CONFIG_IP_NF_IPTABLES=m
CONFIG_IP_NF_FILTER=m
CONFIG_IP_NF_TARGET_REJECT=m
CONFIG_IP_NF_NAT=m
CONFIG_IP_NF_TARGET_MASQUERADE=m
CONFIG_IP_NF_MANGLE=m
CONFIG_IP6_NF_IPTABLES=m
CONFIG_IP6_NF_FILTER=m
CONFIG_IP6_NF_TARGET_REJECT=m
CONFIG_IP6_NF_MANGLE=m
CONFIG_IP6_NF_NAT=m
CONFIG_IP6_NF_TARGET_MASQUERADE=m
CONFIG_BRIDGE=m
CONFIG_BRIDGE_VLAN_FILTERING=y
CONFIG_NET_DSA=m
CONFIG_VLAN_8021Q=m
CONFIG_VLAN_8021Q_GVRP=y
CONFIG_VLAN_8021Q_MVRP=y
CONFIG_NET_SCHED=y
CONFIG_NET_SCH_CBS=m
CONFIG_NET_SCH_ETF=m
CONFIG_NET_SCH_TAPRIO=m
CONFIG_NET_SCH_MQPRIO=m
CONFIG_NET_SCH_INGRESS=m
CONFIG_NET_CLS_BASIC=m
CONFIG_NET_CLS_FLOWER=m
CONFIG_NET_CLS_ACT=y
CONFIG_NET_ACT_GACT=m
CONFIG_NET_ACT_MIRRED=m
CONFIG_NET_ACT_GATE=m
CONFIG_QRTR=m
CONFIG_QRTR_SMD=m
CONFIG_QRTR_TUN=m
CONFIG_BPF_JIT=y
CONFIG_CAN=m
CONFIG_CAN_RCAR=m
CONFIG_CAN_RCAR_CANFD=m
CONFIG_CAN_FLEXCAN=m
CONFIG_BT=m
CONFIG_BT_HIDP=m
# CONFIG_BT_HS is not set
# CONFIG_BT_LE is not set
CONFIG_BT_LEDS=y
# CONFIG_BT_DEBUGFS is not set
CONFIG_BT_HCIBTUSB=m
CONFIG_BT_HCIUART=m
CONFIG_BT_HCIUART_LL=y
CONFIG_BT_HCIUART_BCM=y
CONFIG_BT_HCIUART_QCA=y
CONFIG_CFG80211=m
CONFIG_MAC80211=m
CONFIG_MAC80211_LEDS=y
CONFIG_RFKILL=m
CONFIG_NET_9P=y
CONFIG_NET_9P_VIRTIO=y
CONFIG_NFC=m
CONFIG_NFC_NCI=m
CONFIG_NFC_S3FWRN5_I2C=m
CONFIG_PCI=y
CONFIG_PCIEPORTBUS=y
CONFIG_PCI_IOV=y
CONFIG_PCI_PASID=y
CONFIG_HOTPLUG_PCI=y
CONFIG_HOTPLUG_PCI_ACPI=y
CONFIG_PCI_AARDVARK=y
CONFIG_PCI_TEGRA=y
CONFIG_PCIE_RCAR_HOST=y
CONFIG_PCIE_RCAR_EP=y
CONFIG_PCI_HOST_GENERIC=y
CONFIG_PCI_XGENE=y
CONFIG_PCIE_ALTERA=y
CONFIG_PCIE_ALTERA_MSI=y
CONFIG_PCI_HOST_THUNDER_PEM=y
CONFIG_PCI_HOST_THUNDER_ECAM=y
CONFIG_PCIE_ROCKCHIP_HOST=m
CONFIG_PCIE_BRCMSTB=m
CONFIG_PCI_LAYERSCAPE=y
CONFIG_PCIE_LAYERSCAPE_GEN4=y
CONFIG_PCI_HISI=y
CONFIG_PCIE_QCOM=y
CONFIG_PCIE_ARMADA_8K=y
CONFIG_PCIE_KIRIN=y
CONFIG_PCIE_HISI_STB=y
CONFIG_PCIE_TEGRA194_HOST=m
CONFIG_PCI_ENDPOINT=y
CONFIG_PCI_ENDPOINT_CONFIGFS=y
CONFIG_PCI_EPF_TEST=m
CONFIG_DEVTMPFS=y
CONFIG_DEVTMPFS_MOUNT=y
CONFIG_FW_LOADER_USER_HELPER=y
CONFIG_FW_LOADER_USER_HELPER_FALLBACK=y
CONFIG_HISILICON_LPC=y
CONFIG_SIMPLE_PM_BUS=y
CONFIG_FSL_MC_BUS=y
CONFIG_TEGRA_ACONNECT=m
CONFIG_MTD=y
CONFIG_MTD_BLOCK=y
CONFIG_MTD_CFI=y
CONFIG_MTD_CFI_ADV_OPTIONS=y
CONFIG_MTD_CFI_INTELEXT=y
CONFIG_MTD_CFI_AMDSTD=y
CONFIG_MTD_CFI_STAA=y
CONFIG_MTD_PHYSMAP=y
CONFIG_MTD_PHYSMAP_OF=y
CONFIG_MTD_DATAFLASH=y
CONFIG_MTD_SST25L=y
CONFIG_MTD_RAW_NAND=y
CONFIG_MTD_NAND_DENALI_DT=y
CONFIG_MTD_NAND_MARVELL=y
CONFIG_MTD_NAND_FSL_IFC=y
CONFIG_MTD_NAND_QCOM=y
CONFIG_MTD_SPI_NOR=y
CONFIG_SPI_CADENCE_QUADSPI=y
CONFIG_BLK_DEV_LOOP=y
CONFIG_BLK_DEV_NBD=m
CONFIG_VIRTIO_BLK=y
CONFIG_BLK_DEV_NVME=m
CONFIG_SRAM=y
CONFIG_PCI_ENDPOINT_TEST=m
CONFIG_EEPROM_AT24=m
CONFIG_EEPROM_AT25=m
CONFIG_UACCE=m
# CONFIG_SCSI_PROC_FS is not set
CONFIG_BLK_DEV_SD=y
CONFIG_SCSI_SAS_ATA=y
CONFIG_SCSI_HISI_SAS=y
CONFIG_SCSI_HISI_SAS_PCI=y
CONFIG_MEGARAID_SAS=y
CONFIG_SCSI_MPT3SAS=m
CONFIG_SCSI_UFSHCD=y
CONFIG_SCSI_UFSHCD_PLATFORM=y
CONFIG_SCSI_UFS_QCOM=m
CONFIG_SCSI_UFS_HISI=y
CONFIG_ATA=y
CONFIG_SATA_AHCI=y
CONFIG_SATA_AHCI_PLATFORM=y
CONFIG_AHCI_CEVA=y
CONFIG_AHCI_MVEBU=y
CONFIG_AHCI_XGENE=y
CONFIG_AHCI_QORIQ=y
CONFIG_SATA_SIL24=y
CONFIG_SATA_RCAR=y
CONFIG_PATA_PLATFORM=y
CONFIG_PATA_OF_PLATFORM=y
CONFIG_MD=y
CONFIG_BLK_DEV_MD=m
CONFIG_BLK_DEV_DM=m
CONFIG_DM_MIRROR=m
CONFIG_DM_ZERO=m
CONFIG_NETDEVICES=y
CONFIG_MACVLAN=m
CONFIG_MACVTAP=m
CONFIG_TUN=y
CONFIG_VETH=m
CONFIG_VIRTIO_NET=y
CONFIG_NET_DSA_MSCC_FELIX=m
CONFIG_AMD_XGBE=y
CONFIG_NET_XGENE=y
CONFIG_ATL1C=m
CONFIG_BCMGENET=m
CONFIG_BNX2X=m
CONFIG_MACB=y
CONFIG_THUNDER_NIC_PF=y
CONFIG_FEC=y
CONFIG_FSL_FMAN=y
CONFIG_FSL_DPAA_ETH=y
CONFIG_FSL_DPAA2_ETH=y
CONFIG_FSL_ENETC=y
CONFIG_FSL_ENETC_VF=y
CONFIG_FSL_ENETC_QOS=y
CONFIG_HIX5HD2_GMAC=y
CONFIG_HNS_DSAF=y
CONFIG_HNS_ENET=y
CONFIG_HNS3=y
CONFIG_HNS3_HCLGE=y
CONFIG_HNS3_ENET=y
CONFIG_E1000=y
CONFIG_E1000E=y
CONFIG_IGB=y
CONFIG_IGBVF=y
CONFIG_MVNETA=y
CONFIG_MVPP2=y
CONFIG_SKY2=y
CONFIG_MLX4_EN=m
CONFIG_MLX5_CORE=m
CONFIG_MLX5_CORE_EN=y
CONFIG_QCOM_EMAC=m
CONFIG_RMNET=m
CONFIG_SH_ETH=y
CONFIG_RAVB=y
CONFIG_SMC91X=y
CONFIG_SMSC911X=y
CONFIG_SNI_AVE=y
CONFIG_SNI_NETSEC=y
CONFIG_STMMAC_ETH=m
CONFIG_TI_K3_AM65_CPSW_NUSS=y
CONFIG_QCOM_IPA=m
CONFIG_MDIO_BUS_MUX_MMIOREG=y
CONFIG_MDIO_BUS_MUX_MULTIPLEXER=y
CONFIG_AQUANTIA_PHY=y
CONFIG_MARVELL_PHY=m
CONFIG_MARVELL_10G_PHY=m
CONFIG_MESON_GXL_PHY=m
CONFIG_MICREL_PHY=y
CONFIG_MICROSEMI_PHY=y
CONFIG_AT803X_PHY=y
CONFIG_REALTEK_PHY=m
CONFIG_ROCKCHIP_PHY=y
CONFIG_VITESSE_PHY=y
CONFIG_USB_PEGASUS=m
CONFIG_USB_RTL8150=m
CONFIG_USB_RTL8152=m
CONFIG_USB_LAN78XX=m
CONFIG_USB_USBNET=m
CONFIG_USB_NET_DM9601=m
CONFIG_USB_NET_SR9800=m
CONFIG_USB_NET_SMSC75XX=m
CONFIG_USB_NET_SMSC95XX=m
CONFIG_USB_NET_PLUSB=m
CONFIG_USB_NET_MCS7830=m
CONFIG_ATH10K=m
CONFIG_ATH10K_PCI=m
CONFIG_ATH10K_SNOC=m
CONFIG_BRCMFMAC=m
CONFIG_MWIFIEX=m
CONFIG_MWIFIEX_PCIE=m
CONFIG_WL18XX=m
CONFIG_WLCORE_SDIO=m
CONFIG_INPUT_EVDEV=y
CONFIG_KEYBOARD_ADC=m
CONFIG_KEYBOARD_GPIO=y
CONFIG_KEYBOARD_SNVS_PWRKEY=m
CONFIG_KEYBOARD_IMX_SC_KEY=m
CONFIG_KEYBOARD_CROS_EC=y
CONFIG_INPUT_TOUCHSCREEN=y
CONFIG_TOUCHSCREEN_ATMEL_MXT=m
CONFIG_INPUT_MISC=y
CONFIG_INPUT_PM8941_PWRKEY=y
CONFIG_INPUT_PM8XXX_VIBRATOR=m
CONFIG_INPUT_HISI_POWERKEY=y
# CONFIG_SERIO_SERPORT is not set
CONFIG_SERIO_AMBAKMI=y
CONFIG_LEGACY_PTY_COUNT=16
CONFIG_SERIAL_8250=y
CONFIG_SERIAL_8250_CONSOLE=y
CONFIG_SERIAL_8250_EXTENDED=y
CONFIG_SERIAL_8250_SHARE_IRQ=y
CONFIG_SERIAL_8250_BCM2835AUX=y
CONFIG_SERIAL_8250_DW=y
CONFIG_SERIAL_8250_OMAP=y
CONFIG_SERIAL_8250_MT6577=y
CONFIG_SERIAL_8250_UNIPHIER=y
CONFIG_SERIAL_OF_PLATFORM=y
CONFIG_SERIAL_AMBA_PL011=y
CONFIG_SERIAL_AMBA_PL011_CONSOLE=y
CONFIG_SERIAL_MESON=y
CONFIG_SERIAL_MESON_CONSOLE=y
CONFIG_SERIAL_SAMSUNG=y
CONFIG_SERIAL_SAMSUNG_CONSOLE=y
CONFIG_SERIAL_TEGRA=y
CONFIG_SERIAL_TEGRA_TCU=y
CONFIG_SERIAL_IMX=y
CONFIG_SERIAL_IMX_CONSOLE=y
CONFIG_SERIAL_SH_SCI=y
CONFIG_SERIAL_MSM=y
CONFIG_SERIAL_MSM_CONSOLE=y
CONFIG_SERIAL_QCOM_GENI=y
CONFIG_SERIAL_QCOM_GENI_CONSOLE=y
CONFIG_SERIAL_XILINX_PS_UART=y
CONFIG_SERIAL_XILINX_PS_UART_CONSOLE=y
CONFIG_SERIAL_FSL_LPUART=y
CONFIG_SERIAL_FSL_LPUART_CONSOLE=y
CONFIG_SERIAL_FSL_LINFLEXUART=y
CONFIG_SERIAL_FSL_LINFLEXUART_CONSOLE=y
CONFIG_SERIAL_MVEBU_UART=y
CONFIG_SERIAL_OWL=y
CONFIG_SERIAL_DEV_BUS=y
CONFIG_VIRTIO_CONSOLE=y
CONFIG_IPMI_HANDLER=m
CONFIG_IPMI_DEVICE_INTERFACE=m
CONFIG_IPMI_SI=m
CONFIG_TCG_TPM=y
CONFIG_TCG_TIS_I2C_INFINEON=y
CONFIG_I2C_CHARDEV=y
CONFIG_I2C_MUX=y
CONFIG_I2C_MUX_PCA954x=y
CONFIG_I2C_BCM2835=m
CONFIG_I2C_DESIGNWARE_PLATFORM=y
CONFIG_I2C_GPIO=m
CONFIG_I2C_IMX=y
CONFIG_I2C_IMX_LPI2C=y
CONFIG_I2C_MESON=y
CONFIG_I2C_MV64XXX=y
CONFIG_I2C_OMAP=y
CONFIG_I2C_OWL=y
CONFIG_I2C_PXA=y
CONFIG_I2C_QCOM_CCI=m
CONFIG_I2C_QCOM_GENI=m
CONFIG_I2C_QUP=y
CONFIG_I2C_RK3X=y
CONFIG_I2C_SH_MOBILE=y
CONFIG_I2C_TEGRA=y
CONFIG_I2C_UNIPHIER_F=y
CONFIG_I2C_RCAR=y
CONFIG_I2C_CROS_EC_TUNNEL=y
CONFIG_SPI=y
CONFIG_SPI_ARMADA_3700=y
CONFIG_SPI_BCM2835=m
CONFIG_SPI_BCM2835AUX=m
CONFIG_SPI_FSL_LPSPI=y
CONFIG_SPI_FSL_QUADSPI=y
CONFIG_SPI_NXP_FLEXSPI=y
CONFIG_SPI_IMX=m
CONFIG_SPI_FSL_DSPI=y
CONFIG_SPI_MESON_SPICC=m
CONFIG_SPI_MESON_SPIFC=m
CONFIG_SPI_ORION=y
CONFIG_SPI_PL022=y
CONFIG_SPI_ROCKCHIP=y
CONFIG_SPI_RPCIF=m
CONFIG_SPI_QCOM_QSPI=m
CONFIG_SPI_QUP=y
CONFIG_SPI_QCOM_GENI=m
CONFIG_SPI_S3C64XX=y
CONFIG_SPI_SH_MSIOF=m
CONFIG_SPI_SUN6I=y
CONFIG_SPI_SPIDEV=m
CONFIG_SPMI=y
CONFIG_PINCTRL_SINGLE=y
CONFIG_PINCTRL_MAX77620=y
CONFIG_PINCTRL_OWL=y
CONFIG_PINCTRL_S700=y
CONFIG_PINCTRL_S900=y
CONFIG_PINCTRL_IMX8MM=y
CONFIG_PINCTRL_IMX8MN=y
CONFIG_PINCTRL_IMX8MP=y
CONFIG_PINCTRL_IMX8MQ=y
CONFIG_PINCTRL_IMX8QXP=y
CONFIG_PINCTRL_IMX8DXL=y
CONFIG_PINCTRL_IPQ8074=y
CONFIG_PINCTRL_IPQ6018=y
CONFIG_PINCTRL_MSM8916=y
CONFIG_PINCTRL_MSM8994=y
CONFIG_PINCTRL_MSM8996=y
CONFIG_PINCTRL_MSM8998=y
CONFIG_PINCTRL_QCS404=y
CONFIG_PINCTRL_QDF2XXX=y
CONFIG_PINCTRL_QCOM_SPMI_PMIC=y
CONFIG_PINCTRL_SC7180=y
CONFIG_PINCTRL_SDM845=y
CONFIG_PINCTRL_SM8150=y
CONFIG_PINCTRL_SM8250=y
CONFIG_GPIO_ALTERA=m
CONFIG_GPIO_DAVINCI=y
CONFIG_GPIO_DWAPB=y
CONFIG_GPIO_MB86S7X=y
CONFIG_GPIO_MPC8XXX=y
CONFIG_GPIO_MXC=y
CONFIG_GPIO_PL061=y
CONFIG_GPIO_RCAR=y
CONFIG_GPIO_UNIPHIER=y
CONFIG_GPIO_WCD934X=m
CONFIG_GPIO_XGENE=y
CONFIG_GPIO_XGENE_SB=y
CONFIG_GPIO_MAX732X=y
CONFIG_GPIO_PCA953X=y
CONFIG_GPIO_PCA953X_IRQ=y
CONFIG_GPIO_BD9571MWV=m
CONFIG_GPIO_MAX77620=y
CONFIG_GPIO_SL28CPLD=m
CONFIG_POWER_AVS=y
CONFIG_QCOM_CPR=y
CONFIG_ROCKCHIP_IODOMAIN=y
CONFIG_POWER_RESET_MSM=y
CONFIG_POWER_RESET_XGENE=y
CONFIG_POWER_RESET_SYSCON=y
CONFIG_SYSCON_REBOOT_MODE=y
CONFIG_BATTERY_SBS=m
CONFIG_BATTERY_BQ27XXX=y
CONFIG_SENSORS_ARM_SCPI=y
CONFIG_SENSORS_LM90=m
CONFIG_SENSORS_PWM_FAN=m
CONFIG_SENSORS_RASPBERRYPI_HWMON=m
CONFIG_SENSORS_SL28CPLD=m
CONFIG_SENSORS_INA2XX=m
CONFIG_SENSORS_INA3221=m
CONFIG_THERMAL_GOV_POWER_ALLOCATOR=y
CONFIG_CPU_THERMAL=y
CONFIG_THERMAL_EMULATION=y
CONFIG_QORIQ_THERMAL=m
CONFIG_SUN8I_THERMAL=y
CONFIG_IMX_SC_THERMAL=m
CONFIG_IMX8MM_THERMAL=m
CONFIG_ROCKCHIP_THERMAL=m
CONFIG_RCAR_THERMAL=y
CONFIG_RCAR_GEN3_THERMAL=y
CONFIG_ARMADA_THERMAL=y
CONFIG_BCM2711_THERMAL=m
CONFIG_BCM2835_THERMAL=m
CONFIG_BRCMSTB_THERMAL=m
CONFIG_EXYNOS_THERMAL=y
CONFIG_TEGRA_BPMP_THERMAL=m
CONFIG_QCOM_TSENS=y
CONFIG_QCOM_SPMI_TEMP_ALARM=m
CONFIG_UNIPHIER_THERMAL=y
CONFIG_WATCHDOG=y
CONFIG_SL28CPLD_WATCHDOG=m
CONFIG_ARM_SP805_WATCHDOG=y
CONFIG_ARM_SBSA_WATCHDOG=y
CONFIG_ARM_SMC_WATCHDOG=y
CONFIG_S3C2410_WATCHDOG=y
CONFIG_DW_WATCHDOG=y
CONFIG_SUNXI_WATCHDOG=m
CONFIG_IMX2_WDT=y
CONFIG_IMX_SC_WDT=m
CONFIG_QCOM_WDT=m
CONFIG_MESON_GXBB_WATCHDOG=m
CONFIG_MESON_WATCHDOG=m
CONFIG_RENESAS_WDT=y
CONFIG_UNIPHIER_WATCHDOG=y
CONFIG_BCM2835_WDT=y
CONFIG_MFD_ALTERA_SYSMGR=y
CONFIG_MFD_BD9571MWV=y
CONFIG_MFD_AXP20X_I2C=y
CONFIG_MFD_AXP20X_RSB=y
CONFIG_MFD_EXYNOS_LPASS=m
CONFIG_MFD_HI6421_PMIC=y
CONFIG_MFD_HI655X_PMIC=y
CONFIG_MFD_MAX77620=y
CONFIG_MFD_SPMI_PMIC=y
CONFIG_MFD_RK808=y
CONFIG_MFD_SEC_CORE=y
CONFIG_MFD_SL28CPLD=y
CONFIG_MFD_ROHM_BD718XX=y
CONFIG_MFD_WCD934X=m
CONFIG_REGULATOR_FIXED_VOLTAGE=y
CONFIG_REGULATOR_AXP20X=y
CONFIG_REGULATOR_BD718XX=y
CONFIG_REGULATOR_BD9571MWV=y
CONFIG_REGULATOR_FAN53555=y
CONFIG_REGULATOR_GPIO=y
CONFIG_REGULATOR_HI6421V530=y
CONFIG_REGULATOR_HI655X=y
CONFIG_REGULATOR_MAX77620=y
CONFIG_REGULATOR_MAX8973=y
CONFIG_REGULATOR_PCA9450=y
CONFIG_REGULATOR_PFUZE100=y
CONFIG_REGULATOR_PWM=y
CONFIG_REGULATOR_QCOM_RPMH=y
CONFIG_REGULATOR_QCOM_SMD_RPM=y
CONFIG_REGULATOR_QCOM_SPMI=y
CONFIG_REGULATOR_RK808=y
CONFIG_REGULATOR_S2MPS11=y
CONFIG_REGULATOR_VCTRL=m
CONFIG_RC_CORE=m
CONFIG_RC_DECODERS=y
CONFIG_RC_DEVICES=y
CONFIG_IR_MESON=m
CONFIG_IR_SUNXI=m
CONFIG_MEDIA_SUPPORT=m
CONFIG_MEDIA_CAMERA_SUPPORT=y
CONFIG_MEDIA_ANALOG_TV_SUPPORT=y
CONFIG_MEDIA_DIGITAL_TV_SUPPORT=y
CONFIG_MEDIA_SDR_SUPPORT=y
CONFIG_MEDIA_CONTROLLER=y
CONFIG_VIDEO_V4L2_SUBDEV_API=y
CONFIG_MEDIA_PLATFORM_SUPPORT=y
# CONFIG_DVB_NET is not set
CONFIG_MEDIA_USB_SUPPORT=y
CONFIG_USB_VIDEO_CLASS=m
CONFIG_V4L_PLATFORM_DRIVERS=y
CONFIG_VIDEO_RCAR_CSI2=m
CONFIG_VIDEO_RCAR_VIN=m
CONFIG_VIDEO_SUN6I_CSI=m
CONFIG_V4L_MEM2MEM_DRIVERS=y
CONFIG_VIDEO_SAMSUNG_S5P_JPEG=m
CONFIG_VIDEO_SAMSUNG_S5P_MFC=m
CONFIG_VIDEO_SAMSUNG_EXYNOS_GSC=m
CONFIG_VIDEO_RENESAS_FDP1=m
CONFIG_VIDEO_RENESAS_FCP=m
CONFIG_VIDEO_RENESAS_VSP1=m
CONFIG_SDR_PLATFORM_DRIVERS=y
