Hi team,
SK-TDA4VM AI BASE SDK 08_06_00 version is being used.
When running TI's Edge AI demo, how to get deep learning test results? The customer run object detection using the rpiV2 camera and when running the CPP routine, only the test box is output in the image of output. In the customer's project, it is required to have the information output, such as the center of the test box.
The customer guess that the test box drawing of the original image should be implemented in post-proc, etc., but how to get the output of the specific test case here?
Could you help check this case? Thanks.
Cherry
