Hi Expert!
We had testing on AM62x SK EVM for GPIO.
We followed https://dev.ti.com/tirex/explore/node?node=A__ANR3bSoQUtte3JSAV7ex0g__linux_academy_am62x__XaWts8R__LATEST for testing GPIO.
Used below images:
SDK 8.6 version. Default image for SD card boot.
Below is the console logs for boot and testing GPIO.
We just used 2-GPIO selected right now for testing and we did.
1: GPIO1_16
2: GPIO1_11
Below are gpio banks we got on console:
root@am62xx-evm:~# gpiodetect
gpiochip0 [omap-gpmc] (2 lines)
gpiochip1 [4201000.gpio] (24 lines)
gpiochip2 [600000.gpio] (87 lines)
gpiochip3 [601000.gpio] (88 lines)
gpiochip4 [1-0022] (24 lines)
We did some observation on GPIO1_16 & GPIO1_11
Please find below logs for that.
U-Boot SPL 2021.01-g2ee8efd654 (Feb 24 2023 - 05:37:51 +0000)
SYSFW ABI: 3.1 (firmware rev 0x0008 '8.6.4--v08.06.04 (Chill Capybar')
SPL initial stack usage: 13424 bytes
Trying to boot from MMC2
Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted
Loading Environment from MMC... *** Warning - No MMC card found, using default environment
Starting ATF on ARM64 core...
NOTICE: BL31: v2.8(release):v2.8-226-g2fcd408bb3-dirty
NOTICE: BL31: Built : 05:33:19, Feb 24 2023
U-Boot SPL 2021.01-g2ee8efd654 (Feb 24 2023 - 05:36:12 +0000)
U-Boot 2021.01-g2ee8efd654 (Feb 24 2023 - 05:36:12 +0000)
SoC: AM62X SR1.0 GP
Model: Texas Instruments AM625 SK
EEPROM not available at 0x50, trying to read at 0x51
Reading on-board EEPROM at 0x51 failed -1
DRAM: 2 GiB
MMC: mmc@fa10000: 0, mmc@fa00000: 1, mmc@fa20000: 2
Loading Environment from MMC... OK
In: serial@2800000
Out: serial@2800000
Err: serial@2800000
Net: eth0: ethernet@8000000port@1
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc1 is current device
SD/MMC found on device 1
Failed to load 'boot.scr'
Failed to load 'uEnv.txt'
18862592 bytes read in 203 ms (88.6 MiB/s)
55666 bytes read in 6 ms (8.8 MiB/s)
Loading Device Tree to 000000008feef000, end 000000008fffffff ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 5.10.168-rt83-gc1a1291911 (oe-user@oe-host) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT_RT Fri Feb 24 05:50:07 UTC 2023
[ 0.000000] Machine model: Texas Instruments AM625 SK
[ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[ 0.000000] printk: bootconsole [ns16550a0] enabled
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009c800000, size 3 MiB
[ 0.000000] OF: reserved mem: initialized node ipc-memories@9c800000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009cb00000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node m4f-dma-memory@9cb00000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009cc00000, size 14 MiB
[ 0.000000] OF: reserved mem: initialized node m4f-memory@9cc00000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009da00000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@9da00000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009db00000, size 12 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@9db00000, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x000000009c7fffff]
[ 0.000000] node 0: [mem 0x000000009c800000-0x000000009e6fffff]
[ 0.000000] node 0: [mem 0x000000009e700000-0x000000009e77ffff]
[ 0.000000] node 0: [mem 0x000000009e780000-0x000000009fffffff]
[ 0.000000] node 0: [mem 0x00000000a0000000-0x00000000ffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] On node 0 totalpages: 524288
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 524288 pages, LIFO batch:63
[ 0.000000] cma: Reserved 512 MiB at 0x00000000dd000000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 18 pages/cpu s35392 r8192 d30144 u73728
[ 0.000000] pcpu-alloc: s35392 r8192 d30144 u73728 alloc=18*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: detected: ARM erratum 845719
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 516096
[ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=PARTUUID=5791fadf-02 rw rootfstype=ext4 rootwait
[ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 1456224K/2097152K available (11008K kernel code, 1204K rwdata, 4272K rodata, 1792K init, 438K bss, 116640K reserved, 524288K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[ 0.000000] rcu: RCU priority boosting: priority 1 delay 500 ms.
