TDA4VH-Q1: TDA4VH GPU init FW failed
Part Number: TDA4VH-Q1
Other Parts Discussed in Thread: TDA4VH
Hi  TI expert
Our SDK version : 8.6
Our board model:j784s4_evm
We encountered an issue with GPU FW initialization failure on custom board. The probability of reproducing the problem is low. The problem log is as follows:
[2023-07-06 12:34:38]  U-Boot SPL 2021.01-svn475824 (Jun 29 2023 - 17:26:20 +0800)
[2023-07-06 12:34:38]  SYSFW ABI: 3.1 (firmware rev 0x0008 '8.6.3--v08.06.03 (Chill Capybar')
[2023-07-06 12:34:38]  SPL initial stack usage: 13472 bytes
[2023-07-06 12:34:38]  Trying to boot from SPI
[2023-07-06 12:34:38]  NOTICE:  BL31: v2.8(release):
[2023-07-06 12:34:38]  NOTICE:  BL31: Built : 17:25:53, Jun 29 2023
[2023-07-06 12:34:38]  I/TC:
[2023-07-06 12:34:38]  I/TC: OP-TEE version: 3.19.0 (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10))) #1 Sun Dec 18 12:03:06 UTC 2022 aarch64
[2023-07-06 12:34:38]  I/TC: WARNING: This OP-TEE configuration might be insecure!
[2023-07-06 12:34:38]  I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
[2023-07-06 12:34:38]  I/TC: Primary CPU initializin5
[2023-07-06 12:34:38]  I/TC: SYSFW ABI: 3.1 (firmware rev 0x0008 '8.6.3--v08.06.03 (Chill Capybar')
[2023-07-06 12:34:38]  I/TC: HUK Initialized
[2023-07-06 12:34:38]  I/TC: Activated SA2UL device
[2023-07-06 12:34:38]  I/TC: Fixing SA2UL firewall owner for GP device
[2023-07-06 12:34:38]  I/TC: Enabled firewalls for SA2UL TRNG device
[2023-07-06 12:34:39]  I/TC: SA2UL TRNG initialized
[2023-07-06 12:34:39]  I/TC: SA2UL Drivers initialized
[2023-07-06 12:34:39]  I/TC: Primary CPU switching to normal world boot
[2023-07-06 12:34:39]  U-Boot 2021.01-svn475824 (Jun 29 2023 - 17:26:02 +0800), Build: jenkins-AutoElec-cci-Pipeline-9559
[2023-07-06 12:34:39]  SoC:   J784S4 SR1.0 GP
[2023-07-06 12:34:39]  Model: HIKAUTO AE-B50038-M
[2023-07-06 12:34:39]  DRAM:  8 GiB
[2023-07-06 12:34:39]  Flash: 0 Bytes
[2023-07-06 12:34:39]  MMC:   mmc@4f80000: 0, mmc@4fb0000: 1
[2023-07-06 12:34:39]  In:    serial@2880000
[2023-07-06 12:34:39]  Out:   serial@2880000
[2023-07-06 12:34:39]  Err:   serial@2880000
[2023-07-06 12:34:39]  Net:   eth2: ethernet@c200000am65_cpsw_nuss_port ethernet@c200000port@1: can't parse phy-handle port 1 (-2)
[2023-07-06 12:34:39]  , eth0: ethernet@c200000port@1
[2023-07-06 12:34:39]  Hit ctr+u key to stop autoboot:  0
[2023-07-06 12:34:39]  k3_r5f_rproc r5f@41000000: Core 1 is already in use. No rproc commands work
[2023-07-06 12:34:39]  k3_r5f_rproc r5f@41400000: Core 2 is already in use. No rproc commands work
[2023-07-06 12:34:39]  [    0.000000] cma: Failed to reserve 144 MiB
[2023-07-06 12:34:39]  I/TC: Secondary CPU 1 initializing
[2023-07-06 12:34:39]  I/TC: Secondary CPU 1 switching to normal world boot
[2023-07-06 12:34:39]  I/TC: Secondary CPU 2 initializing
[2023-07-06 12:34:39]  I/TC: Secondary CPU 2 switching to normal world boot
[2023-07-06 12:34:39]  I/TC: Secondary CPU 3 initializing
[2023-07-06 12:34:39]  I/TC: Secondary CPU 3 switching to normal world boot
[2023-07-06 12:34:39]  I/TC: Secondary CPU 4 initializing
[2023-07-06 12:34:39]  I/TC: Secondary CPU 4 switching to normal world boot
[2023-07-06 12:34:39]  I/TC: Secondary CPU 5 initializing
[2023-07-06 12:34:39]  I/TC: Secondary CPU 5 switching to normal world boot
[2023-07-06 12:34:39]  mCH[    4.591620] EXT4-fs (mmcblk0p112): VFS: Can't find ext4 filesystem
[2023-07-06 12:34:39]  mount: /hat-s/model: wrong fs type, bad option, bad superblock on /dev/[    4.599726] EXT4-fs (mmcblk0p114): VFS: Can't find ext4 filesystem
[2023-07-06 12:34:40]  mmcblk0p112, missing codepage or helper program, or other error.
[2023-07-06 12:34:40]  mount: /hat-s/app: wrong fs type, bad option, bad superblock on /dev/mmcblk0p114, missing codepage or helper program, or other error.
[2023-07-06 12:34:40]  exporting *:/ab/res
[2023-07-06 12:34:40]  exporting *:/ab/log
[2023-07-06 12:34:40]  exporting *:/hat-s/model
[2023-07-06 12:34:40]  exporting *:/ab/cfg
[2023-07-06 12:34:40]  exporting *:/ab/app
[2023-07-06 12:34:40]  exporting *:/ab/map
[2023-07-06 12:34:40]  exporting *:/hat/map
[2023-07-06 12:34:40]  exporting *:/hat/cfg
[2023-07-06 12:34:40]  exportin[    4.640729] k3-dsp-rproc 64800000.dsp: configured DSP for IPC-only mode
[2023-07-06 12:34:40]  g *:/hat/log
[2023-07-06 12:34:40]  exporting *:/hat-s/app
[2023-07-06 12:34:40]  [19641]Prepare run initrun[    4.650362] k3-dsp-rproc 64800000.dsp: DSP initialized in IPC-only mode
[2023-07-06 12:34:40]  .sh
[2023-07-06 12:34:40]  [    4.664500] k3-dsp-rproc 65800000.dsp: configured DSP for IPC-only mode
[2023-07-06 12:34:40]  [    4.671221] k3-dsp-rproc 65800000.dsp: DSP initialized in IPC-only mode
[2023-07-06 12:34:40]  [    4.679720] k3-dsp-rproc 66800000.dsp: configured DSP for IPC-only mode
[2023-07-06 12:34:40]  [    4.686511] k3-dsp-rproc 66800000.dsp: DSP initialized in IPC-only mode
[2023-07-06 12:34:40]  [    4.694608] k3-dsp-rproc 67800000.dsp: configured DSP for IPC-only mode
[2023-07-06 12:34:40]  [    4.701327] k3-dsp-rproc 67800000.dsp: DSP initialized in IPC-only mode
[2023-07-06 12:34:40]  [    4.712374] platform 41000000.r5f: configured R5F for IPC-only mode
[2023-07-06 12:34:40]  [    4.719088] platform 41000000.r5f: R5F core initialized in IPC-only mode
[2023-07-06 12:34:40]  [    4.727480] platform 5c00000.r5f: configured R5F for IPC-only mode
[2023-07-06 12:34:40]  [    4.734620] platform 5c00000.r5f: R5F core initialized in IPC-only mode
[2023-07-06 12:34:40]  [    4.741880] platform 5d00000.r5f: configured R5F for IPC-only mode
[2023-07-06 12:34:40]  [    4.748450] platform 5d00000.r5f: R5F core initialized in IPC-only mode
[2023-07-06 12:34:40]  [    4.756442] platform 5e00000.r5f: configured R5F for IPC-only mode
[2023-07-06 12:34:40]  [    4.763090] platform 5e00000.r5f: R5F core initialized in IPC-only mode
[2023-07-06 12:34:40]  [    4.770344] platform 5f00000.r5f: configured R5F for IPC-only mode
[2023-07-06 12:34:41]  [    4.776913] platform 5f00000.r5f: R5F core initialized in IPC-only mode
[2023-07-06 12:34:41]  [    4.785419] platform 5900000.r5f: configured R5F for IPC-only mode
[2023-07-06 12:34:41]  [    4.792359] platform 5900000.r5f: R5F core initialized in IPC-only mode
[2023-07-06 12:34:41]  [    4.799650] platform 5a00000.r5f: configured R5F for IPC-only mode
[2023-07-06 12:34:41]  [    4.806238] platform 5a00000.r5f: R5F core initialized in IPC-only mode
[2023-07-06 12:34:41]  [    4.878290] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac7: rpmsg attach_ext - rx_mtu:1522 features:00000007 tx_mtu[0]:2024 flow_idx:114 tx_cpsw_psil_dst_id:51712 mac_addr:70:ff:76:00:2f:f0 mac-only:7
[2023-07-06 12:34:41]  [    4.898600] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac8: rpmsg attach_ext - rx_mtu:1522 features:00000007 tx_mtu[0]:2024 flow_idx:115 tx_cpsw_psil_dst_id:51713 mac_addr:70:ff:76:00:3a:1e mac-only:8
[2023-07-06 12:34:41]  root@j7-evm:~# ldconfig: /lib/libEGL.so.1 is not a symbolic link
[2023-07-06 12:34:54]
[2023-07-06 12:34:54]  ldconfig: /lib/libGLESv1_CM.so.1 is not a symbolic link
[2023-07-06 12:34:54]  ldconfig: /lib/libGLESv1_CM_PVR_MESA.so is not a symbolic link
[2023-07-06 12:34:54]  ldconfig: /lib/libGLESv2.so.2 is not a symbolic link
[2023-07-06 12:34:54]  ldconfig: /lib/libGLESv2_PVR_MESA.so is not a symbolic link
[2023-07-06 12:34:54]  ldconfig: /lib/libPVRScopeServices.so is not a symbolic link
[2023-07-06 12:34:54]  ldconfig: /lib/libgbm.so.1 is not a symbolic link
[2023-07-06 12:34:54]  ldconfig: /lib/libglapi.so.0 is not a symbolic link
[2023-07-06 12:34:54]  ldconfig: /lib/libglslcompiler.so is not a symbolic link
[2023-07-06 12:34:54]  ldconfig: /lib/libpvr_dri_support.so is not a symbolic link
[2023-07-06 12:34:54]  ldconfig: /lib/libsrv_um.so is not a symbolic link
[2023-07-06 12:34:54]  ldconfig: /lib/libsutu_display.so is not a symbolic link
[2023-07-06 12:34:54]  ldconfig: /lib/libusc.so is not a symbolic link
[2023-07-06 12:34:54]  ldconfig: /hat/app/home/lib/liblzma.so.5 is not a symbolic link
[2023-07-06 12:34:54]  Support EGL_MESA_platform_surfaceless!
[2023-07-06 12:34:54]  [   25.489017] PVR_K:(Error):   832: PollForValueKM: Timeout. Expected 0x1 but found 0x0 (mask 0xffffffff). [2927]
[2023-07-06 12:34:54]  [   25.499097] PVR_K:(Error):   832: PVRSRVPollForValueKM: Failed! Error(PVRSRV_ERROR_TIMEOUT) CPU linear address(00000000248746de) Expected value(1) [2954]
[2023-07-06 12:34:54]  [   25.513092] ------[ Native Fence Sync: timelines ]------
[2023-07-06 12:34:54]  [   25.518395] foreign_sync: @0 ctx=1 refs=1
[2023-07-06 12:34:54]  [   25.523039] PVR_K:(Error):   832: RGXPostPowerState: Polling for 'FW started' flag failed. [1003]
[2023-07-06 12:34:54]  [   25.744533] PVR_K:(Error):   832: PVRSRVDeviceFinalise: Failed to set device 00000000288ea223 power state to 'on' (PVRSRV_ERROR_TIMEOUT) [2774]
[2023-07-06 12:34:55]  [   25.757382] PVR_K:(Error):   832: PVRSRVDeviceFinalise() failed (PVRSRV_ERROR_TIMEOUT) in PVRSRVCommonDeviceInitialise() [2225]
[2023-07-06 12:34:55]  [   25.768839] PVR_K:(Error):   832: PVRSRVDeviceOpen: Failed to initialise device (PVRSRV_ERROR_TIMEOUT) [476]
[2023-07-06 12:34:55]  libEGL warning: MESA-LOADER: failed to open swrast: /usr/lib/dri[   25.779365] PVR_K:(Error):   832: PVRSRVDeviceOpen: Driver already in bad state. Device open failed. [464]
[2023-07-06 12:34:55]  /swrast_dri.so: cannot open shared object file: No such file or directory (search paths /usr/lib/dri)
[2023-07-06 12:34:55]  libEGL warning: MESA-LOADER: failed to open swrast: /usr/lib/dri/swrast_dri.so: cannot open shared object file: No such file or directory (search paths /usr/lib/dri)
[2023-07-06 12:34:55]  failed to eglInitialize
[2023-07-06 12:34:55]  EGL: version -924838152.65535
[2023-07-06 12:34:55]  failed to eglCreateContext
[2023-07-06 12:34:55]  Create YUV Buffer begin 0
[2023-07-06 12:34:55]  MEM: Init ... !!!
[2023-07-06 12:34:55]  MEM: Initialized DMA HEAP (fd=3) !!!
[2023-07-06 12:34:55]  MEM: Init ... Done !!!
[2023-07-06 12:34:55]  MEM: Allocated virt addr = ffff8964d000 -> phy addr = c1000000, size = 1843200 (FD's = 4 5) !!!
[2023-07-06 12:34:55]   CreateImageKHR: error12289
[2023-07-06 12:34:55]   m_pKHRImage iS Null !!!
[2023-07-06 12:34:55]  gen 1 tex 0
[2023-07-06 12:34:55]  MEM: Allocated virt addr = ffff892c9000 -> phy addr = c11c2000, size = 3686400 (FD's = 6 7) !!!
[2023-07-06 12:34:55]  [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[2023-07-06 12:34:59]  [    0.000000] Linux version 5.10.162-g76b3e88d56 (ci@CI-HZV-AUTOELEC-SLAVE-66-157) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT Thu Jun 29 17:26:47 CST 2023
[2023-07-06 12:35:00]  [    0.000000] Machine model: HIKAUTO AE-B50038-M
[2023-07-06 12:35:00]  [    0.000000] Malformed early option 'console'
[2023-07-06 12:35:00]  [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002880000 (options '')
[2023-07-06 12:35:00]  [    0.000000] printk: bootconsole [ns16550a0] enabled
[2023-07-06 12:35:00]  [    0.000000] efi: UEFI not found.
[2023-07-06 12:35:00]  [    0.000000] Reserved memory: created DMA memory pool at 0x0000000088000000, size 176 MiB
[2023-07-06 12:35:00]  [    0.000000] OF: reserved mem: initialized node dsp-multicore-dma-memory@88000000, compatible id shared-dma-pool
[2023-07-06 12:35:00]  [    0.000000] Reserved memory: created DMA memory pool at 0x0000000093000000, size 16 MiB
[2023-07-06 12:35:00]  [    0.000000] OF: reserved mem: initialized node bsp-multicore-dma-memory@93000000, compatible id shared-dma-pool
[2023-07-06 12:35:00]  [    0.000000] Reserved memory: created DMA memory pool at 0x0000000094000000, size 168 MiB
[2023-07-06 12:35:00]  [    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@94000000, compatible id shared-dma-pool
[2023-07-06 12:35:00]  [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[2023-07-06 12:35:00]  [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
[2023-07-06 12:35:00]  [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[2023-07-06 12:35:00]  [    0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
[2023-07-06 12:35:00]  [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[2023-07-06 12:35:00]  [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
[2023-07-06 12:35:00]  [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
[2023-07-06 12:35:01]  [    0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
[2023-07-06 12:35:01]  [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
[2023-07-06 12:35:01]  [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
[2023-07-06 12:35:01]  [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 47 MiB
[2023-07-06 12:35:01]  [    0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
[2023-07-06 12:35:01]  [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[2023-07-06 12:35:01]  [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a6000000, compatible id shared-dma-pool
[2023-07-06 12:35:01]  [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[2023-07-06 12:35:01]  [    0.000000] OF: reserved mem: initialized node r5f-memory@a6100000, compatible id shared-dma-pool
[2023-07-06 12:35:01]  [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[2023-07-06 12:35:01]  [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a7000000, compatible id shared-dma-pool
[2023-07-06 12:35:01]  [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[2023-07-06 12:35:01]  [    0.000000] OF: reserved mem: initialized node r5f-memory@a7100000, compatible id shared-dma-pool
[2023-07-06 12:35:01]  [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
[2023-07-06 12:35:01]  [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a8000000, compatible id shared-dma-pool
[2023-07-06 12:35:01]  [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
[2023-07-06 12:35:01]  [    0.000000] OF: reserved mem: initialized node r5f-memory@a8100000, compatible id shared-dma-pool
[2023-07-06 12:35:02]  [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 1 MiB
[2023-07-06 12:35:02]  [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a9000000, compatible id shared-dma-pool
[2023-07-06 12:35:02]  [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a9100000, size 31 MiB
[2023-07-06 12:35:02]  [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a9100000, compatible id shared-dma-pool
[2023-07-06 12:35:02]  [    0.000000] Reserved memory: created DMA memory pool at 0x00000000ab000000, size 1 MiB
[2023-07-06 12:35:02]  [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@ab000000, compatible id shared-dma-pool
[2023-07-06 12:35:02]  [    0.000000] Reserved memory: created DMA memory pool at 0x00000000ab100000, size 15 MiB
[2023-07-06 12:35:02]  [    0.000000] OF: reserved mem: initialized node r5f-memory@ab100000, compatible id shared-dma-pool
[2023-07-06 12:35:02]  [    0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 48 MiB
[2023-07-06 12:35:02]  [    0.000000] OF: reserved mem: initialized node rtos-ipc-memory-region@ac000000, compatible id shared-dma-pool
[2023-07-06 12:35:02]  [    0.000000] Reserved memory: created DMA memory pool at 0x00000000af000000, size 80 MiB
[2023-07-06 12:35:02]  [    0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@af000000, compatible id shared-dma-pool
[2023-07-06 12:35:02]  [    0.000000] Reserved memory: created DMA memory pool at 0x00000000b4000000, size 1 MiB
[2023-07-06 12:35:02]  [    0.000000] OF: reserved mem: initialized node c71-dma-memory@b4000000, compatible id shared-dma-pool
[2023-07-06 12:35:02]  [    0.000000] Reserved memory: created DMA memory pool at 0x00000000b4100000, size 51 MiB
[2023-07-06 12:35:02]  [    0.000000] OF: reserved mem: initialized node c71_0-memory@b4100000, compatible id shared-dma-pool
[2023-07-06 12:35:03]  [    0.000000] Reserved memory: created DMA memory pool at 0x00000000b7400000, size 1 MiB
[2023-07-06 12:35:03]  [    0.000000] OF: reserved mem: initialized node c71_1-dma-memory@b7400000, compatible id shared-dma-pool
[2023-07-06 12:35:03]  [    0.000000] Reserved memory: created DMA memory pool at 0x00000000b7500000, size 51 MiB
[2023-07-06 12:35:03]  [    0.000000] OF: reserved mem: initialized node c71_1-memory@b7500000, compatible id shared-dma-pool
[2023-07-06 12:35:03]  [    0.000000] Reserved memory: created DMA memory pool at 0x00000000ba800000, size 1 MiB
[2023-07-06 12:35:03]  [    0.000000] OF: reserved mem: initialized node c71_2-dma-memory@ba800000, compatible id shared-dma-pool
[2023-07-06 12:35:03]  [    0.000000] Reserved memory: created DMA memory pool at 0x00000000ba900000, size 51 MiB
[2023-07-06 12:35:03]  [    0.000000] OF: reserved mem: initialized node c71_2-memory@ba900000, compatible id shared-dma-pool
[2023-07-06 12:35:03]  [    0.000000] Reserved memory: created DMA memory pool at 0x00000000bdc00000, size 1 MiB
[2023-07-06 12:35:03]  [    0.000000] OF: reserved mem: initialized node c71_3-dma-memory@bdc00000, compatible id shared-dma-pool
[2023-07-06 12:35:03]  [    0.000000] Reserved memory: created DMA memory pool at 0x00000000bdd00000, size 51 MiB
[2023-07-06 12:35:03]  [    0.000000] OF: reserved mem: initialized node c71_3-memory@bdd00000, compatible id shared-dma-pool
[2023-07-06 12:35:03]  [    0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout
[2023-07-06 12:35:03]  [    0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 1330 MiB
[2023-07-06 12:35:03]  [    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool
[2023-07-06 12:35:03]  [    0.000000] Reserved memory: created DMA memory pool at 0x00000008d4000000, size 64 MiB
[2023-07-06 12:35:04]  [    0.000000] OF: reserved mem: initialized node pcie-memory-region@8d4000000, compatible id shared-dma-pool
[2023-07-06 12:35:04]  [    0.000000] Reserved memory: created DMA memory pool at 0x00000008e0000000, size 512 MiB
[2023-07-06 12:35:04]  [    0.000000] OF: reserved mem: initialized node vpu-memory-region@8e0000000, compatible id shared-dma-pool
[2023-07-06 12:35:04]  [    0.000000] OF: reserved mem: initialized node vision_apps_shared-memories_64, compatible id dma-heap-carveout
[2023-07-06 12:35:04]  [    0.000000] Reserved memory: created DMA memory pool at 0x00000009b0000000, size 768 MiB
[2023-07-06 12:35:04]  [    0.000000] OF: reserved mem: initialized node ddr-high-shared-memory@9b0000000, compatible id shared-dma-pool
[2023-07-06 12:35:04]  [    0.000000] Zone ranges:
[2023-07-06 12:35:04]  [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[2023-07-06 12:35:04]  [    0.000000]   DMA32    empty
[2023-07-06 12:35:04]  [    0.000000]   Normal   [mem 0x0000000100000000-0x00000009ffffffff]
[2023-07-06 12:35:04]  [    0.000000] Movable zone start for each node
[2023-07-06 12:35:04]  [    0.000000] Early memory node ranges
[2023-07-06 12:35:04]  [    0.000000]   node   0: [mem 0x0000000080000000-0x0000000087ffffff]
[2023-07-06 12:35:04]  [    0.000000]   node   0: [mem 0x0000000088000000-0x000000009fffffff]
[2023-07-06 12:35:04]  [    0.000000]   node   0: [mem 0x00000000a0000000-0x00000000a0ffffff]
[2023-07-06 12:35:04]  [    0.000000]   node   0: [mem 0x00000000a1000000-0x00000000c0ffffff]
[2023-07-06 12:35:04]  [    0.000000]   node   0: [mem 0x00000000c1000000-0x00000000ffffffff]
[2023-07-06 12:35:04]  [    0.000000]   node   0: [mem 0x0000000880000000-0x00000008d31fffff]
[2023-07-06 12:35:04]  [    0.000000]   node   0: [mem 0x00000008d3200000-0x00000008d3ffffff]
[2023-07-06 12:35:04]  [    0.000000]   node   0: [mem 0x00000008d4000000-0x00000008d7ffffff]
[2023-07-06 12:35:04]  [    0.000000]   node   0: [mem 0x00000008d8000000-0x00000008dfffffff]
[2023-07-06 12:35:04]  [    0.000000]   node   0: [mem 0x00000008e0000000-0x00000008ffffffff]
[2023-07-06 12:35:05]  [    0.000000]   node   0: [mem 0x0000000900000000-0x00000009afffffff]
[2023-07-06 12:35:05]  [    0.000000]   node   0: [mem 0x00000009b0000000-0x00000009dfffffff]
[2023-07-06 12:35:05]  [    0.000000]   node   0: [mem 0x00000009e0000000-0x00000009ffffffff]
[2023-07-06 12:35:05]  [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000009ffffffff]
[2023-07-06 12:35:05]  [    0.000000] On node 0 totalpages: 2097152
[2023-07-06 12:35:05]  [    0.000000]   DMA zone: 8192 pages used for memmap
[2023-07-06 12:35:05]  [    0.000000]   DMA zone: 0 pages reserved
[2023-07-06 12:35:05]  [    0.000000]   DMA zone: 524288 pages, LIFO batch:63
[2023-07-06 12:35:05]  [    0.000000]   Normal zone: 24576 pages used for memmap
[2023-07-06 12:35:05]  [    0.000000]   Normal zone: 1572864 pages, LIFO batch:63
[2023-07-06 12:35:05]  [    0.000000] cma: Failed to reserve 144 MiB
[2023-07-06 12:35:05]  [    0.000000] psci: probing for conduit method from DT.
[2023-07-06 12:35:05]  [    0.000000] psci: PSCIv1.1 detected in firmware.
