Part Number: TDA4VM
Hi.
Expert.
I'm doing video display aging test.
I got a error PVR DBG.
After error occurs, system is rebooted.
Could you check error log "RGX FW State: NOT RESPONDING" ? I want to know cause of occurrence.
Custom Board
OS: QNX
SDK: SDK7_1(fix)
[2023-06-06 00:41:18.157] call stack: [2023-06-06 18:51:48.568] ------------[ PVR DBG: START (High) ]------------ [2023-06-06 18:51:48.941] DDK info: Rogue_DDK_Neutrino rogueddk 1.10@5307123 (release) jacinto7_neutrino [2023-06-06 18:51:48.941] Time now: 0000018096a9120 [2023-06-06 18:51:48.941] Services State: OK [2023-06-06 18:51:48.941] Active connects: 487462 (./CtApCC_FreeRu [2023-06-06 18:51:48.941] ------[ Driver Info ]------ [2023-06-06 18:51:48.941] UM info: 1.10 @ 5307123 (release) build options: 0x80000050 [2023-06-06 18:51:48.941] KM info: 1.10 @ 5307123 (release) build options: 0x00000050 [2023-06-06 18:51:48.941] FW info: 1.10 @ 5307123 (release) build options: 0x80000050 [2023-06-06 18:51:48.941] Comparison of UM/KM components: MATCHING [2023-06-06 18:51:48.941] KM Arch: 64 Bit [2023-06-06 18:51:48.941] UM Connected Clients: 64 Bit [2023-06-06 18:51:48.941] ------[ RGX summary ]------ [2023-06-06 18:51:48.941] RGX BVNC: 22.104.208.318 [2023-06-06 18:51:48.941] RGX Device State: Active [2023-06-06 18:51:48.941] RGX Power State: ON [2023-06-06 18:51:48.941] BIF0 - OK [2023-06-06 18:51:48.941] RGX FW State: NOT RESPONDING - Poll failure (HWRState 0x00000011: HWR OK; DM running ok; ) [2023-06-06 18:51:48.941] RGX FW Power State: RGXFWIF_POW_ON (APM disabled: 0 ok, 0 denied, 0 non-idle, 0 other, 0 total. Latency: 0 ms) [2023-06-06 18:51:48.941] RGX DVFS: 0 frequency changes. Current frequency: 749 MHz (sampled at 5de4c846e7fd) [2023-06-06 18:51:48.941] RGX FW OS 0 State: 0x00000003 (Active: Yes, Freelists: Ok, Grow Request Pending: No) [2023-06-06 18:51:48.941] ------[ RGX registers ]------ [2023-06-06 18:51:48.941] RGX Register Base Address (Linear): 0x28004000 [2023-06-06 18:51:48.972] RGX Register Base Address (Physical): 0x4E20000000 [2023-06-06 18:51:48.972] CORE_ID : 0x0000000008470000 [2023-06-06 18:51:48.972] CORE_REVISION : 0x00D0013E [2023-06-06 18:51:48.972] DESIGNER_REV_FIELD1 : 0x00000000 [2023-06-06 18:51:48.972] DESIGNER_REV_FIELD2 : 0x00000000 [2023-06-06 18:51:48.972] CHANGESET_NUMBER : 0x0000000000000000 [2023-06-06 18:51:48.972] CLK_CTRL : 0x0AAAAA002A2AA9AA [2023-06-06 18:51:48.972] CLK_STATUS : 0x0000000002700151 [2023-06-06 