Part Number: AM625
For older discussion refer this : e2e.ti.com/.../am625-ramdisk-image-not-syncing-vfs-unable-to-mount-root-fs-on-unknown-block-0-0
Can't we use any other image other than "tisdk-tiny-image-am62xx-evm.cpio".Below file system we are facing mount issue.
setenv serverip 128.224.96.31 && tftp 0x80000000 tkumar1/Images/Image && tftp 0x83000000 tkumar1/Images/k3-am625-sk.dtb && tftpboot 0x85000000 tkumar1/Images/tisdk-base-image-am62xx-evm.tar.xz
setenv bootargs console=ttyS2,115200 initrd=0x85000000,0x50761c4 && booti 0x80000000 - 0x83000000
Log:
root@am62xx-evm:/etc# setenv serverip 128.224.96.31 && tftp 0x80000000 tkumar1/Images/Image && tftp 0x83000000 tkumar1/Images/k3-am625-sk.dtb && tftpboot 0x85000000 tkumar1/Images/tisdk-base-image-am62xx-evm.tar.xz
link up on port 1, speed 1000, full duplex
Using ethernet@8000000port@1 device
TFTP from server 128.224.96.31; our IP address is 128.224.103.229; sending through gateway 128.224.102.1
Filename 'tkumar1/Images/Image'.
Load address: 0x80000000
Loading: #################################################################
2.1 MiB/s
done
Bytes transferred = 20593152 (13a3a00 hex)
Filename 'tkumar1/Images/k3-am625-sk.dtb'.
Load address: 0x83000000
Loading: ####
2.3 MiB/s
done
Bytes transferred = 57500 (e09c hex)
Filename 'tkumar1/Images/tisdk-base-image-am62xx-evm.tar.xz'.
Load address: 0x85000000
2.1 MiB/s
done
Bytes transferred = 84369860 (50761c4 hex)
=> setenv bootargs console=ttyS2,115200 initrd=0x85000000,0x50761c4 && booti 0x80000000 - 0x83000000
## Flattened Device Tree blob at 83000000
Booting using the fdt blob at 0x83000000
ERROR: reserving fdt memory region failed (addr=ff700000 size=8ca000)
Loading Device Tree to 000000008ffee000, end 000000008ffff09b ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 6.1.33 (root@CG-TKUMAR1-L1) (aarch64-none-linux-gnu-gcc (Arm GNU Toolchain 11.3.Rel1) 11.3.1 20220712, GNU ld (Arm GNU Toolchain 11.3.Rel1) 2.38.20220708) #1 SMP PREEMPT Mon Aug 7 18:00:57 IST 2023
[ 0.000000] Machine model: Texas Instruments AM625 SK
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created CMA memory pool at 0x00000000f7600000, size 128 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009c800000, size 3 MiB
[ 0.000000] OF: reserved mem: initialized node ipc-memories@9c800000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009cb00000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node m4f-dma-memory@9cb00000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009cc00000, size 14 MiB
[ 0.000000] OF: reserved mem: initialized node m4f-memory@9cc00000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009da00000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@9da00000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009db00000, size 12 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@9db00000, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x000000009c7fffff]
[ 0.000000] node 0: [mem 0x000000009c800000-0x000000009e6fffff]
[ 0.000000] node 0: [mem 0x000000009e700000-0x000000009e77ffff]
[ 0.000000] node 0: [mem 0x000000009e780000-0x000000009fffffff]
[ 0.000000] node 0: [mem 0x00000000a0000000-0x00000000ff6fffff]
[ 0.000000] node 0: [mem 0x00000000ff700000-0x00000000fffc9fff]
[ 0.000000] node 0: [mem 0x00000000fffca000-0x00000000ffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 19 pages/cpu s38376 r8192 d31256 u77824
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: ARM erratum 845719
[ 0.000000] alternatives: applying boot alternatives
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 516096
[ 0.000000] Kernel command line: console=ttyS2,115200 initrd=0x85000000,0x50761c4
[ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 1755700K/2097152K available (12480K kernel code, 1294K rwdata, 4040K rodata, 2176K init, 498K bss, 210380K reserved, 131072K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 256 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: GICv3 features: 16 PPIs
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
[ 0.000000] ITS [mem 0x01820000-0x0182ffff]
[ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @82000000 (flat, esz 8, psz 64K, shr 0)
[ 0.000000] ITS: using cache flushing for cmd queue
[ 0.000000] GICv3: using LPI property table @0x0000000081840000
[ 0.000000] GIC: using cache flushing for LPI property table
[ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000081850000
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[ 0.000001] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[ 0.000311] Console: colour dummy device 80x25
[ 0.000364] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[ 0.000377] pid_max: default: 32768 minimum: 301
[ 0.000432] LSM: Security Framework initializing
[ 0.000567] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.000590] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.002424] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.002443] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.002516] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.002684] rcu: Hierarchical SRCU implementation.
