TDA4VM: CCS debug SBL failed
Part Number: TDA4VM
Hi team,
SDK: ti-processor-sdk-rtos-j721e-evm-08_01_00_13
Development board: tda4vm
The customer is trying to boot with the SD card via SBL, but there is no log output when power-up. Referenced this link https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1121933/faq-tda4vm-debugging-sbl-boot-in-rtos-sdk?tisearch=e2e-sitesearch&keymatch=faq%3Atrue , CCS was found unable to halt to SBL, and the customer checked SBL memory to see if it used the memory only for ROM code, but they found no memory out of bounds.
The map file is as follows:
https://e2echina.ti.com/cfs-file/__key/communityserver-discussions-components-files/120/sbl_5F00_mmcsd_5F00_img_5F00_mcu1_5F00_0_5F00_release.xer5f.map
tiboot3.bin file is here:
https://e2echina.ti.com/cfs-file/__key/communityserver-discussions-components-files/120/sbl_5F00_mmcsd_5F00_img_5F00_mcu1_5F00_0_5F00_release.bin
Could you please help check this case? Thanks.
Cherry
  • Hi Cherry,
    I believe this is TI EVM right? Can you please share the boot mode settings you are using?
    Also, can you please share the code modified to halt the SBL with CCS.
    Parth
  • Hi Parth,
    Yes, This is TI EVM.
    Boot mode seting is: I tried using both the NO BOOT mode and the SD BOOT mode.
    CODE:
     *  \file   sbl_main.c
     *  \brief  This file contain main function, call the Board Initialization
     *          functions & slave core boot-up functions in sequence.
     * Copyright (C) 2018-2019 Texas Instruments Incorporated - http://www.ti.com/
     * Redistribution and use in source and binary forms, with or without
     * modification, are permitted provided that the following conditions
     * are met:
     * Redistributions of source code must retain the above copyright
     * notice, this list of conditions and the following disclaimer.
     * Redistributions in binary form must reproduce the above copyright
     * notice, this list of conditions and the following disclaimer in the
     * documentation and/or other materials provided with the
     * distribution.
     * Neither the name of Texas Instruments Incorporated nor the names of
     * its contributors may be used to endorse or promote products derived
     * from this software without specific prior written permission.
     * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
     * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
     * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
     * A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
     * OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
     * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
     * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
     * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
     * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
     * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
     * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
     /* TI RTOS header files */
    #include "sbl_main.h"
    #include <ti/csl/cslr_gtc.h>
     ************************** Macros ************************************
     ************************** Internal functions ************************
     ************************** Global Variables **************************
    extern sblProfileInfo_t sblProfileLog[MAX_PROFILE_LOG_ENTRIES];
    extern uint32_t sblProfileLogIndx;
    extern uint32_t sblProfileLogOvrFlw;
    volatile sblProfileInfo_t * sblProfileLogAddr __attribute__((section(".sbl_profile_info")));
    volatile uint32_t *sblProfileLogIndxAddr __attribute__((section(".sbl_profile_info")));
    volatile uint32_t *sblProfileLogOvrFlwAddr __attribute__((section(".sbl_profile_info")));
    sblEntryPoint_t k3xx_evmEntry;
    #if defined(SOC_AM64X)
    const CSL_ArmR5MpuRegionCfg gCslR5MpuCfg[CSL_ARM_R5F_MPU_REGIONS_MAX] =
            /* Region 0 configuration: complete 32 bit address space = 4Gbits */
            .regionId         = 0U,
            .enable           = 1U,
            .baseAddr         = 0x0U,
