Part Number: TDA4VM
Hello TI,
I have a couple question about Ethernet on the R5F cores. I am using SDK version 8.06.01.03 (QNX + FreeRTOS)
1. In the file main.c (vision_apps/platform/j721e/rtos/mcu2_0/main.c) in appMain function, I have added a simple UDP socket application. In a loop, I am sending messages using the lwip_sendto function to an Ubuntu PC through the CPSW9G switch. However, when I run the application on the board, I cannot see any messages in Wireshark or in the receiving application on the PC. Additionally, there are no messages displayed on the terminal.
When I added a sleep function for 1 ms (appLogWaitMsecs(1u)), I can see the messages in Wireshark, but the bandwidth is limited to 10 Mbit/s.
I would like to know if there is a sleep function available in microseconds or nanoseconds for the R5F cores. Also, what could be the problem when the sleep function is not used?
boot and vision_apps_init.sh
U-Boot SPL 2021.01-g62a9e51344 (May 02 2023 - 15:41:24 +0000) Model: Texas Instruments K3 J721E SoC Board: J721EX-PM2-SOM rev E6 SYSFW ABI: 3.1 (firmware rev 0x0008 '8.6.3--v08.06.03 (Chill Capybar') Trying to boot from MMC2 Starting ATF on ARM64 core... NOTICE: BL31: v2.8(release):v2.8-226-g2fcd408bb3-dirty NOTICE: BL31: Built : 15:40:55, May 2 2023 I/TC: I/TC: OP-TEE version: 3.20.0 (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10))) #1 Tue May 2 15:41:00 UTC 2023 aarch64 I/TC: WARNING: This OP-TEE configuration might be insecure! I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html I/TC: Primary CPU initializing I/TC: SYSFW ABI: 3.1 (firmware rev 0x0008 '8.6.3--v08.06.03 (Chill Capybar') I/TC: HUK Initialized I/TC: Activated SA2UL device I/TC: Fixing SA2UL firewall owner for GP device I/TC: Enabled firewalls for SA2UL TRNG device I/TC: SA2UL TRNG initialized I/TC: SA2UL Drivers initialized I/TC: Primary CPU switching to normal world boot U-Boot SPL 2021.01-g62a9e51344 (May 02 2023 - 15:41:16 +0000) Model: Texas Instruments K3 J721E SoC Board: J721EX-PM2-SOM rev E6 SYSFW ABI: 3.1 (firmware rev 0x0008 '8.6.3--v08.06.03 (Chill Capybar') Detected: J7X-BASE-CPB rev E3 Detected: J7X-GESI-EXP rev E3 Detected: J7X-VSC8514-ETH rev E2 Trying to boot from MMC2 U-Boot 2021.01-g62a9e51344 (May 02 2023 - 15:41:16 +0000) SoC: J721E SR1.0 GP Model: Texas Instruments K3 J721E SoC Board: J721EX-PM2-SOM rev E6 DRAM: 4 GiB Flash: 0 Bytes MMC: sdhci@4f80000: 0, sdhci@4fb0000: 1 Loading Environment from FAT... *** Warning - bad CRC, using default environment In: serial@2800000 Out: serial@2800000 Err: serial@2800000 am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA00101 cpsw_ver: 0x6BA80100 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000 Detected: J7X-BASE-CPB rev E3 Detected: J7X-GESI-EXP rev E3 Detected: J7X-VSC8514-ETH rev E2 cdns,sierra serdes@5000000: sierra probed Net: eth0: ethernet@46000000port@1 Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc1 is current device SD/MMC found on device 1 Failed to load 'boot.scr' 556 bytes read in 8 ms (67.4 KiB/s) Loaded env from uEnv.txt Importing environment from mmc1 ... Running uenvcmd ... gpio: pin gpio@22_17 (gpio 281) value is 1 gpio: pin gpio@22_16 (gpio 280) value is 0 k3_r5f_rproc r5f@41000000: Core 1 is already in use. No rproc commands work k3_r5f_rproc r5f@41400000: Core 2 is already in use. No rproc commands work 1428824 bytes read in 72 ms (18.9 MiB/s) Load Remote Processor 2 with data@addr=0x82000000 1428824 bytes: Success! 301996 bytes read in 26 ms (11.1 MiB/s) Load Remote Processor 3 with data@addr=0x82000000 301996 bytes: Success! Failed to load '/lib/firmware/j7-main-r5f1_0-fw' Failed to load '/lib/firmware/j7-main-r5f1_1-fw' 1334004 bytes read in 70 ms (18.2 MiB/s) Load Remote Processor 6 with data@addr=0x82000000 1334004 bytes: Success! 1334004 bytes read in 68 ms (18.7 MiB/s) Load Remote Processor 7 with data@addr=0x82000000 1334004 bytes: Success! 15576248 bytes read in 663 ms (22.4 MiB/s) Load Remote Processor 8 with data@addr=0x82000000 15576248 bytes: Success! 8329020 bytes read in 368 ms (21.6 MiB/s) ## Starting application at 0x80080000 ... MMU: 16-bit ASID 44-bit PA TCR_EL1=b5183519 ARM GIC-500 r1p1, arch v3.0 detected gic_v3_lpi_add_entry for vectors 8192 -> 8447, Ok gic_v3_lpi_add_entry for vectors 8448 -> 65535, Ok No SPI intrinfo. Add default entry for 32 -> 991 vectors, Ok LPI config table #1 @ 000000008000f000, callout vaddr: ffffff8040251000 cpu0: MPIDR=80000000 cpu0: MIDR=411fd080 Cortex-A72 r1p0 cpu0: CWG=4 ERG=4 Dminline=4 Iminline=4 PIPT cpu0: CLIDR=a200023 LoUU=1 LoC=2 LoUIS=1 cpu0: L1 Icache 48K linesz=64 set/way=256/3 cpu0: L1 Dcache 32K linesz=64 set/way=256/2 cpu0: L2 Unified 1024K linesz=64 set/way=1024/16 Enabling ITS 0 ITS queue at 0000000080020000, num slots: 256 Issue MAPC/SYNC/INVALL commands for ICID 0 update CWRITER to 0x00000060 Waiting for all commands to be processed ... Done in 1 tries Enable LPIs in GICR_CTLR @ 0000000001900000 for CPU0 Display set to R5 TI: Not configuring pcie to avoid serdes conflict with EthFw using QSGMII board Total Available L3 cache (MSMC SRAM): 0 bytes Loading IFS...decompressing...done I/TC: Secondary CPU 1 initializing I/TC: Secondary CPU 1 switching to normal world boot cpu1: MPIDR=80000001 cpu1: MIDR=411fd080 Cortex-A72 r1p0 cpu1: CWG=4 ERG=4 Dminline=4 Iminline=4 PIPT cpu1: CLIDR=a200023 LoUU=1 LoC=2 LoUIS=1 cpu1: L1 Icache 48K linesz=64 set/way=256/3 cpu1: L1 Dcache 32K linesz=64 set/way=256/2 cpu1: L2 Unified 1024K linesz=64 set/way=1024/16 ITS 0 already Enabled ITS queue at 0000000080020000, num slots: 256 Issue MAPC/SYNC/INVALL commands for ICID 1 update CWRITER to 0x000000c0 Waiting for all commands to be processed ... Done in 1 tries Enable LPIs in GICR_CTLR @ 0000000001920000 for CPU1 System page at phys:0000000080023000 user:ffffff8040275000 kern:ffffff8040272000 Starting next program at vffffff8060097280 All ClockCycles offsets within tolerance Welcome to QNX Neutrino 7.1.0 on the TI J721E EVM Board!! Starting random service ... start serial driver Setting OS clock from RTC Starting MMC/SD memory card driver... eMMC Starting MMC/SD memory card driver... SD Starting XHCI driver on USB3SS0 and USB3SS1 Path=0 - am65x target=0 lun=0 Direct-Access(0) - SDMMC: S0J56X Rev: 1.0 Setting environment variables... done.. Mounting the sd .. Looking for user script to run: /ti_fs/scripts/user.sh Running user script... user.sh called... Setting additional environment variables... Starting tisci-mgr.. Starting shmemallocator.. Starting tiipc-mgr.. Starting tiudma-mgr.. Starting VXE-ENC resource manager... Start screen.. screen started with dss_on_r5 configuration.. Start CPSW9G.. done... J7EVM@QNX:/# sh ti_fs/vision_apps/vision_apps_init.sh J7EVM@QNX:/# [MCU2_0] 4.374694 s: CIO: Init ... Done !!! [MCU2_0] 4.374797 s: ### CPU Frequency = 1000000000 Hz [MCU2_0] 4.374846 s: CPU is running FreeRTOS [MCU2_0] 4.374877 s: APP: Init ... !!! [MCU2_0] 4.374902 s: SCICLIENT: Init ... !!! [MCU2_0] 4.375263 s: SCICLIENT: DMSC FW version [8.6.3--v08.06.03 (Chill Capybar] [MCU2_0] 4.375314 s: SCICLIENT: DMSC FW revision 0x8 [MCU2_0] 4.375350 s: SCICLIENT: DMSC FW ABI revision 3.1 [MCU2_0] 4.375392 s: SCICLIENT: Init ... Done !!! [MCU2_0] 4.375422 s: UDMA: Init ... !!! [MCU2_0] 4.376904 s: UDMA: Init ... Done !!! [MCU2_0] 4.376967 s: MEM: Init ... !!! [MCU2_0] 4.377011 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ d9000000 of size 16777216 bytes !!! [MCU2_0] 4.377086 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000000) @ 3600000 of size 262144 bytes !!! [MCU2_0] 4.377149 s: MEM: Init ... Done !!! [MCU2_0] 4.377176 s: IPC: Init ... !!! [MCU2_0] 4.377247 s: IPC: 6 CPUs participating in IPC !!! [MCU2_0] 4.392209 s: IPC: Init ... Done !!! [MCU2_0] 4.392289 s: APP: Syncing with 5 CPUs ... !!! [MCU2_0] 5.184133 s: APP: Syncing with 5 CPUs ... Done !!! [MCU2_0] 5.184335 s: REMOTE_SERVICE: Init ... !!! [MCU2_0] 5.186013 s: REMOTE_SERVICE: Init ... Done !!! [MCU2_0] 5.186079 s: ETHFW: Init ... !!! [MCU2_0] 5.191061 s: Warning: Using 6 MAC address(es) from static pool [MCU2_0] 5.191172 s: ETHFW: Shared multicasts (software fanout): [MCU2_0] 5.191218 s: ETHFW: Reserved multicasts: [MCU2_0] 5.191328 s: 01:80:c2:00:00:0e [MCU2_0] 5.191393 s: 01:1b:19:00:00:00 [MCU2_0] 5.191646 s: EnetMcm: CPSW_9G on MAIN NAVSS [MCU2_0] 5.200905 s: Mdio_open: MDIO manual mode enabled [MCU2_0] 5.203822 s: PHY 0 is alive [MCU2_0] 5.204114 s: PHY 3 is alive [MCU2_0] 5.204753 s: PHY 12 is alive [MCU2_0] 5.204992 s: PHY 15 is alive [MCU2_0] 5.205096 s: PHY 16 is alive [MCU2_0] 5.205197 s: PHY 17 is alive [MCU2_0] 5.205308 s: PHY 18 is alive [MCU2_0] 5.205413 s: PHY 19 is alive [MCU2_0] 5.205810 s: PHY 23 is alive [MCU2_0] 5.206777 s: EnetPhy_bindDriver: PHY 12: OUI:080028 Model:23 Ver:01 <-> 'dp83867' : OK [MCU2_0] 5.207274 s: EnetPhy_bindDriver: PHY 0: OUI:080028 Model:23 Ver:01 <-> 'dp83867' : OK [MCU2_0] 5.207757 s: EnetPhy_bindDriver: PHY 3: OUI:080028 Model:23 Ver:01 <-> 'dp83867' : OK [MCU2_0] 5.208226 s: EnetPhy_bindDriver: PHY 15: OUI:080028 Model:23 Ver:01 <-> 'dp83867' : OK [MCU2_0] 5.209960 s: [MCU2_0] ETHFW Version : 0.02.00 [MCU2_0] 5.210029 s: ETHFW Build Date: May 16, 2023 [MCU2_0] 5.210064 s: ETHFW Build Time: 08:46:20 [MCU2_0] 5.210092 s: ETHFW Commit SHA: [MCU2_0] 5.210166 s: ETHFW: Init ... DONE !!! [MCU2_0] 5.210198 s: ETHFW: Remove server Init ... !!! [MCU2_0] 5.210390 s: CpswProxyServer: Virtual port configuration: [MCU2_0] 5.210448 s: mpu_1_0 <-> Switch port 0: mpu_1_0_ethswitch-device-0 [MCU2_0] 5.210497 s: mcu_2_1 <-> Switch port 1: mcu_2_1_ethswitch-device-1 [MCU2_0] 5.210540 s: mpu_1_0 <-> MAC port 1: mpu_1_0_ethmac-device-1 [MCU2_0] 5.210581 s: mcu_2_1 <-> MAC port 4: mcu_2_1_ethmac-device-4 [MCU2_0] 5.211628 s: CpswProxyServer: initialization completed (core: mcu2_0) [MCU2_0] 5.211696 s: ETHFW: Remove server Init ... DONE !!! [MCU2_0] 5.212821 s: Starting lwIP, local interface IP is 192.168.1.200 [MCU2_0] 5.220658 s: Host MAC address: 70:ff:76:1d:92:c3 [MCU2_0] 5.224767 s: [LWIPIF_LWIP] Enet LLD netif initialized successfully [MCU2_0] 5.224858 s: Added interface 'ti1', IP is 192.168.1.200 [MCU2_0] 5.238979 s: EthFw: TimeSync PTP enabled [MCU2_0] 5.243679 s: Rx Flow for Software Inter-VLAN Routing is up [MCU2_0] 5.261265 s: FVID2: Init ... !!! [MCU2_0] 5.261386 s: FVID2: Init ... Done !!! [MCU2_0] 5.261441 s: DSS: Init ... !!! [MCU2_0] 5.261471 s: DSS: Display type is eDP !!! [MCU2_0] 5.261499 s: DSS: M2M Path is enabled !!! [MCU2_0] 5.261525 s: DSS: SoC init ... !!! [MCU2_0] 5.261551 s: SCICLIENT: Sciclient_pmSetModuleState module=152 state=2 [MCU2_0] 5.261779 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 5.261818 s: SCICLIENT: Sciclient_pmSetModuleState module=297 state=2 [MCU2_0] 5.262023 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 5.262058 s: SCICLIENT: Sciclient_pmSetModuleState module=151 state=2 [MCU2_0] 5.262208 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 5.262340 s: SCICLIENT: Sciclient_pmSetModuleClkParent module=152 clk=9 parent=11 [MCU2_0] 5.262495 s: SCICLIENT: Sciclient_pmSetModuleClkParent success [MCU2_0] 5.262537 s: SCICLIENT: Sciclient_pmSetModuleClkParent module=152 clk=13 parent=18 [MCU2_0] 5.262662 s: SCICLIENT: Sciclient_pmSetModuleClkParent success [MCU2_0] 5.262696 s: SCICLIENT: Sciclient_pmSetModuleClkParent module=152 clk=1 parent=2 [MCU2_0] 