TDA4VM: surround demo debug
Part Number: TDA4VM
Hi, team
     we are debug surround camera demo by using vx_app_srv_camera.out. we found  it's different  from multi_cam demo in the control of camera. so we need to modify  sensor_drv? Because we use max96712 + max96705 + sensor, can you help us. Thinks
1) SDK:
ti-processor-sdk-linux-j7-evm-08_06_00_11
ti-processor-sdk-rtos-j721e-evm-08_06_00_12
2) Video link, EVK board from MAX96712 is connected to TDA4VM evaluation board via CSI interface:
AR0147+MAX96705+MAX96712-->CSI -->TDA4VM
  • we run the run_app_srv.sh script, but it can't init.  The log is fellows:
    ./run_app_srv.sh
    APP: Init ... !!!
    MEM: Init ... !!!
    MEM: Initialized DMA HEAP (fd=4) !!!
    MEM: Init ... Done !!!
    IPC: Init ... !!!
    IPC: Init ... Done !!!
    REMOTE_SERVICE: Init ... !!!
    REMOTE_SERVICE: Init ... Done !!!
        78.642150 s: GTC Frequency = 200 MHz
    APP: Init ... Done !!!
        78.648360 s:  VX_ZONE_INIT:Enabled
        78.648381 s:  VX_ZONE_ERROR:Enabled
        78.648387 s:  VX_ZONE_WARNING:Enabled
        78.649142 s:  VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
        78.650150 s:  VX_ZONE_INIT:[tivxHostInitLocal:93] Initialization Done for HOST !!!
        78.720032 s: ISS: Enumerating sensors ... !!!
    [MCU2_0]     78.720335 s: test999----ImageSensor_RemoteServiceHandler.CMD=0
    [MCU2_0]     78.720457 s: test-----IssSensor_DeserializerInit
    [MCU2_0]     78.720724 s: test-----ub960I2cInstId=6, ub960I2cAddr=75
    [MCU2_0]     78.720768 s: test-----setupI2CInst
    [MCU2_0]     78.720822 s: test----initFusion2_UB97x test
    [MCU2_0]     78.920453 s: test--writing to TCA6408 register 0x3 --status 0
    [MCU2_0]     79.120203 s: test----max96712_cfgScript
    [MCU2_0]     79.120271 s: MAX96712 config start
    [MCU2_0]     79.195466 s: End of MAX96712 config
    [MCU2_0]     79.195535 s: test----max96712_cfgScript
    [MCU2_0]     79.195573 s: MAX96712 config start
    [MCU2_0]     79.270463 s: End of MAX96712 config
    [MCU2_0]     79.270531 s: test----max96712_cfgScript
    [MCU2_0]     79.270567 s: MAX96712 config start
        79.345711 s: ISS: Enumerating sensors ... found 0 : IMX390-UB953_D3
        79.345728 s: ISS: Enumerating sensors ... found 1 : AR0233-UB953_MARS
        79.345749 s: ISS: Enumerating sensors ... found 2 : AR0820-UB953_LI
        79.345755 s: ISS: Enumerating sensors ... found 3 : UB9xxx_RAW12_TESTPATTERN
        79.345760 s: ISS: Enumerating sensors ... found 4 : UB96x_UYVY_TESTPATTERN
        79.345766 s: ISS: Enumerating sensors ... found 5 : GW_AR0233_UYVY
        79.345771 s: ISS: Enumerating sensors ... found 6 : MAX96705_AR0147_UYVY
    Sensor selected : MAX96705_AR0147_UYVY, 6
        79.345803 s: ISS: Querying sensor [MAX96705_AR0147_UYVY] ... !!!
        79.346732 s: ISS: Querying sensor [MAX96705_AR0147_UYVY] ... Done !!!
        79.346812 s:  VX_ZONE_ERROR:[ownIsValidCreateParams:60] invalid pixel_container for exposure index 0
        79.346828 s:  VX_ZONE_ERROR:[vxGetStatus:700] Reference is NULL
    [MCU2_0]     79.345462 s: End of MAX96712 config
    [MCU2_0]     79.346458 s: test999----ImageSensor_RemoteServiceHandler.CMD=1
    [MCU2_0]     79.346533 s: test-----IssSensor_GetSensorInfo.name--MAX96705_AR0147_UYVY
        79.359472 s:  VX_ZONE_WARNING:[vxReleaseContext:1055] Found a reference 0xffff95ed9dc0 of type 00000802 at external count 1, internal count 0, releasing it
        79.359487 s:  VX_ZONE_WARNING:[vxReleaseContext:1057] Releasing reference (name=3DSRV) now as a part of garbage collection
        79.359519 s: ISS: De-initializing sensor [MAX96705_AR0147_UYVY] ... !!!
        79.359997 s: ISS: De-initializing sensor [MAX96705_AR0147_UYVY] ... Done !!!
        79.360009 s:  VX_ZONE_INIT:[tivxHostDeInitLocal:107] De-Initialization Done for HOST !!!
    [MCU2_0]     79.359762 s: test999----ImageSensor_RemoteServiceHandler.CMD=6
    [MCU2_0]     79.359822 s: test----IssSensor_CloseHandle
        79.364375 s:  VX_ZONE_INIT:[tivxDeInitLocal:193] De-Initialization Done !!!
    APP: Deinit ... !!!
    REMOTE_SERVICE: Deinit ... !!!
    REMOTE_SERVICE: Deinit ... Done !!!
    IPC: Deinit ... !!!
    IPC: DeInit ... Done !!!
    MEM: Deinit ... !!!
    DDR_SHARED_MEM: Alloc's: 2 alloc's of 4147244 bytes
    DDR_SHARED_MEM: Free's : 2 free's  of 4147244 bytes
    DDR_SHARED_MEM: Open's : 0 allocs  of 0 bytes
    DDR_SHARED_MEM: Total size: 536870912 bytes
    MEM: Deinit ... Done !!!
    APP: Deinit ... Done !!!
    the app_srv.cfg is here. we modify the option is_enable_yuyv value from 0 to 1.
    cat app_srv.cfg
    # sensor selection. Currently only IMX390 supports multi-channel
    # 0 : IMX390
    sensor_index   6
    # Bowl offset
    offsetXleft    -400
    offsetXright   400
    offsetYfront   -450
    offsetYback    450
    # Num views
    num_views 10
    # view 0 parameters
    camx 0
    camy 0
    camz 200
    targetx 0
    targety 0
    targetz 0
    anglex 0
    angley 0
    anglez 0
    # view 1 parameters
    camx 0
    camy 0
    camz 400
    targetx 0
    targety 0
    targetz 0
    anglex 0
    angley 0
    anglez 0
    # view 2 parameters
    camx 0
    camy -260
    camz 240
    targetx 0
    targety 0
    targetz 0
    anglex 0
    angley 0
    anglez 0
    # view 3 parameters
    camx 0
    camy -260
    camz 160
    targetx -5
    targety 0
    targetz 0
    anglex 0
    angley 0
    anglez 0.5
    # view 4 parameters
    camx 0
    camy -260
    camz 160
    targetx -5
    targety 0
    targetz 0
    anglex 0
    angley 0
    anglez 1.5
    # view 5 parameters
    camx 0
    camy -260
    camz 160
    targetx -5
    targety 0
    targetz 0
    anglex 0
    angley 0
    anglez 2.50
    # view 6 parameters
    camx 0
    camy -280
    camz 160
    targetx -10
    targety 0
    targetz 0
    anglex 0
    angley 0
    anglez 3.14
    # view 7 parameters
    camx 0
    camy -280
    camz 160
    targetx -10
    targety 0
    targetz 0
    anglex 0
    angley 0
    anglez 4.0
    # view 8 parameters
    camx 0
    camy -280
    camz 160
    targetx -10
    targety 0
    targetz 0
    anglex 0
    angley 0
    anglez 5.0
    # view 9 parameters
    camx 0
    camy -280
    camz 160
    targetx -10
    targety 0
    targetz 0
    anglex 0
    angley 0
    anglez 5.5
    is_interactive 1
    is_enable_yuyv 1
    What exactly difference are you seeing in the output? Can you elaborate more on the output?
    Brijesh
  • when we run run_app_srv.sh script, it is error. Can you tell us why. The logs:
    ./run_app_srv.sh
    APP: Init ... !!!
    MEM: Init ... !!!
    IPC: Init ... !!!
    APP: Deinit ... !!!
    IPC: Deinit ... !!!
    MEM: Deinit ... !!!
    In  run_app_srv.txt we found that  IIC address of sensor serializer is write by appilcation, but in the multi_cam demo those address is config by IssSensor_CreateParams and we not found write address in the log.
    It clearly says that the pixel container for your output is not correct. Please correct pixel_container variable in your sensor config parameters.
    "VX_ZONE_ERROR:[ownIsValidCreateParams:60] invalid pixel_container for exposure index 0"
    Brijesh
  • HI,
    The sensor's output is yuv422@8bit UYVY, but the demo only support NV12 YUYV.  so we modify is_enable_yuyv from 0 to 1, and add code in API app_create_viss_aewb in vision_apps/apps/srv_demos/app_srv_camera/app_srv_camera.c as follows:
    if (0 == obj->is_enable_yuyv)
            obj->sample_nv12_img =
                vxCreateImage(obj->context, obj->inWidth, obj->inHeight,
                VX_DF_IMAGE_NV12);
        else if(1 == obj->is_enable_yuyv)
                VX_DF_IMAGE_UYVY);
            printf("Sensor pixel_container:is_enable_yuyv= 0x%x\n", obj->is_enable_yuyv);
        else
                VX_DF_IMAGE_YUYV);
    we add UYVY type of image, but it doesn't work.
    So how  to solve this problem? parameters of sensor  is fellow. Thinks
    static IssSensor_CreateParams  gw_ar0147CreatePrms = {
        GW_AR0147_UYVY,     /*sensor name*/
        0x6,                             /*i2cInstId*/
        {0, 0, 0, 0, 0, 0, 0, 0},   /*i2cAddrSensor*/
        {0x41, 0x42, 0x43, 0x44, 0, 0, 0, 0},      /*i2cAddrSer*/
        /*IssSensor_Info*/
                GW_AR0147_OUT_WIDTH,               /*width*/
                GW_AR0147_OUT_HEIGHT,              /*height*/
                1,                              /*num_exposures*/
                vx_false_e,                     /*line_interleaved*/
                    {VX_DF_IMAGE_UYVY, 7},    /*dataFormat and MSB [0]*/
                0,                              /*meta_height_before*/
                0,                              /*meta_height_after*/
            ISS_SENSOR_GW_AR0147_FEATURES,     /*features*/
            ALGORITHMS_ISS_AEWB_MODE_NONE,  /*aewbMode*/
            30,                             /*fps*/
            4,                              /*numDataLanes*/
            {1, 2, 3, 4},                   /*dataLanesMap*/
            {0, 0, 0, 0},                   /*dataLanesPolarity*/
    		CSIRX_LANE_BAND_SPEED_1350_TO_1500_MBPS, /*csi_laneBandSpeed*/
        4,                                  /*numChan*/
        5233,                                /*dccId*/
    Do you get a different error now that you have changed the vxCreateImage to support VX_DF_IMAGE_UYVY? Is the error in the SRV GPU node, or somewhere else?
    Please provide the logs of the issue when you made the code change so we can identify where the issue is.
    Erick
  • HI,team
    The error occurs after the modification,logs is follows:
    ./run_app_srv.sh
    APP: Init ... !!!
    MEM: Init ... !!!
    IPC: Init ... !!!
       325.328765 s: GTC Frequency = 200 MHz
       325.334969 s:  VX_ZONE_INIT:Enabled
       325.334989 s:  VX_ZONE_ERROR:Enabled
       325.334995 s:  VX_ZONE_WARNING:Enabled
       325.335788 s:  VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
       325.335917 s:  VX_ZONE_INIT:[tivxHostInitLocal:93] Initialization Done for HOST !!!
       325.404949 s: ISS: Enumerating sensors ... !!!
    [MCU2_0]    325.405267 s: test999----ImageSensor_RemoteServiceHandler.CMD=0
    [MCU2_0]    325.405389 s: test-----IssSensor_DeserializerInit
    [MCU2_0]    325.405662 s: test-----ub960I2cInstId=6, ub960I2cAddr=75
    [MCU2_0]    325.405706 s: test-----setupI2CInst
    [MCU2_0]    325.405761 s: test----initFusion2_UB97x test
    [MCU2_0]    325.606292 s: test--writing to TCA6408 register 0x3 --status 0
    [MCU2_0]    325.806037 s: test----max96712_cfgScript
    [MCU2_0]    325.806108 s: MAX96712 config start
    [MCU2_0]    325.881295 s: End of MAX96712 config
    [MCU2_0]    325.881365 s: test----max96712_cfgScript
    [MCU2_0]    325.881399 s: MAX96712 config start
    [MCU2_0]    325.956299 s: End of MAX96712 config
    [MCU2_0]    325.956365 s: test----max96712_cfgScript
    [MCU2_0]    325.956399 s: MAX96712 config start
       326.031547 s: ISS: Enumerating sensors ... found 0 : IMX390-UB953_D3
       326.031590 s: ISS: Enumerating sensors ... found 1 : AR0233-UB953_MARS
       326.031596 s: ISS: Enumerating sensors ... found 2 : AR0820-UB953_LI
       326.031601 s: ISS: Enumerating sensors ... found 3 : UB9xxx_RAW12_TESTPATTERN
       326.031607 s: ISS: Enumerating sensors ... found 4 : UB96x_UYVY_TESTPATTERN
       326.031612 s: ISS: Enumerating sensors ... found 5 : GW_AR0233_UYVY
       326.031617 s: ISS: Enumerating sensors ... found 6 : MAX96705_AR0147_UYVY
       326.031642 s: ISS: Querying sensor [MAX96705_AR0147_UYVY] ... !!!
       326.032542 s: ISS: Querying sensor [MAX96705_AR0147_UYVY] ... Done !!!
       326.032630 s:  VX_ZONE_ERROR:[ownIsValidCreateParams:60] invalid pixel_container for exposure index 0
       326.032646 s:  VX_ZONE_ERROR:[vxGetStatus:700] Reference is NULL
    [MCU2_0]    326.031296 s: End of MAX96712 config
    [MCU2_0]    326.032290 s: test999----ImageSensor_RemoteServiceHandler.CMD=1
    [MCU2_0]    326.032360 s: test-----IssSensor_GetSensorInfo.name--MAX96705_AR0147_UYVY
       326.054379 s:  VX_ZONE_WARNING:[vxReleaseContext:1055] Found a reference 0xffffa06dddc0 of type 00000802 at external count 1, internal count 0, releasing it
       326.054394 s:  VX_ZONE_WARNING:[vxReleaseContext:1057] Releasing reference (name=3DSRV) now as a part of garbage collection
       326.054425 s: ISS: De-initializing sensor [MAX96705_AR0147_UYVY] ... !!!
       326.054908 s: ISS: De-initializing sensor [MAX96705_AR0147_UYVY] ... Done !!!
       326.054921 s:  VX_ZONE_INIT:[tivxHostDeInitLocal:107] De-Initialization Done for HOST !!!
       326.059288 s:  VX_ZONE_INIT:[tivxDeInitLocal:193] De-Initialization Done !!!
    APP: Deinit ... !!!
    IPC: Deinit ... !!!
    MEM: Deinit ... !!!
    [MCU2_0]    326.054669 s: test999----ImageSensor_RemoteServiceHandler.CMD=6
    [MCU2_0]    326.054730 s: test----IssSensor_CloseHandle
    our sensor's parameters:
        0x6,                             /*i2cInstId*/
        /*IssSensor_Info*/
            30,                             /*fps*/
            4,                              /*numDataLanes*/
        4,                                  /*numChan*/
        5233,                                /*dccId*/
    when  set TIVX_RAW_IMAGE_16_BIT, we can get pixel_container value is 1052672 in API IssSensor_GetSensorInfo. It is correct value of TIVX_RAW_IMAGE_16_BIT(VX_ENUM_BASE(0x0001, 0X01) +0x00)
    when set VX_DF_IMAGE_UYVY, the pixel_container value  is 1498831189. It is correct value of VX_DF_IMAGE_UYVY.
    the error occurs in ownIsValidCreateParams  API in /ti-processor-sdk-rtos-j721e-evm-08_06_00_12/tiovx/source/framework/vx_raw_image.c, in the API   when  "pixel_container > (int32_t)TIVX_RAW_IMAGE_P12_BIT", it is error.  this is meaning  pixel_container only support  three mode  TIVX_RAW_IMAGE_16_BIT   TIVX_RAW_IMAGE_8_BIT TIVX_RAW_IMAGE_P12_BIT.
    But we run single_cam and multi_cam demo, it is no error about pixel_container using VX_DF_IMAGE_UYVY.  Can you help us? Thinks
    static vx_bool ownIsValidCreateParams(const tivx_raw_image_create_params_t *params)
        vx_bool is_valid = (vx_bool)vx_true_e;
        if( (params->width < 2u ) || (params->height < 1u ) || ((params->width & 1u) == 1u) )
            is_valid = (vx_bool)vx_false_e;
            VX_PRINT(VX_ZONE_ERROR, "invalid width and/or height\n");
        if( (params->num_exposures < 1u) || ((int32_t)params->num_exposures > TIVX_RAW_IMAGE_MAX_EXPOSURES) )
            VX_PRINT(VX_ZONE_ERROR, "invalid num_exposures\n");
        else
            uint32_t i;
            for(i=0; i < params->num_exposures; i++)
                if( (int32_t)params->format[i].pixel_container > (int32_t)TIVX_RAW_IMAGE_P12_BIT )
                    VX_PRINT(VX_ZONE_ERROR, "invalid pixel_container for exposure index %d\n", i);
                if( params->format[i].msb > 15u )
                    VX_PRINT(VX_ZONE_ERROR, "invalid msb for exposure index %d\n", i);
        return is_valid;
  • Hi,team
    We're still struggling with this question, Can you help us. Thinks
    Sorry for the delay in response.
    In the surround view application provided in the SDK, the "is_enable_yuyv" in the cfg file tells whether the VISS should output NV12 or YUV422 output.
    In this application, it expects the input to be a raw input from the sensor, which is why you are getting this error.
    In order to support a YUV input, you would have to modify the input based on the multi-cam application, which takes in YUV input and bypasses the VISS.
    Please refer the multi-cam example and modify the surround view demo.
