AM62A7: Reboot is not working
Part Number: AM62A7
Dear Team,
Reboot is not working in our board, only hard ware reset is working. Please let us know anything need to take care from Hardware side for software reboot.
Manu
  • Hi Manu,
    "not working" doesn't have sufficient information for me to comment. Please provide more details. SDK version, boot mode, console log, etc.
  • Hi Bin Lie,
    SDK 8.06.45, eMMC (UDA in raw mode) and log attached.
    https://www.transfernow.net/en/dltransfer?utm_source=20230516S4irJMlr&utm_medium=gewIaR3N
    Manu
  • Hi Manu,
    The link is blocked by our firewall, I cannot see the log. Can you please attach the log file in this thread (please don't copy & paste it)?
    Are you able to boot U-Boot and Linux from eMMC, but Linux reboot command doesn't reboot the board?
    Do you have any other way, other than from eMMC, to boot the board, then check if reboot command works?
  • Are you able to boot U-Boot and Linux from eMMC, but Linux reboot command doesn't reboot the board? - Yes
    Do you have any other way, other than from eMMC, to boot the board, then check if reboot command works? - We will check this and update.
  • Hi
    The eMMC RST_n is enabled by programming eMMC ECSD register in Uboot, still issue is persist like before.
    Kindly find the attached log FYR.
    root@am62axx-evm:~# mmc extcsd read /dev/mmcblk0 | grep -i RST
    H/W reset function [RST_N_FUNCTION]: 0x01
    root@am62axx-evm:~# [   31.795863] vdd_mmc1: disabling
    root@am62axx-evm:~#
    root@am62axx-evm:~# reboot
             Stopping Session c1 of user root.
    [  OK  ] Stopped target RPC Port Mapper.
    [  OK  ] Stopped target Sound Card.
    [  OK  ] Stopped target Timers.
    [  OK  ] Stopped Daily rotation of log files.
    [  OK  ] Stopped Daily Cleanup of Temporary Directories.
    [  OK  ] Stopped target Hardware activated USB gadget.
             Stopping Save/Restore Sound Card State...
             Stopping Reboot and dump vmcore via kexec...
             Stopping NFS status monitor for NFSv2/3 locking....
             Stopping Load/Save Random Seed...
    [  OK  ] Stopped target Login Prompts.
             Stopping Job spooling tools...
             Stopping Avahi mDNS/DNS-SD Stack...
             Stopping Periodic Command Scheduler...
             Stopping Ethernet Bridge Filtering Tables...
             Stopping EdgeAI OOB demos...
             Stopping Getty on tty1...
             Stopping irqbalance daemon...
    [  OK  ] Stopped Matrix GUI.
             Stopping Serial Getty on ttyS0...
             Stopping Serial Getty on ttyS2...
             Stopping Simple Network Ma…ent Protocol (SNMP) Daemon....
             Stopping System Logger Daemon "default" instance...
             Stopping TEE Supplicant...
    [  OK  ] Stopped target System Time Synchronized.
    [  OK  ] Stopped target System Time Set.
             Stopping LSB: Expand Rootfs of boot device...
             Stopping syslog.service...
             Stopping Vsftpd ftp daemon...
    [  OK  ] Stopped Job spooling tools.
    [  OK  ] Stopped Periodic Command Scheduler.
    [  OK  ] Stopped irqbalance daemon.
    [  OK  ] Stopped System Logger Daemon "default" instance.
    [  OK  ] Stopped TEE Supplicant.
    [  OK  ] Stopped Wait for Network to be Configured.
    [  OK  ] Stopped Avahi mDNS/DNS-SD Stack.
    [  OK  ] Stopped NFS status monitor for NFSv2/3 locking..
    [  OK  ] Stopped Simple Network Man…ement Protocol (SNMP) Daemon..
    [  OK  ] Stopped Vsftpd ftp daemon.
    [  OK  ] Stopped Getty on tty1.
    [  OK  ] Stopped Serial Getty on ttyS2.
    [  OK  ] Stopped Serial Getty on ttyS0.
    [  OK  ] Stopped Save/Restore Sound Card State.
    [  OK  ] Stopped Reboot and dump vmcore via kexec.
    [  OK  ] Stopped Load/Save Random Seed.
    [  OK  ] Stopped Ethernet Bridge Filtering Tables.
    [  OK  ] Stopped LSB: Expand Rootfs of boot device.
    [  OK  ] Stopped syslog.service.
    [  OK  ] Stopped Session c1 of user root.
    [  OK  ] Removed slice system-getty.slice.
    [  OK  ] Removed slice system-serial\x2dgetty.slice.
    [  OK  ] Removed slice system-syslog\x2dng.slice.
    [  OK  ] Stopped target Host and Network Name Lookups.
             Stopping Login Service...
             Stopping telnetd.service...
             Stopping User Manager for UID 0...
    [  OK  ] Stopped User Manager for UID 0.