18:51:48.972] CLK_CTRL2 : 0x0000000000000000 [2023-06-06 18:51:48.972] CLK_STATUS2 : 0x0000000000000000 [2023-06-06 18:51:48.972] EVENT_STATUS : 0x00000410 [2023-06-06 18:51:48.972] TIMER : 0x000000466B98FFCF [2023-06-06 18:51:48.972] BIF_FAULT_BANK0_MMU_STATUS : 0x00000000 [2023-06-06 18:51:48.972] BIF_FAULT_BANK0_REQ_STATUS : 0x0000000000000000 [2023-06-06 18:51:48.972] BIF_FAULT_BANK1_MMU_STATUS : 0x00000000 [2023-06-06 18:51:48.972] BIF_FAULT_BANK1_REQ_STATUS : 0x0000000000000000 [2023-06-06 18:51:48.972] BIF_MMU_STATUS : 0x00000041 [2023-06-06 18:51:48.972] BIF_MMU_ENTRY : 0x00000000 [2023-06-06 18:51:48.972] BIF_MMU_ENTRY_STATUS : 0x0000000000000000 [2023-06-06 18:51:48.972] BIF_STATUS_MMU : 0x00000000 [2023-06-06 18:51:48.972] BIF_READS_EXT_STATUS : 0x00000000 [2023-06-06 18:51:49.004] BIF_READS_INT_STATUS : 0x00030000 [2023-06-06 18:51:49.004] BIFPM_STATUS_MMU : 0x00000009 [2023-06-06 18:51:49.004] BIFPM_READS_EXT_STATUS : 0x00000005 [2023-06-06 18:51:49.004] BIFPM_READS_INT_STATUS : 0x00000000 [2023-06-06 18:51:49.004] Warning: BRN44871 is present [2023-06-06 18:51:49.004] BIF_CAT_BASE_INDEX : 0x0000000000000202 [2023-06-06 18:51:49.004] BIF_CAT_BASE0 : 0x0000000000000000 [2023-06-06 18:51:49.004] BIF_CAT_BASE1 : 0x00000008CBF70000 [2023-06-06 18:51:49.004] BIF_CAT_BASE2 : 0x00000008CBD43000 [2023-06-06 18:51:49.004] BIF_CAT_BASE3 : 0x0000000000000000 [2023-06-06 18:51:49.004] BIF_CAT_BASE4 : 0x0000000000000000 [2023-06-06 18:51:49.004] BIF_CAT_BASE5 : 0x0000000000000000 [2023-06-06 18:51:49.004] BIF_CAT_BASE6 : 0x0000000000000000 [2023-06-06 18:51:49.004] BIF_CAT_BASE7 : 0x0000000000000000 [2023-06-06 18:51:49.004] BIF_CTRL_INVAL : 0x00000000 [2023-06-06 18:51:49.004] BIF_CTRL : 0x000000C0 [2023-06-06 18:51:49.004] BIF_PM_CAT_BASE_VCE0 : 0x000000008DFB5001 [2023-06-06 18:51:49.004] BIF_PM_CAT_BASE_TE0 : 0x000000008DFBA001 [2023-06-06 18:51:49.004] BIF_PM_CAT_BASE_ALIST0 : 0x000000008DFD3001 [2023-06-06 18:51:49.004] BIF_PM_CAT_BASE_VCE1 : 0x000000008DFD3001 [2023-06-06 18:51:49.004] BIF_PM_CAT_BASE_TE1 : 0x000000008DFCF001 [2023-06-06 18:51:49.020] BIF_PM_CAT_BASE_ALIST1 : 0x000000008DFC1001 [2023-06-06 18:51:49.020] PERF_TA_PHASE : 0x002E4EBE [2023-06-06 18:51:49.020] PERF_TA_CYCLE : 0xD9D5CDFC [2023-06-06 18:51:49.020] PERF_3D_PHASE : 0x002E4EF2 [2023-06-06 18:51:49.020] PERF_3D_CYCLE : 0x0FDEE757 [2023-06-06 18:51:49.020] PERF_TA_OR_3D_CYCLE : 0xE9B4B553 [2023-06-06 18:51:49.020] PERF_TA_AND_3D_CYCLE : 0x00000000 [2023-06-06 18:51:49.020] PERF_COMPUTE_PHASE : 0x00000000 [2023-06-06 18:51:49.020] PERF_COMPUTE_CYCLE : 0x00000000 [2023-06-06 18:51:49.020] PM_PARTIAL_RENDER_ENABLE : 0x00000000 [2023-06-06 18:51:49.020] ISP_RENDER : 0x00000000 [2023-06-06 18:51:49.020] TLA_STATUS : 0x0000000000000000 [2023-06-06 18:51:49.020] MCU_FENCE : 0x0000018000000000 [2023-06-06 18:51:49.020] VDM_CONTEXT_STORE_STATUS : 0x00000001 [2023-06-06 18:51:49.020] VDM_CONTEXT_STORE_TASK0 : 0x0000220522001004 [2023-06-06 18:51:49.020] VDM_CONTEXT_STORE_TASK1 : 0x0000000000002240 [2023-06-06 18:51:49.020] VDM_CONTEXT_STORE_TASK2 : 0x0000200000000420 [2023-06-06 18:51:49.020] VDM_CONTEXT_RESUME_TASK0 : 0x0000230520011004 [2023-06-06 18:51:49.020] VDM_CONTEXT_RESUME_TASK1 : 0x0000000000002340 [2023-06-06 18:51:49.273] VDM_CONTEXT_RESUME_TASK2 : 0x0000210000000420 [2023-06-06 18:51:49.273] ISP_CTL : 0x0003B00F [2023-06-06 18:51:49.273] ISP_STATUS : 0x00000003 [2023-06-06 18:51:49.273] MTS_INTCTX : 0x00000000 [2023-06-06 18:51:49.273] MTS_BGCTX : 0x00000000 [2023-06-06 18:51:49.273] MTS_BGCTX_COUNTED_SCHEDULE : 0x00000000 [2023-06-06 18:51:49.273] MTS_SCHEDULE : 0x00000000 [2023-06-06 18:51:49.273] MTS_GPU_INT_STATUS : 0x00004550 [2023-06-06 18:51:49.273] CDM_CONTEXT_STORE_STATUS : 0x00000000 [2023-06-06 18:51:49.273] CDM_CONTEXT_PDS0 : 0x0000000000000000 [2023-06-06 18:51:49.273] CDM_CONTEXT_PDS1 : 0x0000000000000000 [2023-06-06 18:51:49.273] CDM_TERMINATE_PDS : 0x0000000000000000 [2023-06-06 18:51:49.273] CDM_TERMINATE_PDS1 : 0x0000000000000000 [2023-06-06 18:51:49.273] SIDEKICK_IDLE : 0x0000007E [2023-06-06 18:51:49.273] SLC_IDLE : 0x000000FF [2023-06-06 18:51:49.273] SLC_STATUS0 : 0x00000000 [2023-06-06 18:51:49.273] SLC_STATUS1 : 0x0000000000000000 [2023-06-06 18:51:49.273] SLC_CTRL_BYPASS : 0x01000000 [2023-06-06 18:51:49.273] SLC_CTRL_MISC : 0x0000000000200003 [2023-06-06 18:51:49.273] MIPS_ADDR_REMAP1_CONFIG1 : 0x1FC00001 [2023-06-06 18:51:49.273] MIPS_ADDR_REMAP1_CONFIG2 : 0x000000008007700C [2023-06-06 18:51:49.273] MIPS_ADDR_REMAP2_CONFIG1 : 0x1FC01001 [2023-06-06 18:51:49.304] MIPS_ADDR_REMAP2_CONFIG2 : 0x000000008007B00C [2023-06-06 18:51:49.304] MIPS_ADDR_REMAP3_CONFIG1 : 0x1FC02001 [2023-06-06 18:51:49.304] MIPS_ADDR_REMAP3_CONFIG2 : 0x000000008007600C [2023-06-06 18:51:49.304] MIPS_ADDR_REMAP4_CONFIG1 : 0x80000001 [2023-06-06 18:51:49.304] MIPS_ADDR_REMAP4_CONFIG2 : 0x000000001FC0000E [2023-06-06 18:51:49.304] MIPS_ADDR_REMAP5_CONFIG1 : 0x00000001 [2023-06-06 18:51:49.304] MIPS_ADDR_REMAP5_CONFIG2 : 0x000000008007700C [2023-06-06 18:51:49.304] MIPS_WRAPPER_CONFIG : 0x000000000001CF40 [2023-06-06 18:51:49.304] MIPS_EXCEPTION_STATUS : 0x00000020 [2023-06-06 18:51:49.304] ---- [ MIPS internal state ] ---- [2023-06-06 18:51:49.304] PC : 0xC001A16A [2023-06-06 18:51:49.304] STATUS_REGISTER : 0x00481C05 [2023-06-06 18:51:49.304] CAUSE_REGISTER : 0x00800000 [2023-06-06 18:51:49.304] BAD_REGISTER : 0xC001A16A [2023-06-06 18:51:49.304] EPC : 0xC001A166 [2023-06-06 18:51:49.304] SP : 0xCF600FE0 [2023-06-06 18:51:49.304] BAD_INSTRUCTION : 0x00000000 [2023-06-06 18:51:49.304] TLB : [2023-06-06 18:51:49.304] 0) VA 0xCF400000 ( 64k) -> PA0 0xE20000000 DV , PA1 0x00000000 C [2023-06-06 18:51:49.304] 1) VA 0xCF000000 ( 16k) -> PA0 0x80050000 DVGC, PA1 0x80054000 DVGC [2023-06-06 18:51:49.304] 2) VA 0xCF600000 ( 4k) -> PA0 0x8007C000 DV C, PA1 0x00000000 C [2023-06-06 18:51:49.337] 3) VA 0xC0012000 ( 4k) -> PA0 0x8006D000 DVGC, PA1 0x8006E000 DVGC [2023-06-06 18:51:49.337] 4) VA 0xC002E000 ( 4k) -> PA0 0x80078000 DVGC, PA1 0x80079000 DVGC [2023-06-06 18:51:49.337] 5) VA 0xC0006000 ( 4k) -> PA0 0x80061000 DVGC, PA1 0x80062000 DVGC [2023-06-06 18:51:49.337] 6) VA 0xC001A000 ( 4k) -> PA0 0x80075000 DVGC, PA1 0x80076000 DVGC [2023-06-06 18:51:49.337] 7) VA 0xC0036000 ( 4k) -> PA0 0x8CBF92000 DVG , PA1 0x8CBF6F000 DVGC [2023-06-06 18:51:49.337] 8) VA 0xC0030000 ( 4k) -> PA0 0x8007A000 DVGC, PA1 0x8007B000 DVGC [2023-06-06 18:51:49.337] 9) VA 0xC000A000 ( 4k) -> PA0 0x80065000 DVGC, PA1 0x80066000 DVGC [2023-06-06 18:51:49.337] 10) VA 0xC005C000 ( 4k) -> PA0 0x8CBD38000 DVG , PA1 0x88FF7000 DVGC [2023-06-06 18:51:49.337] 11) VA 0xC000C000 ( 4k) -> PA0 0x80067000 DVGC, PA1 0x80068000 DVGC [2023-06-06 18:51:49.337] 12) VA 0xC0022000 ( 4k) -> PA0 0x8007E000 VGC, PA1 0x80004000 DVG [2023-06-06 18:51:49.337] 13) VA 0xC0010000 ( 4k) -> PA0 0x8006B000 DVGC, PA1 0x8006C000 DVGC [2023-06-06 18:51:49.337] 14) VA 0xC006C000 ( 4k) -> PA0 0x8908B000 DVGC, PA1 0x8908C000 DVGC [2023-06-06 18:51:49.337] 15) VA 0xC0008000 ( 4k) -> PA0 0x80063000 DVGC, PA1 0x80064000 DVGC [2023-06-06 18:51:49.337] -------------------------------- [2023-06-06 18:51:49.337] RGX Kernel CCB WO:0x63 RO:0x63 [2023-06-06 18:51:49.352] RGX Firmware CCB WO:0x3 RO:0x3 [2023-06-06 18:51:49.352] RGX Kernel CCB commands executed = 6069731 [2023-06-06 18:51:49.352] Thread0: FW IRQ count = 9104544 [2023-06-06 18:51:49.352] Last