Part Number: SK-TDA4VM
I'm using SK-TDA4VM.
I want to connect OV5647 camera module to this product and capture the video.
However, a dtbo file for this camera module is not provided.
Below is a list of dtbo files in each path.
- - /boot/
Image k3-j721e-fpdlink-imx390-cm-0-2.dtbo k3-j721e-fpdlink-imx390-rcm-1-1.dtbo Image-5.10.162-g76b3e88d56 k3-j721e-fpdlink-imx390-cm-0-3.dtbo k3-j721e-fpdlink-imx390-rcm-1-2.dtbo fitImage k3-j721e-fpdlink-imx390-cm-1-0.dtbo k3-j721e-fpdlink-imx390-rcm-1-3.dtbo fitImage-5.10.162-g76b3e88d56 k3-j721e-fpdlink-imx390-cm-1-1.dtbo k3-j721e-fpdlink-sk-fusion.dtbo k3-j721e-common-proc-board-infotainment.dtbo k3-j721e-fpdlink-imx390-cm-1-2.dtbo k3-j721e-proc-board-tps65917.dtb k3-j721e-common-proc-board.dtb k3-j721e-fpdlink-imx390-cm-1-3.dtbo k3-j721e-sk-csi2-ov5640.dtbo k3-j721e-cpb-csi2-ov5640.dtbo k3-j721e-fpdlink-imx390-rcm-0-0.dtbo k3-j721e-sk-rpi-cam-imx219.dtbo k3-j721e-edgeai-apps.dtbo k3-j721e-fpdlink-imx390-rcm-0-1.dtbo k3-j721e-sk-rpi-hdr-ehrpwm.dtbo k3-j721e-fpdlink-cpb-fusion.dtbo k3-j721e-fpdlink-imx390-rcm-0-2.dtbo k3-j721e-sk.dtb k3-j721e-fpdlink-imx390-cm-0-0.dtbo k3-j721e-fpdlink-imx390-rcm-0-3.dtbo k3-j721e-vision-apps.dtbo k3-j721e-fpdlink-imx390-cm-0-1.dtbo k3-j721e-fpdlink-imx390-rcm-1-0.dtbo
- - ./{PSDK_LINUX_PATH}/board-support/prebuilt-images/\
bl31.bin k3-j721e-fpdlink-imx390-rcm-1-0.dtbo bl31.bin.signed k3-j721e-fpdlink-imx390-rcm-1-0.dtbo.sec bl32.bin k3-j721e-fpdlink-imx390-rcm-1-1.dtbo bl32.bin.signed k3-j721e-fpdlink-imx390-rcm-1-1.dtbo.sec boot-j7-evm.tar.gz k3-j721e-fpdlink-imx390-rcm-1-2.dtbo fitImage k3-j721e-fpdlink-imx390-rcm-1-2.dtbo.sec fitImage.its k3-j721e-fpdlink-imx390-rcm-1-3.dtbo Image k3-j721e-fpdlink-imx390-rcm-1-3.dtbo.sec Image-j7-evm.bin k3-j721e-fpdlink-sk-fusion.dtbo Image.sec k3-j721e-fpdlink-sk-fusion.dtbo.sec ipc_echo_testb_mcu1_0_release_strip.xer5f k3-j721e-proc-board-tps65917.dtb ipc_echo_testb_mcu1_0_release_strip.xer5f.signed k3-j721e-proc-board-tps65917.dtb.sec k3-j721e-common-proc-board.dtb k3-j721e-sk-csi2-ov5640.dtbo k3-j721e-common-proc-board.dtb.sec k3-j721e-sk-csi2-ov5640.dtbo.sec k3-j721e-common-proc-board-infotainment.dtbo k3-j721e-sk.dtb k3-j721e-common-proc-board-infotainment.dtbo.sec k3-j721e-sk.dtb.sec k3-j721e-cpb-csi2-ov5640.dtbo k3-j721e-sk-rpi-cam-imx219.dtbo k3-j721e-cpb-csi2-ov5640.dtbo.sec k3-j721e-sk-rpi-cam-imx219.dtbo.sec k3-j721e-edgeai-apps.dtbo k3-j721e-sk-rpi-hdr-ehrpwm.dtbo k3-j721e-edgeai-apps.dtbo.sec k3-j721e-sk-rpi-hdr-ehrpwm.dtbo.sec k3-j721e-fpdlink-cpb-fusion.dtbo k3-j721e-vision-apps.dtbo k3-j721e-fpdlink-cpb-fusion.dtbo.sec k3-j721e-vision-apps.dtbo.sec k3-j721e-fpdlink-imx390-cm-0-0.dtbo README k3-j721e-fpdlink-imx390-cm-0-0.dtbo.sec sysfw.itb