Hi all
How to setting 'Noise suppression' on tlvaic31
thanks ~
Hi all
thanks ~
Hi Phil,
There is no "Noise Supression" feature available in the AIC31. Perhaps you were referring to AGC (Automatic Gain Control) which can be used to dynamically change the gain values applied to get a good trade-off between recorded volume and noise levels. More information about this feature is available in pg 27 of the datasheet
hari
Hi Hari
If noise is louder than voice ; how to use AIC31 to Eliminate noise
thanks ~
Hi Phil,
It is not possible to do noise reduction on the AIC31. Please look at AIC3254 or one of the codecs with a miniDSP should you require advanced processing capability.
hari
