Part Number: TDA4VH-Q1
Other Parts Discussed in Thread: TDA2,
Dear TI experts,
we are currently using TDA2 (C66x DSP @ 1Ghz) to run C code that is not optimized w.r.t. TI intrinsics etc.The code has complex data structures and performs many operations in nested loops. We basically fully rely on the compiler optimizations (O3 level) to make best out of the DSP's capacity.
We are now considering to switch to TDA4VH-Q1 (C7x DSP @ 1 GHz). In that context I have the following questions:
1) I know that C7x has a wider SIMD data path compared to C6x (512 bit vs 64 bit). Much much would we benefit from that given the same i.e. non-TI-optimized code? Meaning, will the compiler generally be able to make use of that in our case?
2) How could we take more advantage from the C7x (compared to C66x)? Would introducing the TI intrinsics etc. improve the performance a lot? What else would be helpful here?
