Other Parts Discussed in Thread: BQ25890, TPS51632, TPS65090, TPS65912, TPA6130A2, TPS65910, LM95241, TVP7002, ADC161S626, LM95245, ADS7846, LP8727, TMP006, LM63, PCM1681, DA8XX, BQ27000, LM3639, TLV320AIC23B, TPD12S015, LM8333, ADS8688, BQ24190, TAS2552, CDCE925, TPS65218, LP5562, AFE4404, TPS65217, AMC6821, ADS7828, TPS65010, LP3972, LP3971, LM8323, ADC128S052, BQ24257, LM3642, DAC7512, TLV320AIC23, CDCE706, ADS1015, TCA6507, LP5521, INA3221, LM83, TPS62360, LM80, LM87, LP3944, TPS65086, LM3630A, OPA362, THS8200, TPS65023, LP3943, LM95234, TFP410, TVP5150, TSC2004, TSC2005, OPT3001, TMP401, LM77, LM70, LM92, LM73, LM3530, INA209, PCF8574, THS7303, LM3533, BQ24735, TSC2007, TCA8418, PMP, TWL6040, TAS5086, LP8501, AFE4403, TMP102, TMP103, ADC128D818, TS3A227E, DAC124S085, TMP421, ADS7871, TPIC2810, LM3560, PCM3168A, LP5523, TCA6416, LM93, LM90
I am running a customized Linux kernel 4.9.74 on Beagle Bone Black with AM358 processor. The system image is generated using Yocto build system and my kernel is based on the official ti-linux-kernel with a few patches related to UART and touch screen. Now I am trying to connect a measurement device equipped with FT2232 chip via USB and read data from it using libusb 1.0.20 and libftdi 1.3. Unfortunately, reading from the USB device fails with error -7 which means USB device time out.
In order to exclude the hardware issues, I tried to install my (very) old system image based on kernel 3.14, and it worked without problems. Then I tried to update libusb and libftdi to the recent versions, but this did not change anything. After these tests, my attention turned to the Linux kernel. Having read the discussion at the link below, I started to experiment with musb kernel driver.
My old kernel uses USB in PIO mode (CONFIG_MUSB_PIO_ONLY), while my new kernel uses USB in DMA mode (CONFIG_USB_TI_CPPI41_DMA). Therefore, I tried to test my new kernel 4.9.74 in both PIO and DMA mode:
- DMA mode:
- If reading is preceded by a write, it succeeds.
- If there is silence before reading, reading fails.
- When I connect the USB device via USB hub, everything works flawlessly.
- PIO mode:
- Reading works until the USB communication is going. When I put e.g. 100ms delay before the reading request, it times out.
- When I write some data to my USB-UART before reading, the subsequent reading works.
- Connecting the device via a USB hub somehow reduces the reading errors, but they still appear when the communication stays silent for some time.
Since I want to stream large amounts of data from the USB, I would prefer to stay with DMA mode, which should save some CPU cycles for me. My current kernel configuration in DMA mode is here:
# # Automatically generated file; DO NOT EDIT. # Linux/arm 4.9.74 Kernel Configuration # CONFIG_ARM=y CONFIG_ARM_HAS_SG_CHAIN=y CONFIG_MIGHT_HAVE_PCI=y CONFIG_SYS_SUPPORTS_APM_EMULATION=y CONFIG_HAVE_PROC_CPU=y CONFIG_STACKTRACE_SUPPORT=y CONFIG_LOCKDEP_SUPPORT=y CONFIG_TRACE_IRQFLAGS_SUPPORT=y CONFIG_RWSEM_XCHGADD_ALGORITHM=y CONFIG_ARCH_HAS_BANDGAP=y CONFIG_FIX_EARLYCON_MEM=y CONFIG_GENERIC_HWEIGHT=y CONFIG_GENERIC_CALIBRATE_DELAY=y CONFIG_NEED_DMA_MAP_STATE=y CONFIG_ARCH_SUPPORTS_UPROBES=y CONFIG_VECTORS_BASE=0xffff0000 CONFIG_ARM_PATCH_PHYS_VIRT=y CONFIG_GENERIC_BUG=y CONFIG_PGTABLE_LEVELS=2 CONFIG_DEFCONFIG_LIST="/lib/modules/$UNAME_RELEASE/.config" CONFIG_IRQ_WORK=y CONFIG_BUILDTIME_EXTABLE_SORT=y # # General setup # CONFIG_BROKEN_ON_SMP=y CONFIG_INIT_ENV_ARG_LIMIT=32 CONFIG_CROSS_COMPILE="" # CONFIG_COMPILE_TEST is not set CONFIG_LOCALVERSION="" CONFIG_LOCALVERSION_AUTO=y CONFIG_HAVE_KERNEL_GZIP=y CONFIG_HAVE_KERNEL_LZMA=y CONFIG_HAVE_KERNEL_XZ=y CONFIG_HAVE_KERNEL_LZO=y CONFIG_HAVE_KERNEL_LZ4=y # CONFIG_KERNEL_GZIP is not set CONFIG_KERNEL_LZMA=y # CONFIG_KERNEL_XZ is not set # CONFIG_KERNEL_LZO is not set # CONFIG_KERNEL_LZ4 is not set CONFIG_DEFAULT_HOSTNAME="(none)" CONFIG_SWAP=y CONFIG_SYSVIPC=y CONFIG_SYSVIPC_SYSCTL=y CONFIG_POSIX_MQUEUE=y CONFIG_POSIX_MQUEUE_SYSCTL=y CONFIG_CROSS_MEMORY_ATTACH=y CONFIG_FHANDLE=y # CONFIG_USELIB is not set # CONFIG_AUDIT is not set CONFIG_HAVE_ARCH_AUDITSYSCALL=y # # IRQ subsystem # CONFIG_GENERIC_IRQ_PROBE=y CONFIG_GENERIC_IRQ_SHOW=y CONFIG_GENERIC_IRQ_SHOW_LEVEL=y CONFIG_HARDIRQS_SW_RESEND=y CONFIG_GENERIC_IRQ_CHIP=y CONFIG_IRQ_DOMAIN=y CONFIG_IRQ_DOMAIN_HIERARCHY=y CONFIG_GENERIC_MSI_IRQ=y CONFIG_GENERIC_MSI_IRQ_DOMAIN=y CONFIG_HANDLE_DOMAIN_IRQ=y # CONFIG_IRQ_DOMAIN_DEBUG is not set CONFIG_IRQ_FORCED_THREADING=y CONFIG_SPARSE_IRQ=y CONFIG_ARCH_CLOCKSOURCE_DATA=y CONFIG_GENERIC_CLOCKEVENTS=y # # Timers subsystem # CONFIG_TICK_ONESHOT=y CONFIG_NO_HZ_COMMON=y # CONFIG_HZ_PERIODIC is not set CONFIG_NO_HZ_IDLE=y CONFIG_NO_HZ=y CONFIG_HIGH_RES_TIMERS=y # # CPU/Task time and stats accounting # CONFIG_TICK_CPU_ACCOUNTING=y # CONFIG_VIRT_CPU_ACCOUNTING_GEN is not set # CONFIG_IRQ_TIME_ACCOUNTING is not set CONFIG_BSD_PROCESS_ACCT=y # CONFIG_BSD_PROCESS_ACCT_V3 is not set # CONFIG_TASKSTATS is not set # # RCU Subsystem # CONFIG_PREEMPT_RCU=y # CONFIG_RCU_EXPERT is not set CONFIG_SRCU=y # CONFIG_TASKS_RCU is not set CONFIG_RCU_STALL_COMMON=y # CONFIG_TREE_RCU_TRACE is not set # CONFIG_RCU_EXPEDITE_BOOT is not set CONFIG_BUILD_BIN2C=y CONFIG_IKCONFIG=y CONFIG_IKCONFIG_PROC=y CONFIG_LOG_BUF_SHIFT=17 CONFIG_NMI_LOG_BUF_SHIFT=13 CONFIG_GENERIC_SCHED_CLOCK=y CONFIG_CGROUPS=y CONFIG_PAGE_COUNTER=y CONFIG_MEMCG=y CONFIG_MEMCG_SWAP=y CONFIG_MEMCG_SWAP_ENABLED=y CONFIG_BLK_CGROUP=y # CONFIG_DEBUG_BLK_CGROUP is not set CONFIG_CGROUP_WRITEBACK=y CONFIG_CGROUP_SCHED=y CONFIG_FAIR_GROUP_SCHED=y CONFIG_CFS_BANDWIDTH=y # CONFIG_RT_GROUP_SCHED is not set CONFIG_CGROUP_PIDS=y CONFIG_CGROUP_FREEZER=y # CONFIG_CPUSETS is not set CONFIG_CGROUP_DEVICE=y CONFIG_CGROUP_CPUACCT=y CONFIG_CGROUP_PERF=y # CONFIG_CGROUP_DEBUG is not set CONFIG_CHECKPOINT_RESTORE=y CONFIG_NAMESPACES=y CONFIG_UTS_NS=y CONFIG_IPC_NS=y # CONFIG_USER_NS is not set CONFIG_PID_NS=y CONFIG_NET_NS=y # CONFIG_SCHED_AUTOGROUP is not set # CONFIG_SYSFS_DEPRECATED is not set # CONFIG_RELAY is not set CONFIG_BLK_DEV_INITRD=y CONFIG_INITRAMFS_SOURCE="" CONFIG_RD_GZIP=y CONFIG_RD_BZIP2=y CONFIG_RD_LZMA=y CONFIG_RD_XZ=y CONFIG_RD_LZO=y CONFIG_RD_LZ4=y CONFIG_CC_OPTIMIZE_FOR_PERFORMANCE=y # CONFIG_CC_OPTIMIZE_FOR_SIZE is not set CONFIG_SYSCTL=y CONFIG_ANON_INODES=y CONFIG_HAVE_UID16=y CONFIG_BPF=y CONFIG_EXPERT=y CONFIG_UID16=y CONFIG_MULTIUSER=y # CONFIG_SGETMASK_SYSCALL is not set CONFIG_SYSFS_SYSCALL=y # CONFIG_SYSCTL_SYSCALL is not set CONFIG_KALLSYMS=y CONFIG_KALLSYMS_ALL=y # CONFIG_KALLSYMS_ABSOLUTE_PERCPU is not set CONFIG_KALLSYMS_BASE_RELATIVE=y CONFIG_PRINTK=y CONFIG_PRINTK_NMI=y CONFIG_BUG=y CONFIG_ELF_CORE=y CONFIG_BASE_FULL=y CONFIG_FUTEX=y CONFIG_EPOLL=y CONFIG_SIGNALFD=y CONFIG_TIMERFD=y CONFIG_EVENTFD=y # CONFIG_BPF_SYSCALL is not set CONFIG_SHMEM=y CONFIG_AIO=y CONFIG_ADVISE_SYSCALLS=y # CONFIG_USERFAULTFD is not set CONFIG_PCI_QUIRKS=y CONFIG_MEMBARRIER=y CONFIG_EMBEDDED=y CONFIG_HAVE_PERF_EVENTS=y CONFIG_PERF_USE_VMALLOC=y # # Kernel Performance Events And Counters # CONFIG_PERF_EVENTS=y # CONFIG_DEBUG_PERF_USE_VMALLOC is not set CONFIG_VM_EVENT_COUNTERS=y # CONFIG_SLUB_DEBUG is not set CONFIG_COMPAT_BRK=y # CONFIG_SLAB is not set CONFIG_SLUB=y # CONFIG_SLOB is not set # CONFIG_SLAB_FREELIST_RANDOM is not set # CONFIG_SYSTEM_DATA_VERIFICATION is not set # CONFIG_PROFILING is not set CONFIG_KEXEC_CORE=y CONFIG_HAVE_OPROFILE=y # CONFIG_KPROBES is not set CONFIG_JUMP_LABEL=y # CONFIG_STATIC_KEYS_SELFTEST is not set # CONFIG_UPROBES is not set # CONFIG_HAVE_64BIT_ALIGNED_ACCESS is not set CONFIG_HAVE_EFFICIENT_UNALIGNED_ACCESS=y CONFIG_ARCH_USE_BUILTIN_BSWAP=y CONFIG_HAVE_KPROBES=y CONFIG_HAVE_KRETPROBES=y CONFIG_HAVE_OPTPROBES=y CONFIG_HAVE_NMI=y CONFIG_HAVE_ARCH_TRACEHOOK=y CONFIG_HAVE_DMA_CONTIGUOUS=y CONFIG_GENERIC_SMP_IDLE_THREAD=y CONFIG_GENERIC_IDLE_POLL_SETUP=y CONFIG_HAVE_REGS_AND_STACK_ACCESS_API=y CONFIG_HAVE_CLK=y CONFIG_HAVE_DMA_API_DEBUG=y CONFIG_HAVE_HW_BREAKPOINT=y CONFIG_HAVE_PERF_REGS=y CONFIG_HAVE_PERF_USER_STACK_DUMP=y CONFIG_HAVE_ARCH_JUMP_LABEL=y CONFIG_ARCH_WANT_IPC_PARSE_VERSION=y CONFIG_HAVE_ARCH_SECCOMP_FILTER=y CONFIG_SECCOMP_FILTER=y CONFIG_HAVE_GCC_PLUGINS=y # CONFIG_GCC_PLUGINS is not set CONFIG_HAVE_CC_STACKPROTECTOR=y # CONFIG_CC_STACKPROTECTOR is not set CONFIG_CC_STACKPROTECTOR_NONE=y # CONFIG_CC_STACKPROTECTOR_REGULAR is not set # CONFIG_CC_STACKPROTECTOR_STRONG is not set CONFIG_HAVE_CONTEXT_TRACKING=y CONFIG_HAVE_VIRT_CPU_ACCOUNTING_GEN=y CONFIG_HAVE_IRQ_TIME_ACCOUNTING=y CONFIG_HAVE_MOD_ARCH_SPECIFIC=y CONFIG_MODULES_USE_ELF_REL=y CONFIG_ARCH_HAS_ELF_RANDOMIZE=y CONFIG_HAVE_ARCH_MMAP_RND_BITS=y CONFIG_HAVE_EXIT_THREAD=y CONFIG_ARCH_MMAP_RND_BITS_MIN=8 CONFIG_ARCH_MMAP_RND_BITS_MAX=16 CONFIG_ARCH_MMAP_RND_BITS=8 # CONFIG_HAVE_ARCH_HASH is not set # CONFIG_ISA_BUS_API is not set CONFIG_CLONE_BACKWARDS=y CONFIG_OLD_SIGSUSPEND3=y CONFIG_OLD_SIGACTION=y # CONFIG_CPU_NO_EFFICIENT_FFS is not set # CONFIG_HAVE_ARCH_VMAP_STACK is not set # # GCOV-based kernel profiling # # CONFIG_GCOV_KERNEL is not set CONFIG_ARCH_HAS_GCOV_PROFILE_ALL=y CONFIG_HAVE_GENERIC_DMA_COHERENT=y CONFIG_RT_MUTEXES=y CONFIG_BASE_SMALL=0 CONFIG_MODULES=y CONFIG_MODULE_FORCE_LOAD=y CONFIG_MODULE_UNLOAD=y CONFIG_MODULE_FORCE_UNLOAD=y CONFIG_MODVERSIONS=y CONFIG_MODULE_SRCVERSION_ALL=y # CONFIG_MODULE_SIG is not set # CONFIG_MODULE_COMPRESS is not set # CONFIG_TRIM_UNUSED_KSYMS is not set CONFIG_MODULES_TREE_LOOKUP=y CONFIG_BLOCK=y CONFIG_LBDAF=y CONFIG_BLK_DEV_BSG=y # CONFIG_BLK_DEV_BSGLIB is not set # CONFIG_BLK_DEV_INTEGRITY is not set # CONFIG_BLK_DEV_THROTTLING is not set CONFIG_BLK_CMDLINE_PARSER=y # # Partition Types # CONFIG_PARTITION_ADVANCED=y # CONFIG_ACORN_PARTITION is not set # CONFIG_AIX_PARTITION is not set # CONFIG_OSF_PARTITION is not set # CONFIG_AMIGA_PARTITION is not set # CONFIG_ATARI_PARTITION is not set # CONFIG_MAC_PARTITION is not set CONFIG_MSDOS_PARTITION=y # CONFIG_BSD_DISKLABEL is not set # CONFIG_MINIX_SUBPARTITION is not set # CONFIG_SOLARIS_X86_PARTITION is not set # CONFIG_UNIXWARE_DISKLABEL is not set # CONFIG_LDM_PARTITION is not set # CONFIG_SGI_PARTITION is not set # CONFIG_ULTRIX_PARTITION is not set # CONFIG_SUN_PARTITION is not set # CONFIG_KARMA_PARTITION is not set CONFIG_EFI_PARTITION=y # CONFIG_SYSV68_PARTITION is not set CONFIG_CMDLINE_PARTITION=y CONFIG_BLK_MQ_PCI=y # # IO Schedulers # CONFIG_IOSCHED_NOOP=y CONFIG_IOSCHED_DEADLINE=y CONFIG_IOSCHED_CFQ=y # CONFIG_CFQ_GROUP_IOSCHED is not set # CONFIG_DEFAULT_DEADLINE is not set CONFIG_DEFAULT_CFQ=y # CONFIG_DEFAULT_NOOP is not set CONFIG_DEFAULT_IOSCHED="cfq" CONFIG_UNINLINE_SPIN_UNLOCK=y CONFIG_ARCH_SUPPORTS_ATOMIC_RMW=y CONFIG_FREEZER=y # # System Type # CONFIG_MMU=y CONFIG_ARCH_MULTIPLATFORM=y # CONFIG_ARCH_GEMINI is not set # CONFIG_ARCH_EBSA110 is not set # CONFIG_ARCH_EP93XX is not set # CONFIG_ARCH_FOOTBRIDGE is not set # CONFIG_ARCH_NETX is not set # CONFIG_ARCH_IOP13XX is not set # CONFIG_ARCH_IOP32X is not set # CONFIG_ARCH_IOP33X is not set # CONFIG_ARCH_IXP4XX is not set # CONFIG_ARCH_DOVE is not set # CONFIG_ARCH_KS8695 is not set # CONFIG_ARCH_W90X900 is not set # CONFIG_ARCH_LPC32XX is not set # CONFIG_ARCH_PXA is not set # CONFIG_ARCH_RPC is not set # CONFIG_ARCH_SA1100 is not set # CONFIG_ARCH_S3C24XX is not set # CONFIG_ARCH_DAVINCI is not set # CONFIG_ARCH_OMAP1 is not set # # Multiple platform selection # # # CPU Core family selection # # CONFIG_ARCH_MULTI_V6 is not set CONFIG_ARCH_MULTI_V7=y CONFIG_ARCH_MULTI_V6_V7=y # CONFIG_ARCH_MULTI_CPU_AUTO is not set # CONFIG_ARCH_VIRT is not set # CONFIG_ARCH_MVEBU is not set # CONFIG_ARCH_ALPINE is not set # CONFIG_ARCH_ARTPEC is not set # CONFIG_ARCH_AT91 is not set # CONFIG_ARCH_BCM is not set # CONFIG_ARCH_BERLIN is not set # CONFIG_ARCH_DIGICOLOR is not set # CONFIG_ARCH_HIGHBANK is not set # CONFIG_ARCH_HISI is not set # CONFIG_ARCH_KEYSTONE is not set # CONFIG_ARCH_MESON is not set # CONFIG_ARCH_MXC is not set # CONFIG_ARCH_MEDIATEK is not set CONFIG_ARCH_OMAP=y # # TI OMAP Common Features # # # OMAP Feature Selections # CONFIG_OMAP_RESET_CLOCKS=y CONFIG_OMAP_MUX=y # CONFIG_OMAP_MUX_DEBUG is not set CONFIG_OMAP_MUX_WARNINGS=y CONFIG_OMAP_32K_TIMER=y CONFIG_OMAP_DM_TIMER=y CONFIG_OMAP_PM_NOOP=y CONFIG_MACH_OMAP_GENERIC=y # # TI OMAP/AM/DM/DRA Family # # CONFIG_ARCH_OMAP3 is not set # CONFIG_ARCH_OMAP4 is not set # CONFIG_SOC_OMAP5 is not set CONFIG_SOC_AM33XX=y # CONFIG_SOC_AM43XX is not set # CONFIG_SOC_DRA7XX is not set CONFIG_ARCH_OMAP2PLUS=y # # TI OMAP2/3/4 Specific Features # CONFIG_ARCH_OMAP2PLUS_TYPICAL=y # CONFIG_SOC_HAS_OMAP2_SDRC is not set # # OMAP Legacy Platform Data Board Type # # CONFIG_ARCH_MMP is not set # CONFIG_ARCH_QCOM is not set # CONFIG_ARCH_REALVIEW is not set # CONFIG_ARCH_ROCKCHIP is not set # CONFIG_ARCH_SOCFPGA is not set # CONFIG_PLAT_SPEAR is not set # CONFIG_ARCH_STI is not set # CONFIG_ARCH_S5PV210 is not set # CONFIG_ARCH_EXYNOS is not set # CONFIG_ARCH_RENESAS is not set # CONFIG_ARCH_SUNXI is not set # CONFIG_ARCH_SIRF is not set # CONFIG_ARCH_TANGO is not set # CONFIG_ARCH_TEGRA is not set # CONFIG_ARCH_UNIPHIER is not set # CONFIG_ARCH_U8500 is not set # CONFIG_ARCH_VEXPRESS is not set # CONFIG_ARCH_WM8850 is not set # CONFIG_ARCH_ZX is not set # CONFIG_ARCH_ZYNQ is not set # # Processor Type # CONFIG_CPU_V7=y CONFIG_CPU_32v6K=y CONFIG_CPU_32v7=y CONFIG_CPU_ABRT_EV7=y CONFIG_CPU_PABRT_V7=y CONFIG_CPU_CACHE_V7=y CONFIG_CPU_CACHE_VIPT=y CONFIG_CPU_COPY_V6=y CONFIG_CPU_TLB_V7=y CONFIG_CPU_HAS_ASID=y CONFIG_CPU_CP15=y CONFIG_CPU_CP15_MMU=y # # Processor Features # # CONFIG_ARM_LPAE is not set # CONFIG_ARCH_PHYS_ADDR_T_64BIT is not set CONFIG_ARM_THUMB=y # CONFIG_ARM_THUMBEE is not set CONFIG_ARM_VIRT_EXT=y # CONFIG_SWP_EMULATE is not set # CONFIG_CPU_ICACHE_DISABLE is not set # CONFIG_CPU_DCACHE_DISABLE is not set # CONFIG_CPU_BPREDICT_DISABLE is not set CONFIG_KUSER_HELPERS=y # CONFIG_VDSO is not set CONFIG_OUTER_CACHE=y CONFIG_OUTER_CACHE_SYNC=y CONFIG_MIGHT_HAVE_CACHE_L2X0=y CONFIG_CACHE_L2X0=y # CONFIG_CACHE_L2X0_PMU is not set # CONFIG_PL310_ERRATA_588369 is not set # CONFIG_PL310_ERRATA_727915 is not set # CONFIG_PL310_ERRATA_753970 is not set # CONFIG_PL310_ERRATA_769419 is not set CONFIG_ARM_L1_CACHE_SHIFT_6=y CONFIG_ARM_L1_CACHE_SHIFT=6 CONFIG_ARM_DMA_MEM_BUFFERABLE=y CONFIG_ARM_HEAVY_MB=y CONFIG_DEBUG_RODATA=y CONFIG_DEBUG_ALIGN_RODATA=y CONFIG_MULTI_IRQ_HANDLER=y # CONFIG_ARM_ERRATA_430973 is not set # CONFIG_ARM_ERRATA_720789 is not set # CONFIG_ARM_ERRATA_754322 is not set # CONFIG_ARM_ERRATA_775420 is not set # CONFIG_ARM_ERRATA_773022 is not set # CONFIG_ARM_ERRATA_818325_852422 is not set # CONFIG_ARM_ERRATA_821420 is not set # CONFIG_ARM_ERRATA_825619 is not set # CONFIG_ARM_ERRATA_852421 is not set # CONFIG_ARM_ERRATA_852423 is not set # # Bus support # CONFIG_PCI=y CONFIG_PCI_DOMAINS=y CONFIG_PCI_DOMAINS_GENERIC=y CONFIG_PCI_SYSCALL=y CONFIG_PCIEPORTBUS=y CONFIG_PCIEAER=y # CONFIG_PCIE_ECRC is not set # CONFIG_PCIEAER_INJECT is not set CONFIG_PCIEASPM=y # CONFIG_PCIEASPM_DEBUG is not set CONFIG_PCIEASPM_DEFAULT=y # CONFIG_PCIEASPM_POWERSAVE is not set # CONFIG_PCIEASPM_PERFORMANCE is not set CONFIG_PCIE_PME=y # CONFIG_PCIE_DPC is not set # CONFIG_PCIE_PTM is not set CONFIG_PCI_MSI=y CONFIG_PCI_MSI_IRQ_DOMAIN=y # CONFIG_PCI_DEBUG is not set # CONFIG_PCI_REALLOC_ENABLE_AUTO is not set # CONFIG_PCI_STUB is not set CONFIG_PCI_ECAM=y # CONFIG_PCI_IOV is not set # CONFIG_PCI_PRI is not set # CONFIG_PCI_PASID is not set # CONFIG_HOTPLUG_PCI is not set # # DesignWare PCI Core Support # CONFIG_PCIE_DW=y CONFIG_PCIE_DW_HOST=y CONFIG_PCIE_DW_EP=y CONFIG_PCI_DRA7XX=y CONFIG_PCI_DRA7XX_HOST=y CONFIG_PCI_DRA7XX_EP=y # CONFIG_PCIE_DW_PLAT is not set # CONFIG_PCI_LAYERSCAPE is not set # # PCI host controller drivers # CONFIG_PCI_HOST_COMMON=y CONFIG_PCI_HOST_GENERIC=y # CONFIG_PCIE_ALTERA is not set # # PCI Endpoint # CONFIG_PCI_ENDPOINT=y CONFIG_PCI_EPF_TEST=y # CONFIG_PCCARD is not set # # Kernel Features # CONFIG_HAVE_SMP=y # CONFIG_SMP is not set # CONFIG_HAVE_ARM_ARCH_TIMER is not set CONFIG_VMSPLIT_3G=y # CONFIG_VMSPLIT_3G_OPT is not set # CONFIG_VMSPLIT_2G is not set # CONFIG_VMSPLIT_1G is not set CONFIG_PAGE_OFFSET=0xC0000000 # CONFIG_ARM_PSCI is not set CONFIG_ARCH_NR_GPIO=0 # CONFIG_PREEMPT_NONE is not set # CONFIG_PREEMPT_VOLUNTARY is not set CONFIG_PREEMPT=y CONFIG_PREEMPT_COUNT=y CONFIG_HZ_FIXED=0 CONFIG_HZ_100=y # CONFIG_HZ_200 is not set # CONFIG_HZ_250 is not set # CONFIG_HZ_300 is not set # CONFIG_HZ_500 is not set # CONFIG_HZ_1000 is not set CONFIG_HZ=100 CONFIG_SCHED_HRTICK=y # CONFIG_THUMB2_KERNEL is not set CONFIG_ARM_PATCH_IDIV=y CONFIG_AEABI=y # CONFIG_OABI_COMPAT is not set CONFIG_ARCH_HAS_HOLES_MEMORYMODEL=y # CONFIG_ARCH_SPARSEMEM_DEFAULT is not set # CONFIG_ARCH_SELECT_MEMORY_MODEL is not set CONFIG_HAVE_ARCH_PFN_VALID=y CONFIG_HIGHMEM=y CONFIG_HIGHPTE=y CONFIG_CPU_SW_DOMAIN_PAN=y CONFIG_HW_PERF_EVENTS=y CONFIG_ARCH_WANT_GENERAL_HUGETLB=y # CONFIG_ARM_MODULE_PLTS is not set CONFIG_FLATMEM=y CONFIG_FLAT_NODE_MEM_MAP=y CONFIG_HAVE_MEMBLOCK=y CONFIG_NO_BOOTMEM=y CONFIG_MEMORY_ISOLATION=y # CONFIG_HAVE_BOOTMEM_INFO_NODE is not set CONFIG_SPLIT_PTLOCK_CPUS=4 CONFIG_COMPACTION=y CONFIG_MIGRATION=y # CONFIG_PHYS_ADDR_T_64BIT is not set CONFIG_BOUNCE=y # CONFIG_KSM is not set CONFIG_DEFAULT_MMAP_MIN_ADDR=4096 CONFIG_NEED_PER_CPU_KM=y # CONFIG_CLEANCACHE is not set # CONFIG_FRONTSWAP is not set CONFIG_CMA=y # CONFIG_CMA_DEBUG is not set # CONFIG_CMA_DEBUGFS is not set CONFIG_CMA_AREAS=7 # CONFIG_ZPOOL is not set # CONFIG_ZBUD is not set # CONFIG_ZSMALLOC is not set CONFIG_GENERIC_EARLY_IOREMAP=y # CONFIG_IDLE_PAGE_TRACKING is not set CONFIG_FRAME_VECTOR=y CONFIG_FORCE_MAX_ZONEORDER=12 CONFIG_ALIGNMENT_TRAP=y # CONFIG_UACCESS_WITH_MEMCPY is not set CONFIG_SECCOMP=y CONFIG_SWIOTLB=y CONFIG_IOMMU_HELPER=y # CONFIG_PARAVIRT is not set # CONFIG_PARAVIRT_TIME_ACCOUNTING is not set # CONFIG_XEN is not set # # Boot options # CONFIG_USE_OF=y CONFIG_ATAGS=y # CONFIG_DEPRECATED_PARAM_STRUCT is not set CONFIG_ZBOOT_ROM_TEXT=0x0 CONFIG_ZBOOT_ROM_BSS=0x0 CONFIG_ARM_APPENDED_DTB=y CONFIG_ARM_ATAG_DTB_COMPAT=y CONFIG_ARM_ATAG_DTB_COMPAT_CMDLINE_FROM_BOOTLOADER=y # CONFIG_ARM_ATAG_DTB_COMPAT_CMDLINE_EXTEND is not set CONFIG_CMDLINE="" CONFIG_KEXEC=y