5.262798 s: SCICLIENT: Sciclient_pmSetModuleClkParent success [MCU2_0] 5.262833 s: SCICLIENT: Sciclient_pmSetModuleClkFreq module=152 clk=1 freq=148500000 [MCU2_0] 5.264052 s: SCICLIENT: Sciclient_pmSetModuleClkFreq success [MCU2_0] 5.264100 s: SCICLIENT: Sciclient_pmModuleClkRequest module=152 clk=1 state=2 flag=0 [MCU2_0] 5.264304 s: SCICLIENT: Sciclient_pmModuleClkRequest success [MCU2_0] 5.264353 s: DSS: SoC init ... Done !!! [MCU2_0] 5.264382 s: DSS: Board init ... !!! [MCU2_0] 5.264408 s: DSS: Board init ... Done !!! [MCU2_0] 5.282617 s: DSS: Init ... Done !!! [MCU2_0] 5.282683 s: VHWA: VPAC Init ... !!! [MCU2_0] 5.282712 s: SCICLIENT: Sciclient_pmSetModuleState module=290 state=2 [MCU2_0] 5.282929 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 5.282969 s: VHWA: LDC Init ... !!! [MCU2_0] 5.286776 s: VHWA: LDC Init ... Done !!! [MCU2_0] 5.286839 s: VHWA: MSC Init ... !!! [MCU2_0] 5.299191 s: VHWA: MSC Init ... Done !!! [MCU2_0] 5.299396 s: VHWA: NF Init ... !!! [MCU2_0] 5.301363 s: VHWA: NF Init ... Done !!! [MCU2_0] 5.301429 s: VHWA: VISS Init ... !!! [MCU2_0] 5.312602 s: VHWA: VISS Init ... Done !!! [MCU2_0] 5.312667 s: VHWA: VPAC Init ... Done !!! [MCU2_0] 5.312712 s: VX_ZONE_INIT:Enabled [MCU2_0] 5.312742 s: VX_ZONE_ERROR:Enabled [MCU2_0] 5.312770 s: VX_ZONE_WARNING:Enabled [MCU2_0] 5.314409 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target MCU2-0 [MCU2_0] 5.314675 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_NF [MCU2_0] 5.314911 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_LDC1 [MCU2_0] 5.315145 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_MSC1 [MCU2_0] 5.315547 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_MSC2 [MCU2_0] 5.315933 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_VISS1 [MCU2_0] 5.316230 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE1 [MCU2_0] 5.316653 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE2 [MCU2_0] 5.316933 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DISPLAY1 [MCU2_0] 5.317198 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DISPLAY2 [MCU2_0] 5.317604 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CSITX [MCU2_0] 5.317891 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE3 [MCU2_0] 5.318170 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE4 [MCU2_0] 5.318564 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE5 [MCU2_0] 5.318843 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE6 [MCU2_0] 5.319121 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE7 [MCU2_0] 5.319503 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE8 [MCU2_0] 5.319772 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DSS_M2M1 [MCU2_0] 5.320031 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DSS_M2M2 [MCU2_0] 5.320432 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DSS_M2M3 [MCU2_0] 5.320724 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DSS_M2M4 [MCU2_0] 5.320783 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!! [MCU2_0] 5.320818 s: APP: OpenVX Target kernel init ... !!! [MCU2_0] 5.344829 s: APP: OpenVX Target kernel init ... Done !!! [MCU2_0] 5.344893 s: CSI2RX: Init ... !!! [MCU2_0] 5.344920 s: SCICLIENT: Sciclient_pmSetModuleState module=25 state=2 [MCU2_0] 5.345062 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 5.345101 s: SCICLIENT: Sciclient_pmSetModuleState module=26 state=2 [MCU2_0] 5.345341 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 5.345392 s: SCICLIENT: Sciclient_pmSetModuleState module=27 state=2 [MCU2_0] 5.345550 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 5.345587 s: SCICLIENT: Sciclient_pmSetModuleState module=147 state=2 [MCU2_0] 5.345705 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 5.345738 s: SCICLIENT: Sciclient_pmSetModuleState module=148 state=2 [MCU2_0] 5.345843 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 5.346074 s: CSI2RX: Init ... Done !!! [MCU2_0] 5.346116 s: CSI2TX: Init ... !!! [MCU2_0] 5.346143 s: SCICLIENT: Sciclient_pmSetModuleState module=25 state=2 [MCU2_0] 5.346354 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 5.346406 s: SCICLIENT: Sciclient_pmSetModuleState module=28 state=2 [MCU2_0] 5.346556 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 5.346593 s: SCICLIENT: Sciclient_pmSetModuleState module=296 state=2 [MCU2_0] 5.346723 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 5.346818 s: CSI2TX: Init ... Done !!! [MCU2_0] 5.346859 s: ISS: Init ... !!! [MCU2_0] 5.346899 s: IssSensor_Init ... Done !!! [MCU2_0] 5.346988 s: IttRemoteServer_Init ... Done !!! [MCU2_0] 5.347027 s: VISS REMOTE SERVICE: Init ... !!! [MCU2_0] 5.347099 s: VISS REMOTE SERVICE: Init ... Done !!! [MCU2_0] 5.347133 s: UDMA Copy: Init ... !!! [MCU2_0] 5.349075 s: UDMA Copy: Init ... Done !!! [MCU2_0] 5.349217 s: APP: Init ... Done !!! [MCU2_0] 5.349399 s: APP: Run ... !!! [MCU2_0] 5.349428 s: IPC: Starting echo test ... [MCU2_0] 5.352367 s: APP: Run ... Done !!! [MCU2_0] 5.352419 s: UDP client: Starting UDP client [MCU2_0] 5.354146 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[.] C66X_1[P] C66X_2[.] C7X_1[.] [MCU2_0] 5.354423 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] C66X_1[P] C66X_2[.] C7X_1[.] [MCU2_0] 5.354543 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[.] [MCU2_0] 5.354637 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[P] [MCU2_0] 7.113588 s: Function:CpswProxyServer_attachHandlerCb,HostId:0,CpswType:6 [MCU2_0] 7.114089 s: Function:CpswProxyServer_allocMacHandlerCb,HostId:0,Handle:a3ac6d44,CoreKey:38acb7e6 [MCU2_0] 8.066221 s: Function:CpswProxyServer_allocTxHandlerCb,HostId:0,Handle:a3ac6d44,CoreKey:38acb7e6 [MCU2_0] 8.068415 s: Function:CpswProxyServer_allocRxHandlerCb,HostId:0,Handle:a3ac6d44,CoreKey:38acb7e6 [MCU2_0] 8.068831 s: Function:CpswProxyServer_ioctlHandlerCb,HostId:0,Handle:a3ac6d44,CoreKey:38acb7e6, Cmd:1010401,InArgsLen:0, OutArgsLen:4 [MCU2_0] 8.084371 s: Function:CpswProxyServer_ioctlHandlerCb,HostId:0,Handle:a3ac6d44,CoreKey:38acb7e6, Cmd:1010201,InArgsLen:24, OutArgsLen:4 [MCU2_0] 8.086400 s: Function:CpswProxyServer_registerMacHandlerCb,HostId:0,Handle:a3ac6d44,CoreKey:38acb7e6, MacAddress:70:ff:76:1d:92:c1, FlowIdx:172, FlowIdxOffset:0 [MCU2_0] 8.086676 s: Cpsw_ioctlInternal: CPSW: Registered MAC address. ALE entry:12, Policer Entry:3 [MCU2_0] 8.708690 s: Cpsw_handleLinkUp: Port 8: Link up: 1-Gbps Full-Duplex [MCU2_0] 8.810081 s: Function:CpswProxyServer_ioctlHandlerCb,HostId:0,Handle:a3ac6d44,CoreKey:38acb7e6, Cmd:1010222,InArgsLen:144, OutArgsLen:36 [MCU2_0] 8.813679 s: Function:CpswProxyServer_ioctlHandlerCb,HostId:0,Handle:a3ac6d44,CoreKey:38acb7e6, Cmd:1010202,InArgsLen:24, OutArgsLen:4 [MCU2_0] 8.814169 s: Function:CpswProxyServer_ioctlHandlerCb,HostId:0,Handle:a3ac6d44,CoreKey:38acb7e6, Cmd:1010224,InArgsLen:132, OutArgsLen:0 [MCU2_0] 8.814886 s: Function:CpswProxyServer_ioctlHandlerCb,HostId:0,Handle:a3ac6d44,CoreKey:38acb7e6, Cmd:1010222,InArgsLen:144, OutArgsLen:36 [MCU2_0] 8.818394 s: Function:CpswProxyServer_ioctlHandlerCb,HostId:0,Handle:a3ac6d44,CoreKey:38acb7e6, Cmd:1010202,InArgsLen:24, OutArgsLen:4 [MCU2_0] 8.818937 s: Function:CpswProxyServer_ioctlHandlerCb,HostId:0,Handle:a3ac6d44,CoreKey:38acb7e6, Cmd:1010222,InArgsLen:144, OutArgsLen:36 [MCU2_0] 8.822417 s: Function:CpswProxyServer_ioctlHandlerCb,HostId:0,Handle:a3ac6d44,CoreKey:38acb7e6, Cmd:1010202,InArgsLen:24, OutArgsLen:4 [MCU2_0] 8.823004 s: Function:CpswProxyServer_registerIpv4MacHandlerCb,HostId:0,Handle:a3ac6d44,CoreKey:38acb7e6, MacAddress:70:ff:76:1d:92:c1 IPv4Addr:192.168.1.70 [MCU2_0] 8.823167 s: [MCU2_0] SNo. IP Address MAC Address [MCU2_0] 8.823210 s: ------ ------------- ----------------- [MCU2_0] 8.823315 s: 1 192.168.1.70 70:ff:76:1d:92:c1 [MCU2_0] 8.823789 s: Function:CpswProxyServer_ioctlHandlerCb,HostId:0,Handle:a3ac6d44,CoreKey:38acb7e6, Cmd:1010224,InArgsLen:132, OutArgsLen:0 [MCU2_0] 8.824394 s: Function:CpswProxyServer_ioctlHandlerCb,HostId:0,Handle:a3ac6d44,CoreKey:38acb7e6, Cmd:1010224,InArgsLen:132, OutArgsLen:0 [MCU2_0] 8.825048 s: Function:CpswProxyServer_ioctlHandlerCb,HostId:0,Handle:a3ac6d44,CoreKey:38acb7e6, Cmd:1010222,InArgsLen:144, OutArgsLen:36 [MCU2_0] 8.828578 s: Function:CpswProxyServer_ioctlHandlerCb,HostId:0,Handle:a3ac6d44,CoreKey:38acb7e6, Cmd:1010202,InArgsLen:24, OutArgsLen:4 [MCU2_0] 8.829062 s: Function:CpswProxyServer_ioctlHandlerCb,HostId:0,Handle:a3ac6d44,CoreKey:38acb7e6, Cmd:1010222,InArgsLen:144, OutArgsLen:36 [MCU2_0] 8.832601 s: Function:CpswProxyServer_ioctlHandlerCb,HostId:0,Handle:a3ac6d44,CoreKey:38acb7e6, Cmd:1010202,InArgsLen:24, OutArgsLen:4 [MCU2_0] 8.833084 s: Function:CpswProxyServer_ioctlHandlerCb,HostId:0,Handle:a3ac6d44,CoreKey:38acb7e6, Cmd:1010222,InArgsLen:144, OutArgsLen:36 [MCU2_0] 8.836640 s: Function:CpswProxyServer_ioctlHandlerCb,HostId:0,Handle:a3ac6d44,CoreKey:38acb7e6, Cmd:1010202,InArgsLen:24, OutArgsLen:4 [MCU2_0] 9.973963 s: CpswCpts_ioctl: Eth RX event not found (msgType=2, seqId=256, dom=0, portNum=7) [MCU2_0] 10.974860 s: CpswCpts_ioctl: Eth RX event not found (msgType=2, seqId=256, dom=0, portNum=7) [MCU2_0] 11.976786 s: CpswCpts_ioctl: Eth RX event not found (msgType=2, seqId=256, dom=0, portNum=7) [MCU2_1] 4.324217 s: CIO: Init ... Done !!! [MCU2_1] 4.324289 s: ### CPU Frequency = 1000000000 Hz [MCU2_1] 4.324332 s: CPU is running FreeRTOS [MCU2_1] 4.324358 s: APP: Init ... !!! [MCU2_1] 4.324381 s: SCICLIENT: Init ... !!! [MCU2_1] 4.324625 s: SCICLIENT: DMSC FW version [8.6.3--v08.06.03 (Chill Capybar] [MCU2_1] 4.324673 s: SCICLIENT: DMSC FW revision 0x8 [MCU2_1] 4.324707 s: SCICLIENT: DMSC FW ABI revision 3.1 [MCU2_1] 4.324759 s: SCICLIENT: Init ... Done !!! [MCU2_1] 4.324787 s: UDMA: Init ... !!! [MCU2_1] 4.326229 s: UDMA: Init ... Done !!! [MCU2_1] 4.326290 s: MEM: Init ... !!! [MCU2_1] 4.326334 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ da000000 of size 16777216 bytes !!! [MCU2_1] 4.326406 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000001) @ 3640000 of size 262144 bytes !!! [MCU2_1] 4.326469 s: MEM: Init ... Done !!! [MCU2_1] 4.326494 s: IPC: Init ... !!! [MCU2_1] 4.326557 s: IPC: 6 CPUs participating in IPC !!! [MCU2_1] 4.341516 s: IPC: Init ... Done !!! [MCU2_1] 4.341582 s: APP: Syncing with 5 CPUs ... !!! [MCU2_1] 5.184132 s: APP: Syncing with 5 CPUs ... Done !!! [MCU2_1] 5.184173 s: REMOTE_SERVICE: Init ... !!! [MCU2_1] 5.185868 s: REMOTE_SERVICE: Init ... Done !!! [MCU2_1] 5.185931 s: FVID2: Init ... !!! [MCU2_1] 5.186004 s: FVID2: Init ... Done !!! [MCU2_1] 5.186037 s: VHWA: DMPAC: Init ... !!! [MCU2_1] 5.186064 s: SCICLIENT: Sciclient_pmSetModuleState module=48 state=2 [MCU2_1] 5.186550 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_1] 5.186590 s: SCICLIENT: Sciclient_pmSetModuleState module=305 state=2 [MCU2_1] 5.187090 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_1] 5.187130 s: VHWA: DOF Init ... !!! [MCU2_1] 5.195597 s: VHWA: DOF Init ... Done !!! [MCU2_1] 5.195663 s: VHWA: SDE Init ... !!! [MCU2_1] 5.198302 s: VHWA: SDE Init ... Done !!! [MCU2_1] 5.198362 s: VHWA: DMPAC: Init ... Done !!! [MCU2_1] 5.198410 s: VX_ZONE_INIT:Enabled [MCU2_1] 5.198443 s: VX_ZONE_ERROR:Enabled [MCU2_1] 5.198471 s: VX_ZONE_WARNING:Enabled [MCU2_1] 5.199882 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target MCU2-1 [MCU2_1] 5.200126 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DMPAC_SDE [MCU2_1] 5.200352 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DMPAC_DOF [MCU2_1] 5.200407 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!! [MCU2_1] 5.200445 s: APP: OpenVX Target kernel init ... !!! [MCU2_1] 5.200716 s: APP: OpenVX Target kernel init ... Done !!! [MCU2_1] 5.200773 s: UDMA Copy: Init ... !!! [MCU2_1] 5.202669 s: UDMA Copy: Init ... Done !!! [MCU2_1] 5.202747 s: APP: Init ... Done !!! [MCU2_1] 5.202781 s: APP: Run ... !!! [MCU2_1] 5.202808 s: IPC: Starting echo test ... [MCU2_1] 5.205357 s: APP: Run ... Done !!! [MCU2_1] 5.206484 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C66X_1[P] C66X_2[.] C7X_1[.] [MCU2_1] 5.206595 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C66X_1[P] C66X_2[P] C7X_1[.] [MCU2_1] 5.206684 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C66X_1[P] C66X_2[P] C7X_1[P] [MCU2_1] 5.353192 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[s] C66X_1[P] C66X_2[P] C7X_1[P] [C6x_1 ] 4.411822 s: CIO: Init ... Done !!! [C6x_1 ] 4.411847 s: ### CPU Frequency = 1350000000 Hz [C6x_1 ] 4.411857 s: CPU is running FreeRTOS [C6x_1 ] 4.411865 s: APP: Init ... !!! [C6x_1 ] 4.411872 s: SCICLIENT: Init ... !!! [C6x_1 ] 4.412083 s: SCICLIENT: DMSC FW version [8.6.3--v08.06.03 (Chill Capybar] [C6x_1 ] 4.412094 s: SCICLIENT: DMSC FW revision 0x8 [C6x_1 ] 4.412103 s: SCICLIENT: DMSC FW ABI revision 3.1 [C6x_1 ] 4.412113 s: SCICLIENT: Init ... Done !!! [C6x_1 ] 4.412122 s: UDMA: Init ... !!! [C6x_1 ] 4.413573 s: UDMA: Init ... Done !!! [C6x_1 ] 4.413593 s: MEM: Init ... !!! [C6x_1 ] 4.413606 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ dc000000 of size 16777216 bytes !!! [C6x_1 ] 4.413622 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 800000 of size 229376 bytes !!! [C6x_1 ] 4.413638 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ dd000000 of size 50331648 bytes !!! [C6x_1 ] 4.413654 s: MEM: Init ... Done !!! [C6x_1 ] 4.413661 s: IPC: Init ... !!! [C6x_1 ] 4.413681 s: IPC: 6 CPUs participating in IPC !!! [C6x_1 ] 4.417143 s: IPC: Init ... Done !!! [C6x_1 ] 4.417169 s: APP: Syncing with 5 CPUs ... !!! [C6x_1 ] 5.184131 s: APP: Syncing with 5 CPUs ... Done !!! [C6x_1 ] 5.184141 s: REMOTE_SERVICE: Init ... !!! [C6x_1 ] 5.184868 s: REMOTE_SERVICE: Init ... Done !!! [C6x_1 ] 5.184904 s: VX_ZONE_INIT:Enabled [C6x_1 ] 5.184914 s: VX_ZONE_ERROR:Enabled [C6x_1 ] 5.184923 s: VX_ZONE_WARNING:Enabled [C6x_1 ] 5.185692 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!! [C6x_1 ] 5.185708 s: APP: OpenVX Target kernel init ... !!! [C6x_1 ] 5.185962 s: APP: OpenVX Target kernel init ... Done !!! [C6x_1 ] 5.185976 s: UDMA Copy: Init ... !!! [C6x_1 ] 5.189644 s: UDMA Copy: Init ... Done !!! [C6x_1 ] 5.189664 s: APP: Init ... Done !!! [C6x_1 ] 5.189673 s: APP: Run ... !!! [C6x_1 ] 5.189681 s: IPC: Starting echo test ... [C6x_1 ] 5.190743 s: APP: Run ... Done !!! [C6x_1 ] 5.191041 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[s] C66X_2[x] C7X_1[P] [C6x_1 ] 5.191524 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[s] C66X_2[P] C7X_1[P] [C6x_1 ] 5.205894 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C66X_1[s] C66X_2[P] C7X_1[P] [C6x_1 ] 5.353099 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] C66X_1[s] C66X_2[P] C7X_1[P] [C6x_2 ] 4.501035 s: CIO: Init ... Done !!! [C6x_2 ] 4.501060 s: ### CPU Frequency = 1350000000 Hz [C6x_2 ] 4.501070 s: CPU is running FreeRTOS [C6x_2 ] 4.501078 s: APP: Init ... !!! [C6x_2 ] 4.501086 s: SCICLIENT: Init ... !!! [C6x_2 ] 4.501290 s: SCICLIENT: DMSC FW version [8.6.3--v08.06.03 (Chill Capybar] [C6x_2 ] 4.501302 s: SCICLIENT: DMSC FW revision 0x8 [C6x_2 ] 4.501311 s: SCICLIENT: DMSC FW ABI revision 3.1 [C6x_2 ] 4.501321 s: SCICLIENT: Init ... Done !!! [C6x_2 ] 4.501330 s: UDMA: Init ... !!! [C6x_2 ] 4.502820 s: UDMA: Init ... Done !!! [C6x_2 ] 4.502838 s: MEM: Init ... !!! [C6x_2 ] 4.502852 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ e0000000 of size 16777216 bytes !!! [C6x_2 ] 4.502868 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 800000 of size 229376 bytes !!! [C6x_2 ] 4.502884 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ e1000000 of size 50331648 bytes !!! [C6x_2 ] 4.502900 s: MEM: Init ... Done !!! [C6x_2 ] 4.502908 s: IPC: Init ... !!! [C6x_2 ] 4.502928 s: IPC: 6 CPUs participating in IPC !!! [C6x_2 ] 4.506427 s: IPC: Init ... Done !!! [C6x_2 ] 4.506453 s: APP: Syncing with 5 CPUs ... !!! [C6x_2 ] 5.184131 s: APP: Syncing with 5 CPUs ... Done !!! [C6x_2 ] 5.184141 s: REMOTE_SERVICE: Init ... !!! [C6x_2 ] 5.184872 s: REMOTE_SERVICE: Init ... Done !!! [C6x_2 ] 5.184906 s: VX_ZONE_INIT:Enabled [C6x_2 ] 5.184916 s: VX_ZONE_ERROR:Enabled [C6x_2 ] 5.184925 s: VX_ZONE_WARNING:Enabled [C6x_2 ] 5.185693 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!! [C6x_2 ] 5.185710 s: APP: OpenVX Target kernel init ... !!! [C6x_2 ] 5.185974 s: APP: OpenVX Target kernel init ... Done !!! [C6x_2 ] 5.185990 s: UDMA Copy: Init ... !!! [C6x_2 ] 5.190026 s: UDMA Copy: Init ... Done !!! [C6x_2 ] 5.190050 s: APP: Init ... Done !!! [C6x_2 ] 5.190059 s: APP: Run ... !!! [C6x_2 ] 5.190068 s: IPC: Starting echo test ... [C6x_2 ] 5.191199 s: APP: Run ... Done !!! [C6x_2 ] 5.191523 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[s] C7X_1[.] [C6x_2 ] 5.191555 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[s] C7X_1[P] [C6x_2 ] 5.205921 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C66X_1[P] C66X_2[s] C7X_1[P] [C6x_2 ] 5.353129 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] C66X_1[P] C66X_2[s] C7X_1[P] [C7x_1 ] 5.180674 s: CIO: Init ... Done !!! [C7x_1 ] 5.180688 s: ### CPU Frequency = 1000000000 Hz [C7x_1 ] 5.180700 s: CPU is running FreeRTOS [C7x_1 ] 5.180708 s: APP: Init ... !!! [C7x_1 ] 5.180716 s: SCICLIENT: Init ... !!! [C7x_1 ] 5.180924 s: SCICLIENT: DMSC FW version [8.6.3--v08.06.03 (Chill Capybar] [C7x_1 ] 5.180939 s: SCICLIENT: DMSC FW revision 0x8 [C7x_1 ] 5.180950 s: SCICLIENT: DMSC FW ABI revision 3.1 [C7x_1 ] 5.180960 s: SCICLIENT: Init ... Done !!! [C7x_1 ] 5.180970 s: UDMA: Init ... !!! [C7x_1 ] 5.182092 s: UDMA: Init ... Done !!! [C7x_1 ] 5.182104 s: MEM: Init ... !!! [C7x_1 ] 5.182115 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ 117000000 of size 268435456 bytes !!! [C7x_1 ] 5.182135 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000001) @ 70020000 of size 8159232 bytes !!! [C7x_1 ] 5.182153 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 64800000 of size 458752 bytes !!! [C7x_1 ] 5.182170 s: MEM: Created heap (L1_MEM, id=3, flags=0x00000001) @ 64e00000 of size 16384 bytes !!! [C7x_1 ] 5.182188 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ 100000000 of size 385875968 bytes !!! [C7x_1 ] 5.182206 s: MEM: Init ... Done !!! [C7x_1 ] 5.182214 s: IPC: Init ... !!! [C7x_1 ] 5.182228 s: IPC: 6 CPUs participating in IPC !!! [C7x_1 ] 5.184104 s: IPC: Init ... Done !!! [C7x_1 ] 5.184118 s: APP: Syncing with 5 CPUs ... !!! [C7x_1 ] 5.184131 s: APP: Syncing with 5 CPUs ... Done !!! [C7x_1 ] 5.184142 s: REMOTE_SERVICE: Init ... !!! [C7x_1 ] 5.184282 s: REMOTE_SERVICE: Init ... Done !!! [C7x_1 ] 5.184306 s: VX_ZONE_INIT:Enabled [C7x_1 ] 5.184316 s: VX_ZONE_ERROR:Enabled [C7x_1 ] 5.184326 s: VX_ZONE_WARNING:Enabled [C7x_1 ] 5.184475 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1 [C7x_1 ] 5.184568 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_2 [C7x_1 ] 5.184653 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_3 [C7x_1 ] 5.184723 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_4 [C7x_1 ] 5.184787 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_5 [C7x_1 ] 5.184850 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_6 [C7x_1 ] 5.184912 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_7 [C7x_1 ] 5.184995 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_8 [C7x_1 ] 5.185062 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!! [C7x_1 ] 5.185076 s: APP: OpenVX Target kernel init ... !!! [C7x_1 ] 5.185216 s: APP: OpenVX Target kernel init ... Done !!! [C7x_1 ] 5.185230 s: APP: Init ... Done !!! [C7x_1 ] 5.185239 s: APP: Run ... !!! [C7x_1 ] 5.185247 s: IPC: Starting echo test ... [C7x_1 ] 5.185379 s: APP: Run ... Done !!! [C7x_1 ] 5.191059 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[x] C7X_1[s] [C7x_1 ] 5.191515 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[P] C7X_1[s] [C7x_1 ] 5.205944 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[s] [C7x_1 ] 5.353175 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[s]
Slog2info
J7EVM@QNX:/# slog2info Jan 01 00:00:00.016 random.5 low* 0 qcrypto: loading configuration file '/etc/qcrypto.conf' [qcrypto_common.c(190)] Jan 01 00:00:00.017 random.5..0 slog* 700 Random is using the Fortuna PRNG Jan 01 00:00:00.021 random.5 low 0 qcrypto: 'openssl' plugin loaded [qcrypto_plugins.c(354)] Jan 01 00:00:00.021 random.5..0 slog 700 Selecting timer as an entropy source Jan 01 00:00:00.021 random.5..0 slog 700 Registered path names Jan 01 00:00:00.021 random.5..0 slog 700 random: starting resmgr Jan 01 00:00:00.021 random.5..0 slog 700 random: Daemonizing the process Jan 01 00:00:00.002 devb_sdmmc_am65x.4104 slog* 1800 devb-sdmmc-am65x 1.00A (May 16 2023 08:55:14) Jan 01 00:00:00.002 devb_sdmmc_am65x.4104 slog 0 libcam.so (Aug 22 2022 09:45:51) bver 7010004 Jan 01 00:00:00.003 devb_sdmmc_am65x.4104 slog 1800 sdio_cd: insertion path 0, cd state 0x1 Jan 01 00:00:00.004 devb_sdmmc_am65x.4105 slog* 1800 devb-sdmmc-am65x 1.00A (May 16 2023 08:55:14) Jan 01 00:00:00.005 devb_sdmmc_am65x.4105 slog 0 libcam.so (Aug 22 2022 09:45:51) bver 7010004 Jan 01 00:00:00.005 devb_sdmmc_am65x.4105 slog 1800 sdio_cd: insertion path 0, cd state 0x1 Jan 01 00:00:00.010 io_usb_otg.16394 slog* 0 main(453)[tid:1]: io-usb-otg (Jan 16 2023 12:54:50) args: -d cdns3-xhci ioport=0x6010000,irq=128,iosize=65536,ioport=0x6410000,irq=136,iosize=65536,nousb3 Jan 01 00:00:00.014 io_usb_otg.16394 slog 0 xhci_init: Initialiaing with sever version: 2 Jan 01 00:00:00.014 io_usb_otg.16394 slog 0 xhci_controller_init(2661): devu-hcd-cdns3-xhci.so (Jan 20 2022 16:08:39): args Jan 01 00:00:00.014 io_usb_otg.16394 slog 0 cdns3_usb_port_info(308)[tid:1]: cdns3: chipset j721e xhci_irq=128 serdes_addr=0x5030000 Jan 01 00:00:00.019 io_usb_otg.16394 slog 8 usb_enum_port(94)[tid:1]: busno 0, parent -1, port 0, Super speed Jan 01 00:00:00.019 io_usb_otg.16394 slog 11 usb_client_descriptor_get(198)[tid:1]: (type 1, index 0, length 8) Jan 01 00:00:00.019 io_usb_otg.16394 slog 12 usb_device_set_address(245)[tid:1]: b:0 devno 0 Jan 01 00:00:00.019 io_usb_otg.16394 slog 11 usb_client_descriptor_get(198)[tid:1]: (type 1, index 0, length 18) Jan 01 00:00:00.019 io_usb_otg.16394 slog 11 usb_client_descriptor_get(198)[tid:1]: (type 2, index 0, length 9) Jan 01 00:00:00.019 io_usb_otg.16394 slog 11 usb_client_descriptor_get(198)[tid:1]: (type 2, index 0, length 25) Jan 01 00:00:00.019 io_usb_otg.16394 slog 8 usb_enum_port(141)[tid:1]: vid 0x0000, did 0x0000 enumerated(busno 0, devno 0:0) Jan 01 00:00:00.020 io_usb_otg.16394 slog 11 hub_state_inserted(569)[tid:1]: bdentry 0, dentry 0 0 Jan 01 00:00:00.020 io_usb_otg.16394 slog 13 hub_configuration_enable(263)[tid:1]: 1 Jan 01 00:00:00.092 devb_sdmmc_am65x.4104 slog 1800 MMC CID: Jan 01 00:00:00.092 devb_sdmmc_am65x.4104 slog 1800 MID 0x13, OID 0x4e, PNM S0J56X Jan 01 00:00:00.092 