TDA4VM: Error log in HS device boot
Part Number: TDA4VM
Hi, TI Expert
I have booted Linux through SBL/SPL on the customized board of the TDA4VM HS device.
I found 2 Error logs:
E/TC:0 0 ti_sci_get_response:120 Message not acknowledged
E/TC:0 0 ti_sci_do_xfer:149 Failed to get response (-65536)
Could you please teach me:
What do these two logs mean? Is there an error in HS boot?
SDK Version:8.4
Both SPL and SBL boot mode will display these log,
Full boot logs for SPL and SBL are as follows:
U-Boot SPL 2021.01 (Jun 27 2023 - 11:44:51 +0800)
Model: Texas Instruments K3 J721E SoC
SYSFW ABI: 3.1 (firmware rev 0x0008 '8.4.1--v08.04.01 (Jolly Jellyfi')
Trying to boot from MMC2
Authentication passed
Starting ATF on ARM64 core...
NOTICE:  BL31: v2.6(release):v2.7-rc0-dirty
NOTICE:  BL31: Built : 09:18:58, Aug 30 2022
I/TC:
I/TC: OP-TEE version: 3.17.0-125-g15a746d28 (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10))) #1 Tue Aug 30 09:19:19 UTC 2022 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: SYSFW ABI: 3.1 (firmware rev 0x0008 '8.4.1--v08.04.01 (Jolly Jellyfi')
I/TC: HUK Initialized
I/TC: Activated SA2UL device
I/TC: Enabled firewalls for SA2UL TRNG device
I/TC: SA2UL TRNG initialized
I/TC: SA2UL Drivers initialized
I/TC: Primary CPU switching to normal world boot
U-Boot SPL 2021.01 (Jun 27 2023 - 11:44:34 +0800)
U-Boot 2021.01 (Jun 27 2023 - 11:44:34 +0800)
SoC:   J721E SR1.1 HS-SE
DRAM:  2 GiB
Flash: 0 Bytes
MMC:   sdhci@4f80000: 0, sdhci@4fb0000: 1
Loading Environment from FAT... OK
In:    serial@2800000
Out:   serial@2800000
Err:   serial@2800000
am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA00101 cpsw_ver: 0x6BA80100 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000
Net:   Could not get PHY for ethernet@46000000port@1: addr 0
am65_cpsw_nuss_port ethernet@46000000port@1: phy_connect() failed
No ethernet found.
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc1 is current device
SD/MMC found on device 1
Failed to load 'boot.scr'
1694 bytes read in 9 ms (183.6 KiB/s)
Loaded env from uEnv.txt
Importing environment from mmc1 ...
Running uenvcmd ...
1 bytes read in 9 ms (0 Bytes/s)
Already setup.
k3_r5f_rproc r5f@41000000: Core 1 is already in use. No rproc commands work
k3_r5f_rproc r5f@41400000: Core 2 is already in use. No rproc commands work
1359284 bytes read in 66 ms (19.6 MiB/s)
Load Remote Processor 2 with data@addr=0x82000000 1359284 bytes: Success!
302028 bytes read in 23 ms (12.5 MiB/s)
Load Remote Processor 3 with data@addr=0x82000000 302028 bytes: Success!
1469172 bytes read in 71 ms (19.7 MiB/s)
Load Remote Processor 6 with data@addr=0x82000000 1469172 bytes: Success!
1469172 bytes read in 70 ms (20 MiB/s)
Load Remote Processor 7 with data@addr=0x82000000 1469172 bytes: Success!
12980176 bytes read in 545 ms (22.7 MiB/s)
Load Remote Processor 8 with data@addr=0x82000000 12980176 bytes: Success!
16810039 bytes read in 702 ms (22.8 MiB/s)
## Loading kernel from FIT Image at 90000000 ...
   Using 'reach-db2-sd.dtb' configuration
   Trying 'kernel@1' kernel subimage
     Description:  Linux kernel
     Type:         Kernel Image
     Compression:  uncompressed
     Data Start:   0x900000f4
     Data Size:    16707698 Bytes = 15.9 MiB
     Architecture: AArch64
     OS:           Linux
     Load Address: 0x80080000
     Entry Point:  0x80080000
   Verifying Hash Integrity ... OK
## Loading fdt from FIT Image at 90000000 ...
   Trying 'reach-db2-sd.dtb' fdt subimage
     Description:  Flattened Device Tree blob
     Type:         Flat Device Tree
     Data Start:   0x90fef228
     Data Size:    100539 Bytes = 98.2 KiB
     Load Address: 0x83000000
   Loading fdt from 0x90fef228 to 0x83000000
   Booting using the fdt blob at 0x83000000
   Loading Kernel Image
   Loading Device Tree to 000000008ffe4000, end 000000008ffff249 ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[    0.000000] Linux version 5.10.120-g95b90aa828 (db2@TDA4) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT Tue Jun 27 11:37:56 CST 2023
[    0.000000] Machine model: Neusoft Reach DB2 Board - SDMMC
[    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[    0.000000] printk: bootconsole [ns16550a0] enabled
[    0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader!
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a0100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 31 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a6000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a6100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a7000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a7100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@a8000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 79 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c71-memory@a8100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000af000000, size 96 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@af000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000cd000000, size 416 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory@cd000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000e7000000, size 8 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-queues@e7000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000e7800000, size 24 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-buffers@e7800000, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
[    0.000000]   node   0: [mem 0x000000009e800000-0x00000000b4ffffff]
[    0.000000]   node   0: [mem 0x00000000b5000000-0x00000000ccffffff]
[    0.000000]   node   0: [mem 0x00000000cd000000-0x00000000e8ffffff]
[    0.000000]   node   0: [mem 0x00000000e9000000-0x00000000ffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000] cma: Failed to reserve 400 MiB
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 22 pages/cpu s50008 r8192 d31912 u90112
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: EL2 vector hardening
[    0.000000] CPU features: kernel page table isolation forced ON by KASLR
[    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[    0.000000] CPU features: detected: Spectre-BHB
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 516096
[    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:640k(ospi.tiboot3.bin),384k(ospi.tifs.bin),1536k(a_ospi.app),1536k(a_ospi_mcu1_1.app),512k(a_atf_optee.appimage),16384k(a_tikernelimage_linux.appimage),128k(a_tidtb_linux.appimage),2048k(a_lateapp1),9216k(a_lateapp2),1536k(b_ospi.app),1536k(b_ospi_mcu1_1.app),512k(b_atf_optee.appimage),16384k(b_tikernelimage_linux.appimage),128k(b_tidtb_linux.appimage),2048k(b_lateapp1),9216k(b_lateapp2),128k(a_ota_data),128k(b_ota_data),128k(nor_spi_patterns.bin);47034000.hyperbus:512k(hbmc.tiboot3),512k(hbmc.tifs),768k(hbmc.app),6m(hbmc.aft_optee),23m(hbmc.linux.image),1m(hbmc.linux.dtb),8m(hbmc.lateapp1),-@40704k(hbmc.lateapp2) root=PARTUUID=f3465619-02 rw rootfstype=ext4 rootwait
[    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] Memory: 820756K/2097152K available (9664K kernel code, 1082K rwdata, 3800K rodata, 1664K init, 384K bss, 1276396K reserved, 0K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 960 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[    0.000000] ITS [mem 0x01820000-0x0182ffff]
[    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @81c00000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x0000000081430000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000081440000
[    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[    0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[    0.008376] Console: colour dummy device 80x25
[    0.012939] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[    0.023609] pid_max: default: 32768 minimum: 301
[    0.028367] LSM: Security Framework initializing
[    0.033114] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.040682] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.049483] rcu: Hierarchical SRCU implementation.
