TMDS64EVM: Data verification error M4F
Part Number: TMDS64EVM
I am using the TMDS64EVM board and testing a custom application written in C++. When loading the application through CSS it works fine in the R5s, but in the M4F processor I get a Data verification error on address 0x00014A20. What I noticed is that modifying the entry .ARM.exidx in the linker file changes the address error.
How can I solve this?
Thanks.
  • Thomas can you share the linker file or the part of linker file for us to understand the problem better. If sharing the sample application is easy please do.
    please also specify your compiler version and your development environment.
    Anshu
  • Hi Anshu,
    thanks for the reply.
    This is the part of the linker file needed for C++ projects, it's the same linker file used for the hello_world.cpp project. The sdk I am using is mcu_plus_sdk_am64x_08_05_00_24.
    My IDE is CCS version 12.3 and the compiler is TI Arm Clang Compiler 2.1.2.LTS and I tried using both freertos and nortos on the M4.
    The problem seems to be the use of C++ classes.
    Thomas
  • Hello Thomas,
    Sorry for the delayed reply since Anshu was busy with other work.
    I have assigned this thread to Tushar. You may get a reply in one or two days.
    S.Anil.
  • Hi Thomas,
    Can you please confirm for your custom application, the linker.cmd file and example.syscfg file are not same for both R5F and M4F processor ?
    It would be helpful if you can share both the linker.cmd and example.syscfg file of your application for both R5F and M4F processor.
    Thanks & Regards,
    Tushar
  • Hi Tushar,
    I managed to make the application work on the M4 as well, by flashing the application directly on the processor, but it doesn't work if I try to load it from CCS.
    Do you have any suggestion to make it work, to make the debugging process faster?
    Thomas
  • Hi Thomas,
    Thanks for the notes.
    Can you please confirm after flashing, is it working as expected ?
    Can you please tell what error are you facing while loading it to CCS? It would be better if you can share screenshot/logs of the error.
    Tushar
  • Hi Tushar,
    Sorry for the delay in the response.
    I confirm that after flashing directly the executable on the processor it works as expected.
    The error message just says: "A data verification error occurred. File load failed."
    And in the logs I have the following error:
    "BLAZAR_Cortex_M4F_0: File Loader: Verification failed: Values at address 0x00015F01 do not match Please verify target memory and memory map."
    I read that it should be solvable with GEL files; in that case, is there a premade GEL file for the M4 processor?
    Also I wanted to ask another question. If I want to load a firmware through Linux on the A53 on another processor, what kind of format should the firmware have and can I get if from the standard makefile?
    Thomas
  • Hi Thomas,
    Thank you for your reply.
    Can you please share the .map file of your project? It would be helpful to debug the issue.
    You can follow the steps mentioned in Linux Academy for Booting Remote Cores. Please refer Booting Remote Cores.
    If you face any issues to follow the steps mentioned above, please let me know.
    In order to launch the application from remote cores, IPC needs to be added to the application.
    For more info please refer Application Development on Remote Cores.
    Tushar
  • Hi Tushar,
    Thank you for the links for the Linux part.
    This is the .map file for the M4.
                TI ARM Clang Linker Unix v2.1.2
    >> Linked Sun Jul 16 16:11:35 2023
    ENTRY POINT SYMBOL: "_c_int00"  address: 00008a67
    MEMORY CONFIGURATION
             name            origin    length      used     unused   attr    fill
      M4F_VECS              00000000   00000200  00000140  000000c0  RWIX
      M4F_IRAM              00000200   0002fe00  00015d08  0001a0f8  RWIX
      M4F_DRAM              00030000   00010000  00009630  000069d0  RWIX
      USER_SHM_MEM          701d0000   00000080  00000000  00000080  RWIX
      LOG_SHM_MEM           701d0080   00003f80  00003800  00000780  RWIX
      IPC_VRING_MEM         701d4000   0000c000  000099c0  00002640  RWIX
    SEGMENT ALLOCATION MAP
    run origin  load origin   length   init length attrs members
    00000000    00000000    00000140   00000140    rw-
      00000000    00000000    00000140   00000140    rw- .vectors
    00000200    00000200    00009d00   00009d00    r-x
      00000200    00000200    00009d00   00009d00    r-x .text
    00009f00    00009f00    0000c000   00000000    rw-
      00009f00    00009f00    00008000   00000000    rw- .sysmem
      00011f00    00011f00    00004000   00000000    rw- .stack
    00015f00    00015f00    00000008   00000008    r--
      00015f00    00015f00    00000008   00000008    r-- .ARM.exidx
    00030000    00030000    00006da0   00000000    rw-
      00030000    00030000    00006da0   00000000    rw- .bss
    00036da0    00036da0    000024b0   000024b0    r--
      00036da0    00036da0    000024b0   000024b0    r-- .rodata
    00039250    00039250    000003e0   000003e0    rw-
      00039250    00039250    000003e0   000003e0    rw- .data
    SECTION ALLOCATION MAP
     output                                  attributes/
    section   page    origin      length       input sections
    .vectors   0    00000000    00000140
                      00000000    00000140     freertos.am64x.m4f.ti-arm-clang.release.lib : HwiP_armv7m_handlers_freertos.obj (.vectors)
    .text      0    00000200    00009d00
                      00000200    000009d4     libc.a : _printfi.c.obj (.text:__TI_printfi)
                      00000bd4    00000570     freertos.am64x.m4f.ti-arm-clang.release.lib : printf.obj (.text._vsnprintf)
                      00001144    000004f6     drivers.am64x.m4f.ti-arm-clang.release.lib : uart_v0.obj (.text.UART_open)
                      0000163a    00000006     freertos.am64x.m4f.ti-arm-clang.release.lib : SemaphoreP_freertos.obj (.text.SemaphoreP_destruct)
                      00001640    000004a8                                                 : printf.obj (.text._etoa)
                      00001ae8    00000438                                                 : printf.obj (.text._ftoa)
                      00001f20    000003a4                                                 : HwiP_armv7m.obj (.text.hwi)
                      000022c4    00000384     drivers.am64x.m4f.ti-arm-clang.release.lib : ipc_notify_v0.obj (.text.IpcNotify_init)
                      00002648    0000035a                                                : sciclient.obj (.text.Sciclient_service)
                      000029a2    00000006     freertos.am64x.m4f.ti-arm-clang.release.lib : list.obj (.text.vListInitialiseItem)
                      000029a8    000002b8     libc.a : _printfi.c.obj (.text._pconv_a)
                      00002c60    00000240     freertos.am64x.m4f.ti-arm-clang.release.lib : timers.obj (.text.prvTimerTask)
                      00002ea0    00000238     libc.a : _printfi.c.obj (.text._pconv_g)
                      000030d8    0000021e     drivers.am64x.m4f.ti-arm-clang.release.lib : uart_v0.obj (.text.UART_masterIsr)
                      000032f6    00000002     ti_board_open_close.obj (.text.Board_driversClose)
                      000032f8    00000206     drivers.am64x.m4f.ti-arm-clang.release.lib : uart_v0.obj (.text.UART_write)
                      000034fe    00000002     ti_board_config.obj (.text.Board_init)
                      00003500    000001fc     freertos.am64x.m4f.ti-arm-clang.release.lib : queue.obj (.text.xQueueSemaphoreTake)
                      000036fc    000001e8                                                 : queue.obj (.text.xQueueGenericSend)
                      000038e4    000001be                                                 : MpuP_armv7m.obj (.text.mpu)
                      00003aa2    00000002                                                 : ClockP_freertos_m4.obj (.text.ClockP_timerClearOverflowInt)
                      00003aa4    000001ba                                                 : queue.obj (.text.xQueueReceive)
                      00003c5e    00000002     RPMessageEndpoint.obj (.text._ZN17RPMessageEndpoint9from_jsonERKN8nlohmann16json_abi_v3_11_210basic_jsonINSt3__13mapENS3_6vectorENS3_12basic_stringIcNS3_11char_traitsIcEENS3_9allocatorIcEEEEbxydS9_NS1_14adl_serializerENS5_IhNS9_IhEEEEvEE)
                      00003c60    000001b6     libclang_rt.builtins.a : adddf3.S.obj (.text)
                      00003e16    00000002     RPMessageEndpoint.obj (.text._ZN17RPMessageEndpointD2Ev)
                      00003e18    000001a0     libc.a : _printfi.c.obj (.text.fcvt)
                      00003fb8    0000019a     embedded_kafka.obj (.text._Z11r5_0_0_codei)
                      00004152    00000004     ti_board_open_close.obj (.text.Board_driversOpen)
                      00004156    00000002     RPMessageEndpoint.obj (.text._ZNK17RPMessageEndpoint7to_jsonERN8nlohmann16json_abi_v3_11_210basic_jsonINSt3__13mapENS3_6vectorENS3_12basic_stringIcNS3_11char_traitsIcEENS3_9allocatorIcEEEEbxydS9_NS1_14adl_serializerENS5_IhNS9_IhEEEEvEE)
                      00004158    00000180     libc.a : _printfi.c.obj (.text._pconv_e)
                      000042d8    0000016a     freertos.am64x.m4f.ti-arm-clang.release.lib : tasks.obj (.text.xTaskIncrementTick)
                      00004442    00000146     drivers.am64x.m4f.ti-arm-clang.release.lib : uart_v0.obj (.text.UART_close)
                      00004588    0000013e     freertos.am64x.m4f.ti-arm-clang.release.lib : tasks.obj (.text.xTaskResumeAll)
                      000046c6    00000136     drivers.am64x.m4f.ti-arm-clang.release.lib : ipc_rpmsg.obj (.text.RPMessage_recv)
                      000047fc    00000136     libclang_rt.builtins.a : divdf3.S.obj (.text)
                      00004932    00000002                            : aeabi_div0.c.obj (.text.__aeabi_ldiv0)
                      00004934    00000134     drivers.am64x.m4f.ti-arm-clang.release.lib : soc.obj (.text.SOC_moduleSetClockFrequency)
                      00004a68    00000130     freertos.am64x.m4f.ti-arm-clang.release.lib : ClockP_freertos_m4.obj (.text.ClockP_init)
                      00004b98    0000012c                                                 : queue.obj (.text.xQueueGenericSendFromISR)
                      00004cc4    00000122                                                 : tasks.obj (.text.vTaskDelete)
                      00004de6    00000002     libc.a : _lock.c.obj (.text._nop)
                      00004de8    00000120            : memory.c.obj (.text.aligned_alloc)
