AM4376: rtcwake failure on top of custom U-boot and Kernel combination along with Buildroot
Part Number: AM4376
Hi TI
Even though TI PSDK official releases work for rtcwake funtion. A customer reported a rtcwake failure on their custom platform based on Uboot 2020.01 and Kernel 5.4.188.
The following is the failure log captured on their target board. Also the standy mode has same result. (e.g. -m standby)
$ rtcwake -s 10 -d /dev/rtc0 -m mem
(Kernel stop, unable to wake upas below)
root@INSCOBEE-MSU:/sys/power# rtcwake -s 10 -d /dev/rtc0 -m mem
wakeup from "mem" at Mon Aug  1 00:17:55 2022
[ 1087.224065] PM: suspend entry (deep)
[ 1087.229389] Filesystems sync: 0.001 seconds
[ 1087.238484] Freezing user space processes ... (elapsed 0.002 seconds) done.
[ 1087.248009] OOM killer disabled.
[ 1087.251375] Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
[ 1087.273439] cpsw 4a100000.ethernet eth0: Link is Down
[ 1087.281272] cpsw 4a100000.ethernet eth1: Link is Down
[ 1087.295067] PM: suspend devices took 0.030 seconds
When they enabled the debug mode of kernel power driver, the following error message is also shown.
The full log is attached with 'mem_suspend_resume_log_230410.txt)
[  231.588300] pm33xx pm33xx: PM: Kernel suspend failure
The followings are the list of /sys/power/state directories.
root@INSCOBEE-MSU:/sys/kernel/debug/pm_debug# cd /sys/
root@INSCOBEE-MSU:/sys# ls
block     class     devices   fs        module
bus       dev       firmware  kernel    power
root@INSCOBEE-MSU:/sys# cd power/
root@INSCOBEE-MSU:/sys/power# ls
mem_sleep          pm_freeze_timeout  pm_wakeup_irq      wake_lock
pm_async           pm_print_times     state              wake_unlock
pm_debug_messages  pm_test            suspend_stats      wakeup_count
root@INSCOBEE-MSU:/sys/power# cat state
freeze standby mem
Here is the kernel log by dmesg
root@INSCOBEE-MSU:/# dmesg
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 5.4.188 (am437x@4bfebc466fc7) (gcc version 8.4.0 (OpenWrt GCC 8.4.0 r16554-1d4dea6d4f)) #0 PREEMPT Sat A2
[    0.000000] CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: KDCU MSU V1.0
[    0.000000] Memory policy: Data cache writeback
[    0.000000] cma: Reserved 48 MiB at 0xfcc00000
[    0.000000] On node 0 totalpages: 524287
[    0.000000]   Normal zone: 1728 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 196608 pages, LIFO batch:63
[    0.000000]   HighMem zone: 327679 pages, LIFO batch:63
[    0.000000] CPU: All CPU(s) started in SVC mode.
[    0.000000] AM437x ES1.2 (neon)
[    0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[    0.000000] pcpu-alloc: [0] 0
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 522559
[    0.000000] Kernel command line: consoleblank=0 no_console_suspend=1 console=ttyS0,115200n8 root=/dev/mmcblk0p2 noinitrd rootwait 4
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] Memory: 2015600K/2097148K available (8192K kernel code, 325K rwdata, 2148K rodata, 1024K init, 248K bss, 32396K reserv)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000]  Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] L2C: platform modifies aux control register: 0x0e030000 -> 0x3e430000
[    0.000000] L2C: DT/platform modifies aux control register: 0x0e030000 -> 0x3e430000
[    0.000000] L2C-310 enabling early BRESP for Cortex-A9
[    0.000000] OMAP L2C310: ROM does not support power control setting
[    0.000000] L2C-310 dynamic clock gating disabled, standby mode disabled
[    0.000000] L2C-310 cache controller enabled, 16 ways, 256 kB
[    0.000000] L2C-310: CACHE_ID 0x410000c9, AUX_CTRL 0x4e430000
[    0.000000] random: get_random_bytes called from start_kernel+0x2b0/0x458 with crng_init=0
[    0.000000] OMAP clockevent source: timer2 at 24000000 Hz
[    0.000012] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[    0.000029] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000037] OMAP clocksource: timer1 at 24000000 Hz
[    0.000452] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
[    0.000460] OMAP clocksource: 32k_counter at 32768 Hz
[    0.000910] Console: colour dummy device 80x30
[    0.000975] Calibrating delay loop... 1987.37 BogoMIPS (lpj=9936896)
[    0.060179] pid_max: default: 32768 minimum: 301
[    0.060352] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.060375] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.061191] CPU: Testing write buffer coherency: ok
[    0.061252] CPU0: Spectre v2: using BPIALL workaround
[    0.062069] Setting up static identity map for 0x80100000 - 0x80100060
[    0.062208] rcu: Hierarchical SRCU implementation.
[    0.073375] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[    0.073750] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.073773] futex hash table entries: 256 (order: -1, 3072 bytes, linear)
[    0.076877] pinctrl core: initialized pinctrl subsystem
[    0.078020] NET: Registered protocol family 16
[    0.079676] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.100499] cpuidle: using governor ladder
[    0.100532] cpuidle: using governor menu
[    0.118410] No ATAGs?
[    0.132773] edma 49000000.edma: TI EDMA DMA engine driver
[    0.134308] iommu: Default domain type: Translated
[    0.135774] SCSI subsystem initialized
[    0.135990] usbcore: registered new interface driver usbfs
[    0.136034] usbcore: registered new interface driver hub
[    0.136079] usbcore: registered new device driver usb
[    0.136609] pps_core: LinuxPPS API ver. 1 registered
[    0.136617] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[    0.136638] PTP clock support registered
[    0.136671] EDAC MC: Ver: 3.0.0
[    0.138557] clocksource: Switched to clocksource timer1
[    0.143296] thermal_sys: Registered thermal governor 'fair_share'
[    0.143302] thermal_sys: Registered thermal governor 'bang_bang'
[    0.143316] thermal_sys: Registered thermal governor 'step_wise'
[    0.143321] thermal_sys: Registered thermal governor 'user_space'
[    0.143326] thermal_sys: Registered thermal governor 'power_allocator'
[    0.143947] NET: Registered protocol family 2
[    0.144276] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.145210] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
[    0.145238] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[    0.145297] TCP bind hash table entries: 8192 (order: 3, 32768 bytes, linear)
[    0.145369] TCP: Hash tables configured (established 8192 bind 8192)
[    0.145543] UDP hash table entries: 512 (order: 1, 8192 bytes, linear)
[    0.145565] UDP-Lite hash table entries: 512 (order: 1, 8192 bytes, linear)
[    0.145687] NET: Registered protocol family 1
[    0.146210] RPC: Registered named UNIX socket transport module.
[    0.146222] RPC: Registered udp transport module.
[    0.146227] RPC: Registered tcp transport module.
[    0.146232] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.147500] Initialise system trusted keyrings
[    0.147775] workingset: timestamp_bits=14 max_order=19 bucket_order=5
[    0.152445] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.153163] NFS: Registering the id_resolver key type
[    0.153200] Key type id_resolver registered
[    0.153206] Key type id_legacy registered
[    0.153246] ntfs: driver 2.1.32 [Flags: R/O].
