OMAP3530: Linux Kernel Migration issue
Part Number: OMAP3530
Hello Everyone!!
I am trying upgrade Linux kernel from v4.0 to v5.4. Our machine is based on OMAP3530 CPU & we're using  SHARP LQ043T1DG01 TFT LCD display.
We noticed fb0 device hasn't been detected after upgrade.
Jul 24 06:59:02 rfs200 user.debug kernel: [ 33.135864] panel-dpi display: GPIO lookup for consumer enable
Jul 24 06:59:02 rfs200 user.debug kernel: [ 33.135894] panel-dpi display: using device tree for GPIO lookup
Jul 24 06:59:02 rfs200 user.debug kernel: [ 33.135955] panel-dpi display: No GPIO consumer enable found
Jul 24 06:59:02 rfs200 user.info kernel: [ 33.169189] platform backlight: deferred probe pending
Jul 24 06:59:02 rfs200 user.info kernel: [ 33.174591] platform display: deferred probe pending
Jul 24 06:59:02 rfs200 user.info kernel: [ 33.179870] platform leds: deferred probe pending
Jul 24 06:59:02 rfs200 user.info kernel: [ 33.184814] platform omapdrm.0: deferred probe pending
Here is the configuration
DTS:
    lcd: display {
        compatible = "sharp,lq043t1dg01", "panel-dpi"
        label = "lcd";
        enable-gpios = <&gpio5 20 GPIO_ACTIVE_HIGH>;
        panel-timing {
            clock-frequency = <9000000>;
            hactive = <480>;
            vactive = <272>;
            hfront-porch = <2>;
            hback-porch = <2>;
            hsync-len = <41>;
            vback-porch = <2>;
            vfront-porch = <2>;
            vsync-len = <10>;
            hsync-active = <0>;
            vsync-active = <0>;
            de-active = <1>;
            pixelclk-active = <1>;
        port {
            lcd_in: endpoint {
                remote-endpoint = <&dpi_out>;
CONFIG:
v5.4
CONFIG_DRM_OMAP=y
CONFIG_OMAP2_DSS_INIT=y
CONFIG_OMAP_DSS_BASE=y
CONFIG_OMAP2_DSS=y
CONFIG_OMAP2_DSS_DPI=y
CONFIG_OMAP2_DSS_VENC=y
CONFIG_OMAP2_DSS_HDMI_COMMON=y
CONFIG_OMAP4_DSS_HDMI=y
CONFIG_OMAP4_DSS_HDMI_CEC=y
CONFIG_OMAP5_DSS_HDMI=y
CONFIG_DRM_TILCDC=y
CONFIG_DRM_PANEL=y
# Display Panels
CONFIG_DRM_PANEL_SIMPLE=y
# Frame buffer Devices
CONFIG_FB=y
CONFIG_FB_CMDLINE=y
CONFIG_FB_NOTIFY=y
CONFIG_FB_CFB_FILLRECT=y
CONFIG_FB_CFB_COPYAREA=y
CONFIG_FB_CFB_IMAGEBLIT=y
CONFIG_FB_SYS_FILLRECT=y
CONFIG_FB_SYS_COPYAREA=y
CONFIG_FB_SYS_IMAGEBLIT=y
CONFIG_FB_SYS_FOPS=y
CONFIG_FB_DEFERRED_IO=y
From the kernel commits , we noticed that the framebuffer device driver for a SHARP LQ043T1DG01 TFT LCD was removed
https://github.com/torvalds/linux/commit/e3ed8b436bc32102ac2995940bc3a63c09755b63.
In older versions of Linux kernel, we were using CONFIG_DISPLAY_PANEL_DPI included a generic driver -
"drivers/video/fbdev/omap2/displays-new/panel-dpi.c"  but it was completely removed in v5.4.
Tried with CONFIG_DRM_OMAP_PANEL_DPI=y & CONFIG_DRM_PANEL_SIMPLE=y options but no image has been on the LCD display.
Observed same issue with v4.19 as well. Attached bootup log.
Jul 24 06:58:42 rfs200 user.debug redstripe: applauncher  42.812:Main Thread ID:  0xb6fb3000
Jul 24 06:59:02 rfs200 user.debug kernel: [   33.120300] pwm-backlight backlight: GPIO lookup for consumer enable
Jul 24 06:59:02 rfs200 user.debug kernel: [   33.120330] pwm-backlight backlight: using device tree for GPIO lookup
Jul 24 06:59:02 rfs200 user.debug kernel: [   33.120391] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/backlight[0]'
Jul 24 06:59:02 rfs200 user.debug kernel: [   33.120422] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/backlight[0]'
Jul 24 06:59:02 rfs200 user.debug kernel: [   33.120452] pwm-backlight backlight: using lookup tables for GPIO lookup
Jul 24 06:59:02 rfs200 user.debug kernel: [   33.120483] pwm-backlight backlight: No GPIO consumer enable found
Jul 24 06:59:02 rfs200 user.info kernel: [   33.120819] pwm-backlight backlight: Linked as a consumer to regulator.2
Jul 24 06:59:02 rfs200 user.info kernel: [   33.128143] pwm-backlight backlight: Dropping the link to regulator.2
Jul 24 06:59:02 rfs200 user.info kernel: [   33.190246] i2c 2-0048: deferred probe pending
Jul 24 06:59:03 rfs200 user.info kernel: [   33.760284] VAUX3: disabling
Jul 24 06:59:20 rfs200 auth.info login[178]: root login on 'console'
Jul 24 07:00:52 rfs200 user.notice kernel: [  142.710754] random: crng init done
Jul 24 07:00:52 rfs200 user.notice kernel: [  142.714599] random: 2 urandom warning(s) missed due to ratelimiting
Jul 24 08:27:06 rfs200 syslog.info syslogd started: BusyBox v1.24.1
Jul 24 08:27:06 rfs200 user.notice kernel: klogd started: BusyBox v1.24.1 (2016-12-07 16:43:21 CST)
Jul 24 08:27:06 rfs200 user.info kernel: [    0.000000] Booting Linux on physical CPU 0x0
Jul 24 08:27:06 rfs200 user.notice kernel: [    0.000000] Linux version 4.19.288-rfs200-7.0 (nadens3@BB022J3) (gcc version 5.3.0 (Buildroot 2016.02)) #3 Mon Jul 24 11:46:43 IST 2023
Jul 24 08:27:06 rfs200 user.info kernel: [    0.000000] CPU: ARMv7 Processor [411fc087] revision 7 (ARMv7), cr=10c5387d
Jul 24 08:27:06 rfs200 user.info kernel: [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Jul 24 08:27:06 rfs200 user.info kernel: [    0.000000] OF: fdt: Machine model: TI OMAP3 RFS200
Jul 24 08:27:06 rfs200 user.info kernel: [    0.000000] Memory policy: Data cache writeback
Jul 24 08:27:06 rfs200 user.info kernel: [    0.000000] cma: Reserved 16 MiB at 0x8ec00000
Jul 24 08:27:06 rfs200 user.debug kernel: [    0.000000] On node 0 totalpages: 65280
Jul 24 08:27:06 rfs200 user.debug kernel: [    0.000000]   Normal zone: 510 pages used for memmap
Jul 24 08:27:06 rfs200 user.debug kernel: [    0.000000]   Normal zone: 0 pages reserved
Jul 24 08:27:06 rfs200 user.debug kernel: [    0.000000]   Normal zone: 65280 pages, LIFO batch:15
Jul 24 08:27:06 rfs200 user.info kernel: [    0.000000] CPU: All CPU(s) started in SVC mode.