                      00004f08    0000011c     freertos.am64x.m4f.ti-arm-clang.release.lib : printf.obj (.text._ntoa_format)
                      00005024    0000011a                                                 : tasks.obj (.text.prvAddNewTaskToReadyList)
                      0000513e    0000010c     drivers.am64x.m4f.ti-arm-clang.release.lib : ipc_rpmsg.obj (.text.RPMessage_recvHandler)
                      0000524a    00000004     freertos.am64x.m4f.ti-arm-clang.release.lib : ClockP_freertos.obj (.text.ClockP_getTicks)
                      0000524e    00000002                                                 : printf.obj (.text._out_null)
                      00005250    0000010c     libc.a : s_scalbn.c.obj (.text.scalbn)
                      0000535c    0000010c     freertos.am64x.m4f.ti-arm-clang.release.lib : queue.obj (.text.xQueueGiveFromISR)
                      00005468    00000108                                                 : SysTickTimerP.obj (.text.SysTickTimerP_setup)
                      00005570    00000100                                                 : queue.obj (.text.xQueueReceiveFromISR)
                      00005670    000000fe                                                 : queue.obj (.text.xQueueGenericCreateStatic)
                      0000576e    000000fc     drivers.am64x.m4f.ti-arm-clang.release.lib : ipc_rpmsg.obj (.text.RPMessage_send)
                      0000586a    00000002     freertos.am64x.m4f.ti-arm-clang.release.lib : port.obj (.text.vPortConfigTimerForRunTimeStats)
                      0000586c    000000fc     libclang_rt.builtins.a : muldf3.S.obj (.text)
                      00005968    000000f8     ti_drivers_config.obj (.text.System_init)
                      00005a60    000000f8     libc.a : memory.c.obj (.text.free)
                      00005b58    000000f8     freertos.am64x.m4f.ti-arm-clang.release.lib : tasks.obj (.text.vTaskSwitchContext)
                      00005c50    000000ee     drivers.am64x.m4f.ti-arm-clang.release.lib : ipc_rpmsg.obj (.text.RPMessage_init)
                      00005d3e    000000da     freertos.am64x.m4f.ti-arm-clang.release.lib : tasks.obj (.text.vTaskPriorityDisinheritAfterTimeout)
                      00005e18    000000cc     drivers.am64x.m4f.ti-arm-clang.release.lib : ipc_notify_v0.obj (.text.IpcNotify_isr)
                      00005ee4    000000cc     freertos.am64x.m4f.ti-arm-clang.release.lib : timers.obj (.text.prvSampleTimeNow)
                      00005fb0    000000ca     drivers.am64x.m4f.ti-arm-clang.release.lib : ipc_notify_v0.obj (.text.IpcNotify_sendMsg)
                      0000607a    000000ca     freertos.am64x.m4f.ti-arm-clang.release.lib : tasks.obj (.text.xTaskPriorityDisinherit)
                      00006144    000000c4                                                 : tasks.obj (.text.vTaskStartScheduler)
                      00006208    000000c2                                                 : tasks.obj (.text.prvInitialiseNewTask)
                      000062ca    000000c2                                                 : tasks.obj (.text.xTaskCreateStatic)
                      0000638c    000000be     drivers.am64x.m4f.ti-arm-clang.release.lib : pinmux.obj (.text.Pinmux_config)
                      0000644a    000000b8                                                : ipc_rpmsg_vring.obj (.text.RPMessage_vringReset)
                      00006502    000000b8                                                : uart_v0.obj (.text.UART_divisorLatchWrite)
                      000065ba    00000002     --HOLE-- [fill = 0]
                      000065bc    000000b4                                                : uart_v0.obj (.text.UART_flushTxFifo)
                      00006670    000000b0     freertos.am64x.m4f.ti-arm-clang.release.lib : AddrTranslateP.obj (.text.AddrTranslateP_init)
                      00006720    000000b0                                                 : DebugP_shmLogWriter.obj (.text.DebugP_shmLogWriterPutChar)
                      000067d0    000000b0                                                 : TaskP_freertos.obj (.text.TaskP_loadUpdateAll)
                      00006880    000000b0     libclang_rt.builtins.a : udivmoddi4.S.obj (.text)
                      00006930    000000aa     drivers.am64x.m4f.ti-arm-clang.release.lib : uart_v0.obj (.text.UART_procLineStatusErr)
                      000069da    000000a8     freertos.am64x.m4f.ti-arm-clang.release.lib : tasks.obj (.text.xTaskPriorityInherit)
                      00006a82    00000002     --HOLE-- [fill = 0]
                      00006a84    000000a6                                                 : HwiP_armv7m_handlers_freertos.obj (.text.hwi)
                      00006b2a    000000a4     drivers.am64x.m4f.ti-arm-clang.release.lib : ipc_rpmsg_vring.obj (.text.RPMessage_vringGetFullRxBuf)
                      00006bce    00000002     --HOLE-- [fill = 0]
                      00006bd0    000000a4     freertos.am64x.m4f.ti-arm-clang.release.lib : printf.obj (.text._ntoa_long_long)
                      00006c74    000000a4                                                 : printf.obj (.text._out_rev)
                      00006d18    000000a4                                                 : tasks.obj (.text.xTaskRemoveFromEventList)
                      00006dbc    000000a0                                                 : tasks.obj (.text.eTaskGetState)
                      00006e5c    000000a0                                                 : tasks.obj (.text.prvAddCurrentTaskToDelayedList)
                      00006efc    0000009e     drivers.am64x.m4f.ti-arm-clang.release.lib : ipc_rpmsg_vring.obj (.text.RPMessage_vringPutEmptyRxBuf)
                      00006f9a    0000009e                                                : sciclient_pm.obj (.text.Sciclient_pmQueryModuleClkFreq)
                      00007038    0000009e     embedded_kafka.obj (.text._Z8receiveri)
                      000070d6    0000009e     freertos.am64x.m4f.ti-arm-clang.release.lib : tasks.obj (.text.xTaskCheckForTimeOut)
                      00007174    0000009a     drivers.am64x.m4f.ti-arm-clang.release.lib : sciclient.obj (.text.Sciclient_init)
                      0000720e    00000002     --HOLE-- [fill = 0]
                      00007210    0000009a                                                : sciclient.obj (.text.Sciclient_sendMessage)
                      000072aa    00000002     --HOLE-- [fill = 0]
                      000072ac    00000098                                                : ipc_rpmsg.obj (.text.RPMessage_coreInit)
                      00007344    00000096     freertos.am64x.m4f.ti-arm-clang.release.lib : tasks.obj (.text.vTaskGetInfo)
                      000073da    00000002     --HOLE-- [fill = 0]
                      000073dc    00000094     drivers.am64x.m4f.ti-arm-clang.release.lib : uart_v0.obj (.text.UART_init)
                      00007470    00000094     freertos.am64x.m4f.ti-arm-clang.release.lib : printf.obj (.text._ntoa_long)
                      00007504    00000092     drivers.am64x.m4f.ti-arm-clang.release.lib : ipc_rpmsg_vring.obj (.text.RPMessage_vringGetEmptyTxBuf)
                      00007596    00000092     freertos.am64x.m4f.ti-arm-clang.release.lib : queue.obj (.text.xQueueGenericReset)
                      00007628    00000090     drivers.am64x.m4f.ti-arm-clang.release.lib : ipc_rpmsg_vring.obj (.text.RPMessage_vringResetInternal)
                      000076b8    0000008c                                                : sciclient_pm.obj (.text.Sciclient_pmSetModuleClkFreq)
                      00007744    00000086     freertos.am64x.m4f.ti-arm-clang.release.lib : DebugP_shmLogWriter.obj (.text.DebugP_shmLogWriterPutLine)
                      000077ca    00000086                                                 : timers.obj (.text.xTimerCreateTimerTask)
                      00007850    00000082     main.obj (.text.main)
                      000078d2    00000080     RPMessageCommunication.obj (.text._ZN22RPMessageCommunicationC2ERK17RPMessageEndpointRK6Logger)
                      00007952    0000007a     drivers.am64x.m4f.ti-arm-clang.release.lib : sciclient_pm.obj (.text.Sciclient_pmGetModuleClkNumParent)
                      000079cc    0000007a     freertos.am64x.m4f.ti-arm-clang.release.lib : timers.obj (.text.prvCheckForValidListAndQueue)
                      00007a46    0000007a                                                 : port.obj (.text.xPortStartScheduler)
                      00007ac0    00000078     drivers.am64x.m4f.ti-arm-clang.release.lib : ipc_rpmsg.obj (.text.RPMessage_construct)
                      00007b38    00000078     freertos.am64x.m4f.ti-arm-clang.release.lib : queue.obj (.text.prvCopyDataToQueue)
                      00007bb0    00000078                                                 : timers.obj (.text.xTimerGenericCommand)
                      00007c28    00000076                                                 : DebugP_freertos.obj (.text._DebugP_logZone)
                      00007c9e    00000002     --HOLE-- [fill = 0]
                      00007ca0    00000076     RPMessageCommunication.obj (.text._ZN22RPMessageCommunication5writeEPKcjRK8Endpoint)
                      00007d16    00000072     drivers.am64x.m4f.ti-arm-clang.release.lib : soc.obj (.text.SOC_moduleClockEnable)
                      00007d88    00000072     freertos.am64x.m4f.ti-arm-clang.release.lib : queue.obj (.text.prvUnlockQueue)
                      00007dfa    00000070                                                 : SemaphoreP_freertos.obj (.text.SemaphoreP_constructBinary)
                      00007e6a    00000002     --HOLE-- [fill = 0]
                      00007e6c    00000070                                                 : tasks.obj (.text.prvIdleTask)
                      00007edc    0000006e     drivers.am64x.m4f.ti-arm-clang.release.lib : ipc_rpmsg.obj (.text.RPMessage_getEndPtMsg)
                      00007f4a    0000006e                                                : sciclient_pm.obj (.text.Sciclient_pmGetModuleState)
                      00007fb8    0000006e     libclang_rt.builtins.a : comparedf2.c.obj (.text.__gedf2)
                      00008026    00000002     --HOLE-- [fill = 0]
                      00008028    0000006e                            : comparedf2.c.obj (.text.__ledf2)
                      00008096    0000006c     libc.a : _printfi.c.obj (.text._mcpy)
                      00008102    00000002     --HOLE-- [fill = 0]
                      00008104    0000006c            : memory.c.obj (.text.split)