[2023-07-06 12:35:05]  [    0.000000] psci: Using standard PSCI v0.2 function IDs
[2023-07-06 12:35:05]  [    0.000000] psci: Trusted OS migration not required
[2023-07-06 12:35:05]  [    0.000000] psci: SMC Calling Convention v1.2
[2023-07-06 12:35:05]  [    0.000000] percpu: Embedded 22 pages/cpu s50136 r8192 d31784 u90112
[2023-07-06 12:35:05]  [    0.000000] pcpu-alloc: s50136 r8192 d31784 u90112 alloc=22*4096
[2023-07-06 12:35:05]  [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7
[2023-07-06 12:35:05]  [    0.000000] Detected PIPT I-cache on CPU0
[2023-07-06 12:35:05]  [    0.000000] CPU features: detected: GIC system register CPU interface
[2023-07-06 12:35:05]  [    0.000000] CPU features: detected: EL2 vector hardening
[2023-07-06 12:35:05]  [    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[2023-07-06 12:35:05]  [    0.000000] CPU features: detected: Spectre-BHB
[2023-07-06 12:35:05]  [    0.000000] CPU features: detected: ARM erratum 1742098
[2023-07-06 12:35:05]  [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 2064384
[2023-07-06 12:35:06]  [    0.000000] Kernel command line: console= quiet uboot_version=v2.2.3 uboot_svnversion=475824 earlycon=ns16550a,mmio32,0x02880000 rproc_rsctable=41000000.r5f:0x8c@0xa2100000;5c00000.r5f:0x8c@0xa3100000;5d00000.r5f:0x8c@0xa6100000;5e00000.r5f:0x8c@0xa7100000;5f00000.r5f:0x8c@0xa8100000;5900000.r5f:0x8c@0xa9100000;5a00000.r5f:0x8c@0xab100000;64800000.dsp:0x98@0xb4100000;65800000.dsp:0x98@0xb7500000;66800000.dsp:0x98@0xba900000;67800000.dsp:0x98@0xbdd00000 bootxpart=main
[2023-07-06 12:35:06]  [    0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[2023-07-06 12:35:06]  [    0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[2023-07-06 12:35:06]  [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[2023-07-06 12:35:06]  [    0.000000] software IO TLB: Cannot allocate buffer
[2023-07-06 12:35:06]  [    0.000000] Memory: 2467984K/8388608K available (10816K kernel code, 1168K rwdata, 4148K rodata, 1792K init, 432K bss, 5920624K reserved, 0K cma-reserved)
[2023-07-06 12:35:06]  [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[2023-07-06 12:35:06]  [    0.000000] rcu: Preemptible hierarchical RCU implementation.
[2023-07-06 12:35:06]  [    0.000000] rcu: RCU event tracing is enabled.
[2023-07-06 12:35:06]  [    0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=8.
[2023-07-06 12:35:06]  [    0.000000] Trampoline variant of Tasks RCU enabled.
[2023-07-06 12:35:06]  [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[2023-07-06 12:35:06]  [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[2023-07-06 12:35:06]  [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[2023-07-06 12:35:06]  [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[2023-07-06 12:35:06]  [    0.000000] GICv3: 960 SPIs implemented
[2023-07-06 12:35:06]  [    0.000000] GICv3: 0 Extended SPIs implemented
[2023-07-06 12:35:06]  [    0.000000] GICv3: Distributor has no Range Selector support
[2023-07-06 12:35:07]  [    0.000000] GICv3: 16 PPIs implemented
[2023-07-06 12:35:07]  [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[2023-07-06 12:35:07]  [    0.000000] ITS [mem 0x01820000-0x0182ffff]
[2023-07-06 12:35:07]  [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[2023-07-06 12:35:07]  [    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[2023-07-06 12:35:07]  [    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @8d3c00000 (flat, esz 8, psz 64K, shr 0)
[2023-07-06 12:35:07]  [    0.000000] ITS: using cache flushing for cmd queue
[2023-07-06 12:35:07]  [    0.000000] GICv3: using LPI property table @0x00000008d3450000
[2023-07-06 12:35:07]  [    0.000000] GIC: using cache flushing for LPI property table
[2023-07-06 12:35:07]  [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008d3460000
[2023-07-06 12:35:07]  [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[2023-07-06 12:35:07]  [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[2023-07-06 12:35:07]  [    0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[2023-07-06 12:35:07]  [    0.000238] Console: colour dummy device 80x25
[2023-07-06 12:35:07]  [    0.000274] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[2023-07-06 12:35:07]  [    0.000282] pid_max: default: 32768 minimum: 301
[2023-07-06 12:35:07]  [    0.000329] LSM: Security Framework initializing
[2023-07-06 12:35:07]  [    0.000384] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[2023-07-06 12:35:07]  [    0.000415] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[2023-07-06 12:35:07]  [    0.001402] rcu: Hierarchical SRCU implementation.
[2023-07-06 12:35:07]  [    0.001617] Platform MSI: msi-controller@1820000 domain created
[2023-07-06 12:35:07]  [    0.001731] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[2023-07-06 12:35:07]  [    0.001787] EFI services will not be available.
[2023-07-06 12:35:08]  [    0.002005] smp: Bringing up secondary CPUs ...
[2023-07-06 12:35:08]  [    0.010473] Detected PIPT I-cache on CPU1
[2023-07-06 12:35:08]  [    0.010496] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[2023-07-06 12:35:08]  [    0.010509] GICv3: CPU1: using allocated LPI pending table @0x00000008d3470000
[2023-07-06 12:35:08]  [    0.010544] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[2023-07-06 12:35:08]  [    0.019018] Detected PIPT I-cache on CPU2
[2023-07-06 12:35:08]  [    0.019031] GICv3: CPU2: found redistributor 2 region 0:0x0000000001940000
[2023-07-06 12:35:08]  [    0.019043] GICv3: CPU2: using allocated LPI pending table @0x00000008d3480000
[2023-07-06 12:35:08]  [    0.019072] CPU2: Booted secondary processor 0x0000000002 [0x411fd080]
[2023-07-06 12:35:08]  [    0.027522] Detected PIPT I-cache on CPU3
[2023-07-06 12:35:08]  [    0.027537] GICv3: CPU3: found redistributor 3 region 0:0x0000000001960000
[2023-07-06 12:35:08]  [    0.027549] GICv3: CPU3: using allocated LPI pending table @0x00000008d3490000
[2023-07-06 12:35:08]  [    0.027578] CPU3: Booted secondary processor 0x0000000003 [0x411fd080]
[2023-07-06 12:35:08]  [    0.036055] Detected PIPT I-cache on CPU4
[2023-07-06 12:35:08]  [    0.036080] GICv3: CPU4: found redistributor 100 region 0:0x0000000001980000
[2023-07-06 12:35:08]  [    0.036093] GICv3: CPU4: using allocated LPI pending table @0x00000008d34a0000
[2023-07-06 12:35:08]  [    0.036131] CPU4: Booted secondary processor 0x0000000100 [0x411fd080]
[2023-07-06 12:35:08]  [    0.044627] Detected PIPT I-cache on CPU5
[2023-07-06 12:35:08]  [    0.044645] GICv3: CPU5: found redistributor 101 region 0:0x00000000019a0000
[2023-07-06 12:35:08]  [    0.044657] GICv3: CPU5: using allocated LPI pending table @0x00000008d34b0000
[2023-07-06 12:35:08]  [    0.044686] CPU5: Booted secondary processor 0x0000000101 [0x411fd080]
[2023-07-06 12:35:08]  [    0.053146] Detected PIPT I-cache on CPU6
[2023-07-06 12:35:08]  [    0.053165] GICv3: CPU6: found redistributor 102 region 0:0x00000000019c0000
[2023-07-06 12:35:08]  [    0.053177] GICv3: CPU6: using allocated LPI pending table @0x00000008d34c0000
[2023-07-06 12:35:09]  [    0.053206] CPU6: Booted secondary processor 0x0000000102 [0x411fd080]
[2023-07-06 12:35:09]  [    0.061659] Detected PIPT I-cache on CPU7
[2023-07-06 12:35:09]  [    0.061681] GICv3: CPU7: found redistributor 103 region 0:0x00000000019e0000
[2023-07-06 12:35:09]  [    0.061692] GICv3: CPU7: using allocated LPI pending table @0x00000008d34d0000
[2023-07-06 12:35:09]  [    0.061722] CPU7: Booted secondary processor 0x0000000103 [0x411fd080]
[2023-07-06 12:35:09]  [    0.061784] smp: Brought up 1 node, 8 CPUs
[2023-07-06 12:35:09]  [    0.061793] SMP: Total of 8 processors activated.
[2023-07-06 12:35:09]  [    0.061798] CPU features: detected: 32-bit EL0 Support
[2023-07-06 12:35:09]  [    0.061801] CPU features: detected: CRC32 instructions
[2023-07-06 12:35:09]  [    0.073679] CPU: All CPU(s) started at EL2
[2023-07-06 12:35:09]  [    0.073709] alternatives: patching kernel code
[2023-07-06 12:35:09]  [    0.074293] devtmpfs: initialized
[2023-07-06 12:35:09]  [    0.079505] KASLR disabled due to lack of seed
[2023-07-06 12:35:09]  [    0.079612] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[2023-07-06 12:35:09]  [    0.079621] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[2023-07-06 12:35:09]  [    0.079791] pinctrl core: initialized pinctrl subsystem
[2023-07-06 12:35:09]  [    0.080039] DMI not present or invalid.
[2023-07-06 12:35:09]  [    0.080358] NET: Registered protocol family 16
[2023-07-06 12:35:09]  [    0.080771] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[2023-07-06 12:35:09]  [    0.080875] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[2023-07-06 12:35:09]  [    0.080969] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[2023-07-06 12:35:09]  [    0.081263] thermal_sys: Registered thermal governor 'step_wise'
[2023-07-06 12:35:09]  [    0.081266] thermal_sys: Registered thermal governor 'power_allocator'
[2023-07-06 12:35:09]  [    0.081523] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[2023-07-06 12:35:09]  [    0.081626] ASID allocator initialised with 65536 entries
[2023-07-06 12:35:09]  [    0.095580] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[2023-07-06 12:35:10]  [    0.095585] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[2023-07-06 12:35:10]  [    0.095589] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[2023-07-06 12:35:10]  [    0.095592] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[2023-07-06 12:35:10]  [    0.096483] cryptd: max_cpu_qlen set to 1000
[2023-07-06 12:35:10]  [    0.098395] k3-chipinfo 43000014.chipid: Family:J784S4 rev:SR1.0 JTAGID[0x0bb8002f] Detected
[2023-07-06 12:35:10]  [    0.098666] vsys_3v3: supplied by evm_12v0
[2023-07-06 12:35:10]  [    0.098883] vsys_5v0: supplied by evm_12v0
[2023-07-06 12:35:10]  [    0.099036] vdd_mmc1: supplied by vsys_3v3
[2023-07-06 12:35:10]  [    0.099700] iommu: Default domain type: Translated
[2023-07-06 12:35:10]  [    0.099824] vgaarb: loaded
[2023-07-06 12:35:10]  [    0.099970] SCSI subsystem initialized
[2023-07-06 12:35:10]  [    0.100120] mc: Linux media interface: v0.10
[2023-07-06 12:35:10]  [    0.100132] videodev: Linux video capture interface: v2.00
[2023-07-06 12:35:10]  [    0.100160] pps_core: LinuxPPS API ver. 1 registered
[2023-07-06 12:35:10]  [    0.100162] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[2023-07-06 12:35:10]  [    0.100169] PTP clock support registered
[2023-07-06 12:35:10]  [    0.100191] EDAC MC: Ver: 3.0.0
[2023-07-06 12:35:10]  [    0.100786] FPGA manager framework
[2023-07-06 12:35:10]  [    0.101198] clocksource: Switched to clocksource arch_sys_counter
[2023-07-06 12:35:10]  [    0.101283] VFS: Disk quotas dquot_6.6.0
[2023-07-06 12:35:10]  [    0.101311] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[2023-07-06 12:35:10]  [    0.104155] Carveout Heap: Exported 1008 MiB at 0x00000000c1000000
[2023-07-06 12:35:10]  [    0.104213] Carveout Heap: Exported 1024 MiB at 0x0000000900000000
[2023-07-06 12:35:10]  [    0.104270] NET: Registered protocol family 2
[2023-07-06 12:35:10]  [    0.104593] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[2023-07-06 12:35:10]  [    0.106629] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[2023-07-06 12:35:11]  [    0.106681] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[2023-07-06 12:35:11]  [    0.106894] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[2023-07-06 12:35:11]  [    0.107307] TCP: Hash tables configured (established 65536 bind 65536)
[2023-07-06 12:35:11]  [    0.107402] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[2023-07-06 12:35:11]  [    0.107484] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[2023-07-06 12:35:11]  [    0.107643] NET: Registered protocol family 1
[2023-07-06 12:35:11]  [    0.107993] RPC: Registered named UNIX socket transport module.
[2023-07-06 12:35:11]  [    0.107998] RPC: Registered udp transport module.
[2023-07-06 12:35:11]  [    0.108000] RPC: Registered tcp transport module.
[2023-07-06 12:35:11]  [    0.108003] RPC: Registered tcp NFSv4.1 backchannel transport module.
[2023-07-06 12:35:11]  [    0.108012] PCI: CLS 0 bytes, default 64
[2023-07-06 12:35:11]  [    0.108128] Trying to unpack rootfs image as initramfs...
[2023-07-06 12:35:11]  [    0.190686] Freeing initrd memory: 11740K
[2023-07-06 12:35:11]  [    0.191384] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[2023-07-06 12:35:11]  [    0.193953] Initialise system trusted keyrings
[2023-07-06 12:35:11]  [    0.194041] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[2023-07-06 12:35:11]  [    0.195975] NFS: Registering the id_resolver key type
[2023-07-06 12:35:11]  [    0.195995] Key type id_resolver registered
[2023-07-06 12:35:11]  [    0.195998] Key type id_legacy registered
[2023-07-06 12:35:11]  [    0.196028] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[2023-07-06 12:35:11]  [    0.196032] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[2023-07-06 12:35:11]  [    0.196034] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[2023-07-06 12:35:11]  [    0.196285] 9p: Installing v9fs 9p2000 file system support
[2023-07-06 12:35:11]  [    0.215906] Key type asymmetric registered
[2023-07-06 12:35:11]  [    0.215909] Asymmetric key parser 'x509' registered
[2023-07-06 12:35:11]  [    0.215930] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 241)
[2023-07-06 12:35:12]  [    0.215934] io scheduler mq-deadline registered
[2023-07-06 12:35:12]  [    0.215937] io scheduler kyber registered
[2023-07-06 12:35:12]  [    0.217380] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
[2023-07-06 12:35:12]  [    0.217515] pinctrl-single 11c000.pinctrl: 72 pins, size 288
[2023-07-06 12:35:12]  [    0.221861] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[2023-07-06 12:35:12]  [    0.228541] brd: module loaded
[2023-07-06 12:35:12]  [    0.232779] loop: module loaded
[2023-07-06 12:35:12]  [    0.235322] tun: Universal TUN/TAP device driver, 1.6
[2023-07-06 12:35:12]  [    0.235951] VFIO - User Level meta-driver version: 0.3
[2023-07-06 12:35:12]  [    0.236310] i2c /dev entries driver
[2023-07-06 12:35:12]  [    0.237147] sdhci: Secure Digital Host Controller Interface driver
[2023-07-06 12:35:12]  [    0.237149] sdhci: Copyright(c) Pierre Ossman
[2023-07-06 12:35:12]  [    0.237359] sdhci-pltfm: SDHCI platform and OF driver helper
[2023-07-06 12:35:12]  [    0.237862] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[2023-07-06 12:35:12]  [    0.238704] optee: probing for conduit method.
[2023-07-06 12:35:12]  [    0.238721] optee: revision 3.19 (afacf356)
[2023-07-06 12:35:12]  [    0.238848] optee: dynamic shared memory is enabled
[2023-07-06 12:35:12]  [    0.239056] optee: initialized driver
[2023-07-06 12:35:12]  [    0.239924] NET: Registered protocol family 17
[2023-07-06 12:35:12]  [    0.239959] 8021q: 802.1Q VLAN Support v1.8
[2023-07-06 12:35:12]  [    0.240017] 9pnet: Installing 9P2000 support
[2023-07-06 12:35:12]  [    0.240055] Key type dns_resolver registered
[2023-07-06 12:35:12]  [    0.240172] registered taskstats version 1
[2023-07-06 12:35:12]  [    0.240176] Loading compiled-in X.509 certificates
[2023-07-06 12:35:12]  [    0.244871] ti-sci 44083000.system-controller: ABI: 3.1 (firmware rev 0x0008 '8.6.3--v08.06.03 (Chill Capybar')
[2023-07-06 12:35:12]  [    0.264986] ti-sci-intr 310e0000.interrupt-controller: Interrupt Router 283 domain created
[2023-07-06 12:35:12]  [    0.265159] ti-sci-inta 33d00000.msi-controller: Interrupt Aggregator domain 321 created
[2023-07-06 12:35:12]  [    0.272431] j721e-pcie 2900000.pcie: defined num-lanes 4 is greater than the allowed maximum of 2, defaulting to 1
[2023-07-06 12:35:13]  [    0.272606] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[2023-07-06 12:35:13]  [    0.272634] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[2023-07-06 12:35:13]  [    0.272652] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[2023-07-06 12:35:13]  [    0.272667] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[2023-07-06 12:35:13]  [    0.272669] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[2023-07-06 12:35:13]  [    0.272694] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[2023-07-06 12:35:13]  [    0.272705] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[2023-07-06 12:35:13]  [    0.272717] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[2023-07-06 12:35:13]  [    0.273251] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:328
[2023-07-06 12:35:13]  [    0.273255] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[2023-07-06 12:35:13]  [    0.273258] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66349100, num_proxies:64
[2023-07-06 12:35:13]  [    0.274784] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[878,128] sci-dev-id:315
[2023-07-06 12:35:13]  [    0.274788] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[2023-07-06 12:35:13]  [    0.274791] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66349100, num_proxies:64
[2023-07-06 12:35:13]  [    0.275241] 2830000.serial: ttyS3 at MMIO 0x2830000 (irq = 16, base_baud = 3000000) is a 8250
[2023-07-06 12:35:13]  [    0.275755] 2880000.serial: ttyS2 at MMIO 0x2880000 (irq = 17, base_baud = 3000000) is a 8250
[2023-07-06 12:35:13]  [    0.275786] printk: console [ttyS2] enabled
[2023-07-06 12:35:13]  [    0.275790] printk: bootconsole [ns16550a0] disabled
[2023-07-06 12:35:13]  [    0.285965] spi-nor spi0.0: w25q128 (16384 Kbytes)
[2023-07-06 12:35:14]  [    0.288117] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fca100
[2023-07-06 12:35:14]  [    0.288442] mmc0: CQHCI version 5.10
[2023-07-06 12:35:14]  [    0.288468] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fca100
[2023-07-06 12:35:14]  [    0.288650] mmc1: CQHCI version 5.10
[2023-07-06 12:35:14]  [    0.288783] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fca100
[2023-07-06 12:35:14]  [    0.289086] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fca100
[2023-07-06 12:35:14]  [    0.289393] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fca100
[2023-07-06 12:35:14]  [    0.289695] omap-mailbox 31f85000.mailbox: omap mailbox rev 0x66fca100
[2023-07-06 12:35:14]  [    0.290296] ti-udma 285c0000.dma-controller: Channels: 22 (tchan: 11, rchan: 11, gp-rflow: 8)
[2023-07-06 12:35:14]  [    0.291835] ti-udma 31150000.dma-controller: Channels: 66 (tchan: 33, rchan: 33, gp-rflow: 16)
[2023-07-06 12:35:14]  [    0.298597] debugfs: Directory 'pd:73' with parent 'pm_genpd' already present!
[2023-07-06 12:35:14]  [    0.298636] debugfs: Directory 'pd:72' with parent 'pm_genpd' already present!
[2023-07-06 12:35:14]  [    0.299166] debugfs: Directory 'pd:335' with parent 'pm_genpd' already present!
[2023-07-06 12:35:14]  [    0.299196] debugfs: Directory 'pd:334' with parent 'pm_genpd' already present!
[2023-07-06 12:35:14]  [    0.299218] debugfs: Directory 'pd:333' with parent 'pm_genpd' already present!
[2023-07-06 12:35:14]  [    0.299239] debugfs: Directory 'pd:332' with parent 'pm_genpd' already present!
[2023-07-06 12:35:14]  [    0.317774] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
[2023-07-06 12:35:14]  [    0.321204] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
[2023-07-06 12:35:14]  [    0.337212] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[2023-07-06 12:35:14]  [    0.340254] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver RTL9000BF Ethernet
[2023-07-06 12:35:14]  [    0.340309] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
[2023-07-06 12:35:14]  [    0.340427] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[2023-07-06 12:35:15]  [    0.340430] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[2023-07-06 12:35:15]  [    0.340879] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:0
[2023-07-06 12:35:15]  [    0.341762] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
[2023-07-06 12:35:15]  [    0.343109] am65-cpsw-nuss c200000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
[2023-07-06 12:35:15]  [    0.343202] am65-cpsw-nuss c200000.ethernet: initialized cpsw ale version 1.4
[2023-07-06 12:35:15]  [    0.343206] am65-cpsw-nuss c200000.ethernet: ALE Table size 64
[2023-07-06 12:35:15]  [    0.343590] am65-cpsw-nuss c200000.ethernet: CPTS ver 0x4e8a010b, freq:200000000, add_val:4 pps:0
[2023-07-06 12:35:15]  [    0.344532] am65-cpsw-nuss c200000.ethernet: set new flow-id-base 82
[2023-07-06 12:35:15]  [    0.372031] j721e-pcie 2900000.pcie: Link up
[2023-07-06 12:35:15]  [    0.372132] j721e-pcie 2900000.pcie: PCI host bridge to bus 0000:00
[2023-07-06 12:35:15]  [    0.372138] pci_bus 0000:00: root bus resource [bus 00-ff]
[2023-07-06 12:35:15]  [    0.372142] pci_bus 0000:00: root bus resource [io  0x0000-0xffff] (bus address [0x10001000-0x10010fff])
[2023-07-06 12:35:15]  [    0.372146] pci_bus 0000:00: root bus resource [mem 0x10011000-0x17ffffff]
[2023-07-06 12:35:15]  [    0.372182] pci 0000:00:00.0: [104c:b00d] type 01 class 0x060400
[2023-07-06 12:35:15]  [    0.372187] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
[2023-07-06 12:35:15]  [    0.372315] pci 0000:00:00.0: supports D1
[2023-07-06 12:35:15]  [    0.372318] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[2023-07-06 12:35:15]  [    0.374351] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[2023-07-06 12:35:15]  [    0.374477] pci 0000:01:00.0: [1b21:0611] type 00 class 0x010185
[2023-07-06 12:35:15]  [    0.374523] pci 0000:01:00.0: reg 0x10: initial BAR value 0x00000000 invalid
[2023-07-06 12:35:15]  [    0.374527] pci 0000:01:00.0: reg 0x10: [io  size 0x0008]
[2023-07-06 12:35:15]  [    0.374549] pci 0000:01:00.0: reg 0x14: initial BAR value 0x00000000 invalid
[2023-07-06 12:35:16]  [    0.374551] pci 0000:01:00.0: reg 0x14: [io  size 0x0004]
[2023-07-06 12:35:16]  [    0.374574] pci 0000:01:00.0: reg 0x18: initial BAR value 0x00000000 invalid
[2023-07-06 12:35:16]  [    0.374576] pci 0000:01:00.0: reg 0x18: [io  size 0x0008]
[2023-07-06 12:35:16]  [    0.374598] pci 0000:01:00.0: reg 0x1c: initial BAR value 0x00000000 invalid
[2023-07-06 12:35:16]  [    0.374600] pci 0000:01:00.0: reg 0x1c: [io  size 0x0004]
[2023-07-06 12:35:16]  [    0.374622] pci 0000:01:00.0: reg 0x20: initial BAR value 0x00000000 invalid
[2023-07-06 12:35:16]  [    0.374625] pci 0000:01:00.0: reg 0x20: [io  size 0x0010]
[2023-07-06 12:35:16]  [    0.374647] pci 0000:01:00.0: reg 0x24: [mem 0x00000000-0x000001ff]
[2023-07-06 12:35:16]  [    0.374669] pci 0000:01:00.0: reg 0x30: [mem 0x00000000-0x0000ffff pref]
[2023-07-06 12:35:16]  [    0.387026] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[2023-07-06 12:35:16]  [    0.387044] pci 0000:00:00.0: BAR 14: assigned [mem 0x10100000-0x101fffff]
[2023-07-06 12:35:16]  [    0.387048] pci 0000:00:00.0: BAR 13: assigned [io  0x1000-0x1fff]
[2023-07-06 12:35:16]  [    0.387053] pci 0000:01:00.0: BAR 6: assigned [mem 0x10100000-0x1010ffff pref]
[2023-07-06 12:35:16]  [    0.387057] pci 0000:01:00.0: BAR 5: assigned [mem 0x10110000-0x101101ff]
[2023-07-06 12:35:16]  [    0.387068] pci 0000:01:00.0: BAR 4: assigned [io  0x1000-0x100f]
[2023-07-06 12:35:16]  [    0.387079] pci 0000:01:00.0: BAR 0: assigned [io  0x1010-0x1017]
[2023-07-06 12:35:16]  [    0.387090] pci 0000:01:00.0: BAR 2: assigned [io  0x1018-0x101f]
[2023-07-06 12:35:16]  [    0.387101] pci 0000:01:00.0: BAR 1: assigned [io  0x1020-0x1023]
[2023-07-06 12:35:16]  [    0.387112] pci 0000:01:00.0: BAR 3: assigned [io  0x1024-0x1027]
[2023-07-06 12:35:16]  [    0.387124] pci 0000:00:00.0: PCI bridge to [bus 01]
[2023-07-06 12:35:16]  [    0.387129] pci 0000:00:00.0:   bridge window [io  0x1000-0x1fff]
[2023-07-06 12:35:16]  [    0.387135] pci 0000:00:00.0:   bridge window [mem 0x10100000-0x101fffff]
[2023-07-06 12:35:16]  [    0.387271] pcieport 0000:00:00.0: enabling device (0000 -> 0003)
[2023-07-06 12:35:17]  [    0.387425] pcieport 0000:00:00.0: PME: Signaling with IRQ 280
[2023-07-06 12:35:17]  [    0.400489] mmc0: Command Queue Engine enabled
[2023-07-06 12:35:17]  [    0.400499] mmc0: new HS400 MMC card at address 0001
[2023-07-06 12:35:17]  [    0.400771] mmcblk0: mmc0:0001 CJUD4R 59.6 GiB
[2023-07-06 12:35:17]  [    0.400848] mmcblk0boot0: mmc0:0001 CJUD4R partition 1 31.9 MiB
[2023-07-06 12:35:17]  [    0.400924] mmcblk0boot1: mmc0:0001 CJUD4R partition 2 31.9 MiB
[2023-07-06 12:35:17]  [    0.401006] mmcblk0rpmb: mmc0:0001 CJUD4R partition 3 4.00 MiB, chardev (235:0)
[2023-07-06 12:35:17]  [    0.401708]  mmcblk0: 119 partitions parsed from device tree
[2023-07-06 12:35:17]  [    1.276044] j721e-pcie 2910000.pcie: PCI host bridge to bus 0001:00
[2023-07-06 12:35:17]  [    1.276051] pci_bus 0001:00: root bus resource [bus 00-ff]
[2023-07-06 12:35:17]  [    1.276056] pci_bus 0001:00: root bus resource [io  0x10000-0x1ffff] (bus address [0x18001000-0x18010fff])
[2023-07-06 12:35:17]  [    1.276059] pci_bus 0001:00: root bus resource [mem 0x18011000-0x1fffffff]
[2023-07-06 12:35:17]  [    1.276094] pci 0001:00:00.0: [104c:b013] type 01 class 0x060400
[2023-07-06 12:35:17]  [    1.276099] pci_bus 0001:00: 2-byte config write to 0001:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
[2023-07-06 12:35:17]  [    1.276217] pci 0001:00:00.0: supports D1
[2023-07-06 12:35:17]  [    1.276220] pci 0001:00:00.0: PME# supported from D0 D1 D3hot
[2023-07-06 12:35:17]  [    1.278090] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[2023-07-06 12:35:17]  [    1.279771] pci_bus 0001:01: busn_res: [bus 01-ff] end is updated to 01
[2023-07-06 12:35:17]  [    1.279785] pci 0001:00:00.0: PCI bridge to [bus 01]
[2023-07-06 12:35:17]  [    1.280050] pcieport 0001:00:00.0: PME: Signaling with IRQ 282
[2023-07-06 12:35:17]  [    1.281259] Freeing unused kernel memory: 1792K
[2023-07-06 12:35:17]  [    1.293279] Run /init as init process
[2023-07-06 12:35:17]  [    1.293281]   with arguments:
[2023-07-06 12:35:17]  [    1.293283]     /init
[2023-07-06 12:35:17]  [    1.293285]   with environment:
[2023-07-06 12:35:17]  [    1.293287]     HOME=/
[2023-07-06 12:35:18]  [    1.293289]     TERM=linux
[2023-07-06 12:35:18]  [    1.293291]     bootxpart=main
[2023-07-06 12:35:18]  [    1.333375] random: dd: uninitialized urandom read (512 bytes read)
[2023-07-06 12:35:18]  [    1.348906] random: dropbear: uninitialized urandom read (32 bytes read)
[2023-07-06 12:35:18]  [    4.545192] am65-cpsw-nuss c200000.ethernet eth2: configuring for fixed/rgmii-rxid link mode
[2023-07-06 12:35:18]  [    4.545265] am65-cpsw-nuss c200000.ethernet eth2: Link is Up - 100Mbps/Full - flow control off
[2023-07-06 12:35:18]  [    4.545807] 8021q: adding VLAN 0 to HW filter on device eth2
[2023-07-06 12:35:18]  [    4.575648] EXT4-fs (mmcblk0p51): mounted filesystem with ordered data mode. Opts: (null)
[2023-07-06 12:35:18]  [    4.583597] EXT4-fs (mmcblk0p63): mounted filesystem with ordered data mode. Opts: (null)
[2023-07-06 12:35:18]  [    4.587056] EXT4-fs (mmcblk0p61): mounted filesystem with ordered data mode. Opts: (null)
[2023-07-06 12:35:18]  [    4.587498] EXT4-fs (mmcblk0p65): mounted filesystem with ordered data mode. Opts: (null)
[2023-07-06 12:35:18]  [    4.587887] EXT4-fs (mmcblk0p53): mounted filesystem with ordered data mode. Opts: (null)
[2023-07-06 12:35:18]  [    4.588213] EXT4-fs (mmcblk0p66): mounted filesystem with ordered data mode. Opts: (null)
[2023-07-06 12:35:18]  [    4.588567] EXT4-fs (mmcblk0p116): mounted filesystem with ordered data mode. Opts: (null)
[2023-07-06 12:35:18]  [    4.588976] EXT4-fs (mmcblk0p57): mounted filesystem with ordered data mode. Opts: (null)
[2023-07-06 12:35:18]  [    4.589396] EXT4-fs (mmcblk0p55): mounted filesystem with ordered data mode. Opts: (null)
[2023-07-06 12:35:18]  [    4.591620] EXT4-fs (mmcblk0p112): VFS: Can't find ext4 filesystem
[2023-07-06 12:35:18]  [    4.599726] EXT4-fs (mmcblk0p114): VFS: Can't find ext4 filesystem
[2023-07-06 12:35:18]  [    4.614449] EXT4-fs (mmcblk0p117): mounted filesystem with ordered data mode. Opts: (null)
[2023-07-06 12:35:18]  [    4.619208] EXT4-fs (mmcblk0p118): mounted filesystem with ordered data mode. Opts: (null)
[2023-07-06 12:35:18]  [    4.632073] GTC: loading out-of-tree module taints kernel.
