SK-TDA4VM: Model deployment error
Part Number: SK-TDA4VM
Hi team,
When running compiled yolov5s, the following error occurs:
libtidl_onnxrt_EP loaded 0x23ebc470
Final number of subgraphs created are : 3, - Offloaded Nodes - 196, Total Nodes - 236
APP: Init ... !!!
MEM: Init ... !!!
MEM: Initialized DMA HEAP (fd=4) !!!
MEM: Init ... Done !!!
IPC: Init ... !!!
IPC: Init ... Done !!!
REMOTE_SERVICE: Init ... !!!
REMOTE_SERVICE: Init ... Done !!!
165.858162 s: GTC Frequency = 200 MHz
APP: Init ... Done !!!
165.858182 s: VX_ZONE_INIT:Enabled
165.858185 s: VX_ZONE_ERROR:Enabled
165.858187 s: VX_ZONE_WARNING:Enabled
165.858780 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
165.859005 s: VX_ZONE_INIT:[tivxHostInitLocal:86] Initialization Done for HOST !!!
165.875596 s: VX_ZONE_ERROR:[ownContextSendCmd:815] Command ack message returned failure cmd_status: -1
165.875603 s: VX_ZONE_ERROR:[ownContextSendCmd:851] tivxEventWait() failed.
165.875608 s: VX_ZONE_ERROR:[ownNodeKernelInit:538] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
165.875611 s: VX_ZONE_ERROR:[ownNodeKernelInit:539] Please be sure the target callbacks have been registered for this core
165.875614 s: VX_ZONE_ERROR:[ownNodeKernelInit:540] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
165.875618 s: VX_ZONE_ERROR:[ownGraphNodeKernelInit:583] kernel init for node 0, kernel com.ti.tidl ... failed !!!
165.875625 s: VX_ZONE_ERROR:[vxVerifyGraph:2055] Node kernel init failed
165.875627 s: VX_ZONE_ERROR:[vxVerifyGraph:2109] Graph verify failed
TIDL_RT_OVX: ERROR: Verifying TIDL graph ... Failed !!!
TIDL_RT_OVX: ERROR: Verify OpenVX graph failed
165.998258 s: VX_ZONE_ERROR:[ownContextSendCmd:815] Command ack message returned failure cmd_status: -1
165.998265 s: VX_ZONE_ERROR:[ownContextSendCmd:851] tivxEventWait() failed.
165.998268 s: VX_ZONE_ERROR:[ownNodeKernelInit:538] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
165.998272 s: VX_ZONE_ERROR:[ownNodeKernelInit:539] Please be sure the target callbacks have been registered for this core
165.998274 s: VX_ZONE_ERROR:[ownNodeKernelInit:540] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
165.998279 s: VX_ZONE_ERROR:[ownGraphNodeKernelInit:583] kernel init for node 0, kernel com.ti.tidl ... failed !!!
165.998284 s: VX_ZONE_ERROR:[vxVerifyGraph:2055] Node kernel init failed
165.998287 s: VX_ZONE_ERROR:[vxVerifyGraph:2109] Graph verify failed
166.019533 s: VX_ZONE_ERROR:[ownContextSendCmd:815] Command ack message returned failure cmd_status: -1
166.019540 s: VX_ZONE_ERROR:[ownContextSendCmd:851] tivxEventWait() failed.
166.019544 s: VX_ZONE_ERROR:[ownNodeKernelInit:538] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
166.019546 s: VX_ZONE_ERROR:[ownNodeKernelInit:539] Please be sure the target callbacks have been registered for this core
166.019549 s: VX_ZONE_ERROR:[ownNodeKernelInit:540] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
166.019552 s: VX_ZONE_ERROR:[ownGraphNodeKernelInit:583] kernel init for node 0, kernel com.ti.tidl ... failed !!!
166.019557 s: VX_ZONE_ERROR:[vxVerifyGraph:2055] Node kernel init failed
166.019559 s: VX_ZONE_ERROR:[vxVerifyGraph:2109] Graph verify failed
Could you help check this case? Thanks.
