TDA4VM: TDA4VM: issue:ti-sci 44083000.dmsc: Mbox timedout in resp I have q problem with this err 'ti-sci 44083000.dmsc: Mbox timedout in resp '.
Part Number: TDA4VM
I meet this issue sometimes on my board when i do reset test.
we use 8.4 linux sdk.
This is full logs on soc print.
It is produce on my board, not TI EVM board
It is repoduce sometimes, meybe it happen one time when i test 200 times.
Is there any ways to debug it?
c801soc2 login: NOTICE:  BL31: v2.6(release):v2.7-rc0-dirty
NOTICE:  BL31: Built : 09:18:58, Aug 30 2022
I/TC:
I/TC: OP-TEE version: 3.17.0-125-g15a746d28 (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10))) #1 Tue Aug 30 09:19:19 UTC 2022 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: SYSFW ABI: 3.1 (firmware rev 0x0008 '8.4.1--v08.04.01 (Jolly Jellyfi')
I/TC: HUK Initialized
I/TC: Activated SA2UL device
I/TC: Enabled firewalls for SA2UL TRNG device
I/TC: SA2UL TRNG initialized
I/TC: SA2UL Drivers initialized
I/TC: Primary CPU switching to normal world boot
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[    0.000000] Linux version 5.10.120 (yangle@ubuntu) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #6 SMP PREEMPT Tue Aug 1 02:35:14 PDT 2023
[    0.000000] Machine model: Texas Instruments K3 J721E SoC
[    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[    0.000000] printk: bootconsole [ns16550a0] enabled
[    0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader!
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a0100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 31 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a6100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a8000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a8100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a9000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a9100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a9100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000aa000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@aa000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000aa100000, size 79 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c71-memory@aa100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000b2000000, size 96 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@b2000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000d8000000, size 192 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@d8000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000e4000000, size 8 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-queues@e4000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000e4800000, size 24 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-buffers@e4800000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 624 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x00000008ffffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
[    0.000000]   node   0: [mem 0x000000009e800000-0x00000000aeffffff]
[    0.000000]   node   0: [mem 0x00000000af000000-0x00000000afffffff]
[    0.000000]   node   0: [mem 0x00000000b0000000-0x00000000b7ffffff]
[    0.000000]   node   0: [mem 0x00000000b8000000-0x00000000d7ffffff]
[    0.000000]   node   0: [mem 0x00000000d8000000-0x00000000e5ffffff]
[    0.000000]   node   0: [mem 0x00000000e6000000-0x00000000ffffffff]
[    0.000000]   node   0: [mem 0x0000000880000000-0x00000008a6ffffff]
[    0.000000]   node   0: [mem 0x00000008a7000000-0x00000008ffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
[    0.000000] cma: Reserved 400 MiB at 0x00000000e7000000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 22 pages/cpu s50008 r8192 d31912 u90112
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: EL2 vector hardening
[    0.000000] CPU features: kernel page table isolation forced ON by KASLR
[    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[    0.000000] CPU features: detected: Spectre-BHB
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1032192
[    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=/dev/mmcblk0p2 rw rootfstype=ext4 rootwait
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x000000009a800000-0x000000009e800000] (64MB)
[    0.000000] Memory: 1828076K/4194304K available (10880K kernel code, 1126K rwdata, 4188K rodata, 1792K init, 431K bss, 1956628K reserved, 409600K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu: 	RCU event tracing is enabled.
[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[    0.000000] 	Trampoline variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 960 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[    0.000000] ITS [mem 0x01820000-0x0182ffff]
[    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @8a7800000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x00000008a7030000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008a7040000
[    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[    0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[    0.008384] Console: colour dummy device 80x25
[    0.012949] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[    0.023620] pid_max: default: 32768 minimum: 301
[    0.028376] LSM: Security Framework initializing
[    0.033135] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.040715] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.049515] rcu: Hierarchical SRCU implementation.
[    0.054563] Platform MSI: msi-controller@1820000 domain created
[    0.060784] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[    0.070081] EFI services will not be available.
[    0.074806] smp: Bringing up secondary CPUs ...
I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
[    0.088001] Detected PIPT I-cache on CPU1
[    0.088025] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[    0.088036] GICv3: CPU1: using allocated LPI pending table @0x00000008a7050000
[    0.088070] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[    0.088122] smp: Brought up 1 node, 2 CPUs
[    0.117467] SMP: Total of 2 processors activated.