[ 0.002687] rcu: Max phase no-delay instances is 1000.
[ 0.002947] Platform MSI: msi-controller@1820000 domain created
[ 0.003181] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created
[ 0.003848] EFI services will not be available.
[ 0.004229] smp: Bringing up secondary CPUs ...
[ 0.004926] Detected VIPT I-cache on CPU1
[ 0.005047] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
[ 0.005066] GICv3: CPU1: using allocated LPI pending table @0x0000000081860000
[ 0.005124] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.005854] Detected VIPT I-cache on CPU2
[ 0.005932] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000
[ 0.005946] GICv3: CPU2: using allocated LPI pending table @0x0000000081870000
[ 0.005982] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.006634] Detected VIPT I-cache on CPU3
[ 0.006716] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000
[ 0.006730] GICv3: CPU3: using allocated LPI pending table @0x0000000081880000
[ 0.006762] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.006835] smp: Brought up 1 node, 4 CPUs
[ 0.006841] SMP: Total of 4 processors activated.
[ 0.006847] CPU features: detected: 32-bit EL0 Support
[ 0.006852] CPU features: detected: CRC32 instructions
[ 0.006920] CPU: All CPU(s) started at EL2
[ 0.006924] alternatives: applying system-wide alternatives
[ 0.008966] devtmpfs: initialized
[ 0.017039] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.017073] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.021689] pinctrl core: initialized pinctrl subsystem
[ 0.022291] DMI not present or invalid.
[ 0.022930] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.024131] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[ 0.024486] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.024671] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.024766] audit: initializing netlink subsys (disabled)
[ 0.024950] audit: type=2000 audit(0.024:1): state=initialized audit_enabled=0 res=1
[ 0.025439] thermal_sys: Registered thermal governor 'step_wise'
[ 0.025445] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.025494] cpuidle: using governor menu
[ 0.025649] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.025749] ASID allocator initialised with 65536 entries
[ 0.036702] platform 30200000.dss: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/sii9022@3b
[ 0.038568] platform connector: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/sii9022@3b
[ 0.040410] KASLR disabled due to lack of seed
[ 0.047598] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.047612] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[ 0.047617] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.047620] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[ 0.047625] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.047628] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[ 0.047633] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.047636] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[ 0.049461] k3-chipinfo 43000014.chipid: Family:AM62X rev:SR1.0 JTAGID[0x0bb7e02f] Detected
[ 0.050955] iommu: Default domain type: Translated
[ 0.050967] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.051252] SCSI subsystem initialized
[ 0.051607] usbcore: registered new interface driver usbfs
[ 0.051643] usbcore: registered new interface driver hub
[ 0.051686] usbcore: registered new device driver usb
[ 0.052213] pps_core: LinuxPPS API ver. 1 registered
[ 0.052218] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.052233] PTP clock support registered
[ 0.052411] EDAC MC: Ver: 3.0.0
[ 0.053325] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fc9100
[ 0.053774] FPGA manager framework
[ 0.053869] Advanced Linux Sound Architecture Driver Initialized.
[ 0.054863] clocksource: Switched to clocksource arch_sys_counter
[ 0.055100] VFS: Disk quotas dquot_6.6.0
[ 0.055139] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.061041] NET: Registered PF_INET protocol family
[ 0.061351] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.063159] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
[ 0.063197] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.063212] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.063358] TCP bind hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 0.063882] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.064090] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 0.064146] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 0.064383] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.064913] RPC: Registered named UNIX socket transport module.
[ 0.064921] RPC: Registered udp transport module.
[ 0.064924] RPC: Registered tcp transport module.
[ 0.064927] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.064936] NET: Registered PF_XDP protocol family
[ 0.064955] PCI: CLS 0 bytes, default 64
[ 0.065224] Unpacking initramfs...