            .size             = CSL_ARM_R5_MPU_REGION_SIZE_4GB,
            .subRegionEnable  = CSL_ARM_R5_MPU_SUB_REGION_ENABLE_ALL,
            .exeNeverControl  = 1U,
            .accessPermission = CSL_ARM_R5_ACC_PERM_PRIV_USR_RD_WR,
            .shareable        = 0U,
            .cacheable        = (uint32_t)FALSE,
            .cachePolicy      = 0U,
            .memAttr          = 0U,
            /* Region 1 configuration: 64K bytes ATCM for exception vector execution */
            .regionId         = 1U,
            .enable           = 1U,
            .baseAddr         = 0x0U,
            .size             = CSL_ARM_R5_MPU_REGION_SIZE_32KB,
            .exeNeverControl  = 0U,
            .shareable        = 0U,
            .cacheable        = (uint32_t)TRUE,
            .cachePolicy      = CSL_ARM_R5_CACHE_POLICY_NON_CACHEABLE,
            .memAttr          = 0U,
            /* Region 2 configuration: 2 MB MCMS3 RAM */
            .regionId         = 2U,
            .enable           = 1U,
            .baseAddr         = 0x70000000,
            .size             = CSL_ARM_R5_MPU_REGION_SIZE_2MB,
            .shareable        = 0U,
            .cachePolicy      = CSL_ARM_R5_MEM_ATTR_CACHED_WT_NO_WA,
            .memAttr          = 0U,
            /* Region 3 configuration: 2 GB DDR RAM */
            .regionId         = 3U,
            .enable           = 1U,
            .baseAddr         = 0x80000000,
            .size             = CSL_ARM_R5_MPU_REGION_SIZE_2GB,
            .shareable        = 0U,
            .memAttr          = 0U,
            /* Region 4 configuration: 64 KB BTCM */
            .regionId         = 4U,
            .enable           = 1U,
            .baseAddr         = 0x41010000,
            .shareable        = 0U,
            .memAttr          = 0U,
            /* Region 5 configuration: 128 MB FSS DAT0 */
            .regionId         = 5U,
            .enable           = 1U,
            .baseAddr         = 0x60000000,
            .size             = CSL_ARM_R5_MPU_REGION_SIZE_128MB,
            .shareable        = 0U,
            .memAttr          = 0U,
            /* Region 6 configuration (Non-cached for PHY tuning data): Covers last 256KB of EVM Flash (FSS DAT0) */
            .regionId         = 6U,
            .enable           = 1U,
            .baseAddr         = 0x63FC0000,
            .size             = CSL_ARM_R5_MPU_REGION_SIZE_256KB,
            .shareable        = 0U,
            /* OSPI PHY tuning algorithm which runs in DAC mode needs
             * cache to be disabled for this section of FSS data region.
            .cachePolicy      = 0U,
            .memAttr          = 0U,
            /* Region 7 configuration: Covers the M4F memory regions */
            .regionId         = 7U,
            .enable           = 1U,
            .baseAddr         = 0x5000000,
            .size             = CSL_ARM_R5_MPU_REGION_SIZE_512KB,
            .shareable        = 0U,
            .memAttr          = 0U,
    #else
            .regionId         = 0U,
            .enable           = 1U,
            .baseAddr         = 0x0U,
            .shareable        = 0U,
            .cachePolicy      = 0U,
            .memAttr          = 0U,
            /* Region 1 configuration: 128 bytes memory for exception vector execution */
            .regionId         = 1U,
            .enable           = 1U,
            .baseAddr         = 0x0U,
            .shareable        = 0U,
            .memAttr          = 0U,
            /* Region 2 configuration: 1 MB OCMS RAM - Covers RAM sizes for multiple SoCs */
            .regionId         = 2U,
            .enable           = 1U,
            .baseAddr         = 0x41C00000,
            .size             = CSL_ARM_R5_MPU_REGION_SIZE_1MB,
            .shareable        = 0U,
            .memAttr          = 0U,
            /* Region 3 configuration: 2 MB MCMS3 RAM */
            .regionId         = 3U,
            .enable           = 1U,
            .size             = CSL_ARM_R5_MPU_REGION_SIZE_8MB,
            .shareable        = 0U,