[    0.122272] CPU features: detected: 32-bit EL0 Support
[    0.127526] CPU features: detected: CRC32 instructions
[    0.141695] CPU: All CPU(s) started at EL2
[    0.145892] alternatives: patching kernel code
[    0.150992] devtmpfs: initialized
[    0.159226] KASLR disabled due to lack of seed
[    0.163869] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.173833] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[    0.185775] pinctrl core: initialized pinctrl subsystem
[    0.191425] DMI not present or invalid.
[    0.195676] NET: Registered protocol family 16
[    0.200905] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[    0.208235] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.216307] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.224608] thermal_sys: Registered thermal governor 'step_wise'
[    0.224611] thermal_sys: Registered thermal governor 'power_allocator'
[    0.231160] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.244793] ASID allocator initialised with 32768 entries
[    0.263385] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.270240] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.277090] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.283938] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.291407] cryptd: max_cpu_qlen set to 1000
[    0.297413] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected
[    0.306202] vsys_3v3: supplied by evm_12v0
[    0.310568] vsys_5v0: supplied by evm_12v0
[    0.315092] iommu: Default domain type: Translated
[    0.320264] SCSI subsystem initialized
[    0.324353] mc: Linux media interface: v0.10
[    0.328729] videodev: Linux video capture interface: v2.00
[    0.334367] pps_core: LinuxPPS API ver. 1 registered
[    0.339437] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.348775] PTP clock support registered
[    0.352794] EDAC MC: Ver: 3.0.0
[    0.356557] FPGA manager framework
[    0.360066] Advanced Linux Sound Architecture Driver Initialized.
[    0.366658] clocksource: Switched to clocksource arch_sys_counter
[    0.372980] VFS: Disk quotas dquot_6.6.0
[    0.377010] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.386607] Carveout Heap: Exported 512 MiB at 0x00000000b8000000
[    0.392895] NET: Registered protocol family 2
[    0.397635] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.406202] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    0.414968] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.423171] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[    0.430974] TCP: Hash tables configured (established 32768 bind 32768)
[    0.437759] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.444650] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.452056] NET: Registered protocol family 1
[    0.456792] RPC: Registered named UNIX socket transport module.
[    0.462856] RPC: Registered udp transport module.
[    0.467660] RPC: Registered tcp transport module.
[    0.472463] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.479048] PCI: CLS 0 bytes, default 64
[    0.483389] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[    0.493696] Initialise system trusted keyrings
[    0.498331] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[    0.506487] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.512705] NFS: Registering the id_resolver key type
[    0.517904] Key type id_resolver registered
[    0.522178] Key type id_legacy registered
[    0.526302] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.533149] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.540788] 9p: Installing v9fs 9p2000 file system support
[    0.565540] Key type asymmetric registered
[    0.569726] Asymmetric key parser 'x509' registered
[    0.574725] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[    0.582284] io scheduler mq-deadline registered
[    0.586909] io scheduler kyber registered
[    0.592314] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
[    0.598503] pinctrl-single 11c000.pinctrl: 173 pins, size 692
[    0.606787] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[    0.613047] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[    0.620867] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[    0.628905] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
[    0.637223] arm-smmu-v3 36600000.iommu: allocated 65536 entries for cmdq
[    0.644342] arm-smmu-v3 36600000.iommu: allocated 32768 entries for evtq
[    0.653001] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
[    0.665564] brd: module loaded
[    0.672095] loop: module loaded
[    0.675905] megasas: 07.714.04.00-rc1
[    0.681265] tun: Universal TUN/TAP device driver, 1.6
[    0.686682] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[    0.693085] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    0.699154] sky2: driver version 1.30
[    0.703401] VFIO - User Level meta-driver version: 0.3
[    0.709120] i2c /dev entries driver
[    0.713319] sdhci: Secure Digital Host Controller Interface driver
[    0.719642] sdhci: Copyright(c) Pierre Ossman
[    0.724254] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.730525] ledtrig-cpu: registered to indicate activity on CPUs
[    0.736827] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    0.744004] optee: probing for conduit method.