                      00008170    0000006a     freertos.am64x.m4f.ti-arm-clang.release.lib : AddrTranslateP.obj (.text.AddrTranslateP_getLocalAddr)
                      000081da    00000002     --HOLE-- [fill = 0]
                      000081dc    0000006a     TI_DebugLogger.obj (.text._ZNK14TI_DebugLogger3logEPKcz)
                      00008246    00000002     --HOLE-- [fill = 0]
                      00008248    0000006a     TI_DebugLogger.obj (.text._ZNK14TI_DebugLogger8logErrorEPKcz)
                      000082b2    0000006a     freertos.am64x.m4f.ti-arm-clang.release.lib : tasks.obj (.text.vTaskDelay)
                      0000831c    00000068     drivers.am64x.m4f.ti-arm-clang.release.lib : uart_v0.obj (.text.UART_writeCancelNoCB)
                      00008384    00000004     freertos.am64x.m4f.ti-arm-clang.release.lib : ClockP_freertos_m4.obj (.text.ClockP_getTimerCount)
                      00008388    00000068     libc.a : s_frexp.c.obj (.text.frexp)
                      000083f0    00000066     drivers.am64x.m4f.ti-arm-clang.release.lib : sciclient_pm.obj (.text.Sciclient_pmGetModuleClkParent)
                      00008456    00000066     freertos.am64x.m4f.ti-arm-clang.release.lib : SemaphoreP_freertos.obj (.text.SemaphoreP_pend)
                      000084bc    00000066                                                 : SemaphoreP_freertos.obj (.text.SemaphoreP_post)
                      00008522    00000066     RPMessageCommunication.obj (.text._ZN22RPMessageCommunication4readEPcjR8Endpoint)
                      00008588    00000064     drivers.am64x.m4f.ti-arm-clang.release.lib : ipc_notify_v0.obj (.text.IpcNotify_waitSync)
                      000085ec    00000064                                                : sciclient_pm.obj (.text.Sciclient_pmModuleGetClkStatus)
                      00008650    00000064     freertos.am64x.m4f.ti-arm-clang.release.lib : queue.obj (.text.vQueueDelete)
                      000086b4    0000000c                                                 : DebugP_uartLogWriter.obj (.text.DebugP_uartSetDrvIndex)
                      000086c0    00000064                                                 : port.obj (.text.xPortPendSVHandler)
                      00008724    00000062     libclang_rt.builtins.a : aeabi_dcmp.S.obj (.text)
                      00008786    0000005e     drivers.am64x.m4f.ti-arm-clang.release.lib : ipc_rpmsg_vring.obj (.text.RPMessage_vringPutFullTxBuf)
                      000087e4    0000005e                                                : sciclient_pm.obj (.text.Sciclient_pmSetModuleClkParent)
                      00008842    00000002     --HOLE-- [fill = 0]
                      00008844    0000005e     freertos.am64x.m4f.ti-arm-clang.release.lib : DebugP_log.obj (.text._DebugP_assert)
                      000088a2    0000005e                                                 : port.obj (.text.vPortEnterCritical)
                      00008900    0000005c     drivers.am64x.m4f.ti-arm-clang.release.lib : sciclient_pm.obj (.text.Sciclient_pmModuleClkRequest)
                      0000895c    0000005a                                                : ipc_rpmsg_vring.obj (.text.RPMessage_vringIsFullRxBuf)
                      000089b6    00000058     ti_dpl_config.obj (.text.Dpl_init)
                      00008a0e    00000058     freertos.am64x.m4f.ti-arm-clang.release.lib : tasks.obj (.text.vTaskPlaceOnEventListRestricted)
                      00008a66    00000058                                                 : boot_armv7m.obj (.text:_c_int00)
                      00008abe    00000056     drivers.am64x.m4f.ti-arm-clang.release.lib : uart_dma.obj (.text.UART_dmaDisableChannel)
                      00008b14    00000056     libc.a : _ltoa.c.obj (.text.__TI_ltoa)
                      00008b6a    00000002     --HOLE-- [fill = 0]
                      00008b6c    00000056     freertos.am64x.m4f.ti-arm-clang.release.lib : port.obj (.text.prvTaskExitError)
                      00008bc2    00000054     drivers.am64x.m4f.ti-arm-clang.release.lib : uart_dma.obj (.text.UART_dmaClose)
                      00008c16    00000054     libc.a : _printfi.c.obj (.text._pconv_f)
                      00008c6a    00000052     drivers.am64x.m4f.ti-arm-clang.release.lib : sciclient_pm.obj (.text.Sciclient_pmSetModuleState)
                      00008cbc    00000052     freertos.am64x.m4f.ti-arm-clang.release.lib : queue.obj (.text.xQueueGiveMutexRecursive)
                      00008d0e    00000002     --HOLE-- [fill = 0]
                      00008d10    00000050     drivers.am64x.m4f.ti-arm-clang.release.lib : ipc_rpmsg.obj (.text.RPMessage_notifyCallback)
                      00008d60    00000050                                                : sciclient_soc_priv.obj (.text.Sciclient_getContext)
                      00008db0    00000050     freertos.am64x.m4f.ti-arm-clang.release.lib : SemaphoreP_freertos.obj (.text.SemaphoreP_constructMutex)
                      00008e00    00000050                                                 : tasks.obj (.text.prvDeleteTCB)
                      00008e50    00000050                                                 : queue.obj (.text.xQueueTakeMutexRecursive)
                      00008ea0    0000004e     libc.a : _printfi.c.obj (.text._ecpy)
                      00008eee    0000004e     freertos.am64x.m4f.ti-arm-clang.release.lib : tasks.obj (.text.vTaskPlaceOnEventList)
                      00008f3c    0000004c                                                 : ClockP_freertos.obj (.text.ClockP_getTimeUsec)
                      00008f88    0000004c     ti_drivers_open_close.obj (.text.Drivers_uartOpen)
                      00008fd4    0000004c     drivers.am64x.m4f.ti-arm-clang.release.lib : ipc_rpmsg.obj (.text.RPMessage_allocEndPtMsg)
                      00009020    00000048     libc.a : atoi.c.obj (.text.atoi)
                      00009068    00000048     libclang_rt.builtins.a : fixdfsi.S.obj (.text)
                      000090b0    00000046     freertos.am64x.m4f.ti-arm-clang.release.lib : queue.obj (.text.vQueueWaitForMessageRestricted)
                      000090f6    00000044     drivers.am64x.m4f.ti-arm-clang.release.lib : sciclient_pm.obj (.text.Sciclient_pmSetModuleRst)
                      0000913a    00000044     freertos.am64x.m4f.ti-arm-clang.release.lib : port.obj (.text.vPortExitCritical)
                      0000917e    00000002     --HOLE-- [fill = 0]
                      00009180    00000044     libclang_rt.builtins.a : fixunsdfsi.S.obj (.text)
                      000091c4    00000040     freertos.am64x.m4f.ti-arm-clang.release.lib : timers.obj (.text.prvInsertTimerInActiveList)
                      00009204    0000003e     drivers.am64x.m4f.ti-arm-clang.release.lib : ipc_notify_v0.obj (.text.IpcNotify_registerClient)
                      00009242    0000003e     freertos.am64x.m4f.ti-arm-clang.release.lib : TaskP_freertos.obj (.text.vApplicationLoadHook)
                      00009280    0000003e                                                 : port.obj (.text.vPortTimerTickHandler)
                      000092be    0000003e                                                 : tasks.obj (.text.xTaskGetIdleTaskHandle)
                      000092fc    0000003c     drivers.am64x.m4f.ti-arm-clang.release.lib : uart_dma.obj (.text.UART_dmaOpen)
                      00009338    0000003c     embedded_kafka.obj (.text._Z18communication_mainPv)
                      00009374    0000003c     libc.a : vsnprintf.c.obj (.text.vsnprintf)
                      000093b0    0000003a     freertos.am64x.m4f.ti-arm-clang.release.lib : DebugP_uartLogWriter.obj (.text.DebugP_uartLogWriterPutChar)
                      000093ea    00000002     --HOLE-- [fill = 0]
                      000093ec    0000003a                                                 : list.obj (.text.vListInsert)
                      00009426    00000002     --HOLE-- [fill = 0]
                      00009428    00000038     ti_power_clock_config.obj (.text.Module_clockSetFrequency)
                      00009460    00000038     drivers.am64x.m4f.ti-arm-clang.release.lib : ipc_rpmsg_vring.obj (.text.RPMessage_vringCheckEmptyTxBuf)
                      00009498    00000038                                                : sciclient.obj (.text.Sciclient_getCurrentContext)
                      000094d0    00000038     libc.a : autoinit.c.obj (.text:__TI_auto_init_nobinit_nopinit)
                      00009508    00000036     freertos.am64x.m4f.ti-arm-clang.release.lib : ClockP_freertos.obj (.text.ClockP_usleep)
                      0000953e    00000034     libc.a : _printfi.c.obj (.text._fcpy)
                      00009572    00000032     freertos.am64x.m4f.ti-arm-clang.release.lib : printf.obj (.text.snprintf_)
                      000095a4    00000030                                                 : DebugP_shmLogWriter.obj (.text.DebugP_shmLogWriterInit)
                      000095d4    00000030     libclang_rt.builtins.a : comparedf2.c.obj (.text.__unorddf2)
                      00009604    00000030     libc.a : vsnprintf.c.obj (.text._outs)
                      00009634    00000030     freertos.am64x.m4f.ti-arm-clang.release.lib : port.obj (.text.prvPortStartFirstTask)
                      00009664    00000030                                                 : port.obj (.text.vApplicationStackOverflowHook)
                      00009694    00000030                                                 : queue.obj (.text.xQueueCreateMutexStatic)
                      000096c4    0000002e                                                 : ClockP_freertos.obj (.text.ClockP_timerTickIsr)
                      000096f2    00000002     --HOLE-- [fill = 0]
                      000096f4    0000002e     ti_power_clock_config.obj (.text.Module_clockEnable)
                      00009722    0000002e     drivers.am64x.m4f.ti-arm-clang.release.lib : uart_v0.obj (.text.UART_getHandle)
                      00009750    0000002e     libclang_rt.builtins.a : floatsidf.S.obj (.text)
                      0000977e    00000002     --HOLE-- [fill = 0]
                      00009780    0000002a     embedded_kafka.obj (.text._ZNSt3__16vectorI13TopicMetadataNS_9allocatorIS1_EEE22__base_destruct_at_endEPS1_)
                      000097aa    00000028     drivers.am64x.m4f.ti-arm-clang.release.lib : ipc_rpmsg.obj (.text.RPMessage_Params_init)
                      000097d2    00000002     --HOLE-- [fill = 0]
                      000097d4    00000028     libc.a : memory.c.obj (.text.free_list_insert)