[2023-07-06 12:35:18]  [    4.639840] k3-dsp-rproc 64800000.dsp: assigned reserved memory node c71-dma-memory@b4000000
[2023-07-06 12:35:19]  [    4.640729] k3-dsp-rproc 64800000.dsp: configured DSP for IPC-only mode
[2023-07-06 12:35:19]  [    4.650235] remoteproc remoteproc0: 64800000.dsp is available
[2023-07-06 12:35:19]  [    4.650276] remoteproc remoteproc0: attaching to 64800000.dsp
[2023-07-06 12:35:19]  [    4.650303] remoteproc remoteproc0: unsupported resource 65538
[2023-07-06 12:35:19]  [    4.650362] k3-dsp-rproc 64800000.dsp: DSP initialized in IPC-only mode
[2023-07-06 12:35:19]  [    4.662477]  remoteproc0#vdev0buffer: assigned reserved memory node c71-dma-memory@b4000000
[2023-07-06 12:35:19]  [    4.662707] virtio_rpmsg_bus virtio0: rpmsg host is online
[2023-07-06 12:35:19]  [    4.663067]  remoteproc0#vdev0buffer: registered virtio0 (type 7)
[2023-07-06 12:35:19]  [    4.663071] remoteproc remoteproc0: remote processor 64800000.dsp is now attached
[2023-07-06 12:35:19]  [    4.663590] k3-dsp-rproc 65800000.dsp: assigned reserved memory node c71_1-dma-memory@b7400000
[2023-07-06 12:35:19]  [    4.664500] k3-dsp-rproc 65800000.dsp: configured DSP for IPC-only mode
[2023-07-06 12:35:19]  [    4.664721] virtio_rpmsg_bus virtio0: creating channel rpmsg-remote-service addr 0x37
[2023-07-06 12:35:19]  [    4.671141] remoteproc remoteproc1: 65800000.dsp is available
[2023-07-06 12:35:19]  [    4.671164] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0x4
[2023-07-06 12:35:19]  [    4.671173] remoteproc remoteproc1: attaching to 65800000.dsp
[2023-07-06 12:35:19]  [    4.671198] remoteproc remoteproc1: unsupported resource 65538
[2023-07-06 12:35:19]  [    4.671221] k3-dsp-rproc 65800000.dsp: DSP initialized in IPC-only mode
[2023-07-06 12:35:19]  [    4.677837]  remoteproc1#vdev0buffer: assigned reserved memory node c71_1-dma-memory@b7400000
[2023-07-06 12:35:19]  [    4.678053] virtio_rpmsg_bus virtio1: rpmsg host is online
[2023-07-06 12:35:19]  [    4.678330]  remoteproc1#vdev0buffer: registered virtio1 (type 7)
[2023-07-06 12:35:19]  [    4.678334] remoteproc remoteproc1: remote processor 65800000.dsp is now attached
[2023-07-06 12:35:19]  [    4.678809] k3-dsp-rproc 66800000.dsp: assigned reserved memory node c71_2-dma-memory@ba800000
[2023-07-06 12:35:20]  [    4.679720] k3-dsp-rproc 66800000.dsp: configured DSP for IPC-only mode
[2023-07-06 12:35:20]  [    4.686393] remoteproc remoteproc2: 66800000.dsp is available
[2023-07-06 12:35:20]  [    4.686430] remoteproc remoteproc2: attaching to 66800000.dsp
[2023-07-06 12:35:20]  [    4.686457] remoteproc remoteproc2: unsupported resource 65538
[2023-07-06 12:35:20]  [    4.686511] k3-dsp-rproc 66800000.dsp: DSP initialized in IPC-only mode
[2023-07-06 12:35:20]  [    4.692969] virtio_rpmsg_bus virtio1: creating channel rpmsg-remote-service addr 0x37
[2023-07-06 12:35:20]  [    4.693137]  remoteproc2#vdev0buffer: assigned reserved memory node c71_2-dma-memory@ba800000
[2023-07-06 12:35:20]  [    4.693150] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0x4
[2023-07-06 12:35:20]  [    4.693382] virtio_rpmsg_bus virtio2: rpmsg host is online
[2023-07-06 12:35:20]  [    4.693399]  remoteproc2#vdev0buffer: registered virtio2 (type 7)
[2023-07-06 12:35:20]  [    4.693402] remoteproc remoteproc2: remote processor 66800000.dsp is now attached
[2023-07-06 12:35:20]  [    4.693701] k3-dsp-rproc 67800000.dsp: assigned reserved memory node c71_3-dma-memory@bdc00000
[2023-07-06 12:35:20]  [    4.694608] k3-dsp-rproc 67800000.dsp: configured DSP for IPC-only mode
[2023-07-06 12:35:20]  [    4.701248] remoteproc remoteproc3: 67800000.dsp is available
[2023-07-06 12:35:20]  [    4.701275] remoteproc remoteproc3: attaching to 67800000.dsp
[2023-07-06 12:35:20]  [    4.701300] remoteproc remoteproc3: unsupported resource 65538
[2023-07-06 12:35:20]  [    4.701327] k3-dsp-rproc 67800000.dsp: DSP initialized in IPC-only mode
[2023-07-06 12:35:20]  [    4.707936]  remoteproc3#vdev0buffer: assigned reserved memory node c71_3-dma-memory@bdc00000
[2023-07-06 12:35:20]  [    4.708148] virtio_rpmsg_bus virtio3: rpmsg host is online
[2023-07-06 12:35:20]  [    4.708469]  remoteproc3#vdev0buffer: registered virtio3 (type 7)
[2023-07-06 12:35:20]  [    4.708473] remoteproc remoteproc3: remote processor 67800000.dsp is now attached
[2023-07-06 12:35:20]  [    4.712265] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[2023-07-06 12:35:21]  [    4.712374] platform 41000000.r5f: configured R5F for IPC-only mode
[2023-07-06 12:35:21]  [    4.718715] platform 41000000.r5f: assigned reserved memory node r5f-dma-memory@a2000000
[2023-07-06 12:35:21]  [    4.718968] remoteproc remoteproc4: 41000000.r5f is available
[2023-07-06 12:35:21]  [    4.719012] remoteproc remoteproc4: attaching to 41000000.r5f
[2023-07-06 12:35:21]  [    4.719088] platform 41000000.r5f: R5F core initialized in IPC-only mode
[2023-07-06 12:35:21]  [    4.725780]  remoteproc4#vdev0buffer: assigned reserved memory node r5f-dma-memory@a2000000
[2023-07-06 12:35:21]  [    4.726003] virtio_rpmsg_bus virtio4: rpmsg host is online
[2023-07-06 12:35:21]  [    4.726167] virtio_rpmsg_bus virtio2: creating channel rpmsg-remote-service addr 0x37
[2023-07-06 12:35:21]  [    4.726218] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0x4
[2023-07-06 12:35:21]  [    4.726320]  remoteproc4#vdev0buffer: registered virtio4 (type 7)
[2023-07-06 12:35:21]  [    4.726324] remoteproc remoteproc4: remote processor 41000000.r5f is now attached
[2023-07-06 12:35:21]  [    4.727480] platform 5c00000.r5f: configured R5F for IPC-only mode
[2023-07-06 12:35:21]  [    4.733700] platform 5c00000.r5f: assigned reserved memory node r5f-dma-memory@a3000000
[2023-07-06 12:35:21]  [    4.734528] remoteproc remoteproc5: 5c00000.r5f is available
[2023-07-06 12:35:21]  [    4.734559] remoteproc remoteproc5: attaching to 5c00000.r5f
[2023-07-06 12:35:21]  [    4.734620] platform 5c00000.r5f: R5F core initialized in IPC-only mode
[2023-07-06 12:35:21]  [    4.741225]  remoteproc5#vdev0buffer: assigned reserved memory node r5f-dma-memory@a3000000
[2023-07-06 12:35:21]  [    4.741438] virtio_rpmsg_bus virtio5: rpmsg host is online
[2023-07-06 12:35:21]  [    4.741727]  remoteproc5#vdev0buffer: registered virtio5 (type 7)
[2023-07-06 12:35:21]  [    4.741730] remoteproc remoteproc5: remote processor 5c00000.r5f is now attached
[2023-07-06 12:35:22]  [    4.741880] platform 5d00000.r5f: configured R5F for IPC-only mode
[2023-07-06 12:35:22]  [    4.748095] platform 5d00000.r5f: assigned reserved memory node r5f-dma-memory@a6000000
[2023-07-06 12:35:22]  [    4.748385] remoteproc remoteproc6: 5d00000.r5f is available
[2023-07-06 12:35:22]  [    4.748410] remoteproc remoteproc6: attaching to 5d00000.r5f
[2023-07-06 12:35:22]  [    4.748450] platform 5d00000.r5f: R5F core initialized in IPC-only mode
[2023-07-06 12:35:22]  [    4.754865] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0xd
[2023-07-06 12:35:22]  [    4.755064]  remoteproc6#vdev0buffer: assigned reserved memory node r5f-dma-memory@a6000000
[2023-07-06 12:35:22]  [    4.755280] virtio_rpmsg_bus virtio6: rpmsg host is online
[2023-07-06 12:35:22]  [    4.755295]  remoteproc6#vdev0buffer: registered virtio6 (type 7)
[2023-07-06 12:35:22]  [    4.755299] remoteproc remoteproc6: remote processor 5d00000.r5f is now attached
[2023-07-06 12:35:22]  [    4.755764] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0x15
[2023-07-06 12:35:22]  [    4.756442] platform 5e00000.r5f: configured R5F for IPC-only mode
[2023-07-06 12:35:22]  [    4.758840] virtio_rpmsg_bus virtio3: creating channel rpmsg-remote-service addr 0x37
[2023-07-06 12:35:22]  [    4.762649] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0x4
[2023-07-06 12:35:22]  [    4.762656] platform 5e00000.r5f: assigned reserved memory node r5f-dma-memory@a7000000
[2023-07-06 12:35:22]  [    4.762985] remoteproc remoteproc7: 5e00000.r5f is available
[2023-07-06 12:35:22]  [    4.763022] remoteproc remoteproc7: attaching to 5e00000.r5f
[2023-07-06 12:35:22]  [    4.763090] platform 5e00000.r5f: R5F core initialized in IPC-only mode
[2023-07-06 12:35:22]  [    4.769697]  remoteproc7#vdev0buffer: assigned reserved memory node r5f-dma-memory@a7000000
[2023-07-06 12:35:22]  [    4.769910] virtio_rpmsg_bus virtio7: rpmsg host is online
[2023-07-06 12:35:22]  [    4.770190]  remoteproc7#vdev0buffer: registered virtio7 (type 7)
[2023-07-06 12:35:22]  [    4.770194] remoteproc remoteproc7: remote processor 5e00000.r5f is now attached
[2023-07-06 12:35:23]  [    4.770344] platform 5f00000.r5f: configured R5F for IPC-only mode
[2023-07-06 12:35:23]  [    4.776559] platform 5f00000.r5f: assigned reserved memory node r5f-dma-memory@a8000000
[2023-07-06 12:35:23]  [    4.776848] remoteproc remoteproc8: 5f00000.r5f is available
[2023-07-06 12:35:23]  [    4.776872] remoteproc remoteproc8: attaching to 5f00000.r5f
[2023-07-06 12:35:23]  [    4.776913] platform 5f00000.r5f: R5F core initialized in IPC-only mode
[2023-07-06 12:35:23]  [    4.783518]  remoteproc8#vdev0buffer: assigned reserved memory node r5f-dma-memory@a8000000
[2023-07-06 12:35:23]  [    4.783734] virtio_rpmsg_bus virtio8: rpmsg host is online
[2023-07-06 12:35:23]  [    4.784018]  remoteproc8#vdev0buffer: registered virtio8 (type 7)
[2023-07-06 12:35:23]  [    4.784022] remoteproc remoteproc8: remote processor 5f00000.r5f is now attached
[2023-07-06 12:35:23]  [    4.785419] platform 5900000.r5f: configured R5F for IPC-only mode
[2023-07-06 12:35:23]  [    4.787400] virtio_rpmsg_bus virtio4: creating channel rpmsg-remote-service addr 0x37
[2023-07-06 12:35:23]  [    4.791636] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0x4
[2023-07-06 12:35:23]  [    4.791655] platform 5900000.r5f: assigned reserved memory node r5f-dma-memory@a9000000
[2023-07-06 12:35:23]  [    4.792267] remoteproc remoteproc9: 5900000.r5f is available
[2023-07-06 12:35:23]  [    4.792294] remoteproc remoteproc9: attaching to 5900000.r5f
[2023-07-06 12:35:23]  [    4.792359] platform 5900000.r5f: R5F core initialized in IPC-only mode
[2023-07-06 12:35:23]  [    4.798964]  remoteproc9#vdev0buffer: assigned reserved memory node r5f-dma-memory@a9000000
[2023-07-06 12:35:23]  [    4.799170] virtio_rpmsg_bus virtio9: rpmsg host is online
[2023-07-06 12:35:23]  [    4.799446]  remoteproc9#vdev0buffer: registered virtio9 (type 7)
[2023-07-06 12:35:23]  [    4.799450] remoteproc remoteproc9: remote processor 5900000.r5f is now attached
[2023-07-06 12:35:23]  [    4.799650] platform 5a00000.r5f: configured R5F for IPC-only mode
[2023-07-06 12:35:23]  [    4.805866] platform 5a00000.r5f: assigned reserved memory node r5f-dma-memory@ab000000
[2023-07-06 12:35:24]  [    4.806156] remoteproc remoteproc10: 5a00000.r5f is available
[2023-07-06 12:35:24]  [    4.806182] remoteproc remoteproc10: attaching to 5a00000.r5f
[2023-07-06 12:35:24]  [    4.806238] platform 5a00000.r5f: R5F core initialized in IPC-only mode
[2023-07-06 12:35:24]  [    4.812843]  remoteproc10#vdev0buffer: assigned reserved memory node r5f-dma-memory@ab000000
[2023-07-06 12:35:24]  [    4.813048] virtio_rpmsg_bus virtio10: rpmsg host is online
[2023-07-06 12:35:24]  [    4.813337]  remoteproc10#vdev0buffer: registered virtio10 (type 7)
[2023-07-06 12:35:24]  [    4.813341] remoteproc remoteproc10: remote processor 5a00000.r5f is now attached
[2023-07-06 12:35:24]  [    4.824004] virtio_rpmsg_bus virtio6: creating channel rpmsg-remote-service addr 0x37
[2023-07-06 12:35:24]  [    4.824723] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrdev addr 0x4
[2023-07-06 12:35:24]  [    4.840162] virtio_rpmsg_bus virtio8: creating channel rpmsg-remote-service addr 0x37
[2023-07-06 12:35:24]  [    4.842460] virtio_rpmsg_bus virtio8: creating channel rpmsg_chrdev addr 0x4
[2023-07-06 12:35:24]  [    4.844727] virtio_rpmsg_bus virtio7: creating channel rpmsg-remote-service addr 0x37
[2023-07-06 12:35:24]  [    4.845094] virtio_rpmsg_bus virtio7: creating channel rpmsg_chrdev addr 0x4
[2023-07-06 12:35:24]  [    4.848221] virtio_rpmsg_bus virtio9: creating channel rpmsg-remote-service addr 0x37
[2023-07-06 12:35:24]  [    4.848846] virtio_rpmsg_bus virtio9: creating channel rpmsg_chrdev addr 0x4
[2023-07-06 12:35:24]  [    4.856394] virtio_rpmsg_bus virtio10: creating channel rpmsg-remote-service addr 0x37
[2023-07-06 12:35:24]  [    4.856497] virtio_rpmsg_bus virtio10: creating channel rpmsg_chrdev addr 0x4
[2023-07-06 12:35:24]  [    4.876774] virtio_rpmsg_bus virtio5: creating channel ti.ethfw.notifyservice addr 0x1e
[2023-07-06 12:35:24]  [    4.877176] virtio_rpmsg_bus virtio5: creating channel rpmsg-kdrv addr 0x1a
[2023-07-06 12:35:24]  [    4.877744] rpmsg-kdrv-eth-switch rpmsg-kdrv-1-mpu_1_0_ethmac-device-7: Device info: permissions: 3FFFFFFF uart_id: 2
[2023-07-06 12:35:25]  [    4.877749] rpmsg-kdrv-eth-switch rpmsg-kdrv-1-mpu_1_0_ethmac-device-7: FW ver 0.2 (rev 0) 29/Jun/2023 SHA:
[2023-07-06 12:35:25]  [    4.877782] rpmsg-kdrv-eth-switch rpmsg-kdrv-2-mpu_1_0_ethmac-device-8: Device info: permissions: 3FFFFFFF uart_id: 2
[2023-07-06 12:35:25]  [    4.877787] rpmsg-kdrv-eth-switch rpmsg-kdrv-2-mpu_1_0_ethmac-device-8: FW ver 0.2 (rev 0) 29/Jun/2023 SHA:
[2023-07-06 12:35:25]  [    4.878290] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac7: rpmsg attach_ext - rx_mtu:1522 features:00000007 tx_mtu[0]:2024 flow_idx:114 tx_cpsw_psil_dst_id:51712 mac_addr:70:ff:76:00:2f:f0 mac-only:7
[2023-07-06 12:35:25]  [    4.898029] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac7: virt_cpsw_nuss mac loaded
[2023-07-06 12:35:25]  [    4.898035] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac7: rdev_features:00000007 rdev_mtu:1522 flow_id:114 tx_psil_dst_id:4A00 mac_only:7
[2023-07-06 12:35:25]  [    4.898039] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac7: local_mac_addr:00:00:00:00:00:00 rdev_mac_addr:70:ff:76:00:2f:f0
[2023-07-06 12:35:25]  [    4.898600] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac8: rpmsg attach_ext - rx_mtu:1522 features:00000007 tx_mtu[0]:2024 flow_idx:115 tx_cpsw_psil_dst_id:51713 mac_addr:70:ff:76:00:3a:1e mac-only:8
[2023-07-06 12:35:25]  [    4.918724] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac8: virt_cpsw_nuss mac loaded
[2023-07-06 12:35:25]  [    4.918730] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac8: rdev_features:00000007 rdev_mtu:1522 flow_id:115 tx_psil_dst_id:4A01 mac_only:8
[2023-07-06 12:35:25]  [    4.918734] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac8: local_mac_addr:00:00:00:00:00:00 rdev_mac_addr:70:ff:76:00:3a:1e
[2023-07-06 12:35:25]  [    5.009360] virtio_rpmsg_bus virtio5: creating channel ti.ipc4.ping-pong addr 0xe
[2023-07-06 12:35:25]  [    5.713456] NFSD: Using /var/lib/nfs/v4recovery as the NFSv4 state recovery directory
[2023-07-06 12:35:25]  [    5.713476] NFSD: Using legacy client tracking operations.
[2023-07-06 12:35:25]  [    5.713480] NFSD: starting 90-second grace period (net f0000081)
[2023-07-06 12:35:26]  [    6.641204] random: crng init done
[2023-07-06 12:35:26]  [   24.965867] PVR_K:  823: Read BVNC 36.53.104.796 from HW device registers
[2023-07-06 12:35:26]  [   24.965878] PVR_K:  823: RGX Device registered BVNC 36.53.104.796 with 1 core in the system
[2023-07-06 12:35:26]  [   24.966172] [drm] Initialized pvr 1.15.6133109 20170530 for 4e20000000.gpu on minor 0
[2023-07-06 12:35:26]  [   24.987385] PVR_K:  832: RGX Firmware image 'rgx.fw.36.53.104.796' loaded
[2023-07-06 12:35:26]  [   24.988543] PVR_K:  832: Shader binary image 'rgx.sh.36.53.104.796' loaded
[2023-07-06 12:35:26]  [   25.489017] PVR_K:(Error):   832: PollForValueKM: Timeout. Expected 0x1 but found 0x0 (mask 0xffffffff). [2927]
[2023-07-06 12:35:26]  [   25.499097] PVR_K:(Error):   832: PVRSRVPollForValueKM: Failed! Error(PVRSRV_ERROR_TIMEOUT) CPU linear address(00000000248746de) Expected value(1) [2954]
[2023-07-06 12:35:26]  [   25.512807] PVR_K:  832: ------------[ PVR DBG: START (High) ]------------
[2023-07-06 12:35:26]  [   25.512812] PVR_K:  832: OS kernel info: Linux 5.10.162-g76b3e88d56 #1 SMP PREEMPT Thu Jun 29 17:26:47 CST 2023 aarch64
[2023-07-06 12:35:26]  [   25.512815] PVR_K:  832: DDK info: Rogue_DDK_Linux_WS rogueddk 1.15@6133109 (release) j784s4_linux
[2023-07-06 12:35:26]  [   25.512819] PVR_K:  832: Time now: 25512817us
[2023-07-06 12:35:26]  [   25.512821] PVR_K:  832: Services State: OK
[2023-07-06 12:35:26]  [   25.512824] PVR_K:  832: Server Errors: 2
[2023-07-06 12:35:26]  [   25.512828] PVR_K:  832: Connections: No Devices: No active connections
[2023-07-06 12:35:26]  [   25.512830] PVR_K:  832: ------[ Driver Info ]------
[2023-07-06 12:35:26]  [   25.512833] PVR_K:  832: Comparison of UM/KM components: MATCHING
[2023-07-06 12:35:26]  [   25.512836] PVR_K:  832: KM Arch: 32 Bit
[2023-07-06 12:35:26]  [   25.512840] PVR_K:  832: UM info: 0.0 @        0 (debug) build options: 0x00000000
[2023-07-06 12:35:26]  [   25.512844] PVR_K:  832: KM info: 0.0 @        0 (debug) build options: 0x00000000
[2023-07-06 12:35:26]  [   25.512846] PVR_K:  832: Window system: wayland
[2023-07-06 12:35:26]  [   25.512852] PVR_K:  832: ------[ RGX Device ID:0 Start ]------
[2023-07-06 12:35:27]  [   25.512855] PVR_K:  832: ------[ RGX Info ]------
[2023-07-06 12:35:27]  [   25.512858] PVR_K:  832: Device Node (Info): 00000000288ea223 (000000006aec0e3a)
[2023-07-06 12:35:27]  [   25.512861] PVR_K:  832: RGX BVNC: 36.53.104.796 (rogue)
[2023-07-06 12:35:27]  [   25.512864] PVR_K:  832: RGX Device State: Initialising
[2023-07-06 12:35:27]  [   25.512867] PVR_K:  832: RGX Power State: OFF
[2023-07-06 12:35:27]  [   25.512870] PVR_K:  832: FW info: UNINITIALIZED
[2023-07-06 12:35:27]  [   25.512876] PVR_K:  832: RGX FW State: OK (HWRState 0x00000000:)
[2023-07-06 12:35:27]  [   25.512881] PVR_K:  832: RGX FW Power State: RGXFWIF_POW_OFF (APM disabled: 0 ok, 0 denied, 0 non-idle, 0 retry, 0 other, 0 total. Latency: 100 ms)
[2023-07-06 12:35:27]  [   25.512888] PVR_K:  832: RGX DVFS: 0 frequency changes. Current frequency: 800.000 MHz (sampled at 24987713730 ns). FW frequency: 800.000 MHz.
