look for Anshuman Saxena.Could you help me? some error in DVSDK IPNC release
Hello:
I used Davinci DM368IPNC-IMX036-A175(TMS320DM368)   dvsdk_2_10_01_18 ipnc release and linux-2.6.18_pro500
I have already modified Makefile and Rule.make.
But when I "$make sysall" in the ipnc file.  I encounter serveral errors as below:
"/home/user/workdir2/IPNC_DM368_IMX036_NewGUI/IPNC_NewGUI/av_capture/framework/alg/src/aewb_ap/aew_xdm_lib/Appro_aew_control.c" is not my file path.
and I didn't have the file such as Appro_aew_control.c  aew_xdm_lib
I don't know why?
please tell me.
thanks for your visit
 any help would be great!
Best regards
Making all in subdirectory armloading...
make[7]: Entering directory `/home/dvdev/ipnc/ipnc_app/testsuite/armloading'
/opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I/home/dvdev/ipnc/ti-davinci/include  -O2 -Wall -static -g -D__DEBUG -c main.c
/opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc  -o arm_loading main.o
make[7]: Leaving directory `/home/dvdev/ipnc/ipnc_app/testsuite/armloading'
make[6]: Leaving directory `/home/dvdev/ipnc/ipnc_app/testsuite'
make[5]: Leaving directory `/home/dvdev/ipnc/ipnc_app'
make[4]: Leaving directory `/home/dvdev/ipnc/av_capture/application/ipnc'
make[3]: Leaving directory `/home/dvdev/ipnc'
make -fMAKEFILE.MK -C/home/dvdev/ipnc/av_capture/build/../application/test exe
make[3]: Entering directory `/home/dvdev/ipnc/av_capture/application/test'
make -fMAKEFILE.MK -C./regrw MODULE=regrw exe
make[4]: Entering directory `/home/dvdev/ipnc/av_capture/application/test/regrw'
regrw: Linking to .out
/opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -lpthread -lpng -fPIC -lasound -o/home/dvdev/ipnc/av_capture/build/../bin//regrw.out /home/dvdev/ipnc/av_capture/build/lib//regrw.a /home/dvdev/ipnc/av_capture/build/lib//drv.a /home/dvdev/ipnc/av_capture/build/lib//csl.a  /home/dvdev/ipnc/av_capture/build/lib//osa.a
Final executable /home/dvdev/ipnc/av_capture/build/../bin//regrw.out !!!
make[4]: Leaving directory `/home/dvdev/ipnc/av_capture/application/test/regrw'
make -fMAKEFILE.MK -C./i2crw MODULE=i2crw exe
make[4]: Entering directory `/home/dvdev/ipnc/av_capture/application/test/i2crw'
i2crw: Linking to .out
/opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -lpthread -lpng -fPIC -lasound -o/home/dvdev/ipnc/av_capture/build/../bin//i2crw.out /home/dvdev/ipnc/av_capture/build/lib//i2crw.a /home/dvdev/ipnc/av_capture/build/lib//drv.a /home/dvdev/ipnc/av_capture/build/lib//csl.a  /home/dvdev/ipnc/av_capture/build/lib//osa.a
Final executable /home/dvdev/ipnc/av_capture/build/../bin//i2crw.out !!!