                      000097fc    00000028     freertos.am64x.m4f.ti-arm-clang.release.lib : port.obj (.text.pxPortInitialiseStack)
                      00009824    00000028                                                 : queue.obj (.text.vQueueAddToRegistry)
                      0000984c    00000026     drivers.am64x.m4f.ti-arm-clang.release.lib : ipc_rpmsg.obj (.text.RPMessage_controlEndPtHandler)
                      00009872    00000024     RPMessageCommunication.obj (.text._ZN22RPMessageCommunicationD0Ev)
                      00009896    00000002     --HOLE-- [fill = 0]
                      00009898    00000024     libc++abi.a : stdlib_new_delete.cpp.obj (.text._Znwj)
                      000098bc    00000024     freertos.am64x.m4f.ti-arm-clang.release.lib : list.obj (.text.uxListRemove)
                      000098e0    00000024                                                 : port.obj (.text.vPortSVCHandler)
                      00009904    00000024                                                 : printf.obj (.text.vprintf_)
                      00009928    00000024                                                 : tasks.obj (.text.xTaskGetSchedulerState)
                      0000994c    00000022     ti_pinmux_config.obj (.text.Pinmux_init)
                      0000996e    00000022     drivers.am64x.m4f.ti-arm-clang.release.lib : ipc_rpmsg.obj (.text.RPMessage_isLinuxCore)
                      00009990    00000020     freertos.am64x.m4f.ti-arm-clang.release.lib : DebugP_log.obj (.text.DebugP_logZoneEnable)
                      000099b0    00000020     CommunicationFactory.obj (.text._ZN20CommunicationFactory19createCommunicationE17CommunicationTypeRK8EndpointRK6Logger)
                      000099d0    00000020     RPMessageEndpoint.obj (.text._ZNK17RPMessageEndpoint24printEndpointInformationERK6Logger)
                      000099f0    00000020     libclang_rt.builtins.a : floatunsidf.S.obj (.text)
                      00009a10    0000001e     drivers.am64x.m4f.ti-arm-clang.release.lib : ipc_notify_v0.obj (.text.IpcNotify_syncCallback)
                      00009a2e    0000001e     freertos.am64x.m4f.ti-arm-clang.release.lib : SysTickTimerP.obj (.text.SysTickTimerP_Params_init)
                      00009a4c    0000001e                                                 : DebugP_log.obj (.text._DebugP_assertNoLog)
                      00009a6a    0000001e     RPMessageCommunication.obj (.text._ZN22RPMessageCommunicationD2Ev)
                      00009a88    0000001e     libc.a : memccpy.c.obj (.text.memccpy)
                      00009aa6    0000001c     drivers.am64x.m4f.ti-arm-clang.release.lib : ipc_rpmsg_vring.obj (.text.RPMessage_vringGetTxBufLen)
                      00009ac2    0000001c                                                : soc.obj (.text.SOC_getCoreName)
                      00009ade    00000002     --HOLE-- [fill = 0]
                      00009ae0    0000001c     libc.a : memory.c.obj (.text.free_list_remove)
                      00009afc    0000001c     freertos.am64x.m4f.ti-arm-clang.release.lib : port.obj (.text.vApplicationGetIdleTaskMemory)
                      00009b18    0000001c                                                 : port.obj (.text.vApplicationGetTimerTaskMemory)
                      00009b34    0000001c                                                 : list.obj (.text.vListInsertEnd)
                      00009b50    0000001a     drivers.am64x.m4f.ti-arm-clang.release.lib : ipc_notify_v0.obj (.text.IpcNotify_Params_init)
                      00009b6a    0000001a                                                : ipc_rpmsg_vring.obj (.text.RPMessage_vringGetRxBufAddr)
                      00009b84    0000001a                                                : ipc_rpmsg_vring.obj (.text.RPMessage_vringGetTxBufAddr)
                      00009b9e    0000001a                                                : uart_dma.obj (.text.UART_writeInterruptDma)
                      00009bb8    0000001a     RPMessageEndpoint.obj (.text._ZN17RPMessageEndpointC2Ev)
                      00009bd2    0000001a     freertos.am64x.m4f.ti-arm-clang.release.lib : heap_3.obj (.text.vPortFree)
                      00009bec    0000001a                                                 : tasks.obj (.text.vTaskInternalSetTimeOutState)
                      00009c06    00000018     ti_drivers_config.obj (.text.IpcNotify_getConfig)
                      00009c1e    00000018     drivers.am64x.m4f.ti-arm-clang.release.lib : ipc_notify_v0.obj (.text.IpcNotify_isCoreEnabled)
                      00009c36    00000018     freertos.am64x.m4f.ti-arm-clang.release.lib : TaskP_freertos.obj (.text.TaskP_yield)
                      00009c4e    00000018     EndpointFactory.obj (.text._ZN15EndpointFactory14createEndpointE17CommunicationType)
                      00009c66    00000018     embedded_kafka.obj (.text._ZNSt3__16vectorI13TopicMetadataNS_9allocatorIS1_EEED2Ev)
                      00009c7e    00000018     libc.a : vsnprintf.c.obj (.text._outc)
                      00009c96    00000018     freertos.am64x.m4f.ti-arm-clang.release.lib : tasks.obj (.text.pvTaskIncrementMutexHeldCount)
                      00009cae    00000016                                                 : HwiP_armv7m.obj (.text.HwiP_inISR)
                      00009cc4    00000016     drivers.am64x.m4f.ti-arm-clang.release.lib : sciclient_soc_priv.obj (.text.Sciclient_getDevId)
                      00009cda    00000016     freertos.am64x.m4f.ti-arm-clang.release.lib : list.obj (.text.vListInitialise)
                      00009cf0    00000014                                                 : ClockP_freertos.obj (.text.ClockP_usecToTicks)
                      00009d04    00000014                                                 : port.obj (.text.vPortEnableVFP)
                      00009d18    00000014     libclang_rt.builtins.a : aeabi_memset.S.obj (.text)
                      00009d2c    00000014                            : aeabi_uldivmod.S.obj (.text)
                      00009d40    00000012     freertos.am64x.m4f.ti-arm-clang.release.lib : SysTickTimerP.obj (.text.SysTickTimerP_start)
                      00009d52    00000012     main.obj (.text._Z13freertos_mainPv)
                      00009d64    00000012     RPMessageEndpoint.obj (.text._ZN17RPMessageEndpointC2Ejt)
                      00009d76    00000012     ti_dpl_config.obj (.text.putchar_)
                      00009d88    00000012     libc.a : _printfi.c.obj (.text.strchr)
                      00009d9a    00000012            : memcpy_t2.S.obj (.text:TI_memcpy_small)
                      00009dac    00000010     freertos.am64x.m4f.ti-arm-clang.release.lib : ClockP_freertos.obj (.text.ClockP_ticksToUsec)
                      00009dbc    00000010     drivers.am64x.m4f.ti-arm-clang.release.lib : ipc_rpmsg.obj (.text.RPMessage_CreateParams_init)
                      00009dcc    00000010     freertos.am64x.m4f.ti-arm-clang.release.lib : tasks.obj (.text.vTaskSuspendAll)
                      00009ddc    00000010     libc.a : wcslen.c.obj (.text.wcslen)
                      00009dec    0000000e     ti_power_clock_config.obj (.text.PowerClock_init)
                      00009dfa    0000000e     freertos.am64x.m4f.ti-arm-clang.release.lib : SysTickTimerP.obj (.text.SysTickTimerP_getCount)
                      00009e08    0000000e                                                 : SysTickTimerP.obj (.text.SysTickTimerP_getReloadCount)
                      00009e16    0000000e     libc.a : _printfi.c.obj (.text.strlen)
                      00009e24    0000000e     freertos.am64x.m4f.ti-arm-clang.release.lib : tasks.obj (.text.vTaskMissedYield)
                      00009e32    0000000e     libc.a : memset_t2.S.obj (.text:TI_memset_small)
                      00009e40    0000000c     drivers.am64x.m4f.ti-arm-clang.release.lib : ipc_notify_v0.obj (.text.IpcNotify_getSelfCoreId)
                      00009e4c    0000000c     BrokerMetadata.obj (.text._ZN14BrokerMetadataC2EP8Endpoint)
                      00009e58    0000000c     libc++abi.a : cxa_handlers.cpp.obj (.text._ZSt15get_new_handlerv)
                      00009e64    0000000c     freertos.am64x.m4f.ti-arm-clang.release.lib : tasks.obj (.text.xTaskGetCurrentTaskHandle)
                      00009e70    0000000c                                                 : tasks.obj (.text.xTaskGetTickCount)
                      00009e7c    0000000a                                                 : AddrTranslateP.obj (.text.AddrTranslateP_Params_init)
                      00009e86    0000000a     drivers.am64x.m4f.ti-arm-clang.release.lib : csl_sec_proxy.obj (.text.CSL_secProxyGetDataAddr)
                      00009e90    0000000a                                                : ipc_notify_v0.obj (.text.IpcNotify_sendSync)
                      00009e9a    0000000a     freertos.am64x.m4f.ti-arm-clang.release.lib : printf.obj (.text._out_char)
                      00009ea4    0000000a                                                 : port.obj (.text.vApplicationIdleHook)
                      00009eae    00000002     --HOLE-- [fill = 0]
                      00009eb0    00000008     libc.a : aeabi_portable.c.obj (.text.__aeabi_errno_addr)
                      00009eb8    00000008     freertos.am64x.m4f.ti-arm-clang.release.lib : printf.obj (.text._out_buffer)
                      00009ec0    00000008     libc.a : memory.c.obj (.text.malloc)
                      00009ec8    00000008     freertos.am64x.m4f.ti-arm-clang.release.lib : port.obj (.text.uiPortGetRunTimeCounterValue)
                      00009ed0    00000004     ti_drivers_open_close.obj (.text.Drivers_open)
                      00009ed4    00000004     drivers.am64x.m4f.ti-arm-clang.release.lib : ipc_rpmsg.obj (.text.RPMessage_getLocalEndPt)
                      00009ed8    00000004     RPMessageEndpoint.obj (.text._ZN17RPMessageEndpoint18setServiceEndpointEt)
                      00009edc    00000004     RPMessageEndpoint.obj (.text._ZN17RPMessageEndpoint9setCoreIdEj)
                      00009ee0    00000004     RPMessageEndpoint.obj (.text._ZN17RPMessageEndpointD0Ev)
                      00009ee4    00000004     BrokerMetadata.obj (.text._ZNK14BrokerMetadata11getEndpointEv)
                      00009ee8    00000004     RPMessageEndpoint.obj (.text._ZNK17RPMessageEndpoint18getServiceEndpointEv)
                      00009eec    00000004     RPMessageEndpoint.obj (.text._ZNK17RPMessageEndpoint9getCoreIdEv)
                      00009ef0    00000004     libc++abi.a : stdlib_new_delete.cpp.obj (.text._ZdlPv)
                      00009ef4    00000004     ti_dpl_config.obj (.text.boot)