k3-j721e-fpdlink-imx390-cm-0-1.dtbo tiboot3.bin k3-j721e-fpdlink-imx390-cm-0-1.dtbo.sec ti-fs-firmware-j721e-gp.bin k3-j721e-fpdlink-imx390-cm-0-2.dtbo ti-fs-firmware-j721e-hs-cert.bin k3-j721e-fpdlink-imx390-cm-0-2.dtbo.sec ti-fs-firmware-j721e-hs-enc.bin k3-j721e-fpdlink-imx390-cm-0-3.dtbo ti-fs-firmware-j721e_sr1_1-hs-cert.bin k3-j721e-fpdlink-imx390-cm-0-3.dtbo.sec ti-fs-firmware-j721e_sr1_1-hs-enc.bin k3-j721e-fpdlink-imx390-cm-1-0.dtbo ti-fs-firmware-j721e_sr2-hs-cert.bin k3-j721e-fpdlink-imx390-cm-1-0.dtbo.sec ti-fs-firmware-j721e_sr2-hs-enc.bin k3-j721e-fpdlink-imx390-cm-1-1.dtbo ti-fs-firmware-j721e_sr2-hs-fs-cert.bin k3-j721e-fpdlink-imx390-cm-1-1.dtbo.sec ti-fs-firmware-j721e_sr2-hs-fs-enc.bin k3-j721e-fpdlink-imx390-cm-1-2.dtbo tispl.bin k3-j721e-fpdlink-imx390-cm-1-2.dtbo.sec u-boot.img k3-j721e-fpdlink-imx390-cm-1-3.dtbo u-boot-spl.bin-j7-evm k3-j721e-fpdlink-imx390-cm-1-3.dtbo.sec uEnv_edgeai-apps.txt k3-j721e-fpdlink-imx390-rcm-0-0.dtbo uenv.txt k3-j721e-fpdlink-imx390-rcm-0-0.dtbo.sec uEnv.txt k3-j721e-fpdlink-imx390-rcm-0-1.dtbo uenv.txt.base k3-j721e-fpdlink-imx390-rcm-0-1.dtbo.sec uEnv.txt.base k3-j721e-fpdlink-imx390-rcm-0-2.dtbo uenv.txt.disp_sharing k3-j721e-fpdlink-imx390-rcm-0-2.dtbo.sec uenv.txt.jailhouse k3-j721e-fpdlink-imx390-rcm-0-3.dtbo uenv.txt.psdkra k3-j721e-fpdlink-imx390-rcm-0-3.dtbo.sec
- - {PSDK_LINUX_PATH}/board-support/linux*/arch/arm64/boot/dts/ti/
k3-am625.dtsi k3-am654-evm-ov5640.dts k3-j721e-fpdlink-imx390-cm-1-1.dts k3-am625-sk-csi2-ov5640.dts k3-am654-evm-tc358876.dts k3-j721e-fpdlink-imx390-cm-1-2.dts k3-am625-sk-csi2-tevi-ov5640.dts k3-am654-gp.dts k3-j721e-fpdlink-imx390-cm-1-3.dts k3-am625-sk.dts k3-am654-idk.dts k3-j721e-fpdlink-imx390-rcm-0-0.dts k3-am625-sk-ecap-capture.dts k3-am654-idk-sr1.dts k3-j721e-fpdlink-imx390-rcm-0-1.dts k3-am625-skeleton.dts k3-am654-industrial-thermal.dtsi k3-j721e-fpdlink-imx390-rcm-0-2.dts k3-am625-sk-hdmi-audio.dts k3-am654-pcie-usb2.dts k3-j721e-fpdlink-imx390-rcm-0-3.dts k3-am625-sk-lpmdemo.dts k3-am654-pcie-usb3.dts k3-j721e-fpdlink-imx390-rcm-1-0.dts k3-am625-sk-mcan.dts k3-am654-sr1.dts k3-j721e-fpdlink-imx390-rcm-1-1.dts k3-am625-sk-oldi-panel.dts k3-am65.dtsi k3-j721e-fpdlink-imx390-rcm-1-2.dts k3-am625-sk-qspi-flash.dts k3-am65-main.dtsi k3-j721e-fpdlink-imx390-rcm-1-3.dts k3-am625-sk-rpi-hdr-pwm.dts k3-am65-mcu.dtsi k3-j721e-fpdlink-sk-fusion.dts k3-am625-sk-rpi-hdr-spi.dts k3-am65-wakeup.dtsi k3-j721e-gesi-exp-board.dts k3-am62a7.dtsi k3-am68-sk-base-board.dts k3-j721e-main.dtsi k3-am62a7-fpdlink-ov2312-0-0.dts k3-am68-sk-bb-csi2-ov5640.dts k3-j721e-mcu-wakeup.dtsi k3-am62a7-fpdlink-ov2312-0-1.dts k3-am68-sk-bb-rpi-cam-imx219.dts k3-j721e-proc-board-tps65917.dts k3-am62a7-fpdlink-ov2312-0-2.dts