[ 0.000000] rcu: RCU_SOFTIRQ processing moved to rcuc kthreads.
[ 0.000000] No expedited grace period (rcu_normal_after_boot).
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 256 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
[ 0.000000] ITS [mem 0x01820000-0x0182ffff]
[ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @80800000 (flat, esz 8, psz 64K, shr 0)
[ 0.000000] ITS: using cache flushing for cmd queue
[ 0.000000] GICv3: using LPI property table @0x0000000080030000
[ 0.000000] GIC: using cache flushing for LPI property table
[ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000080040000
[ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[ 0.000001] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[ 0.008529] Console: colour dummy device 80x25
[ 0.013124] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[ 0.023806] pid_max: default: 32768 minimum: 301
[ 0.028626] LSM: Security Framework initializing
[ 0.033422] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.041004] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.051010] rcu: Hierarchical SRCU implementation.
[ 0.056459] Platform MSI: msi-controller@1820000 domain created
[ 0.062847] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created
[ 0.072141] EFI services will not be available.
[ 0.077103] smp: Bringing up secondary CPUs ...
[ 0.082525] Detected VIPT I-cache on CPU1
[ 0.086660] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
[ 0.093696] GICv3: CPU1: using allocated LPI pending table @0x0000000080050000
[ 0.101131] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.108688] Detected VIPT I-cache on CPU2
[ 0.112813] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000
[ 0.119847] GICv3: CPU2: using allocated LPI pending table @0x0000000080060000
[ 0.127268] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.134755] Detected VIPT I-cache on CPU3
[ 0.138877] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000
[ 0.145911] GICv3: CPU3: using allocated LPI pending table @0x0000000080070000
[ 0.153325] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.160095] smp: Brought up 1 node, 4 CPUs
[ 0.164301] SMP: Total of 4 processors activated.
[ 0.169119] CPU features: detected: 32-bit EL0 Support
[ 0.174381] CPU features: detected: CRC32 instructions
[ 0.186792] CPU: All CPU(s) started at EL2
[ 0.190999] alternatives: patching kernel code
[ 0.196768] devtmpfs: initialized
[ 0.208395] KASLR disabled due to lack of seed
[ 0.213119] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.223097] futex hash table entries: 1024 (order: 5, 131072 bytes, linear)
[ 0.244768] pinctrl core: initialized pinctrl subsystem
[ 0.250734] DMI not present or invalid.
[ 0.255374] NET: Registered protocol family 16
[ 0.261943] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[ 0.269319] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.277421] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.286232] thermal_sys: Registered thermal governor 'step_wise'
[ 0.286848] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.300033] ASID allocator initialised with 65536 entries
[ 0.332734] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.339645] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.346510] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.353398] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.361281] cryptd: max_cpu_qlen set to 1000
[ 0.368798] k3-chipinfo 43000014.chipid: Family:AM62X rev:SR1.0 JTAGID[0x0bb7e02f] Detected
[ 0.377959] vcc_5v0: supplied by vmain_pd
[ 0.382511] vcc_3v3_sys: supplied by vmain_pd
[ 0.387471] vcc_1v8: supplied by vcc_3v3_sys
[ 0.393057] iommu: Default domain type: Translated
[ 0.398464] SCSI subsystem initialized
[ 0.402773] mc: Linux media interface: v0.10
[ 0.407176] videodev: Linux video capture interface: v2.00
[ 0.412867] pps_core: LinuxPPS API ver. 1 registered
[ 0.417941] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.427291] PTP clock support registered
[ 0.431329] EDAC MC: Ver: 3.0.0
[ 0.435288] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fc9100
[ 0.442503] FPGA manager framework
[ 0.446085] Advanced Linux Sound Architecture Driver Initialized.