CONFIG_ATAGS_PROC=y # CONFIG_CRASH_DUMP is not set CONFIG_AUTO_ZRELADDR=y CONFIG_EFI_STUB=y CONFIG_EFI=y # # CPU Power Management # # # CPU Frequency scaling # CONFIG_CPU_FREQ=y CONFIG_CPU_FREQ_GOV_ATTR_SET=y CONFIG_CPU_FREQ_GOV_COMMON=y CONFIG_CPU_FREQ_STAT=y CONFIG_CPU_FREQ_STAT_DETAILS=y # CONFIG_CPU_FREQ_DEFAULT_GOV_PERFORMANCE is not set # CONFIG_CPU_FREQ_DEFAULT_GOV_POWERSAVE is not set # CONFIG_CPU_FREQ_DEFAULT_GOV_USERSPACE is not set CONFIG_CPU_FREQ_DEFAULT_GOV_ONDEMAND=y # CONFIG_CPU_FREQ_DEFAULT_GOV_CONSERVATIVE is not set CONFIG_CPU_FREQ_GOV_PERFORMANCE=y CONFIG_CPU_FREQ_GOV_POWERSAVE=y CONFIG_CPU_FREQ_GOV_USERSPACE=y CONFIG_CPU_FREQ_GOV_ONDEMAND=y CONFIG_CPU_FREQ_GOV_CONSERVATIVE=y # # CPU frequency scaling drivers # CONFIG_CPUFREQ_DT=y CONFIG_CPUFREQ_DT_PLATDEV=y # CONFIG_ARM_KIRKWOOD_CPUFREQ is not set # CONFIG_ARM_OMAP2PLUS_CPUFREQ is not set CONFIG_ARM_TI_CPUFREQ=y # CONFIG_QORIQ_CPUFREQ is not set # # CPU Idle # CONFIG_CPU_IDLE=y CONFIG_CPU_IDLE_GOV_LADDER=y CONFIG_CPU_IDLE_GOV_MENU=y CONFIG_DT_IDLE_STATES=y # # ARM CPU Idle Drivers # CONFIG_ARM_CPUIDLE=y # CONFIG_ARCH_NEEDS_CPU_IDLE_COUPLED is not set # # Floating point emulation # # # At least one emulation must be selected # CONFIG_VFP=y CONFIG_VFPv3=y CONFIG_NEON=y CONFIG_KERNEL_MODE_NEON=y # # Userspace binary formats # CONFIG_BINFMT_ELF=y CONFIG_ELFCORE=y CONFIG_CORE_DUMP_DEFAULT_ELF_HEADERS=y CONFIG_BINFMT_SCRIPT=y # CONFIG_BINFMT_FLAT is not set # CONFIG_HAVE_AOUT is not set # CONFIG_BINFMT_MISC is not set CONFIG_COREDUMP=y # # Power management options # CONFIG_SUSPEND=y CONFIG_SUSPEND_FREEZER=y # CONFIG_SUSPEND_SKIP_SYNC is not set # CONFIG_HIBERNATION is not set CONFIG_PM_SLEEP=y # CONFIG_PM_AUTOSLEEP is not set # CONFIG_PM_WAKELOCKS is not set CONFIG_PM=y CONFIG_PM_DEBUG=y # CONFIG_PM_ADVANCED_DEBUG is not set # CONFIG_PM_TEST_SUSPEND is not set CONFIG_PM_SLEEP_DEBUG=y # CONFIG_APM_EMULATION is not set CONFIG_PM_OPP=y CONFIG_PM_CLK=y # CONFIG_WQ_POWER_EFFICIENT_DEFAULT is not set CONFIG_CPU_PM=y CONFIG_ARCH_SUSPEND_POSSIBLE=y CONFIG_ARM_CPU_SUSPEND=y CONFIG_ARCH_HIBERNATION_POSSIBLE=y CONFIG_NET=y CONFIG_NET_INGRESS=y CONFIG_NET_EGRESS=y # # Networking options # CONFIG_PACKET=y # CONFIG_PACKET_DIAG is not set CONFIG_UNIX=y # CONFIG_UNIX_DIAG is not set CONFIG_XFRM=y CONFIG_XFRM_ALGO=m CONFIG_XFRM_USER=m # CONFIG_XFRM_SUB_POLICY is not set # CONFIG_XFRM_MIGRATE is not set # CONFIG_XFRM_STATISTICS is not set CONFIG_XFRM_IPCOMP=m CONFIG_NET_KEY=m # CONFIG_NET_KEY_MIGRATE is not set CONFIG_INET=y CONFIG_WIREGUARD=m # CONFIG_WIREGUARD_DEBUG is not set CONFIG_IP_MULTICAST=y # CONFIG_IP_ADVANCED_ROUTER is not set CONFIG_IP_ROUTE_CLASSID=y CONFIG_IP_PNP=y CONFIG_IP_PNP_DHCP=y CONFIG_IP_PNP_BOOTP=y CONFIG_IP_PNP_RARP=y # CONFIG_NET_IPIP is not set # CONFIG_NET_IPGRE_DEMUX is not set CONFIG_NET_IP_TUNNEL=y # CONFIG_IP_MROUTE is not set # CONFIG_SYN_COOKIES is not set # CONFIG_NET_IPVTI is not set CONFIG_NET_UDP_TUNNEL=m # CONFIG_NET_FOU is not set # CONFIG_NET_FOU_IP_TUNNELS is not set CONFIG_INET_AH=m CONFIG_INET_ESP=m CONFIG_INET_IPCOMP=m CONFIG_INET_XFRM_TUNNEL=m CONFIG_INET_TUNNEL=y CONFIG_INET_XFRM_MODE_TRANSPORT=m CONFIG_INET_XFRM_MODE_TUNNEL=m CONFIG_INET_XFRM_MODE_BEET=m CONFIG_INET_DIAG=y CONFIG_INET_TCP_DIAG=y # CONFIG_INET_UDP_DIAG is not set # CONFIG_INET_DIAG_DESTROY is not set # CONFIG_TCP_CONG_ADVANCED is not set CONFIG_TCP_CONG_CUBIC=y CONFIG_DEFAULT_TCP_CONG="cubic" # CONFIG_TCP_MD5SIG is not set CONFIG_IPV6=y CONFIG_IPV6_ROUTER_PREF=y # CONFIG_IPV6_ROUTE_INFO is not set CONFIG_IPV6_OPTIMISTIC_DAD=y CONFIG_INET6_AH=m CONFIG_INET6_ESP=m CONFIG_INET6_IPCOMP=m CONFIG_IPV6_MIP6=m # CONFIG_IPV6_ILA is not set CONFIG_INET6_XFRM_TUNNEL=m CONFIG_INET6_TUNNEL=m CONFIG_INET6_XFRM_MODE_TRANSPORT=y CONFIG_INET6_XFRM_MODE_TUNNEL=y CONFIG_INET6_XFRM_MODE_BEET=y # CONFIG_INET6_XFRM_MODE_ROUTEOPTIMIZATION is not set # CONFIG_IPV6_VTI is not set CONFIG_IPV6_SIT=y # CONFIG_IPV6_SIT_6RD is not set CONFIG_IPV6_NDISC_NODETYPE=y CONFIG_IPV6_TUNNEL=m # CONFIG_IPV6_FOU is not set # CONFIG_IPV6_FOU_TUNNEL is not set CONFIG_IPV6_MULTIPLE_TABLES=y # CONFIG_IPV6_SUBTREES is not set # CONFIG_IPV6_MROUTE is not set # CONFIG_NETWORK_SECMARK is not set CONFIG_NET_PTP_CLASSIFY=y # CONFIG_NETWORK_PHY_TIMESTAMPING is not set CONFIG_NETFILTER=y # CONFIG_NETFILTER_DEBUG is not set CONFIG_NETFILTER_ADVANCED=y CONFIG_BRIDGE_NETFILTER=m # # Core Netfilter Configuration # CONFIG_NETFILTER_INGRESS=y # CONFIG_NETFILTER_NETLINK_ACCT is not set # CONFIG_NETFILTER_NETLINK_QUEUE is not set # CONFIG_NETFILTER_NETLINK_LOG is not set CONFIG_NF_CONNTRACK=m # CONFIG_NF_CONNTRACK_MARK is not set CONFIG_NF_CONNTRACK_PROCFS=y # CONFIG_NF_CONNTRACK_EVENTS is not set # CONFIG_NF_CONNTRACK_TIMEOUT is not set # CONFIG_NF_CONNTRACK_TIMESTAMP is not set # CONFIG_NF_CT_PROTO_DCCP is not set CONFIG_NF_CT_PROTO_SCTP=m # CONFIG_NF_CT_PROTO_UDPLITE is not set # CONFIG_NF_CONNTRACK_AMANDA is not set # CONFIG_NF_CONNTRACK_FTP is not set # CONFIG_NF_CONNTRACK_H323 is not set # CONFIG_NF_CONNTRACK_IRC is not set # CONFIG_NF_CONNTRACK_NETBIOS_NS is not set # CONFIG_NF_CONNTRACK_SNMP is not set # CONFIG_NF_CONNTRACK_PPTP is not set # CONFIG_NF_CONNTRACK_SANE is not set # CONFIG_NF_CONNTRACK_SIP is not set # CONFIG_NF_CONNTRACK_TFTP is not set # CONFIG_NF_CT_NETLINK is not set # CONFIG_NF_CT_NETLINK_TIMEOUT is not set CONFIG_NF_NAT=m CONFIG_NF_NAT_NEEDED=y CONFIG_NF_NAT_PROTO_SCTP=m # CONFIG_NF_NAT_AMANDA is not set # CONFIG_NF_NAT_FTP is not set # CONFIG_NF_NAT_IRC is not set # CONFIG_NF_NAT_SIP is not set # CONFIG_NF_NAT_TFTP is not set # CONFIG_NF_NAT_REDIRECT is not set # CONFIG_NF_TABLES is not set CONFIG_NETFILTER_XTABLES=m # # Xtables combined modules # CONFIG_NETFILTER_XT_MARK=m # CONFIG_NETFILTER_XT_CONNMARK is not set # # Xtables targets # CONFIG_NETFILTER_XT_TARGET_CLASSIFY=m # CONFIG_NETFILTER_XT_TARGET_CONNMARK is not set # CONFIG_NETFILTER_XT_TARGET_HMARK is not set CONFIG_NETFILTER_XT_TARGET_IDLETIMER=m # CONFIG_NETFILTER_XT_TARGET_LED is not set # CONFIG_NETFILTER_XT_TARGET_LOG is not set CONFIG_NETFILTER_XT_TARGET_MARK=m CONFIG_NETFILTER_XT_NAT=m # CONFIG_NETFILTER_XT_TARGET_NETMAP is not set # CONFIG_NETFILTER_XT_TARGET_NFLOG is not set # CONFIG_NETFILTER_XT_TARGET_NFQUEUE is not set # CONFIG_NETFILTER_XT_TARGET_RATEEST is not set # CONFIG_NETFILTER_XT_TARGET_REDIRECT is not set # CONFIG_NETFILTER_XT_TARGET_TEE is not set # CONFIG_NETFILTER_XT_TARGET_TCPMSS is not set # # Xtables matches # # CONFIG_NETFILTER_XT_MATCH_ADDRTYPE is not set # CONFIG_NETFILTER_XT_MATCH_BPF is not set # CONFIG_NETFILTER_XT_MATCH_CGROUP is not set # CONFIG_NETFILTER_XT_MATCH_CLUSTER is not set CONFIG_NETFILTER_XT_MATCH_COMMENT=m # CONFIG_NETFILTER_XT_MATCH_CONNBYTES is not set # CONFIG_NETFILTER_XT_MATCH_CONNLABEL is not set # CONFIG_NETFILTER_XT_MATCH_CONNLIMIT is not set # CONFIG_NETFILTER_XT_MATCH_CONNMARK is not set # CONFIG_NETFILTER_XT_MATCH_CONNTRACK is not set CONFIG_NETFILTER_XT_MATCH_CPU=m # CONFIG_NETFILTER_XT_MATCH_DCCP is not set # CONFIG_NETFILTER_XT_MATCH_DEVGROUP is not set # CONFIG_NETFILTER_XT_MATCH_DSCP is not set # CONFIG_NETFILTER_XT_MATCH_ECN is not set # CONFIG_NETFILTER_XT_MATCH_ESP is not set # CONFIG_NETFILTER_XT_MATCH_HASHLIMIT is not set # CONFIG_NETFILTER_XT_MATCH_HELPER is not set # CONFIG_NETFILTER_XT_MATCH_HL is not set # CONFIG_NETFILTER_XT_MATCH_IPCOMP is not set CONFIG_NETFILTER_XT_MATCH_IPRANGE=m # CONFIG_NETFILTER_XT_MATCH_L2TP is not set CONFIG_NETFILTER_XT_MATCH_LENGTH=m CONFIG_NETFILTER_XT_MATCH_LIMIT=m CONFIG_NETFILTER_XT_MATCH_MAC=m CONFIG_NETFILTER_XT_MATCH_MARK=m CONFIG_NETFILTER_XT_MATCH_MULTIPORT=m # CONFIG_NETFILTER_XT_MATCH_NFACCT is not set # CONFIG_NETFILTER_XT_MATCH_OWNER is not set CONFIG_NETFILTER_XT_MATCH_POLICY=m # CONFIG_NETFILTER_XT_MATCH_PHYSDEV is not set CONFIG_NETFILTER_XT_MATCH_PKTTYPE=m # CONFIG_NETFILTER_XT_MATCH_QUOTA is not set # CONFIG_NETFILTER_XT_MATCH_RATEEST is not set # CONFIG_NETFILTER_XT_MATCH_REALM is not set # CONFIG_NETFILTER_XT_MATCH_RECENT is not set CONFIG_NETFILTER_XT_MATCH_SCTP=m # CONFIG_NETFILTER_XT_MATCH_SOCKET is not set # CONFIG_NETFILTER_XT_MATCH_STATE is not set # CONFIG_NETFILTER_XT_MATCH_STATISTIC is not set # CONFIG_NETFILTER_XT_MATCH_STRING is not set # CONFIG_NETFILTER_XT_MATCH_TCPMSS is not set # CONFIG_NETFILTER_XT_MATCH_TIME is not set # CONFIG_NETFILTER_XT_MATCH_U32 is not set # CONFIG_IP_SET is not set # CONFIG_IP_VS is not set # # IP: Netfilter Configuration # CONFIG_NF_DEFRAG_IPV4=m CONFIG_NF_CONNTRACK_IPV4=m # CONFIG_NF_DUP_IPV4 is not set # CONFIG_NF_LOG_ARP is not set # CONFIG_NF_LOG_IPV4 is not set # CONFIG_NF_REJECT_IPV4 is not set CONFIG_NF_NAT_IPV4=m CONFIG_NF_NAT_MASQUERADE_IPV4=m # CONFIG_NF_NAT_PPTP is not set # CONFIG_NF_NAT_H323 is not set CONFIG_IP_NF_IPTABLES=m # CONFIG_IP_NF_MATCH_AH is not set # CONFIG_IP_NF_MATCH_ECN is not set # CONFIG_IP_NF_MATCH_TTL is not set CONFIG_IP_NF_FILTER=m # CONFIG_IP_NF_TARGET_REJECT is not set # CONFIG_IP_NF_TARGET_SYNPROXY is not set CONFIG_IP_NF_NAT=m CONFIG_IP_NF_TARGET_MASQUERADE=m # CONFIG_IP_NF_TARGET_NETMAP is not set # CONFIG_IP_NF_TARGET_REDIRECT is not set # CONFIG_IP_NF_MANGLE is not set # CONFIG_IP_NF_RAW is not set CONFIG_IP_NF_ARPTABLES=m CONFIG_IP_NF_ARPFILTER=m CONFIG_IP_NF_ARP_MANGLE=m # # IPv6: Netfilter Configuration # # CONFIG_NF_DEFRAG_IPV6 is not set # CONFIG_NF_CONNTRACK_IPV6 is not set # CONFIG_NF_DUP_IPV6 is not set # CONFIG_NF_REJECT_IPV6 is not set # CONFIG_NF_LOG_IPV6 is not set # CONFIG_IP6_NF_IPTABLES is not set CONFIG_BRIDGE_NF_EBTABLES=m CONFIG_BRIDGE_EBT_BROUTE=m CONFIG_BRIDGE_EBT_T_FILTER=m CONFIG_BRIDGE_EBT_T_NAT=m CONFIG_BRIDGE_EBT_802_3=m CONFIG_BRIDGE_EBT_AMONG=m CONFIG_BRIDGE_EBT_ARP=m CONFIG_BRIDGE_EBT_IP=m CONFIG_BRIDGE_EBT_IP6=m CONFIG_BRIDGE_EBT_LIMIT=m CONFIG_BRIDGE_EBT_MARK=m CONFIG_BRIDGE_EBT_PKTTYPE=m CONFIG_BRIDGE_EBT_STP=m CONFIG_BRIDGE_EBT_VLAN=m CONFIG_BRIDGE_EBT_ARPREPLY=m CONFIG_BRIDGE_EBT_DNAT=m CONFIG_BRIDGE_EBT_MARK_T=m CONFIG_BRIDGE_EBT_REDIRECT=m CONFIG_BRIDGE_EBT_SNAT=m CONFIG_BRIDGE_EBT_LOG=m CONFIG_BRIDGE_EBT_NFLOG=m # CONFIG_IP_DCCP is not set CONFIG_IP_SCTP=m # CONFIG_SCTP_DBG_OBJCNT is not set CONFIG_SCTP_DEFAULT_COOKIE_HMAC_MD5=y # CONFIG_SCTP_DEFAULT_COOKIE_HMAC_SHA1 is not set # CONFIG_SCTP_DEFAULT_COOKIE_HMAC_NONE is not set CONFIG_SCTP_COOKIE_HMAC_MD5=y # CONFIG_SCTP_COOKIE_HMAC_SHA1 is not set CONFIG_INET_SCTP_DIAG=m # CONFIG_RDS is not set # CONFIG_TIPC is not set # CONFIG_ATM is not set # CONFIG_L2TP is not set CONFIG_STP=m CONFIG_BRIDGE=m CONFIG_BRIDGE_IGMP_SNOOPING=y # CONFIG_BRIDGE_VLAN_FILTERING is not set CONFIG_HAVE_NET_DSA=y CONFIG_NET_DSA=m CONFIG_NET_DSA_HWMON=y CONFIG_VLAN_8021Q=m # CONFIG_VLAN_8021Q_GVRP is not set # CONFIG_VLAN_8021Q_MVRP is not set # CONFIG_DECNET is not set CONFIG_LLC=m # CONFIG_LLC2 is not set # CONFIG_IPX is not set # CONFIG_ATALK is not set # CONFIG_X25 is not set # CONFIG_LAPB is not set # CONFIG_PHONET is not set # CONFIG_6LOWPAN is not set # CONFIG_IEEE802154 is not set CONFIG_NET_SCHED=y # # Queueing/Scheduling # CONFIG_NET_SCH_CBQ=m CONFIG_NET_SCH_HTB=m CONFIG_NET_SCH_HFSC=m CONFIG_NET_SCH_PRIO=m CONFIG_NET_SCH_MULTIQ=m CONFIG_NET_SCH_RED=m CONFIG_NET_SCH_SFB=m CONFIG_NET_SCH_SFQ=m CONFIG_NET_SCH_TEQL=m CONFIG_NET_SCH_TBF=m CONFIG_NET_SCH_GRED=m CONFIG_NET_SCH_DSMARK=m CONFIG_NET_SCH_NETEM=m CONFIG_NET_SCH_DRR=m CONFIG_NET_SCH_MQPRIO=m CONFIG_NET_SCH_CHOKE=m CONFIG_NET_SCH_QFQ=m CONFIG_NET_SCH_CODEL=m CONFIG_NET_SCH_FQ_CODEL=m # CONFIG_NET_SCH_FQ is not set # CONFIG_NET_SCH_HHF is not set # CONFIG_NET_SCH_PIE is not set CONFIG_NET_SCH_INGRESS=m # CONFIG_NET_SCH_PLUG is not set # # Classification # CONFIG_NET_CLS=y CONFIG_NET_CLS_BASIC=m CONFIG_NET_CLS_TCINDEX=m CONFIG_NET_CLS_ROUTE4=m CONFIG_NET_CLS_FW=m CONFIG_NET_CLS_U32=m # CONFIG_CLS_U32_PERF is not set CONFIG_CLS_U32_MARK=y CONFIG_NET_CLS_RSVP=m CONFIG_NET_CLS_RSVP6=m CONFIG_NET_CLS_FLOW=m # CONFIG_NET_CLS_CGROUP is not set # CONFIG_NET_CLS_BPF is not set # CONFIG_NET_CLS_FLOWER is not set # CONFIG_NET_CLS_MATCHALL is not set CONFIG_NET_EMATCH=y CONFIG_NET_EMATCH_STACK=32 CONFIG_NET_EMATCH_CMP=m CONFIG_NET_EMATCH_NBYTE=m CONFIG_NET_EMATCH_U32=m CONFIG_NET_EMATCH_META=m CONFIG_NET_EMATCH_TEXT=m # CONFIG_NET_EMATCH_CANID is not set CONFIG_NET_CLS_ACT=y CONFIG_NET_ACT_POLICE=m CONFIG_NET_ACT_GACT=m CONFIG_GACT_PROB=y CONFIG_NET_ACT_MIRRED=m CONFIG_NET_ACT_IPT=m CONFIG_NET_ACT_NAT=m CONFIG_NET_ACT_PEDIT=m CONFIG_NET_ACT_SIMP=m CONFIG_NET_ACT_SKBEDIT=m CONFIG_NET_ACT_CSUM=m # CONFIG_NET_ACT_VLAN is not set # CONFIG_NET_ACT_BPF is not set # CONFIG_NET_ACT_SKBMOD is not set # CONFIG_NET_ACT_IFE is not set # CONFIG_NET_ACT_TUNNEL_KEY is not set CONFIG_NET_CLS_IND=y CONFIG_NET_SCH_FIFO=y # CONFIG_DCB is not set CONFIG_DNS_RESOLVER=y # CONFIG_BATMAN_ADV is not set # CONFIG_OPENVSWITCH is not set # CONFIG_VSOCKETS is not set # CONFIG_NETLINK_DIAG is not set # CONFIG_MPLS is not set # CONFIG_HSR is not set CONFIG_NET_SWITCHDEV=y # CONFIG_NET_L3_MASTER_DEV is not set # CONFIG_NET_NCSI is not set # CONFIG_SOCK_CGROUP_DATA is not set # CONFIG_CGROUP_NET_PRIO is not set # CONFIG_CGROUP_NET_CLASSID is not set CONFIG_NET_RX_BUSY_POLL=y CONFIG_BQL=y # CONFIG_BPF_JIT is not set # # Network testing # # CONFIG_NET_PKTGEN is not set # CONFIG_HAMRADIO is not set CONFIG_CAN=m CONFIG_CAN_RAW=m CONFIG_CAN_BCM=m CONFIG_CAN_GW=m # # CAN Device Drivers # # CONFIG_CAN_VCAN is not set # CONFIG_CAN_SLCAN is not set CONFIG_CAN_DEV=m CONFIG_CAN_CALC_BITTIMING=y # CONFIG_CAN_LEDS is not set # CONFIG_CAN_FLEXCAN is not set # CONFIG_CAN_GRCAN is not set # CONFIG_CAN_TI_HECC is not set CONFIG_CAN_C_CAN=m CONFIG_CAN_C_CAN_PLATFORM=m # CONFIG_CAN_C_CAN_PCI is not set # CONFIG_CAN_CC770 is not set # CONFIG_CAN_IFI_CANFD is not set CONFIG_CAN_M_CAN=m CONFIG_CAN_RCAR=m # CONFIG_CAN_RCAR_CANFD is not set # CONFIG_CAN_SJA1000 is not set # CONFIG_CAN_SOFTING is not set # # CAN SPI interfaces # CONFIG_CAN_MCP251X=m # # CAN USB interfaces # # CONFIG_CAN_EMS_USB is not set # CONFIG_CAN_ESD_USB2 is not set # CONFIG_CAN_GS_USB is not set # CONFIG_CAN_KVASER_USB is not set # CONFIG_CAN_PEAK_USB is not set # CONFIG_CAN_8DEV_USB is not set # CONFIG_CAN_DEBUG_DEVICES is not set # CONFIG_IRDA is not set CONFIG_BT=m CONFIG_BT_BREDR=y CONFIG_BT_RFCOMM=m # CONFIG_BT_RFCOMM_TTY is not set # CONFIG_BT_BNEP is not set # CONFIG_BT_HIDP is not set CONFIG_BT_HS=y CONFIG_BT_LE=y # CONFIG_BT_LEDS is not set # CONFIG_BT_SELFTEST is not set CONFIG_BT_DEBUGFS=y # # Bluetooth device drivers # # CONFIG_BT_HCIBTUSB is not set # CONFIG_BT_HCIBTSDIO is not set CONFIG_BT_HCIUART=m CONFIG_BT_HCIUART_H4=y # CONFIG_BT_HCIUART_BCSP is not set # CONFIG_BT_HCIUART_ATH3K is not set CONFIG_BT_HCIUART_LL=y CONFIG_BT_HCIUART_3WIRE=y # CONFIG_BT_HCIUART_INTEL is not set # CONFIG_BT_HCIUART_BCM is not set # CONFIG_BT_HCIUART_QCA is not set # CONFIG_BT_HCIUART_AG6XX is not set # CONFIG_BT_HCIUART_MRVL is not set # CONFIG_BT_HCIBCM203X is not set # CONFIG_BT_HCIBPA10X is not set # CONFIG_BT_HCIBFUSB is not set # CONFIG_BT_HCIVHCI is not set CONFIG_BT_MRVL=m CONFIG_BT_MRVL_SDIO=m # CONFIG_AF_RXRPC is not set # CONFIG_AF_KCM is not set # CONFIG_STREAM_PARSER is not set CONFIG_FIB_RULES=y CONFIG_WIRELESS=y CONFIG_CFG80211=m # CONFIG_NL80211_TESTMODE is not set # CONFIG_CFG80211_DEVELOPER_WARNINGS is not set # CONFIG_CFG80211_CERTIFICATION_ONUS is not set CONFIG_CFG80211_DEFAULT_PS=y # CONFIG_CFG80211_DEBUGFS is not set # CONFIG_CFG80211_INTERNAL_REGDB is not set CONFIG_CFG80211_CRDA_SUPPORT=y # CONFIG_CFG80211_WEXT is not set # CONFIG_LIB80211 is not set CONFIG_MAC80211=m CONFIG_MAC80211_HAS_RC=y CONFIG_MAC80211_RC_MINSTREL=y CONFIG_MAC80211_RC_MINSTREL_HT=y # CONFIG_MAC80211_RC_MINSTREL_VHT is not set CONFIG_MAC80211_RC_DEFAULT_MINSTREL=y CONFIG_MAC80211_RC_DEFAULT="minstrel_ht" # CONFIG_MAC80211_MESH is not set CONFIG_MAC80211_LEDS=y # CONFIG_MAC80211_DEBUGFS is not set # CONFIG_MAC80211_MESSAGE_TRACING is not set # CONFIG_MAC80211_DEBUG_MENU is not set CONFIG_MAC80211_STA_HASH_MAX_SIZE=0 # CONFIG_WIMAX is not set CONFIG_RFKILL=y CONFIG_RFKILL_LEDS=y CONFIG_RFKILL_INPUT=y # CONFIG_RFKILL_REGULATOR is not set CONFIG_RFKILL_GPIO=y # CONFIG_NET_9P is not set # CONFIG_CAIF is not set # CONFIG_CEPH_LIB is not set # CONFIG_NFC is not set # CONFIG_LWTUNNEL is not set CONFIG_DST_CACHE=y # CONFIG_NET_DEVLINK is not set CONFIG_MAY_USE_DEVLINK=y CONFIG_HAVE_CBPF_JIT=y # # Device Drivers # # # Generic Driver Options # CONFIG_UEVENT_HELPER=y CONFIG_UEVENT_HELPER_PATH="" CONFIG_DEVTMPFS=y CONFIG_DEVTMPFS_MOUNT=y CONFIG_STANDALONE=y CONFIG_PREVENT_FIRMWARE_BUILD=y CONFIG_FW_LOADER=y CONFIG_FIRMWARE_IN_KERNEL=y CONFIG_EXTRA_FIRMWARE="" # CONFIG_FW_LOADER_USER_HELPER_FALLBACK is not set CONFIG_WANT_DEV_COREDUMP=y CONFIG_ALLOW_DEV_COREDUMP=y CONFIG_DEV_COREDUMP=y # CONFIG_DEBUG_DRIVER is not set # CONFIG_DEBUG_DEVRES is not set # CONFIG_DEBUG_TEST_DRIVER_REMOVE is not set # CONFIG_SYS_HYPERVISOR is not set # CONFIG_GENERIC_CPU_DEVICES is not set CONFIG_SOC_BUS=y CONFIG_REGMAP=y CONFIG_REGMAP_I2C=y CONFIG_REGMAP_SPI=y CONFIG_REGMAP_MMIO=y CONFIG_REGMAP_IRQ=y CONFIG_DMA_SHARED_BUFFER=y # CONFIG_FENCE_TRACE is not set CONFIG_DMA_CMA=y # # Default contiguous memory area size: # CONFIG_CMA_SIZE_MBYTES=48 CONFIG_CMA_SIZE_SEL_MBYTES=y # CONFIG_CMA_SIZE_SEL_PERCENTAGE is not set # CONFIG_CMA_SIZE_SEL_MIN is not set # CONFIG_CMA_SIZE_SEL_MAX is not set CONFIG_CMA_ALIGNMENT=8 # # Bus devices # # CONFIG_ARM_CCI400_PMU is not set # CONFIG_ARM_CCI5xx_PMU is not set # CONFIG_ARM_CCN is not set # CONFIG_BRCMSTB_GISB_ARB is not set # CONFIG_OMAP_INTERCONNECT is not set CONFIG_OMAP_OCP2SCP=y CONFIG_SIMPLE_PM_BUS=y # CONFIG_VEXPRESS_CONFIG is not set # CONFIG_CONNECTOR is not set CONFIG_MTD=y CONFIG_MTD_TESTS=m # CONFIG_MTD_REDBOOT_PARTS is not set CONFIG_MTD_CMDLINE_PARTS=y # CONFIG_MTD_AFS_PARTS is not set CONFIG_MTD_OF_PARTS=y # CONFIG_MTD_AR7_PARTS is not set # # User Modules And Translation Layers # CONFIG_MTD_BLKDEVS=y CONFIG_MTD_BLOCK=y # CONFIG_FTL is not set # CONFIG_NFTL is not set # CONFIG_INFTL is not set # CONFIG_RFD_FTL is not set # CONFIG_SSFDC is not set # CONFIG_SM_FTL is not set # CONFIG_MTD_OOPS is not set # CONFIG_MTD_SWAP is not set # CONFIG_MTD_PARTITIONED_MASTER is not set # # RAM/ROM/Flash chip drivers # # CONFIG_MTD_CFI is not set # CONFIG_MTD_JEDECPROBE is not set