Jul 24 08:27:06 rfs200 user.info kernel: [    0.000000] OMAP3430/3530 ES3.1.2 (l2cache iva sgx neon isp)
Jul 24 08:27:06 rfs200 user.debug kernel: [    0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
Jul 24 08:27:06 rfs200 user.debug kernel: [    0.000000] pcpu-alloc: [0] 0
Jul 24 08:27:06 rfs200 user.info kernel: [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 64770
Jul 24 08:27:06 rfs200 user.notice kernel: [    0.000000] Kernel command line: console=ttyO2,115200n8 root=ubi0:rootfs ubi.mtd=4 noinitrd rootfstype=ubifs rootdelay=2 vt.global_cursor_default=0
Jul 24 08:27:06 rfs200 user.info kernel: [    0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Jul 24 08:27:06 rfs200 user.info kernel: [    0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Jul 24 08:27:06 rfs200 user.info kernel: [    0.000000] Memory: 225232K/261120K available (7168K kernel code, 319K rwdata, 2248K rodata, 1024K init, 5295K bss, 19504K reserved, 16384K cma-reserved, 0K highmem)
Jul 24 08:27:06 rfs200 user.notice kernel: [    0.000000] Virtual kernel memory layout:
Jul 24 08:27:06 rfs200 user.notice kernel: [    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
Jul 24 08:27:06 rfs200 user.notice kernel: [    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
Jul 24 08:27:06 rfs200 user.notice kernel: [    0.000000]     vmalloc : 0xd0000000 - 0xff800000   ( 760 MB)
Jul 24 08:27:06 rfs200 user.notice kernel: [    0.000000]     lowmem  : 0xc0000000 - 0xcff00000   ( 255 MB)
Jul 24 08:27:06 rfs200 user.notice kernel: [    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
Jul 24 08:27:06 rfs200 user.notice kernel: [    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
Jul 24 08:27:06 rfs200 user.notice kernel: [    0.000000]       .text : 0x(ptrval) - 0x(ptrval)   (8160 kB)
Jul 24 08:27:06 rfs200 user.notice kernel: [    0.000000]       .init : 0x(ptrval) - 0x(ptrval)   (1024 kB)
Jul 24 08:27:06 rfs200 user.notice kernel: [    0.000000]       .data : 0x(ptrval) - 0x(ptrval)   ( 320 kB)
Jul 24 08:27:06 rfs200 user.notice kernel: [    0.000000]        .bss : 0x(ptrval) - 0x(ptrval)   (5296 kB)
Jul 24 08:27:06 rfs200 user.info kernel: [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
Jul 24 08:27:06 rfs200 user.info kernel: [    0.000000] IRQ: Found an INTC at 0x(ptrval) (revision 4.0) with 96 interrupts
Jul 24 08:27:06 rfs200 user.info kernel: [    0.000000] Clocking rate (Crystal/Core/MPU): 26.0/332/600 MHz
Jul 24 08:27:06 rfs200 user.info kernel: [    0.000000] OMAP clockevent source: timer1 at 32768 Hz
Jul 24 08:27:06 rfs200 user.info kernel: [    0.000000] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
Jul 24 08:27:06 rfs200 user.info kernel: [    0.000000] sched_clock: 32 bits at 32kHz, resolution 30517ns, wraps every 65535999984741ns
Jul 24 08:27:06 rfs200 user.info kernel: [    0.000030] OMAP clocksource: 32k_counter at 32768 Hz
Jul 24 08:27:06 rfs200 user.info kernel: [    0.001251] Console: colour dummy device 80x30
Jul 24 08:27:06 rfs200 user.warn kernel: [    0.001281] Lock dependency validator: Copyright (c) 2006 Red Hat, Inc., Ingo Molnar
Jul 24 08:27:06 rfs200 user.warn kernel: [    0.001312] ... MAX_LOCKDEP_SUBCLASSES:  8
Jul 24 08:27:06 rfs200 user.warn kernel: [    0.001342] ... MAX_LOCK_DEPTH:          48
Jul 24 08:27:06 rfs200 user.warn kernel: [    0.001342] ... MAX_LOCKDEP_KEYS:        8191
Jul 24 08:27:06 rfs200 user.warn kernel: [    0.001373] ... CLASSHASH_SIZE:          4096
Jul 24 08:27:06 rfs200 user.warn kernel: [    0.001373] ... MAX_LOCKDEP_ENTRIES:     32768
Jul 24 08:27:06 rfs200 user.warn kernel: [    0.001403] ... MAX_LOCKDEP_CHAINS:      65536
Jul 24 08:27:07 rfs200 user.warn kernel: [    0.001403] ... CHAINHASH_SIZE:          32768
Jul 24 08:27:07 rfs200 user.warn kernel: [    0.001434]  memory used by lock dependency info: 4639 kB
Jul 24 08:27:07 rfs200 user.warn kernel: [    0.001464]  per task-struct memory footprint: 1536 bytes
Jul 24 08:27:07 rfs200 user.info kernel: [    0.001525] Calibrating delay loop... 594.73 BogoMIPS (lpj=2973696)
Jul 24 08:27:07 rfs200 user.info kernel: [    0.048400] pid_max: default: 32768 minimum: 301
Jul 24 08:27:07 rfs200 user.info kernel: [    0.048706] Security Framework initialized
Jul 24 08:27:07 rfs200 user.info kernel: [    0.048858] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
Jul 24 08:27:07 rfs200 user.info kernel: [    0.048919] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
Jul 24 08:27:07 rfs200 user.info kernel: [    0.050537] CPU: Testing write buffer coherency: ok
Jul 24 08:27:07 rfs200 user.info kernel: [    0.050689] CPU0: Spectre v2: using BPIALL workaround
Jul 24 08:27:07 rfs200 user.info kernel: [    0.053039] Setting up static identity map for 0x80100000 - 0x80100078
Jul 24 08:27:07 rfs200 user.info kernel: [    0.056945] devtmpfs: initialized
Jul 24 08:27:07 rfs200 user.info kernel: [    0.111663] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 1
Jul 24 08:27:07 rfs200 user.info kernel: [    0.112335] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
Jul 24 08:27:07 rfs200 user.info kernel: [    0.112396] futex hash table entries: 256 (order: 1, 11264 bytes)
Jul 24 08:27:07 rfs200 user.info kernel: [    0.114013] pinctrl core: initialized pinctrl subsystem
Jul 24 08:27:07 rfs200 user.info kernel: [    0.118530] NET: Registered protocol family 16
Jul 24 08:27:07 rfs200 user.info kernel: [    0.122985] DMA: preallocated 256 KiB pool for atomic coherent allocations
Jul 24 08:27:07 rfs200 user.warn kernel: [    0.176300] omap_hwmod: mcbsp2_sidetone using broken dt data from mcbsp
Jul 24 08:27:07 rfs200 user.warn kernel: [    0.177856] omap_hwmod: mcbsp3_sidetone using broken dt data from mcbsp
Jul 24 08:27:07 rfs200 user.info kernel: [    0.300415] cpuidle: using governor ladder
Jul 24 08:27:07 rfs200 user.info kernel: [    0.300476] cpuidle: using governor menu
Jul 24 08:27:07 rfs200 user.info kernel: [    0.301239] Reprogramming SDRC clock to 332000000 Hz
Jul 24 08:27:07 rfs200 user.debug kernel: [    0.312103] gpio gpiochip0: (gpio-0-31): added GPIO chardev (254:0)
Jul 24 08:27:07 rfs200 user.debug kernel: [    0.312469] gpiochip_setup_dev: registered GPIOs 0 to 31 on device: gpiochip0 (gpio-0-31)
Jul 24 08:27:07 rfs200 user.info kernel: [    0.312530] OMAP GPIO hardware version 2.5
Jul 24 08:27:07 rfs200 user.debug kernel: [    0.314361] gpio gpiochip1: (gpio-32-63): added GPIO chardev (254:1)
Jul 24 08:27:07 rfs200 user.debug kernel: [    0.314605] gpiochip_setup_dev: registered GPIOs 32 to 63 on device: gpiochip1 (gpio-32-63)
Jul 24 08:27:07 rfs200 user.debug kernel: [    0.316253] gpio gpiochip2: (gpio-64-95): added GPIO chardev (254:2)
Jul 24 08:27:07 rfs200 user.debug kernel: [    0.316528] gpiochip_setup_dev: registered GPIOs 64 to 95 on device: gpiochip2 (gpio-64-95)
Jul 24 08:27:07 rfs200 user.info kernel: [    0.335968] omap-gpmc 6e000000.gpmc: GPMC revision 5.0
Jul 24 08:27:07 rfs200 user.warn kernel: [    0.336120] gpmc_mem_init: disabling cs 0 mapped at 0x0-0x1000000
Jul 24 08:27:07 rfs200 user.debug kernel: [    0.336181] gpiochip_find_base: found new base at 508
Jul 24 08:27:07 rfs200 user.debug kernel: [    0.336853] gpio gpiochip3: (omap-gpmc): added GPIO chardev (254:3)
Jul 24 08:27:07 rfs200 user.debug kernel: [    0.337127] gpiochip_setup_dev: registered GPIOs 508 to 511 on device: gpiochip3 (omap-gpmc)
Jul 24 08:27:07 rfs200 user.info kernel: [    0.345581] No ATAGs?