devb_sdmmc_am65x.4104 slog 1800 PRV 0x10, PSN 0x10e5bbab, MDT 6-2019 Jan 01 00:00:00.092 devb_sdmmc_am65x.4104 slog 1800 MMC CSD: Jan 01 00:00:00.092 devb_sdmmc_am65x.4104 slog 1800 CSD_STRUCTURE 3, SPEC_VERS 4, CCC 0x8f5 Jan 01 00:00:00.092 devb_sdmmc_am65x.4104 slog 1800 TAAC 127, NSAC 1, TRAN_SPEED 50 Jan 01 00:00:00.092 devb_sdmmc_am65x.4104 slog 1800 C_SIZE 4095, C_SIZE_MULT 7 Jan 01 00:00:00.092 devb_sdmmc_am65x.4104 slog 1800 READ_BL_LEN 9, WRITE_BL_LEN 9 Jan 01 00:00:00.092 devb_sdmmc_am65x.4104 slog 1800 ERASE GRP_SIZE 31, GRP_MULT 31, SIZE 0 Jan 01 00:00:00.092 devb_sdmmc_am65x.4104 slog 1800 blksz 512, sectors 2097152, dtr 25000000 Jan 01 00:00:00.092 devb_sdmmc_am65x.4104 slog 1800 MMC EXT CSD: Jan 01 00:00:00.092 devb_sdmmc_am65x.4104 slog 1800 DEVICE_TYPE 0x57, EXT_CSD_REV 8 Jan 01 00:00:00.092 devb_sdmmc_am65x.4104 slog 1800 SEC_COUNT 31080448, dtr 200000000 Jan 01 00:00:00.092 devb_sdmmc_am65x.4104 slog 1800 HC_ERASE_GRP_SIZE 1, HC_WP_GRP_SIZE 16 Jan 01 00:00:00.092 devb_sdmmc_am65x.4104 slog 1800 STROBE 0x0, BKOPS_EN 0x0 Jan 01 00:00:00.092 devb_sdmmc_am65x.4104 slog 1800 Driver type: 0x0 Jan 01 00:00:00.092 devb_sdmmc_am65x.4104 slog 1800 CFG: Timing HS200, DTR 200000000, Bus Width 8 bit Jan 01 00:00:00.092 devb_sdmmc_am65x.4104 slog 100 cam-disk.so (Aug 22 2022 09:45:53) Jan 01 00:00:00.122 io_usb_otg.16394 slog 0 xhci_init: Initialiaing with sever version: 2 Jan 01 00:00:00.122 io_usb_otg.16394 slog 0 xhci_controller_init(2661): devu-hcd-cdns3-xhci.so (Jan 20 2022 16:08:39): args nousb3 Jan 01 00:00:00.122 io_usb_otg.16394 slog 0 cdns3_usb_port_info(308)[tid:1]: cdns3: chipset j721e xhci_irq=136 serdes_addr=0x0 Jan 01 00:00:00.122 io_usb_otg.16394 slog 8 usb_enum_port(94)[tid:1]: busno 1, parent -1, port 0, High speed Jan 01 00:00:00.122 io_usb_otg.16394 slog 11 usb_client_descriptor_get(198)[tid:1]: (type 1, index 0, length 8) Jan 01 00:00:00.122 io_usb_otg.16394 slog 12 usb_device_set_address(245)[tid:1]: b:1 devno 0 Jan 01 00:00:00.122 io_usb_otg.16394 slog 11 usb_client_descriptor_get(198)[tid:1]: (type 1, index 0, length 18) Jan 01 00:00:00.123 io_usb_otg.16394 slog 11 usb_client_descriptor_get(198)[tid:1]: (type 2, index 0, length 9) Jan 01 00:00:00.123 io_usb_otg.16394 slog 11 usb_client_descriptor_get(198)[tid:1]: (type 2, index 0, length 25) Jan 01 00:00:00.123 io_usb_otg.16394 slog 8 usb_enum_port(141)[tid:1]: vid 0x0000, did 0x0000 enumerated(busno 1, devno 0:1) Jan 01 00:00:00.123 io_usb_otg.16394 slog 11 hub_state_inserted(569)[tid:1]: bdentry 0, dentry 0 0 Jan 01 00:00:00.123 io_usb_otg.16394 slog 13 hub_configuration_enable(263)[tid:1]: 1 Jan 01 00:00:00.199 devb_sdmmc_am65x.4105 slog 1800 SD CID: Jan 01 00:00:00.199 devb_sdmmc_am65x.4105 slog 1800 MID 0x27, OID 0x5048, PNM SD16G Jan 01 00:00:00.199 devb_sdmmc_am65x.4105 slog 1800 PRV 0xe2, PSN 0x1e20863, MDT 7-2017 Jan 01 00:00:00.199 devb_sdmmc_am65x.4105 slog 1800 SD CSD: Jan 01 00:00:00.199 devb_sdmmc_am65x.4105 slog 1800 CSD_STRUCTURE 1, SPEC_VERS 0, CCC 0x5b5 Jan 01 00:00:00.199 devb_sdmmc_am65x.4105 slog 1800 TAAC 14, NSAC 0, TRAN_SPEED 50 Jan 01 00:00:00.199 devb_sdmmc_am65x.4105 slog 1800 C_SIZE 29735, C_SIZE_MULT 0 Jan 01 00:00:00.199 devb_sdmmc_am65x.4105 slog 1800 READ_BL_LEN 9, WRITE_BL_LEN 9 Jan 01 00:00:00.200 devb_sdmmc_am65x.4105 slog 1800 ERASE GRP_SIZE 0, GRP_MULT 0, SIZE 127 Jan 01 00:00:00.200 devb_sdmmc_am65x.4105 slog 1800 blksz 512, sectors 30449664, dtr 25000000 Jan 01 00:00:00.200 devb_sdmmc_am65x.4105 slog 1800 SD SW CAPS: Jan 01 00:00:00.200 devb_sdmmc_am65x.4105 slog 1800 bus mode 0x1f, cmd sys 0x1 Jan 01 00:00:00.200 devb_sdmmc_am65x.4105 slog 1800 drv type 0xf, curr limit 0xf Jan 01 00:00:00.200 devb_sdmmc_am65x.4105 slog 1800 dtr 50000000 Jan 01 00:00:00.200 devb_sdmmc_am65x.4105 slog 1800 CFG: Timing SDR104, DTR 200000000, Bus Width 4 bit Jan 01 00:00:00.200 devb_sdmmc_am65x.4105 slog 100 cam-disk.so (Aug 22 2022 09:45:53) Jan 01 00:00:00.225 io_usb_otg.16394 slog 0 usbh_timeout_init(203)[tid:1]: Complete Jan 01 00:00:00.284 io_usb_otg.16394 slog 8 usb_enum_port_extract(172)[tid:8]: (busno 0, pdevno 0, portno 1) Jan 01 00:00:00.284 io_usb_otg.16394 slog 8 usb_enum_port_extract(192)[tid:8]: status (2) Jan 01 00:00:00.284 io_usb_otg.16394 slog 8 usb_enum_port_extract(172)[tid:8]: (busno 0, pdevno 0, portno 2) Jan 01 00:00:00.284 io_usb_otg.16394 slog 8 usb_enum_port_extract(192)[tid:8]: status (2) Jan 01 00:00:00.290 io_usb_otg.16394 slog 8 usb_enum_port_extract(172)[tid:8]: (busno 1, pdevno 0, portno 1) Jan 01 00:00:00.290 io_usb_otg.16394 slog 8 usb_enum_port_extract(192)[tid:8]: status (2) Jan 01 00:00:00.305 io_usb_otg.16394 slog 8 usb_enum_port_extract(172)[tid:8]: (busno 1, pdevno 0, portno 1) Jan 01 00:00:00.305 io_usb_otg.16394 slog 8 usb_enum_port_extract(192)[tid:8]: status (2) Jan 01 00:00:00.563 io_usb_otg.16394 slog 0 xhci_get_root_device_speed: port 0 is HIGH speed, psts e03 Jan 01 00:00:00.563 io_usb_otg.16394 slog 8 usb_enum_port(94)[tid:8]: busno 1, parent 0, port 1, High speed Jan 01 00:00:00.563 io_usb_otg.16394 slog 0 xring_create: ep->mbuf = 0x022757c0 Jan 01 00:00:00.569 io_usb_otg.16394 slog 11 usb_client_descriptor_get(198)[tid:8]: (type 1, index 0, length 8) Jan 01 00:00:00.569 io_usb_otg.16394 slog 12 usb_device_set_address(245)[tid:8]: b:1 devno 1 Jan 01 00:00:00.569 io_usb_otg.16394 slog 0 xHCI: Internal Device Addr 1 Jan 01 00:00:00.590 io_usb_otg.16394 slog 11 usb_client_descriptor_get(198)[tid:8]: (type 1, index 0, length 18) Jan 01 00:00:00.590 io_usb_otg.16394 slog 11 usb_client_descriptor_get(198)[tid:8]: (type 2, index 0, length 9) Jan 01 00:00:00.590 io_usb_otg.16394 slog 11 usb_client_descriptor_get(198)[tid:8]: (type 2, index 0, length 41) Jan 01 00:00:00.590 io_usb_otg.16394 slog 8 usb_enum_port(141)[tid:8]: vid 0x0451, did 0x8142 enumerated(busno 1, devno 1:2) Jan 01 00:00:00.590 io_usb_otg.16394 slog 11 hub_state_inserted(569)[tid:8]: bdentry 1, dentry 1 0 Jan 01 00:00:00.591 io_usb_otg.16394 slog 0 xring_create: ep->mbuf = 0x02275950 Jan 01 00:00:00.591 io_usb_otg.16394 slog 13 hub_configuration_enable(263)[tid:2]: 1 Jan 01 00:00:00.591 io_usb_otg.16394 slog 0 process_xfer_complete: No Outstanding Transfer, slotid = 1 devaddr = 0x1 epnum = 0x1 epdir = 0x80 xring->enq_idx = 0 xring->deq_idx = 0 Jan 01 00:00:00.591 io_usb_otg.16394 slog 0 process_xfer_complete: evt->w0 = 0x8002e000 evt->w1 = 0x0 evt->w2 = 0x1b000000 evt->w3 = 0x1038001 Jan 01 00:00:00.591 io_usb_otg.16394 slog 16 hub_notification_disable(353)[tid:2]: Jan 01 00:00:00.591 io_usb_otg.16394 slog 0 xring_create: ep->mbuf = 0x02275950 Jan 01 00:00:00.672 tisci_mgr.57356 slog* 130 TI SCI ResMgr for SOC J721E (version=PSDKQNX_08_06_00, date=Thu 18 May 14:52:18 CEST 2023) Jan 01 00:00:00.672 tisci_mgr.57356 slog 130 SYSFW Firmware Version 8.6.3--v08.06.03 (Chill Capybar Jan 01 00:00:00.672 tisci_mgr.57356 slog 130 SYSFW Firmware revision 0x8 Jan 01 00:00:00.672 tisci_mgr.57356 slog 130 SYSFW ABI revision 3.1 Jan 01 00:00:00.681 shmemallocator.69645 slog* 129 TI Shared memory Allocator for SOC J721E (version=PSDKQNX_08_06_00, date=Thu 18 May 14:52:18 CEST 2023) Jan 01 00:00:00.681 shmemallocator.69645 slog 129 initSHM:Block[0] @ 0xb8000000 has free-mem = 0x20000000 - 512 M Jan 01 00:00:00.693 io_usb_otg.16394 slog 8 usb_enum_port_extract(172)[tid:8]: (busno 1, pdevno 1, portno 1) Jan 01 00:00:00.693 io_usb_otg.16394 slog 8 usb_enum_port_extract(192)[tid:8]: status (2) Jan 01 00:00:00.693 io_usb_otg.16394 slog 8 usb_enum_port_extract(172)[tid:8]: (busno 1, pdevno 1, portno 2) Jan 01 00:00:00.693 io_usb_otg.16394 slog 8 usb_enum_port_extract(192)[tid:8]: status (2) Jan 01 00:00:00.693 io_usb_otg.16394 slog 8 usb_enum_port_extract(172)[tid:8]: (busno 1, pdevno 1, portno 3) Jan 01 00:00:00.693 io_usb_otg.16394 slog 8 usb_enum_port_extract(192)[tid:8]: status (2) Jan 01 00:00:00.693 io_usb_otg.16394 slog 8 usb_enum_port_extract(172)[tid:8]: (busno 1, pdevno 1, portno 4) Jan 01 00:00:00.693 io_usb_otg.16394 slog 8 usb_enum_port_extract(192)[tid:8]: status (2) Jan 01 00:00:00.701 tiipc_mgr.73742 slog* 133 TI IPC ResMgr for SOC J721E (version=PSDKQNX_08_06_00, date=Thu 18 May 14:52:18 CEST 2023) Jan 01 00:00:00.701 tiipc_mgr.73742 slog 133 tiipc-mgr: Starting TI IPC Resmgr Jan 01 00:00:00.701 tiipc_mgr.73742 slog 133 tiipc-mgr: Using VRING base address: 0xaa000000, size:0x1c00000 Jan 01 00:00:00.715 tiipc_mgr.73742 slog 133 [IPC] Jan 01 00:00:00.715 tiipc_mgr.73742 slog 133 Mailbox_plugInterrupt: interrupt Number 489, arg 0x3EC32180 Jan 01 00:00:00.729 tiipc_mgr.73742 slog 133 [IPC] Jan 01 00:00:00.729 tiipc_mgr.73742 slog 133 Mailbox_plugInterrupt: interrupt Number 490, arg 0x3EC32320 Jan 01 00:00:00.743 tiipc_mgr.73742 slog 133 [IPC] Jan 01 00:00:00.743 tiipc_mgr.73742 slog 133 Mailbox_plugInterrupt: interrupt Number 491, arg 0x3EC324C0 Jan 01 00:00:00.757 tiipc_mgr.73742 slog 133 [IPC] Jan 01 00:00:00.757 tiipc_mgr.73742 slog 133 Mailbox_plugInterrupt: interrupt Number 492, arg 0x3EC32660 Jan 01 00:00:00.770 tiipc_mgr.73742 slog 133 [IPC] Jan 01 00:00:00.770 tiipc_mgr.73742 slog 133 Mailbox_plugInterrupt: interrupt Number 493, arg 0x3EC32800 Jan 01 00:00:00.788 tiudma_mgr.77839 slog* 131 TI UDMA ResMgr for SOC J721E (version=PSDKQNX_08_06_00, date=Thu 18 May 14:52:18 CEST 2023) Jan 01 00:00:00.839 vxe_enc.81936 slog* 2 MM_ENC_Init: No OCM RAM pool available, fallback to DDR mode for above mp params Jan 01 00:00:00.840 vxe_enc.81936 slog 2 MM_ENC_Init: adding heap of type 1 Jan 01 00:00:00.840 vxe_enc.81936 slog 2 MM_ENC_Init: using heap 1 for internal alloc Jan 01 00:00:00.840 vxe_enc.81936 slog 2 Page table directory at physical address 0x08f76440 Jan 01 00:00:00.841 vxe_enc.81936 slog 2 Loading firmware. Jan 01 00:00:00.841 vxe_enc.81936 slog 2 Using firmware: ALL_CODECS with 2 pipes, hwconfig=1 (text size = 15278, data size = 13643) for requested codec: H264 RC mode ALL Jan 01 00:00:00.848 vxe_enc.81936 slog 2 mtx_uploadfw complete! Jan 01 00:00:00.848 vxe_enc.81936 slog 2 PC_START_ADDRESS = 0x80900000 Jan 01 00:00:00.850 vxe_enc.81936 slog 2 firmware uploaded! Jan 01 00:00:00.853 vxe_enc.81936 slog 2 VXE-ENC resource manager started Jan 01 00:00:00.894 vxd_dec.86033 slog* 2 Starting VXD-DEC resource manager... Jan 01 00:00:00.894 vxd_dec.86033 slog 2 hw:8.15.2, num_pix: 2, num_ent: 1, mmu: 40, MTX RAM: 135168 Jan 01 00:00:00.901 vxd_dec.86033 slog 2 PVDEC revision 00080f02 detected, id 00000003. Jan 01 00:00:00.902 vxd_dec.86033 slog 2 Found 1 entropy pipe(s), 2 pixel pipe(s), 4 group size Jan 01 00:00:00.902 vxd_dec.86033 slog 2 cur_bitdepth: 10 cur_h264_hw_chromaformat: 2 Jan 01 00:00:00.902 vxd_dec.86033 slog 2 cur_hevc_hw_chromaformat: 2 pipe_minus1: 0 Jan 01 00:00:00.902 vxd_dec.86033 slog 2 cur_bitdepth: 10 cur_h264_hw_chromaformat: 0 Jan 01 00:00:00.902 vxd_dec.86033 slog 2 cur_hevc_hw_chromaformat: 3 pipe_minus1: 1 Jan 01 00:00:00.902 vxd_dec.86033 slog 2 Decode slots/core: 2 Jan 01 00:00:00.902 vxd_dec.86033 slog 2 FW: acquired pvdec_full_bin.fw size 247976 Jan 01 00:00:00.902 vxd_dec.86033 slog 2 FW: info cs: 53704, bs: 247960, id: 0x3b8a0ee2, ts: 1669807230 Jan 01 00:00:00.902 vxd_dec.86033 slog 2 VXD-DEC resource manager started Jan 01 00:00:00.938 screen.90130 slog* 300 screen: starting up... Jan 01 00:00:00.942 screen.90130 slog 300 screen: Configuration file: /ti_fs/usr/lib/graphics/j721e/graphics.conf.dss_on_r5 