[    0.054531] Platform MSI: msi-controller@1820000 domain created
[    0.060718] EFI services will not be available.
[    0.065445] smp: Bringing up secondary CPUs ...
I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
[    0.078728] Detected PIPT I-cache on CPU1
[    0.078751] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[    0.078762] GICv3: CPU1: using allocated LPI pending table @0x0000000081450000
[    0.078799] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[    0.078850] smp: Brought up 1 node, 2 CPUs
[    0.108193] SMP: Total of 2 processors activated.
[    0.112998] CPU features: detected: 32-bit EL0 Support
[    0.118252] CPU features: detected: CRC32 instructions
[    0.130988] CPU: All CPU(s) started at EL2
[    0.135183] alternatives: patching kernel code
[    0.140278] devtmpfs: initialized
[    0.148642] KASLR disabled due to lack of seed
[    0.153289] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.163252] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[    0.170312] pinctrl core: initialized pinctrl subsystem
[    0.175887] DMI not present or invalid.
[    0.180097] NET: Registered protocol family 16
[    0.184847] DMA: preallocated 128 KiB GFP_KERNEL pool for atomic allocations
[    0.192085] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.200024] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.208291] thermal_sys: Registered thermal governor 'step_wise'
[    0.208293] thermal_sys: Registered thermal governor 'power_allocator'
[    0.214826] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.228455] ASID allocator initialised with 32768 entries
[    0.243967] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.250823] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.257670] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.264515] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.271977] cryptd: max_cpu_qlen set to 1000
[    0.277885] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected
[    0.286648] vsys_3v3: supplied by board_12v0
[    0.291183] vsys_5v0: supplied by board_12v0
[    0.295936] iommu: Default domain type: Translated
[    0.301101] SCSI subsystem initialized
[    0.305064] mc: Linux media interface: v0.10
[    0.309442] videodev: Linux video capture interface: v2.00
[    0.315072] pps_core: LinuxPPS API ver. 1 registered
[    0.320142] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.329479] PTP clock support registered
[    0.333496] EDAC MC: Ver: 3.0.0
[    0.337205] FPGA manager framework
[    0.340718] Advanced Linux Sound Architecture Driver Initialized.
[    0.347303] clocksource: Switched to clocksource arch_sys_counter
[    0.353633] VFS: Disk quotas dquot_6.6.0
[    0.357666] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.367228] Carveout Heap: Exported 384 MiB at 0x00000000b5000000
[    0.373520] NET: Registered protocol family 2
[    0.378143] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.386336] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
[    0.395086] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.403235] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
[    0.410859] TCP: Hash tables configured (established 16384 bind 16384)
[    0.417636] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[    0.424508] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[    0.431876] NET: Registered protocol family 1
[    0.436693] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[    0.446947] Initialise system trusted keyrings
[    0.451579] workingset: timestamp_bits=46 max_order=18 bucket_order=0
[    0.459691] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.485046] Key type asymmetric registered
[    0.489232] Asymmetric key parser 'x509' registered
[    0.494231] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[    0.501790] io scheduler mq-deadline registered
[    0.506415] io scheduler kyber registered
[    0.511465] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
[    0.517625] pinctrl-single 11c000.pinctrl: 173 pins, size 692
[    0.524828] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[    0.531088] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[    0.538768] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[    0.546601] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001f8f)
[    0.554726] arm-smmu-v3 36600000.iommu: allocated 65536 entries for cmdq
[    0.561775] arm-smmu-v3 36600000.iommu: allocated 32768 entries for evtq
[    0.570272] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
[    0.582506] brd: module loaded
[    0.588906] loop: module loaded
[    0.594066] tun: Universal TUN/TAP device driver, 1.6
[    0.599818] VFIO - User Level meta-driver version: 0.3
[    0.605348] i2c /dev entries driver
[    0.609433] sdhci: Secure Digital Host Controller Interface driver
[    0.615753] sdhci: Copyright(c) Pierre Ossman
[    0.620334] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.626506] ledtrig-cpu: registered to indicate activity on CPUs
[    0.632791] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    0.639902] optee: probing for conduit method.
[    0.644462] optee: revision 3.17 (15a746d2)
[    0.644585] optee: dynamic shared memory is enabled
[    0.654046] optee: initialized driver
[    0.658848] NET: Registered protocol family 17
[    0.663454] 9pnet: Installing 9P2000 support
[    0.667855] Key type dns_resolver registered
[    0.672299] Loading compiled-in X.509 certificates
[    0.680220] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[    0.686555] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[    0.694048] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0008 '8.4.1--v08.04.01 (Jolly Jellyfi')
[    0.741541] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
[    0.750422] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created
[    0.760308] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
[    0.778142] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
[    0.788035] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[    0.794798] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[    0.803899] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
[    0.814043] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[    0.820802] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[    0.828761] printk: console [ttyS2] disabled
[    0.833155] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 19, base_baud = 3000000) is a 8250
[    0.841897] printk: console [ttyS2] enabled
[    0.850333] printk: bootconsole [ns16550a0] disabled
[    0.862518] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
[    0.972449] mmc0: CQHCI version 5.10
[    0.972841] mmc1: CQHCI version 5.10
[    0.983192] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
[    0.990061] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
[    0.996898] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
[    1.003743] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
[    1.010562] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
[    1.011970] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
[    1.017803] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
[    1.035392] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16)
[    1.049917] spi-nor spi0.0: mt35xu512aba (65536 Kbytes)
[    1.055159] 19 cmdlinepart partitions found on MTD device 47040000.spi.0
[    1.061851] Creating 19 MTD partitions on "47040000.spi.0":
[    1.067413] 0x000000000000-0x0000000a0000 : "ospi.tiboot3.bin"
[    1.073758] 0x0000000a0000-0x000000100000 : "ospi.tifs.bin"
[    1.079725] 0x000000100000-0x000000280000 : "a_ospi.app"
[    1.085421] 0x000000280000-0x000000400000 : "a_ospi_mcu1_1.app"
[    1.091711] 0x000000400000-0x000000480000 : "a_atf_optee.appimage"
[    1.098247] 0x000000480000-0x000001480000 : "a_tikernelimage_linux.appimage"
[    1.105685] 0x000001480000-0x0000014a0000 : "a_tidtb_linux.appimage"
[    1.112412] 0x0000014a0000-0x0000016a0000 : "a_lateapp1"
[    1.118104] 0x0000016a0000-0x000001fa0000 : "a_lateapp2"
[    1.123787] 0x000001fa0000-0x000002120000 : "b_ospi.app"
[    1.129486] 0x000002120000-0x0000022a0000 : "b_ospi_mcu1_1.app"
[    1.135813] 0x0000022a0000-0x000002320000 : "b_atf_optee.appimage"
[    1.142388] 0x000002320000-0x000003320000 : "b_tikernelimage_linux.appimage"
[    1.149829] 0x000003320000-0x000003340000 : "b_tidtb_linux.appimage"
[    1.156564] 0x000003340000-0x000003540000 : "b_lateapp1"
[    1.162279] 0x000003540000-0x000003e40000 : "b_lateapp2"
[    1.167961] 0x000003e40000-0x000003e60000 : "a_ota_data"
[    1.174340] 0x000003e60000-0x000003e80000 : "b_ota_data"
[    1.174375] mmc0: Command Queue Engine enabled
[    1.180054] 0x000003e80000-0x000003ea0000 : "nor_spi_patterns.bin"
[    1.184093] mmc0: new HS200 MMC card at address 0001
[    1.191456] debugfs: Directory 'pd:27' with parent 'pm_genpd' already present!
[    1.202587] debugfs: Directory 'pd:26' with parent 'pm_genpd' already present!