    [  OK  ] Stopped telnetd.service.
             Stopping User Runtime Directory /run/user/0...
    [  OK  ] Unmounted /run/user/0.
    [  OK  ] Stopped User Runtime Directory /run/user/0.
    [  OK  ] Removed slice User Slice of UID 0.
             Stopping D-Bus System Message Bus...
             Stopping Permit User Sessions...
    [  OK  ] Stopped D-Bus System Message Bus.
    [  OK  ] Stopped Login Service.
    [  OK  ] Stopped Permit User Sessions.
    [  OK  ] Stopped target Network.
             Stopping Network Name Resolution...
    [  OK  ] Stopped Network Name Resolution.
             Stopping Network Service...
    [  OK  ] Stopped Network Service.
    [  OK  ] Stopped target Network (Pre).
    [  OK  ] Stopped IPv6 Packet Filtering Framework.
    [  OK  ] Stopped IPv4 Packet Filtering Framework.
    [  OK  ] Stopped EdgeAI OOB demos.
             Stopping weston.service...
    [  OK  ] Stopped weston.service.
    [  OK  ] Stopped target Basic System.
    [  OK  ] Stopped target Paths.
    [  OK  ] Stopped Dispatch Password …ts to Console Directory Watch.
    [  OK  ] Stopped Forward Password R…uests to Wall Directory Watch.
    [  OK  ] Stopped target Remote File Systems.
    [  OK  ] Stopped target Slices.
    [  OK  ] Removed slice User and Session Slice.
    [  OK  ] Stopped target Sockets.
    [  OK  ] Closed Avahi mDNS/DNS-SD Stack Activation Socket.
    [  OK  ] Closed D-Bus System Message Bus Socket.
    [  OK  ] Closed Docker Socket for the API.
    [  OK  ] Closed dropbear.socket.
    [  OK  ] Stopped target System Initialization.
             Stopping Hardware RNG Entropy Gatherer Daemon...
    [  OK  ] Stopped Apply Kernel Variables.
    [  OK  ] Stopped Load Kernel Modules.
             Stopping Network Time Synchronization...
             Stopping Update UTMP about System Boot/Shutdown...
    [  OK  ] Stopped Network Time Synchronization.
    [  OK  ] Stopped Hardware RNG Entropy Gatherer Daemon.
    [  OK  ] Stopped Update UTMP about System Boot/Shutdown.
    [  OK  ] Stopped Create Volatile Files and Directories.
    [  OK  ] Stopped target Local File Systems.
             Unmounting /media/ram...
             Unmounting Temporary Directory (/tmp)...
             Unmounting /var/volatile...
    [  OK  ] Unmounted /media/ram.
    [  OK  ] Unmounted Temporary Directory (/tmp).
    [  OK  ] Unmounted /var/volatile.
    [  OK  ] Stopped target Local File Systems (Pre).
    [  OK  ] Stopped target Swap.
    [  OK  ] Reached target Unmount All Filesystems.
    [  OK  ] Stopped Remount Root and Kernel File Systems.
    [  OK  ] Stopped Create Static Device Nodes in /dev.
    [  OK  ] Reached target Shutdown.
    [  OK  ] Reached target Final Step.
    [  OK  ] Started Reboot.
    [  OK  ] Reached target Reboot.
    [   53.190062] systemd-shutdown[1]: Syncing filesystems and block devices.
    [   53.269022] systemd-shutdown[1]: Sending SIGTERM to remaining processes...
    [   53.284514] systemd-journald[182]: Received SIGTERM from PID 1 (systemd-shutdow).
    [   53.304784] systemd-shutdown[1]: Sending SIGKILL to remaining processes...
    [   53.320790] systemd-shutdown[1]: Unmounting file systems.
    [   53.328679] [1208]: Remounting '/' read-only in with options '(null)'.
    [   53.371472] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
    [   53.384241] systemd-shutdown[1]: All filesystems unmounted.
    [   53.389853] systemd-shutdown[1]: Deactivating swaps.
    [   53.395043] systemd-shutdown[1]: All swaps deactivated.
    [   53.400276] systemd-shutdown[1]: Detaching loop devices.
    [   53.408447] systemd-shutdown[1]: All loop devices detached.
    [   53.414042] systemd-shutdown[1]: Detaching DM devices.
    [   53.419445] systemd-shutdown[1]: All DM devices detached.
    [   53.424847] systemd-shutdown[1]: All filesystems, swaps, loop devices and DM devices detached.
    [   53.440338] systemd-shutdown[1]: Syncing filesystems and block devices.
    [   53.447183] systemd-shutdown[1]: Rebooting.
    [   53.482585] reboot: Restarting system
  • Hi Manu,
    Sorry for my late response.
    Does this issue still open? If so, does your board have a different way to boot from instead of eMMC? I am trying to understand if eMMC got stuck during reboot/reset.
