J784S4XEVM: mmalib build failed
Part Number: J784S4XEVM
I am going to evaluate MMALIB  on the J784S4XEVM,I get the following error when I try to compile MMALIB in in ti-processor-sdk-rtos-j784s4-evm-08_06_01_03 :
make -j16 mmalib mmalib_cn common test TARGET_CPU=C7100 TARGET_BUILD=release CHECKPARAMS=1 SOC=J7AEP TEST_ENV=EVM
TARGET_CPU=C7100
find: ‘/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/common/c7100’: No such file or directory
find: ‘/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/test/c7100’: No such file or directory
find: ‘/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/cnn_c7xmma/MMALIB_CNN_deconvolve_row_ixX_ixX_oxX/c71’: No such file or directory
find: ‘/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/cnn_c7xmma/c71’: No such file or directory
find: ‘/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/cnn_c7xmma/MMALIB_CNN_deconvolveBias_row_ixX_ixX_oxX/c71’: No such file or directory
HOST_ROOT=/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00
HOST_COMPILER=CGT7X
HOST_OS=LINUX
HOST_CPU=x86_64
HOST_ARCH=64
TARGET_OS=NO_OS
TARGET_CPU=C7100
MMA_IMPLEMENTATION=HARDWARE
SOC=J7AEP
TEST_ENV=EVM
TARGET_PLATFORM=
TARGET_OUT=/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/out/C7100/release
TARGET_DOC=/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/out/docs
MODULES= common test mmalib mmalib_cn mmalib_d linker_cmd regress_linker_cmd regress mma_self_test
SCM_ROOT=
SCM_VERSION=
make: Nothing to be done for 'mmalib'.
make: Nothing to be done for 'mmalib_cn'.
Linking /home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/out/C7100/release/common_C7100.lib
  ==>  building archive '/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/out/C7100/release/common_C7100.lib'
Linking /home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/out/C7100/release/test_C7100.lib
  ==>  new archive '/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/out/C7100/release/test_C7100.lib'
  ==>  building archive '/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/out/C7100/release/test_C7100.lib'
  -->  error: '/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/out/C7100/release/module/test/test/TI_profile.obj' not found
  -->  error: '/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/out/C7100/release/module/test/test/TI_test.obj' not found
  -->  error: '/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/out/C7100/release/module/test/test/TI_memory.obj' not found
  -->  error: '/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/out/C7100/release/module/test/test/c71/TI_cache.obj' not found
concerto/finale.mak:119: recipe for target '/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/out/C7100/release/test_C7100.lib' failed
make: [/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/out/C7100/release/test_C7100.lib] Error 1 (ignored)
how to fix?
By the way, J784S4's c71 core is C7100 or C7120 ? and which version MMA is used?
Thanks.
  • The c71 core on this device is, according to my notes, a C7120 and the SOC is a J7AHP, so please try the build with the TARGET_CPU and SOC options as follows:
    make -j16 mmalib mmalib_cn common test TARGET_CPU=C7120 TARGET_BUILD=release CHECKPARAMS=1 SOC=J7AHP TEST_ENV=EVM
  • Hi William,
    Thank you for your reply, but the problem remains.
  • Please post the build output as was done above.  While the build may still be failing, it cannot be failing in the same way as above with the new parameters.
