TMS320C5517: I2S received data are 1-bit right-shifted
Part Number: TMS320C5517
My customer reported an issue related I2S receive.
I2S is connected with FPGA. DSP and I2S configurations are below:
DSP clock = 172.8MHz (w/ 19.2MHz source)
I2S0 is used.
I2S configuration:
MONO = 0 (Stereo)
LOOPBACK = 0 (disabled)
FSPOL = 0 (high active)
CLKPOL = 1
DATADLY = 0 (1-bit delay)
PACK = 0 (disabled)
SIGN_EXT = 0
WDLENGTH = 8 (32bits word)
MODE = 0 (slave)
FRMT = 1 (DSP format)
Issue description:
If I2S_FS period is 64cycles (there is no gap between R-ch and next L-ch), there is no issue.
If I2S_FS period is 100cycles (there are 36 cycles between R-ch and next L-ch), R-ch data are received with 1-bit right-shifted.
Waveform example:
DSP_I2S_IN is DSP to FPGA data
DSP_I2S_OUT is FPGA to DSP data
Now 0x80001000(L-ch) and 0x20003000(R-ch) are received.
Then DSP sends out the received data, but data are
0x80001000(L-ch) and 0x10001800(R-ch). Only R-ch data are 1-bit right-shifted.
The customer also checked received data in DSP memory and confirmed they are 1-bit shifted.
This is the code the customer uses. It is CSL ver.3.08.01 with modification.
They corrected I2S_setup() function as the original code cannot configure DSP format (FRMT bit is forced 0 regardless i2sHwConfig).
 * Copyright (c) 2008-2012 Texas Instruments Incorporated.
 *  Redistribution and use in source and binary forms, with or without
 *  modification, are permitted provided that the following conditions
 *  are met:
 *    Redistributions of source code must retain the above copyright
 *    Redistributions in binary form must reproduce the above copyright
 *    documentation and/or other materials provided with the
 *    distribution.
 *    Neither the name of Texas Instruments Incorporated nor the names of
 *  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
 *  "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
 *  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
 *  A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
 *  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
 *  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
 *  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
 *  DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
 *  THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
 *  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
 *  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/** @file csl_i2s.c
 *  @brief I2S functional layer API defenition file
 *  Path: \(CSLPATH)/src
 * Revision History
 * 25-Aug-2008 Added I2S for CSL.
 * 25-Aug-2008 Updated for Doxygen.
 * 28-Aug-2008 Added Return Types for Error checking for API's parameter.
 * 04-Jan-2009 Modified I2S_read to add latency for the first data receive
 * 11-Jan-2010 Replaced magic numbers with macros as per review comments
 * 13-Aug-2010 CSL v2.10 release
 * 06-Jul-2011 CSL v2.50 release
 * 13-Sep-2012 CSL v3.00 release
 * 20-Dec-2012 CSL v3.01 release
#include "csl_i2s.h"
#include "csl_sysctrl.h"
Uint16	fsError = 0;	/**< FSYNC gobal parameter 				*/
Uint16	ouError = 0;	/**< under/over run global parameter	*/
 *   @n@b I2S_open
 *   @b Description
 *   @n This function returns the handle to the I2S
 *      instance. This handle is passed to all other CSL APIs.
 *   @b Arguments
 *   @verbatim
            i2sInstNum	Instance number to open.
            opMode		Mode of operation (intrrupt/Polling/DMA)
			chType		Channel Type (Stereo/Mono)
     @endverbatim
 *   <b> Return Value </b>  CSL_I2sHandle
 *   @n                     Valid I2S handle will be returned if
 *                          handler value is not equal to NULL.
 *   <b> Pre Condition </b>
 *   @n
 *   <b> Post Condition </b>
 *   @n   1.    The status is returned in the status variable. If status
 *              returned is
 *   @li            NULL               - InValid I2S handle is returned
 *   @n   2.    CSL_DMA_ChannelObj object structure is populated
 *   @b Modifies
 *   @n    1. CSL_I2sObj	 I2S object structure
 *   @n    2.
