TDA4VH-Q1: RTOS serdes1 setting
Part Number: TDA4VH-Q1
Other Parts Discussed in Thread: TEST2
Dear ti,
we want to set the serdes1 lane0 SGMII mode, lane1 SGMII mode, lane2 USXGMII mode, lane3 USXGMII mode as the same time
in psdk/pdk_j784s4_08_05_00_37/packages/ti/board/src/j784s4_evm/board_serdes_cfg.c, I can see the USXGMII and SGMII code in separate settings
How to set up serdes1 with USXGMII and SGMII at the same time, thanks
  • HI doredla,
    This also can't ping successly, I chech the macport config, which is same with the USXGMII alone, we have just changeed the serdes config
    Can you please try by changing the below yellow highlighted in "CSL_serdesEnableLanes" function under USXGMII phy type.
    Change above highlighted value to 3, as follows.
     /* Set P0_MAC_SRC_SEL to PMA output cmn_ref_clk_rcv */
            CSL_FINSR(*(volatile uint32_t *)(uintptr_t)(baseAddr + 0x480 + (0x40*laneNum)),21, 20, 0x3);
    Can you check with this once and share the SerDes registers dump for checking the change reflection.
    Sudheer
  • Dear Doredla,
    4555.serdes1.txt
    Will check internally with expertise on SerDes and update you.
    Sudheer
    Can you please dump CPSW Port1 & Port2 registers in working and non working case (i.e. single link case and multi-link case).
    Also, can you please dump Port statistics while running ping on Port1 & Port-2 in Multilink-case, Please refer to FAQ [How to get Ethernet Statistics].
    Sudheer
    There is an issue in SerDes Multi-link configuration.
    Please use the updated Multi-link configuration form attached file below and clean build ETHFW, also rebuild pdk_libs.
    csl_wiz16m_ct3_refclk156p25MHz_USXGMII_100MHz_SGMII_multilink.c
    * File: csl_wiz16m_ct3_refclk156p25MHz_USXGMII_100MHz_SGMII_multilink.c
    *  using_plllc
    *  multilink
    * (C) Copyright 2022, Texas Instruments, Inc.
    * Redistribution and use in source and binary forms, with or without
    * modification, are permitted provided that the following conditions
    * are met:
    * Redistributions of source code must retain the above copyright
    * notice, this list of conditions and the following disclaimer.
    * Redistributions in binary form must reproduce the above copyright
    * notice, this list of conditions and the following disclaimer in the
    * documentation and/or other materials provided with the
    * distribution.
    * Neither the name of Texas Instruments Incorporated nor the names of
    * its contributors may be used to endorse or promote products derived
    * from this software without specific prior written permission.
    * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
    * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
    * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
    * A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
    * OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
    * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
    * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
    * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
    * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
    * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
    * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    #ifndef CSL_WIZ16M_CT3_REFCLK156p25MHz_USXGMII_100MHz_SGMII_C
    #define CSL_WIZ16M_CT3_REFCLK156p25MHz_USXGMII_100MHz_SGMII_C
    #include <stdint.h>
    #include <ti/csl/soc.h>
    #include <ti/csl/csl.h>
    #include <ti/csl/src/ip/serdes_cd/V3/cslr_wiz16b8m4ct3_nda.h>
    void csl_wiz16m_ct3_refclk156p25MHz_USXGMII_100MHz_SGMII_multilink(uint32_t baseAddr, uint32_t laneNum)
        CSL_wiz16b8m4ct3Regs *torrent_sds_reg = (CSL_wiz16b8m4ct3Regs *)(uintptr_t)(baseAddr);
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_CMN_REGISTERS.CMN_PLL0_VCOCAL_OVRD__CMN_PLL0_VCOCAL_TCTRL),15,0,(uint32_t)0x0003);
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_CMN_REGISTERS.CMN_PLL1_VCOCAL_OVRD__CMN_PLL1_VCOCAL_TCTRL),15,0,(uint32_t)0x0003);