CONFIG_MTD_MAP_BANK_WIDTH_1=y CONFIG_MTD_MAP_BANK_WIDTH_2=y CONFIG_MTD_MAP_BANK_WIDTH_4=y # CONFIG_MTD_MAP_BANK_WIDTH_8 is not set # CONFIG_MTD_MAP_BANK_WIDTH_16 is not set # CONFIG_MTD_MAP_BANK_WIDTH_32 is not set CONFIG_MTD_CFI_I1=y CONFIG_MTD_CFI_I2=y # CONFIG_MTD_CFI_I4 is not set # CONFIG_MTD_CFI_I8 is not set # CONFIG_MTD_RAM is not set # CONFIG_MTD_ROM is not set # CONFIG_MTD_ABSENT is not set # # Mapping drivers for chip access # # CONFIG_MTD_COMPLEX_MAPPINGS is not set # CONFIG_MTD_INTEL_VR_NOR is not set # CONFIG_MTD_PLATRAM is not set # # Self-contained MTD device drivers # # CONFIG_MTD_PMC551 is not set # CONFIG_MTD_DATAFLASH is not set CONFIG_MTD_M25P80=y # CONFIG_MTD_SST25L is not set # CONFIG_MTD_SLRAM is not set # CONFIG_MTD_PHRAM is not set # CONFIG_MTD_MTDRAM is not set # CONFIG_MTD_BLOCK2MTD is not set # # Disk-On-Chip Device Drivers # # CONFIG_MTD_DOCG3 is not set CONFIG_MTD_NAND_ECC=y # CONFIG_MTD_NAND_ECC_SMC is not set CONFIG_MTD_NAND=y # CONFIG_MTD_NAND_ECC_BCH is not set # CONFIG_MTD_SM_COMMON is not set CONFIG_MTD_NAND_DENALI=y # CONFIG_MTD_NAND_DENALI_PCI is not set CONFIG_MTD_NAND_DENALI_DT=y # CONFIG_MTD_NAND_GPIO is not set CONFIG_MTD_NAND_OMAP2=y CONFIG_MTD_NAND_OMAP_BCH=y CONFIG_MTD_NAND_OMAP_BCH_BUILD=y CONFIG_MTD_NAND_IDS=y # CONFIG_MTD_NAND_RICOH is not set # CONFIG_MTD_NAND_DISKONCHIP is not set # CONFIG_MTD_NAND_DOCG4 is not set # CONFIG_MTD_NAND_CAFE is not set # CONFIG_MTD_NAND_NANDSIM is not set CONFIG_MTD_NAND_BRCMNAND=y # CONFIG_MTD_NAND_PLATFORM is not set # CONFIG_MTD_NAND_HISI504 is not set # CONFIG_MTD_NAND_MTK is not set # CONFIG_MTD_ONENAND is not set # # LPDDR & LPDDR2 PCM memory drivers # # CONFIG_MTD_LPDDR is not set # CONFIG_MTD_LPDDR2_NVM is not set CONFIG_MTD_SPI_NOR=y # CONFIG_MTD_MT81xx_NOR is not set # CONFIG_MTD_SPI_NOR_USE_4K_SECTORS is not set CONFIG_SPI_CADENCE_QUADSPI=y CONFIG_MTD_UBI=y CONFIG_MTD_UBI_WL_THRESHOLD=4096 CONFIG_MTD_UBI_BEB_LIMIT=20 # CONFIG_MTD_UBI_FASTMAP is not set # CONFIG_MTD_UBI_GLUEBI is not set # CONFIG_MTD_UBI_BLOCK is not set CONFIG_DTC=y CONFIG_OF=y # CONFIG_OF_UNITTEST is not set CONFIG_OF_FLATTREE=y CONFIG_OF_EARLY_FLATTREE=y CONFIG_OF_DYNAMIC=y CONFIG_OF_ADDRESS=y CONFIG_OF_ADDRESS_PCI=y CONFIG_OF_IRQ=y CONFIG_OF_NET=y CONFIG_OF_MDIO=y CONFIG_OF_PCI=y CONFIG_OF_PCI_IRQ=y CONFIG_OF_RESERVED_MEM=y CONFIG_OF_RESOLVE=y CONFIG_OF_OVERLAY=y # CONFIG_OF_CONFIGFS is not set CONFIG_ARCH_MIGHT_HAVE_PC_PARPORT=y # CONFIG_PARPORT is not set CONFIG_BLK_DEV=y # CONFIG_BLK_DEV_NULL_BLK is not set # CONFIG_BLK_DEV_PCIESSD_MTIP32XX is not set # CONFIG_BLK_CPQ_CISS_DA is not set # CONFIG_BLK_DEV_DAC960 is not set # CONFIG_BLK_DEV_UMEM is not set # CONFIG_BLK_DEV_COW_COMMON is not set CONFIG_BLK_DEV_LOOP=y CONFIG_BLK_DEV_LOOP_MIN_COUNT=8 # CONFIG_BLK_DEV_CRYPTOLOOP is not set # CONFIG_BLK_DEV_DRBD is not set # CONFIG_BLK_DEV_NBD is not set # CONFIG_BLK_DEV_SX8 is not set CONFIG_BLK_DEV_RAM=y CONFIG_BLK_DEV_RAM_COUNT=16 CONFIG_BLK_DEV_RAM_SIZE=65536 # CONFIG_CDROM_PKTCDVD is not set # CONFIG_ATA_OVER_ETH is not set # CONFIG_MG_DISK is not set CONFIG_VIRTIO_BLK=y # CONFIG_BLK_DEV_RBD is not set # CONFIG_BLK_DEV_RSXX is not set # CONFIG_BLK_DEV_NVME is not set # CONFIG_NVME_TARGET is not set # # Misc devices # # CONFIG_SENSORS_LIS3LV02D is not set CONFIG_AD525X_DPOT=y CONFIG_AD525X_DPOT_I2C=y # CONFIG_AD525X_DPOT_SPI is not set # CONFIG_DUMMY_IRQ is not set # CONFIG_PHANTOM is not set # CONFIG_SGI_IOC4 is not set # CONFIG_TIFM_CORE is not set CONFIG_ICS932S401=y # CONFIG_ENCLOSURE_SERVICES is not set # CONFIG_HP_ILO is not set CONFIG_APDS9802ALS=y CONFIG_ISL29003=y # CONFIG_ISL29020 is not set # CONFIG_SENSORS_TSL2550 is not set # CONFIG_SENSORS_BH1770 is not set # CONFIG_SENSORS_APDS990X is not set # CONFIG_HMC6352 is not set # CONFIG_DS1682 is not set # CONFIG_TI_DAC7512 is not set # CONFIG_USB_SWITCH_FSA9480 is not set # CONFIG_LATTICE_ECP3_CONFIG is not set CONFIG_SRAM=y CONFIG_PCI_ENDPOINT_TEST=m CONFIG_BONE_CAPEMGR=y # CONFIG_BEAGLELOGIC is not set # CONFIG_DEV_OVERLAYMGR is not set # CONFIG_TIEQEP is not set # CONFIG_C2PORT is not set # # EEPROM support # CONFIG_EEPROM_AT24=y # CONFIG_EEPROM_AT25 is not set # CONFIG_EEPROM_LEGACY is not set # CONFIG_EEPROM_MAX6875 is not set CONFIG_EEPROM_93CX6=y # CONFIG_EEPROM_93XX46 is not set # CONFIG_CB710_CORE is not set # # Texas Instruments shared transport line discipline # # CONFIG_TI_ST is not set # CONFIG_SENSORS_LIS3_SPI is not set # CONFIG_SENSORS_LIS3_I2C is not set # # Altera FPGA firmware download module # # CONFIG_ALTERA_STAPL is not set # # Intel MIC Bus Driver # # # SCIF Bus Driver # # # VOP Bus Driver # # # Intel MIC Host Driver # # # Intel MIC Card Driver # # # SCIF Driver # # # Intel MIC Coprocessor State Management (COSM) Drivers # # # VOP Driver # # # Argus cape driver for beaglebone black # CONFIG_CAPE_BONE_ARGUS=y # CONFIG_BEAGLEBONE_PINMUX_HELPER is not set # CONFIG_ECHO is not set # CONFIG_CXL_BASE is not set # CONFIG_CXL_AFU_DRIVER_OPS is not set CONFIG_HAVE_IDE=y # CONFIG_IDE is not set # # SCSI device support # CONFIG_SCSI_MOD=m # CONFIG_RAID_ATTRS is not set CONFIG_SCSI=m CONFIG_SCSI_DMA=y # CONFIG_SCSI_NETLINK is not set # CONFIG_SCSI_MQ_DEFAULT is not set CONFIG_SCSI_PROC_FS=y # # SCSI support type (disk, tape, CD-ROM) # CONFIG_BLK_DEV_SD=m # CONFIG_CHR_DEV_ST is not set # CONFIG_CHR_DEV_OSST is not set CONFIG_BLK_DEV_SR=m # CONFIG_BLK_DEV_SR_VENDOR is not set # CONFIG_CHR_DEV_SG is not set # CONFIG_CHR_DEV_SCH is not set # CONFIG_SCSI_CONSTANTS is not set # CONFIG_SCSI_LOGGING is not set # CONFIG_SCSI_SCAN_ASYNC is not set # # SCSI Transports # # CONFIG_SCSI_SPI_ATTRS is not set # CONFIG_SCSI_FC_ATTRS is not set # CONFIG_SCSI_ISCSI_ATTRS is not set # CONFIG_SCSI_SAS_ATTRS is not set # CONFIG_SCSI_SAS_LIBSAS is not set # CONFIG_SCSI_SRP_ATTRS is not set CONFIG_SCSI_LOWLEVEL=y # CONFIG_ISCSI_TCP is not set # CONFIG_ISCSI_BOOT_SYSFS is not set # CONFIG_SCSI_CXGB3_ISCSI is not set # CONFIG_SCSI_CXGB4_ISCSI is not set # CONFIG_SCSI_BNX2_ISCSI is not set # CONFIG_BE2ISCSI is not set # CONFIG_BLK_DEV_3W_XXXX_RAID is not set # CONFIG_SCSI_HPSA is not set # CONFIG_SCSI_3W_9XXX is not set # CONFIG_SCSI_3W_SAS is not set # CONFIG_SCSI_ACARD is not set # CONFIG_SCSI_AACRAID is not set # CONFIG_SCSI_AIC7XXX is not set # CONFIG_SCSI_AIC79XX is not set # CONFIG_SCSI_AIC94XX is not set # CONFIG_SCSI_MVSAS is not set # CONFIG_SCSI_MVUMI is not set # CONFIG_SCSI_ADVANSYS is not set # CONFIG_SCSI_ARCMSR is not set # CONFIG_SCSI_ESAS2R is not set # CONFIG_MEGARAID_NEWGEN is not set # CONFIG_MEGARAID_LEGACY is not set # CONFIG_MEGARAID_SAS is not set # CONFIG_SCSI_MPT3SAS is not set # CONFIG_SCSI_MPT2SAS is not set # CONFIG_SCSI_SMARTPQI is not set # CONFIG_SCSI_UFSHCD is not set # CONFIG_SCSI_HPTIOP is not set # CONFIG_SCSI_SNIC is not set # CONFIG_SCSI_DMX3191D is not set # CONFIG_SCSI_FUTURE_DOMAIN is not set # CONFIG_SCSI_IPS is not set # CONFIG_SCSI_INITIO is not set # CONFIG_SCSI_INIA100 is not set # CONFIG_SCSI_STEX is not set # CONFIG_SCSI_SYM53C8XX_2 is not set # CONFIG_SCSI_IPR is not set # CONFIG_SCSI_QLOGIC_1280 is not set # CONFIG_SCSI_QLA_ISCSI is not set # CONFIG_SCSI_DC395x is not set # CONFIG_SCSI_AM53C974 is not set # CONFIG_SCSI_NSP32 is not set # CONFIG_SCSI_WD719X is not set # CONFIG_SCSI_DEBUG is not set # CONFIG_SCSI_PMCRAID is not set # CONFIG_SCSI_PM8001 is not set # CONFIG_SCSI_VIRTIO is not set # CONFIG_SCSI_DH is not set # CONFIG_SCSI_OSD_INITIATOR is not set CONFIG_ATA=m # CONFIG_ATA_NONSTANDARD is not set CONFIG_ATA_VERBOSE_ERROR=y CONFIG_SATA_PMP=y # # Controllers with non-SFF native interface # CONFIG_SATA_AHCI=m CONFIG_SATA_AHCI_PLATFORM=m # CONFIG_AHCI_CEVA is not set # CONFIG_AHCI_QORIQ is not set # CONFIG_SATA_INIC162X is not set # CONFIG_SATA_ACARD_AHCI is not set # CONFIG_SATA_SIL24 is not set CONFIG_ATA_SFF=y # # SFF controllers with custom DMA interface # # CONFIG_PDC_ADMA is not set # CONFIG_SATA_QSTOR is not set # CONFIG_SATA_SX4 is not set CONFIG_ATA_BMDMA=y # # SATA SFF controllers with BMDMA # # CONFIG_ATA_PIIX is not set # CONFIG_SATA_DWC is not set CONFIG_SATA_MV=m # CONFIG_SATA_NV is not set # CONFIG_SATA_PROMISE is not set # CONFIG_SATA_SIL is not set # CONFIG_SATA_SIS is not set # CONFIG_SATA_SVW is not set # CONFIG_SATA_ULI is not set # CONFIG_SATA_VIA is not set # CONFIG_SATA_VITESSE is not set # # PATA SFF controllers with BMDMA # # CONFIG_PATA_ALI is not set # CONFIG_PATA_AMD is not set # CONFIG_PATA_ARTOP is not set # CONFIG_PATA_ATIIXP is not set # CONFIG_PATA_ATP867X is not set # CONFIG_PATA_CMD64X is not set # CONFIG_PATA_CYPRESS is not set # CONFIG_PATA_EFAR is not set # CONFIG_PATA_HPT366 is not set # CONFIG_PATA_HPT37X is not set # CONFIG_PATA_HPT3X2N is not set # CONFIG_PATA_HPT3X3 is not set # CONFIG_PATA_IT8213 is not set # CONFIG_PATA_IT821X is not set # CONFIG_PATA_JMICRON is not set # CONFIG_PATA_MARVELL is not set # CONFIG_PATA_NETCELL is not set # CONFIG_PATA_NINJA32 is not set # CONFIG_PATA_NS87415 is not set # CONFIG_PATA_OLDPIIX is not set # CONFIG_PATA_OPTIDMA is not set # CONFIG_PATA_PDC2027X is not set # CONFIG_PATA_PDC_OLD is not set # CONFIG_PATA_RADISYS is not set # CONFIG_PATA_RDC is not set # CONFIG_PATA_SCH is not set # CONFIG_PATA_SERVERWORKS is not set # CONFIG_PATA_SIL680 is not set # CONFIG_PATA_SIS is not set # CONFIG_PATA_TOSHIBA is not set # CONFIG_PATA_TRIFLEX is not set # CONFIG_PATA_VIA is not set # CONFIG_PATA_WINBOND is not set # # PIO-only SFF controllers # # CONFIG_PATA_CMD640_PCI is not set # CONFIG_PATA_MPIIX is not set # CONFIG_PATA_NS87410 is not set # CONFIG_PATA_OPTI is not set # CONFIG_PATA_PLATFORM is not set # CONFIG_PATA_RZ1000 is not set # # Generic fallback / legacy drivers # # CONFIG_ATA_GENERIC is not set # CONFIG_PATA_LEGACY is not set # CONFIG_MD is not set # CONFIG_TARGET_CORE is not set # CONFIG_FUSION is not set # # IEEE 1394 (FireWire) support # # CONFIG_FIREWIRE is not set # CONFIG_FIREWIRE_NOSY is not set CONFIG_NETDEVICES=y CONFIG_MII=y CONFIG_NET_CORE=y # CONFIG_BONDING is not set # CONFIG_DUMMY is not set # CONFIG_EQUALIZER is not set # CONFIG_NET_FC is not set # CONFIG_IFB is not set # CONFIG_NET_TEAM is not set # CONFIG_MACVLAN is not set # CONFIG_VXLAN is not set # CONFIG_GENEVE is not set # CONFIG_GTP is not set # CONFIG_MACSEC is not set # CONFIG_NETCONSOLE is not set # CONFIG_NETPOLL is not set # CONFIG_NET_POLL_CONTROLLER is not set # CONFIG_TUN is not set # CONFIG_TUN_VNET_CROSS_LE is not set # CONFIG_VETH is not set CONFIG_VIRTIO_NET=y # CONFIG_NLMON is not set # CONFIG_ARCNET is not set # # CAIF transport drivers # # # Distributed Switch Architecture drivers # # CONFIG_NET_DSA_MV88E6060 is not set # CONFIG_NET_DSA_BCM_SF2 is not set # CONFIG_B53 is not set # CONFIG_NET_DSA_MV88E6XXX is not set # CONFIG_NET_DSA_QCA8K is not set CONFIG_ETHERNET=y # CONFIG_NET_VENDOR_3COM is not set # CONFIG_NET_VENDOR_ADAPTEC is not set # CONFIG_NET_VENDOR_AGERE is not set # CONFIG_NET_VENDOR_ALTEON is not set # CONFIG_ALTERA_TSE is not set # CONFIG_NET_VENDOR_AMAZON is not set # CONFIG_NET_VENDOR_AMD is not set # CONFIG_NET_VENDOR_ARC is not set # CONFIG_NET_VENDOR_ATHEROS is not set # CONFIG_NET_VENDOR_AURORA is not set # CONFIG_NET_CADENCE is not set CONFIG_NET_VENDOR_BROADCOM=y # CONFIG_B44 is not set # CONFIG_BCMGENET is not set # CONFIG_BNX2 is not set # CONFIG_CNIC is not set CONFIG_TIGON3=m # CONFIG_BNX2X is not set # CONFIG_SYSTEMPORT is not set # CONFIG_BNXT is not set # CONFIG_NET_VENDOR_BROCADE is not set # CONFIG_NET_VENDOR_CAVIUM is not set # CONFIG_NET_VENDOR_CHELSIO is not set # CONFIG_NET_VENDOR_CIRRUS is not set # CONFIG_NET_VENDOR_CISCO is not set # CONFIG_DM9000 is not set # CONFIG_DNET is not set # CONFIG_NET_VENDOR_DEC is not set # CONFIG_NET_VENDOR_DLINK is not set # CONFIG_NET_VENDOR_EMULEX is not set # CONFIG_NET_VENDOR_EZCHIP is not set # CONFIG_NET_VENDOR_EXAR is not set # CONFIG_NET_VENDOR_FARADAY is not set # CONFIG_NET_VENDOR_HISILICON is not set # CONFIG_NET_VENDOR_HP is not set CONFIG_NET_VENDOR_INTEL=y # CONFIG_E100 is not set CONFIG_E1000=m CONFIG_E1000E=m # CONFIG_IGB is not set # CONFIG_IGBVF is not set # CONFIG_IXGB is not set # CONFIG_IXGBE is not set # CONFIG_IXGBEVF is not set # CONFIG_I40E is not set # CONFIG_I40EVF is not set # CONFIG_FM10K is not set # CONFIG_NET_VENDOR_I825XX is not set # CONFIG_JME is not set CONFIG_NET_VENDOR_MARVELL=y # CONFIG_MVMDIO is not set # CONFIG_MVNETA_BM is not set CONFIG_SKGE=m # CONFIG_SKGE_DEBUG is not set # CONFIG_SKGE_GENESIS is not set # CONFIG_SKY2 is not set # CONFIG_NET_VENDOR_MELLANOX is not set CONFIG_NET_VENDOR_MICREL=y # CONFIG_KS8842 is not set CONFIG_KS8851=y # CONFIG_KS8851_MLL is not set # CONFIG_KSZ884X_PCI is not set # CONFIG_NET_VENDOR_MICROCHIP is not set # CONFIG_NET_VENDOR_MYRI is not set # CONFIG_FEALNX is not set # CONFIG_NET_VENDOR_NATSEMI is not set # CONFIG_NET_VENDOR_NETRONOME is not set # CONFIG_NET_VENDOR_NVIDIA is not set # CONFIG_NET_VENDOR_OKI is not set # CONFIG_ETHOC is not set CONFIG_NET_PACKET_ENGINE=y # CONFIG_HAMACHI is not set # CONFIG_YELLOWFIN is not set # CONFIG_NET_VENDOR_QLOGIC is not set # CONFIG_NET_VENDOR_QUALCOMM is not set # CONFIG_NET_VENDOR_REALTEK is not set # CONFIG_NET_VENDOR_RENESAS is not set # CONFIG_NET_VENDOR_RDC is not set # CONFIG_NET_VENDOR_ROCKER is not set # CONFIG_NET_VENDOR_SAMSUNG is not set # CONFIG_NET_VENDOR_SEEQ is not set # CONFIG_NET_VENDOR_SILAN is not set # CONFIG_NET_VENDOR_SIS is not set # CONFIG_SFC is not set CONFIG_NET_VENDOR_SMSC=y # CONFIG_SMC91X is not set # CONFIG_EPIC100 is not set # CONFIG_SMC911X is not set CONFIG_SMSC911X=y # CONFIG_SMSC911X_ARCH_HOOKS is not set # CONFIG_SMSC9420 is not set # CONFIG_NET_VENDOR_STMICRO is not set # CONFIG_NET_VENDOR_SUN is not set # CONFIG_NET_VENDOR_SYNOPSYS is not set # CONFIG_NET_VENDOR_TEHUTI is not set CONFIG_NET_VENDOR_TI=y CONFIG_TI_DAVINCI_MDIO=y CONFIG_TI_DAVINCI_CPDMA=y CONFIG_TI_CPSW_PHY_SEL=y CONFIG_TI_CPSW_ALE=y CONFIG_TI_CPSW=y CONFIG_TI_CPTS=y # CONFIG_TLAN is not set CONFIG_TI_PRUETH=m # CONFIG_NET_VENDOR_VIA is not set # CONFIG_NET_VENDOR_WIZNET is not set # CONFIG_FDDI is not set # CONFIG_HIPPI is not set CONFIG_PHYLIB=y CONFIG_SWPHY=y # # MDIO bus device drivers # # CONFIG_MDIO_BCM_UNIMAC is not set # CONFIG_MDIO_BITBANG is not set # CONFIG_MDIO_BUS_MUX_GPIO is not set # CONFIG_MDIO_BUS_MUX_MMIOREG is not set # CONFIG_MDIO_HISI_FEMAC is not set # # MII PHY device drivers # # CONFIG_AMD_PHY is not set # CONFIG_AQUANTIA_PHY is not set CONFIG_AT803X_PHY=y # CONFIG_BCM7XXX_PHY is not set # CONFIG_BCM87XX_PHY is not set # CONFIG_BROADCOM_PHY is not set # CONFIG_CICADA_PHY is not set # CONFIG_DAVICOM_PHY is not set CONFIG_DP83848_PHY=y CONFIG_DP83867_PHY=y CONFIG_FIXED_PHY=y # CONFIG_ICPLUS_PHY is not set # CONFIG_INTEL_XWAY_PHY is not set # CONFIG_LSI_ET1011C_PHY is not set # CONFIG_LXT_PHY is not set CONFIG_MARVELL_PHY=y CONFIG_MICREL_PHY=y # CONFIG_MICROCHIP_PHY is not set # CONFIG_MICROSEMI_PHY is not set # CONFIG_NATIONAL_PHY is not set # CONFIG_QSEMI_PHY is not set CONFIG_REALTEK_PHY=y CONFIG_SMSC_PHY=y # CONFIG_STE10XP is not set # CONFIG_TERANETICS_PHY is not set # CONFIG_VITESSE_PHY is not set # CONFIG_XILINX_GMII2RGMII is not set # CONFIG_MICREL_KS8995MA is not set # CONFIG_PPP is not set # CONFIG_SLIP is not set # # Host-side USB support is needed for USB Network Adapter support # CONFIG_USB_NET_DRIVERS=m # CONFIG_USB_CATC is not set # CONFIG_USB_KAWETH is not set CONFIG_USB_PEGASUS=m # CONFIG_USB_RTL8150 is not set CONFIG_USB_RTL8152=m # CONFIG_USB_LAN78XX is not set CONFIG_USB_USBNET=m CONFIG_USB_NET_AX8817X=m CONFIG_USB_NET_AX88179_178A=m CONFIG_USB_NET_CDCETHER=m # CONFIG_USB_NET_CDC_EEM is not set CONFIG_USB_NET_CDC_NCM=m # CONFIG_USB_NET_HUAWEI_CDC_NCM is not set # CONFIG_USB_NET_CDC_MBIM is not set # CONFIG_USB_NET_DM9601 is not set # CONFIG_USB_NET_SR9700 is not set # CONFIG_USB_NET_SR9800 is not set CONFIG_USB_NET_SMSC75XX=m CONFIG_USB_NET_SMSC95XX=m # CONFIG_USB_NET_GL620A is not set CONFIG_USB_NET_NET1080=m # CONFIG_USB_NET_PLUSB is not set # CONFIG_USB_NET_MCS7830 is not set # CONFIG_USB_NET_RNDIS_HOST is not set CONFIG_USB_NET_CDC_SUBSET_ENABLE=m CONFIG_USB_NET_CDC_SUBSET=m # CONFIG_USB_ALI_M5632 is not set # CONFIG_USB_AN2720 is not set CONFIG_USB_BELKIN=y CONFIG_USB_ARMLINUX=y # CONFIG_USB_EPSON2888 is not set # CONFIG_USB_KC2190 is not set CONFIG_USB_NET_ZAURUS=m # CONFIG_USB_NET_CX82310_ETH is not set # CONFIG_USB_NET_KALMIA is not set # CONFIG_USB_NET_QMI_WWAN is not set # CONFIG_USB_HSO is not set # CONFIG_USB_NET_INT51X1 is not set # CONFIG_USB_IPHETH is not set # CONFIG_USB_SIERRA_NET is not set # CONFIG_USB_VL600 is not set # CONFIG_USB_NET_CH9200 is not set CONFIG_WLAN=y CONFIG_WLAN_VENDOR_ADMTEK=y # CONFIG_ADM8211 is not set CONFIG_WLAN_VENDOR_ATH=y # CONFIG_ATH_DEBUG is not set # CONFIG_ATH5K is not set # CONFIG_ATH5K_PCI is not set # CONFIG_ATH9K is not set # CONFIG_ATH9K_HTC is not set # CONFIG_CARL9170 is not set # CONFIG_ATH6KL is not set # CONFIG_AR5523 is not set # CONFIG_WIL6210 is not set # CONFIG_ATH10K is not set # CONFIG_WCN36XX is not set CONFIG_WLAN_VENDOR_ATMEL=y # CONFIG_ATMEL is not set # CONFIG_AT76C50X_USB is not set CONFIG_WLAN_VENDOR_BROADCOM=y # CONFIG_B43 is not set # CONFIG_B43LEGACY is not set CONFIG_BRCMUTIL=m # CONFIG_BRCMSMAC is not set CONFIG_BRCMFMAC=m CONFIG_BRCMFMAC_PROTO_BCDC=y CONFIG_BRCMFMAC_SDIO=y # CONFIG_BRCMFMAC_USB is not set # CONFIG_BRCMFMAC_PCIE is not set # CONFIG_BRCM_TRACING is not set # CONFIG_BRCMDBG is not set CONFIG_WLAN_VENDOR_CISCO=y CONFIG_WLAN_VENDOR_INTEL=y # CONFIG_IPW2100 is not set # CONFIG_IPW2200 is not set # CONFIG_IWL4965 is not set # CONFIG_IWL3945 is not set CONFIG_IWLWIFI=m CONFIG_IWLWIFI_LEDS=y CONFIG_IWLDVM=m CONFIG_IWLMVM=m CONFIG_IWLWIFI_OPMODE_MODULAR=y # CONFIG_IWLWIFI_BCAST_FILTERING is not set # CONFIG_IWLWIFI_PCIE_RTPM is not set # # Debugging Options # # CONFIG_IWLWIFI_DEBUG is not set CONFIG_WLAN_VENDOR_INTERSIL=y # CONFIG_HOSTAP is not set # CONFIG_HERMES is not set # CONFIG_P54_COMMON is not set # CONFIG_PRISM54 is not set CONFIG_WLAN_VENDOR_MARVELL=y # CONFIG_LIBERTAS is not set # CONFIG_LIBERTAS_THINFIRM is not set CONFIG_MWIFIEX=m CONFIG_MWIFIEX_SDIO=m # CONFIG_MWIFIEX_PCIE is not set # CONFIG_MWIFIEX_USB is not set # CONFIG_MWL8K is not set