 *   @b Example
 *   @verbatim
            I2S_Instance		 i2sInstNum;
            I2S_OpMode		     opMode;
            I2S_ChanType 	     chType;
            hI2S = I2S_open(I2S_Instance	i2sInstNum,
					   		I2S_OpMode		opMode,
					   		I2S_ChanType 	chType);
    @endverbatim
CSL_I2sHandle I2S_open(I2S_Instance		i2sInstNum,
					   I2S_OpMode		opMode,
	CSL_I2sHandle hI2s;
	ioport volatile CSL_SysRegs		*sysRegs;
	///ioport volatile CSL_SysPGFlags	*sysFlags;
	hI2s = NULL;
	/* Check device is already in used*/
#if (defined(CHIP_C5517)) //No I2S1 in CHIP 5517
	if(i2sInstNum == I2S_INVALID || i2sInstNum == I2S_INSTANCE1)
		return (NULL);
#else
	if(i2sInstNum == I2S_INVALID)
		return (NULL);
#endif
	hI2s = &I2S_InstanceNum[i2sInstNum];
	if((i2sInstNum >= 0) & (i2sInstNum <= 3))
		hI2s->i2sNum    = i2sInstNum;
		hI2s->chType    = chType;
		hI2s->opMode    = opMode;
		hI2s->firstRead = TRUE;
		sysRegs = (CSL_SysRegs *)CSL_SYSCTRL_REGS;
		/* Configure the Peripheral Reset Control Register in each instance */
    	//CSL_FINS(sysRegs->PRCR, SYS_PRCR_PG3_RST, CSL_SYS_PRCR_PG3_RST_RST);
		//CSL_FINS(sysRegs->PRCR, SYS_PRCR_PG4_RST, CSL_SYS_PRCR_PG4_RST_RST);
		/* Set Instance hardware registers*/
		switch(i2sInstNum)
			case I2S_INSTANCE0:
				SYS_peripheralReset(CSL_SYS_PG3);
				hI2s->hwRegs = (CSL_I2sRegs *)(CSL_I2S0_REGS);
				CSL_FINS(sysRegs->PCGCR1, SYS_PCGCR1_I2S0CG,
										CSL_SYS_PCGCR1_I2S0CG_ACTIVE);
//				CSL_FINS(sysRegs->EBSR, SYS_EBSR_SP0MODE,
//										CSL_SYS_EBSR_SP0MODE_MODE1);
				break;
#if (!(defined(CHIP_C5517)))
			case I2S_INSTANCE1:
				hI2s->hwRegs = (CSL_I2sRegs *)(CSL_I2S1_REGS);
				CSL_FINS(sysRegs->PCGCR1, SYS_PCGCR1_I2S1CG,
										CSL_SYS_PCGCR1_I2S1CG_ACTIVE);
//				CSL_FINS(sysRegs->EBSR, SYS_EBSR_SP1MODE,
//										CSL_SYS_EBSR_SP1MODE_MODE1);
				break;
#endif
			case I2S_INSTANCE2:
				SYS_peripheralReset(CSL_SYS_PG4);
				hI2s->hwRegs = (CSL_I2sRegs *)(CSL_I2S2_REGS);
				CSL_FINS(sysRegs->PCGCR1, SYS_PCGCR1_I2S2CG,
										CSL_SYS_PCGCR1_I2S2CG_ACTIVE);
//				CSL_FINS(sysRegs->EBSR, SYS_EBSR_PPMODE,
//										CSL_SYS_EBSR_PPMODE_MODE6);
				break;
			case I2S_INSTANCE3:
				hI2s->hwRegs = (CSL_I2sRegs *)(CSL_I2S3_REGS);
				CSL_FINS(sysRegs->PCGCR1, SYS_PCGCR1_I2S3CG,
										CSL_SYS_PCGCR1_I2S3CG_ACTIVE);
				break;
			default:
				break;
	hI2s->configured = FALSE;
	return(hI2s);
 *   @n@b I2S_setup
 *   @b Description
 *   @n It configures the I2S Controller registers of particular handle as per
 *      the values passed in the I2S config structure.
