Part Number: AM6442
Hi TI team,
I’m looking for timing specification of the DDRSS of the AM6442. I need some specific timing of your DDR controller in order to check by simulation that integrity and timings are ok.
Would you be able to give me those values :
- Controller AM6442 Setting (Write) applies to Data and AddCmd Timing Parameters :
- Minimum Transmit setup time : This is the minimum amount of setup time that is guaranteed to exist between the signals and their timing reference at the driving component, that is, the Controller.
- Minimum Transmit hold time : This is the minimum amount of hold time that is guaranteed to exist between the signals and their timing reference at the driving component, that is, the Controller.
- Controller AM6442 Setting (Read) Data Timing Parameters :
- Max Receive Skew (+) : This is the maximum amount by which the Data is allowed to lag the Strobe at the receiving component, that is, the Controller.
- Max Receive Skew (+) : This is the maximum amount by which the Data is allowed to lead the Strobe at the receiving component, that is, the Controller.
Those parameters are mandatory to validate the interface between LPDDR4 and AM64 by simulation.
Thank you
Best Regards