[    0.748566] optee: revision 3.17 (15a746d2)
[    0.748697] optee: dynamic shared memory is enabled
E/TC:0 0 std_entry_with_parg:234 Bad arg address 0x8a8527000
[    0.763501] optee: initialized driver
[    0.768370] NET: Registered protocol family 17
[    0.772991] 9pnet: Installing 9P2000 support
[    0.777390] Key type dns_resolver registered
[    0.781838] Loading compiled-in X.509 certificates
[    0.791545] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[    0.797881] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[    0.805655] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0008 '8.4.1--v08.04.01 (Jolly Jellyfi')
[    0.852330] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
[    0.858425] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
[    0.864474] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
[    0.876547] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
[    0.882547] omap_i2c 2010000.i2c: bus 4 rev0.12 at 400 kHz
[    0.888531] omap_i2c 2020000.i2c: bus 5 rev0.12 at 400 kHz
[    0.894516] omap_i2c 2030000.i2c: bus 6 rev0.12 at 400 kHz
[    0.905539] omap_i2c 2040000.i2c: bus 7 rev0.12 at 100 kHz
[    0.911458] omap_i2c 2050000.i2c: bus 8 rev0.12 at 100 kHz
[    0.917894] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
[    0.934324] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
[    0.943116] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created
[    0.952972] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
[    0.978897] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
[    0.988773] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[    0.995543] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[    1.004556] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
[    1.014737] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[    1.021497] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[    1.029418] printk: console [ttyS2] disabled
[    1.033812] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 25, base_baud = 3000000) is a 8250
[    1.042559] printk: console [ttyS2] enabled
[    1.050994] printk: bootconsole [ns16550a0] disabled
[    1.061504] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 26, base_baud = 3000000) is a 8250
[    1.079487] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 27, base_baud = 3000000) is a 8250
[    1.089015] am65-cpsw-nuss: probe of 46000000.ethernet failed with error -2
[    1.096674] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
[    1.209431] mmc0: CQHCI version 5.10
[    1.213219] mmc1: CQHCI version 5.10
[    1.229702] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
[    1.236532] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
[    1.243327] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
[    1.253490] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
[    1.255244] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
[    1.260110] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
[    1.275057] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
[    1.282739] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
[    1.293377] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16)
[    1.313324] spi-nor spi0.0: mt35xu512aba (65536 Kbytes)
[    1.327257] ALSA device list:
[    1.330219]   No soundcards found.
[    1.333989] Waiting for root device /dev/mmcblk0p2...
[    1.355329] mmc1: Problem switching card into high-speed mode!
[    1.361278] mmc1: new SDHC card at address 0001
[    1.366229] mmcblk1: mmc1:0001 SD32G 29.1 GiB
[    1.372357]  mmcblk1: p1 p2
[    1.390850] mmc0: Command Queue Engine enabled
[    1.395288] mmc0: new HS200 MMC card at address 0001
[    1.400528] mmcblk0: mmc0:0001 AGUF4R 14.6 GiB
[    1.405139] mmcblk0boot0: mmc0:0001 AGUF4R partition 1 31.9 MiB
[    1.411125] mmcblk0boot1: mmc0:0001 AGUF4R partition 2 31.9 MiB
[    1.417114] mmcblk0rpmb: mmc0:0001 AGUF4R partition 3 4.00 MiB, chardev (237:0)
[    1.424996]  mmcblk0: p1 p2
[    1.540400] EXT4-fs (mmcblk0p2): recovery complete
[    1.545523] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    1.553637] VFS: Mounted root (ext4 filesystem) on device 179:34.
[    1.559990] devtmpfs: mounted
[    1.563864] Freeing unused kernel memory: 1792K
[    1.568489] Run /sbin/init as init process
[    1.622496] systemd[1]: System time before build time, advancing clock.
[    1.646117] NET: Registered protocol family 10
[    1.651024] Segment Routing with IPv6
[    1.660380] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
[    1.682123] systemd[1]: Detected architecture arm64.
Welcome to Arago 2021.09!
[    1.710972] systemd[1]: Set hostname to <c801soc2>.
[    1.833558] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock ¡ú /run/docker.sock; please update the unit file accordingly.
[    1.886341] random: systemd: uninitialized urandom read (16 bytes read)
[    1.893108] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[    1.905434] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[    1.915509] systemd[1]: Created slice system-getty.slice.
[  OK  ] Created slice system-getty.slice.
[    1.938747] random: systemd: uninitialized urandom read (16 bytes read)
[    1.946132] systemd[1]: Created slice system-serial\x2dgetty.slice.
[  OK  ] Created slice system-serial\x2dgetty.slice.
[    1.966740] random: systemd: uninitialized urandom read (16 bytes read)
[    1.973961] systemd[1]: Created slice User and Session Slice.
[  OK  ] Created slice User and Session Slice.
[    1.994871] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Started Dispatch Password ¡­ts to Console Directory Watch.