 *   @b Arguments
 *   @verbatim
            i2sHandle       Handle to the I2S.
            i2sHwConfig     Pointer to I2S Config structure.
     @endverbatim
 *   <b> Return Value </b>  CSL_Status
 *   @li                    CSL_SOK             - Hardware setup successful
 *   @li                    CSL_ESYS_BADHANDLE  - Invalid handle
 *   @li                    CSL_ESYS_INVPARAMS  - Congig Parameter is invalid.
 *   @n  I2S_open has to call, before calling I2S_setup
 *   @n  None
 *   @b Modifies
 *   @n 1. I2S registers will be updated as per config parameter
 *   @n 2. CSL_I2sObj Object will be updated to store some info
 *              as passed config parameter.
 *   @b Example
 *   @verbatim
            CSL_I2sHandle   hI2S;
            I2S_Config      hwConfig;
            Int16           status;
            status = I2S_setup(hI2S, &hwConfig);
     @endverbatim
CSL_Status I2S_setup(CSL_I2sHandle	hI2s,
				     I2S_Config 	*i2sHwConfig)
	ioport CSL_I2sRegs	  *regs;
	if(NULL == hI2s)
		return (CSL_ESYS_BADHANDLE);
	if(NULL == i2sHwConfig)
		return (CSL_ESYS_INVPARAMS);
	if(TRUE != hI2s->configured)
		regs = hI2s->hwRegs;
		hI2s->fsDiv        = i2sHwConfig->fsDiv;
		hI2s->loopBackMode = i2sHwConfig->loopBackMode;
		hI2s->datapack     = i2sHwConfig->datapack;
		hI2s->wordLen      = i2sHwConfig->wordLen;
		/* Reset All the registers*/
		regs->I2SSCTRL   &= (Uint16)CSL_I2S_I2SSCTRL_RESETVAL;
		regs->I2SSRATE   &= (Uint16)CSL_I2S_I2SSRATE_RESETVAL;
		regs->I2STXLTL   &= (Uint16)CSL_I2S_I2STXLTL_RESETVAL;
		regs->I2STXLTU   &= (Uint16)CSL_I2S_I2STXLTU_RESETVAL;
		regs->I2STXRTL   &= (Uint16)CSL_I2S_I2STXRTL_RESETVAL;
		regs->I2STXRTU   &= (Uint16)CSL_I2S_I2STXRTU_RESETVAL;
#else
		regs->I2STXLT0   &= (Uint16)CSL_I2S_I2STXLT0_RESETVAL;
		regs->I2STXLT1   &= (Uint16)CSL_I2S_I2STXLT1_RESETVAL;
		regs->I2STXRT0   &= (Uint16)CSL_I2S_I2STXRT0_RESETVAL;
		regs->I2STXRT1   &= (Uint16)CSL_I2S_I2STXRT1_RESETVAL;
#endif
		regs->I2SINTFL   &= (Uint16)CSL_I2S_I2SINTFL_RESETVAL;
		regs->I2SINTMASK &= (Uint16)CSL_I2S_I2SINTMASK_RESETVAL;
		regs->I2SRXLTL   &= (Uint16)CSL_I2S_I2SRXLTL_RESETVAL;
		regs->I2SRXLTU   &= (Uint16)CSL_I2S_I2SRXLTU_RESETVAL;
		regs->I2SRXRTL   &= (Uint16)CSL_I2S_I2SRXRTL_RESETVAL;
		regs->I2SRXRTU   &= (Uint16)CSL_I2S_I2SRXRTU_RESETVAL;
#else
		regs->I2SRXLT0   &= (Uint16)CSL_I2S_I2SRXLT0_RESETVAL;
		regs->I2SRXLT1   &= (Uint16)CSL_I2S_I2SRXLT1_RESETVAL;
		regs->I2SRXRT0   &= (Uint16)CSL_I2S_I2SRXRT0_RESETVAL;
		regs->I2SRXRT1   &= (Uint16)CSL_I2S_I2SRXRT1_RESETVAL;
#endif
		/* Data transmit/receive is Mono/Stereo type*/