[2023-07-06 12:35:27]  [   25.512892] PVR_K:  832: RGX FW OS 0 - State: offline; Freelists: Not Ok; Priority: 0; MTS on;
[2023-07-06 12:35:27]  [   25.512909] PVR_K:  832: Number of HWR: GP(0/0+0), 2D(0/0+0), TA(0/0+0), 3D(0/0+0), CDM(0/0+0), RAY(0/0+0), FALSE(0,0,0,0,0,0)
[2023-07-06 12:35:27]  [   25.512913] PVR_K:  832: DM 0 (GP)
[2023-07-06 12:35:27]  [   25.512922] PVR_K:  832: DM 1 (HWRflags 0x00000000: working;)
[2023-07-06 12:35:27]  [   25.512928] PVR_K:  832: DM 2 (HWRflags 0x00000000: working;)
[2023-07-06 12:35:27]  [   25.512933] PVR_K:  832: DM 3 (HWRflags 0x00000000: working;)
[2023-07-06 12:35:27]  [   25.512939] PVR_K:  832: DM 4 (HWRflags 0x00000000: working;)
[2023-07-06 12:35:27]  [   25.512945] PVR_K:  832: DM 5 (HWRflags 0x00000000: working;)
[2023-07-06 12:35:27]  [   25.512951] PVR_K:  832: RGX Kernel CCB WO:0x0 RO:0x0
[2023-07-06 12:35:27]  [   25.512955] PVR_K:  832: RGX Firmware CCB WO:0x0 RO:0x0
[2023-07-06 12:35:27]  [   25.512957] PVR_K:  832: RGX Kernel CCB commands executed = 0
[2023-07-06 12:35:27]  [   25.512960] PVR_K:  832: RGX SLR: Forced UFO updates requested = 0
[2023-07-06 12:35:27]  [   25.512963] PVR_K:  832: RGX Errors: WGP:0, TRP:0
[2023-07-06 12:35:28]  [   25.512969] PVR_K:  832: FW System config flags = 0x00020000 (Ctx switch options: Medium CSW profile; VDM CS INDEX mode;)
[2023-07-06 12:35:28]  [   25.512974] PVR_K:  832: FW OS config flags = 0x0000000F (Ctx switch: TDM; TA; 3D; CDM;)
[2023-07-06 12:35:28]  [   25.512976] PVR_K:  832:  (!) RGX power is down. No registers dumped
[2023-07-06 12:35:28]  [   25.512979] PVR_K:  832: ------[ RGX FW Trace Info ]------
[2023-07-06 12:35:28]  [   25.512982] PVR_K:  832: Debug log type: none
[2023-07-06 12:35:28]  [   25.512986] PVR_K:  832: RGX FW thread 0: Trace buffer not yet allocated
[2023-07-06 12:35:28]  [   25.512988] PVR_K:  832: ------[ Full CCB Status ]------
[2023-07-06 12:35:28]  [   25.512994] PVR_K:  832: ------[ RGX Device ID:0 End ]------
[2023-07-06 12:35:28]  [   25.512997] PVR_K:  832: ------[ System Summary Device ID:0 ]------
[2023-07-06 12:35:28]  [   25.513000] PVR_K:  832: Device System Power State: ON
[2023-07-06 12:35:28]  [   25.513003] PVR_K:  832: MaxHWTOut: 500000us, WtTryCt: 10000, WDGTOut(on,off): (10000ms,3600000ms)
[2023-07-06 12:35:28]  [   25.513007] PVR_K:  832: ------[ Server Thread Summary ]------
[2023-07-06 12:35:28]  [   25.513010] PVR_K:  832:   pvr_defer_free : Running
[2023-07-06 12:35:28]  [   25.513013] PVR_K:  832:     Number of deferred cleanup items : 0
[2023-07-06 12:35:28]  [   25.513016] PVR_K:  832:   pvr_device_wdg : Running
[2023-07-06 12:35:28]  [   25.513019] PVR_K:  832:   pvr_cacheop : Running
[2023-07-06 12:35:28]  [   25.513023] PVR_K:  832:     Configuration: QSZ: 16, UKT: -1, KDFT: 131072, LINESIZE: 64, PGSIZE: 4096, KDF: Yes, URBF: Yes
[2023-07-06 12:35:28]  [   25.513026] PVR_K:  832:     Pending deferred CacheOp entries : 0
[2023-07-06 12:35:28]  [   25.513030] PVR_K:  832: ------[ AppHint Settings ]------
[2023-07-06 12:35:28]  [   25.513033] PVR_K:  832:   Build Vars
[2023-07-06 12:35:28]  [   25.513037] PVR_K:  832:     EnableTrustedDeviceAceConfig: N
[2023-07-06 12:35:28]  [   25.513040] PVR_K:  832:     CleanupThreadPriority: 0x00000005
[2023-07-06 12:35:28]  [   25.513043] PVR_K:  832:     CacheOpThreadPriority: 0x00000001
[2023-07-06 12:35:29]  [   25.513047] PVR_K:  832:     WatchdogThreadPriority: 0x00000000
[2023-07-06 12:35:29]  [   25.513049] PVR_K:  832:     HWPerfClientBufferSize: 0x000c0000
[2023-07-06 12:35:29]  [   25.513052] PVR_K:  832:   Module Params
[2023-07-06 12:35:29]  [   25.513061] PVR_K:  832:     none
[2023-07-06 12:35:29]  [   25.513064] PVR_K:  832:   Debug Info Params
[2023-07-06 12:35:29]  [   25.513069] PVR_K:  832:     CacheOpConfig: 0x0000000c
[2023-07-06 12:35:29]  [   25.513072] PVR_K:  832:     CacheOpUMKMThresholdSize: 0xffffffff
[2023-07-06 12:35:29]  [   25.513075] PVR_K:  832:   Debug Info Params Device ID: 0
[2023-07-06 12:35:29]  [   25.513081] PVR_K:  832:     none
[2023-07-06 12:35:29]  [   25.513085] PVR_K:  832: ------[ HTB Log state: Off ]------
[2023-07-06 12:35:29]  [   25.513089] PVR_K:  832: ------[ Active Sync Checkpoints ]------
[2023-07-06 12:35:29]  [   25.513092] ------[ Native Fence Sync: timelines ]------
[2023-07-06 12:35:29]  [   25.518395] foreign_sync: @0 ctx=1 refs=1
[2023-07-06 12:35:29]  [   25.522394] PVR_K:  832: ------------[ PVR DBG: END ]------------
[2023-07-06 12:35:29]  [   25.522427] ------------[ cut here ]------------
[2023-07-06 12:35:29]  [   25.522483] WARNING: CPU: 4 PID: 832 at /data/jenkins/workspace/AutoElec-cci-Pipeline/kernel_tda4vh_v8.6.0/linux/extra-drivers/ti-img-rogue-driver-1.15.6133109/binary_j784s4_linux_wayland_release/target_aarch64/kbuild/services/server/common/pvr_notifier.c:529 PVRSRVDebugRequest+0x4a8/0x618 [pvrsrvkm]
[2023-07-06 12:35:29]  [   25.522486] Modules linked in: pvrsrvkm(O) remote_service(O) ti_k3_r5_remoteproc ti_k3_dsp_remoteproc shared_memory(O) dma_engine(O) GTC(O)
[2023-07-06 12:35:29]  [   25.522508] CPU: 4 PID: 832 Comm: gpu_Test Tainted: G           O      5.10.162-g76b3e88d56 #1
[2023-07-06 12:35:29]  [   25.522510] Hardware name: HIKAUTO AE-B50038-M (DT)
[2023-07-06 12:35:29]  [   25.522514] pstate: 80000005 (Nzcv daif -PAN -UAO -TCO BTYPE=--)
[2023-07-06 12:35:29]  [   25.522546] pc : PVRSRVDebugRequest+0x4a8/0x618 [pvrsrvkm]
[2023-07-06 12:35:29]  [   25.522577] lr : PVRSRVDebugRequest+0x4a8/0x618 [pvrsrvkm]
[2023-07-06 12:35:30]  [   25.522579] sp : ffff8000126fb7d0
[2023-07-06 12:35:30]  [   25.522582] x29: ffff8000126fb7d0 x28: ffff800008bbf000
[2023-07-06 12:35:30]  [   25.522587] x27: 0000000000000000 x26: ffff800008b7f898
[2023-07-06 12:35:30]  [   25.522592] x25: ffff00085d26b400 x24: 0000000000000009
[2023-07-06 12:35:30]  [   25.522596] x23: 0000000000000002 x22: 0000000000000000
[2023-07-06 12:35:30]  [   25.522601] x21: 0000000000000000 x20: ffff00085d26b4d8
[2023-07-06 12:35:30]  [   25.522605] x19: ffff00085c16a7a0 x18: 0000000000000000
[2023-07-06 12:35:30]  [   25.522609] x17: 0000000000000000 x16: 0000000000000000
[2023-07-06 12:35:30]  [   25.522614] x15: ffff00085bfe5700 x14: 0000000000000286
[2023-07-06 12:35:30]  [   25.522618] x13: ffff00085bfe5c30 x12: 00000000ffffffea
[2023-07-06 12:35:30]  [   25.522623] x11: ffff800011110928 x10: ffff8000110f88e8
[2023-07-06 12:35:30]  [   25.522627] x9 : ffff8000110f8940 x8 : 0000000000017fe8
[2023-07-06 12:35:30]  [   25.522632] x7 : c0000000ffffefff x6 : 0000000000000001
[2023-07-06 12:35:30]  [   25.522636] x5 : 0000000000000000 x4 : 0000000000000000
[2023-07-06 12:35:30]  [   25.522640] x3 : 0000000000000000 x2 : ffffffffffffff00
[2023-07-06 12:35:30]  [   25.522644] x1 : 0000000000000000 x0 : ffff00085c29d680
[2023-07-06 12:35:30]  [   25.522649] Call trace:
[2023-07-06 12:35:30]  [   25.522681]  PVRSRVDebugRequest+0x4a8/0x618 [pvrsrvkm]
[2023-07-06 12:35:30]  [   25.522713]  PVRSRVPollForValueKM+0x17c/0x180 [pvrsrvkm]
[2023-07-06 12:35:30]  [   25.522745]  RGXPostPowerState.part.0+0x78/0x138 [pvrsrvkm]
[2023-07-06 12:35:30]  [   25.522776]  RGXPostPowerState+0x20/0x38 [pvrsrvkm]
[2023-07-06 12:35:30]  [   25.522807]  PVRSRVSetDevicePowerStateKM+0x178/0x280 [pvrsrvkm]
[2023-07-06 12:35:30]  [   25.522837]  PVRSRVDeviceFinalise.part.0+0x94/0x340 [pvrsrvkm]
[2023-07-06 12:35:30]  [   25.522868]  PVRSRVCommonDeviceInitialise+0x94/0x330 [pvrsrvkm]
[2023-07-06 12:35:30]  [   25.522899]  PVRSRVDeviceOpen+0xac/0x170 [pvrsrvkm]
[2023-07-06 12:35:30]  [   25.522929]  pvr_drm_open+0x44/0x98 [pvrsrvkm]
[2023-07-06 12:35:30]  [   25.522941]  drm_file_alloc+0x148/0x230
[2023-07-06 12:35:30]  [   25.522944]  drm_open+0x14c/0x290
[2023-07-06 12:35:30]  [   25.522948]  drm_stub_open+0xa8/0x160
[2023-07-06 12:35:31]  [   25.522958]  chrdev_open+0xa4/0x1a0
[2023-07-06 12:35:31]  [   25.522964]  do_dentry_open+0x12c/0x398
[2023-07-06 12:35:31]  [   25.522970]  vfs_open+0x2c/0x38
[2023-07-06 12:35:31]  [   25.522975]  path_openat+0x818/0xca8
[2023-07-06 12:35:31]  [   25.522980]  do_filp_open+0x7c/0x100
[2023-07-06 12:35:31]  [   25.522986]  do_sys_openat2+0x210/0x2c8
[2023-07-06 12:35:31]  [   25.522990]  do_sys_open+0x58/0xa0
[2023-07-06 12:35:31]  [   25.522996]  __arm64_sys_openat+0x24/0x30
[2023-07-06 12:35:31]  [   25.523003]  el0_svc_common.constprop.0+0x78/0x1e0
[2023-07-06 12:35:31]  [   25.523008]  do_el0_svc+0x24/0x90
[2023-07-06 12:35:31]  [   25.523015]  el0_svc+0x14/0x20
[2023-07-06 12:35:31]  [   25.523021]  el0_sync_handler+0xb0/0xb8
[2023-07-06 12:35:31]  [   25.523027]  el0_sync+0x180/0x1c0
[2023-07-06 12:35:31]  [   25.523032] ---[ end trace beb8cadb70ccfba0 ]---
[2023-07-06 12:35:31]  [   25.523039] PVR_K:(Error):   832: RGXPostPowerState: Polling for 'FW started' flag failed. [1003]
[2023-07-06 12:35:31]  [   25.531897] PVR_K:  832: BIF0 - OK
[2023-07-06 12:35:31]  [   25.531901] PVR_K:  832: BIF1 - OK
[2023-07-06 12:35:31]  [   25.531904] PVR_K:  832: FWCORE - OK
[2023-07-06 12:35:31]  [   25.531908] PVR_K:  832: RGX FW State: OK (HWRState 0x00000000:)
[2023-07-06 12:35:31]  [   25.531912] PVR_K:  832: RGX FW Power State: RGXFWIF_POW_OFF (APM disabled: 0 ok, 0 denied, 0 non-idle, 0 retry, 0 other, 0 total. Latency: 100 ms)
[2023-07-06 12:35:31]  [   25.531919] PVR_K:  832: RGX DVFS: 0 frequency changes. Current frequency: 800.000 MHz (sampled at 24987713730 ns). FW frequency: 800.000 MHz.
[2023-07-06 12:35:31]  [   25.531923] PVR_K:  832: RGX FW OS 0 - State: offline; Freelists: Not Ok; Priority: 0; MTS on;
[2023-07-06 12:35:31]  [   25.531937] PVR_K:  832: Number of HWR: GP(0/0+0), 2D(0/0+0), TA(0/0+0), 3D(0/0+0), CDM(0/0+0), RAY(0/0+0), FALSE(0,0,0,0,0,0)
[2023-07-06 12:35:31]  [   25.531940] PVR_K:  832: DM 0 (GP)
[2023-07-06 12:35:31]  [   25.531948] PVR_K:  832: DM 1 (HWRflags 0x00000000: working;)
[2023-07-06 12:35:31]  [   25.531954] PVR_K:  832: DM 2 (HWRflags 0x00000000: working;)
[2023-07-06 12:35:31]  [   25.531959] PVR_K:  832: DM 3 (HWRflags 0x00000000: working;)
[2023-07-06 12:35:32]  [   25.531965] PVR_K:  832: DM 4 (HWRflags 0x00000000: working;)
[2023-07-06 12:35:32]  [   25.531970] PVR_K:  832: DM 5 (HWRflags 0x00000000: working;)
[2023-07-06 12:35:32]  [   25.531976] PVR_K:  832: ------[ RGX registers ]------
[2023-07-06 12:35:32]  [   25.531979] PVR_K:  832: RGX Register Base Address (Linear):   0x00000000b581efe5
[2023-07-06 12:35:32]  [   25.531982] PVR_K:  832: RGX Register Base Address (Physical): 0x4E20000000
[2023-07-06 12:35:32]  [   25.531986] PVR_K:  832: CORE_ID                       : 0x0000000008470000
[2023-07-06 12:35:32]  [   25.531990] PVR_K:  832: CORE_REVISION                 : 0x0068031C
[2023-07-06 12:35:32]  [   25.531992] PVR_K:  832: DESIGNER_REV_FIELD1           : 0x00000000
[2023-07-06 12:35:32]  [   25.531995] PVR_K:  832: DESIGNER_REV_FIELD2           : 0x00000000
[2023-07-06 12:35:32]  [   25.531999] PVR_K:  832: CHANGESET_NUMBER              : 0x0000000000000000
[2023-07-06 12:35:32]  [   25.532002] PVR_K:  832: MULTICORE_SYSTEM              : 0x00000001
[2023-07-06 12:35:32]  [   25.532005] PVR_K:  832: MULTICORE_GPU                 : 0x00000078
[2023-07-06 12:35:32]  [   25.532009] PVR_K:  832: CLK_CTRL                      : 0x002aaa002a22aaaa
[2023-07-06 12:35:32]  [   25.532012] PVR_K:  832: CLK_STATUS                    : 0x0000000000600000
[2023-07-06 12:35:32]  [   25.532016] PVR_K:  832: CLK_CTRL2                     : 0x0000000000000000
[2023-07-06 12:35:32]  [   25.532019] PVR_K:  832: CLK_STATUS2                   : 0x0000000000000000
[2023-07-06 12:35:32]  [   25.532022] PVR_K:  832: EVENT_STATUS                  : 0x00000000
[2023-07-06 12:35:32]  [   25.532025] PVR_K:  832: TIMER                         : 0x00000000001b017d
[2023-07-06 12:35:32]  [   25.532029] PVR_K:  832: BIF_FAULT_BANK0_MMU_STATUS    : 0x00000000
[2023-07-06 12:35:32]  [   25.532032] PVR_K:  832: BIF_FAULT_BANK0_REQ_STATUS    : 0x0000000000000000
[2023-07-06 12:35:32]  [   25.532035] PVR_K:  832: BIF_FAULT_BANK1_MMU_STATUS    : 0x00000000
[2023-07-06 12:35:32]  [   25.532038] PVR_K:  832: BIF_FAULT_BANK1_REQ_STATUS    : 0x0000000000000000
[2023-07-06 12:35:33]  [   25.532042] PVR_K:  832: BIF_MMU_STATUS                : 0x00000000
[2023-07-06 12:35:33]  [   25.532045] PVR_K:  832: BIF_MMU_ENTRY                 : 0x00000000
[2023-07-06 12:35:33]  [   25.532048] PVR_K:  832: BIF_MMU_ENTRY_STATUS          : 0x0000000000000000
[2023-07-06 12:35:33]  [   25.532052] PVR_K:  832: BIF_STATUS_MMU                : 0x00000000
[2023-07-06 12:35:33]  [   25.532055] PVR_K:  832: BIF_READS_EXT_STATUS          : 0x00000000
[2023-07-06 12:35:33]  [   25.532058] PVR_K:  832: BIF_READS_INT_STATUS          : 0x00000000
[2023-07-06 12:35:33]  [   25.532061] PVR_K:  832: BIFPM_STATUS_MMU              : 0x00000000
[2023-07-06 12:35:33]  [   25.532064] PVR_K:  832: BIFPM_READS_EXT_STATUS        : 0x00000000
[2023-07-06 12:35:33]  [   25.532067] PVR_K:  832: BIFPM_READS_INT_STATUS        : 0x00000000
[2023-07-06 12:35:33]  [   25.532071] PVR_K:  832: BIF_CAT_BASE_INDEX            : 0x0000000000000000
[2023-07-06 12:35:33]  [   25.532074] PVR_K:  832: BIF_CAT_BASE0                 : 0x00000008dc2bf000
[2023-07-06 12:35:33]  [   25.532078] PVR_K:  832: BIF_CAT_BASE1                 : 0x0000000000000000
[2023-07-06 12:35:33]  [   25.532081] PVR_K:  832: BIF_CAT_BASE2                 : 0x0000000000000000
[2023-07-06 12:35:33]  [   25.532085] PVR_K:  832: BIF_CAT_BASE3                 : 0x0000000000000000
[2023-07-06 12:35:33]  [   25.532088] PVR_K:  832: BIF_CAT_BASE4                 : 0x0000000000000000
[2023-07-06 12:35:33]  [   25.532091] PVR_K:  832: BIF_CAT_BASE5                 : 0x0000000000000000
[2023-07-06 12:35:33]  [   25.532095] PVR_K:  832: BIF_CAT_BASE6                 : 0x0000000000000000
[2023-07-06 12:35:33]  [   25.532098] PVR_K:  832: BIF_CAT_BASE7                 : 0x0000000000000000
[2023-07-06 12:35:33]  [   25.532102] PVR_K:  832: BIF_CTRL_INVAL                : 0x00000000
[2023-07-06 12:35:33]  [   25.532105] PVR_K:  832: BIF_CTRL                      : 0x00000000
[2023-07-06 12:35:33]  [   25.532108] PVR_K:  832: BIF_PM_CAT_BASE_VCE0          : 0x0000000000000000
[2023-07-06 12:35:33]  [   25.532111] PVR_K:  832: BIF_PM_CAT_BASE_TE0           : 0x0000000000000000
[2023-07-06 12:35:34]  [   25.532115] PVR_K:  832: BIF_PM_CAT_BASE_ALIST0        : 0x0000000000000000
[2023-07-06 12:35:34]  [   25.532118] PVR_K:  832: BIF_PM_CAT_BASE_VCE1          : 0x0000000000000000
[2023-07-06 12:35:34]  [   25.532122] PVR_K:  832: BIF_PM_CAT_BASE_TE1           : 0x0000000000000000
[2023-07-06 12:35:34]  [   25.532125] PVR_K:  832: BIF_PM_CAT_BASE_ALIST1        : 0x0000000000000000
[2023-07-06 12:35:34]  [   25.532128] PVR_K:  832: MULTICORE_GEOMETRY_CTRL_COMMON: 0x00000000
[2023-07-06 12:35:34]  [   25.532131] PVR_K:  832: MULTICORE_FRAGMENT_CTRL_COMMON: 0x00000101
[2023-07-06 12:35:34]  [   25.532134] PVR_K:  832: MULTICORE_COMPUTE_CTRL_COMMON : 0x00000101
[2023-07-06 12:35:34]  [   25.532137] PVR_K:  832: PERF_TA_PHASE                 : 0x00000000
[2023-07-06 12:35:34]  [   25.532140] PVR_K:  832: PERF_TA_CYCLE                 : 0x00000000
[2023-07-06 12:35:34]  [   25.532143] PVR_K:  832: PERF_3D_PHASE                 : 0x00000000
[2023-07-06 12:35:34]  [   25.532146] PVR_K:  832: PERF_3D_CYCLE                 : 0x00000000
[2023-07-06 12:35:34]  [   25.532150] PVR_K:  832: PERF_TA_OR_3D_CYCLE           : 0x00000000
[2023-07-06 12:35:34]  [   25.532153] PVR_K:  832: PERF_TA_AND_3D_CYCLE          : 0x00000000
[2023-07-06 12:35:34]  [   25.532155] PVR_K:  832: PERF_COMPUTE_PHASE            : 0x00000000
[2023-07-06 12:35:34]  [   25.532159] PVR_K:  832: PERF_COMPUTE_CYCLE            : 0x00000000
[2023-07-06 12:35:34]  [   25.532161] PVR_K:  832: PM_PARTIAL_RENDER_ENABLE      : 0x00000000
[2023-07-06 12:35:34]  [   25.532164] PVR_K:  832: ISP_RENDER                    : 0x00000000
[2023-07-06 12:35:34]  [   25.532167] PVR_K:  832: TLA_STATUS                    : 0x0000000000000000
[2023-07-06 12:35:34]  [   25.532171] PVR_K:  832: MCU_FENCE                     : 0x0000000000000000
[2023-07-06 12:35:34]  [   25.532173] PVR_K:  832: VDM_CONTEXT_STORE_STATUS      : 0x00000001
[2023-07-06 12:35:34]  [   25.532177] PVR_K:  832: VDM_CONTEXT_STORE_TASK0       : 0x0000000000000000
[2023-07-06 12:35:35]  [   25.532180] PVR_K:  832: VDM_CONTEXT_STORE_TASK1       : 0x0000000000000000
[2023-07-06 12:35:35]  [   25.532183] PVR_K:  832: VDM_CONTEXT_STORE_TASK2       : 0x0000000000000000
[2023-07-06 12:35:35]  [   25.532187] PVR_K:  832: VDM_CONTEXT_RESUME_TASK0      : 0x0000000000000000
[2023-07-06 12:35:35]  [   25.532190] PVR_K:  832: VDM_CONTEXT_RESUME_TASK1      : 0x0000000000000000
[2023-07-06 12:35:35]  [   25.532193] PVR_K:  832: VDM_CONTEXT_RESUME_TASK2      : 0x0000000000000000
[2023-07-06 12:35:35]  [   25.532196] PVR_K:  832: ISP_CTL                       : 0x00000000
[2023-07-06 12:35:35]  [   25.532199] PVR_K:  832: ISP_STATUS                    : 0x00000000
[2023-07-06 12:35:35]  [   25.532202] PVR_K:  832: MTS_INTCTX                    : 0x00000000
[2023-07-06 12:35:35]  [   25.532205] PVR_K:  832: MTS_BGCTX                     : 0x00000000
[2023-07-06 12:35:35]  [   25.532208] PVR_K:  832: MTS_BGCTX_COUNTED_SCHEDULE    : 0x00000000
[2023-07-06 12:35:35]  [   25.532211] PVR_K:  832: MTS_SCHEDULE                  : 0x00000000
[2023-07-06 12:35:35]  [   25.532214] PVR_K:  832: MTS_GPU_INT_STATUS            : 0x00000000
[2023-07-06 12:35:35]  [   25.532217] PVR_K:  832: CDM_CONTEXT_STORE_STATUS      : 0x00000000
[2023-07-06 12:35:35]  [   25.532220] PVR_K:  832: CDM_CONTEXT_PDS0              : 0x0000000000000000
[2023-07-06 12:35:35]  [   25.532224] PVR_K:  832: CDM_CONTEXT_PDS1              : 0x0000000000000000
[2023-07-06 12:35:35]  [   25.532227] PVR_K:  832: CDM_TERMINATE_PDS             : 0x0000000000000000
[2023-07-06 12:35:35]  [   25.532230] PVR_K:  832: CDM_TERMINATE_PDS1            : 0x0000000000000000
[2023-07-06 12:35:35]  [   25.532234] PVR_K:  832: CDM_CONTEXT_LOAD_PDS0         : 0x0000000000000000
[2023-07-06 12:35:35]  [   25.532237] PVR_K:  832: CDM_CONTEXT_LOAD_PDS1         : 0x0000000000000000
[2023-07-06 12:35:35]  [   25.532240] PVR_K:  832: SIDEKICK_IDLE                 : 0x0000007F
[2023-07-06 12:35:35]  [   25.532243] PVR_K:  832: SLC_IDLE                      : 0x000000FF
[2023-07-06 12:35:36]  [   25.532246] PVR_K:  832: SLC_STATUS0                   : 0x00000000
[2023-07-06 12:35:36]  [   25.532249] PVR_K:  832: SLC_STATUS1                   : 0x0000000000000000
[2023-07-06 12:35:36]  [   25.532253] PVR_K:  832: SLC_STATUS2                   : 0x0000000000000000
[2023-07-06 12:35:36]  [   25.532256] PVR_K:  832: SLC_CTRL_BYPASS               : 0x00000000
[2023-07-06 12:35:36]  [   25.532259] PVR_K:  832: SLC_CTRL_MISC                 : 0x0000000000200003
[2023-07-06 12:35:36]  [   25.532262] PVR_K:  832: SAFETY_EVENT_STATUS__ROGUEXE  : 0x00000000
[2023-07-06 12:35:36]  [   25.532265] PVR_K:  832: MTS_SAFETY_EVENT_ENABLE__ROGUEXE: 0x00000000
[2023-07-06 12:35:36]  [   25.532268] PVR_K:  832: FWCORE_WDT_CTRL               : 0x00000000
[2023-07-06 12:35:36]  [   25.532271] PVR_K:  832: SCRATCH0                      : 0x00000000
[2023-07-06 12:35:36]  [   25.532274] PVR_K:  832: SCRATCH1                      : 0x00000000
[2023-07-06 12:35:36]  [   25.532277] PVR_K:  832: SCRATCH2                      : 0x00000000
[2023-07-06 12:35:36]  [   25.532280] PVR_K:  832: SCRATCH3                      : 0x00000000
[2023-07-06 12:35:36]  [   25.532283] PVR_K:  832: SCRATCH4                      : 0x00000000
[2023-07-06 12:35:36]  [   25.532286] PVR_K:  832: SCRATCH5                      : 0x00000000
[2023-07-06 12:35:36]  [   25.532289] PVR_K:  832: SCRATCH6                      : 0x00000000
[2023-07-06 12:35:36]  [   25.532292] PVR_K:  832: SCRATCH7                      : 0x00000000
[2023-07-06 12:35:36]  [   25.532295] PVR_K:  832: SCRATCH8                      : 0x00000000
[2023-07-06 12:35:36]  [   25.532298] PVR_K:  832: SCRATCH9                      : 0x00000000
[2023-07-06 12:35:36]  [   25.532301] PVR_K:  832: SCRATCH10                     : 0x00000000
[2023-07-06 12:35:36]  [   25.532304] PVR_K:  832: SCRATCH11                     : 0x00000000
[2023-07-06 12:35:36]  [   25.532307] PVR_K:  832: SCRATCH12                     : 0x00000000
[2023-07-06 12:35:36]  [   25.532310] PVR_K:  832: SCRATCH13                     : 0x00000000
[2023-07-06 12:35:36]  [   25.532313] PVR_K:  832: SCRATCH14                     : 0x00000000
[2023-07-06 12:35:37]  [   25.532316] PVR_K:  832: SCRATCH15                     : 0x00000000
[2023-07-06 12:35:37]  [   25.532320] PVR_K:  832: FWCORE_MEM_CAT_BASE0          : 0x00000008dc2bf000
[2023-07-06 12:35:37]  [   25.532324] PVR_K:  832: FWCORE_MEM_CAT_BASE1          : 0x0000000000000000
[2023-07-06 12:35:37]  [   25.532327] PVR_K:  832: FWCORE_MEM_CAT_BASE2          : 0x0000000000000000
[2023-07-06 12:35:37]  [   25.532330] PVR_K:  832: FWCORE_MEM_CAT_BASE3          : 0x0000000000000000
[2023-07-06 12:35:37]  [   25.532333] PVR_K:  832: FWCORE_MEM_CAT_BASE4          : 0x0000000000000000
[2023-07-06 12:35:37]  [   25.532337] PVR_K:  832: FWCORE_MEM_CAT_BASE5          : 0x0000000000000000
[2023-07-06 12:35:37]  [   25.532340] PVR_K:  832: FWCORE_MEM_CAT_BASE6          : 0x0000000000000000
[2023-07-06 12:35:37]  [   25.532343] PVR_K:  832: FWCORE_MEM_CAT_BASE7          : 0x0000000000000000
