Other Parts Discussed in Thread: AM1808
Can AM1808 use the NAND-FLASH and MMC/SD in the same time?
thanks,
JAY
Jay,
(corrected section # on edited post)
you can look at the device pinmux table (suggest you look at the Terminal functions tables in the datasheet, section 2.7 for each individual module and see) and see if both pins are available at the same time if not multiplexed with each other. If they might be muxed w/each other then you will have to change the pinmux registers to use one and then the other.
regards,
miguel
