Part Number: AM625
Dear TI,
I'm trying to implement GPMC NAND boot on AM6252. After MMC boot, I could program NAND flash successfully.
During GPMC NAND boot, linux kernel stucks while acessing GPMC revision register[GPMC_nand_boot_kernel_stuck.log].
In case of MMC boot, kernel accesses GPMC revision register without problem[MMC_boot_kernel_access_GPMC_reg_OK.log].
Attached two logs for the reference.
Here are partial logs:
[ 10.975775] ti-sci 44043000.system-controller: lpm region is required for suspend but not provided.
[ 10.985118] ti-sci 44043000.system-controller: ABI: 3.1 (firmware rev 0x0008 '8.6.4--v08.06.04 (Chill Capybar')
[ 11.047032] davinci-mcasp 2b10000.mcasp: IRQ common not found
[ 11.055286] omap-gpmc 3b000000.memory-controller: GPMC revision 6.0
[ 10.974897] ti-sci 44043000.system-controller: lpm region is required for suspend but not provided.
[ 10.984231] ti-sci 44043000.system-controller: ABI: 3.1 (firmware rev 0x0008 '8.6.4--v08.06.04 (Chill Capybar')
[ 11.063101] davinci-mcasp 2b10000.mcasp: IRQ common not found
Currently I'm using ti-processor-sdk-linux-am62xx-evm-08.06.00.42.
Could you please let me know if this is known issue or there is any patch to solve this issue?
Honggi
U-Boot SPL 2021.01 (Jul 14 2023 - 17:06:14 +0900)
SYSFW ABI: 3.1 (firmware rev 0x0008 '8.6.4--v08.06.04 (Chill Capybar')
SPL initial stack usage: 13424 bytes
Trying to boot from MMC2
Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted
Loading Environment from MMC... *** Warning - No MMC card found, using default environment
Starting ATF on ARM64 core...
NOTICE: BL31: v2.8(release):v2.8-226-g2fcd408bb3-dirty
NOTICE: BL31: Built : 05:06:58, Feb 24 2023
U-Boot SPL 2021.01 (Jul 14 2023 - 17:05:43 +0900)
U-Boot 2021.01 (Jul 14 2023 - 17:05:43 +0900)
SoC: AM62X SR1.0 GP
Model: Texas Instruments AM625 SK
[CRZ] board/ti/am62x/evm.c (150) do_board_detect:
[CRZ] board/ti/common/board_detect.c (309) CRZ_set_board_header_and_name:
Board: AM62-SKEVM rev CRZ
DRAM: 1 GiB
NAND: 256 MiB
MMC: mmc@fa10000: 0, mmc@fa00000: 1, mmc@fa20000: 2
Loading Environment from MMC... MMC: block number 0x3500 exceeds max(0x2000)
*** Warning - !read failed, using default environment
In: serial@2800000
Out: serial@2800000
Err: serial@2800000
Net: eth0: ethernet@8000000port@1
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc1 is current device
SD/MMC found on device 1
Failed to load 'boot.scr'
Failed to load 'uEnv.txt'
19147264 bytes read in 765 ms (23.9 MiB/s)
40256 bytes read in 7 ms (5.5 MiB/s)
Loading Device Tree to 000000008fef3000, end 000000008fffffff ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 5.10.168-g2c23e6c538 (ubuntu@ubuntu) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT Thu Jul 13 22:35:47 KST 2023
[ 0.000000] Machine model: Texas Instruments AM625 SK
[ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[ 0.000000] printk: bootconsole [ns16550a0] enabled
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009c800000, size 3 MiB
[ 0.000000] OF: reserved mem: initialized node ipc-memories@9c800000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009cb00000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node m4f-dma-memory@9cb00000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009cc00000, size 14 MiB
[ 0.000000] OF: reserved mem: initialized node m4f-memory@9cc00000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009da00000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@9da00000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009db00000, size 12 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@9db00000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x00000000a0000000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node buffer@0, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000bfffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x000000009c7fffff]
[ 0.000000] node 0: [mem 0x000000009c800000-0x000000009e6fffff]
[ 0.000000] node 0: [mem 0x000000009e700000-0x000000009e77ffff]
[ 0.000000] node 0: [mem 0x000000009e780000-0x000000009fffffff]
[ 0.000000] node 0: [mem 0x00000000a0000000-0x00000000bfffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000bfffffff]
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 22 pages/cpu s51288 r8192 d30632 u90112
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: detected: ARM erratum 845719
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 258048
[ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=PARTUUID=366e505f-02 rw rootfstype=ext4 rootwait
[ 0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 689440K/1048576K available (11200K kernel code, 1162K rwdata, 4308K rodata, 1920K init, 431K bss, 96992K reserved, 262144K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 256 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
[ 0.000000] ITS [mem 0x01820000-0x0182ffff]
[ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @80800000 (flat, esz 8, psz 64K, shr 0)
[ 0.000000] ITS: using cache flushing for cmd queue
[ 0.000000] GICv3: using LPI property table @0x0000000080040000
[ 0.000000] GIC: using cache flushing for LPI property table
[ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000080050000
[ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[ 0.000004] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[ 0.008511] Console: colour dummy device 80x25
[ 0.013105] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[ 0.023787] pid_max: default: 32768 minimum: 301
[ 0.028589] LSM: Security Framework initializing
[ 0.033366] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
[ 0.040938] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
[ 0.050741] rcu: Hierarchical SRCU implementation.