Jan 01 00:00:00.955 screen.90130 slog 300 screen: slog2 context created with 1 pages Jan 01 00:00:00.955 screen.90130 slog 300 screen: loading alloc module stdbuf... Jan 01 00:00:00.957 screen.90130 slog 300 screen: display 1 returned invalid value 0 for WFD_PORT_MODE_ROTATION_SUPPORT Jan 01 00:00:00.959 screen.90130 slog 300 screen: loading libhiddi.so... Jan 01 00:00:00.959 screen.90130 slog 300 screen: server is ready Jan 01 00:00:00.963 iopkt.94227 main_buffer* 0 tcpip starting Jan 01 00:00:00.963 iopkt.94227 main_buffer 0 smmu support is disabled Jan 01 00:00:00.965 iopkt.94227 main_buffer 0 initializing IPsec... Jan 01 00:00:00.965 iopkt.94227 main_buffer 0 done Jan 01 00:00:00.965 iopkt.94227 main_buffer 0 IPsec: Initialized Security Association Processing. Jan 01 00:00:01.025 iopkt.94227 main_buffer 0 devnp-cpsw9g.so (null) Jan 01 00:00:01.025 iopkt.94227 main_buffer 0 an0 Jan 01 00:00:01.025 io_pkt_v6_hc.94227 slog* 0 cpsw_entry:546 Entry --> Jan 01 00:00:01.025 io_pkt_v6_hc.94227 slog 0 cpsw_attach:718 Entry --> Jan 01 00:00:01.026 io_pkt_v6_hc.94227 slog 0 CPSW9G Client (core : mpu1_0) ..... Jan 01 00:00:01.027 io_pkt_v6_hc.94227 slog 0 appRemoteDeviceInitFn(5) has started! Jan 01 00:00:01.029 io_pkt_v6_hc.94227 slog 0 Remote device (core : mpu1_0) ..... Jan 01 00:00:01.029 io_pkt_v6_hc.94227 slog 0 Remote Device Framework Endpoint located. Remote Core Id:3, Remote End Point:26 Jan 01 00:00:01.029 io_pkt_v6_hc.94227 slog 0 CpswProxy_notifyServiceTskFxn(6) has started! Jan 01 00:00:01.029 io_pkt_v6_hc.94227 slog 0 appRemoteDeviceDiscoverTaskFn(7) has started! Jan 01 00:00:01.029 io_pkt_v6_hc.94227 slog 0 appRemoteDeviceRxTaskFn(8) has started! Jan 01 00:00:01.031 io_pkt_v6_hc.94227 slog 0 appRemoteDeviceInitFn(5) exited! Jan 01 00:00:01.031 io_pkt_v6_hc.94227 slog 0 appRemoteDeviceTxTaskFn(9) has started! Jan 01 00:00:01.031 io_pkt_v6_hc.94227 slog 0 CpswProxy_rdevCmdTskFxn(10) has started! Jan 01 00:00:01.031 io_pkt_v6_hc.94227 slog 0 Connecting to 'mpu_1_0_ethswitch-device-0' Jan 01 00:00:01.031 io_pkt_v6_hc.94227 slog 0 Registered a device name = mpu_1_0_ethswitch-device-0, id = 0, type = 3 Jan 01 00:00:01.031 io_pkt_v6_hc.94227 slog 0 ETHFW Version: 0. 2. 0 Jan 01 00:00:01.031 io_pkt_v6_hc.94227 slog 0 ETHFW Build Date (YYYY/MMM/DD):2023/May/16 Jan 01 00:00:01.031 io_pkt_v6_hc.94227 slog 0 ETHFW Commit SHA: Jan 01 00:00:01.031 io_pkt_v6_hc.94227 slog 0 ETHFW PermissionFlag:0x3fffffff, UART Connected:true,UART Id:2 Jan 01 00:00:01.033 io_pkt_v6_hc.94227 slog 0 CPSW9G: Attach to CpswProxy Server. Jan 01 00:00:01.033 io_pkt_v6_hc.94227 slog 0 appRemoteDeviceDiscoverTaskFn(7) exited! Jan 01 00:00:01.033 io_pkt_v6_hc.94227 slog 0 Function:CpswProxy_cmdHandler,Handle:a3ac6d44,CoreKey:38acb7e6, RxMtu:1522, TxMtu:2024:2024:2024:2024:2024:2024:2024:2024, TxCsum:enabled, MacOnly:0 Jan 01 00:00:01.033 io_pkt_v6_hc.94227 slog 0 EnetIf_RemoteAttach:371 RX MTU returned - 1522 Jan 01 00:00:01.034 io_pkt_v6_hc.94227 slog 0 Function:CpswProxy_cmdHandler,mac_address:70:ff:76:1d:92:c1 Jan 01 00:00:01.034 io_pkt_v6_hc.94227 slog 0 MAC Address: 70:ff:76:1d:92:c1 Jan 01 00:00:01.971 io_pkt_v6_hc.94227 slog 0 ENET_CPSW_9G on MAIN NAVSS Jan 01 00:00:01.974 io_pkt_v6_hc.94227 slog 56 [UDMA] Calling Udma_resmgr_open Jan 01 00:00:01.974 io_pkt_v6_hc.94227 slog 56 [UDMA] Opening resmgr!!! Jan 01 00:00:01.974 io_pkt_v6_hc.94227 slog 56 [UDMA] Opened resmgr fd=10!!! Jan 01 00:00:01.974 io_pkt_v6_hc.94227 slog 56 [UDMA] eventHandle->vintrNum = 39!!! Jan 01 00:00:01.974 io_pkt_v6_hc.94227 slog 56 [UDMA] eventHandle->irIntrNum = 11!!! Jan 01 00:00:01.974 io_pkt_v6_hc.94227 slog 56 [UDMA] eventHandle->coreIntrNum = 75!!! Jan 01 00:00:01.981 io_pkt_v6_hc.94227 slog 0 EnetIf_registerIntr2: tx isr 75 thread priority set to 21 Jan 01 00:00:01.981 io_pkt_v6_hc.94227 slog 0 EnetIf_CreateISRThread: InterruptAttachEvent succeed irq/75 coid/1073741850 event/10 Jan 01 00:00:01.981 io_pkt_v6_hc.94227 slog 0 cpsw_alloc:299: Alloc successfull; Virt: 0x3539e5a000, Phys: 0x8fcced000 Jan 01 00:00:01.981 io_pkt_v6_hc.94227 slog 0 EnetUdma_memMgrInit: addr=0x3539e5a000 is aligned Jan 01 00:00:01.982 io_pkt_v6_hc.94227 slog 0 cpsw_alloc:299: Alloc successfull; Virt: 0x3539e6d000, Phys: 0x8fcd00000 Jan 01 00:00:01.982 io_pkt_v6_hc.94227 slog 0 EnetIfMem_init: addr=0x3539e6d000 is aligned Jan 01 00:00:01.982 io_pkt_v6_hc.94227 slog 0 EnetIfMem_init: addr=0x3539e6d000, size=0x221000, gMem=0x3539e6d000, gMemBufPhys=0x8fcd00000 Jan 01 00:00:01.983 io_pkt_v6_hc.94227 slog 0 EnetIfMem_init: gDmaDescMemArray=0x3539e6d000, size=0x200000 Jan 01 00:00:01.983 io_pkt_v6_hc.94227 slog 0 EnetIfMem_init: gRingMemArray=0x353a06d000, size=0x21000 Jan 01 00:00:01.983 io_pkt_v6_hc.94227 slog 0 EnetIfMem_init: gDmaDescMemArrayBasePhys=0x8fcd00000, gDmaDescMemArrayBase=0x3539e6d000 Jan 01 00:00:01.985 io_pkt_v6_hc.94227 slog 0 initQs() freePktInfoQ initialized with 256 pkts Jan 01 00:00:01.986 io_pkt_v6_hc.94227 slog 0 Function:CpswProxy_cmdHandler,Txid:51712 Jan 01 00:00:01.988 io_pkt_v6_hc.94227 slog 0 Function:CpswProxy_cmdHandler,RxAllocId:172 Jan 01 00:00:01.990 io_pkt_v6_hc.94227 slog 56 [UDMA] eventHandle->globalEvent = 38!!! Jan 01 00:00:01.990 io_pkt_v6_hc.94227 slog 56 [UDMA] eventHandle->vintrNum = 40!!! Jan 01 00:00:01.990 io_pkt_v6_hc.94227 slog 56 [UDMA] eventHandle->vintrBitNum = 0!!! Jan 01 00:00:01.990 io_pkt_v6_hc.94227 slog 56 [UDMA] eventHandle->irIntrNum = 12!!! Jan 01 00:00:01.990 io_pkt_v6_hc.94227 slog 56 [UDMA] eventHandle->coreIntrNum = 76!!! Jan 01 00:00:02.003 io_pkt_v6_hc.94227 slog 0 EnetIf_registerIntr2: rx isr 76 thread priority set to 21 Jan 01 00:00:02.003 io_pkt_v6_hc.94227 slog 0 EnetIf_registerIntr2: RX InterruptAttachEvent succeed irq/76 coid/1073741851 event/11 Jan 01 00:00:02.006 io_pkt_v6_hc.94227 slog 0 Host MAC address: Jan 01 00:00:02.006 io_pkt_v6_hc.94227 slog 0 70:ff:76:1d:92:c1 Jan 01 00:00:02.729 io_pkt_v6_hc.94227 slog 0 cpsw_init:1068 Phy is linked Jan 01 00:00:02.729 io_pkt_v6_hc.94227 slog 0 cpsw_filter: Clear IFF_ALLMULTI Jan 01 00:00:02.729 io_pkt_v6_hc.94227 slog 0 cpsw_filter: Adding Multicast MAC Addr -> 33:33:ff:1d:92:c1 Jan 01 00:00:02.733 io_pkt_v6_hc.94227 slog 0 cpsw_filter: Clear IFF_ALLMULTI Jan 01 00:00:02.734 io_pkt_v6_hc.94227 slog 0 cpsw_filter: Adding Multicast MAC Addr -> 33:33:00:00:00:01 Jan 01 00:00:02.738 io_pkt_v6_hc.94227 slog 0 cpsw_filter: Adding Multicast MAC Addr -> 33:33:ff:1d:92:c1 Jan 01 00:00:02.742 io_pkt_v6_hc.94227 slog 0 IPv4 address: 192:168:1:70 Jan 01 00:00:02.743 io_pkt_v6_hc.94227 slog 0 cpsw_filter: Clear IFF_ALLMULTI Jan 01 00:00:02.744 io_pkt_v6_hc.94227 slog 0 cpsw_filter: Adding Multicast MAC Addr -> 01:00:5e:00:00:01 Jan 01 00:00:02.748 io_pkt_v6_hc.94227 slog 0 cpsw_filter: Adding Multicast MAC Addr -> 33:33:00:00:00:01 Jan 01 00:00:02.752 io_pkt_v6_hc.94227 slog 0 cpsw_filter: Adding Multicast MAC Addr -> 33:33:ff:1d:92:c1
2. In the same file main.c (vision_apps/platform/j721e/rtos/mcu2_0/main.c), I have added a simple TCP socket application instead of UDP. However, I am encountering an error:
I/TC:
SoC: J721E SR1.0 GP
DRAM: 4 GiB
Flash: 0 Bytes
In: serial@2800000
Out: serial@2800000
Err: serial@2800000
556 bytes read in 10 ms (53.7 KiB/s)
Running uenvcmd ...
1428824 bytes read in 74 ms (18.4 MiB/s)
301996 bytes read in 27 ms (10.7 MiB/s)
1334004 bytes read in 69 ms (18.4 MiB/s)
15576248 bytes read in 664 ms (22.4 MiB/s)
8329020 bytes read in 369 ms (21.5 MiB/s)
Enabling ITS 0
Display set to R5
start serial driver
Path=0 - am65x
done..
Mounting the sd ..
user.sh called...
Start screen..
Start CPSW9G..
done...
J7EVM@QNX:/# [MCU2_0] 4.281987 s: CIO: Init ... Done !!!
[MCU2_0] 4.282055 s: ### CPU Frequency = 1000000000 Hz
[MCU2_0] 4.282097 s: CPU is running FreeRTOS
[MCU2_0] 4.282122 s: APP: Init ... !!!
[MCU2_0] 4.282144 s: SCICLIENT: Init ... !!!
[MCU2_0] 4.282447 s: SCICLIENT: DMSC FW version [8.6.3--v08.06.03 (Chill Capybar]
[MCU2_0] 4.282493 s: SCICLIENT: DMSC FW revision 0x8
[MCU2_0] 4.282526 s: SCICLIENT: DMSC FW ABI revision 3.1
[MCU2_0] 4.282560 s: SCICLIENT: Init ... Done !!!
[MCU2_0] 4.282588 s: UDMA: Init ... !!!
[MCU2_0] 4.284342 s: UDMA: Init ... Done !!!
[MCU2_0] 4.284417 s: MEM: Init ... !!!
[MCU2_0] 4.284475 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ d9000000 of size 16777216 bytes !!!
[MCU2_0] 4.284559 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000000) @ 3600000 of size 262144 bytes !!!
[MCU2_0] 4.284625 s: MEM: Init ... Done !!!
[MCU2_0] 4.284650 s: IPC: Init ... !!!
[MCU2_0] 4.284754 s: IPC: 6 CPUs participating in IPC !!!
[MCU2_0] 4.299731 s: IPC: Init ... Done !!!
[MCU2_0] 4.299797 s: APP: Syncing with 5 CPUs ... !!!
[MCU2_0] 5.095170 s: APP: Syncing with 5 CPUs ... Done !!!
[MCU2_0] 5.095370 s: REMOTE_SERVICE: Init ... !!!
[MCU2_0] 5.096918 s: REMOTE_SERVICE: Init ... Done !!!
[MCU2_0] 5.096983 s: ETHFW: Init ... !!!
[MCU2_0] 5.102019 s: Warning: Using 6 MAC address(es) from static pool
[MCU2_0] 5.102134 s: ETHFW: Shared multicasts (software fanout):
[MCU2_0] 5.102177 s: ETHFW: Reserved multicasts:
[MCU2_0] 5.102204 s: 01:80:c2:00:00:0e
[MCU2_0] 5.102249 s: 01:1b:19:00:00:00
[MCU2_0] 5.102566 s: EnetMcm: CPSW_9G on MAIN NAVSS
[MCU2_0] 5.111844 s: Mdio_open: MDIO manual mode enabled
[MCU2_0] 5.114777 s: PHY 0 is alive
[MCU2_0] 5.115066 s: PHY 3 is alive
[MCU2_0] 5.115685 s: PHY 12 is alive
[MCU2_0] 5.115926 s: PHY 15 is alive
[MCU2_0] 5.116029 s: PHY 16 is alive
[MCU2_0] 5.116127 s: PHY 17 is alive
[MCU2_0] 5.116224 s: PHY 18 is alive
[MCU2_0] 5.116323 s: PHY 19 is alive
[MCU2_0] 5.116615 s: PHY 23 is alive
[MCU2_0] 5.117666 s: EnetPhy_bindDriver: PHY 12: OUI:080028 Model:23 Ver:01 <-> 'dp83867' : OK
[MCU2_0] 5.118171 s: EnetPhy_bindDriver: PHY 0: OUI:080028 Model:23 Ver:01 <-> 'dp83867' : OK
[MCU2_0] 5.118643 s: EnetPhy_bindDriver: PHY 3: OUI:080028 Model:23 Ver:01 <-> 'dp83867' : OK
[MCU2_0] 5.119124 s: EnetPhy_bindDriver: PHY 15: OUI:080028 Model:23 Ver:01 <-> 'dp83867' : OK
[MCU2_0] 5.120836 s:
[MCU2_0] 5.120902 s: ETHFW Build Date: May 16, 2023
[MCU2_0] 5.120934 s: ETHFW Build Time: 08:46:20
[MCU2_0] 5.120961 s: ETHFW Commit SHA:
[MCU2_0] 5.121027 s: ETHFW: Init ... DONE !!!
[MCU2_0] 5.121057 s: ETHFW: Remove server Init ... !!!
[MCU2_0] 5.121229 s: CpswProxyServer: Virtual port configuration:
[MCU2_0] 5.121287 s: mpu_1_0 <-> Switch port 0: mpu_1_0_ethswitch-device-0
[MCU2_0] 5.121333 s: mcu_2_1 <-> Switch port 1: mcu_2_1_ethswitch-device-1
[MCU2_0] 5.121374 s: mpu_1_0 <-> MAC port 1: mpu_1_0_ethmac-device-1
[MCU2_0] 5.121414 s: mcu_2_1 <-> MAC port 4: mcu_2_1_ethmac-device-4
[MCU2_0] 5.122431 s: CpswProxyServer: initialization completed (core: mcu2_0)
[MCU2_0] 5.122498 s: ETHFW: Remove server Init ... DONE !!!
[MCU2_0] 5.123626 s: Starting lwIP, local interface IP is 192.168.1.200
[MCU2_0] 5.131351 s: Host MAC address: 70:ff:76:1d:92:c3
[MCU2_0] 5.135442 s: [LWIPIF_LWIP] Enet LLD netif initialized successfully
[MCU2_0] 5.135534 s: Added interface 'ti1', IP is 192.168.1.200
[MCU2_0] 5.149514 s: EthFw: TimeSync PTP enabled
[MCU2_0] 5.153990 s: Rx Flow for Software Inter-VLAN Routing is up
[MCU2_0] 5.171738 s: FVID2: Init ... !!!
[MCU2_0] 5.171857 s: FVID2: Init ... Done !!!
[MCU2_0] 5.171910 s: DSS: Init ... !!!
[MCU2_0] 5.171938 s: DSS: Display type is eDP !!!
[MCU2_0] 5.171964 s: DSS: M2M Path is enabled !!!
[MCU2_0] 5.171990 s: DSS: SoC init ... !!!