CONFIG_VIDEO_RCAR_DRIF=m
CONFIG_VIDEO_IMX219=m
CONFIG_VIDEO_OV5645=m
CONFIG_VIDEO_QCOM_CAMSS=m
CONFIG_DRM=m
CONFIG_DRM_I2C_NXP_TDA998X=m
CONFIG_DRM_MALI_DISPLAY=m
CONFIG_DRM_NOUVEAU=m
CONFIG_DRM_EXYNOS=m
CONFIG_DRM_EXYNOS5433_DECON=y
CONFIG_DRM_EXYNOS7_DECON=y
CONFIG_DRM_EXYNOS_DSI=y
# CONFIG_DRM_EXYNOS_DP is not set
CONFIG_DRM_EXYNOS_HDMI=y
CONFIG_DRM_EXYNOS_MIC=y
CONFIG_DRM_ROCKCHIP=m
CONFIG_ROCKCHIP_ANALOGIX_DP=y
CONFIG_ROCKCHIP_CDN_DP=y
CONFIG_ROCKCHIP_DW_HDMI=y
CONFIG_ROCKCHIP_DW_MIPI_DSI=y
CONFIG_ROCKCHIP_INNO_HDMI=y
CONFIG_DRM_RCAR_DU=m
CONFIG_DRM_RCAR_DW_HDMI=m
CONFIG_DRM_SUN4I=m
CONFIG_DRM_SUN6I_DSI=m
CONFIG_DRM_SUN8I_DW_HDMI=m
CONFIG_DRM_SUN8I_MIXER=m
CONFIG_DRM_MSM=m
CONFIG_DRM_TEGRA=m
CONFIG_DRM_PANEL_LVDS=m
CONFIG_DRM_PANEL_SIMPLE=m
CONFIG_DRM_PANEL_RAYDIUM_RM67191=m
CONFIG_DRM_PANEL_SITRONIX_ST7703=m
CONFIG_DRM_PANEL_TRULY_NT35597_WQXGA=m
CONFIG_DRM_DISPLAY_CONNECTOR=m
CONFIG_DRM_NWL_MIPI_DSI=m
CONFIG_DRM_LONTIUM_LT9611=m
CONFIG_DRM_SII902X=m
CONFIG_DRM_SIMPLE_BRIDGE=m
CONFIG_DRM_THINE_THC63LVD1024=m
CONFIG_DRM_TI_SN65DSI86=m
CONFIG_DRM_I2C_ADV7511=m
CONFIG_DRM_I2C_ADV7511_AUDIO=y
CONFIG_DRM_DW_HDMI_AHB_AUDIO=m
CONFIG_DRM_DW_HDMI_CEC=m
CONFIG_DRM_VC4=m
CONFIG_DRM_ETNAVIV=m
CONFIG_DRM_HISI_HIBMC=m
CONFIG_DRM_HISI_KIRIN=m
CONFIG_DRM_MXSFB=m
CONFIG_DRM_MESON=m
CONFIG_DRM_PL111=m
CONFIG_DRM_LIMA=m
CONFIG_DRM_PANFROST=m
CONFIG_FB=y
CONFIG_FB_MODE_HELPERS=y
CONFIG_FB_EFI=y
CONFIG_BACKLIGHT_GENERIC=m
CONFIG_BACKLIGHT_PWM=m
CONFIG_BACKLIGHT_LP855X=m
CONFIG_LOGO=y
# CONFIG_LOGO_LINUX_MONO is not set
# CONFIG_LOGO_LINUX_VGA16 is not set
CONFIG_SOUND=y
CONFIG_SND=y
CONFIG_SND_HDA_TEGRA=m
CONFIG_SND_HDA_CODEC_HDMI=m
CONFIG_SND_SOC=y
CONFIG_SND_BCM2835_SOC_I2S=m
CONFIG_SND_SOC_FSL_SAI=m
CONFIG_SND_MESON_AXG_SOUND_CARD=m
CONFIG_SND_MESON_GX_SOUND_CARD=m
CONFIG_SND_SOC_QCOM=m
CONFIG_SND_SOC_APQ8016_SBC=m
CONFIG_SND_SOC_MSM8996=m
CONFIG_SND_SOC_SDM845=m
CONFIG_SND_SOC_ROCKCHIP=m
CONFIG_SND_SOC_ROCKCHIP_SPDIF=m
CONFIG_SND_SOC_ROCKCHIP_RT5645=m
CONFIG_SND_SOC_RK3399_GRU_SOUND=m
CONFIG_SND_SOC_SAMSUNG=y
CONFIG_SND_SOC_RCAR=m
CONFIG_SND_SUN4I_SPDIF=m
CONFIG_SND_SOC_TEGRA=m
CONFIG_SND_SOC_TEGRA210_AHUB=m
CONFIG_SND_SOC_TEGRA210_DMIC=m
CONFIG_SND_SOC_TEGRA210_I2S=m
CONFIG_SND_SOC_TEGRA186_DSPK=m
CONFIG_SND_SOC_TEGRA210_ADMAIF=m
CONFIG_SND_SOC_AK4613=m
CONFIG_SND_SOC_ES7134=m
CONFIG_SND_SOC_ES7241=m
CONFIG_SND_SOC_PCM3168A_I2C=m
CONFIG_SND_SOC_SIMPLE_AMPLIFIER=m
CONFIG_SND_SOC_TAS571X=m
CONFIG_SND_SOC_WCD934X=m
CONFIG_SND_SOC_WM8904=m
CONFIG_SND_SOC_WSA881X=m
CONFIG_SND_SIMPLE_CARD=m
CONFIG_SND_AUDIO_GRAPH_CARD=m
CONFIG_I2C_HID=m
CONFIG_USB_CONN_GPIO=m
CONFIG_USB=y
CONFIG_USB_OTG=y
CONFIG_USB_XHCI_HCD=y
CONFIG_USB_XHCI_TEGRA=y
CONFIG_USB_EHCI_HCD=y
CONFIG_USB_EHCI_EXYNOS=y
CONFIG_USB_EHCI_HCD_PLATFORM=y
CONFIG_USB_OHCI_HCD=y
CONFIG_USB_OHCI_EXYNOS=y
CONFIG_USB_OHCI_HCD_PLATFORM=y
CONFIG_USB_RENESAS_USBHS_HCD=m
CONFIG_USB_RENESAS_USBHS=m
CONFIG_USB_ACM=m
CONFIG_USB_STORAGE=y
CONFIG_USB_MUSB_HDRC=y
CONFIG_USB_MUSB_SUNXI=y
CONFIG_USB_DWC3=y
CONFIG_USB_DWC2=y
CONFIG_USB_CHIPIDEA=y
CONFIG_USB_CHIPIDEA_UDC=y
CONFIG_USB_CHIPIDEA_HOST=y
CONFIG_USB_ISP1760=y
CONFIG_USB_SERIAL=m
CONFIG_USB_SERIAL_FTDI_SIO=m
CONFIG_USB_HSIC_USB3503=y
CONFIG_NOP_USB_XCEIV=y
CONFIG_USB_GADGET=y
CONFIG_USB_RENESAS_USBHS_UDC=m
CONFIG_USB_RENESAS_USB3=m
CONFIG_USB_TEGRA_XUDC=m
CONFIG_USB_CONFIGFS=m
CONFIG_USB_CONFIGFS_SERIAL=y
CONFIG_USB_CONFIGFS_ACM=y
CONFIG_USB_CONFIGFS_OBEX=y
CONFIG_USB_CONFIGFS_NCM=y
CONFIG_USB_CONFIGFS_ECM=y
CONFIG_USB_CONFIGFS_ECM_SUBSET=y
CONFIG_USB_CONFIGFS_RNDIS=y
CONFIG_USB_CONFIGFS_EEM=y
CONFIG_USB_CONFIGFS_MASS_STORAGE=y
CONFIG_USB_CONFIGFS_F_FS=y
CONFIG_TYPEC=m
CONFIG_TYPEC_TCPM=m
CONFIG_TYPEC_FUSB302=m
CONFIG_TYPEC_HD3SS3220=m
CONFIG_MMC=y
CONFIG_MMC_BLOCK_MINORS=32
CONFIG_MMC_ARMMMCI=y
CONFIG_MMC_SDHCI=y
CONFIG_MMC_SDHCI_ACPI=y
CONFIG_MMC_SDHCI_PLTFM=y
CONFIG_MMC_SDHCI_OF_ARASAN=y
CONFIG_MMC_SDHCI_OF_ESDHC=y
CONFIG_MMC_SDHCI_CADENCE=y
CONFIG_MMC_SDHCI_ESDHC_IMX=y
CONFIG_MMC_SDHCI_TEGRA=y
CONFIG_MMC_SDHCI_F_SDH30=y
CONFIG_MMC_MESON_GX=y
CONFIG_MMC_SDHCI_MSM=y
CONFIG_MMC_SPI=y
CONFIG_MMC_SDHI=y
CONFIG_MMC_UNIPHIER=y
CONFIG_MMC_DW=y
CONFIG_MMC_DW_EXYNOS=y
CONFIG_MMC_DW_HI3798CV200=y
CONFIG_MMC_DW_K3=y
CONFIG_MMC_DW_ROCKCHIP=y
CONFIG_MMC_SUNXI=y
CONFIG_MMC_BCM2835=y
CONFIG_MMC_SDHCI_XENON=y
CONFIG_MMC_SDHCI_AM654=y
CONFIG_MMC_OWL=y
CONFIG_NEW_LEDS=y
CONFIG_LEDS_CLASS=y
CONFIG_LEDS_GPIO=y
CONFIG_LEDS_PWM=y
CONFIG_LEDS_SYSCON=y
CONFIG_LEDS_TRIGGER_TIMER=y
CONFIG_LEDS_TRIGGER_DISK=y
CONFIG_LEDS_TRIGGER_HEARTBEAT=y
CONFIG_LEDS_TRIGGER_CPU=y
CONFIG_LEDS_TRIGGER_DEFAULT_ON=y
CONFIG_LEDS_TRIGGER_PANIC=y
CONFIG_EDAC=y
CONFIG_EDAC_GHES=y
CONFIG_RTC_CLASS=y
CONFIG_RTC_DRV_DS1307=m
CONFIG_RTC_DRV_MAX77686=y
CONFIG_RTC_DRV_RK808=m
CONFIG_RTC_DRV_PCF85363=m
CONFIG_RTC_DRV_RX8581=m
CONFIG_RTC_DRV_RV8803=m
CONFIG_RTC_DRV_S5M=y
CONFIG_RTC_DRV_DS3232=y
CONFIG_RTC_DRV_PCF2127=m
CONFIG_RTC_DRV_EFI=y
CONFIG_RTC_DRV_CROS_EC=y
CONFIG_RTC_DRV_S3C=y
CONFIG_RTC_DRV_PL031=y
CONFIG_RTC_DRV_SUN6I=y
CONFIG_RTC_DRV_ARMADA38X=y
CONFIG_RTC_DRV_PM8XXX=m
CONFIG_RTC_DRV_TEGRA=y
CONFIG_RTC_DRV_SNVS=m
CONFIG_RTC_DRV_IMX_SC=m
CONFIG_RTC_DRV_XGENE=y
CONFIG_DMADEVICES=y
CONFIG_DMA_BCM2835=y
CONFIG_DMA_SUN6I=m
CONFIG_FSL_EDMA=y
CONFIG_IMX_SDMA=m
CONFIG_K3_DMA=y
CONFIG_MV_XOR=y
CONFIG_MV_XOR_V2=y
CONFIG_OWL_DMA=y
CONFIG_PL330_DMA=y
CONFIG_TEGRA20_APB_DMA=y
CONFIG_TEGRA210_ADMA=m
CONFIG_QCOM_BAM_DMA=y
CONFIG_QCOM_HIDMA_MGMT=y
CONFIG_QCOM_HIDMA=y
CONFIG_RCAR_DMAC=y
CONFIG_RENESAS_USB_DMAC=m
CONFIG_TI_K3_UDMA=y
CONFIG_TI_K3_UDMA_GLUE_LAYER=y
CONFIG_VFIO=y
CONFIG_VFIO_PCI=y
CONFIG_VIRTIO_PCI=y
CONFIG_VIRTIO_BALLOON=y
CONFIG_VIRTIO_MMIO=y
CONFIG_XEN_GNTDEV=y
CONFIG_XEN_GRANT_DEV_ALLOC=y
CONFIG_MFD_CROS_EC_DEV=y
CONFIG_CHROME_PLATFORMS=y
CONFIG_CROS_EC=y
CONFIG_CROS_EC_I2C=y
CONFIG_CROS_EC_SPI=y
CONFIG_CROS_EC_CHARDEV=m
CONFIG_COMMON_CLK_RK808=y
CONFIG_COMMON_CLK_SCPI=y
CONFIG_COMMON_CLK_CS2000_CP=y
CONFIG_COMMON_CLK_FSL_SAI=y
CONFIG_COMMON_CLK_S2MPS11=y
CONFIG_COMMON_CLK_PWM=y
CONFIG_COMMON_CLK_VC5=y
CONFIG_COMMON_CLK_BD718XX=m
CONFIG_CLK_RASPBERRYPI=m
CONFIG_CLK_IMX8MM=y
CONFIG_CLK_IMX8MN=y
CONFIG_CLK_IMX8MP=y
CONFIG_CLK_IMX8MQ=y
CONFIG_CLK_IMX8QXP=y
CONFIG_TI_SCI_CLK=y
CONFIG_COMMON_CLK_QCOM=y
CONFIG_QCOM_A53PLL=y
CONFIG_QCOM_CLK_APCS_MSM8916=y
CONFIG_QCOM_CLK_SMD_RPM=y
CONFIG_QCOM_CLK_RPMH=y
CONFIG_IPQ_GCC_8074=y
CONFIG_IPQ_GCC_6018=y
CONFIG_MSM_GCC_8916=y
CONFIG_MSM_GCC_8994=y
CONFIG_MSM_MMCC_8996=y
CONFIG_MSM_GCC_8998=y
CONFIG_QCS_GCC_404=y
CONFIG_SC_GCC_7180=y
CONFIG_SDM_CAMCC_845=m
CONFIG_SDM_GCC_845=y
CONFIG_SDM_GPUCC_845=y
CONFIG_SDM_VIDEOCC_845=y
CONFIG_SDM_DISPCC_845=y
CONFIG_SM_GCC_8150=y
CONFIG_SM_GCC_8250=y
CONFIG_SM_GPUCC_8150=y
CONFIG_SM_GPUCC_8250=y
CONFIG_QCOM_HFPLL=y
CONFIG_HWSPINLOCK=y
CONFIG_HWSPINLOCK_QCOM=y
CONFIG_ARM_MHU=y
CONFIG_IMX_MBOX=y
CONFIG_PLATFORM_MHU=y
CONFIG_BCM2835_MBOX=y
CONFIG_QCOM_APCS_IPC=y
CONFIG_QCOM_IPCC=y
CONFIG_ROCKCHIP_IOMMU=y
CONFIG_TEGRA_IOMMU_SMMU=y
CONFIG_ARM_SMMU=y
CONFIG_ARM_SMMU_V3=y
CONFIG_QCOM_IOMMU=y
CONFIG_REMOTEPROC=y
CONFIG_QCOM_Q6V5_MSS=m
CONFIG_QCOM_Q6V5_PAS=m
CONFIG_QCOM_SYSMON=m
CONFIG_RPMSG_QCOM_GLINK_RPM=y
CONFIG_RPMSG_QCOM_GLINK_SMEM=m
CONFIG_RPMSG_QCOM_SMD=y
CONFIG_SOUNDWIRE=m
CONFIG_SOUNDWIRE_QCOM=m
CONFIG_OWL_PM_DOMAINS=y
CONFIG_RASPBERRYPI_POWER=y
CONFIG_FSL_DPAA=y
CONFIG_FSL_MC_DPIO=y
CONFIG_QCOM_AOSS_QMP=y
CONFIG_QCOM_GENI_SE=y
CONFIG_QCOM_RMTFS_MEM=m
CONFIG_QCOM_RPMH=y
CONFIG_QCOM_RPMHPD=y
CONFIG_QCOM_RPMPD=y
CONFIG_QCOM_SMEM=y
CONFIG_QCOM_SMD_RPM=y
CONFIG_QCOM_SMP2P=y
CONFIG_QCOM_SMSM=y
CONFIG_QCOM_SOCINFO=m
CONFIG_QCOM_APR=m
CONFIG_ARCH_R8A774A1=y
CONFIG_ARCH_R8A774B1=y
CONFIG_ARCH_R8A774C0=y
CONFIG_ARCH_R8A774E1=y
CONFIG_ARCH_R8A77950=y
CONFIG_ARCH_R8A77951=y
CONFIG_ARCH_R8A77960=y
CONFIG_ARCH_R8A77961=y
CONFIG_ARCH_R8A77965=y
CONFIG_ARCH_R8A77970=y
CONFIG_ARCH_R8A77980=y
CONFIG_ARCH_R8A77990=y
CONFIG_ARCH_R8A77995=y
CONFIG_ROCKCHIP_PM_DOMAINS=y
CONFIG_ARCH_TEGRA_132_SOC=y
CONFIG_ARCH_TEGRA_210_SOC=y
CONFIG_ARCH_TEGRA_186_SOC=y
CONFIG_ARCH_TEGRA_194_SOC=y
CONFIG_TI_SCI_PM_DOMAINS=y
CONFIG_EXTCON_PTN5150=m
CONFIG_EXTCON_USB_GPIO=y
CONFIG_EXTCON_USBC_CROS_EC=y
CONFIG_RENESAS_RPCIF=m
CONFIG_IIO=y
CONFIG_EXYNOS_ADC=y
CONFIG_MAX9611=m
CONFIG_QCOM_SPMI_ADC5=m
CONFIG_ROCKCHIP_SARADC=m
CONFIG_IIO_CROS_EC_SENSORS_CORE=m
CONFIG_IIO_CROS_EC_SENSORS=m
CONFIG_IIO_CROS_EC_LIGHT_PROX=m
CONFIG_SENSORS_ISL29018=m
CONFIG_IIO_CROS_EC_BARO=m
CONFIG_MPL3115=m
CONFIG_PWM=y
CONFIG_PWM_BCM2835=m
CONFIG_PWM_CROS_EC=m
CONFIG_PWM_MESON=m
CONFIG_PWM_RCAR=m
CONFIG_PWM_ROCKCHIP=y
CONFIG_PWM_SAMSUNG=y
CONFIG_PWM_SL28CPLD=m
CONFIG_PWM_SUN4I=m
CONFIG_PWM_TEGRA=m
CONFIG_SL28CPLD_INTC=y
CONFIG_QCOM_PDC=y
CONFIG_RESET_IMX7=y
CONFIG_RESET_QCOM_AOSS=y
CONFIG_RESET_QCOM_PDC=m
CONFIG_RESET_TI_SCI=y
CONFIG_PHY_XGENE=y
CONFIG_PHY_SUN4I_USB=y
CONFIG_PHY_MIXEL_MIPI_DPHY=m
CONFIG_PHY_HI6220_USB=y
CONFIG_PHY_HISTB_COMBPHY=y
CONFIG_PHY_HISI_INNO_USB2=y
CONFIG_PHY_MVEBU_CP110_COMPHY=y
CONFIG_PHY_QCOM_QMP=m
CONFIG_PHY_QCOM_QUSB2=m
CONFIG_PHY_QCOM_USB_HS=y
CONFIG_PHY_QCOM_USB_SNPS_FEMTO_V2=y
CONFIG_PHY_RCAR_GEN3_PCIE=y
CONFIG_PHY_RCAR_GEN3_USB2=y
CONFIG_PHY_RCAR_GEN3_USB3=m
CONFIG_PHY_ROCKCHIP_EMMC=y
CONFIG_PHY_ROCKCHIP_INNO_HDMI=m
CONFIG_PHY_ROCKCHIP_INNO_USB2=y
CONFIG_PHY_ROCKCHIP_PCIE=m
CONFIG_PHY_ROCKCHIP_TYPEC=y
CONFIG_PHY_UNIPHIER_USB2=y
CONFIG_PHY_UNIPHIER_USB3=y
CONFIG_PHY_TEGRA_XUSB=y
CONFIG_ARM_SMMU_V3_PMU=m
CONFIG_FSL_IMX8_DDR_PMU=m
CONFIG_HISI_PMU=y
CONFIG_QCOM_L2_PMU=y
CONFIG_QCOM_L3_PMU=y
CONFIG_NVMEM_IMX_OCOTP=y
CONFIG_NVMEM_IMX_OCOTP_SCU=y
CONFIG_QCOM_QFPROM=y
CONFIG_ROCKCHIP_EFUSE=y
CONFIG_NVMEM_SUNXI_SID=y
CONFIG_UNIPHIER_EFUSE=y
CONFIG_MESON_EFUSE=m
CONFIG_FPGA=y
CONFIG_FPGA_MGR_STRATIX10_SOC=m
CONFIG_FPGA_BRIDGE=m
CONFIG_ALTERA_FREEZE_BRIDGE=m
CONFIG_FPGA_REGION=m
CONFIG_OF_FPGA_REGION=m
CONFIG_TEE=y
CONFIG_OPTEE=y
CONFIG_SLIMBUS=m
CONFIG_SLIM_QCOM_CTRL=m
CONFIG_SLIM_QCOM_NGD_CTRL=m
CONFIG_MUX_MMIO=y
CONFIG_INTERCONNECT=y
CONFIG_INTERCONNECT_QCOM=y
CONFIG_INTERCONNECT_QCOM_MSM8916=m
CONFIG_INTERCONNECT_QCOM_SDM845=m
CONFIG_INTERCONNECT_QCOM_SM8150=m
CONFIG_INTERCONNECT_QCOM_SM8250=m
CONFIG_EXT2_FS=y
CONFIG_EXT3_FS=y
CONFIG_EXT4_FS_POSIX_ACL=y
CONFIG_BTRFS_FS=m
CONFIG_BTRFS_FS_POSIX_ACL=y
CONFIG_FANOTIFY=y
CONFIG_FANOTIFY_ACCESS_PERMISSIONS=y
CONFIG_QUOTA=y
CONFIG_AUTOFS4_FS=y
CONFIG_FUSE_FS=m
CONFIG_CUSE=m
CONFIG_OVERLAY_FS=m
CONFIG_VFAT_FS=y
CONFIG_HUGETLBFS=y
CONFIG_CONFIGFS_FS=y
CONFIG_EFIVAR_FS=y
CONFIG_SQUASHFS=y
CONFIG_NFS_FS=y
CONFIG_NFS_V4=y
CONFIG_NFS_V4_1=y
CONFIG_NFS_V4_2=y
CONFIG_ROOT_NFS=y
CONFIG_9P_FS=y
CONFIG_NLS_CODEPAGE_437=y
CONFIG_NLS_ISO8859_1=y
CONFIG_SECURITY=y
CONFIG_CRYPTO_ECHAINIV=y
CONFIG_CRYPTO_ANSI_CPRNG=y
CONFIG_CRYPTO_USER_API_RNG=m
CONFIG_CRYPTO_DEV_SUN8I_CE=m
CONFIG_CRYPTO_DEV_FSL_CAAM=m
CONFIG_CRYPTO_DEV_FSL_DPAA2_CAAM=m
CONFIG_CRYPTO_DEV_QCOM_RNG=m
CONFIG_CRYPTO_DEV_CCREE=m
CONFIG_CRYPTO_DEV_HISI_SEC2=m
CONFIG_CRYPTO_DEV_HISI_ZIP=m
CONFIG_CRYPTO_DEV_HISI_HPRE=m
CONFIG_CMA_SIZE_MBYTES=32
CONFIG_PRINTK_TIME=y
CONFIG_DEBUG_INFO=y
CONFIG_MAGIC_SYSRQ=y
CONFIG_DEBUG_FS=y
CONFIG_DEBUG_KERNEL=y
# CONFIG_SCHED_DEBUG is not set
# CONFIG_DEBUG_PREEMPT is not set
# CONFIG_FTRACE is not set
CONFIG_MEMTEST=y
7725.bootlog.txt
    Please share the complete patch that you have applied on top of the SDK to cater to 4GB DDR.