[ 0.055935] Platform MSI: msi-controller@1820000 domain created
[ 0.062212] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created
[ 0.071446] EFI services will not be available.
[ 0.076333] smp: Bringing up secondary CPUs ...
[ 0.081601] Detected VIPT I-cache on CPU1
[ 0.081639] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
[ 0.081653] GICv3: CPU1: using allocated LPI pending table @0x0000000080060000
[ 0.081719] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 5.124358] CPU2: failed to come online
[ 5.153451] CPU2: failed in unknown state : 0x0
[ 10.261498] CPU3: failed to come online
[ 10.265418] CPU3: failed in unknown state : 0x0
[ 10.270114] smp: Brought up 1 node, 2 CPUs
[ 10.274313] SMP: Total of 2 processors activated.
[ 10.279129] CPU features: detected: 32-bit EL0 Support
[ 10.284396] CPU features: detected: CRC32 instructions
[ 10.297041] CPU: All CPU(s) started at EL2
[ 10.301249] alternatives: patching kernel code
[ 10.306894] devtmpfs: initialized
[ 10.316138] KASLR disabled due to lack of seed
[ 10.320907] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 10.330884] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 10.345235] pinctrl core: initialized pinctrl subsystem
[ 10.351254] DMI not present or invalid.
[ 10.355878] NET: Registered protocol family 16
[ 10.361937] DMA: preallocated 128 KiB GFP_KERNEL pool for atomic allocations
[ 10.369248] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 10.377258] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 10.385911] thermal_sys: Registered thermal governor 'step_wise'
[ 10.385916] thermal_sys: Registered thermal governor 'power_allocator'
[ 10.392441] cpuidle: using governor menu
[ 10.403334] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 10.410336] ASID allocator initialised with 65536 entries
[ 10.438136] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 10.445023] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 10.451877] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 10.458729] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 10.466673] cryptd: max_cpu_qlen set to 1000
[ 10.473988] k3-chipinfo 43000014.chipid: Family:AM62X rev:SR1.0 JTAGID[0x0bb7e02f] Detected
[ 10.483033] vcc_3v3_sys: supplied by vmain_pd
[ 10.487934] vcc_1v8: supplied by vcc_3v3_sys
[ 10.493234] iommu: Default domain type: Translated
[ 10.498646] SCSI subsystem initialized
[ 10.502874] mc: Linux media interface: v0.10
[ 10.507268] videodev: Linux video capture interface: v2.00
[ 10.512946] pps_core: LinuxPPS API ver. 1 registered
[ 10.518022] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 10.527379] PTP clock support registered
[ 10.531418] EDAC MC: Ver: 3.0.0
[ 10.535303] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fc9100
[ 10.542462] FPGA manager framework
[ 10.546046] Advanced Linux Sound Architecture Driver Initialized.
[ 10.553199] clocksource: Switched to clocksource arch_sys_counter
[ 10.559663] VFS: Disk quotas dquot_6.6.0
[ 10.563736] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 10.576059] NET: Registered protocol family 2
[ 10.580746] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 10.589213] tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 8192 bytes, linear)
[ 10.597797] TCP established hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 10.605771] TCP bind hash table entries: 8192 (order: 5, 131072 bytes, linear)
[ 10.613332] TCP: Hash tables configured (established 8192 bind 8192)
[ 10.620010] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 10.626808] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 10.634169] NET: Registered protocol family 1
[ 10.639114] RPC: Registered named UNIX socket transport module.
[ 10.645195] RPC: Registered udp transport module.
[ 10.650004] RPC: Registered tcp transport module.
