Part Number: TDA3MV
Hi team,
Depending on the TDA3EVM to design the board, the following issues occur when running the program:
Here's the config message, could you help locate where this error occurred?
/home/cy/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/configs/autorules_footer_cfg.mk:67: avbtp_PATH does not exist! (/home/cy/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/networking/avbtp_0_10_00_00) /home/cy/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/configs/autorules_footer_cfg.mk:67: hdvicplib_PATH does not exist! (/home/cy/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/codecs/ivahd_hdvicp20api_01_00_00_23_production) /home/cy/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/configs/autorules_footer_cfg.mk:67: jpegvdec_PATH does not exist! (/home/cy/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/codecs/ivahd_jpegvdec_01_00_13_01_production) /home/cy/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/configs/autorules_footer_cfg.mk:67: jpegvenc_PATH does not exist! (/home/cy/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/codecs/ivahd_jpegvenc_01_00_16_01_production) /home/cy/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/configs/autorules_footer_cfg.mk:67: vlib_PATH does not exist! (/home/cy/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/algorithms/vlib_c66x_3_3_2_0) /home/cy/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/configs/autorules_footer_cfg.mk:67: fc_PATH does not exist! (/home/cy/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/codecs/framework_components_3_40_02_07) /home/cy/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/configs/autorules_footer_cfg.mk:67: ipc_PATH does not exist! () /home/cy/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/configs/autorules_footer_cfg.mk:67: avbtp_PATH does not exist! (/home/cy/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/networking/avbtp_0_10_00_00) /home/cy/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/configs/autorules_footer_cfg.mk:67: hdvicplib_PATH does not exist! (/home/cy/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/codecs/ivahd_hdvicp20api_01_00_00_23_production) /home/cy/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/configs/autorules_footer_cfg.mk:67: jpegvdec_PATH does not exist! (/home/cy/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/codecs/ivahd_jpegvdec_01_00_13_01_production) /home/cy/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/configs/autorules_footer_cfg.mk:67: jpegvenc_PATH does not exist! (/home/cy/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/codecs/ivahd_jpegvenc_01_00_16_01_production) /home/cy/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/configs/autorules_footer_cfg.mk:67: vlib_PATH does not exist! (/home/cy/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/algorithms/vlib_c66x_3_3_2_0) /home/cy/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/configs/autorules_footer_cfg.mk:67: fc_PATH does not exist! (/home/cy/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/codecs/framework_components_3_40_02_07) /home/cy/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/configs/autorules_footer_cfg.mk:67: ipc_PATH does not exist! () # # Build Config is [ tda3xx_evm_bios_radar ] # Build Config file is @ /home/cy/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/configs/tda3xx_evm_bios_radar/cfg.mk # Build Config .h file is @ /home/cy/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/links_fw/include/config/apps/tda3xx_evm_bios_radar/system_cfg.h # Build CPUs is @ ipu1_0 ipu1_1 dsp1 eve1 # # CPUs included in application, # PROC_IPU1_0_INCLUDE=yes # PROC_IPU1_1_INCLUDE=yes # PROC_IPU2_INCLUDE=no # PROC_DSP1_INCLUDE=yes # PROC_DSP2_INCLUDE=no # PROC_EVE1_INCLUDE=yes # PROC_EVE2_INCLUDE=no # PROC_EVE3_INCLUDE=no # PROC_EVE4_INCLUDE=no # PROC_A15_0_INCLUDE=no # # Platform config, # VSDK_BOARD_TYPE=TDA3XX_EVM [options: TDA2XX_EVM TDA2EX_EVM TDA3XX_EVM TDA3XX_RVP TDA2XX_RVP] # PLATFORM=tda3xx-evm # DUAL_A15_SMP_BIOS=no # IPU1_SMP_BIOS=no # DDR_MEM=DDR_MEM_128M [options: DDR_MEM_128M DDR_MEM_512M