Part Number: PROCESSOR-SDK-J721E
We are looking for a linux user application which can do IPC with other cores other than OpenVx ?
Thank you.
Thank you.
Hello ,
ti_rpmsg_char utility library is available for Linux user-space applications. The library provides an easy means to identify rpmsg character devices created by the Linux kernel rpmsg-char driver using the virtio-rpmsg-bus transport back-end.
The ti-rpmsg-char repo provides a user-space example called rpmsg-char-simple. The PDK IPC LLD “ipc_echo_test” firmwares can be used as sample firmwares for testing along with rpmsg-char-simple.
Can you please take a look into the below link ?
software-dl.ti.com/.../Foundational_Components_IPCLLD.html
Tarun Mukesh