[ 10.654813] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 10.661402] NET: Registered protocol family 44
[ 10.665960] PCI: CLS 0 bytes, default 64
[ 10.670683] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 10.682887] Initialise system trusted keyrings
[ 10.687632] workingset: timestamp_bits=46 max_order=18 bucket_order=0
[ 10.697957] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 10.704516] NFS: Registering the id_resolver key type
[ 10.709756] Key type id_resolver registered
[ 10.714033] Key type id_legacy registered
[ 10.718187] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 10.725041] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 10.732805] 9p: Installing v9fs 9p2000 file system support
[ 10.772884] Key type asymmetric registered
[ 10.777085] Asymmetric key parser 'x509' registered
[ 10.782112] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[ 10.789678] io scheduler mq-deadline registered
[ 10.794309] io scheduler kyber registered
[ 10.800354] pinctrl-single 4084000.pinctrl: 34 pins, size 136
[ 10.806701] pinctrl-single f4000.pinctrl: 171 pins, size 684
[ 10.819587] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[ 10.838682] brd: module loaded
[ 10.848783] loop: module loaded
[ 10.852903] megasas: 07.714.04.00-rc1
[ 10.860196] tun: Universal TUN/TAP device driver, 1.6
[ 10.865981] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 10.872399] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 10.878511] sky2: driver version 1.30
[ 10.883171] VFIO - User Level meta-driver version: 0.3
[ 10.889496] i2c /dev entries driver
[ 10.894726] sdhci: Secure Digital Host Controller Interface driver
[ 10.901082] sdhci: Copyright(c) Pierre Ossman
[ 10.905859] sdhci-pltfm: SDHCI platform and OF driver helper
[ 10.912626] ledtrig-cpu: registered to indicate activity on CPUs
[ 10.919098] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 10.927166] optee: probing for conduit method.
[ 10.931774] optee: revision 3.20 (8e74d476)
[ 10.932062] optee: dynamic shared memory is enabled
[ 10.941574] optee: initialized driver
[ 10.947196] NET: Registered protocol family 17
[ 10.951901] 9pnet: Installing 9P2000 support
[ 10.956348] Key type dns_resolver registered
[ 10.961123] Loading compiled-in X.509 certificates
[ 11.061765] gpmc_mem_init: disabling cs 0 mapped at 0x0-0x1000000
[ 11.069596] nand: device found, Manufacturer ID: 0xef, Chip ID: 0xda
[ 11.076110] nand: Winbond W29N02KV
[ 11.079589] nand: 256 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 128
[ 11.087424] omap2-nand 51000000.nand: using prefetch polled xfer mode
[ 11.094067] nand: using OMAP_ECC_BCH8_CODE_HW ECC scheme
[ 11.099502] platform 25010000.ecc: Unable to configure elm - device not probed?
[ 11.129628] pcf85363 0-0051: registered as rtc0
[ 11.134613] pcf85363 0-0051: setting system clock to 2023-07-14T09:03:49 UTC (1689325429)
[ 11.143110] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
[ 11.150252] omap_i2c 20010000.i2c: bus 1 rev0.12 at 100 kHz
[ 11.156504] ti-sci-intr 4210000.interrupt-controller: Interrupt Router 5 domain created
[ 11.164853] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
[ 11.174091] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
[ 11.183120] ti-udma 485c0100.dma-controller: Number of rings: 82
[ 11.191108] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18)
[ 11.202138] ti-udma 485c0000.dma-controller: Number of rings: 150
[ 11.211936] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
[ 11.222132] printk: console [ttyS2] disabled
[ 11.226576] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 27, base_baud = 3000000) is a 8250
[ 11.235347] printk: console [ttyS2] enabled
[ 11.243790] printk: bootconsole [ns16550a0] disabled
[ 11.255903] [drm] Initialized tidss 1.0.0 20180215 for 30200000.dss on minor 0
[ 11.269123] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode
[ 11.313202] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 11.322764] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver Qualcomm Atheros AR8035
[ 11.332005] davinci_mdio 8000f00.mdio: phy[1]: device 8000f00.mdio:01, driver Qualcomm Atheros AR8035
[ 11.341310] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01103, cpsw version 0x6BA81103 Ports: 3 quirks:00000006
[ 11.354240] am65-cpsw-nuss 8000000.ethernet: Use random MAC address
[ 11.360508] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
[ 11.367634] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
[ 11.374309] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:0
[ 11.384432] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
[ 11.394669] rtc-ti-k3 2b1f0000.rtc: registered as rtc1
[ 11.504028] pinctrl-single f4000.pinctrl: pin PIN36 already requested by 3b000000.memory-controller; cannot claim for 2b10000.mcasp
[ 11.504196] mmc0: CQHCI version 5.10