DDR_MEM_1024M] # EMIFMODE=SINGLE_EMIF_512MB [options: SINGLE_EMIF_512MB SINGLE_EMIF_1GB ref build_pdk.mk] # NDK_PROC_TO_USE=ipu1_1 [options: a15_0 ipu1_0 ipu1_1 ipu2 none] # NSP_TFDTP_INCLUDE=no [options: yes no] # TDA2EX_ETHSRV_BOARD=no [options: yes no] # FATFS_PROC_TO_USE=none [options: ipu1_0 none] # RADAR_BOARD=TDA3XX_AR12_VIB_DAB_BOOSTER [options: TDA3XX_AR12_ALPS TDA3XX_AR12_VIB_DAB_BOOSTER TDA3XX_RADAR_RVP none] # # Build config, # BUILD_OS=Linux [options: Windows_NT Linux] # BUILD_DEPENDENCY_ALWAYS=no # BUILD_ALGORITHMS=no # BUILD_INFOADAS=no # PROFILE=debug [options: debug release] # KW_BUILD=no # CPLUSPLUS_BUILD=no # IPU_PRIMARY_CORE=ipu1_0 [options: ipu1_0 ipu2] # IPU_SECONDARY_CORE=ipu2 [options: ipu1_0 ipu2] # A15_TARGET_OS=Bios [options: Bios Linux Qnx] # BSP_STW_PACKAGE_SELECT=all [options: all vps-iss-dss-only vps-vip-vpe] # # Safety Module config, # RTI_INCLUDE=no # ECC_FFI_INCLUDE=no # DCC_ESM_INCLUDE=no # # Video Module config, # IVAHD_INCLUDE=no # VPE_INCLUDE=no # CAL_INCLUDE=yes # ISS_INCLUDE=yes # ISS_ENABLE_DEBUG_TAPS=no # WDR_LDC_INCLUDE=yes # DSS_INCLUDE=yes # # Open Compute config, # OPENCL_INCLUDE=no # TARGET_ROOTDIR=/home/cy/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/opencl # ENABLE_OPENCV=no # ENABLE_OPENCV_TESTS=no # OPENVX_INCLUDE=no # # Log config, # ENABLE_UART_LOG=yes # ENABLE_NETWORK_LOG=no # ENABLE_CCS_LOG=no # CIO_REDIRECT=no # # IPC config, # WORKQ_INCLUDE=yes # IPC_LIB_INCLUDE=yes # # AUTOSAR_APP=no # # Surround View config, # SRV_FAST_BOOT_INCLUDE=no # # Other Module config, # AVB_INCLUDE=no # DCAN_INCLUDE=no # RADAR_ONLY=yes # RADAR_STUDIO=no # CPU_IDLE_ENABLED=no # FAST_BOOT_INCLUDE=no # DATA_VIS_INCLUDE=no # HS_DEVICE=no # ULTRASONIC_INCLUDE=no # PGA450= # PGA460= # ENABLE_ALL_DEPTH= # # Linux config, # DEFAULT_UBOOT_CONFIG=dra7xx_evm_vision_config # DEFAULT_KERNEL_CONFIG=ti_sdk_dra7x_release_defconfig # DEFAULT_DTB=dra7-evm-infoadas.dtb # CMEM_INCLUDE=no # IPUMM_INCLUDE=no # IPU1_EVELOADER_INCLUDE=no # ROBUST_RVC_INCLUDE=no # BUILD_ADAM_CAR=no # # Alg plugins included in build, # ALG_radarprocess # # Use-cases included in build, # UC_radar_capture_only UC_radar_read_fft_write UC_radar_objectdetect_display UC_radar_objectdetect_null UC_radar_capture_process # /home/cy/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/configs/autorules_footer_cfg.mk:67: avbtp_PATH does not exist! (/home/cy/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/networking/avbtp_0_10_00_00) /home/cy/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/configs/autorules_footer_cfg.mk:67: hdvicplib_PATH does not exist! (/home/cy/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/codecs/ivahd_hdvicp20api_01_00_00_23_production) /home/cy/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/configs/autorules_footer_cfg.mk:67: jpegvdec_PATH does not exist! (/home/cy/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/codecs/ivahd_jpegvdec_01_00_13_01_production) /home/cy/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/configs/autorules_footer_cfg.mk:67: jpegvenc_PATH does not exist! (/home/cy/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/codecs/ivahd_jpegvenc_01_00_16_01_production) /home/cy/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/configs/autorules_footer_cfg.mk:67: vlib_PATH does not exist! (/home/cy/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/algorithms/vlib_c66x_3_3_2_0) /home/cy/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/configs/autorules_footer_cfg.mk:67: fc_PATH does not exist! (/home/cy/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/codecs/framework_components_3_40_02_07) /home/cy/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/configs/autorules_footer_cfg.mk:67: ipc_PATH does not exist! () # # CPUs that are NOT required but included in config [ tda3xx_evm_bios_radar ], # # # CPUs that are required but not included in config [ tda3xx_evm_bios_radar ], # # # Edit /home/cy/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/configs/tda3xx_evm_bios_radar/cfg.mk to include or exclude CPUs in an application
Thanks.
Cherry