Cherry
    Can you confirm your board has same sdk version that you have used during network compilation ?
    Also can you share your network compilation logs as well ?
    Pratik
  • Hi Pratik,
    Thank you for the support.
    The log file generated after the run is as follows:
    libtidl_onnxrt_EP loaded 0x2d3cc470
    APP: Init ... !!!
    MEM: Init ... !!!
    IPC: Init ... !!!
       305.600825 s: GTC Frequency = 200 MHz
       305.600852 s:  VX_ZONE_INIT:Enabled
       305.600855 s:  VX_ZONE_ERROR:Enabled
       305.600857 s:  VX_ZONE_WARNING:Enabled
       305.601366 s:  VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
       305.601658 s:  VX_ZONE_INIT:[tivxHostInitLocal:86] Initialization Done for HOST !!!
       305.618095 s:  VX_ZONE_ERROR:[ownContextSendCmd:815] Command ack message returned failure cmd_status: -1
       305.618103 s:  VX_ZONE_ERROR:[ownContextSendCmd:851] tivxEventWait() failed.
       305.618108 s:  VX_ZONE_ERROR:[ownNodeKernelInit:538] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
       305.618110 s:  VX_ZONE_ERROR:[ownNodeKernelInit:539] Please be sure the target callbacks have been registered for this core
       305.618113 s:  VX_ZONE_ERROR:[ownNodeKernelInit:540] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
       305.618117 s:  VX_ZONE_ERROR:[ownGraphNodeKernelInit:583] kernel init for node 0, kernel com.ti.tidl ... failed !!!
       305.618123 s:  VX_ZONE_ERROR:[vxVerifyGraph:2055] Node kernel init failed
       305.618126 s:  VX_ZONE_ERROR:[vxVerifyGraph:2109] Graph verify failed
       305.740672 s:  VX_ZONE_ERROR:[ownContextSendCmd:815] Command ack message returned failure cmd_status: -1
       305.740679 s:  VX_ZONE_ERROR:[ownContextSendCmd:851] tivxEventWait() failed.
       305.740683 s:  VX_ZONE_ERROR:[ownNodeKernelInit:538] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
       305.740686 s:  VX_ZONE_ERROR:[ownNodeKernelInit:539] Please be sure the target callbacks have been registered for this core
       305.740689 s:  VX_ZONE_ERROR:[ownNodeKernelInit:540] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
       305.740693 s:  VX_ZONE_ERROR:[ownGraphNodeKernelInit:583] kernel init for node 0, kernel com.ti.tidl ... failed !!!
       305.740698 s:  VX_ZONE_ERROR:[vxVerifyGraph:2055] Node kernel init failed
       305.740701 s:  VX_ZONE_ERROR:[vxVerifyGraph:2109] Graph verify failed
       305.761984 s:  VX_ZONE_ERROR:[ownContextSendCmd:815] Command ack message returned failure cmd_status: -1
       305.761991 s:  VX_ZONE_ERROR:[ownContextSendCmd:851] tivxEventWait() failed.
       305.761994 s:  VX_ZONE_ERROR:[ownNodeKernelInit:538] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
       305.761997 s:  VX_ZONE_ERROR:[ownNodeKernelInit:539] Please be sure the target callbacks have been registered for this core
       305.762000 s:  VX_ZONE_ERROR:[ownNodeKernelInit:540] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
       305.762004 s:  VX_ZONE_ERROR:[ownGraphNodeKernelInit:583] kernel init for node 0, kernel com.ti.tidl ... failed !!!
       305.762009 s:  VX_ZONE_ERROR:[vxVerifyGraph:2055] Node kernel init failed
       305.762012 s:  VX_ZONE_ERROR:[vxVerifyGraph:2109] Graph verify failed
    )0[?7h
     | Lane Detection|
     | Input Src: /opt/edge_ai_apps/data/videos/video_0000_h264.mp4|
     | Model Name: yolov5s|
     | Model Type: detection|
     +--------------------------------------------------------------------------+   306.161757 s:  VX_ZONE_ERROR:[ownContextSendCmd:815] Command ack message returned failure cmd_status: -1
       306.161775 s:  VX_ZONE_ERROR:[ownContextSendCmd:851] tivxEventWait() failed.
