TDA4VM Jacinto Processors for ADAS and Autonomous Vehicles.
Application to take data from LiDAR sensor and camera over Ethernet at the same time. And process the data. Is it possible with TDA4VM development board?
Hi Mohan,
Well you can use development board, but there is not any Lidar sensor supported in the SDK, nor does it support camera over ethernet. You would require to develop this example.
Brijesh
Hi Team,
We are going to use LiDAR Sensor and Camera, both has Ethernet connectivity. Our application is to take data from LiDAR Sensor and camera at the same time and process the data. Kindly suggest which development board is suitable for our application.
Hi Mohan,
What's the format in which the camera and Lidar data sent?
Again, you could use development board, but there isn't any readily available example for this in the SDK.
Brijesh
Hi Brijesh,
Which data format your SDK is support. In that format we are providing the data.
Mohan
Hi Mohan,
SDK supports camera input over CSI/MIPI interface and it captures data over YUV422 or RAW12 bit Bayer format..
Brijesh
