Other Parts Discussed in Thread: TDA4VH
Hello Everyone!
Hope this query finds you well!
I was looking through the datasheet of TDA4VH-Q1 ( https://www.ti.com/lit/ds/symlink/tda4vh-q1.pdf ) and in the section tittled "High speed serial interfaces:" there are 8 external ports mentioned, while on the section tittled: " Ethernet" it is mentioned that there are only 2 RGMII/RMII interfaces.
Can you help clarify what the optimal/maximal data output from the SoC to outside through the ethernet ports is? Also what the maximal data throughput per port is for the SoC? I read quite a few high speed ethernet interfaces while loking through the datasheet, but seems like they all only apply to the "switch" section of the ethernet of the SoC, not to the ethernet output of the SoC itself.
Thank you in advance!
Nuri