[    2.018789] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Started Forward Password R¡­uests to Wall Directory Watch.
[    2.042779] systemd[1]: Reached target Paths.
[  OK  ] Reached target Paths.
[    2.058726] systemd[1]: Reached target Remote File Systems.
[  OK  ] Reached target Remote File Systems.
[    2.078713] systemd[1]: Reached target Slices.
[  OK  ] Reached target Slices.
[    2.094721] systemd[1]: Reached target Swap.
[  OK  ] Reached target Swap.
[    2.112360] systemd[1]: Listening on RPCbind Server Activation Socket.
[  OK  ] Listening on RPCbind Server Activation Socket.
[    2.134766] systemd[1]: Reached target RPC Port Mapper.
[  OK  ] Reached target RPC Port Mapper.
[    2.156557] systemd[1]: Listening on Process Core Dump Socket.
[  OK  ] Listening on Process Core Dump Socket.
[    2.178876] systemd[1]: Listening on initctl Compatibility Named Pipe.
[  OK  ] Listening on initctl Compatibility Named Pipe.
[    2.206317] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[    2.214702] systemd[1]: Listening on Journal Socket (/dev/log).
[  OK  ] Listening on Journal Socket (/dev/log).
[    2.234976] systemd[1]: Listening on Journal Socket.
[  OK  ] Listening on Journal Socket.
[    2.251024] systemd[1]: Listening on Network Service Netlink Socket.
[  OK  ] Listening on Network Service Netlink Socket.
[    2.274941] systemd[1]: Listening on udev Control Socket.
[  OK  ] Listening on udev Control Socket.
[    2.294850] systemd[1]: Listening on udev Kernel Socket.
[  OK  ] Listening on udev Kernel Socket.
[    2.317123] systemd[1]: Mounting Huge Pages File System...
[    2.337008] systemd[1]: Mounting POSIX Message Queue File System...
[    2.361035] systemd[1]: Mounting Kernel Debug File System...
[    2.381052] systemd[1]: Mounting Temporary Directory (/tmp)...
[    2.401196] systemd[1]: Starting Create list of static device nodes for the current kernel...
         Starting Create list of st¡­odes for the current kernel...
[    2.428962] systemd[1]: Starting Start psplash boot splash screen...
[    2.457513] systemd[1]: Starting RPC Bind...
[    2.474914] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    2.486644] systemd[1]: Starting Journal Service...
[    2.510138] systemd[1]: Starting Load Kernel Modules...
[    2.523678] cryptodev: loading out-of-tree module taints kernel.
[    2.530637] cryptodev: driver 1.10 loaded.
[    2.532135] systemd[1]: Starting Remount Root and Kernel File Systems...
[    2.549513] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[    2.557881] systemd[1]: Starting udev Coldplug all Devices...
[    2.585788] systemd[1]: Started RPC Bind.
[  OK  ] Started RPC Bind.
[    2.607143] systemd[1]: Started Journal Service.
[  OK  ] Started Journal Service.
[  OK  ] Mounted Huge Pages File System.
[  OK  ] Mounted POSIX Message Queue File System.
[  OK  ] Mounted Kernel Debug File System.
[  OK  ] Mounted Temporary Directory (/tmp).
[  OK  ] Started Create list of sta¡­ nodes for the current kernel.
[FAILED] Failed to start Start psplash boot splash screen.
See 'systemctl status psplash-start.service' for details.
[DEPEND] Dependency failed for Star¡­progress communication helper.
[  OK  ] Started Load Kernel Modules.
[  OK  ] Started Remount Root and Kernel File Systems.
         Mounting Kernel Configuration File System...
         Starting Flush Journal to Persistent Storage...
[    2.821719] systemd-journald[155]: Received client request to flush runtime journal.
         Starting Apply Kernel Variables...
         Starting Create Static Device Nodes in /dev...
[    2.866729] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti_sci_cmd_put_device+0x18/0x28)
[  OK  ] Mounted Kernel Configuration File S[    2.878072] ti-sci 44083000.dmsc: Mbox send fail -110
ystem.