[ 11.515879] pinctrl-single f4000.pinctrl: pin-36 (2b10000.mcasp) status -22
[ 11.519877] mmc1: CQHCI version 5.10
[ 11.526394] pinctrl-single f4000.pinctrl: could not request pin 36 (PIN36) from group main-mcasp1-pins-default on device pinctrl-single
[ 11.526402] davinci-mcasp 2b10000.mcasp: Error applying setting, reverse things back
[ 11.549966] davinci-mcasp: probe of 2b10000.mcasp failed with error -22
[ 11.564328] nand: device found, Manufacturer ID: 0xef, Chip ID: 0xda
[ 11.569812] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
[ 11.570768] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
[ 11.585641] nand: Winbond W29N02KV
[ 11.589036] nand: 256 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 128
[ 11.596694] omap2-nand 51000000.nand: using prefetch polled xfer mode
[ 11.603182] nand: using OMAP_ECC_BCH8_CODE_HW ECC scheme
[ 11.608545] 7 fixed-partitions partitions found on MTD device omap2-nand.0
[ 11.615412] Creating 7 MTD partitions on "omap2-nand.0":
[ 11.620720] 0x000000000000-0x000000200000 : "NAND.tiboot3"
[ 11.628225] 0x000000200000-0x000000400000 : "NAND.tispl"
[ 11.628232] mmc1: new ultra high speed SDR104 SDHC card at address 59b4
[ 11.628896] mmcblk1: mmc1:59b4 USDU1 14.9 GiB
[ 11.641286] 0x000000400000-0x000000600000 : "NAND.tiboot3.backup"
[ 11.651654] mmcblk1: p1 p2
[ 11.652872] 0x000000600000-0x000000a00000 : "NAND.u-boot"
[ 11.662163] 0x000000a00000-0x000000a40000 : "NAND.u-boot-env"
[ 11.669053] 0x000000a40000-0x000000a80000 : "NAND.u-boot-env.backup"
[ 11.676444] 0x000000a80000-0x000010000000 : "NAND.file-system"
[ 11.748828] mmc0: Command Queue Engine enabled
[ 11.753293] mmc0: new HS200 MMC card at address 0001
[ 11.760641] mmcblk0: mmc0:0001 8GTF4R 7.28 GiB
[ 11.760720] debugfs: Directory 'pd:53' with parent 'pm_genpd' already present!
[ 11.765363] mmcblk0boot0: mmc0:0001 8GTF4R partition 1 4.00 MiB
[ 11.772554] debugfs: Directory 'pd:52' with parent 'pm_genpd' already present!
[ 11.778471] mmcblk0boot1: mmc0:0001 8GTF4R partition 2 4.00 MiB
[ 11.785557] debugfs: Directory 'pd:51' with parent 'pm_genpd' already present!
[ 11.798740] mmcblk0rpmb: mmc0:0001 8GTF4R partition 3 512 KiB, chardev (237:0)
[ 11.799035] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
[ 11.815847] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 11.832132] ALSA device list:
[ 11.835112] No soundcards found.
[ 11.879409] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[ 11.887608] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 11.896754] devtmpfs: mounted
[ 11.901062] Freeing unused kernel memory: 1920K
[ 11.905718] Run /sbin/init as init process
[ 12.250246] NET: Registered protocol family 10
[ 12.255794] Segment Routing with IPv6
[ 12.294369] systemd[1]: systemd 245.4-4ubuntu3.22 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 12.317398] systemd[1]: Detected architecture arm64.
Welcome to Ubuntu 20.04.6 LTS!
[ 12.354093] systemd[1]: Set hostname to <mango>.
[ 12.798555] random: systemd: uninitialized urandom read (16 bytes read)
[ 12.808032] systemd[1]: Created slice system-getty.slice.
[ OK ] Created slice system-getty.slice.
[ 12.829478] random: systemd: uninitialized urandom read (16 bytes read)
[ 12.837399] systemd[1]: Created slice system-modprobe.slice.
[ OK ] Created slice system-modprobe.slice.
[ 12.857381] random: systemd: uninitialized urandom read (16 bytes read)
[ 12.865157] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ 12.890580] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
[ 12.913725] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Started Dispatch Password …ts to Console Directory Watch.
[ 12.937538] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password R…uests to Wall Directory Watch.
[ 12.961436] systemd[1]: Condition check resulted in Arbitrary Executable File Formats File System Automount Point being skipped.
[ 12.973210] systemd[1]: Reached target Local Encrypted Volumes.
[ OK ] Reached target Local Encrypted Volumes.
[ 12.993496] systemd[1]: Reached target Slices.
[ OK ] Reached target Slices.
[ 13.009338] systemd[1]: Reached target Swap.
[ OK ] Reached target Swap.
[ 13.042574] systemd[1]: Listening on RPCbind Server Activation Socket.
[ OK ] Listening on RPCbind Server Activation Socket.
[ 13.066067] systemd[1]: Listening on fsck to fsckd communication Socket.
[ OK ] Listening on fsck to fsckd communication Socket.
[ 13.089652] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ OK ] Listening on initctl Compatibility Named Pipe.
[ 13.119703] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[ 13.128618] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 13.150013] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 13.165967] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ 13.185732] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 13.209563] systemd[1]: Mounting Huge Pages File System...
