Hi team,
I've run following command on TDA4VM:
root@tda4vm-sk:/opt/edgeai-gst-apps/apps_cpp# ./bin/Release/app_edgeai ../configs/single_input_multi_infer.yaml
It ended up with Segmentation fault. Following are logs after running the command:
root@tda4vm-sk:/opt/edgeai-gst-apps/apps_cpp# ./bin/Release/app_edgeai ../configs/single_input_multi_infer.yaml Number of subgraphs:1 , 107 nodes delegated out of 107 nodes APP: Init ... !!! MEM: Init ... !!! MEM: Initialized DMA HEAP (fd=5) !!! MEM: Init ... Done !!! IPC: Init ... !!! IPC: Init ... Done !!! REMOTE_SERVICE: Init ... !!! REMOTE_SERVICE: Init ... Done !!! 6029.148206 s: GTC Frequency = 200 MHz APP: Init ... Done !!! 6029.148295 s: VX_ZONE_INIT:Enabled 6029.148302 s: VX_ZONE_ERROR:Enabled 6029.148308 s: VX_ZONE_WARNING:Enabled 6029.149071 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!! 6029.149243 s: VX_ZONE_INIT:[tivxHostInitLocal:93] Initialization Done for HOST !!! 6029.183827 s: VX_ZONE_ERROR:[ownContextSendCmd:799] Command ack message returned failure cmd_status: -1 6029.183880 s: VX_ZONE_ERROR:[ownContextSendCmd:835] tivxEventWait() failed. 6029.183888 s: VX_ZONE_ERROR:[ownNodeKernelInit:527] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode 6029.183893 s: VX_ZONE_ERROR:[ownNodeKernelInit:528] Please be sure the target callbacks have been registered for this core 6029.183899 s: VX_ZONE_ERROR:[ownNodeKernelInit:529] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel 6029.183907 s: VX_ZONE_ERROR:[ownGraphNodeKernelInit:583] kernel init for node 0, kernel com.ti.tidl:1:4 ... failed !!! 6029.183921 s: VX_ZONE_ERROR:[vxVerifyGraph:2055] Node kernel init failed 6029.183927 s: VX_ZONE_ERROR:[vxVerifyGraph:2109] Graph verify failed TIDL_RT_OVX: ERROR: Verifying TIDL graph ... Failed !!! TIDL_RT_OVX: ERROR: Verify OpenVX graph failed libtidl_onnxrt_EP loaded 0x41c3370 Final number of subgraphs created are : 1, - Offloaded Nodes - 289, Total Nodes - 289 6029.409934 s: VX_ZONE_ERROR:[ownContextSendCmd:799] Command ack message returned failure cmd_status: -1 6029.409991 s: VX_ZONE_ERROR:[ownContextSendCmd:835] tivxEventWait() failed. 6029.409999 s: VX_ZONE_ERROR:[ownNodeKernelInit:527] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode 6029.410005 s: VX_ZONE_ERROR:[ownNodeKernelInit:528] Please be sure the target callbacks have been registered for this core 6029.410011 s: VX_ZONE_ERROR:[ownNodeKernelInit:529] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel 6029.410019 s: VX_ZONE_ERROR:[ownGraphNodeKernelInit:583] kernel init for node 0, kernel com.ti.tidl:1:2 ... failed !!! 6029.410026 s: VX_ZONE_ERROR:[vxVerifyGraph:2055] Node kernel init failed 6029.410033 s: VX_ZONE_ERROR:[vxVerifyGraph:2109] Graph verify failed TIDL_RT_OVX: ERROR: Verifying TIDL graph ... Failed !!! TIDL_RT_OVX: ERROR: Verify OpenVX graph failed Number of subgraphs:1 , 34 nodes delegated out of 34 nodes 6029.434803 s: VX_ZONE_ERROR:[ownContextSendCmd:799] Command ack message returned failure cmd_status: -1 6029.434828 s: VX_ZONE_ERROR:[ownContextSendCmd:835] tivxEventWait() failed. 6029.434835 s: VX_ZONE_ERROR:[ownNodeKernelInit:527] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode 6029.434841 s: VX_ZONE_ERROR:[ownNodeKernelInit:528] Please be sure the target callbacks have been registered for this core 6029.434847 s: VX_ZONE_ERROR:[ownNodeKernelInit:529] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel 6029.434855 s: VX_ZONE_ERROR:[ownGraphNodeKernelInit:583] kernel init for node 0, kernel com.ti.tidl:1:1 ... failed !!! 6029.434863 s: VX_ZONE_ERROR:[vxVerifyGraph:2055] Node kernel init failed 6029.434869 s: VX_ZONE_ERROR:[vxVerifyGraph:2109] Graph verify failed TIDL_RT_OVX: ERROR: Verifying TIDL graph ... Failed !!! TIDL_RT_OVX: ERROR: Verify OpenVX graph failed libtidl_onnxrt_EP loaded 0x41c3370 Final number of subgraphs created are : 1, - Offloaded Nodes - 320, Total Nodes - 320 6030.103399 s: VX_ZONE_ERROR:[ownContextSendCmd:799] Command ack message returned failure cmd_status: -1 6030.103454 s: VX_ZONE_ERROR:[ownContextSendCmd:835] tivxEventWait() failed. 6030.103462 s: VX_ZONE_ERROR:[ownNodeKernelInit:527] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode 6030.103468 s: VX_ZONE_ERROR:[ownNodeKernelInit:528] Please be sure the target callbacks have been registered for this core 6030.103474 s: VX_ZONE_ERROR:[ownNodeKernelInit:529] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel 6030.103481 s: VX_ZONE_ERROR:[ownGraphNodeKernelInit:583] kernel init for node 0, kernel com.ti.tidl:1:1 ... failed !!! 6030.103489 s: VX_ZONE_ERROR:[vxVerifyGraph:2055] Node kernel init failed 6030.103496 s: VX_ZONE_ERROR:[vxVerifyGraph:2109] Graph verify failed TIDL_RT_OVX: ERROR: Verifying TIDL graph ... Failed !!! TIDL_RT_OVX: ERROR: Verify OpenVX graph failed [07:54:38.000.000000]:ERROR:[getConfig:0147] Mean value specification missing. [07:54:38.000.000000]:ERROR:[initialize:1642] getConfig() failed. [07:54:38.026.026763]:ERROR:[getConfig:0147] Mean value specification missing. (app_edgeai:2942): GLib-GObject-WARNING **: 07:54:38.189: value "((GstTIOVXDLPreProcDataType) 0)" of type 'GstTIOVXDLPreProcDataType' is invalid or out of range for property 'data-type' of type 'GstTIOVXDLPreProcDataType' [07:54:38.027.027652]:ERROR:[makePostprocessImageObj:0083] Invalid post-processing task type. [07:54:38.027.027675]:ERROR:[createPostprocCntxt:1776] PostprocessImage::makePostprocessImageObj() failed. [07:54:38.027.027690]:ERROR:[initialize:2062] createPostprocCntxt() failed. Segmentation fault (core dumped)
single_input_multi_infer.yaml is as follows:
title: "Single Input, Multi Inference" log_level: 2 inputs: input0: source: /dev/video2 format: jpeg width: 1280 height: 720 framerate: 30 input1: source: /opt/edgeai-test-data/videos/video_0000_h264.h264 format: h264 width: 1280 height: 720 framerate: 30 loop: True input2: source: /opt/edgeai-test-data/images/%04d.jpg width: 1280 height: 720 index: 0 framerate: 1 loop: True models: model0: model_path: /opt/model_zoo/TFL-OD-2010-ssd-mobV2-coco-mlperf-300x300 viz_threshold: 0.6 model1: model_path: /opt/model_zoo/ONR-OD-8200-yolox-nano-lite-mmdet-coco-416x416 viz_threshold: 0.6 model2: model_path: /opt/model_zoo/TFL-CL-0000-mobileNetV1-mlperf topN: 5 model3: model_path: /opt/model_zoo/ONR-SS-8610-deeplabv3lite-mobv2-ade20k32-512x512 alpha: 0.4 model4: model_path: /opt/model_zoo/yolov5s6_640_ti_lite_37p4_56p0 viz_threshold: 0.3 outputs: output0: sink: kmssink width: 1920 height: 1080 overlay-performance: True output1: sink: /opt/edgeai-test-data/output/output_video.mkv width: 1920 height: 1080 output2: sink: /opt/edgeai-test-data/output/output_image_%04d.jpg width: 1920 height: 1080 flows: flow0: [input1,model0,output0,[320,180,640,360]] flow1: [input1,model1,output0,[960,180,640,360]] flow2: [input1,model2,output0,[320,560,640,360]] flow3: [input1,model4,output0,[960,560,640,360]]
The error came from 4th model("yolov5s6_640_ti_lite_37p4_56p0") only, which was downloaded from https://github.com/TexasInstruments/edgeai-yolov5 and compiled with:
python3 onnxrt_ep.py -c
The compilation finished with following warning message:
------------------ Network Compiler Traces ----------------------------- successful Memory allocation INFORMATION: [TIDL_ResizeLayer] Resize_107 Any resize ratio which is power of 2 and greater than 4 will be placed by combination of 4x4 resize layer and 2x2 resize layer. For example a 8x8 resize will be replaced by 4x4 resize followed by 2x2 resize. INFORMATION: [TIDL_ResizeLayer] Resize_123 Any resize ratio which is power of 2 and greater than 4 will be placed by combination of 4x4 resize layer and 2x2 resize layer. For example a 8x8 resize will be replaced by 4x4 resize followed by 2x2 resize. INFORMATION: [TIDL_ResizeLayer] Resize_139 Any resize ratio which is power of 2 and greater than 4 will be placed by combination of 4x4 resize layer and 2x2 resize layer. For example a 8x8 resize will be replaced by 4x4 resize followed by 2x2 resize. ****************************************************
Also, the auto-generated param.yaml from compilation is:
postprocess: data_layout: NCHW detection_thr: 0.3 preprocess: crop: - 640 - 640 data_layout: NCHW mean: - 0 - 0 - 0 resize: - 640 - 640 scale: - 0.003921568627 - 0.003921568627 - 0.003921568627 session: artifacts_folder: '' model_folder: model model_path: yolov5s6_640_ti_lite_37p4_56p0.onnx session_name: onnxrt target_device: pc task_type: detection
Thank you in advance for your support!
