Part Number: TDA4VE-Q1
Hello Champs,
Customer is using two own boards:
1. tda4ve board with emmc: MTFC32GAZAQHD-AA
2. TDAVH board with emmc: KLMBG4GEUF-B04Q
SW: sdk 8.6
He found that the two boards' HS400 is not stable.
Below is the log.
13:36:59]tar: ./opt/ltp/testcases/open_posix_testsuite/conformance/definitions/signal_h/33-1-buildonly.c: time stamp 202[ 321.746701] mmc0: Got data interrupt 0x00200000 even though no data operation was in progress.
[13:36:59][ 321.758903] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
[13:36:59][ 321.765325] mmc0: sdhci: Sys addr: 0x000003d8 | Version: 0x00001004
[13:36:59][ 321.771747] mmc0: sdhci: Blk size: 0x00007080 | Blk cnt: 0x00000001
[13:36:59][ 321.778169] mmc0: sdhci: Argument: 0x00000000 | Trn mode: 0x00000013
[13:36:59][ 321.784590] mmc0: sdhci: Present: 0x01ff00f0 | Host ctl: 0x0000003d
[13:36:59][ 321.791012] mmc0: sdhci: Power: 0x0000000b | Blk gap: 0x00000080
[13:36:59][ 321.797433] mmc0: sdhci: Wake-up: 0x00000000 | Clock: 0x00000007
[13:36:59][ 321.803854] mmc0: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[13:36:59][ 321.810275] mmc0: sdhci: Int enab: 0x03ff000b | Sig enab: 0x03ff000b
[13:36:59][ 321.816696] mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[13:36:59][ 321.823117] mmc0: sdhci: Caps: 0x7cecc801 | Caps_1: 0x98002407
[13:36:59][ 321.829538] mmc0: sdhci: Cmd: 0x0000153a | Max curr: 0x00000000
[13:36:59][ 321.835959] mmc0: sdhci: Resp[0]: 0x00000940 | Resp[1]: 0xffc003ff
[13:36:59][ 321.842380] mmc0: sdhci: Resp[2]: 0x328f5903 | Resp[3]: 0x00d07f01
[13:36:59][ 321.848801] mmc0: sdhci: Host ctl2: 0x0000000b
[13:36:59][ 321.853230] mmc0: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000008e5a3d200
[13:36:59][ 321.860343] mmc0: sdhci: ============================================
[13:36:59]3-03-01 19:07:57 is 3236.160522205 s in the future
[13:36:59]./opt/ltp/testcases/open_posix_testsuite/conformance/definitions/signal_h/34-1-buildonly.c
[13:36:59]tar: ./opt/ltp/testcases/open_posix_testsuite/co[ 321.879118] mmc0: running CQE recovery
[13:36:59]nformance/definitions/signal_h/34-1-buildonly.c: time stamp 2023-03-01 19:07:57 is 3236.16042483 s in the future
[13:36:59]./opt/ltp/testcases/open_posix_testsuite/conformance/definitions/signal_h/35-1-buildonly.c
[13:36:59]tar: ./opt/ltp/testcases/open_posix_testsuite/conformance/definitions/signal_h/35-1-buildonly.c: time stamp 2023-0[ 321.911007] mmc0: Got data interrupt 0x00200000 even though no data operation was in progress.