  • Hi Willian, build output is :
    TARGET_CPU=C7120
    find: ‘/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/cnn_c7xmma/MMALIB_CNN_convolve_col_smallNo_highPrecision/c71’: No such file or directory
    find: ‘/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/cnn_c7xmma/MMALIB_CNN_convolve_col_smallNo_legacy_ixX_ixX_oxX/c71’: No such file or directory
    find: ‘/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/cnn_c7xmma/MMALIB_CNN_convolve_row_ixX_ixX_oxX/c71’: No such file or directory
    find: ‘/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/cnn_c7xmma/MMALIB_CNN_fullyConnected_ixX_ixX_oxX/c71’: No such file or directory
    find: ‘/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/cnn_c7xmma/MMALIB_CNN_convolveBias_row_ixX_ixX_oxX/c71’: No such file or directory
    find: ‘/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/cnn_c7xmma/MMALIB_CNN_fullyConnectedBias_ixX_ixX_oxX/c71’: No such file or directory
    find: ‘/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/cnn_c7xmma/MMALIB_CNN_tensor_convert_ixX_oxX/c71’: No such file or directory
    find: ‘/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/cnn_c7xmma/MMALIB_CNN_convolve_col_smallNo_ixX_ixX_oxX/c71’: No such file or directory
    find: ‘/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/cnn_c7xmma/MMALIB_CNN_pixelShuffle_row_ixX_ixX_oxX/c71’: No such file or directory
    find: ‘/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/dsp_c7xmma/MMALIB_DSP_fir_ixX_ixX_oxX/c71’: No such file or directory
    find: ‘/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/dsp_c7xmma/c71’: No such file or directory
    find: ‘/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/dsp_c7xmma/MMALIB_DSP_firSmall_ixX_ixX_oxX/c71’: No such file or directory
    find: ‘/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/fft_c7xmma/MMALIB_FFT_dftLarge_ixX_cxX_oxX/c71’: No such file or directory
    find: ‘/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/fft_c7xmma/MMALIB_FFT_dftSmall_ixX_cxX_oxX/c71’: No such file or directory
    find: ‘/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/fft_c7xmma/MMALIB_FFT_fft_ixX_cxX_oxX/c71’: No such file or directory
    find: ‘/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/fft_c7xmma/c71’: No such file or directory
    find: ‘/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/fft_c7xmma/MMALIB_FFT_highRadixDecompositions_ixX_cxX_oxX/c71’: No such file or directory
    find: ‘/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/linalg_c7xmma/MMALIB_LINALG_matrixTranspose_ixX_oxX/c71’: No such file or directory
    find: ‘/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/linalg_c7xmma/MMALIB_LINALG_pointwiseMatrixMatrixMultiply_ixX_ixX_oxX/c71’: No such file or directory
    find: ‘/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/linalg_c7xmma/c71’: No such file or directory
    find: ‘/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/linalg_c7xmma/MMALIB_LINALG_matrixMatrixMultiply_ixX_ixX_oxX/c71’: No such file or directory
    find: ‘/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/linalg_c7xmma/MMALIB_LINALG_matrixMatrixMultiplyAccumulate_ixX_ixX_ixX_oxX/c71’: No such file or directory
    find: ‘/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/fft_c7x/MMALIB_fft1d_i32fc_c32fc_o32fc/c71’: No such file or directory
    find: ‘/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/fft_c7x/MMALIB_fft1dBatched_i16sc_c16sc_o16sc/c71’: No such file or directory
    find: ‘/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/fft_c7x/MMALIB_fft1d_i16sc_c16sc_o16sc/c71’: No such file or directory
    find: ‘/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/fft_c7x/MMALIB_fft1dBatched_i32fc_c32fc_o32fc/c71’: No such file or directory
    find: ‘/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/fft_c7x/c71’: No such file or directory
    find: ‘/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/cnn_c7xmma/MMALIB_CNN_convolve_col_smallNo_highPrecision/c7120’: No such file or directory
    find: ‘/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/cnn_c7xmma/MMALIB_CNN_convolve_col_smallNo_legacy_ixX_ixX_oxX/c7120’: No such file or directory
    find: ‘/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/cnn_c7xmma/MMALIB_CNN_deconvolve_row_ixX_ixX_oxX/c7120’: No such file or directory
    find: ‘/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/cnn_c7xmma/c7120’: No such file or directory
    find: ‘/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/cnn_c7xmma/MMALIB_CNN_deconvolveBias_row_ixX_ixX_oxX/c7120’: No such file or directory
    find: ‘/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/cnn_c7xmma/MMALIB_CNN_convolve_row_ixX_ixX_oxX/c7120’: No such file or directory
    find: ‘/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/cnn_c7xmma/MMALIB_CNN_fullyConnected_ixX_ixX_oxX/c7120’: No such file or directory
    find: ‘/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/cnn_c7xmma/MMALIB_CNN_convolveBias_row_ixX_ixX_oxX/c7120’: No such file or directory
    find: ‘/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/cnn_c7xmma/MMALIB_CNN_fullyConnectedBias_ixX_ixX_oxX/c7120’: No such file or directory
    find: ‘/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/cnn_c7xmma/MMALIB_CNN_tensor_convert_ixX_oxX/c7120’: No such file or directory
    find: ‘/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/cnn_c7xmma/MMALIB_CNN_convolve_col_smallNo_ixX_ixX_oxX/c7120’: No such file or directory
    find: ‘/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/cnn_c7xmma/MMALIB_CNN_pixelShuffle_row_ixX_ixX_oxX/c7120’: No such file or directory