sampled IRQ count in LISR = 9104544 [2023-06-06 18:51:49.352] FW OS config flags = 0x800127 (Ctx switch: TA; 3D; CDM; VDM CS INDEX mode; Medium CSW profile; Use extended; HWR EN; ) [2023-06-06 18:51:49.352] Device System Power State: ON [2023-06-06 18:51:49.352] Debug log type: none [2023-06-06 18:51:49.352] RGX FW thread 0: Trace buffer not yet allocated [2023-06-06 18:51:49.352] ------[ Stalled FWCtxs ]------ [2023-06-06 18:51:49.352] FWCtx 0xC0037620 @ 30960 (3D-P516145-T2-./CtApIPSV_Free) pending on FENCE_PR: [2023-06-06 18:51:49.352] Addr:0xc005c050 Value=0x002e4ebd [2023-06-06 18:51:49.352] FWCtx 0xC0037620 fenced command is of type 3D_PR [2023-06-06 18:51:49.352] ------[ Active Sync Checkpoints ]------ [2023-06-06 18:51:49.352] - ID = 6069670, FWAddr = 0xc0059018, r1:e1:f0: es3-DoKickTA-0 [2023-06-06 18:51:49.352] ------[ Pending Server Syncs ]------ [2023-06-06 18:51:49.352] ------[ Fallback Fence Sync: timelines ]------ [2023-06-06 18:51:49.352] Timeline: Screen_Timeline-Running--487462, SeqNum: 0/0 - <0x10148240> [2023-06-06 18:51:49.352] Timeline: RM_SWTimeline-eeRunning--487462, SeqNum: 0/0 - <0x101485a0> [2023-06-06 18:51:49.352] Timeline: V3-./CtApCC_FreeRunning--487462, SeqNum: 0/0 - <0x10148630> [2023-06-06 18:51:49.551] Timeline: P3-./CtApCC_FreeRunning--487462, SeqNum: 0/0 - <0x101486c0> [2023-06-06 18:51:49.551] Timeline: QE-/CtApCC_FreeRunning-1-487462, SeqNum: 29/29 - <0x10148090> [2023-06-06 18:51:49.551] Timeline: Screen_Timeline-Running--516145, SeqNum: 0/0 - <0x10a89750> [2023-06-06 18:51:49.551] Timeline: RM_SWTimeline-eeRunning--516145, SeqNum: 0/0 - <0x10a89900> [2023-06-06 18:51:49.551] Timeline: V3-CtApIPSV_FreeRunning--516145, SeqNum: 3034813/3034813 - <0x10a89990> [2023-06-06 18:51:49.551] Timeline: P3-CtApIPSV_FreeRunning--516145, SeqNum: 3034812/3034813 - <0x10a89a20> [2023-06-06 18:51:49.551] - SyncPt: SeqNum: 3034813, Refs: 2, Active - <0x15b1cc90> [2023-06-06 18:51:49.551] - CbType: PVR-Checkpoint, ID: 6069670, FWAddr: 0xc0059019, Enq: 1, Ref: 1, Active - <0x13f16a20> [2023-06-06 18:51:49.551] Timeline: QE-FreeRunning-sampler2D-516145, SeqNum: 16/16 - <0x10a89bd0> [2023-06-06 18:51:49.551] ------[ Fallback Fence Sync: fences ]------ [2023-06-06 18:51:49.551] Fence: TQM, Signalled - <0x101c5630> [2023-06-06 18:51:49.551] - SyncPt: SeqNum: 29, Refs: 1, Timeline: QE-/CtApCC_FreeRunning-1-487462 <0x10148090>, Signalled - <0x101c5690> [2023-06-06 18:51:49.551] - CbType: PVR-Checkpoint, ID: 