Ann
From the above logs, the occurred error is "6029.183927 s: VX_ZONE_ERROR:[vxVerifyGraph:2109] Graph verify failed"
Please check our FAQ : https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1227571/faq-sk-tda4vm-error-while-running-custom-compiled-model?tisearch=e2e-sitesearch&keymatch=faq%3Atrue
Pratik
How to re compile with same sdk version as that of target tda4vm. I go through the edgeaibechmark github but the instruction is not very clear to step wise compilation of pretained yolov5 model. Is there any detailed documentation and supportive steps to help me to compile model.
I'm not sure that the "Segmentation fault" is caused by "Graph verify failed error".
When I tested other already-compiled-model provided by TI, the "Graph verify failed" also occurred. However, there were no "Segmentation fault" in log as follows:
root@tda4vm-sk:/opt/edgeai-gst-apps/apps_cpp# ./bin/Release/app_edgeai ../configs/single_input_multi_infer.yaml Number of subgraphs:1 , 107 nodes delegated out of 107 nodes APP: Init ... !!! MEM: Init ... !!! MEM: Initialized DMA HEAP (fd=5) !!! MEM: Init ... Done !!! IPC: Init ... !!! IPC: Init ... Done !!! REMOTE_SERVICE: Init ... !!! REMOTE_SERVICE: Init ... Done !!! 5800.299044 s: GTC Frequency = 200 MHz APP: Init ... Done !!! 5800.299128 s: VX_ZONE_INIT:Enabled 5800.299135 s: VX_ZONE_ERROR:Enabled 5800.299140 s: VX_ZONE_WARNING:Enabled 5800.299889 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!! 5800.300072 s: VX_ZONE_INIT:[tivxHostInitLocal:93] Initialization Done for HOST !!! 5800.323022 s: VX_ZONE_ERROR:[ownContextSendCmd:799] Command ack message returned failure cmd_status: -1 5800.323048 s: VX_ZONE_ERROR:[ownContextSendCmd:835] tivxEventWait() failed. 5800.323056 s: VX_ZONE_ERROR:[ownNodeKernelInit:527] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode 5800.323062 s: VX_ZONE_ERROR:[ownNodeKernelInit:528] Please be sure the target callbacks have been registered for this core 5800.323068 s: VX_ZONE_ERROR:[ownNodeKernelInit:529] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel 5800.323076 s: VX_ZONE_ERROR:[ownGraphNodeKernelInit:583] kernel init for node 0, kernel com.ti.tidl:1:4 ... failed !!! 5800.323087 s: VX_ZONE_ERROR:[vxVerifyGraph:2055] Node kernel init failed 5800.323093 s: VX_ZONE_ERROR:[vxVerifyGraph:2109] Graph verify failed TIDL_RT_OVX: ERROR: Verifying TIDL graph ... Failed !!! TIDL_RT_OVX: ERROR: Verify OpenVX graph failed libtidl_onnxrt_EP loaded 0x3cf93410 Final number of subgraphs created are : 1, - Offloaded Nodes - 289, Total Nodes - 289 5800.555218 s: VX_ZONE_ERROR:[ownContextSendCmd:799] Command ack message returned failure cmd_status: -1 5800.555272 s: VX_ZONE_ERROR:[ownContextSendCmd:835] tivxEventWait() failed. 5800.555279 s: VX_ZONE_ERROR:[ownNodeKernelInit:527] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode 5800.555286 s: VX_ZONE_ERROR:[ownNodeKernelInit:528] Please be sure the target callbacks have been registered for this core 5800.555292 s: VX_ZONE_ERROR:[ownNodeKernelInit:529] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel 5800.555300 s: VX_ZONE_ERROR:[ownGraphNodeKernelInit:583] kernel init for node 0, kernel com.ti.tidl:1:2 ... failed !!! 5800.555307 s: VX_ZONE_ERROR:[vxVerifyGraph:2055] Node kernel init failed 5800.555313 s: VX_ZONE_ERROR:[vxVerifyGraph:2109] Graph verify failed TIDL_RT_OVX: ERROR: Verifying TIDL graph ... Failed !!! TIDL_RT_OVX: ERROR: Verify OpenVX graph failed Number of subgraphs:1 , 34 nodes delegated out of 34 nodes 5800.580320 s: VX_ZONE_ERROR:[ownContextSendCmd:799] Command ack message returned failure cmd_status: -1 5800.580345 s: VX_ZONE_ERROR:[ownContextSendCmd:835] tivxEventWait() failed. 5800.580352 s: VX_ZONE_ERROR:[ownNodeKernelInit:527] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode 5800.580358 s: VX_ZONE_ERROR:[ownNodeKernelInit:528] Please be sure the target callbacks have been registered for this core 5800.580364 s: VX_ZONE_ERROR:[ownNodeKernelInit:529] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel 5800.580371 s: VX_ZONE_ERROR:[ownGraphNodeKernelInit:583] kernel init for node 0, kernel com.ti.tidl:1:1 ... failed !!! 5800.580379 s: VX_ZONE_ERROR:[vxVerifyGraph:2055] Node kernel init failed 5800.580386 s: VX_ZONE_ERROR:[vxVerifyGraph:2109] Graph verify failed TIDL_RT_OVX: ERROR: Verifying TIDL graph ... Failed !!! TIDL_RT_OVX: ERROR: Verify OpenVX graph failed libtidl_onnxrt_EP loaded 0x3cf93410 Final number of subgraphs created are : 1, - Offloaded Nodes - 123, Total Nodes - 123 5801.092153 s: VX_ZONE_ERROR:[ownContextSendCmd:799] Command ack message returned failure cmd_status: -1 5801.092210 s: VX_ZONE_ERROR:[ownContextSendCmd:835] tivxEventWait() failed. 5801.092218 s: VX_ZONE_ERROR:[ownNodeKernelInit:527] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode 5801.092224 s: VX_ZONE_ERROR:[ownNodeKernelInit:528] Please be sure the target callbacks have been registered for this core 5801.092231 s: VX_ZONE_ERROR:[ownNodeKernelInit:529] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel 5801.092238 s: VX_ZONE_ERROR:[ownGraphNodeKernelInit:583] kernel init for node 0, kernel com.ti.tidl:1:1 ... failed !!! 5801.092246 s: VX_ZONE_ERROR:[vxVerifyGraph:2055] Node kernel init failed 5801.092253 s: VX_ZONE_ERROR:[vxVerifyGraph:2109] Graph verify failed TIDL_RT_OVX: ERROR: Verifying TIDL graph ... Failed !!! TIDL_RT_OVX: ERROR: Verify OpenVX graph failed ==========[INPUT PIPELINE(S)]========== : : : :
Is there any other possible reason that cause Segmentation fault?
Many thanks,
Ann
Pratik
Could you please share run log of vx_app_arm_remote_log.out
Please follow instructions mentioned in FAQ
Pratik
root@tda4vm-sk:/opt/vision_apps# ./vx_app_arm_remote_log.out & [1] 3179 root@tda4vm-sk:/opt/vision_apps# [MCU2_0] 3.813979 s: CIO: Init ... Done !!! [MCU2_0] 3.814052 s: ### CPU Frequency = 1000000000 Hz [MCU2_0] 3.814100 s: CPU is running FreeRTOS [MCU2_0] 3.814127 s: APP: Init ... !!! [MCU2_0] 3.814152 s: SCICLIENT: Init ... !!! [MCU2_0] 3.814410 s: SCICLIENT: DMSC FW version [8.6.3--v08.06.03 (Chill Capybar] [MCU2_0] 3.814459 s: SCICLIENT: DMSC FW revision 0x8 [MCU2_0] 3.814513 s: SCICLIENT: DMSC FW ABI revision 3.1 [MCU2_0] 3.814559 s: SCICLIENT: Init ... Done !!! [MCU2_0] 3.814590 s: UDMA: Init ... !!! [MCU2_0] 3.815900 s: UDMA: Init ... Done !!! [MCU2_0] 3.815963 s: MEM: Init ... !!! [MCU2_0] 3.816009 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ d9000000 of size 16777216 bytes !!! [MCU2_0] 3.816089 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000000) @ 3600000 of size 262144 bytes !!! [MCU2_0] 3.816152 s: MEM: Init ... Done !!! [MCU2_0] 3.816178 s: IPC: Init ... !!! [MCU2_0] 3.816239 s: IPC: 6 CPUs participating in IPC !!! [MCU2_0] 3.816287 s: IPC: Waiting for HLOS to be ready ... !!! [MCU2_0] 14.151892 s: IPC: HLOS is ready !!! [MCU2_0] 14.167632 s: IPC: Init ... Done !!! [MCU2_0] 14.167702 s: APP: Syncing with 5 CPUs ... !!! [MCU2_0] 14.176742 s: APP: Syncing with 5 CPUs ... Done !!! [MCU2_0] 14.176955 s: REMOTE_SERVICE: Init ... !!! [MCU2_0] 14.178551 s: REMOTE_SERVICE: Init ... Done !!! [MCU2_0] 14.178621 s: FVID2: Init ... !!! [MCU2_0] 14.178699 s: FVID2: Init ... Done !!! [MCU2_0] 14.178733 s: VHWA: VPAC Init ... !!! [MCU2_0] 14.178762 s: SCICLIENT: Sciclient_pmSetModuleState module=290 state=2 [MCU2_0] 14.179228 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 14.179268 s: VHWA: LDC Init ... !!! [MCU2_0] 14.186524 s: VHWA: LDC Init ... Done !!! [MCU2_0] 14.186589 s: VHWA: MSC Init ... !!! [MCU2_0] 14.201307 s: VHWA: MSC Init ... Done !!! [MCU2_0] 14.201369 s: VHWA: NF Init ... !!! [MCU2_0] 14.203683 s: VHWA: NF Init ... Done !!! [MCU2_0] 14.203749 s: VHWA: VISS Init ... !!! [MCU2_0] 14.215150 s: VHWA: VISS Init ... Done !!! [MCU2_0] 14.215219 s: VHWA: VPAC Init ... Done !!! [MCU2_0] 14.215274 s: VX_ZONE_INIT:Enabled [MCU2_0] 14.215308 s: VX_ZONE_ERROR:Enabled [MCU2_0] 14.215337 s: VX_ZONE_WARNING:Enabled [MCU2_0] 14.216779 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target MCU2-0 [MCU2_0] 14.217037 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_NF [MCU2_0] 14.217279 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_LDC1 [MCU2_0] 14.217536 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_MSC1 [MCU2_0] 14.217760 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_MSC2 [MCU2_0] 14.218049 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_VISS1 [MCU2_0] 14.218303 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE1 [MCU2_0] 14.218573 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE2 [MCU2_0] 14.218840 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DISPLAY1 [MCU2_0] 14.219090 