TDA4VM: App_srv_camera output
Part Number: TDA4VM
Dear
static vx_status app_run_graph(AppObj *obj)
    vx_status status = VX_SUCCESS;
    uint32_t num_refs, buf_id;
    int graph_parameter_num = 0;
    uint32_t iteration = 0;
    if(NULL == obj->sensor_name)
        printf("sensor name is NULL \n");
        status = VX_FAILURE;
    if(status == VX_SUCCESS)
        status = appStartImageSensor(obj->sensor_name, 0xF);
        APP_PRINTF("Sensor start status = %d\n", status);
    /* Enqueue buf for pipe up but don't trigger graph execution */
    for(buf_id=0; buf_id<NUM_BUFS; buf_id++)
            status = vxGraphParameterEnqueueReadyRef(obj->graph, graph_parameter_num,
                       (vx_reference*)&obj->capt_frames[buf_id], 1);
        graph_parameter_num++;
    if(obj->test_mode == 1)
                status = vxGraphParameterEnqueueReadyRef(obj->graph, obj->displayNodeGraphParamNum,
                                (vx_reference*)&obj->output_image[buf_id], 1);
    /* wait for graph instances to complete, compare output and
     * recycle data buffers, schedule again */
    vx_uint32 actual_checksum = 0;
    while(status == VX_SUCCESS)
        vx_object_array out_capture_frames;
        vx_image test_image;
        appPerfPointBegin(&obj->total_perf);
        /* Get output reference, waits until a frame is available */
            status = vxGraphParameterDequeueDoneRef(obj->graph, graph_parameter_num,
                            (vx_reference*)&out_capture_frames, 1, &num_refs);
                status = vxGraphParameterDequeueDoneRef(obj->graph, obj->displayNodeGraphParamNum,
                                                        (vx_reference*)&test_image, 1, &num_refs);
            printf("test iteration: %d of %d\n", iteration, TEST_BUFFER+1);
            if( (status == VX_SUCCESS) && (iteration > TEST_BUFFER) )
                if(app_test_check_image(test_image, checksums_expected[0][0], &actual_checksum) == vx_false_e)
                    test_result = vx_false_e;
                populate_gatherer(0, 0, actual_checksum);
                obj->stop_task = 1;
                                (vx_reference*)&test_image, 1);
            status = vxGraphParameterEnqueueReadyRef(obj->graph, graph_parameter_num, (vx_reference*)&out_capture_frames, 1);
        appPerfPointEnd(&obj->total_perf);
        if(iteration==100)
            /* after first 'n' iteration reset performance stats */
            appPerfStatsResetAll();
        iteration++;
        if((obj->stop_task) || (status != VX_SUCCESS))
            break;
    /* ensure all graph processing is complete */
    vxWaitGraph(obj->graph);
    /* Dequeue buf for pipe down */
    num_refs = 0xFF;
    while((num_refs > 0) && (status == VX_SUCCESS))
            status = vxGraphParameterCheckDoneRef(obj->graph, graph_parameter_num, &num_refs);
        if(num_refs > 0)
            APP_PRINTF("Dequeue capture\n");
                                            obj->graph,
                                            1,
                                            &num_refs);
    num_refs = 0xFF;
    while((num_refs > 0) && (obj->test_mode == 1) && (status == VX_SUCCESS))
        vx_image out_image;
            status = vxGraphParameterCheckDoneRef(obj->graph, obj->displayNodeGraphParamNum, &num_refs);
        if(num_refs > 0)
            APP_PRINTF("Dequeue display \n");
                                            obj->graph,
                                            (vx_reference*)&out_image,
                                            1,
                                            &num_refs);
    return status;
How can I find the output stream in "app_srv_camera" in this code and convert it (RGB) to H264 output?