[2023-07-06 12:35:37]  [   25.532346] PVR_K:  832: FWCORE_ADDR_REMAP_CONFIG4     : 0x120000e1c0002000
[2023-07-06 12:35:37]  [   25.532350] PVR_K:  832: FWCORE_ADDR_REMAP_CONFIG5     : 0x220000e1c001d000
[2023-07-06 12:35:37]  [   25.532353] PVR_K:  832: FWCORE_ADDR_REMAP_CONFIG6     : 0x220000e1c0000000
[2023-07-06 12:35:37]  [   25.532356] PVR_K:  832: FWCORE_ADDR_REMAP_CONFIG12    : 0x120000e1c0000000
[2023-07-06 12:35:37]  [   25.532360] PVR_K:  832: FWCORE_ADDR_REMAP_CONFIG13    : 0x220000e1c0000000
[2023-07-06 12:35:37]  [   25.532363] PVR_K:  832: FWCORE_ADDR_REMAP_CONFIG14    : 0x000000e1c0000000
[2023-07-06 12:35:37]  [   25.532366] PVR_K:  832: FWCORE_MEM_FAULT_MMU_STATUS   : 0x00000000
[2023-07-06 12:35:37]  [   25.532369] PVR_K:  832: FWCORE_MEM_FAULT_REQ_STATUS   : 0x0000000000000000
[2023-07-06 12:35:37]  [   25.532372] PVR_K:  832: FWCORE_MEM_MMU_STATUS         : 0x00000000
[2023-07-06 12:35:37]  [   25.532375] PVR_K:  832: FWCORE_MEM_READS_EXT_STATUS   : 0x00000000
[2023-07-06 12:35:37]  [   25.532378] PVR_K:  832: FWCORE_MEM_READS_INT_STATUS   : 0x00000000
[2023-07-06 12:35:37]  [   25.532380] PVR_K:  832: ---- [ RISC-V internal state ] ----
[2023-07-06 12:35:38]  [   25.532387] PVR_K:  832: pc                            : 0xC0001010
[2023-07-06 12:35:38]  [   25.532391] PVR_K:  832: ra                            : 0x40019ED8
[2023-07-06 12:35:38]  [   25.532395] PVR_K:  832: sp                            : 0x50001010
[2023-07-06 12:35:38]  [   25.532399] PVR_K:  832: mepc                          : 0x4001A034
[2023-07-06 12:35:38]  [   25.532403] PVR_K:  832: mcause                        : 0xF0000001
[2023-07-06 12:35:38]  [   25.532407] PVR_K:  832: mdseac                        : 0x00000004
[2023-07-06 12:35:38]  [   25.532411] PVR_K:  832: mstatus                       : 0x00001880
[2023-07-06 12:35:38]  [   25.532415] PVR_K:  832: mie                           : 0x40000888
[2023-07-06 12:35:38]  [   25.532419] PVR_K:  832: mip                           : 0x00000000
[2023-07-06 12:35:38]  [   25.532423] PVR_K:  832: mscratch                      : 0x00000080
[2023-07-06 12:35:38]  [   25.532427] PVR_K:  832: mbvnc0                        : 0x00010001
[2023-07-06 12:35:38]  [   25.532431] PVR_K:  832: mbvnc1                        : 0x0032000B
[2023-07-06 12:35:38]  [   25.532435] PVR_K:  832: micect                        : 0x10000000
[2023-07-06 12:35:38]  [   25.532439] PVR_K:  832: mdcect                        : 0x10000000
[2023-07-06 12:35:38]  [   25.532442] PVR_K:  832: mdcrfct                       : 0x10000000
[2023-07-06 12:35:38]  [   25.532447] PVR_K:  832: RISC-V FW hit an exception: Machine D-bus non-blocking load error NMI
[2023-07-06 12:35:38]  [   25.532627] PVR_K:  832: RGX Firmware image 'rgx.fw.36.53.104.796' loaded
[2023-07-06 12:35:38]  [   25.744492] PVR_K:  832: Match between Host and RISC-V view of the FW code
[2023-07-06 12:35:38]  [   25.744533] PVR_K:(Error):   832: PVRSRVDeviceFinalise: Failed to set device 00000000288ea223 power state to 'on' (PVRSRV_ERROR_TIMEOUT) [2774]
[2023-07-06 12:35:39]  [   25.757382] PVR_K:(Error):   832: PVRSRVDeviceFinalise() failed (PVRSRV_ERROR_TIMEOUT) in PVRSRVCommonDeviceInitialise() [2225]
[2023-07-06 12:35:39]  [   25.768839] PVR_K:(Error):   832: PVRSRVDeviceOpen: Failed to initialise device (PVRSRV_ERROR_TIMEOUT) [476]
[2023-07-06 12:35:39]  [   25.779365] PVR_K:(Error):   832: PVRSRVDeviceOpen: Driver already in bad state. Device open failed. [464]
[2023-07-06 12:35:39]  [   31.709222] vdd_mmc1: disabling
We found that the following threads encountered the same problem as ours on e2e:TDA4VE-Q1: TDA4 ECO PVR issue - Processors forum - Processors - TI E2E support forums
I followed your suggestion to manually loaded the GPU driver, but I still encountered the above problem
If experts have any ideas, please help provide some. Thank you very much!
Best regards !
Alex
  • Hello Alex,
    We have a known issue with the GPU driver that might be affecting you here.
    I want to first check that you have the default Linux setup, kernel, etc. Or have you made some changes for your custom board?
    How are you booting, SBL or SPL (U-boot)?
    The patch for the GPU driver has been tested on J721S2, let me test with J784S4 to ensure it will still work for you here.
    Erick
  • Hello Alex,
    There is a patch that comes by default that helps with the GPU related issue I was telling you about. There should not be any issue with simply inserting the driver.
    It looks like a power issue, the driver seems to try to connect to the hardware but finds some discrepancies in the registers. These can sometimes be due to hardware related issues, is there a way you can increase the supply voltage of the GPU?
    Erick
  • HI Erick
    Thank you for your reply. For your question, I will answer it below
    1 Q: I want to first check that you have the default Linux setup, kernel, etc.
       A: Are you talking about kernel config? If it is config, we have made changes on the original basis. But for GPU, there should be no changes.
    2 Q: have you made some changes for your custom board?
       A: There are no changes on the custom board.
    3 Q: How are you booting, SBL or SPL (U-boot)?
       A: SPL
    4 Q: It looks like a power issue, the driver seems to try to connect to the hardware but finds some discrepancies in the registers. These can sometimes be due to hardware related issues, is there a way you can increase the supply voltage of the GPU?
       A: We measured the power supply voltage at the TDA4VH chip particles using a multimeter, and all voltages were normal, meeting the requirements of the chip specification.
           VDD_DDR_1V1 1.104V
           VDD_RAM_0V85 0.852V
           VDD_IO_1V8 1.805V
           VDD_CORE_0V8 0.804V
           VDD_CPU_AVS 0.804V
           VDD_MCU_0V85 0.853V
           VDD_MCUIO_3V3 3.3V
           VDA_DLL_0V8 0.802V
           VDA_MCU_1V8 1.803V
           VDA_PLL_1V8 1.815V
           VDA_PHY_1V8 1.829V
          We use an oscilloscope to measure the ripple and noise of the Core power supply, both of which are within 3% and meet the chip requirements.
          During the reboot process, the voltage and ripple of the Core power supply were measured, and no abnormalities or exceeding the chip requirements were found.
    We have provided the above answers to your question,In addition, we have another question: In terms of hardware design, the core power supply of each core is the same VDD_CORE_0V8 power supply, and there are no issues with other cores, only GPU core have issues; Is there any difference in the power supply of the GPU core inside the chip?
    Finally, you said  "There is a patch that comes by default that helps with the GPU related issue I was telling you about.". Could you please provide this patch. I also want to test based on this patch.
    Best regards !
    Alex
  • Alex,
    In SDK 8.6, this patch already comes with our GPU Kernel driver:
    ti-processor-sdk-linux-j784s4-evm-08_06_00_12/board-support/extra-drivers/ti-img-rogue-driver-1.15.6133109
    commit c901804e8221d477983a6f7224a9cdc6e832f050
    Author: Randolph Sapp <rs@ti.com>
    Date:   Fri Oct 21 12:58:50 2022 -0500
        HACK: server: Make CCB allocations incoherent
    This patch should prevent a known bug. But the reproduceability of your issue does not indicate it is related to the known bug since it only sometimes replicates. I've forwarded the logs to our developers for further debug steps we can take.
    Erick
  • Alex,
    Can you please gather initial GPU driver information as detailed here:
    https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1218307/faq-how-can-i-analyze-a-gpu-graphics-process-unit-driver-or-hardware-issue
    See the section called PVR Debug Dump. Disable the auto-loading of the GPU driver and gather logs and send over a "pvrlogdump" after seeing the issue.
    Erick
  • Alex,
    I have some updated GPU driver libraries to help gather more information about your issue. Can you please replace the ones in your filesystem with these I've attached?
    tisdk-1.15.6133109-debug.tar.gz
    Then, boot your board and try to reproduce the issue, and if you are able to reproduce the issue, please share the logs you get on the console.
    If the system is still usable after the issue is experienced, please also run "pvrlogdump" and share the output file of that too.
    Erick
  • HI Erick
    Thank you for your help
    I used the patch you provided and captured the logs, and the results are as follows
    Log during normal operation:
    U-Boot SPL 2021.01-svn475824 (Jun 29 2023 - 17:26:20 +0800)
    SYSFW ABI: 3.1 (firmware rev 0x0008 '8.6.3--v08.06.03 (Chill Capybar')
    SPL initial stack usage: 13472 bytes
    Trying to boot from SPI
    NOTICE:  BL31: v2.8(release):
    NOTICE:  BL31: Built : 17:25:53, Jun 29 2023
    I/TC:
    I/TC: OP-TEE version: 3.19.0 (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10))) #1 Sun Dec 18 12:03:06 UTC 2022 aarch64
    I/TC: WARNING: This OP-TEE configuration might be insecure!
    I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
    I/TC: Primary CPU initialI/TC: SYSFW ABI: 3.1 (firmware rev 0x0008 '8.6.3--v08.06.03 (Chill Capybar')
    I/TC: HUK Initialized
    I/TC: Activated SA2UL device
    I/TC: Fixing SA2UL firewall owner for GP device
    I/TC: Enabled firewalls for SA2UL TRNG device
    I/TC: SA2UL TRNG initialized
    I/TC: SA2UL Drivers initialized
    I/TC: Primary CPU switching to normal world boot
    U-Boot 2021.01-svn475824 (Jun 29 2023 - 17:26:02 +0800), Build: jenkins-AutoElec-cci-Pipeline-9559
    SoC:   J784S4 SR1.0 GP
    Model: HIKAUTO AE-B50038-M
    DRAM:  8 GiB
    Flash: 0 Bytes
    MMC:   mmc@4f80000: 0, mmc@4fb0000: 1
    In:    serial@2880000
    Out:   serial@2880000
    Err:   serial@2880000
    Net:   eth2: ethernet@c200000am65_cpsw_nuss_port ethernet@c200000port@1: can't parse phy-handle port 1 (-2)
    , eth0: ethernet@c200000port@1
    Hit ctr+u key to stop autoboot:  0
    k3_r5f_rproc r5f@41000000: Core 1 is already in use. No rproc commands work
    k3_r5f_rproc r5f@41400000: Core 2 is already in use. No rproc commands work
    [    0.000000] cma: Failed to reserve 144 MiB
    I/TC: Secondary CPU 1 initializing
    I/TC: Secondary CPU 1 switching to normal world boot
    I/TC: Secondary CPU 2 initializing
    I/TC: Secondary CPU 2 switching to normal world boot
    I/TC: Secondary CPU 3 initializing
    I/TC: Secondary CPU 3 switching to normal world boot
    I/TC: Secondary CPU 4 initializing
    I/TC: Secondary CPU 4 switching to normal world boot
    I/TC: Secondary CPU 5 initializing
    I/TC: Secondary CPU 5 switching to normal world boot
    exporting *:/ab/res
    exporting *:/ab/log
    exporting *:/hat-s/model
    exporting *:/ab/cfg
    exporting *:/ab/app
    exporting *:/ab/map
    exporting *:/hat/map
    exporting *:/hat/cfg
    exporting *:/hat/log
    exporting *:/hat[    1.653953] k3-dsp-rproc 64800000.dsp: configured DSP for IPC-only mode
    -s/app
    [12515]Prepare run initrun.sh
    [    1.661211] k3-dsp-rproc 64800000.dsp: DSP initialized in IPC-only mode
    [    1.672978] k3-dsp-rproc 65800000.dsp: configured DSP for IPC-only mode
    [    1.679796] k3-dsp-rproc 65800000.dsp: DSP initialized in IPC-only mode
    [    1.688285] k3-dsp-rproc 66800000.dsp: configured DSP for IPC-only mode
    [    1.695008] k3-dsp-rproc 66800000.dsp: DSP initialized in IPC-only mode
    [    1.703458] k3-dsp-rproc 67800000.dsp: configured DSP for IPC-only mode
    [    1.710180] k3-dsp-rproc 67800000.dsp: DSP initialized in IPC-only mode
    [    1.720720] platform 41000000.r5f: configured R5F for IPC-only mode
    [    1.727463] platform 41000000.r5f: R5F core initialized in IPC-only mode
    [    1.736032] platform 5c00000.r5f: configured R5F for IPC-only mode
    [    1.743195] platform 5c00000.r5f: R5F core initialized in IPC-only mode
    [    1.750906] platform 5d00000.r5f: configured R5F for IPC-only mode
    [    1.757632] platform 5d00000.r5f: R5F core initialized in IPC-only mode
    [    1.765825] platform 5e00000.r5f: configured R5F for IPC-only mode
    [    1.772447] platform 5e00000.r5f: R5F core initialized in IPC-only mode
    [    1.779535] platform 5f00000.r5f: configured R5F for IPC-only mode
    [    1.786142] platform 5f00000.r5f: R5F core initialized in IPC-only mode
    [    1.794689] platform 5900000.r5f: configured R5F for IPC-only mode
    [    1.801569] platform 5900000.r5f: R5F core initialized in IPC-only mode
    [    1.808843] platform 5a00000.r5f: configured R5F for IPC-only mode
    [    1.815483] platform 5a00000.r5f: R5F core initialized in IPC-only mode
    [    1.887812] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac8: rpmsg attach_ext - rx_mtu:1522 features:00000007 tx_mtu[0]:2024 flow_idx:114 tx_cpsw_psil_dst_id:51712 mac_addr:70:ff:76:00:ca:6b mac-only:8
    [    1.908091] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac7: rpmsg attach_ext - rx_mtu:1522 features:00000007 tx_mtu[0]:2024 flow_idx:115 tx_cpsw_psil_dst_id:51713 mac_addr:70:ff:76:00:c5:71 mac-only:7
    root@j7-evm:~# ldconfig: /hat/app/home/lib/liblzma.so.5 is not a symbolic link
    ----------------------- Start -----------------------
    Set FW Log type to TRACE ( main mts hwr )
    Connecting to first (0) default pvr device
    ------------------------ End ------------------------
    Support EGL_MESA_platform_surfaceless!
    EGL: version 1.4
    Create YUV Buffer begin 0
    MEM: Init ... !!!
    MEM: Initialized DMA HEAP (fd=9) !!!
    MEM: Init ... Done !!!
    MEM: Allocated virt addr = ffffb7afb000 -> phy addr = c1000000, size = 1843200 (FD's = 11 12) !!!
     eglCreateImageKHR: success!
    gen 1 tex 1
    MEM: Allocated virt addr = ffffb7777000 -> phy addr = c11c2000, size = 3686400 (FD's = 13 14) !!!
    gen 1 tex 2
    start
    ( 838) PVR:(Warning): Kicking TA to free up CBUF space [ rgxif.c:3621 ]
    fwrite
    ( 838) PVR:(Warning): GrowSparseBuffer SCBUF:VERTEX_DATA (1): Requested size increase (770052) greater than space available. Increase to allocation size (1638400, 400 pages) [ buffers.c:783 ]
    Display time: 3 ms
    Checking driver state ............... initialised
    Checking for debugfs ................ found
    Checking for lockdep ................ not found
    Checking for ftrace ................. not found
    Checking for firmware log groups .... found
    Dumping data ........................ done
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
    [    0.000000] Linux version 5.10.162-g76b3e88d56 (ci@CI-HZV-AUTOELEC-SLAVE-66-157) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT Thu Jun 29 17:26:47 CST 2023
    [    0.000000] Machine model: HIKAUTO AE-B50038-M
    [    0.000000] Malformed early option 'console'
    [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002880000 (options '')
    [    0.000000] printk: bootconsole [ns16550a0] enabled
    [    0.000000] Reserved memory: created DMA memory pool at 0x0000000088000000, size 176 MiB
    [    0.000000] OF: reserved mem: initialized node dsp-multicore-dma-memory@88000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x0000000093000000, size 16 MiB
    [    0.000000] OF: reserved mem: initialized node bsp-multicore-dma-memory@93000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x0000000094000000, size 168 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@94000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 47 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a6000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a6100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a7000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a7100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a8000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a8100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a9000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a9100000, size 31 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a9100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000ab000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@ab000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000ab100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@ab100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 48 MiB
    [    0.000000] OF: reserved mem: initialized node rtos-ipc-memory-region@ac000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000af000000, size 80 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@af000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000b4000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node c71-dma-memory@b4000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000b4100000, size 51 MiB
    [    0.000000] OF: reserved mem: initialized node c71_0-memory@b4100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000b7400000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node c71_1-dma-memory@b7400000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000b7500000, size 51 MiB
    [    0.000000] OF: reserved mem: initialized node c71_1-memory@b7500000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000ba800000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node c71_2-dma-memory@ba800000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000ba900000, size 51 MiB
    [    0.000000] OF: reserved mem: initialized node c71_2-memory@ba900000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000bdc00000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node c71_3-dma-memory@bdc00000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000bdd00000, size 51 MiB
    [    0.000000] OF: reserved mem: initialized node c71_3-memory@bdd00000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout
    [    0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 1330 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000008d4000000, size 64 MiB
    [    0.000000] OF: reserved mem: initialized node pcie-memory-region@8d4000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000008e0000000, size 512 MiB
    [    0.000000] OF: reserved mem: initialized node vpu-memory-region@8e0000000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: initialized node vision_apps_shared-memories_64, compatible id dma-heap-carveout
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000009b0000000, size 768 MiB
    [    0.000000] OF: reserved mem: initialized node ddr-high-shared-memory@9b0000000, compatible id shared-dma-pool
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   [mem 0x0000000100000000-0x00000009ffffffff]
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x0000000087ffffff]
    [    0.000000]   node   0: [mem 0x0000000088000000-0x000000009fffffff]
    [    0.000000]   node   0: [mem 0x00000000a0000000-0x00000000a0ffffff]
    [    0.000000]   node   0: [mem 0x00000000a1000000-0x00000000c0ffffff]
    [    0.000000]   node   0: [mem 0x00000000c1000000-0x00000000ffffffff]
    [    0.000000]   node   0: [mem 0x0000000880000000-0x00000008d31fffff]
    [    0.000000]   node   0: [mem 0x00000008d3200000-0x00000008d3ffffff]
    [    0.000000]   node   0: [mem 0x00000008d4000000-0x00000008d7ffffff]
    [    0.000000]   node   0: [mem 0x00000008d8000000-0x00000008dfffffff]
    [    0.000000]   node   0: [mem 0x00000008e0000000-0x00000008ffffffff]
    [    0.000000]   node   0: [mem 0x0000000900000000-0x00000009afffffff]
    [    0.000000]   node   0: [mem 0x00000009b0000000-0x00000009dfffffff]
    [    0.000000]   node   0: [mem 0x00000009e0000000-0x00000009ffffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000009ffffffff]
    [    0.000000] On node 0 totalpages: 2097152
    [    0.000000]   DMA zone: 8192 pages used for memmap
    [    0.000000]   DMA zone: 0 pages reserved
    [    0.000000]   DMA zone: 524288 pages, LIFO batch:63
    [    0.000000]   Normal zone: 24576 pages used for memmap
    [    0.000000]   Normal zone: 1572864 pages, LIFO batch:63
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.2
    [    0.000000] percpu: Embedded 22 pages/cpu s50136 r8192 d31784 u90112
    [    0.000000] pcpu-alloc: s50136 r8192 d31784 u90112 alloc=22*4096
    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7
    [    0.000000] Detected PIPT I-cache on CPU0
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] CPU features: detected: EL2 vector hardening
    [    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
    [    0.000000] CPU features: detected: Spectre-BHB
    [    0.000000] CPU features: detected: ARM erratum 1742098
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 2064384
    [    0.000000] Kernel command line: console= quiet uboot_version=v2.2.3 uboot_svnversion=475824 earlycon=ns16550a,mmio32,0x02880000 rproc_rsctable=41000000.r5f:0x8c@0xa2100000;5c00000.r5f:0x8c@0xa3100000;5d00000.r5f:0x8c@0xa6100000;5e00000.r5f:0x8c@0xa7100000;5f00000.r5f:0x8c@0xa8100000;5900000.r5f:0x8c@0xa9100000;5a00000.r5f:0x8c@0xab100000;64800000.dsp:0x98@0xb4100000;65800000.dsp:0x98@0xb7500000;66800000.dsp:0x98@0xba900000;67800000.dsp:0x98@0xbdd00000 bootxpart=main
    [    0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] software IO TLB: Cannot allocate buffer
    [    0.000000] Memory: 2465292K/8388608K available (10816K kernel code, 1168K rwdata, 4148K rodata, 1792K init, 432K bss, 5923316K reserved, 0K cma-reserved)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu:     RCU event tracing is enabled.