[    0.153799] Key type asymmetric registered
[    0.153809] Asymmetric key parser 'x509' registered
[    0.153857] bounce: pool size: 64 pages
[    0.153902] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    0.154099] io scheduler mq-deadline registered
[    0.154113] io scheduler kyber registered
[    0.158348] OMAP GPIO hardware version 0.1
[    0.183069] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[    0.217479] pinctrl-single 44e10800.pinmux: 199 pins, size 796
[    0.246286] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[    0.249423] omap8250 44e09000.serial: No clock speed specified: using default: 48000000
[    0.250075] printk: console [ttyS0] disabled
[    0.250173] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 66, base_baud = 3000000) is a 8250
[    0.864636] printk: console [ttyS0] enabled
[    0.869504] omap8250 48022000.serial: No clock speed specified: using default: 48000000
[    0.878145] 48022000.serial: ttyS1 at MMIO 0x48022000 (irq = 72, base_baud = 3000000) is a 8250
[    0.887503] omap8250 48024000.serial: No clock speed specified: using default: 48000000
[    0.896190] 48024000.serial: ttyS2 at MMIO 0x48024000 (irq = 73, base_baud = 3000000) is a 8250
[    0.905548] omap8250 481a6000.serial: No clock speed specified: using default: 48000000
[    0.914222] 481a6000.serial: ttyS3 at MMIO 0x481a6000 (irq = 80, base_baud = 3000000) is a 8250
[    0.923536] omap8250 481a8000.serial: No clock speed specified: using default: 48000000
[    0.932154] 481a8000.serial: ttyS4 at MMIO 0x481a8000 (irq = 81, base_baud = 3000000) is a 8250
[    0.941469] omap8250 481aa000.serial: No clock speed specified: using default: 48000000
[    0.950135] 481aa000.serial: ttyS5 at MMIO 0x481aa000 (irq = 82, base_baud = 3000000) is a 8250
[    0.961216] omap_rng 48310000.rng: Random Number Generator ver. 20
[    0.968794] random: fast init done
[    0.972450] crng init done
[    0.984316] brd: module loaded
[    0.996254] loop: module loaded
[    1.058591] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6, bus freq 1000000
[    1.067307] Probing for 175d address: 4
[    1.072130] davinci_mdio 4a101000.mdio: phy[4]: device 4a101000.mdio:04, driver ICPlus IP175D
[    1.080799] davinci_mdio 4a101000.mdio: phy[5]: device 4a101000.mdio:05, driver unknown
[    1.089166] cpsw 4a100000.ethernet: initialized cpsw ale version 1.4
[    1.095554] cpsw 4a100000.ethernet: ALE Table size 1024
[    1.100973] cpsw 4a100000.ethernet: cpts: overflow check period 500 (jiffies)
[    1.108186] cpsw 4a100000.ethernet: Detected MACID = e0:ff:f1:ae:fc:bb
[    1.115528] cpsw 4a100000.ethernet: cpsw: Detected MACID = e0:ff:f1:ae:fc:bd
[    1.123490] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.131024] usbcore: registered new interface driver cdc_acm
[    1.136712] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    1.146818] omap_rtc 44e3e000.rtc: char device (253:0)
[    1.146837] omap_rtc 44e3e000.rtc: registered as rtc0
[    1.152220] i2c /dev entries driver
[    1.159510] /cpus/cpu@0: unsupported enable-method property: ti,am4372
[    1.166607] sdhci: Secure Digital Host Controller Interface driver
[    1.172859] sdhci: Copyright(c) Pierre Ossman
[    1.178364] omap_gpio 44e07000.gpio: Could not set line 6 debounce to 200000 microseconds (-22)
[    1.187144] omap_hsmmc 48060000.mmc: Got CD GPIO
[    1.199149] omap_gpio 481ae000.gpio: Could not set line 15 debounce to 200000 microseconds (-22)
[    1.207980] omap_hsmmc 481d8000.mmc: Got CD GPIO
[    1.219186] omap_hsmmc 47810000.mmc: RX DMA channel request failed
[    1.225671] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.232737] ledtrig-cpu: registered to indicate activity on CPUs
[    1.241789] NET: Registered protocol family 10
[    1.247475] Segment Routing with IPv6
[    1.251361] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    1.257931] NET: Registered protocol family 17
[    1.262553] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if .
[    1.275647] 8021q: 802.1Q VLAN Support v1.8
[    1.279912] Key type dns_resolver registered
[    1.284373] omap_voltage_late_init: Voltage driver support not added
[    1.291260] Loading compiled-in X.509 certificates
[    1.341278] tps6521x_pwrbutton tps65218-pwrbutton.1.auto: DMA mask not set
[    1.349000] input: tps65218_pwrbutton as /devices/platform/44000000.ocp/44c00000.interconnect/44c00000.interconnect:segment@2000000
[    1.383089] omap_i2c 44e0b000.i2c: bus 0 rev0.12 at 100 kHz
[    1.390021] omap_i2c 4802a000.i2c: bus 1 rev0.12 at 400 kHz
[    1.396509] omap_i2c 4819c000.i2c: bus 2 rev0.12 at 400 kHz
[    1.404873] omap_gpio 44e07000.gpio: Could not set line 6 debounce to 200000 microseconds (-22)
[    1.413739] omap_hsmmc 48060000.mmc: Got CD GPIO
[    1.445472] omap_gpio 481ae000.gpio: Could not set line 15 debounce to 200000 microseconds (-22)
[    1.454363] omap_hsmmc 481d8000.mmc: Got CD GPIO
[    1.490925] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01T00:00:00 UTC (946684800)
[    1.503046] Waiting for root device /dev/mmcblk0p2...
[    1.559188] mmc0: new high speed MMC card at address 0001
[    1.565957] mmcblk0: mmc0:0001 eMMC   3.64 GiB
[    1.571167] mmcblk0boot0: mmc0:0001 eMMC   partition 1 4.00 MiB
[    1.577633] mmcblk0boot1: mmc0:0001 eMMC   partition 2 4.00 MiB
[    1.583915] mmcblk0rpmb: mmc0:0001 eMMC   partition 3 4.00 MiB, chardev (246:0)
[    1.595873]  mmcblk0: p1 p2 p3
[    1.629507] EXT4-fs (mmcblk0p2): mounted filesystem without journal. Opts: (null)
[    1.637116] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[    1.646371] Freeing unused kernel memory: 1024K
[    1.651121] Run /sbin/init as init process
[    1.755915] init: Console is alive
[    1.907330] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[    1.919515] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[    1.937237] init: - preinit -
[    2.169155] cpsw 4a100000.ethernet: initializing cpsw version 1.15 (0)
[    2.178816] Resetting master bus...
[    2.182331] Found my OF Node
[    2.185223] VLAN Setup is 1
[    2.211175] Full reset performed
[    2.214478] ICPlus IP175D 4a101000.mdio:04: attached PHY driver [ICPlus IP175D] (mii_bus:phy_addr=4a101000.mdio:04, irq=POLL)
[    2.232788] 8021q: adding VLAN 0 to HW filter on device eth0
[    4.329080] Link is OK
[    4.329089] 100M/Full
[    4.334831] cpsw 4a100000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[    4.342952] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[    6.387544] mount_root: mounting /dev/root
[    6.392467] EXT4-fs (mmcblk0p2): warning: mounting unchecked fs, running e2fsck is recommended
[    6.441853] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[    6.449123] urandom-seed: Seeding with /etc/urandom.seed
[    6.493641] cpsw 4a100000.ethernet eth0: Link is Down
[    6.504487] procd: - early -
[    7.268420] procd: - ubus -
[    7.324247] procd: - init -
[    7.706014] kmodloader: loading kernel modules from /etc/modules.d/*
[    7.723668] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
[    7.743189] remoteproc remoteproc0: wkup_m3 is available
[    7.763233] remoteproc remoteproc0: powering up wkup_m3
[    7.774403] PM: Cannot get wkup_m3_ipc handle
[    7.785643] urngd: v1.0.2 started.
[    7.803228] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 217168
[    7.835756] remoteproc remoteproc0: remote processor wkup_m3 is now up
[    7.842413] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x193
[    7.964901] GACT probability on
[    7.969667] Mirror/redirect action on
[    7.982633] u32 classifier
[    7.985367]     input device check on
[    7.993380]     Actions configured
[    8.024290] Bridge firewalling registered
[    8.094256] xt_time: kernel timezone is -0000
[    8.107196] PPP generic driver version 2.4.2
[    8.113606] NET: Registered protocol family 24
[    8.125904] kmodloader: done loading kernel modules from /etc/modules.d/*
[   10.145526] xt_CT: No such helper "snmp"
[   11.461674] net eth1: initializing cpsw version 1.15 (0)
[   11.498840] Generic PHY 4a101000.mdio:05: attached PHY driver [Generic PHY] (mii_bus:phy_addr=4a101000.mdio:05, irq=POLL)
[   11.522203] cpsw 4a100000.ethernet eth1: Link is Up - 100Mbps/Full - flow control off
[   11.535320] 8021q: adding VLAN 0 to HW filter on device eth1
[   11.561489] net eth1: Adding vlanid 3 to vlan filter
[   11.607591] net eth1: Adding vlanid 4 to vlan filter
[   11.705688] cpsw 4a100000.ethernet: initializing cpsw version 1.15 (0)
[   11.744203] ICPlus IP175D 4a101000.mdio:04: attached PHY driver [ICPlus IP175D] (mii_bus:phy_addr=4a101000.mdio:04, irq=POLL)
[   11.799454] Link is OK
[   11.799459] 100M/Full
[   11.805455] 8021q: adding VLAN 0 to HW filter on device eth0
[   11.822831] cpsw 4a100000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[   11.883931] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   12.768026] xt_CT: No such helper "snmp"
[   13.548417] xt_CT: No such helper "snmp"
[   13.679592] INSCOBEE MSU Starting...
[   13.694267] mount mmcblk0p3
[   13.930758] EXT4-fs (mmcblk0p3): recovery complete
[   13.944586] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null)
[   14.487828] xt_CT: No such helper "snmp"
[   15.024244] kmcu run...