    find: ‘/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/dsp_c7xmma/MMALIB_DSP_fir_ixX_ixX_oxX/c7120’: No such file or directory
    find: ‘/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/dsp_c7xmma/c7120’: No such file or directory
    find: ‘/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/dsp_c7xmma/MMALIB_DSP_firSmall_ixX_ixX_oxX/c7120’: No such file or directory
    find: ‘/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/fft_c7xmma/MMALIB_FFT_dftLarge_ixX_cxX_oxX/c7120’: No such file or directory
    find: ‘/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/fft_c7xmma/MMALIB_FFT_dftSmall_ixX_cxX_oxX/c7120’: No such file or directory
    find: ‘/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/fft_c7xmma/MMALIB_FFT_fft_ixX_cxX_oxX/c7120’: No such file or directory
    find: ‘/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/fft_c7xmma/c7120’: No such file or directory
    find: ‘/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/fft_c7xmma/MMALIB_FFT_highRadixDecompositions_ixX_cxX_oxX/c7120’: No such file or directory
    find: ‘/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/linalg_c7xmma/MMALIB_LINALG_matrixTranspose_ixX_oxX/c7120’: No such file or directory
    find: ‘/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/linalg_c7xmma/MMALIB_LINALG_pointwiseMatrixMatrixMultiply_ixX_ixX_oxX/c7120’: No such file or directory
    find: ‘/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/linalg_c7xmma/c7120’: No such file or directory
    find: ‘/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/linalg_c7xmma/MMALIB_LINALG_matrixMatrixMultiply_ixX_ixX_oxX/c7120’: No such file or directory
    find: ‘/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/linalg_c7xmma/MMALIB_LINALG_matrixMatrixMultiplyAccumulate_ixX_ixX_ixX_oxX/c7120’: No such file or directory
    find: ‘/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/fft_c7x/MMALIB_fft1d_i32fc_c32fc_o32fc/c7120’: No such file or directory
    find: ‘/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/fft_c7x/MMALIB_fft1dBatched_i16sc_c16sc_o16sc/c7120’: No such file or directory
    find: ‘/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/fft_c7x/MMALIB_fft1d_i16sc_c16sc_o16sc/c7120’: No such file or directory
    find: ‘/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/fft_c7x/MMALIB_fft1dBatched_i32fc_c32fc_o32fc/c7120’: No such file or directory
    find: ‘/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/fft_c7x/c7120’: No such file or directory
    HOST_COMPILER=CGT7X
    HOST_OS=LINUX
    HOST_CPU=x86_64
    HOST_ARCH=64
    TARGET_OS=NO_OS
    TARGET_CPU=C7120
    SOC=J7AHP
    TEST_ENV=EVM
    TARGET_PLATFORM=
    TARGET_OUT=/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/out/C7120/release
    SCM_ROOT=
    SCM_VERSION=
    make: Nothing to be done for 'common'.
    Linking /home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/out/C7120/release/test_C7120.lib
      ==>  new archive '/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/out/C7120/release/test_C7120.lib'
      ==>  building archive '/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/out/C7120/release/test_C7120.lib'
      -->  error: '/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/out/C7120/release/module/test/test/TI_profile.obj' not found
      -->  error: '/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/out/C7120/release/module/test/test/TI_test.obj' not found
      -->  error: '/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/out/C7120/release/module/test/test/TI_memory.obj' not found
      -->  error: '/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/out/C7120/release/module/test/test/c71/TI_cache.obj' not found
    concerto/finale.mak:119: recipe for target '/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/out/C7120/release/test_C7120.lib' failed
    make: [/home/lrz/ti/tda4vh-rtos/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/out/C7120/release/test_C7120.lib] Error 1 (ignored)
    Thanks.
  • Hello.  Looks like we got started in the wrong direction.  The MMALIB documentation is poor in this regard.  I'll look into updating that, but for now, here's what is going on.
    1. The command you used (which came from MMALIB user guide; again poor documentation on our part) is for compiling MMALIB *from source code*.
    2. MMALIB source code is not released; instead the compiled library is released as a binary package
    3. The user guide does have an example command for building a test case using the binary package, but it's hiding near the bottom of the bulleted list in the user guide (whereas it should be the only thing present!)
    Please try this command, which I verified built on a clean local copy of processor SDK.  This particular command will run a matrix-matrix multiply example using the MMALIB binary package.
    make scrub; make -j12 TARGET_CPU=C7120 LINK_LIBS=1 linalg_c7xmma/MMALIB_LINALG_matrixMatrixMultiply_ixX_ixX_oxX TEST_CASE=1000 TEST_ENV=EVM CHECKPARAMS=1 SOC=J7AHP
    Let me know how it goes.
    Using this command compiles successfully, but the warning ‘find: ‘.../c71’: No such file or directory’still exists .
    And could you provide the source code of MMALIB?
    Thanks.
  • Hi, that "warning" is always there - it's a normal part of the build.
    No, I cannot provide the MMALIB source code.
    Is there any way to get the source code?
    Thanks.
  • The MMA is intended to be accessed through MMALIB; the source code is not shared at this time.
