TDA4VM: C7x UDMA DRU channel waits indefinitely for __EFR event in copy mode 2
Part Number: TDA4VM
SDK Version: ti-processor-sdk-rtos-j721e-evm-08_06_00_12
DMA Driver: vision_apps/utils/udma
I was implementing the following scenario using a couple of DRU channels:
  • STEP1: Initialise 1st DRU channel using "appUdmaCopyNDGetHandle".
  • STEP2: Initialise 2nd DRU channel using "appUdmaCopyNDGetHandle".
  • STEP3: for N iterations:
    • STEP3_1: Copy srcBuffer1 to dstBuffer1 using 1st channel using "copy_mode" 0.
    • STEP3_2: Copy srcBuffer2 to dstBuffer2 using 2nd channel using "copy_mode" 0.
    • STEP3_3: Copy srcBuffer3 to dstBuffer3 using 1st and 2nd channels in ping_pong using "copy_mode" 2.
  • STEP4: DeInitialise 1st DRU channel using "appUdmaCopyNDReleaseHandle".
  • STEP5: DeInitialise 2nd DRU channel using "appUdmaCopyNDReleaseHandle".
During the execution of STEP3_3, DRU channels seems to randomly hung and wait indefinitely for __EFR event.
This issue only happens in STEP3_3 and only when we switch to copy_mode 2.
Regards.
    A followup on my previous comment.
    Whe the DRU channel randomly hungs, the __EFR event register value is allways 0 and no event is reported.
    The value is retreived using:
    volatile uint64_t eflRegisterVal  =  __get_indexed(__EFR,0);
    In the "appUdmaTrpdInit" function located in "vision_apps/utils/udma/src/app_udma_utils.c" file, we added the following modifications:
    For copy_mode 0:
    • Set the UDMAP_TR_FLAGS_TRIGGER0 to CSL_UDMAP_TR_FLAGS_TRIGGER_GLOBAL0
    • Set the UDMAP_TR_FLAGS_EOL to CSL_UDMAP_TR_FLAGS_EOL_MATCH_SOL_EOL
    Below is the code:
     if(copy_mode == 0)
            // pTr->flags |= CSL_FMK(UDMAP_TR_FLAGS_EVENT_SIZE, CSL_UDMAP_TR_FLAGS_EVENT_SIZE_COMPLETION);
            // pTr->flags |= CSL_FMK(UDMAP_TR_FLAGS_TRIGGER0, CSL_UDMAP_TR_FLAGS_TRIGGER_NONE);
            // pTr->flags |= CSL_FMK(UDMAP_TR_FLAGS_TRIGGER0_TYPE, CSL_UDMAP_TR_FLAGS_TRIGGER_TYPE_ALL);
            pTr->flags |= CSL_FMK(UDMAP_TR_FLAGS_TRIGGER0, CSL_UDMAP_TR_FLAGS_TRIGGER_GLOBAL0);
            pTr->flags |= CSL_FMK(UDMAP_TR_FLAGS_EOL, CSL_UDMAP_TR_FLAGS_EOL_MATCH_SOL_EOL);
        else if(copy_mode == 1)
    This seems to fix the issue for the switch between copy mode 0 and 2, however we would like a confirmation from TI's side.
  • Unlocking this ticket.