Jul 24 08:27:07 rfs200 user.info kernel: [    0.345611] hw-breakpoint: debug architecture 0x4 unsupported.
Jul 24 08:27:07 rfs200 user.info kernel: [    0.347961] OMAP DMA hardware revision 4.0
Jul 24 08:27:07 rfs200 user.info kernel: [    0.399261] omap-dma-engine 48056000.dma-controller: OMAP DMA engine driver
Jul 24 08:27:07 rfs200 user.debug kernel: [    0.400390] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vcc3[0]'
Jul 24 08:27:07 rfs200 user.debug kernel: [    0.401245] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/fixed_regulator[0]'
Jul 24 08:27:07 rfs200 user.info kernel: [    0.408447] omap-iommu 480bd400.mmu: 480bd400.mmu registered
Jul 24 08:27:07 rfs200 user.info kernel: [    0.409362] iommu: Adding device 480bc000.isp to group 0
Jul 24 08:27:07 rfs200 user.notice kernel: [    0.412536] SCSI subsystem initialized
Jul 24 08:27:07 rfs200 user.debug kernel: [    0.413360] libata version 3.00 loaded.
Jul 24 08:27:07 rfs200 user.info kernel: [    0.414123] usbcore: registered new interface driver usbfs
Jul 24 08:27:07 rfs200 user.info kernel: [    0.414337] usbcore: registered new interface driver hub
Jul 24 08:27:07 rfs200 user.info kernel: [    0.414489] usbcore: registered new device driver usb
Jul 24 08:27:07 rfs200 user.debug kernel: [    0.415008] usb_phy_generic hsusb1_phy: GPIO lookup for consumer reset
Jul 24 08:27:07 rfs200 user.debug kernel: [    0.415008] usb_phy_generic hsusb1_phy: using device tree for GPIO lookup
Jul 24 08:27:07 rfs200 user.debug kernel: [    0.415069] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/hsusb1_phy[0]'
Jul 24 08:27:07 rfs200 user.debug kernel: [    0.415100] of_get_named_gpiod_flags: can't parse 'reset-gpio' property of node '/hsusb1_phy[0]'
Jul 24 08:27:07 rfs200 user.debug kernel: [    0.415100] usb_phy_generic hsusb1_phy: using lookup tables for GPIO lookup
Jul 24 08:27:07 rfs200 user.debug kernel: [    0.415191] usb_phy_generic hsusb1_phy: No GPIO consumer reset found
Jul 24 08:27:07 rfs200 user.debug kernel: [    0.415222] usb_phy_generic hsusb1_phy: GPIO lookup for consumer vbus-detect
Jul 24 08:27:07 rfs200 user.debug kernel: [    0.415252] usb_phy_generic hsusb1_phy: using device tree for GPIO lookup
Jul 24 08:27:07 rfs200 user.debug kernel: [    0.415283] of_get_named_gpiod_flags: can't parse 'vbus-detect-gpios' property of node '/hsusb1_phy[0]'
Jul 24 08:27:07 rfs200 user.debug kernel: [    0.415313] of_get_named_gpiod_flags: can't parse 'vbus-detect-gpio' property of node '/hsusb1_phy[0]'
Jul 24 08:27:07 rfs200 user.debug kernel: [    0.415313] usb_phy_generic hsusb1_phy: using lookup tables for GPIO lookup
Jul 24 08:27:07 rfs200 user.debug kernel: [    0.415344] usb_phy_generic hsusb1_phy: No GPIO consumer vbus-detect found
Jul 24 08:27:07 rfs200 user.info kernel: [    0.415802] usb_phy_generic hsusb1_phy: Linked as a consumer to regulator.1
Jul 24 08:27:07 rfs200 user.info kernel: [    0.419006] omap_i2c 48070000.i2c: bus 0 rev3.3 at 2600 kHz
Jul 24 08:27:07 rfs200 user.info kernel: [    0.420410] omap_i2c 48072000.i2c: bus 1 rev3.3 at 400 kHz
Jul 24 08:27:07 rfs200 user.info kernel: [    0.424011] clocksource: Switched to clocksource 32k_counter
Jul 24 08:27:07 rfs200 user.notice kernel: [    0.424652] VFS: Disk quotas dquot_6.6.0
Jul 24 08:27:07 rfs200 user.info kernel: [    0.424804] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Jul 24 08:27:07 rfs200 user.info kernel: [    0.454437] NET: Registered protocol family 2
Jul 24 08:27:07 rfs200 user.info kernel: [    0.455078] IP idents hash table entries: 4096 (order: 3, 32768 bytes)
Jul 24 08:27:07 rfs200 user.info kernel: [    0.456512] tcp_listen_portaddr_hash hash table entries: 128 (order: 0, 5120 bytes)
Jul 24 08:27:07 rfs200 user.info kernel: [    0.456634] TCP established hash table entries: 2048 (order: 1, 8192 bytes)
Jul 24 08:27:07 rfs200 user.info kernel: [    0.456695] TCP bind hash table entries: 2048 (order: 4, 73728 bytes)
Jul 24 08:27:07 rfs200 user.info kernel: [    0.457275] TCP: Hash tables configured (established 2048 bind 2048)
Jul 24 08:27:07 rfs200 user.info kernel: [    0.457641] UDP hash table entries: 256 (order: 2, 20480 bytes)
Jul 24 08:27:07 rfs200 user.info kernel: [    0.457855] UDP-Lite hash table entries: 256 (order: 2, 20480 bytes)
Jul 24 08:27:07 rfs200 user.info kernel: [    0.458404] NET: Registered protocol family 1
Jul 24 08:27:07 rfs200 user.info kernel: [    0.460601] RPC: Registered named UNIX socket transport module.
Jul 24 08:27:07 rfs200 user.info kernel: [    0.460632] RPC: Registered udp transport module.
Jul 24 08:27:07 rfs200 user.info kernel: [    0.460662] RPC: Registered tcp transport module.
Jul 24 08:27:07 rfs200 user.info kernel: [    0.460662] RPC: Registered tcp NFSv4.1 backchannel transport module.