    Nikhil
  • Hello, we have changed the output of the capture node to UYVY format, as shown below, but there were still errors during debugging.
    static vx_status app_create_capture(AppObj *obj)
        vx_status status = VX_SUCCESS;
        tivx_capture_params_t capture_params;
        uint32_t buf_id, loop_id;
        if(0)
            /* Creating exemplar to use for raw image */
            obj->sample_raw_img = tivxCreateRawImage(obj->context, &(sensorParams.sensorInfo.raw_params));
            if (vxGetStatus((vx_reference)obj->sample_raw_img) != VX_SUCCESS)
                APP_PRINTF("sample_raw_img create failed\n");
            /* Creating object arrays to be used as output to capture node */
            for(buf_id=0; buf_id<NUM_BUFS; buf_id++)
                obj->capt_frames[buf_id] =
                    vxCreateObjectArray(obj->context,
                    (vx_reference)obj->sample_raw_img, NUM_CAPT_CHANNELS);
                if (vxGetStatus((vx_reference)obj->capt_frames[buf_id]) != VX_SUCCESS)
                    APP_PRINTF("obj->capt_frames[buf_id] create failed\n");
                    return VX_FAILURE;
            tivxReleaseRawImage(&obj->sample_raw_img);
        else
            obj->cap_yuv_image=vxCreateImage(obj->context,sensorParams.sensorInfo.raw_params.width,sensorParams.sensorInfo.raw_params.height,VX_DF_IMAGE_UYVY);
            if (vxGetStatus((vx_reference)obj->cap_yuv_image) != VX_SUCCESS)
                APP_PRINTF("cap_yuv_image create failed\n");
                    (vx_reference)obj->cap_yuv_image, NUM_CAPT_CHANNELS);
                    return VX_FAILURE;
            vxReleaseImage(&obj->cap_yuv_image);
        /* Capture initialization */
        tivx_capture_params_init(&capture_params);
        capture_params.numInst                          = 1U;
        capture_params.numCh                            = NUM_CAPT_CHANNELS;
        capture_params.instId[0U]                       = CAPT_INST_ID;
        capture_params.instCfg[0U].enableCsiv2p0Support = (uint32_t)vx_true_e;
        capture_params.instCfg[0U].numDataLanes         = sensorParams.sensorInfo.numDataLanes;
        if(obj->test_mode == 1)
            capture_params.timeout = 33;
            capture_params.timeoutInitial = 500;
        for (loop_id=0U; loop_id<capture_params.instCfg[0U].numDataLanes; loop_id++)
            capture_params.instCfg[0U].dataLanesMap[loop_id] = sensorParams.sensorInfo.dataLanesMap[loop_id];
        obj->capture_param_obj =
            vxCreateUserDataObject(obj->context, "tivx_capture_params_t" ,
            sizeof(tivx_capture_params_t), &capture_params);
        if (vxGetStatus((vx_reference)obj->capture_param_obj) != VX_SUCCESS)
            APP_PRINTF("capture_param_obj create failed\n");
            return VX_FAILURE;
        obj->captureNode = tivxCaptureNode(obj->graph, obj->capture_param_obj, obj->capt_frames[0]);
        if (vxGetStatus((vx_reference)obj->captureNode) != VX_SUCCESS)
            APP_PRINTF("captureNode create failed\n");
            return VX_FAILURE;
        vxSetNodeTarget(obj->captureNode, VX_TARGET_STRING,
            TIVX_TARGET_CAPTURE1);
        vxSetReferenceName((vx_reference)obj->captureNode, "Capture_node");
        return status;
    there is the log:
    root@j7-evm:/opt/vision_apps# ./run_app_srv.sh
    APP: Init ... !!!
    MEM: Init ... !!!
    IPC: Init ... !!!
       136.886618 s: GTC Frequency = 200 MHz
       136.890048 s:  VX_ZONE_INIT:Enabled
       136.890071 s:  VX_ZONE_ERROR:Enabled
       136.890128 s:  VX_ZONE_WARNING:Enabled
       136.890959 s:  VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
       136.891950 s:  VX_ZONE_INIT:[tivxHostInitLocal:93] Initialization Done for HOST !!!
    00000000000000-------------------------vxVerifyGraph test!
    00000000000001-------------------------vxVerifyGraph test!
    00000000000002-------------------------vxVerifyGraph test! graph != NULL
    0000000000000004-------------------------vxVerifyGraph test! graph == NULL
    0000000000000005-------------------------vxVerifyGraph test! graph == NULL
    0000000000000006-------------------------vxVerifyGraph test! graph == NULL
    0000000000000007-------------------------vxVerifyGraph test! graph == NULL
    0000000000000007x1-------------------------vxVerifyGraph test! graph == NULL
    111111111111000000000-------------------------vxVerifyGraph test! graph == NULL
    111111111111000000004-------------------------vxVerifyGraph test! graph == NULL
    0000000000000007x2-------------------------vxVerifyGraph test! graph == NULL
    0000000000000008-------------------------vxVerifyGraph test! graph == NULL
    0000000000000009-------------------------vxVerifyGraph test! graph == NULL
    00000000000000010-------------------------vxVerifyGraph test! graph == NULL
    00000000000000011-------------------------vxVerifyGraph test! graph == NULL
    00000000000000012-------------------------vxVerifyGraph test! graph == NULL
    00000000000000013-------------------------vxVerifyGraph test! graph == NULL
    00000000000000014-------------------------vxVerifyGraph test! graph == NULL
    00000000000000015-------------------------vxVerifyGraph test! graph == NULL
    00000000000000016-------------------------vxVerifyGraph test! graph == NULL
    00000000000000017-------------------------vxVerifyGraph test! graph == NULL
    00000000000000018-------------------------vxVerifyGraph test! graph == NULL
    00000000000000019-------------------------vxVerifyGraph test! graph == NULL
    00000000000000020-------------------------vxVerifyGraph test! graph == NULL
    00000000000000021-------------------------vxVerifyGraph test! graph == NULL
    00000000000000023-------------------------vxVerifyGraph test! graph == NULL
       136.954359 s: ISS: Enumerating sensors ... !!!
       137.379456 s: ISS: Enumerating sensors ... found 0 : IMX390-UB953_D3
       137.379508 s: ISS: Enumerating sensors ... found 1 : AR0233-UB953_MARS
       137.379526 s: ISS: Enumerating sensors ... found 2 : AR0820-UB953_LI
       137.379543 s: ISS: Enumerating sensors ... found 3 : UB9xxx_RAW12_TESTPATTERN
       137.379559 s: ISS: Enumerating sensors ... found 4 : UB96x_UYVY_TESTPATTERN
       137.379574 s: ISS: Enumerating sensors ... found 5 : GW_AR0233_UYVY
       137.379589 s: ISS: Enumerating sensors ... found 6 : MAX96705_AR0147_UYVY
       137.379635 s: ISS: Querying sensor [MAX96705_AR0147_UYVY] ... !!!
       137.380346 s: ISS: Querying sensor [MAX96705_AR0147_UYVY] ... Done !!!
       137.384646 s: ISS: Initializing sensor [MAX96705_AR0147_UYVY], doing IM_SENSOR_CMD_PWRON ... !!!
       137.384992 s: ISS: Initializing sensor [MAX96705_AR0147_UYVY], doing IM_SENSOR_CMD_CONFIG ... !!!
    [MCU2_0]    137.385224 s: comon--appInit----start!!test--get handle returned for sensor MAX96705_AR0147_UYVY,sensorBroadcast=0
    [MCU2_0]    137.385371 s: test--set no broadcast mode, max96712 have no this mode
    [MCU2_0]    137.385429 s: test--IM_SENSOR_CMD_CONFIG channel_mask = f
    [MCU2_0]    137.385472 s: test--probeStatus = 0
    [MCU2_0]    137.385507 s: Configuring camera # 0
    [MCU2_0]    137.386525 s:  test---max96705 Write regAddr 4
    [MCU2_0]    137.386602 s:  test--max96705 Reg Write slaveAddr:0x40, regAddr:0x0004, regValue:0x47
    [MCU2_0]    137.626530 s:  test---max96705 Write regAddr 0
    [MCU2_0]    137.626616 s:  test--max96705 Reg Write slaveAddr:0x40, regAddr:0x0000, regValue:0x82
    [MCU2_0]    137.866310 s: test--MAx96712_SetSensorAlias status = 0
    [MCU2_0]    137.866599 s:  test---max96705 Write regAddr 7
    [MCU2_0]    137.866668 s:  test--max96705 Reg Write slaveAddr:0x41, regAddr:0x0007, regValue:0x84
    [MCU2_0]    137.962527 s:  test---max96705 Write regAddr 15
    [MCU2_0]    137.962609 s:  test--max96705 Reg Write slaveAddr:0x41, regAddr:0x000f, regValue:0xbf
    [MCU2_0]    138.058315 s: test--probeStatus = 0
    [MCU2_0]    138.058379 s: Configuring camera # 1
    [MCU2_0]    138.059607 s:  test---max96705 Write regAddr 4
    [MCU2_0]    138.059681 s:  test--max96705 Reg Write slaveAddr:0x40, regAddr:0x0004, regValue:0x47
    [MCU2_0]    138.299526 s:  test---max96705 Write regAddr 0
    [MCU2_0]    138.299611 s:  test--max96705 Reg Write slaveAddr:0x40, regAddr:0x0000, regValue:0x84
    [MCU2_0]    138.539314 s: test--MAx96712_SetSensorAlias status = 0
    [MCU2_0]    138.539609 s:  test---max96705 Write regAddr 7
    [MCU2_0]    138.539676 s:  test--max96705 Reg Write slaveAddr:0x42, regAddr:0x0007, regValue:0x84
    [MCU2_0]    138.635526 s:  test---max96705 Write regAddr 15
    [MCU2_0]    138.635608 s:  test--max96705 Reg Write slaveAddr:0x42, regAddr:0x000f, regValue:0xbf
    [MCU2_0]    138.731308 s: test--probeStatus = 0
    [MCU2_0]    138.731369 s: Configuring camera # 2
    [MCU2_0]    138.732605 s:  test---max96705 Write regAddr 4
    [MCU2_0]    138.732682 s:  test--max96705 Reg Write slaveAddr:0x40, regAddr:0x0004, regValue:0x47
    [MCU2_0]    138.972526 s:  test---max96705 Write regAddr 0
    [MCU2_0]    138.972613 s:  test--max96705 Reg Write slaveAddr:0x40, regAddr:0x0000, regValue:0x86
    [MCU2_0]    139.212316 s: test--MAx96712_SetSensorAlias status = 0
    [MCU2_0]    139.212603 s:  test---max96705 Write regAddr 7
    [MCU2_0]    139.212665 s:  test--max96705 Reg Write slaveAddr:0x43, regAddr:0x0007, regValue:0x84
    [MCU2_0]    139.308541 s:  test---max96705 Write regAddr 15
    [MCU2_0]    139.308622 s:  test--max96705 Reg Write slaveAddr:0x43, regAddr:0x000f, regValue:0xbf
    [MCU2_0]    139.404308 s: test--probeStatus = 0
    [MCU2_0]    139.404371 s: Configuring camera # 3
    [MCU2_0]    139.405608 s:  test---max96705 Write regAddr 4
    [MCU2_0]    139.405684 s:  test--max96705 Reg Write slaveAddr:0x40, regAddr:0x0004, regValue:0x47
    [MCU2_0]    139.645525 s:  test---max96705 Write regAddr 0
    [MCU2_0]    139.645607 s:  test--max96705 Reg Write slaveAddr:0x40, regAddr:0x0000, regValue:0x88
    [MCU2_0]    139.885312 s: test--MAx96712_SetSensorAlias status = 0
    [MCU2_0]    139.885606 s:  test---max96705 Write regAddr 7
    [MCU2_0]    139.885671 s:  test--max96705 Reg Write slaveAddr:0x44, regAddr:0x0007, regValue:0x84
    [MCU2_0]    139.981532 s:  test---max96705 Write regAddr 15
    [MCU2_0]    139.981615 s:  test--max96705 Reg Write slaveAddr:0x44, regAddr:0x000f, regValue:0xbf
       140.077440 s: ISS: Initializing sensor [MAX96705_AR0147_UYVY] ... Done !!!
    MEM: ERROR: Alloc failed with status = 12 !!!
       140.078690 s:  VX_ZONE_ERROR:[tivxMemBufferAlloc:87] Shared mem ptr allocation failed
       140.078721 s:  VX_ZONE_ERROR:[ownAllocUserDataObjectBuffer:96] Could not allocate user data object memory
       140.078746 s:  VX_ZONE_ERROR:[vxMapUserDataObject:476] Invalid user data object reference
    Error getting VISS DCC buffer
       140.091780 s:  VX_ZONE_WARNING:[vxReleaseContext:1066] A kernel with name com.ti.capture has not been removed, possibly due to a kernel module not being unloaded.
       140.091804 s:  VX_ZONE_WARNING:[vxReleaseContext:1067] Removing as a part of garbage collection
       140.091830 s:  VX_ZONE_WARNING:[ownDecrementReference:190] #### EXTERNAL REF COUNT IS ALREADY ZERO!!! 0xffffbcaff500 type:00000804 #####
       140.091849 s:  VX_ZONE_WARNING:[vxReleaseContext:1055] Found a reference 0xffffbc18fdc0 of type 00000802 at external count 1, internal count 0, releasing it
       140.091867 s:  VX_ZONE_WARNING:[vxReleaseContext:1057] Releasing reference (name=3DSRV) now as a part of garbage collection
       140.091896 s:  VX_ZONE_WARNING:[vxReleaseContext:1055] Found a reference 0xffffbcb42b88 of type 00000816 at external count 1, internal count 0, releasing it
       140.091913 s:  VX_ZONE_WARNING:[vxReleaseContext:1057] Releasing reference (name=user_data_object_95) now as a part of garbage collection
       140.091956 s:  VX_ZONE_WARNING:[vxReleaseContext:1055] Found a reference 0xffffbcbe9090 of type 00000813 at external count 1, internal count 0, releasing it
       140.091977 s:  VX_ZONE_WARNING:[vxReleaseContext:1057] Releasing reference (name=object_array_96) now as a part of garbage collection
       140.092007 s:  VX_ZONE_WARNING:[vxReleaseContext:1055] Found a reference 0xffffbcb7c458 of type 0000080f at external count 1, internal count 0, releasing it
       140.092024 s:  VX_ZONE_WARNING:[vxReleaseContext:1057] Releasing reference (name=image_97) now as a part of garbage collection
       140.092042 s:  VX_ZONE_WARNING:[vxReleaseContext:1055] Found a reference 0xffffbcbe9230 of type 00000813 at external count 1, internal count 0, releasing it
       140.092058 s:  VX_ZONE_WARNING:[vxReleaseContext:1057] Releasing reference (name=object_array_101) now as a part of garbage collection
       140.092087 s:  VX_ZONE_WARNING:[vxReleaseContext:1055] Found a reference 0xffffbcbe93d0 of type 00000813 at external count 1, internal count 0, releasing it
       140.092103 s:  VX_ZONE_WARNING:[vxReleaseContext:1057] Releasing reference (name=object_array_106) now as a part of garbage collection
       140.092133 s:  VX_ZONE_WARNING:[vxReleaseContext:1055] Found a reference 0xffffbcbe9570 of type 00000813 at external count 1, internal count 0, releasing it
       140.092149 s:  VX_ZONE_WARNING:[vxReleaseContext:1057] Releasing reference (name=object_array_111) now as a part of garbage collection
       140.092178 s:  VX_ZONE_WARNING:[vxReleaseContext:1055] Found a reference 0xffffbcb42da8 of type 00000816 at external count 1, internal count 0, releasing it
       140.092194 s:  VX_ZONE_WARNING:[vxReleaseContext:1057] Releasing reference (name=user_data_object_117) now as a part of garbage collection
       140.092233 s:  VX_ZONE_WARNING:[vxReleaseContext:1055] Found a reference 0xffffbcbe9710 of type 00000813 at external count 1, internal count 0, releasing it
       140.092251 s:  VX_ZONE_WARNING:[vxReleaseContext:1057] Releasing reference (name=object_array_118) now as a part of garbage collection
       140.092277 s:  VX_ZONE_WARNING:[vxReleaseContext:1055] Found a reference 0xffffbcb7efd8 of type 0000080f at external count 1, internal count 0, releasing it
       140.092293 s:  VX_ZONE_WARNING:[vxReleaseContext:1057] Releasing reference (name=image_119) now as a part of garbage collection
       140.092312 s:  VX_ZONE_WARNING:[vxReleaseContext:1055] Found a reference 0xffffbcb42fc8 of type 00000816 at external count 1, internal count 0, releasing it
       140.092327 s:  VX_ZONE_WARNING:[vxReleaseContext:1057] Releasing reference (name=user_data_object_123) now as a part of garbage collection
       140.092345 s:  VX_ZONE_WARNING:[vxReleaseContext:1055] Found a reference 0xffffbcbe98b0 of type 00000813 at external count 1, internal count 0, releasing it
       140.092361 s:  VX_ZONE_WARNING:[vxReleaseContext:1057] Releasing reference (name=object_array_124) now as a part of garbage collection
       140.092453 s:  VX_ZONE_WARNING:[vxReleaseContext:1055] Found a reference 0xffffbcb431e8 of type 00000816 at external count 1, internal count 0, releasing it
       140.092475 s:  VX_ZONE_WARNING:[vxReleaseContext:1057] Releasing reference (name=user_data_object_125) now as a part of garbage collection
       140.092514 s:  VX_ZONE_WARNING:[vxReleaseContext:1055] Found a reference 0xffffbcbe9a50 of type 00000813 at external count 1, internal count 0, releasing it
       140.092539 s:  VX_ZONE_WARNING:[vxReleaseContext:1057] Releasing reference (name=object_array_129) now as a part of garbage collection
       140.092615 s:  VX_ZONE_WARNING:[vxReleaseContext:1055] Found a reference 0xffffbcb43a68 of type 00000816 at external count 1, internal count 0, releasing it
       140.092627 s:  VX_ZONE_WARNING:[vxReleaseContext:1057] Releasing reference (name=user_data_object_130) now as a part of garbage collection
       140.092679 s: ISS: De-initializing sensor [MAX96705_AR0147_UYVY] ... !!!
       140.093023 s: ISS: De-initializing sensor [MAX96705_AR0147_UYVY] ... Done !!!
       140.093038 s:  VX_ZONE_INIT:[tivxHostDeInitLocal:107] De-Initialization Done for HOST !!!
       140.097445 s:  VX_ZONE_INIT:[tivxDeInitLocal:193] De-Initialization Done !!!
    APP: Deinit ... !!!
    IPC: Deinit ... !!!
    MEM: Deinit ... !!!
    DDR_SHARED_MEM: Alloc's: 14 alloc's of 4271112 bytes
    DDR_SHARED_MEM: Free's : 14 free's  of 4271112 bytes
    You should bypass the VISS, AEWB nodes here if the input format is YUV.
    Please refer the multi-cam example to check where all the changes are required if the capture node outputs YUV format.
    Nikhil
    we have made relevant modifications based on multi cam codec, but when "status=appStartImageSensor (obj ->sensorname, 0xF);", the return value is incorrect. However, when we run "multi cam codec", "appStartImageSensor" is not a problem. What is the reason for this? Is there a solution?
    Yueqian
    We are puzzled here that the "appStartImageSensor" function and parameters in "app_multi_cam_codec" and "app_srv_camera" are the same, but the return value in "app_multi_cam_codec" is correct, but the return value in "app_srv_camera" is incorrect.
    Yueqian
  • There are the logs:
    (1)test_"app_multi_cam_codec"________________appStartImageSensor(obj->sensor_name, ch_mask) sensor_name:MAX96705_AR0147_UYVY, ch_mask=15;
    (2)test_"app_srv_camera"________________appStartImageSensor(obj->sensor_name, 0xF) sensor_name:MAX96705_AR0147_UYVY;
    May I know what is the error that is being faced currently. Sorry, I couldn't find your latest logs in this thread (after the VISS issue)
    Could you please share your latest logs? Is the Verify graph successfully executed?
    Nikhil
  • OK, there is the log.
    APP: Init ... !!!
    MEM: Init ... !!!
    IPC: Init ... !!!
       247.236512 s: GTC Frequency = 200 MHz
       247.236846 s:  VX_ZONE_INIT:Enabled
       247.236914 s:  VX_ZONE_ERROR:Enabled
       247.236974 s:  VX_ZONE_WARNING:Enabled
       247.237684 s:  VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
       247.239031 s:  VX_ZONE_INIT:[tivxHostInitLocal:93] Initialization Done for HOST !!!
       247.292370 s: ISS: Enumerating sensors ... !!!
       247.717991 s: ISS: Enumerating sensors ... found 0 : IMX390-UB953_D3
       247.718028 s: ISS: Enumerating sensors ... found 1 : AR0233-UB953_MARS
       247.718241 s: ISS: Enumerating sensors ... found 2 : AR0820-UB953_LI
       247.718272 s: ISS: Enumerating sensors ... found 3 : UB9xxx_RAW12_TESTPATTERN
       247.718283 s: ISS: Enumerating sensors ... found 4 : UB96x_UYVY_TESTPATTERN
       247.718291 s: ISS: Enumerating sensors ... found 5 : GW_AR0233_UYVY
       247.718299 s: ISS: Enumerating sensors ... found 6 : MAX96705_AR0147_UYVY
    test_a1_________________status: 0
    test0________Querying MAX96705_AR0147_UYVY
       247.718338 s: ISS: Querying sensor [MAX96705_AR0147_UYVY] ... !!!