[13:36:59][ 321.923503] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
[13:36:59][ 321.929924] mmc0: sdhci: Sys addr: 0x00000398 | Version: 0x00001004
[13:36:59][ 321.936345] mmc0: sdhci: Blk size: 0x00007080 | Blk cnt: 0x00000001
[13:36:59][ 321.942766] mmc0: sdhci: Argument: 0x00000000 | Trn mode: 0x00000013
[13:36:59][ 321.949187] mmc0: sdhci: Present: 0x01ff00f0 | Host ctl: 0x0000003d
[13:36:59][ 321.955608] mmc0: sdhci: Power: 0x0000000b | Blk gap: 0x00000080
[13:36:59][ 321.962029] mmc0: sdhci: Wake-up: 0x00000000 | Clock: 0x00000007
[13:36:59][ 321.968449] mmc0: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[13:36:59][ 321.974870] mmc0: sdhci: Int enab: 0x03ff000b | Sig enab: 0x03ff000b
[13:36:59][ 321.981291] mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[13:36:59][ 321.987712] mmc0: sdhci: Caps: 0x7cecc801 | Caps_1: 0x98002407
[13:36:59][ 321.994133] mmc0: sdhci: Cmd: 0x0000153a | Max curr: 0x00000000
[13:36:59][ 322.000554] mmc0: sdhci: Resp[0]: 0x00001300 | Resp[1]: 0xffc003ff
[13:36:59][ 322.006977] mmc0: sdhci: Resp[2]: 0x328f5903 | Resp[3]: 0x00d07f01
[13:36:59][ 322.013397] mmc0: sdhci: Host ctl2: 0x0000000b
[13:36:59][ 322.017826] mmc0: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000008e5a3d200
[13:36:59][ 322.024939] mmc0: sdhci: ============================================
[13:36:59]3-01 19:07:57 is 3236.16031264 s in the future
[13:41:12][ 575.134475] mmc0: running CQE recovery
[13:41:12][ 575.173474] mmc0: running CQE recovery
[13:41:12][ 575.205391] mmc0: Got data interrupt 0x00200000 even though no data operation was in progress.
[13:41:12][ 575.213980] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
[13:41:12][ 575.220402] mmc0: sdhci: Sys addr: 0x000003e8 | Version: 0x00001004
[13:41:12][ 575.226823] mmc0: sdhci: Blk size: 0x00007080 | Blk cnt: 0x00000001
[13:41:12][ 575.233244] mmc0: sdhci: Argument: 0x00000000 | Trn mode: 0x00000013
[13:41:12][ 575.239666] mmc0: sdhci: Present: 0x01ff00f0 | Host ctl: 0x0000003d
[13:41:12][ 575.246087] mmc0: sdhci: Power: 0x0000000b | Blk gap: 0x00000080
[13:41:12][ 575.252508] mmc0: sdhci: Wake-up: 0x00000000 | Clock: 0x00000007
[13:41:12][ 575.258929] mmc0: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[13:41:12][ 575.265350] mmc0: sdhci: Int enab: 0x03ff000b | Sig enab: 0x03ff000b
[13:41:12][ 575.271771] mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[13:41:12][ 575.278192] mmc0: sdhci: Caps: 0x7cecc801 | Caps_1: 0x98002407
[13:41:12][ 575.284613] mmc0: sdhci: Cmd: 0x0000153a | Max curr: 0x00000000
[13:41:12][ 575.291034] mmc0: sdhci: Resp[0]: 0x00001b80 | Resp[1]: 0xffc003ff
[13:41:12][ 575.297455] mmc0: sdhci: Resp[2]: 0x328f5903 | Resp[3]: 0x00d07f01
[13:41:12][ 575.303875] mmc0: sdhci: Host ctl2: 0x0000000b
[13:41:12][ 575.308306] mmc0: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000008e5a3d200
[13:41:12][ 575.315419] mmc0: sdhci: ============================================
[13:41:12][ 575.801088] EXT4-fs warning (device mmcblk0p2): ext4_end_bio:347: I/O error 10 writing to inode 393543 starting block 283904)
[13:41:17][ 580.511113] EXT4-fs warning (device mmcblk0p2): ext4_end_bio:347: I/O error 10 writing to inode 392899 starting block 279808)
[13:41:17][ 580.522444] EXT4-fs warning (device mmcblk0p2): ext4_end_bio:347: I/O error 10 writing to inode 392906 starting block 281856)
emmc烧录问题.log
Shine