    Keerthy
  • Hi Keerthy,
    Attachments are the customized board files we applied on top of the uboot repo in SDK. We made no changes to 'k3-j721s2-ddr.dtsi', 'k3-j721s2.dtsi', 'k3-j721s2-mcu-wakeup.dtsi'. And we made little changes to 'k3-j721s2-main.dtsi' unrelated to DDR.
    The file 'k3-j721s2-som-p0.dtsi' mentioned in my first post is named as 'custom-common.dtsi' in the attachments.
    custom-r5.dts is our dts file for R5 and custom.dts is our dts file for A72. all the included files are also attached.
    Thanks!
    // SPDX-License-Identifier: GPL-2.0
     *  Reference is k3-j721s2-r5-common-proc-board.dts
    /dts-v1/;
    #include "custom-common.dtsi"
    #include "custom-2gb-lp4-4266.dtsi"
    #include "k3-j721s2-ddr.dtsi"
        chosen {
            firmware-loader = &fs_loader0;
            stdout-path = &mcu_uart0;
            tick-timer = &timer1;
        aliases {
            remoteproc0 = &sysctrler;
            remoteproc1 = &a72_0;
            remoteproc2 = &main_r5fss0_core0;
            remoteproc3 = &main_r5fss0_core1;
        fs_loader0: fs_loader@0 {
            compatible = "u-boot,fs-loader";
            u-boot,dm-pre-reloc;
        a72_0: a72@0 {
            compatible = "ti,am654-rproc";
            reg = <0x0 0x00a90000 0x0 0x10>;
            power-domains = <&k3_pds 61 TI_SCI_PD_EXCLUSIVE>,
                    <&k3_pds 202 TI_SCI_PD_EXCLUSIVE>;
            resets = <&k3_reset 202 0>;
            clocks = <&k3_clks 61 1>;
            assigned-clocks = <&k3_clks 61 1>, <&k3_clks 202 0>;
            assigned-clock-parents = <&k3_clks 61 2>;
            assigned-clock-rates = <200000000>, <2000000000>;
            ti,sci = <&sms>;
            ti,sci-proc-id = <32>;
            ti,sci-host-id = <10>;
            u-boot,dm-spl;
        clk_200mhz: dummy_clock_200mhz {
            compatible = "fixed-clock";
            #clock-cells = <0>;
            clock-frequency = <200000000>;
            u-boot,dm-spl;
        clk_19_2mhz: dummy_clock_19_2mhz {
            #clock-cells = <0>;
            clock-frequency = <19200000>;
            u-boot,dm-spl;
    &cbass_mcu_wakeup {
        sa3_secproxy: secproxy@44880000 {
            u-boot,dm-spl;
            compatible = "ti,am654-secure-proxy";
            reg = <0x0 0x44880000 0x0 0x20000>,
                  <0x0 0x44860000 0x0 0x20000>,
                  <0x0 0x43600000 0x0 0x10000>;
            reg-names = "rt", "scfg", "target_data";
            #mbox-cells = <1>;
        mcu_secproxy: secproxy@2a380000 {
            reg = <0x0 0x2a380000 0x0 0x80000>,
                  <0x0 0x2a400000 0x0 0x80000>,
                  <0x0 0x2a480000 0x0 0x80000>;
            #mbox-cells = <1>;
            u-boot,dm-spl;
        sysctrler: sysctrler {
            compatible = "ti,am654-system-controller";
            mboxes= <&mcu_secproxy 4>, <&mcu_secproxy 5>, <&sa3_secproxy 5>;
            mbox-names = "tx", "rx", "boot_notify";
            u-boot,dm-spl;
        dm_tifs: dm-tifs {
            compatible = "ti,j721e-dm-sci";
            ti,host-id = <3>;
            ti,secure-host;
            mbox-names = "rx", "tx";
            mboxes= <&mcu_secproxy 21>,
                <&mcu_secproxy 23>;
            u-boot,dm-spl;
    &main_pmx0 {
        main_uart8_pins_default: main-uart8-pins-default {
            pinctrl-single,pins = <
    			J721S2_IOPAD(0x038, PIN_INPUT, 11) /* (AB28) MCASP0_ACLKX.UART8_RXD */
    			J721S2_IOPAD(0x03c, PIN_INPUT, 11) /* (U27) MCASP0_AFSX.UART8_TXD */
    &wkup_pmx0 {
        mcu_uart0_pins_default: mcu-uart0-pins-default {
            u-boot,dm-spl;
                J721S2_WKUP_IOPAD(0x0f4, PIN_INPUT, 0) /* (C24) WKUP_GPIO0_13.MCU_UART0_RXD */
                J721S2_WKUP_IOPAD(0x0f0, PIN_OUTPUT, 0) /* (C25) WKUP_GPIO0_12.MCU_UART0_TXD */
        mymcu_ospi1_pins_default: mymcu_ospi1_pins_default {
                J721S2_WKUP_IOPAD(0x000, PIN_OUTPUT_PULLUP, 0) /* (D19) MCU_OSPI0_CLK */
                J721S2_WKUP_IOPAD(0x02c, PIN_OUTPUT_PULLUP, 0) /* (F15) MCU_OSPI0_CSn0 */
                J721S2_WKUP_IOPAD(0x00c, PIN_INPUT_PULLUP, 0) /* (C19) MCU_OSPI0_D0 */
                J721S2_WKUP_IOPAD(0x010, PIN_INPUT_PULLUP, 0) /* (F16) MCU_OSPI0_D1 */
                J721S2_WKUP_IOPAD(0x014, PIN_INPUT_PULLUP, 0) /* (G15) MCU_OSPI0_D2 */
                J721S2_WKUP_IOPAD(0x018, PIN_INPUT_PULLUP, 0) /* (F18) MCU_OSPI0_D3 */
                J721S2_WKUP_IOPAD(0x01c, PIN_INPUT_PULLUP, 0) /* (E19) MCU_OSPI0_D4 */
                J721S2_WKUP_IOPAD(0x020, PIN_INPUT_PULLUP, 0) /* (G19) MCU_OSPI0_D5 */
                J721S2_WKUP_IOPAD(0x024, PIN_INPUT_PULLUP, 0) /* (F19) MCU_OSPI0_D6 */
                J721S2_WKUP_IOPAD(0x028, PIN_INPUT_PULLUP, 0) /* (F20) MCU_OSPI0_D7 */
                J721S2_WKUP_IOPAD(0x008, PIN_INPUT_PULLDOWN, 0) /* (E18) MCU_OSPI0_DQS */
                J721S2_WKUP_IOPAD(0x004, PIN_OUTPUT_PULLUP, 0) /* (E20) MCU_OSPI0_LBCLKO */
    &sms {
        mboxes= <&mcu_secproxy 8>, <&mcu_secproxy 6>, <&mcu_secproxy 5>;
        mbox-names = "tx", "rx", "notify";
        ti,host-id = <4>;
        ti,secure-host;
        u-boot,dm-spl;
    &wkup_uart0 {
        status = "disabled";
    &mcu_uart0 {
        status = "okay";
        pinctrl-names = "default";
        pinctrl-0 = <&mcu_uart0_pins_default>;
    &main_uart8 {
        status = "okay";
        pinctrl-0 = <&main_uart8_pins_default>;
    &main_uart8_pins_default {
    	u-boot,dm-spl;
    &main_sdhci0 {
        /delete-property/ power-domains;
        /delete-property/ assigned-clocks;
        /delete-property/ assigned-clock-parents;
        clock-names = "clk_xin";
        clocks = <&clk_200mhz>;
        ti,driver-strength-ohm = <50>;
        non-removable;
        status="okay";
    &usbss0 {
    &usb0 {
        // Add support
    &mcu_ringacc {
        ti,sci = <&dm_tifs>;
    &mcu_udmap {
    &ospi0 {
        reg = <0x0 0x47040000 0x0 0x100>,
              <0x0 0x50000000 0x0 0x8000000>;
        status = "okay";
        pinctrl-0 = <&mymcu_ospi1_pins_default>;
        flash@0{
            compatible = "jedec,spi-nor";
            reg = <0x0>;
            spi-tx-bus-width = <8>;
            spi-rx-bus-width = <8>;
            spi-max-frequency = <25000000>;
            cdns,tshsl-ns = <60>;
            cdns,tsd2d-ns = <60>;
            cdns,tchsh-ns = <60>;
            cdns,tslch-ns = <60>;
            cdns,read-delay = <0>;
            #address-cells = <1>;
            #size-cells = <1>;
    #include "custom-u-boot.dtsi"
    /* Lets now HACK things so that we get our config back */
        chosen {
            stdout-path = &main_uart8;
        aliases {
            spi0 = &ospi0;
    // Only single DDR slot used
    &memorycontroller1 {
    /dts-v1/;
    #include "k3-j721s2.dtsi"
    #include <dt-bindings/gpio/gpio.h>
    	memory@80000000 {
    		device_type = "memory";
    		/* 4 GB RAM */
    		reg = <0x00 0x80000000 0x00 0x80000000>,
    		      <0x08 0x80000000 0x00 0x80000000>;
    	/* Reserving memory regions still pending */
    	reserved_memory: reserved-memory {
    		#address-cells = <2>;
    		#size-cells = <2>;
    		ranges;
    		secure_ddr: optee@9e800000 {
    			reg = <0x00 0x9e800000 0x00 0x01800000>;
    			alignment = <0x1000>;
    			no-map;
    &main_mcan16 {
    &ospi0 {
    	flash@0 {
    		reg = <0x0>;
    		#size-cells = <1>;
    &mailbox0_cluster0 {
    	interrupts = <436>;
    	mbox_mcu_r5fss0_core0: mbox-mcu-r5fss0-core0 {
    		ti,mbox-rx = <0 0 0>;
    		ti,mbox-tx = <1 0 0>;
    	mbox_mcu_r5fss0_core1: mbox-mcu-r5fss0-core1 {
    		ti,mbox-rx = <2 0 0>;
    		ti,mbox-tx = <3 0 0>;
    &mailbox0_cluster1 {
    	interrupts = <432>;
    	mbox_main_r5fss0_core0: mbox-main-r5fss0-core0 {
    	mbox_main_r5fss0_core1: mbox-main-r5fss0-core1 {
    &mailbox0_cluster2 {
    	interrupts = <428>;
    	mbox_main_r5fss1_core0: mbox-main-r5fss1-core0 {
    	mbox_main_r5fss1_core1: mbox-main-r5fss1-core1 {
    &mailbox0_cluster3 {
    &mailbox0_cluster4 {
    	interrupts = <420>;
    	mbox_c71_0: mbox-c71-0 {
    	mbox_c71_1: mbox-c71-1 {
    &mailbox0_cluster5 {
    &mailbox0_cluster6 {
    &mailbox0_cluster7 {
    &mailbox0_cluster8 {
    &mailbox0_cluster9 {
    &mailbox0_cluster10 {
    &mailbox0_cluster11 {
    &mcu_r5fss0_core0 {
    	mboxes = <&mailbox0_cluster0 &mbox_mcu_r5fss0_core0>;
    &mcu_r5fss0_core1 {
    	mboxes = <&mailbox0_cluster0 &mbox_mcu_r5fss0_core1>;
    &main_r5fss0_core0 {
    	mboxes = <&mailbox0_cluster1 &mbox_main_r5fss0_core0>;
    &main_r5fss0_core1 {
    	mboxes = <&mailbox0_cluster1 &mbox_main_r5fss0_core1>;
    &main_r5fss1_core0 {
    	mboxes = <&mailbox0_cluster2 &mbox_main_r5fss1_core0>;
    &main_r5fss1_core1 {
    	mboxes = <&mailbox0_cluster2 &mbox_main_r5fss1_core1>;
    &c71_0 {
    	mboxes = <&mailbox0_cluster4 &mbox_c71_0>;
    &c71_1 {
    	mboxes = <&mailbox0_cluster4 &mbox_c71_1>;
    custom-2gb-lp4-4266.dtsi.txt
    k3-j721s2-ddr.dtsi.txt
     * Reference is k3-j721s2-common-proc-board-u-boot.dtss
    	chosen {
    		stdout-path = "serial2:115200n8";
    	aliases {
    		serial0 = &wkup_uart0;
    		serial1 = &mcu_uart0;
    		serial2 = &main_uart8;
    		i2c0 = &wkup_i2c0;
    		i2c1 = &mcu_i2c0;
    		i2c2 = &mcu_i2c1;
    		i2c3 = &main_i2c0;
    		ethernet0 = &main_cpsw_port1;
    		spi0 = &ospi0;
    		mmc0 = &main_sdhci0;
    &cbass_main {
    	u-boot,dm-spl;
    &main_navss {
    	u-boot,dm-spl;
    &cbass_mcu_wakeup {
    	u-boot,dm-spl;
    	timer1: timer@40400000 {
    		compatible = "ti,omap5430-timer";
    		reg = <0x0 0x40400000 0x0 0x80>;
    		ti,timer-alwon;
    		clock-frequency = <25000000>;
    		u-boot,dm-spl;
    	chipid@43000014 {
    		u-boot,dm-spl;
    &mcu_navss {
    	u-boot,dm-spl;
    &mcu_ringacc {
    	reg =   <0x0 0x2b800000 0x0 0x400000>,
    		<0x0 0x2b000000 0x0 0x400000>,
    		<0x0 0x28590000 0x0 0x100>,
    		<0x0 0x2a500000 0x0 0x40000>,
    		<0x0 0x28440000 0x0 0x40000>;
    	reg-names = "rt", "fifos", "proxy_gcfg", "proxy_target", "cfg";
    	u-boot,dm-spl;
    &mcu_udmap {
    	reg =   <0x0 0x285c0000 0x0 0x100>,
    		<0x0 0x284c0000 0x0 0x4000>,
    		<0x0 0x2a800000 0x0 0x40000>,
    		<0x0 0x284a0000 0x0 0x4000>,
    		<0x0 0x2aa00000 0x0 0x40000>,
    		<0x0 0x28400000 0x0 0x2000>;
    	reg-names = "gcfg", "rchan", "rchanrt", "tchan",
    		    "tchanrt", "rflow";
    	u-boot,dm-spl;
    &secure_proxy_main {
    	u-boot,dm-spl;
    &sms {
    	u-boot,dm-spl;
    	k3_sysreset: sysreset-controller {
    		compatible = "ti,sci-sysreset";
    		u-boot,dm-spl;
    &main_pmx0 {
    	u-boot,dm-spl;
    // &main_mmc0_pins_default {
    // 	u-boot,dm-spl;
    // &main_usbss0_pins_default {
    // 	u-boot,dm-spl;
    &main_uart8 {
    	u-boot,dm-spl;
    &wkup_pmx0 {
    	u-boot,dm-spl;
    &k3_pds {
    	u-boot,dm-spl;
    &k3_clks {
    	u-boot,dm-spl;
    &k3_reset {
    	u-boot,dm-spl;
    &mcu_uart0 {
    	u-boot,dm-spl;
    &wkup_uart0 {
    	u-boot,dm-spl;
    &fss {
    	u-boot,dm-spl;
    &mcu_cpsw {
    	reg = <0x0 0x46000000 0x0 0x200000>,
    	      <0x0 0x40f00200 0x0 0x8>;
    	reg-names = "cpsw_nuss", "mac_efuse";
    	/delete-property/ ranges;
    	cpsw-phy-sel@40f04040 {
            	compatible = "ti,am654-cpsw-phy-sel";
    		reg= <0x0 0x40f04040 0x0 0x4>;
    		reg-names = "gmii-sel";
    &main_cpsw {
    	cpsw-phy-sel@104034 {
    		reg= <0x0 0x104034 0x0 0x4>;
    &mymcu_ospi1_pins_default {
    	u-boot,dm-spl;
    &main_r5fss0 {
    	ti,cluster-mode = <0>;
    &main_r5fss1 {
    &wiz0_pll1_refclk {
    	assigned-clocks = <&wiz0_pll1_refclk>, <&wiz0_pll0_refclk>;
    	assigned-clock-parents = <&k3_clks 365 40>, <&k3_clks 365 75>;
    &serdes_ln_ctrl {
    	u-boot,mux-autoprobe;
    &usb_serdes_mux {
    &ospi0 {
    	u-boot,dm-spl;
    	flash@0 {
    		cdns,phy-mode;
    		u-boot,dm-spl;
    		partition@3fc0000 {
    			label = "ospi.phypattern";
    			reg = <0x3fc0000 0x40000>;
    			u-boot,dm-spl;
    &main_sdhci0 {
    	u-boot,dm-spl;
     * Reference is k3-j721s2-common-proc-board.dts
    /dts-v1/;
    #include <dt-bindings/phy/phy-cadence.h>
    #include <dt-bindings/phy/phy.h>
    #include <dt-bindings/net/ti-dp83867.h>
        compatible = "ti,j721s2-evm", "ti,j721s2";
        model = "custom";
        aliases {
            serial3 = &main_uart1;
            serial4 = &main_uart2;
            serial5 = &main_uart3;
            serial6 = &main_uart4;
            serial7 = &main_uart5;
            serial8 = &main_uart6;
            serial9 = &main_uart7;
            serial10 = &main_uart8;
            serial11 = &main_uart9;
            spi0 = &ospi0;
        chosen {
            stdout-path = "serial10:115200n8";
            bootargs = "console=ttyS10,115200n8 earlycon=ns16550a,mmio32,2880000";
    &main_pmx0 {
    	main_spi0_pins_default: main_spi0_pins_default {
    			J721S2_IOPAD(0x0d4, PIN_OUTPUT, 0) /* (AH27) SPI0_CLK */
    			J721S2_IOPAD(0x0cc, PIN_OUTPUT_PULLUP, 0) /* (AE27) SPI0_CS0 */
                /*J721S2_IOPAD(0x0d8, PIN_INPUT, 0)*/ /* (AG26) SPI0_D0 */
    			/*J721S2_IOPAD(0x0dc, PIN_OUTPUT, 0)*/ /* (AH26) SPI0_D1 */
                /* SPI PIN管脚修改*/
                 J721S2_IOPAD(0x0d8, PIN_OUTPUT, 0)  /* (AG26) SPI0_D0 */
                 J721S2_IOPAD(0x0dc, PIN_INPUT, 0)  /* (AH26) SPI0_D1 */
    	main_gpio0_pins_default: main_gpio0_pins_default {
                J721S2_IOPAD(0x07c, PIN_OUTPUT, 7) /* (T27) MCASP0_AXR3.GPIO0_31 GPIO_拉高 */
    			J721S2_IOPAD(0x0c8, PIN_OUTPUT_PULLDOWN, 7) /* (AD28) RESET_N_PPP2ETHSW */
    			J721S2_IOPAD(0x0c4, PIN_OUTPUT_PULLDOWN, 7) /* (AB26) RESET_N_PPP2ETHPHY234 */
    	main_cpsw_mdio_pins_default: main-cpsw-mdio-pins-default {
    			J721S2_IOPAD(0x0c0, PIN_OUTPUT, 6) /* (T28) MCASP1_AXR0.MDIO0_MDC */
    			J721S2_IOPAD(0x0bc, PIN_INPUT, 6) /* (V28) MCASP1_AFSX.MDIO0_MDIO */
    	rgmii1_pins_default: rgmii1_pins_default {
    			J721S2_IOPAD(0x0b8, PIN_INPUT, 6) /* (AA24) MCASP1_ACLKX.RGMII1_RD0 */
    			J721S2_IOPAD(0x0a0, PIN_INPUT, 6) /* (AB25) MCASP0_AXR12.RGMII1_RD1 */