       247.718638 s: ISS: Querying sensor [MAX96705_AR0147_UYVY] ... Done !!!
    test1________TIVX_TARGET_DISPLAY1 1
    test2________TIVX_TARGET_CAPTURE1 1
    test3________TIVX_TARGET_VPAC_VISS1 1
    start cap_yuv_image create!
    test4________app_create_capture end1, status = 0
    test_____________start app_create_graph_gpu_lut
    Reading calmat file
    file read completed
    test_______________obj->srv_node = tivxGlSrvNode:capt_frames[0]
    111111111111000000001-------------------------vxVerifyGraph test! graph == NULL
    111111111111000000002-------------------------num_params=1,param_idx=0
    EGL: version 1.5
    EGL: GL Version = (null)
    EGL: GL Vendor = (null)
    EGL: GL Renderer = (null)
    EGL: GL Extensions = (null)
    test_a2_______________ _status: 0
    test_a3_______________ _status: 0
    test_a4_______________ app_run_graph_gpu_lut
     Demo : Integrated SRV
     p: Print performance statistics
     e: Export performance statistics
     x: Exit
     Enter Choice: test_b0_________________app_run_graph start
    test_b1________________appStartImageSensor(obj->sensor_name, 0xF)  sensor_name:MAX96705_AR0147_UYVY
       248.133652 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] ... !!!
    [MCU2_0]    248.133976 s: test--IM_SENSOR_CMD_STREAM_ON:  channel_mask = 0xf, sensorBroadcast=0
    [MCU2_0]    248.134049 s: test--ar0147_StreamOn
    [MCU2_0]    248.134326 s:  test---max96705 Write regAddr 4
    [MCU2_0]    248.134390 s:  test--max96705 Reg Write slaveAddr:0x41, regAddr:0x0004, regValue:0x87
       248.231013 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] failed !!!
    test_b2________________Sensor start status = -1
    test_b3________________vxGraphParameterEnqueueReadyRef status = -1
    test_b4________________status = -1
       248.231083 s:  VX_ZONE_ERROR:[vxWaitGraph:867] graph not in expected state
       248.231103 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] ... !!!
    [MCU2_0]    248.229820 s: test--ar0147_StreamOn
    [MCU2_0]    248.230014 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    248.230067 s:  test---max96705 Write regAddr 4
    [MCU2_0]    248.230157 s: Error : Failed to start sensor at channel Id 1
    [MCU2_0]    248.230193 s: test--ar0147_StreamOn
    [MCU2_0]    248.230324 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    248.230369 s:  test---max96705 Write regAddr 4
    [MCU2_0]    248.230411 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    248.230458 s: Error : Failed to start sensor at channel Id 2
    [MCU2_0]    248.230493 s: test--ar0147_StreamOn
    [MCU2_0]    248.230619 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    248.230665 s:  test---max96705 Write regAddr 4
    [MCU2_0]    248.230708 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    248.230753 s: Error : Failed to start sensor at channel Id 3
    [MCU2_0]    248.231361 s: test--IM_SENSOR_CMD_STREAM_ON:  channel_mask = 0xf, sensorBroadcast=0
    [MCU2_0]    248.231425 s: test--ar0147_StreamOn
    [MCU2_0]    248.231691 s:  test---max96705 Write regAddr 4
    [MCU2_0]    248.231753 s:  test--max96705 Reg Write slaveAddr:0x41, regAddr:0x0004, regValue:0x87
    [MCU2_0]    248.230110 s:  max96705 Error: Reg Write Failed for regAddr 4
       248.329058 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] failed !!!
       248.329136 s:  VX_ZONE_ERROR:[vxWaitGraph:867] graph not in expected state
       248.329155 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] ... !!!
    [MCU2_0]    248.327833 s: test--ar0147_StreamOn
    [MCU2_0]    248.328025 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    248.328127 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    248.328174 s: Error : Failed to start sensor at channel Id 1
    [MCU2_0]    248.328209 s: test--ar0147_StreamOn
    [MCU2_0]    248.328343 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    248.328393 s:  test---max96705 Write regAddr 4
    [MCU2_0]    248.328435 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    248.328479 s: Error : Failed to start sensor at channel Id 2
    [MCU2_0]    248.328513 s: test--ar0147_StreamOn
    [MCU2_0]    248.328644 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    248.328690 s:  test---max96705 Write regAddr 4
    [MCU2_0]    248.328731 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    248.328855 s: Error : Failed to start sensor at channel Id 3
    [MCU2_0]    248.329903 s: test--IM_SENSOR_CMD_STREAM_ON:  channel_mask = 0xf, sensorBroadcast=0
    [MCU2_0]    248.329965 s: test--ar0147_StreamOn
    [MCU2_0]    248.330235 s:  test---max96705 Write regAddr 4
    [MCU2_0]    248.330298 s:  test--max96705 Reg Write slaveAddr:0x41, regAddr:0x0004, regValue:0x87
    [MCU2_0]    248.328080 s:  test---max96705 Write regAddr 4
       248.427021 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] failed !!!
       248.427152 s:  VX_ZONE_ERROR:[vxWaitGraph:867] graph not in expected state
       248.427195 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] ... !!!
    [MCU2_0]    248.425815 s: test--ar0147_StreamOn
    [MCU2_0]    248.426011 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    248.426104 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    248.426149 s: Error : Failed to start sensor at channel Id 1
    [MCU2_0]    248.426187 s: test--ar0147_StreamOn
    [MCU2_0]    248.426320 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    248.426365 s:  test---max96705 Write regAddr 4
    [MCU2_0]    248.426407 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    248.426452 s: Error : Failed to start sensor at channel Id 2
    [MCU2_0]    248.426487 s: test--ar0147_StreamOn
    [MCU2_0]    248.426612 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    248.426658 s:  test---max96705 Write regAddr 4
    [MCU2_0]    248.426703 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    248.426749 s: Error : Failed to start sensor at channel Id 3
    [MCU2_0]    248.426062 s:  test---max96705 Write regAddr 4
    [MCU2_0]    248.428146 s: test--IM_SENSOR_CMD_STREAM_ON:  channel_mask = 0xf, sensorBroadcast=0
    [MCU2_0]    248.428214 s: test--ar0147_StreamOn
    [MCU2_0]    248.428478 s:  test---max96705 Write regAddr 4
    [MCU2_0]    248.428542 s:  test--max96705 Reg Write slaveAddr:0x41, regAddr:0x0004, regValue:0x87
       248.525035 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] failed !!!
       248.525410 s:  VX_ZONE_ERROR:[vxWaitGraph:867] graph not in expected state
       248.525431 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] ... !!!
    [MCU2_0]    248.523820 s: test--ar0147_StreamOn
    [MCU2_0]    248.524013 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    248.524066 s:  test---max96705 Write regAddr 4
    [MCU2_0]    248.524111 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    248.524158 s: Error : Failed to start sensor at channel Id 1
    [MCU2_0]    248.524195 s: test--ar0147_StreamOn
    [MCU2_0]    248.524328 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    248.524374 s:  test---max96705 Write regAddr 4
    [MCU2_0]    248.524417 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    248.524463 s: Error : Failed to start sensor at channel Id 2
    [MCU2_0]    248.524497 s: test--ar0147_StreamOn
    [MCU2_0]    248.524625 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    248.524673 s:  test---max96705 Write regAddr 4
    [MCU2_0]    248.524716 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    248.524762 s: Error : Failed to start sensor at channel Id 3
    [MCU2_0]    248.525682 s: test--IM_SENSOR_CMD_STREAM_ON:  channel_mask = 0xf, sensorBroadcast=0
    [MCU2_0]    248.525744 s: test--ar0147_StreamOn
    [MCU2_0]    248.526088 s:  test---max96705 Write regAddr 4
    [MCU2_0]    248.526156 s:  test--max96705 Reg Write slaveAddr:0x41, regAddr:0x0004, regValue:0x87
       248.623035 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] failed !!!
       248.623138 s:  VX_ZONE_ERROR:[vxWaitGraph:867] graph not in expected state
       248.623177 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] ... !!!
    [MCU2_0]    248.621820 s: test--ar0147_StreamOn
    [MCU2_0]    248.622014 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    248.622069 s:  test---max96705 Write regAddr 4
    [MCU2_0]    248.622114 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    248.622163 s: Error : Failed to start sensor at channel Id 1
    [MCU2_0]    248.622200 s: test--ar0147_StreamOn
    [MCU2_0]    248.622334 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    248.622380 s:  test---max96705 Write regAddr 4
    [MCU2_0]    248.622421 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    248.622467 s: Error : Failed to start sensor at channel Id 2
    [MCU2_0]    248.622503 s: test--ar0147_StreamOn
    [MCU2_0]    248.622633 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    248.622678 s:  test---max96705 Write regAddr 4
    [MCU2_0]    248.622721 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    248.622837 s: Error : Failed to start sensor at channel Id 3
    [MCU2_0]    248.623431 s: test--IM_SENSOR_CMD_STREAM_ON:  channel_mask = 0xf, sensorBroadcast=0
    [MCU2_0]    248.623496 s: test--ar0147_StreamOn
    [MCU2_0]    248.623762 s:  test---max96705 Write regAddr 4
    [MCU2_0]    248.623910 s:  test--max96705 Reg Write slaveAddr:0x41, regAddr:0x0004, regValue:0x87
    [MCU2_0]    248.719819 s: test--ar0147_StreamOn
    [MCU2_0]    248.720021 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    248.720078 s:  test---max96705 Write regAddr 4
    [MCU2_0]    248.720122 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    248.720169 s: Error : Failed to start sensor at channel Id 1
    [MCU2_0]    248.720207 s: test--ar0147_StreamOn
    [MCU2_0]    248.720340 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    248.720386 s:  test---max96705 Write regAddr 4
    [MCU2_0]    248.720429 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    248.720475 s: Error : Failed to start sensor at channel Id 2
    [MCU2_0]    248.720510 s: test--ar0147_StreamOn
       248.721043 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] failed !!!
       248.721097 s:  VX_ZONE_ERROR:[vxWaitGraph:867] graph not in expected state
       248.721115 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] ... !!!
    [MCU2_0]    248.720638 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    248.720682 s:  test---max96705 Write regAddr 4
    [MCU2_0]    248.720722 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    248.720844 s: Error : Failed to start sensor at channel Id 3
    [MCU2_0]    248.721365 s: test--IM_SENSOR_CMD_STREAM_ON:  channel_mask = 0xf, sensorBroadcast=0
    [MCU2_0]    248.721428 s: test--ar0147_StreamOn
    [MCU2_0]    248.721695 s:  test---max96705 Write regAddr 4
    [MCU2_0]    248.721761 s:  test--max96705 Reg Write slaveAddr:0x41, regAddr:0x0004, regValue:0x87
       248.819037 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] failed !!!
       248.819113 s:  VX_ZONE_ERROR:[vxWaitGraph:867] graph not in expected state
       248.819132 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] ... !!!
    [MCU2_0]    248.817821 s: test--ar0147_StreamOn
    [MCU2_0]    248.818016 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    248.818069 s:  test---max96705 Write regAddr 4
    [MCU2_0]    248.818162 s: Error : Failed to start sensor at channel Id 1
    [MCU2_0]    248.818114 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    248.818330 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    248.818199 s: test--ar0147_StreamOn
    [MCU2_0]    248.818416 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    248.818375 s:  test---max96705 Write regAddr 4
    [MCU2_0]    248.818496 s: test--ar0147_StreamOn
    [MCU2_0]    248.818623 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    248.818461 s: Error : Failed to start sensor at channel Id 2
    [MCU2_0]    248.818712 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    248.818758 s: Error : Failed to start sensor at channel Id 3
    [MCU2_0]    248.818670 s:  test---max96705 Write regAddr 4
    [MCU2_0]    248.819982 s: test--ar0147_StreamOn
    [MCU2_0]    248.820246 s:  test---max96705 Write regAddr 4
    [MCU2_0]    248.819915 s: test--IM_SENSOR_CMD_STREAM_ON:  channel_mask = 0xf, sensorBroadcast=0
    [MCU2_0]    248.820310 s:  test--max96705 Reg Write slaveAddr:0x41, regAddr:0x0004, regValue:0x87
       248.917070 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] failed !!!
       248.917147 s:  VX_ZONE_ERROR:[vxWaitGraph:867] graph not in expected state
       248.917169 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] ... !!!
    [MCU2_0]    248.915818 s: test--ar0147_StreamOn
    [MCU2_0]    248.916072 s:  test---max96705 Write regAddr 4
    [MCU2_0]    248.916016 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    248.916119 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    248.916167 s: Error : Failed to start sensor at channel Id 1
    [MCU2_0]    248.916205 s: test--ar0147_StreamOn
    [MCU2_0]    248.916340 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    248.916387 s:  test---max96705 Write regAddr 4
    [MCU2_0]    248.916429 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    248.916476 s: Error : Failed to start sensor at channel Id 2
    [MCU2_0]    248.916512 s: test--ar0147_StreamOn
    [MCU2_0]    248.916643 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    248.916691 s:  test---max96705 Write regAddr 4
    [MCU2_0]    248.916734 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    248.916859 s: Error : Failed to start sensor at channel Id 3
    [MCU2_0]    248.917872 s: test--IM_SENSOR_CMD_STREAM_ON:  channel_mask = 0xf, sensorBroadcast=0
    [MCU2_0]    248.917939 s: test--ar0147_StreamOn
    [MCU2_0]    248.918207 s:  test---max96705 Write regAddr 4
    [MCU2_0]    248.918271 s:  test--max96705 Reg Write slaveAddr:0x41, regAddr:0x0004, regValue:0x87
       249.015048 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] failed !!!
       249.015115 s:  VX_ZONE_ERROR:[vxWaitGraph:867] graph not in expected state
       249.015134 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] ... !!!
    [MCU2_0]    249.013822 s: test--ar0147_StreamOn
    [MCU2_0]    249.014019 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    249.014070 s:  test---max96705 Write regAddr 4
    [MCU2_0]    249.014113 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    249.014160 s: Error : Failed to start sensor at channel Id 1
    [MCU2_0]    249.014195 s: test--ar0147_StreamOn
    [MCU2_0]    249.014329 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    249.014373 s:  test---max96705 Write regAddr 4
    [MCU2_0]    249.014415 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    249.014460 s: Error : Failed to start sensor at channel Id 2
    [MCU2_0]    249.014495 s: test--ar0147_StreamOn
    [MCU2_0]    249.014625 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    249.014670 s:  test---max96705 Write regAddr 4
    [MCU2_0]    249.014713 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    249.014759 s: Error : Failed to start sensor at channel Id 3
    [MCU2_0]    249.015652 s: test--IM_SENSOR_CMD_STREAM_ON:  channel_mask = 0xf, sensorBroadcast=0
    [MCU2_0]    249.015716 s: test--ar0147_StreamOn
    [MCU2_0]    249.015994 s:  test---max96705 Write regAddr 4
    [MCU2_0]    249.016061 s:  test--max96705 Reg Write slaveAddr:0x41, regAddr:0x0004, regValue:0x87
       249.113035 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] failed !!!
       249.113090 s:  VX_ZONE_ERROR:[vxWaitGraph:867] graph not in expected state
       249.113108 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] ... !!!
    [MCU2_0]    249.111824 s: test--ar0147_StreamOn
    [MCU2_0]    249.112021 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    249.112076 s:  test---max96705 Write regAddr 4
    [MCU2_0]    249.112120 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    249.112167 s: Error : Failed to start sensor at channel Id 1
    [MCU2_0]    249.112203 s: test--ar0147_StreamOn
    [MCU2_0]    249.112332 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    249.112378 s:  test---max96705 Write regAddr 4
    [MCU2_0]    249.112420 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    249.112465 s: Error : Failed to start sensor at channel Id 2
    [MCU2_0]    249.112499 s: test--ar0147_StreamOn
    [MCU2_0]    249.112626 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    249.112670 s:  test---max96705 Write regAddr 4
    [MCU2_0]    249.112712 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    249.112758 s: Error : Failed to start sensor at channel Id 3
    [MCU2_0]    249.113363 s: test--IM_SENSOR_CMD_STREAM_ON:  channel_mask = 0xf, sensorBroadcast=0
    [MCU2_0]    249.113426 s: test--ar0147_StreamOn
    [MCU2_0]    249.113691 s:  test---max96705 Write regAddr 4
    [MCU2_0]    249.113753 s:  test--max96705 Reg Write slaveAddr:0x41, regAddr:0x0004, regValue:0x87
       249.211139 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] failed !!!
       249.211180 s:  VX_ZONE_ERROR:[vxWaitGraph:867] graph not in expected state
       249.211199 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] ... !!!
    [MCU2_0]    249.209819 s: test--ar0147_StreamOn
    [MCU2_0]    249.210015 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    249.210070 s:  test---max96705 Write regAddr 4
    [MCU2_0]    249.210111 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    249.210157 s: Error : Failed to start sensor at channel Id 1
    [MCU2_0]    249.210193 s: test--ar0147_StreamOn
    [MCU2_0]    249.210324 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    249.210397 s:  test---max96705 Write regAddr 4
    [MCU2_0]    249.210445 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    249.210543 s: Error : Failed to start sensor at channel Id 2
    [MCU2_0]    249.210591 s: test--ar0147_StreamOn
    [MCU2_0]    249.210726 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    249.210854 s:  test---max96705 Write regAddr 4
    [MCU2_0]    249.210910 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    249.210958 s: Error : Failed to start sensor at channel Id 3
    [MCU2_0]    249.211450 s: test--IM_SENSOR_CMD_STREAM_ON:  channel_mask = 0xf, sensorBroadcast=0
    [MCU2_0]    249.211512 s: test--ar0147_StreamOn
    [MCU2_0]    249.211847 s:  test---max96705 Write regAddr 4
    [MCU2_0]    249.211918 s:  test--max96705 Reg Write slaveAddr:0x41, regAddr:0x0004, regValue:0x87
       249.309040 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] failed !!!
       249.309121 s:  VX_ZONE_ERROR:[vxWaitGraph:867] graph not in expected state
       249.309140 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] ... !!!
    [MCU2_0]    249.307821 s: test--ar0147_StreamOn
    [MCU2_0]    249.308071 s:  test---max96705 Write regAddr 4
    [MCU2_0]    249.308115 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    249.308162 s: Error : Failed to start sensor at channel Id 1
    [MCU2_0]    249.308198 s: test--ar0147_StreamOn
    [MCU2_0]    249.308332 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    249.308378 s:  test---max96705 Write regAddr 4
    [MCU2_0]    249.308419 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    249.308465 s: Error : Failed to start sensor at channel Id 2
    [MCU2_0]    249.308500 s: test--ar0147_StreamOn
    [MCU2_0]    249.308631 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    249.308676 s:  test---max96705 Write regAddr 4
    [MCU2_0]    249.308717 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    249.308762 s: Error : Failed to start sensor at channel Id 3
    [MCU2_0]    249.309875 s: test--IM_SENSOR_CMD_STREAM_ON:  channel_mask = 0xf, sensorBroadcast=0
    [MCU2_0]    249.308016 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    249.309938 s: test--ar0147_StreamOn
    [MCU2_0]    249.310209 s:  test---max96705 Write regAddr 4
    [MCU2_0]    249.310273 s:  test--max96705 Reg Write slaveAddr:0x41, regAddr:0x0004, regValue:0x87
       249.407042 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] failed !!!
       249.407179 s:  VX_ZONE_ERROR:[vxWaitGraph:867] graph not in expected state
       249.407235 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] ... !!!