[    2.902719] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti_sci_cmd_put_device+0x18/0x28)
[    2.911517] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti_sci_cmd_put_device+0x18/0x28)
[    2.920315] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti_sci_cmd_put_device+0x18/0x28)
[    2.929114] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti_sci_cmd_put_device+0x18/0x28)
[    2.937914] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti_sci_cmd_put_device+0x18/0x28)
[    2.937924] ti-sci 44083000.dmsc: Mbox send fail -110
[    2.951743] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti_sci_cmd_put_device+0x18/0x28)
[    2.960522] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti_sci_cmd_put_device+0x18/0x28)
[  OK  ] Started udev Coldplug all Devices    2.969322] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti_sci_cmd_put_device+0x18/0x28)
0m.[    2.983637] ti-sci 44083000.dmsc: Mbox send fail -110
[    2.988917] ti-sci 44083000.dmsc: Mbox send fail -110
[    2.994134] ti-sci 44083000.dmsc: Mbox send fail -110
[    2.999184] ti-sci 44083000.dmsc: Mbox send fail -110
[    3.004250] ti-sci 44083000.dmsc: Mbox send fail -110
[    3.009300] ti-sci 44083000.dmsc: Mbox send fail -110
[  OK  ] Started Flush Journal to Persistent[    3.014418] ti-sci 44083000.dmsc: Mbox send fail -110
 Storage.
[  OK  ] Started Apply Kernel Variables.
[  OK  ] Started Create Static Device Nodes in /dev.
[    3.075304] urandom_read_iter: 47 callbacks suppressed
[    3.075308] random: systemd: uninitialized urandom read (16 bytes read)
[  OK  ] Reached target Local File Systems (Pre).
[    3.102772] random: systemd: uninitialized urandom read (16 bytes read)
         Mounting /media/ram...
[    3.112671] random: systemd-journal: uninitialized urandom read (16 bytes read)
         Mounting /var/volatile...
         Starting udev Wait for Complete Device Initialization...
         Starting udev Kernel Device Manager...
[  OK  ] Mounted /media/ram.
[  OK  ] Mounted /var/volatile.
[  OK  ] Started udev Kernel Device Manager.
         Starting Load/Save Random Seed...
[  OK  ] Reached target Local File Systems.
         Starting Create Volatile Files and Directories...
[  OK  ] Started Create Volatile Files and Directories.
         Starting Network Time Synchronization...
         Starting Update UTMP about System Boot/Shutdown...
[  OK  ] Started Update UTMP about System Boot/Shutdown.
[  OK  ] Started Network Time Synchronization.
[  OK  ] Reached target System Time Set.
[  OK  ] Reached target System Time Synchronized.
[    3.544370] CAN device driver interface
[    3.850748] pvrsrvkm 4e20000000.gpu: More than one power domain for this GPU, gpu driver manages power domains
[    4.107484] urandom_read_iter: 25 callbacks suppressed
[    4.107488] random: systemd: uninitialized urandom read (16 bytes read)
[    4.128818] random: systemd: uninitialized urandom read (16 bytes read)
[    4.140765] random: systemd: uninitialized urandom read (16 bytes read)
[    4.534723] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: sci_clk_recalc_rate+0x44/0xa0)
[    4.584504] ti-sci 44083000.dmsc: Mbox send fail -110
[    4.609139] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti_sci_cmd_get_device_exclusive+0x18/0x28)
[    4.635502] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti_sci_cmd_get_device_exclusive+0x18/0x28)
[    4.644262] ti-sci-clk 44083000.dmsc:clocks: recalc-rate failed for dev=252, clk=1, ret=-110
[    4.658723] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti_sci_cmd_get_device_exclusive+0x18/0x28)
[    4.667648] ti-sci 44083000.dmsc: Mbox send fail -110
[    4.668591] ti-sci 44083000.dmsc: Mbox send fail -110
[    4.684158] ti-sci 44083000.dmsc: Mbox send fail -110
[    4.722752] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: k3_dsp_rproc_probe+0x1a0/0x850 [ti_k3_dsp_remoteproc])
[    4.755360] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti_sci_cmd_get_device_exclusive+0x18/0x28)
[    4.771884] ti-sci 44083000.dmsc: Mbox send fail -110
[    4.783323] k3-dsp-rproc 4d80800000.dsp: ti-sci processor request failed: -110
[    4.800503] k3-dsp-rproc 4d80800000.dsp: ti_sci_proc_request failed, ret = -110
[    4.806952] ti-sci 44083000.dmsc: Mbox send fail -110
[    4.841818] remoteproc remoteproc0: releasing 4d80800000.dsp
[    4.849328] k3-dsp-rproc: probe of 4d80800000.dsp failed with error -110
[    4.859027] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti_sci_cmd_get_device_exclusive+0x18/0x28)
[    4.884526] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti_sci_cmd_get_device_exclusive+0x18/0x28)
[    4.902098] ti-sci 44083000.dmsc: Mbox send fail -110
[    4.907196] pvrsrvkm 4e20000000.gpu: adding gpu_0 device link failed!