    			J721S2_IOPAD(0x0a4, PIN_INPUT, 6) /* (T23) MCASP0_AXR13.RGMII1_RD2 */
    			J721S2_IOPAD(0x0a8, PIN_INPUT, 6) /* (U24) MCASP0_AXR14.RGMII1_RD3 */
    			J721S2_IOPAD(0x0b0, PIN_INPUT, 6) /* (AD26) MCASP1_AXR3.RGMII1_RXC */
    			J721S2_IOPAD(0x0ac, PIN_INPUT, 6) /* (AC25) MCASP0_AXR15.RGMII1_RX_CTL */
    			J721S2_IOPAD(0x08c, PIN_OUTPUT, 6) /* (T25) MCASP0_AXR7.RGMII1_TD0 */
    			J721S2_IOPAD(0x090, PIN_OUTPUT, 6) /* (W24) MCASP0_AXR8.RGMII1_TD1 */
    			J721S2_IOPAD(0x094, PIN_OUTPUT, 6) /* (AA25) MCASP0_AXR9.RGMII1_TD2 */
    			J721S2_IOPAD(0x098, PIN_OUTPUT, 6) /* (V25) MCASP0_AXR10.RGMII1_TD3 */
    			J721S2_IOPAD(0x0b4, PIN_OUTPUT, 6) /* (U25) MCASP1_AXR4.RGMII1_TXC */
    			J721S2_IOPAD(0x09c, PIN_OUTPUT, 6) /* (T24) MCASP0_AXR11.RGMII1_TX_CTL */
    &wkup_pmx0 {
        // Taken over by IU core
        // mymcu_cpsw2g1_pins_default: mymcu_cpsw2g1_pins_default {
        //     pinctrl-single,pins = <
        //         J721S2_WKUP_IOPAD(0x08c, PIN_INPUT_PULLDOWN, 0) /* (C22) MCU_RGMII1_RD2 */
        //         J721S2_WKUP_IOPAD(0x088, PIN_INPUT_PULLDOWN, 0) /* (D23) MCU_RGMII1_RD3 */
        //         J721S2_WKUP_IOPAD(0x084, PIN_INPUT_PULLDOWN, 0) /* (D22) MCU_RGMII1_RXC */
        //         J721S2_WKUP_IOPAD(0x094, PIN_INPUT_PULLDOWN, 0) /* (B22) MCU_RGMII1_RD0.MCU_RMII1_RXD0 */
        //         J721S2_WKUP_IOPAD(0x090, PIN_INPUT_PULLDOWN, 0) /* (B21) MCU_RGMII1_RD1.MCU_RMII1_RXD1 */
        //         J721S2_WKUP_IOPAD(0x06c, PIN_INPUT_PULLDOWN, 0) /* (E23) MCU_RGMII1_RX_CTL */
        //         J721S2_WKUP_IOPAD(0x07c, PIN_OUTPUT, 0) /* (F23) MCU_RGMII1_TD0 */
        //         J721S2_WKUP_IOPAD(0x078, PIN_OUTPUT, 0) /* (G22) MCU_RGMII1_TD1 */
        //         J721S2_WKUP_IOPAD(0x074, PIN_OUTPUT, 0) /* (E21) MCU_RGMII1_TD2 */
        //         J721S2_WKUP_IOPAD(0x070, PIN_OUTPUT, 0) /* (E22) MCU_RGMII1_TD3 */
        //         J721S2_WKUP_IOPAD(0x080, PIN_OUTPUT, 0) /* (F21) MCU_RGMII1_TXC */
        //         J721S2_WKUP_IOPAD(0x068, PIN_OUTPUT, 0) /* (F22) MCU_RGMII1_TX_CTL */
        // mcu_mdio_pins_default: mcu-mdio-pins-default {
        //         J721S2_WKUP_IOPAD(0x09c, PIN_OUTPUT, 0) /* (A21) MCU_MDIO0_MDC */
        //         J721S2_WKUP_IOPAD(0x098, PIN_INPUT, 0) /* (A22) MCU_MDIO0_MDIO */
        mywkup_gpio0_pins_default: mywkup_gpio0_pins_default {
    			J721S2_WKUP_IOPAD(0x0d0, PIN_OUTPUT_PULLDOWN, 7) /* (C23) WKUP_GPIO0_4 */
    			J721S2_WKUP_IOPAD(0x0d4, PIN_OUTPUT_PULLDOWN, 7) /* (F26) WKUP_GPIO0_5 */
    			J721S2_WKUP_IOPAD(0x0d8, PIN_OUTPUT_PULLDOWN, 7) /* (E25) WKUP_GPIO0_6 */
    			J721S2_WKUP_IOPAD(0x0dc, PIN_OUTPUT_PULLUP, 7) /* (F28) WKUP_GPIO0_7 */
    			J721S2_WKUP_IOPAD(0x0e8, PIN_INPUT_PULLUP, 7) /* (F27) WKUP_GPIO0_10 */
    			J721S2_WKUP_IOPAD(0x0ec, PIN_INPUT_PULLDOWN, 7) /* (F25) WKUP_GPIO0_11 */
    			J721S2_WKUP_IOPAD(0x040, PIN_OUTPUT_PULLDOWN, 7) /* (A19) MCU_OSPI1_CLK.WKUP_GPIO0_31 */
    			J721S2_WKUP_IOPAD(0x044, PIN_OUTPUT_PULLDOWN, 7) /* (B20) MCU_OSPI1_LBCLKO.WKUP_GPIO0_32 */
    			J721S2_WKUP_IOPAD(0x048, PIN_OUTPUT_PULLDOWN, 7) /* (B19) MCU_OSPI1_DQS.WKUP_GPIO0_33 */
    			J721S2_WKUP_IOPAD(0x04c, PIN_OUTPUT_PULLDOWN, 7) /* (D21) MCU_OSPI1_D0.WKUP_GPIO0_34 */
    			J721S2_WKUP_IOPAD(0x050, PIN_OUTPUT_PULLDOWN, 7) /* (G20) MCU_OSPI1_D1.WKUP_GPIO0_35 */
    			J721S2_WKUP_IOPAD(0x054, PIN_OUTPUT_PULLDOWN, 7) /* (C20) MCU_OSPI1_D2.WKUP_GPIO0_36 */
    			J721S2_WKUP_IOPAD(0x058, PIN_OUTPUT_PULLDOWN, 7) /* (A20) MCU_OSPI1_D3.WKUP_GPIO0_37 */
    			J721S2_WKUP_IOPAD(0x05c, PIN_INPUT_PULLUP, 7) /* (D20) MCU_OSPI1_CSn0.WKUP_GPIO0_38 */
    			J721S2_WKUP_IOPAD(0x060, PIN_INPUT_PULLUP, 7) /* (C21) MCU_OSPI1_CSn1.WKUP_GPIO0_39 */
    			J721S2_WKUP_IOPAD(0x17c, PIN_OUTPUT_PULLDOWN, 7) /* (J26) WKUP_GPIO0_57 */
    			J721S2_WKUP_IOPAD(0x0b0, PIN_INPUT, 7) /* (D28) WKUP_UART0_RXD.WKUP_GPIO0_58 */
    			J721S2_WKUP_IOPAD(0x0b4, PIN_OUTPUT_PULLDOWN, 7) /* (D27) WKUP_UART0_TXD.WKUP_GPIO0_59 */
    			J721S2_WKUP_IOPAD(0x180, PIN_INPUT, 7) /* (G25) WKUP_GPIO0_66 */
    			J721S2_WKUP_IOPAD(0x184, PIN_OUTPUT_PULLDOWN, 7) /* (J27) WKUP_GPIO0_67 */
    			J721S2_WKUP_IOPAD(0x134, PIN_INPUT, 7) /* (L25) MCU_ADC0_AIN0.WKUP_GPIO0_71 */
    			J721S2_WKUP_IOPAD(0x138, PIN_INPUT, 7) /* (K25) MCU_ADC0_AIN1.WKUP_GPIO0_72 */
    			J721S2_WKUP_IOPAD(0x13c, PIN_INPUT, 7) /* (M24) MCU_ADC0_AIN2.WKUP_GPIO0_73 */
    			J721S2_WKUP_IOPAD(0x140, PIN_INPUT, 7) /* (L24) MCU_ADC0_AIN3.WKUP_GPIO0_74 */
    			J721S2_WKUP_IOPAD(0x144, PIN_INPUT, 7) /* (L27) MCU_ADC0_AIN4.WKUP_GPIO0_75 */
    			J721S2_WKUP_IOPAD(0x148, PIN_INPUT, 7) /* (K24) MCU_ADC0_AIN5.WKUP_GPIO0_76 */
    			J721S2_WKUP_IOPAD(0x150, PIN_INPUT, 7) /* (M26) MCU_ADC0_AIN7.WKUP_GPIO0_78 */
    			J721S2_WKUP_IOPAD(0x154, PIN_INPUT, 7) /* (P25) MCU_ADC1_AIN0.WKUP_GPIO0_79 */
    			J721S2_WKUP_IOPAD(0x158, PIN_INPUT, 7) /* (R25) MCU_ADC1_AIN1.WKUP_GPIO0_80 */
    			J721S2_WKUP_IOPAD(0x160, PIN_INPUT, 7) /* (P27) MCU_ADC1_AIN3.WKUP_GPIO0_82 */
    			J721S2_WKUP_IOPAD(0x164, PIN_INPUT, 7) /* (N25) MCU_ADC1_AIN4.WKUP_GPIO0_83 */
            J721S2_WKUP_IOPAD(0x120, PIN_OUTPUT_PULLDOWN, 7)
    &wkup_gpio0 {
         status = "okay";
         pinctrl-0 = <&mywkup_gpio0_pins_default>;
         eth_phy1_wakeup {
             gpio-hog;
             gpios = <56 GPIO_ACTIVE_HIGH>; // G27
             output-high;
             line-name = "RESET_N_PPP2ETHSW";
    // &wkup_gpio0 {
    //     status = "okay";
    //     pinctrl-names = "default";
    //     pinctrl-0 = <&mywkup_gpio0_pins_default>;
    //     eth_phy1_wakeup {
    //         gpio-hog;
    //         gpios = <32 GPIO_ACTIVE_HIGH>; // B20
    //         output-high;
    //         line-name = "eth_phy1_wakeup";
    // &mcu_cpsw {
    //     status = "okay";
    //     pinctrl-0 = <&mymcu_cpsw2g1_pins_default &mcu_mdio_pins_default>;
    //     mac-address = [ 02 ad c5 10 b0 00 ];
    // &davinci_mdio {
    //     status = "okay";
    //     bus_freq = <20000>;
    //     phy0: ethernet-phy@0 {
    //         reg = <0>;
    // &cpsw_port1 {
    //     phy-mode = "rgmii-rxid";
    //     phy-handle = <&phy0>;
    &davinci_mdio {
    &mcu_cpsw {
    &main_gpio0 {
    	pinctrl-0 = <&main_gpio0_pins_default>;
        p31 {
    		gpio-hog;
    		gpios = <31 0>;
    		output-high;
    		line-name = "RESET_N_PPP2ETHPHY234";
    	p49 {
    		gpio-hog;
    		gpios = <49 0>;
    		output-high;
    	p50 {
    		gpio-hog;
    		gpios = <50 0>;
    		output-high;
    &main_gpio2 {
    &main_gpio4 {
    &main_gpio6 {
    &wkup_gpio1 {
    &wkup_uart0 {
        status = "reserved";
    &main_uart0 {
    &main_uart1 {
    &main_uart2 {
    &main_uart3 {
    &main_uart4 {
    &main_uart5 {
    &main_uart6 {
    &main_uart7 {
    &main_uart8 {
        status = "okay";
        /* Shared with ATF on this platform */
        power-domains = <&k3_pds 357 TI_SCI_PD_SHARED>;
    &main_uart9 {
    &main_i2c0 {
    &main_i2c1 {
    &main_i2c2 {
    &main_i2c3 {
    &main_i2c4 {
    &main_i2c5 {
    &main_i2c6 {
    &usbss0 {
    &usb0 {
        dr_mode = "otg";
        maximum-speed = "high-speed";
    &main_sdhci0 {
        /* eMMC */
        non-removable;
        disable-wp;
        status = "okay";
    &main_sdhci1 {
        /* SD card do not exists*/
    &serdes_ln_ctrl {
        idle-states = <J721S2_SERDES0_LANE0_PCIE1_LANE0>, <J721S2_SERDES0_LANE1_USB>,
                  <J721S2_SERDES0_LANE2_EDP_LANE2>, <J721S2_SERDES0_LANE3_EDP_LANE3>;
    &usb_serdes_mux {
        idle-states = <1>; /* USB0 to SERDES lane 1 */
    &serdes_refclk {
        clock-frequency = <100000000>;
    &serdes0 {
    &pcie1_rc {
    &pcie1_ep {
    &mcu_mcan0 {
    &mcu_mcan1 {
    &main_mcan0 {
    &main_mcan1 {
    &main_mcan2 {
    &main_mcan3 {
    &main_mcan4 {
    &main_mcan6 {
    &main_mcan7 {
    &main_mcan8 {
    &main_mcan9 {
    &main_mcan10 {
    &main_mcan11 {
    &main_mcan12 {
    &main_mcan13 {
    &main_mcan14 {
    &main_mcan15 {
    &main_mcan17 {
    &ospi1 {
        /* Do not exists */
    &main_cpsw {
    	pinctrl-0 = <&main_cpsw_mdio_pins_default
    		     &rgmii1_pins_default>;
    	fixed-link {
    		speed = <1000>;
    		full-duplex;
    &main_cpsw_port1 {
        mac-address = [ 02 ad c5 10 b0 01 ];
    	fixed-link {
    		speed = <1000>;
    		full-duplex;
    &main_davinci_mdio {
    &main_spi0 {
    	pinctrl-0 = <&main_spi0_pins_default>;
     * Device Tree Source for J721S2 SoC Family
     * TRM (SPRUJ28 – NOVEMBER 2021) : http://www.ti.com/lit/pdf/spruj28
     * Copyright (C) 2021 Texas Instruments Incorporated - https://www.ti.com/
    #include <dt-bindings/interrupt-controller/irq.h>
    #include <dt-bindings/interrupt-controller/arm-gic.h>
    #include <dt-bindings/pinctrl/k3.h>
    #include <dt-bindings/soc/ti,sci_pm_domain.h>
    	model = "Texas Instruments K3 J721S2 SoC";
    	compatible = "ti,j721s2";
    	interrupt-parent = <&gic500>;
    	#size-cells = <2>;
    	chosen { };
    	cpus {
    		#size-cells = <0>;
    		cpu-map {
    			cluster0: cluster0 {
    				core0 {
    					cpu = <&cpu0>;
    				core1 {
    					cpu = <&cpu1>;
    		cpu0: cpu@0 {
    			compatible = "arm,cortex-a72";
    			reg = <0x000>;
    			device_type = "cpu";
    			enable-method = "psci";
    			i-cache-size = <0xc000>;
    			i-cache-line-size = <64>;
    			i-cache-sets = <256>;
    			d-cache-size = <0x8000>;
    			d-cache-line-size = <64>;
    			d-cache-sets = <256>;
    			next-level-cache = <&L2_0>;
    		cpu1: cpu@1 {
    			reg = <0x001>;
    	L2_0: l2-cache0 {
    		compatible = "cache";
    		cache-level = <2>;
    		cache-size = <0x100000>;
    		cache-sets = <1024>;
    		next-level-cache = <&msmc_l3>;
    	msmc_l3: l3-cache0 {
    		cache-level = <3>;
    	firmware {
    		optee {
    			compatible = "linaro,optee-tz";
    			method = "smc";
    		psci: psci {
    			compatible = "arm,psci-1.0";
    			method = "smc";
    	a72_timer0: timer-cl0-cpu0 {
    		compatible = "arm,armv8-timer";
    		interrupts = <GIC_PPI 13 IRQ_TYPE_LEVEL_LOW>, /* cntpsirq */
    			     <GIC_PPI 14 IRQ_TYPE_LEVEL_LOW>, /* cntpnsirq */
    			     <GIC_PPI 11 IRQ_TYPE_LEVEL_LOW>, /* cntvirq */
    			     <GIC_PPI 10 IRQ_TYPE_LEVEL_LOW>; /* cnthpirq */
    	pmu: pmu {
    		compatible = "arm,cortex-a72-pmu";
    		/* Recommendation from GIC500 TRM Table A.3 */
    		interrupts = <GIC_PPI 7 IRQ_TYPE_LEVEL_HIGH>;
    	cbass_main: bus@100000 {
    		compatible = "simple-bus";
    		#size-cells = <2>;
    		ranges = <0x00 0x00100000 0x00 0x00100000 0x00 0x00020000>, /* ctrl mmr */
    			 <0x00 0x00600000 0x00 0x00600000 0x00 0x00031100>, /* GPIO */
    			 <0x00 0x01000000 0x00 0x01000000 0x00 0x0d000000>, /* Most peripherals */
    			 <0x00 0x0d800000 0x00 0x0d800000 0x00 0x00800000>, /* PCIe Core*/
    			 <0x00 0x18000000 0x00 0x18000000 0x00 0x08000000>, /* PCIe1 DAT0 */
    			 <0x00 0x64800000 0x00 0x64800000 0x00 0x0070c000>, /* C71_1 */
    			 <0x00 0x65800000 0x00 0x65800000 0x00 0x0070c000>, /* C71_2 */
    			 <0x00 0x70000000 0x00 0x70000000 0x00 0x00400000>, /* MSMC RAM */
    			 <0x00 0x30000000 0x00 0x30000000 0x00 0x0c400000>, /* MAIN NAVSS */
    			 <0x41 0x00000000 0x41 0x00000000 0x01 0x00000000>, /* PCIe1 DAT1 */
    			 <0x4e 0x20000000 0x4e 0x20000000 0x00 0x00080000>, /* GPU */
    			 /* MCUSS_WKUP Range */
    			 <0x00 0x28380000 0x00 0x28380000 0x00 0x03880000>,
    			 <0x00 0x40200000 0x00 0x40200000 0x00 0x00998400>,
    			 <0x00 0x40f00000 0x00 0x40f00000 0x00 0x00020000>,
    			 <0x00 0x41000000 0x00 0x41000000 0x00 0x00020000>,
    			 <0x00 0x41400000 0x00 0x41400000 0x00 0x00020000>,
    			 <0x00 0x41c00000 0x00 0x41c00000 0x00 0x00100000>,
    			 <0x00 0x42040000 0x00 0x42040000 0x00 0x03ac2400>,
    			 <0x00 0x45100000 0x00 0x45100000 0x00 0x00c24000>,
    			 <0x00 0x46000000 0x00 0x46000000 0x00 0x00200000>,
    			 <0x00 0x47000000 0x00 0x47000000 0x00 0x00068400>,
    			 <0x00 0x50000000 0x00 0x50000000 0x00 0x10000000>,
    			 <0x05 0x00000000 0x05 0x00000000 0x01 0x00000000>,
    			 <0x07 0x00000000 0x07 0x00000000 0x01 0x00000000>;
    		cbass_mcu_wakeup: bus@28380000 {
    			#size-cells = <2>;
    			ranges = <0x00 0x28380000 0x00 0x28380000 0x00 0x03880000>, /* MCU NAVSS*/
    				 <0x00 0x40200000 0x00 0x40200000 0x00 0x00998400>, /* First peripheral window */
    				 <0x00 0x40f00000 0x00 0x40f00000 0x00 0x00020000>, /* CTRL_MMR0 */
    				 <0x00 0x41000000 0x00 0x41000000 0x00 0x00020000>, /* MCU R5F Core0 */
    				 <0x00 0x41400000 0x00 0x41400000 0x00 0x00020000>, /* MCU R5F Core1 */
    				 <0x00 0x41c00000 0x00 0x41c00000 0x00 0x00100000>, /* MCU SRAM */
    				 <0x00 0x42040000 0x00 0x42040000 0x00 0x03ac2400>, /* WKUP peripheral window */
    				 <0x00 0x45100000 0x00 0x45100000 0x00 0x00c24000>, /* MMRs, remaining NAVSS */
    				 <0x00 0x46000000 0x00 0x46000000 0x00 0x00200000>, /* CPSW */
    				 <0x00 0x47000000 0x00 0x47000000 0x00 0x00068400>, /* OSPI register space */
    				 <0x00 0x50000000 0x00 0x50000000 0x00 0x10000000>, /* FSS OSPI0/1 data region 0 */
    				 <0x05 0x00000000 0x05 0x00000000 0x01 0x00000000>, /* FSS OSPI0 data region 3 */
    				 <0x07 0x00000000 0x07 0x00000000 0x01 0x00000000>; /* FSS OSPI1 data region 3*/
    /* Now include peripherals from each bus segment */
    #include "k3-j721s2-main.dtsi"
    #include "k3-j721s2-mcu-wakeup.dtsi"
     * Device Tree Source for J721S2 SoC Family MCU/WAKEUP Domain peripherals
    &cbass_mcu_wakeup {
    	sms: system-controller@44083000 {
    		compatible = "ti,k2g-sci";
    		ti,host-id = <12>;
    		mboxes= <&secure_proxy_main 11>,
    			<&secure_proxy_main 13>;
    		reg-names = "debug_messages";
    		reg = <0x00 0x44083000 0x00 0x1000>;
    		k3_pds: power-controller {
    			compatible = "ti,sci-pm-domain";
    			#power-domain-cells = <2>;
    		k3_clks: clock-controller {
    			compatible = "ti,k2g-sci-clk";
    			#clock-cells = <2>;
    		k3_reset: reset-controller {