            .memAttr          = 0U,
            /* Region 4 configuration: 2 GB DDR RAM */
            .regionId         = 4U,
            .enable           = 1U,
            .shareable        = 0U,
            .memAttr          = 0U,
            /* Region 5 configuration: 64 KB BTCM */
            .regionId         = 5U,
            .enable           = 1U,
            .shareable        = 0U,
            .memAttr          = 0U,
            /* Region 6 configuration: Covers first 64MB of EVM Flash (FSS DAT0) */
            .regionId         = 6U,
            .enable           = 1U,
            .baseAddr         = 0x50000000,
            .size             = CSL_ARM_R5_MPU_REGION_SIZE_64MB,
            .shareable        = 0U,
            .cachePolicy      = CSL_ARM_R5_CACHE_POLICY_WB_WA,
            .memAttr          = 0U,
            /* Region 14 configuration (Non-cached for PHY tuning data): Covers last 256KB of EVM Flash (FSS DAT0) */
            .regionId         = 7U,
            .enable           = 1U,
    #if defined(SOC_J7200)
            .baseAddr         = 0x53FC0000,
    #else
            .baseAddr         = 0x53FE0000,
            .size             = CSL_ARM_R5_MPU_REGION_SIZE_128KB,
    #endif
            .shareable        = 0U,
            .cachePolicy      = 0U,
            .memAttr          = 0U,
            /* Region 15 configuration: 128 MB FSS DAT1 */
            .regionId         = 8U,
            .enable           = 1U,
            .baseAddr         = 0x58000000,
            .shareable        = 0U,
            .memAttr          = 0U,
    #if defined(SOC_J721E)
            /* Region 9 configuration: 512KB Main OCMRAM - no need for mapping */
            .regionId         = 9U,
            .enable           = 1U,
            .baseAddr         = 0x03600000,
            .shareable        = 0U,
            .memAttr          = 0U,
    #endif
    #if defined(SBL_OCM_MAIN_DOMAIN_RAT) && defined(SOC_J7200)
            /* Region 10 configuration: 512KB Virtually Mapped Main OCMRAM */
            .regionId         = 10U,
            .enable           = 1U,
            .baseAddr         = 0xD0000000,
            .shareable        = 0U,
            .memAttr          = 0U,
    #endif
    volatile int ccsHalt = 1;
    #endif
    int main()
        while(ccsHalt);
    #if defined(SBL_ENABLE_HLOS_BOOT) && (defined(SOC_J721E) || defined(SOC_J7200))
        cpu_core_id_t core_id;
    #endif
        uint32_t atcm_size;
        SBL_ADD_PROFILE_POINT;
        /* Any SoC specific Init. */
        SBL_SocEarlyInit();
        if (SBL_LOG_LEVEL > SBL_LOG_ERR)
            /* Configure UART Tx pinmux. */
            Board_uartTxPinmuxConfig();
        if (SBL_LOG_LEVEL > SBL_LOG_NONE)
            UART_HwAttrs uart_cfg;
            UART_socGetInitCfg(BOARD_UART_INSTANCE, &uart_cfg);
            /* Use UART fclk freq setup by ROM */
            uart_cfg.frequency = SBL_ROM_UART_MODULE_INPUT_CLK;
            /* Disable the UART interrupt */
            uart_cfg.enableInterrupt = FALSE;
            UART_socSetInitCfg(BOARD_UART_INSTANCE, &uart_cfg);
            /* Init UART for logging. */
            UART_stdioInit(BOARD_UART_INSTANCE);
        SBL_log(SBL_LOG_MIN, "%s (%s - %s)\n", SBL_VERSION_STR, __DATE__, __TIME__);
        /* Initialize the ATCM */
        atcm_size = sblAtcmSize();
        memset((void *)SBL_MCU_ATCM_BASE, 0xFF, atcm_size);
        /* Relocate CSL Vectors to ATCM*/
        memcpy((void *)SBL_MCU_ATCM_BASE, (void *)_resetvectors, 0x100);
        /* Setup RAT to load data into MCU2_0 OCM RAM for MCU1_0 */
        /* This is mapping the OCM RAM for MCU2_0 (a 40 bit address) Main domain to 0xD0000000 */
        SBL_log(SBL_LOG_MAX, "Initializing RAT ...");
    #define RAT_BASE (0x40F90000)
    #define REGION_ID (0x0)
        *(unsigned int *)(RAT_BASE + 0x44 + (REGION_ID*0x10)) = 0xD0000000; //IN ADDRESS
        *(unsigned int *)(RAT_BASE + 0x48 + (REGION_ID*0x10)) = 0x02000000;
        *(unsigned int *)(RAT_BASE + 0x4C + (REGION_ID*0x10)) = 0x0000004F; //Upper 16 bits of the real physical address.