    [MCU2_0]    249.405821 s: test--ar0147_StreamOn
    [MCU2_0]    249.406016 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    249.406072 s:  test---max96705 Write regAddr 4
    [MCU2_0]    249.406117 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    249.406165 s: Error : Failed to start sensor at channel Id 1
    [MCU2_0]    249.406201 s: test--ar0147_StreamOn
    [MCU2_0]    249.406334 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    249.406379 s:  test---max96705 Write regAddr 4
    [MCU2_0]    249.406421 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    249.406468 s: Error : Failed to start sensor at channel Id 2
    [MCU2_0]    249.406503 s: test--ar0147_StreamOn
    [MCU2_0]    249.406629 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    249.406674 s:  test---max96705 Write regAddr 4
    [MCU2_0]    249.406717 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    249.406761 s: Error : Failed to start sensor at channel Id 3
    [MCU2_0]    249.407857 s: test--IM_SENSOR_CMD_STREAM_ON:  channel_mask = 0xf, sensorBroadcast=0
    [MCU2_0]    249.407920 s: test--ar0147_StreamOn
    [MCU2_0]    249.408185 s:  test---max96705 Write regAddr 4
    [MCU2_0]    249.408250 s:  test--max96705 Reg Write slaveAddr:0x41, regAddr:0x0004, regValue:0x87
       249.505058 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] failed !!!
       249.505415 s:  VX_ZONE_ERROR:[vxWaitGraph:867] graph not in expected state
       249.505457 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] ... !!!
    [MCU2_0]    249.503821 s: test--ar0147_StreamOn
    [MCU2_0]    249.504017 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    249.504071 s:  test---max96705 Write regAddr 4
    [MCU2_0]    249.504120 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    249.504168 s: Error : Failed to start sensor at channel Id 1
    [MCU2_0]    249.504204 s: test--ar0147_StreamOn
    [MCU2_0]    249.504342 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    249.504387 s:  test---max96705 Write regAddr 4
    [MCU2_0]    249.504429 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    249.504475 s: Error : Failed to start sensor at channel Id 2
    [MCU2_0]    249.504510 s: test--ar0147_StreamOn
    [MCU2_0]    249.504639 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    249.504687 s:  test---max96705 Write regAddr 4
    [MCU2_0]    249.504850 s: Error : Failed to start sensor at channel Id 3
    [MCU2_0]    249.505712 s: test--IM_SENSOR_CMD_STREAM_ON:  channel_mask = 0xf, sensorBroadcast=0
    [MCU2_0]    249.505843 s: test--ar0147_StreamOn
    [MCU2_0]    249.506120 s:  test---max96705 Write regAddr 4
    [MCU2_0]    249.506184 s:  test--max96705 Reg Write slaveAddr:0x41, regAddr:0x0004, regValue:0x87
    [MCU2_0]    249.504730 s:  max96705 Error: Reg Write Failed for regAddr 4
       249.603046 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] failed !!!
       249.603114 s:  VX_ZONE_ERROR:[vxWaitGraph:867] graph not in expected state
       249.603133 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] ... !!!
    [MCU2_0]    249.601819 s: test--ar0147_StreamOn
    [MCU2_0]    249.602017 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    249.602073 s:  test---max96705 Write regAddr 4
    [MCU2_0]    249.602166 s: Error : Failed to start sensor at channel Id 1
    [MCU2_0]    249.602118 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    249.602333 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    249.602379 s:  test---max96705 Write regAddr 4
    [MCU2_0]    249.602422 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    249.602469 s: Error : Failed to start sensor at channel Id 2
    [MCU2_0]    249.602504 s: test--ar0147_StreamOn
    [MCU2_0]    249.602630 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    249.602678 s:  test---max96705 Write regAddr 4
    [MCU2_0]    249.602720 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    249.602841 s: Error : Failed to start sensor at channel Id 3
    [MCU2_0]    249.603388 s: test--IM_SENSOR_CMD_STREAM_ON:  channel_mask = 0xf, sensorBroadcast=0
    [MCU2_0]    249.603452 s: test--ar0147_StreamOn
    [MCU2_0]    249.603719 s:  test---max96705 Write regAddr 4
    [MCU2_0]    249.603867 s:  test--max96705 Reg Write slaveAddr:0x41, regAddr:0x0004, regValue:0x87
    [MCU2_0]    249.602203 s: test--ar0147_StreamOn
       249.701033 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] failed !!!
       249.701093 s:  VX_ZONE_ERROR:[vxWaitGraph:867] graph not in expected state
       249.701112 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] ... !!!
    [MCU2_0]    249.699817 s: test--ar0147_StreamOn
    [MCU2_0]    249.700010 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    249.700064 s:  test---max96705 Write regAddr 4
    [MCU2_0]    249.700109 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    249.700157 s: Error : Failed to start sensor at channel Id 1
    [MCU2_0]    249.700194 s: test--ar0147_StreamOn
    [MCU2_0]    249.700325 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    249.700373 s:  test---max96705 Write regAddr 4
    [MCU2_0]    249.700416 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    249.700462 s: Error : Failed to start sensor at channel Id 2
    [MCU2_0]    249.700498 s: test--ar0147_StreamOn
    [MCU2_0]    249.700626 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    249.700673 s:  test---max96705 Write regAddr 4
    [MCU2_0]    249.700715 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    249.700763 s: Error : Failed to start sensor at channel Id 3
    [MCU2_0]    249.701361 s: test--IM_SENSOR_CMD_STREAM_ON:  channel_mask = 0xf, sensorBroadcast=0
    [MCU2_0]    249.701690 s:  test---max96705 Write regAddr 4
    [MCU2_0]    249.701424 s: test--ar0147_StreamOn
    [MCU2_0]    249.701755 s:  test--max96705 Reg Write slaveAddr:0x41, regAddr:0x0004, regValue:0x87
       249.799054 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] failed !!!
       249.799123 s:  VX_ZONE_ERROR:[vxWaitGraph:867] graph not in expected state
       249.799142 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] ... !!!
    [MCU2_0]    249.797822 s: test--ar0147_StreamOn
    [MCU2_0]    249.798078 s:  test---max96705 Write regAddr 4
    [MCU2_0]    249.798020 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    249.798173 s: Error : Failed to start sensor at channel Id 1
    [MCU2_0]    249.798210 s: test--ar0147_StreamOn
    [MCU2_0]    249.798342 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    249.798389 s:  test---max96705 Write regAddr 4
    [MCU2_0]    249.798430 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    249.798477 s: Error : Failed to start sensor at channel Id 2
    [MCU2_0]    249.798512 s: test--ar0147_StreamOn
    [MCU2_0]    249.798639 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    249.798684 s:  test---max96705 Write regAddr 4
    [MCU2_0]    249.798726 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    249.798847 s: Error : Failed to start sensor at channel Id 3
    [MCU2_0]    249.799879 s: test--IM_SENSOR_CMD_STREAM_ON:  channel_mask = 0xf, sensorBroadcast=0
    [MCU2_0]    249.799941 s: test--ar0147_StreamOn
    [MCU2_0]    249.800205 s:  test---max96705 Write regAddr 4
    [MCU2_0]    249.800268 s:  test--max96705 Reg Write slaveAddr:0x41, regAddr:0x0004, regValue:0x87
    [MCU2_0]    249.798125 s:  max96705 Error: Reg Write Failed for regAddr 4
       249.897050 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] failed !!!
       249.897173 s:  VX_ZONE_ERROR:[vxWaitGraph:867] graph not in expected state
       249.897215 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] ... !!!
    [MCU2_0]    249.895822 s: test--ar0147_StreamOn
    [MCU2_0]    249.896018 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    249.896074 s:  test---max96705 Write regAddr 4
    [MCU2_0]    249.896119 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    249.896168 s: Error : Failed to start sensor at channel Id 1
    [MCU2_0]    249.896204 s: test--ar0147_StreamOn
    [MCU2_0]    249.896335 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    249.896381 s:  test---max96705 Write regAddr 4
    [MCU2_0]    249.896423 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    249.896469 s: Error : Failed to start sensor at channel Id 2
    [MCU2_0]    249.896503 s: test--ar0147_StreamOn
    [MCU2_0]    249.896632 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    249.896677 s:  test---max96705 Write regAddr 4
    [MCU2_0]    249.896719 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    249.896836 s: Error : Failed to start sensor at channel Id 3
    [MCU2_0]    249.897860 s: test--IM_SENSOR_CMD_STREAM_ON:  channel_mask = 0xf, sensorBroadcast=0
    [MCU2_0]    249.897925 s: test--ar0147_StreamOn
    [MCU2_0]    249.898200 s:  test---max96705 Write regAddr 4
    [MCU2_0]    249.898262 s:  test--max96705 Reg Write slaveAddr:0x41, regAddr:0x0004, regValue:0x87
    [MCU2_0]    249.993859 s: test--ar0147_StreamOn
    [MCU2_0]    249.994067 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    249.994121 s:  test---max96705 Write regAddr 4
    [MCU2_0]    249.994165 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    249.994213 s: Error : Failed to start sensor at channel Id 1
    [MCU2_0]    249.994251 s: test--ar0147_StreamOn
    [MCU2_0]    249.994385 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    249.994431 s:  test---max96705 Write regAddr 4
    [MCU2_0]    249.994518 s: Error : Failed to start sensor at channel Id 2
    [MCU2_0]    249.994553 s: test--ar0147_StreamOn
    [MCU2_0]    249.994681 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    249.994729 s:  test---max96705 Write regAddr 4
    [MCU2_0]    249.994472 s:  max96705 Error: Reg Write Failed for regAddr 4
       249.995130 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] failed !!!
       249.995203 s:  VX_ZONE_ERROR:[vxWaitGraph:867] graph not in expected state
       249.995221 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] ... !!!
    [MCU2_0]    249.994854 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    249.994919 s: Error : Failed to start sensor at channel Id 3
    [MCU2_0]    249.995542 s: test--IM_SENSOR_CMD_STREAM_ON:  channel_mask = 0xf, sensorBroadcast=0
    [MCU2_0]    249.995607 s: test--ar0147_StreamOn
    [MCU2_0]    249.995881 s:  test---max96705 Write regAddr 4
    [MCU2_0]    249.995949 s:  test--max96705 Reg Write slaveAddr:0x41, regAddr:0x0004, regValue:0x87
    x   250.093035 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] failed !!!
       250.093093 s:  VX_ZONE_ERROR:[vxWaitGraph:867] graph not in expected state
       250.093112 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] ... !!!
    [MCU2_0]    250.091823 s: test--ar0147_StreamOn
    [MCU2_0]    250.092023 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    250.092077 s:  test---max96705 Write regAddr 4
    [MCU2_0]    250.092121 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    250.092168 s: Error : Failed to start sensor at channel Id 1
    [MCU2_0]    250.092204 s: test--ar0147_StreamOn
    [MCU2_0]    250.092337 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    250.092382 s:  test---max96705 Write regAddr 4
    [MCU2_0]    250.092422 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    250.092468 s: Error : Failed to start sensor at channel Id 2
    [MCU2_0]    250.092502 s: test--ar0147_StreamOn
    [MCU2_0]    250.092628 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    250.092673 s:  test---max96705 Write regAddr 4
    [MCU2_0]    250.092713 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    250.092758 s: Error : Failed to start sensor at channel Id 3
    [MCU2_0]    250.093364 s: test--IM_SENSOR_CMD_STREAM_ON:  channel_mask = 0xf, sensorBroadcast=0
    [MCU2_0]    250.093424 s: test--ar0147_StreamOn
    [MCU2_0]    250.093715 s:  test---max96705 Write regAddr 4
    [MCU2_0]    250.093930 s:  test--max96705 Reg Write slaveAddr:0x41, regAddr:0x0004, regValue:0x87
       250.191042 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] failed !!!
       250.191165 s:  VX_ZONE_ERROR:[vxWaitGraph:867] graph not in expected state
       250.191208 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] ... !!!
    [MCU2_0]    250.189822 s: test--ar0147_StreamOn
    [MCU2_0]    250.190016 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    250.190115 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    250.190161 s: Error : Failed to start sensor at channel Id 1
    [MCU2_0]    250.190196 s: test--ar0147_StreamOn
    [MCU2_0]    250.190329 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    250.190377 s:  test---max96705 Write regAddr 4
    [MCU2_0]    250.190421 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    250.190467 s: Error : Failed to start sensor at channel Id 2
    [MCU2_0]    250.190502 s: test--ar0147_StreamOn
    [MCU2_0]    250.190632 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    250.190676 s:  test---max96705 Write regAddr 4
    [MCU2_0]    250.190719 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    250.190833 s: Error : Failed to start sensor at channel Id 3
    [MCU2_0]    250.191469 s: test--IM_SENSOR_CMD_STREAM_ON:  channel_mask = 0xf, sensorBroadcast=0
    [MCU2_0]    250.191529 s: test--ar0147_StreamOn
    [MCU2_0]    250.191870 s:  test---max96705 Write regAddr 4
    [MCU2_0]    250.191939 s:  test--max96705 Reg Write slaveAddr:0x41, regAddr:0x0004, regValue:0x87
    [MCU2_0]    250.190070 s:  test---max96705 Write regAddr 4
       250.289018 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] failed !!!
       250.289142 s:  VX_ZONE_ERROR:[vxWaitGraph:867] graph not in expected state
    [MCU2_0]    250.287818 s: test--ar0147_StreamOn
    [MCU2_0]    250.288015 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    250.288114 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    250.288161 s: Error : Failed to start sensor at channel Id 1
    [MCU2_0]    250.288196 s: test--ar0147_StreamOn
    [MCU2_0]    250.288330 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    250.288377 s:  test---max96705 Write regAddr 4
    [MCU2_0]    250.288418 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    250.288463 s: Error : Failed to start sensor at channel Id 2
    [MCU2_0]    250.288496 s: test--ar0147_StreamOn
    [MCU2_0]    250.288624 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]    250.288070 s:  test---max96705 Write regAddr 4
    [MCU2_0]    250.288710 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    250.288668 s:  test---max96705 Write regAddr 4
    [MCU2_0]    250.288755 s: Error : Failed to start sensor at channel Id 3
       250.341469 s: ISS: Stopping sensor [MAX96705_AR0147_UYVY] ... !!!
    [MCU2_0]    250.341716 s: test--ar0147_StreamOff
    [MCU2_0]    250.342088 s:  test---max96705 Write regAddr 4
    [MCU2_0]    250.342166 s:  test--max96705 Reg Write slaveAddr:0x41, regAddr:0x0004, regValue:0x47
       250.439012 s: ISS: Stopping sensor [MAX96705_AR0147_UYVY] failed !!!
       250.439212 s:  VX_ZONE_ERROR:[ownReleaseReferenceInt:294] Invalid reference
    [MCU2_0]    250.437820 s: test--ar0147_StreamOff
    [MCU2_0]    250.438012 s: Error writing 0x47 to max96705 register 0x4
    [MCU2_0]    250.438065 s:  test---max96705 Write regAddr 4
    [MCU2_0]    250.438108 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    250.438157 s: Warning : Failed to stop sensor at channel Id 1
    [MCU2_0]    250.438192 s: test--ar0147_StreamOff
    [MCU2_0]    250.438322 s: Error writing 0x47 to max96705 register 0x4
    [MCU2_0]    250.438366 s:  test---max96705 Write regAddr 4
    [MCU2_0]    250.438408 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    250.438456 s: Warning : Failed to stop sensor at channel Id 2
    [MCU2_0]    250.438492 s: test--ar0147_StreamOff
    [MCU2_0]    250.438616 s: Error writing 0x47 to max96705 register 0x4
    [MCU2_0]    250.438660 s:  test---max96705 Write regAddr 4
    [MCU2_0]    250.438701 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]    250.438748 s: Warning : Failed to stop sensor at channel Id 3
       250.442495 s:  VX_ZONE_ERROR:[ownReleaseReferenceInt:294] Invalid reference
       250.442512 s:  VX_ZONE_ERROR:[ownReleaseReferenceInt:294] Invalid reference
       250.442537 s:  VX_ZONE_ERROR:[ownReleaseReferenceInt:294] Invalid reference
    [MCU2_0]    250.445494 s: ==========================================================
    [MCU2_0]    250.445589 s:  Capture Status: Instance|0
    [MCU2_0]    250.445623 s: ==========================================================
    [MCU2_0]    250.445670 s:  overflowCount: 0
    [MCU2_0]    250.445703 s:  spuriousUdmaIntrCount: 0
    [MCU2_0]    250.445739 s:  frontFIFOOvflCount: 0
    [MCU2_0]    250.445863 s:  crcCount: 0
    [MCU2_0]    250.445908 s:  eccCount: 0
    [MCU2_0]    250.445946 s:  correctedEccCount: 0
    [MCU2_0]    250.445979 s:  dataIdErrorCount: 0
    [MCU2_0]    250.446013 s:  invalidAccessCount: 0
    [MCU2_0]    250.446047 s:  invalidSpCount: 0
    [MCU2_0]    250.446085 s:  strmFIFOOvflCount[0]: 0
    [MCU2_0]    250.446124 s:  strmFIFOOvflCount[1]: 0
    [MCU2_0]    250.446154 s:  Channel Num | Frame Queue Count | Frame De-queue Count | Frame Drop Count | Error Fr                           ame Count |
    [MCU2_0]    250.446231 s:            0 |               118 |                  118 |                4 |                                            0 |
    [MCU2_0]    250.446308 s:            1 |               118 |                  118 |                8 |                                            0 |
    [MCU2_0]    250.446383 s:            2 |               118 |                  118 |               14 |                                            0 |
    [MCU2_0]    250.446457 s:            3 |               118 |                  118 |               20 |                                            0 |
    test________________ _deinit app...
       250.811616 s: ISS: De-initializing sensor [MAX96705_AR0147_UYVY] ... !!!
       250.812043 s: ISS: De-initializing sensor [MAX96705_AR0147_UYVY] ... Done !!!
       250.812064 s:  VX_ZONE_INIT:[tivxHostDeInitLocal:107] De-Initialization Done for HOST !!!
       250.815951 s:  VX_ZONE_INIT:[tivxDeInitLocal:193] De-Initialization Done !!!
    APP: Deinit ... !!!
    REMOTE_SERVICE: Deinit ... !!!
    REMOTE_SERVICE: Deinit ... Done !!!
    IPC: Deinit ... !!!
    IPC: DeInit ... Done !!!
    MEM: Deinit ... !!!
    DDR_SHARED_MEM: Alloc's: 45 alloc's of 60483784 bytes
    DDR_SHARED_MEM: Free's : 45 free's  of 60483784 bytes
    DDR_SHARED_MEM: Open's : 0 allocs  of 0 bytes
    DDR_SHARED_MEM: Total size: 536870912 bytes
    MEM: Deinit ... Done !!!
    APP: Deinit ... Done !!!
    If you have time, could you please provide me with some guidance?
    Thank you very much!
    Yueqian
    I see test_b0, test_b3 etc in the logs and ISS: Starting sensor being called multiple times here. In the SDK SRV demo, we just start the sensor once at a time for all channel.
    May I know your code flow or the code changes done at your end?
    Nikhil
  • Yes, I am also puzzled why test_b0, test_b3 etc is executed repeatedly. There is no loop added here.
    There are the changes in the code:
    ​1."vx_image cap_yuv_image;"is added in"typedef struct{*}AppObj".
    2.static vx_status app_create_capture(AppObj *obj)
            printf("start cap_yuv_image create!\n");
                    return VX_FAILURE;
            return VX_FAILURE;
            return VX_FAILURE;
        return status;
    3.static vx_status app_create_viss_aewb(AppObj *obj){} is deleted.
    4."obj->viss_out_frames" is changed to "obj->capt_frames[0]" in app_create_graph_gpu_lut(AppObj *obj){}.
    As "obj->srv_node = tivxGlSrvNode(obj->graph, obj->param_obj, obj->capt_frames[0], obj->srv_views_array, obj->out_gpulut_array, obj->output_image[0]);"
    Could you share the differences you have added to the SRV application, vision_apps and the imaging component in the form of a patch?
    From the above, i'm not able to figure out where are the logs test_b0, test_b3 placed in the code.