[MCU2_0] 5.172014 s: SCICLIENT: Sciclient_pmSetModuleState module=152 state=2
[MCU2_0] 5.172242 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0] 5.172281 s: SCICLIENT: Sciclient_pmSetModuleState module=297 state=2
[MCU2_0] 5.172478 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0] 5.172513 s: SCICLIENT: Sciclient_pmSetModuleState module=151 state=2
[MCU2_0] 5.172657 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0] 5.172690 s: SCICLIENT: Sciclient_pmSetModuleClkParent module=152 clk=9 parent=11
[MCU2_0] 5.172933 s: SCICLIENT: Sciclient_pmSetModuleClkParent success
[MCU2_0] 5.172974 s: SCICLIENT: Sciclient_pmSetModuleClkParent module=152 clk=13 parent=18
[MCU2_0] 5.173097 s: SCICLIENT: Sciclient_pmSetModuleClkParent success
[MCU2_0] 5.173133 s: SCICLIENT: Sciclient_pmSetModuleClkParent module=152 clk=1 parent=2
[MCU2_0] 5.173234 s: SCICLIENT: Sciclient_pmSetModuleClkParent success
[MCU2_0] 5.173270 s: SCICLIENT: Sciclient_pmSetModuleClkFreq module=152 clk=1 freq=148500000
[MCU2_0] 5.174481 s: SCICLIENT: Sciclient_pmSetModuleClkFreq success
[MCU2_0] 5.174528 s: SCICLIENT: Sciclient_pmModuleClkRequest module=152 clk=1 state=2 flag=0
[MCU2_0] 5.174693 s: SCICLIENT: Sciclient_pmModuleClkRequest success
[MCU2_0] 5.174814 s: DSS: SoC init ... Done !!!
[MCU2_0] 5.174844 s: DSS: Board init ... !!!
[MCU2_0] 5.174868 s: DSS: Board init ... Done !!!
[MCU2_0] 5.192924 s: DSS: Init ... Done !!!
[MCU2_0] 5.192990 s: VHWA: VPAC Init ... !!!
[MCU2_0] 5.193018 s: SCICLIENT: Sciclient_pmSetModuleState module=290 state=2
[MCU2_0] 5.193232 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0] 5.193272 s: VHWA: LDC Init ... !!!
[MCU2_0] 5.196889 s: VHWA: LDC Init ... Done !!!
[MCU2_0] 5.196953 s: VHWA: MSC Init ... !!!
[MCU2_0] 5.208875 s: VHWA: MSC Init ... Done !!!
[MCU2_0] 5.208937 s: VHWA: NF Init ... !!!
[MCU2_0] 5.210840 s: VHWA: NF Init ... Done !!!
[MCU2_0] 5.210903 s: VHWA: VISS Init ... !!!
[MCU2_0] 5.221954 s: VHWA: VISS Init ... Done !!!
[MCU2_0] 5.222016 s: VHWA: VPAC Init ... Done !!!
[MCU2_0] 5.222060 s: VX_ZONE_INIT:Enabled
[MCU2_0] 5.222087 s: VX_ZONE_ERROR:Enabled
[MCU2_0] 5.222112 s: VX_ZONE_WARNING:Enabled
[MCU2_0] 5.223624 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target MCU2-0
[MCU2_0] 5.224016 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_NF
[MCU2_0] 5.224276 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_LDC1
[MCU2_0] 5.224510 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_MSC1
[MCU2_0] 5.224910 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_MSC2
[MCU2_0] 5.225212 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_VISS1
[MCU2_0] 5.225491 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE1
[MCU2_0] 5.225858 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE2
[MCU2_0] 5.226181 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DISPLAY1
[MCU2_0] 5.226480 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DISPLAY2
[MCU2_0] 5.226862 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CSITX
[MCU2_0] 5.227161 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE3
[MCU2_0] 5.227430 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE4
[MCU2_0] 5.227692 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE5
[MCU2_0] 5.228094 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE6
[MCU2_0] 5.228376 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE7
[MCU2_0] 5.228646 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE8
[MCU2_0] 5.229012 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DSS_M2M1
[MCU2_0] 5.229264 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DSS_M2M2
[MCU2_0] 5.229505 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DSS_M2M3
[MCU2_0] 5.229919 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DSS_M2M4
[MCU2_0] 5.229978 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
[MCU2_0] 5.230012 s: APP: OpenVX Target kernel init ... !!!
[MCU2_0] 5.251133 s: APP: OpenVX Target kernel init ... Done !!!
[MCU2_0] 5.251196 s: CSI2RX: Init ... !!!
[MCU2_0] 5.251222 s: SCICLIENT: Sciclient_pmSetModuleState module=25 state=2
[MCU2_0] 5.251364 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0] 5.251402 s: SCICLIENT: Sciclient_pmSetModuleState module=26 state=2
[MCU2_0] 5.251561 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0] 5.251596 s: SCICLIENT: Sciclient_pmSetModuleState module=27 state=2
[MCU2_0] 5.251815 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0] 5.251861 s: SCICLIENT: Sciclient_pmSetModuleState module=147 state=2
[MCU2_0] 5.251990 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0] 5.252027 s: SCICLIENT: Sciclient_pmSetModuleState module=148 state=2
[MCU2_0] 5.252127 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0] 5.252363 s: CSI2RX: Init ... Done !!!
[MCU2_0] 5.252403 s: CSI2TX: Init ... !!!
[MCU2_0] 5.252427 s: SCICLIENT: Sciclient_pmSetModuleState module=25 state=2
[MCU2_0] 5.252522 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0] 5.252555 s: SCICLIENT: Sciclient_pmSetModuleState module=28 state=2
[MCU2_0] 5.252691 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0] 5.252867 s: SCICLIENT: Sciclient_pmSetModuleState module=296 state=2
[MCU2_0] 5.253020 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0] 5.253119 s: CSI2TX: Init ... Done !!!
[MCU2_0] 5.253155 s: ISS: Init ... !!!
[MCU2_0] 5.253191 s: IssSensor_Init ... Done !!!
[MCU2_0] 5.253272 s: IttRemoteServer_Init ... Done !!!
[MCU2_0] 5.253308 s: VISS REMOTE SERVICE: Init ... !!!
[MCU2_0] 5.253377 s: VISS REMOTE SERVICE: Init ... Done !!!
[MCU2_0] 5.253410 s: UDMA Copy: Init ... !!!
[MCU2_0] 5.255345 s: UDMA Copy: Init ... Done !!!
[MCU2_0] 5.255453 s: APP: Init ... Done !!!
[MCU2_0] 5.255488 s: APP: Run ... !!!
[MCU2_0] 5.255512 s: IPC: Starting echo test ...
[MCU2_0] 5.258395 s: APP: Run ... Done !!!
[MCU2_0] 5.258448 s: UDP client: Starting UDP client
[MCU2_0] 5.260431 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[.] C66X_1[P] C66X_2[.] C7X_1[.]
[MCU2_0] 5.260552 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] C66X_1[P] C66X_2[.] C7X_1[.]
[MCU2_0] 5.260649 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[.]
[MCU2_0] 5.260876 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[P]
[MCU2_0] 7.025306 s: Function:CpswProxyServer_attachHandlerCb,HostId:0,CpswType:6
[MCU2_0] 7.025861 s: Function:CpswProxyServer_allocMacHandlerCb,HostId:0,Handle:a3ac6d44,CoreKey:38acb7e6
[MCU2_0] 7.977023 s: Function:CpswProxyServer_allocTxHandlerCb,HostId:0,Handle:a3ac6d44,CoreKey:38acb7e6
[MCU2_0] 7.979117 s: Function:CpswProxyServer_allocRxHandlerCb,HostId:0,Handle:a3ac6d44,CoreKey:38acb7e6
[MCU2_0] 7.979535 s: Function:CpswProxyServer_ioctlHandlerCb,HostId:0,Handle:a3ac6d44,CoreKey:38acb7e6, Cmd:1010401,InArgsLen:0, OutArgsLen:4
[MCU2_0] 7.995372 s: Function:CpswProxyServer_ioctlHandlerCb,HostId:0,Handle:a3ac6d44,CoreKey:38acb7e6, Cmd:1010201,InArgsLen:24, OutArgsLen:4
[MCU2_0] 7.997390 s: Function:CpswProxyServer_registerMacHandlerCb,HostId:0,Handle:a3ac6d44,CoreKey:38acb7e6, MacAddress:70:ff:76:1d:92:c1, FlowIdx:172, FlowIdxOffset:0
[MCU2_0] 7.997661 s: Cpsw_ioctlInternal: CPSW: Registered MAC address. ALE entry:12, Policer Entry:3
[MCU2_0] 8.619167 s: Cpsw_handleLinkUp: Port 8: Link up: 1-Gbps Full-Duplex
[MCU2_0] 8.720578 s: Function:CpswProxyServer_ioctlHandlerCb,HostId:0,Handle:a3ac6d44,CoreKey:38acb7e6, Cmd:1010222,InArgsLen:144, OutArgsLen:36
[MCU2_0] 8.724143 s: Function:CpswProxyServer_ioctlHandlerCb,HostId:0,Handle:a3ac6d44,CoreKey:38acb7e6, Cmd:1010202,InArgsLen:24, OutArgsLen:4
[MCU2_0] 8.724630 s: Function:CpswProxyServer_ioctlHandlerCb,HostId:0,Handle:a3ac6d44,CoreKey:38acb7e6, Cmd:1010224,InArgsLen:132, OutArgsLen:0
[MCU2_0] 8.725338 s: Function:CpswProxyServer_ioctlHandlerCb,HostId:0,Handle:a3ac6d44,CoreKey:38acb7e6, Cmd:1010222,InArgsLen:144, OutArgsLen:36
[MCU2_0] 8.728968 s: Function:CpswProxyServer_ioctlHandlerCb,HostId:0,Handle:a3ac6d44,CoreKey:38acb7e6, Cmd:1010202,InArgsLen:24, OutArgsLen:4
[MCU2_0] 8.729457 s: Function:CpswProxyServer_ioctlHandlerCb,HostId:0,Handle:a3ac6d44,CoreKey:38acb7e6, Cmd:1010222,InArgsLen:144, OutArgsLen:36
[MCU2_0] 8.732964 s: Function:CpswProxyServer_ioctlHandlerCb,HostId:0,Handle:a3ac6d44,CoreKey:38acb7e6, Cmd:1010202,InArgsLen:24, OutArgsLen:4
[MCU2_0] 8.733573 s: Function:CpswProxyServer_registerIpv4MacHandlerCb,HostId:0,Handle:a3ac6d44,CoreKey:38acb7e6, MacAddress:70:ff:76:1d:92:c1 IPv4Addr:192.168.1.70
[MCU2_0] 8.733788 s:
[MCU2_0] 8.733835 s: ------ ------------- -----------------
[MCU2_0] 8.733874 s: 1 192.168.1.70 70:ff:76:1d:92:c1
[MCU2_0] 8.734298 s: Function:CpswProxyServer_ioctlHandlerCb,HostId:0,Handle:a3ac6d44,CoreKey:38acb7e6, Cmd:1010224,InArgsLen:132, OutArgsLen:0
[MCU2_0] 8.734873 s: Function:CpswProxyServer_ioctlHandlerCb,HostId:0,Handle:a3ac6d44,CoreKey:38acb7e6, Cmd:1010224,InArgsLen:132, OutArgsLen:0
[MCU2_0] 8.735535 s: Function:CpswProxyServer_ioctlHandlerCb,HostId:0,Handle:a3ac6d44,CoreKey:38acb7e6, Cmd:1010222,InArgsLen:144, OutArgsLen:36
[MCU2_0] 8.739087 s: Function:CpswProxyServer_ioctlHandlerCb,HostId:0,Handle:a3ac6d44,CoreKey:38acb7e6, Cmd:1010202,InArgsLen:24, OutArgsLen:4
[MCU2_0] 8.739564 s: Function:CpswProxyServer_ioctlHandlerCb,HostId:0,Handle:a3ac6d44,CoreKey:38acb7e6, Cmd:1010222,InArgsLen:144, OutArgsLen:36
[MCU2_0] 8.743120 s: Function:CpswProxyServer_ioctlHandlerCb,HostId:0,Handle:a3ac6d44,CoreKey:38acb7e6, Cmd:1010202,InArgsLen:24, OutArgsLen:4
[MCU2_0] 8.743602 s: Function:CpswProxyServer_ioctlHandlerCb,HostId:0,Handle:a3ac6d44,CoreKey:38acb7e6, Cmd:1010222,InArgsLen:144, OutArgsLen:36
[MCU2_0] 8.747101 s: Function:CpswProxyServer_ioctlHandlerCb,HostId:0,Handle:a3ac6d44,CoreKey:38acb7e6, Cmd:1010202,InArgsLen:24, OutArgsLen:4
[MCU2_0] 10.042699 s: CpswCpts_ioctl: Eth RX event not found (msgType=2, seqId=256, dom=0, portNum=7)
[MCU2_0] 11.042871 s: CpswCpts_ioctl: Eth RX event not found (msgType=2, seqId=256, dom=0, portNum=7)
[MCU2_0] 12.043450 s: CpswCpts_ioctl: Eth RX event not found (msgType=2, seqId=256, dom=0, portNum=7)
[MCU2_1] 4.232914 s: CIO: Init ... Done !!!
[MCU2_1] 4.232988 s: ### CPU Frequency = 1000000000 Hz
[MCU2_1] 4.233031 s: CPU is running FreeRTOS
[MCU2_1] 4.233057 s: APP: Init ... !!!
[MCU2_1] 4.233080 s: SCICLIENT: Init ... !!!
[MCU2_1] 4.233332 s: SCICLIENT: DMSC FW version [8.6.3--v08.06.03 (Chill Capybar]
[MCU2_1] 4.233388 s: SCICLIENT: DMSC FW revision 0x8
[MCU2_1] 4.233438 s: SCICLIENT: DMSC FW ABI revision 3.1
[MCU2_1] 4.233475 s: SCICLIENT: Init ... Done !!!
[MCU2_1] 4.233502 s: UDMA: Init ... !!!
[MCU2_1] 4.234894 s: UDMA: Init ... Done !!!
[MCU2_1] 4.234957 s: MEM: Init ... !!!
[MCU2_1] 4.234999 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ da000000 of size 16777216 bytes !!!
[MCU2_1] 4.235074 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000001) @ 3640000 of size 262144 bytes !!!
[MCU2_1] 4.235138 s: MEM: Init ... Done !!!
[MCU2_1] 4.235164 s: IPC: Init ... !!!
[MCU2_1] 4.235227 s: IPC: 6 CPUs participating in IPC !!!
[MCU2_1] 4.250238 s: IPC: Init ... Done !!!
[MCU2_1] 4.250299 s: APP: Syncing with 5 CPUs ... !!!
[MCU2_1] 5.095169 s: APP: Syncing with 5 CPUs ... Done !!!
[MCU2_1] 5.095368 s: REMOTE_SERVICE: Init ... !!!
[MCU2_1] 5.096908 s: REMOTE_SERVICE: Init ... Done !!!
[MCU2_1] 5.096973 s: FVID2: Init ... !!!
[MCU2_1] 5.097047 s: FVID2: Init ... Done !!!
[MCU2_1] 5.097083 s: VHWA: DMPAC: Init ... !!!
[MCU2_1] 5.097110 s: SCICLIENT: Sciclient_pmSetModuleState module=48 state=2
[MCU2_1] 5.097655 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_1] 5.097703 s: SCICLIENT: Sciclient_pmSetModuleState module=305 state=2
[MCU2_1] 5.098152 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_1] 5.098187 s: VHWA: DOF Init ... !!!
[MCU2_1] 5.106714 s: VHWA: DOF Init ... Done !!!
[MCU2_1] 5.106781 s: VHWA: SDE Init ... !!!
[MCU2_1] 5.109427 s: VHWA: SDE Init ... Done !!!
[MCU2_1] 5.109484 s: VHWA: DMPAC: Init ... Done !!!
[MCU2_1] 5.109529 s: VX_ZONE_INIT:Enabled
[MCU2_1] 5.109562 s: VX_ZONE_ERROR:Enabled
[MCU2_1] 5.109590 s: VX_ZONE_WARNING:Enabled
[MCU2_1] 5.110989 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target MCU2-1
[MCU2_1] 5.111231 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DMPAC_SDE
[MCU2_1] 5.111468 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DMPAC_DOF
[MCU2_1] 5.111527 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
[MCU2_1] 5.111563 s: APP: OpenVX Target kernel init ... !!!