    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=8.
    [    0.000000]  Trampoline variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 960 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] GICv3: Distributor has no Range Selector support
    [    0.000000] GICv3: 16 PPIs implemented
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
    [    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @8d3c00000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x00000008d3450000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008d3460000
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.000224] Console: colour dummy device 80x25
    [    0.000261] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.000267] pid_max: default: 32768 minimum: 301
    [    0.000315] LSM: Security Framework initializing
    [    0.000372] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.000406] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.001398] rcu: Hierarchical SRCU implementation.
    [    0.001609] Platform MSI: msi-controller@1820000 domain created
    [    0.001722] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.001776] EFI services will not be available.
    [    0.001995] smp: Bringing up secondary CPUs ...
    [    0.010452] Detected PIPT I-cache on CPU1
    [    0.010475] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
    [    0.010487] GICv3: CPU1: using allocated LPI pending table @0x00000008d3470000
    [    0.010524] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
    [    0.018995] Detected PIPT I-cache on CPU2
    [    0.019010] GICv3: CPU2: found redistributor 2 region 0:0x0000000001940000
    [    0.019021] GICv3: CPU2: using allocated LPI pending table @0x00000008d3480000
    [    0.019049] CPU2: Booted secondary processor 0x0000000002 [0x411fd080]
    [    0.027496] Detected PIPT I-cache on CPU3
    [    0.027510] GICv3: CPU3: found redistributor 3 region 0:0x0000000001960000
    [    0.027522] GICv3: CPU3: using allocated LPI pending table @0x00000008d3490000
    [    0.027550] CPU3: Booted secondary processor 0x0000000003 [0x411fd080]
    [    0.036029] Detected PIPT I-cache on CPU4
    [    0.036054] GICv3: CPU4: found redistributor 100 region 0:0x0000000001980000
    [    0.036067] GICv3: CPU4: using allocated LPI pending table @0x00000008d34a0000
    [    0.036105] CPU4: Booted secondary processor 0x0000000100 [0x411fd080]
    [    0.044598] Detected PIPT I-cache on CPU5
    [    0.044616] GICv3: CPU5: found redistributor 101 region 0:0x00000000019a0000
    [    0.044628] GICv3: CPU5: using allocated LPI pending table @0x00000008d34b0000
    [    0.044656] CPU5: Booted secondary processor 0x0000000101 [0x411fd080]
    [    0.053122] Detected PIPT I-cache on CPU6
    [    0.053141] GICv3: CPU6: found redistributor 102 region 0:0x00000000019c0000
    [    0.053153] GICv3: CPU6: using allocated LPI pending table @0x00000008d34c0000
    [    0.053182] CPU6: Booted secondary processor 0x0000000102 [0x411fd080]
    [    0.061639] Detected PIPT I-cache on CPU7
    [    0.061660] GICv3: CPU7: found redistributor 103 region 0:0x00000000019e0000
    [    0.061671] GICv3: CPU7: using allocated LPI pending table @0x00000008d34d0000
    [    0.061700] CPU7: Booted secondary processor 0x0000000103 [0x411fd080]
    [    0.061765] smp: Brought up 1 node, 8 CPUs
    [    0.061774] SMP: Total of 8 processors activated.
    [    0.061778] CPU features: detected: 32-bit EL0 Support
    [    0.061781] CPU features: detected: CRC32 instructions
    [    0.073644] CPU: All CPU(s) started at EL2
    [    0.073671] alternatives: patching kernel code
    [    0.074263] devtmpfs: initialized
    [    0.079514] KASLR disabled due to lack of seed
    [    0.079624] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.079634] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
    [    0.079797] pinctrl core: initialized pinctrl subsystem
    [    0.080047] DMI not present or invalid.
    [    0.080359] NET: Registered protocol family 16
    [    0.080780] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
    [    0.080885] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.080980] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.081266] thermal_sys: Registered thermal governor 'step_wise'
    [    0.081268] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.081515] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.081618] ASID allocator initialised with 65536 entries
    [    0.095536] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.095541] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.095544] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.095547] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.096438] cryptd: max_cpu_qlen set to 1000
    [    0.098344] k3-chipinfo 43000014.chipid: Family:J784S4 rev:SR1.0 JTAGID[0x0bb8002f] Detected
    [    0.098614] vsys_3v3: supplied by evm_12v0
    [    0.098831] vsys_5v0: supplied by evm_12v0
    [    0.098983] vdd_mmc1: supplied by vsys_3v3
    [    0.099650] iommu: Default domain type: Translated
    [    0.099772] vgaarb: loaded
    [    0.099914] SCSI subsystem initialized
    [    0.100059] mc: Linux media interface: v0.10
    [    0.100072] videodev: Linux video capture interface: v2.00
    [    0.100101] pps_core: LinuxPPS API ver. 1 registered
    [    0.100104] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.100112] PTP clock support registered
    [    0.100133] EDAC MC: Ver: 3.0.0
    [    0.100727] FPGA manager framework
    [    0.101142] clocksource: Switched to clocksource arch_sys_counter
    [    0.101220] VFS: Disk quotas dquot_6.6.0
    [    0.101249] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.104102] Carveout Heap: Exported 1008 MiB at 0x00000000c1000000
    [    0.104159] Carveout Heap: Exported 1024 MiB at 0x0000000900000000
    [    0.104217] NET: Registered protocol family 2
    [    0.104543] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
    [    0.106598] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
    [    0.106650] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [    0.106863] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
    [    0.107275] TCP: Hash tables configured (established 65536 bind 65536)
    [    0.107370] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
    [    0.107452] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
    [    0.107613] NET: Registered protocol family 1
    [    0.107963] RPC: Registered named UNIX socket transport module.
    [    0.107967] RPC: Registered udp transport module.
    [    0.107970] RPC: Registered tcp transport module.
    [    0.107972] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.107981] PCI: CLS 0 bytes, default 64
    [    0.108099] Trying to unpack rootfs image as initramfs...
    [    0.208878] Freeing initrd memory: 14432K
    [    0.209639] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
    [    0.212214] Initialise system trusted keyrings
    [    0.212307] workingset: timestamp_bits=46 max_order=20 bucket_order=0
    [    0.214259] NFS: Registering the id_resolver key type
    [    0.214273] Key type id_resolver registered
    [    0.214276] Key type id_legacy registered
    [    0.214305] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.214309] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.214312] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
    [    0.214560] 9p: Installing v9fs 9p2000 file system support
    [    0.234522] Key type asymmetric registered
    [    0.234525] Asymmetric key parser 'x509' registered
    [    0.234546] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 241)
    [    0.234550] io scheduler mq-deadline registered
    [    0.234554] io scheduler kyber registered
    [    0.235978] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
    [    0.236110] pinctrl-single 11c000.pinctrl: 72 pins, size 288
    [    0.240473] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    0.247153] brd: module loaded
    [    0.251424] loop: module loaded
    [    0.253980] tun: Universal TUN/TAP device driver, 1.6
    [    0.254613] VFIO - User Level meta-driver version: 0.3
    [    0.254976] i2c /dev entries driver
    [    0.255819] sdhci: Secure Digital Host Controller Interface driver
    [    0.255821] sdhci: Copyright(c) Pierre Ossman
    [    0.256008] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.256512] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.257372] optee: probing for conduit method.
    [    0.257389] optee: revision 3.19 (afacf356)
    [    0.257511] optee: dynamic shared memory is enabled
    [    0.257721] optee: initialized driver
    [    0.258590] NET: Registered protocol family 17
    [    0.258626] 8021q: 802.1Q VLAN Support v1.8
    [    0.258684] 9pnet: Installing 9P2000 support
    [    0.258724] Key type dns_resolver registered
    [    0.258844] registered taskstats version 1
    [    0.258848] Loading compiled-in X.509 certificates
    [    0.263630] ti-sci 44083000.system-controller: ABI: 3.1 (firmware rev 0x0008 '8.6.3--v08.06.03 (Chill Capybar')
    [    0.283932] ti-sci-intr 310e0000.interrupt-controller: Interrupt Router 283 domain created
    [    0.284108] ti-sci-inta 33d00000.msi-controller: Interrupt Aggregator domain 321 created
    [    0.291385] j721e-pcie 2900000.pcie: defined num-lanes 4 is greater than the allowed maximum of 2, defaulting to 1
    [    0.291617] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    0.291662] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    0.291676] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    0.291680] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    0.291745] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    0.291752] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    0.291782] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    0.291818] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    0.292240] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:328
    [    0.292244] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
    [    0.292247] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66349100, num_proxies:64
    [    0.293787] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[878,128] sci-dev-id:315
    [    0.293791] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
    [    0.293794] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66349100, num_proxies:64
    [    0.294248] 2830000.serial: ttyS3 at MMIO 0x2830000 (irq = 16, base_baud = 3000000) is a 8250
    [    0.294763] 2880000.serial: ttyS2 at MMIO 0x2880000 (irq = 17, base_baud = 3000000) is a 8250
    [    0.294794] printk: console [ttyS2] enabled
    [    0.294796] printk: bootconsole [ns16550a0] disabled
    [    0.304820] spi-nor spi0.0: w25q128 (16384 Kbytes)
    [    0.307067] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fca100
    [    0.307300] mmc1: CQHCI version 5.10
    [    0.307383] mmc0: CQHCI version 5.10
    [    0.307446] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fca100
    [    0.307770] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fca100
    [    0.308071] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fca100
    [    0.308369] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fca100
    [    0.308666] omap-mailbox 31f85000.mailbox: omap mailbox rev 0x66fca100
    [    0.309265] ti-udma 285c0000.dma-controller: Channels: 22 (tchan: 11, rchan: 11, gp-rflow: 8)
    [    0.310787] ti-udma 31150000.dma-controller: Channels: 66 (tchan: 33, rchan: 33, gp-rflow: 16)
    [    0.317338] debugfs: Directory 'pd:73' with parent 'pm_genpd' already present!
    [    0.317374] debugfs: Directory 'pd:72' with parent 'pm_genpd' already present!
    [    0.317887] debugfs: Directory 'pd:335' with parent 'pm_genpd' already present!
    [    0.317916] debugfs: Directory 'pd:334' with parent 'pm_genpd' already present!
    [    0.317938] debugfs: Directory 'pd:333' with parent 'pm_genpd' already present!
    [    0.317958] debugfs: Directory 'pd:332' with parent 'pm_genpd' already present!
    [    0.338279] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
    [    0.342754] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
    [    0.357148] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    0.360176] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver RTL9000BF Ethernet
    [    0.360233] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
    [    0.360346] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    0.360349] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    0.360776] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:0
    [    0.361629] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
    [    0.362943] am65-cpsw-nuss c200000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
    [    0.363025] am65-cpsw-nuss c200000.ethernet: initialized cpsw ale version 1.4
    [    0.363029] am65-cpsw-nuss c200000.ethernet: ALE Table size 64
    [    0.363437] am65-cpsw-nuss c200000.ethernet: CPTS ver 0x4e8a010b, freq:200000000, add_val:4 pps:0
    [    0.364438] am65-cpsw-nuss c200000.ethernet: set new flow-id-base 82
    [    0.394942] j721e-pcie 2900000.pcie: Link up
    [    0.395027] j721e-pcie 2900000.pcie: PCI host bridge to bus 0000:00
    [    0.395032] pci_bus 0000:00: root bus resource [bus 00-ff]
    [    0.395037] pci_bus 0000:00: root bus resource [io  0x0000-0xffff] (bus address [0x10001000-0x10010fff])
    [    0.395040] pci_bus 0000:00: root bus resource [mem 0x10011000-0x17ffffff]
    [    0.395078] pci 0000:00:00.0: [104c:b00d] type 01 class 0x060400
    [    0.395083] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
    [    0.395202] pci 0000:00:00.0: supports D1
    [    0.395205] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
    [    0.397030] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    0.397168] pci 0000:01:00.0: [1b21:0611] type 00 class 0x010185
    [    0.397215] pci 0000:01:00.0: reg 0x10: initial BAR value 0x00000000 invalid
    [    0.397218] pci 0000:01:00.0: reg 0x10: [io  size 0x0008]
    [    0.397240] pci 0000:01:00.0: reg 0x14: initial BAR value 0x00000000 invalid
    [    0.397243] pci 0000:01:00.0: reg 0x14: [io  size 0x0004]
    [    0.397265] pci 0000:01:00.0: reg 0x18: initial BAR value 0x00000000 invalid
    [    0.397268] pci 0000:01:00.0: reg 0x18: [io  size 0x0008]
    [    0.397290] pci 0000:01:00.0: reg 0x1c: initial BAR value 0x00000000 invalid
    [    0.397293] pci 0000:01:00.0: reg 0x1c: [io  size 0x0004]
    [    0.397314] pci 0000:01:00.0: reg 0x20: initial BAR value 0x00000000 invalid
    [    0.397317] pci 0000:01:00.0: reg 0x20: [io  size 0x0010]
    [    0.397339] pci 0000:01:00.0: reg 0x24: [mem 0x00000000-0x000001ff]
    [    0.397362] pci 0000:01:00.0: reg 0x30: [mem 0x00000000-0x0000ffff pref]
    [    0.410798] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
    [    0.410816] pci 0000:00:00.0: BAR 14: assigned [mem 0x10100000-0x101fffff]
    [    0.410820] pci 0000:00:00.0: BAR 13: assigned [io  0x1000-0x1fff]
    [    0.410825] pci 0000:01:00.0: BAR 6: assigned [mem 0x10100000-0x1010ffff pref]
    [    0.410829] pci 0000:01:00.0: BAR 5: assigned [mem 0x10110000-0x101101ff]
    [    0.410840] pci 0000:01:00.0: BAR 4: assigned [io  0x1000-0x100f]
    [    0.410851] pci 0000:01:00.0: BAR 0: assigned [io  0x1010-0x1017]
    [    0.410862] pci 0000:01:00.0: BAR 2: assigned [io  0x1018-0x101f]
    [    0.410873] pci 0000:01:00.0: BAR 1: assigned [io  0x1020-0x1023]
    [    0.410885] pci 0000:01:00.0: BAR 3: assigned [io  0x1024-0x1027]
    [    0.410896] pci 0000:00:00.0: PCI bridge to [bus 01]
    [    0.410901] pci 0000:00:00.0:   bridge window [io  0x1000-0x1fff]
    [    0.410907] pci 0000:00:00.0:   bridge window [mem 0x10100000-0x101fffff]
    [    0.411018] pcieport 0000:00:00.0: enabling device (0000 -> 0003)
    [    0.411170] pcieport 0000:00:00.0: PME: Signaling with IRQ 280
    [    0.422035] mmc0: Command Queue Engine enabled
    [    0.422045] mmc0: new HS400 MMC card at address 0001
    [    0.422296] mmcblk0: mmc0:0001 CJUD4R 59.6 GiB
    [    0.422373] mmcblk0boot0: mmc0:0001 CJUD4R partition 1 31.9 MiB
    [    0.422448] mmcblk0boot1: mmc0:0001 CJUD4R partition 2 31.9 MiB
    [    0.422519] mmcblk0rpmb: mmc0:0001 CJUD4R partition 3 4.00 MiB, chardev (235:0)
    [    0.423298]  mmcblk0: 119 partitions parsed from device tree
    [    1.295148] j721e-pcie 2910000.pcie: PCI host bridge to bus 0001:00
    [    1.295157] pci_bus 0001:00: root bus resource [bus 00-ff]
    [    1.295162] pci_bus 0001:00: root bus resource [io  0x10000-0x1ffff] (bus address [0x18001000-0x18010fff])
    [    1.295165] pci_bus 0001:00: root bus resource [mem 0x18011000-0x1fffffff]
    [    1.295202] pci 0001:00:00.0: [104c:b013] type 01 class 0x060400
    [    1.295207] pci_bus 0001:00: 2-byte config write to 0001:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
    [    1.295325] pci 0001:00:00.0: supports D1
    [    1.295329] pci 0001:00:00.0: PME# supported from D0 D1 D3hot
    [    1.297189] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    1.298869] pci_bus 0001:01: busn_res: [bus 01-ff] end is updated to 01
    [    1.298882] pci 0001:00:00.0: PCI bridge to [bus 01]
    [    1.299152] pcieport 0001:00:00.0: PME: Signaling with IRQ 282
    [    1.300383] Freeing unused kernel memory: 1792K
    [    1.313219] Run /init as init process
    [    1.313222]   with arguments:
    [    1.313224]     /init
    [    1.313226]   with environment:
    [    1.313228]     HOME=/
    [    1.313230]     TERM=linux
    [    1.313232]     bootxpart=main
    [    1.352961] random: dd: uninitialized urandom read (512 bytes read)
    [    1.368283] random: dropbear: uninitialized urandom read (32 bytes read)
    [    1.570731] am65-cpsw-nuss c200000.ethernet eth2: configuring for fixed/rgmii-rxid link mode
    [    1.570795] am65-cpsw-nuss c200000.ethernet eth2: Link is Up - 100Mbps/Full - flow control off
    [    1.571338] 8021q: adding VLAN 0 to HW filter on device eth2
    [    1.603939] EXT4-fs (mmcblk0p51): mounted filesystem with ordered data mode. Opts: (null)
    [    1.612828] EXT4-fs (mmcblk0p63): mounted filesystem with ordered data mode. Opts: (null)
    [    1.614594] EXT4-fs (mmcblk0p65): mounted filesystem with ordered data mode. Opts: (null)
    [    1.615024] EXT4-fs (mmcblk0p53): mounted filesystem with ordered data mode. Opts: (null)
    [    1.615583] EXT4-fs (mmcblk0p61): mounted filesystem with ordered data mode. Opts: (null)
    [    1.615878] EXT4-fs (mmcblk0p66): mounted filesystem with ordered data mode. Opts: (null)
    [    1.616188] EXT4-fs (mmcblk0p57): mounted filesystem with ordered data mode. Opts: (null)
    [    1.616523] EXT4-fs (mmcblk0p55): mounted filesystem with ordered data mode. Opts: (null)
    [    1.616889] EXT4-fs (mmcblk0p116): mounted filesystem with ordered data mode. Opts: (null)
    [    1.620126] EXT4-fs (mmcblk0p112): mounted filesystem with ordered data mode. Opts: (null)
    [    1.623951] EXT4-fs (mmcblk0p114): mounted filesystem with ordered data mode. Opts: (null)
    [    1.628416] EXT4-fs (mmcblk0p117): mounted filesystem with ordered data mode. Opts: (null)
    [    1.632974] EXT4-fs (mmcblk0p118): mounted filesystem with ordered data mode. Opts: (null)
    [    1.645602] GTC: loading out-of-tree module taints kernel.