[    1.202628] mmcblk0: mmc0:0001 8GUF4R 7.28 GiB
[    1.210897] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
[    1.214469] mmcblk0boot0: mmc0:0001 8GUF4R partition 1 31.9 MiB
[    1.221654] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
[    1.227624] mmcblk0boot1: mmc0:0001 8GUF4R partition 2 31.9 MiB
[    1.234832] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
[    1.240849] mmcblk0rpmb: mmc0:0001 8GUF4R partition 3 4.00 MiB, chardev (238:0)
[    1.248038] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
[    1.262633]  mmcblk0: p1
[    1.274827] ALSA device list:
[    1.277796]   No soundcards found.
[    2.038187] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
[    2.045951] Waiting for root device PARTUUID=f3465619-02...
[    2.079492] mmc1: new high speed SDHC card at address 5048
[    2.085319] mmcblk1: mmc1:5048 SD32G 29.7 GiB
[    2.091931]  mmcblk1: p1 p2
[    2.498714] EXT4-fs (mmcblk1p2): recovery complete
[    2.505012] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[    2.513121] VFS: Mounted root (ext4 filesystem) on device 179:98.
[    2.520438] devtmpfs: mounted
[    2.524187] Freeing unused kernel memory: 1664K
[    2.528804] Run /sbin/init as init process
[    2.798048] systemd[1]: System time before build time, advancing clock.
[    2.853954] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
[    2.875687] systemd[1]: Detected architecture arm64.
Welcome to Arago 2021.09!
[    2.912355] systemd[1]: Set hostname to <j7-evm>.
[    3.089867] systemd[1]: Binding to IPv6 address not available since kernel does not support IPv6.
[    3.098766] systemd[1]: Binding to IPv6 address not available since kernel does not support IPv6.
[    3.123906] systemd[1]: Configuration file /lib/systemd/system/apps.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[    3.184739] random: systemd: uninitialized urandom read (16 bytes read)
[    3.191477] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[    3.203802] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[    3.213501] systemd[1]: Created slice system-getty.slice.
[  OK  ] Created slice system-getty.slice.
[    3.235385] random: systemd: uninitialized urandom read (16 bytes read)
[    3.242506] systemd[1]: Created slice system-serial\x2dgetty.slice.
[  OK  ] Created slice system-serial\x2dgetty.slice.
[    3.263376] random: systemd: uninitialized urandom read (16 bytes read)
[    3.270385] systemd[1]: Created slice User and Session Slice.
[  OK  ] Created slice User and Session Slice.
[    3.291505] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Started Dispatch Password …ts to Console Directory Watch.
[    3.315432] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Started Forward Password R…uests to Wall Directory Watch.
[    3.339414] systemd[1]: Reached target Paths.
[  OK  ] Reached target Paths.
[    3.355369] systemd[1]: Reached target Remote File Systems.
[  OK  ] Reached target Remote File Systems.
[    3.375357] systemd[1]: Reached target Slices.
[  OK  ] Reached target Slices.
[    3.391359] systemd[1]: Reached target Swap.
[  OK  ] Reached target Swap.
[    3.411867] systemd[1]: Listening on RPCbind Server Activation Socket.
[  OK  ] Listening on RPCbind Server Activation Socket.
[    3.435404] systemd[1]: Reached target RPC Port Mapper.
[  OK  ] Reached target RPC Port Mapper.
[    3.458048] systemd[1]: Listening on Process Core Dump Socket.
[  OK  ] Listening on Process Core Dump Socket.
[    3.479515] systemd[1]: Listening on initctl Compatibility Named Pipe.
[  OK  ] Listening on initctl Compatibility Named Pipe.
[    3.512545] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[    3.520936] systemd[1]: Listening on Journal Socket (/dev/log).
[  OK  ] Listening on Journal Socket (/dev/log).
[    3.543611] systemd[1]: Listening on Journal Socket.
[  OK  ] Listening on Journal Socket.
[    3.559689] systemd[1]: Listening on Network Service Netlink Socket.
[  OK  ] Listening on Network Service Netlink Socket.
[    3.583563] systemd[1]: Listening on udev Control Socket.
[  OK  ] Listening on udev Control Socket.
[    3.603498] systemd[1]: Listening on udev Kernel Socket.
[  OK  ] Listening on udev Kernel Socket.
[    3.625499] systemd[1]: Mounting Huge Pages File System...
[    3.641445] systemd[1]: Mounting POSIX Message Queue File System...
[    3.669412] systemd[1]: Mounting Kernel Debug File System...
[    3.698390] systemd[1]: Mounting Temporary Directory (/tmp)...
[    3.717564] systemd[1]: Starting Create list of static device nodes for the current kernel...
         Starting Create list of st…odes for the current kernel...
[    3.745290] systemd[1]: Starting Start psplash boot splash screen...
[    3.774346] systemd[1]: Starting RPC Bind...
[    3.791533] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    3.803212] systemd[1]: Starting Journal Service...
[    3.832252] systemd[1]: Starting Load Kernel Modules...
[    3.848857] systemd[1]: Starting Remount Root and Kernel File Systems...
         Starting Remount Root and Kernel File Systems cryptodev: loading out-of-tree module taints kernel.
[0m...
[    3.870247] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
[    3.872368] cryptodev: driver 1.10 loaded.
[    3.882126] systemd[1]: Starting udev Coldplug all Devices...
[    3.906034] systemd[1]: Started RPC Bind.
[  OK  ] Started RPC Bind.
[    3.923757] systemd[1]: Started Journal Service.
[  OK  ] Started Journal Service.
[  OK  ] Mounted Huge Pages File System.
[  OK  ] Mounted POSIX Message Queue File System.
[  OK  ] Mounted Kernel Debug File System.
[  OK  ] Mounted Temporary Directory (/tmp).
[  OK  ] Started Create list of sta… nodes for the current kernel.
[FAILED] Failed to start Start psplash boot splash screen.
See 'systemctl status psplash-start.service' for details.
[DEPEND] Dependency failed for Star…progress communication helper.
[  OK  ] Started Load Kernel Modules.
[  OK  ] Started Remount Root and Kernel File Systems.
         Mounting Kernel Configuration File System...
         Starting Flush Journal to Persistent Storage...
[    4.148527] systemd-journald[138]: Received client request to flush runtime journal.
         Starting Apply Kernel Variables...
         Starting Create Static Device Nodes in /dev...
[  OK  ] Mounted Kernel Configuration File System.
[  OK  ] Started Flush Journal to Persistent Storage.
[  OK  ] Started Apply Kernel Variables.
[  OK  ] Started Create Static Device Nodes in /dev.
[  OK  ] Started udev Coldplug all Devices.
[    4.275886] urandom_read_iter: 47 callbacks suppressed
[    4.275891] random: systemd: uninitialized urandom read (16 bytes read)
[  OK  ] Reached target Local File Systems (Pre).
[    4.307396] random: systemd: uninitialized urandom read (16 bytes read)
         Mounting /media/ram...
[    4.320520] random: systemd-journal: uninitialized urandom read (16 bytes read)
         Mounting /var/volatile...
         Starting udev Wait for Complete Device Initialization...
         Starting udev Kernel Device Manager...
[  OK  ] Mounted /media/ram.
[  OK  ] Mounted /var/volatile.
         Starting Load/Save Random Seed...
[  OK  ] Reached target Local File Systems.
         Starting Create Volatile Files and Directories...
[  OK  ] Started Create Volatile Files and Directories.
         Starting Network Time Synchronization...
         Starting Update UTMP about System Boot/Shutdown...
[  OK  ] Started udev Kernel Device Manager.
[  OK  ] Started Update UTMP about System Boot/Shutdown.