[ 0.075794] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.077885] Initialise system trusted keyrings
[ 0.078234] workingset: timestamp_bits=46 max_order=19 bucket_order=0
[ 0.080659] Initramfs unpacking failed: no cpio magic
[ 0.086238] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.087865] NFS: Registering the id_resolver key type
[ 0.087971] Key type id_resolver registered
[ 0.087976] Key type id_legacy registered
[ 0.088087] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.088099] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.088672] 9p: Installing v9fs 9p2000 file system support
[ 0.124051] Key type asymmetric registered
[ 0.124108] Asymmetric key parser 'x509' registered
[ 0.124444] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 0.125072] io scheduler mq-deadline registered
[ 0.125087] io scheduler kyber registered
[ 0.132327] pinctrl-single 4084000.pinctrl: 34 pins, size 136
[ 0.133311] pinctrl-single f4000.pinctrl: 171 pins, size 684
[ 0.134653] pinctrl-single a40000.pinctrl: 512 pins, size 2048
[ 0.138996] Freeing initrd memory: 82392K
[ 0.144786] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.153285] loop: module loaded
[ 0.154574] megasas: 07.719.03.00-rc1
[ 0.158682] tun: Universal TUN/TAP device driver, 1.6
[ 0.159474] thunder_xcv, ver 1.0
[ 0.159509] thunder_bgx, ver 1.0
[ 0.159538] nicpf, ver 1.0
[ 0.159934] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 0.159939] hns3: Copyright (c) 2017 Huawei Corporation.
[ 0.159996] hclge is initializing
[ 0.160021] e1000: Intel(R) PRO/1000 Network Driver
[ 0.160024] e1000: Copyright (c) 1999-2006 Intel Corporation.
[ 0.160058] e1000e: Intel(R) PRO/1000 Network Driver
[ 0.160061] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 0.160102] igb: Intel(R) Gigabit Ethernet Network Driver
[ 0.160106] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 0.160136] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 0.160139] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 0.160250] sky2: driver version 1.30
[ 0.160948] VFIO - User Level meta-driver version: 0.3
[ 0.161721] usbcore: registered new interface driver usb-storage
[ 0.162468] i2c_dev: i2c /dev entries driver
[ 0.164670] sdhci: Secure Digital Host Controller Interface driver
[ 0.164679] sdhci: Copyright(c) Pierre Ossman
[ 0.165146] Synopsys Designware Multimedia Card Interface Driver
[ 0.165561] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.166601] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.166793] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 0.167202] usbcore: registered new interface driver usbhid
[ 0.167208] usbhid: USB HID core driver
[ 0.168499] optee: probing for conduit method.
[ 0.168536] optee: revision 3.18 (8e155bae)
[ 0.168864] optee: dynamic shared memory is enabled
[ 0.169114] optee: initialized driver
[ 0.171000] Initializing XFRM netlink socket
[ 0.171043] NET: Registered PF_PACKET protocol family
[ 0.171189] 9pnet: Installing 9P2000 support
[ 0.171261] Key type dns_resolver registered
[ 0.171702] registered taskstats version 1
[ 0.171731] Loading compiled-in X.509 certificates
[ 0.180703] ti-sci 44043000.system-controller: ABI: 3.1 (firmware rev 0x0008 '8.4.7--v08.04.07 (Jolly Jellyfi')
[ 0.234955] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
[ 0.236740] omap_i2c 20010000.i2c: bus 1 rev0.12 at 100 kHz
[ 0.238073] omap_i2c 20020000.i2c: bus 2 rev0.12 at 400 kHz
[ 0.238330] ti-sci-intr 4210000.interrupt-controller: Interrupt Router 5 domain created
[ 0.238485] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
[ 0.238726] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
[ 0.240023] ti-udma 485c0100.dma-controller: Number of rings: 82
[ 0.242033] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18)
[ 0.244670] ti-udma 485c0000.dma-controller: Number of rings: 150
[ 0.248533] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
[ 0.251219] printk: console [ttyS2] disabled
[ 0.251297] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 239, base_baud = 3000000) is a 8250
[ 1.685811] printk: console [ttyS2] enabled
[ 1.693308] spi-nor spi0.0: s28hs512t (65536 Kbytes)
[ 1.698398] 7 fixed-partitions partitions found on MTD device fc40000.spi.0
[ 1.705356] Creating 7 MTD partitions on "fc40000.spi.0":
[ 1.710749] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[ 1.717493] 0x000000080000-0x000000280000 : "ospi.tispl"
[ 1.723957] 0x000000280000-0x000000680000 : "ospi.u-boot"
[ 1.730437] 0x000000680000-0x0000006c0000 : "ospi.env"
[ 1.736634] 0x0000006c0000-0x000000700000 : "ospi.env.backup"
[ 1.743518] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
[ 1.750027] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
[ 1.758476] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode
[ 1.802891] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 1.812739] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
[ 1.820848] davinci_mdio 8000f00.mdio: phy[1]: device 8000f00.mdio:01, driver TI DP83867
[ 1.828973] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01103, cpsw version 0x6BA81103 Ports: 3 quirks:00000006
[ 1.841835] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
[ 1.848963] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
[ 1.855467] pps pps0: new PPS source ptp0
[ 1.859783] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:1
[ 1.870383] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
[ 1.882002] mmc0: CQHCI version 5.10
[ 1.888584] pca953x 1-0022: supply vcc not found, using dummy regulator
[ 1.895349] pca953x 1-0022: using AI
[ 1.927106] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
[ 1.932247] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
[ 1.932904] mmc1: CQHCI version 5.10
[ 1.932944] mmc2: CQHCI version 5.10
[ 1.963356] ALSA device list:
[ 1.966341] No soundcards found.