		CSL_FINS(regs->I2SSCTRL, I2S_I2SSCTRL_MONO, i2sHwConfig->dataType);
		/* Enable/disable the loopback bit */
		CSL_FINS(regs->I2SSCTRL, I2S_I2SSCTRL_LOOPBACK, i2sHwConfig->loopBackMode);
		/* Set FSYNC polarity is High/Low */
		CSL_FINS(regs->I2SSCTRL, I2S_I2SSCTRL_FSPOL, i2sHwConfig->fsPol);
		/* Set the clock polarity FALLING/RESING */
		CSL_FINS(regs->I2SSCTRL, I2S_I2SSCTRL_CLKPOL, i2sHwConfig->clkPol);
		/* Data delay set to ONE/TWo bit*/
		CSL_FINS(regs->I2SSCTRL, I2S_I2SSCTRL_DATADLY, i2sHwConfig->datadelay);
		/* Data packing Enable/Disable */
		CSL_FINS(regs->I2SSCTRL, I2S_I2SSCTRL_PACK, i2sHwConfig->datapack);
		/* Set data sign extension*/
		CSL_FINS(regs->I2SSCTRL, I2S_I2SSCTRL_SIGN_EXT, i2sHwConfig->signext);
		/* Set Word length for a word */
		CSL_FINS(regs->I2SSCTRL, I2S_I2SSCTRL_WDLNGTH, i2sHwConfig->wordLen);
		/* Set the Mode of transmission */
		if(i2sHwConfig->i2sMode == I2S_SLAVE)
			CSL_FINST(regs->I2SSCTRL, I2S_I2SSCTRL_MODE, CLEAR);
		else
			CSL_FINST(regs->I2SSCTRL, I2S_I2SSCTRL_MODE, SET);
		/* Channel type is Mono/Stereo, Set the dependant bit*/
		if(hI2s->chType == I2S_CHAN_MONO)
			CSL_FINST(regs->I2SSCTRL, I2S_I2SSCTRL_FRMT, SET);
			/* Left transmit & recv channel disable */
			CSL_FINST(regs->I2SINTMASK, I2S_I2SINTMASK_XMITST, DISABLE);
			CSL_FINST(regs->I2SINTMASK, I2S_I2SINTMASK_XMITMON, ENABLE);
			CSL_FINST(regs->I2SINTMASK, I2S_I2SINTMASK_RCVST, DISABLE);
			CSL_FINST(regs->I2SINTMASK, I2S_I2SINTMASK_RCVMON, ENABLE);
		else
			/*CSL_FINST(regs->I2SSCTRL, I2S_I2SSCTRL_FRMT, CLEAR);*/				/* del 2022/11/29 */
			CSL_FINS(regs->I2SSCTRL, I2S_I2SSCTRL_FRMT, i2sHwConfig->dataFormat);	/* add 2022/11/29 */
			/* Right transmit & recv channel disable */
			CSL_FINST(regs->I2SINTMASK, I2S_I2SINTMASK_XMITST, ENABLE);
			CSL_FINST(regs->I2SINTMASK, I2S_I2SINTMASK_XMITMON, DISABLE);
			CSL_FINST(regs->I2SINTMASK, I2S_I2SINTMASK_RCVST, ENABLE);
			CSL_FINST(regs->I2SINTMASK, I2S_I2SINTMASK_RCVMON, DISABLE);
		/* Set the bit for the frame sync devider */
		CSL_FINS(regs->I2SSRATE, I2S_I2SSRATE_FSDIV, i2sHwConfig->fsDiv);
		/* Set bit for the serializer clock divider */
		CSL_FINS(regs->I2SSRATE, I2S_I2SSRATE_CLKDIV, i2sHwConfig->clkDiv);
		/* Frame-sync error enable/disable	*/
		CSL_FINS(regs->I2SINTMASK, I2S_I2SINTMASK_FERR, i2sHwConfig->FError);
		/* Overrun or under-run error enable/disable	*/
		CSL_FINS(regs->I2SINTMASK, I2S_I2SINTMASK_OUERR, i2sHwConfig->OuError);
		/* Reset the IR*/
		hI2s->configured = TRUE;
	return(CSL_SOK);
 *   @n@b I2S_close
 *   @b Description
 *   @n This function closes the specified handle to I2S.