    			compatible = "ti,sci-reset";
    			#reset-cells = <2>;
    	chipid@43000014 {
    		compatible = "ti,am654-chipid";
    		reg = <0x00 0x43000014 0x00 0x4>;
    	mcu_ram: sram@41c00000 {
    		compatible = "mmio-sram";
    		reg = <0x00 0x41c00000 0x00 0x100000>;
    		ranges = <0x00 0x00 0x41c00000 0x100000>;
    		#size-cells = <1>;
    	wkup_pmx0: pinctrl@4301c000 {
    		compatible = "pinctrl-single";
    		/* Proxy 0 addressing */
    		reg = <0x00 0x4301c000 0x00 0x178>;
    		#pinctrl-cells = <1>;
    		pinctrl-single,register-width = <32>;
    		pinctrl-single,function-mask = <0xffffffff>;
    	wkup_gpio_intr: interrupt-controller@42200000 {
    		compatible = "ti,sci-intr";
    		reg = <0x00 0x42200000 0x00 0x400>;
    		ti,intr-trigger-type = <1>;
    		interrupt-controller;
    		#interrupt-cells = <1>;
    		ti,sci = <&sms>;
    		ti,sci-dev-id = <125>;
    		ti,interrupt-ranges = <16 928 16>;
    	mcu_conf: syscon@40f00000 {
    		compatible = "syscon", "simple-mfd";
    		reg = <0x0 0x40f00000 0x0 0x20000>;
    		#size-cells = <1>;
    		ranges = <0x0 0x0 0x40f00000 0x20000>;
    		phy_gmii_sel: phy@4040 {
    			compatible = "ti,am654-phy-gmii-sel";
    			reg = <0x4040 0x4>;
    			#phy-cells = <1>;
    	wkup_uart0: serial@42300000 {
    		compatible = "ti,j721e-uart", "ti,am654-uart";
    		reg = <0x00 0x42300000 0x00 0x200>;
    		interrupts = <GIC_SPI 897 IRQ_TYPE_LEVEL_HIGH>;
    		current-speed = <115200>;
    		clocks = <&k3_clks 359 3>;
    		clock-names = "fclk";
    		power-domains = <&k3_pds 359 TI_SCI_PD_EXCLUSIVE>;
    	mcu_uart0: serial@40a00000 {
    		reg = <0x00 0x40a00000 0x00 0x200>;
    		interrupts = <GIC_SPI 846 IRQ_TYPE_LEVEL_HIGH>;
    		clocks = <&k3_clks 149 3>;
    		power-domains = <&k3_pds 149 TI_SCI_PD_EXCLUSIVE>;
    	wkup_gpio0: gpio@42110000 {
    		compatible = "ti,j721e-gpio", "ti,keystone-gpio";
    		reg = <0x00 0x42110000 0x00 0x100>;
    		gpio-controller;
    		#gpio-cells = <2>;
    		interrupt-parent = <&main_gpio_intr>;
    		interrupts = <103>, <104>, <105>, <106>, <107>, <108>;
    		#interrupt-cells = <2>;
    		ti,ngpio = <89>;
    		ti,davinci-gpio-unbanked = <0>;
    		power-domains = <&k3_pds 115 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 115 0>;
    		clock-names = "gpio";
    	wkup_gpio1: gpio@42100000 {
    		reg = <0x00 0x42100000 0x00 0x100>;
    		gpio-controller;
    		#gpio-cells = <2>;
    		interrupts = <112>, <113>, <114>, <115>, <116>, <117>;
    		ti,ngpio = <89>;
    		power-domains = <&k3_pds 116 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 116 0>;
    	wkup_i2c0: i2c@42120000 {
    		compatible = "ti,j721e-i2c", "ti,omap4-i2c";
    		reg = <0x00 0x42120000 0x00 0x100>;
    		interrupts = <GIC_SPI 896 IRQ_TYPE_LEVEL_HIGH>;
    		#size-cells = <0>;
    		clocks = <&k3_clks 223 1>;
    		clock-names = "fck";
    		power-domains = <&k3_pds 223 TI_SCI_PD_EXCLUSIVE>;
    	mcu_i2c0: i2c@40b00000 {
    		reg = <0x00 0x40b00000 0x00 0x100>;
    		interrupts = <GIC_SPI 852 IRQ_TYPE_LEVEL_HIGH>;
    		#size-cells = <0>;
    		clocks = <&k3_clks 221 1>;
    		power-domains = <&k3_pds 221 TI_SCI_PD_EXCLUSIVE>;
    	mcu_i2c1: i2c@40b10000 {
    		reg = <0x00 0x40b10000 0x00 0x100>;
    		interrupts = <GIC_SPI 853 IRQ_TYPE_LEVEL_HIGH>;
    		#size-cells = <0>;
    		clocks = <&k3_clks 222 1>;
    		power-domains = <&k3_pds 222 TI_SCI_PD_EXCLUSIVE>;
    	mcu_mcan0: can@40528000 {
    		compatible = "bosch,m_can";
    		reg = <0x00 0x40528000 0x00 0x200>,
    		      <0x00 0x40500000 0x00 0x8000>;
    		reg-names = "m_can", "message_ram";
    		power-domains = <&k3_pds 207 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 207 0>, <&k3_clks 207 1>;
    		clock-names = "hclk", "cclk";
    		interrupts = <GIC_SPI 832 IRQ_TYPE_LEVEL_HIGH>,
    			     <GIC_SPI 833 IRQ_TYPE_LEVEL_HIGH>;
    		interrupt-names = "int0", "int1";
    		bosch,mram-cfg = <0x0 128 64 64 64 64 32 32>;
    	mcu_mcan1: can@40568000 {
    		reg = <0x00 0x40568000 0x00 0x200>,
    		      <0x00 0x40540000 0x00 0x8000>;
    		power-domains = <&k3_pds 208 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 208 0>, <&k3_clks 208 1>;
    		interrupts = <GIC_SPI 835 IRQ_TYPE_LEVEL_HIGH>,
    			     <GIC_SPI 836 IRQ_TYPE_LEVEL_HIGH>;
    	mcu_navss: bus@28380000{
    		compatible = "simple-mfd";
    		#size-cells = <2>;
    		ranges = <0x00 0x28380000 0x00 0x28380000 0x00 0x03880000>;
    		dma-coherent;
    		dma-ranges;
    		ti,sci-dev-id = <267>;
    		mcu_ringacc: ringacc@2b800000 {
    			compatible = "ti,am654-navss-ringacc";
    			      <0x0 0x2a500000 0x0 0x40000>;
    			reg-names = "rt", "fifos", "proxy_gcfg", "proxy_target";
    			ti,num-rings = <286>;
    			ti,sci-rm-range-gp-rings = <0x1>;
    			ti,sci = <&sms>;
    			ti,sci-dev-id = <272>;
    			msi-parent = <&main_udmass_inta>;
    		mcu_udmap: dma-controller@285c0000 {
    			compatible = "ti,j721e-navss-mcu-udmap";
    			      <0x0 0x2aa00000 0x0 0x40000>;
    			reg-names = "gcfg", "rchanrt", "tchanrt";
    			#dma-cells = <1>;
    			ti,sci = <&sms>;
    			ti,sci-dev-id = <273>;
    			ti,ringacc = <&mcu_ringacc>;
    			ti,sci-rm-range-tchan = <0x0d>, /* TX_CHAN */
    						<0x0f>; /* TX_HCHAN */
    			ti,sci-rm-range-rchan = <0x0a>, /* RX_CHAN */
    						<0x0b>; /* RX_HCHAN */
    			ti,sci-rm-range-rflow = <0x00>; /* GP RFLOW */
    	mcu_cpsw: ethernet@46000000 {
    		compatible = "ti,j721e-cpsw-nuss";
    		#size-cells = <2>;
    		reg = <0x0 0x46000000 0x0 0x200000>;
    		reg-names = "cpsw_nuss";
    		ranges = <0x0 0x0 0x0 0x46000000 0x0 0x200000>;
    		dma-coherent;
    		clocks = <&k3_clks 29 28>;
    		power-domains = <&k3_pds 29 TI_SCI_PD_EXCLUSIVE>;
    		dmas = <&mcu_udmap 0xf000>,
    		       <&mcu_udmap 0xf001>,
    		       <&mcu_udmap 0xf002>,
    		       <&mcu_udmap 0xf003>,
    		       <&mcu_udmap 0xf004>,
    		       <&mcu_udmap 0xf005>,
    		       <&mcu_udmap 0xf006>,
    		       <&mcu_udmap 0xf007>,
    		       <&mcu_udmap 0x7000>;
    		dma-names = "tx0", "tx1", "tx2", "tx3",
    			    "tx4", "tx5", "tx6", "tx7",
    			    "rx";
    		ethernet-ports {
    			#size-cells = <0>;
    			cpsw_port1: port@1 {
    				reg = <1>;
    				ti,mac-only;
    				label = "port1";
    				ti,syscon-efuse = <&mcu_conf 0x200>;
    				phys = <&phy_gmii_sel 1>;
    		davinci_mdio: mdio@f00 {
    			compatible = "ti,cpsw-mdio","ti,davinci_mdio";
    			reg = <0x0 0xf00 0x0 0x100>;
    			#size-cells = <0>;
    			bus_freq = <1000000>;
    		cpts@3d000 {
    			compatible = "ti,am65-cpts";
    			reg = <0x0 0x3d000 0x0 0x400>;
    			clocks = <&k3_clks 29 3>;
    			clock-names = "cpts";
    			interrupts-extended = <&gic500 GIC_SPI 858 IRQ_TYPE_LEVEL_HIGH>;
    			interrupt-names = "cpts";
    			ti,cpts-ext-ts-inputs = <4>;
    			ti,cpts-periodic-outputs = <2>;
    	fss: syscon@47000000 {
    		reg = <0x0 0x47000000 0x0 0x100>;
    		#size-cells = <2>;
    		ranges;
    		ospi0: spi@47040000 {
    			compatible = "ti,am654-ospi", "cdns,qspi-nor";
    			reg = <0x00 0x47040000 0x00 0x100>,
    			      <0x5 0x0000000 0x1 0x0000000>;
    			interrupts = <GIC_SPI 840 IRQ_TYPE_LEVEL_HIGH>;
    			cdns,fifo-depth = <256>;
    			cdns,fifo-width = <4>;
    			cdns,trigger-address = <0x0>;
    			clocks = <&k3_clks 109 5>;
    			assigned-clocks = <&k3_clks 109 5>;
    			assigned-clock-parents = <&k3_clks 109 7>;
    			assigned-clock-rates = <166666666>;
    			power-domains = <&k3_pds 109 TI_SCI_PD_EXCLUSIVE>;
    			#size-cells = <0>;
    		ospi1: spi@47050000 {
    			reg = <0x00 0x47050000 0x00 0x100>,
    			      <0x7 0x0000000 0x1 0x0000000>;
    			interrupts = <GIC_SPI 841 IRQ_TYPE_LEVEL_HIGH>;
    			clocks = <&k3_clks 110 5>;
    			power-domains = <&k3_pds 110 TI_SCI_PD_EXCLUSIVE>;
    			#size-cells = <0>;
    	mcu_r5fss0: r5fss@41000000 {
    		compatible = "ti,j721s2-r5fss";
    		ti,cluster-mode = <1>;
    		#size-cells = <1>;
    		ranges = <0x41000000 0x00 0x41000000 0x20000>,
    			 <0x41400000 0x00 0x41400000 0x20000>;
    		power-domains = <&k3_pds 283 TI_SCI_PD_EXCLUSIVE>;
    		mcu_r5fss0_core0: r5f@41000000 {
    			compatible = "ti,j721s2-r5f";
    			reg = <0x41000000 0x00010000>,
    			      <0x41010000 0x00010000>;
    			reg-names = "atcm", "btcm";
    			ti,sci = <&sms>;
    			ti,sci-dev-id = <284>;
    			ti,sci-proc-ids = <0x01 0xff>;
    			resets = <&k3_reset 284 1>;
    			firmware-name = "j7-mcu-r5f0_0-fw";
    			ti,atcm-enable = <1>;
    			ti,btcm-enable = <1>;
    			ti,loczrama = <1>;
    		mcu_r5fss0_core1: r5f@41400000 {
    			reg = <0x41400000 0x00010000>,
    			      <0x41410000 0x00010000>;
    			ti,sci = <&sms>;
    			ti,sci-dev-id = <285>;
    			ti,sci-proc-ids = <0x02 0xff>;
    			resets = <&k3_reset 285 1>;
    			firmware-name = "j7-mcu-r5f0_1-fw";
    			ti,loczrama = <1>;
     * Device Tree Source for J721S2 SoC Family Main Domain peripherals
    #include <dt-bindings/mux/mux.h>
    #include <dt-bindings/mux/ti-serdes.h>
    	serdes_refclk: serdes-refclk {
    		#clock-cells = <0>;
    &cbass_main {
    	msmc_ram: sram@70000000 {
    		reg = <0x0 0x70000000 0x0 0x400000>;
    		#size-cells = <1>;
    		ranges = <0x0 0x0 0x70000000 0x400000>;
    		atf-sram@0 {
    			reg = <0x0 0x20000>;
    		tifs-sram@1f0000 {
    			reg = <0x1f0000 0x10000>;
    		l3cache-sram@200000 {
    			reg = <0x200000 0x200000>;
    	scm_conf: scm-conf@104000 {
    		compatible = "ti,j721e-system-controller", "syscon", "simple-mfd";
    		reg = <0x00 0x00104000 0x00 0x18000>;
    		#size-cells = <1>;
    		ranges = <0x00 0x00 0x00104000 0x18000>;
    		serdes_ln_ctrl: mux-controller0 {
    			compatible = "mmio-mux";
    			#mux-control-cells = <1>;
    			mux-reg-masks = <0x80 0x3>, <0x84 0x3>, /* SERDES0 lane0/1 select */
    					<0x88 0x3>, <0x8c 0x3>; /* SERDES0 lane2/3 select */
    		usb_serdes_mux: mux-controller1 {
    			mux-reg-masks = <0x0 0x8000000>; /* USB0 to SERDES0 lane 1/3 mux */
    	gic500: interrupt-controller@1800000 {
    		compatible = "arm,gic-v3";
    		#size-cells = <2>;
    		ranges;
    		#interrupt-cells = <3>;
    		reg = <0x00 0x01800000 0x00 0x200000>, /* GICD */
    		      <0x00 0x01900000 0x00 0x100000>; /* GICR */
    		/* vcpumntirq: virtual CPU interface maintenance interrupt */
    		interrupts = <GIC_PPI 9 IRQ_TYPE_LEVEL_HIGH>;
    		gic_its: msi-controller@1820000 {
    			compatible = "arm,gic-v3-its";
    			reg = <0x00 0x01820000 0x00 0x10000>;
    			socionext,synquacer-pre-its = <0x1000000 0x400000>;
    			msi-controller;
    			#msi-cells = <1>;
    	main_cpsw: ethernet@c200000 {
    		#size-cells = <2>;
    		reg = <0x0 0xc200000 0x0 0x200000>;
    		ranges = <0x0 0x0 0x0 0xc200000 0x0 0x200000>;
    		dma-coherent;
    		clocks = <&k3_clks 28 28>;
    		power-domains = <&k3_pds 28 TI_SCI_PD_EXCLUSIVE>;
    		dmas = <&main_udmap 0xc640>,
    		       <&main_udmap 0xc641>,
    		       <&main_udmap 0xc642>,
    		       <&main_udmap 0xc643>,
    		       <&main_udmap 0xc644>,
    		       <&main_udmap 0xc645>,
    		       <&main_udmap 0xc646>,
    		       <&main_udmap 0xc647>,
    		       <&main_udmap 0x4640>;
    			    "rx";
    		ethernet-ports {
    			#size-cells = <0>;
    			main_cpsw_port1: port@1 {
    				reg = <1>;
    				ti,mac-only;
    				label = "port1";
    		main_davinci_mdio: mdio@f00 {
    			#size-cells = <0>;
    		cpts@3d000 {
    			clocks = <&k3_clks 28 3>;
    			interrupts-extended = <&gic500 GIC_SPI 21 IRQ_TYPE_LEVEL_HIGH>;
    	main_gpio_intr: interrupt-controller@a00000 {
    		reg = <0x00 0x00a00000 0x00 0x800>;
    		ti,sci = <&sms>;
    		ti,sci-dev-id = <148>;
    		ti,interrupt-ranges = <8 360 56>;
    	main_pmx0: pinctrl@11c000 {
    		reg = <0x0 0x11c000 0x0 0x120>;
    	main_uart0: serial@2800000 {
    		reg = <0x00 0x02800000 0x00 0x200>;
    		interrupts = <GIC_SPI 192 IRQ_TYPE_LEVEL_HIGH>;
    		clocks = <&k3_clks 146 3>;
    		power-domains = <&k3_pds 146 TI_SCI_PD_EXCLUSIVE>;
    	main_uart1: serial@2810000 {
    		reg = <0x00 0x02810000 0x00 0x200>;
    		interrupts = <GIC_SPI 193 IRQ_TYPE_LEVEL_HIGH>;
    		clocks = <&k3_clks 350 3>;
    		power-domains = <&k3_pds 350 TI_SCI_PD_EXCLUSIVE>;
    	main_uart2: serial@2820000 {
    		reg = <0x00 0x02820000 0x00 0x200>;
    		interrupts = <GIC_SPI 194 IRQ_TYPE_LEVEL_HIGH>;
    		clocks = <&k3_clks 351 3>;
    		power-domains = <&k3_pds 351 TI_SCI_PD_EXCLUSIVE>;
    	main_uart3: serial@2830000 {
    		reg = <0x00 0x02830000 0x00 0x200>;
    		interrupts = <GIC_SPI 195 IRQ_TYPE_LEVEL_HIGH>;
    		clocks = <&k3_clks 352 3>;
    		power-domains = <&k3_pds 352 TI_SCI_PD_EXCLUSIVE>;
    	main_uart4: serial@2840000 {
    		reg = <0x00 0x02840000 0x00 0x200>;
    		interrupts = <GIC_SPI 196 IRQ_TYPE_LEVEL_HIGH>;
    		clocks = <&k3_clks 353 3>;
    		power-domains = <&k3_pds 353 TI_SCI_PD_EXCLUSIVE>;
    	main_uart5: serial@2850000 {
    		reg = <0x00 0x02850000 0x00 0x200>;
    		interrupts = <GIC_SPI 197 IRQ_TYPE_LEVEL_HIGH>;
    		clocks = <&k3_clks 354 3>;
    		power-domains = <&k3_pds 354 TI_SCI_PD_EXCLUSIVE>;
    	main_uart6: serial@2860000 {
    		reg = <0x00 0x02860000 0x00 0x200>;
    		interrupts = <GIC_SPI 198 IRQ_TYPE_LEVEL_HIGH>;
    		clocks = <&k3_clks 355 3>;
    		power-domains = <&k3_pds 355 TI_SCI_PD_EXCLUSIVE>;
    	main_uart7: serial@2870000 {
    		reg = <0x00 0x02870000 0x00 0x200>;
    		interrupts = <GIC_SPI 199 IRQ_TYPE_LEVEL_HIGH>;
    		clocks = <&k3_clks 356 3>;
    		power-domains = <&k3_pds 356 TI_SCI_PD_EXCLUSIVE>;
    	main_uart8: serial@2880000 {
    		reg = <0x00 0x02880000 0x00 0x200>;
    		interrupts = <GIC_SPI 248 IRQ_TYPE_LEVEL_HIGH>;
    		clocks = <&k3_clks 357 3>;
    		power-domains = <&k3_pds 357 TI_SCI_PD_EXCLUSIVE>;
    	main_uart9: serial@2890000 {
    		reg = <0x00 0x02890000 0x00 0x200>;
    		interrupts = <GIC_SPI 249 IRQ_TYPE_LEVEL_HIGH>;
    		clocks = <&k3_clks 358 3>;
    		power-domains = <&k3_pds 358 TI_SCI_PD_EXCLUSIVE>;