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DISPLAY2 [MCU2_0] 14.219311 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CSITX [MCU2_0] 14.219591 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE3 [MCU2_0] 14.219862 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE4 [MCU2_0] 14.220121 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE5 [MCU2_0] 14.220370 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE6 [MCU2_0] 14.220636 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE7 [MCU2_0] 14.220895 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE8 [MCU2_0] 14.221125 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DSS_M2M1 [MCU2_0] 14.221356 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DSS_M2M2 [MCU2_0] 14.221591 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DSS_M2M3 [MCU2_0] 14.221819 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DSS_M2M4 [MCU2_0] 14.221877 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!! [MCU2_0] 14.221914 s: APP: OpenVX Target kernel init ... !!! [MCU2_0] 14.243186 s: APP: OpenVX Target kernel init ... Done !!! [MCU2_0] 14.243244 s: VISS REMOTE SERVICE: Init ... !!! [MCU2_0] 14.243328 s: VISS REMOTE SERVICE: Init ... Done !!! [MCU2_0] 14.243368 s: UDMA Copy: Init ... !!! [MCU2_0] 14.245217 s: UDMA Copy: Init ... Done !!! [MCU2_0] 14.245318 s: APP: Init ... Done !!! [MCU2_0] 14.245357 s: APP: Run ... !!! [MCU2_0] 14.245385 s: IPC: Starting echo test ... [MCU2_0] 14.248164 s: APP: Run ... Done !!! [MCU2_0] 14.249680 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[.] C66X_1[P] C66X_2[.] C7X_1[.] [MCU2_0] 14.249797 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] C66X_1[P] C66X_2[.] C7X_1[.] [MCU2_0] 14.249895 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[.] [MCU2_0] 14.249984 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[P] [MCU2_1] 3.831293 s: CIO: Init ... Done !!! [MCU2_1] 3.831364 s: ### CPU Frequency = 1000000000 Hz [MCU2_1] 3.831409 s: CPU is running FreeRTOS [MCU2_1] 3.831437 s: APP: Init ... !!! [MCU2_1] 3.831462 s: SCICLIENT: Init ... !!! [MCU2_1] 3.831706 s: SCICLIENT: DMSC FW version [8.6.3--v08.06.03 (Chill Capybar] [MCU2_1] 3.831756 s: SCICLIENT: DMSC FW revision 0x8 [MCU2_1] 3.831790 s: SCICLIENT: DMSC FW ABI revision 3.1 [MCU2_1] 3.831841 s: SCICLIENT: Init ... Done !!! [MCU2_1] 3.831871 s: UDMA: Init ... !!! [MCU2_1] 3.833248 s: UDMA: Init ... Done !!! [MCU2_1] 3.833308 s: MEM: Init ... !!! [MCU2_1] 3.833351 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ da000000 of size 16777216 bytes !!! [MCU2_1] 3.833426 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000001) @ 3640000 of size 262144 bytes !!! [MCU2_1] 3.833489 s: MEM: Init ... Done !!! [MCU2_1] 3.833516 s: IPC: Init ... !!! [MCU2_1] 3.833578 s: IPC: 6 CPUs participating in IPC !!! [MCU2_1] 3.833626 s: IPC: Waiting for HLOS to be ready ... !!! [MCU2_1] 14.153782 s: IPC: HLOS is ready !!! [MCU2_1] 14.169672 s: IPC: Init ... Done !!! [MCU2_1] 14.169743 s: APP: Syncing with 5 CPUs ... !!! [MCU2_1] 14.176751 s: APP: Syncing with 5 CPUs ... Done !!! [MCU2_1] 14.176967 s: REMOTE_SERVICE: Init ... !!! [MCU2_1] 14.178551 s: REMOTE_SERVICE: Init ... Done !!! [MCU2_1] 14.178617 s: FVID2: Init ... !!! [MCU2_1] 14.178694 s: FVID2: Init ... Done !!! [MCU2_1] 14.178732 s: VHWA: DMPAC: Init ... !!! [MCU2_1] 14.178760 s: SCICLIENT: Sciclient_pmSetModuleState module=48 state=2 [MCU2_1] 14.179333 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_1] 14.179379 s: SCICLIENT: Sciclient_pmSetModuleState module=305 state=2 [MCU2_1] 14.179773 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_1] 14.179808 s: VHWA: DOF Init ... !!! [MCU2_1] 14.190845 s: VHWA: DOF Init ... Done !!! [MCU2_1] 14.190911 s: VHWA: SDE Init ... !!! [MCU2_1] 14.194877 s: VHWA: SDE Init ... Done !!! [MCU2_1] 14.194939 s: VHWA: DMPAC: Init ... Done !!! [MCU2_1] 14.194987 s: VX_ZONE_INIT:Enabled [MCU2_1] 14.195019 s: VX_ZONE_ERROR:Enabled [MCU2_1] 14.195045 s: VX_ZONE_WARNING:Enabled [MCU2_1] 14.196480 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target MCU2-1 [MCU2_1] 14.196713 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DMPAC_SDE [MCU2_1] 14.196963 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DMPAC_DOF [MCU2_1] 14.197024 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!! [MCU2_1] 14.197061 s: APP: OpenVX Target kernel init ... !!! [MCU2_1] 14.197353 s: APP: OpenVX Target kernel init ... Done !!! [MCU2_1] 14.197396 s: UDMA Copy: Init ... !!! [MCU2_1] 14.199879 s: UDMA Copy: Init ... Done !!! [MCU2_1] 14.199951 s: APP: Init ... Done !!! [MCU2_1] 14.199983 s: APP: Run ... !!! [MCU2_1] 14.200008 s: IPC: Starting echo test ... [MCU2_1] 14.202584 s: APP: Run ... Done !!! [MCU2_1] 14.203765 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C66X_1[P] C66X_2[.] C7X_1[.] [MCU2_1] 14.203900 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C66X_1[P] C66X_2[P] C7X_1[.] [MCU2_1] 14.203997 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C66X_1[P] C66X_2[P] C7X_1[P] [MCU2_1] 14.248965 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[s] C66X_1[P] C66X_2[P] C7X_1[P] [C6x_1 ] 3.896780 s: CIO: Init ... Done !!! [C6x_1 ] 3.896805 s: ### CPU Frequency = 1350000000 Hz [C6x_1 ] 3.896814 s: CPU is running FreeRTOS [C6x_1 ] 3.896822 s: APP: Init ... !!! [C6x_1 ] 3.896829 s: SCICLIENT: Init ... !!! [C6x_1 ] 3.897031 s: SCICLIENT: DMSC FW version [8.6.3--v08.06.03 (Chill Capybar] [C6x_1 ] 3.897043 s: SCICLIENT: DMSC FW revision 0x8 [C6x_1 ] 3.897052 s: SCICLIENT: DMSC FW ABI revision 3.1 [C6x_1 ] 3.897061 s: SCICLIENT: Init ... Done !!! [C6x_1 ] 3.897071 s: UDMA: Init ... !!! [C6x_1 ] 3.898530 s: UDMA: Init ... Done !!! [C6x_1 ] 3.898548 s: MEM: Init ... !!! [C6x_1 ] 3.898562 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ dc000000 of size 16777216 bytes !!! [C6x_1 ] 3.898579 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 800000 of size 229376 bytes !!! [C6x_1 ] 3.898594 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ dd000000 of size 50331648 bytes !!! [C6x_1 ] 3.898610 s: MEM: Init ... Done !!! [C6x_1 ] 3.898618 s: IPC: Init ... !!! [C6x_1 ] 3.898639 s: IPC: 6 CPUs participating in IPC !!! [C6x_1 ] 3.898652 s: IPC: Waiting for HLOS to be ready ... !!! [C6x_1 ] 13.999000 s: IPC: HLOS is ready !!! [C6x_1 ] 14.002773 s: IPC: Init ... Done !!! [C6x_1 ] 14.002801 s: APP: Syncing with 5 CPUs ... !!! [C6x_1 ] 14.176741 s: APP: Syncing with 5 CPUs ... Done !!! [C6x_1 ] 14.176753 s: REMOTE_SERVICE: Init ... !!! [C6x_1 ] 14.177440 s: REMOTE_SERVICE: Init ... Done !!! [C6x_1 ] 14.177475 s: VX_ZONE_INIT:Enabled [C6x_1 ] 14.177485 s: VX_ZONE_ERROR:Enabled [C6x_1 ] 14.177495 s: VX_ZONE_WARNING:Enabled [C6x_1 ] 14.178331 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!! [C6x_1 ] 14.178345 s: APP: OpenVX Target kernel init ... !!! [C6x_1 ] 14.178613 s: APP: OpenVX Target kernel init ... Done !!! [C6x_1 ] 14.178628 s: UDMA Copy: Init ... !!! [C6x_1 ] 14.182873 s: UDMA Copy: Init ... Done !!! [C6x_1 ] 14.182894 s: APP: Init ... Done !!! [C6x_1 ] 14.182903 s: APP: Run ... !!! [C6x_1 ] 14.182911 s: IPC: Starting echo test ... [C6x_1 ] 14.184034 s: APP: Run ... Done !!! [C6x_1 ] 14.184348 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[s] C66X_2[x] C7X_1[P] [C6x_1 ] 14.184992 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[s] C66X_2[P] C7X_1[P] [C6x_1 ] 14.203139 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C66X_1[s] C66X_2[P] C7X_1[P] [C6x_1 ] 14.248821 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] C66X_1[s] C66X_2[P] C7X_1[P] [C6x_2 ] 3.981735 s: CIO: Init ... Done !!! [C6x_2 ] 3.981760 s: ### CPU Frequency = 1350000000 Hz [C6x_2 ] 3.981769 s: CPU is running FreeRTOS [C6x_2 ] 3.981777 s: APP: Init ... !!! [C6x_2 ] 3.981785 s: SCICLIENT: Init ... !!! [C6x_2 ] 3.982004 s: SCICLIENT: DMSC FW version [8.6.3--v08.06.03 (Chill Capybar] [C6x_2 ] 3.982019 s: SCICLIENT: DMSC FW revision 0x8 [C6x_2 ] 3.982030 s: SCICLIENT: DMSC FW ABI revision 3.1 [C6x_2 ] 3.982040 s: SCICLIENT: Init ... Done !!! [C6x_2 ] 3.982052 s: UDMA: Init ... !!! [C6x_2 ] 3.983563 s: UDMA: Init ... Done !!! [C6x_2 ] 3.983582 s: MEM: Init ... !!! [C6x_2 ] 3.983594 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ e0000000 of size 16777216 bytes !!! [C6x_2 ] 3.983611 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 800000 of size 229376 bytes !!! [C6x_2 ] 3.983626 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ e1000000 of size 50331648 bytes !!! [C6x_2 ] 3.983643 s: MEM: Init ... Done !!! [C6x_2 ] 3.983650 s: IPC: Init ... !!! [C6x_2 ] 3.983672 s: IPC: 6 CPUs participating in IPC !!! [C6x_2 ] 3.983685 s: IPC: Waiting for HLOS to be ready ... !!! [C6x_2 ] 14.156099 s: IPC: HLOS is ready !!! [C6x_2 ] 14.160479 s: IPC: Init ... Done !!! [C6x_2 ] 14.160508 s: APP: Syncing with 5 CPUs ... !!! [C6x_2 ] 14.176741 s: APP: Syncing with 5 CPUs ... Done !!! [C6x_2 ] 14.176754 s: REMOTE_SERVICE: Init ... !!! [C6x_2 ] 14.177456 s: REMOTE_SERVICE: Init ... Done !!! [C6x_2 ] 14.177490 s: VX_ZONE_INIT:Enabled [C6x_2 ] 14.177500 s: VX_ZONE_ERROR:Enabled [C6x_2 ] 14.177519 s: VX_ZONE_WARNING:Enabled [C6x_2 ] 14.178344 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!! [C6x_2 ] 14.178359 s: APP: OpenVX Target kernel init ... !!! [C6x_2 ] 14.178625 s: APP: OpenVX Target kernel init ... Done !!! [C6x_2 ] 14.178640 s: UDMA Copy: Init ... !!! [C6x_2 ] 14.183363 s: UDMA Copy: Init ... Done !!! [C6x_2 ] 14.183386 s: APP: Init ... Done !!! [C6x_2 ] 14.183395 s: APP: Run ... !!! [C6x_2 ] 14.183403 s: IPC: Starting echo test ... [C6x_2 ] 14.184625 s: APP: Run ... Done !!! [C6x_2 ] 14.184928 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[s] C7X_1[.] [C6x_2 ] 14.184990 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[s] C7X_1[P] [C6x_2 ] 14.203163 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C66X_1[P] C66X_2[s] C7X_1[P] [C6x_2 ] 14.248864 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] C66X_1[P] C66X_2[s] C7X_1[P] [C7x_1 ] 4.201587 s: CIO: Init ... Done !!! [C7x_1 ] 4.201601 s: ### CPU Frequency = 1000000000 Hz [C7x_1 ] 4.201612 s: CPU is running FreeRTOS [C7x_1 ] 4.201620 s: APP: Init ... !!! [C7x_1 ] 4.201628 s: SCICLIENT: Init ... !!! [C7x_1 ] 4.201834 s: SCICLIENT: DMSC FW version [8.6.3--v08.06.03 (Chill Capybar] [C7x_1 ] 4.201848 s: SCICLIENT: DMSC FW revision 0x8 [C7x_1 ] 4.201858 s: SCICLIENT: DMSC FW ABI revision 3.1 [C7x_1 ] 4.201869 s: SCICLIENT: Init ... Done !!! [C7x_1 ] 4.201878 s: UDMA: Init ... !!! [C7x_1 ] 4.203017 s: UDMA: Init ... Done !!! [C7x_1 ] 4.203029 s: MEM: Init ... !!! [C7x_1 ] 4.203040 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ 117000000 of size 268435456 bytes !!! [C7x_1 ] 4.203059 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000001) @ 70020000 of size 8159232 bytes !!! [C7x_1 ] 4.203077 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 64800000 of size 458752 bytes !!! [C7x_1 ] 4.203095 s: MEM: Created heap (L1_MEM, id=3, flags=0x00000001) @ 64e00000 of size 16384 bytes !!! [C7x_1 ] 4.203112 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ 100000000 of size 385875968 bytes !!! [C7x_1 ] 4.203130 s: MEM: Init ... Done !!! [C7x_1 ] 4.203138 s: IPC: Init ... !!! [C7x_1 ] 4.203152 s: IPC: 6 CPUs participating in IPC !!! [C7x_1 ] 4.203164 s: IPC: Waiting for HLOS to be ready ... !!! [C7x_1 ] 14.174475 s: IPC: HLOS is ready !!! [C7x_1 ] 14.176710 s: IPC: Init ... Done !!! [C7x_1 ] 14.176726 s: APP: Syncing with 5 CPUs ... !!! [C7x_1 ] 14.176740 s: APP: Syncing with 5 CPUs ... Done !!! [C7x_1 ] 14.176751 s: REMOTE_SERVICE: Init ... !!! [C7x_1 ] 14.176900 s: REMOTE_SERVICE: Init ... Done !!! [C7x_1 ] 14.176922 s: VX_ZONE_INIT:Enabled [C7x_1 ] 14.176933 s: VX_ZONE_ERROR:Enabled [C7x_1 ] 14.176943 s: VX_ZONE_WARNING:Enabled [C7x_1 ] 14.177113 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1 [C7x_1 ] 14.177209 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_2 [C7x_1 ] 14.177315 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_3 [C7x_1 ] 14.177388 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_4 [C7x_1 ] 14.177467 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_5 [C7x_1 ] 14.177543 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_6 [C7x_1 ] 14.177659 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_7 [C7x_1 ] 14.177730 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_8 [C7x_1 ] 14.177753 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!! [C7x_1 ] 14.177765 s: APP: OpenVX Target kernel init ... !!! [C7x_1 ] 14.177906 s: APP: OpenVX Target kernel init ... Done !!! [C7x_1 ] 14.177922 s: APP: Init ... Done !!! [C7x_1 ] 14.177931 s: APP: Run ... !!! [C7x_1 ] 14.177939 s: IPC: Starting echo test ... [C7x_1 ] 14.178115 s: APP: Run ... Done !!! [C7x_1 ] 14.184353 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[x] C7X_1[s] [C7x_1 ] 14.184987 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[P] C7X_1[s] [C7x_1 ] 14.203188 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[s] [C7x_1 ] 14.248898 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[s] [C7x_1 ] 725.686493 s: VX_ZONE_ERROR:[tivxAlgiVisionCreate:335] Calling ialg.algInit failed with status = -1111 [C7x_1 ] 725.686534 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:720] tivxAlgiVisionCreate returned NULL [C7x_1 ] 727.113840 s: VX_ZONE_ERROR:[tivxAlgiVisionCreate:335] Calling ialg.algInit failed with status = -1111 [C7x_1 ] 727.113885 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:720] tivxAlgiVisionCreate returned NULL [C7x_1 ] 727.239568 s: VX_ZONE_ERROR:[tivxAlgiVisionCreate:335] Calling ialg.algInit failed with status = -1111 [C7x_1 ] 727.239612 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:720] tivxAlgiVisionCreate returned NULL [C7x_1 ] 727.356119 s: VX_ZONE_ERROR:[tivxAlgiVisionCreate:335] Calling ialg.algInit failed with status = -1111 [C7x_1 ] 727.356167 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:720] tivxAlgiVisionCreate returned NULL [C7x_1 ] 727.467981 s: VX_ZONE_ERROR:[tivxAlgiVisionCreate:335] Calling ialg.algInit failed with status = -1111 [C7x_1 ] 727.468025 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:720] tivxAlgiVisionCreate returned NULL [C7x_1 ] 727.583755 s: VX_ZONE_ERROR:[tivxAlgiVisionCreate:335] Calling ialg.algInit failed with status = -1111 [C7x_1 ] 727.583798 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:720] tivxAlgiVisionCreate returned NULL [C7x_1 ] 727.699241 s: VX_ZONE_ERROR:[tivxAlgiVisionCreate:335] Calling ialg.algInit failed with status = -1111 [C7x_1 ] 727.699284 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:720] tivxAlgiVisionCreate returned NULL [C7x_1 ] 727.809704 s: VX_ZONE_ERROR:[tivxAlgiVisionCreate:335] Calling ialg.algInit failed with status = -1111 [C7x_1 ] 727.809747 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:720] tivxAlgiVisionCreate returned NULL [C7x_1 ] 727.921666 s: VX_ZONE_ERROR:[tivxAlgiVisionCreate:335] Calling ialg.algInit failed with status = -1111 [C7x_1 ] 727.921729 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:720] tivxAlgiVisionCreate returned NULL [C7x_1 ] 728.032851 s: VX_ZONE_ERROR:[tivxAlgiVisionCreate:335] Calling ialg.algInit failed with status = -1111 [C7x_1 ] 728.032893 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:720] tivxAlgiVisionCreate returned NULL [C7x_1 ] 728.150061 s: VX_ZONE_ERROR:[tivxAlgiVisionCreate:335] Calling ialg.algInit failed with status = -1111 [C7x_1 ] 728.150103 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:720] tivxAlgiVisionCreate returned NULL [C7x_1 ] 728.268806 s: VX_ZONE_ERROR:[tivxAlgiVisionCreate:335] Calling ialg.algInit failed with status = -1111 [C7x_1 ] 728.268848 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:720] tivxAlgiVisionCreate returned NULL [C7x_1 ] 728.382708 s: VX_ZONE_ERROR:[tivxAlgiVisionCreate:335] Calling ialg.algInit failed with status = -1111 [C7x_1 ] 728.382751 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:720] tivxAlgiVisionCreate returned NULL [C7x_1 ] 728.493102 s: VX_ZONE_ERROR:[tivxAlgiVisionCreate:335] Calling ialg.algInit failed with status = -1111 [C7x_1 ] 728.493144 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:720] tivxAlgiVisionCreate returned NULL [C7x_1 ] 728.607624 s: VX_ZONE_ERROR:[tivxAlgiVisionCreate:335] Calling ialg.algInit failed with status = -1111 [C7x_1 ] 728.607667 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:720] tivxAlgiVisionCreate returned NULL [C7x_1 ] 728.718898 s: VX_ZONE_ERROR:[tivxAlgiVisionCreate:335] Calling ialg.algInit failed with status = -1111 [C7x_1 ] 728.718945 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:720] tivxAlgiVisionCreate returned NULL [C7x_1 ] 728.832450 s: VX_ZONE_ERROR:[tivxAlgiVisionCreate:335] Calling ialg.algInit failed with status = -1111 [C7x_1 ] 728.832493 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:720] tivxAlgiVisionCreate returned NULL [C7x_1 ] 728.948319 s: VX_ZONE_ERROR:[tivxAlgiVisionCreate:335] Calling ialg.algInit failed with status = -1111 [C7x_1 ] 728.948362 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:720] tivxAlgiVisionCreate returned NULL [C7x_1 ] 729.071621 s: VX_ZONE_ERROR:[tivxAlgiVisionCreate:335] Calling ialg.algInit failed with status = -1111 [C7x_1 ] 729.071664 