[  OK  ] Started Network Time Synchronization.
[  OK  ] Reached target System Time Set.
[  OK  ] Reached target System Time Synchronized.
[    4.750933] CAN device driver interface
[    4.762041] m_can_platform 2771000.can: m_can device registered (irq=25, version=32)
[    4.799061] random: crng init done
[    4.802570] random: 19 urandom warning(s) missed due to ratelimiting
[    4.841087] m_can_platform 2791000.can: m_can device registered (irq=27, version=32)
[    4.870450] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node vision-apps-c66-dma-memory@a7000000
[    4.881444] m_can_platform 27b1000.can: m_can device registered (irq=29, version=32)
[    4.892183] k3-dsp-rproc 4d80800000.dsp: configured DSP for IPC-only mode
[    4.925750] remoteproc remoteproc0: 4d80800000.dsp is available
[    4.933891] remoteproc remoteproc0: attaching to 4d80800000.dsp
[    4.943469] m_can_platform 27d1000.can: m_can device registered (irq=31, version=32)
[    4.953598] k3-dsp-rproc 4d80800000.dsp: DSP initialized in IPC-only mode
[    4.973709]  remoteproc0#vdev0buffer: assigned reserved memory node vision-apps-c66-dma-memory@a7000000
[    5.004442] virtio_rpmsg_bus virtio0: rpmsg host is online
[    5.010017] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xd
[    5.023249]  remoteproc0#vdev0buffer: registered virtio0 (type 7)
[    5.047455] remoteproc remoteproc0: remote processor 4d80800000.dsp is now attached
[    5.056387] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node vision-apps-c66-dma-memory@a6000000
[    5.067127] k3-dsp-rproc 4d81800000.dsp: configured DSP for IPC-only mode
[    5.074958] remoteproc remoteproc1: 4d81800000.dsp is available
[    5.081942] remoteproc remoteproc1: attaching to 4d81800000.dsp
[    5.108509] k3-dsp-rproc 4d81800000.dsp: DSP initialized in IPC-only mode
[    5.115921]  remoteproc1#vdev0buffer: assigned reserved memory node vision-apps-c66-dma-memory@a6000000
[    5.125796] virtio_rpmsg_bus virtio1: rpmsg host is online
[    5.131352] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xd
[    5.138594]  remoteproc1#vdev0buffer: registered virtio1 (type 7)
[    5.145369] pvrsrvkm 4e20000000.gpu: More than one power domain for this GPU, gpu driver manages power domains
[    5.155767] remoteproc remoteproc1: remote processor 4d81800000.dsp is now attached
[    5.166617] PVR_K:  173: Read BVNC 22.104.208.318 from HW device registers
[    5.168748] k3-dsp-rproc 64800000.dsp: assigned reserved memory node vision-apps-c71-dma-memory@a8000000
[    5.203413] PVR_K:  173: RGX Device registered with BVNC 22.104.208.318
[    5.206391] k3-dsp-rproc 64800000.dsp: configured DSP for IPC-only mode
[    5.248522] remoteproc remoteproc2: 64800000.dsp is available
[    5.272406] [drm] Initialized pvr 1.15.6133109 20170530 for 4e20000000.gpu on minor 0
[    5.315723] remoteproc remoteproc2: attaching to 64800000.dsp
[    5.342480] k3_r5_rproc bus@100000:bus@28380000:r5fss@41000000: MCU cluster requires both R5F cores to be enabled, num_cores = 0
[    5.359873] remoteproc remoteproc2: unsupported resource 65538
[    5.376028] k3-dsp-rproc 64800000.dsp: DSP initialized in IPC-only mode
[    5.390124] platform 5c00000.r5f: configured R5F for IPC-only mode
[    5.390503]  remoteproc2#vdev0buffer: assigned reserved memory node vision-apps-c71-dma-memory@a8000000
[    5.407697] platform 5c00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
[    5.412140] virtio_rpmsg_bus virtio2: rpmsg host is online
[    5.416790] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xd
[    5.423702]  remoteproc2#vdev0buffer: registered virtio2 (type 7)
[    5.451894] remoteproc remoteproc2: remote processor 64800000.dsp is now attached
[    5.456270] remoteproc remoteproc3: 5c00000.r5f is available
[    5.507505] remoteproc remoteproc3: attaching to 5c00000.r5f
[    5.521212] platform 5c00000.r5f: R5F core initialized in IPC-only mode
[    5.527977]  remoteproc3#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
[    5.544878] virtio_rpmsg_bus virtio3: rpmsg host is online
[    5.559779] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xd
[    5.601987]  remoteproc3#vdev0buffer: registered virtio3 (type 7)
[    5.624835] remoteproc remoteproc3: remote processor 5c00000.r5f is now attached
[    5.655366] platform 5d00000.r5f: configured R5F for IPC-only mode
[    5.682213] platform 5d00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
[    5.700964] remoteproc remoteproc4: 5d00000.r5f is available
[    5.734860] remoteproc remoteproc4: attaching to 5d00000.r5f
[    5.765773] platform 5d00000.r5f: R5F core initialized in IPC-only mode
[    5.787709]  remoteproc4#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
[    5.826385] virtio_rpmsg_bus virtio4: rpmsg host is online
[    5.841266] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xd
[    5.850698] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0x15
[    5.855151]  remoteproc4#vdev0buffer: registered virtio4 (type 7)
[    5.858059] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0x15
[    5.878014] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xe
[    5.888978] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0x15
[    5.898313] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xe
[    5.907194] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0x15
[    5.914845] remoteproc remoteproc4: remote processor 5d00000.r5f is now attached
[    5.922469] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xe
[    5.930123] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0x15
[    5.939582] virtio_rpmsg_bus virtio3: creating channel ti.ethfw.notifyservice addr 0x1e
[    5.947794] virtio_rpmsg_bus virtio3: creating channel rpmsg-kdrv addr 0x1a
[    5.955166] virtio_rpmsg_bus virtio4: creating channel ti.ipc4.ping-pong addr 0xe
[    5.962937] rpmsg-kdrv-eth-switch rpmsg-kdrv-1-mpu_1_0_ethswitch-device-0: Device info: permissions: 3FFFFFFF uart_id: 2
[    5.974355] rpmsg-kdrv-eth-switch rpmsg-kdrv-1-mpu_1_0_ethswitch-device-0: FW ver 0.2 (rev 0) 27/Jun/2023 SHA:fd3a6ecf
[    5.986390] k3_r5_rproc bus@100000:r5fss@5e00000: MCU cluster requires both R5F cores to be enabled, num_cores = 0
[    5.986764] rpmsg-kdrv-eth-switch rpmsg-kdrv-3-mpu_1_0_ethmac-device-1: Device info: permissions: 3FFFFFFF uart_id: 2
[    6.007461] rpmsg-kdrv-eth-switch rpmsg-kdrv-3-mpu_1_0_ethmac-device-1: FW ver 0.2 (rev 0) 27/Jun/2023 SHA:fd3a6ecf
[    6.030956] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xe
[  OK  ] Created slice system-systemd\x2dfsck.slice.
[  OK  ] Found device /dev/mmcblk0p1.
         Starting File System Check on /dev/mmcblk0p1...
[  OK  ] Started File System Check on /dev/mmcblk0p1.
         Mounting /run/media/mmcblk0p1...
[    6.702919] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[  OK  ] Mounted /run/media/mmcblk0p1.