[ 1.974300] mmc2: SDHCI controller on fa20000.mmc [fa20000.mmc] using ADMA 64-bit
[ 1.984553] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
[ 1.992889] /dev/root: Can't open blockdev
[ 1.997018] VFS: Cannot open root device "(null)" or unknown-block(0,0): error -6
[ 2.004507] Please append a correct "root=" boot option; here are the available partitions:
[ 2.012886] 1f00 512 mtdblock0
[ 2.012894] (driver?)
[ 2.019449] 1f01 2048 mtdblock1
[ 2.019457] (driver?)
[ 2.026009] 1f02 4096 mtdblock2
[ 2.026015] (driver?)
[ 2.032608] 1f03 256 mtdblock3
[ 2.032614] (driver?)
[ 2.039208] 1f04 256 mtdblock4
[ 2.039218] (driver?)
[ 2.039387] mmc0: Command Queue Engine enabled
[ 2.043439] 1f05 57088 mtdblock5
[ 2.045771] mmc0: new HS200 MMC card at address 0001
[ 2.050212] (driver?)
[ 2.055659] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
[ 2.059369] 1f06 256 mtdblock6
[ 2.062967] mmc1: new ultra high speed SDR104 SDHC card at address aaaa
[ 2.063458] mmcblk0: p1 p2
[ 2.064124] mmcblk0boot0: mmc0:0001 S0J56X 31.5 MiB
[ 2.065196] mmcblk0boot1: mmc0:0001 S0J56X 31.5 MiB
[ 2.066092] mmcblk0rpmb: mmc0:0001 S0J56X 4.00 MiB, chardev (240:0)
[ 2.066248] (driver?)
[ 2.071248] mmcblk1: mmc1:aaaa SD32G 29.7 GiB
[ 2.077030] b300 15540224 mmcblk0
[ 2.081986] mmcblk1: p1 p2 p3
[ 2.084770] driver: mmcblk
[ 2.084777] b301 16384 mmcblk0p1 76e788e3-01
[ 2.112610]
[ 2.119401] b302 15522816 mmcblk0p2 76e788e3-02
[ 2.119408]
[ 2.126198] b320 32256 mmcblk0boot0
[ 2.126202] (driver?)
[ 2.132990] b340 32256 mmcblk0boot1
[ 2.132994] (driver?)
[ 2.139779] b360 31166976 mmcblk1
[ 2.139784] driver: mmcblk
[ 2.146565] b361 135808 mmcblk1p1 17c4538e-01
[ 2.146570]
[ 2.153350] b362 3206842 mmcblk1p2 17c4538e-02
[ 2.153355]
[ 2.160143] b363 27821056 mmcblk1p3 17c4538e-03
[ 2.160147]
[ 2.166939] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[ 2.175186] CPU: 2 PID: 1 Comm: swapper/0 Not tainted 6.1.33 #1
[ 2.181093] Hardware name: Texas Instruments AM625 SK (DT)
[ 2.186564] Call trace:
[ 2.189000] dump_backtrace.part.0+0xdc/0xf0
[ 2.193276] show_stack+0x18/0x30
[ 2.196583] dump_stack_lvl+0x68/0x84
[ 2.200241] dump_stack+0x18/0x34
[ 2.203549] panic+0x184/0x344
[ 2.206596] mount_block_root+0x184/0x234
[ 2.210598] mount_root+0x204/0x240
[ 2.214076] prepare_namespace+0x130/0x170
[ 2.218160] kernel_init_freeable+0x258/0x284
[ 2.222505] kernel_init+0x24/0x130
[ 2.225985] ret_from_fork+0x10/0x20
[ 2.229554] SMP: stopping secondary CPUs
[ 2.233470] Kernel Offset: disabled
[ 2.236945] CPU features: 0x00000,00800084,0000420b
[ 2.241811] Memory Limit: none
[ 2.244861] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) ]---
