Other Parts Discussed in Thread: DM3730
Dears,
One of our customer need to use h.263 codec on DSP side of DM3730. So I adviced them to use MPEG4 Encoder and Decoder of C64XPlus_Video_CODECS 1_00_003 from http://software-dl.ti.com/dsps/dsps_public_sw/codecs/C64XPlus_Video/index_FDS.html , which is noted to support h.263 encoding and decoding.
And they followed the c64xplus_mpeg4enc_02_02_04_production\c64xplus_mpeg4enc_02_02_04_production\packages\ti\sdo\codecs\mpeg4enc\docs\MPEG4_Encoder_DM6446_UserGuide.pdf to configure the H.263 encoding, but found the encoded stream was still MPEG4 standard, which could be identified by PC SW.
So please help to see if anything else we need to do when using this H.263 encoder.
For H.263 decoder, we couldn't see any configuration issue about H.263 decoding in MPEG4_Decoder_C64XPLUS_UserGuide.pdf, please also help to give a clue.