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_CMN_REGISTERS.CMN_PLL1_VCOCAL_ITER_TMR__CMN_PLL1_VCOCAL_INIT_TMR),15,0,(uint32_t)0x061B);
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_CMN_REGISTERS.CMN_PLL1_VCOCAL_ITER_TMR__CMN_PLL1_VCOCAL_INIT_TMR),31,16,(uint32_t)0x0019);
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_CMN_REGISTERS.CMN_PLL1_VCOCAL_REFTIM_START),15,0,(uint32_t)0x1354);
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_CMN_REGISTERS.CMN_PLL1_VCOCAL_PLLCNT_START),15,0,(uint32_t)0x1354);
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_CMN_REGISTERS.CMN_PLL1_DSM_FBH_OVRD_M0__CMN_PLL1_DSM_DIAG_M0),31,16,(uint32_t)0x0014);
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_CMN_REGISTERS.CMN_PLL1_DSM_FBL_OVRD_M0),15,0,(uint32_t)0x0005);
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_CMN_REGISTERS.CMN_PLL1_LOCK_REFCNT_IDLE__CMN_PLL1_LOCK_REFCNT_START),15,0,(uint32_t)0x0138);
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_CMN_REGISTERS.CMN_PLL1_LOCK_PLLCNT_THR__CMN_PLL1_LOCK_PLLCNT_START),15,0,(uint32_t)0x0138);
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_CMN_REGISTERS.CMN_TXPUCAL_TUNE__CMN_TXPUCAL_START),31,16,(uint32_t)0x007F);
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_CMN_REGISTERS.CMN_TXPDCAL_TUNE__CMN_TXPDCAL_START),31,16,(uint32_t)0x007F);
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_CMN_REGISTERS.CMN_PDIAG_PLL1_CP_IADJ_M0__CMN_PDIAG_PLL1_CP_PADJ_M0),15,0,(uint32_t)0x0028);
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_TX_LANE_REGISTERS[0].TX_TXCC_CPOST_MULT_01__TX_TXCC_CPOST_MULT_00),15,0,(uint32_t)0x0000); //SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_TX_LANE_REGISTERS[1].TX_TXCC_CPOST_MULT_01__TX_TXCC_CPOST_MULT_00),15,0,(uint32_t)0x0000); //SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_TX_LANE_REGISTERS[2].TX_TXCC_CPOST_MULT_01__TX_TXCC_CPOST_MULT_00),15,0,(uint32_t)0x0000); //USXGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_TX_LANE_REGISTERS[3].TX_TXCC_CPOST_MULT_01__TX_TXCC_CPOST_MULT_00),15,0,(uint32_t)0x0000); //SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_TX_LANE_REGISTERS[0].DRV_DIAG_TX_DRV),15,0,(uint32_t)0x00B3); //SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_TX_LANE_REGISTERS[1].DRV_DIAG_TX_DRV),15,0,(uint32_t)0x00B3); //SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_TX_LANE_REGISTERS[3].DRV_DIAG_TX_DRV),15,0,(uint32_t)0x00B3); //SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_TX_LANE_REGISTERS[0].XCVR_DIAG_PLLDRC_CTRL__XCVR_DIAG_XDP_PWRI_STAT),31,16,(uint32_t)0x0113); //SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_TX_LANE_REGISTERS[1].XCVR_DIAG_PLLDRC_CTRL__XCVR_DIAG_XDP_PWRI_STAT),31,16,(uint32_t)0x0113); //SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_TX_LANE_REGISTERS[2].XCVR_DIAG_PLLDRC_CTRL__XCVR_DIAG_XDP_PWRI_STAT),31,16,(uint32_t)0x0089); //USXGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_TX_LANE_REGISTERS[3].XCVR_DIAG_PLLDRC_CTRL__XCVR_DIAG_XDP_PWRI_STAT),31,16,(uint32_t)0x0113); //SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_TX_LANE_REGISTERS[2].XCVR_DIAG_HSCLK_DIV__XCVR_DIAG_HSCLK_SEL),15,0,(uint32_t)0x0011); //USXGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_TX_LANE_REGISTERS[0].XCVR_DIAG_HSCLK_DIV__XCVR_DIAG_HSCLK_SEL),31,16,(uint32_t)0x0003); //SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_TX_LANE_REGISTERS[1].XCVR_DIAG_HSCLK_DIV__XCVR_DIAG_HSCLK_SEL),31,16,(uint32_t)0x0003); //SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_TX_LANE_REGISTERS[3].XCVR_DIAG_HSCLK_DIV__XCVR_DIAG_HSCLK_SEL),31,16,(uint32_t)0x0003); //SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_TX_LANE_REGISTERS[0].XCVR_DIAG_PSC_OVRD__XCVR_DIAG_BIDI_CTRL),31,16,(uint32_t)0x0002); //SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_TX_LANE_REGISTERS[1].XCVR_DIAG_PSC_OVRD__XCVR_DIAG_BIDI_CTRL),31