    Nikhil
  • 'test-b0, test-b3 'is located in the function' app_run_graph 'in' app_srv_camera. c ', as shown below
    static vx_status app_run_graph(AppObj *obj)
        printf("test_b0_________________app_run_graph start\n");
        uint32_t num_refs, buf_id;
        int graph_parameter_num = 0;
        uint32_t iteration = 0;
        if(NULL == obj->sensor_name)
            printf("sensor name is NULL \n");
            status = VX_FAILURE;
        if(status == VX_SUCCESS)
            printf("test_b1_________0_______appStartImageSensor(obj->sensor_name, 0xF)  sensor_name:%s\n",obj->sensor_name);
            status = appStartImageSensor(obj->sensor_name, 0x0F);
            APP_PRINTF("Sensor start status = %d\n", status);
            printf("test_b2________________Sensor start status = %d\n", status);
        /* Enqueue buf for pipe up but don't trigger graph execution */
            printf("test_b3________________vxGraphParameterEnqueueReadyRef status = %d\n", status);
                status = vxGraphParameterEnqueueReadyRef(obj->graph, graph_parameter_num,
                           (vx_reference*)&obj->capt_frames[buf_id], 1);
            graph_parameter_num++;
                    status = vxGraphParameterEnqueueReadyRef(obj->graph, obj->displayNodeGraphParamNum,
                                    (vx_reference*)&obj->output_image[buf_id], 1);
        /* wait for graph instances to complete, compare output and
         * recycle data buffers, schedule again */
        vx_uint32 actual_checksum = 0;
        printf("test_b4________________status = %d\n", status);
  • Here are the modifications made in the code.
    (​1)"vx_image cap_yuv_image;"is added in"typedef struct{*}AppObj".
    (2)static vx_status app_create_capture(AppObj *obj)
    return VX_FAILURE;
    return VX_FAILURE;
    return VX_FAILURE;
    return status;
    (3)static vx_status app_create_viss_aewb(AppObj *obj){} is deleted.
    (4)"obj->viss_out_frames" is changed to "obj->capt_frames[0]" in app_create_graph_gpu_lut(AppObj *obj){}.
    The changes look fine.
    You are basically bypassing the viss and aewb node and passing the capture output directly to SRV node.
    However, I don't see why these changes should affect the start of the sensor.
    The ISS: Starting sensor is being called multiple times here as your app_run_graph is running in a task and the first set of Starting sensors failed and further was not executed; hence it did not do the initial pipe-up and thus did not enter the while loop.
    Let us see the error log from start sensor. If you see the below log, for channel 0, the register write was successful whereas it is not successful for channel 1, 2, 3.
    You mentioned that you ran the multi_cam_codec app and the start sensor for 4 channels were working fine. Is that correct?
    Could you test with multi cam application, then end the multi-cam application and then run this SRV demo. Have you tried this usecase already?
    Nikhil
  • Yes, I have tried running the multi-cam application and then run this SRV demo. However,running multi-cam application can succeed, but this SRV demo will result in errors.
    May I ask how I can investigate the cause of this problem?
    Yueqian
    Here is the test log. First, run 'app_srv_camera' and there was an error in the log. Then run 'app_multi_cam_codec' immediately, and it can run smoothly. Two consecutive logs are printed as follows:
    APP: Init ... !!!
    MEM: Init ... !!!
    MEM: Initialized DMA HEAP (fd=4) !!!
    MEM: Init ... Done !!!
    IPC: Init ... !!!
    IPC: Init ... Done !!!
    REMOTE_SERVICE: Init ... !!!
    REMOTE_SERVICE: Init ... Done !!!
        53.088206 s: GTC Frequency = 200 MHz
    APP: Init ... Done !!!
        53.093574 s:  VX_ZONE_INIT:Enabled
        53.093595 s:  VX_ZONE_ERROR:Enabled
        53.093601 s:  VX_ZONE_WARNING:Enabled
        53.094416 s:  VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
        53.095438 s:  VX_ZONE_INIT:[tivxHostInitLocal:93] Initialization Done for HOST !!!
        53.485724 s: ISS: Enumerating sensors ... !!!
        53.910595 s: ISS: Enumerating sensors ... found 0 : IMX390-UB953_D3
        53.910618 s: ISS: Enumerating sensors ... found 1 : AR0233-UB953_MARS
        53.910640 s: ISS: Enumerating sensors ... found 2 : AR0820-UB953_LI
        53.910645 s: ISS: Enumerating sensors ... found 3 : UB9xxx_RAW12_TESTPATTERN
        53.910650 s: ISS: Enumerating sensors ... found 4 : UB96x_UYVY_TESTPATTERN
        53.910655 s: ISS: Enumerating sensors ... found 5 : GW_AR0233_UYVY
        53.910660 s: ISS: Enumerating sensors ... found 6 : MAX96705_AR0147_UYVY
    Sensor selected : MAX96705_AR0147_UYVY, 6
        53.910688 s: ISS: Querying sensor [MAX96705_AR0147_UYVY] ... !!!
        53.911390 s: ISS: Querying sensor [MAX96705_AR0147_UYVY] ... Done !!!
    test00
    test01________obj->inWidth = 1280
    test11________obj->inHeight = 720
    test21________obj->cam_dcc_id = 147
    test4________app_create_capture end, status = 0
    Reading calmat file
    file read completed
    test4________app_create_graph_gpu_lut end, status = 0
    EGL: version 1.5
     x: Exit
    test_b1_________0_______appStartImageSensor(obj->sensor_name, 0xF)  sensor_name:MAX96705_AR0147_UYVY
        55.333108 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] ... !!!
    test__appStartImageSensor____0___________APP_IPC_CPU_MCU2_0 = 3
    test__appStartImageSensor____1__________appRemoteServiceRun_status = -1
    test__appStartImageSensor____2__________IMAGE_SENSOR_REMOTE_SERVICE_NAME = com.ti.image_sensor
    test__appStartImageSensor____3__________IM_SENSOR_CMD_STREAM_ON = 4
    test__appStartImageSensor____4__________CMD_PARAM_SIZE = 384
    test__appStartImageSensor____5__________g_cmdPrm = MAX96705_AR0147_UYVY
        55.335012 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] failed !!!
        55.335043 s:  VX_ZONE_ERROR:[vxWaitGraph:867] graph not in expected state
    test_b9________________vxWaitGraph status = -1
        55.335058 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] ... !!!
        55.336907 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] failed !!!
        55.336931 s:  VX_ZONE_ERROR:[vxWaitGraph:867] graph not in expected state
    [MCU2_0]     55.333359 s: comon--appInit----start!!test--IM_SENSOR_CMD_STREAM_ON:  channel_mask = 0xf, sensorBroadcast=0
        55.668406 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] ... !!!
    [MCU2_0]     55.333505 s: test--ar0147_StreamOn
    [MCU2_0]     55.333675 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]     55.333729 s:  test---max96705 Write regAddr 4
    [MCU2_0]     55.333773 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]     55.333821 s: Error : Failed to start sensor at channel Id 0
    [MCU2_0]     55.333858 s: test--ar0147_StreamOn
    [MCU2_0]     55.333988 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]     55.334035 s:  test---max96705 Write regAddr 4
    [MCU2_0]     55.334079 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]     55.334127 s: Error : Failed to start sensor at channel Id 1
    [MCU2_0]     55.334162 s: test--ar0147_StreamOn
    [MCU2_0]     55.334291 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]     55.334336 s:  test---max96705 Write regAddr 4
    [MCU2_0]     55.334378 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]     55.334507 s: Error : Failed to start sensor at channel Id 2
    [MCU2_0]     55.334548 s: test--ar0147_StreamOn
    [MCU2_0]     55.334688 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]     55.334736 s:  test---max96705 Write regAddr 4
    [MCU2_0]     55.334778 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]     55.334826 s: Error : Failed to start sensor at channel Id 3
    [MCU2_0]     55.335291 s: test--IM_SENSOR_CMD_STREAM_ON:  channel_mask = 0xf, sensorBroadcast=0
    [MCU2_0]     55.335353 s: test--ar0147_StreamOn
    [MCU2_0]     55.335575 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]     55.335630 s:  test---max96705 Write regAddr 4
    [MCU2_0]     55.335675 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]     55.335722 s: Error : Failed to start sensor at channel Id 0
    [MCU2_0]     55.335759 s: test--ar0147_StreamOn
    [MCU2_0]     55.335894 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]     55.335941 s:  test---max96705 Write regAddr 4
    [MCU2_0]     55.335986 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]     55.336032 s: Error : Failed to start sensor at channel Id 1
    [MCU2_0]     55.336068 s: test--ar0147_StreamOn
    [MCU2_0]     55.336196 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]     55.336249 s:  test---max96705 Write regAddr 4
    [MCU2_0]     55.336293 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]     55.336340 s: Error : Failed to start sensor at channel Id 2
    [MCU2_0]     55.336375 s: test--ar0147_StreamOn
    [MCU2_0]     55.336582 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]     55.336634 s:  test---max96705 Write regAddr 4
    [MCU2_0]     55.336677 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]     55.336725 s: Error : Failed to start sensor at channel Id 3
    [MCU2_0]     55.668682 s: test--IM_SENSOR_CMD_STREAM_ON:  channel_mask = 0xf, sensorBroadcast=0
    [MCU2_0]     55.668753 s: test--ar0147_StreamOn
    [MCU2_0]     55.668910 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]     55.668963 s:  test---max96705 Write regAddr 4
        55.670275 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] failed !!!
    [MCU2_0]     55.669007 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]     55.669056 s: Error : Failed to start sensor at channel Id 0
    [MCU2_0]     55.669094 s: test--ar0147_StreamOn
        56.001744 s:  VX_ZONE_ERROR:[vxWaitGraph:867] graph not in expected state
    [MCU2_0]     55.669224 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]     55.669274 s:  test---max96705 Write regAddr 4
        56.001803 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] ... !!!
    [MCU2_0]     55.669318 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]     55.669365 s: Error : Failed to start sensor at channel Id 1
    [MCU2_0]     55.669473 s: test--ar0147_StreamOn
    [MCU2_0]     55.669629 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]     55.669682 s:  test---max96705 Write regAddr 4
    [MCU2_0]     55.669727 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]     55.669775 s: Error : Failed to start sensor at channel Id 2
    [MCU2_0]     55.669813 s: test--ar0147_StreamOn
    [MCU2_0]     55.669945 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]     55.669991 s:  test---max96705 Write regAddr 4
    [MCU2_0]     55.670036 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]     55.670084 s: Error : Failed to start sensor at channel Id 3
        56.003721 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] failed !!!
        56.003747 s:  VX_ZONE_ERROR:[vxWaitGraph:867] graph not in expected state
        56.003762 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] ... !!!
        56.005587 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] failed !!!
    [MCU2_0]     56.002069 s: test--IM_SENSOR_CMD_STREAM_ON:  channel_mask = 0xf, sensorBroadcast=0
    [MCU2_0]     56.002139 s: test--ar0147_StreamOn
        56.334935 s:  VX_ZONE_ERROR:[vxWaitGraph:867] graph not in expected state
    [MCU2_0]     56.002296 s: Error writing 0x87 to max96705 register 0x4
        56.334956 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] ... !!!
    [MCU2_0]     56.002347 s:  test---max96705 Write regAddr 4
    [MCU2_0]     56.002465 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]     56.002527 s: Error : Failed to start sensor at channel Id 0
    [MCU2_0]     56.002565 s: test--ar0147_StreamOn
    [MCU2_0]     56.002708 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]     56.002759 s:  test---max96705 Write regAddr 4
    [MCU2_0]     56.002803 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]     56.002850 s: Error : Failed to start sensor at channel Id 1
    [MCU2_0]     56.002884 s: test--ar0147_StreamOn
    [MCU2_0]     56.003011 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]     56.003055 s:  test---max96705 Write regAddr 4
    [MCU2_0]     56.003096 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]     56.003143 s: Error : Failed to start sensor at channel Id 2
    [MCU2_0]     56.003178 s: test--ar0147_StreamOn
    [MCU2_0]     56.003303 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]     56.003348 s:  test---max96705 Write regAddr 4
    [MCU2_0]     56.003459 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]     56.003517 s: Error : Failed to start sensor at channel Id 3
    [MCU2_0]     56.003996 s: test--IM_SENSOR_CMD_STREAM_ON:  channel_mask = 0xf, sensorBroadcast=0
    [MCU2_0]     56.004054 s: test--ar0147_StreamOn
    [MCU2_0]     56.004202 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]     56.004249 s:  test---max96705 Write regAddr 4
    [MCU2_0]     56.004293 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]     56.004342 s: Error : Failed to start sensor at channel Id 0
    [MCU2_0]     56.004379 s: test--ar0147_StreamOn
    [MCU2_0]     56.004599 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]     56.004652 s:  test---max96705 Write regAddr 4
    [MCU2_0]     56.004695 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]     56.004740 s: Error : Failed to start sensor at channel Id 1
    [MCU2_0]     56.004776 s: test--ar0147_StreamOn
    [MCU2_0]     56.004907 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]     56.004957 s:  test---max96705 Write regAddr 4
    [MCU2_0]     56.005003 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]     56.005049 s: Error : Failed to start sensor at channel Id 2
    [MCU2_0]     56.005085 s: test--ar0147_StreamOn
    [MCU2_0]     56.005216 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]     56.005262 s:  test---max96705 Write regAddr 4
    [MCU2_0]     56.005304 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]     56.005349 s: Error : Failed to start sensor at channel Id 3
    [MCU2_0]     56.335237 s: test--IM_SENSOR_CMD_STREAM_ON:  channel_mask = 0xf, sensorBroadcast=0
    [MCU2_0]     56.335307 s: test--ar0147_StreamOn
    [MCU2_0]     56.335492 s: Error writing 0x87 to max96705 register 0x4
        56.668081 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] failed !!!
    [MCU2_0]     56.335551 s:  test---max96705 Write regAddr 4
    [MCU2_0]     56.335600 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]     56.335649 s: Error : Failed to start sensor at channel Id 0
        56.668136 s:  VX_ZONE_ERROR:[vxWaitGraph:867] graph not in expected state
    [MCU2_0]     56.335687 s: test--ar0147_StreamOn
        56.668154 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] ... !!!
    [MCU2_0]     56.335821 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]     56.335867 s:  test---max96705 Write regAddr 4
    [MCU2_0]     56.335910 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]     56.335958 s: Error : Failed to start sensor at channel Id 1
    [MCU2_0]     56.335994 s: test--ar0147_StreamOn
    [MCU2_0]     56.336123 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]     56.336168 s:  test---max96705 Write regAddr 4
    [MCU2_0]     56.336212 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]     56.336258 s: Error : Failed to start sensor at channel Id 2
    [MCU2_0]     56.336294 s: test--ar0147_StreamOn
    [MCU2_0]     56.336481 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]     56.336536 s:  test---max96705 Write regAddr 4
    [MCU2_0]     56.336581 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]     56.336629 s: Error : Failed to start sensor at channel Id 3
        56.670103 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] failed !!!
        56.670129 s:  VX_ZONE_ERROR:[vxWaitGraph:867] graph not in expected state
        56.670144 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] ... !!!
        56.672007 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] failed !!!
    [MCU2_0]     56.668494 s: test--IM_SENSOR_CMD_STREAM_ON:  channel_mask = 0xf, sensorBroadcast=0
    [MCU2_0]     56.668562 s: test--ar0147_StreamOn
        57.001341 s:  VX_ZONE_ERROR:[vxWaitGraph:867] graph not in expected state
    [MCU2_0]     56.668718 s: Error writing 0x87 to max96705 register 0x4
        57.001362 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] ... !!!
    [MCU2_0]     56.668770 s:  test---max96705 Write regAddr 4
    [MCU2_0]     56.668814 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]     56.668863 s: Error : Failed to start sensor at channel Id 0
    [MCU2_0]     56.668902 s: test--ar0147_StreamOn
    [MCU2_0]     56.669036 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]     56.669085 s:  test---max96705 Write regAddr 4
    [MCU2_0]     56.669130 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]     56.669180 s: Error : Failed to start sensor at channel Id 1
    [MCU2_0]     56.669218 s: test--ar0147_StreamOn
    [MCU2_0]     56.669348 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]     56.669466 s:  test---max96705 Write regAddr 4
    [MCU2_0]     56.669525 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]     56.669575 s: Error : Failed to start sensor at channel Id 2
    [MCU2_0]     56.669614 s: test--ar0147_StreamOn
    [MCU2_0]     56.669750 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]     56.669800 s:  test---max96705 Write regAddr 4
    [MCU2_0]     56.669845 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]     56.669894 s: Error : Failed to start sensor at channel Id 3
    [MCU2_0]     56.670382 s: test--IM_SENSOR_CMD_STREAM_ON:  channel_mask = 0xf, sensorBroadcast=0
    [MCU2_0]     56.670509 s: test--ar0147_StreamOn
    [MCU2_0]     56.670662 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]     56.670716 s:  test---max96705 Write regAddr 4
    [MCU2_0]     56.670764 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]     56.670813 s: Error : Failed to start sensor at channel Id 0
    [MCU2_0]     56.670849 s: test--ar0147_StreamOn
    [MCU2_0]     56.670982 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]     56.671029 s:  test---max96705 Write regAddr 4
    [MCU2_0]     56.671074 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]     56.671121 s: Error : Failed to start sensor at channel Id 1
    [MCU2_0]     56.671159 s: test--ar0147_StreamOn
    [MCU2_0]     56.671289 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]     56.671338 s:  test---max96705 Write regAddr 4
    [MCU2_0]     56.671383 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]     56.671503 s: Error : Failed to start sensor at channel Id 2
    [MCU2_0]     56.671544 s: test--ar0147_StreamOn
    [MCU2_0]     56.671680 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]     56.671728 s:  test---max96705 Write regAddr 4
    [MCU2_0]     56.671773 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]     56.671821 s: Error : Failed to start sensor at channel Id 3
    [MCU2_0]     57.001664 s: test--IM_SENSOR_CMD_STREAM_ON:  channel_mask = 0xf, sensorBroadcast=0
    [MCU2_0]     57.001731 s: test--ar0147_StreamOn
    [MCU2_0]     57.001890 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]     57.001942 s:  test---max96705 Write regAddr 4
    [MCU2_0]     57.001986 s:  max96705 Error: Reg Write Failed for regAddr 4
        57.334501 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] failed !!!
    [MCU2_0]     57.002032 s: Error : Failed to start sensor at channel Id 0
    [MCU2_0]     57.002068 s: test--ar0147_StreamOn
        57.334542 s:  VX_ZONE_ERROR:[vxWaitGraph:867] graph not in expected state
    [MCU2_0]     57.002197 s: Error writing 0x87 to max96705 register 0x4
        57.334560 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] ... !!!
    [MCU2_0]     57.002245 s:  test---max96705 Write regAddr 4
    [MCU2_0]     57.002288 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]     57.002335 s: Error : Failed to start sensor at channel Id 1
    [MCU2_0]     57.002371 s: test--ar0147_StreamOn
    [MCU2_0]     57.002586 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]     57.002642 s:  test---max96705 Write regAddr 4
    [MCU2_0]     57.002684 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]     57.002730 s: Error : Failed to start sensor at channel Id 2
    [MCU2_0]     57.002765 s: test--ar0147_StreamOn
    [MCU2_0]     57.002894 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]     57.002940 s:  test---max96705 Write regAddr 4
    [MCU2_0]     57.002981 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]     57.003028 s: Error : Failed to start sensor at channel Id 3
        57.336468 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] failed !!!
        57.336495 s:  VX_ZONE_ERROR:[vxWaitGraph:867] graph not in expected state
        57.336510 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] ... !!!
    [MCU2_0]     57.334840 s: test--IM_SENSOR_CMD_STREAM_ON:  channel_mask = 0xf, sensorBroadcast=0
    [MCU2_0]     57.334907 s: test--ar0147_StreamOn
        57.667703 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] failed !!!
    [MCU2_0]     57.335062 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]     57.335111 s:  test---max96705 Write regAddr 4
        57.667743 s:  VX_ZONE_ERROR:[vxWaitGraph:867] graph not in expected state
    [MCU2_0]     57.335157 s:  max96705 Error: Reg Write Failed for regAddr 4
        57.667761 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] ... !!!