        *(unsigned int *)(RAT_BASE + 0x40 + (REGION_ID*0x10)) = 0x80000013;
        SBL_log(SBL_LOG_MAX, "done.\n");
    #endif
        /* Load SYSFW. */
        SBL_SciClientInit();
    #if !defined(SBL_SKIP_PINMUX_ENABLE)
        /* Board pinmux. */
        /* AM64x should not re-configure Pinmux on reset */
        uint32_t mmrResetRegister = (*((volatile uint32_t *)(CSL_CTRL_MMR0_CFG0_BASE+CSL_MAIN_CTRL_MMR_CFG0_RST_SRC_PROXY)));
        uint32_t mmrResetMask = CSL_MAIN_CTRL_MMR_CFG0_RST_SRC_PROXY_RST_SRC_MAIN_RESET_REQ_PROXY_MASK
            | CSL_MAIN_CTRL_MMR_CFG0_RST_SRC_PROXY_RST_SRC_WARM_OUT_RST_PROXY_MASK
            | CSL_MAIN_CTRL_MMR_CFG0_RST_SRC_PROXY_RST_SRC_SW_MCU_WARMRST_PROXY_MASK
            | CSL_MAIN_CTRL_MMR_CFG0_RST_SRC_PROXY_RST_SRC_SW_MAIN_WARMRST_FROM_MCU_PROXY_MASK
            | CSL_MAIN_CTRL_MMR_CFG0_RST_SRC_PROXY_RST_SRC_SW_MAIN_WARMRST_FROM_MAIN_PROXY_MASK
            | CSL_MAIN_CTRL_MMR_CFG0_RST_SRC_PROXY_RST_SRC_MAIN_ESM_ERROR_PROXY_MASK;
        if (mmrResetRegister & mmrResetMask)
            /* Do not do PinMux */
            SBL_log(SBL_LOG_MAX, "SKIPPING PINMUX ENABLE\n");
        else
            SBL_log(SBL_LOG_MAX, "ENABLING PINMUX\n");
            Board_init(BOARD_INIT_PINMUX_CONFIG);
    #else
    #endif
    #endif
    #if !defined(SBL_SKIP_LATE_INIT)
        SBL_SocLateInit();
    #endif
    #if defined(SBL_ENABLE_PLL) && !defined(SBL_SKIP_SYSFW_INIT)
        SBL_log(SBL_LOG_MAX, "Initlialzing PLLs ...");
        Board_init(SBL_PLL_INIT);
    #endif
    #if defined(SBL_ENABLE_CLOCKS) && !defined(SBL_SKIP_SYSFW_INIT)
        SBL_log(SBL_LOG_MAX, "InitlialzingClocks ...");
    #if defined(SOC_J721E) || defined(SOC_J7200) || defined(SOC_AM64X)
        Board_initParams_t initParams;
        Board_getInitParams(&initParams);
        initParams.mainClkGrp = BOARD_MAIN_CLOCK_GROUP1;
        initParams.mcuClkGrp  = BOARD_MCU_CLOCK_GROUP1;
        Board_setInitParams(&initParams);
    #endif
    #endif
        Board_init(SBL_CLOCK_INIT);
    #endif
    #if defined(SBL_ENABLE_DDR) && defined(SBL_ENABLE_PLL) && defined(SBL_ENABLE_CLOCKS)  && !defined(SBL_SKIP_SYSFW_INIT)
        SBL_log(SBL_LOG_MAX, "Initlialzing DDR ...");
        Board_init(BOARD_INIT_DDR);
    #endif
    #if !defined(SBL_USE_MCU_DOMAIN_ONLY) && !defined(SBL_ENABLE_DEV_GRP_MCU)
        /* Enable GTC */
        SBL_log(SBL_LOG_MAX, "Initializing GTC ...");
