Part Number: PROCESSOR-SDK-AM62X
I am trying to flash the following board: ARM64-AM62 EVM with the instructions provided in different forums.
Everytime I execute the flash command the device returns:
No DFU Device found, please set the target to DFU mode!
This is the log
182 - DEBUG - displaying banner
192 - DEBUG - displayed banner
193 - DEBUG - added /home/as2214/flash-container_ims-titan_v2023dev3-arm64-am62x_evm_20230511.0811/artifacts/0.boot.img to /home/as2214/flash-container_ims-titan_v2023dev3-arm64-am62x_evm_20230511.0811/artifacts/ims-titan.img
193 - DEBUG - added /home/as2214/flash-container_ims-titan_v2023dev3-arm64-am62x_evm_20230511.0811/artifacts/2.general_storage.img to /home/as2214/flash-container_ims-titan_v2023dev3-arm64-am62x_evm_20230511.0811/artifacts/ims-titan.img
193 - DEBUG - added /home/as2214/flash-container_ims-titan_v2023dev3-arm64-am62x_evm_20230511.0811/artifacts/1.system.img to /home/as2214/flash-container_ims-titan_v2023dev3-arm64-am62x_evm_20230511.0811/artifacts/ims-titan.img
1207 - DEBUG - Serial port /dev/ttyUSB0 open successfully...
10460 - ERROR - No DFU Device found, please set the target to DFU mode
What I am trying to do, is flashing the board from the laptop and since I already got some help for Ubuntu 22 systems, I understood that the first thing I had to do was installing some packages
I missed.
Did you install following packages in your Linux host:
libusb-1.0.0-dev
libftdi1-2
dfu-utils (ver 0.9)
Please check if dfu-util -l finds your target as a dfu device.
I followed all these steps, but unfortunately I still get the same message.
The configuration of the pins in the board is the second picture (emmC) in the following link:
- If I do:
/dev/serial$ dfu-util -l
dfu-util 0.9
Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc.
Copyright 2010-2016 Tormod Volden and Stefan Schmidt
This program is Free Software and has ABSOLUTELY NO WARRANTY
Please report bugs to sourceforge.net/.../
dfu-util: Cannot open DFU device 0bda:5510
So I decided to change the rules file as follows:
/etc/udev/rules.d/11-ftdi.rules
SUBSYSTEM=="usb", ATTRS{idVendor}=="0bda", ATTRS{idProduct}=="5510", GROUP="plugdev", MODE="0666"
SUBSYSTEM=="usb_device", ATTRS{idVendor}=="0bda", ATTRS{idProduct}=="5510", GROUP="plugdev", MODE="0666"
- If I use sudo
$ sudo dfu-util -l
[sudo] password for as2214:
dfu-util 0.9
Found Runtime: [0bda:5510] ver=9179, devnum=3, cfg=1, intf=4, path="1-11", alt=0, name="Camera DFU Device", serial="200901010001"
I dont have any camera connected to the board so I dont understand this result. One of my colleagues has a different output after doing this.
Should I ensure that GROUP="plugdev" is already created? Do you have any suggestion about how to fix the "No DFU Device found, please set the target to DFU mode! "
problem?
Thank you in advance
Best regards
Antia