[ 0.453278] clocksource: Switched to clocksource arch_sys_counter
[ 0.459769] VFS: Disk quotas dquot_6.6.0
[ 0.463843] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.477012] NET: Registered protocol family 2
[ 0.481782] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.490585] tcp_listen_portaddr_hash hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.499419] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.507668] TCP bind hash table entries: 16384 (order: 7, 917504 bytes, linear)
[ 0.516058] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.523162] UDP hash table entries: 1024 (order: 5, 131072 bytes, linear)
[ 0.530287] UDP-Lite hash table entries: 1024 (order: 5, 131072 bytes, linear)
[ 0.538082] NET: Registered protocol family 1
[ 0.543177] RPC: Registered named UNIX socket transport module.
[ 0.549289] RPC: Registered udp transport module.
[ 0.554099] RPC: Registered tcp transport module.
[ 0.558907] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.565509] NET: Registered protocol family 44
[ 0.570069] PCI: CLS 0 bytes, default 64
[ 0.575014] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.587477] Initialise system trusted keyrings
[ 0.592309] workingset: timestamp_bits=46 max_order=19 bucket_order=0
[ 0.603673] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.610406] NFS: Registering the id_resolver key type
[ 0.615665] Key type id_resolver registered
[ 0.619953] Key type id_legacy registered
[ 0.624143] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.631011] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.638831] 9p: Installing v9fs 9p2000 file system support
[ 0.678522] Key type asymmetric registered
[ 0.682744] Asymmetric key parser 'x509' registered
[ 0.687785] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[ 0.695360] io scheduler mq-deadline registered
[ 0.699999] io scheduler kyber registered
[ 0.706489] pinctrl-single 4084000.pinctrl: 34 pins, size 136
[ 0.712860] pinctrl-single f4000.pinctrl: 171 pins, size 684
[ 0.727311] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[ 0.748726] brd: module loaded
[ 0.760927] loop: module loaded
[ 0.765135] megasas: 07.714.04.00-rc1
[ 0.773079] tun: Universal TUN/TAP device driver, 1.6
[ 0.778939] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 0.785388] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 0.791514] sky2: driver version 1.30
[ 0.796339] VFIO - User Level meta-driver version: 0.3
[ 0.802757] i2c /dev entries driver
[ 0.807540] sdhci: Secure Digital Host Controller Interface driver
[ 0.813891] sdhci: Copyright(c) Pierre Ossman
[ 0.818706] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.825956] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 0.834329] optee: probing for conduit method.
[ 0.838938] optee: revision 3.20 (8e74d476)
[ 0.839242] optee: dynamic shared memory is enabled
[ 0.848772] optee: initialized driver
[ 0.854741] NET: Registered protocol family 17
[ 0.859531] 9pnet: Installing 9P2000 support
[ 0.863996] Key type dns_resolver registered
[ 0.868733] printk: bootconsole [ns16550a0]: printing thread started
[ 0.868786] Loading compiled-in X.509 certificates
[ 0.881707] ti-sci 44043000.system-controller: lpm region is required for suspend but not provided.