Jul 24 08:27:07 rfs200 user.info kernel: [    0.465240] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
Jul 24 08:27:07 rfs200 user.info kernel: [    0.472106] workingset: timestamp_bits=30 max_order=16 bucket_order=0
Jul 24 08:27:07 rfs200 user.notice kernel: [    0.474670] NFS: Registering the id_resolver key type
Jul 24 08:27:07 rfs200 user.notice kernel: [    0.475036] Key type id_resolver registered
Jul 24 08:27:07 rfs200 user.notice kernel: [    0.475067] Key type id_legacy registered
Jul 24 08:27:07 rfs200 user.info kernel: [    0.488983] jitterentropy: Initialization failed with host not compliant with requirements: 2
Jul 24 08:27:07 rfs200 user.info kernel: [    0.489166] io scheduler noop registered (default)
Jul 24 08:27:07 rfs200 user.info kernel: [    0.489196] io scheduler deadline registered
Jul 24 08:27:07 rfs200 user.info kernel: [    0.489227] io scheduler mq-deadline registered
Jul 24 08:27:07 rfs200 user.info kernel: [    0.489227] io scheduler kyber registered
Jul 24 08:27:07 rfs200 user.warn kernel: [    0.491210] ti-sysc 480cb024.target-module: sysc_flags 00000100 != 00000110
Jul 24 08:27:07 rfs200 user.warn kernel: [    0.492767] ti-sysc 480c9024.target-module: sysc_flags 00000100 != 00000110
Jul 24 08:27:07 rfs200 user.info kernel: [    0.497192] pinctrl-single 48002030.pinmux: 284 pins, size 568
Jul 24 08:27:07 rfs200 user.info kernel: [    0.498138] pinctrl-single 48002a00.pinmux: 46 pins, size 92
Jul 24 08:27:07 rfs200 user.info kernel: [    0.499176] pinctrl-single 480025d8.pinmux: 18 pins, size 36
Jul 24 08:27:07 rfs200 user.debug kernel: [    0.501342] pwm-backlight backlight: GPIO lookup for consumer enable
Jul 24 08:27:07 rfs200 user.debug kernel: [    0.501373] pwm-backlight backlight: using device tree for GPIO lookup
Jul 24 08:27:07 rfs200 user.debug kernel: [    0.501403] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/backlight[0]'
Jul 24 08:27:07 rfs200 user.debug kernel: [    0.501434] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/backlight[0]'
Jul 24 08:27:07 rfs200 user.debug kernel: [    0.501464] pwm-backlight backlight: using lookup tables for GPIO lookup
Jul 24 08:27:07 rfs200 user.debug kernel: [    0.501464] pwm-backlight backlight: No GPIO consumer enable found
Jul 24 08:27:07 rfs200 user.info kernel: [    0.501770] pwm-backlight backlight: Linked as a consumer to regulator.2
Jul 24 08:27:07 rfs200 user.info kernel: [    0.502502] pwm-backlight backlight: Dropping the link to regulator.2
Jul 24 08:27:07 rfs200 user.info kernel: [    0.506958] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
Jul 24 08:27:07 rfs200 user.info kernel: [    0.511871] omap_uart 4806a000.serial: no wakeirq for uart0
Jul 24 08:27:07 rfs200 user.debug kernel: [    0.511932] of_get_named_gpiod_flags: can't parse 'rts-gpio' property of node '/ocp@68000000/serial@4806a000[0]'
Jul 24 08:27:07 rfs200 user.info kernel: [    0.512329] 4806a000.serial: ttyO0 at MMIO 0x4806a000 (irq = 88, base_baud = 3000000) is a OMAP UART0
Jul 24 08:27:07 rfs200 user.info kernel: [    0.513580] omap_uart 4806c000.serial: no wakeirq for uart1
Jul 24 08:27:07 rfs200 user.debug kernel: [    0.513671] of_get_named_gpiod_flags: can't parse 'rts-gpio' property of node '/ocp@68000000/serial@4806c000[0]'
Jul 24 08:27:07 rfs200 user.info kernel: [    0.513885] 4806c000.serial: ttyO1 at MMIO 0x4806c000 (irq = 89, base_baud = 3000000) is a OMAP UART1
Jul 24 08:27:07 rfs200 user.debug kernel: [    0.515472] of_get_named_gpiod_flags: can't parse 'rts-gpio' property of node '/ocp@68000000/serial@49020000[0]'
Jul 24 08:27:07 rfs200 user.info kernel: [    0.515716] 49020000.serial: ttyO2 at MMIO 0x49020000 (irq = 90, base_baud = 3000000) is a OMAP UART2
Jul 24 08:27:07 rfs200 user.info kernel: [    1.249359] console [ttyO2] enabled
Jul 24 08:27:07 rfs200 user.debug kernel: [    1.256469] DSS: set fck to 172800000
Jul 24 08:27:07 rfs200 user.warn kernel: [    1.256591] omapdss_dss 48050000.dss: 48050000.dss supply vdda_video not found, using dummy regulator
Jul 24 08:27:07 rfs200 user.info kernel: [    1.266571] omapdss_dss 48050000.dss: Linked as a consumer to regulator.0
Jul 24 08:27:07 rfs200 user.debug kernel: [    1.273742] DSS: dss_runtime_get
Jul 24 08:27:07 rfs200 user.debug kernel: [    1.273834] DSS: dss_restore_context
Jul 24 08:27:07 rfs200 user.info kernel: [    1.273864] DSS: OMAP DSS rev 2.0
Jul 24 08:27:07 rfs200 user.debug kernel: [    1.277404] DSS: dss_runtime_put
Jul 24 08:27:07 rfs200 user.debug kernel: [    1.277404] DSS: dss_save_context
Jul 24 08:27:07 rfs200 user.debug kernel: [    1.277435] DSS: context saved
Jul 24 08:27:07 rfs200 user.debug kernel: [    1.278686] DSS: dss_restore_context
Jul 24 08:27:07 rfs200 user.debug kernel: [    1.278717] DSS: context restored
Jul 24 08:27:07 rfs200 user.debug kernel: [    1.278991] DISPC: dispc_runtime_get
Jul 24 08:27:07 rfs200 user.debug kernel: [    1.279052] DISPC: fifo(0) threshold (bytes), old 960/1023, new 960/1023
Jul 24 08:27:07 rfs200 user.debug kernel: [    1.279052] DISPC: fifo(1) threshold (bytes), old 960/1023, new 960/1023
Jul 24 08:27:07 rfs200 user.debug kernel: [    1.279083] DISPC: fifo(2) threshold (bytes), old 960/1023, new 960/1023
Jul 24 08:27:07 rfs200 user.debug kernel: [    1.279083] DISPC: dispc_restore_context
Jul 24 08:27:07 rfs200 user.debug kernel: [    1.279113] DISPC: dispc_restore_gamma_tables()
Jul 24 08:27:07 rfs200 user.debug kernel: [    1.279113] DISPC: fifo(0) threshold (bytes), old 960/1023, new 960/1023
Jul 24 08:27:07 rfs200 user.debug kernel: [    1.279144] DISPC: fifo(1) threshold (bytes), old 960/1023, new 960/1023
Jul 24 08:27:07 rfs200 user.debug kernel: [    1.279144] DISPC: fifo(2) threshold (bytes), old 960/1023, new 960/1023
Jul 24 08:27:07 rfs200 user.debug kernel: [    1.279174] omapdss_dispc 48050400.dispc: OMAP DISPC rev 3.0
Jul 24 08:27:07 rfs200 user.debug kernel: [    1.279174] DISPC: dispc_runtime_put
Jul 24 08:27:07 rfs200 user.debug kernel: [    1.279205] DISPC: dispc_save_context
Jul 24 08:27:07 rfs200 user.debug kernel: [    1.279266] DISPC: context saved
Jul 24 08:27:07 rfs200 user.info kernel: [    1.279388] omapdss_dss 48050000.dss: bound 48050400.dispc (ops dispc_component_ops)
Jul 24 08:27:07 rfs200 user.debug kernel: [    1.288665] panel-dpi display: GPIO lookup for consumer enable
Jul 24 08:27:07 rfs200 user.debug kernel: [    1.288696] panel-dpi display: using device tree for GPIO lookup
Jul 24 08:27:07 rfs200 user.debug kernel: [    1.288757] panel-dpi display: No GPIO consumer enable found
Jul 24 08:27:07 rfs200 user.debug kernel: [    1.291595] DSS: dss_save_context
Jul 24 08:27:07 rfs200 user.debug kernel: [    1.291595] DSS: context saved
Jul 24 08:27:07 rfs200 user.info kernel: [    1.317047] brd: module loaded
Jul 24 08:27:07 rfs200 user.info kernel: [    1.345367] loop: module loaded
Jul 24 08:27:07 rfs200 user.warn kernel: [    1.351684] Skipping twl internal clock init and using bootloader value (unknown osc rate)
Jul 24 08:27:07 rfs200 user.info kernel: [    1.366424] twl 0-0048: PIH (irq 23) chaining IRQs 147..155
Jul 24 08:27:07 rfs200 user.info kernel: [    1.372558] twl 0-0048: power (irq 152) chaining IRQs 155..162
Jul 24 08:27:07 rfs200 user.info kernel: [    1.423645] twl4030_gpio twl4030-gpio: gpio (irq 147) chaining IRQs 163..180
Jul 24 08:27:07 rfs200 user.debug kernel: [    1.431579] gpiochip_find_base: found new base at 488
Jul 24 08:27:07 rfs200 user.debug kernel: [    1.432128] gpio gpiochip4: (twl4030): added GPIO chardev (254:4)