                      00009ef8    00000004     libc.a : exit.c.obj (.text:abort)
                      00009efc    00000004     libclang_rt.builtins.a : aeabi_memcpy.S.obj (.text)
    .sysmem    0    00009f00    00008000     UNINITIALIZED
                      00009f00    00000010     libc.a : memory.c.obj (.sysmem)
                      00009f10    00007ff0     --HOLE--
    .stack     0    00011f00    00004000     UNINITIALIZED
                      00011f00    00000004     freertos.am64x.m4f.ti-arm-clang.release.lib : boot_armv7m.obj (.stack)
                      00011f04    00003ffc     --HOLE--
    .bss       0    00030000    00006da0     UNINITIALIZED
                      00030000    00004000     main.obj (.bss.gMainTaskStack)
                      00034000    00001000     freertos.am64x.m4f.ti-arm-clang.release.lib : port.obj (.bss.uxIdleTaskStack)
                      00035000    00000b2c     (.common:gIpcRpmsgCtrl)
                      00035b2c    00000400                                                 : port.obj (.bss.uxTimerTaskStack)
                      00035f2c    00000280     ti_drivers_config.obj (.bss.gUartObjects)
                      000361ac    00000280     freertos.am64x.m4f.ti-arm-clang.release.lib : tasks.obj (.bss.pxReadyTasksLists)
                      0003642c    00000280     (.common:gHwiCtrl)
                      000366ac    00000100                                                 : timers.obj (.bss.prvCheckForValidListAndQueue.ucStaticTimerQueueStorage)
                      000367ac    00000100     (.common:xQueueRegistry)
                      000368ac    000000a8     (.common:gIpcNotifyCtrl)
                      00036954    00000004     main.obj (.bss.gMainTask)
                      00036958    000000a0     (.common:gTaskP_ctrl)
                      000369f8    00000098     freertos.am64x.m4f.ti-arm-clang.release.lib : DebugP_freertos.obj (.bss.gDebugLogLockObj)
                      00036a90    00000088                                                 : port.obj (.bss.xIdleTaskTCB)
                      00036b18    00000088                                                 : port.obj (.bss.xTimerTaskTCB)
                      00036ba0    0000007a                                                 : DebugP_shmLogWriter.obj (.bss.DebugP_shmLogWriterPutChar.lineBuf)
                      00036c1a    00000002     --HOLE--
                      00036c1c    00000050                                                 : timers.obj (.bss.prvCheckForValidListAndQueue.xStaticTimerQueue)
                      00036c6c    00000050     (.common:gRovDummyQueue)
                      00036cbc    00000004                                                 : timers.obj (.bss.pxCurrentTimerList)
                      00036cc0    00000038     (.common:gClockCtrl)
                      00036cf8    00000014                                                 : timers.obj (.bss.xActiveTimerList1)
                      00036d0c    00000014                                                 : timers.obj (.bss.xActiveTimerList2)
                      00036d20    00000014                                                 : tasks.obj (.bss.xDelayedTaskList1)
                      00036d34    00000014                                                 : tasks.obj (.bss.xDelayedTaskList2)
                      00036d48    00000014                                                 : tasks.obj (.bss.xPendingReadyList)
                      00036d5c    00000014                                                 : tasks.obj (.bss.xSuspendedTaskList)
                      00036d70    00000014                                                 : tasks.obj (.bss.xTasksWaitingTermination)
                      00036d84    00000004                                                 : tasks.obj (.bss.pxDelayedTaskList)
                      00036d88    00000004                                                 : tasks.obj (.bss.pxOverflowDelayedTaskList)
                      00036d8c    00000004                                                 : timers.obj (.bss.pxOverflowTimerList)
                      00036d90    00000004     libc.a : memory.c.obj (.bss.sys_free)
                      00036d94    00000004     (.common:gUartHandle)
                      00036d98    00000008     --HOLE--
    .rodata    0    00036da0    000024b0
                      00036da0    000007ee     freertos.am64x.m4f.ti-arm-clang.release.lib : tasks.obj (.rodata.str1.1)
                      0003758e    00000756                                                 : queue.obj (.rodata.str1.1)
                      00037ce4    0000031a     drivers.am64x.m4f.ti-arm-clang.release.lib : ipc_rpmsg.obj (.rodata.str1.1)
                      00037ffe    000002bc     freertos.am64x.m4f.ti-arm-clang.release.lib : timers.obj (.rodata.str1.1)
                      000382ba    00000208     embedded_kafka.obj (.rodata.str1.1)
                      000384c2    000001ad     freertos.am64x.m4f.ti-arm-clang.release.lib : port.obj (.rodata.str1.1)
                      0003866f    0000017d     drivers.am64x.m4f.ti-arm-clang.release.lib : ipc_notify_v0.obj (.rodata.str1.1)
                      000387ec    00000135                                                : uart_v0.obj (.rodata.str1.1)
                      00038921    00000003     TI_DebugLogger.obj (.rodata.str1.1)
                      00038924    0000012c     drivers.am64x.m4f.ti-arm-clang.release.lib : sciclient_fmwSecureProxyMap.obj (.rodata.gSciclientMap)
                      00038a50    0000010a     freertos.am64x.m4f.ti-arm-clang.release.lib : ClockP_freertos_m4.obj (.rodata.str1.1)
                      00038b5a    00000002     --HOLE-- [fill = 0]
                      00038b5c    00000004                                                 : tasks.obj (.rodata.uxTopUsedPriority)
                      00038b60    00000101     libc.a : aeabi_ctype.S.obj (.rodata)
                      00038c61    000000da     freertos.am64x.m4f.ti-arm-clang.release.lib : SemaphoreP_freertos.obj (.rodata.str1.1)
                      00038d3b    000000a9                                                 : SysTickTimerP.obj (.rodata.str1.1)
                      00038de4    0000007b     drivers.am64x.m4f.ti-arm-clang.release.lib : soc.obj (.rodata.str1.1)
                      00038e5f    00000076     RPMessageCommunication.obj (.rodata.str1.1)
                      00038ed5    00000003     --HOLE-- [fill = 0]
                      00038ed8    0000006f     embedded_kafka.obj (.rodata.str1.4)
                      00038f47    00000001     --HOLE-- [fill = 0]
                      00038f48    00000050     freertos.am64x.m4f.ti-arm-clang.release.lib : printf.obj (.rodata._ftoa.pow10)
                      00038f98    00000050     drivers.am64x.m4f.ti-arm-clang.release.lib : ipc_rpmsg_vring.obj (.rodata.str1.1)
                      00038fe8    0000004b                                                : uart_dma.obj (.rodata.str1.1)
                      00039033    00000046     ti_drivers_open_close.obj (.rodata.str1.1)
                      00039079    00000042     ti_drivers_config.obj (.rodata.str1.1)
                      000390bb    0000003f     main.obj (.rodata.str1.1)
                      000390fa    0000002d     freertos.am64x.m4f.ti-arm-clang.release.lib : DebugP_log.obj (.rodata.str1.1)
                      00039127    0000002c     RPMessageEndpoint.obj (.rodata.str1.1)
                      00039153    00000022     libc.a : _printfi.c.obj (.rodata.str1.1)
                      00039175    00000003     --HOLE-- [fill = 0]
                      00039178    00000020     drivers.am64x.m4f.ti-arm-clang.release.lib : soc.obj (.rodata.SOC_getCoreName.coreIdNames)
                      00039198    00000020     ti_dpl_config.obj (.rodata.gMpuRegionConfig)
                      000391b8    0000001c     RPMessageEndpoint.obj (.rodata._ZTV17RPMessageEndpoint)
                      000391d4    0000001b     freertos.am64x.m4f.ti-arm-clang.release.lib : DebugP_shmLogWriter.obj (.rodata.str1.1)
                      000391ef    00000001     --HOLE-- [fill = 0]
                      000391f0    00000018     drivers.am64x.m4f.ti-arm-clang.release.lib : sciclient_soc_priv.obj (.rodata..Lswitch.table.Sciclient_getDevId)
                      00039208    00000018     RPMessageCommunication.obj (.rodata._ZTV22RPMessageCommunication)
                      00039220    00000012     freertos.am64x.m4f.ti-arm-clang.release.lib : printf.obj (.rodata.str1.1)
                      00039232    00000002     --HOLE-- [fill = 0]
                      00039234    00000010     TI_DebugLogger.obj (.rodata._ZTV14TI_DebugLogger)
                      00039244    0000000c     ti_dpl_config.obj (.rodata.gMpuConfig)
    .data      0    00039250    000003e0
                      00039250    0000009c     drivers.am64x.m4f.ti-arm-clang.release.lib : uart_v0.obj (.data.gUartDrvObj)
                      000392ec    00000093                                                : ipc_notify_v0_cfg.obj (.data.gIpcNotifyMailboxConfig)
                      0003937f    00000001                                                : sciclient.obj (.data.gSecHeaderSizeWords)
                      00039380    00000088     main.obj (.data.gMainTaskObj)
                      00039408    00000054     ti_drivers_open_close.obj (.data.gUartParams)
                      0003945c    00000004     freertos.am64x.m4f.ti-arm-clang.release.lib : DebugP_shmLogWriter.obj (.data.DebugP_shmLogWriterPutChar.lineBufIndex)
                      00039460    00000040     ti_dpl_config.obj (.data.gAddrTranslateRegionConfig)
                      000394a0    00000030     drivers.am64x.m4f.ti-arm-clang.release.lib : ipc_notify_v0_cfg.obj (.data.gIpcNotifyInterruptConfig_m4fss0_0)
                      000394d0    00000024                                                : ipc_notify_v0_cfg.obj (.data.gIpcNotifyMailboxBaseAddr)
                      000394f4    00000004     freertos.am64x.m4f.ti-arm-clang.release.lib : tasks.obj (.data.FreeRTOS_errno)
                      000394f8    00000020     drivers.am64x.m4f.ti-arm-clang.release.lib : sciclient_soc_priv.obj (.data.gSciclientSecProxyCfg)
                      00039518    00000018     ti_pinmux_config.obj (.data.gPinMuxMcuDomainCfg)
                      00039530    00000018     ti_power_clock_config.obj (.data.gSocModulesClockFrequency)
                      00039548    00000014     ti_dpl_config.obj (.data.gClockConfig)
                      0003955c    0000000c     freertos.am64x.m4f.ti-arm-clang.release.lib : AddrTranslateP.obj (.data.gAddrTranslateConfig)
                      00039568    00000008     ti_pinmux_config.obj (.data.gPinMuxMainDomainCfg)