       306.161783 s:  VX_ZONE_ERROR:[ownNodeKernelInit:538] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
       306.161788 s:  VX_ZONE_ERROR:[ownNodeKernelInit:539] Please be sure the target callbacks have been registered for this core
       306.161793 s:  VX_ZONE_ERROR:[ownNodeKernelInit:540] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
       306.161804 s:  VX_ZONE_ERROR:[ownGraphNodeKernelInit:583] kernel init for node 0, kernel com.ti.tidl ... failed !!!
       306.161817 s:  VX_ZONE_ERROR:[vxVerifyGraph:2055] Node kernel init failed
       306.161822 s:  VX_ZONE_ERROR:[vxVerifyGraph:2109] Graph verify failed
       306.162070 s:  VX_ZONE_ERROR:[ownGraphScheduleGraphWrapper:820] graph is not in a state required to be scheduled
       306.162075 s:  VX_ZONE_ERROR:[vxProcessGraph:755] schedule graph failed
       306.162079 s:  VX_ZONE_ERROR:[vxProcessGraph:760] wait graph failed
    ERROR: Running TIDL graph ... Failed !!!
       306.177924 s:  VX_ZONE_ERROR:[ownContextSendCmd:815] Command ack message returned failure cmd_status: -1
       306.177931 s:  VX_ZONE_ERROR:[ownContextSendCmd:851] tivxEventWait() failed.
       306.177935 s:  VX_ZONE_ERROR:[ownNodeKernelInit:538] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
       306.177938 s:  VX_ZONE_ERROR:[ownNodeKernelInit:539] Please be sure the target callbacks have been registered for this core
       306.177940 s:  VX_ZONE_ERROR:[ownNodeKernelInit:540] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
       306.177945 s:  VX_ZONE_ERROR:[ownGraphNodeKernelInit:583] kernel init for node 0, kernel com.ti.tidl ... failed !!!
       306.177951 s:  VX_ZONE_ERROR:[vxVerifyGraph:2055] Node kernel init failed
       306.177953 s:  VX_ZONE_ERROR:[vxVerifyGraph:2109] Graph verify failed
       306.178068 s:  VX_ZONE_ERROR:[ownGraphScheduleGraphWrapper:820] graph is not in a state required to be scheduled
       306.178074 s:  VX_ZONE_ERROR:[vxProcessGraph:755] schedule graph failed
       306.178084 s:  VX_ZONE_ERROR:[vxProcessGraph:760] wait graph failed
       306.220401 s:  VX_ZONE_ERROR:[ownContextSendCmd:815] Command ack message returned failure cmd_status: -1
       306.220408 s:  VX_ZONE_ERROR:[ownContextSendCmd:851] tivxEventWait() failed.
       306.220411 s:  VX_ZONE_ERROR:[ownNodeKernelInit:538] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
       306.220415 s:  VX_ZONE_ERROR:[ownNodeKernelInit:539] Please be sure the target callbacks have been registered for this core
       306.220417 s:  VX_ZONE_ERROR:[ownNodeKernelInit:540] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
       306.220421 s:  VX_ZONE_ERROR:[ownGraphNodeKernelInit:583] kernel init for node 0, kernel com.ti.tidl ... failed !!!