 *   @b Arguments
 *   @verbatim
     @endverbatim
 *   @li                    CSL_SOK             - Close successful
 *   @n  None
 *   @n  None
 *   @b Modifies
 *   @n None
 *   @b Example
 *   @verbatim
            CSL_I2sHandle   hI2S;
            CSL_status   status;
            status = I2S_close(hI2S);
     @endverbatim
CSL_Status I2S_close(CSL_I2sHandle	hI2s)
	Int16 status;
	if(NULL == hI2s)
	switch(hI2s->i2sNum)
		case I2S_INSTANCE0:
										CSL_SYS_PCGCR1_I2S0CG_DISABLED);
			break;
		case I2S_INSTANCE1:
										CSL_SYS_PCGCR1_I2S1CG_DISABLED);
			break;
	#endif
		case I2S_INSTANCE2:
										CSL_SYS_PCGCR1_I2S2CG_DISABLED);
			break;
		case I2S_INSTANCE3:
										CSL_SYS_PCGCR1_I2S3CG_DISABLED);
			break;
	I2S_InstanceNum[hI2s->i2sNum].hwRegs = NULL;
	/* Reset the Instance to Invalid */
	hI2s->i2sNum = I2S_INVALID;
	/* Set the configutation to FALSE */
	hI2s = NULL;
	status = CSL_SOK;
	return (status);
 *   @n@b I2S_read
 *   @b Description
 *   @n This function Read data form specified device.
 *      This function introduces a delay during the first data receive operation.
 *      Data latency is calculated as per the I2S hardware specification. This
 *      delay is applicable only to polled mode operation. For interrupt mode
 *      this function should be called only after getting the receive interrupt
 *      from the I2S.
 *   @b Arguments
 *   @verbatim
			readBuff          Pointer to the read buffer.
			buffLen           Maximum read buffer size.
     @endverbatim
 *   @li                    CSL_SOK             - Read successful
 *   @n  This function has to call after I2S_open function call.
 *   @n  SPI_close can be call after this function call.
 *   @b Modifies
 *   @n None
 *   @b Example
 *   @verbatim
            CSL_I2sHandle   hI2S;
			Uint16          readBuff[size];
            Uint16          buffLen;
            CSL_status   status;
            status = I2S_read(hI2S, &readBuff, buffLen);
     @endverbatim
CSL_Status I2S_read (CSL_I2sHandle	hI2s,
				Uint16 *readBuff, Uint16 buffLen)
	Uint16	i2sIrStatus;
	Int16  latency;
	Uint16  dummyData;
	if(NULL == hI2s)
		return(CSL_ESYS_BADHANDLE);
	if ((NULL == readBuff) || (0 == buffLen))
		return(CSL_ESYS_INVPARAMS);
	if ((hI2s->firstRead == TRUE) && (hI2s->opMode == I2S_POLLED))
		hI2s->firstRead = FALSE;
		if (hI2s->loopBackMode == I2S_LOOPBACK_ENABLE)
			if (hI2s->datapack == I2S_DATAPACK_ENABLE)
				switch(hI2s->wordLen)
	     			case I2S_WORDLEN_8:
						if(hI2s->fsDiv == I2S_FSDIV8)
							latency = CSL_I2S_LATENCY_6;