Jul 24 08:27:07 rfs200 user.debug kernel: [    1.432403] gpiochip_setup_dev: registered GPIOs 488 to 507 on device: gpiochip4 (twl4030)
Jul 24 08:27:07 rfs200 user.info kernel: [    1.434814] twl4030_usb 48070000.i2c:twl@48:twl4030-usb: Linked as a consumer to regulator.18
Jul 24 08:27:07 rfs200 user.info kernel: [    1.444396] twl4030_usb 48070000.i2c:twl@48:twl4030-usb: Linked as a consumer to regulator.16
Jul 24 08:27:07 rfs200 user.info kernel: [    1.453857] twl4030_usb 48070000.i2c:twl@48:twl4030-usb: Linked as a consumer to regulator.17
Jul 24 08:27:07 rfs200 user.info kernel: [    1.534881] twl4030_usb 48070000.i2c:twl@48:twl4030-usb: Initialized TWL4030 USB module
Jul 24 08:27:07 rfs200 user.err kernel: [    1.567352] mtdoops: mtd device (mtddev=name/number) must be supplied
Jul 24 08:27:07 rfs200 user.debug kernel: [    1.575622] omap2-nand 30000000.nand: GPIO lookup for consumer rb
Jul 24 08:27:07 rfs200 user.debug kernel: [    1.575653] omap2-nand 30000000.nand: using device tree for GPIO lookup
Jul 24 08:27:07 rfs200 user.debug kernel: [    1.575714] of_get_named_gpiod_flags: can't parse 'rb-gpios' property of node '/ocp@68000000/gpmc@6e000000/nand@0,0[0]'
Jul 24 08:27:07 rfs200 user.debug kernel: [    1.575744] of_get_named_gpiod_flags: can't parse 'rb-gpio' property of node '/ocp@68000000/gpmc@6e000000/nand@0,0[0]'
Jul 24 08:27:07 rfs200 user.debug kernel: [    1.575744] omap2-nand 30000000.nand: using lookup tables for GPIO lookup
Jul 24 08:27:07 rfs200 user.debug kernel: [    1.575775] omap2-nand 30000000.nand: No GPIO consumer rb found
Jul 24 08:27:07 rfs200 user.info kernel: [    1.576110] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xbc
Jul 24 08:27:07 rfs200 user.info kernel: [    1.582733] nand: Micron MT29F4G16ABBDA3W
Jul 24 08:27:07 rfs200 user.info kernel: [    1.587036] nand: 512 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
Jul 24 08:27:07 rfs200 user.info kernel: [    1.595001] nand: using OMAP_ECC_BCH8_CODE_HW_DETECTION_SW
Jul 24 08:27:07 rfs200 user.notice kernel: [    1.604034] 7 fixed-partitions partitions found on MTD device omap2-nand.0
Jul 24 08:27:07 rfs200 user.notice kernel: [    1.611328] Creating 7 MTD partitions on "omap2-nand.0":
Jul 24 08:27:07 rfs200 user.notice kernel: [    1.616943] 0x000000000000-0x000000080000 : "spl-nand"
Jul 24 08:27:07 rfs200 user.notice kernel: [    1.626068] 0x000000080000-0x000000260000 : "bootloader-nand"
Jul 24 08:27:07 rfs200 user.notice kernel: [    1.636291] 0x000000260000-0x000000280000 : "params-nand"
Jul 24 08:27:07 rfs200 us[   99.505920] random: crng init done
er.notice kernel: [    1.644500] 0x000000280000-[   99.512725] random: 2 urandom warning(s) missed due to ratelimiting
0x000000800000 : "kernel-nand"
Jul 24 08:27:07 rfs200 user.notice kernel: [    1.657623] 0x000000800000-0x00000e200000 : "filesystem-nand-BANK_A"
Jul 24 08:27:07 rfs200 user.notice kernel: [    1.870056] 0x00000e200000-0x00001bc00000 : "filesystem-nand-BANK_B"
Jul 24 08:27:07 rfs200 user.notice kernel: [    2.082519] 0x00001bc00000-0x000020000000 : "persistent-data"
Jul 24 08:27:07 rfs200 user.debug kernel: [    2.164276] mdio_bus fixed-0: GPIO lookup for consumer reset
Jul 24 08:27:07 rfs200 user.debug kernel: [    2.164306] mdio_bus fixed-0: using lookup tables for GPIO lookup
Jul 24 08:27:07 rfs200 user.debug kernel: [    2.164337] mdio_bus fixed-0: No GPIO consumer reset found
Jul 24 08:27:07 rfs200 user.info kernel: [    2.167114] usbcore: registered new interface driver asix
Jul 24 08:27:07 rfs200 user.info kernel: [    2.172912] usbcore: registered new interface driver cdc_ether
Jul 24 08:27:07 rfs200 user.info kernel: [    2.179290] usbcore: registered new interface driver smsc95xx
Jul 24 08:27:07 rfs200 user.info kernel: [    2.187561] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Jul 24 08:27:07 rfs200 user.info kernel: [    2.194519] ehci-omap: OMAP-EHCI Host Controller driver
Jul 24 08:27:07 rfs200 user.err kernel: [    2.200805] OF: /ocp@68000000/usbhshost@48064000/ehci@48064800: could not get #phy-cells for /hsusb1_phy
Jul 24 08:27:07 rfs200 user.info kernel: [    2.210815] ehci-omap 48064800.ehci: EHCI Host Controller
Jul 24 08:27:07 rfs200 user.info kernel: [    2.217498] ehci-omap 48064800.ehci: new USB bus registered, assigned bus number 1
Jul 24 08:27:07 rfs200 user.info kernel: [    2.226806] ehci-omap 48064800.ehci: irq 93, io mem 0x48064800
Jul 24 08:27:07 rfs200 user.info kernel: [    2.254211] ehci-omap 48064800.ehci: USB 2.0 started, EHCI 1.00
Jul 24 08:27:07 rfs200 user.info kernel: [    2.261413] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
Jul 24 08:27:07 rfs200 user.info kernel: [    2.270141] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jul 24 08:27:07 rfs200 user.info kernel: [    2.277740] usb usb1: Product: EHCI Host Controller
Jul 24 08:27:07 rfs200 user.info kernel: [    2.282836] usb usb1: Manufacturer: Linux 4.19.288-rfs200-7.0 ehci_hcd
Jul 24 08:27:07 rfs200 user.info kernel: [    2.289703] usb usb1: SerialNumber: 48064800.ehci
Jul 24 08:27:07 rfs200 user.info kernel: [    2.296783] hub 1-0:1.0: USB hub found
Jul 24 08:27:07 rfs200 user.info kernel: [    2.300842] hub 1-0:1.0: 3 ports detected
Jul 24 08:27:07 rfs200 user.info kernel: [    2.307617] usbcore: registered new interface driver usb-storage
Jul 24 08:27:07 rfs200 user.info kernel: [    2.314056] usbcore: registered new interface driver cypress_cy7c63
Jul 24 08:27:07 rfs200 user.info kernel: [    2.322906] musb-hdrc musb-hdrc.0.auto: MUSB HDRC host driver
Jul 24 08:27:07 rfs200 user.info kernel: [    2.329803] musb-hdrc musb-hdrc.0.auto: new USB bus registered, assigned bus number 2
Jul 24 08:27:07 rfs200 user.info kernel: [    2.339324] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
Jul 24 08:27:07 rfs200 user.info kernel: [    2.348083] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jul 24 08:27:07 rfs200 user.info kernel: [    2.355682] usb usb2: Product: MUSB HDRC host driver
Jul 24 08:27:07 rfs200 user.info kernel: [    2.360870] usb usb2: Manufacturer: Linux 4.19.288-rfs200-7.0 musb-hcd
Jul 24 08:27:07 rfs200 user.info kernel: [    2.367736] usb usb2: SerialNumber: musb-hdrc.0.auto
Jul 24 08:27:07 rfs200 user.info kernel: [    2.374664] hub 2-0:1.0: USB hub found
Jul 24 08:27:07 rfs200 user.info kernel: [    2.378875] hub 2-0:1.0: 1 port detected
Jul 24 08:27:07 rfs200 user.debug kernel: [    2.386077] userial_init: registered 4 ttyGS* devices
Jul 24 08:27:07 rfs200 user.info kernel: [    2.386169] udc-core: couldn't find an available UDC - added [g_serial] to list of pending drivers
Jul 24 08:27:07 rfs200 user.info kernel: [    2.398742] input: twl4030_pwrbutton as /devices/platform/68000000.ocp/48070000.i2c/i2c-0/0-0048/48070000.i2c:twl@48:pwrbutton/input/input0
Jul 24 08:27:07 rfs200 user.info kernel: [    2.414123] twl_rtc 48070000.i2c:twl@48:rtc: Enabling TWL-RTC
Jul 24 08:27:08 rfs200 user.info kernel: [    2.423522] twl_rtc 48070000.i2c:twl@48:rtc: rtc core: registered 48070000.i2c:twl@48:rtc as rtc0
Jul 24 08:27:08 rfs200 user.info kernel: [    2.433990] i2c /dev entries driver
Jul 24 08:27:08 rfs200 user.info kernel: [    2.438964] Driver for 1-wire Dallas network protocol.
Jul 24 08:27:08 rfs200 user.info kernel: [    2.445343] omap_hdq 480b2000.1w: OMAP HDQ Hardware Rev 0.5. Driver in Interrupt mode
Jul 24 08:27:08 rfs200 user.info kernel: [    2.604187] usb 1-1: new high-speed USB device number 2 using ehci-omap
Jul 24 08:27:08 rfs200 user.warn kernel: [    2.656341] adcxx spi0.3: hwmon_device_register() is deprecated. Please convert the driver to use hwmon_device_register_with_info().