[    6.752572] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: rpmsg attach_ext - rx_mtu:1522 features:0000000B tx_mtu[0]:2024 flow_idx:172 tx_cpsw_psil_dst_id:51712 mac_addr:70:ff:76:1d:92:c1 mac-only:0
[    6.904683] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: virt_cpsw_nuss mac loaded
[    6.918092] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: rdev_features:0000000B rdev_mtu:1522 flow_id:172 tx_psil_dst_id:4A00 mac_only:0
[    6.958081] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: local_mac_addr:00:00:00:00:00:00 rdev_mac_addr:70:ff:76:1d:92:c1
[  OK  ] Found device /dev/mmcblk1p1.
         Starting File System Check on /dev/mmcblk1p1...
[    7.059282] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: rpmsg attach_ext - rx_mtu:1522 features:00000007 tx_mtu[0]:2024 flow_idx:173 tx_cpsw_psil_dst_id:51713 mac_addr:70:ff:76:1d:92:c2 mac-only:1
[    7.144441] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: virt_cpsw_nuss mac loaded
[    7.156657] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: rdev_features:00000007 rdev_mtu:1522 flow_id:173 tx_psil_dst_id:4A01 mac_only:1
[    7.215934] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: local_mac_addr:00:00:00:00:00:00 rdev_mac_addr:70:ff:76:1d:92:c2
[  OK  ] Started File System Check on /dev/mmcblk1p1.
         Mounting /run/media/mmcblk1p1...
[  OK  ] Mounted /run/media/mmcblk1p1.
[    7.659573] remoteproc remoteproc5: b034000.pru is available
[    7.676203] remoteproc remoteproc6: b004000.rtu is available
[    7.698342] remoteproc remoteproc7: b00a000.txpru is available
[    7.706744] remoteproc remoteproc8: b038000.pru is available
[    7.713554] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c
[    7.716146] remoteproc remoteproc9: b006000.rtu is available
[    7.727863] remoteproc remoteproc10: b00c000.txpru is available
[    7.740177] remoteproc remoteproc11: b134000.pru is available
[    7.758831] remoteproc remoteproc12: b104000.rtu is available
[    7.771281] remoteproc remoteproc13: b10a000.txpru is available
[    7.778207] remoteproc remoteproc14: b138000.pru is available
[    7.789772] remoteproc remoteproc15: b106000.rtu is available
[    7.796331] remoteproc remoteproc16: b10c000.txpru is available
[  OK  ] Started udev Wait for Complete Device Initialization.
[  OK  ] Started Hardware RNG Entropy Gatherer Daemon.
[  OK  ] Reached target System Initialization.
[  OK  ] Started Daily rotation of log files.
[  OK  ] Started Daily Cleanup of Temporary Directories.
[  OK  ] Reached target Timers.
[  OK  ] Listening on D-Bus System Message Bus Socket.
[  OK  ] Listening on dropbear.socket.
[  OK  ] Reached target Sockets.
[  OK  ] Reached target Basic System.
[  OK  ] Started Job spooling tools.
[  OK  ] Started Periodic Command Scheduler.
[  OK  ] Started D-Bus System Message Bus.
         Starting set host name as per compatible name...
         Starting IPv6 Packet Filtering Framework...
         Starting IPv4 Packet Filtering Framework...
[  OK  ] Started irqbalance daemon.
         Starting Reboot and dump vmcore via kexec...
         Starting Update pmic regis…fety feature on power rails...
         Starting rc.pvr.service...
         Starting Login Service...
[  OK  ] Started TEE Supplicant.
[  OK  ] Started set host name as per compatible name.
[  OK  ] Started IPv6 Packet Filtering Framework.
[  OK  ] Started IPv4 Packet Filtering Framework.
[  OK  ] Started Reboot and dump vmcore via kexec.
[  OK  ] Started Update pmic regist…safety feature on power rails.
[  OK  ] Reached target Network (Pre).
         Starting Network Service...
[  OK  ] Started Login Service.
[  OK  ] Started rc.pvr.service.
[  OK  ] Started Network Service.
[    8.714865] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: virt_cpsw_nuss mac started
         Starting Wait for Network to be Configured[    8.736908] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: virt_cpsw_nuss mac started
         Starting Network Name Resolution...
         Starting weston.service...
[  OK  ] Started Network Name Resolution.
[  OK  ] Reached target Network.
[  OK  ] Reached target Host and Network Name Lookups.
[  OK  ] Started NFS status monitor for NFSv2/3 locking..
         Starting Simple Network Ma…ent Protocol (SNMP) Daemon....
         Starting Permit User Sessions...
[  OK  ] Started Permit User Sessions.
[  OK  ] Started Getty on tty1.
[  OK  ] Started Serial Getty on ttyS2.
[  OK  ] Started Serial Getty on ttyS3.
[  OK  ] Reached target Login Prompts.
         Starting Synchronize System and HW clocks...
[FAILED] Failed to start Synchronize System and HW clocks.
See 'systemctl status sync-clocks.service' for details.
[  OK  ] Started Simple Network Man…ement Protocol (SNMP) Daemon..
[  OK  ] Started weston.service.
         Starting NRA Service...
         Starting telnetd.service...
[  OK  ] Started telnetd.service.
[   11.958785] can: controller area network core
[   11.963384] NET: Registered protocol family 29
[   12.000815] can: raw protocol
[  OK  ] Started NRA Service.
[   12.104018] PVR_K:  952: RGX Firmware image 'rgx.fw.22.104.208.318' loaded
[   12.148112] PVR_K:  952: Shader binary image 'rgx.sh.22.104.208.318' loaded
 _____                    _____           _         _
|  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
|     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
|__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
              |___|                    |___|
Arago Project j7-evm ttyS2
Arago 2021.09 j7-evm ttyS2
I/TC:
[    0.000000] Machine model: Neusoft Reach DB2 Board - OSPI
[    0.000000] cma: Reserved 400 MiB at 0x0000000085800000
[    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000  root=/dev/mmcblk0p1 rw rootfstype=ext4 rootwait
[    0.000000] Memory: 411156K/2097152K available (9664K kernel code, 1082K rwdata, 3800K rodata, 1664K init, 384K bss, 1276396K reserved, 409600K cma-reserved)
[    0.010465] Console: colour dummy device 80x25
[    0.016170] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[    0.029508] pid_max: default: 32768 minimum: 301
[    0.035452] LSM: Security Framework initializing
[    0.041388] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.050850] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.061845] rcu: Hierarchical SRCU implementation.
[    0.068156] Platform MSI: msi-controller@1820000 domain created
[    0.075892] EFI services will not be available.
[    0.081796] smp: Bringing up secondary CPUs ...
[    0.098346] Detected PIPT I-cache on CPU1
[    0.098375] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[    0.098388] GICv3: CPU1: using allocated LPI pending table @0x0000000081450000
[    0.098431] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[    0.098494] smp: Brought up 1 node, 2 CPUs
[    0.135172] SMP: Total of 2 processors activated.
[    0.141178] CPU features: detected: 32-bit EL0 Support
[    0.147745] CPU features: detected: CRC32 instructions
[    0.163566] CPU: All CPU(s) started at EL2
[    0.168811] alternatives: patching kernel code
[    0.175182] devtmpfs: initialized
[    0.185591] KASLR disabled due to lack of seed
[    0.191403] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.203856] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[    0.219769] pinctrl core: initialized pinctrl subsystem
[    0.226857] DMI not present or invalid.