                      00039570    00000008     ti_power_clock_config.obj (.data.gSocModules)
                      00039578    00000008     ti_drivers_config.obj (.data.gUartAttrs)
                      00039580    00000008     ti_drivers_config.obj (.data.gUartConfig)
                      00039588    00000008     freertos.am64x.m4f.ti-arm-clang.release.lib : TaskP_freertos.obj (.data.vApplicationLoadHook.lastUpdateTime)
                      00039590    00000004     libc.a : aeabi_portable.c.obj (.data.__aeabi_errno)
                      00039594    00000004     libc++abi.a : cxa_default_handlers.cpp.obj (.data.__cxa_new_handler)
                      00039598    00000004     libc.a : _lock.c.obj (.data._lock)
                      0003959c    00000004            : _lock.c.obj (.data._unlock)
                      000395a0    00000004     freertos.am64x.m4f.ti-arm-clang.release.lib : DebugP_log.obj (.data.gDebugLogZone)
                      000395a4    00000004                                                 : DebugP_uartLogWriter.obj (.data.gDebugP_uartDrvIndex)
                      000395a8    00000004                                                 : DebugP_shmLogWriter.obj (.data.gDebugShmLogWriter)
                      000395ac    00000004                                                 : DebugP_shmLogWriter.obj (.data.gDebugShmLogWriterSelfCoreName)
                      000395b0    00000004     drivers.am64x.m4f.ti-arm-clang.release.lib : ipc_notify_v0_cfg.obj (.data.gIpcNotifyInterruptConfigNum_m4fss0_0)
                      000395b4    00000004     embedded_kafka.obj (.data.gMsgEchoCount)
                      000395b8    00000004     drivers.am64x.m4f.ti-arm-clang.release.lib : sciclient.obj (.data.gSciclientHandle.0)
                      000395bc    00000004                                                : sciclient.obj (.data.gSciclientHandle.2)
                      000395c0    00000004                                                : sciclient.obj (.data.gSciclientHandle.3)
                      000395c4    00000004                                                : sciclient.obj (.data.gSciclientHandle.4)
                      000395c8    00000004                                                : sciclient.obj (.data.gSciclientHandle.5)
                      000395cc    00000004     ti_drivers_config.obj (.data.gUartConfigNum)
                      000395d0    00000004     ti_drivers_config.obj (.data.gUartDmaConfigNum)
                      000395d4    00000004     freertos.am64x.m4f.ti-arm-clang.release.lib : timers.obj (.data.prvSampleTimeNow.xLastTime)
                      000395d8    00000004                                                 : tasks.obj (.data.pxCurrentTCB)
                      000395dc    00000004                                                 : tasks.obj (.data.ulTaskSwitchedInTime)
                      000395e0    00000004                                                 : tasks.obj (.data.ulTotalRunTime)
                      000395e4    00000004                                                 : port.obj (.data.uxCriticalNesting)
                      000395e8    00000004                                                 : tasks.obj (.data.uxCurrentNumberOfTasks)
                      000395ec    00000004                                                 : tasks.obj (.data.uxDeletedTasksWaitingCleanUp)
                      000395f0    00000004                                                 : tasks.obj (.data.uxSchedulerSuspended)
                      000395f4    00000004                                                 : tasks.obj (.data.uxTaskNumber)
                      000395f8    00000004                                                 : tasks.obj (.data.uxTopReadyPriority)
                      000395fc    00000004                                                 : tasks.obj (.data.xIdleTaskHandle)
                      00039600    00000004                                                 : tasks.obj (.data.xNextTaskUnblockTime)
                      00039604    00000004                                                 : tasks.obj (.data.xNumOfOverflows)
                      00039608    00000004                                                 : tasks.obj (.data.xPendedTicks)
                      0003960c    00000004                                                 : tasks.obj (.data.xSchedulerRunning)
                      00039610    00000004                                                 : tasks.obj (.data.xTickCount)
                      00039614    00000004                                                 : timers.obj (.data.xTimerQueue)
                      00039618    00000004                                                 : timers.obj (.data.xTimerTaskHandle)
                      0003961c    00000004                                                 : tasks.obj (.data.xYieldPending)
                      00039620    00000001                                                 : DebugP_freertos.obj (.data.gDebugLogIsInitDone)
                      00039621    00000003     --HOLE-- [fill = 0]
                      00039624    00000001     libc.a : memory.c.obj (.data.memory_is_initialized)
                      00039625    00000003     --HOLE-- [fill = 0]
                      00039628    00000001     freertos.am64x.m4f.ti-arm-clang.release.lib : port.obj (.data.ulPortSchedularRunning)
                      00039629    00000007     --HOLE-- [fill = 0]
    .init_array
    *          0    00000200    00000000     UNINITIALIZED
    .bss.log_shared_mem
    *          0    701d0080    00003800     NOLOAD SECTION
                      701d0080    00003800     ti_dpl_config.obj (.bss.log_shared_mem)
    .bss.ipc_vring_mem
    *          0    701d4000    000099c0     NOLOAD SECTION
                      701d4000    000099c0     ti_drivers_config.obj (.bss.ipc_vring_mem)
    __llvm_prf_cnts
    *          0    00030000    00000000     UNINITIALIZED
    __llvm_prf_bits
    .ARM.exidx
    *          0    00015f00    00000008
                      00015f00    00000008     (.ARM.exidx.text:__TI_printfi:libc.a<_printfi.c.obj>)
    MODULE SUMMARY
           Module                              code    ro data   rw data
        obj/release/
           ti_drivers_config.obj               272     66        40024
           main.obj                            148     63        16524
           ti_dpl_config.obj                   110     44        14420
           embedded_kafka.obj                  694     631       4
           RPMessageCommunication.obj          414     142       0
           ti_drivers_open_close.obj           80      70        88
           TI_DebugLogger.obj                  212     19        0
           RPMessageEndpoint.obj               102     72        0
           ti_power_clock_config.obj           116     0         32
           ti_pinmux_config.obj                34      0         32
           CommunicationFactory.obj            32      0         0
           EndpointFactory.obj                 24      0         0
           BrokerMetadata.obj                  16      0         0
           ti_board_open_close.obj             6       0         0
           ti_board_config.obj                 2       0         0
           Total:                              2262    1107      71124
        /home/thomas/ti/mcu_plus_sdk_am64x_08_05_00_24/source/drivers/lib/drivers.am64x.m4f.ti-arm-clang.release.lib
           ipc_rpmsg.obj                       1738    794       2860
           uart_v0.obj                         3488    309       156
           ipc_notify_v0.obj                   1570    381       168
           sciclient.obj                       1222    0         21
           ipc_rpmsg_vring.obj                 1116    80        0
           sciclient_pm.obj                    1068    0         0
           soc.obj                             450     155       0
           uart_dma.obj                        256     75        0
           sciclient_fmwSecureProxyMap.obj     0       300       0
           ipc_notify_v0_cfg.obj               0       0         235
           pinmux.obj                          190     0         0
           sciclient_soc_priv.obj              102     24        32
           csl_sec_proxy.obj                   10      0         0
           Total:                              11210   2118      3472
        /home/thomas/ti/mcu_plus_sdk_am64x_08_05_00_24/source/kernel/freertos/lib/freertos.am64x.m4f.ti-arm-clang.release.lib
           tasks.obj                           4130    2034      812
           port.obj                            800     429       5397
           queue.obj                           3316    1878      256
           printf.obj                          4530    98        0
           timers.obj                          1220    700       396
           HwiP_armv7m.obj                     954     0         640
           SemaphoreP_freertos.obj             402     218       80
           ClockP_freertos_m4.obj              310     266       0
           DebugP_shmLogWriter.obj             358     27        134
           SysTickTimerP.obj                   340     169       0
           HwiP_armv7m_handlers_freertos.obj   166     0         320
           MpuP_armv7m.obj                     446     0         0
           TaskP_freertos.obj                  262     0         168
           AddrTranslateP.obj                  292     0         12
           ClockP_freertos.obj                 216     0         56
           DebugP_freertos.obj                 118     0         153
           DebugP_log.obj                      156     45        4
           list.obj                            150     0         0
           boot_armv7m.obj                     88      0         0
           DebugP_uartLogWriter.obj            70      0         4
           heap_3.obj                          26      0         0
           Total:                              18350   5864      8432
        /home/thomas/ti/ti-cgt-armllvm_2.1.2.LTS/lib/armv7em-ti-none-eabihf/c/libc.a
           _printfi.c.obj                      4934    34        0
           memory.c.obj                        720     0         5
           s_scalbn.c.obj                      268     0         0
           aeabi_ctype.S.obj                   0       257       0
           vsnprintf.c.obj                     132     0         0
           s_frexp.c.obj                       104     0         0
           _ltoa.c.obj                         86      0         0
           atoi.c.obj                          72      0         0