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:720] tivxAlgiVisionCreate returned NULL [C7x_1 ] 729.189132 s: VX_ZONE_ERROR:[tivxAlgiVisionCreate:335] Calling ialg.algInit failed with status = -1111 [C7x_1 ] 729.189175 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:720] tivxAlgiVisionCreate returned NULL [C7x_1 ] 729.301339 s: VX_ZONE_ERROR:[tivxAlgiVisionCreate:335] Calling ialg.algInit failed with status = -1111 [C7x_1 ] 729.301381 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:720] tivxAlgiVisionCreate returned NULL [C7x_1 ] 729.413117 s: VX_ZONE_ERROR:[tivxAlgiVisionCreate:335] Calling ialg.algInit failed with status = -1111 [C7x_1 ] 729.413161 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:720] tivxAlgiVisionCreate returned NULL [C7x_1 ] 729.533012 s: VX_ZONE_ERROR:[tivxAlgiVisionCreate:335] Calling ialg.algInit failed with status = -1111 [C7x_1 ] 729.533055 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:720] tivxAlgiVisionCreate returned NULL [C7x_1 ] 729.643293 s: VX_ZONE_ERROR:[tivxAlgiVisionCreate:335] Calling ialg.algInit failed with status = -1111 [C7x_1 ] 729.643337 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:720] tivxAlgiVisionCreate returned NULL [C7x_1 ] 729.753665 s: VX_ZONE_ERROR:[tivxAlgiVisionCreate:335] Calling ialg.algInit failed with status = -1111 [C7x_1 ] 729.753708 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:720] tivxAlgiVisionCreate returned NULL [C7x_1 ] 729.863360 s: VX_ZONE_ERROR:[tivxAlgiVisionCreate:335] Calling ialg.algInit failed with status = -1111 [C7x_1 ] 729.863403 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:720] tivxAlgiVisionCreate returned NULL [C7x_1 ] 729.971850 s: VX_ZONE_ERROR:[tivxAlgiVisionCreate:335] Calling ialg.algInit failed with status = -1111 [C7x_1 ] 729.971893 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:720] tivxAlgiVisionCreate returned NULL [C7x_1 ] 730.082453 s: VX_ZONE_ERROR:[tivxAlgiVisionCreate:335] Calling ialg.algInit failed with status = -1111 [C7x_1 ] 730.082507 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:720] tivxAlgiVisionCreate returned NULL [C7x_1 ] 730.192937 s: VX_ZONE_ERROR:[tivxAlgiVisionCreate:335] Calling ialg.algInit failed with status = -1111 [C7x_1 ] 730.192979 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:720] tivxAlgiVisionCreate returned NULL [C7x_1 ] 730.303218 s: VX_ZONE_ERROR:[tivxAlgiVisionCreate:335] Calling ialg.algInit failed with status = -1111 [C7x_1 ] 730.303260 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:720] tivxAlgiVisionCreate returned NULL [C7x_1 ] 730.412975 s: VX_ZONE_ERROR:[tivxAlgiVisionCreate:335] Calling ialg.algInit failed with status = -1111 [C7x_1 ] 730.413025 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:720] tivxAlgiVisionCreate returned NULL [C7x_1 ] 730.525148 s: VX_ZONE_ERROR:[tivxAlgiVisionCreate:335] Calling ialg.algInit failed with status = -1111 [C7x_1 ] 730.525190 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:720] tivxAlgiVisionCreate returned NULL [C7x_1 ] 730.634794 s: VX_ZONE_ERROR:[tivxAlgiVisionCreate:335] Calling ialg.algInit failed with status = -1111 [C7x_1 ] 730.634834 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:720] tivxAlgiVisionCreate returned NULL [C7x_1 ] 730.741309 s: VX_ZONE_ERROR:[tivxAlgiVisionCreate:335] Calling ialg.algInit failed with status = -1111 [C7x_1 ] 730.741351 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:720] tivxAlgiVisionCreate returned NULL [C7x_1 ] 730.854361 s: VX_ZONE_ERROR:[tivxAlgiVisionCreate:335] Calling ialg.algInit failed with status = -1111 [C7x_1 ] 730.854404 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:720] tivxAlgiVisionCreate returned NULL [C7x_1 ] 730.962249 s: VX_ZONE_ERROR:[tivxAlgiVisionCreate:335] Calling ialg.algInit failed with status = -1111 [C7x_1 ] 730.962292 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:720] tivxAlgiVisionCreate returned NULL [C7x_1 ] 731.071067 s: VX_ZONE_ERROR:[tivxAlgiVisionCreate:335] Calling ialg.algInit failed with status = -1111 [C7x_1 ] 731.071110 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:720] tivxAlgiVisionCreate returned NULL [C7x_1 ] 731.181895 s: VX_ZONE_ERROR:[tivxAlgiVisionCreate:335] Calling ialg.algInit failed with status = -1111 [C7x_1 ] 731.181946 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:720] tivxAlgiVisionCreate returned NULL [C7x_1 ] 731.292949 s: VX_ZONE_ERROR:[tivxAlgiVisionCreate:335] Calling ialg.algInit failed with status = -1111 [C7x_1 ] 731.292992 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:720] tivxAlgiVisionCreate returned NULL [C7x_1 ] 731.404127 s: VX_ZONE_ERROR:[tivxAlgiVisionCreate:335] Calling ialg.algInit failed with status = -1111 [C7x_1 ] 731.404169 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:720] tivxAlgiVisionCreate returned NULL [C7x_1 ] 731.516699 s: VX_ZONE_ERROR:[tivxAlgiVisionCreate:335] Calling ialg.algInit failed with status = -1111 [C7x_1 ] 731.516742 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:720] tivxAlgiVisionCreate returned NULL [C7x_1 ] 731.634967 s: VX_ZONE_ERROR:[tivxAlgiVisionCreate:335] Calling ialg.algInit failed with status = -1111 [C7x_1 ] 731.635009 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:720] tivxAlgiVisionCreate returned NULL [C7x_1 ] 731.744633 s: VX_ZONE_ERROR:[tivxAlgiVisionCreate:335] Calling ialg.algInit failed with status = -1111 [C7x_1 ] 731.744681 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:720] tivxAlgiVisionCreate returned NULL [C7x_1 ] 731.860194 s: VX_ZONE_ERROR:[tivxAlgiVisionCreate:335] Calling ialg.algInit failed with status = -1111 [C7x_1 ] 731.860235 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:720] tivxAlgiVisionCreate returned NULL [C7x_1 ] 731.978551 s: VX_ZONE_ERROR:[tivxAlgiVisionCreate:335] Calling ialg.algInit failed with status = -1111 [C7x_1 ] 731.978603 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:720] tivxAlgiVisionCreate returned NULL [C7x_1 ] 732.093718 s: VX_ZONE_ERROR:[tivxAlgiVisionCreate:335] Calling ialg.algInit failed with status = -1111 [C7x_1 ] 732.093759 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:720] tivxAlgiVisionCreate returned NULL [C7x_1 ] 732.209358 s: VX_ZONE_ERROR:[tivxAlgiVisionCreate:335] Calling ialg.algInit failed with status = -1111 [C7x_1 ] 732.209400 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:720] tivxAlgiVisionCreate returned NULL [C7x_1 ] 732.324079 s: VX_ZONE_ERROR:[tivxAlgiVisionCreate:335] Calling ialg.algInit failed with status = -1111 [C7x_1 ] 732.324120 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:720] tivxAlgiVisionCreate returned NULL [C7x_1 ] 732.434653 s: VX_ZONE_ERROR:[tivxAlgiVisionCreate:335] Calling ialg.algInit failed with status = -1111 [C7x_1 ] 732.434696 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:720] tivxAlgiVisionCreate returned NULL [C7x_1 ] 732.545172 s: VX_ZONE_ERROR:[tivxAlgiVisionCreate:335] Calling ialg.algInit failed with status = -1111 [C7x_1 ] 732.545225 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:720] tivxAlgiVisionCreate returned NULL [C7x_1 ] 732.654613 s: VX_ZONE_ERROR:[tivxAlgiVisionCreate:335] Calling ialg.algInit failed with status = -1111 [C7x_1 ] 732.654655 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:720] tivxAlgiVisionCreate returned NULL [C7x_1 ] 732.768078 s: VX_ZONE_ERROR:[tivxAlgiVisionAllocMem:194] Failed to Allocate memory record 5 @ space = 17 and size = 1575056 !!! [C7x_1 ] 732.768105 s: VX_ZONE_ERROR:[tivxAlgiVisionCreate:358] tivxAlgiVisionAllocMem Failed [C7x_1 ] 732.768129 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:720] tivxAlgiVisionCreate returned NULL [C7x_1 ] 732.878960 s: VX_ZONE_ERROR:[tivxAlgiVisionAllocMem:194] Failed to Allocate memory record 5 @ space = 17 and size = 1575056 !!! [C7x_1 ] 732.878995 s: VX_ZONE_ERROR:[tivxAlgiVisionCreate:358] tivxAlgiVisionAllocMem Failed [C7x_1 ] 732.879022 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:720] tivxAlgiVisionCreate returned NULL [C7x_1 ] 732.987361 s: VX_ZONE_ERROR:[tivxAlgiVisionAllocMem:194] Failed to Allocate memory record 5 @ space = 17 and size = 1575056 !!! [C7x_1 ] 732.987390 s: VX_ZONE_ERROR:[tivxAlgiVisionCreate:358] tivxAlgiVisionAllocMem Failed [C7x_1 ] 732.987413 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:720] tivxAlgiVisionCreate returned NULL [C7x_1 ] 733.099891 s: VX_ZONE_ERROR:[tivxAlgiVisionAllocMem:194] Failed to Allocate memory record 5 @ space = 17 and size = 1575056 !!! [C7x_1 ] 733.099919 s: VX_ZONE_ERROR:[tivxAlgiVisionCreate:358] tivxAlgiVisionAllocMem Failed [C7x_1 ] 733.099943 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:720] tivxAlgiVisionCreate