CONFIG_WLAN_VENDOR_MEDIATEK=y # CONFIG_MT7601U is not set CONFIG_WLAN_VENDOR_RALINK=y CONFIG_RT2X00=m # CONFIG_RT2400PCI is not set # CONFIG_RT2500PCI is not set # CONFIG_RT61PCI is not set # CONFIG_RT2800PCI is not set # CONFIG_RT2500USB is not set # CONFIG_RT73USB is not set CONFIG_RT2800USB=m CONFIG_RT2800USB_RT33XX=y CONFIG_RT2800USB_RT35XX=y # CONFIG_RT2800USB_RT3573 is not set CONFIG_RT2800USB_RT53XX=y # CONFIG_RT2800USB_RT55XX is not set # CONFIG_RT2800USB_UNKNOWN is not set CONFIG_RT2800_LIB=m CONFIG_RT2X00_LIB_USB=m CONFIG_RT2X00_LIB=m CONFIG_RT2X00_LIB_FIRMWARE=y CONFIG_RT2X00_LIB_CRYPTO=y CONFIG_RT2X00_LIB_LEDS=y # CONFIG_RT2X00_DEBUG is not set CONFIG_WLAN_VENDOR_REALTEK=y # CONFIG_RTL8180 is not set # CONFIG_RTL8187 is not set CONFIG_RTL_CARDS=m # CONFIG_RTL8192CE is not set # CONFIG_RTL8192SE is not set # CONFIG_RTL8192DE is not set # CONFIG_RTL8723AE is not set # CONFIG_RTL8723BE is not set # CONFIG_RTL8188EE is not set # CONFIG_RTL8192EE is not set # CONFIG_RTL8821AE is not set # CONFIG_RTL8192CU is not set # CONFIG_RTL8XXXU is not set CONFIG_WLAN_VENDOR_RSI=y # CONFIG_RSI_91X is not set CONFIG_WLAN_VENDOR_ST=y # CONFIG_CW1200 is not set CONFIG_WLAN_VENDOR_TI=y # CONFIG_WL1251 is not set # CONFIG_WL12XX is not set CONFIG_WL18XX=m CONFIG_WLCORE=m CONFIG_WLCORE_SPI=m CONFIG_WLCORE_SDIO=m CONFIG_WILINK_PLATFORM_DATA=y CONFIG_WLAN_VENDOR_ZYDAS=y # CONFIG_USB_ZD1201 is not set # CONFIG_ZD1211RW is not set # CONFIG_MAC80211_HWSIM is not set # CONFIG_USB_NET_RNDIS_WLAN is not set # # Enable WiMAX (Networking options) to see the WiMAX drivers # # CONFIG_WAN is not set # CONFIG_VMXNET3 is not set # CONFIG_ISDN is not set # CONFIG_NVM is not set # # Input device support # CONFIG_INPUT=y CONFIG_INPUT_LEDS=y # CONFIG_INPUT_FF_MEMLESS is not set CONFIG_INPUT_POLLDEV=m # CONFIG_INPUT_SPARSEKMAP is not set CONFIG_INPUT_MATRIXKMAP=m # # Userland interfaces # CONFIG_INPUT_MOUSEDEV=y CONFIG_INPUT_MOUSEDEV_PSAUX=y CONFIG_INPUT_MOUSEDEV_SCREEN_X=1024 CONFIG_INPUT_MOUSEDEV_SCREEN_Y=768 CONFIG_INPUT_JOYDEV=y CONFIG_INPUT_EVDEV=y # CONFIG_INPUT_EVBUG is not set # # Input Device Drivers # CONFIG_INPUT_KEYBOARD=y # CONFIG_KEYBOARD_ADC is not set # CONFIG_KEYBOARD_ADP5588 is not set # CONFIG_KEYBOARD_ADP5589 is not set CONFIG_KEYBOARD_ATKBD=y CONFIG_KEYBOARD_QT1070=m # CONFIG_KEYBOARD_QT2160 is not set # CONFIG_KEYBOARD_LKKBD is not set CONFIG_KEYBOARD_GPIO=y # CONFIG_KEYBOARD_GPIO_POLLED is not set # CONFIG_KEYBOARD_TCA6416 is not set # CONFIG_KEYBOARD_TCA8418 is not set CONFIG_KEYBOARD_MATRIX=m # CONFIG_KEYBOARD_LM8323 is not set # CONFIG_KEYBOARD_LM8333 is not set # CONFIG_KEYBOARD_MAX7359 is not set # CONFIG_KEYBOARD_MCS is not set # CONFIG_KEYBOARD_MPR121 is not set # CONFIG_KEYBOARD_NEWTON is not set # CONFIG_KEYBOARD_OPENCORES is not set CONFIG_KEYBOARD_SAMSUNG=m # CONFIG_KEYBOARD_STOWAWAY is not set # CONFIG_KEYBOARD_SUNKBD is not set # CONFIG_KEYBOARD_OMAP4 is not set # CONFIG_KEYBOARD_XTKBD is not set # CONFIG_KEYBOARD_CAP11XX is not set # CONFIG_KEYBOARD_BCM is not set CONFIG_INPUT_MOUSE=y CONFIG_MOUSE_PS2=y CONFIG_MOUSE_PS2_ALPS=y CONFIG_MOUSE_PS2_BYD=y CONFIG_MOUSE_PS2_LOGIPS2PP=y CONFIG_MOUSE_PS2_SYNAPTICS=y CONFIG_MOUSE_PS2_CYPRESS=y CONFIG_MOUSE_PS2_TRACKPOINT=y CONFIG_MOUSE_PS2_ELANTECH=y # CONFIG_MOUSE_PS2_SENTELIC is not set # CONFIG_MOUSE_PS2_TOUCHKIT is not set CONFIG_MOUSE_PS2_FOCALTECH=y # CONFIG_MOUSE_SERIAL is not set # CONFIG_MOUSE_APPLETOUCH is not set # CONFIG_MOUSE_BCM5974 is not set CONFIG_MOUSE_CYAPA=m CONFIG_MOUSE_ELAN_I2C=y CONFIG_MOUSE_ELAN_I2C_I2C=y # CONFIG_MOUSE_ELAN_I2C_SMBUS is not set # CONFIG_MOUSE_VSXXXAA is not set # CONFIG_MOUSE_GPIO is not set # CONFIG_MOUSE_SYNAPTICS_I2C is not set # CONFIG_MOUSE_SYNAPTICS_USB is not set # CONFIG_INPUT_JOYSTICK is not set # CONFIG_INPUT_TABLET is not set CONFIG_INPUT_TOUCHSCREEN=y CONFIG_TOUCHSCREEN_PROPERTIES=y # CONFIG_TOUCHSCREEN_ADS7846 is not set # CONFIG_TOUCHSCREEN_AD7877 is not set # CONFIG_TOUCHSCREEN_AD7879 is not set # CONFIG_TOUCHSCREEN_AR1021_I2C is not set CONFIG_TOUCHSCREEN_ATMEL_MXT=m # CONFIG_TOUCHSCREEN_ATMEL_MXT_T37 is not set # CONFIG_TOUCHSCREEN_AUO_PIXCIR is not set # CONFIG_TOUCHSCREEN_BU21013 is not set # CONFIG_TOUCHSCREEN_CHIPONE_ICN8318 is not set # CONFIG_TOUCHSCREEN_CY8CTMG110 is not set # CONFIG_TOUCHSCREEN_CYTTSP_CORE is not set # CONFIG_TOUCHSCREEN_CYTTSP4_CORE is not set # CONFIG_TOUCHSCREEN_DYNAPRO is not set # CONFIG_TOUCHSCREEN_HAMPSHIRE is not set # CONFIG_TOUCHSCREEN_EETI is not set # CONFIG_TOUCHSCREEN_EGALAX is not set # CONFIG_TOUCHSCREEN_EGALAX_SERIAL is not set # CONFIG_TOUCHSCREEN_FUJITSU is not set CONFIG_TOUCHSCREEN_GOODIX=m # CONFIG_TOUCHSCREEN_ILI210X is not set # CONFIG_TOUCHSCREEN_GUNZE is not set # CONFIG_TOUCHSCREEN_EKTF2127 is not set # CONFIG_TOUCHSCREEN_ELAN is not set # CONFIG_TOUCHSCREEN_ELO is not set # CONFIG_TOUCHSCREEN_WACOM_W8001 is not set # CONFIG_TOUCHSCREEN_WACOM_I2C is not set # CONFIG_TOUCHSCREEN_MAX11801 is not set # CONFIG_TOUCHSCREEN_MCS5000 is not set CONFIG_TOUCHSCREEN_MMS114=m # CONFIG_TOUCHSCREEN_MELFAS_MIP4 is not set # CONFIG_TOUCHSCREEN_MTOUCH is not set # CONFIG_TOUCHSCREEN_IMX6UL_TSC is not set # CONFIG_TOUCHSCREEN_INEXIO is not set # CONFIG_TOUCHSCREEN_MK712 is not set # CONFIG_TOUCHSCREEN_PENMOUNT is not set CONFIG_TOUCHSCREEN_EDT_FT5X06=y # CONFIG_TOUCHSCREEN_TOUCHRIGHT is not set # CONFIG_TOUCHSCREEN_TOUCHWIN is not set CONFIG_TOUCHSCREEN_TI_AM335X_TSC=m CONFIG_TOUCHSCREEN_PIXCIR=m # CONFIG_TOUCHSCREEN_WDT87XX_I2C is not set # CONFIG_TOUCHSCREEN_USB_COMPOSITE is not set # CONFIG_TOUCHSCREEN_TOUCHIT213 is not set # CONFIG_TOUCHSCREEN_TSC_SERIO is not set # CONFIG_TOUCHSCREEN_TSC2004 is not set # CONFIG_TOUCHSCREEN_TSC2005 is not set # CONFIG_TOUCHSCREEN_TSC2007 is not set # CONFIG_TOUCHSCREEN_RM_TS is not set # CONFIG_TOUCHSCREEN_SILEAD is not set # CONFIG_TOUCHSCREEN_SIS_I2C is not set CONFIG_TOUCHSCREEN_ST1232=m # CONFIG_TOUCHSCREEN_SUR40 is not set # CONFIG_TOUCHSCREEN_SURFACE3_SPI is not set # CONFIG_TOUCHSCREEN_SX8654 is not set # CONFIG_TOUCHSCREEN_TPS6507X is not set # CONFIG_TOUCHSCREEN_ZFORCE is not set # CONFIG_TOUCHSCREEN_COLIBRI_VF50 is not set # CONFIG_TOUCHSCREEN_ROHM_BU21023 is not set CONFIG_INPUT_MISC=y # CONFIG_INPUT_AD714X is not set # CONFIG_INPUT_ATMEL_CAPTOUCH is not set # CONFIG_INPUT_BMA150 is not set # CONFIG_INPUT_E3X0_BUTTON is not set # CONFIG_INPUT_MMA8450 is not set CONFIG_INPUT_MPU3050=y # CONFIG_INPUT_GP2A is not set # CONFIG_INPUT_GPIO_BEEPER is not set # CONFIG_INPUT_GPIO_TILT_POLLED is not set CONFIG_INPUT_GPIO_DECODER=m # CONFIG_INPUT_ATI_REMOTE2 is not set # CONFIG_INPUT_KEYSPAN_REMOTE is not set # CONFIG_INPUT_KXTJ9 is not set # CONFIG_INPUT_POWERMATE is not set # CONFIG_INPUT_YEALINK is not set # CONFIG_INPUT_CM109 is not set # CONFIG_INPUT_REGULATOR_HAPTIC is not set # CONFIG_INPUT_TPS65218_PWRBUTTON is not set CONFIG_INPUT_AXP20X_PEK=m # CONFIG_INPUT_TWL6040_VIBRA is not set # CONFIG_INPUT_UINPUT is not set # CONFIG_INPUT_PALMAS_PWRBUTTON is not set # CONFIG_INPUT_PCF8574 is not set # CONFIG_INPUT_PWM_BEEPER is not set # CONFIG_INPUT_GPIO_ROTARY_ENCODER is not set CONFIG_INPUT_ADXL34X=m CONFIG_INPUT_ADXL34X_I2C=m CONFIG_INPUT_ADXL34X_SPI=m # CONFIG_INPUT_IMS_PCU is not set # CONFIG_INPUT_CMA3000 is not set # CONFIG_INPUT_SOC_BUTTON_ARRAY is not set # CONFIG_INPUT_DRV260X_HAPTICS is not set # CONFIG_INPUT_DRV2665_HAPTICS is not set # CONFIG_INPUT_DRV2667_HAPTICS is not set # CONFIG_RMI4_CORE is not set # # Hardware I/O ports # CONFIG_SERIO=y CONFIG_SERIO_SERPORT=y # CONFIG_SERIO_PCIPS2 is not set CONFIG_SERIO_LIBPS2=y # CONFIG_SERIO_RAW is not set # CONFIG_SERIO_ALTERA_PS2 is not set # CONFIG_SERIO_PS2MULT is not set # CONFIG_SERIO_ARC_PS2 is not set # CONFIG_SERIO_APBPS2 is not set # CONFIG_USERIO is not set # CONFIG_GAMEPORT is not set # # Character devices # CONFIG_TTY=y CONFIG_VT=y CONFIG_CONSOLE_TRANSLATIONS=y CONFIG_VT_CONSOLE=y CONFIG_VT_CONSOLE_SLEEP=y CONFIG_HW_CONSOLE=y CONFIG_VT_HW_CONSOLE_BINDING=y CONFIG_UNIX98_PTYS=y CONFIG_LEGACY_PTYS=y CONFIG_LEGACY_PTY_COUNT=256 # CONFIG_SERIAL_NONSTANDARD is not set # CONFIG_NOZOMI is not set # CONFIG_N_GSM is not set # CONFIG_TRACE_SINK is not set CONFIG_DEVMEM=y CONFIG_DEVKMEM=y # # Serial drivers # CONFIG_SERIAL_EARLYCON=y CONFIG_SERIAL_8250=y CONFIG_SERIAL_8250_DEPRECATED_OPTIONS=y # CONFIG_SERIAL_8250_FINTEK is not set CONFIG_SERIAL_8250_CONSOLE=y CONFIG_SERIAL_8250_DMA=y CONFIG_SERIAL_8250_PCI=y CONFIG_SERIAL_8250_NR_UARTS=10 CONFIG_SERIAL_8250_RUNTIME_UARTS=10 # CONFIG_SERIAL_8250_EXTENDED is not set CONFIG_SERIAL_8250_FSL=y # CONFIG_SERIAL_8250_DW is not set # CONFIG_SERIAL_8250_EM is not set # CONFIG_SERIAL_8250_RT288X is not set CONFIG_SERIAL_8250_OMAP=y CONFIG_SERIAL_8250_OMAP_TTYO_FIXUP=y # CONFIG_SERIAL_8250_MOXA is not set CONFIG_SERIAL_OF_PLATFORM=y # # Non-8250 serial port support # # CONFIG_SERIAL_EARLYCON_ARM_SEMIHOST is not set # CONFIG_SERIAL_MAX3100 is not set # CONFIG_SERIAL_MAX310X is not set # CONFIG_SERIAL_UARTLITE is not set CONFIG_SERIAL_CORE=y CONFIG_SERIAL_CORE_CONSOLE=y # CONFIG_SERIAL_JSM is not set CONFIG_SERIAL_OMAP=m # CONFIG_SERIAL_SCCNXP is not set # CONFIG_SERIAL_SC16IS7XX is not set CONFIG_SERIAL_BCM63XX=y CONFIG_SERIAL_BCM63XX_CONSOLE=y # CONFIG_SERIAL_ALTERA_JTAGUART is not set # CONFIG_SERIAL_ALTERA_UART is not set # CONFIG_SERIAL_IFX6X60 is not set # CONFIG_SERIAL_XILINX_PS_UART is not set # CONFIG_SERIAL_ARC is not set # CONFIG_SERIAL_RP2 is not set # CONFIG_SERIAL_FSL_LPUART is not set # CONFIG_SERIAL_CONEXANT_DIGICOLOR is not set # CONFIG_SERIAL_ST_ASC is not set # CONFIG_SERIAL_STM32 is not set # CONFIG_TTY_PRINTK is not set CONFIG_HVC_DRIVER=y # CONFIG_HVC_DCC is not set CONFIG_VIRTIO_CONSOLE=y # CONFIG_IPMI_HANDLER is not set CONFIG_HW_RANDOM=y # CONFIG_HW_RANDOM_TIMERIOMEM is not set CONFIG_HW_RANDOM_OMAP=y # CONFIG_HW_RANDOM_VIRTIO is not set # CONFIG_R3964 is not set # CONFIG_APPLICOM is not set # CONFIG_RAW_DRIVER is not set # CONFIG_TCG_TPM is not set CONFIG_DEVPORT=y # CONFIG_XILLYBUS is not set # # I2C support # CONFIG_I2C=y CONFIG_I2C_BOARDINFO=y CONFIG_I2C_COMPAT=y CONFIG_I2C_CHARDEV=y # CONFIG_I2C_MUX is not set CONFIG_I2C_HELPER_AUTO=y CONFIG_I2C_ALGOBIT=y # # I2C Hardware Bus support # # # PC SMBus host controller drivers # # CONFIG_I2C_ALI1535 is not set # CONFIG_I2C_ALI1563 is not set # CONFIG_I2C_ALI15X3 is not set # CONFIG_I2C_AMD756 is not set # CONFIG_I2C_AMD8111 is not set # CONFIG_I2C_I801 is not set # CONFIG_I2C_ISCH is not set # CONFIG_I2C_PIIX4 is not set # CONFIG_I2C_NFORCE2 is not set # CONFIG_I2C_SIS5595 is not set # CONFIG_I2C_SIS630 is not set # CONFIG_I2C_SIS96X is not set # CONFIG_I2C_VIA is not set # CONFIG_I2C_VIAPRO is not set # # I2C system bus drivers (mostly embedded / system-on-chip) # # CONFIG_I2C_CBUS_GPIO is not set # CONFIG_I2C_DESIGNWARE_PLATFORM is not set # CONFIG_I2C_DESIGNWARE_PCI is not set CONFIG_I2C_EMEV2=m # CONFIG_I2C_GPIO is not set # CONFIG_I2C_OCORES is not set CONFIG_I2C_OMAP=y # CONFIG_I2C_PCA_PLATFORM is not set # CONFIG_I2C_PXA_PCI is not set # CONFIG_I2C_RK3X is not set # CONFIG_I2C_SIMTEC is not set # CONFIG_I2C_XILINX is not set # # External I2C/SMBus adapter drivers # # CONFIG_I2C_DIOLAN_U2C is not set # CONFIG_I2C_PARPORT_LIGHT is not set # CONFIG_I2C_ROBOTFUZZ_OSIF is not set # CONFIG_I2C_TAOS_EVM is not set # CONFIG_I2C_TINY_USB is not set # # Other I2C/SMBus bus drivers # # CONFIG_I2C_STUB is not set CONFIG_I2C_SLAVE=y CONFIG_I2C_SLAVE_EEPROM=y # CONFIG_I2C_DEBUG_CORE is not set # CONFIG_I2C_DEBUG_ALGO is not set # CONFIG_I2C_DEBUG_BUS is not set CONFIG_SPI=y # CONFIG_SPI_DEBUG is not set CONFIG_SPI_MASTER=y # # SPI Master Controller Drivers # # CONFIG_SPI_ALTERA is not set # CONFIG_SPI_AXI_SPI_ENGINE is not set CONFIG_SPI_BITBANG=m # CONFIG_SPI_CADENCE is not set # CONFIG_SPI_DESIGNWARE is not set CONFIG_SPI_GPIO=m # CONFIG_SPI_FSL_SPI is not set # CONFIG_SPI_OC_TINY is not set CONFIG_SPI_OMAP24XX=y CONFIG_SPI_TI_QSPI=y # CONFIG_SPI_PXA2XX is not set # CONFIG_SPI_PXA2XX_PCI is not set # CONFIG_SPI_ROCKCHIP is not set # CONFIG_SPI_SC18IS602 is not set # CONFIG_SPI_XCOMM is not set # CONFIG_SPI_XILINX is not set # CONFIG_SPI_ZYNQMP_GQSPI is not set # # SPI Protocol Masters # # CONFIG_SPI_SPIDEV is not set # CONFIG_SPI_LOOPBACK_TEST is not set # CONFIG_SPI_TLE62X0 is not set CONFIG_SPMI=y # CONFIG_HSI is not set # # PPS support # CONFIG_PPS=y # CONFIG_PPS_DEBUG is not set # # PPS clients support # # CONFIG_PPS_CLIENT_KTIMER is not set # CONFIG_PPS_CLIENT_LDISC is not set # CONFIG_PPS_CLIENT_GPIO is not set # # PPS generators support # # # PTP clock support # CONFIG_PTP_1588_CLOCK=y # # Enable PHYLIB and NETWORK_PHY_TIMESTAMPING to see the additional clocks. # CONFIG_PINCTRL=y # # Pin controllers # CONFIG_GENERIC_PINCTRL_GROUPS=y CONFIG_PINMUX=y CONFIG_GENERIC_PINMUX_FUNCTIONS=y CONFIG_PINCONF=y CONFIG_GENERIC_PINCONF=y # CONFIG_DEBUG_PINCTRL is not set # CONFIG_PINCTRL_AMD is not set CONFIG_PINCTRL_SINGLE=y CONFIG_PINCTRL_PALMAS=y CONFIG_PINCTRL_TI_IODELAY=y CONFIG_ARCH_HAVE_CUSTOM_GPIO_H=y CONFIG_GPIOLIB=y CONFIG_OF_GPIO=y CONFIG_GPIOLIB_IRQCHIP=y CONFIG_DEBUG_GPIO=y CONFIG_GPIO_SYSFS=y # CONFIG_GPIO_OF_HELPER is not set # # Memory mapped GPIO drivers # # CONFIG_GPIO_74XX_MMIO is not set # CONFIG_GPIO_ALTERA is not set # CONFIG_GPIO_AXP209 is not set # CONFIG_GPIO_DWAPB is not set # CONFIG_GPIO_EM is not set # CONFIG_GPIO_GENERIC_PLATFORM is not set # CONFIG_GPIO_GRGPIO is not set # CONFIG_GPIO_MOCKUP is not set # CONFIG_GPIO_MPC8XXX is not set CONFIG_GPIO_OMAP=y CONFIG_GPIO_SYSCON=y # CONFIG_GPIO_VX855 is not set # CONFIG_GPIO_XILINX is not set # CONFIG_GPIO_ZEVIO is not set # CONFIG_GPIO_ZX is not set # # I2C GPIO expanders # # CONFIG_GPIO_ADP5588 is not set # CONFIG_GPIO_ADNP is not set # CONFIG_GPIO_MAX7300 is not set # CONFIG_GPIO_MAX732X is not set CONFIG_GPIO_PCA953X=m CONFIG_GPIO_PCF857X=y # CONFIG_GPIO_SX150X is not set CONFIG_GPIO_TPIC2810=m # CONFIG_GPIO_TS4900 is not set # # MFD GPIO expanders # # CONFIG_HTC_EGPIO is not set # CONFIG_GPIO_LP873X is not set CONFIG_GPIO_PALMAS=y # CONFIG_GPIO_TPS65218 is not set # CONFIG_GPIO_TPS6586X is not set CONFIG_GPIO_TPS65910=y # CONFIG_GPIO_TWL6040 is not set # # PCI GPIO expanders # # CONFIG_GPIO_AMD8111 is not set # CONFIG_GPIO_BT8XX is not set # CONFIG_GPIO_ML_IOH is not set # CONFIG_GPIO_RDC321X is not set # # SPI GPIO expanders # # CONFIG_GPIO_74X164 is not set # CONFIG_GPIO_MAX7301 is not set # CONFIG_GPIO_MC33880 is not set CONFIG_GPIO_PISOSR=m # # SPI or I2C GPIO expanders # # CONFIG_GPIO_MCP23S08 is not set # # USB GPIO expanders # CONFIG_W1=m # # 1-wire Bus Masters # # CONFIG_W1_MASTER_MATROX is not set # CONFIG_W1_MASTER_DS2490 is not set # CONFIG_W1_MASTER_DS2482 is not set # CONFIG_W1_MASTER_DS1WM is not set # CONFIG_W1_MASTER_GPIO is not set CONFIG_HDQ_MASTER_OMAP=m # # 1-wire Slaves # # CONFIG_W1_SLAVE_THERM is not set # CONFIG_W1_SLAVE_SMEM is not set # CONFIG_W1_SLAVE_DS2408 is not set # CONFIG_W1_SLAVE_DS2413 is not set # CONFIG_W1_SLAVE_DS2406 is not set # CONFIG_W1_SLAVE_DS2423 is not set # CONFIG_W1_SLAVE_DS2431 is not set # CONFIG_W1_SLAVE_DS2433 is not set # CONFIG_W1_SLAVE_DS2760 is not set # CONFIG_W1_SLAVE_DS2780 is not set # CONFIG_W1_SLAVE_DS2781 is not set # CONFIG_W1_SLAVE_DS28E04 is not set # CONFIG_W1_SLAVE_BQ27000 is not set CONFIG_POWER_AVS=y CONFIG_POWER_RESET=y # CONFIG_POWER_RESET_BRCMKONA is not set # CONFIG_POWER_RESET_BRCMSTB is not set CONFIG_POWER_RESET_GPIO=y CONFIG_POWER_RESET_GPIO_RESTART=y # CONFIG_POWER_RESET_LTC2952 is not set # CONFIG_POWER_RESET_RESTART is not set # CONFIG_POWER_RESET_VERSATILE is not set CONFIG_POWER_RESET_SYSCON=y # CONFIG_POWER_RESET_SYSCON_POWEROFF is not set # CONFIG_SYSCON_REBOOT_MODE is not set CONFIG_POWER_SUPPLY=y # CONFIG_POWER_SUPPLY_DEBUG is not set # CONFIG_PDA_POWER is not set # CONFIG_GENERIC_ADC_BATTERY is not set # CONFIG_TEST_POWER is not set CONFIG_BATTERY_ACT8945A=y # CONFIG_BATTERY_DS2780 is not set # CONFIG_BATTERY_DS2781 is not set # CONFIG_BATTERY_DS2782 is not set CONFIG_BATTERY_SBS=y # CONFIG_BATTERY_BQ27XXX is not set # CONFIG_AXP288_FUEL_GAUGE is not set CONFIG_BATTERY_MAX17040=m CONFIG_BATTERY_MAX17042=m # CONFIG_CHARGER_ISP1704 is not set # CONFIG_CHARGER_MAX8903 is not set # CONFIG_CHARGER_LP8727 is not set # CONFIG_CHARGER_GPIO is not set # CONFIG_CHARGER_MANAGER is not set # CONFIG_CHARGER_BQ2415X is not set # CONFIG_CHARGER_BQ24190 is not set # CONFIG_CHARGER_BQ24257 is not set # CONFIG_CHARGER_BQ24735 is not set # CONFIG_CHARGER_BQ25890 is not set # CONFIG_CHARGER_SMB347 is not set CONFIG_CHARGER_TPS65090=y # CONFIG_CHARGER_TPS65217 is not set # CONFIG_BATTERY_GAUGE_LTC2941 is not set # CONFIG_CHARGER_RT9455 is not set CONFIG_AXP20X_POWER=m CONFIG_HWMON=y # CONFIG_HWMON_VID is not set # CONFIG_HWMON_DEBUG_CHIP is not set # # Native drivers # # CONFIG_SENSORS_AD7314 is not set # CONFIG_SENSORS_AD7414 is not set # CONFIG_SENSORS_AD7418 is not set # CONFIG_SENSORS_ADM1021 is not set # CONFIG_SENSORS_ADM1025 is not set # CONFIG_SENSORS_ADM1026 is not set # CONFIG_SENSORS_ADM1029 is not set # CONFIG_SENSORS_ADM1031 is not set # CONFIG_SENSORS_ADM9240 is not set # CONFIG_SENSORS_ADT7310 is not set # CONFIG_SENSORS_ADT7410 is not set # CONFIG_SENSORS_ADT7411 is not set # CONFIG_SENSORS_ADT7462 is not set # CONFIG_SENSORS_ADT7470 is not set # CONFIG_SENSORS_ADT7475 is not set # CONFIG_SENSORS_ASC7621 is not set # CONFIG_SENSORS_ATXP1 is not set # CONFIG_SENSORS_DS620 is not set # CONFIG_SENSORS_DS1621 is not set # CONFIG_SENSORS_I5K_AMB is not set # CONFIG_SENSORS_F71805F is not set # CONFIG_SENSORS_F71882FG is not set # CONFIG_SENSORS_F75375S is not set # CONFIG_SENSORS_FTSTEUTATES is not set # CONFIG_SENSORS_GL518SM is not set # CONFIG_SENSORS_GL520SM is not set # CONFIG_SENSORS_G760A is not set # CONFIG_SENSORS_G762 is not set CONFIG_SENSORS_GPIO_FAN=y # CONFIG_SENSORS_HIH6130 is not set CONFIG_SENSORS_IIO_HWMON=y # CONFIG_SENSORS_IT87 is not set # CONFIG_SENSORS_JC42 is not set # CONFIG_SENSORS_POWR1220 is not set # CONFIG_SENSORS_LINEAGE is not set # CONFIG_SENSORS_LTC2945 is not set # CONFIG_SENSORS_LTC2990 is not set # CONFIG_SENSORS_LTC4151 is not set # CONFIG_SENSORS_LTC4215 is not set # CONFIG_SENSORS_LTC4222 is not set # CONFIG_SENSORS_LTC4245 is not set # CONFIG_SENSORS_LTC4260 