    	main_gpio0: gpio@600000 {
    		reg = <0x00 0x00600000 0x00 0x100>;
    		gpio-controller;
    		#gpio-cells = <2>;
    		interrupts = <145>, <146>, <147>, <148>, <149>;
    		ti,ngpio = <66>;
    		power-domains = <&k3_pds 111 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 111 0>;
    	main_gpio2: gpio@610000 {
    		reg = <0x00 0x00610000 0x00 0x100>;
    		gpio-controller;
    		#gpio-cells = <2>;
    		interrupts = <154>, <155>, <156>, <157>, <158>;
    		ti,ngpio = <66>;
    		power-domains = <&k3_pds 112 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 112 0>;
    	main_gpio4: gpio@620000 {
    		reg = <0x00 0x00620000 0x00 0x100>;
    		gpio-controller;
    		#gpio-cells = <2>;
    		interrupts = <163>, <164>, <165>, <166>, <167>;
    		ti,ngpio = <66>;
    		power-domains = <&k3_pds 113 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 113 0>;
    	main_gpio6: gpio@630000 {
    		reg = <0x00 0x00630000 0x00 0x100>;
    		gpio-controller;
    		#gpio-cells = <2>;
    		interrupts = <172>, <173>, <174>, <175>, <176>;
    		ti,ngpio = <66>;
    		power-domains = <&k3_pds 114 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 114 0>;
    	main_i2c0: i2c@2000000 {
    		reg = <0x00 0x02000000 0x00 0x100>;
    		interrupts = <GIC_SPI 200 IRQ_TYPE_LEVEL_HIGH>;
    		#size-cells = <0>;
    		clocks = <&k3_clks 214 1>;
    		power-domains = <&k3_pds 214 TI_SCI_PD_EXCLUSIVE>;
    	main_i2c1: i2c@2010000 {
    		reg = <0x00 0x02010000 0x00 0x100>;
    		interrupts = <GIC_SPI 201 IRQ_TYPE_LEVEL_HIGH>;
    		#size-cells = <0>;
    		clocks = <&k3_clks 215 1>;
    		power-domains = <&k3_pds 215 TI_SCI_PD_EXCLUSIVE>;
    	main_i2c2: i2c@2020000 {
    		reg = <0x00 0x02020000 0x00 0x100>;
    		interrupts = <GIC_SPI 202 IRQ_TYPE_LEVEL_HIGH>;
    		#size-cells = <0>;
    		clocks = <&k3_clks 216 1>;
    		power-domains = <&k3_pds 216 TI_SCI_PD_EXCLUSIVE>;
    	main_i2c3: i2c@2030000 {
    		reg = <0x00 0x02030000 0x00 0x100>;
    		interrupts = <GIC_SPI 203 IRQ_TYPE_LEVEL_HIGH>;
    		#size-cells = <0>;
    		clocks = <&k3_clks 217 1>;
    		power-domains = <&k3_pds 217 TI_SCI_PD_EXCLUSIVE>;
    	main_i2c4: i2c@2040000 {
    		reg = <0x00 0x02040000 0x00 0x100>;
    		interrupts = <GIC_SPI 204 IRQ_TYPE_LEVEL_HIGH>;
    		#size-cells = <0>;
    		clocks = <&k3_clks 218 1>;
    		power-domains = <&k3_pds 218 TI_SCI_PD_EXCLUSIVE>;
    	main_i2c5: i2c@2050000 {
    		reg = <0x00 0x02050000 0x00 0x100>;
    		interrupts = <GIC_SPI 205 IRQ_TYPE_LEVEL_HIGH>;
    		#size-cells = <0>;
    		clocks = <&k3_clks 219 1>;
    		power-domains = <&k3_pds 219 TI_SCI_PD_EXCLUSIVE>;
    	main_i2c6: i2c@2060000 {
    		reg = <0x00 0x02060000 0x00 0x100>;
    		interrupts = <GIC_SPI 206 IRQ_TYPE_LEVEL_HIGH>;
    		#size-cells = <0>;
    		clocks = <&k3_clks 220 1>;
    		power-domains = <&k3_pds 220 TI_SCI_PD_EXCLUSIVE>;
    	main_spi0: spi@2100000 {
    		compatible = "ti,am654-mcspi", "ti,omap4-mcspi";
    		reg = <0x00 0x2100000 0x00 0x400>;
    		interrupts = <GIC_SPI 184 IRQ_TYPE_LEVEL_HIGH>;
    		#size-cells = <0>;
    		power-domains = <&k3_pds 339 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 339 0>;
    	main_sdhci0: mmc@4f80000 {
    		compatible = "ti,j721e-sdhci-8bit";
    		reg = <0x00 0x04f80000 0x00 0x1000>,
    		      <0x00 0x04f88000 0x00 0x400>;
    		interrupts = <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>;
    		power-domains = <&k3_pds 98 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 98 7>, <&k3_clks 98 1>;
    		clock-names =  "clk_ahb", "clk_xin";
    		assigned-clocks = <&k3_clks 98 1>;
    		assigned-clock-parents = <&k3_clks 98 2>;
    		bus-width = <8>;
    		ti,otap-del-sel-legacy = <0x0>;
    		ti,otap-del-sel-mmc-hs = <0x0>;
    	//	ti,otap-del-sel-ddr52 = <0x6>;
    	//	ti,otap-del-sel-hs200 = <0x8>;
    	//	ti,otap-del-sel-hs400 = <0x5>;
    		ti,itap-del-sel-legacy = <0x10>;
    		ti,itap-del-sel-mmc-hs = <0xa>;
    		ti,strobe-sel = <0x77>;
    		ti,clkbuf-sel = <0x7>;
    		ti,trm-icp = <0x8>;
    	//	mmc-ddr-1_8v;
    	//	mmc-hs200-1_8v;
    	//	mmc-hs400-1_8v;
    		dma-coherent;
    	main_sdhci1: mmc@4fb0000 {
    		compatible = "ti,j721e-sdhci-4bit";
    		reg = <0x00 0x04fb0000 0x00 0x1000>,
    		      <0x00 0x04fb8000 0x00 0x400>;
    		interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>;
    		power-domains = <&k3_pds 99 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 99 8>, <&k3_clks 99 1>;
    		assigned-clocks = <&k3_clks 99 1>;
    		assigned-clock-parents = <&k3_clks 99 2>;
    		bus-width = <4>;
    		ti,otap-del-sel-sd-hs = <0x0>;
    		ti,otap-del-sel-sdr12 = <0xf>;
    		ti,otap-del-sel-sdr25 = <0xf>;
    		ti,otap-del-sel-sdr50 = <0xc>;
    		ti,otap-del-sel-sdr104 = <0x5>;
    		ti,otap-del-sel-ddr50 = <0xc>;
    		ti,itap-del-sel-legacy = <0x0>;
    		ti,itap-del-sel-sd-hs = <0x0>;
    		ti,itap-del-sel-sdr12 = <0x0>;
    		ti,itap-del-sel-sdr25 = <0x0>;
    		ti,trm-icp = <0x8>;
    		dma-coherent;
    		/* Masking support for SDR104 capability */
    		sdhci-caps-mask = <0x00000003 0x00000000>;
    	main_navss: bus@30000000 {
    		#size-cells = <2>;
    		ranges = <0x00 0x30000000 0x00 0x30000000 0x00 0x0c400000>;
    		ti,sci-dev-id = <224>;
    		dma-coherent;
    		dma-ranges;
    		main_navss_intr: interrupt-controller@310e0000 {
    			reg = <0x00 0x310e0000 0x00 0x4000>;
    			ti,intr-trigger-type = <4>;
    			ti,sci = <&sms>;
    			ti,sci-dev-id = <227>;
    			ti,interrupt-ranges = <0 64 64>,
    					      <64 448 64>,
    					      <128 672 64>;
    		main_udmass_inta: msi-controller@33d00000 {
    			compatible = "ti,sci-inta";
    			reg = <0x00 0x33d00000 0x00 0x100000>;
    			#interrupt-cells = <0>;
    			interrupt-parent = <&main_navss_intr>;
    			msi-controller;
    			ti,sci = <&sms>;
    			ti,sci-dev-id = <265>;
    			ti,interrupt-ranges = <0 0 256>;
    		secure_proxy_main: mailbox@32c00000 {
    			#mbox-cells = <1>;
    			reg-names = "target_data", "rt", "scfg";
    			reg = <0x00 0x32c00000 0x00 0x100000>,
    			      <0x00 0x32400000 0x00 0x100000>,
    			      <0x00 0x32800000 0x00 0x100000>;
    			interrupt-names = "rx_011";
    			interrupts = <GIC_SPI 37 IRQ_TYPE_LEVEL_HIGH>;
    		hwspinlock: spinlock@30e00000 {
    			compatible = "ti,am654-hwspinlock";
    			reg = <0x00 0x30e00000 0x00 0x1000>;
    			#hwlock-cells = <1>;
    		mailbox0_cluster0: mailbox@31f80000 {
    			compatible = "ti,am654-mailbox";
    			reg = <0x00 0x31f80000 0x00 0x200>;
    			#mbox-cells = <1>;
    			ti,mbox-num-users = <4>;
    			ti,mbox-num-fifos = <16>;
    		mailbox0_cluster1: mailbox@31f81000 {
    			reg = <0x00 0x31f81000 0x00 0x200>;
    			#mbox-cells = <1>;
    		mailbox0_cluster2: mailbox@31f82000 {
    			reg = <0x00 0x31f82000 0x00 0x200>;
    			#mbox-cells = <1>;
    		mailbox0_cluster3: mailbox@31f83000 {
    			reg = <0x00 0x31f83000 0x00 0x200>;
    			#mbox-cells = <1>;
    		mailbox0_cluster4: mailbox@31f84000 {
    			reg = <0x00 0x31f84000 0x00 0x200>;
    			#mbox-cells = <1>;
    		mailbox0_cluster5: mailbox@31f85000 {
    			reg = <0x00 0x31f85000 0x00 0x200>;
    			#mbox-cells = <1>;
    		mailbox0_cluster6: mailbox@31f86000 {
    			reg = <0x00 0x31f86000 0x00 0x200>;
    			#mbox-cells = <1>;
    		mailbox0_cluster7: mailbox@31f87000 {
    			reg = <0x00 0x31f87000 0x00 0x200>;
    			#mbox-cells = <1>;
    		mailbox0_cluster8: mailbox@31f88000 {
    			reg = <0x00 0x31f88000 0x00 0x200>;
    			#mbox-cells = <1>;
    		mailbox0_cluster9: mailbox@31f89000 {
    			reg = <0x00 0x31f89000 0x00 0x200>;
    			#mbox-cells = <1>;
    		mailbox0_cluster10: mailbox@31f8a000 {
    			reg = <0x00 0x31f8a000 0x00 0x200>;
    			#mbox-cells = <1>;
    		mailbox0_cluster11: mailbox@31f8b000 {
    			reg = <0x00 0x31f8b000 0x00 0x200>;
    			#mbox-cells = <1>;
    		mailbox1_cluster0: mailbox@31f90000 {
    			reg = <0x00 0x31f90000 0x00 0x200>;
    			#mbox-cells = <1>;
    		mailbox1_cluster1: mailbox@31f91000 {
    			reg = <0x00 0x31f91000 0x00 0x200>;
    			#mbox-cells = <1>;
    		mailbox1_cluster2: mailbox@31f92000 {
    			reg = <0x00 0x31f92000 0x00 0x200>;
    			#mbox-cells = <1>;
    		mailbox1_cluster3: mailbox@31f93000 {
    			reg = <0x00 0x31f93000 0x00 0x200>;
    			#mbox-cells = <1>;
    		mailbox1_cluster4: mailbox@31f94000 {
    			reg = <0x00 0x31f94000 0x00 0x200>;
    			#mbox-cells = <1>;
    		mailbox1_cluster5: mailbox@31f95000 {
    			reg = <0x00 0x31f95000 0x00 0x200>;
    			#mbox-cells = <1>;
    		mailbox1_cluster6: mailbox@31f96000 {
    			reg = <0x00 0x31f96000 0x00 0x200>;
    			#mbox-cells = <1>;
    		mailbox1_cluster7: mailbox@31f97000 {
    			reg = <0x00 0x31f97000 0x00 0x200>;
    			#mbox-cells = <1>;
    		mailbox1_cluster8: mailbox@31f98000 {
    			reg = <0x00 0x31f98000 0x00 0x200>;
    			#mbox-cells = <1>;
    		mailbox1_cluster9: mailbox@31f99000 {
    			reg = <0x00 0x31f99000 0x00 0x200>;
    			#mbox-cells = <1>;
    		mailbox1_cluster10: mailbox@31f9a000 {
    			reg = <0x00 0x31f9a000 0x00 0x200>;
    			#mbox-cells = <1>;
    		mailbox1_cluster11: mailbox@31f9b000 {
    			reg = <0x00 0x31f9b000 0x00 0x200>;
    			#mbox-cells = <1>;
    		main_ringacc: ringacc@3c000000 {
    			reg = <0x0 0x3c000000 0x0 0x400000>,
    			      <0x0 0x38000000 0x0 0x400000>,
    			      <0x0 0x31120000 0x0 0x100>,
    			      <0x0 0x33000000 0x0 0x40000>;
    			ti,num-rings = <1024>;
    			ti,sci = <&sms>;
    			ti,sci-dev-id = <259>;
    		main_udmap: dma-controller@31150000 {
    			compatible = "ti,j721e-navss-main-udmap";
    			reg = <0x0 0x31150000 0x0 0x100>,
    			      <0x0 0x34000000 0x0 0x80000>,
    			      <0x0 0x35000000 0x0 0x200000>;
    			#dma-cells = <1>;
    			ti,sci = <&sms>;
    			ti,sci-dev-id = <263>;
    			ti,ringacc = <&main_ringacc>;
    						<0x0f>, /* TX_HCHAN */
    						<0x10>; /* TX_UHCHAN */
    						<0x0b>, /* RX_HCHAN */
    						<0x0c>; /* RX_UHCHAN */
    		cpts@310d0000 {
    			compatible = "ti,j721e-cpts";
    			reg = <0x0 0x310d0000 0x0 0x400>;
    			reg-names = "cpts";
    			clocks = <&k3_clks 226 5>;
    			interrupts-extended = <&main_navss_intr 391>;
    			ti,cpts-periodic-outputs = <6>;
    			ti,cpts-ext-ts-inputs = <8>;
    	usbss0: cdns-usb@4104000 {
    		compatible = "ti,j721e-usb";
    		reg = <0x00 0x04104000 0x00 0x100>;
    		clocks = <&k3_clks 360 16>, <&k3_clks 360 15>;
    		clock-names = "ref", "lpm";
    		assigned-clocks = <&k3_clks 360 16>; /* USB2_REFCLK */
    		assigned-clock-parents = <&k3_clks 360 17>;
    		power-domains = <&k3_pds 360 TI_SCI_PD_EXCLUSIVE>;
    		#size-cells = <2>;
    		ranges;
    		dma-coherent;
    		usb0: usb@6000000 {
    			compatible = "cdns,usb3";
    			reg = <0x00 0x06000000 0x00 0x10000>,
    			      <0x00 0x06010000 0x00 0x10000>,
    			      <0x00 0x06020000 0x00 0x10000>;
    			reg-names = "otg", "xhci", "dev";
    			interrupts = <GIC_SPI 96 IRQ_TYPE_LEVEL_HIGH>,
    				     <GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH>,
    				     <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>;
    			 interrupt-names = "host", "peripheral", "otg";
    			 maximum-speed = "super-speed";
    			 dr_mode = "otg";
    	serdes_wiz0: wiz@5060000 {
    		compatible = "ti,j721e-wiz-10g";
    		#size-cells = <1>;
    		power-domains = <&k3_pds 365 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 365 0>, <&k3_clks 365 3>, <&serdes_refclk>;
    		clock-names = "fck", "core_ref_clk", "ext_ref_clk";
    		num-lanes = <4>;
    		#reset-cells = <1>;
    		ranges = <0x5060000 0x0 0x5060000 0x10000>;
    		assigned-clocks = <&k3_clks 365 3>;
    		assigned-clock-parents = <&k3_clks 365 7>;
    		wiz0_pll0_refclk: pll0-refclk {
    			clocks = <&k3_clks 365 3>, <&serdes_refclk>;
    			clock-output-names = "wiz0_pll0_refclk";
    			#clock-cells = <0>;
    			assigned-clocks = <&wiz0_pll0_refclk>;
    			assigned-clock-parents = <&k3_clks 365 3>;
    		wiz0_pll1_refclk: pll1-refclk {
    			clock-output-names = "wiz0_pll1_refclk";
    			#clock-cells = <0>;
    			assigned-clocks = <&wiz0_pll1_refclk>;
    		wiz0_refclk_dig: refclk-dig {
    			clock-output-names = "wiz0_refclk_dig";
    			#clock-cells = <0>;
    			assigned-clocks = <&wiz0_refclk_dig>;
    		wiz0_cmn_refclk_dig_div: cmn-refclk-dig-div {
    			#clock-cells = <0>;
    		serdes0: serdes@5060000 {
    			compatible = "ti,j721e-serdes-10g";
    			reg = <0x05060000 0x00010000>;
    			reg-names = "torrent_phy";
    			resets = <&serdes_wiz0 0>;
    			reset-names = "torrent_reset";
    			clock-names = "refclk";
    			#size-cells = <0>;
    	pcie1_rc: pcie@2910000 {
    		compatible = "ti,j7200-pcie-host", "ti,j721e-pcie-host";
    		reg = <0x00 0x02910000 0x00 0x1000>,
    		      <0x00 0x02917000 0x00 0x400>,
    		      <0x00 0x0d800000 0x00 0x00800000>,
    		      <0x00 0x18000000 0x00 0x00001000>;
    		reg-names = "intd_cfg", "user_cfg", "reg", "cfg";
    		interrupt-names = "link_state";
    		interrupts = <GIC_SPI 330 IRQ_TYPE_EDGE_RISING>;
    		device_type = "pci";
    		ti,syscon-pcie-ctrl = <&scm_conf 0x074>;
    		max-link-speed = <3>;
    		num-lanes = <4>;
    		power-domains = <&k3_pds 276 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 276 41>;
    		#address-cells = <3>;
    		#size-cells = <2>;
    		bus-range = <0x0 0xff>;
    		vendor-id = <0x104c>;
    		device-id = <0xb013>;
    		msi-map = <0x0 &gic_its 0x0 0x10000>;
    		dma-coherent;
    		ranges = <0x01000000 0x0 0x18001000  0x00 0x18001000  0x0 0x0010000>,
    			 <0x02000000 0x0 0x18011000  0x00 0x18011000  0x0 0x7fef000>;
    		dma-ranges = <0x02000000 0x0 0x0 0x0 0x0 0x10000 0x0>;
    		interrupt-map-mask = <0 0 0 7>;
    		interrupt-map = <0 0 0 1 &pcie1_intc 0>, /* INT A */
    				<0 0 0 2 &pcie1_intc 0>, /* INT B */
    				<0 0 0 3 &pcie1_intc 0>, /* INT C */
    				<0 0 0 4 &pcie1_intc 0>; /* INT D */
    		pcie1_intc: interrupt-controller {