           autoinit.c.obj                      56      0         0
           memccpy.c.obj                       30      0         0
           memcpy_t2.S.obj                     18      0         0
           wcslen.c.obj                        16      0         0
           memset_t2.S.obj                     14      0         0
           aeabi_portable.c.obj                8       0         4
           _lock.c.obj                         2       0         8
           exit.c.obj                          4       0         0
           Total:                              6464    291       17
        /home/thomas/ti/ti-cgt-armllvm_2.1.2.LTS/lib/armv7em-ti-none-eabihf/libc++abi.a
           stdlib_new_delete.cpp.obj           40      0         0
           cxa_handlers.cpp.obj                12      0         0
           cxa_default_handlers.cpp.obj        0       0         4
           Total:                              52      0         4
        /home/thomas/ti/ti-cgt-armllvm_2.1.2.LTS/lib/clang/14.0.6/lib/armv7em-ti-none-eabihf/libclang_rt.builtins.a
           adddf3.S.obj                        438     0         0
           divdf3.S.obj                        310     0         0
           comparedf2.c.obj                    268     0         0
           muldf3.S.obj                        252     0         0
           udivmoddi4.S.obj                    176     0         0
           aeabi_dcmp.S.obj                    98      0         0
           fixdfsi.S.obj                       72      0         0
           fixunsdfsi.S.obj                    68      0         0
           floatsidf.S.obj                     46      0         0
           floatunsidf.S.obj                   32      0         0
           aeabi_memset.S.obj                  20      0         0
           aeabi_uldivmod.S.obj                20      0         0
           aeabi_memcpy.S.obj                  4       0         0
           aeabi_div0.c.obj                    2       0         0
           Total:                              1806    0         0
           Heap:                               0       0         32768
           Stack:                              0       0         16384
           Linker Generated:                   0       8         0
           Grand Total:                        40144   9388      132201
    GLOBAL SYMBOLS: SORTED ALPHABETICALLY BY Name
    address   name
    00015f00  .ARM.exidx$$Base
    00015f08  .ARM.exidx$$Limit
    00009e7d  AddrTranslateP_Params_init
    00008171  AddrTranslateP_getLocalAddr
    00006671  AddrTranslateP_init
    000032f7  Board_driversClose
    00004153  Board_driversOpen
    000034ff  Board_init
    00009ef8  C$$EXIT
    00009e87  CSL_secProxyGetDataAddr
    0000524b  ClockP_getTicks
    00008f3d  ClockP_getTimeUsec
    00008385  ClockP_getTimerCount
    00004a69  ClockP_init
    00009dad  ClockP_ticksToUsec
    00003aa3  ClockP_timerClearOverflowInt
    000096c5  ClockP_timerTickIsr
    00009cf1  ClockP_usecToTicks
    00009509  ClockP_usleep
    00009991  DebugP_logZoneEnable
    000095a5  DebugP_shmLogWriterInit
    00006721  DebugP_shmLogWriterPutChar
    00007745  DebugP_shmLogWriterPutLine
    000093b1  DebugP_uartLogWriterPutChar
    000086b5  DebugP_uartSetDrvIndex
    000089b7  Dpl_init
    00009ed1  Drivers_open
    00008f89  Drivers_uartOpen
    000394f4  FreeRTOS_errno
    000020a1  HwiP_Params_init
    00006aeb  HwiP_busFault_handler
    00002031  HwiP_clearInt
    000020b3  HwiP_construct
    00006b1b  HwiP_debugMon_handler
    00002151  HwiP_destruct
    000021df  HwiP_disable
    00001f79  HwiP_disableInt
    000021eb  HwiP_enable
    00001f21  HwiP_enableInt
    00006acb  HwiP_hardFault_handler
    00009caf  HwiP_inISR
    000021f7  HwiP_init
    00006a85  HwiP_interrupt_handler
    00006adb  HwiP_memFault_handler
    00006ab9  HwiP_nmi_handler
    000021cb  HwiP_post
    00006b0b  HwiP_reserved_handler
    00001f6f  HwiP_restore
    00001fd5  HwiP_restoreInt
    00002053  HwiP_setPri
    00006afb  HwiP_usageFault_handler
    00009b51  IpcNotify_Params_init
    00009c07  IpcNotify_getConfig
    00009e41  IpcNotify_getSelfCoreId
    000022c5  IpcNotify_init
    00009c1f  IpcNotify_isCoreEnabled
    00005e19  IpcNotify_isr
    00009205  IpcNotify_registerClient
    00005fb1  IpcNotify_sendMsg
    00009e91  IpcNotify_sendSync
    00009a11  IpcNotify_syncCallback
    00008589  IpcNotify_waitSync
    000096f5  Module_clockEnable
    00009429  Module_clockSetFrequency
    000038e5  MpuP_RegionAttrs_init
    000039f5  MpuP_disable
    000039bb  MpuP_enable
    00003a2b  MpuP_init
    00003a1b  MpuP_isEnable
    000038f3  MpuP_setRegion
    0000638d  Pinmux_config
    0000994d  Pinmux_init
    00009ded  PowerClock_init
    00009dbd  RPMessage_CreateParams_init
    000097ab  RPMessage_Params_init
    00008fd5  RPMessage_allocEndPtMsg
    00007ac1  RPMessage_construct
    0000984d  RPMessage_controlEndPtHandler
    000072ad  RPMessage_coreInit
    00007edd  RPMessage_getEndPtMsg
    00009ed5  RPMessage_getLocalEndPt
    00005c51  RPMessage_init
    0000996f  RPMessage_isLinuxCore
    00008d11  RPMessage_notifyCallback
    000046c7  RPMessage_recv
    0000513f  RPMessage_recvHandler
    0000576f  RPMessage_send
    00009461  RPMessage_vringCheckEmptyTxBuf
    00007505  RPMessage_vringGetEmptyTxBuf
    00006b2b  RPMessage_vringGetFullRxBuf
    00009b6b  RPMessage_vringGetRxBufAddr
    00009b85  RPMessage_vringGetTxBufAddr
    00009aa7  RPMessage_vringGetTxBufLen
    0000895d  RPMessage_vringIsFullRxBuf
    00006efd  RPMessage_vringPutEmptyRxBuf
    00008787  RPMessage_vringPutFullTxBuf
    0000644b  RPMessage_vringReset
    00007629  RPMessage_vringResetInternal
    00009ac3  SOC_getCoreName
    00007d17  SOC_moduleClockEnable
    00004935  SOC_moduleSetClockFrequency
    00008d61  Sciclient_getContext
    00009499  Sciclient_getCurrentContext
    00009cc5  Sciclient_getDevId
    00007175  Sciclient_init
    00007953  Sciclient_pmGetModuleClkNumParent
    000083f1  Sciclient_pmGetModuleClkParent
    00007f4b  Sciclient_pmGetModuleState
    00008901  Sciclient_pmModuleClkRequest
    000085ed  Sciclient_pmModuleGetClkStatus
    00006f9b  Sciclient_pmQueryModuleClkFreq
    000076b9  Sciclient_pmSetModuleClkFreq
    000087e5  Sciclient_pmSetModuleClkParent
    000090f7  Sciclient_pmSetModuleRst
    00008c6b  Sciclient_pmSetModuleState
    00002649  Sciclient_service
    00007dfb  SemaphoreP_constructBinary
    00008db1  SemaphoreP_constructMutex
    0000163b  SemaphoreP_destruct
    00008457  SemaphoreP_pend
    000084bd  SemaphoreP_post
    00009a2f  SysTickTimerP_Params_init
    00009dfb  SysTickTimerP_getCount
    00009e09  SysTickTimerP_getReloadCount
    00005469  SysTickTimerP_setup
    00009d41  SysTickTimerP_start
    00005969  System_init
    00009d9b  TI_memcpy_small
    00009e33  TI_memset_small
    000067d1  TaskP_loadUpdateAll
    00009c37  TaskP_yield
    00004443  UART_close
    00008bc3  UART_dmaClose
    00008abf  UART_dmaDisableChannel
    000092fd  UART_dmaOpen
    000065bd  UART_flushTxFifo
    00009723  UART_getHandle
    000073dd  UART_init
    00001145  UART_open
    000032f9  UART_write
    00009b9f  UART_writeInterruptDma
    00008845  _DebugP_assert
    00009a4d  _DebugP_assertNoLog
    00007c29  _DebugP_logZone
    00003fb9  _Z11r5_0_0_codei
    00009d53  _Z13freertos_mainPv
    00009339  _Z18communication_mainPv
    00007039  _Z8receiveri
    00009e4d  _ZN14BrokerMetadataC1EP8Endpoint
    00009e4d  _ZN14BrokerMetadataC2EP8Endpoint
    00009c4f  _ZN15EndpointFactory14createEndpointE17CommunicationType
    00009ed9  _ZN17RPMessageEndpoint18setServiceEndpointEt
    00003c5f  _ZN17RPMessageEndpoint9from_jsonERKN8nlohmann16json_abi_v3_11_210basic_jsonINSt3__13mapENS3_6vectorENS3_12basic_stringIcNS3_11char_traitsIcEENS3_9allocatorIcEEEEbxydS9_NS1_14adl_serializerENS5_IhNS9_IhEEEEvEE
    00009edd  _ZN17RPMessageEndpoint9setCoreIdEj
    00009d65  _ZN17RPMessageEndpointC1Ejt
    00009bb9  _ZN17RPMessageEndpointC1Ev
    00009d65  _ZN17RPMessageEndpointC2Ejt
    00009bb9  _ZN17RPMessageEndpointC2Ev
    00009ee1  _ZN17RPMessageEndpointD0Ev
    00003e17  _ZN17RPMessageEndpointD1Ev
    00003e17  _ZN17RPMessageEndpointD2Ev
    000099b1  _ZN20CommunicationFactory19createCommunicationE17CommunicationTypeRK8EndpointRK6Logger
    00008523  _ZN22RPMessageCommunication4readEPcjR8Endpoint
    00007ca1  _ZN22RPMessageCommunication5writeEPKcjRK8Endpoint
    000078d3  _ZN22RPMessageCommunicationC1ERK17RPMessageEndpointRK6Logger
    000078d3  _ZN22RPMessageCommunicationC2ERK17RPMessageEndpointRK6Logger
    00009873  _ZN22RPMessageCommunicationD0Ev
    00009a6b  _ZN22RPMessageCommunicationD1Ev
    00009a6b  _ZN22RPMessageCommunicationD2Ev
    00009ee5  _ZNK14BrokerMetadata11getEndpointEv
    000081dd  _ZNK14TI_DebugLogger3logEPKcz
    00008249  _ZNK14TI_DebugLogger8logErrorEPKcz
    00009ee9  _ZNK17RPMessageEndpoint18getServiceEndpointEv
    000099d1  _ZNK17RPMessageEndpoint24printEndpointInformationERK6Logger
    00004157  _ZNK17RPMessageEndpoint7to_jsonERN8nlohmann16json_abi_v3_11_210basic_jsonINSt3__13mapENS3_6vectorENS3_12basic_stringIcNS3_11char_traitsIcEENS3_9allocatorIcEEEEbxydS9_NS1_14adl_serializerENS5_IhNS9_IhEEEEvEE
    00009eed  _ZNK17RPMessageEndpoint9getCoreIdEv
    00009781  _ZNSt3__16vectorI13TopicMetadataNS_9allocatorIS1_EEE22__base_destruct_at_endEPS1_
    00009c67  _ZNSt3__16vectorI13TopicMetadataNS_9allocatorIS1_EEED2Ev
    00009e59  _ZSt15get_new_handlerv
    00039234  _ZTV14TI_DebugLogger
    000391b8  _ZTV17RPMessageEndpoint
    00039208  _ZTV22RPMessageCommunication
    00009ef1  _ZdlPv
    00009899  _Znwj
    00036da0  __BSS_END
    00030000  __BSS_START
    00015f00  __STACK_END
    00004000  __STACK_SIZE
    00008000  __SYSMEM_SIZE
    UNDEFED   __TI_CINIT_Base
    UNDEFED   __TI_CINIT_Limit
    UNDEFED   __TI_Handler_Table_Base
    UNDEFED   __TI_Handler_Table_Limit
    00015f08  __TI_UNWIND_TABLE_END
    00015f00  __TI_UNWIND_TABLE_START
    000094d1  __TI_auto_init_nobinit_nopinit
    00008b15  __TI_ltoa
    ffffffff  __TI_pprof_out_hndl
    00000201  __TI_printfi
    ffffffff  __TI_prof_data_size
    ffffffff  __TI_prof_data_start
    00000000  __TI_static_base__
    00003c6b  __adddf3
    00038b60  __aeabi_ctype_table_
    00038b60  __aeabi_ctype_table_C
    00009069  __aeabi_d2iz
    00009181  __aeabi_d2uiz
    00003c6b  __aeabi_dadd
    00008725  __aeabi_dcmpeq
    00008761  __aeabi_dcmpge
    00008775  __aeabi_dcmpgt
    0000874d  __aeabi_dcmple
    00008739  __aeabi_dcmplt
    000095d5  __aeabi_dcmpun
    000047fd  __aeabi_ddiv
    0000586d  __aeabi_dmul
    00003c61  __aeabi_dsub
    00039590  __aeabi_errno
    00009eb1  __aeabi_errno_addr