						else
							latency = CSL_I2S_LATENCY_5;
						break;
	     			case I2S_WORDLEN_10:
	     			case I2S_WORDLEN_12:
	     			case I2S_WORDLEN_14:
	     			case I2S_WORDLEN_16:
						latency = 6;
						break;
					default:
						break;
			else
				latency = CSL_I2S_LATENCY_2;
		else
     			case I2S_WORDLEN_8:
     			case I2S_WORDLEN_18:
     			case I2S_WORDLEN_20:
     			case I2S_WORDLEN_24:
     			case I2S_WORDLEN_32:
					break;
					latency = CSL_I2S_LATENCY_3;
					break;
				default:
					break;
		/* Ignore the first few frames */
		while(latency > 0)
			i2sIrStatus = regs->I2SINTFL;
			if((i2sIrStatus & CSL_I2S_I2SINTFL_RCVMONFL_MASK) ||
			   (i2sIrStatus & CSL_I2S_I2SINTFL_RCVSTFL_MASK))
			    /* Copy data from receive register to local buffer      */
				dummyData = regs->I2SRXLTU;
				dummyData = regs->I2SRXLTL;
#else
				dummyData = regs->I2SRXLT1;
				dummyData = regs->I2SRXLT0;
#endif
				if(hI2s->chType == I2S_CHAN_STEREO)
					dummyData = regs->I2SRXRTU;
					dummyData = regs->I2SRXRTL;
#else
					dummyData = regs->I2SRXRT1;
					dummyData = regs->I2SRXRT0;
#endif
					/* Reset IIR register for the stereo channel  */
					CSL_FINST(regs->I2SINTFL, I2S_I2SINTFL_RCVSTFL, CLEAR);
				CSL_FINST(regs->I2SINTFL, I2S_I2SINTFL_RCVMONFL, CLEAR);
				latency--;
				latency--;
		dummyData = dummyData;
	/* This function is not supporting for DMA_POLLED & DMA_INTERRUPT mode */
	if((hI2s->opMode == DMA_POLLED)||
		(hI2s->opMode == DMA_INTERRUPT))
	if(hI2s->opMode == I2S_INTERRUPT)
		while(buffLen > 0)
			*readBuff++ = regs->I2SRXLTU;
			*readBuff++ = regs->I2SRXLTL;
#else
			*readBuff++ = regs->I2SRXLT1;
			*readBuff++ = regs->I2SRXLT0;
#endif
				*readBuff++ = regs->I2SRXRTU;
				*readBuff++ = regs->I2SRXRTL;
#else
				*readBuff++ = regs->I2SRXRT1;
				*readBuff++ = regs->I2SRXRT0;
#endif
				buffLen -= 2;
			buffLen -= 2;
		/* Reset IIR register for the mono and sterio channel  */
	else
		while((buffLen > 0) && (fsError == 0) &&
				(ouError == 0))
			if(i2sIrStatus & CSL_I2S_I2SINTFL_FERRFL_MASK)
				fsError++;
			if(i2sIrStatus & CSL_I2S_I2SINTFL_OUERRFL_MASK)
				ouError++;
#else
#endif
				if(i2sIrStatus & CSL_I2S_I2SINTFL_RCVSTFL_MASK)
#else
#endif
					/* Reset IIR register for the sterio channel  */
					buffLen -= 2;
				buffLen -= 2;
	fsError = 0;
	ouError = 0;
	return (CSL_SOK);
 *   @n@b I2S_write
 *   @b Description
 *   @n This function Write data to specified device.
 *   @b Arguments
 *   @verbatim
			writeBuff         Pointer to the write buffer.