[    0.232168] NET: Registered protocol family 16
[    0.238892] DMA: preallocated 128 KiB GFP_KERNEL pool for atomic allocations
[    0.247966] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.257935] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.268295] thermal_sys: Registered thermal governor 'step_wise'
[    0.268299] thermal_sys: Registered thermal governor 'power_allocator'
[    0.276475] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.293516] ASID allocator initialised with 32768 entries
[    0.312902] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.321478] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.330037] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.338594] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.347922] cryptd: max_cpu_qlen set to 1000
[    0.355283] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected
[    0.366240] vsys_3v3: supplied by board_12v0
[    0.371929] vsys_5v0: supplied by board_12v0
[    0.377907] iommu: Default domain type: Translated
[    0.384308] SCSI subsystem initialized
[    0.389256] mc: Linux media interface: v0.10
[    0.394719] videodev: Linux video capture interface: v2.00
[    0.401752] pps_core: LinuxPPS API ver. 1 registered
[    0.408091] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.419762] PTP clock support registered
[    0.424793] EDAC MC: Ver: 3.0.0
[    0.429428] FPGA manager framework
[    0.433827] Advanced Linux Sound Architecture Driver Initialized.
[    0.442055] clocksource: Switched to clocksource arch_sys_counter
[    0.449971] VFS: Disk quotas dquot_6.6.0
[    0.455012] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.467051] Carveout Heap: Exported 384 MiB at 0x00000000b5000000
[    0.474917] NET: Registered protocol family 2
[    0.480695] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.490954] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
[    0.501893] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.512078] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
[    0.521615] TCP: Hash tables configured (established 16384 bind 16384)
[    0.530102] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[    0.538691] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[    0.547902] NET: Registered protocol family 1
[    0.553929] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[    0.566782] Initialise system trusted keyrings
[    0.572566] workingset: timestamp_bits=46 max_order=18 bucket_order=0
[    0.582790] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.614417] Key type asymmetric registered
[    0.619649] Asymmetric key parser 'x509' registered
[    0.625900] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[    0.635349] io scheduler mq-deadline registered
[    0.641130] io scheduler kyber registered
[    0.647435] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
[    0.655125] pinctrl-single 11c000.pinctrl: 173 pins, size 692
[    0.664119] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[    0.671947] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[    0.681541] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[    0.691368] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001f8f)
[    0.701628] arm-smmu-v3 36600000.iommu: allocated 65536 entries for cmdq
[    0.710609] arm-smmu-v3 36600000.iommu: allocated 32768 entries for evtq
[    0.721342] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
[    0.736759] brd: module loaded
[    0.744805] loop: module loaded
[    0.751340] tun: Universal TUN/TAP device driver, 1.6
[    0.758536] VFIO - User Level meta-driver version: 0.3
[    0.765464] i2c /dev entries driver
[    0.770589] sdhci: Secure Digital Host Controller Interface driver
[    0.778482] sdhci: Copyright(c) Pierre Ossman
[    0.784207] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.791923] ledtrig-cpu: registered to indicate activity on CPUs
[    0.799781] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    0.808691] optee: probing for conduit method.
[    0.814393] optee: revision 3.17 (15a746d2)
[    0.814546] optee: dynamic shared memory is enabled
[    0.826382] optee: initialized driver
[    0.832390] NET: Registered protocol family 17
[    0.838148] 9pnet: Installing 9P2000 support
[    0.843643] Key type dns_resolver registered
[    0.849195] Loading compiled-in X.509 certificates
[    0.859144] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[    0.867070] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[    0.876368] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0008 '8.4.1--v08.04.01 (Jolly Jellyfi')
[    0.928064] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
[    0.939114] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created
[    0.951440] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
[    0.971886] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
[    0.984260] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[    0.992711] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[    1.004038] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
[    1.016731] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[    1.025192] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[    1.035121] printk: console [ttyS2] disabled
[    1.040614] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 19, base_baud = 3000000) is a 8250
[    1.051541] printk: console [ttyS2] enabled
[    1.062084] printk: bootconsole [ns16550a0] disabled
[    1.076717] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:250000000, add_val:3 pps:0
[    1.188832] mmc0: CQHCI version 5.10
[    1.193680] mmc1: CQHCI version 5.10
[    1.202265] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
[    1.210802] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
[    1.219316] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
[    1.227837] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
[    1.234379] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
[    1.245335] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
[    1.254323] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
[    1.267673] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16)
[    1.284744] spi-nor spi0.0: mt35xu512aba (65536 Kbytes)
[    1.291321] 19 fixed-partitions partitions found on MTD device 47040000.spi.0
[    1.300219] Creating 19 MTD partitions on "47040000.spi.0":
[    1.307167] 0x000000000000-0x0000000a0000 : "ospi.tiboot3.bin"
[    1.315146] 0x0000000a0000-0x000000100000 : "ospi.tifs.bin"
[    1.322639] 0x000000100000-0x000000280000 : "a_ospi.app"
[    1.329538] mmc0: Command Queue Engine enabled
[    1.335122] mmc0: new HS200 MMC card at address 0001
[    1.335344] 0x000000280000-0x000000400000 : "a_ospi_mcu1_1.app"
[    1.341679] mmcblk0: mmc0:0001 8GUF4R 7.28 GiB
[    1.349294] 0x000000400000-0x000000480000 : "a_atf_optee.appimage"
[    1.354456] mmcblk0boot0: mmc0:0001 8GUF4R partition 1 31.9 MiB
[    1.362614] 0x000000480000-0x000001480000 : "a_tikernelimage_linux.appimage"
[    1.369553] mmcblk0boot1: mmc0:0001 8GUF4R partition 2 31.9 MiB
[    1.378764] 0x000001480000-0x0000014a0000 : "a_tidtb_linux.appimage"
[    1.385697] mmcblk0rpmb: mmc0:0001 8GUF4R partition 3 4.00 MiB, chardev (238:0)
[    1.394076] 0x0000014a0000-0x0000016a0000 : "a_lateapp1"
[    1.403312]  mmcblk0: p1
[    1.409848] 0x0000016a0000-0x000001fa0000 : "a_lateapp2"
[    1.419703] 0x000001fa0000-0x000002120000 : "b_ospi.app"
[    1.426877] 0x000002120000-0x0000022a0000 : "b_ospi_mcu1_1.app"
[    1.434781] 0x0000022a0000-0x000002320000 : "b_atf_optee.appimage"
[    1.443006] 0x000002320000-0x000003320000 : "b_tikernelimage_linux.appimage"
[    1.452341] 0x000003320000-0x000003340000 : "b_tidtb_linux.appimage"
[    1.460779] 0x000003340000-0x000003540000 : "b_lateapp1"
[    1.467928] 0x000003540000-0x000003e40000 : "b_lateapp2"
[    1.475106] 0x000003e40000-0x000003e60000 : "a_ota_data"
[    1.482259] 0x000003e60000-0x000003e80000 : "b_ota_data"
[    1.489387] 0x000003ea0000-0x000003ec0000 : "nor_spi_patterns.bin"
[    1.497977] debugfs: Directory 'pd:27' with parent 'pm_genpd' already present!
[    1.507085] debugfs: Directory 'pd:26' with parent 'pm_genpd' already present!
[    1.517473] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
[    1.526629] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
[    1.535767] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
[    1.544897] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
[    1.565931] ALSA device list:
[    1.569639]   No soundcards found.
[    2.710124] sdhci-am654 4fb0000.mmc: Power on failed
[    2.746956] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
[    2.760257] EXT4-fs (mmcblk0p1): recovery complete
[    2.766259] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[    2.776385] VFS: Mounted root (ext4 filesystem) on device 179:1.
[    2.785577] devtmpfs: mounted
[    2.790331] Freeing unused kernel memory: 1664K
[    2.796077] Run /sbin/init as init process
[    2.869825] systemd[1]: System time before build time, advancing clock.
[    2.894459] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
[    2.921606] systemd[1]: Detected architecture arm64.
[    2.966420] systemd[1]: Set hostname to <j7-evm>.
[    3.095007] systemd[1]: Binding to IPv6 address not available since kernel does not support IPv6.
