Other Parts Discussed in Thread: TPS65219
Hello experts!
We are doing PMIC binding for our custom HW.
Used TPS6521904 and below is binding which we add in our dts.
After adding tps65219 kernel binding we are facing issue.
Log data follows:
| DEBUG: Executing python function externalsrc_compile_prefunc
| NOTE: linux-ti-staging-rt: compiling from external source tree /home/aws-suma/builds/build-lrd-am62xx-onecontrol-lrd-5.10-rt-test/workspace/sources/linux-ti-staging-rt
| DEBUG: Python function externalsrc_compile_prefunc finished
| DEBUG: Executing shell function do_compile
| NOTE: KBUILD_BUILD_TIMESTAMP: Tue May 2 05:02:10 UTC 2023
| NOTE: make 1 HOSTCC=gcc -isystem/home/aws-suma/builds/build-lrd-am62xx-onecontrol-lrd-5.10-rt-test/tmp/work/am62xx_onecontrol_lrd-poky-linux/linux-ti-staging-rt/5.10.158+git999-r0b/recipe-sysroot-native/usr/include -O2 -pipe -L/home/aws-suma/builds/build-lrd-am62xx-onecontrol-lrd-5.10-rt-test/tmp/work/am62xx_onecontrol_lrd-poky-linux/linux-ti-staging-rt/5.10.158+git999-r0b/recipe-sysroot-native/usr/lib -L/home/aws-suma/builds/build-lrd-am62xx-onecontrol-lrd-5.10-rt-test/tmp/work/am62xx_onecontrol_lrd-poky-linux/linux-ti-staging-rt/5.10.158+git999-r0b/recipe-sysroot-native/lib -Wl,--enable-new-dtags -Wl,-rpath-link,/home/aws-suma/builds/build-lrd-am62xx-onecontrol-lrd-5.10-rt-test/tmp/work/am62xx_onecontrol_lrd-poky-linux/linux-ti-staging-rt/5.10.158+git999-r0b/recipe-sysroot-native/usr/lib -Wl,-rpath-link,/home/aws-suma/builds/build-lrd-am62xx-onecontrol-lrd-5.10-rt-test/tmp/work/am62xx_onecontrol_lrd-poky-linux/linux-ti-staging-rt/5.10.158+git999-r0b/recipe-sysroot-native/lib -Wl,-rpath,/home/aws-suma/builds/build-lrd-am62xx-onecontrol-lrd-5.10-rt-test/tmp/work/am62xx_onecontrol_lrd-poky-linux/linux-ti-staging-rt/5.10.158+git999-r0b/recipe-sysroot-native/usr/lib -Wl,-rpath,/home/aws-suma/builds/build-lrd-am62xx-onecontrol-lrd-5.10-rt-test/tmp/work/am62xx_onecontrol_lrd-poky-linux/linux-ti-staging-rt/5.10.158+git999-r0b/recipe-sysroot-native/lib -Wl,-O1 -Wl,--allow-shlib-undefined -Wl,--dynamic-linker=/home/aws-suma/builds/build-lrd-am62xx-onecontrol-lrd-5.10-rt-test/tmp/sysroots-uninative/x86_64-linux/lib/ld-linux-x86-64.so.2 HOSTCPP=gcc -E HOSTCXX=g++ -isystem/home/aws-suma/builds/build-lrd-am62xx-onecontrol-lrd-5.10-rt-test/tmp/work/am62xx_onecontrol_lrd-poky-linux/linux-ti-staging-rt/5.10.158+git999-r0b/recipe-sysroot-native/usr/include -O2 -pipe -L/home/aws-suma/builds/build-lrd-am62xx-onecontrol-lrd-5.10-rt-test/tmp/work/am62xx_onecontrol_lrd-poky-linux/linux-ti-staging-rt/5.10.158+git999-r0b/recipe-sysroot-native/usr/lib -L/home/aws-suma/builds/build-lrd-am62xx-onecontrol-lrd-5.10-rt-test/tmp/work/am62xx_onecontrol_lrd-poky-linux/linux-ti-staging-rt/5.10.158+git999-r0b/recipe-sysroot-native/lib -Wl,--enable-new-dtags -Wl,-rpath-link,/home/aws-suma/builds/build-lrd-am62xx-onecontrol-lrd-5.10-rt-test/tmp/work/am62xx_onecontrol_lrd-poky-linux/linux-ti-staging-rt/5.10.158+git999-r0b/recipe-sysroot-native/usr/lib -Wl,-rpath-link,/home/aws-suma/builds/build-lrd-am62xx-onecontrol-lrd-5.10-rt-test/tmp/work/am62xx_onecontrol_lrd-poky-linux/linux-ti-staging-rt/5.10.158+git999-r0b/recipe-sysroot-native/lib -Wl,-rpath,/home/aws-suma/builds/build-lrd-am62xx-onecontrol-lrd-5.10-rt-test/tmp/work/am62xx_onecontrol_lrd-poky-linux/linux-ti-staging-rt/5.10.158+git999-r0b/recipe-sysroot-native/usr/lib -Wl,-rpath,/home/aws-suma/builds/build-lrd-am62xx-onecontrol-lrd-5.10-rt-test/tmp/work/am62xx_onecontrol_lrd-poky-linux/linux-ti-staging-rt/5.10.158+git999-r0b/recipe-sysroot-native/lib -Wl,-O1 -Wl,--allow-shlib-undefined -Wl,--dynamic-linker=/home/aws-suma/builds/build-lrd-am62xx-onecontrol-lrd-5.10-rt-test/tmp/sysroots-uninative/x86_64-linux/lib/ld-linux-x86-64.so.2 Image CC=aarch64-poky-linux-gcc -fuse-ld=bfd -fmacro-prefix-map=/home/aws-suma/builds/build-lrd-am62xx-onecontrol-lrd-5.10-rt-test/tmp/work/am62xx_onecontrol_lrd-poky-linux/linux-ti-staging-rt/5.10.158+git999-r0b=/usr/src/debug/linux-ti-staging-rt/5.10.158+git999-r0b -fdebug-prefix-map=/home/aws-suma/builds/build-lrd-am62xx-onecontrol-lrd-5.10-rt-test/tmp/work/am62xx_onecontrol_lrd-poky-linux/linux-ti-staging-rt/5.10.158+git999-r0b=/usr/src/debug/linux-ti-staging-rt/5.10.158+git999-r0b -fdebug-prefix-map=/home/aws-suma/builds/build-lrd-am62xx-onecontrol-lrd-5.10-rt-test/tmp/work/am62xx_onecontrol_lrd-poky-linux/linux-ti-staging-rt/5.10.158+git999-r0b/recipe-sysroot= -fdebug-prefix-map=/home/aws-suma/builds/build-lrd-am62xx-onecontrol-lrd-5.10-rt-test/tmp/work/am62xx_onecontrol_lrd-poky-linux/linux-ti-staging-rt/5.10.158+git999-r0b/recipe-sysroot-native= -fdebug-prefix-map=/home/aws-suma/builds/build-lrd-am62xx-onecontrol-lrd-5.10-rt-test/tmp/work-shared/am62xx-onecontrol-lrd/kernel-source=/usr/src/kernel -fdebug-prefix-map=/home/aws-suma/builds/build-lrd-am62xx-onecontrol-lrd-5.10-rt-test/tmp/work-shared/am62xx-onecontrol-lrd/kernel-build-artifacts=/usr/src/kernel LD=aarch64-poky-linux-ld.bfd LOADADDR=0x80008000 DTC_FLAGS=-@
| make[1]: *** No rule to make target '1'. Stop.
| /home/aws-suma/builds/build-lrd-am62xx-onecontrol-lrd-5.10-rt-test/workspace/sources/linux-ti-staging-rt/Makefile:185: recipe for target '__sub-make' failed
| make: *** [__sub-make] Error 2
| ERROR: oe_runmake failed
| WARNING: /home/aws-suma/builds/build-lrd-am62xx-onecontrol-lrd-5.10-rt-test/tmp/work/am62xx_onecontrol_lrd-poky-linux/linux-ti-staging-rt/5.10.158+git999-r0b/temp/run.do_compile.24104:1 exit 1 from 'exit 1'
| ERROR: Execution of '/home/aws-suma/builds/build-lrd-am62xx-onecontrol-lrd-5.10-rt-test/tmp/work/am62xx_onecontrol_lrd-poky-linux/linux-ti-staging-rt/5.10.158+git999-r0b/temp/run.do_compile.24104' failed with exit code 1
ERROR: Task (/home/aws-suma/builds/yocto/meta-ti/recipes-kernel/linux/linux-ti-staging-rt_5.10.bb:do_compile) failed with exit code '1'
NOTE: Tasks Summary: Attempted 3986 tasks of which 3980 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There were 2 ERROR messages shown, returning a non-zero exit code.
Is that fine to give only tps65219 name ?
below is data for binding we added on our custom DTS.
tps65219: pmic@30 {
compatible = "ti,tps65219";
reg = <0x30>;
buck1-supply = <&vcc_3v3_sys>;
buck2-supply = <&vcc_3v3_sys>;
buck3-supply = <&vcc_3v3_sys>;
ldo1-supply = <&vcc_3v3_sys>;
ldo2-supply = <&buck2_reg>;
ldo3-supply = <&vcc_3v3_sys>;
ldo4-supply = <&vcc_3v3_sys>;
pinctrl-0 = <&pmic_irq_pins_default>;
interrupt-parent = <&gic500>;
interrupts = <GIC_SPI 224 IRQ_TYPE_LEVEL_HIGH>;
interrupt-controller;
#interrupt-cells = <1>;
regulators {
buck1_reg: buck1 {
regulator-name = "VDD_CORE";
regulator-min-microvolt = <750000>;
regulator-max-microvolt = <750000>;
regulator-boot-on;
regulator-always-on;
buck2_reg: buck2 {
regulator-name = "VCC1V8";
regulator-min-microvolt = <1800000>;
regulator-max-microvolt = <1800000>;
regulator-boot-on;
buck3_reg: buck3 {
regulator-name = "VDD_LPDDR4";
regulator-min-microvolt = <1200000>;
regulator-max-microvolt = <1200000>;
regulator-boot-on;
ldo1_reg: ldo1 {
regulator-name = "VDDSHV_SD_IO_PMIC";
regulator-min-microvolt = <33000000>;
regulator-max-microvolt = <33000000>;
ldo2_reg: ldo2 {
regulator-name = "VDDAR_CORE";
regulator-min-microvolt = <850000>;
regulator-max-microvolt = <850000>;
regulator-boot-on;
ldo3_reg: ldo3 {
regulator-name = "VDDA_1V8";
regulator-min-microvolt = <18000000>;
regulator-max-microvolt = <18000000>;
regulator-boot-on;
ldo4_reg: ldo4 {
regulator-name = "VDD_PHY_2V5";
regulator-min-microvolt = <25000000>;
regulator-max-microvolt = <25000000>;
regulator-boot-on;
is that fine or we need to add on u-boot DTS as well ?
Anything we missed here?
Suraj.