[   31.848708] vmmcwl_fixed: disabling
Also attached list of /lib/firmware and /lib/modules.
root@INSCOBEE-MSU:/lib/firmware# ll
drwxr-xr-x    5 root     root          4096 Apr 16 21:59 ./
drwxr-xr-x   11 root     root          4096 Apr 16 21:59 ../
-rw-r--r--    1 root     root          2046 Apr 16 21:59 LICENCE.iwlwifi_firmware
-rw-r--r--    1 root     root            73 Apr 16 21:59 am335x-bone-scale-data.bin
-rw-r--r--    1 root     root            17 Apr 16 21:59 am335x-evm-scale-data.bin
-rw-r--r--    1 root     root        217168 Apr 16 21:59 am335x-pm-firmware.elf
lrwxrwxrwx    1 root     root            49 Apr 16 21:59 am437x-pru0_0-fw ->/lib/firmware/pru/PRU_RPMsg_Echo_Interrupt0_0.out
lrwxrwxrwx    1 root     root            49 Apr 16 21:59 am437x-pru0_1-fw -> /lib/firmware/pru/PRU_RPMsg_Echo_Interrupt0_1.out
lrwxrwxrwx    1 root     root            49 Apr 16 21:59 am437x-pru1_0-fw -> /lib/firmware/pru/PRU_RPMsg_Echo_Interrupt1_0.out
lrwxrwxrwx    1 root     root            49 Apr 16 21:59 am437x-pru1_1-fw -> /lib/firmware/pru/PRU_RPMsg_Echo_Interrupt1_1.out
-rw-r--r--    1 root     root            41 Apr 16 21:59 am43x-evm-scale-data.bin
-rw-r--r--    1 root     root        918268 Apr 16 21:59 iwlwifi-3160-17.ucode
-rw-r--r--    1 root     root       1745176 Apr 16 21:59 iwlwifi-8000C-13.ucode
-rw-r--r--    1 root     root       2351636 Apr 16 21:59 iwlwifi-8000C-16.ucode
-rw-r--r--    1 root     root       2394060 Apr 16 21:59 iwlwifi-8000C-21.ucode
-rw-r--r--    1 root     root       2120860 Apr 16 21:59 iwlwifi-8000C-22.ucode
-rw-r--r--    1 root     root       2227284 Apr 16 21:59 iwlwifi-8000C-27.ucode
-rw-r--r--    1 root     root       2310116 Apr 16 21:59 iwlwifi-8000C-31.ucode
-rw-r--r--    1 root     root       2448976 Apr 16 21:59 iwlwifi-8000C-34.ucode
-rw-r--r--    1 root     root       2428004 Apr 16 21:59 iwlwifi-8000C-36.ucode
-rw-r--r--    1 root     root       2389968 Apr 16 21:59 iwlwifi-8265-21.ucode
-rw-r--r--    1 root     root       1811984 Apr 16 21:59 iwlwifi-8265-22.ucode
-rw-r--r--    1 root     root       2234528 Apr 16 21:59 iwlwifi-8265-27.ucode
-rw-r--r--    1 root     root       2307104 Apr 16 21:59 iwlwifi-8265-31.ucode
-rw-r--r--    1 root     root       2440780 Apr 16 21:59 iwlwifi-8265-34.ucode
-rw-r--r--    1 root     root       2436632 Apr 16 21:59 iwlwifi-8265-36.ucode
drwxr-xr-x    2 root     root          4096 Apr 16 21:59 pru/
-rw-r--r--    1 root     root          3940 Apr 16 21:59 regulatory.db
-rw-r--r--    1 root     root          1182 Apr 16 21:59 regulatory.db.p7s
drwxr-xr-x    2 root     root          4096 Apr 16 21:59 ti-connectivity/
drwxr-xr-x    2 root     root          4096 Apr 16 21:59 ti-pruss/
root@INSCOBEE-MSU:/lib# cd modules/
root@INSCOBEE-MSU:/lib/modules# ls
5.4.188
root@INSCOBEE-MSU:/lib/modules# cd 5.4.188/
root@INSCOBEE-MSU:/lib/modules/5.4.188# ll
drwxr-xr-x    2 root     root          4096 Apr 16 21:59 ./
drwxr-xr-x    3 root     root          4096 Apr 16 21:59 ../
-rw-r--r--    1 root     root          9956 Apr 16 21:59 act_gact.ko
-rw-r--r--    1 root     root         14520 Apr 16 21:59 act_mirred.ko
-rw-r--r--    1 root     root         10844 Apr 16 21:59 act_skbedit.ko
-rw-r--r--    1 root     root         24168 Apr 16 21:59 br_netfilter.ko
-rw-r--r--    1 root     root         10968 Apr 16 21:59 cls_basic.ko
-rw-r--r--    1 root     root         14736 Apr 16 21:59 cls_flow.ko
-rw-r--r--    1 root     root         11160 Apr 16 21:59 cls_fw.ko
-rw-r--r--    1 root     root         11516 Apr 16 21:59 cls_matchall.ko
-rw-r--r--    1 root     root         12384 Apr 16 21:59 cls_route.ko
-rw-r--r--    1 root     root         13268 Apr 16 21:59 cls_tcindex.ko
-rw-r--r--    1 root     root         20820 Apr 16 21:59 cls_u32.ko
-rw-r--r--    1 root     root          4360 Apr 16 21:59 crc-ccitt.ko
-rw-r--r--    1 root     root          5992 Apr 16 21:59 em_ipset.ko
-rw-r--r--    1 root     root          3604 Apr 16 21:59 em_u32.ko
-rw-r--r--    1 root     root         10232 Apr 16 21:59 ifb.ko
-rw-r--r--    1 root     root         17876 Apr 16 21:59 ip17xx.ko
-rw-r--r--    1 root     root         21888 Apr 16 21:59 ip6_tables.ko
-rw-r--r--    1 root     root          5380 Apr 16 21:59 ip6t_NPT.ko
-rw-r--r--    1 root     root          5240 Apr 16 21:59 ip6t_REJECT.ko
-rw-r--r--    1 root     root          5644 Apr 16 21:59 ip6table_filter.ko
-rw-r--r--    1 root     root          6024 Apr 16 21:59 ip6table_mangle.ko
-rw-r--r--    1 root     root          5444 Apr 16 21:59 ip6table_nat.ko
-rw-r--r--    1 root     root         42180 Apr 16 21:59 ip_set.ko
-rw-r--r--    1 root     root         13592 Apr 16 21:59 ip_set_bitmap_ip.ko
-rw-r--r--    1 root     root         13448 Apr 16 21:59 ip_set_bitmap_ipmac.ko
-rw-r--r--    1 root     root         12464 Apr 16 21:59 ip_set_bitmap_port.ko
-rw-r--r--    1 root     root         34836 Apr 16 21:59 ip_set_hash_ip.ko
-rw-r--r--    1 root     root         35004 Apr 16 21:59 ip_set_hash_ipmark.ko
-rw-r--r--    1 root     root         35796 Apr 16 21:59 ip_set_hash_ipport.ko
-rw-r--r--    1 root     root         36812 Apr 16 21:59 ip_set_hash_ipportip.ko
-rw-r--r--    1 root     root         41864 Apr 16 21:59 ip_set_hash_ipportnet.ko
-rw-r--r--    1 root     root         21040 Apr 16 21:59 ip_set_hash_mac.ko
-rw-r--r--    1 root     root         38740 Apr 16 21:59 ip_set_hash_net.ko
-rw-r--r--    1 root     root         40708 Apr 16 21:59 ip_set_hash_netiface.ko
-rw-r--r--    1 root     root         41172 Apr 16 21:59 ip_set_hash_netnet.ko
-rw-r--r--    1 root     root         40440 Apr 16 21:59 ip_set_hash_netport.ko
-rw-r--r--    1 root     root         42696 Apr 16 21:59 ip_set_hash_netportnet.ko
-rw-r--r--    1 root     root         14412 Apr 16 21:59 ip_set_list_set.ko
-rw-r--r--    1 root     root         21952 Apr 16 21:59 ip_tables.ko
-rw-r--r--    1 root     root          5240 Apr 16 21:59 ipt_ECN.ko
-rw-r--r--    1 root     root          5172 Apr 16 21:59 ipt_REJECT.ko
-rw-r--r--    1 root     root          5604 Apr 16 21:59 iptable_filter.ko
-rw-r--r--    1 root     root          5540 Apr 16 21:59 iptable_mangle.ko
-rw-r--r--    1 root     root          5436 Apr 16 21:59 iptable_nat.ko
-rw-r--r--    1 root     root          5916 Apr 16 21:59 iptable_raw.ko
-rw-r--r--    1 root     root          4672 Apr 16 21:59 libcrc32c.ko
-rw-r--r--    1 root     root         13900 Apr 16 21:59 nf_conncount.ko
-rw-r--r--    1 root     root        122512 Apr 16 21:59 nf_conntrack.ko