       306.220427 s:  VX_ZONE_ERROR:[vxVerifyGraph:2055] Node kernel init failed
       306.220430 s:  VX_ZONE_ERROR:[vxVerifyGraph:2109] Graph verify failed
       306.220539 s:  VX_ZONE_ERROR:[ownGraphScheduleGraphWrapper:820] graph is not in a state required to be scheduled
       306.220542 s:  VX_ZONE_ERROR:[vxProcessGraph:755] schedule graph failed
       306.220544 s:  VX_ZONE_ERROR:[vxProcessGraph:760] wait graph failed
     | Lane Detection|
     | dl-inference:       181.26 ms   from   1    samples |
     | Lane Detection|
     | Lane Detection|
     | Lane Detection|
     | Lane Detection|
     | Lane Detection|
     | Lane Detection|
     | Lane Detection|
     | Lane Detection|
     | Lane Detection|
     | Lane Detection|
     | Lane Detection|
     | Lane Detection|
     | Lane Detection|
     | Lane Detection|
     | Lane Detection|
     | Lane Detection|
     | Lane Detection|
     | Lane Detection|
     | Lane Detection|
     | Lane Detection|
     | Lane Detection|
     | Lane Detection|
     | Lane Detection|
     | Lane Detection|
     | Lane Detection|
     | Lane Detection|
     | Lane Detection|
     | Lane Detection|
     | Lane Detection|
     | Lane Detection|
     | Lane Detection|
     | Lane Detection|
     | Lane Detection|
     | Lane Detection|
     | Lane Detection|
     | Lane Detection|
     | Lane Detection|
     | Lane Detection|
     | Lane Detection|
     | Lane Detection|
     | Lane Detection|
     | Lane Detection|
     | Lane Detection|
     | Lane Detection|
     | Lane Detection|
     | Lane Detection|
     | Lane Detection|
     | Lane Detection|
     | Lane Detection|
     | Lane Detection|
     | Lane Detection|
     | Lane Detection|
     | Lane Detection|
     | Lane Detection|
     | Lane Detection|
     | Lane Detection|
     | Lane Detection|
    The compiling log file is as follows:
    Available execution providers :  ['TIDLExecutionProvider', 'TIDLCompilationProvider', 'CPUExecutionProvider']
    Running 1 Models - ['besta']
    Running_Model :  besta
    Running shape inference on model ../../../models/public/yolov5s.onnx
    Preliminary subgraphs created = 5
    /home/leo/code/edgeai-tidl-tools-master/examples/osrt_python/ort/tidl_tools/tidl_graphVisualiser_runtimes.out: error while loading shared libraries: libcgraph.so.6: cannot open shared object file: No such file or directory
     ************** Frame index 1 : Running float import *************
    /home/leo/code/edgeai-tidl-tools-master/examples/osrt_python/ort/tidl_tools/tidl_graphVisualiser.out: error while loading shared libraries: libcgraph.so.6: cannot open shared object file: No such file or directory
    **                ALL MODEL CHECK PASSED          **
    The soft limit is 2048
    The hard limit is 2048
    MEM: Init ... !!!
     0.0s:  VX_ZONE_INIT:Enabled
     0.6s:  VX_ZONE_ERROR:Enabled
     0.7s:  VX_ZONE_WARNING:Enabled
     0.1533s:  VX_ZONE_INIT:[tivxInit:184] Initialization Done !!!
    **********  Frame Index 1 : Running float inference **********
    INFORMATION: [TIDL_ResizeLayer] Resize_118 Any resize ratio which is power of 2 and greater than 4 will be placed by combination of 4x4 resize layer and 2x2 resize layer. For example a 8x8 resize will be replaced by 4x4 resize followed by 2x2 resize.
    INFORMATION: [TIDL_ResizeLayer] Resize_140 Any resize ratio which is power of 2 and greater than 4 will be placed by combination of 4x4 resize layer and 2x2 resize layer. For example a 8x8 resize will be replaced by 4x4 resize followed by 2x2 resize.
    **          2 WARNINGS          0 ERRORS          **
    **********  Frame Index 2 : Running fixed point mode for calibration **********
    ~~~~~Running TIDL in PC emulation mode to collect Activations range for each layer~~~~~
    Processing config file #0 : /home/leo/code/edgeai-tidl-tools-master/model-artifacts/besta/tempDir/228_tidl_io_.qunat_stats_config.txt