    [MCU2_0]     57.335207 s: Error : Failed to start sensor at channel Id 0
    [MCU2_0]     57.335243 s: test--ar0147_StreamOn
    [MCU2_0]     57.335377 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]     57.335516 s:  test---max96705 Write regAddr 4
    [MCU2_0]     57.335563 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]     57.335613 s: Error : Failed to start sensor at channel Id 1
    [MCU2_0]     57.335651 s: test--ar0147_StreamOn
    [MCU2_0]     57.335792 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]     57.335839 s:  test---max96705 Write regAddr 4
    [MCU2_0]     57.335883 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]     57.335931 s: Error : Failed to start sensor at channel Id 2
    [MCU2_0]     57.335968 s: test--ar0147_StreamOn
    [MCU2_0]     57.336098 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]     57.336146 s:  test---max96705 Write regAddr 4
    [MCU2_0]     57.336191 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]     57.336239 s: Error : Failed to start sensor at channel Id 3
    [MCU2_0]     57.336759 s: test--IM_SENSOR_CMD_STREAM_ON:  channel_mask = 0xf, sensorBroadcast=0
    [MCU2_0]     57.336824 s: test--ar0147_StreamOn
    [MCU2_0]     57.336974 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]     57.337023 s:  test---max96705 Write regAddr 4
    [MCU2_0]     57.337066 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]     57.337113 s: Error : Failed to start sensor at channel Id 0
    [MCU2_0]     57.337150 s: test--ar0147_StreamOn
    [MCU2_0]     57.337282 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]     57.337327 s:  test---max96705 Write regAddr 4
    [MCU2_0]     57.337369 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]     57.337500 s: Error : Failed to start sensor at channel Id 1
    [MCU2_0]     57.337546 s: test--ar0147_StreamOn
    [MCU2_0]     57.337685 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]     57.337735 s:  test---max96705 Write regAddr 4
    [MCU2_0]     57.337782 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]     57.337830 s: Error : Failed to start sensor at channel Id 2
    [MCU2_0]     57.337865 s: test--ar0147_StreamOn
    [MCU2_0]     57.337994 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]     57.338042 s:  test---max96705 Write regAddr 4
    [MCU2_0]     57.338085 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]     57.338132 s: Error : Faixled to start sensor at channel Id 3
    [MCU2_0]     57.668041 s: test--IM_SENSOR_CMD_STREAM_ON:  channel_mask = 0xf, sensorBroadcast=0
    [MCU2_0]     57.668113 s: test--ar0147_StreamOn
        58.006507 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] failed !!!
    [MCU2_0]     57.668274 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]     57.668330 s:  test---max96705 Write regAddr 4
        58.006545 s:  VX_ZONE_ERROR:[vxWaitGraph:867] graph not in expected state
    [MCU2_0]     57.668375 s:  max96705 Error: Reg Write Failed for regAddr 4
        58.006562 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] ... !!!
    [MCU2_0]     57.668517 s: Error : Failed to start sensor at channel Id 0
    [MCU2_0]     57.668562 s: test--ar0147_StreamOn
    [MCU2_0]     57.668706 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]     57.668758 s:  test---max96705 Write regAddr 4
    [MCU2_0]     57.668802 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]     57.668851 s: Error : Failed to start sensor at channel Id 1
    [MCU2_0]     57.668887 s: test--ar0147_StreamOn
    [MCU2_0]     57.669020 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]     57.669068 s:  test---max96705 Write regAddr 4
    [MCU2_0]     57.669111 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]     57.669158 s: Error : Failed to start sensor at channel Id 2
    [MCU2_0]     57.669194 s: test--ar0147_StreamOn
    [MCU2_0]     57.669325 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]     57.669371 s:  test---max96705 Write regAddr 4
    [MCU2_0]     57.669490 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]     57.669546 s: Error : Failed to start sensor at channel Id 3
        58.008436 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] failed !!!
        58.008463 s:  VX_ZONE_ERROR:[vxWaitGraph:867] graph not in expected state
        58.008478 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] ...
    [MCU2_0]     58.006830 s: test--IM_SENSOR_CMD_STREAM_ON:  channel_mask = 0xf, sensorBroadcast=0
    [MCU2_0]     58.006919 s: test--ar0147_StreamOn
    [MCU2_0]     58.007076 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]     58.007128 s:  test---max96705 Write regAddr 4
    [MCU2_0]     58.007171 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]     58.007219 s: Error : Failed to start sensor at channel Id 0
    [MCU2_0]     58.007254 s: test--ar0147_StreamOn
    [MCU2_0]     58.007457 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]     58.007521 s:  test---max96705 Write regAddr 4
    [MCU2_0]     58.007567 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]     58.007615 s: Error : Failed to start sensor at channel Id 1
    [MCU2_0]     58.007652 s: test--ar0147_StreamOn
    [MCU2_0]     58.007790 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]     58.007838 s:  test---max96705 Write regAddr 4
    [MCU2_0]     58.007880 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]     58.007925 s: Error : Failed to start sensor at channel Id 2
    [MCU2_0]     58.007961 s: test--ar0147_StreamOn
    [MCU2_0]     58.008095 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]     58.008142 s:  test---max96705 Write regAddr 4
    [MCU2_0]     58.008184 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]     58.008231 s: Error : Failed to start sensor at channel Id 3
        58.347307 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] failed !!!
    test_b2________________Sensor start status = -1
    test_b3________________vxGraphParameterEnqueueReadyRef status = -1
    test_b4________________status = -1
        58.347343 s:  VX_ZONE_ERROR:[vxWaitGraph:867] graph not in expected state
    [MCU2_0]     58.345669 s: test--IM_SENSOR_CMD_STREAM_ON:  channel_mask = 0xf, sensorBroadcast=0
    [MCU2_0]     58.345741 s: test--ar0147_StreamOn
    [MCU2_0]     58.345902 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]     58.345956 s:  test---max96705 Write regAddr 4
    [MCU2_0]     58.346000 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]     58.346049 s: Error : Failed to start sensor at channel Id 0
    [MCU2_0]     58.346086 s: test--ar0147_StreamOn
    [MCU2_0]     58.346220 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]     58.346266 s:  test---max96705 Write regAddr 4
    [MCU2_0]     58.346309 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]     58.346355 s: Error : Failed to start sensor at channel Id 1
    [MCU2_0]     58.346459 s: test--ar0147_StreamOn
    [MCU2_0]     58.346615 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]     58.346667 s:  test---max96705 Write regAddr 4
    [MCU2_0]     58.346709 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]     58.346758 s: Error : Failed to start sensor at channel Id 2
    [MCU2_0]     58.346793 s: test--ar0147_StreamOn
    [MCU2_0]     58.346924 s: Error writing 0x87 to max96705 register 0x4
    [MCU2_0]     58.346973 s:  test---max96705 Write regAddr 4
    [MCU2_0]     58.347014 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]     58.347061 s: Error : Failed to start sensor at channel Id 3
        58.445521 s: ISS: Stopping sensor [MAX96705_AR0147_UYVY] ... !!!
    [MCU2_0]     58.445778 s: test--ar0147_StreamOff
    [MCU2_0]     58.445965 s: Error writing 0x47 to max96705 register 0x4
    [MCU2_0]     58.446020 s:  test---max96705 Write regAddr 4
    [MCU2_0]     58.446064 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]     58.446112 s: Warning : Failed to stop sensor at channel Id 0
    [MCU2_0]     58.446148 s: test--ar0147_StreamOff
    [MCU2_0]     58.446281 s: Error writing 0x47 to max96705 register 0x4
    [MCU2_0]     58.446324 s:  test---max96705 Write regAddr 4
    [MCU2_0]     58.446367 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]     58.446499 s: Warning : Failed to stop sensor at channel Id 1
    [MCU2_0]     58.446546 s: test--ar0147_StreamOff
    [MCU2_0]     58.446686 s: Error writing 0x47 to max96705 register 0x4
    [MCU2_0]     58.446733 s:  test---max96705 Write regAddr 4
        58.447305 s: ISS: Stopping sensor [MAX96705_AR0147_UYVY] failed !!!
        58.447456 s:  VX_ZONE_ERROR:[ownReleaseReferenceInt:294] Invalid reference
        58.450778 s:  VX_ZONE_ERROR:[ownReleaseReferenceInt:294] Invalid reference
    [MCU2_0]     58.446775 s:  max96705 Error: Reg Write Failed for regAddr 4
        58.778561 s:  VX_ZONE_ERROR:[ownReleaseReferenceInt:294] Invalid reference
    [MCU2_0]     58.446823 s: Warning : Failed to stop sensor at channel Id 2
        58.778577 s:  VX_ZONE_ERROR:[ownReleaseReferenceInt:294] Invalid reference
    [MCU2_0]     58.446860 s: test--ar0147_StreamOff
    [MCU2_0]     58.446988 s: Error writing 0x47 to max96705 register 0x4
    [MCU2_0]     58.447032 s:  test---max96705 Write regAddr 4
    [MCU2_0]     58.447073 s:  max96705 Error: Reg Write Failed for regAddr 4
    [MCU2_0]     58.447121 s: Warning : Failed to stop sensor at channel Id 3
    [MCU2_0]     58.781621 s: ==========================================================
    [MCU2_0]     58.781716 s:  Capture Status: Instance|0
    [MCU2_0]     58.781754 s: ==========================================================
    [MCU2_0]     58.781804 s:  overflowCount: 0
    [MCU2_0]     58.781839 s:  spuriousUdmaIntrCount: 0
    [MCU2_0]     58.781876 s:  frontFIFOOvflCount: 0
    [MCU2_0]     58.781910 s:  crcCount: 0
    [MCU2_0]     58.781940 s:  eccCount: 0
    [MCU2_0]     58.781971 s:  correctedEccCount: 0
    [MCU2_0]     58.782006 s:  dataIdErrorCount: 0
    [MCU2_0]     58.782040 s:  invalidAccessCount: 0
    [MCU2_0]     58.782075 s:  invalidSpCount: 0
    [MCU2_0]     58.782114 s:  strmFIFOOvflCount[0]: 0
    [MCU2_0]     58.782155 s:  strmFIFOOvflCount[1]: 0
    [MCU2_0]     58.782186 s:  Channel Num | Frame Queue Count | Frame De-queue Count | Frame Drop Count | Error Frame Count |
    [MCU2_0]     58.782262 s:            0 |                 0 |                    0 |                0 |                 0 |
    [MCU2_0]     58.782338 s:            1 |                 0 |                    0 |                0 |                 0 |
    [MCU2_0]     58.782500 s:            2 |                 0 |                    0 |                0 |                 0 |
    [MCU2_0]     58.782583 s:            3 |                 0 |                    0 |                0 |                 0 |
        58.998903 s: ISS: De-initializing sensor [MAX96705_AR0147_UYVY] ... !!!
        58.999294 s: ISS: De-initializing sensor [MAX96705_AR0147_UYVY] ... Done !!!
        58.999308 s:  VX_ZONE_INIT:[tivxHostDeInitLocal:107] De-Initialization Done for HOST !!!
        59.003747 s:  VX_ZONE_INIT:[tivxDeInitLocal:193] De-Initialization Done !!!
    APP: Deinit ... !!!
    IPC: Deinit ... !!!
    MEM: Deinit ... !!!
    root@j7-evm:/opt/vision_apps# [  133.898422] Initializing XFRM netlink socket
    [  135.358495] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
    [  135.374275] Bridge firewalling registered
    [  135.908407] process 'docker/tmp/qemu-check245040377/check' started with executable stack
    root@j7-evm:/opt/vision_apps# ./run_app_multi_cam_codec.sh
    test---------------------------main,start!
    APP: Init ... !!!
    MEM: Init ... !!!
    IPC: Init ... !!!
       187.747495 s: GTC Frequency = 200 MHz
       187.747580 s:  VX_ZONE_INIT:Enabled
       187.747587 s:  VX_ZONE_ERROR:Enabled
       187.747592 s:  VX_ZONE_WARNING:Enabled
       187.748259 s:  VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
       187.749448 s:  VX_ZONE_INIT:[tivxHostInitLocal:93] Initialization Done for HOST !!!
    test1---------------------------main,status=0!
    test1.5-----------------------------app_multi_cam_codec_main!
       187.752450 s: ISS: Enumerating sensors ... !!!
       188.177597 s: ISS: Enumerating sensors ... found 0 : IMX390-UB953_D3
       188.177627 s: ISS: Enumerating sensors ... found 1 : AR0233-UB953_MARS
       188.177646 s: ISS: Enumerating sensors ... found 2 : AR0820-UB953_LI
       188.177651 s: ISS: Enumerating sensors ... found 3 : UB9xxx_RAW12_TESTPATTERN
       188.177657 s: ISS: Enumerating sensors ... found 4 : UB96x_UYVY_TESTPATTERN
       188.177662 s: ISS: Enumerating sensors ... found 5 : GW_AR0233_UYVY
       188.177668 s: ISS: Enumerating sensors ... found 6 : MAX96705_AR0147_UYVY
    Querying MAX96705_AR0147_UYVY
       188.177686 s: ISS: Querying sensor [MAX96705_AR0147_UYVY] ... !!!
       188.178009 s: ISS: Querying sensor [MAX96705_AR0147_UYVY] ... Done !!!
    test800-----------------------------app_multi_cam_codec_main--app_querry_sensor--0
    YUV Input selected. VISS, AEWB and Mosaic nodes will be bypassed.
    Capture->Encode Selection Yes(1)/No(0)
    1
    Decode->Display Selection Yes(1)/No(0)
    0
    Max number of cameras supported by sensor MAX96705_AR0147_UYVY = 4
    Please enter number of channels to be enabled
    4
    GstCmdString:
    appsrc format=GST_FORMAT_TIME is-live=true do-timestamp=true block=false name=myAppSrc0 ! queue
    ! video/x-raw, width=(int)960, height=(int)420, framerate=(fraction)30/1, format=(string)NV12, interlace-mode=(string)progressive, colorimetry=(string)bt601
    ! v4l2h264enc bitrate=1500000
    ! multifilesink max-files=5 next-file=4 max-file-size=100000000 location=output_video_0.h264_%d
    GstCmdString:
    appsrc format=GST_FORMAT_TIME is-live=true do-timestamp=true block=false name=myAppSrc1 ! queue
    ! multifilesink max-files=5 next-file=4 max-file-size=100000000 location=output_video_1.h264_%d
    GstCmdString:
    appsrc format=GST_FORMAT_TIME is-live=true do-timestamp=true block=false name=myAppSrc2 ! queue
    ! multifilesink max-files=5 next-file=4 max-file-size=100000000 location=output_video_2.h264_%d
    GstCmdString:
    appsrc format=GST_FORMAT_TIME is-live=true do-timestamp=true block=false name=myAppSrc3 ! queue
    ! multifilesink max-files=5 next-file=4 max-file-size=100000000 location=output_video_3.h264_%d
    test3---------------------------app_init! enable_configure_hwa_freq=0--0
    test4---------------------------app_init! status=0--
    Creating context done!
    test5---------------------------app_init! status=0--
    Kernel loading done!
    test6---------------------------app_init! status=0--
    test----app_init_sensor
       191.362199 s: ISS: Initializing sensor [MAX96705_AR0147_UYVY], doing IM_SENSOR_CMD_PWRON ... !!!
       191.362599 s: ISS: Initializing sensor [MAX96705_AR0147_UYVY], doing IM_SENSOR_CMD_CONFIG ... !!!
    [MCU2_0]    191.362837 s: test--get handle returned for sensor MAX96705_AR0147_UYVY,sensorBroadcast=0
    [MCU2_0]    191.362905 s: test--set no broadcast mode, max96712 have no this mode
    [MCU2_0]    191.362961 s: test--IM_SENSOR_CMD_CONFIG channel_mask = f
    [MCU2_0]    191.363004 s: test--probeStatus = 0
    [MCU2_0]    191.363041 s: Configuring camera # 0
    [MCU2_0]    191.363685 s:  test---max96705 Write regAddr 4
    [MCU2_0]    191.363756 s:  test--max96705 Reg Write slaveAddr:0x40, regAddr:0x0004, regValue:0x47
    [MCU2_0]    191.603678 s:  test---max96705 Write regAddr 0
    [MCU2_0]    191.603756 s:  test--max96705 Reg Write slaveAddr:0x40, regAddr:0x0000, regValue:0x82
    [MCU2_0]    191.843462 s: test--MAx96712_SetSensorAlias status = 0
    [MCU2_0]    191.843756 s:  test---max96705 Write regAddr 7
    [MCU2_0]    191.843824 s:  test--max96705 Reg Write slaveAddr:0x41, regAddr:0x0007, regValue:0x84
    [MCU2_0]    191.939676 s:  test---max96705 Write regAddr 15
    [MCU2_0]    191.939757 s:  test--max96705 Reg Write slaveAddr:0x41, regAddr:0x000f, regValue:0xbf
    [MCU2_0]    192.035459 s: test--probeStatus = 0
    [MCU2_0]    192.035517 s: Configuring camera # 1
    [MCU2_0]    192.036761 s:  test---max96705 Write regAddr 4
    [MCU2_0]    192.036834 s:  test--max96705 Reg Write slaveAddr:0x40, regAddr:0x0004, regValue:0x47
    [MCU2_0]    192.276676 s:  test---max96705 Write regAddr 0
    [MCU2_0]    192.276758 s:  test--max96705 Reg Write slaveAddr:0x40, regAddr:0x0000, regValue:0x84
    [MCU2_0]    192.516463 s: test--MAx96712_SetSensorAlias status = 0
    [MCU2_0]    192.516750 s:  test---max96705 Write regAddr 7
    [MCU2_0]    192.516818 s:  test--max96705 Reg Write slaveAddr:0x42, regAddr:0x0007, regValue:0x84
    [MCU2_0]    192.612670 s:  test---max96705 Write regAddr 15
    [MCU2_0]    192.612752 s:  test--max96705 Reg Write slaveAddr:0x42, regAddr:0x000f, regValue:0xbf
    [MCU2_0]    192.708457 s: test--probeStatus = 0
    [MCU2_0]    192.708512 s: Configuring camera # 2
    [MCU2_0]    192.709757 s:  test---max96705 Write regAddr 4
    [MCU2_0]    192.709835 s:  test--max96705 Reg Write slaveAddr:0x40, regAddr:0x0004, regValue:0x47
    [MCU2_0]    192.949673 s:  test---max96705 Write regAddr 0
    [MCU2_0]    192.949759 s:  test--max96705 Reg Write slaveAddr:0x40, regAddr:0x0000, regValue:0x86
    [MCU2_0]    193.189463 s: test--MAx96712_SetSensorAlias status = 0
    [MCU2_0]    193.189752 s:  test---max96705 Write regAddr 7
    [MCU2_0]    193.189822 s:  test--max96705 Reg Write slaveAddr:0x43, regAddr:0x0007, regValue:0x84
    [MCU2_0]    193.285672 s:  test---max96705 Write regAddr 15
    [MCU2_0]    193.285752 s:  test--max96705 Reg Write slaveAddr:0x43, regAddr:0x000f, regValue:0xbf
    [MCU2_0]    193.381470 s: test--probeStatus = 0
    [MCU2_0]    193.381531 s: Configuring camera # 3
    [MCU2_0]    193.382759 s:  test---max96705 Write regAddr 4
    [MCU2_0]    193.382833 s:  test--max96705 Reg Write slaveAddr:0x40, regAddr:0x0004, regValue:0x47
    [MCU2_0]    193.622674 s:  test---max96705 Write regAddr 0
    [MCU2_0]    193.622759 s:  test--max96705 Reg Write slaveAddr:0x40, regAddr:0x0000, regValue:0x88
    [MCU2_0]    193.862460 s: test--MAx96712_SetSensorAlias status = 0
    [MCU2_0]    193.862749 s:  test---max96705 Write regAddr 7
    [MCU2_0]    193.862819 s:  test--max96705 Reg Write slaveAddr:0x44, regAddr:0x0007, regValue:0x84
    [MCU2_0]    193.958674 s:  test---max96705 Write regAddr 15
    [MCU2_0]    193.958757 s:  test--max96705 Reg Write slaveAddr:0x44, regAddr:0x000f, regValue:0xbf
       194.054592 s: ISS: Initializing sensor [MAX96705_AR0147_UYVY] ... Done !!!
    test71---------------------------app_init! status=0--
    Sensor init done!
    test72---------------------------app_init! status=0--
    test73---------------------------app_init! status=0--
    test74---------------------------app_init! status=0--
    init_ldc_start!
    init_ldc :ldcObj->table_width=1280,ldcObj->table_height =720,ldcObj->ds_factor=4
    init_ldc :configure_dcc_params status =0
    init_ldc :configure_mesh_params status =0
    init_ldc :configure_region_params status =0
    init_ldc :configure_ldc_params status =0
    init_ldc :create_ldc_outputs status =0
    init_ldc_end!