-rw-r--r--    1 root     root         39260 Apr 16 21:59 nf_conntrack_netlink.ko
-rw-r--r--    1 root     root          5428 Apr 16 21:59 nf_defrag_ipv4.ko
-rw-r--r--    1 root     root         14668 Apr 16 21:59 nf_defrag_ipv6.ko
-rw-r--r--    1 root     root         27320 Apr 16 21:59 nf_flow_table.ko
-rw-r--r--    1 root     root          6968 Apr 16 21:59 nf_flow_table_hw.ko
-rw-r--r--    1 root     root          8796 Apr 16 21:59 nf_log_common.ko
-rw-r--r--    1 root     root         10632 Apr 16 21:59 nf_log_ipv4.ko
-rw-r--r--    1 root     root         12284 Apr 16 21:59 nf_log_ipv6.ko
-rw-r--r--    1 root     root         37948 Apr 16 21:59 nf_nat.ko
-rw-r--r--    1 root     root          5856 Apr 16 21:59 nf_reject_ipv4.ko
-rw-r--r--    1 root     root          7452 Apr 16 21:59 nf_reject_ipv6.ko
-rw-r--r--    1 root     root         13092 Apr 16 21:59 nfnetlink.ko
-rw-r--r--    1 root     root         12684 Apr 16 21:59 pm33xx.ko
-rw-r--r--    1 root     root         15732 Apr 16 21:59 ppp_async.ko
-rw-r--r--    1 root     root         46724 Apr 16 21:59 ppp_generic.ko
-rw-r--r--    1 root     root         20816 Apr 16 21:59 pppoe.ko
-rw-r--r--    1 root     root          6052 Apr 16 21:59 pppox.ko
-rw-r--r--    1 root     root         37204 Apr 16 21:59 sch_cake.ko
-rw-r--r--    1 root     root         23528 Apr 16 21:59 sch_hfsc.ko
-rw-r--r--    1 root     root         26060 Apr 16 21:59 sch_htb.ko
-rw-r--r--    1 root     root          6972 Apr 16 21:59 sch_ingress.ko
-rw-r--r--    1 root     root         13604 Apr 16 21:59 sch_tbf.ko
-rw-r--r--    1 root     root          8252 Apr 16 21:59 slhc.ko
-rw-r--r--    1 root     root         12784 Apr 16 21:59 wkup_m3_ipc.ko
-rw-r--r--    1 root     root          8132 Apr 16 21:59 wkup_m3_rproc.ko
-rw-r--r--    1 root     root         30228 Apr 16 21:59 x_tables.ko
-rw-r--r--    1 root     root          3752 Apr 16 21:59 xt_CLASSIFY.ko
-rw-r--r--    1 root     root          8820 Apr 16 21:59 xt_CT.ko
-rw-r--r--    1 root     root          4936 Apr 16 21:59 xt_DSCP.ko
-rw-r--r--    1 root     root         10144 Apr 16 21:59 xt_FLOWOFFLOAD.ko
-rw-r--r--    1 root     root          4584 Apr 16 21:59 xt_HL.ko
-rw-r--r--    1 root     root          4468 Apr 16 21:59 xt_LOG.ko
-rw-r--r--    1 root     root          5316 Apr 16 21:59 xt_MASQUERADE.ko
-rw-r--r--    1 root     root          4672 Apr 16 21:59 xt_REDIRECT.ko
-rw-r--r--    1 root     root          8236 Apr 16 21:59 xt_TCPMSS.ko
-rw-r--r--    1 root     root          3604 Apr 16 21:59 xt_comment.ko
-rw-r--r--    1 root     root          5440 Apr 16 21:59 xt_connbytes.ko
-rw-r--r--    1 root     root          5028 Apr 16 21:59 xt_connlimit.ko
-rw-r--r--    1 root     root          6472 Apr 16 21:59 xt_connmark.ko
-rw-r--r--    1 root     root          6528 Apr 16 21:59 xt_conntrack.ko
-rw-r--r--    1 root     root          4284 Apr 16 21:59 xt_dscp.ko
-rw-r--r--    1 root     root          5380 Apr 16 21:59 xt_ecn.ko
-rw-r--r--    1 root     root          5032 Apr 16 21:59 xt_helper.ko
-rw-r--r--    1 root     root          4148 Apr 16 21:59 xt_hl.ko
-rw-r--r--    1 root     root          3848 Apr 16 21:59 xt_length.ko
-rw-r--r--    1 root     root          5528 Apr 16 21:59 xt_limit.ko
-rw-r--r--    1 root     root          3664 Apr 16 21:59 xt_mac.ko
-rw-r--r--    1 root     root          4168 Apr 16 21:59 xt_mark.ko
-rw-r--r--    1 root     root          4584 Apr 16 21:59 xt_multiport.ko
-rw-r--r--    1 root     root          7312 Apr 16 21:59 xt_nat.ko
-rw-r--r--    1 root     root         17536 Apr 16 21:59 xt_recent.ko
-rw-r--r--    1 root     root         13720 Apr 16 21:59 xt_set.ko
-rw-r--r--    1 root     root          4712 Apr 16 21:59 xt_state.ko
-rw-r--r--    1 root     root          4424 Apr 16 21:59 xt_statistic.ko
-rw-r--r--    1 root     root          4512 Apr 16 21:59 xt_tcpmss.ko
-rw-r--r--    1 root     root          5436 Apr 16 21:59 xt_tcpudp.ko
-rw-r--r--    1 root     root          6228 Apr 16 21:59 xt_time.ko
Gcc info on top of OpwnWRT Buildroot RootFS
$ ./arm-openwrt-linux-gcc -v
Reading specs from /home/am437x/work/openwrt/staging_dir/toolchain-arm_cortex-a9+vfpv3_gcc-8.4.0_musl_eabi/lib/gcc/arm-openwrt-linux-muslgnueabi/8.4.0/specs
COLLECT_GCC=./arm-openwrt-linux-gcc
COLLECT_LTO_WRAPPER=/home/am437x/work/openwrt/staging_dir/toolchain-arm_cortex-a9+vfpv3_gcc-8.4.0_musl_eabi/libexec/gcc/arm-openwrt-linux-muslgnueabi/8.4.0/lto-wrapper
Target: arm-openwrt-linux-muslgnueabi
Configured with: /home/am437x/work/openwrt/build_dir/toolchain-arm_cortex-a9+vfpv3_gcc-8.4.0_musl_eabi/gcc-8.4.0/configure --with-bugurl=http://bugs.openwrt.org/ --with-pkgversion='OpenWrt GCC 8.4.0 r16554-1d4dea6d4f' --prefix=/home/am437x/work/openwrt/staging_dir/toolchain-arm_cortex-a9+vfpv3_gcc-8.4.0_musl_eabi --build=x86_64-pc-linux-gnu --host=x86_64-pc-linux-gnu --target=arm-openwrt-linux-muslgnueabi --with-gnu-ld --enable-target-optspace --disable-libgomp --disable-libmudflap --disable-multilib --disable-libmpx --disable-nls --disable-libssp --without-isl --without-cloog --with-host-libstdcxx=-lstdc++ --with-gmp=/home/am437x/work/openwrt/staging_dir/host --with-mpfr=/home/am437x/work/openwrt/staging_dir/host --with-mpc=/home/am437x/work/openwrt/staging_dir/host --disable-decimal-float --with-diagnostics-color=auto-if-env --enable-__cxa_atexit --disable-libstdcxx-dual-abi --with-default-libstdcxx-abi=new --with-cpu=cortex-a9 --with-fpu=vfpv3 --with-float=hard --with-headers=/home/am437x/work/openwrt/staging_dir/toolchain-arm_cortex-a9+vfpv3_gcc-8.4.0_musl_eabi/include --enable-languages=c,c++ --enable-shared --enable-threads --with-slibdir=/home/am437x/work/openwrt/staging_dir/toolchain-arm_cortex-a9+vfpv3_gcc-8.4.0_musl_eabi/lib --enable-lto --with-libelf=/home/am437x/work/openwrt/staging_dir/host --disable-libsanitizer
Thread model: posix
0535.dts.zip
Could you please help to solve this rtcwake failure on custom bootloader and kernel combination?
Jack
  • Hi Jack,
    I am not sure I fully understand this. Does the customer have a passing and failing cases? Please elaborate.
    Can you please attach the full kernel boot log for the failing case?
  • Hi Bin Liu.
    Their issue is 100% reproducible. I would attach the full booting log tomorrow as I am out of office today.
    Thanks.
    Jack
  • Hi Bin Liu
    Please look at the full booting log.
    <debug_uart>
    U-Boot SPL 2020.01-dirty (Apr 16 2022 - 12:59:34 +0000)
    WDT:   Not found!
