TDA4VL-Q1: RTSP steam player demo on SDK8.5 + VL EVM
Part Number: TDA4VL-Q1
use gstreamer to support this feature.
    Environment setup:
    Connect host PC to MODEM with DHCP capability. And connect CP EVM J35 (RJ45, MCU ENET) to MODEM.
    host ip: 192.168.0.100
    EVM ip:192.168.0.103 @eth0@Linux OS
    Step 1.
    Prepare SD card with default rootfs,
    a0224068local@a0224068local-HP-EkiteBook-830-G7:/opt/1Twork/repository/ti-processor-sdk-rtos-j721s2-evm-08_05_00_11$ psdk_rtos/scripts/install_to_sd_card.sh
    Installing /opt/1Twork/repository/ti-processor-sdk-rtos-j721s2-evm-08_05_00_11/boot-j721s2-evm.tar.gz to /media/a0224068local/BOOT ...
    Installing /opt/1Twork/repository/ti-processor-sdk-rtos-j721s2-evm-08_05_00_11/boot-j721s2-evm.tar.gz to /media/a0224068local/BOOT ... Done
    Installing /opt/1Twork/repository/ti-processor-sdk-rtos-j721s2-evm-08_05_00_11/tisdk-default-image-j721s2-evm.tar.xz to /media/a0224068local/rootfs ...
    Installing /opt/1Twork/repository/ti-processor-sdk-rtos-j721s2-evm-08_05_00_11/tisdk-default-image-j721s2-evm.tar.xz to /media/a0224068local//media/a0224068local/rootfs ... Done
    Step2.
    Apply patch. See ticket.
    TDA4VL-Q1: The mp4mux and rtspclientsink plugins of tda4vl sdk8.5 gstreamer cannot be used - Valeo Jacinto Forum - Valeo - EP Automotive - TI E2E support forums
    /cfs-file/__key/communityserver-discussions-components-files/791/Multimedia_5F00_SDK8.5_5F00_to_5F00_SDK_5F00_8.6_5F00_changes.zip
    build wave5.ko and replace to SD card.
    a0224068local@a0224068local-HP-EkiteBook-830-G7:/opt/1Twork/repository/ti-processor-sdk-linux-j721s2-evm-08_05_00_08/board-support/linux-5.10.153+gitAUTOINC+90c3a58fd2-g90c3a58fd2$ git apply ~/Downloads/Multimedia_SDK8.5_to_SDK_8.6_changes/Multimedia_8_5_to_8_6_changes.patch
    a0224068local@a0224068local-HP-EkiteBook-830-G7:/opt/1Twork/repository/ti-processor-sdk-linux-j721s2-evm-08_05_00_08$ sudo cp board-support/linux-5.10.153+gitAUTOINC+90c3a58fd2-g90c3a58fd2/drivers/media/platform/chips-media/wave5/wave5.ko /media/a0224068local/rootfs/lib/modules/5.10.153-g90c3a58fd2/kernel/drivers/media/platform/chips-media/wave5/wave5.ko
    Step2. Launch mediamtx server on host PC
    a0224068local@a0224068local-HP-EkiteBook-830-G7:~/mediamtx_v0.23.6_linux_amd64$ ./mediamtx
    2023/06/30 09:41:53 INF MediaMTX v0.23.6
    2023/06/30 09:41:53 INF [RTSP] listener opened on :8554 (TCP), :8000 (UDP/RTP), :8001 (UDP/RTCP)
    2023/06/30 09:41:53 INF [RTMP] listener opened on :1935
    2023/06/30 09:41:53 INF [HLS] listener opened on :8888
    2023/06/30 09:41:53 INF [WebRTC] listener opened on :8889 (HTTP)
    Step3. Run command on EVM.
    gst-launch-1.0 videotestsrc is-live=true do-timestamp=true ! video/x-raw, width=1280, height=720, framerate=30/1, format=NV12 ! rawvideoparse width=1280 height=720 format=nv12 framerate=30/1 ! v4l2h264enc ! h264parse ! rtspclientsink location=rtsp://192.168.0.100:8554/video
    Step4. Run vlc on Host PC.
    a0224068local@a0224068local-HP-EkiteBook-830-G7:~/mediamtx_v0.23.6_linux_amd64$ gst-play-1.0 rtsp://192.168.0.100:8554/video
    log on hostPC:
    2023/06/30 09:42:40 INF [RTSP] [conn 192.168.0.101:38012] opened
    2023/06/30 09:42:40 INF [RTSP] [session 89beffa0] created by 192.168.0.101:38012
    2023/06/30 09:42:41 INF [RTSP] [session 89beffa0] is publishing to path 'video', with UDP, 1 track (H264)
    2023/06/30 09:42:47 INF [RTSP] [conn 192.168.0.100:39720] opened
    2023/06/30 09:42:47 INF [RTSP] [session b591d5d3] created by 192.168.0.100:39720
    2023/06/30 09:42:48 INF [RTSP] [session b591d5d3] is reading from path 'video', with UDP, 1 track (H264)
    log on hostPC:
    Press 'k' to see a list of keyboard shortcuts.
    Now playing rtsp://192.168.0.100:8554/video
    Pipeline is live.
    Redistribute latency...
    Prerolled.
    log on UART0:
    j721s2-evm login: root
    spclientsink location=rtsp://192.168.0.100:8554/video[   25.947324] Initializint
    [   27.491463] bridge: filtering via arp/ip/ip6tables is no longer available by.
    [   27.507397] Bridge firewalling registered
    [   28.172027] process 'docker/tmp/qemu-check629541102/check' started with execk
    Setting pipeline to PAUSED ...
    Pipeline is live and does not need PREROLL ...
    Progress: (open) Opening Stream
    Progress: (connect) Connecting to rtsp://192.168.0.100:8554/video
    Progress: (open) Retrieving server options
    Progress: (open) Opened Stream
    Setting pipeline to PLAYING ...
    New clock: GstSystemClock
    Progress: (request) Sending RECORD request
    Progress: (record) Sending server stream info
    Progress: (request) SETUP stream 0
    Progress: (record) Starting recording
    capture screen.