    LDC init done!
    test75---------------------------app_init! status=0--
    test76---------------------------app_init! status=0--
    test77---------------------------app_init! status=0--
    test78---------------------------app_init! status=0--
    test79---------------------------app_init! status=0--
    Img Mosaic init done!
    test710---------------------------app_init! status=0--
    Display init done!
    test711---------------------------app_init! status=0--
    test712---------------------------app_init! status=0--
    test801-----------------------------app_init--0
    App Init Done!
    test--8020--vxGetStatus. status= 0
    capture_graph create done!
    test--8021--vxSetReferenceName. status= 0
    test--8022--vxGetStatus. status= 0
    display_graph create done!
    test--8023--vxSetReferenceName. status= 0
    Capture graph done!
    test--8024--app_create_graph_capture. status= 0
    test--8025--app_create_graph_viss. status= 0
    test--8026--app_create_graph_aewb. status= 0
    LDC graph done!
    test--8027--app_create_graph_ldc. status= 0
    test--8028--app_create_graph_scaler. status= 0
    Img Mosaic graph done!
    test--8029--tiovx_img_mosaic_module_create. status= 0
    Display graph done!
    test--80210--app_create_graph_display. status= 0
    888888888888888888----. disp_graph_paramete_nums= 1
    test--80211--vxSetGraphScheduleConfig. status= 0
    test--80212--tivxSetGraphPipelineDepth. status= 0
    Pipeline params setup done!
    test--80215--tivxSetNodeParameterNumBufByIndex. status= 0
    gst_wrapper: GstCmdString:
    Codec Pipeline done!
    test--80216--tivxSetNodeParameterNumBufByIndex. status= 0
    test802-----------------------------app_create_graph==0
    App Create Graph Done!
    00000000000000-------------------------vxVerifyGraph test!
    00000000000001-------------------------vxVerifyGraph test!
    00000000000002-------------------------vxVerifyGraph test! graph != NULL
    0000000000000004-------------------------vxVerifyGraph test! graph == NULL
    0000000000000005-------------------------vxVerifyGraph test! graph == NULL
    0000000000000006-------------------------vxVerifyGraph test! graph == NULL
    0000000000000007-------------------------vxVerifyGraph test! graph == NULL
    0000000000000007x1-------------------------vxVerifyGraph test! graph == NULL
    111111111111000000000-------------------------vxVerifyGraph test! graph == NULL
    111111111111000000001-------------------------vxVerifyGraph test! graph == NULL
    111111111111000000002-------------------------num_params=2,param_idx=0
    111111111111000000002-------------------------num_params=2,param_idx=1
    111111111111000000004-------------------------vxVerifyGraph test! graph == NULL
    0000000000000007x2-------------------------vxVerifyGraph test! graph == NULL
    0000000000000008-------------------------vxVerifyGraph test! graph == NULL
    0000000000000009-------------------------vxVerifyGraph test! graph == NULL
    00000000000000010-------------------------vxVerifyGraph test! graph == NULL
    00000000000000011-------------------------vxVerifyGraph test! graph == NULL
    00000000000000012-------------------------vxVerifyGraph test! graph == NULL
    00000000000000013-------------------------vxVerifyGraph test! graph == NULL
    00000000000000014-------------------------vxVerifyGraph test! graph == NULL
    00000000000000015-------------------------vxVerifyGraph test! graph == NULL
    00000000000000016-------------------------vxVerifyGraph test! graph == NULL
    00000000000000017-------------------------vxVerifyGraph test! graph == NULL
    00000000000000018-------------------------vxVerifyGraph test! graph == NULL
    00000000000000019-------------------------vxVerifyGraph test! graph == NULL
    00000000000000020-------------------------vxVerifyGraph test! graph == NULL
    00000000000000021-------------------------vxVerifyGraph test! graph == NULL
    00000000000000023-------------------------vxVerifyGraph test! graph == NULL
    Capture Graph verify done!
    111111111111000000002-------------------------num_params=1,param_idx=0
    9000-------------------------vxVerifyGraph done! status=0
    Display Graph verify done!
    90001-------------------------tivxExportGraphToDot done! status=0
    90002-------------------------tivxExportGraphToDot done! status=0
    90003-------------------------tivxExportGraphToDot done! status=0
    appCodecSrcInit Done!
    90004-------------------------tivxExportGraphToDot done! status=0
    90005-------------------------tivxExportGraphToDot done! status=0
    test803-----------------------------app_verify_graph==0
    App Verify Graph Done!
    App Send Error Frame Done!
     app_run_task_create()  start:
     app_run_task_create()  end. status = 0
     app_run_task()  start:
     app_run_graph()  start:
    app_pipeline_params_defaults returned
    test_b1________________appStartImageSensor(obj->sensor_name, 0xF)  sensor_name:MAX96705_AR0147_UYVY, ch_mask=15
       195.414404 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] ... !!!
    [MCU2_0]    195.415041 s: test--IM_SENSOR_CMD_STREAM_ON:  channel_mask = 0xf, sensorBroadcast=0
    [MCU2_0]    195.415112 s: test--ar0147_StreamOn
    [MCU2_0]    195.415468 s:  test---max96705 Write regAddr 4
    [MCU2_0]    195.415545 s:  test--max96705 Reg Write slaveAddr:0x41, regAddr:0x0004, regValue:0x87
    [MCU2_0]    195.511432 s: test--ar0147_StreamOn
    [MCU2_0]    195.511737 s:  test---max96705 Write regAddr 4
    [MCU2_0]    195.511806 s:  test--max96705 Reg Write slaveAddr:0x42, regAddr:0x0004, regValue:0x87
    [MCU2_0]    195.607435 s: test--ar0147_StreamOn
    [MCU2_0]    195.607739 s:  test---max96705 Write regAddr 4
    [MCU2_0]    195.607808 s:  test--max96705 Reg Write slaveAddr:0x43, regAddr:0x0004, regValue:0x87
    [MCU2_0]    195.703434 s: test--ar0147_StreamOn
    [MCU2_0]    195.703742 s:  test---max96705 Write regAddr 4
    [MCU2_0]    195.703813 s:  test--max96705 Reg Write slaveAddr:0x44, regAddr:0x0004, regValue:0x87
    test__appStartImageSensor____0___________APP_IPC_CPU_MCU2_0 = 3[  188.930418] img_enc 4200000.video-encoder: vxe_g_ext_ctrls Invalid control id 0x980927
    test__appStartImageSensor____1__________appRemoteServiceRun_st[  188.939100] img_enc 4200000.video-encoder: vxe_g_ext_ctrls Invalid control id 0x980927
    atus = 0
    test__appStartImageSensor____2__________IMAGE_SENSOR_R[  188.953442] img_enc 4200000.video-encoder: vxe_g_ext_ctrls Invalid control id 0x980927
    test__appStartImageSen[  188.966401] img_enc 4200000.video-encoder: vxe_g_ext_ctrls Invalid control id 0x980927
    test__appStartIma[  188.980058] img_enc 4200000.video-encoder: vxe_g_ext_ctrls Invalid control id 0x980927
    test__appStartImage[  188.993272] img_enc 4200000.video-encoder: vxe_g_ext_ctrls Invalid control id 0x980927
       195.799652 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] ... !!!
    appStartImageSensor returned with status: 0
     Demo : Camera Demo
     s: [  189.023312] img_enc 4200000.video-encoder: vxe_g_ext_ctrls Invalid control id 0x980927
    Save CSIx, VISS and LDC outputs
     p: Print performance statist[  189.036498] img_enc 4200000.video-encoder: vxe_g_ext_ctrls Invalid control id 0x980928
    ics
     x: Exit
     Enter Choice: appCodecStart Done!
    capture[  189.050123] img_enc 4200000.video-encoder: vxe_g_ext_ctrls Invalid control id 0x980928
    _encode: frame 0 beginning
    [  189.063394] img_enc 4200000.video-encoder: vxe_g_ext_ctrls Invalid control id 0x980928
    capture_encode: frame 2 beginning
    capture_encode: frame 3 [  189.077331] img_enc 4200000.video-encoder: vxe_g_ext_ctrls Invalid control id 0x980927
    beginning
    capture_encode: frame 4 beginning
    capture_encode: frame 5 beginning
    capture_encode: frame 6 beginning
    [  189.103289] img_enc 4200000.video-encoder: vxe_g_ext_ctrls Invalid control id 0x980928
    capture_encode: frame 7 beginning
    capture_encode: frame 8 beginning
    capture_encode: frame 9 beginning
    capture_encode: frame 10 beginning
    capture_encode: frame 11 beginning
    capture_encode: frame 12 beginning
    capture_encode: frame 13 beginning
    capture_encode: frame 14 beginning
    capture_encode: frame 15 beginning
    capture_encode: frame 16 beginning
    capture_encode: frame 17 beginning
    capture_encode: frame 18 beginning
    capture_encode: frame 19 beginning
    capture_encode: frame 20 beginning
    capture_encode: frame 21 beginning
    capture_encode: frame 22 beginning
    capture_encode: frame 23 beginning
    capture_encode: frame 24 beginning
    capture_encode: frame 25 beginning
    capture_encode: frame 26 beginning
    capture_encode: frame 27 beginning
    x
    capture_encode: frame 28 beginning
    capture_encode: frame 29 beginning
    capture_encode: frame 30 beginning
    capture_encode: frame 31 beginning
    Among them, for functions
    “Status=appRemoteServiceRun(
    APP_ IPC_ CPU_ MCU 2_ 0
    IMAGE_ SENSOR_ REMOTE_ Service_ NAME,
    IM_ SENSOR_ CMD_ STREAM_ ON,
    (void *) g_ CmdPrm,
    CMD_ PARAM_ SIZE,
    0); " in "app_iss.c".
     I have added all the parameters for printing.
    From the logs, it can be seen that when running "app_srv_camera" and "app_multi_cam_codec", the print output of "printf("test__appStartImageSensor____0__________APP_IPC_CPU_MCU2_0 = %d\n", APP_IPC_CPU_MCU2_0);
    printf("test__appStartImageSensor____2__________IMAGE_SENSOR_REMOTE_SERVICE_NAME = %s\n", IMAGE_SENSOR_REMOTE_SERVICE_NAME);
    printf("test__appStartImageSensor____3__________IM_SENSOR_CMD_STREAM_ON = %d\n", IM_SENSOR_CMD_STREAM_ON);
    printf("test__appStartImageSensor____4__________CMD_PARAM_SIZE = %d\n", CMD_PARAM_SIZE);
    printf("test__appStartImageSensor____5__________g_cmdPrm = %s\n", g_cmdPrm);" is the same,
    but the return value "status" of the function is different.(printf("test__appStartImageSensor____1__________appRemoteServiceRun_status = %d\n", status);)
    What is the reason for this situation? I think this is the main reason why 'app_srv_camera' failed to run.
    Yueqian
    I have attempted to skip the issue of camera initialization, but a new error has appeared in the subsequent log. May I ask what is the reason for this error?
    Yueqian
    (1789) PVR:(Error): IsTextureConsistent: IMGEGLImage is not consistent [ :4923 ]
    (1789) PVR:(Error): CreateImageSharedFromDMABufs: Unsupported DRI FourCC (fourcc = 0x59565955) [ :277 ]
    EGL: after eglCreateImageKHR() eglError (0x3009)
    EGL: ERROR: eglCreateImageKHR failed !!!
    EGL: ERROR: appEglWindowCreateIMG failed !!!
  • The log is as follows:
    root@j7-evm:/opt/vision_apps# ./run_app_srv.sh
    APP: Init ... !!!
    MEM: Init ... !!!
    IPC: Init ... !!!
        90.888545 s: GTC Frequency = 200 MHz
        90.892055 s:  VX_ZONE_INIT:Enabled
        90.892078 s:  VX_ZONE_ERROR:Enabled
        90.892084 s:  VX_ZONE_WARNING:Enabled
        90.892913 s:  VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
        90.893885 s:  VX_ZONE_INIT:[tivxHostInitLocal:93] Initialization Done for HOST !!!
        91.288698 s: ISS: Enumerating sensors ... !!!
        91.714355 s: ISS: Enumerating sensors ... found 0 : IMX390-UB953_D3
        91.714379 s: ISS: Enumerating sensors ... found 1 : AR0233-UB953_MARS
        91.714399 s: ISS: Enumerating sensors ... found 2 : AR0820-UB953_LI
        91.714404 s: ISS: Enumerating sensors ... found 3 : UB9xxx_RAW12_TESTPATTERN
        91.714410 s: ISS: Enumerating sensors ... found 4 : UB96x_UYVY_TESTPATTERN
        91.714415 s: ISS: Enumerating sensors ... found 5 : GW_AR0233_UYVY
        91.714420 s: ISS: Enumerating sensors ... found 6 : MAX96705_AR0147_UYVY
    test_a1_________________status: 0
    test0________Querying MAX96705_AR0147_UYVY
        91.714448 s: ISS: Querying sensor [MAX96705_AR0147_UYVY] ... !!!
        91.715153 s: ISS: Querying sensor [MAX96705_AR0147_UYVY] ... Done !!!
    test1________TIVX_TARGET_DISPLAY1 1
    test2________TIVX_TARGET_CAPTURE1 1
    test3________TIVX_TARGET_VPAC_VISS1 1
        91.715191 s: ISS: Initializing sensor [MAX96705_AR0147_UYVY], doing IM_SENSOR_CMD_PWRON ... !!!
        91.715503 s: ISS: Initializing sensor [MAX96705_AR0147_UYVY], doing IM_SENSOR_CMD_CONFIG ... !!!
    [MCU2_0]     91.715736 s: comon--appInit----start!!test--get handle returned for sensor MAX96705_AR0147_UYVY,sensorBroadcast=0
    [MCU2_0]     91.715818 s: test--set no broadcast mode, max96712 have no this mode
    [MCU2_0]     91.715875 s: test--IM_SENSOR_CMD_CONFIG channel_mask = f
    [MCU2_0]     91.715924 s: test--probeStatus = 0
    [MCU2_0]     91.715962 s: Configuring camera # 0
    [MCU2_0]     91.717433 s:  test---max96705 Write regAddr 4
    [MCU2_0]     91.717511 s:  test--max96705 Reg Write slaveAddr:0x40, regAddr:0x0004, regValue:0x47
    [MCU2_0]     91.957436 s:  test---max96705 Write regAddr 0
    [MCU2_0]     91.957517 s:  test--max96705 Reg Write slaveAddr:0x40, regAddr:0x0000, regValue:0x82
    [MCU2_0]     92.197223 s: test--MAx96712_SetSensorAlias status = 0
    [MCU2_0]     92.197513 s:  test---max96705 Write regAddr 7
    [MCU2_0]     92.197577 s:  test--max96705 Reg Write slaveAddr:0x41, regAddr:0x0007, regValue:0x84
    [MCU2_0]     92.293455 s:  test---max96705 Write regAddr 15
    [MCU2_0]     92.293543 s:  test--max96705 Reg Write slaveAddr:0x41, regAddr:0x000f, regValue:0xbf
    [MCU2_0]     92.389229 s: test--probeStatus = 0
    [MCU2_0]     92.389289 s: Configuring camera # 1
    [MCU2_0]     92.390514 s:  test---max96705 Write regAddr 4
    [MCU2_0]     92.390589 s:  test--max96705 Reg Write slaveAddr:0x40, regAddr:0x0004, regValue:0x47
    [MCU2_0]     92.630435 s:  test---max96705 Write regAddr 0
    [MCU2_0]     92.630519 s:  test--max96705 Reg Write slaveAddr:0x40, regAddr:0x0000, regValue:0x84
    [MCU2_0]     92.870224 s: test--MAx96712_SetSensorAlias status = 0
    [MCU2_0]     92.870518 s:  test---max96705 Write regAddr 7
    [MCU2_0]     92.870586 s:  test--max96705 Reg Write slaveAddr:0x42, regAddr:0x0007, regValue:0x84
    [MCU2_0]     92.966439 s:  test---max96705 Write regAddr 15
    [MCU2_0]     92.966524 s:  test--max96705 Reg Write slaveAddr:0x42, regAddr:0x000f, regValue:0xbf
    [MCU2_0]     93.062223 s: test--probeStatus = 0
    [MCU2_0]     93.062281 s: Configuring camera # 2
    [MCU2_0]     93.063522 s:  test---max96705 Write regAddr 4
    [MCU2_0]     93.063597 s:  test--max96705 Reg Write slaveAddr:0x40, regAddr:0x0004, regValue:0x47
    [MCU2_0]     93.303431 s:  test---max96705 Write regAddr 0
    [MCU2_0]     93.303517 s:  test--max96705 Reg Write slaveAddr:0x40, regAddr:0x0000, regValue:0x86
    [MCU2_0]     93.543232 s: test--MAx96712_SetSensorAlias status = 0
    [MCU2_0]     93.543519 s:  test---max96705 Write regAddr 7
    [MCU2_0]     93.543582 s:  test--max96705 Reg Write slaveAddr:0x43, regAddr:0x0007, regValue:0x84
    [MCU2_0]     93.639441 s:  test---max96705 Write regAddr 15
    [MCU2_0]     93.639524 s:  test--max96705 Reg Write slaveAddr:0x43, regAddr:0x000f, regValue:0xbf
    [MCU2_0]     93.735223 s: test--probeStatus = 0
    [MCU2_0]     93.735281 s: Configuring camera # 3
    [MCU2_0]     93.736516 s:  test---max96705 Write regAddr 4
    [MCU2_0]     93.736595 s:  test--max96705 Reg Write slaveAddr:0x40, regAddr:0x0004, regValue:0x47
    [MCU2_0]     93.976469 s:  test---max96705 Write regAddr 0
    [MCU2_0]     93.976552 s:  test--max96705 Reg Write slaveAddr:0x40, regAddr:0x0000, regValue:0x88
    [MCU2_0]     94.216227 s: test--MAx96712_SetSensorAlias status = 0
    [MCU2_0]     94.216517 s:  test---max96705 Write regAddr 7
    [MCU2_0]     94.216581 s:  test--max96705 Reg Write slaveAddr:0x44, regAddr:0x0007, regValue:0x84
    [MCU2_0]     94.312437 s:  test---max96705 Write regAddr 15
    [MCU2_0]     94.312515 s:  test--max96705 Reg Write slaveAddr:0x44, regAddr:0x000f, regValue:0xbf
        94.408339 s: ISS: Initializing sensor [MAX96705_AR0147_UYVY] ... Done !!!
    appInitImageSensor obj->sensor_name=MAX96705_AR0147_UYVY,sensor_features_enabled=288
    test_____________start app_create_graph_gpu_lut
    Reading calmat file
    file read completed
    test_______________obj->srv_node = tivxGlSrvNode:capt_frames[0]
    EGL: version 1.5
    EGL: GL Version = (null)
    EGL: GL Vendor = (null)
    EGL: GL Renderer = (null)
    EGL: GL Extensions = (null)
    test_a2_______________ _status: 0
    test_a3_______________ _status: 0
    test_a4_______________ app_run_graph_gpu_lut
     Demo : Integrated SRV
     p: Print performance statistics
     e: Export performance statistics
     x: Exit
     Enter Choice: test_b0_________________app_run_graph start
        95.823524 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] ... !!!