[ 0.881797] ti-sci 44043000.system-controller: ABI: 3.1 (firmware rev 0x0008 '8.6.4--v08.06.04 (Chill Capybar')
[ 0.947158] davinci-mcasp 2b10000.mcasp: IRQ common not found
[ 0.949800] omap-gpmc 3b000000.memory-controller: GPMC revision 6.0
[ 0.949818] gpmc_mem_init: disabling cs 0 mapped at 0x0-0x1000000
[ 0.953120] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
[ H▒▒0.955281] omap_i2c 20010000.i2c: bus 1 rev0.12 at 100 kHz
[ 0.955905] ti-sci-intr 4210000.interrupt-controller: Interrupt Router 5 domain created
[ 0.979703] printk: console [ttyS2]: printing thread started
[ 0.956072] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
[ 0.979721] printk: console [ttyS2] enabled
[ 0.979724] printk: bootconsole [ns16550a0] disabled
[ 1.002539] printk: bootconsole [ns16550a0]: printing thread stopped
[ 1.008367] spi-nor spi0.0: s28hs512t (65536 Kbytes)
[ 1.008425] 7 fixed-partitions partitions found on MTD device fc40000.spi.0
[ 1.008430] Creating 7 MTD partitions on "fc40000.spi.0":
[ 1.008436] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[ 1.009958] 0x000000080000-0x000000280000 : "ospi.tispl"
[ 1.011168] 0x000000280000-0x000000680000 : "ospi.u-boot"
[ 1.012394] 0x000000680000-0x0000006c0000 : "ospi.env"
[ 1.013645] 0x0000006c0000-0x000000700000 : "ospi.env.backup"
[ 1.014946] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
[ 1.016156] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
[ 1.024706] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode
[ 1.061291] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 1.063427] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
[ 1.063440] davinci_mdio 8000f00.mdio: phy[1]: device 8000f00.mdio:01, driver TI DP83867
[ 1.063548] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01103, cpsw version 0x6BA81103 Ports: 3 quirks:00000006
[ 1.063814] am65-cpsw-nuss 8000000.ethernet: Use random MAC address
[ 1.063824] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
[ 1.063831] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
[ 1.064649] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:0
[ 1.066424] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
[ 1.070644] rtc-ti-k3 2b1f0000.rtc: registered as rtc0
[ 1.070694] rtc-ti-k3 2b1f0000.rtc: setting system clock to 1970-01-01T00:00:07 UTC (7)
[ 1.173977] mmc0: CQHCI version 5.10
[ 1.176383] davinci-mcasp 2b10000.mcasp: IRQ common not found
[ 1.191812] pca953x 1-0022: supply vcc not found, using dummy regulator
[ 1.191942] pca953x 1-0022: using AI
[ 1.220917] sii902x 1-003b: supply iovcc not found, using dummy regulator
[ 1.221103] sii902x 1-003b: supply cvcc12 not found, using dummy regulator
[ 1.224174] i2c i2c-1: Added multiplexed i2c bus 2
[ 1.226669] [drm] Initialized tidss 1.0.0 20180215 for 30200000.dss on minor 0
[ 1.227200] tidss 30200000.dss: [drm] Cannot find any crtc or sizes
[ 1.227956] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
1.230144] vdd_mmc1: supplied by vcc_3v3_sys
[ 1.232060] wlan_lten: supplied by vcc_3v3_sys
[ 1.234334] debugfs: Directory 'pd:53' with parent 'pm_genpd' already present!
[ 1.234399] wlan_en: supplied by wlan_lten
[ 1.234411] debugfs: Directory 'pd:52' with parent 'pm_genpd' already present!
[ 1.234456] debugfs: Directory 'pd:51' with parent 'pm_genpd' already present!
[ 1.234680] mmc2: CQHCI version 5.10
[ 1.234930] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
[ 1.234996] mmc1: CQHCI version 5.10
[ 1.248717] ALSA device list:
[ 1.248733] No soundcards found.
[ 1.276515] mmc2: SDHCI controller on fa20000.mmc [fa20000.mmc] using ADMA 64-bit
[ 1.282389] sdhci-am654 fa20000.mmc: card claims to support voltages below defined range
[ 1.286562] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
[ 1.287172] Waiting for root device PARTUUID=5791fadf-02...
[ 1.295319] mmc2: new high speed SDIO card at address 0001
[ 1.310374] mmc0: Command Queue Engine enabled
[ 1.310394] mmc0: new HS200 MMC card at address 0001
[ 1.311144] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
[ 1.311348] mmcblk0boot0: mmc0:0001 S0J56X partition 1 31.5 MiB
[ 1.311546] mmcblk0boot1: mmc0:0001 S0J56X partition 2 31.5 MiB
[ 1.311743] mmcblk0rpmb: mmc0:0001 S0J56X partition 3 4.00 MiB, chardev (237:0)
[ 1.342211] mmc1: new ultra high speed SDR104 SDHC card at address aaaa
[ 1.343019] mmcblk1: mmc1:aaaa SC32G 29.7 GiB
[ 1.345702] mmcblk1: p1 p2
[ 1.704309] EXT4-fs (mmcblk1p2): recovery complete
[ 1.705193] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.705359] VFS: Mounted root (ext4 filesystem) on device 179:98.