k3-am68-sk-fpdlink-fusion.dts k3-j721e-quad-port-eth-exp.dts k3-am62a7-fpdlink-ov2312-0-3.dts k3-am68-sk-rpi-hdr-ehrpwm.dts k3-j721e-rtos-memory-map.dtsi k3-am62a7-fpdlink-sk-fusion.dts k3-am68-sk-som-ddr_mem_carveout.dts k3-j721e-sk-csi2-ov5640.dts k3-am62a7-sk-csi2-imx219.dts k3-am68-sk-som.dtsi k3-j721e-sk.dts k3-am62a7-sk.dts k3-am69-sk-csi2-ov5640.dts k3-j721e-sk-rpi-cam-imx219.dts k3-am62a.dtsi k3-am69-sk-ddr-mem-carveout.dts k3-j721e-sk-rpi-hdr-ehrpwm.dts k3-am62a-main.dtsi k3-am69-sk.dts k3-j721e-som-p0.dtsi k3-am62a-mcu.dtsi k3-am69-sk-fpdlink-fusion.dts k3-j721e-thermal.dtsi k3-am62a-thermal.dtsi k3-am69-sk-rpi-cam-imx219.dts k3-j721e-vision-apps.dts k3-am62a-wakeup.dtsi k3-am69-sk-rpi-hdr-ehrpwm.dts k3-j721s2-common-proc-board.dts k3-am62.dtsi k3-j7200-common-proc-board.dts k3-j721s2-common-proc-board-uarts.dts k3-am62-main.dtsi k3-j7200-common-proc-board-sr1.dts k3-j721s2-cpb-csi2-ov5640.dts k3-am62-mcu.dtsi k3-j7200-common-proc-board-uarts.dts k3-j721s2.dtsi k3-am62-thermal.dtsi k3-j7200.dtsi k3-j721s2-fpdlink-cpb-fusion.dts k3-am62-wakeup.dtsi k3-j7200-main.dtsi k3-j721s2-gesi-exp-board.dts k3-am62x-lp-sk.dts k3-j7200-mcspi-loopback.dts k3-j721s2-main.dtsi k3-am62x-lp-sk-nand.dts k3-j7200-mcu-wakeup.dtsi k3-j721s2-mcu-wakeup.dtsi k3-am62x-lp-sk-oldi-panel.dts k3-j7200-quad-port-eth-exp.dts k3-j721s2-som-p0.dtsi k3-am62x-sk-common.dtsi k3-j7200-som-p0.dtsi k3-j721s2-thermal.dtsi k3-am642.dtsi k3-j7200-sr1.dts k3-j784s4.dtsi k3-am642-evm.dts k3-j7200-thermal.dtsi k3-j784s4-evm-csi2-ov5640.dts k3-am642-evm-icssg1-dualemac.dts k3-j721e-common-proc-board.dts k3-j784s4-evm.dts k3-am642-evm-icssg1-dualemac-mii.dts k3-j721e-common-proc-board-infotainment.dts k3-j784s4-evm-uarts.dts k3-am642-evm-nand.dts k3-j721e-common-proc-board-uarts.dts k3-j784s4-exp1-exp2-usxgmii.dts k3-am642-sk.dts k3-j721e-cpb-csi2-ov5640.dts k3-j784s4-exp1-usxgmii.dts k3-am64.dtsi k3-j721e.dtsi k3-j784s4-exp2-usxgmii.dts k3-am64-main.dtsi k3-j721e-edgeai-apps.dts k3-j784s4-fpdlink-fusion.dts k3-am64-mcu.dtsi k3-j721e-fpdlink-cpb-fusion.dts k3-j784s4-main.dtsi k3-am64-thermal.dtsi k3-j721e-fpdlink-imx390-cm-0-0.dts k3-j784s4-mcu-wakeup.dtsi k3-am654-base-board.dts k3-j721e-fpdlink-imx390-cm-0-1.dts k3-j784s4-quad-port-eth1-exp.dts k3-am654-base-board-sr1.dts k3-j721e-fpdlink-imx390-cm-0-2.dts k3-j784s4-thermal.dtsi k3-am654.dtsi k3-j721e-fpdlink-imx390-cm-0-3.dts Makefile k3-am654-evm-oldi-lcd1evm.dts k3-j721e-fpdlink-imx390-cm-1-0.dts
I can't find the dtbo file for ov5647 anywhere I look.
I found the ov5647.dtbo file on my raspberry pie github, but it still doesn't recognize it, so it doesn't seem to be compatible with this file.
Ask for help.
Thank you in advance for your help.