Jul 24 08:27:08 rfs200 user.info kernel: [    2.670989] w1_master_driver w1_bus_master1: Attaching one wire slave 01.000000000000 crc 3d
Jul 24 08:27:08 rfs200 user.info kernel: [    2.681640] omap_wdt: OMAP Watchdog Timer Rev 0x31: initial timeout 60 sec
Jul 24 08:27:08 rfs200 user.info kernel: [    2.691925] w1_master_driver w1_bus_master1: Family 1 for 01.000000000000.3d is not registered.
Jul 24 08:27:08 rfs200 user.info kernel: [    2.703887] cpu cpu0: Linked as a consumer to regulator.8
Jul 24 08:27:08 rfs200 user.info kernel: [    2.710357] cpu cpu0: Dropping the link to regulator.8
Jul 24 08:27:08 rfs200 user.info kernel: [    2.716705] cpu cpu0: Linked as a consumer to regulator.8
Jul 24 08:27:08 rfs200 user.debug kernel: [    2.728027] omap_hsmmc 4809c000.mmc: GPIO lookup for consumer cd
Jul 24 08:27:08 rfs200 user.debug kernel: [    2.728027] omap_hsmmc 4809c000.mmc: using device tree for GPIO lookup
Jul 24 08:27:08 rfs200 user.debug kernel: [    2.728088] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/ocp@68000000/mmc@4809c000[0]'
Jul 24 08:27:08 rfs200 user.debug kernel: [    2.728118] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/ocp@68000000/mmc@4809c000[0]'
Jul 24 08:27:08 rfs200 user.debug kernel: [    2.728149] omap_hsmmc 4809c000.mmc: using lookup tables for GPIO lookup
Jul 24 08:27:08 rfs200 user.debug kernel: [    2.728179] omap_hsmmc 4809c000.mmc: No GPIO consumer cd found
Jul 24 08:27:08 rfs200 user.debug kernel: [    2.728179] omap_hsmmc 4809c000.mmc: GPIO lookup for consumer wp
Jul 24 08:27:08 rfs200 user.debug kernel: [    2.728210] omap_hsmmc 4809c000.mmc: using device tree for GPIO lookup
Jul 24 08:27:08 rfs200 user.debug kernel: [    2.728240] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp@68000000/mmc@4809c000[0]'
Jul 24 08:27:08 rfs200 user.debug kernel: [    2.728271] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp@68000000/mmc@4809c000[0]'
Jul 24 08:27:08 rfs200 user.debug kernel: [    2.728302] omap_hsmmc 4809c000.mmc: using lookup tables for GPIO lookup
Jul 24 08:27:08 rfs200 user.debug kernel: [    2.728302] omap_hsmmc 4809c000.mmc: No GPIO consumer wp found
Jul 24 08:27:08 rfs200 user.info kernel: [    2.729614] omap_hsmmc 4809c000.mmc: Linked as a consumer to regulator.14
Jul 24 08:27:08 rfs200 user.info kernel: [    2.737640] omap_hsmmc 4809c000.mmc: Linked as a consumer to regulator.21
Jul 24 08:27:08 rfs200 user.info kernel: [    2.745056] omap_hsmmc 4809c000.mmc: Linked as a consumer to regulator.3
Jul 24 08:27:08 rfs200 user.info kernel: [    2.786071] ledtrig-cpu: registered to indicate activity on CPUs
Jul 24 08:27:08 rfs200 user.info kernel: [    2.803771] oprofile: using arm/armv7
Jul 24 08:27:08 rfs200 user.info kernel: [    2.808288] pktgen: Packet Generator for packet performance testing. Version: 2.75
Jul 24 08:27:08 rfs200 user.info kernel: [    2.819549] usb 1-1: New USB device found, idVendor=0424, idProduct=2517, bcdDevice= 0.02
Jul 24 08:27:08 rfs200 user.info kernel: [    2.828460] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Jul 24 08:27:08 rfs200 user.info kernel: [    2.839996] hub 1-1:1.0: USB hub found
Jul 24 08:27:08 rfs200 user.info kernel: [    2.850463] xt_time: kernel timezone is -0000
Jul 24 08:27:08 rfs200 user.info kernel: [    2.858367] ipt_CLUSTERIP: ClusterIP Version 0.8 loaded successfully
Jul 24 08:27:08 rfs200 user.info kernel: [    2.866088] Initializing XFRM netlink socket
Jul 24 08:27:08 rfs200 user.info kernel: [    2.871154] NET: Registered protocol family 17
Jul 24 08:27:08 rfs200 user.info kernel: [    2.876159] NET: Registered protocol family 15
Jul 24 08:27:08 rfs200 user.notice kernel: [    2.881805] Key type dns_resolver registered
Jul 24 08:27:08 rfs200 user.info kernel: [    2.886993] ThumbEE CPU extension supported.
Jul 24 08:27:08 rfs200 user.info kernel: [    2.894714] SmartReflex Class3 initialized
Jul 24 08:27:08 rfs200 user.info kernel: [    2.900878] hub 1-1:1.0: 7 ports detected
Jul 24 08:27:08 rfs200 user.debug kernel: [    3.093170] gpio gpiochip5: (gpio-96-127): added GPIO chardev (254:5)
Jul 24 08:27:08 rfs200 user.debug kernel: [    3.093475] gpiochip_setup_dev: registered GPIOs 96 to 127 on device: gpiochip5 (gpio-96-127)
Jul 24 08:27:08 rfs200 user.err kernel: [    3.093749] pinctrl-single 48002030.pinmux: Invalid number of rows: -2
Jul 24 08:27:08 rfs200 user.err kernel: [    3.101043] pinctrl-single 48002030.pinmux: no pins entries for pinmux_gpio5_pins
Jul 24 08:27:08 rfs200 user.warn kernel: [    3.109008] omap_gpio: probe of 49056000.gpio failed with error -22
Jul 24 08:27:08 rfs200 user.err kernel: [    3.116302] pinctrl-single 48002030.pinmux: Invalid number of rows: -2
Jul 24 08:27:08 rfs200 user.err kernel: [    3.123260] pinctrl-single 48002030.pinmux: no pins entries for pinmux_gpio6_pins
Jul 24 08:27:08 rfs200 user.warn kernel: [    3.131195] omap_gpio: probe of 49058000.gpio failed with error -22
Jul 24 08:27:08 rfs200 user.info kernel: [    3.142211] omap_i2c 48060000.i2c: bus 2 rev3.3 at 100 kHz
Jul 24 08:27:08 rfs200 user.debug kernel: [    3.148620] pwm-backlight backlight: GPIO lookup for consumer enable
Jul 24 08:27:08 rfs200 user.debug kernel: [    3.148651] pwm-backlight backlight: using device tree for GPIO lookup
Jul 24 08:27:08 rfs200 user.debug kernel: [    3.148681] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/backlight[0]'
Jul 24 08:27:08 rfs200 user.debug kernel: [    3.148712] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/backlight[0]'
Jul 24 08:27:08 rfs200 user.debug kernel: [    3.148742] pwm-backlight backlight: using lookup tables for GPIO lookup
Jul 24 08:27:08 rfs200 user.debug kernel: [    3.148773] pwm-backlight backlight: No GPIO consumer enable found