returned NULL [C7x_1 ] 733.216216 s: VX_ZONE_ERROR:[tivxAlgiVisionAllocMem:194] Failed to Allocate memory record 5 @ space = 17 and size = 1575056 !!! [C7x_1 ] 733.216245 s: VX_ZONE_ERROR:[tivxAlgiVisionCreate:358] tivxAlgiVisionAllocMem Failed [C7x_1 ] 733.216268 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:720] tivxAlgiVisionCreate returned NULL [C7x_1 ] 733.332118 s: VX_ZONE_ERROR:[tivxAlgiVisionAllocMem:194] Failed to Allocate memory record 5 @ space = 17 and size = 1575056 !!! [C7x_1 ] 733.332147 s: VX_ZONE_ERROR:[tivxAlgiVisionCreate:358] tivxAlgiVisionAllocMem Failed [C7x_1 ] 733.332171 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:720] tivxAlgiVisionCreate returned NULL [C7x_1 ] 733.444208 s: VX_ZONE_ERROR:[tivxAlgiVisionAllocMem:194] Failed to Allocate memory record 5 @ space = 17 and size = 1575056 !!! [C7x_1 ] 733.444238 s: VX_ZONE_ERROR:[tivxAlgiVisionCreate:358] tivxAlgiVisionAllocMem Failed [C7x_1 ] 733.444269 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:720] tivxAlgiVisionCreate returned NULL [C7x_1 ] 733.556846 s: VX_ZONE_ERROR:[tivxAlgiVisionAllocMem:194] Failed to Allocate memory record 5 @ space = 17 and size = 1575056 !!! [C7x_1 ] 733.556874 s: VX_ZONE_ERROR:[tivxAlgiVisionCreate:358] tivxAlgiVisionAllocMem Failed [C7x_1 ] 733.556898 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:720] tivxAlgiVisionCreate returned NULL [C7x_1 ] 733.669893 s: VX_ZONE_ERROR:[tivxAlgiVisionAllocMem:194] Failed to Allocate memory record 5 @ space = 17 and size = 1575056 !!! [C7x_1 ] 733.669921 s: VX_ZONE_ERROR:[tivxAlgiVisionCreate:358] tivxAlgiVisionAllocMem Failed0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 [C7x_1 ] 12079.927101 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:705] Network version - 0x20211201, Expected version - 0x20230208 [C7x_1 ] 12079.974571 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:705] Network version - 0x20211201, Expected version - 0x20230208 [C7x_1 ] 12079.974571 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:705] Network version - 0x20211201, Expected version - 0x20230208 [C7x_1 ] 12080.026626 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:705] Network version - 0x20211201, Expected version - 0x20230208 [C7x_1 ] 12080.026626 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:705] Network version - 0x20211201, Expected version - 0x20230208 [C7x_1 ] 12080.071296 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:705] Network version - 0x20211201, Expected version - 0x20230208 [C7x_1 ] 12080.071296 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:705] Network version - 0x20211201, Expected version - 0x20230208 [C7x_1 ] 12080.117696 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:705] Network version - 0x20211201, Expected version - 0x20230208 [C7x_1 ] 12080.163546 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:705] Network version - 0x20211201, Expected version - 0x20230208 [C7x_1 ] 12080.211576 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:705] Network version - 0x20211201, Expected version - 0x20230208 [C7x_1 ] 12080.259561 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:705] Network version - 0x20211201, Expected version - 0x20230208 [C7x_1 ] 12080.259561 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:705] Network version - 0x20211201, Expected version - 0x20230208 [C7x_1 ] 12080.303639 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:705] Network version - 0x20211201, Expected version - 0x20230208 [C7x_1 ] 12080.303639 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:705] Network version - 0x20211201, Expected version - 0x20230208 [C7x_1 ] 12080.350825 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:705] Network version - 0x20211201, Expected version - 0x20230208 [C7x_1 ] 12080.350825 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:705] Network version - 0x20211201, Expected version - 0x20230208 [C7x_1 ] 12080.395019 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:705] Network version - 0x20211201, Expected version - 0x20230208 [C7x_1 ] 12080.395019 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:705] Network version - 0x20211201, Expected version - 0x20230208 [C7x_1 ] 12080.447273 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:705] Network version - 0x20211201, Expected version - 0x20230208 [C7x_1 ] 12080.447273 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:705] Network version - 0x20211201, Expected version - 0x20230208
From above link, I did encounter an version mismatch error as follows:
[C7x_1 ] 149.776057 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:705] Network version - 0x20221206, Expected version - 0x20230208
After downgrade SDK to https://www.ti.com/tool/download/PROCESSOR-SDK-LINUX-SK-TDA4VM/08.05.00.03 (0x20221206), the version mismatch error is solved, but there are still error as follows:
[07:58:02.000.000000]:ERROR:[getConfig:0147] Mean value specification missing. [07:58:02.000.000000]:ERROR:[initialize:1437] getConfig() failed. [07:58:02.000.000536]:ERROR:[getConfig:0147] Mean value specification missing. (app_edgeai:1225): GLib-GObject-WARNING **: 07:58:02.264: value "((GstTIOVXDLPreProcDataType) 0)" of type 'GstTIOVXDLPreProcDataType' is invalid or out of range for property 'data-type' of type 'GstTIOVXDLPreProcDataType' [07:58:02.019.019185]:ERROR:[makePostprocessImageObj:0088] Invalid post-processing task type. [07:58:02.019.019237]:ERROR:[createPostprocCntxt:1571] PostprocessImage::makePostprocessImageObj() failed. [07:58:02.019.019250]:ERROR:[initialize:1857] createPostprocCntxt() failed. Segmentation fault (core dumped)
Also, running ./vx_app_arm_remote_log.out & gave same error.
Logs:
without ./vx_app_arm_remote_log.out:
cd /opt/edge_ai_apps/apps_cpp root@tda4vm-sk:/opt/edge_ai_apps/apps_cpp# ./bin/Release/app_edgeai ../configs/single_input_multi_infer.yaml libtidl_onnxrt_EP loaded 0x115d0ae0 Final number of subgraphs created are : 1, - Offloaded Nodes - 320, Total Nodes - 320 APP: Init ... !!! MEM: Init ... !!! MEM: Initialized DMA HEAP (fd=4) !!! MEM: Init ... Done !!! IPC: Init ... !!! IPC: Init ... Done !!! REMOTE_SERVICE: Init ... !!! REMOTE_SERVICE: Init ... Done !!! 101.577654 s: GTC Frequency = 200 MHz APP: Init ... Done !!! 101.582418 s: VX_ZONE_INIT:Enabled 101.582448 s: VX_ZONE_ERROR:Enabled 101.582454 s: VX_ZONE_WARNING:Enabled 101.583556 s: VX_ZONE_INIT:[tivxInitLocal:145] Initialization Done !!! 101.584717 s: VX_ZONE_INIT:[tivxHostInitLocal:93] Initialization Done for HOST !!! [07:58:07.000.000000]:ERROR:[getConfig:0147] Mean value specification missing. [07:58:07.000.000000]:ERROR:[initialize:1437] getConfig() failed. [07:58:07.000.000528]:ERROR:[getConfig:0147] Mean value specification missing. (app_edgeai:1227): GLib-GObject-WARNING **: 07:58:07.400: value "((GstTIOVXDLPreProcDataType) 0)" of type 'GstTIOVXDLPreProcDataType' is invalid or out of range for property 'data-type' of type 'GstTIOVXDLPreProcDataType' [07:58:07.022.022296]:ERROR:[makePostprocessImageObj:0088] Invalid post-processing task type. [07:58:07.022.022345]:ERROR:[createPostprocCntxt:1571] PostprocessImage::makePostprocessImageObj() failed. [07:58:07.022.022358]:ERROR:[initialize:1857] createPostprocCntxt() failed. Segmentation fault (core dumped) root@tda4vm-sk:/opt/edge_ai_apps/apps_cpp#
with ./vx_app_arm_remote_log.out:
root@tda4vm-sk:/opt/edge_ai_apps/apps_cpp# ./bin/Release/app_edgeai ../configs/single_input_multi_infer.yaml libtidl_onnxrt_EP loaded 0x239baae0 Final number of subgraphs created are : 1, - Offloaded Nodes - 320, Total Nodes - 320 APP: Init ... !!! MEM: Init ... !!! MEM: Initialized DMA HEAP (fd=4) !!! MEM: Init ... Done !!! IPC: Init ... !!! IPC: Init ... Done !!! REMOTE_SERVICE: Init ... !!! REMOTE_SERVICE: Init ... Done !!! 96.969500 s: GTC Frequency = 200 MHz APP: Init ... Done !!! 96.974270 s: VX_ZONE_INIT:Enabled 96.974298 s: VX_ZONE_ERROR:Enabled 96.974303 s: VX_ZONE_WARNING:Enabled 96.975335 s: VX_ZONE_INIT:[tivxInitLocal:145] Initialization Done !!! 96.976640 s: VX_ZONE_INIT:[tivxHostInitLocal:93] Initialization Done for HOST !!! [07:58:02.000.000000]:ERROR:[getConfig:0147] Mean value specification missing. [07:58:02.000.000000]:ERROR:[initialize:1437] getConfig() failed. [07:58:02.000.000536]:ERROR:[getConfig:0147] Mean value specification missing. (app_edgeai:1225): GLib-GObject-WARNING **: 07:58:02.264: value "((GstTIOVXDLPreProcDataType) 0)" of type 'GstTIOVXDLPreProcDataType' is invalid or out of range for property 'data-type' of type 'GstTIOVXDLPreProcDataType' [07:58:02.019.019185]:ERROR:[makePostprocessImageObj:0088] Invalid post-processing task type. [07:58:02.019.019237]:ERROR:[createPostprocCntxt:1571] PostprocessImage::makePostprocessImageObj() failed. [07:58:02.019.019250]:ERROR:[initialize:1857] createPostprocCntxt() failed. Segmentation fault (core dumped) root@tda4vm-sk:/opt/edge_ai_apps/apps_cpp#