28, FWAddr: 0xc0059001, Enq: 1, Ref: 1, Signalled - <0x101cc420> [2023-06-06 18:51:49.582] Fence: TQM, Signalled - <0x13f1ea50> [2023-06-06 18:51:49.582] - SyncPt: SeqNum: 16, Refs: 1, Timeline: QE-FreeRunning-sampler2D-516145 <0x10a89bd0>, Signalled - <0x13f1eab0> [2023-06-06 18:51:49.582] - CbType: PVR-Checkpoint, ID: 44, FWAddr: 0xc0059011, Enq: 1, Ref: 1, Signalled - <0x13f2e4e0> [2023-06-06 18:51:49.582] Fence: es3-DoKickTA-0, Signalled - <0x13f1ecf0> [2023-06-06 18:51:49.582] - SyncPt: SeqNum: 3034813, Refs: 2, Timeline: V3-CtApIPSV_FreeRunning--516145 <0x10a89990>, Signalled - <0x13f1ed50> [2023-06-06 18:51:49.582] - CbType: PVR-Checkpoint, ID: 6069669, FWAddr: 0xc0059009, Enq: 1, Ref: 1, Signalled - <0x101cc5e0> [2023-06-06 18:51:49.582] Fence: es3-DoKickTA-0, Active - <0x15b1cbd0> [2023-06-06 18:51:49.582] - SyncPt: SeqNum: 3034813, Refs: 2, Timeline: P3-CtApIPSV_FreeRunning--516145 <0x10a89a20>, Active - <0x15b1cc90> [2023-06-06 18:51:49.582] - CbType: PVR-Checkpoint, ID: 6069670, FWAddr: 0xc0059019, Enq: 1, Ref: 1, Signalled - <0x13f16a20> [2023-06-06 18:51:49.582] Fence: Fence-Merged, Active - <0x15b1ccf0> [2023-06-06 18:51:49.582] - SyncPt: SeqNum: 3034813, Refs: 2, Timeline: V3-CtApIPSV_FreeRunning--516145 <0x10a89990>, Signalled - <0x13f1ed50> [2023-06-06 18:51:49.582] - CbType: PVR-Checkpoint, ID: 6069669, FWAddr: 0xc0059009, Enq: 1, Ref: 1, Signalled - <0x101cc5e0> [2023-06-06 18:51:49.582] - SyncPt: SeqNum: 3034813, Refs: 2, Timeline: P3-CtApIPSV_FreeRunning--516145 <0x10a89a20>, Active - <0x15b1cc90> [2023-06-06 18:51:49.582] - CbType: PVR-Checkpoint, ID: 6069670, FWAddr: 0xc0059019, Enq: 1, Ref: 1, Signalled - <0x13f16a20> [2023-06-06 18:51:49.582] ------[ Debug summary ]------ [2023-06-06 18:51:49.582] BIF0 - OK [2023-06-06 18:51:49.582] RGX FW State: NOT RESPONDING - Poll failure (HWRState 0x00000001: HWR OK; ) [2023-06-06 18:51:49.582] RGX FW Power State: RGXFWIF_POW_IDLE (APM disabled: 0 ok, 0 denied, 0 non-idle, 0 other, 0 total. Latency: 0 ms) [2023-06-06 18:51:49.582] RGX DVFS: 0 frequency changes. Current frequency: 749 MHz (sampled at 5de4c846e7fd) [2023-06-06 18:51:49.582] RGX FW OS 0 State: 0x00000003 (Active: Yes, Freelists: Ok, Grow Request Pending: No) [2023-06-06 18:51:49.582] ------[ Server Thread Summary ]------ [2023-06-06 18:51:49.582] ------[ HTB Log state: Off ]------ [2023-06-06 18:51:49.582] ------------[ PVR DBG: END ]------------ [2023-06-06 18:51:49.582] call stack:
Thank you.