,16,(uint32_t)0x0002); //SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_TX_LANE_REGISTERS[2].XCVR_DIAG_PSC_OVRD__XCVR_DIAG_BIDI_CTRL),31,16,(uint32_t)0x0000); //USXGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_TX_LANE_REGISTERS[3].XCVR_DIAG_PSC_OVRD__XCVR_DIAG_BIDI_CTRL),31,16,(uint32_t)0x0002); //SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_TX_LANE_REGISTERS[0].TX_PSC_A1__TX_PSC_A0),15,0,(uint32_t)0x00F3); //SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_TX_LANE_REGISTERS[1].TX_PSC_A1__TX_PSC_A0),15,0,(uint32_t)0x00F3); //SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_TX_LANE_REGISTERS[2].TX_PSC_A1__TX_PSC_A0),15,0,(uint32_t)0x00F3); //USXGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_TX_LANE_REGISTERS[3].TX_PSC_A1__TX_PSC_A0),15,0,(uint32_t)0x00F3); //SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_TX_LANE_REGISTERS[0].TX_PSC_A3__TX_PSC_A2),15,0,(uint32_t)0x04A2); //SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_TX_LANE_REGISTERS[1].TX_PSC_A3__TX_PSC_A2),15,0,(uint32_t)0x04A2); //SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_TX_LANE_REGISTERS[2].TX_PSC_A3__TX_PSC_A2),15,0,(uint32_t)0x04A2); //USXGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_TX_LANE_REGISTERS[3].TX_PSC_A3__TX_PSC_A2),15,0,(uint32_t)0x04A2); //SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_TX_LANE_REGISTERS[0].TX_PSC_A3__TX_PSC_A2),31,16,(uint32_t)0x04A2); //SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_TX_LANE_REGISTERS[1].TX_PSC_A3__TX_PSC_A2),31,16,(uint32_t)0x04A2); //SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_TX_LANE_REGISTERS[2].TX_PSC_A3__TX_PSC_A2),31,16,(uint32_t)0x04A2); //USXGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_TX_LANE_REGISTERS[3].TX_PSC_A3__TX_PSC_A2),31,16,(uint32_t)0x04A2); //SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_TX_LANE_REGISTERS[0].TX_RCVDET_ST_TMR__TX_RCVDET_EN_TMR),31,16,(uint32_t)0x07A2);//SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_TX_LANE_REGISTERS[1].TX_RCVDET_ST_TMR__TX_RCVDET_EN_TMR),31,16,(uint32_t)0x07A2);//SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_TX_LANE_REGISTERS[2].TX_RCVDET_ST_TMR__TX_RCVDET_EN_TMR),31,16,(uint32_t)0x07A2);//USXGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_TX_LANE_REGISTERS[3].TX_RCVDET_ST_TMR__TX_RCVDET_EN_TMR),31,16,(uint32_t)0x07A2);//SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[0].RX_PSC_A1__RX_PSC_A0),15,0,(uint32_t)0x091D); //SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[1].RX_PSC_A1__RX_PSC_A0),15,0,(uint32_t)0x091D); //SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[2].RX_PSC_A1__RX_PSC_A0),15,0,(uint32_t)0x091D); //USXGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[3].RX_PSC_A1__RX_PSC_A0),15,0,(uint32_t)0x091D); //SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[0].RX_PSC_A3__RX_PSC_A2),15,0,(uint32_t)0x0900); //SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[1].RX_PSC_A3__RX_PSC_A2),15,0,(uint32_t)0x0900); //SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[2].RX_PSC_A3__RX_PSC_A2),15,0,(uint32_t)0x0900); //USXGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[3].RX_PSC_A3__RX_PSC_A2),15,0,(uint32_t)0x0900); //SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[0].RX_PSC_A3__RX_PSC_A2),31,16,(uint32_t)0x0100); //SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[1].RX_PSC_A3__RX_PSC_A2),31,16,(uint32_t)0x0100); //SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[2].RX_PSC_A3__RX_PSC_A2),31,16,(uint32_t)0x0100); //USXGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[3].RX_PSC_A3__RX_PSC_A2),31,16,(uint32_t)0x0100); //SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[0].RX_SDCAL0_ITER_TMR__RX_SDCAL0_INIT_TMR),15,0,(uint32_t)0x0014); //SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[0].RX_SDCAL0_ITER_TMR__RX_SDCAL0_INIT_TMR),31,16,(uint32_t)0x0062); //SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