is not set # CONFIG_SENSORS_LTC4261 is not set # CONFIG_SENSORS_MAX1111 is not set # CONFIG_SENSORS_MAX16065 is not set # CONFIG_SENSORS_MAX1619 is not set # CONFIG_SENSORS_MAX1668 is not set # CONFIG_SENSORS_MAX197 is not set # CONFIG_SENSORS_MAX31722 is not set # CONFIG_SENSORS_MAX6639 is not set # CONFIG_SENSORS_MAX6642 is not set # CONFIG_SENSORS_MAX6650 is not set # CONFIG_SENSORS_MAX6697 is not set # CONFIG_SENSORS_MAX31790 is not set # CONFIG_SENSORS_MCP3021 is not set # CONFIG_SENSORS_ADCXX is not set # CONFIG_SENSORS_LM63 is not set # CONFIG_SENSORS_LM70 is not set # CONFIG_SENSORS_LM73 is not set # CONFIG_SENSORS_LM75 is not set # CONFIG_SENSORS_LM77 is not set # CONFIG_SENSORS_LM78 is not set # CONFIG_SENSORS_LM80 is not set # CONFIG_SENSORS_LM83 is not set # CONFIG_SENSORS_LM85 is not set # CONFIG_SENSORS_LM87 is not set CONFIG_SENSORS_LM90=y # CONFIG_SENSORS_LM92 is not set # CONFIG_SENSORS_LM93 is not set # CONFIG_SENSORS_LM95234 is not set # CONFIG_SENSORS_LM95241 is not set CONFIG_SENSORS_LM95245=y # CONFIG_SENSORS_PC87360 is not set # CONFIG_SENSORS_PC87427 is not set CONFIG_SENSORS_NTC_THERMISTOR=m # CONFIG_SENSORS_NCT6683 is not set # CONFIG_SENSORS_NCT6775 is not set # CONFIG_SENSORS_NCT7802 is not set # CONFIG_SENSORS_NCT7904 is not set # CONFIG_SENSORS_PCF8591 is not set # CONFIG_PMBUS is not set CONFIG_SENSORS_PWM_FAN=m # CONFIG_SENSORS_SHT15 is not set # CONFIG_SENSORS_SHT21 is not set # CONFIG_SENSORS_SHT3x is not set # CONFIG_SENSORS_SHTC1 is not set # CONFIG_SENSORS_SIS5595 is not set # CONFIG_SENSORS_DME1737 is not set # CONFIG_SENSORS_EMC1403 is not set # CONFIG_SENSORS_EMC2103 is not set # CONFIG_SENSORS_EMC6W201 is not set # CONFIG_SENSORS_SMSC47M1 is not set # CONFIG_SENSORS_SMSC47M192 is not set # CONFIG_SENSORS_SMSC47B397 is not set # CONFIG_SENSORS_SCH56XX_COMMON is not set # CONFIG_SENSORS_SCH5627 is not set # CONFIG_SENSORS_SCH5636 is not set # CONFIG_SENSORS_SMM665 is not set # CONFIG_SENSORS_ADC128D818 is not set # CONFIG_SENSORS_ADS1015 is not set # CONFIG_SENSORS_ADS7828 is not set # CONFIG_SENSORS_ADS7871 is not set # CONFIG_SENSORS_AMC6821 is not set # CONFIG_SENSORS_INA209 is not set CONFIG_SENSORS_INA2XX=m # CONFIG_SENSORS_INA3221 is not set # CONFIG_SENSORS_TC74 is not set # CONFIG_SENSORS_THMC50 is not set CONFIG_SENSORS_TMP102=y # CONFIG_SENSORS_TMP103 is not set # CONFIG_SENSORS_TMP401 is not set # CONFIG_SENSORS_TMP421 is not set # CONFIG_SENSORS_VIA686A is not set # CONFIG_SENSORS_VT1211 is not set # CONFIG_SENSORS_VT8231 is not set # CONFIG_SENSORS_W83781D is not set # CONFIG_SENSORS_W83791D is not set # CONFIG_SENSORS_W83792D is not set # CONFIG_SENSORS_W83793 is not set # CONFIG_SENSORS_W83795 is not set # CONFIG_SENSORS_W83L785TS is not set # CONFIG_SENSORS_W83L786NG is not set # CONFIG_SENSORS_W83627HF is not set # CONFIG_SENSORS_W83627EHF is not set CONFIG_THERMAL=y CONFIG_THERMAL_EMERGENCY_POWEROFF_DELAY_MS=0 CONFIG_THERMAL_HWMON=y CONFIG_THERMAL_OF=y CONFIG_THERMAL_WRITABLE_TRIPS=y CONFIG_THERMAL_DEFAULT_GOV_STEP_WISE=y # CONFIG_THERMAL_DEFAULT_GOV_FAIR_SHARE is not set # CONFIG_THERMAL_DEFAULT_GOV_USER_SPACE is not set # CONFIG_THERMAL_DEFAULT_GOV_POWER_ALLOCATOR is not set CONFIG_THERMAL_GOV_FAIR_SHARE=y CONFIG_THERMAL_GOV_STEP_WISE=y CONFIG_THERMAL_GOV_BANG_BANG=y CONFIG_THERMAL_GOV_USER_SPACE=y CONFIG_THERMAL_GOV_POWER_ALLOCATOR=y CONFIG_CPU_THERMAL=y # CONFIG_CLOCK_THERMAL is not set CONFIG_THERMAL_EMULATION=y # CONFIG_QORIQ_THERMAL is not set # # ACPI INT340X thermal drivers # # # Texas Instruments thermal drivers # CONFIG_TI_SOC_THERMAL=y CONFIG_TI_THERMAL=y CONFIG_TI_THERMAL_EMERGENCY_POWEROFF_DELAY_MS=0 # CONFIG_QCOM_SPMI_TEMP_ALARM is not set # CONFIG_GENERIC_ADC_THERMAL is not set CONFIG_WATCHDOG=y CONFIG_WATCHDOG_CORE=y # CONFIG_WATCHDOG_NOWAYOUT is not set # CONFIG_WATCHDOG_SYSFS is not set # # Watchdog Device Drivers # # CONFIG_SOFT_WATCHDOG is not set # CONFIG_GPIO_WATCHDOG is not set # CONFIG_XILINX_WATCHDOG is not set # CONFIG_ZIIRAVE_WATCHDOG is not set # CONFIG_CADENCE_WATCHDOG is not set # CONFIG_DW_WATCHDOG is not set CONFIG_OMAP_WATCHDOG=m # CONFIG_MAX63XX_WATCHDOG is not set # CONFIG_ALIM7101_WDT is not set # CONFIG_I6300ESB_WDT is not set # CONFIG_MEN_A21_WDT is not set # # PCI-based Watchdog Cards # # CONFIG_PCIPCWATCHDOG is not set # CONFIG_WDTPCI is not set # # USB-based Watchdog Cards # # CONFIG_USBPCWATCHDOG is not set # # Watchdog Pretimeout Governors # # CONFIG_WATCHDOG_PRETIMEOUT_GOV is not set CONFIG_SSB_POSSIBLE=y # # Sonics Silicon Backplane # # CONFIG_SSB is not set CONFIG_BCMA_POSSIBLE=y # # Broadcom specific AMBA # # CONFIG_BCMA is not set # # Multifunction device drivers # CONFIG_MFD_CORE=y CONFIG_MFD_ACT8945A=y # CONFIG_MFD_AS3711 is not set # CONFIG_MFD_AS3722 is not set # CONFIG_PMIC_ADP5520 is not set # CONFIG_MFD_AAT2870_CORE is not set # CONFIG_MFD_ATMEL_FLEXCOM is not set # CONFIG_MFD_ATMEL_HLCDC is not set # CONFIG_MFD_BCM590XX is not set CONFIG_MFD_AXP20X=m CONFIG_MFD_AXP20X_I2C=m # CONFIG_MFD_CROS_EC is not set # CONFIG_MFD_ASIC3 is not set # CONFIG_PMIC_DA903X is not set # CONFIG_MFD_DA9052_SPI is not set # CONFIG_MFD_DA9052_I2C is not set # CONFIG_MFD_DA9055 is not set # CONFIG_MFD_DA9062 is not set # CONFIG_MFD_DA9063 is not set # CONFIG_MFD_DA9150 is not set # CONFIG_MFD_DLN2 is not set # CONFIG_MFD_EXYNOS_LPASS is not set # CONFIG_MFD_MC13XXX_SPI is not set # CONFIG_MFD_MC13XXX_I2C is not set # CONFIG_MFD_HI6421_PMIC is not set # CONFIG_HTC_PASIC3 is not set # CONFIG_HTC_I2CPLD is not set # CONFIG_LPC_ICH is not set # CONFIG_LPC_SCH is not set # CONFIG_INTEL_SOC_PMIC is not set # CONFIG_MFD_JANZ_CMODIO is not set # CONFIG_MFD_KEMPLD is not set # CONFIG_MFD_88PM800 is not set # CONFIG_MFD_88PM805 is not set # CONFIG_MFD_88PM860X is not set # CONFIG_MFD_MAX14577 is not set # CONFIG_MFD_MAX77620 is not set # CONFIG_MFD_MAX77686 is not set # CONFIG_MFD_MAX77693 is not set # CONFIG_MFD_MAX77843 is not set # CONFIG_MFD_MAX8907 is not set # CONFIG_MFD_MAX8925 is not set # CONFIG_MFD_MAX8997 is not set # CONFIG_MFD_MAX8998 is not set # CONFIG_MFD_MT6397 is not set # CONFIG_MFD_MENF21BMC is not set # CONFIG_EZX_PCAP is not set # CONFIG_MFD_VIPERBOARD is not set # CONFIG_MFD_RETU is not set # CONFIG_MFD_PCF50633 is not set # CONFIG_MFD_PM8921_CORE is not set # CONFIG_MFD_RDC321X is not set # CONFIG_MFD_RTSX_PCI is not set # CONFIG_MFD_RT5033 is not set # CONFIG_MFD_RTSX_USB is not set # CONFIG_MFD_RC5T583 is not set # CONFIG_MFD_RK808 is not set # CONFIG_MFD_RN5T618 is not set # CONFIG_MFD_SEC_CORE is not set # CONFIG_MFD_SI476X_CORE is not set # CONFIG_MFD_SM501 is not set # CONFIG_MFD_SKY81452 is not set # CONFIG_MFD_SMSC is not set # CONFIG_ABX500_CORE is not set # CONFIG_MFD_STMPE is not set CONFIG_MFD_SYSCON=y CONFIG_MFD_TI_AM335X_TSCADC=m # CONFIG_MFD_LP3943 is not set # CONFIG_MFD_LP8788 is not set CONFIG_MFD_OMAP_USB_HOST=y CONFIG_MFD_PALMAS=y # CONFIG_TPS6105X is not set # CONFIG_TPS65010 is not set # CONFIG_TPS6507X is not set # CONFIG_MFD_TPS65086 is not set CONFIG_MFD_TPS65090=y CONFIG_MFD_TPS65217=y CONFIG_MFD_TI_LP873X=y CONFIG_MFD_TI_LP87565=y CONFIG_MFD_TPS65218=y CONFIG_MFD_TPS6586X=y CONFIG_MFD_TPS65910=y # CONFIG_MFD_TPS65912_I2C is not set # CONFIG_MFD_TPS65912_SPI is not set # CONFIG_MFD_TPS80031 is not set # CONFIG_TWL4030_CORE is not set CONFIG_TWL6040_CORE=y # CONFIG_MFD_WL1273_CORE is not set # CONFIG_MFD_LM3533 is not set # CONFIG_MFD_TC3589X is not set # CONFIG_MFD_TMIO is not set # CONFIG_MFD_T7L66XB is not set # CONFIG_MFD_TC6387XB is not set # CONFIG_MFD_TC6393XB is not set # CONFIG_MFD_VX855 is not set # CONFIG_MFD_ARIZONA_I2C is not set # CONFIG_MFD_ARIZONA_SPI is not set # CONFIG_MFD_WM8400 is not set # CONFIG_MFD_WM831X_I2C is not set # CONFIG_MFD_WM831X_SPI is not set # CONFIG_MFD_WM8350_I2C is not set # CONFIG_MFD_WM8994 is not set CONFIG_REGULATOR=y # CONFIG_REGULATOR_DEBUG is not set CONFIG_REGULATOR_FIXED_VOLTAGE=y # CONFIG_REGULATOR_VIRTUAL_CONSUMER is not set # CONFIG_REGULATOR_USERSPACE_CONSUMER is not set # CONFIG_REGULATOR_ACT8865 is not set CONFIG_REGULATOR_ACT8945A=y # CONFIG_REGULATOR_AD5398 is not set # CONFIG_REGULATOR_ANATOP is not set # CONFIG_REGULATOR_AXP20X is not set # CONFIG_REGULATOR_DA9210 is not set # CONFIG_REGULATOR_DA9211 is not set # CONFIG_REGULATOR_FAN53555 is not set CONFIG_REGULATOR_GPIO=y # CONFIG_REGULATOR_ISL9305 is not set # CONFIG_REGULATOR_ISL6271A is not set # CONFIG_REGULATOR_LP3971 is not set # CONFIG_REGULATOR_LP3972 is not set # CONFIG_REGULATOR_LP872X is not set CONFIG_REGULATOR_LP873X=y # CONFIG_REGULATOR_LP8755 is not set CONFIG_REGULATOR_LP87565=y # CONFIG_REGULATOR_LTC3589 is not set # CONFIG_REGULATOR_LTC3676 is not set # CONFIG_REGULATOR_MAX1586 is not set # CONFIG_REGULATOR_MAX8649 is not set # CONFIG_REGULATOR_MAX8660 is not set # CONFIG_REGULATOR_MAX8952 is not set # CONFIG_REGULATOR_MAX8973 is not set # CONFIG_REGULATOR_MT6311 is not set CONFIG_REGULATOR_PALMAS=y CONFIG_REGULATOR_PBIAS=y # CONFIG_REGULATOR_PFUZE100 is not set # CONFIG_REGULATOR_PV88060 is not set # CONFIG_REGULATOR_PV88080 is not set # CONFIG_REGULATOR_PV88090 is not set # CONFIG_REGULATOR_PWM is not set # CONFIG_REGULATOR_QCOM_SPMI is not set CONFIG_REGULATOR_TI_ABB=y # CONFIG_REGULATOR_TPS51632 is not set CONFIG_REGULATOR_TPS62360=y CONFIG_REGULATOR_TPS65023=y CONFIG_REGULATOR_TPS6507X=y CONFIG_REGULATOR_TPS65090=y CONFIG_REGULATOR_TPS65217=y CONFIG_REGULATOR_TPS65218=y CONFIG_REGULATOR_TPS6524X=y CONFIG_REGULATOR_TPS6586X=y CONFIG_REGULATOR_TPS65910=y CONFIG_MEDIA_SUPPORT=y # # Multimedia core support # CONFIG_MEDIA_CAMERA_SUPPORT=y # CONFIG_MEDIA_ANALOG_TV_SUPPORT is not set # CONFIG_MEDIA_DIGITAL_TV_SUPPORT is not set # CONFIG_MEDIA_RADIO_SUPPORT is not set # CONFIG_MEDIA_SDR_SUPPORT is not set # CONFIG_MEDIA_RC_SUPPORT is not set CONFIG_MEDIA_CEC_EDID=y CONFIG_MEDIA_CONTROLLER=y # CONFIG_MEDIA_CONTROLLER_DVB is not set CONFIG_VIDEO_DEV=y CONFIG_VIDEO_V4L2_SUBDEV_API=y CONFIG_VIDEO_V4L2=y # CONFIG_VIDEO_ADV_DEBUG is not set # CONFIG_VIDEO_FIXED_MINOR_RANGES is not set # CONFIG_VIDEO_PCI_SKELETON is not set CONFIG_V4L2_MEM2MEM_DEV=y # CONFIG_V4L2_FLASH_LED_CLASS is not set CONFIG_VIDEOBUF_GEN=m CONFIG_VIDEOBUF2_CORE=y CONFIG_VIDEOBUF2_MEMOPS=y CONFIG_VIDEOBUF2_DMA_CONTIG=y CONFIG_VIDEOBUF2_VMALLOC=m # CONFIG_TTPCI_EEPROM is not set # # Media drivers # CONFIG_MEDIA_USB_SUPPORT=y # # Webcam devices # CONFIG_USB_VIDEO_CLASS=m CONFIG_USB_VIDEO_CLASS_INPUT_EVDEV=y CONFIG_USB_GSPCA=m # CONFIG_USB_M5602 is not set # CONFIG_USB_STV06XX is not set # CONFIG_USB_GL860 is not set # CONFIG_USB_GSPCA_BENQ is not set # CONFIG_USB_GSPCA_CONEX is not set # CONFIG_USB_GSPCA_CPIA1 is not set # CONFIG_USB_GSPCA_DTCS033 is not set # CONFIG_USB_GSPCA_ETOMS is not set # CONFIG_USB_GSPCA_FINEPIX is not set # CONFIG_USB_GSPCA_JEILINJ is not set # CONFIG_USB_GSPCA_JL2005BCD is not set # CONFIG_USB_GSPCA_KINECT is not set # CONFIG_USB_GSPCA_KONICA is not set # CONFIG_USB_GSPCA_MARS is not set # CONFIG_USB_GSPCA_MR97310A is not set # CONFIG_USB_GSPCA_NW80X is not set # CONFIG_USB_GSPCA_OV519 is not set # CONFIG_USB_GSPCA_OV534 is not set # CONFIG_USB_GSPCA_OV534_9 is not set # CONFIG_USB_GSPCA_PAC207 is not set # CONFIG_USB_GSPCA_PAC7302 is not set # CONFIG_USB_GSPCA_PAC7311 is not set # CONFIG_USB_GSPCA_SE401 is not set # CONFIG_USB_GSPCA_SN9C2028 is not set # CONFIG_USB_GSPCA_SN9C20X is not set # CONFIG_USB_GSPCA_SONIXB is not set # CONFIG_USB_GSPCA_SONIXJ is not set # CONFIG_USB_GSPCA_SPCA500 is not set # CONFIG_USB_GSPCA_SPCA501 is not set # CONFIG_USB_GSPCA_SPCA505 is not set # CONFIG_USB_GSPCA_SPCA506 is not set # CONFIG_USB_GSPCA_SPCA508 is not set # CONFIG_USB_GSPCA_SPCA561 is not set # CONFIG_USB_GSPCA_SPCA1528 is not set # CONFIG_USB_GSPCA_SQ905 is not set # CONFIG_USB_GSPCA_SQ905C is not set # CONFIG_USB_GSPCA_SQ930X is not set # CONFIG_USB_GSPCA_STK014 is not set # CONFIG_USB_GSPCA_STK1135 is not set # CONFIG_USB_GSPCA_STV0680 is not set # CONFIG_USB_GSPCA_SUNPLUS is not set # CONFIG_USB_GSPCA_T613 is not set # CONFIG_USB_GSPCA_TOPRO is not set # CONFIG_USB_GSPCA_TOUPTEK is not set # CONFIG_USB_GSPCA_TV8532 is not set # CONFIG_USB_GSPCA_VC032X is not set # CONFIG_USB_GSPCA_VICAM is not set # CONFIG_USB_GSPCA_XIRLINK_CIT is not set # CONFIG_USB_GSPCA_ZC3XX is not set # CONFIG_USB_PWC is not set # CONFIG_VIDEO_CPIA2 is not set # CONFIG_USB_ZR364XX is not set # CONFIG_USB_STKWEBCAM is not set # CONFIG_USB_S2255 is not set # CONFIG_VIDEO_USBTV is not set # # Webcam, TV (analog/digital) USB devices # # CONFIG_VIDEO_EM28XX is not set # CONFIG_MEDIA_PCI_SUPPORT is not set CONFIG_V4L_PLATFORM_DRIVERS=y # CONFIG_VIDEO_CAFE_CCIC is not set CONFIG_SOC_CAMERA=m CONFIG_SOC_CAMERA_PLATFORM=m # CONFIG_VIDEO_XILINX is not set CONFIG_V4L_MEM2MEM_DRIVERS=y # CONFIG_VIDEO_MEM2MEM_DEINTERLACE is not set # CONFIG_VIDEO_SH_VEU is not set CONFIG_V4L_TEST_DRIVERS=y CONFIG_VIDEO_VIVID=m CONFIG_VIDEO_VIVID_MAX_DEVS=64 # CONFIG_VIDEO_VIM2M is not set # # Supported MMC/SDIO adapters # # CONFIG_CYPRESS_FIRMWARE is not set CONFIG_VIDEO_V4L2_TPG=m # # Media ancillary drivers (tuners, sensors, i2c, spi, frontends) # # CONFIG_MEDIA_SUBDRV_AUTOSELECT is not set # # I2C Encoders, decoders, sensors and other helper chips # # # Audio decoders, processors and mixers # # CONFIG_VIDEO_TVAUDIO is not set # CONFIG_VIDEO_TDA7432 is not set # CONFIG_VIDEO_TDA9840 is not set # CONFIG_VIDEO_TEA6415C is not set # CONFIG_VIDEO_TEA6420 is not set # CONFIG_VIDEO_MSP3400 is not set # CONFIG_VIDEO_CS3308 is not set # CONFIG_VIDEO_CS5345 is not set # CONFIG_VIDEO_CS53L32A is not set # CONFIG_VIDEO_TLV320AIC23B is not set # CONFIG_VIDEO_UDA1342 is not set # CONFIG_VIDEO_WM8775 is not set # CONFIG_VIDEO_WM8739 is not set # CONFIG_VIDEO_VP27SMPX is not set # CONFIG_VIDEO_SONY_BTF_MPX is not set # # RDS decoders # # CONFIG_VIDEO_SAA6588 is not set # # Video decoders # CONFIG_VIDEO_ADV7180=m # CONFIG_VIDEO_ADV7183 is not set # CONFIG_VIDEO_ADV7604 is not set # CONFIG_VIDEO_ADV7842 is not set # CONFIG_VIDEO_BT819 is not set # CONFIG_VIDEO_BT856 is not set # CONFIG_VIDEO_BT866 is not set # CONFIG_VIDEO_KS0127 is not set CONFIG_VIDEO_ML86V7667=m # CONFIG_VIDEO_AD5820 is not set # CONFIG_VIDEO_SAA7110 is not set # CONFIG_VIDEO_SAA711X is not set # CONFIG_VIDEO_TC358743 is not set # CONFIG_VIDEO_TVP514X is not set # CONFIG_VIDEO_TVP5150 is not set # CONFIG_VIDEO_TVP7002 is not set # CONFIG_VIDEO_TW2804 is not set # CONFIG_VIDEO_TW9903 is not set # CONFIG_VIDEO_TW9906 is not set # CONFIG_VIDEO_VPX3220 is not set # # Video and audio decoders # # CONFIG_VIDEO_SAA717X is not set # CONFIG_VIDEO_CX25840 is not set # # Video encoders # # CONFIG_VIDEO_SAA7127 is not set # CONFIG_VIDEO_SAA7185 is not set # CONFIG_VIDEO_ADV7170 is not set # CONFIG_VIDEO_ADV7175 is not set # CONFIG_VIDEO_ADV7343 is not set # CONFIG_VIDEO_ADV7393 is not set # CONFIG_VIDEO_ADV7511 is not set # CONFIG_VIDEO_AD9389B is not set # CONFIG_VIDEO_AK881X is not set # CONFIG_VIDEO_THS8200 is not set # # Camera sensor devices # CONFIG_VIDEO_OV2659=m # CONFIG_VIDEO_OV7640 is not set # CONFIG_VIDEO_OV7670 is not set # CONFIG_VIDEO_OV9650 is not set CONFIG_VIDEO_OV1063X=m CONFIG_VIDEO_OV490=m # CONFIG_VIDEO_VS6624 is not set # CONFIG_VIDEO_MT9M032 is not set # CONFIG_VIDEO_MT9M111 is not set # CONFIG_VIDEO_MT9P031 is not set # CONFIG_VIDEO_MT9T001 is not set # CONFIG_VIDEO_MT9V011 is not set # CONFIG_VIDEO_MT9V032 is not set CONFIG_VIDEO_MT9T11X=m # CONFIG_VIDEO_SR030PC30 is not set # CONFIG_VIDEO_NOON010PC30 is not set # CONFIG_VIDEO_M5MOLS is not set # CONFIG_VIDEO_S5K6AA is not set # CONFIG_VIDEO_S5K6A3 is not set # CONFIG_VIDEO_S5K4ECGX is not set # CONFIG_VIDEO_S5K5BAF is not set # CONFIG_VIDEO_SMIAPP is not set # CONFIG_VIDEO_S5C73M3 is not set # # Flash devices # # CONFIG_VIDEO_ADP1653 is not set # CONFIG_VIDEO_AS3645A is not set # CONFIG_VIDEO_LM3560 is not set # CONFIG_VIDEO_LM3646 is not set # # Video improvement chips # # CONFIG_VIDEO_UPD64031A is not set # CONFIG_VIDEO_UPD64083 is not set # # Audio/Video compression chips # # CONFIG_VIDEO_SAA6752HS is not set # # Miscellaneous helper chips # # CONFIG_VIDEO_THS7303 is not set # CONFIG_VIDEO_M52790 is not set # # Sensors used on soc_camera driver # # # soc_camera sensor drivers # # CONFIG_SOC_CAMERA_IMX074 is not set # CONFIG_SOC_CAMERA_MT9M001 is not set # CONFIG_SOC_CAMERA_MT9M111 is not set # CONFIG_SOC_CAMERA_MT9T031 is not set # CONFIG_SOC_CAMERA_MT9T112 is not set # CONFIG_SOC_CAMERA_MT9V022 is not set # CONFIG_SOC_CAMERA_OV2640 is not set # CONFIG_SOC_CAMERA_OV5642 is not set # CONFIG_SOC_CAMERA_OV6650 is not set # CONFIG_SOC_CAMERA_OV772X is not set # CONFIG_SOC_CAMERA_OV9640 is not set # CONFIG_SOC_CAMERA_OV9740 is not set # CONFIG_SOC_CAMERA_RJ54N1 is not set # CONFIG_SOC_CAMERA_TW9910 is not set # # SPI helper chips # # CONFIG_VIDEO_GS1662 is not set # # Customise DVB Frontends # CONFIG_DVB_AU8522=m CONFIG_DVB_AU8522_V4L=m CONFIG_DVB_TUNER_DIB0070=m CONFIG_DVB_TUNER_DIB0090=m # # Tools to develop new frontends # # CONFIG_DVB_DUMMY_FE is not set # # Graphics support # # CONFIG_VGA_ARB is not set # CONFIG_IMX_IPUV3_CORE is not set CONFIG_DRM=y # CONFIG_DRM_DP_AUX_CHARDEV is not set CONFIG_DRM_KMS_HELPER=y CONFIG_DRM_KMS_FB_HELPER=y CONFIG_DRM_FBDEV_EMULATION=y # CONFIG_DRM_LOAD_EDID_FIRMWARE is not set CONFIG_DRM_GEM_CMA_HELPER=y CONFIG_DRM_KMS_CMA_HELPER=y # # I2C encoder or helper chips # CONFIG_DRM_I2C_ADIHDMI=m # CONFIG_DRM_I2C_CH7006 is not set # CONFIG_DRM_I2C_SIL164 is not set CONFIG_DRM_I2C_NXP_TDA998X=y # CONFIG_DRM_HDLCD is not set # CONFIG_DRM_MALI_DISPLAY is not set # CONFIG_DRM_RADEON is not set # CONFIG_DRM_AMDGPU is not set # # ACP (Audio CoProcessor) Configuration # # CONFIG_DRM_NOUVEAU is not set # CONFIG_DRM_VGEM is not set # CONFIG_DRM_EXYNOS is not set # CONFIG_DRM_UDL is not set # CONFIG_DRM_AST is not set # CONFIG_DRM_MGAG200 is not set # CONFIG_DRM_CIRRUS_QEMU is not set # CONFIG_DRM_ARMADA is not set CONFIG_DRM_OMAP=y CONFIG_DRM_OMAP_WB=y CONFIG_OMAP2_DSS_INIT=y CONFIG_OMAP_DSS_BASE=y CONFIG_OMAP2_DSS=y # CONFIG_OMAP2_DSS_DEBUG is not set CONFIG_OMAP2_DSS_DEBUGFS=y # CONFIG_OMAP2_DSS_COLLECT_IRQ_STATS is not set CONFIG_OMAP2_DSS_DPI=y # CONFIG_OMAP2_DSS_VENC is not set CONFIG_OMAP2_DSS_HDMI_COMMON=y CONFIG_OMAP4_DSS_HDMI=y CONFIG_OMAP5_DSS_HDMI=y # CONFIG_OMAP2_DSS_SDI is not set # CONFIG_OMAP2_DSS_DSI is not set CONFIG_OMAP2_DSS_MIN_FCK_PER_PCK=0 CONFIG_OMAP2_DSS_SLEEP_AFTER_VENC_RESET=y CONFIG_TI_DSS6=y # # OMAPDRM External Display Device Drivers # # CONFIG_DRM_OMAP_ENCODER_OPA362 is not set CONFIG_DRM_OMAP_ENCODER_TFP410=y CONFIG_DRM_OMAP_ENCODER_TPD12S015=y CONFIG_DRM_OMAP_ENCODER_TC358768=y CONFIG_DRM_OMAP_DRA7EVM_ENCODER_TPD12S015=y CONFIG_DRM_OMAP_ENCODER_SII9022=y CONFIG_DRM_OMAP_ENCODER_SII9022_AUDIO_CODEC=y CONFIG_DRM_OMAP_CONNECTOR_DVI=y CONFIG_DRM_OMAP_CONNECTOR_HDMI=y # CONFIG_DRM_OMAP_CONNECTOR_ANALOG_TV is not set CONFIG_DRM_OMAP_PANEL_DPI=y # CONFIG_DRM_OMAP_PANEL_DSI_CM is not set # CONFIG_DRM_OMAP_PANEL_SONY_ACX565AKM is not set # CONFIG_DRM_OMAP_PANEL_LGPHILIPS_LB035Q02 is not set # CONFIG_DRM_OMAP_PANEL_SHARP_LS037V7DW01 is not set # CONFIG_DRM_OMAP_PANEL_TPO_TD028TTEC1 is not set # CONFIG_DRM_OMAP_PANEL_TPO_TD043MTEA1 is not set # CONFIG_DRM_OMAP_PANEL_NEC_NL8048HL11 is not set CONFIG_DRM_TILCDC=y CONFIG_DRM_TILCDC_SLAVE_COMPAT=y # CONFIG_DRM_QXL is not set # CONFIG_DRM_BOCHS is not set # CONFIG_DRM_VIRTIO_GPU is not set # CONFIG_DRM_FSL_DCU is not set CONFIG_DRM_BRIDGE=y # # Display Interface Bridges # # CONFIG_DRM_ANALOGIX_ANX78XX is not set # CONFIG_DRM_DUMB_VGA_DAC is not set # CONFIG_DRM_NXP_PTN3460 is not set # CONFIG_DRM_PARADE_PS8622 is not set # CONFIG_DRM_SII902X is not set # CONFIG_DRM_TOSHIBA_TC358767 is not set # CONFIG_DRM_TI_TFP410 is not set # CONFIG_DRM_I2C_ADV7511 is not set # CONFIG_DRM_STI is not set # CONFIG_DRM_ETNAVIV is not set # CONFIG_DRM_ARCPGU is not set # CONFIG_DRM_LEGACY is not set # # Frame buffer Devices # CONFIG_FB=y # CONFIG_FIRMWARE_EDID is not set CONFIG_FB_CMDLINE=y CONFIG_FB_NOTIFY=y # CONFIG_FB_DDC is not set # CONFIG_FB_BOOT_VESA_SUPPORT is not set CONFIG_FB_CFB_FILLRECT=y CONFIG_FB_CFB_COPYAREA=y CONFIG_FB_CFB_IMAGEBLIT=y # CONFIG_FB_CFB_REV_PIXELS_IN_BYTE is not set CONFIG_FB_SYS_FILLRECT=y CONFIG_FB_SYS_COPYAREA=y CONFIG_FB_SYS_IMAGEBLIT=y # CONFIG_FB_FOREIGN_ENDIAN is not set CONFIG_FB_SYS_FOPS=y CONFIG_FB_DEFERRED_IO=y # CONFIG_FB_SVGALIB is not set # CONFIG_FB_MACMODES is not set CONFIG_FB_BACKLIGHT=y # CONFIG_FB_MODE_HELPERS is not set # CONFIG_FB_TILEBLITTING is not set # # Frame buffer hardware drivers # # CONFIG_FB_CIRRUS is not set # CONFIG_FB_PM2 is not set # CONFIG_FB_CYBER2000 is not set # CONFIG_FB_ASILIANT is not set # CONFIG_FB_IMSTT is not set CONFIG_FB_EFI=y # CONFIG_FB_OPENCORES is not set # CONFIG_FB_S1D13XXX is not set # CONFIG_FB_NVIDIA is not set # CONFIG_FB_RIVA is not set # CONFIG_FB_I740 is not set # CONFIG_FB_MATROX is not set # CONFIG_FB_RADEON is not set # CONFIG_FB_ATY128 is not set # CONFIG_FB_ATY is not set # CONFIG_FB_S3 is not set # CONFIG_FB_SAVAGE is not set # CONFIG_FB_SIS is not set # CONFIG_FB_NEOMAGIC is not set # CONFIG_FB_KYRO is not set # CONFIG_FB_3DFX is not set # CONFIG_FB_VOODOO1 is not set # CONFIG_FB_VT8623 is not set # CONFIG_FB_TRIDENT is not set # CONFIG_FB_ARK is not set # CONFIG_FB_PM3 is not set # CONFIG_FB_CARMINE is not set # CONFIG_FB_SMSCUFX is not set # CONFIG_FB_UDL is not set # CONFIG_FB_IBM_GXT4500 is not set # CONFIG_FB_DA8XX is not set # CONFIG_FB_VIRTUAL is not set # CONFIG_FB_METRONOME is not set # CONFIG_FB_MB862XX is not set # CONFIG_FB_BROADSHEET is not set # CONFIG_FB_AUO_K190X is not set CONFIG_FB_SIMPLE=y CONFIG_FB_SSD1307=y # CONFIG_FB_SM712 is not set CONFIG_BACKLIGHT_LCD_SUPPORT=y # CONFIG_LCD_CLASS_DEVICE is not set CONFIG_BACKLIGHT_CLASS_DEVICE=y CONFIG_BACKLIGHT_GENERIC=y CONFIG_BACKLIGHT_PWM=y # CONFIG_BACKLIGHT_PM8941_WLED is not set # CONFIG_BACKLIGHT_ADP8860 is not set # CONFIG_BACKLIGHT_ADP8870 is not set # CONFIG_BACKLIGHT_LM3630A is not set # CONFIG_BACKLIGHT_LM3639 is not set # CONFIG_BACKLIGHT_LP855X is not set # CONFIG_BACKLIGHT_TPS65217 is not set CONFIG_BACKLIGHT_GPIO=y # CONFIG_BACKLIGHT_LV5207LP is not set # CONFIG_BACKLIGHT_BD6107 is not set CONFIG_BACKLIGHT_LED=y # CONFIG_VGASTATE is not set CONFIG_VIDEOMODE_HELPERS=y CONFIG_HDMI=y # # Console display driver support # CONFIG_DUMMY_CONSOLE=y CONFIG_FRAMEBUFFER_CONSOLE=y CONFIG_FRAMEBUFFER_CONSOLE_DETECT_PRIMARY=y CONFIG_FRAMEBUFFER_CONSOLE_ROTATION=y CONFIG_LOGO=y # CONFIG_LOGO_LINUX_MONO is not set # CONFIG_LOGO_LINUX_VGA16 is not set CONFIG_LOGO_LINUX_CLUT224=y CONFIG_SOUND=y # CONFIG_SOUND_OSS_CORE is not set CONFIG_SND=y CONFIG_SND_TIMER=y CONFIG_SND_PCM=y CONFIG_SND_PCM_ELD=y CONFIG_SND_PCM_IEC958=y CONFIG_SND_DMAENGINE_PCM=y CONFIG_SND_HWDEP=m CONFIG_SND_RAWMIDI=m CONFIG_SND_JACK=y CONFIG_SND_JACK_INPUT_DEV=y # CONFIG_SND_SEQUENCER is not set # CONFIG_SND_MIXER_OSS is not set # CONFIG_SND_PCM_OSS is not set CONFIG_SND_PCM_TIMER=y # CONFIG_SND_HRTIMER is not set CONFIG_SND_DYNAMIC_MINORS=y CONFIG_SND_MAX_CARDS=32 CONFIG_SND_SUPPORT_OLD_API=y CONFIG_SND_PROC_FS=y CONFIG_SND_VERBOSE_PROCFS=y # CONFIG_SND_VERBOSE_PRINTK is not set # CONFIG_SND_DEBUG is not set # CONFIG_SND_RAWMIDI_SEQ is not set # CONFIG_SND_OPL3_LIB_SEQ is not set # CONFIG_SND_OPL4_LIB_SEQ is not set # CONFIG_SND_SBAWE_SEQ is not set # CONFIG_SND_EMU10K1_SEQ is not set CONFIG_SND_DRIVERS=y # CONFIG_SND_DUMMY is not set # CONFIG_SND_ALOOP is not set # CONFIG_SND_MTPAV is not set # CONFIG_SND_SERIAL_U16550 is not set # CONFIG_SND_MPU401 is not set CONFIG_SND_PCI=y # CONFIG_SND_AD1889 is not set # CONFIG_SND_ATIIXP is not set # CONFIG_SND_ATIIXP_MODEM is not set # CONFIG_SND_AU8810 is not set # CONFIG_SND_AU8820 is not set # CONFIG_SND_AU8830 is not set # CONFIG_SND_AW2 is not set # CONFIG_SND_BT87X is not set # CONFIG_SND_CA0106 is not set # CONFIG_SND_CMIPCI is not set # CONFIG_SND_OXYGEN is not set # CONFIG_SND_CS4281 is not set # CONFIG_SND_CS46XX is not set # CONFIG_SND_CTXFI is not set # CONFIG_SND_DARLA20 is not set # CONFIG_SND_GINA20 is not set # CONFIG_SND_LAYLA20 is not set # CONFIG_SND_DARLA24 is not set # CONFIG_SND_GINA24 is not set # CONFIG_SND_LAYLA24 is not set # CONFIG_SND_MONA is not set # CONFIG_SND_MIA is not set # CONFIG_SND_ECHO3G is not set # CONFIG_SND_INDIGO is not set # CONFIG_SND_INDIGOIO is not set # CONFIG_SND_INDIGODJ is not set # CONFIG_SND_INDIGOIOX is not set # CONFIG_SND_INDIGODJX is not set # CONFIG_SND_ENS1370 is not set # CONFIG_SND_ENS1371 is not set # CONFIG_SND_FM801 is not set # CONFIG_SND_HDSP is not set # CONFIG_SND_HDSPM is not set # CONFIG_SND_ICE1724 is not set # CONFIG_SND_INTEL8X0 is not set # CONFIG_SND_INTEL8X0M is not set # CONFIG_SND_KORG1212 is not set # CONFIG_SND_LOLA is not set # CONFIG_SND_LX6464ES is not set # CONFIG_SND_MIXART is not set # CONFIG_SND_NM256 is not set # CONFIG_SND_PCXHR is not set # CONFIG_SND_RIPTIDE is not set # CONFIG_SND_RME32 is not set # CONFIG_SND_RME96 is not set # CONFIG_SND_RME9652 is not set # CONFIG_SND_SE6X is not set # CONFIG_SND_VIA82XX is not set # CONFIG_SND_VIA82XX_MODEM is not set # CONFIG_SND_VIRTUOSO is not set # CONFIG_SND_VX222 is not set # CONFIG_SND_YMFPCI is not set # # HD-Audio # # CONFIG_SND_HDA_INTEL is not set CONFIG_SND_HDA_PREALLOC_SIZE=64 # CONFIG_SND_ARM is not set # CONFIG_SND_SPI is not set CONFIG_SND_USB=y CONFIG_SND_USB_AUDIO=m # CONFIG_SND_USB_UA101 is not set # CONFIG_SND_USB_CAIAQ is not set # CONFIG_SND_USB_6FIRE is not set # CONFIG_SND_USB_HIFACE is not set # CONFIG_SND_BCD2000 is not set # CONFIG_SND_USB_POD is not set # CONFIG_SND_USB_PODHD is not set # CONFIG_SND_USB_TONEPORT is not set # CONFIG_SND_USB_VARIAX is not set CONFIG_SND_SOC=y CONFIG_SND_SOC_GENERIC_DMAENGINE_PCM=y # CONFIG_SND_SOC_AMD_ACP is not set CONFIG_SND_ATMEL_SOC=m CONFIG_SND_EDMA_SOC=y # CONFIG_SND_DAVINCI_SOC_I2S is not set CONFIG_SND_DAVINCI_SOC_MCASP=y CONFIG_SND_DAVINCI_SOC_GENERIC_EVM=m CONFIG_SND_AM33XX_SOC_EVM=m # CONFIG_SND_AM33XX_SOC_JUSTBOOM_DAC is not set # CONFIG_SND_AM33XX_SOC_JUSTBOOM_DIGI is not set # CONFIG_SND_DESIGNWARE_I2S is not set # # SoC Audio for Freescale CPUs # # # Common SoC Audio options for Freescale CPUs: # # CONFIG_SND_SOC_FSL_ASRC is not set CONFIG_SND_SOC_FSL_SAI=m # CONFIG_SND_SOC_FSL_SSI is not set # CONFIG_SND_SOC_FSL_SPDIF is not set # CONFIG_SND_SOC_FSL_ESAI is not set # CONFIG_SND_SOC_IMX_AUDMUX is not set CONFIG_SND_OMAP_SOC=y CONFIG_SND_OMAP_SOC_HDMI_AUDIO=m # CONFIG_SND_OMAP_SOC_RX51 is not set # CONFIG_SND_SOC_IMG is not set # CONFIG_SND_SOC_XTFPGA_I2S is not set CONFIG_SND_SOC_I2C_AND_SPI=y # # CODEC drivers # # CONFIG_SND_SOC_AC97_CODEC is not set # CONFIG_SND_SOC_ADAU1701 is not set # CONFIG_SND_SOC_ADAU7002 is not set # CONFIG_SND_SOC_AK4104 is not set # CONFIG_SND_SOC_AK4554 is not set # CONFIG_SND_SOC_AK4613 is not set CONFIG_SND_SOC_AK4642=m # CONFIG_SND_SOC_AK5386 is not set # CONFIG_SND_SOC_ALC5623 is not set # CONFIG_SND_SOC_BT_SCO is not set # CONFIG_SND_SOC_CS35L32 is not set # CONFIG_SND_SOC_CS35L33 is not set # CONFIG_SND_SOC_CS42L51_I2C is not set # CONFIG_SND_SOC_CS42L52 is not set # CONFIG_SND_SOC_CS42L56 is not set # CONFIG_SND_SOC_CS42L73 is not set # CONFIG_SND_SOC_CS4265 is not set # CONFIG_SND_SOC_CS4270 is not set # CONFIG_SND_SOC_CS4271_I2C is not set # CONFIG_SND_SOC_CS4271_SPI is not set # CONFIG_SND_SOC_CS42XX8_I2C is not set # CONFIG_SND_SOC_CS4349 is not set # CONFIG_SND_SOC_CS53L30 is not set CONFIG_SND_SOC_HDMI_CODEC=y # CONFIG_SND_SOC_ES8328 is not set # CONFIG_SND_SOC_GTM601 is not set # CONFIG_SND_SOC_INNO_RK3036 is not set # CONFIG_SND_SOC_MAX98504 is not set # CONFIG_SND_SOC_MAX9860 is not set # CONFIG_SND_SOC_PCM1681 is not set # CONFIG_SND_SOC_PCM179X_I2C is not set # CONFIG_SND_SOC_PCM179X_SPI is not set # CONFIG_SND_SOC_PCM3168A_I2C is not set # CONFIG_SND_SOC_PCM3168A_SPI is not set # CONFIG_SND_SOC_PCM512x_I2C is not set # CONFIG_SND_SOC_PCM512x_SPI is not set # CONFIG_SND_SOC_RT5616 is not set # CONFIG_SND_SOC_RT5631 is not set # CONFIG_SND_SOC_RT5677_SPI is not set CONFIG_SND_SOC_SGTL5000=m # CONFIG_SND_SOC_SIRF_AUDIO_CODEC is not set CONFIG_SND_SOC_SPDIF=m # CONFIG_SND_SOC_SSM2602_SPI is not set # CONFIG_SND_SOC_SSM2602_I2C is not set # CONFIG_SND_SOC_SSM4567 is not set # CONFIG_SND_SOC_STA32X is not set # CONFIG_SND_SOC_STA350 is not set CONFIG_SND_SOC_STI_SAS=m # CONFIG_SND_SOC_TAS2552 is not set # CONFIG_SND_SOC_TAS5086 is not set # CONFIG_SND_SOC_TAS571X is not set # CONFIG_SND_SOC_TAS5720 is not set # CONFIG_SND_SOC_TDM is not set # CONFIG_SND_SOC_TFA9879 is not set # CONFIG_SND_SOC_TLV320AIC23_I2C is not set # CONFIG_SND_SOC_TLV320AIC23_SPI is not set CONFIG_SND_SOC_TLV320AIC31XX=m CONFIG_SND_SOC_TLV320AIC3X=m # CONFIG_SND_SOC_TS3A227E is not set # CONFIG_SND_SOC_WM8510 is not set # CONFIG_SND_SOC_WM8523 is not set # CONFIG_SND_SOC_WM8580 is not set # CONFIG_SND_SOC_WM8711 is not set # CONFIG_SND_SOC_WM8728 is not set # CONFIG_SND_SOC_WM8731 is not set # CONFIG_SND_SOC_WM8737 is not set # CONFIG_SND_SOC_WM8741 is not set # CONFIG_SND_SOC_WM8750 is not set # CONFIG_SND_SOC_WM8753 is not set # CONFIG_SND_SOC_WM8770 is not set # CONFIG_SND_SOC_WM8776 is not set # CONFIG_SND_SOC_WM8804_I2C is not set # CONFIG_SND_SOC_WM8804_SPI is not set # CONFIG_SND_SOC_WM8903 is not set # CONFIG_SND_SOC_WM8960 is not set # CONFIG_SND_SOC_WM8962 is not set # CONFIG_SND_SOC_WM8974 is not set CONFIG_SND_SOC_WM8978=m # CONFIG_SND_SOC_WM8985 is not set # CONFIG_SND_SOC_NAU8810 is not set # CONFIG_SND_SOC_TPA6130A2 is not set CONFIG_SND_SIMPLE_CARD_UTILS=m CONFIG_SND_SIMPLE_CARD=m # CONFIG_SND_SIMPLE_SCU_CARD is not set # CONFIG_SOUND_PRIME is not set # # HID support # CONFIG_HID=y # CONFIG_HID_BATTERY_STRENGTH is not set # CONFIG_HIDRAW is not set # CONFIG_UHID is not set CONFIG_HID_GENERIC=y # # Special HID drivers # # CONFIG_HID_A4TECH is not set # CONFIG_HID_ACRUX is not set # CONFIG_HID_APPLE is not set # CONFIG_HID_APPLEIR is not set # CONFIG_HID_AUREAL is not set # CONFIG_HID_BELKIN is not set # CONFIG_HID_BETOP_FF is not set # CONFIG_HID_CHERRY is not set # CONFIG_HID_CHICONY is not set # CONFIG_HID_CORSAIR is not set # CONFIG_HID_PRODIKEYS is not set # CONFIG_HID_CMEDIA is not set # CONFIG_HID_CP2112 is not set # CONFIG_HID_CYPRESS is not set # CONFIG_HID_DRAGONRISE is not set # CONFIG_HID_EMS_FF is not set # CONFIG_HID_ELECOM is not set # CONFIG_HID_ELO is not set # CONFIG_HID_EZKEY is not set # CONFIG_HID_GEMBIRD is not set # CONFIG_HID_GFRM is not set # CONFIG_HID_HOLTEK is not set # CONFIG_HID_GT683R is not set # CONFIG_HID_KEYTOUCH is not set # CONFIG_HID_KYE is not set # CONFIG_HID_UCLOGIC is not set # CONFIG_HID_WALTOP is not set # CONFIG_HID_GYRATION is not set # CONFIG_HID_ICADE is not set # CONFIG_HID_TWINHAN is not set # CONFIG_HID_KENSINGTON is not set # CONFIG_HID_LCPOWER is not set # CONFIG_HID_LED is not set # CONFIG_HID_LENOVO is not set # CONFIG_HID_LOGITECH is not set # CONFIG_HID_MAGICMOUSE is not set # CONFIG_HID_MICROSOFT is not set # CONFIG_HID_MONTEREY is not set CONFIG_HID_MULTITOUCH=m # CONFIG_HID_NTRIG is not set # CONFIG_HID_ORTEK is not set # CONFIG_HID_PANTHERLORD is not set # CONFIG_HID_PENMOUNT is not set # CONFIG_HID_PETALYNX is not set # CONFIG_HID_PICOLCD is not set # CONFIG_HID_PLANTRONICS is not set # CONFIG_HID_PRIMAX is not set # CONFIG_HID_ROCCAT is not set # CONFIG_HID_SAITEK is not set # CONFIG_HID_SAMSUNG is not set # CONFIG_HID_SONY is not set # CONFIG_HID_SPEEDLINK is not set # CONFIG_HID_STEELSERIES is not set # CONFIG_HID_SUNPLUS is not set # CONFIG_HID_RMI is not set # CONFIG_HID_GREENASIA is not set # CONFIG_HID_SMARTJOYPLUS is not set # CONFIG_HID_TIVO is not set # CONFIG_HID_TOPSEED is not set # CONFIG_HID_THINGM is not set # CONFIG_HID_THRUSTMASTER is not set # CONFIG_HID_WACOM is not set # CONFIG_HID_WIIMOTE is not set # CONFIG_HID_XINMO is not set # CONFIG_HID_ZEROPLUS is not set # CONFIG_HID_ZYDACRON is not set # CONFIG_HID_SENSOR_HUB is not set # CONFIG_HID_ALPS is not set # # USB HID support # CONFIG_USB_HID=m # CONFIG_HID_PID is not set # CONFIG_USB_HIDDEV is not set # # USB HID Boot Protocol drivers # # CONFIG_USB_KBD is not set # CONFIG_USB_MOUSE is not set # # I2C HID support # # CONFIG_I2C_HID is not set CONFIG_USB_OHCI_LITTLE_ENDIAN=y CONFIG_USB_SUPPORT=y CONFIG_USB_COMMON=y CONFIG_USB_ARCH_HAS_HCD=y CONFIG_USB=m # CONFIG_USB_ANNOUNCE_NEW_DEVICES is not set # # Miscellaneous USB options # CONFIG_USB_DEFAULT_PERSIST=y # CONFIG_USB_DYNAMIC_MINORS is not set # CONFIG_USB_OTG is not set # CONFIG_USB_OTG_WHITELIST is not set # CONFIG_USB_OTG_BLACKLIST_HUB is not set # CONFIG_USB_LEDS_TRIGGER_USBPORT is not set # CONFIG_USB_MON is not set # CONFIG_USB_WUSB_CBAF is not set # # USB Host Controller Drivers # # CONFIG_USB_C67X00_HCD is not set CONFIG_USB_XHCI_HCD=m CONFIG_USB_XHCI_PCI=m CONFIG_USB_XHCI_PLATFORM=m CONFIG_USB_EHCI_HCD=m # CONFIG_USB_EHCI_ROOT_HUB_TT is not set CONFIG_USB_EHCI_TT_NEWSCHED=y CONFIG_USB_EHCI_PCI=m CONFIG_USB_EHCI_HCD_OMAP=m CONFIG_USB_EHCI_HCD_PLATFORM=m # CONFIG_USB_OXU210HP_HCD is not set # CONFIG_USB_ISP116X_HCD is not set # CONFIG_USB_ISP1362_HCD is not set # CONFIG_USB_FOTG210_HCD is not set # CONFIG_USB_MAX3421_HCD is not set CONFIG_USB_OHCI_HCD=m CONFIG_USB_OHCI_HCD_PCI=m CONFIG_USB_OHCI_HCD_PLATFORM=m # CONFIG_USB_UHCI_HCD is not set # CONFIG_USB_SL811_HCD is not set CONFIG_USB_R8A66597_HCD=m # CONFIG_USB_HCD_TEST_MODE is not set # # USB Device Class drivers # CONFIG_USB_ACM=m # CONFIG_USB_PRINTER is not set # CONFIG_USB_WDM is not set # CONFIG_USB_TMC is not set # # NOTE: USB_STORAGE depends on SCSI but BLK_DEV_SD may # # # also be needed; see USB_STORAGE Help for more info # CONFIG_USB_STORAGE=m # CONFIG_USB_STORAGE_DEBUG is not set # CONFIG_USB_STORAGE_REALTEK is not set # CONFIG_USB_STORAGE_DATAFAB is not set # CONFIG_USB_STORAGE_FREECOM is not set # CONFIG_USB_STORAGE_ISD200 is not set # CONFIG_USB_STORAGE_USBAT is not set # CONFIG_USB_STORAGE_SDDR09 is not set # CONFIG_USB_STORAGE_SDDR55 is not set # CONFIG_USB_STORAGE_JUMPSHOT is not set # CONFIG_USB_STORAGE_ALAUDA is not set # CONFIG_USB_STORAGE_ONETOUCH is not set # CONFIG_USB_STORAGE_KARMA is not set # CONFIG_USB_STORAGE_CYPRESS_ATACB is not set # CONFIG_USB_STORAGE_ENE_UB6250 is not set # CONFIG_USB_UAS is not set # # USB Imaging devices # # CONFIG_USB_MDC800 is not set # CONFIG_USB_MICROTEK is not set # CONFIG_USBIP_CORE is not set CONFIG_USB_MUSB_HDRC=m # CONFIG_USB_MUSB_HOST is not set # CONFIG_USB_MUSB_GADGET is not set CONFIG_USB_MUSB_DUAL_ROLE=y # # Platform Glue Layer # # CONFIG_USB_MUSB_TUSB6010 is not set CONFIG_USB_MUSB_OMAP2PLUS=m CONFIG_USB_MUSB_AM35X=m CONFIG_USB_MUSB_DSPS=m CONFIG_USB_MUSB_AM335X_CHILD=m # # MUSB DMA mode # # CONFIG_MUSB_PIO_ONLY is not set # CONFIG_USB_INVENTRA_DMA is not set CONFIG_USB_TI_CPPI41_DMA=y CONFIG_USB_DWC3=m # CONFIG_USB_DWC3_HOST is not set # CONFIG_USB_DWC3_GADGET is not set CONFIG_USB_DWC3_DUAL_ROLE=y # # Platform Glue Driver Support # CONFIG_USB_DWC3_OMAP=m # CONFIG_USB_DWC3_PCI is not set CONFIG_USB_DWC3_OF_SIMPLE=m # CONFIG_USB_DWC2 is not set # CONFIG_USB_CHIPIDEA is not set CONFIG_USB_ISP1760=m CONFIG_USB_ISP1760_HCD=y CONFIG_USB_ISP1761_UDC=y # CONFIG_USB_ISP1760_HOST_ROLE is not set # CONFIG_USB_ISP1760_GADGET_ROLE is not set CONFIG_USB_ISP1760_DUAL_ROLE=y # # USB port drivers # CONFIG_USB_SERIAL=m # CONFIG_USB_SERIAL_GENERIC is not set # CONFIG_USB_SERIAL_SIMPLE is not set # CONFIG_USB_SERIAL_AIRCABLE is not set # CONFIG_USB_SERIAL_ARK3116 is not set # CONFIG_USB_SERIAL_BELKIN is not set # CONFIG_USB_SERIAL_CH341 is not set # CONFIG_USB_SERIAL_WHITEHEAT is not set # CONFIG_USB_SERIAL_DIGI_ACCELEPORT is not set # CONFIG_USB_SERIAL_CP210X is not set # CONFIG_USB_SERIAL_CYPRESS_M8 is not set # CONFIG_USB_SERIAL_EMPEG is not set # CONFIG_USB_SERIAL_FTDI_SIO is not set # CONFIG_USB_SERIAL_VISOR is not set # CONFIG_USB_SERIAL_IPAQ is not set # CONFIG_USB_SERIAL_IR is not set # CONFIG_USB_SERIAL_EDGEPORT is not set # CONFIG_USB_SERIAL_EDGEPORT_TI is not set # CONFIG_USB_SERIAL_F81232 is not set # CONFIG_USB_SERIAL_GARMIN is not set # CONFIG_USB_SERIAL_IPW is not set # CONFIG_USB_SERIAL_IUU is not set # CONFIG_USB_SERIAL_KEYSPAN_PDA is not set # CONFIG_USB_SERIAL_KEYSPAN is not set # CONFIG_USB_SERIAL_KLSI is not set # CONFIG_USB_SERIAL_KOBIL_SCT is not set # CONFIG_USB_SERIAL_MCT_U232 is not set # CONFIG_USB_SERIAL_METRO is not set # CONFIG_USB_SERIAL_MOS7720 is not set # CONFIG_USB_SERIAL_MOS7840 is not set # CONFIG_USB_SERIAL_MXUPORT is not set # CONFIG_USB_SERIAL_NAVMAN is not set # CONFIG_USB_SERIAL_PL2303 