log of ./vx_app_arm_remote_log.out:
root@tda4vm-sk:/opt/vision_apps# ./vx_app_arm_remote_log.out & [1] 1223 root@tda4vm-sk:/opt/vision_apps# [MCU2_0] 4.206037 s: CIO: Init ... Done !!! [MCU2_0] 4.206104 s: ### CPU Frequency = 1000000000 Hz [MCU2_0] 4.206145 s: CPU is running FreeRTOS [MCU2_0] 4.206171 s: APP: Init ... !!! [MCU2_0] 4.206195 s: SCICLIENT: Init ... !!! [MCU2_0] 4.206461 s: SCICLIENT: DMSC FW version [8.5.2--v08.05.02 (Chill Capybar] [MCU2_0] 4.206510 s: SCICLIENT: DMSC FW revision 0x8 [MCU2_0] 4.206558 s: SCICLIENT: DMSC FW ABI revision 3.1 [MCU2_0] 4.206598 s: SCICLIENT: Init ... Done !!! [MCU2_0] 4.206626 s: UDMA: Init ... !!! [MCU2_0] 4.208139 s: UDMA: Init ... Done !!! [MCU2_0] 4.208197 s: MEM: Init ... !!! [MCU2_0] 4.208239 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ d9000000 of size 16777216 bytes !!! [MCU2_0] 4.208314 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000000) @ 3600000 of size 262144 bytes !!! [MCU2_0] 4.208374 s: MEM: Init ... Done !!! [MCU2_0] 4.208400 s: IPC: Init ... !!! [MCU2_0] 4.208460 s: IPC: 6 CPUs participating in IPC !!! [MCU2_0] 4.208508 s: IPC: Waiting for HLOS to be ready ... !!! [MCU2_0] 15.839688 s: IPC: HLOS is ready !!! [MCU2_0] 15.855033 s: IPC: Init ... Done !!! [MCU2_0] 15.855099 s: APP: Syncing with 5 CPUs ... !!! [MCU2_0] 16.098122 s: APP: Syncing with 5 CPUs ... Done !!! [MCU2_0] 16.098363 s: REMOTE_SERVICE: Init ... !!! [MCU2_0] 16.099922 s: REMOTE_SERVICE: Init ... Done !!! [MCU2_0] 16.099984 s: FVID2: Init ... !!! [MCU2_0] 16.100051 s: FVID2: Init ... Done !!! [MCU2_0] 16.100085 s: VHWA: VPAC Init ... !!! [MCU2_0] 16.100111 s: SCICLIENT: Sciclient_pmSetModuleState module=290 state=2 [MCU2_0] 16.100588 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 16.100631 s: VHWA: LDC Init ... !!! [MCU2_0] 16.107768 s: VHWA: LDC Init ... Done !!! [MCU2_0] 16.107831 s: VHWA: MSC Init ... !!! [MCU2_0] 16.122703 s: VHWA: MSC Init ... Done !!! [MCU2_0] 16.122762 s: VHWA: NF Init ... !!! [MCU2_0] 16.124722 s: VHWA: NF Init ... Done !!! [MCU2_0] 16.124782 s: VHWA: VISS Init ... !!! [MCU2_0] 16.135668 s: VHWA: VISS Init ... Done !!! [MCU2_0] 16.135732 s: VHWA: VPAC Init ... Done !!! [MCU2_0] 16.135779 s: VX_ZONE_INIT:Enabled [MCU2_0] 16.135809 s: VX_ZONE_ERROR:Enabled [MCU2_0] 16.135836 s: VX_ZONE_WARNING:Enabled [MCU2_0] 16.137010 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target MCU2-0 [MCU2_0] 16.137248 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_NF [MCU2_0] 16.137466 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_LDC1 [MCU2_0] 16.137694 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_MSC1 [MCU2_0] 16.137909 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_MSC2 [MCU2_0] 16.138218 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_VISS1 [MCU2_0] 16.138483 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE1 [MCU2_0] 16.138746 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE2 [MCU2_0] 16.138994 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DISPLAY1 [MCU2_0] 16.139253 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DISPLAY2 [MCU2_0] 16.139479 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CSITX [MCU2_0] 16.139764 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE3 [MCU2_0] 16.140027 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE4 [MCU2_0] 16.140277 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE5 [MCU2_0] 16.140521 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE6 [MCU2_0] 16.140787 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE7 [MCU2_0] 16.141045 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE8 [MCU2_0] 16.141282 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DSS_M2M1 [MCU2_0] 16.141502 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DSS_M2M2 [MCU2_0] 16.141739 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DSS_M2M3 [MCU2_0] 16.141966 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DSS_M2M4 [MCU2_0] 16.142023 s: VX_ZONE_INIT:[tivxInitLocal:145] Initialization Done !!! [MCU2_0] 16.142061 s: APP: OpenVX Target kernel init ... !!! [MCU2_0] 16.161227 s: APP: OpenVX Target kernel init ... Done !!! [MCU2_0] 16.161280 s: VISS REMOTE SERVICE: Init ... !!! [MCU2_0] 16.161358 s: VISS REMOTE SERVICE: Init ... Done !!! [MCU2_0] 16.161396 s: UDMA Copy: Init ... !!! [MCU2_0] 16.163236 s: UDMA Copy: Init ... Done !!! [MCU2_0] 16.163331 s: APP: Init ... Done !!! [MCU2_0] 16.163369 s: APP: Run ... !!! [MCU2_0] 16.163398 s: IPC: Starting echo test ... [MCU2_0] 16.165969 s: APP: Run ... Done !!! [MCU2_0] 16.167439 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[.] C66X_1[P] C66X_2[.] C7X_1[.] [MCU2_0] 16.167566 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] C66X_1[P] C66X_2[.] C7X_1[.] [MCU2_0] 16.167670 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[.] [MCU2_0] 16.167759 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[P] [MCU2_1] 4.219623 s: CIO: Init ... Done !!! [MCU2_1] 4.219690 s: ### CPU Frequency = 1000000000 Hz [MCU2_1] 4.219731 s: CPU is running FreeRTOS [MCU2_1] 4.219758 s: APP: Init ... !!! [MCU2_1] 4.219781 s: SCICLIENT: Init ... !!! [MCU2_1] 4.220041 s: SCICLIENT: DMSC FW version [8.5.2--v08.05.02 (Chill Capybar] [MCU2_1] 4.220090 s: SCICLIENT: DMSC FW revision 0x8 [MCU2_1] 4.220125 s: SCICLIENT: DMSC FW ABI revision 3.1 [MCU2_1] 4.220175 s: SCICLIENT: Init ... Done !!! [MCU2_1] 4.220205 s: UDMA: Init ... !!! [MCU2_1] 4.221792 s: UDMA: Init ... Done !!! [MCU2_1] 4.221851 s: MEM: Init ... !!! [MCU2_1] 4.221896 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ da000000 of size 16777216 bytes !!! [MCU2_1] 4.221969 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000001) @ 3640000 of size 262144 bytes !!! [MCU2_1] 4.222029 s: MEM: Init ... Done !!! [MCU2_1] 4.222054 s: IPC: Init ... !!! [MCU2_1] 4.222115 s: IPC: 6 CPUs participating in IPC !!! [MCU2_1] 4.222175 s: IPC: Waiting for HLOS to be ready ... !!! [MCU2_1] 16.082711 s: IPC: HLOS is ready !!! [MCU2_1] 16.098005 s: IPC: Init ... Done !!! [MCU2_1] 16.098073 s: APP: Syncing with 5 CPUs ... !!! [MCU2_1] 16.098120 s: APP: Syncing with 5 CPUs ... Done !!! [MCU2_1] 16.098171 s: REMOTE_SERVICE: Init ... !!! [MCU2_1] 16.099963 s: REMOTE_SERVICE: Init ... Done !!! [MCU2_1] 16.100026 s: FVID2: Init ... !!! [MCU2_1] 16.100097 s: FVID2: Init ... Done !!! [MCU2_1] 16.100130 s: VHWA: DMPAC: Init ... !!! [MCU2_1] 16.100169 s: SCICLIENT: Sciclient_pmSetModuleState module=48 state=2 [MCU2_1] 16.100708 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_1] 16.100752 s: SCICLIENT: Sciclient_pmSetModuleState module=305 state=2 [MCU2_1] 16.101168 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_1] 16.101208 s: VHWA: DOF Init ... !!! [MCU2_1] 16.112276 s: VHWA: DOF Init ... Done !!! [MCU2_1] 16.112339 s: VHWA: SDE Init ... !!! [MCU2_1] 16.116338 s: VHWA: SDE Init ... Done !!! [MCU2_1] 16.116399 s: VHWA: DMPAC: Init ... Done !!! [MCU2_1] 16.116444 s: VX_ZONE_INIT:Enabled [MCU2_1] 16.116470 s: VX_ZONE_ERROR:Enabled [MCU2_1] 16.116495 s: VX_ZONE_WARNING:Enabled [MCU2_1] 16.117704 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target MCU2-1 [MCU2_1] 16.117935 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DMPAC_SDE [MCU2_1] 16.118149 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DMPAC_DOF [MCU2_1] 16.118217 s: VX_ZONE_INIT:[tivxInitLocal:145] Initialization Done !!! [MCU2_1] 16.118253 s: APP: OpenVX Target kernel init ... !!! [MCU2_1] 16.118529 s: APP: OpenVX Target kernel init ... Done !!! [MCU2_1] 16.118573 s: UDMA Copy: Init ... !!! [MCU2_1] 16.121301 s: UDMA Copy: Init ... Done !!! [MCU2_1] 16.121370 s: APP: Init ... Done !!! [MCU2_1] 16.121404 s: APP: Run ... !!! [MCU2_1] 16.121430 s: IPC: Starting echo test ... [MCU2_1] 16.123994 s: APP: Run ... Done !!! [MCU2_1] 16.125247 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C66X_1[P] C66X_2[.] C7X_1[.] [MCU2_1] 16.125362 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C66X_1[P] C66X_2[P] C7X_1[.] [MCU2_1] 16.125453 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C66X_1[P] C66X_2[P] C7X_1[P] [MCU2_1] 16.166735 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[s] C66X_1[P] C66X_2[P] C7X_1[P] [C6x_1 ] 4.275076 s: CIO: Init ... Done !!! [C6x_1 ] 4.275101 s: ### CPU Frequency = 1350000000 Hz [C6x_1 ] 4.275112 s: CPU is running FreeRTOS [C6x_1 ] 4.275120 s: APP: Init ... !!! [C6x_1 ] 