    Trying to boot from MMC1
    N: mmc_dev=0
    CMD_SEND:0
                    ARG                      0x00000000
                    MMC_RSP_NONE
    CMD_SEND:8
                    ARG                      0x000001aa
                    RET                      -110
    CMD_SEND:55
                    ARG                      0x00000000
                    RET                      -110
    CMD_SEND:0
                    ARG                      0x00000000
                    MMC_RSP_NONE
    CMD_SEND:1
                    ARG                      0x00000000
                    MMC_RSP_R3,4             0x40ff8080
    CMD_SEND:1
                    ARG                      0x40300080
    CMD_SEND:0
                    ARG                      0x00000000
                    MMC_RSP_NONE
    CMD_SEND:1
                    ARG                      0x40300080
    CMD_SEND:1
                    ARG                      0x40300080
    CMD_SEND:1
                    ARG                      0x40300080
                    MMC_RSP_R3,4             0xc0ff8080
    CMD_SEND:2
                    ARG                      0x00000000
                    MMC_RSP_R2               0x89010065
                                             0x4d4d4320
                                             0x20012618
                                             0x01212553
                                            DUMPING DATA
                                            000 - 89 01 00 65
                                            004 - 4d 4d 43 20
                                            008 - 20 01 26 18
                                            012 - 01 21 25 53
    CMD_SEND:3
                    ARG                      0x00010000
                    MMC_RSP_R1,5,6,7         0x00000500
    CMD_SEND:9
                    ARG                      0x00010000
                    MMC_RSP_R2               0xd0270132
                                             0x0f5903ff
                                             0xffffffef
                                             0x8a4040d3
                                            DUMPING DATA
                                            000 - d0 27 01 32
                                            004 - 0f 59 03 ff
                                            008 - ff ff ff ef
                                            012 - 8a 40 40 d3
    CMD_SEND:7
                    ARG                      0x00010000
                    MMC_RSP_R1,5,6,7         0x00000700
    CMD_SEND:8
                    ARG                      0x00000000
                    MMC_RSP_R1,5,6,7         0x00000900
    CMD_SEND:6
                    ARG                      0x03b70100
                    MMC_RSP_R1b              0x00000900
    CMD_SEND:13
                    ARG                      0x00010000
    CURR STATE:4
    CMD_SEND:6
                    ARG                      0x03b90100
    CMD_SEND:13
                    ARG                      0x00010000
    CURR STATE:4
    CMD_SEND:8
                    ARG                      0x00000000
    CMD_SEND:8
                    ARG                      0x00000000
    N: boot_mode=2
    spl: mmc boot mode: fs
    N: __func__ 1
    SPL: Please implement spl_start_uboot() for your board
    SPL: Direct Linux boot not active!
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000800
    N: spl_load_image_fat 1, devnum=0, partition=1, err=0
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000800
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x000008a4
    CMD_SEND:12
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000958
    N: file_fat_read ret=64
    N: Found FIT
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000800
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x000008a4
    CMD_SEND:12
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x00000958
    CMD_SEND:12
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x0000095b
    fit read sector 0, sectors=1604, dst=807ff980, count=1604, size=0x644
    N: images=140
    N: spl_load_fit_image 1
    N: spl_load_fit_image 2, external_data=1
    N: spl_load_fit_image 3
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000800
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x000008a4
    CMD_SEND:12
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x00000958
    CMD_SEND:12
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x00000804
    CMD_SEND:12
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x0000095c
    CMD_SEND:12
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000cf0
    N: External data: dst=80800000, offset=644, size=72ac4
    Image OS is U-Boot
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000800
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x000008a4
    CMD_SEND:12
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x00000804
    CMD_SEND:12
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x00000d34
    CMD_SEND:12
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x00000d38
    CMD_SEND:12
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000d82
    N: External data: dst=80872b00, offset=7bca0, size=9864
    N: spl_load_simple_fit 1
    N: spl_load_simple_fit 2
    N:spl_mmc_load, 111 err=0
    U-Boot 2020.01-dirty (Apr 16 2022 - 12:59:34 +0000)
    CPU  : AM437X-GP rev 1.2
    Model: TI AM437x SK EVM
    DRAM:  2 GiB
    PMIC:  TPS65218
    MMC:   OMAP SD/MMC: 0
    Loading Environment from FAT... CMD_SEND:0
                    ARG                      0x00000000
                    MMC_RSP_NONE
    CMD_SEND:8
                    ARG                      0x000001aa
                    RET                      -110
    CMD_SEND:55
                    ARG                      0x00000000
                    RET                      -110
    CMD_SEND:0
                    ARG                      0x00000000
                    MMC_RSP_NONE
    CMD_SEND:1
                    ARG                      0x00000000
    CMD_SEND:1
                    ARG                      0x40300080
    CMD_SEND:0
                    ARG                      0x00000000
                    MMC_RSP_NONE
    CMD_SEND:1
                    ARG                      0x40300080
    CMD_SEND:1
                    ARG                      0x40300080
    CMD_SEND:1
                    ARG                      0x40300080
    CMD_SEND:2
                    ARG                      0x00000000
                                             0x4d4d4320
                                             0x20012618
                                             0x01212553
                                            DUMPING DATA
                                            000 - 89 01 00 65
                                            004 - 4d 4d 43 20
                                            008 - 20 01 26 18
                                            012 - 01 21 25 53
    CMD_SEND:3
                    ARG                      0x00010000
    CMD_SEND:9
                    ARG                      0x00010000
                                             0x0f5903ff
                                             0xffffffef
                                             0x8a4040d3
                                            DUMPING DATA
                                            000 - d0 27 01 32
                                            004 - 0f 59 03 ff
                                            008 - ff ff ff ef
                                            012 - 8a 40 40 d3
    CMD_SEND:7
                    ARG                      0x00010000
    CMD_SEND:8
                    ARG                      0x00000000
    CMD_SEND:6
                    ARG                      0x03b70100
    CMD_SEND:13
                    ARG                      0x00010000
    CURR STATE:4
    CMD_SEND:6
                    ARG                      0x03b90100
    CMD_SEND:13
                    ARG                      0x00010000
    CURR STATE:4
    CMD_SEND:8
                    ARG                      0x00000000
    CMD_SEND:8
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000800
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x000008a4
    CMD_SEND:12
                    ARG                      0x00000000
    *** Warning - bad CRC, using default environment
    Net:
    Warning: ethernet@4a100000 using MAC address from ROM
    eth0: ethernet@4a100000
    Hit any key to stop autoboot:  0
    CMD_SEND:0
                    ARG                      0x00000000
                    MMC_RSP_NONE
    CMD_SEND:8
                    ARG                      0x000001aa
                    RET                      -110
    CMD_SEND:55
                    ARG                      0x00000000
                    RET                      -110
    CMD_SEND:0
                    ARG                      0x00000000
                    MMC_RSP_NONE
    CMD_SEND:1
                    ARG                      0x00000000
    CMD_SEND:1
                    ARG                      0x40300080
    CMD_SEND:0
                    ARG                      0x00000000
                    MMC_RSP_NONE
    CMD_SEND:1
                    ARG                      0x40300080
    CMD_SEND:1
                    ARG                      0x40300080
    CMD_SEND:1
                    ARG                      0x40300080
    CMD_SEND:2
                    ARG                      0x00000000
                                             0x4d4d4320
                                             0x20012618
                                             0x01212553
                                            DUMPING DATA
                                            000 - 89 01 00 65
                                            004 - 4d 4d 43 20
                                            008 - 20 01 26 18
                                            012 - 01 21 25 53
    CMD_SEND:3
                    ARG                      0x00010000
    CMD_SEND:9
                    ARG                      0x00010000
                                             0x0f5903ff
                                             0xffffffef
                                             0x8a4040d3
                                            DUMPING DATA
                                            000 - d0 27 01 32
                                            004 - 0f 59 03 ff
                                            008 - ff ff ff ef
                                            012 - 8a 40 40 d3
    CMD_SEND:7
                    ARG                      0x00010000
    CMD_SEND:8
                    ARG                      0x00000000
    CMD_SEND:6
                    ARG                      0x03b70100
    CMD_SEND:13
                    ARG                      0x00010000
    CURR STATE:4
    CMD_SEND:6
                    ARG                      0x03b90100
    CMD_SEND:13
                    ARG                      0x00010000
    CURR STATE:4
    CMD_SEND:8
                    ARG                      0x00000000
    CMD_SEND:8
                    ARG                      0x00000000
    switch to partitions #0, OK
    mmc0(part 0) is current device
    CMD_SEND:0
                    ARG                      0x00000000
                    MMC_RSP_NONE
    CMD_SEND:8
                    ARG                      0x000001aa
                    RET                      -110
    CMD_SEND:55
                    ARG                      0x00000000
                    RET                      -110
    CMD_SEND:0
                    ARG                      0x00000000
                    MMC_RSP_NONE
    CMD_SEND:1
                    ARG                      0x00000000
    CMD_SEND:1
                    ARG                      0x40300080
    CMD_SEND:0
                    ARG                      0x00000000
                    MMC_RSP_NONE
    CMD_SEND:1
                    ARG                      0x40300080
    CMD_SEND:1
                    ARG                      0x40300080
    CMD_SEND:1
                    ARG                      0x40300080
    CMD_SEND:2
                    ARG                      0x00000000
                                             0x4d4d4320
                                             0x20012618
                                             0x01212553
                                            DUMPING DATA
                                            000 - 89 01 00 65
                                            004 - 4d 4d 43 20
                                            008 - 20 01 26 18
                                            012 - 01 21 25 53
    CMD_SEND:3
                    ARG                      0x00010000
    CMD_SEND:9
                    ARG                      0x00010000
                                             0x0f5903ff
                                             0xffffffef
                                             0x8a4040d3
                                            DUMPING DATA
                                            000 - d0 27 01 32
                                            004 - 0f 59 03 ff
                                            008 - ff ff ff ef
                                            012 - 8a 40 40 d3
    CMD_SEND:7
                    ARG                      0x00010000
    CMD_SEND:8
                    ARG                      0x00000000
    CMD_SEND:6
                    ARG                      0x03b70100
    CMD_SEND:13
                    ARG                      0x00010000
    CURR STATE:4
    CMD_SEND:6
                    ARG                      0x03b90100
    CMD_SEND:13
                    ARG                      0x00010000
    CURR STATE:4
    CMD_SEND:8
                    ARG                      0x00000000
    CMD_SEND:8
                    ARG                      0x00000000
    SD/MMC found on device 0
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000800
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000800
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x000008a4
    CMD_SEND:12
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000800
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000800
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x000008a4
    CMD_SEND:12
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00002c20
    358 bytes read in 46 ms (6.8 KiB/s)
    Loaded env from uEnv.txt
    Importing environment from mmc0 ...