     @endverbatim
 *   @li                    CSL_SOK             - Write successful
 *   @b Modifies
 *   @n None
 *   @b Example
 *   @verbatim
            CSL_I2sHandle   hI2S;
			Uint16          writeBuff[size];
            Uint16          buffLen;
            CSL_status   status;
            status = I2S_write(hI2S, &writeBuff, buffLen);
     @endverbatim
CSL_Status I2S_write(CSL_I2sHandle	hI2s,
				Uint16 *writeBuff, Uint16 buffLen)
	Uint16	i2sIrStatus;
	volatile Int16   i;
	if(hI2s == NULL)
	if((NULL == writeBuff) || (0 == buffLen))
		while(buffLen > 0)
		    /* Copy data from local buffer to transmit register  */
	 		regs->I2STXLTL = *writeBuff++;
			regs->I2STXLTU = *writeBuff++;
#else
	 		regs->I2STXLT0 = *writeBuff++;
			regs->I2STXLT1 = *writeBuff++;
#endif
				regs->I2STXRTL = *writeBuff++;
				regs->I2STXRTU = *writeBuff++;
#else
				regs->I2STXRT0 = *writeBuff++;
				regs->I2STXRT1 = *writeBuff++;
#endif
				buffLen -= 2;
			buffLen -= 2;
	else
				(ouError == 0))
				fsError++;
				ouError++;
			if((i2sIrStatus & CSL_I2S_I2SINTFL_XMITMONFL_MASK) ||
				(i2sIrStatus &  CSL_I2S_I2SINTFL_XMITSTFL_MASK))
				//for(i = 0; i < 100; i++);
#else
#endif
				if(i2sIrStatus & CSL_I2S_I2SINTFL_XMITSTFL_MASK)
#else
#endif
					buffLen -= 2;
				buffLen -= 2;
	fsError = 0;
	ouError = 0;
	return (CSL_SOK);
 *   @n@b I2S_reset
 *   @b Description
 *   @n This function Reset control and hardware specific register.
 *   @b Arguments
 *   @verbatim
     @endverbatim
 *   @li                    CSL_SOK             - Reset successful
 *   @n  This function should call after the I2S_config call.
 *   @n  I2S_close function can be call after this function call.
 *   @b Modifies
 *   @n None
 *   @b Example
 *   @verbatim
            CSL_I2sHandle   hI2S;
            CSL_status   status;
            status = I2S_reset(hI2S);
     @endverbatim
CSL_Status I2S_reset(CSL_I2sHandle	hI2s)
	if(hI2s == NULL)
	/* Reset the register */
#else
#endif
#else
#endif
	return(CSL_SOK);
 *   @n@b I2S_transEnable
 *   @b Description
 *   @n  This function Enable or Disable transmission/receive bit
 *   @b Arguments
 *   @verbatim
     @endverbatim
 *   @n  This fuction calls before read/write function to enable transnission
 *   @n  This fuction calls before read/write function to disable transnission
 *   @b Modifies
 *   @n None
 *   @b Example
 *   @verbatim
            CSL_I2sHandle   hI2S;
			Uint16			enableBit
            CSL_status   	status;
            status = I2S_transEnable(CSL_I2sHandle	i2sHandle,
            						Uint16 enableBit);
     @endverbatim
CSL_Status I2S_transEnable(CSL_I2sHandle	hI2s, Uint16 enableBit)
	if(NULL == hI2s)
	if(enableBit == TRUE)
	    /*  Enable the transmit and receive bit */
		CSL_FINST(regs->I2SSCTRL, I2S_I2SSCTRL_ENABLE, SET);
	else
	    /*  Disable the transmit and receive bit */
		CSL_FINST(regs->I2SSCTRL, I2S_I2SSCTRL_ENABLE, CLEAR);
	return(CSL_SOK);
If you need further information, please let me know.
Thanks and regards,
Koichiro Tashiro
  • Hi Koichiro-san,
    The only thing I can think of at this point is the frame length. If the 64 is working and 100 is not working, maybe there is a limitation on the frame length. Please try the frame length 96 or 128 which are the multiples of 32.
    Ming
  • Hi Ming,
    Changing the frame length is not possible as FPGA side needs to be modified.
    But they tried 481280 cycles (this is also multiples of 32) before and it was failed.
    BTW, if FRMT = 0 (I2S format), the issue never happens. So the customer suspects something is wrong with R-ch data acquisition mechanism in DSP format.
    Thanks and regards,
    Koichiro Tashiro
  • Hi Koichiro-san,
    Since the C55xx device is legacy device, we will not be able to dig deep to find out why the DSP format is not working.
    Can the customer use the I2S format instead of DSP format or use the frame length 64 bit?
    Ming