[0].RX_SDCAL1_ITER_TMR__RX_SDCAL1_INIT_TMR),15,0,(uint32_t)0x0014);//SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[0].RX_SDCAL1_ITER_TMR__RX_SDCAL1_INIT_TMR),31,16,(uint32_t)0x0062);//SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[1].RX_SDCAL0_ITER_TMR__RX_SDCAL0_INIT_TMR),15,0,(uint32_t)0x0014);//SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[1].RX_SDCAL0_ITER_TMR__RX_SDCAL0_INIT_TMR),31,16,(uint32_t)0x0062);//SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[1].RX_SDCAL1_ITER_TMR__RX_SDCAL1_INIT_TMR),15,0,(uint32_t)0x0014);//SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[1].RX_SDCAL1_ITER_TMR__RX_SDCAL1_INIT_TMR),31,16,(uint32_t)0x0062);//SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[2].RX_SDCAL0_ITER_TMR__RX_SDCAL0_INIT_TMR),15,0,(uint32_t)0x0014);//USXGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[2].RX_SDCAL0_ITER_TMR__RX_SDCAL0_INIT_TMR),31,16,(uint32_t)0x0062);//USXGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[2].RX_SDCAL1_ITER_TMR__RX_SDCAL1_INIT_TMR),15,0,(uint32_t)0x0014);//USXGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[2].RX_SDCAL1_ITER_TMR__RX_SDCAL1_INIT_TMR),31,16,(uint32_t)0x0062);//USXGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[3].RX_SDCAL0_ITER_TMR__RX_SDCAL0_INIT_TMR),15,0,(uint32_t)0x0014);//SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[3].RX_SDCAL0_ITER_TMR__RX_SDCAL0_INIT_TMR),31,16,(uint32_t)0x0062);//SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[3].RX_SDCAL1_ITER_TMR__RX_SDCAL1_INIT_TMR),15,0,(uint32_t)0x0014);//SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[3].RX_SDCAL1_ITER_TMR__RX_SDCAL1_INIT_TMR),31,16,(uint32_t)0x0062);//SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[0].RX_CDRLF_CNFG2__RX_CDRLF_CNFG),31,16,(uint32_t)0x018C); //SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[1].RX_CDRLF_CNFG2__RX_CDRLF_CNFG),31,16,(uint32_t)0x018C); //SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[2].RX_CDRLF_CNFG2__RX_CDRLF_CNFG),31,16,(uint32_t)0x018C); //USXGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[3].RX_CDRLF_CNFG2__RX_CDRLF_CNFG),31,16,(uint32_t)0x018C); //SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[0].RX_REE_GCSM1_EQENM_PH1__RX_REE_GCSM1_CTRL),31,16,(uint32_t)0x03C7);//SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[1].RX_REE_GCSM1_EQENM_PH1__RX_REE_GCSM1_CTRL),31,16,(uint32_t)0x03C7);//SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[2].RX_REE_GCSM1_EQENM_PH1__RX_REE_GCSM1_CTRL),31,16,(uint32_t)0x03C7);//USXGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[3].RX_REE_GCSM1_EQENM_PH1__RX_REE_GCSM1_CTRL),31,16,(uint32_t)0x03C7);//SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[0].RX_REE_GCSM1_START_TMR__RX_REE_GCSM1_EQENM_PH2),15,0,(uint32_t)0x01C7);//SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[1].RX_REE_GCSM1_START_TMR__RX_REE_GCSM1_EQENM_PH2),15,0,(uint32_t)0x01C7);//SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[2].RX_REE_GCSM1_START_TMR__RX_REE_GCSM1_EQENM_PH2),15,0,(uint32_t)0x01C7);//USXGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[3].RX_REE_GCSM1_START_TMR__RX_REE_GCSM1_EQENM_PH2),15,0,(uint32_t)0x01C7);//SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[0].RX_REE_TAP1_CLIP__RX_REE_ADDR_CFG),31,16,(uint32_t)0x0019);//SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[1].RX_REE_TAP1_CLIP__RX_REE_ADDR_CFG),31,16,(uint32_t)0x0019);//SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[2].RX_REE_TAP1_CLIP__RX_REE_ADDR_CFG),31,16,(uint32_t)0x0019);//USXGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[3].RX_REE_TAP1_CLIP__RX_REE_ADDR_CFG),31,16,(uint32_t)0x0019);//SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[0].RX_REE_CTRL_DATA_MASK__RX_REE_TAP2TON_CLIP),15,0,(uint32_t)0x0019);//SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[1].RX_REE_CTRL_DATA_MASK__RX_REE_TAP2TON_CLIP),15,0,(uint32_t)0x0019);//SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