    [    1.653049] k3-dsp-rproc 64800000.dsp: assigned reserved memory node c71-dma-memory@b4000000
    [    1.661074] remoteproc remoteproc0: 64800000.dsp is available
    [    1.661114] remoteproc remoteproc0: attaching to 64800000.dsp
    [    1.661147] remoteproc remoteproc0: unsupported resource 65538
    [    1.670979]  remoteproc0#vdev0buffer: assigned reserved memory node c71-dma-memory@b4000000
    [    1.671211] virtio_rpmsg_bus virtio0: rpmsg host is online
    [    1.671572]  remoteproc0#vdev0buffer: registered virtio0 (type 7)
    [    1.671576] remoteproc remoteproc0: remote processor 64800000.dsp is now attached
    [    1.672076] k3-dsp-rproc 65800000.dsp: assigned reserved memory node c71_1-dma-memory@b7400000
    [    1.679724] remoteproc remoteproc1: 65800000.dsp is available
    [    1.679753] remoteproc remoteproc1: attaching to 65800000.dsp
    [    1.679777] remoteproc remoteproc1: unsupported resource 65538
    [    1.686401]  remoteproc1#vdev0buffer: assigned reserved memory node c71_1-dma-memory@b7400000
    [    1.686611] virtio_rpmsg_bus virtio1: rpmsg host is online
    [    1.686905]  remoteproc1#vdev0buffer: registered virtio1 (type 7)
    [    1.686909] remoteproc remoteproc1: remote processor 65800000.dsp is now attached
    [    1.687381] k3-dsp-rproc 66800000.dsp: assigned reserved memory node c71_2-dma-memory@ba800000
    [    1.694915] remoteproc remoteproc2: 66800000.dsp is available
    [    1.694943] remoteproc remoteproc2: attaching to 66800000.dsp
    [    1.694970] remoteproc remoteproc2: unsupported resource 65538
    [    1.701612]  remoteproc2#vdev0buffer: assigned reserved memory node c71_2-dma-memory@ba800000
    [    1.701817] virtio_rpmsg_bus virtio2: rpmsg host is online
    [    1.702097]  remoteproc2#vdev0buffer: registered virtio2 (type 7)
    [    1.702100] remoteproc remoteproc2: remote processor 66800000.dsp is now attached
    [    1.702555] k3-dsp-rproc 67800000.dsp: assigned reserved memory node c71_3-dma-memory@bdc00000
    [    1.710093] remoteproc remoteproc3: 67800000.dsp is available
    [    1.710134] remoteproc remoteproc3: attaching to 67800000.dsp
    [    1.710156] remoteproc remoteproc3: unsupported resource 65538
    [    1.715809] virtio_rpmsg_bus virtio2: creating channel rpmsg-remote-service addr 0x37
    [    1.716831]  remoteproc3#vdev0buffer: assigned reserved memory node c71_3-dma-memory@bdc00000
    [    1.716835] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0x4
    [    1.717083] virtio_rpmsg_bus virtio3: rpmsg host is online
    [    1.717096]  remoteproc3#vdev0buffer: registered virtio3 (type 7)
    [    1.717100] remoteproc remoteproc3: remote processor 67800000.dsp is now attached
    [    1.720607] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [    1.727072] platform 41000000.r5f: assigned reserved memory node r5f-dma-memory@a2000000
    [    1.727341] remoteproc remoteproc4: 41000000.r5f is available
    [    1.727379] remoteproc remoteproc4: attaching to 41000000.r5f
    [    1.734157]  remoteproc4#vdev0buffer: assigned reserved memory node r5f-dma-memory@a2000000
    [    1.734377] virtio_rpmsg_bus virtio4: rpmsg host is online
    [    1.734682]  remoteproc4#vdev0buffer: registered virtio4 (type 7)
    [    1.734687] remoteproc remoteproc4: remote processor 41000000.r5f is now attached
    [    1.742272] platform 5c00000.r5f: assigned reserved memory node r5f-dma-memory@a3000000
    [    1.743087] remoteproc remoteproc5: 5c00000.r5f is available
    [    1.743122] remoteproc remoteproc5: attaching to 5c00000.r5f
    [    1.749825] virtio_rpmsg_bus virtio3: creating channel rpmsg-remote-service addr 0x37
    [    1.749869] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0x4
    [    1.749935]  remoteproc5#vdev0buffer: assigned reserved memory node r5f-dma-memory@a3000000
    [    1.750466] virtio_rpmsg_bus virtio5: rpmsg host is online
    [    1.750746]  remoteproc5#vdev0buffer: registered virtio5 (type 7)
    [    1.750750] remoteproc remoteproc5: remote processor 5c00000.r5f is now attached
    [    1.757102] virtio_rpmsg_bus virtio0: creating channel rpmsg-remote-service addr 0x37
    [    1.757150] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0x4
    [    1.757220] platform 5d00000.r5f: assigned reserved memory node r5f-dma-memory@a6000000
    [    1.757552] remoteproc remoteproc6: 5d00000.r5f is available
    [    1.757580] remoteproc remoteproc6: attaching to 5d00000.r5f
    [    1.763773] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0xd
    [    1.764239]  remoteproc6#vdev0buffer: assigned reserved memory node r5f-dma-memory@a6000000
    [    1.764468] virtio_rpmsg_bus virtio6: rpmsg host is online
    [    1.764484]  remoteproc6#vdev0buffer: registered virtio6 (type 7)
    [    1.764487] remoteproc remoteproc6: remote processor 5d00000.r5f is now attached
    [    1.764574] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0x15
    [    1.772028] platform 5e00000.r5f: assigned reserved memory node r5f-dma-memory@a7000000
    [    1.772335] remoteproc remoteproc7: 5e00000.r5f is available
    [    1.772374] remoteproc remoteproc7: attaching to 5e00000.r5f
    [    1.774362] virtio_rpmsg_bus virtio4: creating channel rpmsg-remote-service addr 0x37
    [    1.779051]  remoteproc7#vdev0buffer: assigned reserved memory node r5f-dma-memory@a7000000
    [    1.779102] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0x4
    [    1.779275] virtio_rpmsg_bus virtio7: rpmsg host is online
    [    1.779289]  remoteproc7#vdev0buffer: registered virtio7 (type 7)
    [    1.779292] remoteproc remoteproc7: remote processor 5e00000.r5f is now attached
    [    1.782732] virtio_rpmsg_bus virtio1: creating channel rpmsg-remote-service addr 0x37
    [    1.785743] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0x4
    [    1.785758] platform 5f00000.r5f: assigned reserved memory node r5f-dma-memory@a8000000
    [    1.786075] remoteproc remoteproc8: 5f00000.r5f is available
    [    1.786100] remoteproc remoteproc8: attaching to 5f00000.r5f
    [    1.792748]  remoteproc8#vdev0buffer: assigned reserved memory node r5f-dma-memory@a8000000
    [    1.792952] virtio_rpmsg_bus virtio8: rpmsg host is online
    [    1.793242]  remoteproc8#vdev0buffer: registered virtio8 (type 7)
    [    1.793246] remoteproc remoteproc8: remote processor 5f00000.r5f is now attached
    [    1.800908] platform 5900000.r5f: assigned reserved memory node r5f-dma-memory@a9000000
    [    1.801475] remoteproc remoteproc9: 5900000.r5f is available
    [    1.801504] remoteproc remoteproc9: attaching to 5900000.r5f
    [    1.808175]  remoteproc9#vdev0buffer: assigned reserved memory node r5f-dma-memory@a9000000
    [    1.808380] virtio_rpmsg_bus virtio9: rpmsg host is online
    [    1.808663]  remoteproc9#vdev0buffer: registered virtio9 (type 7)
    [    1.808667] remoteproc remoteproc9: remote processor 5900000.r5f is now attached
    [    1.810443] virtio_rpmsg_bus virtio6: creating channel rpmsg-remote-service addr 0x37
    [    1.815057] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrdev addr 0x4
    [    1.815071] platform 5a00000.r5f: assigned reserved memory node r5f-dma-memory@ab000000
    [    1.815400] remoteproc remoteproc10: 5a00000.r5f is available
    [    1.815436] remoteproc remoteproc10: attaching to 5a00000.r5f
    [    1.822093]  remoteproc10#vdev0buffer: assigned reserved memory node r5f-dma-memory@ab000000
    [    1.822311] virtio_rpmsg_bus virtio10: rpmsg host is online
    [    1.822592]  remoteproc10#vdev0buffer: registered virtio10 (type 7)
    [    1.822596] remoteproc remoteproc10: remote processor 5a00000.r5f is now attached
    [    1.826596] virtio_rpmsg_bus virtio8: creating channel rpmsg-remote-service addr 0x37
    [    1.827326] virtio_rpmsg_bus virtio8: creating channel rpmsg_chrdev addr 0x4
    [    1.833841] virtio_rpmsg_bus virtio7: creating channel rpmsg-remote-service addr 0x37
    [    1.833908] virtio_rpmsg_bus virtio7: creating channel rpmsg_chrdev addr 0x4
    [    1.835021] virtio_rpmsg_bus virtio9: creating channel rpmsg-remote-service addr 0x37
    [    1.835709] virtio_rpmsg_bus virtio9: creating channel rpmsg_chrdev addr 0x4
    [    1.842900] virtio_rpmsg_bus virtio10: creating channel rpmsg-remote-service addr 0x37
    [    1.843630] virtio_rpmsg_bus virtio10: creating channel rpmsg_chrdev addr 0x4
    [    1.886263] virtio_rpmsg_bus virtio5: creating channel ti.ethfw.notifyservice addr 0x1e
    [    1.886653] virtio_rpmsg_bus virtio5: creating channel rpmsg-kdrv addr 0x1a
    [    1.887227] rpmsg-kdrv-eth-switch rpmsg-kdrv-1-mpu_1_0_ethmac-device-7: Device info: permissions: 3FFFFFFF uart_id: 2
    [    1.887232] rpmsg-kdrv-eth-switch rpmsg-kdrv-1-mpu_1_0_ethmac-device-7: FW ver 0.2 (rev 0) 29/Jun/2023 SHA:
    [    1.887270] rpmsg-kdrv-eth-switch rpmsg-kdrv-2-mpu_1_0_ethmac-device-8: Device info: permissions: 3FFFFFFF uart_id: 2
    [    1.887275] rpmsg-kdrv-eth-switch rpmsg-kdrv-2-mpu_1_0_ethmac-device-8: FW ver 0.2 (rev 0) 29/Jun/2023 SHA:
    [    1.907541] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac8: virt_cpsw_nuss mac loaded
    [    1.907548] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac8: rdev_features:00000007 rdev_mtu:1522 flow_id:114 tx_psil_dst_id:4A00 mac_only:8
    [    1.907552] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac8: local_mac_addr:00:00:00:00:00:00 rdev_mac_addr:70:ff:76:00:ca:6b
    [    1.928061] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac7: virt_cpsw_nuss mac loaded
    [    1.928067] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac7: rdev_features:00000007 rdev_mtu:1522 flow_id:115 tx_psil_dst_id:4A01 mac_only:7
    [    1.928071] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac7: local_mac_addr:00:00:00:00:00:00 rdev_mac_addr:70:ff:76:00:c5:71
    [    2.018879] virtio_rpmsg_bus virtio5: creating channel ti.ipc4.ping-pong addr 0xe
    [    2.733388] NFSD: Using /var/lib/nfs/v4recovery as the NFSv4 state recovery directory
    [    2.733409] NFSD: Using legacy client tracking operations.
    [    2.733413] NFSD: starting 90-second grace period (net f0000081)
    [    3.653146] random: crng init done
    [    7.139040] PVR_K:  826: Read BVNC 36.53.104.796 from HW device registers
    [    7.139051] PVR_K:  826: RGX Device registered BVNC 36.53.104.796 with 1 core in the system
    [    7.139340] [drm] Initialized pvr 1.15.6133109 20170530 for 4e20000000.gpu on minor 0
    [    9.144073] PVR_K:  834: RGX Firmware image 'rgx.fw.36.53.104.796' loaded
    [    9.145319] PVR_K:  834: Shader binary image 'rgx.sh.36.53.104.796' loaded
    [    9.145922] PVR_K:  834: PVRSRVConnectKM: COMPAT_TEST: Client-side (0x0c10) (debug) and KM driver (0x0810) (release) build options differ.
    [   14.159075] seq_file: buggy .next function _Next [pvrsrvkm] did not update position index
    [   14.499530] seq_file: buggy .next function _Next [pvrsrvkm] did not update position index
    [   14.500570] seq_file: buggy .next function _Next [pvrsrvkm] did not update position index
    [   14.501634] seq_file: buggy .next function _Next [pvrsrvkm] did not update position index
    [   14.502664] seq_file: buggy .next function _Next [pvrsrvkm] did not update position index
    [   14.503675] seq_file: buggy .next function _Next [pvrsrvkm] did not update position index
    [   14.504666] seq_file: buggy .next function _Next [pvrsrvkm] did not update position index
    [   14.505708] seq_file: buggy .next function _Next [pvrsrvkm] did not update position index
    [   14.506694] seq_file: buggy .next function _Next [pvrsrvkm] did not update position index
    [   14.507670] seq_file: buggy .next function _Next [pvrsrvkm] did not update position index
    Log during abnormal operation:
    abnormal.txt
    I followed the description of  “GPU Firmware Trace”. After manually loading the driver and before executing the application, run the following command:
    `pvrdebug -loggroups main,mts,hwr`. From abnormal.txt, it can be seen that the GPU module has reported an error at this time, and the log module seems to be unable to function properly.
    In addition, I would like to ask, what is the path for saving logs after running `pvrlogdump`? I cannot find the generated file after running `pvrlogdump under normal circumstances
    Best regards !
    Alex
  • HI Erick
    I used the following procedure to obtain GPU FW logs:
    1. Manual loading drive
    2. pvrdebug -loggroups main,mts,cleanup,csw,bif,pm,rtd,spm,pow,hwr
    3. echo "Y" >/sys/kernel/debug/pvr/apphint/0/AssertOnHWRTrigger
    4. Run app demo
    5. cat /sys/kernel/debug/pvr/firmware_trace > firmware_trace.log
    6. cat /sys/kernel/debug/pvr/debug_dump > debug_dump.log
    For the convenience of your debug, we will provide logs of normal and abnormal situations.
    normal:
    normal_debug_dump.lognormal_firmware_trace.log
    I/TC:
    I/TC: Primary CPU initializin▒C▒I/TC: SYSFW ABI: 3.1 (firmware rev 0x0008 '8.6.3--v08.06.03 (Chill Capybar')
    DRAM:  8 GiB
    Flash: 0 Bytes
    In:    serial@2880000
    Out:   serial@2880000
    Err:   serial@2880000
    exporting *:/ab/res
    exporting *:/ab/log
    exporting *:/ab/cfg
    exporting *:/ab/app
    exporting *:/ab/map
    exporting *:/hat-s/app
    [3068]Prepare run initrun.sh
    [    1.657832] k3-dsp-rproc 64800000.dsp: configured DSP for IPC-only mode
    [    1.664625] k3-dsp-rproc 64800000.dsp: DSP initialized in IPC-only mode
    [    1.673468] k3-dsp-rproc 65800000.dsp: configured DSP for IPC-only mode
    [    1.680260] k3-dsp-rproc 65800000.dsp: DSP initialized in IPC-only mode
    [    1.688955] k3-dsp-rproc 66800000.dsp: configured DSP for IPC-only mode
    [    1.695693] k3-dsp-rproc 66800000.dsp: DSP initialized in IPC-only mode
    [    1.704391] k3-dsp-rproc 67800000.dsp: configured DSP for IPC-only mode
    [    1.711114] k3-dsp-rproc 67800000.dsp: DSP initialized in IPC-only mode
    [    1.722565] platform 41000000.r5f: configured R5F for IPC-only mode
    [    1.729372] platform 41000000.r5f: R5F core initialized in IPC-only mode
    [    1.738155] platform 5c00000.r5f: configured R5F for IPC-only mode
    [    1.745504] platform 5c00000.r5f: R5F core initialized in IPC-only mode
    [    1.752837] platform 5d00000.r5f: configured R5F for IPC-only mode
    [    1.759454] platform 5d00000.r5f: R5F core initialized in IPC-only mode
    [    1.767919] platform 5e00000.r5f: configured R5F for IPC-only mode
    [    1.774517] platform 5e00000.r5f: R5F core initialized in IPC-only mode
    [    1.781894] platform 5f00000.r5f: configured R5F for IPC-only mode
    [    1.788478] platform 5f00000.r5f: R5F core initialized in IPC-only mode
    [    1.797050] platform 5900000.r5f: configured R5F for IPC-only mode
    [    1.803927] platform 5900000.r5f: R5F core initialized in IPC-only mode
    [    1.811221] platform 5a00000.r5f: configured R5F for IPC-only mode
    [    1.817798] platform 5a00000.r5f: R5F core initialized in IPC-only mode
    [    1.889775] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac8: rpmsg attach_ext - rx_mtu:1522 features:00000007 tx_mtu[0]:2024 flow_idx:114 tx_cpsw_psil_dst_id:51712 mac_addr:70:ff:76:00:3e:a5 mac-only:8
    [    1.910047] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac7: rpmsg attach_ext - rx_mtu:1522 features:00000007 tx_mtu[0]:2024 flow_idx:115 tx_cpsw_psil_dst_id:51713 mac_addr:70:ff:76:00:de:60 mac-only:7
    root@j7-evm:~# [1970-01-01 00:00:02][000000.987][c710][INF]c7x1 start run
    [1970-01-01 00:00:02][000001.015][c711][INF]c7x2 start run
    [1970-01-01 00:00:02][000001.048][c712][INF]c7x3 start run
    [1970-01-01 00:00:02][000001.081][c713][INF]c7x4 start run
    [1970-01-01 00:00:02][000000.947][r5f1][INF]mcu2_1 start run
    [1970-01-01 00:00:02][000000.966][r5f2][INF]mcu3_0 start run
    [1970-01-01 00:00:02][000000.963][r5f3][INF]mcu3_1 start run
    [1970-01-01 00:00:02][000000.964][r5f3][DBG][safe-service-lv]Suncess register safe service lv1
    [1970-01-01 00:00:02][000000.971][r5f4][INF]mcu4_0 start run
    [1970-01-01 00:00:02][000000.979][r5f5][INF]mcu4_1 start run
    Set FW Log type to TRACE ( main mts cleanup csw bif pm rtd spm pow hwr )
    EGL: version 1.4
    MEM: Init ... !!!
    MEM: Allocated virt addr = ffffa5936000 -> phy addr = c1000000, size = 1843200 (FD's = 11 12) !!!
    gen 1 tex 1
    MEM: Allocated virt addr = ffffa55b2000 -> phy addr = c11c2000, size = 3686400 (FD's = 13 14) !!!
    gen 1 tex 2
    start
    ( 836) PVR:(Warning): Kicking TA to free up CBUF space [ rgxif.c:3621 ]
    fwrite
    ( 836) PVR:(Warning): GrowSparseBuffer SCBUF:VERTEX_DATA (1): Requested size increase (770052) greater than space available. Increase to allocation size (1638400, 400 pages) [ buffers.c:783 ]
    Display time: 3 ms
    total 264
    -rw-r--r--    1 root     root        123656 Jan  1 00:00 debug_dump.log
    -rw-r--r--    1 root     root        141069 Jan  1 00:00 firmware_trace.log
    [    0.000227] Console: colour dummy device 80x25
    [    0.000263] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.000270] pid_max: default: 32768 minimum: 301
    [    0.000317] LSM: Security Framework initializing
    [    0.000371] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.000402] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.001393] rcu: Hierarchical SRCU implementation.
    [    0.001605] Platform MSI: msi-controller@1820000 domain created
    [    0.001725] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.001779] EFI services will not be available.
    [    0.001994] smp: Bringing up secondary CPUs ...
    [    0.010462] Detected PIPT I-cache on CPU1
    [    0.010485] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
    [    0.010496] GICv3: CPU1: using allocated LPI pending table @0x00000008d3470000
    [    0.010532] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
    [    0.019004] Detected PIPT I-cache on CPU2
    [    0.019019] GICv3: CPU2: found redistributor 2 region 0:0x0000000001940000
    [    0.019030] GICv3: CPU2: using allocated LPI pending table @0x00000008d3480000
    [    0.019058] CPU2: Booted secondary processor 0x0000000002 [0x411fd080]
    [    0.027499] Detected PIPT I-cache on CPU3
    [    0.027514] GICv3: CPU3: found redistributor 3 region 0:0x0000000001960000
    [    0.027525] GICv3: CPU3: using allocated LPI pending table @0x00000008d3490000
    [    0.027554] CPU3: Booted secondary processor 0x0000000003 [0x411fd080]
    [    0.036066] GICv3: CPU4: using allocated LPI pending table @0x00000008d34a0000
    [    0.036104] CPU4: Booted secondary processor 0x0000000100 [0x411fd080]
    [    0.044597] Detected PIPT I-cache on CPU5
    [    0.044615] GICv3: CPU5: found redistributor 101 region 0:0x00000000019a0000
    [    0.044627] GICv3: CPU5: using allocated LPI pending table @0x00000008d34b0000
    [    0.053114] Detected PIPT I-cache on CPU6
    [    0.053133] GICv3: CPU6: found redistributor 102 region 0:0x00000000019c0000
    [    0.053145] GICv3: CPU6: using allocated LPI pending table @0x00000008d34c0000
    [    0.053175] CPU6: Booted secondary processor 0x0000000102 [0x411fd080]
    [    0.061630] Detected PIPT I-cache on CPU7
    [    0.061650] GICv3: CPU7: found redistributor 103 region 0:0x00000000019e0000
    [    0.061662] GICv3: CPU7: using allocated LPI pending table @0x00000008d34d0000
    [    0.061692] CPU7: Booted secondary processor 0x0000000103 [0x411fd080]
    [    0.061754] smp: Brought up 1 node, 8 CPUs
    [    0.061763] SMP: Total of 8 processors activated.
    [    0.061767] CPU features: detected: 32-bit EL0 Support
    [    0.061770] CPU features: detected: CRC32 instructions
    [    0.073744] CPU: All CPU(s) started at EL2
    [    0.073771] alternatives: patching kernel code
    [    0.074365] devtmpfs: initialized
    [    0.079578] KASLR disabled due to lack of seed
    [    0.079689] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.079698] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
    [    0.079865] pinctrl core: initialized pinctrl subsystem
    [    0.080111] DMI not present or invalid.
    [    0.080419] NET: Registered protocol family 16
    [    0.080847] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
    [    0.080953] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.081048] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.081337] thermal_sys: Registered thermal governor 'step_wise'
    [    0.081340] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.081587] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.081690] ASID allocator initialised with 65536 entries
    [    0.095634] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.095639] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.095642] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.095645] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.096536] cryptd: max_cpu_qlen set to 1000
    [    0.098438] k3-chipinfo 43000014.chipid: Family:J784S4 rev:SR1.0 JTAGID[0x0bb8002f] Detected
    [    0.098708] vsys_3v3: supplied by evm_12v0
    [    0.098929] vsys_5v0: supplied by evm_12v0
    [    0.099081] vdd_mmc1: supplied by vsys_3v3
    [    0.099749] iommu: Default domain type: Translated
    [    0.099869] vgaarb: loaded
    [    0.100017] SCSI subsystem initialized
    [    0.100166] mc: Linux media interface: v0.10
    [    0.100178] videodev: Linux video capture interface: v2.00
    [    0.100207] pps_core: LinuxPPS API ver. 1 registered
    [    0.100210] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.100217] PTP clock support registered
    [    0.100238] EDAC MC: Ver: 3.0.0
    [    0.100831] FPGA manager framework
    [    0.101242] clocksource: Switched to clocksource arch_sys_counter
    [    0.101322] VFS: Disk quotas dquot_6.6.0
    [    0.101350] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.104203] Carveout Heap: Exported 1008 MiB at 0x00000000c1000000
    [    0.104262] Carveout Heap: Exported 1024 MiB at 0x0000000900000000
    [    0.104320] NET: Registered protocol family 2
    [    0.104638] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
    [    0.106660] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
    [    0.106736] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [    0.106950] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
    [    0.107361] TCP: Hash tables configured (established 65536 bind 65536)
    [    0.107460] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
    [    0.107541] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
    [    0.107701] NET: Registered protocol family 1
    [    0.108033] RPC: Registered named UNIX socket transport module.
    [    0.108037] RPC: Registered udp transport module.
    [    0.108039] RPC: Registered tcp transport module.
    [    0.108041] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.108049] PCI: CLS 0 bytes, default 64
    [    0.108162] Trying to unpack rootfs image as initramfs...
    [    0.211538] Freeing initrd memory: 14432K
    [    0.212243] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
    [    0.214832] Initialise system trusted keyrings
    [    0.214920] workingset: timestamp_bits=46 max_order=20 bucket_order=0
    [    0.216845] NFS: Registering the id_resolver key type
    [    0.216859] Key type id_resolver registered
    [    0.216862] Key type id_legacy registered
    [    0.216892] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.216896] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.216899] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
    [    0.217144] 9p: Installing v9fs 9p2000 file system support
    [    0.236425] Key type asymmetric registered
    [    0.236428] Asymmetric key parser 'x509' registered
    [    0.236449] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 241)
    [    0.236454] io scheduler mq-deadline registered
    [    0.236457] io scheduler kyber registered
    [    0.237900] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
    [    0.238035] pinctrl-single 11c000.pinctrl: 72 pins, size 288
    [    0.242381] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    0.249074] brd: module loaded
    [    0.253369] loop: module loaded
    [    0.255894] tun: Universal TUN/TAP device driver, 1.6
    [    0.256526] VFIO - User Level meta-driver version: 0.3
    [    0.256888] i2c /dev entries driver
    [    0.257745] sdhci: Secure Digital Host Controller Interface driver
    [    0.257748] sdhci: Copyright(c) Pierre Ossman
    [    0.257935] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.258428] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.259270] optee: probing for conduit method.
    [    0.259289] optee: revision 3.19 (afacf356)
    [    0.259411] optee: dynamic shared memory is enabled
    [    0.259618] optee: initialized driver
    [    0.260489] NET: Registered protocol family 17
    [    0.260526] 8021q: 802.1Q VLAN Support v1.8
    [    0.260584] 9pnet: Installing 9P2000 support
    [    0.260623] Key type dns_resolver registered
    [    0.260767] registered taskstats version 1
    [    0.260771] Loading compiled-in X.509 certificates
    [    0.265442] ti-sci 44083000.system-controller: ABI: 3.1 (firmware rev 0x0008 '8.6.3--v08.06.03 (Chill Capybar')
    [    0.284762] ti-sci-intr 310e0000.interrupt-controller: Interrupt Router 283 domain created
    [    0.284939] ti-sci-inta 33d00000.msi-controller: Interrupt Aggregator domain 321 created
    [    0.292581] j721e-pcie 2900000.pcie: defined num-lanes 4 is greater than the allowed maximum of 2, defaulting to 1
    [    0.292761] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    0.292789] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    0.292808] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    0.292823] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    0.292827] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    0.292844] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    0.292858] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    0.292869] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    0.293415] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:328
    [    0.293420] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
    [    0.293424] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66349100, num_proxies:64
    [    0.294969] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[878,128] sci-dev-id:315
    [    0.294973] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
    [    0.294976] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66349100, num_proxies:64
    [    0.295438] 2830000.serial: ttyS3 at MMIO 0x2830000 (irq = 16, base_baud = 3000000) is a 8250
    [    0.295958] 2880000.serial: ttyS2 at MMIO 0x2880000 (irq = 17, base_baud = 3000000) is a 8250
    [    0.295988] printk: console [ttyS2] enabled
    [    0.295991] printk: bootconsole [ns16550a0] disabled
    [    0.306011] spi-nor spi0.0: w25q128 (16384 Kbytes)
    [    0.308162] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fca100
    [    0.308385] mmc1: CQHCI version 5.10
    [    0.308424] mmc0: CQHCI version 5.10
    [    0.308503] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fca100
    [    0.308827] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fca100
    [    0.309128] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fca100
    [    0.309425] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fca100
    [    0.309729] omap-mailbox 31f85000.mailbox: omap mailbox rev 0x66fca100
    [    0.310328] ti-udma 285c0000.dma-controller: Channels: 22 (tchan: 11, rchan: 11, gp-rflow: 8)
    [    0.311873] ti-udma 31150000.dma-controller: Channels: 66 (tchan: 33, rchan: 33, gp-rflow: 16)
    [    0.318540] debugfs: Directory 'pd:73' with parent 'pm_genpd' already present!
    [    0.318569] debugfs: Directory 'pd:72' with parent 'pm_genpd' already present!
    [    0.319094] debugfs: Directory 'pd:335' with parent 'pm_genpd' already present!
    [    0.319117] debugfs: Directory 'pd:334' with parent 'pm_genpd' already present!
    [    0.319138] debugfs: Directory 'pd:333' with parent 'pm_genpd' already present!
    [    0.319169] debugfs: Directory 'pd:332' with parent 'pm_genpd' already present!