    Running uenvcmd ...
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000800
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000800
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x000008a4
    CMD_SEND:12
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x00000e20
    CMD_SEND:12
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x00000804
    CMD_SEND:12
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x00000e24
    CMD_SEND:12
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000eac
    69934 bytes read in 106 ms (643.6 KiB/s)
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000800
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000800
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x000008a4
    CMD_SEND:12
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x00000804
    CMD_SEND:12
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x0000080a
    CMD_SEND:12
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x00000eb0
    CMD_SEND:12
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00002c09
    3846736 bytes read in 295 ms (12.4 MiB/s)
       Loading Device Tree to 8ffeb000, end 8ffff12d ... OK
    Starting kernel ...
    [    0.000000] Linux version 5.4.188 (am437x@4bfebc466fc7) (gcc version 8.4.0 (OpenWrt GCC 8.4.0 r16554-1d4dea6d4f)) #0 PREEMPT Sat Apr 16 12:59:34 2022
    [    0.000000] Kernel command line: consoleblank=0 no_console_suspend=1 console=ttyS0,115200n8 root=/dev/mmcblk0p2 noinitrd rootwait rootfstype=ext4
    [    0.000000] Memory: 2015600K/2097148K available (8192K kernel code, 325K rwdata, 2148K rodata, 1024K init, 248K bss, 32396K reserved, 49152K cma-reserved, 1261564K highmem)
    [    0.000014] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
    [    0.000030] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
    [    0.000039] OMAP clocksource: timer1 at 24000000 Hz
    [    0.000454] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
    [    0.000463] OMAP clocksource: 32k_counter at 32768 Hz
    [    0.000911] Console: colour dummy device 80x30
    [    0.000972] Calibrating delay loop... 1987.37 BogoMIPS (lpj=9936896)
    [    0.060356] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
    [    0.060377] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
    [    0.061193] CPU: Testing write buffer coherency: ok
    [    0.062073] Setting up static identity map for 0x80100000 - 0x80100060
    [    0.062213] rcu: Hierarchical SRCU implementation.
    [    0.073457] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
    [    0.073832] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    [    0.073855] futex hash table entries: 256 (order: -1, 3072 bytes, linear)
    [    0.076947] pinctrl core: initialized pinctrl subsystem
    [    0.078086] NET: Registered protocol family 16
    [    0.079727] DMA: preallocated 256 KiB pool for atomic coherent allocations
    [    0.100598] cpuidle: using governor ladder
    [    0.100635] cpuidle: using governor menu
    [    0.118503] No ATAGs?
    [    0.132821] edma 49000000.edma: TI EDMA DMA engine driver
    [    0.134353] iommu: Default domain type: Translated
    [    0.135820] SCSI subsystem initialized
    [    0.136043] usbcore: registered new interface driver usbfs
    [    0.136086] usbcore: registered new interface driver hub
    [    0.136129] usbcore: registered new device driver usb
    [    0.136658] pps_core: LinuxPPS API ver. 1 registered
    [    0.136666] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.136686] PTP clock support registered
    [    0.136720] EDAC MC: Ver: 3.0.0
    [    0.138626] clocksource: Switched to clocksource timer1
    [    0.143381] thermal_sys: Registered thermal governor 'fair_share'
    [    0.143387] thermal_sys: Registered thermal governor 'bang_bang'
    [    0.143401] thermal_sys: Registered thermal governor 'step_wise'
    [    0.143405] thermal_sys: Registered thermal governor 'user_space'
    [    0.143410] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.144023] NET: Registered protocol family 2
    [    0.144353] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.145290] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
    [    0.145319] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
    [    0.145378] TCP bind hash table entries: 8192 (order: 3, 32768 bytes, linear)
    [    0.145451] TCP: Hash tables configured (established 8192 bind 8192)
    [    0.145625] UDP hash table entries: 512 (order: 1, 8192 bytes, linear)
    [    0.145648] UDP-Lite hash table entries: 512 (order: 1, 8192 bytes, linear)
    [    0.145771] NET: Registered protocol family 1
    [    0.146298] RPC: Registered named UNIX socket transport module.
    [    0.146309] RPC: Registered udp transport module.
    [    0.146314] RPC: Registered tcp transport module.
    [    0.146319] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.147600] Initialise system trusted keyrings
    [    0.147881] workingset: timestamp_bits=14 max_order=19 bucket_order=5
    [    0.152559] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.153260] NFS: Registering the id_resolver key type
    [    0.153300] Key type id_resolver registered
    [    0.153306] Key type id_legacy registered
    [    0.153345] ntfs: driver 2.1.32 [Flags: R/O].
    [    0.153894] Key type asymmetric registered
    [    0.153906] Asymmetric key parser 'x509' registered
    [    0.153954] bounce: pool size: 64 pages
    [    0.153999] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
    [    0.154197] io scheduler mq-deadline registered
    [    0.154208] io scheduler kyber registered
    [    0.158459] OMAP GPIO hardware version 0.1
    [    0.183241] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
    [    0.217585] pinctrl-single 44e10800.pinmux: 199 pins, size 796
    [    0.246482] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    0.249607] omap8250 44e09000.serial: No clock speed specified: using default: 48000000
    [    0.250255] printk: console [ttyS0] disabled
    [    0.250354] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 66, base_baud = 3000000) is a 8250
    [    0.864814] printk: console [ttyS0] enabled
    [    0.869687] omap8250 48022000.serial: No clock speed specified: using default: 48000000
    [    0.878330] 48022000.serial: ttyS1 at MMIO 0x48022000 (irq = 72, base_baud = 3000000) is a 8250
    [    0.887674] omap8250 48024000.serial: No clock speed specified: using default: 48000000
    [    0.896359] 48024000.serial: ttyS2 at MMIO 0x48024000 (irq = 73, base_baud = 3000000) is a 8250
    [    0.905721] omap8250 481a6000.serial: No clock speed specified: using default: 48000000
    [    0.914399] 481a6000.serial: ttyS3 at MMIO 0x481a6000 (irq = 80, base_baud = 3000000) is a 8250
    [    0.923706] omap8250 481a8000.serial: No clock speed specified: using default: 48000000
    [    0.932332] 481a8000.serial: ttyS4 at MMIO 0x481a8000 (irq = 81, base_baud = 3000000) is a 8250
    [    0.941655] omap8250 481aa000.serial: No clock speed specified: using default: 48000000
    [    0.950316] 481aa000.serial: ttyS5 at MMIO 0x481aa000 (irq = 82, base_baud = 3000000) is a 8250
    [    0.961389] omap_rng 48310000.rng: Random Number Generator ver. 20
    [    0.968875] random: fast init done
    [    0.972531] crng init done
    [    0.984435] brd: module loaded
    [    0.996379] loop: module loaded
    [    1.058658] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6, bus freq 1000000
    [    1.067372] Probing for 175d address: 4
    [    1.072190] davinci_mdio 4a101000.mdio: phy[4]: device 4a101000.mdio:04, driver ICPlus IP175D
    [    1.080852] davinci_mdio 4a101000.mdio: phy[5]: device 4a101000.mdio:05, driver unknown
    [    1.089208] cpsw 4a100000.ethernet: initialized cpsw ale version 1.4
    [    1.095594] cpsw 4a100000.ethernet: ALE Table size 1024
    [    1.101014] cpsw 4a100000.ethernet: cpts: overflow check period 500 (jiffies)
    [    1.108230] cpsw 4a100000.ethernet: Detected MACID = e0:ff:f1:af:02:f1
    [    1.115565] cpsw 4a100000.ethernet: cpsw: Detected MACID = e0:ff:f1:af:02:f3
    [    1.123519] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    [    1.131056] usbcore: registered new interface driver cdc_acm
    [    1.136744] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
    [    1.146867] omap_rtc 44e3e000.rtc: registered as rtc0
    [    1.152244] i2c /dev entries driver
    [    1.159524] /cpus/cpu@0: unsupported enable-method property: ti,am4372
    [    1.166617] sdhci: Secure Digital Host Controller Interface driver
    [    1.172866] sdhci: Copyright(c) Pierre Ossman
    [    1.178372] omap_gpio 44e07000.gpio: Could not set line 6 debounce to 200000 microseconds (-22)
    [    1.187152] omap_hsmmc 48060000.mmc: Got CD GPIO
    [    1.199213] omap_gpio 481ae000.gpio: Could not set line 15 debounce to 200000 microseconds (-22)
    [    1.208046] omap_hsmmc 481d8000.mmc: Got CD GPIO
    [    1.219264] omap_hsmmc 47810000.mmc: RX DMA channel request failed
    [    1.225747] sdhci-pltfm: SDHCI platform and OF driver helper
    [    1.232822] ledtrig-cpu: registered to indicate activity on CPUs
    [    1.241877] NET: Registered protocol family 10
    [    1.247575] Segment Routing with IPv6
    [    1.251459] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
    [    1.258030] NET: Registered protocol family 17
    [    1.262643] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
    [    1.275739] 8021q: 802.1Q VLAN Support v1.8
    [    1.280001] Key type dns_resolver registered
    [    1.284463] omap_voltage_late_init: Voltage driver support not added
    [    1.291349] Loading compiled-in X.509 certificates
    [    1.341338] tps6521x_pwrbutton tps65218-pwrbutton.1.auto: DMA mask not set
    [    1.349072] input: tps65218_pwrbutton as /devices/platform/44000000.ocp/44c00000.interconnect/44c00000.interconnect:segment@200000/44e0b000.target-module/44e0b000.i2c/i2c-0/0-0024/tps65218-pwrbutton.1.auto/input/input0
    [    1.383176] omap_i2c 44e0b000.i2c: bus 0 rev0.12 at 100 kHz
    [    1.390102] omap_i2c 4802a000.i2c: bus 1 rev0.12 at 400 kHz
    [    1.396581] omap_i2c 4819c000.i2c: bus 2 rev0.12 at 400 kHz
    [    1.404922] omap_gpio 44e07000.gpio: Could not set line 6 debounce to 200000 microseconds (-22)
    [    1.413786] omap_hsmmc 48060000.mmc: Got CD GPIO
    [    1.445529] omap_gpio 481ae000.gpio: Could not set line 15 debounce to 200000 microseconds (-22)
    [    1.454420] omap_hsmmc 481d8000.mmc: Got CD GPIO
    [    1.491003] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01T00:00:00 UTC (946684800)
    [    1.503161] Waiting for root device /dev/mmcblk0p2...
