hi,
i use mt9p031 and dvi board with leopard board.
i run gstreamer pipeline example in https://www.ridgerun.com/developer/wiki/index.php/LeopardBoard_365_GStreamer_Pipelines_-_SDK_2011Q2
gst-launch -e v4l2src always-copy=false ! video/x-raw-yuv,format=\(fourcc\)UYVY, width=1280, height=720, framerate=\(fraction\)23/1 ! dmaiaccel ! dmaiperf ! TIDmaiVideoSink videoOutput=DVI sync=false accelFrameCopy=true videoStd=720P_60
i get
Setting pipeline to PAUSED ...
davinci_resizer davinci_resizer.2: RSZ_G_CONFIG:0:1:124
vpfe-capture vpfe-capture: IPIPE Chained
vpfe-capture vpfe-capture: Resizer present
vpfe-capture vpfe-capture: standard not supported
Pipeline is live and does not need PREROLL ...
WARNING: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Failed to set norm for device '/dev/video0'.
Additional debug info:
../../../src/sys/v4l2/v4l2_calls.c(743): gst_v4l2_set_norm (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
system error: Invalid argument
WARNING: from element /GstPipeline:pipeline0/GstDmaiperf:dmaiperf0: Could not get/set settings from/on resource.
../../src/src/gsttidmaiperf.c(273): gst_dmaiperf_start (): /GstPipeline:pipeline0/GstDmaiperf:dmaiperf0:
Engine name not specified, not printing DSP information
WARNING: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Video input device did not accept new frame rate setting.
../../../src/sys/v4l2/v4l2output not found
src_calls.c(342): gst_v4l2src_set_capture (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
Setting pipeline to PLAYING ...
New clock: GstSystemClock
INFO:
Timestamp: 0:03:35.249418271; bps: 0; fps: 0;
ERROR: from element /GstPipeline:pipeline0/GstTIDmaiVideoSink:tidmaivideosink0: GStreamer encountered a general stream error.
../../src/src/gsttidmaivideosink.c(998): gst_tidmaivideosink_init_display (): /GstPipeline:pipeline0/GstTIDmaiVideoSink:tidm:
Failed to create display
Execution ended after 34635291 ns.
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
I follow steps in https://www.ridgerun.com/developer/wiki/index.php/DM365_Leopard_SDK_2011Q2_Getting_Started_Guide to setup my RR SDK and kernel on board.
what's wrong with me ?someone give me any help?
thanks a lot