is not set # CONFIG_USB_SERIAL_OTI6858 is not set # CONFIG_USB_SERIAL_QCAUX is not set # CONFIG_USB_SERIAL_QUALCOMM is not set # CONFIG_USB_SERIAL_SPCP8X5 is not set # CONFIG_USB_SERIAL_SAFE is not set # CONFIG_USB_SERIAL_SIERRAWIRELESS is not set # CONFIG_USB_SERIAL_SYMBOL is not set # CONFIG_USB_SERIAL_TI is not set # CONFIG_USB_SERIAL_CYBERJACK is not set # CONFIG_USB_SERIAL_XIRCOM is not set # CONFIG_USB_SERIAL_OPTION is not set # CONFIG_USB_SERIAL_OMNINET is not set # CONFIG_USB_SERIAL_OPTICON is not set # CONFIG_USB_SERIAL_XSENS_MT is not set # CONFIG_USB_SERIAL_WISHBONE is not set # CONFIG_USB_SERIAL_SSU100 is not set # CONFIG_USB_SERIAL_QT2 is not set # CONFIG_USB_SERIAL_DEBUG is not set # # USB Miscellaneous drivers # # CONFIG_USB_EMI62 is not set # CONFIG_USB_EMI26 is not set # CONFIG_USB_ADUTUX is not set # CONFIG_USB_SEVSEG is not set # CONFIG_USB_RIO500 is not set # CONFIG_USB_LEGOTOWER is not set # CONFIG_USB_LCD is not set # CONFIG_USB_CYPRESS_CY7C63 is not set # CONFIG_USB_CYTHERM is not set # CONFIG_USB_IDMOUSE is not set # CONFIG_USB_FTDI_ELAN is not set # CONFIG_USB_APPLEDISPLAY is not set # CONFIG_USB_SISUSBVGA is not set # CONFIG_USB_LD is not set # CONFIG_USB_TRANCEVIBRATOR is not set # CONFIG_USB_IOWARRIOR is not set CONFIG_USB_TEST=m # CONFIG_USB_EHSET_TEST_FIXTURE is not set # CONFIG_USB_ISIGHTFW is not set # CONFIG_USB_YUREX is not set # CONFIG_USB_EZUSB_FX2 is not set # CONFIG_USB_HSIC_USB3503 is not set # CONFIG_USB_HSIC_USB4604 is not set # CONFIG_USB_LINK_LAYER_TEST is not set # CONFIG_USB_CHAOSKEY is not set # # USB Physical Layer drivers # CONFIG_USB_PHY=y CONFIG_NOP_USB_XCEIV=m CONFIG_AM335X_CONTROL_USB=m CONFIG_AM335X_PHY_USB=m CONFIG_USB_GPIO_VBUS=m CONFIG_USB_ISP1301=m # CONFIG_USB_ULPI is not set CONFIG_USB_GADGET=y # CONFIG_USB_GADGET_DEBUG is not set # CONFIG_USB_GADGET_DEBUG_FILES is not set # CONFIG_USB_GADGET_DEBUG_FS is not set CONFIG_USB_GADGET_VBUS_DRAW=2 CONFIG_USB_GADGET_STORAGE_NUM_BUFFERS=32 # # USB Peripheral Controller # # CONFIG_USB_FUSB300 is not set # CONFIG_USB_FOTG210_UDC is not set # CONFIG_USB_GR_UDC is not set # CONFIG_USB_R8A66597 is not set # CONFIG_USB_PXA27X is not set # CONFIG_USB_MV_UDC is not set # CONFIG_USB_MV_U3D is not set # CONFIG_USB_M66592 is not set # CONFIG_USB_BDC_UDC is not set # CONFIG_USB_AMD5536UDC is not set # CONFIG_USB_NET2272 is not set # CONFIG_USB_NET2280 is not set # CONFIG_USB_GOKU is not set # CONFIG_USB_EG20T is not set # CONFIG_USB_GADGET_XILINX is not set CONFIG_USB_LIBCOMPOSITE=y CONFIG_USB_F_ACM=y CONFIG_USB_F_SS_LB=m CONFIG_USB_U_SERIAL=y CONFIG_USB_U_ETHER=y CONFIG_USB_F_SERIAL=m CONFIG_USB_F_OBEX=m CONFIG_USB_F_NCM=m CONFIG_USB_F_ECM=y CONFIG_USB_F_EEM=m CONFIG_USB_F_SUBSET=m CONFIG_USB_F_RNDIS=m CONFIG_USB_F_MASS_STORAGE=m CONFIG_USB_F_FS=m CONFIG_USB_F_UAC1=m CONFIG_USB_F_UAC2=m CONFIG_USB_F_UVC=m CONFIG_USB_F_MIDI=m CONFIG_USB_F_HID=m CONFIG_USB_F_PRINTER=m CONFIG_USB_CONFIGFS=m CONFIG_USB_CONFIGFS_SERIAL=y CONFIG_USB_CONFIGFS_ACM=y CONFIG_USB_CONFIGFS_OBEX=y CONFIG_USB_CONFIGFS_NCM=y CONFIG_USB_CONFIGFS_ECM=y CONFIG_USB_CONFIGFS_ECM_SUBSET=y CONFIG_USB_CONFIGFS_RNDIS=y CONFIG_USB_CONFIGFS_EEM=y CONFIG_USB_CONFIGFS_MASS_STORAGE=y CONFIG_USB_CONFIGFS_F_LB_SS=y CONFIG_USB_CONFIGFS_F_FS=y CONFIG_USB_CONFIGFS_F_UAC1=y CONFIG_USB_CONFIGFS_F_UAC2=y CONFIG_USB_CONFIGFS_F_MIDI=y CONFIG_USB_CONFIGFS_F_HID=y CONFIG_USB_CONFIGFS_F_UVC=y CONFIG_USB_CONFIGFS_F_PRINTER=y # CONFIG_USB_ZERO is not set # CONFIG_USB_AUDIO is not set # CONFIG_USB_ETH is not set # CONFIG_USB_G_NCM is not set # CONFIG_USB_GADGETFS is not set # CONFIG_USB_FUNCTIONFS is not set # CONFIG_USB_MASS_STORAGE is not set # CONFIG_USB_G_SERIAL is not set # CONFIG_USB_MIDI_GADGET is not set # CONFIG_USB_G_PRINTER is not set CONFIG_USB_CDC_COMPOSITE=y # CONFIG_USB_G_ACM_MS is not set # CONFIG_USB_G_MULTI is not set # CONFIG_USB_G_HID is not set # CONFIG_USB_G_DBGP is not set # CONFIG_USB_G_WEBCAM is not set # CONFIG_USB_LED_TRIG is not set # CONFIG_USB_ULPI_BUS is not set # CONFIG_UWB is not set CONFIG_MMC=y # CONFIG_MMC_DEBUG is not set CONFIG_PWRSEQ_EMMC=y CONFIG_PWRSEQ_SIMPLE=y # # MMC/SD/SDIO Card Drivers # CONFIG_MMC_BLOCK=y CONFIG_MMC_BLOCK_MINORS=16 CONFIG_MMC_BLOCK_BOUNCE=y # CONFIG_SDIO_UART is not set # CONFIG_MMC_TEST is not set # # MMC/SD/SDIO Host Controller Drivers # # CONFIG_MMC_SDHCI is not set CONFIG_MMC_OMAP=y CONFIG_MMC_OMAP_HS=y # CONFIG_MMC_TIFM_SD is not set # CONFIG_MMC_CB710 is not set # CONFIG_MMC_VIA_SDMMC is not set # CONFIG_MMC_DW is not set # CONFIG_MMC_VUB300 is not set # CONFIG_MMC_USHC is not set # CONFIG_MMC_USDHI6ROL0 is not set # CONFIG_MMC_TOSHIBA_PCI is not set # CONFIG_MMC_MTK is not set # CONFIG_MEMSTICK is not set CONFIG_NEW_LEDS=y CONFIG_LEDS_CLASS=y CONFIG_LEDS_CLASS_FLASH=m # # LED drivers # # CONFIG_LEDS_AAT1290 is not set # CONFIG_LEDS_BCM6328 is not set # CONFIG_LEDS_BCM6358 is not set # CONFIG_LEDS_LM3530 is not set # CONFIG_LEDS_LM3642 is not set # CONFIG_LEDS_PCA9532 is not set CONFIG_LEDS_GPIO=y # CONFIG_LEDS_LP3944 is not set # CONFIG_LEDS_LP5521 is not set # CONFIG_LEDS_LP5523 is not set # CONFIG_LEDS_LP5562 is not set # CONFIG_LEDS_LP8501 is not set # CONFIG_LEDS_LP8860 is not set # CONFIG_LEDS_PCA955X is not set # CONFIG_LEDS_PCA963X is not set # CONFIG_LEDS_DAC124S085 is not set CONFIG_LEDS_PWM=y # CONFIG_LEDS_REGULATOR is not set # CONFIG_LEDS_BD2802 is not set # CONFIG_LEDS_LT3593 is not set # CONFIG_LEDS_TCA6507 is not set CONFIG_LEDS_TLC591XX=y # CONFIG_LEDS_LM355x is not set # CONFIG_LEDS_KTD2692 is not set # CONFIG_LEDS_IS31FL319X is not set # CONFIG_LEDS_IS31FL32XX is not set # # LED driver for blink(1) USB RGB LED is under Special HID drivers (HID_THINGM) # # CONFIG_LEDS_BLINKM is not set # CONFIG_LEDS_SYSCON is not set # # LED Triggers # CONFIG_LEDS_TRIGGERS=y CONFIG_LEDS_TRIGGER_TIMER=y CONFIG_LEDS_TRIGGER_ONESHOT=y # CONFIG_LEDS_TRIGGER_DISK is not set # CONFIG_LEDS_TRIGGER_MTD is not set CONFIG_LEDS_TRIGGER_HEARTBEAT=y CONFIG_LEDS_TRIGGER_BACKLIGHT=y CONFIG_LEDS_TRIGGER_CPU=y CONFIG_LEDS_TRIGGER_GPIO=y CONFIG_LEDS_TRIGGER_DEFAULT_ON=y # # iptables trigger is under Netfilter config (LED target) # CONFIG_LEDS_TRIGGER_TRANSIENT=y CONFIG_LEDS_TRIGGER_CAMERA=y # CONFIG_LEDS_TRIGGER_PANIC is not set # CONFIG_ACCESSIBILITY is not set # CONFIG_INFINIBAND is not set CONFIG_EDAC_ATOMIC_SCRUB=y CONFIG_EDAC_SUPPORT=y CONFIG_EDAC=y CONFIG_EDAC_LEGACY_SYSFS=y # CONFIG_EDAC_DEBUG is not set CONFIG_EDAC_MM_EDAC=y CONFIG_RTC_LIB=y CONFIG_RTC_CLASS=y CONFIG_RTC_HCTOSYS=y CONFIG_RTC_HCTOSYS_DEVICE="rtc0" CONFIG_RTC_SYSTOHC=y CONFIG_RTC_SYSTOHC_DEVICE="rtc0" CONFIG_RTC_DEBUG=y # # RTC interfaces # CONFIG_RTC_INTF_SYSFS=y CONFIG_RTC_INTF_PROC=y CONFIG_RTC_INTF_DEV=y # CONFIG_RTC_INTF_DEV_UIE_EMUL is not set # CONFIG_RTC_DRV_TEST is not set # # I2C RTC drivers # # CONFIG_RTC_DRV_ABB5ZES3 is not set # CONFIG_RTC_DRV_ABX80X is not set CONFIG_RTC_DRV_DS1307=m CONFIG_RTC_DRV_DS1307_HWMON=y # CONFIG_RTC_DRV_DS1307_CENTURY is not set # CONFIG_RTC_DRV_DS1374 is not set # CONFIG_RTC_DRV_DS1672 is not set # CONFIG_RTC_DRV_HYM8563 is not set # CONFIG_RTC_DRV_MAX6900 is not set # CONFIG_RTC_DRV_RS5C372 is not set # CONFIG_RTC_DRV_ISL1208 is not set # CONFIG_RTC_DRV_ISL12022 is not set # CONFIG_RTC_DRV_X1205 is not set # CONFIG_RTC_DRV_PCF8523 is not set # CONFIG_RTC_DRV_PCF85063 is not set # CONFIG_RTC_DRV_PCF8563 is not set # CONFIG_RTC_DRV_PCF8583 is not set # CONFIG_RTC_DRV_M41T80 is not set # CONFIG_RTC_DRV_BQ32K is not set CONFIG_RTC_DRV_PALMAS=m CONFIG_RTC_DRV_TPS6586X=m CONFIG_RTC_DRV_TPS65910=m # CONFIG_RTC_DRV_S35390A is not set # CONFIG_RTC_DRV_FM3130 is not set # CONFIG_RTC_DRV_RX8010 is not set # CONFIG_RTC_DRV_RX8581 is not set # CONFIG_RTC_DRV_RX8025 is not set # CONFIG_RTC_DRV_EM3027 is not set # CONFIG_RTC_DRV_RV8803 is not set # # SPI RTC drivers # # CONFIG_RTC_DRV_M41T93 is not set # CONFIG_RTC_DRV_M41T94 is not set # CONFIG_RTC_DRV_DS1302 is not set # CONFIG_RTC_DRV_DS1305 is not set # CONFIG_RTC_DRV_DS1343 is not set # CONFIG_RTC_DRV_DS1347 is not set # CONFIG_RTC_DRV_DS1390 is not set # CONFIG_RTC_DRV_MAX6916 is not set # CONFIG_RTC_DRV_R9701 is not set # CONFIG_RTC_DRV_RX4581 is not set # CONFIG_RTC_DRV_RX6110 is not set # CONFIG_RTC_DRV_RS5C348 is not set # CONFIG_RTC_DRV_MAX6902 is not set # CONFIG_RTC_DRV_PCF2123 is not set # CONFIG_RTC_DRV_MCP795 is not set CONFIG_RTC_I2C_AND_SPI=y # # SPI and I2C RTC drivers # # CONFIG_RTC_DRV_DS3232 is not set # CONFIG_RTC_DRV_PCF2127 is not set # CONFIG_RTC_DRV_RV3029C2 is not set # # Platform RTC drivers # # CONFIG_RTC_DRV_CMOS is not set # CONFIG_RTC_DRV_DS1286 is not set # CONFIG_RTC_DRV_DS1511 is not set # CONFIG_RTC_DRV_DS1553 is not set # CONFIG_RTC_DRV_DS1685_FAMILY is not set # CONFIG_RTC_DRV_DS1742 is not set # CONFIG_RTC_DRV_DS2404 is not set CONFIG_RTC_DRV_EFI=m # CONFIG_RTC_DRV_STK17TA8 is not set # CONFIG_RTC_DRV_M48T86 is not set # CONFIG_RTC_DRV_M48T35 is not set # CONFIG_RTC_DRV_M48T59 is not set # CONFIG_RTC_DRV_MSM6242 is not set # CONFIG_RTC_DRV_BQ4802 is not set # CONFIG_RTC_DRV_RP5C01 is not set # CONFIG_RTC_DRV_V3020 is not set # CONFIG_RTC_DRV_ZYNQMP is not set # # on-CPU RTC drivers # CONFIG_RTC_DRV_OMAP=m # CONFIG_RTC_DRV_SNVS is not set # # HID Sensor RTC drivers # # CONFIG_RTC_DRV_HID_SENSOR_TIME is not set CONFIG_DMADEVICES=y # CONFIG_DMADEVICES_DEBUG is not set # # DMA Devices # CONFIG_DMA_ENGINE=y CONFIG_DMA_VIRTUAL_CHANNELS=y CONFIG_DMA_OF=y CONFIG_DMA_OMAP=y CONFIG_FSL_EDMA=y # CONFIG_INTEL_IDMA64 is not set # CONFIG_NBPFAXI_DMA is not set CONFIG_TI_CPPI41=y CONFIG_TI_DMA_CROSSBAR=y CONFIG_TI_EDMA=y # CONFIG_QCOM_HIDMA_MGMT is not set # CONFIG_QCOM_HIDMA is not set CONFIG_DW_DMAC_CORE=y CONFIG_DW_DMAC=y # CONFIG_DW_DMAC_PCI is not set # # DMA Clients # # CONFIG_ASYNC_TX_DMA is not set # CONFIG_DMATEST is not set # # DMABUF options # # CONFIG_SYNC_FILE is not set # CONFIG_AUXDISPLAY is not set CONFIG_UIO=m # CONFIG_UIO_CIF is not set # CONFIG_UIO_PDRV_GENIRQ is not set # CONFIG_UIO_DMEM_GENIRQ is not set # CONFIG_UIO_AEC is not set # CONFIG_UIO_SERCOS3 is not set # CONFIG_UIO_PCI_GENERIC is not set # CONFIG_UIO_NETX is not set # CONFIG_UIO_PRUSS is not set # CONFIG_UIO_MF624 is not set # CONFIG_VFIO is not set # CONFIG_VIRT_DRIVERS is not set CONFIG_VIRTIO=y # # Virtio drivers # CONFIG_VIRTIO_PCI=y CONFIG_VIRTIO_PCI_LEGACY=y # CONFIG_VIRTIO_BALLOON is not set # CONFIG_VIRTIO_INPUT is not set CONFIG_VIRTIO_MMIO=y # CONFIG_VIRTIO_MMIO_CMDLINE_DEVICES is not set # # Microsoft Hyper-V guest support # # CONFIG_STAGING is not set # CONFIG_GOLDFISH is not set # CONFIG_CHROME_PLATFORMS is not set CONFIG_CLKDEV_LOOKUP=y CONFIG_HAVE_CLK_PREPARE=y CONFIG_COMMON_CLK=y # # Common Clock Framework # # CONFIG_COMMON_CLK_SI5351 is not set # CONFIG_COMMON_CLK_SI514 is not set # CONFIG_COMMON_CLK_SI570 is not set # CONFIG_COMMON_CLK_CDCE706 is not set # CONFIG_COMMON_CLK_CDCE925 is not set # CONFIG_COMMON_CLK_CS2000_CP is not set # CONFIG_CLK_TWL6040 is not set # CONFIG_CLK_QORIQ is not set # CONFIG_COMMON_CLK_NXP is not set CONFIG_COMMON_CLK_PALMAS=y # CONFIG_COMMON_CLK_PWM is not set # CONFIG_COMMON_CLK_PXA is not set # CONFIG_COMMON_CLK_PIC32 is not set # CONFIG_COMMON_CLK_TI_ADPLL is not set CONFIG_HWSPINLOCK=y # # Hardware Spinlock drivers # CONFIG_HWSPINLOCK_OMAP=y # # Clock Source drivers # CONFIG_CLKSRC_OF=y CONFIG_CLKSRC_PROBE=y CONFIG_CLKSRC_MMIO=y CONFIG_CLKSRC_TI_32K=y # CONFIG_ARM_GLOBAL_TIMER is not set # CONFIG_ARM_TIMER_SP804 is not set # CONFIG_ATMEL_PIT is not set # CONFIG_SH_TIMER_CMT is not set # CONFIG_SH_TIMER_MTU2 is not set # CONFIG_SH_TIMER_TMU is not set # CONFIG_EM_TIMER_STI is not set CONFIG_MAILBOX=y # CONFIG_PLATFORM_MHU is not set CONFIG_OMAP2PLUS_MBOX=y CONFIG_OMAP_MBOX_KFIFO_SIZE=256 # CONFIG_ALTERA_MBOX is not set # CONFIG_MAILBOX_TEST is not set CONFIG_IOMMU_API=y CONFIG_IOMMU_SUPPORT=y # # Generic IOMMU Pagetable Support # # CONFIG_IOMMU_IO_PGTABLE_LPAE is not set # CONFIG_IOMMU_IO_PGTABLE_ARMV7S is not set CONFIG_OF_IOMMU=y CONFIG_OMAP_IOMMU=y CONFIG_OMAP_IOMMU_DEBUG=y # CONFIG_ARM_SMMU is not set # # Remoteproc drivers # CONFIG_REMOTEPROC=m # CONFIG_WKUP_M3_RPROC is not set CONFIG_PRUSS_REMOTEPROC=m CONFIG_PRU0_SPI=m # # Rpmsg drivers # CONFIG_RPMSG=m CONFIG_RPMSG_VIRTIO=m CONFIG_RPMSG_PRU=m # # SOC (System On Chip) specific Drivers # # # Broadcom SoC drivers # # CONFIG_SOC_BRCMSTB is not set # CONFIG_SUNXI_SRAM is not set CONFIG_SOC_TI=y # CONFIG_PM_DEVFREQ is not set CONFIG_EXTCON=m # # Extcon Device Drivers # # CONFIG_EXTCON_ADC_JACK is not set # CONFIG_EXTCON_AXP288 is not set # CONFIG_EXTCON_GPIO is not set # CONFIG_EXTCON_MAX3355 is not set CONFIG_EXTCON_PALMAS=m # CONFIG_EXTCON_QCOM_SPMI_MISC is not set # CONFIG_EXTCON_RT8973A is not set # CONFIG_EXTCON_SM5502 is not set CONFIG_EXTCON_USB_GPIO=m CONFIG_MEMORY=y # CONFIG_TI_EMIF is not set CONFIG_OMAP_GPMC=y # CONFIG_OMAP_GPMC_DEBUG is not set CONFIG_TI_EMIF_SRAM=m CONFIG_IIO=y CONFIG_IIO_BUFFER=y # CONFIG_IIO_BUFFER_CB is not set CONFIG_IIO_KFIFO_BUF=y CONFIG_IIO_TRIGGERED_BUFFER=y # CONFIG_IIO_CONFIGFS is not set CONFIG_IIO_TRIGGER=y CONFIG_IIO_CONSUMERS_PER_TRIGGER=2 # CONFIG_IIO_SW_DEVICE is not set # CONFIG_IIO_SW_TRIGGER is not set # # Accelerometers # # CONFIG_BMA180 is not set # CONFIG_BMA220 is not set # CONFIG_BMC150_ACCEL is not set # CONFIG_DMARD06 is not set # CONFIG_DMARD09 is not set # CONFIG_IIO_ST_ACCEL_3AXIS is not set # CONFIG_KXSD9 is not set # CONFIG_KXCJK1013 is not set # CONFIG_MC3230 is not set # CONFIG_MMA7455_I2C is not set # CONFIG_MMA7455_SPI is not set # CONFIG_MMA7660 is not set # CONFIG_MMA8452 is not set # CONFIG_MMA9551 is not set # CONFIG_MMA9553 is not set # CONFIG_MXC4005 is not set # CONFIG_MXC6255 is not set # CONFIG_STK8312 is not set # CONFIG_STK8BA50 is not set # # Analog to digital converters # # CONFIG_AD7266 is not set # CONFIG_AD7291 is not set # CONFIG_AD7298 is not set # CONFIG_AD7476 is not set # CONFIG_AD7791 is not set # CONFIG_AD7793 is not set # CONFIG_AD7887 is not set # CONFIG_AD7923 is not set # CONFIG_AD799X is not set # CONFIG_AXP288_ADC is not set # CONFIG_CC10001_ADC is not set # CONFIG_HI8435 is not set # CONFIG_INA2XX_ADC is not set # CONFIG_LTC2485 is not set # CONFIG_MAX1027 is not set # CONFIG_MAX1363 is not set # CONFIG_MCP320X is not set # CONFIG_MCP3422 is not set # CONFIG_NAU7802 is not set # CONFIG_PALMAS_GPADC is not set # CONFIG_QCOM_SPMI_IADC is not set # CONFIG_QCOM_SPMI_VADC is not set # CONFIG_TI_ADC081C is not set # CONFIG_TI_ADC0832 is not set # CONFIG_TI_ADC12138 is not set # CONFIG_TI_ADC128S052 is not set # CONFIG_TI_ADC161S626 is not set # CONFIG_TI_ADS1015 is not set # CONFIG_TI_ADS8688 is not set CONFIG_TI_AM335X_ADC=m CONFIG_VF610_ADC=m # # Amplifiers # # CONFIG_AD8366 is not set # # Chemical Sensors # # CONFIG_ATLAS_PH_SENSOR is not set # CONFIG_IAQCORE is not set # CONFIG_VZ89X is not set # # Hid Sensor IIO Common # # # SSP Sensor Common # # CONFIG_IIO_SSP_SENSORHUB is not set # # Digital to analog converters # # CONFIG_AD5064 is not set # CONFIG_AD5360 is not set # CONFIG_AD5380 is not set # CONFIG_AD5421 is not set # CONFIG_AD5446 is not set # CONFIG_AD5449 is not set # CONFIG_AD5592R is not set # CONFIG_AD5593R is not set # CONFIG_AD5504 is not set # CONFIG_AD5624R_SPI is not set # CONFIG_AD5686 is not set # CONFIG_AD5755 is not set # CONFIG_AD5761 is not set # CONFIG_AD5764 is not set # CONFIG_AD5791 is not set # CONFIG_AD7303 is not set # CONFIG_AD8801 is not set # CONFIG_M62332 is not set # CONFIG_MAX517 is not set # CONFIG_MAX5821 is not set # CONFIG_MCP4725 is not set # CONFIG_MCP4922 is not set # CONFIG_VF610_DAC is not set # # IIO dummy driver # # # Frequency Synthesizers DDS/PLL # # # Clock Generator/Distribution # # CONFIG_AD9523 is not set # # Phase-Locked Loop (PLL) frequency synthesizers # # CONFIG_ADF4350 is not set # # Digital gyroscope sensors # # CONFIG_ADIS16080 is not set # CONFIG_ADIS16130 is not set # CONFIG_ADIS16136 is not set # CONFIG_ADIS16260 is not set # CONFIG_ADXRS450 is not set # CONFIG_BMG160 is not set # CONFIG_IIO_ST_GYRO_3AXIS is not set # CONFIG_ITG3200 is not set # # Health Sensors # # # Heart Rate Monitors # # CONFIG_AFE4403 is not set # CONFIG_AFE4404 is not set # CONFIG_MAX30100 is not set # # Humidity sensors # # CONFIG_AM2315 is not set # CONFIG_DHT11 is not set # CONFIG_HDC100X is not set # CONFIG_HTU21 is not set # CONFIG_SI7005 is not set # CONFIG_SI7020 is not set # # Inertial measurement units # # CONFIG_ADIS16400 is not set # CONFIG_ADIS16480 is not set # CONFIG_BMI160_I2C is not set # CONFIG_BMI160_SPI is not set # CONFIG_KMX61 is not set # CONFIG_INV_MPU6050_SPI is not set # # Light sensors # # CONFIG_ADJD_S311 is not set # CONFIG_AL3320A is not set # CONFIG_APDS9300 is not set # CONFIG_APDS9960 is not set # CONFIG_BH1750 is not set # CONFIG_BH1780 is not set # CONFIG_CM32181 is not set # CONFIG_CM3232 is not set # CONFIG_CM3323 is not set CONFIG_CM36651=m # CONFIG_GP2AP020A00F is not set # CONFIG_ISL29125 is not set # CONFIG_JSA1212 is not set # CONFIG_RPR0521 is not set # CONFIG_LTR501 is not set # CONFIG_MAX44000 is not set # CONFIG_OPT3001 is not set # CONFIG_PA12203001 is not set # CONFIG_SI1145 is not set # CONFIG_STK3310 is not set # CONFIG_TCS3414 is not set # CONFIG_TCS3472 is not set # CONFIG_SENSORS_TSL2563 is not set # CONFIG_TSL4531 is not set # CONFIG_US5182D is not set # CONFIG_VCNL4000 is not set # CONFIG_VEML6070 is not set # # Magnetometer sensors # # CONFIG_AK8974 is not set CONFIG_AK8975=y # CONFIG_AK09911 is not set # CONFIG_BMC150_MAGN_I2C is not set # CONFIG_BMC150_MAGN_SPI is not set # CONFIG_MAG3110 is not set # CONFIG_MMC35240 is not set # CONFIG_IIO_ST_MAGN_3AXIS is not set # CONFIG_SENSORS_HMC5843_I2C is not set # CONFIG_SENSORS_HMC5843_SPI is not set # # Inclinometer sensors # # # Triggers - standalone # # CONFIG_IIO_INTERRUPT_TRIGGER is not set # CONFIG_IIO_SYSFS_TRIGGER is not set # # Digital potentiometers # # CONFIG_DS1803 is not set # CONFIG_MAX5487 is not set # CONFIG_MCP4131 is not set # CONFIG_MCP4531 is not set # CONFIG_TPL0102 is not set # # Pressure sensors # # CONFIG_BMP280 is not set # CONFIG_HP03 is not set # CONFIG_MPL115_I2C is not set # CONFIG_MPL115_SPI is not set # CONFIG_MPL3115 is not set # CONFIG_MS5611 is not set # CONFIG_MS5637 is not