SK-AM62B: GPU error message
Part Number: SK-AM62B
Hi TI
System would show GPU error message randomly as below when I run application.
(32691) PVR:(Error): PVRDisplayBufferCreate: Failed to create display buffer (err=12) [ :683 ]
(32691) PVR:(Error): PVRDRIPlanesCreate: Failed to create plane [ :1499 ]
(32691) PVR:(Error): PVRDRIBufferCreateWithModifiers: Failed to create buffer planes [ :2044 ]
(32691) PVR:(Error): CreateImageSharedWithModifiers: Failed to create buffer [ :490 ]
(32691) PVR:(Error): PVRImageDrawableGetNativeInfo: Image get buffers call failed [ :106 ]
(32691) PVR:(Error): KEGLGetDrawableParameters: Couldn't get drawable parameters [ :316 ]
(32691) PVR:(Error): PrepareToDraw: Invalid drawable [ :3110 ]
(32691) PVR:(Error): DoClear: Can't prepare to draw [ :2609 ]
(32691) PVR:(Error): DrawElements: Can't prepare to draw [ :5673 ]
Application would occur segmentation fault.
Where does these messages come from? And how could I resolve it?
    Based on the above logs, it seems like the display node disconnected. Is the display out disconnected or you doing offscreen rendering?
    Krunal
  • The display always is connected. It just occurs on the board whit 512M RAM. It couldn't never happen on 1G board.
  • I find that it would easily happen when system free memory is low.
    But available memory is actually enough. Does GPU just use "free" memory?
    Based on my internal discussions, GPU uses both CMA and free region. In the above video that you shared, I noticed you start with very little free memory and I am curious to know how much CMA have you allocated?
    Krunal
  • Hi Krunal:
    I find that CONFIG_DMA_CMA is disable and CMA is not working.
    I re-enable this config, GPU error message isn't appeared.
    Thank you for the update.
    Krunal