[ 13.230421] systemd[1]: Mounting POSIX Message Queue File System...
[ 13.257772] systemd[1]: Mounting RPC Pipe File System...
[ 13.277920] systemd[1]: Mounting Kernel Debug File System...
[ 13.293814] systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
[ 13.308433] systemd[1]: Starting Journal Service...
[ 13.331091] systemd[1]: Starting Create list of static device nodes for the current kernel...
Starting Create list of st…odes for the current kernel...
[ 13.370921] systemd[1]: Starting Load Kernel Module chromeos_pstore...
[ 13.393779] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[ 13.406788] systemd[1]: Starting Load Kernel Module efi_pstore...
[ 13.434418] systemd[1]: Starting Load Kernel Module pstore_blk...
[ 13.469938] systemd[1]: Starting Load Kernel Module pstore_zone...
[ 13.497874] systemd[1]: Starting Load Kernel Module ramoops...
[ 13.517740] systemd[1]: Started Nameserver information manager.
[ OK ] Started Nameserver information manager.
[ 13.548474] systemd[1]: Reached target Network (Pre).
[ OK ] Reached target Network (Pre).
[ 13.571645] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 13.581114] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 13.598713] systemd[1]: Starting Load Kernel Modules...
[ 13.622183] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 13.650233] systemd[1]: Starting udev Coldplug all Devices...
[ 13.653530] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
[ 13.680264] systemd[1]: Started Journal Service.
[ OK ] Started Journal Service.
[ OK ] Mounted Huge Pages File System.
[ OK ] Mounted POSIX Message Queue File System.
[ OK ] Mounted RPC Pipe File System.
[ OK ] Mounted Kernel Debug File System.
[ OK ] Finished Create list of st… nodes for the current kernel.
[ OK ] Finished Load Kernel Module chromeos_pstore.
[ OK ] Finished Load Kernel Module efi_pstore.
[ OK ] Finished Load Kernel Module pstore_blk.
[ OK ] Finished Load Kernel Module pstore_zone.
[ OK ] Finished Load Kernel Module ramoops.
[ OK ] Finished Load Kernel Modules.
[ OK ] Finished Remount Root and Kernel File Systems.
[ 13.955630] random: systemd: uninitialized urandom read (16 bytes read)
[ 13.957655] random: systemd-journal: uninitialized urandom read (16 bytes read)
Mounting Kernel Configuration File System...
[ 13.975880] random: systemd-journal: uninitialized urandom read (16 bytes read)
Starting Flush Journal to Persistent Storage...
Starting Load/Save Random Seed...
[ 14.040208] systemd-journald[184]: Received client request to flush runtime journal.
Starting Apply Kernel Variables...
Starting Create System Users...
[ OK ] Mounted Kernel Configuration File System.
[ OK ] Finished Create System Users.
[ OK ] Finished Apply Kernel Variables.
[ OK ] Finished udev Coldplug all Devices.
Starting Helper to synchronize boot up for ifupdown...
Starting Create Static Device Nodes in /dev...
[ OK ] Finished Helper to synchronize boot up for ifupdown.
[ OK ] Finished Load/Save Random Seed.
[ OK ] Finished Create Static Device Nodes in /dev.
[ OK ] Reached target Local File Systems (Pre).
[ OK ] Reached target Local File Systems.
Starting Raise network interfaces...
Starting Preprocess NFS configuration...
Starting udev Kernel Device Manager...
[ OK ] Finished Flush Journal to Persistent Storage.
[ OK ] Finished Preprocess NFS configuration.
[ OK ] Reached target NFS client services.
Starting Create Volatile Files and Directories...
[ OK ] Started udev Kernel Device Manager.
[ OK ] Finished Create Volatile Files and Directories.
Starting RPC bind portmap service...
Starting Network Name Resolution...
Starting Network Time Synchronization...
Starting Update UTMP about System Boot/Shutdown...
[ OK ] Started RPC bind portmap service.
[ OK ] Reached target Remote File Systems (Pre).
[ OK ] Reached target Remote File Systems.
[ OK ] Reached target RPC Port Mapper.
[ OK ] Finished Update UTMP about System Boot/Shutdown.
[ OK ] Finished Raise network interfaces.
[ OK ] Started Network Time Synchronization.
[ OK ] Reached target System Initialization.
[ OK ] Started resolvconf-pull-resolved.path.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target Paths.
[ OK ] Reached target System Time Set.
[ OK ] Reached target System Time Synchronized.
[ OK ] Started Daily apt download activities.
[ OK ] Started Daily apt upgrade and clean activities.
[ OK ] Started Periodic ext4 Onli…ata Check for All Filesystems.
[ OK ] Started Discard unused blocks once a week.
[ OK ] Started Message of the Day.