[MCU2_1] 5.111835 s: APP: OpenVX Target kernel init ... Done !!!
[MCU2_1] 5.111876 s: UDMA Copy: Init ... !!!
[MCU2_1] 5.113909 s: UDMA Copy: Init ... Done !!!
[MCU2_1] 5.113980 s: APP: Init ... Done !!!
[MCU2_1] 5.114013 s: APP: Run ... !!!
[MCU2_1] 5.114038 s: IPC: Starting echo test ...
[MCU2_1] 5.116610 s: APP: Run ... Done !!!
[MCU2_1] 5.117735 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C66X_1[P] C66X_2[.] C7X_1[.]
[MCU2_1] 5.117850 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C66X_1[P] C66X_2[P] C7X_1[.]
[MCU2_1] 5.117944 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C66X_1[P] C66X_2[P] C7X_1[P]
[MCU2_1] 5.260421 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[s] C66X_1[P] C66X_2[P] C7X_1[P]
[C6x_1 ] 4.321057 s: CIO: Init ... Done !!!
[C6x_1 ] 4.321082 s: ### CPU Frequency = 1350000000 Hz
[C6x_1 ] 4.321092 s: CPU is running FreeRTOS
[C6x_1 ] 4.321100 s: APP: Init ... !!!
[C6x_1 ] 4.321107 s: SCICLIENT: Init ... !!!
[C6x_1 ] 4.321302 s: SCICLIENT: DMSC FW version [8.6.3--v08.06.03 (Chill Capybar]
[C6x_1 ] 4.321313 s: SCICLIENT: DMSC FW revision 0x8
[C6x_1 ] 4.321323 s: SCICLIENT: DMSC FW ABI revision 3.1
[C6x_1 ] 4.321333 s: SCICLIENT: Init ... Done !!!
[C6x_1 ] 4.321342 s: UDMA: Init ... !!!
[C6x_1 ] 4.322867 s: UDMA: Init ... Done !!!
[C6x_1 ] 4.322884 s: MEM: Init ... !!!
[C6x_1 ] 4.322897 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ dc000000 of size 16777216 bytes !!!
[C6x_1 ] 4.322914 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 800000 of size 229376 bytes !!!
[C6x_1 ] 4.322929 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ dd000000 of size 50331648 bytes !!!
[C6x_1 ] 4.322945 s: MEM: Init ... Done !!!
[C6x_1 ] 4.322952 s: IPC: Init ... !!!
[C6x_1 ] 4.322972 s: IPC: 6 CPUs participating in IPC !!!
[C6x_1 ] 4.326460 s: IPC: Init ... Done !!!
[C6x_1 ] 4.326485 s: APP: Syncing with 5 CPUs ... !!!
[C6x_1 ] 5.095168 s: APP: Syncing with 5 CPUs ... Done !!!
[C6x_1 ] 5.095178 s: REMOTE_SERVICE: Init ... !!!
[C6x_1 ] 5.095904 s: REMOTE_SERVICE: Init ... Done !!!
[C6x_1 ] 5.095939 s: VX_ZONE_INIT:Enabled
[C6x_1 ] 5.095949 s: VX_ZONE_ERROR:Enabled
[C6x_1 ] 5.095959 s: VX_ZONE_WARNING:Enabled
[C6x_1 ] 5.096703 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
[C6x_1 ] 5.096719 s: APP: OpenVX Target kernel init ... !!!
[C6x_1 ] 5.096983 s: APP: OpenVX Target kernel init ... Done !!!
[C6x_1 ] 5.096999 s: UDMA Copy: Init ... !!!
[C6x_1 ] 5.100742 s: UDMA Copy: Init ... Done !!!
[C6x_1 ] 5.100763 s: APP: Init ... Done !!!
[C6x_1 ] 5.100771 s: APP: Run ... !!!
[C6x_1 ] 5.100779 s: IPC: Starting echo test ...
[C6x_1 ] 5.101813 s: APP: Run ... Done !!!
[C6x_1 ] 5.102113 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[s] C66X_2[x] C7X_1[P]
[C6x_1 ] 5.102624 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[s] C66X_2[P] C7X_1[P]
[C6x_1 ] 5.117145 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C66X_1[s] C66X_2[P] C7X_1[P]
[C6x_1 ] 5.260268 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] C66X_1[s] C66X_2[P] C7X_1[P]
[C6x_2 ] 4.411497 s: CIO: Init ... Done !!!
[C6x_2 ] 4.411521 s: ### CPU Frequency = 1350000000 Hz
[C6x_2 ] 4.411531 s: CPU is running FreeRTOS
[C6x_2 ] 4.411539 s: APP: Init ... !!!
[C6x_2 ] 4.411547 s: SCICLIENT: Init ... !!!
[C6x_2 ] 4.411748 s: SCICLIENT: DMSC FW version [8.6.3--v08.06.03 (Chill Capybar]
[C6x_2 ] 4.411760 s: SCICLIENT: DMSC FW revision 0x8
[C6x_2 ] 4.411769 s: SCICLIENT: DMSC FW ABI revision 3.1
[C6x_2 ] 4.411779 s: SCICLIENT: Init ... Done !!!
[C6x_2 ] 4.411788 s: UDMA: Init ... !!!
[C6x_2 ] 4.413330 s: UDMA: Init ... Done !!!
[C6x_2 ] 4.413348 s: MEM: Init ... !!!
[C6x_2 ] 4.413361 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ e0000000 of size 16777216 bytes !!!
[C6x_2 ] 4.413378 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 800000 of size 229376 bytes !!!
[C6x_2 ] 4.413393 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ e1000000 of size 50331648 bytes !!!
[C6x_2 ] 4.413409 s: MEM: Init ... Done !!!
[C6x_2 ] 4.413417 s: IPC: Init ... !!!
[C6x_2 ] 4.413437 s: IPC: 6 CPUs participating in IPC !!!
[C6x_2 ] 4.416980 s: IPC: Init ... Done !!!
[C6x_2 ] 4.417006 s: APP: Syncing with 5 CPUs ... !!!
[C6x_2 ] 5.095168 s: APP: Syncing with 5 CPUs ... Done !!!
[C6x_2 ] 5.095178 s: REMOTE_SERVICE: Init ... !!!
[C6x_2 ] 5.095906 s: REMOTE_SERVICE: Init ... Done !!!
[C6x_2 ] 5.095941 s: VX_ZONE_INIT:Enabled
[C6x_2 ] 5.095951 s: VX_ZONE_ERROR:Enabled
[C6x_2 ] 5.095960 s: VX_ZONE_WARNING:Enabled
[C6x_2 ] 5.096714 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
[C6x_2 ] 5.096730 s: APP: OpenVX Target kernel init ... !!!
[C6x_2 ] 5.096987 s: APP: OpenVX Target kernel init ... Done !!!
[C6x_2 ] 5.097002 s: UDMA Copy: Init ... !!!
[C6x_2 ] 5.101108 s: UDMA Copy: Init ... Done !!!
[C6x_2 ] 5.101131 s: APP: Init ... Done !!!
[C6x_2 ] 5.101139 s: APP: Run ... !!!
[C6x_2 ] 5.101148 s: IPC: Starting echo test ...
[C6x_2 ] 5.102277 s: APP: Run ... Done !!!
[C6x_2 ] 5.102571 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[s] C7X_1[.]
[C6x_2 ] 5.102633 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[s] C7X_1[P]
[C6x_2 ] 5.117171 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C66X_1[P] C66X_2[s] C7X_1[P]
[C6x_2 ] 5.260314 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] C66X_1[P] C66X_2[s] C7X_1[P]
[C7x_1 ] 5.091681 s: CIO: Init ... Done !!!
[C7x_1 ] 5.091695 s: ### CPU Frequency = 1000000000 Hz
[C7x_1 ] 5.091707 s: CPU is running FreeRTOS
[C7x_1 ] 5.091716 s: APP: Init ... !!!
[C7x_1 ] 5.091723 s: SCICLIENT: Init ... !!!
[C7x_1 ] 5.091922 s: SCICLIENT: DMSC FW version [8.6.3--v08.06.03 (Chill Capybar]
[C7x_1 ] 5.091936 s: SCICLIENT: DMSC FW revision 0x8
[C7x_1 ] 5.091946 s: SCICLIENT: DMSC FW ABI revision 3.1
[C7x_1 ] 5.091957 s: SCICLIENT: Init ... Done !!!
[C7x_1 ] 5.091966 s: UDMA: Init ... !!!
[C7x_1 ] 5.093143 s: UDMA: Init ... Done !!!
[C7x_1 ] 5.093156 s: MEM: Init ... !!!
[C7x_1 ] 5.093166 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ 117000000 of size 268435456 bytes !!!
[C7x_1 ] 5.093187 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000001) @ 70020000 of size 8159232 bytes !!!
[C7x_1 ] 5.093205 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 64800000 of size 458752 bytes !!!
[C7x_1 ] 5.093223 s: MEM: Created heap (L1_MEM, id=3, flags=0x00000001) @ 64e00000 of size 16384 bytes !!!
[C7x_1 ] 5.093240 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ 100000000 of size 385875968 bytes !!!
[C7x_1 ] 5.093258 s: MEM: Init ... Done !!!
[C7x_1 ] 5.093266 s: IPC: Init ... !!!
[C7x_1 ] 5.093279 s: IPC: 6 CPUs participating in IPC !!!
[C7x_1 ] 5.095140 s: IPC: Init ... Done !!!
[C7x_1 ] 5.095155 s: APP: Syncing with 5 CPUs ... !!!
[C7x_1 ] 5.095168 s: APP: Syncing with 5 CPUs ... Done !!!
[C7x_1 ] 5.095179 s: REMOTE_SERVICE: Init ... !!!
[C7x_1 ] 5.095316 s: REMOTE_SERVICE: Init ... Done !!!
[C7x_1 ] 5.095339 s: VX_ZONE_INIT:Enabled
[C7x_1 ] 5.095349 s: VX_ZONE_ERROR:Enabled
[C7x_1 ] 5.095359 s: VX_ZONE_WARNING:Enabled
[C7x_1 ] 5.095508 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1
[C7x_1 ] 5.095576 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_2
[C7x_1 ] 5.095669 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_3
[C7x_1 ] 5.095767 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_4
[C7x_1 ] 5.095831 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_5
[C7x_1 ] 5.095891 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_6
[C7x_1 ] 5.095953 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_7
[C7x_1 ] 5.096037 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_8
[C7x_1 ] 5.096089 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
[C7x_1 ] 5.096103 s: APP: OpenVX Target kernel init ... !!!
[C7x_1 ] 5.096243 s: APP: OpenVX Target kernel init ... Done !!!
[C7x_1 ] 5.096257 s: APP: Init ... Done !!!
[C7x_1 ] 5.096265 s: APP: Run ... !!!
[C7x_1 ] 5.096273 s: IPC: Starting echo test ...
[C7x_1 ] 5.096403 s: APP: Run ... Done !!!
[C7x_1 ] 5.102120 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[x] C7X_1[s]
[C7x_1 ] 5.102640 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[P] C7X_1[s]
[C7x_1 ] 5.117196 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[s]
[C7x_1 ] 5.260347 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[s]
[MCU2_0] 20.258061 s: Assertion "sem != NULL" failed at line 287 in freertos/sys_arch.c
Slog2info
Jan 01 00:00:00.001 devb_sdmmc_am65x.4104 slog* 1800 devb-sdmmc-am65x 1.00A (May 16 2023 08:55:14)
Jan 01 00:00:00.001 devb_sdmmc_am65x.4104 slog 0 libcam.so (Aug 22 2022 09:45:51) bver 7010004
Jan 01 00:00:00.015 io_usb_otg.16394 slog 0 xhci_init: Initialiaing with sever version: 2
Jan 01 00:00:00.015 io_usb_otg.16394 slog 0 xhci_controller_init(2661): devu-hcd-cdns3-xhci.so (Jan 20 2022 16:08:39): args
Jan 01 00:00:00.015 io_usb_otg.16394 slog 0 cdns3_usb_port_info(308)[tid:1]: cdns3: chipset j721e xhci_irq=128 serdes_addr=0x5030000
Jan 01 00:00:00.019 io_usb_otg.16394 slog 11 hub_state_inserted(569)[tid:1]: bdentry 0, dentry 0 0
Jan 01 00:00:00.021 io_usb_otg.16394 slog 13 hub_configuration_enable(263)[tid:1]: 1
Jan 01 00:00:00.091 devb_sdmmc_am65x.4104 slog 1800 MMC CID:
Jan 01 00:00:00.091 devb_sdmmc_am65x.4104 slog 1800 MID 0x13, OID 0x4e, PNM S0J56X
Jan 01 00:00:00.091 devb_sdmmc_am65x.4104 slog 1800 PRV 0x10, PSN 0x10e5bbab, MDT 6-2019
Jan 01 00:00:00.091 devb_sdmmc_am65x.4104 slog 1800 MMC CSD:
Jan 01 00:00:00.091 devb_sdmmc_am65x.4104 slog 1800 CSD_STRUCTURE 3, SPEC_VERS 4, CCC 0x8f5
Jan 01 00:00:00.091 devb_sdmmc_am65x.4104 slog 1800 TAAC 127, NSAC 1, TRAN_SPEED 50
Jan 01 00:00:00.091 devb_sdmmc_am65x.4104 slog 1800 C_SIZE 4095, C_SIZE_MULT 7
Jan 01 00:00:00.091 devb_sdmmc_am65x.4104 slog 1800 READ_BL_LEN 9, WRITE_BL_LEN 9
Jan 01 00:00:00.091 devb_sdmmc_am65x.4104 slog 1800 ERASE GRP_SIZE 31, GRP_MULT 31, SIZE 0
Jan 01 00:00:00.091 devb_sdmmc_am65x.4104 slog 1800 blksz 512, sectors 2097152, dtr 25000000
Jan 01 00:00:00.091 devb_sdmmc_am65x.4104 slog 1800 MMC EXT CSD:
Jan 01 00:00:00.091 devb_sdmmc_am65x.4104 slog 1800 DEVICE_TYPE 0x57, EXT_CSD_REV 8
Jan 01 00:00:00.091 devb_sdmmc_am65x.4104 slog 1800 SEC_COUNT 31080448, dtr 200000000
Jan 01 00:00:00.091 devb_sdmmc_am65x.4104 slog 1800 HC_ERASE_GRP_SIZE 1, HC_WP_GRP_SIZE 16
Jan 01 00:00:00.091 devb_sdmmc_am65x.4104 slog 1800 STROBE 0x0, BKOPS_EN 0x0
Jan 01 00:00:00.091 devb_sdmmc_am65x.4104 slog 1800 Driver type: 0x0
Jan 01 00:00:00.091 devb_sdmmc_am65x.4104 slog 1800 CFG: Timing HS200, DTR 200000000, Bus Width 8 bit
Jan 01 00:00:00.091 devb_sdmmc_am65x.4104 slog 100 cam-disk.so (Aug 22 2022 09:45:53)
Jan 01 00:00:00.167 devb_sdmmc_am65x.4105 slog 1800 SD CID:
Jan 01 00:00:00.167 devb_sdmmc_am65x.4105 slog 1800 MID 0x27, OID 0x5048, PNM SD16G
Jan 01 00:00:00.167 devb_sdmmc_am65x.4105 slog 1800 PRV 0xe2, PSN 0x1e20863, MDT 7-2017
Jan 01 00:00:00.167 devb_sdmmc_am65x.4105 slog 1800 SD CSD:
Jan 01 00:00:00.167 devb_sdmmc_am65x.4105 slog 1800 CSD_STRUCTURE 1, SPEC_VERS 0, CCC 0x5b5
Jan 01 00:00:00.167 devb_sdmmc_am65x.4105 slog 1800 TAAC 14, NSAC 0, TRAN_SPEED 50
Jan 01 00:00:00.167 devb_sdmmc_am65x.4105 slog 1800 C_SIZE 29735, C_SIZE_MULT 0
Jan 01 00:00:00.167 devb_sdmmc_am65x.4105 slog 1800 READ_BL_LEN 9, WRITE_BL_LEN 9
Jan 01 00:00:00.168 devb_sdmmc_am65x.4105 slog 1800 ERASE GRP_SIZE 0, GRP_MULT 0, SIZE 127
Jan 01 00:00:00.168 devb_sdmmc_am65x.4105 slog 1800 blksz 512, sectors 30449664, dtr 25000000
Jan 01 00:00:00.168 devb_sdmmc_am65x.4105 slog 1800 SD SW CAPS:
Jan 01 00:00:00.168 devb_sdmmc_am65x.4105 slog 1800 bus mode 0x1f, cmd sys 0x1
Jan 01 00:00:00.168 devb_sdmmc_am65x.4105 slog 1800 drv type 0xf, curr limit 0xf
Jan 01 00:00:00.168 devb_sdmmc_am65x.4105 slog 1800 dtr 50000000
Jan 01 00:00:00.168 devb_sdmmc_am65x.4105 slog 1800 CFG: Timing SDR104, DTR 200000000, Bus Width 4 bit
Jan 01 00:00:00.168 devb_sdmmc_am65x.4105 slog 100 cam-disk.so (Aug 22 2022 09:45:53)
Jan 01 00:00:00.563 io_usb_otg.16394 slog 0 xring_create: ep->mbuf = 0x559f87c0
Jan 01 00:00:00.591 io_usb_otg.16394 slog 0 xring_create: ep->mbuf = 0x559f8950
Jan 01 00:00:00.680 shmemallocator.69645 slog* 129 TI Shared memory Allocator for SOC J721E (version=PSDKQNX_08_06_00, date=Thu 18 May 14:52:18 CEST 2023)
Jan 01 00:00:00.680 shmemallocator.69645 slog 129 initSHM:Block[0] @ 0xb8000000 has free-mem = 0x20000000 - 512 M
Jan 01 00:00:00.715 tiipc_mgr.73742 slog 133 Mailbox_plugInterrupt: interrupt Number 489, arg 0xFD9C1180
Jan 01 00:00:00.728 tiipc_mgr.73742 slog 133 [IPC]
Jan 01 00:00:00.728 tiipc_mgr.73742 slog 133 Mailbox_plugInterrupt: interrupt Number 490, arg 0xFD9C1320
Jan 01 00:00:00.742 tiipc_mgr.73742 slog 133 [IPC]
Jan 01 00:00:00.742 tiipc_mgr.73742 slog 133 Mailbox_plugInterrupt: interrupt Number 491, arg 0xFD9C14C0
Jan 01 00:00:00.756 tiipc_mgr.73742 slog 133 [IPC]
Jan 01 00:00:00.756 tiipc_mgr.73742 slog 133 Mailbox_plugInterrupt: interrupt Number 492, arg 0xFD9C1660
Jan 01 00:00:00.770 tiipc_mgr.73742 slog 133 Mailbox_plugInterrupt: interrupt Number 493, arg 0xFD9C1800
Jan 01 00:00:00.787 tiudma_mgr.77839 slog* 131 TI UDMA ResMgr for SOC J721E (version=PSDKQNX_08_06_00, date=Thu 18 May 14:52:18 CEST 2023)
Jan 01 00:00:00.839 vxe_enc.81936 slog 2 MM_ENC_Init: adding heap of type 1
Jan 01 00:00:00.839 vxe_enc.81936 slog 2 MM_ENC_Init: using heap 1 for internal alloc
Jan 01 00:00:00.840 vxe_enc.81936 slog 2 Page table directory at physical address 0x08f76450
Jan 01 00:00:00.901 vxd_dec.86033 slog 2 Found 1 entropy pipe(s), 2 pixel pipe(s), 4 group size
Jan 01 00:00:00.901 vxd_dec.86033 slog 2 cur_bitdepth: 10 cur_h264_hw_chromaformat: 2
Jan 01 00:00:00.901 vxd_dec.86033 slog 2 cur_hevc_hw_chromaformat: 2 pipe_minus1: 0
Jan 01 00:00:00.901 vxd_dec.86033 slog 2 cur_bitdepth: 11 cur_h264_hw_chromaformat: 1
Jan 01 00:00:00.901 vxd_dec.86033 slog 2 cur_hevc_hw_chromaformat: 3 pipe_minus1: 1
Jan 01 00:00:00.901 vxd_dec.86033 slog 2 Decode slots/core: 2
Jan 01 00:00:00.901 vxd_dec.86033 slog 2 FW: acquired pvdec_full_bin.fw size 247976
Jan 01 00:00:00.901 vxd_dec.86033 slog 2 FW: info cs: 53704, bs: 247960, id: 0x3b8a0ee2, ts: 1669807230
Jan 01 00:00:00.937 screen.90130 slog* 300 screen: starting up...