    [    1.559241] mmc0: new high speed MMC card at address 0001
    [    1.566000] mmcblk0: mmc0:0001 eMMC   3.64 GiB
    [    1.571220] mmcblk0boot0: mmc0:0001 eMMC   partition 1 4.00 MiB
    [    1.577681] mmcblk0boot1: mmc0:0001 eMMC   partition 2 4.00 MiB
    [    1.583956] mmcblk0rpmb: mmc0:0001 eMMC   partition 3 4.00 MiB, chardev (246:0)
    [    1.595894]  mmcblk0: p1 p2 p3
    [    1.629578] EXT4-fs (mmcblk0p2): mounted filesystem without journal. Opts: (null)
    [    1.637185] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [    1.646444] Freeing unused kernel memory: 1024K
    [    1.651195] Run /sbin/init as init process
    [    1.755701] init: Console is alive
    [    1.907412] kmodloader: loading kernel modules from /etc/modules-boot.d/*
    [    1.919668] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
    [    1.937390] init: - preinit -
    [    2.167456] cpsw 4a100000.ethernet: initializing cpsw version 1.15 (0)
    [    2.177306] Resetting master bus...
    [    2.180901] Found my OF Node
    [    2.183797] VLAN Setup is 1
    [    2.208885] Full reset performed
    [    2.212251] ICPlus IP175D 4a101000.mdio:04: attached PHY driver [ICPlus IP175D] (mii_bus:phy_addr=4a101000.mdio:04, irq=POLL)
    [    2.230640] 8021q: adding VLAN 0 to HW filter on device eth0
    Press the [f] key and hit [enter] to enter failsafe mode
    Press the [1], [2], [3] or [4] key and hit [enter] to select the debug level
    [    6.385812] mount_root: mounting /dev/root
    [    6.390710] EXT4-fs (mmcblk0p2): warning: mounting unchecked fs, running e2fsck is recommended
    [    6.461189] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    [    6.468165] urandom-seed: Seeding with /etc/urandom.seed
    [    6.515042] procd: - early -
    [    7.282078] procd: - ubus -
    [    7.340288] procd: - init -
    Please press Enter to activate this console.
    [    7.720064] kmodloader: loading kernel modules from /etc/modules.d/*
    [    7.741152] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
    [    7.763179] remoteproc remoteproc0: wkup_m3 is available
    [    7.776930] urngd: v1.0.2 started.
    [    7.781779] remoteproc remoteproc0: powering up wkup_m3
    [    7.795150] PM: Cannot get wkup_m3_ipc handle
    [    7.810943] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 217168
    [    7.844988] remoteproc remoteproc0: remote processor wkup_m3 is now up
    [    7.851630] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x193
    [    7.971474] GACT probability on
    [    7.976027] Mirror/redirect action on
    [    7.993421] u32 classifier
    [    7.996156]     input device check on
    [    7.999953]     Actions configured
    [    8.031330] Bridge firewalling registered
    [    8.105269] xt_time: kernel timezone is -0000
    [    8.118084] PPP generic driver version 2.4.2
    [    8.124483] NET: Registered protocol family 24
    [    8.132549] kmodloader: done loading kernel modules from /etc/modules.d/*
    [   10.171079] xt_CT: No such helper "snmp"
    [   11.516372] net eth1: initializing cpsw version 1.15 (0)
    [   11.554590] Generic PHY 4a101000.mdio:05: attached PHY driver [Generic PHY] (mii_bus:phy_addr=4a101000.mdio:05, irq=POLL)
    [   11.580261] cpsw 4a100000.ethernet eth1: Link is Up - 100Mbps/Full - flow control off
    [   11.595745] 8021q: adding VLAN 0 to HW filter on device eth1
    [   11.614875] net eth1: Adding vlanid 3 to vlan filter
    [   11.682595] net eth1: Adding vlanid 4 to vlan filter
    [   11.781104] cpsw 4a100000.ethernet: initializing cpsw version 1.15 (0)
    [   11.823700] ICPlus IP175D 4a101000.mdio:04: attached PHY driver [ICPlus IP175D] (mii_bus:phy_addr=4a101000.mdio:04, irq=POLL)
    [   11.890709] 8021q: adding VLAN 0 to HW filter on device eth0
    [   12.795300] xt_CT: No such helper "snmp"
    [   13.565213] xt_CT: No such helper "snmp"
    [   13.659350] INSCOBEE MSU Starting...
    [   13.673638] mount mmcblk0p3
    [   13.897287] EXT4-fs (mmcblk0p3): recovery complete
    [   13.977689] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null)
    [   14.475697] xt_CT: No such helper "snmp"
    [   15.044849] kmcu run...
    [   31.849015] vmmcwl_fixed: disabling
    BusyBox v1.33.2 (2022-04-16 12:59:34 UTC) built-in shell (ash)
    | This system have to access authorized user and only use for  |
    | officially. During using equipment, privacy of individuals   |
    | is not guaranteed.                                           |
    | All access and usage is monitored and recorded and can be    |
    | provided evidance as court or related organization.          |
    | Use of this system constitutes consent to monitoring for     |
    | these purposed.                                              |
        INSCOBEE MSU V1.0 by OpenWrt 21.02.3, r16554-1d4dea6d4f
    APHOME set to /data/kmcu
    APREL set to /data/kmcu/r10
    APUSER set to root
    kernel.core_pattern = /data/kmcu/core.%e
    root@INSCOBEE-MSU:/# rtcwake -s 10 -d /dev/rtc0 -m mem
    wakeup from "mem" at Mon Aug  1 00:04:34 2022
    [  286.559058] PM: suspend entry (deep)
    [  286.564768] Filesystems sync: 0.001 seconds
    [  286.575656] Freezing user space processes ... (elapsed 0.003 seconds) done.
    [  286.586199] OOM killer disabled.
    [  286.589705] Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
    [  286.613730] cpsw 4a100000.ethernet eth1: Link is Down
    [  286.627439] PM: suspend devices took 0.020 seconds
    <debug_uart>
    WDT:   Not found!