    00009751  __aeabi_i2d
    00004933  __aeabi_ldiv0
    00009d25  __aeabi_memclr
    00009d25  __aeabi_memclr4
    00009d25  __aeabi_memclr8
    00009efd  __aeabi_memcpy
    00009efd  __aeabi_memcpy4
    00009efd  __aeabi_memcpy8
    00009d19  __aeabi_memset
    00009d19  __aeabi_memset4
    00009d19  __aeabi_memset8
    000099f1  __aeabi_ui2d
    00009d2d  __aeabi_uldivmod
    ffffffff  __binit__
    00008029  __cmpdf2
    00039594  __cxa_new_handler
    000047fd  __divdf3
    00008029  __eqdf2
    00009069  __fixdfsi
    00009181  __fixunsdfsi
    00009751  __floatsidf
    000099f1  __floatunsidf
    00007fb9  __gedf2
    00007fb9  __gtdf2
    00008029  __ledf2
    00008029  __ltdf2
    00009ef5  __mpu_init
    0000586d  __muldf3
    00008029  __nedf2
    00011f00  __stack
    00030000  __start___llvm_prf_bits
    00030000  __start___llvm_prf_cnts
    00030000  __stop___llvm_prf_bits
    00030000  __stop___llvm_prf_cnts
    00003c61  __subdf3
    00006881  __udivmoddi4
    000095d5  __unorddf2
    00008a67  _c_int00
    00039598  _lock
    00004de7  _nop
    00009f00  _sys_memory
    UNDEFED   _system_post_cinit
    0003959c  _unlock
    00009ef9  abort
    00004de9  aligned_alloc
    00009021  atoi
    ffffffff  binit
    00006dbd  eTaskGetState
    00005a61  free
    00008389  frexp
    00008389  frexpl
    0003955c  gAddrTranslateConfig
    00039460  gAddrTranslateRegionConfig
    00039548  gClockConfig
    00036cc0  gClockCtrl
    000395a0  gDebugLogZone
    000395a4  gDebugP_uartDrvIndex
    701d0080  gDebugShmLog
    0003642c  gHwiCtrl
    00000000  gHwiP_vectorTable
    000368ac  gIpcNotifyCtrl
    000395b0  gIpcNotifyInterruptConfigNum_m4fss0_0
    000394a0  gIpcNotifyInterruptConfig_m4fss0_0
    000394d0  gIpcNotifyMailboxBaseAddr
    000392ec  gIpcNotifyMailboxConfig
    00035000  gIpcRpmsgCtrl
    00036954  gMainTask
    00039380  gMainTaskObj
    00030000  gMainTaskStack
    00039244  gMpuConfig
    00039198  gMpuRegionConfig
    000395b4  gMsgEchoCount
    701d4000  gRPMessageVringMem
    00036c6c  gRovDummyQueue
    00038924  gSciclientMap
    000394f8  gSciclientSecProxyCfg
    00039570  gSocModules
    00039530  gSocModulesClockFrequency
    00036958  gTaskP_ctrl
    00039580  gUartConfig
    000395cc  gUartConfigNum
    00039250  gUartDmaConfig
    000395d0  gUartDmaConfigNum
    00036d94  gUartHandle
    00039408  gUartParams
    00005251  ldexp
    00005251  ldexpl
    00007851  main
    00009ec1  malloc
    00004de9  memalign
    00009a89  memccpy
    00009d77  putchar_
    00009c97  pvTaskIncrementMutexHeldCount
    000395d8  pxCurrentTCB
    000097fd  pxPortInitialiseStack
    00005251  scalbn
    00005251  scalbnl
    00009573  snprintf_
    00009ec9  uiPortGetRunTimeCounterValue
    000098bd  uxListRemove
    00038b5c  uxTopUsedPriority
    00009afd  vApplicationGetIdleTaskMemory
    00009b19  vApplicationGetTimerTaskMemory
    00009ea5  vApplicationIdleHook
    00009243  vApplicationLoadHook
    00009665  vApplicationStackOverflowHook
    00009cdb  vListInitialise
    000029a3  vListInitialiseItem
    000093ed  vListInsert
    00009b35  vListInsertEnd
    0000586b  vPortConfigTimerForRunTimeStats
    000088a3  vPortEnterCritical
    0000913b  vPortExitCritical
    00009bd3  vPortFree
    000098e1  vPortSVCHandler
    00009281  vPortTimerTickHandler
    00009825  vQueueAddToRegistry
    00008651  vQueueDelete
    000090b1  vQueueWaitForMessageRestricted
    000082b3  vTaskDelay
    00004cc5  vTaskDelete
    00007345  vTaskGetInfo
    00009bed  vTaskInternalSetTimeOutState
    00009e25  vTaskMissedYield
    00008eef  vTaskPlaceOnEventList
    00008a0f  vTaskPlaceOnEventListRestricted
    00005d3f  vTaskPriorityDisinheritAfterTimeout
    00006145  vTaskStartScheduler
    00009dcd  vTaskSuspendAll
    00005b59  vTaskSwitchContext
    00009905  vprintf_
    00009375  vsnprintf
    00009ddd  wcslen
    000086c1  xPortPendSVHandler
    00007a47  xPortStartScheduler
    00009695  xQueueCreateMutexStatic
    00005671  xQueueGenericCreateStatic
    00007597  xQueueGenericReset
    000036fd  xQueueGenericSend
    00004b99  xQueueGenericSendFromISR
    0000535d  xQueueGiveFromISR
    00008cbd  xQueueGiveMutexRecursive
    00003aa5  xQueueReceive
    00005571  xQueueReceiveFromISR
    000367ac  xQueueRegistry
    00003501  xQueueSemaphoreTake
    00008e51  xQueueTakeMutexRecursive
    000070d7  xTaskCheckForTimeOut
    000062cb  xTaskCreateStatic
    00009e65  xTaskGetCurrentTaskHandle
    000092bf  xTaskGetIdleTaskHandle
    00009929  xTaskGetSchedulerState
    00009e71  xTaskGetTickCount
    000042d9  xTaskIncrementTick
    0000607b  xTaskPriorityDisinherit
    000069db  xTaskPriorityInherit
    00006d19  xTaskRemoveFromEventList
    00004589  xTaskResumeAll
    000077cb  xTimerCreateTimerTask
    00007bb1  xTimerGenericCommand
    GLOBAL SYMBOLS: SORTED BY Symbol Address
    address   name
    00001145  UART_open
    000021cb  HwiP_post
    000021f7  HwiP_init
    000032f9  UART_write
    000034ff  Board_init
    00003a2b  MpuP_init
    00003c61  __subdf3
    00003c6b  __adddf3
    00004443  UART_close
    000047fd  __divdf3
    00004de7  _nop
    00004de9  memalign
    00005251  ldexp
    00005251  ldexpl
    00005251  scalbn
    00005251  scalbnl
    0000586d  __muldf3
    00005a61  free
    000073dd  UART_init
    00007851  main
    00007fb9  __gedf2
    00007fb9  __gtdf2
    00008029  __cmpdf2
    00008029  __eqdf2
    00008029  __ledf2
    00008029  __ltdf2
    00008029  __nedf2
    000082b3  vTaskDelay
    00008389  frexp
    00008389  frexpl
    000089b7  Dpl_init
    00008a67  _c_int00
    00008b15  __TI_ltoa
    00009021  atoi
    00009069  __fixdfsi
    00009375  vsnprintf
    00009573  snprintf_
    000095d5  __unorddf2
    00009899  _Znwj
    00009905  vprintf_
    00009a89  memccpy
    00009bd3  vPortFree
    00009caf  HwiP_inISR
    00009d77  putchar_
    00009ddd  wcslen
    00009ec1  malloc
    00009ef1  _ZdlPv
    00009ef5  __mpu_init
    00009ef8  C$$EXIT
    00009ef9  abort
    00011f00  __stack
    0003642c  gHwiCtrl
    00036954  gMainTask
    00036cc0  gClockCtrl
    00036da0  __BSS_END
    00039244  gMpuConfig
    00039598  _lock
    0003959c  _unlock
    ffffffff  __binit__
    ffffffff  binit
    [379 symbols]
    This is the linker.cmd.
    /* make sure below retain is there in your linker command file, it keeps the vector table in the final binary */
    --retain="*(.vectors)"
    /* This is the stack that is used by code running within main()
     * In case of NORTOS,
     * - This means all the code outside of ISR uses this stack
     * In case of FreeRTOS
     * - This means all the code until vTaskStartScheduler() is called in main()
     *   uses this stack.
     * - After vTaskStartScheduler() each task created in FreeRTOS has its own stack
    --stack_size=16384
    /* This is the heap size for malloc() API in NORTOS and FreeRTOS
     * This is also the heap used by pvPortMalloc in FreeRTOS
    --heap_size=32768
    SECTIONS
        /* This has the M4F entry point and vector table, this MUST be at 0x0 */
        .vectors:{} palign(8) > M4F_VECS
        .text:   {} palign(8) > M4F_IRAM     /* This is where code resides */
        .bss:    {} palign(8) > M4F_DRAM     /* This is where uninitialized globals go */
        RUN_START(__BSS_START)
        RUN_END(__BSS_END)
        .data:   {} palign(8) > M4F_DRAM     /* This is where initialized globals and static go */
        .rodata: {} palign(8) > M4F_DRAM     /* This is where const's go */
        .sysmem: {} palign(8) > M4F_IRAM     /* This is where the malloc heap goes */
        .stack:  {} palign(8) > M4F_IRAM     /* This is where the main() stack goes */
        /* Sections needed for C++ projects */
        .ARM.exidx:     {} palign(8) > M4F_IRAM  /* Needed for C++ exception handling */
        .init_array:    {} palign(8) > M4F_IRAM  /* Contains function pointers called before main */
        .fini_array:    {} palign(8) > M4F_IRAM  /* Contains function pointers called after main */
        /* General purpose user shared memory */
        .bss.user_shared_mem (NOLOAD) : {} > USER_SHM_MEM
        /* this is used when Debug log's to shared memory are enabled, else this is not used */
        .bss.log_shared_mem  (NOLOAD) : {} > LOG_SHM_MEM
        /* this is used only when IPC RPMessage is enabled, else this is not used */
        .bss.ipc_vring_mem   (NOLOAD) : {} > IPC_VRING_MEM
    MEMORY
        M4F_VECS : ORIGIN = 0x00000000 , LENGTH = 0x00000200
        M4F_IRAM : ORIGIN = 0x00000200 , LENGTH = 0x0002FE00
        M4F_DRAM : ORIGIN = 0x00030000 , LENGTH = 0x00010000
        /* shared memories that are used by all cores */
        /* On M4F,
         * - By default MSMC RAM is not accessible to M4F, a RAT entry is needed to make it
         *   accessible on M4F
         * - So make sure there is a RAT entry which has a 1:1 mapping from 0x70000000 to 0x70200000
        USER_SHM_MEM : ORIGIN = 0x701D0000, LENGTH = 0x80
        LOG_SHM_MEM  : ORIGIN = 0x701D0000 + 0x80, LENGTH = 0x00004000 - 0x80
        IPC_VRING_MEM: ORIGIN = 0x701D4000, LENGTH = 0x0000C000
    Thomas
  • Hello Thomas,
    Could you please try the following steps & see if you are able to load and run the M4F core application through CCS.
    • Change the initialization of SP in startup code (_c_int00) of M4F core, defined in ${MCU+_SDK_PATH}/source/kernel/nortos/dpl/m4/boot_armv7m.c, as follows:
      /* Initialize the stack pointer */
      register char* stack_ptr = (char*)&__STACK_END - sizeof(uint32_t*);
      __asm volatile ("MSR msp, %0" : : "r" (stack_ptr) : );
    • Rebuild the libraries for the right profile (release or debug) as follows:
      ${MAKE} -s libs PROFILE={release|debug}
    • Rebuild the example.
    Following the above steps, you should be able to run the M4F application through CCS. Let me know if this works!
    Prashant
  • Hi Prashant,
    I tried the steps you said, but I still get the same error.
    Thomas
  • Hello Thomas,
    Actually, I also see the same behaviour. I am getting in touch with the CCS experts to understand what's going on. Till I have an answer, you can disable the CCS verification option to get away with the verification error.
    To disable the CCS verification option, please follow the below steps:
    • Connect to the M4F core.
    • Right click on the M4F core & click "Open GEL Files View" as shown
    • Choose the No Verification option as shown below
    • Load the application.
    Following the above steps, CCS should be able to load the application and run the same.
    Prashant
  • Hello Prashant,
    Thank you for the response, I confirm you that those steps solved the problem.
    Thomas