Jul 24 08:27:08 rfs200 user.info kernel: [    3.149078] pwm-backlight backlight: Linked as a consumer to regulator.2
Jul 24 08:27:08 rfs200 user.info kernel: [    3.156646] pwm-backlight backlight: Dropping the link to regulator.2
Jul 24 08:27:08 rfs200 user.debug kernel: [    3.164245] panel-dpi display: GPIO lookup for consumer enable
Jul 24 08:27:08 rfs200 user.debug kernel: [    3.164276] panel-dpi display: using device tree for GPIO lookup
Jul 24 08:27:08 rfs200 user.debug kernel: [    3.164306] panel-dpi display: No GPIO consumer enable found
Jul 24 08:27:08 rfs200 user.debug kernel: [    3.166198] pwm-backlight backlight: GPIO lookup for consumer enable
Jul 24 08:27:08 rfs200 user.debug kernel: [    3.166229] pwm-backlight backlight: using device tree for GPIO lookup
Jul 24 08:27:08 rfs200 user.debug kernel: [    3.166259] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/backlight[0]'
Jul 24 08:27:08 rfs200 user.debug kernel: [    3.166290] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/backlight[0]'
Jul 24 08:27:08 rfs200 user.debug kernel: [    3.166320] pwm-backlight backlight: using lookup tables for GPIO lookup
Jul 24 08:27:08 rfs200 user.debug kernel: [    3.166320] pwm-backlight backlight: No GPIO consumer enable found
Jul 24 08:27:08 rfs200 user.info kernel: [    3.166595] pwm-backlight backlight: Linked as a consumer to regulator.2
Jul 24 08:27:08 rfs200 user.info kernel: [    3.174804] pwm-backlight backlight: Dropping the link to regulator.2
Jul 24 08:27:08 rfs200 user.debug kernel: [    3.182464] panel-dpi display: GPIO lookup for consumer enable
Jul 24 08:27:08 rfs200 user.debug kernel: [    3.182464] panel-dpi display: using device tree for GPIO lookup
Jul 24 08:27:08 rfs200 user.debug kernel: [    3.182525] panel-dpi display: No GPIO consumer enable found
Jul 24 08:27:08 rfs200 user.notice kernel: [    3.184906] ubi0: attaching mtd4
Jul 24 08:27:08 rfs200 user.notice kernel: [    3.715942] ubi0: scanning is finished
Jul 24 08:27:08 rfs200 user.notice kernel: [    3.731964] ubi0: attached mtd4 (name "filesystem-nand-BANK_A", size 218 MiB)
Jul 24 08:27:08 rfs200 user.notice kernel: [    3.739593] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 129024 bytes
Jul 24 08:27:08 rfs200 user.notice kernel: [    3.746826] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 512
Jul 24 08:27:08 rfs200 user.notice kernel: [    3.753845] ubi0: VID header offset: 512 (aligned 512), data offset: 2048
Jul 24 08:27:08 rfs200 user.notice kernel: [    3.760986] ubi0: good PEBs: 1744, bad PEBs: 0, corrupted PEBs: 0
Jul 24 08:27:08 rfs200 user.notice kernel: [    3.767425] ubi0: user volume: 1, internal volumes: 1, max. volumes count: 128
Jul 24 08:27:08 rfs200 user.notice kernel: [    3.775024] ubi0: max/mean erase counter: 1/0, WL threshold: 4096, image sequence number: 406712400
Jul 24 08:27:08 rfs200 user.notice kernel: [    3.784515] ubi0: available PEBs: 0, total reserved PEBs: 1744, PEBs reserved for bad PEB handling: 80
Jul 24 08:27:08 rfs200 user.notice kernel: [    3.794799] ubi0: background thread "ubi_bgt0d" started, PID 64
Jul 24 08:27:08 rfs200 user.info kernel: [    3.801727] twl_rtc 48070000.i2c:twl@48:rtc: setting system clock to 2023-07-24 08:27:03 UTC (1690187223)
Jul 24 08:27:08 rfs200 user.warn kernel: [    3.811828] sr_init: No PMIC hook to init smartreflex
Jul 24 08:27:08 rfs200 user.info kernel: [    3.818145] smartreflex 480cb000.smartreflex: omap_sr_probe: SmartReflex driver initialized
Jul 24 08:27:08 rfs200 user.info kernel: [    3.827789] smartreflex 480c9000.smartreflex: omap_sr_probe: SmartReflex driver initialized
Jul 24 08:27:08 rfs200 user.debug kernel: [    3.840606] pwm-backlight backlight: GPIO lookup for consumer enable
Jul 24 08:27:08 rfs200 user.debug kernel: [    3.840637] pwm-backlight backlight: using device tree for GPIO lookup
Jul 24 08:27:08 rfs200 user.debug kernel: [    3.840667] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/backlight[0]'
Jul 24 08:27:08 rfs200 user.debug kernel: [    3.840698] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/backlight[0]'
Jul 24 08:27:08 rfs200 user.debug kernel: [    3.840728] pwm-backlight backlight: using lookup tables for GPIO lookup
Jul 24 08:27:08 rfs200 user.debug kernel: [    3.840728] pwm-backlight backlight: No GPIO consumer enable found
Jul 24 08:27:08 rfs200 user.info kernel: [    3.841064] pwm-backlight backlight: Linked as a consumer to regulator.2
Jul 24 08:27:08 rfs200 user.info kernel: [    3.848541] pwm-backlight backlight: Dropping the link to regulator.2
Jul 24 08:27:08 rfs200 user.debug kernel: [    3.856109] panel-dpi display: GPIO lookup for consumer enable
Jul 24 08:27:08 rfs200 user.debug kernel: [    3.856140] panel-dpi display: using device tree for GPIO lookup
Jul 24 08:27:08 rfs200 user.debug kernel: [    3.856201] panel-dpi display: No GPIO consumer enable found
Jul 24 08:27:08 rfs200 user.info kernel: [    3.859130] Waiting 2 sec before mounting root device...
Jul 24 08:27:08 rfs200 user.notice kernel: [    5.999969] UBIFS (ubi0:4): UBIFS: mounted UBI device 0, volume 4, name "rootfs", R/O mode
Jul 24 08:27:08 rfs200 user.notice kernel: [    6.008758] UBIFS (ubi0:4): LEB size: 129024 bytes (126 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
Jul 24 08:27:08 rfs200 user.notice kernel: [    6.019195] UBIFS (ubi0:4): FS size: 212760576 bytes (202 MiB, 1649 LEBs), journal size 9033728 bytes (8 MiB, 71 LEBs)
Jul 24 08:27:08 rfs200 user.notice kernel: [    6.030426] UBIFS (ubi0:4): reserved for root: 0 bytes (0 KiB)
Jul 24 08:27:08 rfs200 user.notice kernel: [    6.036590] UBIFS (ubi0:4): media format: w4/r0 (latest is w5/r0), UUID E214D31D-2D4C-478E-899E-8FCB2926E238, small LPT model
Jul 24 08:27:08 rfs200 user.info kernel: [    6.050079] VFS: Mounted root (ubifs filesystem) readonly on device 0:14.