    N: mmc_dev=0
    CMD_SEND:0
                    ARG                      0x00000000
                    MMC_RSP_NONE
    CMD_SEND:8
                    ARG                      0x000001aa
                    RET                      -110
    CMD_SEND:55
                    ARG                      0x00000000
                    RET                      -110
    CMD_SEND:0
                    ARG                      0x00000000
                    MMC_RSP_NONE
    CMD_SEND:1
                    ARG                      0x00000000
    CMD_SEND:1
                    ARG                      0x40300080
    CMD_SEND:0
                    ARG                      0x00000000
                    MMC_RSP_NONE
    CMD_SEND:1
                    ARG                      0x40300080
    CMD_SEND:1
                    ARG                      0x40300080
    CMD_SEND:1
                    ARG                      0x40300080
    CMD_SEND:2
                    ARG                      0x00000000
                                             0x4d4d4320
                                             0x20012618
                                             0x01212553
                                            DUMPING DATA
                                            000 - 89 01 00 65
                                            004 - 4d 4d 43 20
                                            008 - 20 01 26 18
                                            012 - 01 21 25 53
    CMD_SEND:3
                    ARG                      0x00010000
    CMD_SEND:9
                    ARG                      0x00010000
                                             0x0f5903ff
                                             0xffffffef
                                             0x8a4040d3
                                            DUMPING DATA
                                            000 - d0 27 01 32
                                            004 - 0f 59 03 ff
                                            008 - ff ff ff ef
                                            012 - 8a 40 40 d3
    CMD_SEND:7
                    ARG                      0x00010000
    CMD_SEND:8
                    ARG                      0x00000000
    CMD_SEND:6
                    ARG                      0x03b70100
    CMD_SEND:13
                    ARG                      0x00010000
    CURR STATE:4
    CMD_SEND:6
                    ARG                      0x03b90100
    CMD_SEND:13
                    ARG                      0x00010000
    CURR STATE:4
    CMD_SEND:8
                    ARG                      0x00000000
    CMD_SEND:8
                    ARG                      0x00000000
    N: boot_mode=2
    N: __func__ 1
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000800
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000800
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x000008a4
    CMD_SEND:12
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000958
    N: Found FIT
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000800
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x000008a4
    CMD_SEND:12
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x00000958
    CMD_SEND:12
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x0000095b
    N: images=140
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000800
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x000008a4
    CMD_SEND:12
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x00000958
    CMD_SEND:12
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x00000804
    CMD_SEND:12
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x0000095c
    CMD_SEND:12
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000cf0
    Image OS is U-Boot
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000800
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x000008a4
    CMD_SEND:12
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x00000804
    CMD_SEND:12
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x00000d34
    CMD_SEND:12
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x00000d38
    CMD_SEND:12
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000d82
    DRAM:  2 GiB
    PMIC:  TPS65218
    MMC:   OMAP SD/MMC: 0
                    ARG                      0x00000000
                    MMC_RSP_NONE
    CMD_SEND:8
                    ARG                      0x000001aa
                    RET                      -110
    CMD_SEND:55
                    ARG                      0x00000000
                    RET                      -110
    CMD_SEND:0
                    ARG                      0x00000000
                    MMC_RSP_NONE
    CMD_SEND:1
                    ARG                      0x00000000
    CMD_SEND:1
                    ARG                      0x40300080
    CMD_SEND:0
                    ARG                      0x00000000
                    MMC_RSP_NONE
    CMD_SEND:1
                    ARG                      0x40300080
    CMD_SEND:1
                    ARG                      0x40300080
    CMD_SEND:1
                    ARG                      0x40300080
    CMD_SEND:2
                    ARG                      0x00000000
                                             0x4d4d4320
                                             0x20012618
                                             0x01212553
                                            DUMPING DATA
                                            000 - 89 01 00 65
                                            004 - 4d 4d 43 20
                                            008 - 20 01 26 18
                                            012 - 01 21 25 53
    CMD_SEND:3
                    ARG                      0x00010000
    CMD_SEND:9
                    ARG                      0x00010000
                                             0x0f5903ff
                                             0xffffffef
                                             0x8a4040d3
                                            DUMPING DATA
                                            000 - d0 27 01 32
                                            004 - 0f 59 03 ff
                                            008 - ff ff ff ef
                                            012 - 8a 40 40 d3
    CMD_SEND:7
                    ARG                      0x00010000
    CMD_SEND:8
                    ARG                      0x00000000
    CMD_SEND:6
                    ARG                      0x03b70100
    CMD_SEND:13
                    ARG                      0x00010000
    CURR STATE:4
    CMD_SEND:6
                    ARG                      0x03b90100
    CMD_SEND:13
                    ARG                      0x00010000
    CURR STATE:4
    CMD_SEND:8
                    ARG                      0x00000000
    CMD_SEND:8
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000800
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x000008a4
    CMD_SEND:12
                    ARG                      0x00000000
    Net:
    CMD_SEND:0
                    ARG                      0x00000000
                    MMC_RSP_NONE
    CMD_SEND:8
                    ARG                      0x000001aa
                    RET                      -110
    CMD_SEND:55
                    ARG                      0x00000000
                    RET                      -110
    CMD_SEND:0
                    ARG                      0x00000000
                    MMC_RSP_NONE
    CMD_SEND:1
                    ARG                      0x00000000
    CMD_SEND:1
                    ARG                      0x40300080
    CMD_SEND:0
                    ARG                      0x00000000
                    MMC_RSP_NONE
    CMD_SEND:1
                    ARG                      0x40300080
    CMD_SEND:1
                    ARG                      0x40300080
    CMD_SEND:1
                    ARG                      0x40300080
    CMD_SEND:2
                    ARG                      0x00000000
                                             0x4d4d4320
                                             0x20012618
                                             0x01212553
                                            DUMPING DATA
                                            000 - 89 01 00 65
                                            004 - 4d 4d 43 20
                                            008 - 20 01 26 18
                                            012 - 01 21 25 53
    CMD_SEND:3
                    ARG                      0x00010000
    CMD_SEND:9
                    ARG                      0x00010000
                                             0x0f5903ff
                                             0xffffffef
                                             0x8a4040d3
                                            DUMPING DATA
                                            000 - d0 27 01 32
                                            004 - 0f 59 03 ff
                                            008 - ff ff ff ef
                                            012 - 8a 40 40 d3
    CMD_SEND:7
                    ARG                      0x00010000
    CMD_SEND:8
                    ARG                      0x00000000
    CMD_SEND:6
                    ARG                      0x03b70100
    CMD_SEND:13
                    ARG                      0x00010000
    CURR STATE:4
    CMD_SEND:6
                    ARG                      0x03b90100
    CMD_SEND:13
                    ARG                      0x00010000
    CURR STATE:4
    CMD_SEND:8
                    ARG                      0x00000000
    CMD_SEND:8
                    ARG                      0x00000000
    CMD_SEND:0
                    ARG                      0x00000000
                    MMC_RSP_NONE
    CMD_SEND:8
                    ARG                      0x000001aa
                    RET                      -110
    CMD_SEND:55
                    ARG                      0x00000000
                    RET                      -110
    CMD_SEND:0
                    ARG                      0x00000000
                    MMC_RSP_NONE
    CMD_SEND:1
                    ARG                      0x00000000
    CMD_SEND:1
                    ARG                      0x40300080
    CMD_SEND:0
                    ARG                      0x00000000
                    MMC_RSP_NONE
    CMD_SEND:1
                    ARG                      0x40300080
    CMD_SEND:1
                    ARG                      0x40300080
    CMD_SEND:1
                    ARG                      0x40300080
    CMD_SEND:2
                    ARG                      0x00000000
                                             0x4d4d4320
                                             0x20012618
                                             0x01212553
                                            DUMPING DATA
                                            000 - 89 01 00 65
                                            004 - 4d 4d 43 20
                                            008 - 20 01 26 18
                                            012 - 01 21 25 53
    CMD_SEND:3
                    ARG                      0x00010000
    CMD_SEND:9
                    ARG                      0x00010000
                                             0x0f5903ff
                                             0xffffffef
                                             0x8a4040d3
                                            DUMPING DATA
                                            000 - d0 27 01 32
                                            004 - 0f 59 03 ff
                                            008 - ff ff ff ef
                                            012 - 8a 40 40 d3
    CMD_SEND:7
                    ARG                      0x00010000
    CMD_SEND:8
                    ARG                      0x00000000
    CMD_SEND:6
                    ARG                      0x03b70100
    CMD_SEND:13
                    ARG                      0x00010000
    CURR STATE:4
    CMD_SEND:6
                    ARG                      0x03b90100
    CMD_SEND:13
                    ARG                      0x00010000
    CURR STATE:4
    CMD_SEND:8
                    ARG                      0x00000000
    CMD_SEND:8
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000800
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000800
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x000008a4
    CMD_SEND:12
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000800
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000800
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x000008a4
    CMD_SEND:12
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00002c20
    Running uenvcmd ...
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000800
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000800
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x000008a4
    CMD_SEND:12
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x00000e20
    CMD_SEND:12
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x00000804
    CMD_SEND:12
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x00000e24
    CMD_SEND:12
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000eac
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000800
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000800
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x000008a4
    CMD_SEND:12
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x00000804
    CMD_SEND:12
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x0000080a
    CMD_SEND:12
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x00000eb0
    CMD_SEND:12
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00002c09
    Starting kernel ...
    | these purposed.                                              |
    APUSER set to root
    Thanks.
    Jack