[2].RX_REE_CTRL_DATA_MASK__RX_REE_TAP2TON_CLIP),15,0,(uint32_t)0x0019);//USXGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[3].RX_REE_CTRL_DATA_MASK__RX_REE_TAP2TON_CLIP),15,0,(uint32_t)0x0019);//SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[2].RX_REE_SMGM_CTRL1__RX_REE_TXEQEVAL_CTRL),31,16,(uint32_t)0x0030);//USXGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[0].RX_DIAG_DFE_AMP_TUNE__RX_DIAG_DFE_CTRL),15,0,(uint32_t)0x0000);//SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[1].RX_DIAG_DFE_AMP_TUNE__RX_DIAG_DFE_CTRL),15,0,(uint32_t)0x0000);//SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[2].RX_DIAG_DFE_AMP_TUNE__RX_DIAG_DFE_CTRL),15,0,(uint32_t)0x0000);//USXGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[3].RX_DIAG_DFE_AMP_TUNE__RX_DIAG_DFE_CTRL),15,0,(uint32_t)0x0000);//SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[0].RX_DIAG_DFE_AMP_TUNE_3__RX_DIAG_DFE_AMP_TUNE_2),15,0,(uint32_t)0x0C01);//SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[1].RX_DIAG_DFE_AMP_TUNE_3__RX_DIAG_DFE_AMP_TUNE_2),15,0,(uint32_t)0x0C01);//SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[2].RX_DIAG_DFE_AMP_TUNE_3__RX_DIAG_DFE_AMP_TUNE_2),15,0,(uint32_t)0x0C21);//USXGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[3].RX_DIAG_DFE_AMP_TUNE_3__RX_DIAG_DFE_AMP_TUNE_2),15,0,(uint32_t)0x0C01);//SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[0].RX_DIAG_DFE_AMP_TUNE_3__RX_DIAG_DFE_AMP_TUNE_2),31,16,(uint32_t)0x0000);//SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[1].RX_DIAG_DFE_AMP_TUNE_3__RX_DIAG_DFE_AMP_TUNE_2),31,16,(uint32_t)0x0000);//SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[2].RX_DIAG_DFE_AMP_TUNE_3__RX_DIAG_DFE_AMP_TUNE_2),31,16,(uint32_t)0x0002);//USXGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[3].RX_DIAG_DFE_AMP_TUNE_3__RX_DIAG_DFE_AMP_TUNE_2),31,16,(uint32_t)0x0000);//SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[0].RX_DIAG_NQST_CTRL__RX_DIAG_REE_DAC_CTRL),31,16,(uint32_t)0x0098);//SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[1].RX_DIAG_NQST_CTRL__RX_DIAG_REE_DAC_CTRL),31,16,(uint32_t)0x0098);//SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[2].RX_DIAG_NQST_CTRL__RX_DIAG_REE_DAC_CTRL),31,16,(uint32_t)0x00B9);//USXGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[3].RX_DIAG_NQST_CTRL__RX_DIAG_REE_DAC_CTRL),31,16,(uint32_t)0x0098);//SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[0].RX_DIAG_PI_CAP__RX_DIAG_PI_RATE),15,0,(uint32_t)0x0010);//SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[1].RX_DIAG_PI_CAP__RX_DIAG_PI_RATE),15,0,(uint32_t)0x0010);//SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[2].RX_DIAG_PI_CAP__RX_DIAG_PI_RATE),15,0,(uint32_t)0x0033);//USXGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[3].RX_DIAG_PI_CAP__RX_DIAG_PI_RATE),15,0,(uint32_t)0x0010);//SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[0].RX_DIAG_PI_CAP__RX_DIAG_PI_RATE),31,16,(uint32_t)0x0000);//SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[1].RX_DIAG_PI_CAP__RX_DIAG_PI_RATE),31,16,(uint32_t)0x0000);//SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[3].RX_DIAG_PI_CAP__RX_DIAG_PI_RATE),31,16,(uint32_t)0x0000);//SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[0].RX_DIAG_ACYA__RX_DIAG_DCYA),31,16,(uint32_t)0x0001);//SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[1].RX_DIAG_ACYA__RX_DIAG_DCYA),31,16,(uint32_t)0x0001);//SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[2].RX_DIAG_ACYA__RX_DIAG_DCYA),31,16,(uint32_t)0x0001);//USXGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PMA_RX_LANE_REGISTERS[3].RX_DIAG_ACYA__RX_DIAG_DCYA),31,16,(uint32_t)0x0001);//SGMII
        CSL_FINSR(*(volatile uint32_t *)(&torrent_sds_reg->PHY_PCS_CMN_REGISTERS.PHY_AUTO_CFG_SPDUP__PHY_PLL_CFG),15,0,(uint32_t)0x0002);
    #endif
    I have confirmed at my end Link is up for both USXGMII from Port-1 and SGMII from Port-2.
    Sudheer