    			interrupts = <GIC_SPI 324 IRQ_TYPE_EDGE_RISING>;
    	pcie1_ep: pcie-ep@2910000 {
    		compatible = "ti,j7200-pcie-ep", "ti,j721e-pcie-ep";
    		      <0x00 0x18000000 0x00 0x08000000>;
    		reg-names = "intd_cfg", "user_cfg", "reg", "mem";
    		num-lanes = <4>;
    		max-functions = /bits/ 8 <6>;
    		max-virtual-functions = /bits/ 8 <4 4 4 4 0 0>;
    		dma-coherent;
    	main_mcan0: can@2701000 {
    		reg = <0x00 0x02701000 0x00 0x200>,
    		      <0x00 0x02708000 0x00 0x8000>;
    		power-domains = <&k3_pds 182 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 182 0>, <&k3_clks 182 1>;
    		interrupts = <GIC_SPI 124 IRQ_TYPE_LEVEL_HIGH>,
    			     <GIC_SPI 125 IRQ_TYPE_LEVEL_HIGH>;
    	main_mcan1: can@2711000 {
    		reg = <0x00 0x02711000 0x00 0x200>,
    		      <0x00 0x02718000 0x00 0x8000>;
    		power-domains = <&k3_pds 183 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 183 0>, <&k3_clks 183 1>;
    		interrupts = <GIC_SPI 127 IRQ_TYPE_LEVEL_HIGH>,
    			     <GIC_SPI 128 IRQ_TYPE_LEVEL_HIGH>;
    	main_mcan2: can@2721000 {
    		reg = <0x00 0x02721000 0x00 0x200>,
    		      <0x00 0x02728000 0x00 0x8000>;
    		power-domains = <&k3_pds 184 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 184 0>, <&k3_clks 184 1>;
    		interrupts = <GIC_SPI 130 IRQ_TYPE_LEVEL_HIGH>,
    			     <GIC_SPI 131 IRQ_TYPE_LEVEL_HIGH>;
    	main_mcan3: can@2731000 {
    		reg = <0x00 0x02731000 0x00 0x200>,
    		      <0x00 0x02738000 0x00 0x8000>;
    		power-domains = <&k3_pds 185 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 185 0>, <&k3_clks 185 1>;
    		interrupts = <GIC_SPI 133 IRQ_TYPE_LEVEL_HIGH>,
    			     <GIC_SPI 134 IRQ_TYPE_LEVEL_HIGH>;
    	main_mcan4: can@2741000 {
    		reg = <0x00 0x02741000 0x00 0x200>,
    		      <0x00 0x02748000 0x00 0x8000>;
    		power-domains = <&k3_pds 186 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 186 0>, <&k3_clks 186 1>;
    		interrupts = <GIC_SPI 136 IRQ_TYPE_LEVEL_HIGH>,
    			     <GIC_SPI 137 IRQ_TYPE_LEVEL_HIGH>;
    	main_mcan6: can@2761000 {
    		reg = <0x00 0x02761000 0x00 0x200>,
    		      <0x00 0x02768000 0x00 0x8000>;
    		power-domains = <&k3_pds 188 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 188 0>, <&k3_clks 188 1>;
    		interrupts = <GIC_SPI 142 IRQ_TYPE_LEVEL_HIGH>,
    			     <GIC_SPI 143 IRQ_TYPE_LEVEL_HIGH>;
    	main_mcan7: can@2771000 {
    		reg = <0x00 0x02771000 0x00 0x200>,
    		      <0x00 0x02778000 0x00 0x8000>;
    		power-domains = <&k3_pds 189 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 189 0>, <&k3_clks 189 1>;
    		interrupts = <GIC_SPI 145 IRQ_TYPE_LEVEL_HIGH>,
    			     <GIC_SPI 146 IRQ_TYPE_LEVEL_HIGH>;
    	main_mcan8: can@2781000 {
    		reg = <0x00 0x02781000 0x00 0x200>,
    		      <0x00 0x02788000 0x00 0x8000>;
    		power-domains = <&k3_pds 190 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 190 0>, <&k3_clks 190 1>;
    		interrupts = <GIC_SPI 576 IRQ_TYPE_LEVEL_HIGH>,
    			     <GIC_SPI 577 IRQ_TYPE_LEVEL_HIGH>;
    	main_mcan9: can@2791000 {
    		reg = <0x00 0x02791000 0x00 0x200>,
    		      <0x00 0x02798000 0x00 0x8000>;
    		power-domains = <&k3_pds 191 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 191 0>, <&k3_clks 191 1>;
    		interrupts = <GIC_SPI 579 IRQ_TYPE_LEVEL_HIGH>,
    			     <GIC_SPI 580 IRQ_TYPE_LEVEL_HIGH>;
    	main_mcan10: can@27a1000 {
    		reg = <0x00 0x027a1000 0x00 0x200>,
    		      <0x00 0x027a8000 0x00 0x8000>;
    		power-domains = <&k3_pds 192 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 192 0>, <&k3_clks 192 1>;
    		interrupts = <GIC_SPI 582 IRQ_TYPE_LEVEL_HIGH>,
    			     <GIC_SPI 583 IRQ_TYPE_LEVEL_HIGH>;
    	main_mcan11: can@27b1000 {
    		reg = <0x00 0x027b1000 0x00 0x200>,
    		      <0x00 0x027b8000 0x00 0x8000>;
    		power-domains = <&k3_pds 193 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 193 0>, <&k3_clks 193 1>;
    		interrupts = <GIC_SPI 585 IRQ_TYPE_LEVEL_HIGH>,
    			     <GIC_SPI 586 IRQ_TYPE_LEVEL_HIGH>;
    	main_mcan12: can@27c1000 {
    		reg = <0x00 0x027c1000 0x00 0x200>,
    		      <0x00 0x027c8000 0x00 0x8000>;
    		power-domains = <&k3_pds 194 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 194 0>, <&k3_clks 194 1>;
    		interrupts = <GIC_SPI 588 IRQ_TYPE_LEVEL_HIGH>,
    			     <GIC_SPI 589 IRQ_TYPE_LEVEL_HIGH>;
    	main_mcan13: can@27d1000 {
    		reg = <0x00 0x027d1000 0x00 0x200>,
    		      <0x00 0x027d8000 0x00 0x8000>;
    		power-domains = <&k3_pds 195 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 195 0>, <&k3_clks 195 1>;
    		interrupts = <GIC_SPI 591 IRQ_TYPE_LEVEL_HIGH>,
    			     <GIC_SPI 592 IRQ_TYPE_LEVEL_HIGH>;
    	main_mcan14: can@2681000 {
    		reg = <0x00 0x02681000 0x00 0x200>,
    		      <0x00 0x02688000 0x00 0x8000>;
    		power-domains = <&k3_pds 197 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 197 0>, <&k3_clks 197 1>;
    		interrupts = <GIC_SPI 594 IRQ_TYPE_LEVEL_HIGH>,
    			     <GIC_SPI 595 IRQ_TYPE_LEVEL_HIGH>;
    	main_mcan15: can@2691000 {
    		reg = <0x00 0x02691000 0x00 0x200>,
    		      <0x00 0x02698000 0x00 0x8000>;
    		power-domains = <&k3_pds 199 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 199 0>, <&k3_clks 199 1>;
    		interrupts = <GIC_SPI 597 IRQ_TYPE_LEVEL_HIGH>,
    			     <GIC_SPI 598 IRQ_TYPE_LEVEL_HIGH>;
    	main_mcan16: can@26a1000 {
    		reg = <0x00 0x026a1000 0x00 0x200>,
    		      <0x00 0x026a8000 0x00 0x8000>;
    		power-domains = <&k3_pds 201 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 201 0>, <&k3_clks 201 1>;
    		interrupts = <GIC_SPI 784 IRQ_TYPE_LEVEL_HIGH>,
    			     <GIC_SPI 785 IRQ_TYPE_LEVEL_HIGH>;
    	main_mcan17: can@26b1000 {
    		reg = <0x00 0x026b1000 0x00 0x200>,
    		      <0x00 0x026b8000 0x00 0x8000>;
    		power-domains = <&k3_pds 206 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 206 0>, <&k3_clks 206 1>;
    		interrupts = <GIC_SPI 787 IRQ_TYPE_LEVEL_HIGH>,
    			     <GIC_SPI 788 IRQ_TYPE_LEVEL_HIGH>;
    	main_r5fss0: r5fss@5c00000 {
    		#size-cells = <1>;
    		ranges = <0x5c00000 0x00 0x5c00000 0x20000>,
    			 <0x5d00000 0x00 0x5d00000 0x20000>;
    		power-domains = <&k3_pds 277 TI_SCI_PD_EXCLUSIVE>;
    		main_r5fss0_core0: r5f@5c00000 {
    			reg = <0x5c00000 0x00010000>,
    			      <0x5c10000 0x00010000>;
    			ti,sci = <&sms>;
    			ti,sci-dev-id = <279>;
    			ti,sci-proc-ids = <0x06 0xff>;
    			resets = <&k3_reset 279 1>;
    			firmware-name = "j721s2-main-r5f0_0-fw";
    			ti,loczrama = <1>;
    		main_r5fss0_core1: r5f@5d00000 {
    			reg = <0x5d00000 0x00010000>,
    			      <0x5d10000 0x00010000>;
    			ti,sci = <&sms>;
    			ti,sci-dev-id = <280>;
    			ti,sci-proc-ids = <0x07 0xff>;
    			resets = <&k3_reset 280 1>;
    			firmware-name = "j721s2-main-r5f0_1-fw";
    			ti,loczrama = <1>;
    	main_r5fss1: r5fss@5e00000 {
    		#size-cells = <1>;
    		ranges = <0x5e00000 0x00 0x5e00000 0x20000>,
    			 <0x5f00000 0x00 0x5f00000 0x20000>;
    		power-domains = <&k3_pds 278 TI_SCI_PD_EXCLUSIVE>;
    		main_r5fss1_core0: r5f@5e00000 {
    			reg = <0x5e00000 0x00010000>,
    			      <0x5e10000 0x00010000>;
    			ti,sci = <&sms>;
    			ti,sci-dev-id = <281>;
    			ti,sci-proc-ids = <0x08 0xff>;
    			resets = <&k3_reset 281 1>;
    			firmware-name = "j721s2-main-r5f1_0-fw";
    			ti,loczrama = <1>;
    		main_r5fss1_core1: r5f@5f00000 {
    			reg = <0x5f00000 0x00010000>,
    			      <0x5f10000 0x00010000>;
    			ti,sci = <&sms>;
    			ti,sci-dev-id = <282>;
    			ti,sci-proc-ids = <0x09 0xff>;
    			resets = <&k3_reset 282 1>;
    			firmware-name = "j721s2-main-r5f1_1-fw";
    			ti,loczrama = <1>;
    	c71_0: dsp@64800000 {
    		compatible = "ti,j721s2-c71-dsp";
    		reg = <0x00 0x64800000 0x00 0x00080000>,
    		      <0x00 0x64e00000 0x00 0x0000c000>;
    		reg-names = "l2sram", "l1dram";
    		ti,sci = <&sms>;
    		ti,sci-dev-id = <8>;
    		ti,sci-proc-ids = <0x30 0xff>;
    		resets = <&k3_reset 8 1>;
    		firmware-name = "j721s2-c71_0-fw";
    	c71_1: dsp@65800000 {
    		reg = <0x00 0x65800000 0x00 0x00080000>,
    		      <0x00 0x65e00000 0x00 0x0000c000>;
    		ti,sci = <&sms>;
    		ti,sci-dev-id = <11>;
    		ti,sci-proc-ids = <0x31 0xff>;
    		resets = <&k3_reset 11 1>;
    		firmware-name = "j721s2-c71_1-fw";
    // SPDX-License-Identifier: GPL-2.0+
     * Board specific initialization for J721S2 custom
     * Copyright (C) 2021 Texas Instruments Incorporated - http://www.ti.com/
     *	David Huang <d-huang@ti.com>
    #include <stdbool.h>
    #include <common.h>
    #include <env.h>
    #include <fdt_support.h>
    #include <generic-phy.h>
    #include <image.h>
    #include <init.h>
    #include <log.h>
    #include <net.h>
    #include <asm/arch/sys_proto.h>
    #include <asm/arch/hardware.h>
    #include <asm/gpio.h>
    #include <asm/io.h>
    #include <spl.h>
    #include <dm.h>
    #include <dm/uclass-internal.h>
    #include <linux/delay.h>
    #include "sja1105.h"
    DECLARE_GLOBAL_DATA_PTR;
    int board_init(void)
    	return 0;
    int dram_init(void)
    #ifdef CONFIG_PHYS_64BIT
    	/* 2GB */
    	gd->ram_size = 0x100000000;
    #else
    	gd->ram_size = 0x80000000;
    #endif
    	return 0;
    ulong board_get_usable_ram_top(ulong total_size)
    	/* Limit RAM used by U-Boot to the DDR low region */
    	if (gd->ram_top > 0x100000000)
    		return 0x100000000;
    #endif
    	return gd->ram_top;
    int dram_init_banksize(void)
    	/* Bank 0 declares the memory available in the DDR low region (2GB) */
    	gd->bd->bi_dram[0].start = CONFIG_SYS_SDRAM_BASE;
    	gd->bd->bi_dram[0].size = 0x80000000;
    	/* Bank 1 declares the memory available in the DDR high region (0GB) */
    	gd->bd->bi_dram[1].start = CONFIG_SYS_SDRAM_BASE1;
    	gd->bd->bi_dram[1].size = 0x80000000;
    #endif
    	return 0;
    #ifdef CONFIG_SPL_LOAD_FIT
    int board_fit_config_name_match(const char *name)
    	if (!strcmp(name, "custom"))
    		return 0;
    	/* legacy */
    	if (!strcmp(name, "k3-j721s2-common-proc-board"))
    		return 0;
    	return -1;
    #endif
    #if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP)
    int ft_board_setup(void *blob, struct bd_info *bd)
    	int ret;
    	ret = fdt_fixup_msmc_ram(blob, "/bus@100000", "sram@70000000");
    	if (ret < 0)
    		ret = fdt_fixup_msmc_ram(blob, "/interconnect@100000",
    					 "sram@70000000");
    	if (ret)
    		printf("%s: fixing up msmc ram failed %d\n", __func__, ret);
    	return ret;
    #endif
    int do_board_detect(void)
    	int ret = 0;
    	return ret;
    int checkboard(void)
    	/* Add detection once there is a B1 */
    	printf("Board: custom rev %s\n", "0");
    	return 0;
    static void setup_board_info(void)
    	env_set("board_name", "custom");
    	env_set("board_rev", "0");
    	env_set("board_software_revision", "0");
    	env_set("board_serial", "0");
    int board_late_init(void)
    	setup_board_info();
    #ifdef CONFIG_TARGET_J721S2_custom
    	udelay(500);
    	init_sja1105();
    #endif
    	return 0;
    void spl_board_init(void)
    It is difficult to review the entire files. It would be convenient if you attach the changes in patch format.
    Also please share the failing boot logs with 4GB enabled and also the success logs with 2GB enabled.
    Keerthy
    The major code modifications to modify the memory to 4 GB are
    uboot:
    --------------- arch/arm/dts/k3-j721s2-r5-common-proc-board.dts ---------------
    index 086f6da06c..40b3f891d1 100644
    @@ -270,3 +270,8 @@
    #include "k3-j721s2-common-proc-board-u-boot.dtsi"
    +// Only single DDR slot used
    +&memorycontroller1 {
    + status = "disabled";
    ----------------- arch/arm/dts/k3-j721s2-ddr-evm-lp4-4266.dtsi -----------------
    index c91576bf09..e99bbf6cb0 100644
    @@ -5,16 +5,16 @@
    * This file was generated on 10/14/2021
    -#define DDRSS_PLL_FHS_CNT 10
    -#define DDRSS_PLL_FREQUENCY_0 27500000
    +#define DDRSS_PLL_FHS_CNT 6
    +#define DDRSS_PLL_FREQUENCY_0 25000000
    #define DDRSS_PLL_FREQUENCY_1 1066500000
    #define DDRSS_PLL_FREQUENCY_2 1066500000
    #define MULTI_DDR_CFG_INTRLV_GRAN 0
    -#define MULTI_DDR_CFG_INTRLV_SIZE 11
    +#define MULTI_DDR_CFG_INTRLV_SIZE 0
    #define MULTI_DDR_CFG_ECC_ENABLE 0
    #define MULTI_DDR_CFG_HYBRID_SELECT 0
    -#define MULTI_DDR_CFG_EMIFS_ACTIVE 3
    +#define MULTI_DDR_CFG_EMIFS_ACTIVE 1
    #define DDRSS0_CTL_00_DATA 0x00000B00
    #define DDRSS0_CTL_01_DATA 0x00000000
    ---------------------- arch/arm/dts/k3-j721s2-som-p0.dtsi ----------------------
    index f3080e948e..9e91110d90 100644
    @@ -13,9 +13,9 @@
    memory@80000000 {
    - /* 16 GB RAM */
    + /* 4 GB RAM */
    - <0x08 0x80000000 0x03 0x80000000>;
    + <0x08 0x80000000 0x00 0x80000000>;
    @@ -13,9 +13,9 @@
    memory@80000000 {
    - /* 16 GB RAM */
    + /* 4 GB RAM */
    linux:
    ----------------- arch/arm64/boot/dts/ti/k3-j721s2-som-p0.dtsi -----------------
    index db1219b2bbff..796d6d464ea1 100644
    @@ -11,11 +11,12 @@
    memory@80000000 {
    - /* 16 GB RAM */
    And we now find whether linux kernel can normally make use of the memory region from 0x880000000 to 0x8ffffffff has nothing to do with the defconfig file we mentioned in the first post.
    Attached is the bootlog. There are many "BUG: Bad page state in process swapper " errors.
    U-Boot SPL 2021.01-g7a30174351 (May 04 2023 - 12:07:24 +0000)
    SYSFW ABI: 3.1 (firmware rev 0x0008 '8.4.1--v08.04.01 (Jolly Jellyfi')
    SPL initial stack usage: 13472 bytes
    Trying to boot from SPI
    Starting ATF on ARM64 core...
    NOTICE:  BL31: v2.6(release):v2.7-rc0-dirty
    NOTICE:  BL31: Built : 07:18:51, Mar  9 2023
    I/TC:
    I/TC: OP-TEE version: 3.17.0-125-g15a746d28 (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10))) #1 Thu 09 Mar 2023 07:45:38 AM UTC aarch64
    I/TC: WARNING: This OP-TEE configuration might be insecure!