     Freeing memory for user provided Net
     ----------------------- TIDL Process with REF_ONLY FLOW ------------------------
    #    0 . .. T    9640.59  .... ..... ... .... .....
    #    1 . .. T    9591.98  .... ..... ... .... .....
    #    0 . .. T    7122.62  .... ..... ... .... .....
    #    1 . .. T    7123.85  .... ..... ... .... .....
     *****************   Calibration iteration number 0 completed ************************
    #    0 . .. T    7126.32  .... ..... ... .... .....
    #    1 . .. T    7126.64  .... ..... ... .... .....
     *****************   Calibration iteration number 1 completed ************************
    #    0 . .. T    7120.21  .... ..... ... .... .....
    #    1 . .. T    7150.90  .... ..... ... .... .....
     *****************   Calibration iteration number 2 completed ************************
    #    0 . .. T    7168.20  .... ..... ... .... .....
    #    1 . .. T    7163.76  .... ..... ... .... .....
     *****************   Calibration iteration number 3 completed ************************
    #    0 . .. T    7127.88  .... ..... ... .... .....
    #    1 . .. T    7137.15  .... ..... ... .... .....
     *****************   Calibration iteration number 4 completed ************************
    ------------------ Network Compiler Traces -----------------------------
    NC running for device: 1
    Running with OTF buffer optimizations
    successful Memory allocation
    Processing config file #0 : /home/leo/code/edgeai-tidl-tools-master/model-artifacts/besta/tempDir/326365404_tidl_io_.qunat_stats_config.txt
    #    0 . .. T    6665.58  .... ..... ... .... .....
    #    1 . .. T    6647.75  .... ..... ... .... .....
    #    0 . .. T    3502.79  .... ..... ... .... .....
    #    1 . .. T    3493.17  .... ..... ... .... .....
    #    0 . .. T    3507.26  .... ..... ... .... .....
    #    1 . .. T    3513.30  .... ..... ... .... .....
    #    0 . .. T    3498.75  .... ..... ... .... .....
    #    1 . .. T    3507.60  .... ..... ... .... .....
    #    0 . .. T    3488.07  .... ..... ... .... .....
    #    1 . .. T    3495.94  .... ..... ... .... .....
    #    0 . .. T    3499.58  .... ..... ... .... .....
    #    1 . .. T    3488.70  .... ..... ... .... .....
    Processing config file #0 : /home/leo/code/edgeai-tidl-tools-master/model-artifacts/besta/tempDir/output0_tidl_io_.qunat_stats_config.txt
    #    0 . .. T      64.20  .... ..... ... .... .....
    #    1 . .. T      56.35  .... ..... ... .... .....
    #    0 . .. T      68.55  .... ..... ... .... .....
    #    1 . .. T      64.69  .... ..... ... .... .....
    #    0 . .. T      68.72  .... ..... ... .... .....
    #    1 . .. T      64.46  .... ..... ... .... .....
    #    0 . .. T      70.52  .... ..... ... .... .....
    #    1 . .. T      64.40  .... ..... ... .... .....
    #    0 . .. T      68.99  .... ..... ... .... .....
    #    1 . .. T      64.80  .... ..... ... .... .....
    #    0 . .. T      68.09  .... ..... ... .... .....
    #    1 . .. T      64.64  .... ..... ... .... .....
    Completed_Model :     1, Name : besta                                             , Total time :   89329.31, Offload Time :    9685.48 , DDR RW MBs : 0, Output File : py_out_besta_2.jpg
    MEM: Deinit ... !!!
    MEM: Alloc's: 89 alloc's of 1044781908 bytes
    MEM: Free's : 89 free's  of 1044781908 bytes
    MEM: Open's : 0 allocs  of 0 bytes
    MEM: Deinit ... Done !!!
    Thanks and regards,
    Cherry
  • Hi
    Thanks for sharing compilation logs.
    Which SDK version you have on the board and which sdk version you have used for tidl-tools for the compilation of above model ?
    Pratik
  • Hi Pratik,
    Thank you but the customer don't know how to check the SDK version, could you help give some guidance?
    Thanks and regards,
    Cherry
    The board SDK version can should one which customers used at the time of creating linux sdk image, you can check which sdk image version was used for flashing.
    Regarding tidl tools version, you can check tag of tidl tools git hub repo, ideally customer should be using specific branch for their sdk version.
    Pratik