4.275128 s: SCICLIENT: Init ... !!! [C6x_1 ] 4.275349 s: SCICLIENT: DMSC FW version [8.5.2--v08.05.02 (Chill Capybar] [C6x_1 ] 4.275361 s: SCICLIENT: DMSC FW revision 0x8 [C6x_1 ] 4.275370 s: SCICLIENT: DMSC FW ABI revision 3.1 [C6x_1 ] 4.275380 s: SCICLIENT: Init ... Done !!! [C6x_1 ] 4.275389 s: UDMA: Init ... !!! [C6x_1 ] 4.276963 s: UDMA: Init ... Done !!! [C6x_1 ] 4.276984 s: MEM: Init ... !!! [C6x_1 ] 4.276998 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ dc000000 of size 16777216 bytes !!! [C6x_1 ] 4.277015 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 800000 of size 229376 bytes !!! [C6x_1 ] 4.277030 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ dd000000 of size 50331648 bytes !!! [C6x_1 ] 4.277047 s: MEM: Init ... Done !!! [C6x_1 ] 4.277055 s: IPC: Init ... !!! [C6x_1 ] 4.277075 s: IPC: 6 CPUs participating in IPC !!! [C6x_1 ] 4.277090 s: IPC: Waiting for HLOS to be ready ... !!! [C6x_1 ] 15.175675 s: IPC: HLOS is ready !!! [C6x_1 ] 15.179717 s: IPC: Init ... Done !!! [C6x_1 ] 15.179744 s: APP: Syncing with 5 CPUs ... !!! [C6x_1 ] 16.098120 s: APP: Syncing with 5 CPUs ... Done !!! [C6x_1 ] 16.098138 s: REMOTE_SERVICE: Init ... !!! [C6x_1 ] 16.098792 s: REMOTE_SERVICE: Init ... Done !!! [C6x_1 ] 16.098824 s: VX_ZONE_INIT:Enabled [C6x_1 ] 16.098842 s: VX_ZONE_ERROR:Enabled [C6x_1 ] 16.098855 s: VX_ZONE_WARNING:Enabled [C6x_1 ] 16.099656 s: VX_ZONE_INIT:[tivxInitLocal:145] Initialization Done !!! [C6x_1 ] 16.099671 s: APP: OpenVX Target kernel init ... !!! [C6x_1 ] 16.099938 s: APP: OpenVX Target kernel init ... Done !!! [C6x_1 ] 16.099958 s: UDMA Copy: Init ... !!! [C6x_1 ] 16.104593 s: UDMA Copy: Init ... Done !!! [C6x_1 ] 16.104614 s: APP: Init ... Done !!! [C6x_1 ] 16.104623 s: APP: Run ... !!! [C6x_1 ] 16.104632 s: IPC: Starting echo test ... [C6x_1 ] 16.105822 s: APP: Run ... Done !!! [C6x_1 ] 16.106182 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[s] C66X_2[x] C7X_1[P] [C6x_1 ] 16.106438 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[s] C66X_2[P] C7X_1[P] [C6x_1 ] 16.124562 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C66X_1[s] C66X_2[P] C7X_1[P] [C6x_1 ] 16.166608 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] C66X_1[s] C66X_2[P] C7X_1[P] [C6x_2 ] 4.354698 s: CIO: Init ... Done !!! [C6x_2 ] 4.354724 s: ### CPU Frequency = 1350000000 Hz [C6x_2 ] 4.354736 s: CPU is running FreeRTOS [C6x_2 ] 4.354744 s: APP: Init ... !!! [C6x_2 ] 4.354751 s: SCICLIENT: Init ... !!! [C6x_2 ] 4.354964 s: SCICLIENT: DMSC FW version [8.5.2--v08.05.02 (Chill Capybar] [C6x_2 ] 4.354976 s: SCICLIENT: DMSC FW revision 0x8 [C6x_2 ] 4.354986 s: SCICLIENT: DMSC FW ABI revision 3.1 [C6x_2 ] 4.354996 s: SCICLIENT: Init ... Done !!! [C6x_2 ] 4.355005 s: UDMA: Init ... !!! [C6x_2 ] 4.356581 s: UDMA: Init ... Done !!! [C6x_2 ] 4.356603 s: MEM: Init ... !!! [C6x_2 ] 4.356617 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ e0000000 of size 16777216 bytes !!! [C6x_2 ] 4.356634 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 800000 of size 229376 bytes !!! [C6x_2 ] 4.356650 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ e1000000 of size 50331648 bytes !!! [C6x_2 ] 4.356667 s: MEM: Init ... Done !!! [C6x_2 ] 4.356675 s: IPC: Init ... !!! [C6x_2 ] 4.356696 s: IPC: 6 CPUs participating in IPC !!! [C6x_2 ] 4.356711 s: IPC: Waiting for HLOS to be ready ... !!! [C6x_2 ] 15.179026 s: IPC: HLOS is ready !!! [C6x_2 ] 15.182825 s: IPC: Init ... Done !!! [C6x_2 ] 15.182851 s: APP: Syncing with 5 CPUs ... !!! [C6x_2 ] 16.098120 s: APP: Syncing with 5 CPUs ... Done !!! [C6x_2 ] 16.098138 s: REMOTE_SERVICE: Init ... !!! [C6x_2 ] 16.098810 s: REMOTE_SERVICE: Init ... Done !!! [C6x_2 ] 16.098842 s: VX_ZONE_INIT:Enabled [C6x_2 ] 16.098853 s: VX_ZONE_ERROR:Enabled [C6x_2 ] 16.098863 s: VX_ZONE_WARNING:Enabled [C6x_2 ] 16.099676 s: VX_ZONE_INIT:[tivxInitLocal:145] Initialization Done !!! [C6x_2 ] 16.099690 s: APP: OpenVX Target kernel init ... !!! [C6x_2 ] 16.099953 s: APP: OpenVX Target kernel init ... Done !!! [C6x_2 ] 16.099969 s: UDMA Copy: Init ... !!! [C6x_2 ] 16.104740 s: UDMA Copy: Init ... Done !!! [C6x_2 ] 16.104763 s: APP: Init ... Done !!! [C6x_2 ] 16.104773 s: APP: Run ... !!! [C6x_2 ] 16.104782 s: IPC: Starting echo test ... [C6x_2 ] 16.106062 s: APP: Run ... Done !!! [C6x_2 ] 16.106437 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[s] C7X_1[.] [C6x_2 ] 16.106476 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[s] C7X_1[P] [C6x_2 ] 16.124587 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C66X_1[P] C66X_2[s] C7X_1[P] [C6x_2 ] 16.166645 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] C66X_1[P] C66X_2[s] C7X_1[P] [C7x_1 ] 4.905567 s: CIO: Init ... Done !!! [C7x_1 ] 4.905581 s: ### CPU Frequency = 1000000000 Hz [C7x_1 ] 4.905593 s: CPU is running FreeRTOS [C7x_1 ] 4.905601 s: APP: Init ... !!! [C7x_1 ] 4.905608 s: SCICLIENT: Init ... !!! [C7x_1 ] 4.905845 s: SCICLIENT: DMSC FW version [8.5.2--v08.05.02 (Chill Capybar] [C7x_1 ] 4.905859 s: SCICLIENT: DMSC FW revision 0x8 [C7x_1 ] 4.905868 s: SCICLIENT: DMSC FW ABI revision 3.1 [C7x_1 ] 4.905879 s: SCICLIENT: Init ... Done !!! [C7x_1 ] 4.905889 s: UDMA: Init ... !!! [C7x_1 ] 4.907178 s: UDMA: Init ... Done !!! [C7x_1 ] 4.907190 s: MEM: Init ... !!! [C7x_1 ] 4.907201 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ 117000000 of size 268435456 bytes !!! [C7x_1 ] 4.907222 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000001) @ 70020000 of size 8159232 bytes !!! [C7x_1 ] 4.907239 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 64800000 of size 458752 bytes !!! [C7x_1 ] 4.907257 s: MEM: Created heap (L1_MEM, id=3, flags=0x00000001) @ 64e00000 of size 16384 bytes !!! [C7x_1 ] 4.907274 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ 100000000 of size 385875968 bytes !!! [C7x_1 ] 4.907292 s: MEM: Init ... Done !!! [C7x_1 ] 4.907300 s: IPC: Init ... !!! [C7x_1 ] 4.907313 s: IPC: 6 CPUs participating in IPC !!! [C7x_1 ] 4.907327 s: IPC: Waiting for HLOS to be ready ... !!! [C7x_1 ] 15.193004 s: IPC: HLOS is ready !!! [C7x_1 ] 15.195115 s: IPC: Init ... Done !!! [C7x_1 ] 15.195129 s: APP: Syncing with 5 CPUs ... !!! [C7x_1 ] 16.098122 s: APP: Syncing with 5 CPUs ... Done !!! [C7x_1 ] 16.098139 s: REMOTE_SERVICE: Init ... !!! [C7x_1 ] 16.098294 s: REMOTE_SERVICE: Init ... Done !!! [C7x_1 ] 16.098316 s: VX_ZONE_INIT:Enabled [C7x_1 ] 16.098327 s: VX_ZONE_ERROR:Enabled [C7x_1 ] 16.098336 s: VX_ZONE_WARNING:Enabled [C7x_1 ] 16.098492 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1 [C7x_1 ] 16.098558 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_2 [C7x_1 ] 16.098657 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_3 [C7x_1 ] 16.098751 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_4 [C7x_1 ] 16.098818 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_5 [C7x_1 ] 16.098881 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_6 [C7x_1 ] 16.098994 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_7 [C7x_1 ] 16.099068 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_8 [C7x_1 ] 16.099089 s: VX_ZONE_INIT:[tivxInitLocal:145] Initialization Done !!! [C7x_1 ] 16.099103 s: APP: OpenVX Target kernel init ... !!! [C7x_1 ] 16.099243 s: APP: OpenVX Target kernel init ... Done !!! [C7x_1 ] 16.099257 s: APP: Init ... Done !!! [C7x_1 ] 16.099266 s: APP: Run ... !!! [C7x_1 ] 16.099274 s: IPC: Starting echo test ... [C7x_1 ] 16.099445 s: APP: Run ... Done !!! [C7x_1 ] 16.106254 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[.] C7X_1[s] [C7x_1 ] 16.106432 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[P] C7X_1[s] [C7x_1 ] 16.124604 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[s] [C7x_1 ] 16.166672 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[s]
Hi Ann,
Could you please share your latest param.yaml file for our reference ?
Pratik
Also Ann can u share the model and artifacts what u compiled so i can verify that issue what iam facing is version dependencies of SDK
N
Hi Pratik,
param.yaml is as follows:
postprocess: data_layout: NCHW detection_thr: 0.3 preprocess: crop: - 640 - 640 data_layout: NCHW mean: - 0 - 0 - 0 resize: - 640 - 640 scale: - 0.003921568627 - 0.003921568627 - 0.003921568627 session: artifacts_folder: artifacts model_folder: model model_path: model/yolov5s6_640_ti_lite_37p4_56p0.onnx session_name: onnxrt target_device: TDA4VM task_type: detection
Thanks for you help!
Ann
Hi
Hi Ann,
Appears to me that param.yaml is not generated correctly.
From the above posted logs,
The mean values are set to 0 in your generated param.yaml file.
Could try setting it random and check if this issue appears after that ?
Pratik