Jan 01 00:00:00.940 screen.90130 slog 300 screen: Configuration file: /ti_fs/usr/lib/graphics/j721e/graphics.conf.dss_on_r5
Jan 01 00:00:00.954 screen.90130 slog 300 screen: slog2 context created with 1 pages
Jan 01 00:00:00.954 screen.90130 slog 300 screen: loading alloc module stdbuf...
Jan 01 00:00:00.956 screen.90130 slog 300 screen: display 1 returned invalid value 0 for WFD_PORT_MODE_ROTATION_SUPPORT
Jan 01 00:00:00.958 screen.90130 slog 300 screen: loading libhiddi.so...
Jan 01 00:00:00.958 screen.90130 slog 300 screen: server is ready
Jan 01 00:00:00.962 iopkt.94227 main_buffer* 0 tcpip starting
Jan 01 00:00:00.962 iopkt.94227 main_buffer 0 smmu support is disabled
Jan 01 00:00:00.963 iopkt.94227 main_buffer 0 initializing IPsec...
Jan 01 00:00:00.963 iopkt.94227 main_buffer 0 done
Jan 01 00:00:00.964 iopkt.94227 main_buffer 0 IPsec: Initialized Security Association Processing.
Jan 01 00:00:01.024 iopkt.94227 main_buffer 0 devnp-cpsw9g.so (null)
Jan 01 00:00:01.024 iopkt.94227 main_buffer 0 an0
Jan 01 00:00:01.024 io_pkt_v6_hc.94227 slog* 0 cpsw_entry:546 Entry -->
Jan 01 00:00:01.024 io_pkt_v6_hc.94227 slog 0 cpsw_attach:718 Entry -->
Jan 01 00:00:01.024 io_pkt_v6_hc.94227 slog 0 CPSW9G Client (core : mpu1_0) .....
Jan 01 00:00:01.026 io_pkt_v6_hc.94227 slog 0 appRemoteDeviceInitFn(5) has started!
Jan 01 00:00:01.028 io_pkt_v6_hc.94227 slog 0 Remote device (core : mpu1_0) .....
Jan 01 00:00:01.028 io_pkt_v6_hc.94227 slog 0 Remote Device Framework Endpoint located. Remote Core Id:3, Remote End Point:26
Jan 01 00:00:01.028 io_pkt_v6_hc.94227 slog 0 CpswProxy_notifyServiceTskFxn(6) has started!
Jan 01 00:00:01.028 io_pkt_v6_hc.94227 slog 0 appRemoteDeviceDiscoverTaskFn(7) has started!
Jan 01 00:00:01.028 io_pkt_v6_hc.94227 slog 0 appRemoteDeviceRxTaskFn(8) has started!
Jan 01 00:00:01.030 io_pkt_v6_hc.94227 slog 0 appRemoteDeviceInitFn(5) exited!
Jan 01 00:00:01.030 io_pkt_v6_hc.94227 slog 0 appRemoteDeviceTxTaskFn(9) has started!
Jan 01 00:00:01.030 io_pkt_v6_hc.94227 slog 0 CpswProxy_rdevCmdTskFxn(10) has started!
Jan 01 00:00:01.030 io_pkt_v6_hc.94227 slog 0 Connecting to 'mpu_1_0_ethswitch-device-0'
Jan 01 00:00:01.030 io_pkt_v6_hc.94227 slog 0 Registered a device name = mpu_1_0_ethswitch-device-0, id = 0, type = 3
Jan 01 00:00:01.030 io_pkt_v6_hc.94227 slog 0 ETHFW Version: 0. 2. 0
Jan 01 00:00:01.030 io_pkt_v6_hc.94227 slog 0 ETHFW Build Date (YYYY/MMM/DD):2023/May/16
Jan 01 00:00:01.030 io_pkt_v6_hc.94227 slog 0 ETHFW Commit SHA:
Jan 01 00:00:01.030 io_pkt_v6_hc.94227 slog 0 ETHFW PermissionFlag:0x3fffffff, UART Connected:true,UART Id:2
Jan 01 00:00:01.032 io_pkt_v6_hc.94227 slog 0 CPSW9G: Attach to CpswProxy Server.
Jan 01 00:00:01.032 io_pkt_v6_hc.94227 slog 0 appRemoteDeviceDiscoverTaskFn(7) exited!
Jan 01 00:00:01.032 io_pkt_v6_hc.94227 slog 0 Function:CpswProxy_cmdHandler,Handle:a3ac6d44,CoreKey:38acb7e6, RxMtu:1522, TxMtu:2024:2024:2024:2024:2024:2024:2024:2024, TxCsum:enabled, MacOnly:0
Jan 01 00:00:01.032 io_pkt_v6_hc.94227 slog 0 EnetIf_RemoteAttach:371 RX MTU returned - 1522
Jan 01 00:00:01.033 io_pkt_v6_hc.94227 slog 0 Function:CpswProxy_cmdHandler,mac_address:70:ff:76:1d:92:c1
Jan 01 00:00:01.033 io_pkt_v6_hc.94227 slog 0 MAC Address: 70:ff:76:1d:92:c1
Jan 01 00:00:01.969 io_pkt_v6_hc.94227 slog 0 ENET_CPSW_9G on MAIN NAVSS
Jan 01 00:00:01.972 io_pkt_v6_hc.94227 slog 56 [UDMA] Calling Udma_resmgr_open
Jan 01 00:00:01.972 io_pkt_v6_hc.94227 slog 56 [UDMA] Opening resmgr!!!
Jan 01 00:00:01.972 io_pkt_v6_hc.94227 slog 56 [UDMA] Opened resmgr fd=10!!!
Jan 01 00:00:01.972 io_pkt_v6_hc.94227 slog 56 [UDMA] eventHandle->vintrNum = 39!!!
Jan 01 00:00:01.972 io_pkt_v6_hc.94227 slog 56 [UDMA] eventHandle->irIntrNum = 11!!!
Jan 01 00:00:01.972 io_pkt_v6_hc.94227 slog 56 [UDMA] eventHandle->coreIntrNum = 75!!!
Jan 01 00:00:01.979 io_pkt_v6_hc.94227 slog 0 EnetIf_registerIntr2: tx isr 75 thread priority set to 21
Jan 01 00:00:01.979 io_pkt_v6_hc.94227 slog 0 EnetIf_CreateISRThread: InterruptAttachEvent succeed irq/75 coid/1073741850 event/10
Jan 01 00:00:01.979 io_pkt_v6_hc.94227 slog 0 cpsw_alloc:299: Alloc successfull; Virt: 0x3eb4ad3000, Phys: 0x8fcced000
Jan 01 00:00:01.979 io_pkt_v6_hc.94227 slog 0 EnetUdma_memMgrInit: addr=0x3eb4ad3000 is aligned
Jan 01 00:00:01.981 io_pkt_v6_hc.94227 slog 0 cpsw_alloc:299: Alloc successfull; Virt: 0x3eb4ae6000, Phys: 0x8fcd00000
Jan 01 00:00:01.981 io_pkt_v6_hc.94227 slog 0 EnetIfMem_init: addr=0x3eb4ae6000 is aligned
Jan 01 00:00:01.981 io_pkt_v6_hc.94227 slog 0 EnetIfMem_init: addr=0x3eb4ae6000, size=0x221000, gMem=0x3eb4ae6000, gMemBufPhys=0x8fcd00000
Jan 01 00:00:01.981 io_pkt_v6_hc.94227 slog 0 EnetIfMem_init: gDmaDescMemArray=0x3eb4ae6000, size=0x200000
Jan 01 00:00:01.981 io_pkt_v6_hc.94227 slog 0 EnetIfMem_init: gRingMemArray=0x3eb4ce6000, size=0x21000
Jan 01 00:00:01.981 io_pkt_v6_hc.94227 slog 0 EnetIfMem_init: gDmaDescMemArrayBasePhys=0x8fcd00000, gDmaDescMemArrayBase=0x3eb4ae6000
Jan 01 00:00:01.983 io_pkt_v6_hc.94227 slog 0 initQs() freePktInfoQ initialized with 256 pkts
Jan 01 00:00:01.984 io_pkt_v6_hc.94227 slog 0 Function:CpswProxy_cmdHandler,Txid:51712
Jan 01 00:00:01.986 io_pkt_v6_hc.94227 slog 0 Function:CpswProxy_cmdHandler,RxAllocId:172
Jan 01 00:00:01.988 io_pkt_v6_hc.94227 slog 56 [UDMA] eventHandle->globalEvent = 38!!!
Jan 01 00:00:01.988 io_pkt_v6_hc.94227 slog 56 [UDMA] eventHandle->vintrNum = 40!!!
Jan 01 00:00:01.988 io_pkt_v6_hc.94227 slog 56 [UDMA] eventHandle->vintrBitNum = 0!!!
Jan 01 00:00:01.988 io_pkt_v6_hc.94227 slog 56 [UDMA] eventHandle->irIntrNum = 12!!!
Jan 01 00:00:01.988 io_pkt_v6_hc.94227 slog 56 [UDMA] eventHandle->coreIntrNum = 76!!!
Jan 01 00:00:02.002 io_pkt_v6_hc.94227 slog 0 EnetIf_registerIntr2: rx isr 76 thread priority set to 21
Jan 01 00:00:02.002 io_pkt_v6_hc.94227 slog 0 EnetIf_registerIntr2: RX InterruptAttachEvent succeed irq/76 coid/1073741851 event/11
Jan 01 00:00:02.004 io_pkt_v6_hc.94227 slog 0 Host MAC address:
Jan 01 00:00:02.004 io_pkt_v6_hc.94227 slog 0 70:ff:76:1d:92:c1
Jan 01 00:00:02.727 io_pkt_v6_hc.94227 slog 0 cpsw_init:1068 Phy is linked
Jan 01 00:00:02.727 io_pkt_v6_hc.94227 slog 0 cpsw_filter: Clear IFF_ALLMULTI
Jan 01 00:00:02.727 io_pkt_v6_hc.94227 slog 0 cpsw_filter: Adding Multicast MAC Addr -> 33:33:ff:1d:92:c1
Jan 01 00:00:02.731 io_pkt_v6_hc.94227 slog 0 cpsw_filter: Clear IFF_ALLMULTI
Jan 01 00:00:02.732 io_pkt_v6_hc.94227 slog 0 cpsw_filter: Adding Multicast MAC Addr -> 33:33:00:00:00:01
Jan 01 00:00:02.736 io_pkt_v6_hc.94227 slog 0 cpsw_filter: Adding Multicast MAC Addr -> 33:33:ff:1d:92:c1
Jan 01 00:00:02.740 io_pkt_v6_hc.94227 slog 0 IPv4 address: 192:168:1:70
Jan 01 00:00:02.741 io_pkt_v6_hc.94227 slog 0 cpsw_filter: Clear IFF_ALLMULTI
Jan 01 00:00:02.742 io_pkt_v6_hc.94227 slog 0 cpsw_filter: Adding Multicast MAC Addr -> 01:00:5e:00:00:01
Jan 01 00:00:02.746 io_pkt_v6_hc.94227 slog 0 cpsw_filter: Adding Multicast MAC Addr -> 33:33:00:00:00:01
Jan 01 00:00:02.750 io_pkt_v6_hc.94227 slog 0 cpsw_filter: Adding Multicast MAC Addr -> 33:33:ff:1d:92:c1
J7EVM@QNX:/#
3. Is it possible to integrate the EthFw client on the MCU2_1 core in the vision apps so that the MCU2_1 core can send messages through the 9G switch? If so, what steps do I need to take in order to enable sending Ethernet messages from the MCU2_1 core, similar to what was described in the first question regarding MCU2_0?
4. Does it possible that MCU2_0 and MCU2_1 use 2G switch directly on EVM board?
5. Where can I add the code for the TCP/UDP application, similar to EthFw, as I added in main.c in Vision Apps(vision_apps/platform/j721e/rtos/mcu2_0/main.c)?
Marko.