    I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
    I/TC: Primary CPU initializing
    I/TC: SYSFW ABI: 3.1 (firmware rev 0x0008 '8.4.1--v08.04.01 (Jolly Jellyfi')
    I/TC: HUK Initialized
    I/TC: Activated SA2UL device
    I/TC: Enabled firewalls for SA2UL TRNG device
    I/TC: SA2UL TRNG initialized
    I/TC: SA2UL Drivers initialized
    I/TC: Primary CPU switching to normal world boot
    U-Boot SPL 2021.01-g7a30174351 (May 03 2023 - 12:26:45 +0000)
    cadence_spi spi@47040000: Can't get reset: -2
    k3-navss-ringacc ringacc@2b800000: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:272
    k3-navss-ringacc ringacc@2b800000: dma-ring-reset-quirk: disabled
    U-Boot 2021.01-g7a30174351 (May 03 2023 - 12:26:45 +0000)
    SoC:   J721S2 SR1.0 GP
    Model: CUSTOM
    Board: CUSTOM
    DRAM:  4 GiB
    Flash: 0 Bytes
    MMC:   mmc@4f80000: 0
    Loading Environment from FAT... OK
    In:    serial@2880000
    Out:   serial@2880000
    Err:   serial@2880000
    am65_cpsw_nuss ethernet@c200000: K3 CPSW: nuss_ver: 0x6BA02102 cpsw_ver: 0x6BA82102 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000
    Initializing SJA1105... done
    Net:   eth0: ethernet@c200000port@1
    Hit any key to stop autoboot:  0
    switch to partitions #0, OK
    mmc0(part 0) is current device
    SD/MMC found on device 0
    Failed to load 'boot.scr'
    1011 bytes read in 0 ms
    Loaded env from uEnv.txt
    Importing environment from mmc0 ...
    Running uenvcmd ...
    ## Error: "main_cpsw0_qsgmii_phyinit" not defined
    31586816 bytes read in 1354 ms (22.2 MiB/s)
    59194 bytes read in 4 ms (14.1 MiB/s)
    224 bytes read in 1 ms (218.8 KiB/s)
       Loading Device Tree to 000000008feee000, end 000000008fffffff ... OK
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
    [    0.000000] Linux version 5.10.120-g889d3a89cbe8-dirty (uif56050@jdd1062u) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT Fri May 5 22:07:54 CST 2023
    [    0.000000] Machine model: CUSTOM 4G
    [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002880000 (options '')
    [    0.000000] printk: bootconsole [ns16550a0] enabled
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node ippu-r5f-dma-memory@a2000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB
    [    0.000000] OF: reserved mem: initialized node ippu-r5f-memory@a2100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node spu-r5f-dma-memory@a4000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 31 MiB
    [    0.000000] OF: reserved mem: initialized node spu-r5f-memory@a4100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 58 MiB
    [    0.000000] OF: reserved mem: initialized node ippu-r5f-memory-hwa@a6100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000aa000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node cvu-c7-dma-memory@aa000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000aa100000, size 79 MiB
    [    0.000000] OF: reserved mem: initialized node cvu-c7-memory@aa100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000af000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node cvu2-c7-dma-memory@af000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000af100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node cvu2-c7-memory@af100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000b2000000, size 64 MiB
    [    0.000000] OF: reserved mem: initialized node slave_cores_region, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000008c0000000, size 512 MiB
    [    0.000000] OF: reserved mem: initialized node memtest_region@880000000, compatible id shared-dma-pool
    [    0.000000] NUMA: No NUMA configuration found
    [    0.000000] NUMA: Faking a node at [mem 0x0000000080000000-0x00000008ffffffff]
    [    0.000000] NUMA: NODE_DATA [mem 0x8ffa98b00-0x8ffa9afff]
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   [mem 0x0000000100000000-0x00000008ffffffff]
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x0000000096ffffff]
    [    0.000000]   node   0: [mem 0x0000000097000000-0x0000000097ffffff]
    [    0.000000]   node   0: [mem 0x0000000098000000-0x000000009e7fffff]
    [    0.000000]   node   0: [mem 0x000000009e800000-0x00000000a0ffffff]
    [    0.000000]   node   0: [mem 0x00000000a1000000-0x00000000a1ffffff]
    [    0.000000]   node   0: [mem 0x00000000a2000000-0x00000000a5ffffff]
    [    0.000000]   node   0: [mem 0x00000000a6000000-0x00000000a60fffff]
    [    0.000000]   node   0: [mem 0x00000000a6100000-0x00000000a9b97fff]
    [    0.000000]   node   0: [mem 0x00000000a9b99000-0x00000000a9ffffff]
    [    0.000000]   node   0: [mem 0x00000000aa000000-0x00000000d9ffffff]
    [    0.000000]   node   0: [mem 0x00000000da000000-0x00000000ffffffff]
    [    0.000000]   node   0: [mem 0x0000000880000000-0x00000008bfffffff]
    [    0.000000]   node   0: [mem 0x00000008c0000000-0x00000008dfffffff]
    [    0.000000]   node   0: [mem 0x00000008e0000000-0x00000008ffffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
    [    0.000000] cma: Reserved 32 MiB at 0x00000000fe000000
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.2
    [    0.000000] percpu: Embedded 23 pages/cpu s56600 r8192 d29416 u94208
    [    0.000000] Detected PIPT I-cache on CPU0
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] CPU features: detected: EL2 vector hardening
    [    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
    [    0.000000] CPU features: detected: Spectre-BHB
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1032191
    [    0.000000] Policy zone: Normal
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x2880000 3 root=PARTUUID=c453128a-f306-4dd6-a891-824a35f40b13 rw rootfstype=ext4 rootwait
    [    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] software IO TLB: mapped [mem 0x00000000fa000000-0x00000000fe000000] (64MB)
    [    0.000000] BUG: Bad page state in process swapper  pfn:80001
    [    0.000000] page:(____ptrval____) refcount:0 mapcount:1 mapping:0000000000000000 index:0x0 pfn:0x80001
    [    0.000000] flags: 0x0()
    [    0.000000] raw: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
    [    0.000000] page dumped because: nonzero mapcount
    [    0.000000] Modules linked in:
    [    0.000000] CPU: 0 PID: 0 Comm: swapper Not tainted 5.10.120-g889d3a89cbe8-dirty #1
    [    0.000000] Hardware name: CUSTOM 4G (DT)
    [    0.000000] Call trace:
    [    0.000000]  dump_backtrace+0x0/0x1a0
    [    0.000000]  show_stack+0x18/0x68
    [    0.000000]  dump_stack+0xd0/0x12c
    [    0.000000]  bad_page+0xdc/0x108
    [    0.000000]  check_free_page_bad+0x7c/0x88
    [    0.000000]  __free_pages_ok+0x3d4/0x3e8
    [    0.000000]  __free_pages_core+0xbc/0xd0
    [    0.000000]  memblock_free_pages+0x14/0x20
    [    0.000000]  memblock_free_all+0x16c/0x24c
    [    0.000000]  mem_init+0x4c/0x60
    [    0.000000]  start_kernel+0x290/0x4c8
    [    0.000000] Disabling lock debugging due to kernel taint
    [    0.000000] BUG: Bad page state in process swapper  pfn:80002
    [    0.000000] page:(____ptrval____) refcount:0 mapcount:1 mapping:0000000000000000 index:0x0 pfn:0x80002
    [    0.000000] CPU: 0 PID: 0 Comm: swapper Tainted: G    B             5.10.120-g889d3a89cbe8-dirty #1
    [    0.000000] BUG: Bad page state in process swapper  pfn:80003
    [    0.000000] page:(____ptrval____) refcount:0 mapcount:1 mapping:0000000000000000 index:0x0 pfn:0x80003
    [    0] page:(____ptrval____) refcount:0 mapcount:1 mapping:0000000000000000 index:0x0 pfn:0x80015
    [    0.000000] BUG: Bad page state in process swapper  pfn:80016
    [    0.000000] page:(____ptrval____) refcount:0 mapcount:1 mapping:0000000000000000 index:0x0 pfn:0x80016
    [    0.000000] BUG: Bad page state in process swapper  pfn:80017
    [    0.000000] page:(____ptrval____) refcount:0 mapcount:1 mapping:0000000000000000 index:0x0 pfn:0x80017
    [    0.000000] BUG: Bad page state in process swapper  pfn:80018
    [    0.000000] page:(____ptrval____) refcount:0 mapcount:1 mapping:0000000000000000 index:0x0 pfn:0x80018
    [    0.000000]  dump_bac0000]  dump_stack+0xd0/0x12c
    [    0.000000] BUG: Bad page state in process swapper  pfn:80031
    [    0.000000] page:(____ptrval____) refcount:0 mapcount:1 mapping:0000000000000000 index:0x0 pfn:0x80031
    [    0.000000] BUG: Bad page state in process swapper  pfn:80032
    [    0.000000] page:(____ptrval____) refcount:0 mapcount:1 mapping:0000000000000000 index:0x0 pfn:0x80032
    [    0.000000] BUG: Bad page state in process swapper  pfn:80033
    [    0.000000] page:(____ptrval____) refcount:0 mapcount:1 mapping:0000000000000000 index:0x0 pfn:0x80033
    [    0.000000] BUG: Bad page state in process swapper  pfn:80034
    [    0.000000] page:(____ptrval____) refcount:0 mapcount:1 mapping:0000000000000000 index:0x0 pfn:0x80034
                            [    0.682203] cma: cma_alloc: alloc failed, req-size: 8 pages, ret: -16
    [    0.793538] cma: cma_alloc: alloc failed, req-size: 4 pages, ret: -16
    [    1.009269] cma: cma_alloc: alloc failed, req-size: 2 pages, ret: -16
    [    1.433707] cma: cma_alloc: alloc failed, req-size: 1 pages, ret: -16
    [    1.440352] DMA: failed to allocate 308 KiB GFP_KERNEL|GFP_DMA pool for atomic allocation
    [    1.452260] cma: cma_alloc: alloc failed, req-size: 128 pages, ret: -16
    [    1.465862] cma: cma_alloc: alloc failed, req-size: 64 pages, ret: -16
    [    1.485885] cma: cma_alloc: alloc failed, req-size: 32 pages, ret: -16
    [    1.518974] cma: cma_alloc: alloc failed, req-size: 16 pages, ret: -16
    [    1.578166] cma: cma_alloc: alloc failed, req-size: 8 pages, ret: -16
    [    1.689444] cma: cma_alloc: alloc failed, req-size: 4 pages, ret: -16
    [    1.905037] cma: cma_alloc: alloc failed, req-size: 2 pages, ret: -16
    [    2.329314] cma: cma_alloc: alloc failed, req-size: 1 pages, ret: -16
    [    2.335955] DMA: failed to allocate 308 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocation
    [    2.344529] audit: initializing netlink subsys (disabled)
    [    2.350192] audit: type=2000 audit(1.960:1): state=initialized audit_enabled=0 res=1
    [    2.350784] thermal_sys: Registered thermal governor 'step_wise'
    [    2.358120] thermal_sys: Registered thermal governor 'power_allocator'
    [    2.364341] cpuidle: using governor menu
    [    2.375163] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    2.382130] ASID allocator initialised with 65536 entries
    [    2.388272] Serial: AMBA PL011 UART driver
    [    2.412210] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
    [    2.419070] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
    [    2.425917] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    2.432764] HugeTLB retel(R) PRO/1000 Network Driver
    [    2.898920] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
    [    2.904988] igb: Intel(R) Gigabit Ethernet Network Driver
    [    2.910502] igb: Copyright (c) 2007-2014 Intel Corporation.
    [    2.916209] igbvf: Intel(R) Gigabit Virtual Function Network Driver
    [    2.922611] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    [    2.928863] sky2: driver version 1.30
    [    2.933360] VFIO - User Level meta-driver version: 0.3
    [    2.939757] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    [    2.946455] ehci-pci: EHCI PCI platform driver
    [    2.951019] ehci-platform: EHCI generic platform driver
    [    2.956444] ehci-orion: EHCI orion driver
    [    2.960600] ehci-exynos: EHCI Exynos driver
    [    2.964923] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
    [    2.971254] ohci-pci: OHCI PCI platform driver
    [    2.975811] ohci-platform: OHCI generic platform driver
    [    2.981219] ohci-exynos: OHCI Exynos driver
    [    2.985769] usbcore: registered new interface driver usb-storage
    [    2.993368] i2c /dev entries driver
    [    3.000318] sdhci: Secure Digital Host Controller Interface driver
    [    3.006659] sdhci: Copyright(c) Pierre Ossman
    [    3.011487] Synopsys Designware Multimedia Card Interface Driver
    [    3.018198] sdhci-pltfm: SDHCI platform and OF driver helper
    [    3.024874] ledtrig-cpu: registered to indicate activity on CPUs
    [    3.031593] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    3.038532] usbcore: registered new interface driver usbhid
    [    3.044235] usbhid: USB HID core driver
    [    3.050256] optee: probing for conduit method.
    [    3.054813] optee: revision 3.17 (15a746d2)
    [    3.054970] optee: dynamic shared memory is enabled
    E/TC:0 0 std_entry_with_parg:234 Bad arg address 0x8e12e5000
    [    3.069789] optee: initialized driver
    [    3.074811] NET: Registered protocol family 17
    [    3.079453] 9pnet: Installing 9P2000 support
    [    3.083854] Key type dns_resolver registered
    [    3.088433] registered taskstats version 1
    [    3.092627] Loading compiled-in X.509 certificates
    [    3.105143] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    3.111984] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    3.122927] ti-sci 44083000.system-controller: ABI: 3.1 (firmware rev 0x0008 '8.4.1--v08.04.01 (Jolly Jellyfi')
    [    3.153281] omap_i2c 42120000.i2c: bus 0 rev0.12 at 100 kHz
    [    3.159341] ti-sci-intr 42200000.interrupt-controller: Interrupt Router 125 domain created
    [    3.167987] ti-sci-intr bus@100000:interrupt-controller@a00000: Interrupt Router 148 domain cr: Listening on udev Control Socket.
    [  OK  ] Listening on udev Control Socket.
    [    4.973684] systemd[1]: Listening on udev Kernel Socket.
    [  OK  ] Listening on udev Kernel Socket.
    [    4.995736] systemd[1]: Mounting Huge Pages File System...
    [    5.012096] systemd[1]: Mounting POSIX Message Queue File System...
    [    5.247867] systemd[1]: Mounting Kernel Debug File System...
    [    5.287434] systemd[1]: Mounting Temporary Directory (/tmp)...
    [    5.305731] systemd1]: Starting udev Coldplug all Devices...
    [    5.444513] systemd[1]: Started RPC Bind.
    [  OK  ] Started RPC Bind.
    [    5.457995] systemd[1]: Started Journal Service.
    [  OK  ] Started Journal Service.
    [  OK  ] Mounted Huge Pages File System.
    [  OK  ] Mounted POSIX Message Queue File System.
    [  OK  ] Mounted Kernel Debug File System.
    [  OK  ] Mounted Temporary Directory (/tmp).
    [FAILED] Failed to start Load Kernel Modules.
    See 'systemctl status systemd-modules-load.service' for details.
    [  OK  ] Started Remount Root and Kernel File Systems.
    [    5.591885] urandom_read_iter: 37 c8;5;185mDEPEND] Dependency failed for NFS server and services.
    [  OK  ] Mounted Kernel Configuration File System.
    [  OK  ] Started Flush Journal to Persistent Storage.
    [  OK  ] Started Apply Kernel Variables.
    [  OK  ] Started Create Static Device Nodes in /dev.
    [  OK  ] Reached target Local File Systems (Pre).
             Mounting /media/ram
                                [    6.622152] urandom_read_iter: 20 callbacks suppressed
    [    6.622156] random: systemd: uninitialized urandom read (16 bytes read)
    [    6.643654] random: systemd: uninitialized urandom read (16 bytes read)
    [    6.655365] random: systemd: uninitialized
                                                 [  OK  ] Found device /dev/mmcblk0p1.
             Starting File System Check on /dev/mmcblk0p1...
    [  OK  ] Started File System Check on /dev/mmcblk0p1.
             Mounting /tiboot...
    [  OK  ] Mounted /tiboot.
    [  OK  ] Reached target Local File Systems.
             Starting Create Volatile Files and Directories...
    [  OK  ] Started Create Volatile Files and Directories.
             Starting Network Time Synchronization...
             Starting Update UTMP awn...
    [  OK  ] Started Update UTMP about System Boot/Shutdown.
    [  OK  ] Started Network Time Synchronization.
    [  OK  ] Reached target System Time Set.
    [  OK  ] Reached target System Time Synchronized.
    [    7.648268] urandom_read_iter: 52 callbacks suppressed
    [    7.648273] random: systemd: uninitialized urandom read (16 bytes read)
    [  OK  ] Started udev Wait for Complete Device Initialization.
    [  OK  ] Started Hardware RNG Entropy Gatherer Daemon.
    [  OK  ] Reached target System Initialization.
    [  OK  ] Started Daily rotation of log files.
    [    7.813506] random: crng init done
    [    7.816902] random: 35 urandom warning(s) missed due to ratelimiting
    [  OK  ] Started Daily Cleanup of Temporary Directories.
    [  OK  ] Reached target Timers.
    [  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
    [  OK  ] Listening on D-Bus System Message Bus Socket.
             Starting sshd.socket.
    [  OK  ] Started Load/Save Random Seed.
    [  OK  ] Listening on sshd.socket.
    [  OK  ] Reached target Sockets.
    [  OK  ] Reached target.
    [  OK  ] Started Job spooling tools.
             Starting Load remote core firmwares (remoteproc)...
    [  OK  ] Started Periodic Command Scheduler.
    [  OK  ] Started D-Bus System 0m.
    [  OK  ] Started Runs fast development update daemon.
             Starting IPv6 Packet Filtering Framework...
             Starting IPv4 Packet Filtering Framework...
             Starting rc.pvr.service...
    [  OK  ] Started System Logging Service.
             Starting Login Service...
    [  OK  ] Started IPv6 Packet Filtering Framework.
    [  OK  ] Started IPv4 Packet Filework.
    [  OK  ] Started rc.pvr.service.
    [  OK  ] Reached target Network (Pre).
             Starting Network Service...
    [  OK  ] Started Login Service.
    [  OK  ] Started Network Service.
             Starting Wait for Network to be Configured...
             Starting Network Name Resolution...
    [  OK  ] Started Network Name Resolution.
    [  OK  ] Reached target Network.
    [  OK  ] Reached target Host and Network Name Lookups.
             Starting Avahi mDNS/DNS-SD Stack...
    [  OK  ] Started NFS status monitor for NFSv2/3 locking..
    [  OK  ] Started Respond to IPv6 Node Information Queries.
    [  OK  ] Started Network Router Discovery Daemon.
             Starting Permit User Sessions...
    [  OK  ] Started Xineent For Inetd.
    [  OK  ] Started LinuxPTP daemon: phc2sys.
    [  OK  ] Started LinuxPTP daemon: ptp4l (IEEE 1588).
    [  OK  ] Started Permit User Sessions.
    [  OK  ] Started Avahi mDNS/DNS-SD Stack.
    [  OK  ] Started Getty on tty1.
    [  OK  ] Started Serial Getty on ttyS2.
    [  OK  ] Reached target Login Prompts.
             Starting Synchronize System and HW clocks...
    [FAILED] Failed to start Synchronize em and HW clocks.
    See 'systemctl status sync-clocks.service' for details.
    CUSTOM login:
    If we reserve all the memory region 0x880000000 to 0x8ffffffff in linux dts, the kernel can boot without such errors. And we also tested the memory using memtester (https://linux.die.net/man/8/memtester) for the region. The result is all good. For example:
    CUSTOM:~# ./memtester -p 0x8c0000000 32m 1
    memtester version 4.6.0 (64-bit)
    Copyright (C) 2001-2020 Charles Cazabon.
    Licensed under the GNU General Public License version 2 (only).
    pagesize is 4096
    pagesizemask is 0xfffffffffffff000
    want 32MB (33554432 bytes)
    Loop 1/1:
    Stuck Address : ok
    Random Value : ok
    Compare XOR : ok
    Compare SUB : ok
    Compare MUL : ok
    Compare DIV : ok
    Compare OR : ok
    Compare AND : ok
    Sequential Increment: ok
    Solid Bits : ok
    Block Sequential : ok
    Checkerboard ok 13
    Bit Spread : ok
    Bit Flip : ok
    Walking Ones : ok
    Walking Zeroes : ok
    8-bit Writes : ok
    16-bit Writes : ok
    Done.
    https://e2e.ti.com/support/processors/f/791/t/1097117
    The above is an FAQ on J721e. You will need to also change the board/ti/j721s2/evm.c
    The function where we declare the memory:
    /* Bank 0 declares the memory available in the DDR low region */
    gd->bd->bi_dram[0].start = CFG_SYS_SDRAM_BASE;
    gd->bd->bi_dram[0].size = 0x7fffffff;
    /* Bank 1 declares the memory available in the DDR high region */
    gd->bd->bi_dram[1].start = CFG_SYS_SDRAM_BASE1;
    gd->bd->bi_dram[1].size = 0x7fffffff;
    #endif
    return 0;
    Keerthy