[ 1.709581] devtmpfs: mounted
[ 1.710920] Freeing unused kernel memory: 1792K
[ 1.711033] Run /sbin/init as init process
[ 1.825263] systemd[1]: System time before build time, advancing clock.
[ 1.868835] NET: Registered protocol family 10
[ 1.870164] Segment Routing with IPv6
[ 1.898656] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
[ 1.899161] systemd[1]: Detected architecture arm64.
Welcome to Arago 2021.09!
[ 1.948358] systemd[1]: Set hostname to <am62xx-evm>.
[ 2.233056] systemd[1]: /lib/systemd/system/startwlansta.service:7: Unknown key name 'After' in section 'Service', ignoring.
[ 2.234353] systemd[1]: /lib/systemd/system/startwlanap.service:7: Unknown key name 'After' in section 'Service', ignoring.
[ 2.246380] systemd[1]: /lib/systemd/system/irqbalanced.service:6: Unknown key name 'ConditionCPUs' in section 'Unit', ignoring.
[ 2.265224] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock → /run/docker.sock; please update the unit file accordingly.
[ 2.357720] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.362318] systemd[1]: Created slice system-getty.slice.
[ OK ] Created slice system-getty.slice.
[ OK ] Created slice system-serial\x2dgett[ 2.389513] random: systemd: uninitialized urandom read (16 bytes read)
y.slice.
[ 2.391607] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice User and Session Slic[ 2.413522] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.415363] systemd[1]: Created slice User and Session Slice.
e.
[ OK ] Started Dispatch Password …ts to [ 2.445889] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Started Forward Password R…uests [ 2.469793] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Reached target Paths.
[ 2.493660] systemd[1]: Reached target Paths.
[ OK ] Reached target Remote File Systems systemd[1]: Reached target Remote File Systems.
[0m.
[ OK ] Reached target Slices.
[ 2.525499] systemd[1]: Reached target Slices.
[ OK ] Reached target Swap.
[ 2.537492] systemd[1]: Reached target Swap.
[ OK ] Listening on RPCbind Server Activat[ 2.570706] systemd[1]: Listening on RPCbind Server Activation Socket.
ion Socket.
[ OK ] Reached target RPC Port Mapper.[ 2.597663] systemd[1]: Reached target RPC Port Mapper.
[ OK ] Listening on Process Core Dump Sock[ 2.624922] systemd[1]: Listening on Process Core Dump Socket.
et.
[ OK ] Listening on initctl Compatibility [ 2.645951] systemd[1]: Listening on initctl Compatibility Named Pipe.
Named Pipe.
[ OK ] Listening on Journal Socket (/dev/l[ 2.673249] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
og).
[ 2.674321] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket.
[ 2.695890] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Network Service Netlin[ 2.707604] systemd[1]: Listening on Network Service Netlink Socket.
k Socket.
[ OK ] Listening on udev Control Socket 2.730165] systemd[1]: Listening on udev Control Socket.
m.
[ OK ] Listening on udev Kernel Socket[ 2.753947] systemd[1]: Listening on udev Kernel Socket.
Mounting Huge Pages File System...[ 2.779539] systemd[1]: Mounting Huge Pages File System...
Mounting POSIX Message Queue File System..[ 2.806938] systemd[1]: Mounting POSIX Message Queue File System...
Mounting Kernel Debug File System...[ 2.835188] systemd[1]: Mounting Kernel Debug File System...
Mounting Temporary Directory (/tmp)...
[ 2.865757] systemd[1]: Mounting Temporary Directory (/tmp)...
Starting Create list of st…odes for the curr[ 2.883428] systemd[1]: Starting Create list of static device nodes for the current kernel...
ent kernel...
Starting Start psplash boot splash screen.[ 2.919193] systemd[1]: Starting Start psplash boot splash screen...
Starting RPC Bind...
[ 2.947121] systemd[1]: Starting RPC Bind...
[ 2.957891] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 2.966395] systemd[1]: Starting Journal Service...
Starting Load Kernel Modules...
