TDA4VM: Multicast not work, How to enable the multicast function? Use SDK8.4
Part Number: TDA4VM
Hi, TI
We used SDK8.4 and found during the test that we could not grab the multicast text,but the broadcast was OK.
Does cpsw restrict multicast messages?
Are there any macro switches that need to be turned on in the SDK?
Which registers need to be set?
    Can you please provide more details about your environment like
    1. Is it related to CPSW2G or CPSW9G
    2. if CPSW9G then are using Ethfw or Native Linux Driver or PDK app (enet_lwip_example)?
    3. if CPSW2G are using MCAL driver or  Linux Driver?
    If you want to handle any frames, you need ALE entries and policers.
    There is no MACRO related configuration to enable and disable Multicast frames.
    Sudheer
