PSP4.00.00.09: auido capture driver problem with 16-bit input - left channel and right channel is swapped
My customer found there is capture problem with 16-bit input for mcasp audio driver in stereo mode. The left channel and right channel is swapped. But if using 32-bit input and change the driver configuration to 32 bit, then everything is ok.
Would you pls kindly check if there is something missed?