ERROR:   Unhandled External Abort received on 0x80000001 from S-EL1
ERROR:   exception reason=0 syndrome=0xbf000000
Unhandled Exception from EL1
x0             = 0xffff800012500000
x1             = 0x0000000000000000
x2             = 0x0000000000000000
x3             = 0xffff800008e3b018
x4             = 0x0000000000000000
x5             = 0x8080808080808080
x6             = 0xffff8000121635d7
x7             = 0xfefefefefefefeff
x8             = 0x7f7f7f7f7f7f7f7f
x9             = 0x6b6860651f397224
x10            = 0x7f7f7f7f7f7f7f7f
x11            = 0x0101010101010101
x12            = 0x0000000000000000
x13            = 0xffff00082b9a1[    4.985685] ti-sci 44083000.dmsc: Mbox send fail -110
000
x14            = 0x000000ffc0000000
x15            = 0xffff800008d7da78
x16            = 0xffff800008d7d9a8
x17            = 0xffff800008d7dca8
x18            = 0xffff800008d7dab0
x19            = 0xffff00082a786800
x20            = 0xffff00082b9a0000
x21            = 0x0000000000000000
x22            = 0x0000000000000000
x23            = 0xffff00082a645400
x24            = 0xffff800008dc4418
x25            = 0xffff800008e4c000
x26            = 0xffff00082b9a0170
x27            = 0x0000000000000000
x28            = 0xffff800008dc4cd8
x29            = 0xffff800012163700
x30            = 0xffff800008d7a460
scr_el3        = 0x000000000000073d
sctlr_el3      = 0x0000000030cd183f
cptr_el3       = 0x0000000000000000
tcr_el3        = 0x0000000080803520
daif           = 0x00000000000002c0
mair_el3       = 0x00000000004404ff
spsr_el3       = 0x0000000080000005
elr_el3        = 0xffff800008d7a1e0
ttbr0_el3      = 0x0000000070011cc0
esr_el3        = 0x00000000bf000000
far_el3        = 0x0000000000000000
spsr_el1       = 0x0000000040000000
elr_el1        = 0x0000ffff8ddcdc98
spsr_abt       = 0x0000000000000000
spsr_und       = 0x0000000000000000
spsr_irq       = 0x0000000000000000
spsr_fiq       = 0x0000000000000000
sctlr_el1      = 0x0000000034d4d91d
actlr_el1      = 0x0000000000000000
cpacr_el1      = 0x0000000000300000
csselr_el1     = 0x0000000000000000
sp_el1         = 0xffff800012163700
esr_el1        = 0x0000000056000000
ttbr0_el1      = 0x00000008aa6cf000
ttbr1_el1      = 0x0092000080f4c000
mair_el1       = 0x000c0400bb44ffff
amair_el1      = 0x0000000000000000
tcr_el1        = 0x00000034b5d03590
tpidr_el1      = 0xffff80086ea10000
tpidr_el0      = 0x0000ffff8dfe6b40
tpidrro_el0    = 0x0000000000000000
par_el1        = 0x0000000000000000
mpidr_el1      = 0x0000000080000001
afsr0_el1      = 0x0000000000000000
afsr1_el1      = 0x0000000000000000
contextidr_el1 = 0x0000000000000000
vbar_el1       = 0xffff800010090800
cntp_ctl_el0   = 0x0000000000000005
cntp_cval_el0  = 0x0000000079eb61ac
cntv_ctl_el0   = 0x0000000000000000
cntv_cval_el0  = 0x0000000000000000
cntkctl_el1    = 0x00000000000000d6
sp_el0         = 0x000000007000bb80
isr_el1        = 0x0000000000000040
dacr32_el2     = 0x0000000000000000
ifsr32_el2     = 0x0000000000000000
cpuectlr_el1   = 0x0000001b00000040
cpumerrsr_el1  = 0x0000000000000000
l2merrsr_el1   = 0x0000000000000000
[  OK  ] Created slice system-systemd\x2dfsck.slice.
I/TC:
  • Hello Ji,
    These traces are classic symptom of the SciServer on MCU1_0 not responding properly.
    What MCU1_0 firmware are you using? Are you able to connect to MCU1_0 using CCS and see where it is stuck?
    regards
    Suman