[ OK ] Reached target Timers.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
[ OK ] Started D-Bus System Message Bus.
Starting Remove Stale Onli…t4 Metadata Check Snapshots...
Starting Dispatcher daemon for systemd-networkd...
[ OK ] Started Set the CPU Frequency Scaling governor.
Starting Login Service...
[ OK ] Started Network Name Resolution.
[ OK ] Found device /dev/ttyS2.
[ OK ] Reached target Network.
[ OK ] Reached target Host and Network Name Lookups.
[ OK ] Started An object/document-oriented database.
Starting resolvconf-pull-resolved.service...
Starting OpenBSD Secure Shell server...
Starting Permit User Sessions...
[ OK ] Finished Remove Stale Onli…ext4 Metadata Check Snapshots.
[ OK ] Finished Permit User Sessions.
[ OK ] Started OpenBSD Secure Shell server.
[ OK ] Started Login Service.
[ OK ] Started Getty on tty1.
[ OK ] Started Serial Getty on ttyS2.
[ OK ] Reached target Login Prompts.
[ OK ] Started Unattended Upgrades Shutdown.
[ 19.005367] k3-m4-rproc 5000000.m4fss: configured M4 for remoteproc mode
[ 19.044149] remoteproc remoteproc0: request_firmware failed: -2
[ OK ] Finished resolvconf-pull-resolved.service.
[ OK ] Found device /sys/subsystem/net/devices/eth0.
[ OK ] Started ifup for eth0.
[ OK ] Found device /sys/subsystem/net/devices/eth1.
[ OK ] Started ifup for eth1.
[ 20.011433] platform 78000000.r5f: configured R5F for IPC-only mode
[ 20.114435] platform 78000000.r5f: R5F core initialized in IPC-only mode
[ OK ] Started Dispatcher daemon for systemd-networkd.
[ OK ] Reached target Multi-User System.
[ OK ] Reached target Graphical Interface.
Starting Update UTMP about System Runlevel Changes...
[ OK ] Finished Update UTMP about System Runlevel Changes.
Ubuntu 20.04.6 LTS mango ttyS2
mango login: [ 50.029930] hub 2-0:1.0: config failed, hub doesn't have any ports! (err -19)
U-Boot SPL 2021.01 (Jul 14 2023 - 17:06:14 +0900) SYSFW ABI: 3.1 (firmware rev 0x0008 '8.6.4--v08.06.04 (Chill Capybar') SPL initial stack usage: 13424 bytes Trying to boot from NAND Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted Loading Environment from MMC... *** Warning - No MMC card found, using default environment init_env from device 11 not supported! Starting ATF on ARM64 core... NOTICE: BL31: v2.8(release):v2.8-226-g2fcd408bb3-dirty NOTICE: BL31: Built : 05:06:58, Feb 24 2023 U-Boot SPL 2021.01 (Jul 14 2023 - 17:05:43 +0900) SYSFW ABI: 3.1 (firmware rev 0x0008 '8.6.4--v08.06.04 (Chill Capybar') Trying to boot from NAND U-Boot 2021.01 (Jul 14 2023 - 17:05:43 +0900) SoC: AM62X SR1.0 GP Model: Texas Instruments AM625 SK [CRZ] board/ti/am62x/evm.c (150) do_board_detect: [CRZ] board/ti/common/board_detect.c (309) CRZ_set_board_header_and_name: Board: AM62-SKEVM rev CRZ DRAM: 1 GiB NAND: 256 MiB MMC: mmc@fa10000: 0, mmc@fa00000: 1, mmc@fa20000: 2 Loading Environment from MMC... MMC: block number 0x3500 exceeds max(0x2000) *** Warning - !read failed, using default environment In: serial@2800000 Out: serial@2800000 Err: serial@2800000 [CRZ] board/ti/am62x/evm.c (150) do_board_detect: Net: eth0: ethernet@8000000port@1 Hit any key to stop autoboot: 0 MMC: no card present SD/MMC found on device 1 MMC: no card present MMC: no card present MMC: no card present MMC: no card present MMC: no card present libfdt fdt_check_header(): FDT_ERR_BADMAGIC No FDT memory address configured. Please configure the FDT address via "fdt addr <address>" command. Aborting! Bad Linux ARM64 Image magic! ubi0: attaching mtd7 ubi0: scanning is finished ubi0: attached mtd7 (name "NAND.file-system", size 245 MiB) ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 512 ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096 ubi0: good PEBs: 1964, bad PEBs: 0, corrupted PEBs: 0 ubi0: user volume: 1, internal volumes: 1, max. volumes count: 128 ubi0: max/mean erase counter: 23/11, WL threshold: 4096, image sequence number: 1082989470 ubi0: available PEBs: 0, total reserved PEBs: 1964, PEBs reserved for bad PEB handling: 40 Loading file '/boot/Image' to addr 0x82000000... Done Loading file '/boot/k3-am625-sk.dtb' to addr 0x88000000... Done ## Flattened Device Tree blob at 88000000 Booting using the fdt blob at 0x88000000 Loading Device Tree to 000000008fef3000, end 000000008fffffff ... OK Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] [ 0.000000] Linux version 5.10.168-g2c23e6c538 (ubuntu@ubuntu) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT Thu Jul 13 22:35:47 KST 2023 [ 0.000000] Machine model: Texas Instruments AM625 SK [ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '') [ 0.000000] printk: bootconsole [ns16550a0] enabled [ 0.000000] efi: UEFI not found. [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009c800000, size 3 MiB [ 0.000000] OF: reserved mem: initialized node ipc-memories@9c800000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009cb00000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node