[ 2.999787] systemd[1]: Starting Load Kernel Modules...
Starting Remount Root and Kernel File Systems...
[ 3.017738] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 3.024469] cryptodev: loading out-of-tree module taints kernel.
[ 3.027044] cryptodev: driver 1.10 loaded.
Starting udev Coldplug all Devices...
[ 3.046451] systemd[1]: Starting udev Coldplug all Devices...
[ 3.049183] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
[ OK ] Started RPC Bind.
[ 3.071032] systemd[1]: Started RPC Bind.
[ OK ] Started Journal Service.
[ 3.082325] systemd[1]: Started Journal Service.
[ OK ] Mounted Huge Pages File System.
[ OK ] Mounted POSIX Message Queue File System.
[ OK ] Mounted Kernel Debug File System.
[ OK ] Mounted Temporary Directory (/tmp).
[ OK ] Started Create list of sta… nodes for the current kernel.
[FAILED] Failed to start Start psplash boot splash screen.
See 'systemctl status psplash-start.service' for details.
[DEPEND] Dependency failed for Star…progress communication helper.
[ OK ] Started Load Kernel Modules.
[ OK ] Started Remount Root and Kernel File Systems.
Mounting Kernel Configuration File System...
Starting Flush Journal to Persistent Storage...
[ 3.322910] systemd-journald[237]: Received client request to flush runtime journal.
Starting Apply Kernel Variables...
Starting Create Static Device Nodes in /dev...
[ OK ] Mounted Kernel Configuration File System.
[ OK ] Started Flush Journal to Persistent Storage.
[ OK ] Started Apply Kernel Variables.
[ OK ] Started Create Static Device Nodes in /dev.
[ OK ] Reached target Local File Systems ([ 3.474741] random: systemd: uninitialized urandom read (16 bytes read)
Pre).
[ 3.501650] random: systemd: uninitialized urandom read (16 bytes read)
Mounting /media/ram...
[ 3.513629] random: systemd-journal: uninitialized urandom read (16 bytes read)
Mounting /var/volatile...
Starting udev Kernel Device Manager...
[ OK ] Mounted /media/ram.
[ OK ] Mounted /var/volatile.
Starting Load/Save Random Seed...
[ OK ] Reached target Local File Systems.
Starting Create Volatile Files and Directories...
[ OK ] Started udev Coldplug all Devices.
Starting udev Wait for Complete Device Initialization...
[ OK ] Started udev Kernel Device Manager.
[ OK ] Started Create Volatile Files and Directories.
Starting Network Time Synchronization...
Starting Update UTMP about System Boot/Shutdown...
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ 4.518031] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.797663] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.797809] random: systemd: uninitialized urandom read (16 bytes read)
[ 5.256741] k3-m4-rproc 5000000.m4fss: assigned reserved memory node m4f-dma-memory@9cb00000
[ 5.256909] k3-m4-rproc 5000000.m4fss: configured M4 for remoteproc mode
[ 5.257093] k3-m4-rproc 5000000.m4fss: local reset is deasserted for device
[ 5.288573] remoteproc remoteproc0: 5000000.m4fss is available
[ 5.298749] remoteproc remoteproc0: powering up 5000000.m4fss
[ 5.298781] remoteproc remoteproc0: Booting fw image am62-mcu-m4f0_0-fw, size 54860
[ 5.333585] remoteproc0#vdev0buffer: assigned reserved memory node m4f-dma-memory@9cb00000
[ 5.354630] remoteproc0#vdev0buffer: registered virtio0 (type 7)
[ 5.354657] remoteproc remoteproc0: remote processor 5000000.m4fss is now up
[ 5.421340] random: crng init done
[ 5.421359] random: 70 urandom warning(s) missed due to ratelimiting
[ OK ] Started Load/Save Random Seed.