Jul 24 08:27:08 rfs200 user.info kernel: [    6.058624] devtmpfs: mounted
Jul 24 08:27:08 rfs200 user.info kernel: [    6.064788] Freeing unused kernel memory: 1024K
Jul 24 08:27:08 rfs200 user.info kernel: [    6.070404] Run /sbin/init as init process
Jul 24 08:27:08 rfs200 user.notice kernel: [    6.594299] ubi1: attaching mtd6
Jul 24 08:27:08 rfs200 user.notice kernel: [    6.775451] ubi1: scanning is finished
Jul 24 08:27:08 rfs200 user.notice kernel: [    6.787384] ubi1: attached mtd6 (name "persistent-data", size 68 MiB)
Jul 24 08:27:08 rfs200 user.notice kernel: [    6.794250] ubi1: PEB size: 131072 bytes (128 KiB), LEB size: 129024 bytes
Jul 24 08:27:08 rfs200 user.notice kernel: [    6.801452] ubi1: min./max. I/O unit sizes: 2048/2048, sub-page size 512
Jul 24 08:27:08 rfs200 user.notice kernel: [    6.808502] ubi1: VID header offset: 512 (aligned 512), data offset: 2048
Jul 24 08:27:08 rfs200 user.notice kernel: [    6.815643] ubi1: good PEBs: 544, bad PEBs: 0, corrupted PEBs: 0
Jul 24 08:27:08 rfs200 user.notice kernel: [    6.821929] ubi1: user volume: 1, internal volumes: 1, max. volumes count: 128
Jul 24 08:27:08 rfs200 user.notice kernel: [    6.829528] ubi1: max/mean erase counter: 1/0, WL threshold: 4096, image sequence number: 475520414
Jul 24 08:27:08 rfs200 user.notice kernel: [    6.839019] ubi1: available PEBs: 0, total reserved PEBs: 544, PEBs reserved for bad PEB handling: 80
Jul 24 08:27:08 rfs200 user.notice kernel: [    6.848815] ubi1: background thread "ubi_bgt1d" started, PID 91
Jul 24 08:27:08 rfs200 user.notice kernel: [    6.909545] UBIFS (ubi1:5): background thread "ubifs_bgt1_5" started, PID 94
Jul 24 08:27:08 rfs200 user.notice kernel: [    6.928833] UBIFS (ubi1:5): recovery needed
Jul 24 08:27:08 rfs200 user.notice kernel: [    7.016693] UBIFS (ubi1:5): recovery completed
Jul 24 08:27:08 rfs200 user.notice kernel: [    7.021789] UBIFS (ubi1:5): UBIFS: mounted UBI device 1, volume 5, name "rootfs"
Jul 24 08:27:08 rfs200 user.notice kernel: [    7.029632] UBIFS (ubi1:5): LEB size: 129024 bytes (126 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
Jul 24 08:27:08 rfs200 user.notice kernel: [    7.040069] UBIFS (ubi1:5): FS size: 57931776 bytes (55 MiB, 449 LEBs), journal size 9033728 bytes (8 MiB, 71 LEBs)
Jul 24 08:27:08 rfs200 user.notice kernel: [    7.051025] UBIFS (ubi1:5): reserved for root: 0 bytes (0 KiB)
Jul 24 08:27:08 rfs200 user.notice kernel: [    7.057159] UBIFS (ubi1:5): media format: w4/r0 (latest is w5/r0), UUID 6799D0B7-4DA9-46FD-A8D5-E4CBEDB33E55, small LPT model
Jul 24 08:27:08 rfs200 daemon.info kernel: [    7.378479] udevd[104]: starting version 3.1.5
Jul 24 08:27:08 rfs200 user.notice kernel: [    7.437286] random: udevd: uninitialized urandom read (16 bytes read)
Jul 24 08:27:08 rfs200 user.notice kernel: [    7.462982] random: udevd: uninitialized urandom read (16 bytes read)
Jul 24 08:27:08 rfs200 user.notice kernel: [    7.481048] random: udevd: uninitialized urandom read (16 bytes read)
Jul 24 08:27:10 rfs200 user.notice kernel: [   10.601562] random: dbus-uuidgen: uninitialized urandom read (12 bytes read)
Jul 24 08:27:10 rfs200 user.notice kernel: [   10.609985] random: dbus-uuidgen: uninitialized urandom read (8 bytes read)
Jul 24 08:27:10 rfs200 user.notice kernel: [   10.669769] random: dbus-daemon: uninitialized urandom read (12 bytes read)
Jul 24 08:27:10 rfs200 user.notice kernel: [   10.843597] ubi2: attaching mtd5
Jul 24 08:27:11 rfs200 user.notice kernel: [   11.382995] ubi2: scanning is finished
Jul 24 08:27:11 rfs200 user.notice kernel: [   11.408966] ubi2: attached mtd5 (name "filesystem-nand-BANK_B", size 218 MiB)
Jul 24 08:27:11 rfs200 user.notice kernel: [   11.416656] ubi2: PEB size: 131072 bytes (128 KiB), LEB size: 129024 bytes
Jul 24 08:27:11 rfs200 user.notice kernel: [   11.423858] ubi2: min./max. I/O unit sizes: 2048/2048, sub-page size 512
Jul 24 08:27:11 rfs200 user.notice kernel: [   11.430938] ubi2: VID header offset: 512 (aligned 512), data offset: 2048
Jul 24 08:27:11 rfs200 user.notice kernel: [   11.438079] ubi2: good PEBs: 1744, bad PEBs: 0, corrupted PEBs: 0
Jul 24 08:27:11 rfs200 user.notice kernel: [   11.444488] ubi2: user volume: 1, internal volumes: 1, max. volumes count: 128
Jul 24 08:27:11 rfs200 user.notice kernel: [   11.452087] ubi2: max/mean erase counter: 1/0, WL threshold: 4096, image sequence number: 572090592
Jul 24 08:27:11 rfs200 user.notice kernel: [   11.461578] ubi2: available PEBs: 0, total reserved PEBs: 1744, PEBs reserved for bad PEB handling: 80
Jul 24 08:27:11 rfs200 user.notice kernel: [   11.472229] ubi2: background thread "ubi_bgt2d" started, PID 146
Jul 24 08:27:11 rfs200 user.notice kernel: [   11.541229] UBIFS (ubi2:4): background thread "ubifs_bgt2_4" started, PID 149
Jul 24 08:27:11 rfs200 user.notice kernel: [   11.562988] UBIFS (ubi2:4): recovery needed
Jul 24 08:27:11 rfs200 user.notice kernel: [   11.601043] UBIFS (ubi2:4): recovery completed
Jul 24 08:27:11 rfs200 user.notice kernel: [   11.606262] UBIFS (ubi2:4): UBIFS: mounted UBI device 2, volume 4, name "rootfs"
Jul 24 08:27:11 rfs200 user.notice kernel: [   11.614013] UBIFS (ubi2:4): LEB size: 129024 bytes (126 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
Jul 24 08:27:11 rfs200 user.notice kernel: [   11.624450] UBIFS (ubi2:4): FS size: 212760576 bytes (202 MiB, 1649 LEBs), journal size 9033728 bytes (8 MiB, 71 LEBs)
Jul 24 08:27:11 rfs200 user.notice kernel: [   11.635681] UBIFS (ubi2:4): reserved for root: 0 bytes (0 KiB)
Jul 24 08:27:11 rfs200 user.notice kernel: [   11.641784] UBIFS (ubi2:4): media format: w4/r0 (latest is w5/r0), UUID E214D31D-2D4C-478E-899E-8FCB2926E238, small LPT model
Jul 24 08:27:11 rfs200 user.notice kernel: [   12.082763] random: dbus-daemon: uninitialized urandom read (12 bytes read)
Jul 24 08:27:11 rfs200 user.notice kernel: [   12.103881] random: dbus-daemon: uninitialized urandom read (10 bytes read)
Jul 24 08:27:11 rfs200 user.notice kernel: [   12.111968] random: dbus-daemon: uninitialized urandom read (12 bytes read)
Jul 24 08:27:12 rfs200 daemon.info init: Entering runlevel: 3
Jul 24 08:27:12 rfs200 user.notice kernel: [   13.140563] random: applauncher: uninitialized urandom read (4 bytes read)
Jul 24 08:27:13 rfs200 user.debug redstripe: applauncher  13.184:Main Thread ID:  0xb6f23000
Jul 24 08:27:33 rfs200 user.debug kernel: [   33.765686] pwm-backlight backlight: GPIO lookup for consumer enable
Jul 24 08:27:33 rfs200 user.debug kernel: [   33.765716] pwm-backlight backlight: using device tree for GPIO lookup
Jul 24 08:27:33 rfs200 user.debug kernel: [   33.765777] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/backlight[0]'
Jul 24 08:27:33 rfs200 user.debug kernel: [   33.765808] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/backlight[0]'
Jul 24 08:27:33 rfs200 user.debug kernel: [   33.765838] pwm-backlight backlight: using lookup tables for GPIO lookup
Jul 24 08:27:33 rfs200 user.debug kernel: [   33.765869] pwm-backlight backlight: No GPIO consumer enable found
Jul 24 08:27:33 rfs200 user.info kernel: [   33.766174] pwm-backlight backlight: Linked as a consumer to regulator.2
Jul 24 08:27:33 rfs200 user.info kernel: [   33.773437] pwm-backlight backlight: Dropping the link to regulator.2
Jul 24 08:27:33 rfs200 user.debug kernel: [   33.781097] panel-dpi display: GPIO lookup for consumer enable
Jul 24 08:27:33 rfs200 user.debug kernel: [   33.781127] panel-dpi display: using device tree for GPIO lookup
Jul 24 08:27:33 rfs200 user.debug kernel: [   33.781188] panel-dpi display: No GPIO consumer enable found
Jul 24 08:27:33 rfs200 user.info kernel: [   33.794342] platform backlight: deferred probe pending
Jul 24 08:27:33 rfs200 user.info kernel: [   33.799743] platform display: deferred probe pending
Jul 24 08:27:33 rfs200 user.info kernel: [   33.805023] platform leds: deferred probe pending
Jul 24 08:27:33 rfs200 user.info kernel: [   33.809936] platform omapdrm.0: deferred probe pending
Jul 24 08:27:33 rfs200 user.info kernel: [   33.815368] i2c 2-0048: deferred probe pending
Jul 24 08:27:34 rfs200 user.info kernel: [   34.408538] VAUX3: disabling
Jul 24 08:28:09 rfs200 auth.info login[178]: root login on 'console'
Jul 24 08:28:39 rfs200 user.notice kernel: [   99.505920] random: crng init done
Jul 24 08:28:39 rfs200 user.notice kernel: [   99.512725] random: 2 urandom warning(s) missed due to ratelimiting
Is there a problem in kernel_config or DTS? Kindly provide your inputs.
Thanks You!!!!