m4f-dma-memory@9cb00000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009cc00000, size 14 MiB [ 0.000000] OF: reserved mem: initialized node m4f-memory@9cc00000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009da00000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@9da00000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009db00000, size 12 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@9db00000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created CMA memory pool at 0x00000000a0000000, size 256 MiB [ 0.000000] OF: reserved mem: initialized node buffer@0, compatible id shared-dma-pool [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000080000000-0x00000000bfffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal empty [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000080000000-0x000000009c7fffff] [ 0.000000] node 0: [mem 0x000000009c800000-0x000000009e6fffff] [ 0.000000] node 0: [mem 0x000000009e700000-0x000000009e77ffff] [ 0.000000] node 0: [mem 0x000000009e780000-0x000000009fffffff] [ 0.000000] node 0: [mem 0x00000000a0000000-0x00000000bfffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000bfffffff] [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: Trusted OS migration not required [ 0.000000] psci: SMC Calling Convention v1.2 [ 0.000000] percpu: Embedded 22 pages/cpu s51288 r8192 d30632 u90112 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: detected: ARM erratum 845719 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 258048 [ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 earlycon=ns16550a,mmio32,0x02800000 ubi.mtd=NAND.file-system,2048 root=ubi0:rootfs rootfstype=ubifs [ 0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes, linear) [ 0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] Memory: 689440K/1048576K available (11200K kernel code, 1162K rwdata, 4308K rodata, 1920K init, 431K bss, 96992K reserved, 262144K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] Tracing variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 256 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] GICv3: Distributor has no Range Selector support [ 0.000000] GICv3: 16 PPIs implemented [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000 [ 0.000000] ITS [mem 0x01820000-0x0182ffff] [ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS [ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19 [ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @80800000 (flat, esz 8, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GICv3: using LPI property table @0x0000000080040000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000080050000 [ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns [ 0.000005] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns [ 0.008508] Console: colour dummy device 80x25 [ 0.013100] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000) [ 0.023780] pid_max: default: 32768 minimum: 301 [ 0.028582] LSM: Security Framework initializing [ 0.033357] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes, linear) [ 0.040929] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes, linear) [ 0.050739] rcu: Hierarchical SRCU implementation. [ 0.055926] Platform MSI: msi-controller@1820000 domain created [ 0.062199] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created [ 0.071430] EFI services will not be available. [ 0.076317] smp: Bringing up secondary CPUs ... [ 0.081573] Detected VIPT I-cache on CPU1 [ 0.081610] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000 [ 0.081624] GICv3: CPU1: using allocated LPI pending table @0x0000000080060000 [ 0.081688] CPU1: Booted secondary processor 0x0000000001 [0x410fd034] [ 5.124344] CPU2: failed to come online [ 5.153433] CPU2: failed in unknown state : 0x0 [ 10.261478] CPU3: failed to come online [ 10.265398] CPU3: failed in unknown state : 0x0 [ 10.270097] smp: Brought up 1 node, 2 CPUs [ 10.274295] SMP: Total of 2 processors activated. [ 10.279112] CPU features: detected: 32-bit EL0 Support [ 10.284378] CPU features: detected: CRC32 instructions [ 10.297014] CPU: All CPU(s) started at EL2 [ 10.301222] alternatives: patching kernel code [ 10.306868] devtmpfs: initialized [ 10.316088] KASLR disabled due to lack of seed [ 10.320860] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 10.330837] futex hash table entries: 1024 (order: 4, 65536 bytes, linear) [ 10.345151] pinctrl core: initialized pinctrl subsystem [ 10.351166] DMI not present or invalid. [ 10.355783] NET: Registered protocol family 16 [ 10.361841] DMA: preallocated 128 KiB GFP_KERNEL pool for atomic allocations [ 10.369149] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 10.377157] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 10.385803] thermal_sys: Registered thermal governor 'step_wise' [ 