make[4]: Leaving directory `/home/dvdev/ipnc/av_capture/application/test/i2crw'
make[3]: Leaving directory `/home/dvdev/ipnc/av_capture/application/test'
make -fMAKEFILE.MK -C/home/dvdev/ipnc/av_capture/build/../application/ipnc/av_server exe
make[3]: Entering directory `/home/dvdev/ipnc/av_capture/application/ipnc/av_server'
make -fMAKEFILE.MK -C./src/common MODULE=av_server exe
make[4]: Entering directory `/home/dvdev/ipnc/av_capture/application/ipnc/av_server/src/common'
av_server: Linking to .out
/opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -lpthread -lpng -fPIC -lasound -o/home/dvdev/ipnc/av_capture/build/../bin//av_server.out /home/dvdev/ipnc/av_capture/build/lib//av_server.a /home/dvdev/ipnc/av_capture/build/lib//alg.a /home/dvdev/ipnc/av_capture/build/lib//drv.a /home/dvdev/ipnc/av_capture/build/lib//image_tune.a /home/dvdev/ipnc/av_capture/build/lib//osa.a /home/dvdev/ipnc/av_capture/build/lib//csl.a /home/dvdev/ipnc/dvsdk_2_10_01_18/linuxutils_2_24_03/packages/ti/sdo/linuxutils/cmem/lib/cmem.a470MV /home/dvdev/ipnc/av_capture/build/../framework/alg/lib/alg_facetrack_ti.a /home/dvdev/ipnc/av_capture/build/../framework/alg/src/alg_config/linker.cmd  /home/dvdev/ipnc/av_capture/build/../framework/alg/lib/alg_vstab_ti.a /home/dvdev/ipnc/av_capture/build/../framework/alg/lib/alg_gbce_ti.a /home/dvdev/ipnc/av_capture/build/../framework/alg/lib/alg_osd_ti.a /home/dvdev/ipnc/av_capture/build/../framework/alg/lib/fr_ti/alg_fr_ti.a /home/dvdev/ipnc/av_capture/build/../framework/alg/lib/fr_ti/libeOkaoFr.a /home/dvdev/ipnc/av_capture/build/../framework/alg/lib/fr_ti/libeOkaoPt.a /home/dvdev/ipnc/av_capture/build/../framework/alg/lib/fr_ti/libeOkaoCo.a /home/dvdev/ipnc/av_capture/build/../framework/alg/src/aewb_ti/lib/libti_awb.a  /home/dvdev/ipnc/av_capture/build/../framework/alg/src/aewb_ap/lib/Appro_2a_lib.a /home/dvdev/ipnc/av_capture/build/../framework/alg/src/aewb_ap/lib/Appro_aew_control.a  /home/dvdev/ipnc/ipnc_app/interface/lib/msg_util.a /home/dvdev/ipnc/ipnc_app/interface/lib/alarm_msg_drv.a /home/dvdev/ipnc/dvsdk_2_10_01_18/dm365mm/lib/libdm365mm.a
/home/dvdev/ipnc/av_capture/build/lib//alg.a(alg_aewb_control.o): In function `ALG_aewbGet_IsDDRInMode':
alg_aewb_control.c:(.text+0x5c0): undefined reference to `DRV_imgsGetDdrInMode'
/home/dvdev/ipnc/av_capture/build/lib//alg.a(alg_aewb_control.o): In function `ALG_aewbSetNDShutterOnOff':
alg_aewb_control.c:(.text+0xdec): undefined reference to `DRV_imgsNDShutter'
/home/dvdev/ipnc/av_capture/build/lib//alg.a(alg_aewb_control.o): In function `ALG_aewb_ChipCtrl':
alg_aewb_control.c:(.text+0x1240): undefined reference to `DRV_imgs_APChipInit'
/home/dvdev/ipnc/av_capture/build/../framework/alg/src/aewb_ap/lib/Appro_aew_control.a(Appro_aew_control.o): In function `GET_INDEX_LIST':
/home/user/workdir2/IPNC_DM368_IMX036_NewGUI/IPNC_NewGUI/av_capture/framework/alg/src/aewb_ap/aew_xdm_lib/Appro_aew_control.c:1778: undefined reference to `DRV_imgsGetLightSensorMode'
collect2: ld returned 1 exit status
make[4]: *** [exe] Error 1
make[4]: Leaving directory `/home/dvdev/ipnc/av_capture/application/ipnc/av_server/src/common'
make[3]: *** [exe] Error 2
make[3]: Leaving directory `/home/dvdev/ipnc/av_capture/application/ipnc/av_server'
make[2]: *** [exe] Error 2
make[2]: Leaving directory `/home/dvdev/ipnc'
make[1]: *** [all] Error 2
make[1]: Leaving directory `/home/dvdev/ipnc'
make: *** [sysall] Error 2