    [    0.339272] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
    [    0.341249] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
    [    0.357248] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    0.360306] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver RTL9000BF Ethernet
    [    0.360361] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
    [    0.360478] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    0.360481] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    0.360906] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:0
    [    0.361744] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
    [    0.363040] am65-cpsw-nuss c200000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
    [    0.363127] am65-cpsw-nuss c200000.ethernet: initialized cpsw ale version 1.4
    [    0.363130] am65-cpsw-nuss c200000.ethernet: ALE Table size 64
    [    0.363494] am65-cpsw-nuss c200000.ethernet: CPTS ver 0x4e8a010b, freq:200000000, add_val:4 pps:0
    [    0.364480] am65-cpsw-nuss c200000.ethernet: set new flow-id-base 82
    [    0.395975] j721e-pcie 2900000.pcie: Link up
    [    0.396070] j721e-pcie 2900000.pcie: PCI host bridge to bus 0000:00
    [    0.396075] pci_bus 0000:00: root bus resource [bus 00-ff]
    [    0.396080] pci_bus 0000:00: root bus resource [io  0x0000-0xffff] (bus address [0x10001000-0x10010fff])
    [    0.396083] pci_bus 0000:00: root bus resource [mem 0x10011000-0x17ffffff]
    [    0.396120] pci 0000:00:00.0: [104c:b00d] type 01 class 0x060400
    [    0.396125] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
    [    0.396243] pci 0000:00:00.0: supports D1
    [    0.396246] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
    [    0.398254] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    0.398377] pci 0000:01:00.0: [1b21:0611] type 00 class 0x010185
    [    0.398423] pci 0000:01:00.0: reg 0x10: initial BAR value 0x00000000 invalid
    [    0.398426] pci 0000:01:00.0: reg 0x10: [io  size 0x0008]
    [    0.398449] pci 0000:01:00.0: reg 0x14: initial BAR value 0x00000000 invalid
    [    0.398451] pci 0000:01:00.0: reg 0x14: [io  size 0x0004]
    [    0.398474] pci 0000:01:00.0: reg 0x18: initial BAR value 0x00000000 invalid
    [    0.398476] pci 0000:01:00.0: reg 0x18: [io  size 0x0008]
    [    0.398498] pci 0000:01:00.0: reg 0x1c: initial BAR value 0x00000000 invalid
    [    0.398501] pci 0000:01:00.0: reg 0x1c: [io  size 0x0004]
    [    0.398523] pci 0000:01:00.0: reg 0x20: initial BAR value 0x00000000 invalid
    [    0.398525] pci 0000:01:00.0: reg 0x20: [io  size 0x0010]
    [    0.398547] pci 0000:01:00.0: reg 0x24: [mem 0x00000000-0x000001ff]
    [    0.398570] pci 0000:01:00.0: reg 0x30: [mem 0x00000000-0x0000ffff pref]
    [    0.411073] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
    [    0.411091] pci 0000:00:00.0: BAR 14: assigned [mem 0x10100000-0x101fffff]
    [    0.411095] pci 0000:00:00.0: BAR 13: assigned [io  0x1000-0x1fff]
    [    0.411101] pci 0000:01:00.0: BAR 6: assigned [mem 0x10100000-0x1010ffff pref]
    [    0.411105] pci 0000:01:00.0: BAR 5: assigned [mem 0x10110000-0x101101ff]
    [    0.411116] pci 0000:01:00.0: BAR 4: assigned [io  0x1000-0x100f]
    [    0.411127] pci 0000:01:00.0: BAR 0: assigned [io  0x1010-0x1017]
    [    0.411138] pci 0000:01:00.0: BAR 2: assigned [io  0x1018-0x101f]
    [    0.411149] pci 0000:01:00.0: BAR 1: assigned [io  0x1020-0x1023]
    [    0.411160] pci 0000:01:00.0: BAR 3: assigned [io  0x1024-0x1027]
    [    0.411172] pci 0000:00:00.0: PCI bridge to [bus 01]
    [    0.411176] pci 0000:00:00.0:   bridge window [io  0x1000-0x1fff]
    [    0.411183] pci 0000:00:00.0:   bridge window [mem 0x10100000-0x101fffff]
    [    0.411303] pcieport 0000:00:00.0: enabling device (0000 -> 0003)
    [    0.411466] pcieport 0000:00:00.0: PME: Signaling with IRQ 280
    [    0.420451] mmc0: Command Queue Engine enabled
    [    0.420461] mmc0: new HS400 MMC card at address 0001
    [    0.420725] mmcblk0: mmc0:0001 CJUD4R 59.6 GiB
    [    0.420799] mmcblk0boot0: mmc0:0001 CJUD4R partition 1 31.9 MiB
    [    0.420873] mmcblk0boot1: mmc0:0001 CJUD4R partition 2 31.9 MiB
    [    0.420971] mmcblk0rpmb: mmc0:0001 CJUD4R partition 3 4.00 MiB, chardev (235:0)
    [    0.421738]  mmcblk0: 119 partitions parsed from device tree
    [    1.293408] j721e-pcie 2910000.pcie: PCI host bridge to bus 0001:00
    [    1.293415] pci_bus 0001:00: root bus resource [bus 00-ff]
    [    1.293419] pci_bus 0001:00: root bus resource [io  0x10000-0x1ffff] (bus address [0x18001000-0x18010fff])
    [    1.293422] pci_bus 0001:00: root bus resource [mem 0x18011000-0x1fffffff]
    [    1.293454] pci 0001:00:00.0: [104c:b013] type 01 class 0x060400
    [    1.293458] pci_bus 0001:00: 2-byte config write to 0001:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
    [    1.293573] pci 0001:00:00.0: supports D1
    [    1.293576] pci 0001:00:00.0: PME# supported from D0 D1 D3hot
    [    1.295379] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    1.297059] pci_bus 0001:01: busn_res: [bus 01-ff] end is updated to 01
    [    1.297070] pci 0001:00:00.0: PCI bridge to [bus 01]
    [    1.297345] pcieport 0001:00:00.0: PME: Signaling with IRQ 282
    [    1.298260] Freeing unused kernel memory: 1792K
    [    1.298360] Run /init as init process
    [    1.298362]   with arguments:
    [    1.298365]     /init
    [    1.298366]   with environment:
    [    1.298369]     HOME=/
    [    1.298371]     TERM=linux
    [    1.298373]     bootxpart=main
    [    1.338407] random: dd: uninitialized urandom read (512 bytes read)
    [    1.353725] random: dropbear: uninitialized urandom read (32 bytes read)
    [    1.554873] am65-cpsw-nuss c200000.ethernet eth2: configuring for fixed/rgmii-rxid link mode
    [    1.554922] am65-cpsw-nuss c200000.ethernet eth2: Link is Up - 100Mbps/Full - flow control off
    [    1.555469] 8021q: adding VLAN 0 to HW filter on device eth2
    [    1.587735] EXT4-fs (mmcblk0p51): recovery complete
    [    1.588159] EXT4-fs (mmcblk0p51): mounted filesystem with ordered data mode. Opts: (null)
    [    1.598109] EXT4-fs (mmcblk0p63): recovery complete
    [    1.598120] EXT4-fs (mmcblk0p63): mounted filesystem with ordered data mode. Opts: (null)
    [    1.600483] EXT4-fs (mmcblk0p61): recovery complete
    [    1.600491] EXT4-fs (mmcblk0p61): mounted filesystem with ordered data mode. Opts: (null)
    [    1.601680] EXT4-fs (mmcblk0p53): recovery complete
    [    1.601689] EXT4-fs (mmcblk0p53): mounted filesystem with ordered data mode. Opts: (null)
    [    1.603238] EXT4-fs (mmcblk0p55): recovery complete
    [    1.603246] EXT4-fs (mmcblk0p55): mounted filesystem with ordered data mode. Opts: (null)
    [    1.604763] EXT4-fs (mmcblk0p57): recovery complete
    [    1.604771] EXT4-fs (mmcblk0p57): mounted filesystem with ordered data mode. Opts: (null)
    [    1.606272] EXT4-fs (mmcblk0p116): recovery complete
    [    1.606279] EXT4-fs (mmcblk0p116): mounted filesystem with ordered data mode. Opts: (null)
    [    1.607955] EXT4-fs (mmcblk0p66): recovery complete
    [    1.607964] EXT4-fs (mmcblk0p66): mounted filesystem with ordered data mode. Opts: (null)
    [    1.609979] EXT4-fs (mmcblk0p112): recovery complete
    [    1.609986] EXT4-fs (mmcblk0p112): mounted filesystem with ordered data mode. Opts: (null)
    [    1.616150] EXT4-fs (mmcblk0p114): recovery complete
    [    1.616159] EXT4-fs (mmcblk0p114): mounted filesystem with ordered data mode. Opts: (null)
    [    1.623881] EXT4-fs (mmcblk0p117): recovery complete
    [    1.623889] EXT4-fs (mmcblk0p117): mounted filesystem with ordered data mode. Opts: (null)
    [    1.631930] EXT4-fs (mmcblk0p118): recovery complete
    [    1.631938] EXT4-fs (mmcblk0p118): mounted filesystem with ordered data mode. Opts: (null)
    [    1.647821] GTC: loading out-of-tree module taints kernel.
    [    1.656730] k3-dsp-rproc 64800000.dsp: assigned reserved memory node c71-dma-memory@b4000000
    [    1.664481] remoteproc remoteproc0: 64800000.dsp is available
    [    1.664535] remoteproc remoteproc0: attaching to 64800000.dsp
    [    1.664565] remoteproc remoteproc0: unsupported resource 65538
    [    1.671230]  remoteproc0#vdev0buffer: assigned reserved memory node c71-dma-memory@b4000000
    [    1.671481] virtio_rpmsg_bus virtio0: rpmsg host is online
    [    1.671834]  remoteproc0#vdev0buffer: registered virtio0 (type 7)
    [    1.671838] remoteproc remoteproc0: remote processor 64800000.dsp is now attached
    [    1.672370] k3-dsp-rproc 65800000.dsp: assigned reserved memory node c71_1-dma-memory@b7400000
    [    1.680179] remoteproc remoteproc1: 65800000.dsp is available
    [    1.680212] remoteproc remoteproc1: attaching to 65800000.dsp
    [    1.680237] remoteproc remoteproc1: unsupported resource 65538
    [    1.686865]  remoteproc1#vdev0buffer: assigned reserved memory node c71_1-dma-memory@b7400000
    [    1.687089] virtio_rpmsg_bus virtio1: rpmsg host is online
    [    1.687407]  remoteproc1#vdev0buffer: registered virtio1 (type 7)
    [    1.687411] remoteproc remoteproc1: remote processor 65800000.dsp is now attached
    [    1.687916] k3-dsp-rproc 66800000.dsp: assigned reserved memory node c71_2-dma-memory@ba800000
    [    1.695592] remoteproc remoteproc2: 66800000.dsp is available
    [    1.695621] remoteproc remoteproc2: attaching to 66800000.dsp
    [    1.695647] remoteproc remoteproc2: unsupported resource 65538
    [    1.702301]  remoteproc2#vdev0buffer: assigned reserved memory node c71_2-dma-memory@ba800000
    [    1.702523] virtio_rpmsg_bus virtio2: rpmsg host is online
    [    1.702826]  remoteproc2#vdev0buffer: registered virtio2 (type 7)
    [    1.702829] remoteproc remoteproc2: remote processor 66800000.dsp is now attached
    [    1.703318] k3-dsp-rproc 67800000.dsp: assigned reserved memory node c71_3-dma-memory@bdc00000
    [    1.711026] remoteproc remoteproc3: 67800000.dsp is available
    [    1.711059] remoteproc remoteproc3: attaching to 67800000.dsp
    [    1.711084] remoteproc remoteproc3: unsupported resource 65538
    [    1.717721]  remoteproc3#vdev0buffer: assigned reserved memory node c71_3-dma-memory@bdc00000
    [    1.717940] virtio_rpmsg_bus virtio3: rpmsg host is online
    [    1.718240]  remoteproc3#vdev0buffer: registered virtio3 (type 7)
    [    1.718244] remoteproc remoteproc3: remote processor 67800000.dsp is now attached
    [    1.718555] virtio_rpmsg_bus virtio2: creating channel rpmsg-remote-service addr 0x37
    [    1.718633] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0x4
    [    1.722442] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [    1.728949] platform 41000000.r5f: assigned reserved memory node r5f-dma-memory@a2000000
    [    1.729225] remoteproc remoteproc4: 41000000.r5f is available
    [    1.729280] remoteproc remoteproc4: attaching to 41000000.r5f
    [    1.736079]  remoteproc4#vdev0buffer: assigned reserved memory node r5f-dma-memory@a2000000
    [    1.736334] virtio_rpmsg_bus virtio4: rpmsg host is online
    [    1.736706]  remoteproc4#vdev0buffer: registered virtio4 (type 7)
    [    1.736711] remoteproc remoteproc4: remote processor 41000000.r5f is now attached
    [    1.744428] platform 5c00000.r5f: assigned reserved memory node r5f-dma-memory@a3000000
    [    1.745380] remoteproc remoteproc5: 5c00000.r5f is available
    [    1.745418] remoteproc remoteproc5: attaching to 5c00000.r5f
    [    1.745795] EXT4-fs (mmcblk0p65): recovery complete
    [    1.751404] virtio_rpmsg_bus virtio3: creating channel rpmsg-remote-service addr 0x37
    [    1.751467] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0x4
    [    1.752112]  remoteproc5#vdev0buffer: assigned reserved memory node r5f-dma-memory@a3000000
    [    1.752335] virtio_rpmsg_bus virtio5: rpmsg host is online
    [    1.752490] EXT4-fs (mmcblk0p65): mounted filesystem with ordered data mode. Opts: (null)
    [    1.752663]  remoteproc5#vdev0buffer: registered virtio5 (type 7)
    [    1.752668] remoteproc remoteproc5: remote processor 5c00000.r5f is now attached
    [    1.757444] virtio_rpmsg_bus virtio0: creating channel rpmsg-remote-service addr 0x37
    [    1.759046] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0x4
    [    1.759084] platform 5d00000.r5f: assigned reserved memory node r5f-dma-memory@a6000000
    [    1.759378] remoteproc remoteproc6: 5d00000.r5f is available
    [    1.759409] remoteproc remoteproc6: attaching to 5d00000.r5f
    [    1.765540] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0xd
    [    1.766060]  remoteproc6#vdev0buffer: assigned reserved memory node r5f-dma-memory@a6000000
    [    1.766168] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0x15
    [    1.766286] virtio_rpmsg_bus virtio6: rpmsg host is online
    [    1.766305]  remoteproc6#vdev0buffer: registered virtio6 (type 7)
    [    1.766309] remoteproc remoteproc6: remote processor 5d00000.r5f is now attached
    [    1.774121] platform 5e00000.r5f: assigned reserved memory node r5f-dma-memory@a7000000
    [    1.774420] remoteproc remoteproc7: 5e00000.r5f is available
    [    1.774449] remoteproc remoteproc7: attaching to 5e00000.r5f
    [    1.781122]  remoteproc7#vdev0buffer: assigned reserved memory node r5f-dma-memory@a7000000
    [    1.781348] virtio_rpmsg_bus virtio7: rpmsg host is online
    [    1.781574] virtio_rpmsg_bus virtio4: creating channel rpmsg-remote-service addr 0x37
    [    1.781646]  remoteproc7#vdev0buffer: registered virtio7 (type 7)
    [    1.781650] remoteproc remoteproc7: remote processor 5e00000.r5f is now attached
    [    1.785437] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0x4
    [    1.788108] platform 5f00000.r5f: assigned reserved memory node r5f-dma-memory@a8000000
    [    1.788140] virtio_rpmsg_bus virtio1: creating channel rpmsg-remote-service addr 0x37
    [    1.788179] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0x4
    [    1.788408] remoteproc remoteproc8: 5f00000.r5f is available
    [    1.788434] remoteproc remoteproc8: attaching to 5f00000.r5f
    [    1.795085]  remoteproc8#vdev0buffer: assigned reserved memory node r5f-dma-memory@a8000000
    [    1.795293] virtio_rpmsg_bus virtio8: rpmsg host is online
    [    1.795595]  remoteproc8#vdev0buffer: registered virtio8 (type 7)
    [    1.795598] remoteproc remoteproc8: remote processor 5f00000.r5f is now attached
    [    1.803269] platform 5900000.r5f: assigned reserved memory node r5f-dma-memory@a9000000
    [    1.803821] remoteproc remoteproc9: 5900000.r5f is available
    [    1.803859] remoteproc remoteproc9: attaching to 5900000.r5f
    [    1.810537]  remoteproc9#vdev0buffer: assigned reserved memory node r5f-dma-memory@a9000000
    [    1.810741] virtio_rpmsg_bus virtio9: rpmsg host is online
    [    1.811026]  remoteproc9#vdev0buffer: registered virtio9 (type 7)
    [    1.811030] remoteproc remoteproc9: remote processor 5900000.r5f is now attached
    [    1.817323] virtio_rpmsg_bus virtio6: creating channel rpmsg-remote-service addr 0x37
    [    1.817426] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrdev addr 0x4
    [    1.817437] platform 5a00000.r5f: assigned reserved memory node r5f-dma-memory@ab000000
    [    1.817727] remoteproc remoteproc10: 5a00000.r5f is available
    [    1.817752] remoteproc remoteproc10: attaching to 5a00000.r5f
    [    1.824407]  remoteproc10#vdev0buffer: assigned reserved memory node r5f-dma-memory@ab000000
    [    1.824613] virtio_rpmsg_bus virtio10: rpmsg host is online
    [    1.824917]  remoteproc10#vdev0buffer: registered virtio10 (type 7)
    [    1.824920] remoteproc remoteproc10: remote processor 5a00000.r5f is now attached
    [    1.833484] virtio_rpmsg_bus virtio8: creating channel rpmsg-remote-service addr 0x37
    [    1.834196] virtio_rpmsg_bus virtio8: creating channel rpmsg_chrdev addr 0x4
    [    1.836752] virtio_rpmsg_bus virtio7: creating channel rpmsg-remote-service addr 0x37
    [    1.837479] virtio_rpmsg_bus virtio7: creating channel rpmsg_chrdev addr 0x4
    [    1.841433] virtio_rpmsg_bus virtio9: creating channel rpmsg-remote-service addr 0x37
    [    1.842133] virtio_rpmsg_bus virtio9: creating channel rpmsg_chrdev addr 0x4
    [    1.849387] virtio_rpmsg_bus virtio10: creating channel rpmsg-remote-service addr 0x37
    [    1.849443] virtio_rpmsg_bus virtio10: creating channel rpmsg_chrdev addr 0x4
    [    1.888236] virtio_rpmsg_bus virtio5: creating channel ti.ethfw.notifyservice addr 0x1e
    [    1.888638] virtio_rpmsg_bus virtio5: creating channel rpmsg-kdrv addr 0x1a
    [    1.889175] rpmsg-kdrv-eth-switch rpmsg-kdrv-1-mpu_1_0_ethmac-device-7: Device info: permissions: 3FFFFFFF uart_id: 2
    [    1.889180] rpmsg-kdrv-eth-switch rpmsg-kdrv-1-mpu_1_0_ethmac-device-7: FW ver 0.2 (rev 0) 29/Jun/2023 SHA:
    [    1.889213] rpmsg-kdrv-eth-switch rpmsg-kdrv-2-mpu_1_0_ethmac-device-8: Device info: permissions: 3FFFFFFF uart_id: 2
    [    1.889217] rpmsg-kdrv-eth-switch rpmsg-kdrv-2-mpu_1_0_ethmac-device-8: FW ver 0.2 (rev 0) 29/Jun/2023 SHA:
    [    1.909507] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac8: virt_cpsw_nuss mac loaded
    [    1.909513] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac8: rdev_features:00000007 rdev_mtu:1522 flow_id:114 tx_psil_dst_id:4A00 mac_only:8
    [    1.909517] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac8: local_mac_addr:00:00:00:00:00:00 rdev_mac_addr:70:ff:76:00:3e:a5
    [    1.929973] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac7: virt_cpsw_nuss mac loaded
    [    1.929978] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac7: rdev_features:00000007 rdev_mtu:1522 flow_id:115 tx_psil_dst_id:4A01 mac_only:7
    [    1.929982] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac7: local_mac_addr:00:00:00:00:00:00 rdev_mac_addr:70:ff:76:00:de:60
    [    2.023627] virtio_rpmsg_bus virtio5: creating channel ti.ipc4.ping-pong addr 0xe
    [    2.729515] NFSD: Using /var/lib/nfs/v4recovery as the NFSv4 state recovery directory
    [    2.729534] NFSD: Using legacy client tracking operations.
    [    2.729538] NFSD: starting 90-second grace period (net f0000081)
    [    3.381248] random: crng init done
    [    7.134759] PVR_K:  825: Read BVNC 36.53.104.796 from HW device registers
    [    7.134769] PVR_K:  825: RGX Device registered BVNC 36.53.104.796 with 1 core in the system
    [    7.135053] [drm] Initialized pvr 1.15.6133109 20170530 for 4e20000000.gpu on minor 0
    [    9.139748] PVR_K:  832: RGX Firmware image 'rgx.fw.36.53.104.796' loaded
    [    9.140887] PVR_K:  832: Shader binary image 'rgx.sh.36.53.104.796' loaded
    [    9.141508] PVR_K:  832: PVRSRVConnectKM: COMPAT_TEST: Client-side (0x0c10) (debug) and KM driver (0x0810) (release) build options differ.
    abnormal:
    ------------[ PVR DBG: START (High) ]------------
    OS kernel info: Linux 5.10.162-g76b3e88d56 #1 SMP PREEMPT Thu Jun 29 17:26:47 CST 2023 aarch64
    DDK info: Rogue_DDK_Linux_WS rogueddk 1.15@6133109 (release) j784s4_linux
    Time now: 14953779us
    Services State: OK
    Server Errors: 9
    Connections: No Devices: No active connections
    ------[ Driver Info ]------
    Comparison of UM/KM components: MATCHING
    KM Arch: 32 Bit
    UM info: 0.0 @        0 (debug) build options: 0x00000000
    KM info: 0.0 @        0 (debug) build options: 0x00000000
    Window system: wayland
    ------[ RGX Device ID:0 Start ]------
    ------[ RGX Info ]------
    Device Node (Info): 00000000f3a17e06 (00000000085b499a)
    RGX BVNC: 36.53.104.796 (rogue)
    RGX Device State: Bad
    RGX Power State: OFF
    FW info: UNINITIALIZED
    RGX FW State: OK (HWRState 0x00000000:)
    RGX FW Power State: RGXFWIF_POW_OFF (APM disabled: 0 ok, 0 denied, 0 non-idle, 0 retry, 0 other, 0 total. Latency: 100 ms)
    RGX DVFS: 0 frequency changes. Current frequency: 800.000 MHz (sampled at 9133159835 ns). FW frequency: 800.000 MHz.
    RGX FW OS 0 - State: offline; Freelists: Ok; Priority: 0; MTS on;
    FW-T0 Assert: bAllCCBOffsetsValid (firmware/rgxfw_utils.c:1425)
    Number of HWR: GP(0/0+0), 2D(0/0+0), TA(0/0+0), 3D(0/0+0), CDM(0/0+0), RAY(0/0+0), FALSE(0,0,0,0,0,0)
    DM 0 (GP)
    DM 1 (HWRflags 0x00000000: working;)
    DM 2 (HWRflags 0x00000000: working;)
    DM 3 (HWRflags 0x00000000: working;)
    DM 4 (HWRflags 0x00000000: working;)
    DM 5 (HWRflags 0x00000000: working;)
    RGX Kernel CCB WO:0x0 RO:0x0
    RGX Firmware CCB WO:0x0 RO:0x0
    RGX Kernel CCB commands executed = 0
    RGX SLR: Forced UFO updates requested = 0
    RGX Errors: WGP:0, TRP:0
    FW System config flags = 0x00120000 (Ctx switch options: Medium CSW profile; VDM CS INDEX mode; Assert on HWR;)
    FW OS config flags = 0x0000000F (Ctx switch: TDM; TA; 3D; CDM;)
     (!) RGX power is down. No registers dumped
    ------[ RGX FW Trace Info ]------
    Debug log type: none
    RGX FW thread 0: Trace buffer not yet allocated
    ------[ Full CCB Status ]------
    ------[ RGX Device ID:0 End ]------
    ------[ System Summary Device ID:0 ]------
    Device System Power State: ON
    MaxHWTOut: 500000us, WtTryCt: 10000, WDGTOut(on,off): (10000ms,3600000ms)
    ------[ Server Thread Summary ]------
      pvr_defer_free : Running
        Number of deferred cleanup items : 0
      pvr_device_wdg : Running
      pvr_cacheop : Running
        Configuration: QSZ: 16, UKT: -1, KDFT: 131072, LINESIZE: 64, PGSIZE: 4096, KDF: Yes, URBF: Yes
        Pending deferred CacheOp entries : 0
    ------[ AppHint Settings ]------
      Build Vars
        EnableTrustedDeviceAceConfig: N
        CleanupThreadPriority: 0x00000005
        CacheOpThreadPriority: 0x00000001
        WatchdogThreadPriority: 0x00000000
        HWPerfClientBufferSize: 0x000c0000
      Module Params
        none
      Debug Info Params
        CacheOpConfig: 0x0000000c
        CacheOpUMKMThresholdSize: 0xffffffff
      Debug Info Params Device ID: 0
        AssertOnHWRTrigger: Y
    ------[ HTB Log state: Off ]------
    ------[ Active Sync Checkpoints ]------
    ------[ Native Fence Sync: timelines ]------
    foreign_sync: @0 ctx=1 refs=1
    ------------[ PVR DBG: END ]------------
    abnormal_dmesg.log
    Thank you for your help
    Best regards !
    Alex
  • Alex,
    Could you please apply the attached patch to your GPU Kernel driver?
    https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/791/PP137113_5F00_CL6465208.patch
    You can apply it as follows:
    cd ti-processor-sdk-linux-j784s4-evm-08_06_00_12/board-support/extra-drivers/ti-img-rogue-driver-1.15.6133109
    patch -p1 < PP137113_CL6465208.patch
    Then rebuild and install the GPU Kernel driver with the following commands:
    make ti-img-rogue-driver
    sudo -E DESTDIR=/media/<username>/rootfs make ti-img-rogue-driver_install
    Please let me know the results, if you experience the same behavior please send me the abnormal logs.
    Erick
  • Erick, delay the GPU kernel module load to a later point of time by 15 second for instance during the Linux boot might be able to resolve this problem. However, need your investigation to see where the conflict happens. thanks.
  • Hello Xu,
    You have tried delaying the kernel module load by 15 seconds, and this is showing no issues in your system? Can you confirm this?
    Erick
  • Hello Xu,
    We are seeing this behavior as well, it looks like it might be related to the register values not updating properly due to cache or something else. We are investigation the issue to get you a concrete solution.
    Erick
  • Hello Xu,
    We currently load the driver with a delay of 20 seconds after startup, but this issue still occurs. Is the delay too long?
    Best regards !
    Alex
  • No i will not suggest to increase that much delay since which impacts booting time and doesn't make sense to add more.
    please keep the delay as 5s let's say.
    and another point is to check and change the atype of the GPU module (a set of groups for both WR and RD, i will assume there're 8 registers in total...), and my suggestion is to change those QoS registers for GPU from 00007000(or any other values) to 0x3000 0000 and have a check. (if 0x3000 0000 failed to make the GPU works, just change to 0x0000 0000). This changes SBL or SPL per your setup.
    Erick, yes this issue should be able to recreate by VH or VME and reported from other customers as well from EVM, so please investigate and provide a clean fix finally. thanks.
  • Hello Xu,
    We avoided this issue by modifying the Linux page size to 64KB (originally 4KB).  But we previously learned that with a 4KB page size, GPU runs more stably. For GPUs, how to choose the page size. If you have any suggestions, please let me know. Thank you very much.
    Best regards !
    Alex
  • Quan, that's great news, thanks! personally, i prefer the 64KB very much and also the old PSDK7.3 for VM is using 64KB page size and mass production very well.
    Erick, please follow up from here, appreciate. As i mentioned previously, with 64KB page size we don't see much PVR recovery issues like the 4KB did.
    For GPU, if you are on SDK 8.6, there is nothing you need to do to change the page size settings. The GPU driver has a feature called "unified page size" firmware that will choose the correct one based on your kernel's configured page size.
    Please let me know if you have issues with this.
    Erick
    Was this issue resolved? Do you have any details on what the issue was for our closed-loop analysis?
    Thank you,
    Erick