set # CONFIG_IIO_ST_PRESS is not set # CONFIG_T5403 is not set # CONFIG_HP206C is not set # CONFIG_ZPA2326 is not set # # Lightning sensors # # CONFIG_AS3935 is not set # # Proximity sensors # # CONFIG_LIDAR_LITE_V2 is not set # CONFIG_SX9500 is not set # # Temperature sensors # # CONFIG_MAXIM_THERMOCOUPLE is not set # CONFIG_MLX90614 is not set # CONFIG_TMP006 is not set # CONFIG_TSYS01 is not set # CONFIG_TSYS02D is not set # CONFIG_NTB is not set # CONFIG_VME_BUS is not set CONFIG_PWM=y CONFIG_PWM_SYSFS=y CONFIG_PWM_FSL_FTM=m # CONFIG_PWM_OMAP_DMTIMER is not set # CONFIG_PWM_PCA9685 is not set CONFIG_PWM_TIECAP=y CONFIG_PWM_TIEHRPWM=y CONFIG_PWM_TIPWMSS=y CONFIG_IRQCHIP=y CONFIG_ARM_GIC_MAX_NR=1 CONFIG_OMAP_IRQCHIP=y # CONFIG_IPACK_BUS is not set CONFIG_RESET_CONTROLLER=y # CONFIG_RESET_ATH79 is not set # CONFIG_RESET_BERLIN is not set # CONFIG_RESET_LPC18XX is not set # CONFIG_RESET_MESON is not set # CONFIG_RESET_PISTACHIO is not set # CONFIG_RESET_SOCFPGA is not set # CONFIG_RESET_STM32 is not set # CONFIG_RESET_SUNXI is not set CONFIG_RESET_TI_SYSCON=y # CONFIG_RESET_ZYNQ is not set # CONFIG_FMC is not set # # PHY Subsystem # CONFIG_GENERIC_PHY=y # CONFIG_PHY_DM816X_USB is not set # CONFIG_PHY_PXA_28NM_HSIC is not set # CONFIG_PHY_PXA_28NM_USB2 is not set CONFIG_OMAP_CONTROL_PHY=y CONFIG_OMAP_USB2=y CONFIG_TI_PIPE3=y # CONFIG_BCM_KONA_USB2_PHY is not set # CONFIG_POWERCAP is not set # CONFIG_MCB is not set # # Performance monitor support # CONFIG_ARM_PMU=y CONFIG_RAS=y # CONFIG_THUNDERBOLT is not set # # Android # # CONFIG_ANDROID is not set CONFIG_NVMEM=y # CONFIG_STM is not set # CONFIG_INTEL_TH is not set # # FPGA Configuration Support # # CONFIG_FPGA is not set # # Optimex drivers # # CONFIG_OPTX_ADC is not set # # Firmware Drivers # # CONFIG_ARM_SCPI_PROTOCOL is not set # CONFIG_FIRMWARE_MEMMAP is not set # CONFIG_FW_CFG_SYSFS is not set CONFIG_HAVE_ARM_SMCCC=y # # EFI (Extensible Firmware Interface) Support # CONFIG_EFI_VARS=m CONFIG_EFI_ESRT=y CONFIG_EFI_PARAMS_FROM_FDT=y CONFIG_EFI_RUNTIME_WRAPPERS=y CONFIG_EFI_ARMSTUB=y # CONFIG_EFI_BOOTLOADER_CONTROL is not set CONFIG_EFI_CAPSULE_LOADER=m # CONFIG_EFI_TEST is not set # # File systems # CONFIG_DCACHE_WORD_ACCESS=y # CONFIG_EXT2_FS is not set # CONFIG_EXT3_FS is not set CONFIG_EXT4_FS=y CONFIG_EXT4_USE_FOR_EXT2=y CONFIG_EXT4_FS_POSIX_ACL=y CONFIG_EXT4_FS_SECURITY=y # CONFIG_EXT4_ENCRYPTION is not set # CONFIG_EXT4_DEBUG is not set CONFIG_JBD2=y # CONFIG_JBD2_DEBUG is not set CONFIG_FS_MBCACHE=y # CONFIG_REISERFS_FS is not set # CONFIG_JFS_FS is not set # CONFIG_XFS_FS is not set # CONFIG_GFS2_FS is not set # CONFIG_OCFS2_FS is not set # CONFIG_BTRFS_FS is not set # CONFIG_NILFS2_FS is not set # CONFIG_F2FS_FS is not set CONFIG_FS_POSIX_ACL=y CONFIG_EXPORTFS=y # CONFIG_EXPORTFS_BLOCK_OPS is not set CONFIG_FILE_LOCKING=y CONFIG_MANDATORY_FILE_LOCKING=y # CONFIG_FS_ENCRYPTION is not set CONFIG_FSNOTIFY=y CONFIG_DNOTIFY=y CONFIG_INOTIFY_USER=y # CONFIG_FANOTIFY is not set # CONFIG_QUOTA is not set # CONFIG_QUOTACTL is not set CONFIG_AUTOFS4_FS=y # CONFIG_FUSE_FS is not set CONFIG_OVERLAY_FS=y # # Caches # CONFIG_FSCACHE=m # CONFIG_FSCACHE_STATS is not set # CONFIG_FSCACHE_HISTOGRAM is not set # CONFIG_FSCACHE_DEBUG is not set # CONFIG_FSCACHE_OBJECT_LIST is not set # CONFIG_CACHEFILES is not set # # CD-ROM/DVD Filesystems # # CONFIG_ISO9660_FS is not set # CONFIG_UDF_FS is not set # # DOS/FAT/NT Filesystems # CONFIG_FAT_FS=y CONFIG_MSDOS_FS=y CONFIG_VFAT_FS=y CONFIG_FAT_DEFAULT_CODEPAGE=437 CONFIG_FAT_DEFAULT_IOCHARSET="iso8859-1" # CONFIG_FAT_DEFAULT_UTF8 is not set CONFIG_NTFS_FS=y # CONFIG_NTFS_DEBUG is not set CONFIG_NTFS_RW=y # # Pseudo filesystems # CONFIG_PROC_FS=y CONFIG_PROC_SYSCTL=y CONFIG_PROC_PAGE_MONITOR=y CONFIG_PROC_CHILDREN=y CONFIG_KERNFS=y CONFIG_SYSFS=y CONFIG_TMPFS=y CONFIG_TMPFS_POSIX_ACL=y CONFIG_TMPFS_XATTR=y # CONFIG_HUGETLB_PAGE is not set CONFIG_CONFIGFS_FS=y CONFIG_EFIVAR_FS=m CONFIG_MISC_FILESYSTEMS=y # CONFIG_ORANGEFS_FS is not set # CONFIG_ADFS_FS is not set # CONFIG_AFFS_FS is not set # CONFIG_ECRYPT_FS is not set # CONFIG_HFS_FS is not set # CONFIG_HFSPLUS_FS is not set # CONFIG_BEFS_FS is not set # CONFIG_BFS_FS is not set # CONFIG_EFS_FS is not set # CONFIG_JFFS2_FS is not set CONFIG_UBIFS_FS=y # CONFIG_UBIFS_FS_ADVANCED_COMPR is not set CONFIG_UBIFS_FS_LZO=y CONFIG_UBIFS_FS_ZLIB=y # CONFIG_UBIFS_ATIME_SUPPORT is not set # CONFIG_LOGFS is not set # CONFIG_CRAMFS is not set CONFIG_SQUASHFS=y CONFIG_SQUASHFS_FILE_CACHE=y # CONFIG_SQUASHFS_FILE_DIRECT is not set CONFIG_SQUASHFS_DECOMP_SINGLE=y # CONFIG_SQUASHFS_DECOMP_MULTI is not set # CONFIG_SQUASHFS_DECOMP_MULTI_PERCPU is not set # CONFIG_SQUASHFS_XATTR is not set CONFIG_SQUASHFS_ZLIB=y # CONFIG_SQUASHFS_LZ4 is not set CONFIG_SQUASHFS_LZO=y CONFIG_SQUASHFS_XZ=y # CONFIG_SQUASHFS_4K_DEVBLK_SIZE is not set # CONFIG_SQUASHFS_EMBEDDED is not set CONFIG_SQUASHFS_FRAGMENT_CACHE_SIZE=3 # CONFIG_VXFS_FS is not set # CONFIG_MINIX_FS is not set # CONFIG_OMFS_FS is not set # CONFIG_HPFS_FS is not set # CONFIG_QNX4FS_FS is not set # CONFIG_QNX6FS_FS is not set # CONFIG_ROMFS_FS is not set # CONFIG_PSTORE is not set # CONFIG_SYSV_FS is not set # CONFIG_UFS_FS is not set # CONFIG_AUFS_FS is not set CONFIG_NETWORK_FILESYSTEMS=y CONFIG_NFS_FS=y CONFIG_NFS_V2=y CONFIG_NFS_V3=y CONFIG_NFS_V3_ACL=y CONFIG_NFS_V4=y # CONFIG_NFS_SWAP is not set # CONFIG_NFS_V4_1 is not set CONFIG_ROOT_NFS=y # CONFIG_NFS_USE_LEGACY_DNS is not set CONFIG_NFS_USE_KERNEL_DNS=y # CONFIG_NFSD is not set CONFIG_GRACE_PERIOD=y CONFIG_LOCKD=y CONFIG_LOCKD_V4=y CONFIG_NFS_ACL_SUPPORT=y CONFIG_NFS_COMMON=y CONFIG_SUNRPC=y CONFIG_SUNRPC_GSS=y # CONFIG_SUNRPC_DEBUG is not set # CONFIG_CEPH_FS is not set CONFIG_CIFS=m CONFIG_CIFS_STATS=y # CONFIG_CIFS_STATS2 is not set # CONFIG_CIFS_WEAK_PW_HASH is not set # CONFIG_CIFS_UPCALL is not set CONFIG_CIFS_XATTR=y CONFIG_CIFS_POSIX=y CONFIG_CIFS_ACL=y CONFIG_CIFS_DEBUG=y # CONFIG_CIFS_DEBUG2 is not set # CONFIG_CIFS_DFS_UPCALL is not set CONFIG_CIFS_SMB2=y # CONFIG_CIFS_SMB311 is not set # CONFIG_CIFS_FSCACHE is not set # CONFIG_NCP_FS is not set # CONFIG_CODA_FS is not set # CONFIG_AFS_FS is not set CONFIG_NLS=y CONFIG_NLS_DEFAULT="iso8859-1" CONFIG_NLS_CODEPAGE_437=y # CONFIG_NLS_CODEPAGE_737 is not set # CONFIG_NLS_CODEPAGE_775 is not set # CONFIG_NLS_CODEPAGE_850 is not set # CONFIG_NLS_CODEPAGE_852 is not set # CONFIG_NLS_CODEPAGE_855 is not set # CONFIG_NLS_CODEPAGE_857 is not set # CONFIG_NLS_CODEPAGE_860 is not set # CONFIG_NLS_CODEPAGE_861 is not set # CONFIG_NLS_CODEPAGE_862 is not set # CONFIG_NLS_CODEPAGE_863 is not set # CONFIG_NLS_CODEPAGE_864 is not set # CONFIG_NLS_CODEPAGE_865 is not set # CONFIG_NLS_CODEPAGE_866 is not set # CONFIG_NLS_CODEPAGE_869 is not set # CONFIG_NLS_CODEPAGE_936 is not set # CONFIG_NLS_CODEPAGE_950 is not set # CONFIG_NLS_CODEPAGE_932 is not set # CONFIG_NLS_CODEPAGE_949 is not set # CONFIG_NLS_CODEPAGE_874 is not set # CONFIG_NLS_ISO8859_8 is not set # CONFIG_NLS_CODEPAGE_1250 is not set # CONFIG_NLS_CODEPAGE_1251 is not set # CONFIG_NLS_ASCII is not set CONFIG_NLS_ISO8859_1=y # CONFIG_NLS_ISO8859_2 is not set # CONFIG_NLS_ISO8859_3 is not set # CONFIG_NLS_ISO8859_4 is not set # CONFIG_NLS_ISO8859_5 is not set # CONFIG_NLS_ISO8859_6 is not set # CONFIG_NLS_ISO8859_7 is not set # CONFIG_NLS_ISO8859_9 is not set # CONFIG_NLS_ISO8859_13 is not set # CONFIG_NLS_ISO8859_14 is not set # CONFIG_NLS_ISO8859_15 is not set # CONFIG_NLS_KOI8_R is not set # CONFIG_NLS_KOI8_U is not set # CONFIG_NLS_MAC_ROMAN is not set # CONFIG_NLS_MAC_CELTIC is not set # CONFIG_NLS_MAC_CENTEURO is not set # CONFIG_NLS_MAC_CROATIAN is not set # CONFIG_NLS_MAC_CYRILLIC is not set # CONFIG_NLS_MAC_GAELIC is not set # CONFIG_NLS_MAC_GREEK is not set # CONFIG_NLS_MAC_ICELAND is not set # CONFIG_NLS_MAC_INUIT is not set # CONFIG_NLS_MAC_ROMANIAN is not set # CONFIG_NLS_MAC_TURKISH is not set CONFIG_NLS_UTF8=y # CONFIG_DLM is not set # # Kernel hacking # # # printk and dmesg options # CONFIG_PRINTK_TIME=y CONFIG_MESSAGE_LOGLEVEL_DEFAULT=4 # CONFIG_BOOT_PRINTK_DELAY is not set # CONFIG_DYNAMIC_DEBUG is not set # # Compile-time checks and compiler options # # CONFIG_DEBUG_INFO is not set CONFIG_ENABLE_WARN_DEPRECATED=y CONFIG_ENABLE_MUST_CHECK=y CONFIG_FRAME_WARN=1024 # CONFIG_STRIP_ASM_SYMS is not set # CONFIG_READABLE_ASM is not set # CONFIG_UNUSED_SYMBOLS is not set # CONFIG_PAGE_OWNER is not set CONFIG_DEBUG_FS=y # CONFIG_HEADERS_CHECK is not set # CONFIG_DEBUG_SECTION_MISMATCH is not set CONFIG_SECTION_MISMATCH_WARN_ONLY=y CONFIG_FRAME_POINTER=y # CONFIG_DEBUG_FORCE_WEAK_PER_CPU is not set CONFIG_MAGIC_SYSRQ=y CONFIG_MAGIC_SYSRQ_DEFAULT_ENABLE=0x1 CONFIG_DEBUG_KERNEL=y # # Memory Debugging # # CONFIG_PAGE_EXTENSION is not set # CONFIG_DEBUG_PAGEALLOC is not set # CONFIG_PAGE_POISONING is not set # CONFIG_DEBUG_OBJECTS is not set # CONFIG_SLUB_STATS is not set CONFIG_HAVE_DEBUG_KMEMLEAK=y # CONFIG_DEBUG_KMEMLEAK is not set # CONFIG_DEBUG_STACK_USAGE is not set # CONFIG_DEBUG_VM is not set # CONFIG_DEBUG_MEMORY_INIT is not set # CONFIG_DEBUG_HIGHMEM is not set # CONFIG_DEBUG_SHIRQ is not set # # Debug Lockups and Hangs # # CONFIG_LOCKUP_DETECTOR is not set # CONFIG_DETECT_HUNG_TASK is not set # CONFIG_WQ_WATCHDOG is not set # CONFIG_PANIC_ON_OOPS is not set CONFIG_PANIC_ON_OOPS_VALUE=0 CONFIG_PANIC_TIMEOUT=0 CONFIG_SCHED_DEBUG=y CONFIG_SCHED_INFO=y CONFIG_SCHEDSTATS=y # CONFIG_SCHED_STACK_END_CHECK is not set # CONFIG_DEBUG_TIMEKEEPING is not set # CONFIG_TIMER_STATS is not set # CONFIG_DEBUG_PREEMPT is not set # # Lock Debugging (spinlocks, mutexes, etc...) # # CONFIG_DEBUG_RT_MUTEXES is not set # CONFIG_DEBUG_SPINLOCK is not set # CONFIG_DEBUG_MUTEXES is not set # CONFIG_DEBUG_WW_MUTEX_SLOWPATH is not set # CONFIG_DEBUG_LOCK_ALLOC is not set # CONFIG_PROVE_LOCKING is not set # CONFIG_LOCK_STAT is not set # CONFIG_DEBUG_ATOMIC_SLEEP is not set # CONFIG_DEBUG_LOCKING_API_SELFTESTS is not set # CONFIG_LOCK_TORTURE_TEST is not set # CONFIG_STACKTRACE is not set # CONFIG_DEBUG_KOBJECT is not set # CONFIG_DEBUG_BUGVERBOSE is not set # CONFIG_DEBUG_LIST is not set # CONFIG_DEBUG_PI_LIST is not set # CONFIG_DEBUG_SG is not set # CONFIG_DEBUG_NOTIFIERS is not set # CONFIG_DEBUG_CREDENTIALS is not set # # RCU Debugging # # CONFIG_PROVE_RCU is not set # CONFIG_SPARSE_RCU_POINTER is not set # CONFIG_TORTURE_TEST is not set # CONFIG_RCU_PERF_TEST is not set # CONFIG_RCU_TORTURE_TEST is not set CONFIG_RCU_CPU_STALL_TIMEOUT=21 # CONFIG_RCU_TRACE is not set # CONFIG_RCU_EQS_DEBUG is not set # CONFIG_DEBUG_WQ_FORCE_RR_CPU is not set # CONFIG_DEBUG_BLOCK_EXT_DEVT is not set # CONFIG_NOTIFIER_ERROR_INJECTION is not set # CONFIG_FAULT_INJECTION is not set # CONFIG_LATENCYTOP is not set CONFIG_HAVE_FUNCTION_TRACER=y CONFIG_HAVE_FUNCTION_GRAPH_TRACER=y CONFIG_HAVE_DYNAMIC_FTRACE=y CONFIG_HAVE_FTRACE_MCOUNT_RECORD=y CONFIG_HAVE_SYSCALL_TRACEPOINTS=y CONFIG_HAVE_C_RECORDMCOUNT=y CONFIG_TRACING_SUPPORT=y # CONFIG_FTRACE is not set # # Runtime Testing # # CONFIG_LKDTM is not set # CONFIG_TEST_LIST_SORT is not set # CONFIG_BACKTRACE_SELF_TEST is not set # CONFIG_RBTREE_TEST is not set # CONFIG_INTERVAL_TREE_TEST is not set # CONFIG_PERCPU_TEST is not set # CONFIG_ATOMIC64_SELFTEST is not set # CONFIG_TEST_HEXDUMP is not set # CONFIG_TEST_STRING_HELPERS is not set # CONFIG_TEST_KSTRTOX is not set # CONFIG_TEST_PRINTF is not set # CONFIG_TEST_BITMAP is not set # CONFIG_TEST_UUID is not set # CONFIG_TEST_RHASHTABLE is not set # CONFIG_TEST_HASH is not set # CONFIG_DMA_API_DEBUG is not set # CONFIG_TEST_LKM is not set # CONFIG_TEST_USER_COPY is not set # CONFIG_TEST_BPF is not set # CONFIG_TEST_FIRMWARE is not set # CONFIG_TEST_UDELAY is not set # CONFIG_MEMTEST is not set # CONFIG_TEST_STATIC_KEYS is not set # CONFIG_SAMPLES is not set CONFIG_HAVE_ARCH_KGDB=y # CONFIG_KGDB is not set # CONFIG_ARCH_WANTS_UBSAN_NO_NULL is not set # CONFIG_UBSAN is not set CONFIG_ARCH_HAS_DEVMEM_IS_ALLOWED=y # CONFIG_STRICT_DEVMEM is not set # CONFIG_ARM_PTDUMP is not set # CONFIG_ARM_UNWIND is not set # CONFIG_DEBUG_USER is not set # CONFIG_DEBUG_LL is not set CONFIG_DEBUG_LL_INCLUDE="mach/debug-macro.S" # CONFIG_DEBUG_UART_8250 is not set CONFIG_UNCOMPRESS_INCLUDE="debug/uncompress.h" # CONFIG_PID_IN_CONTEXTIDR is not set # CONFIG_DEBUG_SET_MODULE_RONX is not set # CONFIG_CORESIGHT is not set # # Security options # CONFIG_KEYS=y # CONFIG_PERSISTENT_KEYRINGS is not set # CONFIG_BIG_KEYS is not set # CONFIG_ENCRYPTED_KEYS is not set # CONFIG_KEY_DH_OPERATIONS is not set # CONFIG_SECURITY_DMESG_RESTRICT is not set # CONFIG_SECURITY is not set # CONFIG_SECURITYFS is not set CONFIG_HAVE_HARDENED_USERCOPY_ALLOCATOR=y CONFIG_HAVE_ARCH_HARDENED_USERCOPY=y # CONFIG_HARDENED_USERCOPY is not set CONFIG_DEFAULT_SECURITY_DAC=y CONFIG_DEFAULT_SECURITY="" CONFIG_CRYPTO=y # # Crypto core or helper # CONFIG_CRYPTO_ALGAPI=y CONFIG_CRYPTO_ALGAPI2=y CONFIG_CRYPTO_AEAD=m CONFIG_CRYPTO_AEAD2=y CONFIG_CRYPTO_BLKCIPHER=m CONFIG_CRYPTO_BLKCIPHER2=y CONFIG_CRYPTO_HASH=y CONFIG_CRYPTO_HASH2=y CONFIG_CRYPTO_RNG=m CONFIG_CRYPTO_RNG2=y CONFIG_CRYPTO_RNG_DEFAULT=m CONFIG_CRYPTO_AKCIPHER2=y CONFIG_CRYPTO_KPP2=y # CONFIG_CRYPTO_RSA is not set # CONFIG_CRYPTO_DH is not set # CONFIG_CRYPTO_ECDH is not set CONFIG_CRYPTO_MANAGER=m CONFIG_CRYPTO_MANAGER2=y # CONFIG_CRYPTO_USER is not set CONFIG_CRYPTO_MANAGER_DISABLE_TESTS=y CONFIG_CRYPTO_GF128MUL=m CONFIG_CRYPTO_NULL=m CONFIG_CRYPTO_NULL2=y CONFIG_CRYPTO_WORKQUEUE=y CONFIG_CRYPTO_CRYPTD=m # CONFIG_CRYPTO_MCRYPTD is not set CONFIG_CRYPTO_AUTHENC=m CONFIG_CRYPTO_TEST=m CONFIG_CRYPTO_ABLK_HELPER=m CONFIG_CRYPTO_ENGINE=m # # Authenticated Encryption with Associated Data # CONFIG_CRYPTO_CCM=m CONFIG_CRYPTO_GCM=m # CONFIG_CRYPTO_CHACHA20POLY1305 is not set CONFIG_CRYPTO_SEQIV=m CONFIG_CRYPTO_ECHAINIV=m # # Block modes # CONFIG_CRYPTO_CBC=m CONFIG_CRYPTO_CTR=m # CONFIG_CRYPTO_CTS is not set CONFIG_CRYPTO_ECB=m # CONFIG_CRYPTO_LRW is not set # CONFIG_CRYPTO_PCBC is not set # CONFIG_CRYPTO_XTS is not set # CONFIG_CRYPTO_KEYWRAP is not set # # Hash modes # CONFIG_CRYPTO_CMAC=m CONFIG_CRYPTO_HMAC=m # CONFIG_CRYPTO_XCBC is not set # CONFIG_CRYPTO_VMAC is not set # # Digest # CONFIG_CRYPTO_CRC32C=y # CONFIG_CRYPTO_CRC32 is not set # CONFIG_CRYPTO_CRCT10DIF is not set CONFIG_CRYPTO_GHASH=m # CONFIG_CRYPTO_POLY1305 is not set CONFIG_CRYPTO_MD4=m CONFIG_CRYPTO_MD5=m # CONFIG_CRYPTO_MICHAEL_MIC is not set # CONFIG_CRYPTO_RMD128 is not set # CONFIG_CRYPTO_RMD160 is not set # CONFIG_CRYPTO_RMD256 is not set # CONFIG_CRYPTO_RMD320 is not set CONFIG_CRYPTO_SHA1=m CONFIG_CRYPTO_SHA256=m CONFIG_CRYPTO_SHA512=m # CONFIG_CRYPTO_SHA3 is not set # CONFIG_CRYPTO_TGR192 is not set # CONFIG_CRYPTO_WP512 is not set # # Ciphers # CONFIG_CRYPTO_AES=y # CONFIG_CRYPTO_ANUBIS is not set CONFIG_CRYPTO_ARC4=m # CONFIG_CRYPTO_BLOWFISH is not set # CONFIG_CRYPTO_CAMELLIA is not set # CONFIG_CRYPTO_CAST5 is not set # CONFIG_CRYPTO_CAST6 is not set CONFIG_CRYPTO_DES=m # CONFIG_CRYPTO_FCRYPT is not set # CONFIG_CRYPTO_KHAZAD is not set # CONFIG_CRYPTO_SALSA20 is not set # CONFIG_CRYPTO_CHACHA20 is not set # CONFIG_CRYPTO_SEED is not set # CONFIG_CRYPTO_SERPENT is not set # CONFIG_CRYPTO_TEA is not set # CONFIG_CRYPTO_TWOFISH is not set # # Compression # CONFIG_CRYPTO_DEFLATE=y CONFIG_CRYPTO_LZO=y # CONFIG_CRYPTO_842 is not set # CONFIG_CRYPTO_LZ4 is not set # CONFIG_CRYPTO_LZ4HC is not set # # Random Number Generation # # CONFIG_CRYPTO_ANSI_CPRNG is not set CONFIG_CRYPTO_DRBG_MENU=m CONFIG_CRYPTO_DRBG_HMAC=y # CONFIG_CRYPTO_DRBG_HASH is not set # CONFIG_CRYPTO_DRBG_CTR is not set CONFIG_CRYPTO_DRBG=m CONFIG_CRYPTO_JITTERENTROPY=m CONFIG_CRYPTO_USER_API=m CONFIG_CRYPTO_USER_API_HASH=m CONFIG_CRYPTO_USER_API_SKCIPHER=m # CONFIG_CRYPTO_USER_API_RNG is not set # CONFIG_CRYPTO_USER_API_AEAD is not set CONFIG_CRYPTO_HW=y # CONFIG_CRYPTO_DEV_HIFN_795X is not set CONFIG_CRYPTO_DEV_OMAP_SHAM=m CONFIG_CRYPTO_DEV_OMAP_AES=m CONFIG_CRYPTO_DEV_OMAP_DES=m # CONFIG_ASYMMETRIC_KEY_TYPE is not set # # Certificates for signature checking # CONFIG_ARM_CRYPTO=y CONFIG_CRYPTO_SHA1_ARM=m CONFIG_CRYPTO_SHA1_ARM_NEON=m CONFIG_CRYPTO_SHA1_ARM_CE=m CONFIG_CRYPTO_SHA2_ARM_CE=m CONFIG_CRYPTO_SHA256_ARM=m CONFIG_CRYPTO_SHA512_ARM=m CONFIG_CRYPTO_AES_ARM=m CONFIG_CRYPTO_AES_ARM_BS=m CONFIG_CRYPTO_AES_ARM_CE=m CONFIG_CRYPTO_GHASH_ARM_CE=m # CONFIG_BINARY_PRINTF is not set # # Library routines # CONFIG_BITREVERSE=y CONFIG_HAVE_ARCH_BITREVERSE=y CONFIG_RATIONAL=y CONFIG_GENERIC_STRNCPY_FROM_USER=y CONFIG_GENERIC_STRNLEN_USER=y CONFIG_GENERIC_NET_UTILS=y CONFIG_GENERIC_PCI_IOMAP=y CONFIG_GENERIC_IO=y CONFIG_ARCH_USE_CMPXCHG_LOCKREF=y CONFIG_CRC_CCITT=m CONFIG_CRC16=y # CONFIG_CRC_T10DIF is not set CONFIG_CRC_ITU_T=m CONFIG_CRC32=y # CONFIG_CRC32_SELFTEST is not set CONFIG_CRC32_SLICEBY8=y # CONFIG_CRC32_SLICEBY4 is not set # CONFIG_CRC32_SARWATE is not set # CONFIG_CRC32_BIT is not set CONFIG_CRC7=m CONFIG_LIBCRC32C=m # CONFIG_CRC8 is not set # CONFIG_AUDIT_ARCH_COMPAT_GENERIC is not set # CONFIG_RANDOM32_SELFTEST is not set CONFIG_ZLIB_INFLATE=y CONFIG_ZLIB_DEFLATE=y CONFIG_LZO_COMPRESS=y CONFIG_LZO_DECOMPRESS=y CONFIG_LZ4_DECOMPRESS=y CONFIG_XZ_DEC=y CONFIG_XZ_DEC_X86=y CONFIG_XZ_DEC_POWERPC=y CONFIG_XZ_DEC_IA64=y CONFIG_XZ_DEC_ARM=y CONFIG_XZ_DEC_ARMTHUMB=y CONFIG_XZ_DEC_SPARC=y CONFIG_XZ_DEC_BCJ=y # CONFIG_XZ_DEC_TEST is not set CONFIG_DECOMPRESS_GZIP=y CONFIG_DECOMPRESS_BZIP2=y CONFIG_DECOMPRESS_LZMA=y CONFIG_DECOMPRESS_XZ=y CONFIG_DECOMPRESS_LZO=y CONFIG_DECOMPRESS_LZ4=y CONFIG_GENERIC_ALLOCATOR=y CONFIG_BCH=y CONFIG_TEXTSEARCH=y CONFIG_TEXTSEARCH_KMP=m CONFIG_TEXTSEARCH_BM=m CONFIG_TEXTSEARCH_FSM=m CONFIG_ASSOCIATIVE_ARRAY=y CONFIG_HAS_IOMEM=y CONFIG_HAS_IOPORT_MAP=y CONFIG_HAS_DMA=y CONFIG_DQL=y CONFIG_GLOB=y # CONFIG_GLOB_SELFTEST is not set CONFIG_NLATTR=y # CONFIG_CORDIC is not set # CONFIG_DDR is not set # CONFIG_IRQ_POLL is not set CONFIG_LIBFDT=y CONFIG_OID_REGISTRY=y CONFIG_UCS2_STRING=y CONFIG_FONT_SUPPORT=y # CONFIG_FONTS is not set CONFIG_FONT_8x8=y CONFIG_FONT_8x16=y CONFIG_SG_SPLIT=y CONFIG_SG_POOL=y CONFIG_ARCH_HAS_SG_CHAIN=y CONFIG_SBITMAP=y # CONFIG_VIRTUALIZATION is not set
I don't know if this only the kernel configuration issue or some kind of bug in the kernel driver. Any help with this issue would be appreciated.
Honza
