LP-MSPM0G3507: I2C read and write EEPROM error
Part Number: LP-MSPM0G3507
Hi team,
The following issues occur when reading and writing EEPROM using the development board of the MSPM0G3057:
Reading and writing 19 lengths of data. If writing 19 at a time and then reading 19 at a time, you will get confused data, that is, the order is wrong. If reading 4 bytes, it can read successfully at one time, but no value is read the next time.
The customer tried to delay and change pin and the problem still exists. It was more stranger that the customer was able to read and write 19 lengths of data at once a week ago. They also tried to change to another development board and EEPROM, but the problem was the same.
Could you help check this case? Thanks.
Cherry