    [MCU2_0]     95.823785 s: test--IM_SENSOR_CMD_STREAM_ON:  channel_mask = 0xf, sensorBroadcast=0
    [MCU2_0]     95.823856 s: test--ar0147_StreamOn
    [MCU2_0]     95.824131 s:  test---max96705 Write regAddr 4
    [MCU2_0]     95.824282 s:  test--max96705 Reg Write slaveAddr:0x41, regAddr:0x0004, regValue:0x87
    [MCU2_0]     95.920193 s: test--ar0147_StreamOn
    [MCU2_0]     95.920503 s:  test---max96705 Write regAddr 4
    [MCU2_0]     95.920573 s:  test--max96705 Reg Write slaveAddr:0x42, regAddr:0x0004, regValue:0x87
    [MCU2_0]     96.016194 s: test--ar0147_StreamOn
    [MCU2_0]     96.016503 s:  test---max96705 Write regAddr 4
    [MCU2_0]     96.016574 s:  test--max96705 Reg Write slaveAddr:0x43, regAddr:0x0004, regValue:0x87
    [MCU2_0]     96.112200 s: test--ar0147_StreamOn
    [MCU2_0]     96.112503 s:  test---max96705 Write regAddr 4
    [MCU2_0]     96.112572 s:  test--max96705 Reg Write slaveAddr:0x44, regAddr:0x0004, regValue:0x87
    test__appStartImageSensor____0__________APP_IPC_CPU_MCU2_0 = 3
    test__appStartImageSensor____1__________appRemoteServiceRun_status = 0
        96.208375 s: ISS: Starting sensor [MAX96705_AR0147_UYVY] ... !!!
    test_b2________________Sensor start status = 0
    test_b3________________vxGraphParameterEnqueueReadyRef status = 0
    test_b4________________status = 0
    test_b5________________vxGraphParameterDequeueDoneRef status = 0
    (1476) PVR:(Error): CreateImageSharedFromDMABufs: Unsupported DRI FourCC (fourcc = 0x59565955) [ :277 ]
    (1476) PVR:(Error): IsTextureConsistent: IMGEGLImage is not consistent [ :4923 ]
    test_b6________________vxGraphParameterDequeueDoneRef status = 0
    test_b7________________vxGraphParameterEnqueueReadyRef status = 0
    test_b8________________vxGraphParameterEnqueueReadyRef status = 0
    (1476) PVR:(Error): IsTextureConsistent: IMGEGLImage is not p
    Summary of CPU load,
    CPU: mpu1_0: TOTAL LOAD =   1.26 % ( HWI =   0. 0 %, SWI =   1.26 % )
    CPU: mcu2_0: TOTAL LOAD =   6. 0 % ( HWI =   0. 0 %, SWI =   0. 0 % )
    CPU: mcu2_1: TOTAL LOAD =   1. 0 % ( HWI =   0. 0 %, SWI =   0. 0 % )
    CPU:  c6x_1: TOTAL LOAD =   1. 0 % ( HWI =   0. 0 %, SWI =   0. 0 % )
    CPU:  c6x_2: TOTAL LOAD =   1. 0 % ( HWI =   0. 0 %, SWI =   0. 0 % )
    CPU:  c7x_1: TOTAL LOAD =   0. 0 % ( HWI =   0. 0 %, SWI =   0. 0 % )
    HWA performance statistics,
    HWA:   GPU : LOAD =  93.17 % ( 224 MP/s )
    DDR performance statistics,
    DDR: READ  BW: AVG =    378 MB/s, PEAK =   5133 MB/s
    DDR: WRITE BW: AVG =    308 MB/s, PEAK =   6258 MB/s
    DDR: TOTAL BW: AVG =    686 MB/s, PEAK =  11391 MB/s
    Detailed CPU performance/memory statistics,
    DDR_SHARED_MEM: Alloc's: 41 alloc's of 43894936 bytes
    DDR_SHARED_MEM: Free's : 1 free's  of 36 bytes
    DDR_SHARED_MEM: Open's : 40 allocs  of 43894900 bytes
    CPU: mcu2_0: TASK:           IPC_RX:   0. 7 %
    CPU: mcu2_0: TASK:       REMOTE_SRV:   0.22 %
    CPU: mcu2_0: TASK:        LOAD_TEST:   0. 0 %
    CPU: mcu2_0: TASK:       TIVX_CPU_0:   0. 0 %
    CPU: mcu2_0: TASK:        TIVX_V1NF:   0. 0 %
    CPU: mcu2_0: TASK:      TIVX_V1LDC1:   0. 0 %
    CPU: mcu2_0: TASK:       TIVX_V1SC1:   0. 0 %
    CPU: mcu2_0: TASK:      TIVX_V1MSC2:   0. 0 %
    CPU: mcu2_0: TASK:       TIVXVVISS1:   0. 0 %
    CPU: mcu2_0: TASK:       TIVX_CAPT1:   0.32 %
    CPU: mcu2_0: TASK:       TIVX_CAPT2:   0. 0 %
    CPU: mcu2_0: TASK:       TIVX_DISP1:   0. 0 %
    CPU: mcu2_0: TASK:       TIVX_DISP2:   0. 0 %
    CPU: mcu2_0: TASK:       TIVX_CSITX:   0. 0 %
    CPU: mcu2_0: TASK:       TIVX_CAPT3:   0. 0 %
    CPU: mcu2_0: TASK:       TIVX_CAPT4:   0. 0 %
    CPU: mcu2_0: TASK:       TIVX_CAPT5:   0. 0 %
    CPU: mcu2_0: TASK:       TIVX_CAPT6:   0. 0 %
    CPU: mcu2_0: TASK:       TIVX_CAPT7:   0. 0 %
    CPU: mcu2_0: TASK:       TIVX_CAPT8:   0. 0 %
    CPU: mcu2_0: TASK:      TIVX_DPM2M1:   0. 0 %
    CPU: mcu2_0: TASK:      TIVX_DPM2M2:   0. 0 %
    CPU: mcu2_0: TASK:      TIVX_DPM2M3:   0. 0 %
    CPU: mcu2_0: TASK:      TIVX_DPM2M4:   0. 0 %
    CPU: mcu2_0: HEAP:    DDR_LOCAL_MEM: size =   16777216 B, free =   16705536 B ( 99 % unused)
    CPU: mcu2_0: HEAP:           L3_MEM: size =     262144 B, free =     261888 B ( 99 % unused)
    CPU: mcu2_1: TASK:           IPC_RX:   0. 0 %
    CPU: mcu2_1: TASK:       REMOTE_SRV:   0.12 %
    CPU: mcu2_1: TASK:        LOAD_TEST:   0. 0 %
    CPU: mcu2_1: TASK:       TIVX_CPU_1:   0. 0 %
    CPU: mcu2_1: TASK:         TIVX_SDE:   0. 0 %
    CPU: mcu2_1: TASK:         TIVX_DOF:   0. 0 %
    CPU: mcu2_1: TASK:      IPC_TEST_RX:   0. 0 %
    CPU: mcu2_1: TASK:      IPC_TEST_TX:   0. 0 %
    CPU: mcu2_1: HEAP:    DDR_LOCAL_MEM: size =   16777216 B, free =   16773376 B ( 99 % unused)
    CPU: mcu2_1: HEAP:           L3_MEM: size =     262144 B, free =     262144 B (100 % unused)
    CPU:  c6x_1: TASK:           IPC_RX:   0. 0 %
    CPU:  c6x_1: TASK:       REMOTE_SRV:   0. 0 %
    CPU:  c6x_1: TASK:        LOAD_TEST:   0. 0 %
    CPU:  c6x_1: TASK:         TIVX_CPU:   0. 0 %
    CPU:  c6x_1: TASK:      IPC_TEST_RX:   0. 0 %
    CPU:  c6x_1: TASK:      IPC_TEST_TX:   0. 0 %
    CPU:  c6x_1: HEAP:    DDR_LOCAL_MEM: size =   16777216 B, free =   16770304 B ( 99 % unused)
    CPU:  c6x_1: HEAP:           L2_MEM: size =     229376 B, free =     229376 B (100 % unused)
    CPU:  c6x_1: HEAP:  DDR_SCRATCH_MEM: size =   50331648 B, free =   50331648 B (100 % unused)
    CPU:  c6x_2: TASK:           IPC_RX:   0. 0 %
    CPU:  c6x_2: TASK:       REMOTE_SRV:   0. 0 %
    CPU:  c6x_2: TASK:        LOAD_TEST:   0. 0 %
    CPU:  c6x_2: TASK:         TIVX_CPU:   0. 0 %
    CPU:  c6x_2: TASK:      IPC_TEST_RX:   0. 0 %
    CPU:  c6x_2: TASK:      IPC_TEST_TX:   0. 0 %
    CPU:  c6x_2: HEAP:    DDR_LOCAL_MEM: size =   16777216 B, free =   16773376 B ( 99 % unused)
    CPU:  c6x_2: HEAP:           L2_MEM: size =     229376 B, free =     229376 B (100 % unused)
    CPU:  c6x_2: HEAP:  DDR_SCRATCH_MEM: size =   50331648 B, free =   50331648 B (100 % unused)
    CPU:  c7x_1: TASK:           IPC_RX:   0. 0 %
    CPU:  c7x_1: TASK:       REMOTE_SRV:   0. 0 %
    CPU:  c7x_1: TASK:        LOAD_TEST:   0. 0 %
    CPU:  c7x_1: TASK:      TIVX_C71_P1:   0. 0 %
    CPU:  c7x_1: TASK:      TIVX_C71_P2:   0. 0 %
    CPU:  c7x_1: TASK:      TIVX_C71_P3:   0. 0 %
    CPU:  c7x_1: TASK:      TIVX_C71_P4:   0. 0 %
    CPU:  c7x_1: TASK:      TIVX_C71_P5:   0. 0 %
    CPU:  c7x_1: TASK:      TIVX_C71_P6:   0. 0 %
    CPU:  c7x_1: TASK:      TIVX_C71_P7:   0. 0 %
    CPU:  c7x_1: TASK:      TIVX_C71_P8:   0. 0 %
    CPU:  c7x_1: TASK:      IPC_TEST_RX:   0. 0 %
    CPU:  c7x_1: TASK:      IPC_TEST_TX:   0. 0 %
    CPU:  c7x_1: HEAP:    DDR_LOCAL_MEM: size =  268435456 B, free =  268435200 B ( 99 % unused)
    CPU:  c7x_1: HEAP:           L3_MEM: size =    8159232 B, free =    8159232 B (100 % unused)
    CPU:  c7x_1: HEAP:           L2_MEM: size =     458752 B, free =     458752 B (100 % unused)
    CPU:  c7x_1: HEAP:           L1_MEM: size =      16384 B, free =      16384 B (100 % unused)
    CPU:  c7x_1: HEAP:  DDR_SCRATCH_MEM: size =  385875968 B, free =  385875968 B (100 % unused)
    GRAPH:            3DSRV (#nodes =   2, #executions =     22)
     NODE:       CAPTURE1:             Capture_node: avg =   6870 usecs, min/max =     99 /  48717 usecs, #executions =         22
     NODE:          A72-0:          OpenGL_SRV_Node: avg = 160425 usecs, min/max =   8616 / 346071 usecs, #executions =         22
     PERF:            TOTAL: avg = 179168 usecs, min/max =     24 / 685413 usecs, #executions =         22
     PERF:            TOTAL:    5.58 FPS
     x: Exit
     Enter Choice:
     x: Exit
     Enter Choice: (1476) PVR:(Error): IsTextureConsistent: IMGEGLImage is not consistent [ :4923 ]
    EGL: ERROR: eglCreateImageKHR fpailed !!!
    (1476)
    CPU: mpu1_0: TOTAL LOAD =   0. 0 % ( HWI =   0. 0 %, SWI =   0. 0 % )
    CPU:  c6x_1: TOTAL LOAD =   0. 0 % ( HWI =   0. 0 %, SWI =   0. 0 % )
    CPU:  c7x_1: TOTAL LOAD =   1. 0 % ( HWI =   0. 0 %, SWI =   0. 0 % )
    HWA:   GPU : LOAD =  98. 9 % ( 237 MP/s )
    DDR: READ  BW: AVG =    347 MB/s, PEAK =   4853 MB/s
    DDR: WRITE BW: AVG =    307 MB/s, PEAK =   3876 MB/s
    DDR: TOTAL BW: AVG =    654 MB/s, PEAK =   8729 MB/s
    DDR_SHARED_MEM: Total size: 536870912 bytes
    CPU: mcu2_0: TASK:           IPC_RX:   0. 5 %
    CPU: mcu2_0: TASK:       REMOTE_SRV:   0.17 %
    CPU: mcu2_0: TASK:       TIVX_CAPT1:   0.13 %
    CPU: mcu2_1: TASK:       REMOTE_SRV:   0.11 %
    GRAPH:            3DSRV (#nodes =   2, #executions =     30)
     NODE:       CAPTURE1:             Capture_node: avg =   5077 usecs, min/max =     99 /  48717 usecs, #executions =         30
     NODE:          A72-0:          OpenGL_SRV_Node: avg = 175418 usecs, min/max =   8616 / 346071 usecs, #executions =         30
     PERF:            TOTAL: avg = 257457 usecs, min/max =     27 / 1003995 usecs, #executions =          8
     PERF:            TOTAL:    3.88 FPS
     x: Exit
     Enter Choice:
     x: Exit
    EGL: after eglCreateImageKHR() eglError p
    (0x3009)
    CPU:  c6x_2: TOTAL LOAD =   0. 0 % ( HWI =   0. 0 %, SWI =   0. 0 % )
    HWA:   GPU : LOAD =  93.30 % ( 227 MP/s )
    DDR: READ  BW: AVG =    352 MB/s, PEAK =   5752 MB/s
    DDR: WRITE BW: AVG =    307 MB/s, PEAK =   3842 MB/s
    DDR: TOTAL BW: AVG =    659 MB/s, PEAK =   9594 MB/s
    CPU: mcu2_0: TASK:           IPC_RX:   0. 1 %
    CPU: mcu2_0: TASK:       REMOTE_SRV:   0.33 %
    CPU: mcu2_0: TASK:       TIVX_CAPT1:   0.16 %
    CPU: mcu2_1: TASK:       REMOTE_SRV:   0.15 %
    GRAPH:            3DSRV (#nodes =   2, #executions =     34)
     NODE:       CAPTURE1:             Capture_node: avg =   4499 usecs, min/max =     99 /  48717 usecs, #executions =         34
     NODE:          A72-0:          OpenGL_SRV_Node: avg = 175424 usecs, min/max =   8616 / 346357 usecs, #executions =         34
     PERF:            TOTAL: avg = 256755 usecs, min/max =     25 / 679525 usecs, #executions =          4
     PERF:            TOTAL:    3.89 FPS
     x: Exit
     Enter Choice:
     x: Exit
     Enter Choice: (1476) PVR:(Error): CreateImageSharedFromDMABufs: Unsupported DRI FourCC (fourcc = 0x59565955) [ :277 ]
    x(1476) PVR:(Error): CreateImageSharedFromDMABufs: Unsupported DRI FourCC (fourcc = 0x59565955) [ :277 ]
    EGL: after eglCre
    test_b9________________vxWaitGraph status = 0
    test_b10________________vxGraphParameterCheckDoneRef status = 0
    test_b11________________vxGraphParameterDequeueDoneRef status = 0
    test_b12________________vxGraphParameterDequeueDoneRef status = 0
       105.024943 s: ISS: Stopping sensor [MAX96705_AR0147_UYVY] ... !!!
    [MCU2_0]    105.025228 s: test--ar0147_StreamOff
    [MCU2_0]    105.025541 s:  test---max96705 Write regAddr 4
    [MCU2_0]    105.025614 s:  test--max96705 Reg Write slaveAddr:0x41, regAddr:0x0004, regValue:0x47
    [MCU2_0]    105.121193 s: test--ar0147_StreamOff
    [MCU2_0]    105.121503 s:  test---max96705 Write regAddr 4
    [MCU2_0]    105.121575 s:  test--max96705 Reg Write slaveAddr:0x42, regAddr:0x0004, regValue:0x47
    [MCU2_0]    105.217249 s: test--ar0147_StreamOff
    [MCU2_0]    105.217566 s:  test---max96705 Write regAddr 4
    [MCU2_0]    105.217634 s:  test--max96705 Reg Write slaveAddr:0x43, regAddr:0x0004, regValue:0x47
    [MCU2_0]    105.313193 s: test--ar0147_StreamOff
    [MCU2_0]    105.313502 s:  test---max96705 Write regAddr 4
    [MCU2_0]    105.313570 s:  test--max96705 Reg Write slaveAddr:0x44, regAddr:0x0004, regValue:0x47
       105.409329 s: ISS: Stopping sensor [MAX96705_AR0147_UYVY] ... Done !!!
       105.409419 s:  VX_ZONE_ERROR:[ownReleaseReferenceInt:294] Invalid reference
       105.409429 s:  VX_ZONE_ERROR:[ownReleaseReferenceInt:294] Invalid reference
       105.412673 s:  VX_ZONE_ERROR:[ownReleaseReferenceInt:294] Invalid reference
       105.412684 s:  VX_ZONE_ERROR:[ownReleaseReferenceInt:294] Invalid reference
       105.412690 s:  VX_ZONE_ERROR:[ownReleaseReferenceInt:294] Invalid reference
    [MCU2_0]    105.416269 s: ==========================================================
    [MCU2_0]    105.416368 s:  Capture Status: Instance|0
    [MCU2_0]    105.416403 s: ==========================================================
    [MCU2_0]    105.416450 s:  overflowCount: 0
    [MCU2_0]    105.416485 s:  spuriousUdmaIntrCount: 0
    [MCU2_0]    105.416520 s:  frontFIFOOvflCount: 0
    [MCU2_0]    105.416553 s:  crcCount: 0
    [MCU2_0]    105.416582 s:  eccCount: 0
    [MCU2_0]    105.416614 s:  correctedEccCount: 0
    [MCU2_0]    105.416647 s:  dataIdErrorCount: 0
    [MCU2_0]    105.416682 s:  invalidAccessCount: 0
    [MCU2_0]    105.416715 s:  invalidSpCount: 0
    [MCU2_0]    105.416753 s:  strmFIFOOvflCount[0]: 0
    [MCU2_0]    105.416793 s:  strmFIFOOvflCount[1]: 0
    [MCU2_0]    105.416823 s:  Channel Num | Frame Queue Count | Frame De-queue Count | Frame Drop Count | Error Frame Count |
    [MCU2_0]    105.416899 s:            0 |                45 |                   45 |              221 |                 0 |
    [MCU2_0]    105.416975 s:            1 |                45 |                   45 |              224 |                 0 |
    [MCU2_0]    105.417050 s:            2 |                45 |                   45 |              227 |                 0 |
    [MCU2_0]    105.417126 s:            3 |                45 |                   45 |              229 |                 0 |
    test________________ _deinit app...
       105.944005 s: ISS: De-initializing sensor [MAX96705_AR0147_UYVY] ... !!!
       105.944432 s: ISS: De-initializing sensor [MAX96705_AR0147_UYVY] ... Done !!!
       105.944446 s:  VX_ZONE_INIT:[tivxHostDeInitLocal:107] De-Initialization Done for HOST !!!
       105.948886 s:  VX_ZONE_INIT:[tivxDeInitLocal:193] De-Initialization Done !!!
    APP: Deinit ... !!!
    REMOTE_SERVICE: Deinit ... !!!
    REMOTE_SERVICE: Deinit ... Done !!!
    IPC: Deinit ... !!!
    IPC: DeInit ... Done !!!
    MEM: Deinit ... !!!
    DDR_SHARED_MEM: Free's : 41 free's  of 43894936 bytes
    DDR_SHARED_MEM: Open's : 0 allocs  of 0 bytes
    MEM: Deinit ... Done !!!
    APP: Deinit ... Done !!!
    Sorry for the delay in response.
    I saw the logs you had shared between srv and multi-cam and noticed that you had skipped the camera initialization in srv. Now in the latest log, you have included this and the start sensor is successful.
    Is my above understanding correct?
    Nikhil
  • Thank you. I see that you have a new thread for the GPU issue.
    I suggest we continue our discussion in this new thread as this would also involve the GPU expert.
    https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1279511/tda4vm-processors-forum
    Hence closing this thread.
    Nikhil