[    3.106178] systemd[1]: Binding to IPv6 address not available since kernel does not support IPv6.
[    3.130093] systemd[1]: Configuration file /lib/systemd/system/apps.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[    3.185112] random: systemd: uninitialized urandom read (16 bytes read)
[    3.193546] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[    3.208981] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[    3.221145] systemd[1]: Created slice system-getty.slice.
[    3.246153] random: systemd: uninitialized urandom read (16 bytes read)
[    3.255038] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    3.278147] random: systemd: uninitialized urandom read (16 bytes read)
[    3.286925] systemd[1]: Created slice User and Session Slice.
[    3.310308] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    3.338217] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    3.366197] systemd[1]: Reached target Paths.
[    3.382135] systemd[1]: Reached target Remote File Systems.
[    3.406127] systemd[1]: Reached target Slices.
[    3.422129] systemd[1]: Reached target Swap.
[    3.440361] systemd[1]: Listening on RPCbind Server Activation Socket.
[    3.466168] systemd[1]: Reached target RPC Port Mapper.
[    3.492359] systemd[1]: Listening on Process Core Dump Socket.
[    3.518330] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    3.545815] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[    3.556277] systemd[1]: Listening on Journal Socket (/dev/log).
[    3.582445] systemd[1]: Listening on Journal Socket.
[    3.598553] systemd[1]: Listening on Network Service Netlink Socket.
[    3.622393] systemd[1]: Listening on udev Control Socket.
[    3.646301] systemd[1]: Listening on udev Kernel Socket.
[    3.672852] systemd[1]: Mounting Huge Pages File System...
[    3.692632] systemd[1]: Mounting POSIX Message Queue File System...
[    3.720679] systemd[1]: Mounting Kernel Debug File System...
[    3.744871] systemd[1]: Mounting Temporary Directory (/tmp)...
[    3.772849] systemd[1]: Starting Create list of static device nodes for the current kernel...
[    3.804599] systemd[1]: Starting Start psplash boot splash screen...
[    3.833109] systemd[1]: Starting RPC Bind...
[    3.854318] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    3.870474] systemd[1]: Starting Journal Service...
[    3.897710] systemd[1]: Starting Load Kernel Modules...
[    3.914636] cryptodev: loading out-of-tree module taints kernel.
[    3.927316] cryptodev: driver 1.10 loaded.
[    3.935389] systemd[1]: Starting Remount Root and Kernel File Systems...
[    3.955339] systemd[1]: Starting udev Coldplug all Devices...
[    3.956532] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[    3.993862] systemd[1]: Started RPC Bind.
[    4.014689] systemd[1]: Started Journal Service.
[    4.208795] urandom_read_iter: 38 callbacks suppressed
[    4.208803] random: systemd-journal: uninitialized urandom read (16 bytes read)
[    4.225300] random: systemd: uninitialized urandom read (16 bytes read)
         Mounting Kernel Configuration File System.[    4.239306] random: systemd-journal: uninitialized urandom read (16 bytes read)
[    4.275040] systemd-journald[138]: Received client request to flush runtime journal.
[    4.875377] random: crng init done
[    4.883353] random: 28 urandom warning(s) missed due to ratelimiting
[    4.906298] CAN device driver interface
[    4.951571] m_can_platform 2771000.can: m_can device registered (irq=25, version=32)
[    4.976978] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node vision-apps-c66-dma-memory@a7000000
[    4.992315] m_can_platform 2791000.can: m_can device registered (irq=27, version=32)
[    4.993945] k3-dsp-rproc 4d80800000.dsp: configured DSP for IPC-only mode
[    5.013378] remoteproc remoteproc0: 4d80800000.dsp is available
[    5.024437] remoteproc remoteproc0: attaching to 4d80800000.dsp
[    5.033788] alloc_contig_range: [8586c, 85870) PFNs busy
[    5.047791] k3-dsp-rproc 4d80800000.dsp: DSP initialized in IPC-only mode
[    5.056983]  remoteproc0#vdev0buffer: assigned reserved memory node vision-apps-c66-dma-memory@a7000000
[    5.069952] virtio_rpmsg_bus virtio0: rpmsg host is online
[    5.070012] m_can_platform 27b1000.can: m_can device registered (irq=29, version=32)
[    5.077838] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xd
[    5.096408]  remoteproc0#vdev0buffer: registered virtio0 (type 7)
[    5.105709] remoteproc remoteproc0: remote processor 4d80800000.dsp is now attached
[    5.117984] alloc_contig_range: [8586c, 85870) PFNs busy
[    5.130426] m_can_platform 27d1000.can: m_can device registered (irq=31, version=32)
[    5.144703] pvrsrvkm 4e20000000.gpu: More than one power domain for this GPU, gpu driver manages power domains
[    5.159010] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node vision-apps-c66-dma-memory@a6000000
[    5.174799] PVR_K:  160: Read BVNC 22.104.208.318 from HW device registers
[    5.255766] PVR_K:  160: RGX Device registered with BVNC 22.104.208.318
[    5.274270] k3-dsp-rproc 4d81800000.dsp: configured DSP for IPC-only mode
[    5.298714] remoteproc remoteproc1: 4d81800000.dsp is available
[    5.298742] [drm] Initialized pvr 1.15.6133109 20170530 for 4e20000000.gpu on minor 0
[    5.316027] remoteproc remoteproc1: attaching to 4d81800000.dsp
[    5.326623] k3-dsp-rproc 4d81800000.dsp: DSP initialized in IPC-only mode
[    5.349719]  remoteproc1#vdev0buffer: assigned reserved memory node vision-apps-c66-dma-memory@a6000000
[    5.403456] k3_r5_rproc bus@100000:bus@28380000:r5fss@41000000: MCU cluster requires both R5F cores to be enabled, num_cores = 0
[    5.429853] virtio_rpmsg_bus virtio1: rpmsg host is online
[    5.437655] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xd
[    5.452775]  remoteproc1#vdev0buffer: registered virtio1 (type 7)
[    5.470307] platform 5c00000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[    5.508005] platform 5c00000.r5f: configured R5F for IPC-only mode
[    5.516856] remoteproc remoteproc1: remote processor 4d81800000.dsp is now attached
[    5.531527] platform 5c00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
[    5.547878] k3-dsp-rproc 64800000.dsp: assigned reserved memory node vision-apps-c71-dma-memory@a8000000
[    5.567409] remoteproc remoteproc2: 5c00000.r5f is available
[    5.605872] remoteproc remoteproc2: attaching to 5c00000.r5f
[    5.613838] k3-dsp-rproc 64800000.dsp: configured DSP for IPC-only mode
[    5.626037] remoteproc remoteproc3: 64800000.dsp is available
[    5.636017] remoteproc remoteproc3: attaching to 64800000.dsp
[    5.643997] remoteproc remoteproc3: unsupported resource 65538
[    5.646850] platform 5c00000.r5f: R5F core initialized in IPC-only mode
[    5.652257] k3-dsp-rproc 64800000.dsp: DSP initialized in IPC-only mode
[    5.669182]  remoteproc3#vdev0buffer: assigned reserved memory node vision-apps-c71-dma-memory@a8000000
[    5.692983]  remoteproc2#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
[    5.709064] virtio_rpmsg_bus virtio2: rpmsg host is online
[    5.717078]  remoteproc2#vdev0buffer: registered virtio2 (type 7)
[    5.724908] remoteproc remoteproc2: remote processor 5c00000.r5f is now attached
[    5.734712] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xd
[    5.743824] platform 5d00000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[    5.747365] virtio_rpmsg_bus virtio3: rpmsg host is online