10.385808] thermal_sys: Registered thermal governor 'power_allocator' [ 10.392335] cpuidle: using governor menu [ 10.403220] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 10.410223] ASID allocator initialised with 65536 entries [ 10.437940] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages [ 10.444827] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages [ 10.451681] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [ 10.458532] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages [ 10.466487] cryptd: max_cpu_qlen set to 1000 [ 10.473762] k3-chipinfo 43000014.chipid: Family:AM62X rev:SR1.0 JTAGID[0x0bb7e02f] Detected [ 10.482784] vcc_3v3_sys: supplied by vmain_pd [ 10.487596] vcc_1v8: supplied by vcc_3v3_sys [ 10.492930] iommu: Default domain type: Translated [ 10.498262] SCSI subsystem initialized [ 10.502615] mc: Linux media interface: v0.10 [ 10.507004] videodev: Linux video capture interface: v2.00 [ 10.512689] pps_core: LinuxPPS API ver. 1 registered [ 10.517764] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 10.527114] PTP clock support registered [ 10.531158] EDAC MC: Ver: 3.0.0 [ 10.535047] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fc9100 [ 10.542183] FPGA manager framework [ 10.545772] Advanced Linux Sound Architecture Driver Initialized. [ 10.552928] clocksource: Switched to clocksource arch_sys_counter [ 10.559406] VFS: Disk quotas dquot_6.6.0 [ 10.563492] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 10.575830] NET: Registered protocol family 2 [ 10.580516] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear) [ 10.588990] tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 8192 bytes, linear) [ 10.597575] TCP established hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 10.605550] TCP bind hash table entries: 8192 (order: 5, 131072 bytes, linear) [ 10.613070] TCP: Hash tables configured (established 8192 bind 8192) [ 10.619753] UDP hash table entries: 512 (order: 2, 16384 bytes, linear) [ 10.626543] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear) [ 10.633898] NET: Registered protocol family 1 [ 10.638833] RPC: Registered named UNIX socket transport module. [ 10.644912] RPC: Registered udp transport module. [ 10.649744] RPC: Registered tcp transport module. [ 10.654553] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 10.661143] NET: Registered protocol family 44 [ 10.665699] PCI: CLS 0 bytes, default 64 [ 10.670422] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available [ 10.682578] Initialise system trusted keyrings [ 10.687335] workingset: timestamp_bits=46 max_order=18 bucket_order=0 [ 10.697526] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 10.704129] NFS: Registering the id_resolver key type [ 10.709357] Key type id_resolver registered [ 10.713636] Key type id_legacy registered [ 10.717794] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 10.724651] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [ 10.732400] 9p: Installing v9fs 9p2000 file system support [ 10.772535] Key type asymmetric registered [ 10.776735] Asymmetric key parser 'x509' registered [ 10.781761] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243) [ 10.789329] io scheduler mq-deadline registered [ 10.793961] io scheduler kyber registered [ 10.799992] pinctrl-single 4084000.pinctrl: 34 pins, size 136 [ 10.806322] pinctrl-single f4000.pinctrl: 171 pins, size 684 [ 10.819115] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled [ 10.838102] brd: module loaded [ 10.848183] loop: module loaded [ 10.852310] megasas: 07.714.04.00-rc1 [ 10.859521] tun: Universal TUN/TAP device driver, 1.6 [ 10.865297] igbvf: Intel(R) Gigabit Virtual Function Network Driver [ 10.871711] igbvf: Copyright (c) 2009 - 2012 Intel Corporation. [ 10.877820] sky2: driver version 1.30 [ 10.882474] VFIO - User Level meta-driver version: 0.3 [ 10.888761] i2c /dev entries driver [ 10.894026] sdhci: Secure Digital Host Controller Interface driver [ 10.900379] sdhci: Copyright(c) Pierre Ossman [ 10.905156] sdhci-pltfm: SDHCI platform and OF driver helper [ 10.911905] ledtrig-cpu: registered to indicate activity on CPUs [ 10.918364] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 10.926409] optee: probing for conduit method. [ 10.931014] optee: revision 3.20 (8e74d476) [ 10.931300] optee: dynamic shared memory is enabled [ 10.940809] optee: initialized driver [ 10.946478] NET: Registered protocol family 17 [ 10.951187] 9pnet: Installing 9P2000 support [ 10.955631] Key type dns_resolver registered [ 10.960398] Loading compiled-in X.509 certificates [ 10.974897] ti-sci 44043000.system-controller: lpm region is required for suspend but not provided. [ 10.984231] ti-sci 44043000.system-controller: ABI: 3.1 (firmware rev 0x0008 '8.6.4--v08.06.04 (Chill Capybar') [ 11.063101] davinci-mcasp 2b10000.mcasp: IRQ common not found ?