        volatile uint32_t *gtcRegister = (uint32_t *) CSL_GTC0_GTC_CFG1_BASE;
        *gtcRegister = *gtcRegister | CSL_GTC_CFG1_CNTCR_EN_MASK | CSL_GTC_CFG1_CNTCR_HDBG_MASK;
    #if defined(SOC_J721E) || (!defined(SBL_ENABLE_HLOS_BOOT) && defined(SOC_J7200))
        /* Configure external Ethernet PHY and pinmux */
        SBL_ConfigureEthernet();
    #endif
    #endif
        SBL_log(SBL_LOG_MAX, "Begin parsing user application\n");
        /* Boot all non-SBL cores in multi-core app image */
        SBL_BootImage(&k3xx_evmEntry);
        /* Export SBL logs */
        sblProfileLogAddr = sblProfileLog;
        sblProfileLogIndxAddr = &sblProfileLogIndx;
        sblProfileLogOvrFlwAddr = &sblProfileLogOvrFlw;
        /* For J721E/J7200 we have to manage all core boots at the end, to load mcu1_0 sciserver app */
        for (core_id = MCU2_CPU0_ID; core_id <= SBL_LAST_CORE_ID; core_id ++)
            /* Try booting all MAIN domain cores except the Cortex-A cores */
            if (k3xx_evmEntry.CpuEntryPoint[core_id] != SBL_INVALID_ENTRY_ADDR)
                SBL_SlaveCoreBoot(core_id, (uint32_t)NULL, &k3xx_evmEntry, SBL_REQUEST_CORE);
        Board_releaseResource(BOARD_RESOURCE_MODULE_CLOCK);
        /* Boot the HLOS on the Cortex-A cores towards the end */
        for (core_id = MPU1_CPU0_ID; core_id <= MPU1_CPU1_ID; core_id ++)
            /* Try booting all cores other than the cluster running the SBL */
    #endif
    #if defined(SBL_ENABLE_HLOS_BOOT) && defined(SOC_AM64X)
    #endif
        /* Boot the core running SBL in the end */
        if ((k3xx_evmEntry.CpuEntryPoint[MCU1_CPU1_ID] != SBL_INVALID_ENTRY_ADDR) ||
            (k3xx_evmEntry.CpuEntryPoint[MCU1_CPU0_ID] < SBL_INVALID_ENTRY_ADDR))
            SBL_SlaveCoreBoot(MCU1_CPU0_ID, 0, &k3xx_evmEntry, SBL_REQUEST_CORE);
            SBL_SlaveCoreBoot(MCU1_CPU1_ID, 0, &k3xx_evmEntry, SBL_REQUEST_CORE);
        /* Execute a WFI */
        asm volatile (" wfi");
        return 0;
    I followed the method in the link above.
    link:
  • Hi Eason,
    Can you please state the boot switch settings that you are doing?
    Parth
  • Hi Parth,
    I tried both the NO-BOOT mode and the SD BOOT mode.
    Under both of these modes, CCS was unable to load the SBL image.
    Eason
  • Hi Parth,
    Any update here?
    Eason
    Can you please share your SW8 and SW9 settings? Also, can you please try with a different SD card?
    Parth