[    5.759763] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xd
[    5.774403]  remoteproc3#vdev0buffer: registered virtio3 (type 7)
[    5.782821] remoteproc remoteproc3: remote processor 64800000.dsp is now attached
[    5.818185] platform 5d00000.r5f: configured R5F for IPC-only mode
[    5.849761] platform 5d00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
[    5.865854] remoteproc remoteproc4: 5d00000.r5f is available
[    5.875187] remoteproc remoteproc4: attaching to 5d00000.r5f
[    5.886888] platform 5d00000.r5f: R5F core initialized in IPC-only mode
[    5.906591]  remoteproc4#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
[    5.966609] virtio_rpmsg_bus virtio4: rpmsg host is online
[    5.985251] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xd
[    5.994680]  remoteproc4#vdev0buffer: registered virtio4 (type 7)
[    5.998156] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0x15
[    6.007207] remoteproc remoteproc4: remote processor 5d00000.r5f is now attached
[    6.020228] virtio_rpmsg_bus virtio4: creating channel ti.ipc4.ping-pong addr 0xe
[    6.030271] k3_r5_rproc bus@100000:r5fss@5e00000: MCU cluster requires both R5F cores to be enabled, num_cores = 0
[    6.035332] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0x15
[    6.058876] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xe
[    6.074267] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0x15
[    6.087857] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xe
[    6.101867] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0x15
[    6.114362] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xe
[    6.127285] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0x15
[    6.136377] virtio_rpmsg_bus virtio2: creating channel ti.ethfw.notifyservice addr 0x1e
[    6.152993] virtio_rpmsg_bus virtio2: creating channel rpmsg-kdrv addr 0x1a
[    6.163825] rpmsg-kdrv-eth-switch rpmsg-kdrv-1-mpu_1_0_ethswitch-device-0: Device info: permissions: 3FFFFFFF uart_id: 2
[    6.180664] rpmsg-kdrv-eth-switch rpmsg-kdrv-1-mpu_1_0_ethswitch-device-0: FW ver 0.2 (rev 0) 27/Jun/2023 SHA:fd3a6ecf
[    6.199426] rpmsg-kdrv-eth-switch rpmsg-kdrv-3-mpu_1_0_ethmac-device-1: Device info: permissions: 3FFFFFFF uart_id: 2
[    6.214763] rpmsg-kdrv-eth-switch rpmsg-kdrv-3-mpu_1_0_ethmac-device-1: FW ver 0.2 (rev 0) 27/Jun/2023 SHA:fd3a6ecf
[    6.227983] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xe
[    6.819350] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: rpmsg attach_ext - rx_mtu:1522 features:0000000B tx_mtu[0]:2024 flow_idx:172 tx_cpsw_psil_dst_id:51712 mac_addr:70:ff:76:1d:92:c1 mac-only:0
[    6.908148] alloc_contig_range: [8586c, 8586e) PFNs busy
[    6.924811] alloc_contig_range: [8586e, 85870) PFNs busy
[    6.938548] alloc_contig_range: [8586c, 8586e) PFNs busy
[    6.971758] alloc_contig_range: [8586e, 85870) PFNs busy
[    7.006949] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: virt_cpsw_nuss mac loaded
[    7.027481] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: rdev_features:0000000B rdev_mtu:1522 flow_id:172 tx_psil_dst_id:4A00 mac_only:0
[    7.135058] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: local_mac_addr:00:00:00:00:00:00 rdev_mac_addr:70:ff:76:1d:92:c1
[    7.151431] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: rpmsg attach_ext - rx_mtu:1522 features:00000007 tx_mtu[0]:2024 flow_idx:173 tx_cpsw_psil_dst_id:51713 mac_addr:70:ff:76:1d:92:c2 mac-only:1
[    7.182752] alloc_contig_range: [85b40, 85b51) PFNs busy
[    7.202134] alloc_contig_range: [8586c, 8586e) PFNs busy
[    7.237586] alloc_contig_range: [8586e, 85870) PFNs busy
[    7.257634] alloc_contig_range: [8586c, 8586e) PFNs busy
[    7.289754] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: virt_cpsw_nuss mac loaded
[    7.362496] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: rdev_features:00000007 rdev_mtu:1522 flow_id:173 tx_psil_dst_id:4A01 mac_only:1
[    7.444365] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: local_mac_addr:00:00:00:00:00:00 rdev_mac_addr:70:ff:76:1d:92:c2
[    7.657977] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c
[    7.741451] remoteproc remoteproc5: b034000.pru is available
[    7.762555] remoteproc remoteproc6: b004000.rtu is available
[    7.800061] remoteproc remoteproc7: b00a000.txpru is available
[    7.813812] remoteproc remoteproc8: b038000.pru is available
[    7.830773] remoteproc remoteproc9: b006000.rtu is available
[    7.868080] remoteproc remoteproc10: b00c000.txpru is available
[    7.883878] remoteproc remoteproc11: b134000.pru is available
[    7.914841] remoteproc remoteproc12: b104000.rtu is available
[    7.925350] remoteproc remoteproc13: b10a000.txpru is available
[    7.935138] remoteproc remoteproc14: b138000.pru is available
[    7.942848] remoteproc remoteproc15: b106000.rtu is available
[    7.950510] remoteproc remoteproc16: b10c000.txpru is available
[    8.900989] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: virt_cpsw_nuss mac started
         Starting Wait for Network to be Configured...
[    8.937930] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: virt_cpsw_nuss mac started
[   12.113502] can: controller area network core
[   12.119030] NET: Registered protocol family 29
[   12.139937] PVR_K:  829: RGX Firmware image 'rgx.fw.22.104.208.318' loaded
[   12.154993] can: raw protocol
[   12.166369] PVR_K:  829: Shader binary image 'rgx.sh.22.104.208.318' loaded
 _____                    _____           _         _
              |___|                    |___|
j7-evm login:
BRs
Tiancheng
  • Hi Tiancheng,
    Is this on a TI EVM or your custom board? Do you see this issue only on a HS device, or do you see similar behavior on a GP device as well? What firmware image are you using on MCU1_0?
    The particular error messages are coming from OPTEE, and triggered due to a timeout of the TI-SCI message request. The DM firmware or the TIFS hasn't responded.
    regards
    Suman
  • Hi Suman
    Thank you for your reply.
    >> Our custom board.
    >> This issue only on a HS device, GP device does not have this issue.
    SPL boot: $(PSDKLA)/board-support/prebuilt-images/ipc_echo_testb_mcu1_0_release_strip.xer5f.signed
    SBL boot: boot_app_mcu_rtos ($PSDKRA/mcusw/mcuss_demos/boot_app_mcu_rtos/)
    BRs
    Tiancheng
  • Hi Tiancheng,
    Are you customizing OPTEE in any way, or using the prebuilt OPTEE binaries?
    What keys are programmed into the HS device - TI Dummy Keys or your customer keys?
    Also, can you check if the issue is reproducible using the latest J721E 8.6.1 SDK?
    regards
    Suman
  • Hi Suman
    Sorry for the late reply.
    >> We using the prebuilt OPTEE binaries.
    >> TI Dummy Keys.
    >>Since we do not have HS type EVM, I may not be able to verify J721E 8.6.1 SDK in a short period of time on our custom board.
    and we are also unable to verify if EVM has the same problem.
    Do you know if there is the same error log on EVM?
    Thank you.
    BRs
    Tiancheng
  • Hi Tiancheng,
    I am not aware of any issues on the TI EVM. Given that you are using pre-built binaries, you can use the pre-built binaries for TIFS, DM, ATF and OPTEE from the 8.6.1 kernel on your board.
    I would concentrate on SPL boot flow for now to chase down the issue.
    regards
    Suman