[ 5.703390] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 5.703929] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
[ 5.735193] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
[ 5.825868] platform 78000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[ 5.826046] platform 78000000.r5f: configured R5F for IPC-only mode
[ 5.826200] platform 78000000.r5f: assigned reserved memory node r5f-dma-memory@9da00000
[ 5.828148] PVR_K: 264: Read BVNC 33.15.11.3 from HW device registers
[ 5.828385] PVR_K: 264: RGX Device registered with BVNC 33.15.11.3
[ 5.851907] remoteproc remoteproc1: 78000000.r5f is available
[ 5.852055] remoteproc remoteproc1: attaching to 78000000.r5f
[ 5.873465] platform 78000000.r5f: R5F core initialized in IPC-only mode
[ 5.873516] remoteproc1#vdev0buffer: assigned reserved memory node r5f-dma-memory@9da00000
[ 5.874116] virtio_rpmsg_bus virtio1: rpmsg host is online
[ 5.875074] remoteproc1#vdev0buffer: registered virtio1 (type 7)
[ 5.875087] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xd
[ 5.875094] remoteproc remoteproc1: remote processor 78000000.r5f is now attached
[ 5.891305] [drm] Initialized pvr 1.15.6133109 20170530 for fd00000.gpu on minor 1
[ 5.894077] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe
[ OK ] Started Network Time Synchronization.
[ OK ] Reached target System Time Set.
[ OK ] Reached target System Time Synchronized.
[ OK ] Created slice system-systemd\x2dfsck.slice.
[ OK ] Found device /dev/mmcblk0.
Starting File System Check on /dev/mmcblk0...
[ 7.818491] remoteproc remoteproc2: 30074000.pru is available
[ 7.850782] remoteproc remoteproc3: 30078000.pru is available
[ 7.923369] cdns-csi2rx: probe of 30101000.csi-bridge failed with error -22
[ 8.040486] tps6598x 0-003f: Unable to find the interrupt, switching to polling
See 'systemctl status psplash-start.servic[ 8.186996] cfg80211: Loading compiled-in X.509 certificates for regulatory database
e' for details.
/dev/mmc[ 8.209074] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ OK ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
[ OK ] Reached target Hardware activated U[ 8.231013] usbcore: registered new interface driver usbfs
[ 8.231981] usbcore: registered new interface driver hub
[ 8.232104] usbcore: registered new device driver usb
SB gadget.
[ 8.291566] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
[ 8.291638] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 1
[ 8.292061] xhci-hcd xhci-hcd.3.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000000000010010
[ 8.303494] xhci-hcd xhci-hcd.3.auto: irq 495, io mem 0x31100000
[ 8.303738] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
[ 8.303863] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 2
[ 8.303892] xhci-hcd xhci-hcd.3.auto: Host supports USB 3.0 SuperSpeed
[ 8.304088] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 8.304098] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.304104] usb usb1: Product: xHCI Host Controller
[ 8.304109] usb usb1: Manufacturer: Linux 5.10.168-rt83-gc1a1291911 xhci-hcd
[ 8.304114] usb usb1: SerialNumber: xhci-hcd.3.auto
[ 8.319208] hub 1-0:1.0: USB hub found
[ 8.319301] hub 1-0:1.0: 1 port detected
[ 8.331112] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 8.331274] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 8.331286] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.331292] usb usb2: Product: xHCI Host Controller
[ 8.331298] usb usb2: Manufacturer: Linux 5.10.168-rt83-gc1a1291911 xhci-hcd
[ 8.331303] usb usb2: SerialNumber: xhci-hcd.3.auto
[ 8.332215] hub 2-0:1.0: USB hub found
[ 8.332277] hub 2-0:1.0: config failed, hub doesn't have any ports! (err -19)
[ OK ] Found device /dev/mmcblk1p1.
[ 8.428352] wl18xx_driver wl18xx.2.auto: Direct firmware load for ti-connectivity/wl1271-nvs.bin failed with error -2
Starting File System Check on /dev/mmcblk1p1...
[ OK ] Started udev Wait for Complete Device Initialization.
[ OK ] Started Hardware RNG Entropy Gatherer Daemon.
[ OK ] Reached target System Initialization.
[ OK ] Started Daily rotation of log files.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target Timers.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Listening on D-Bus System Message Bus Socket.
Starting Docker Socket for the API.
[ OK ] Listening on dropbear.socket.
Starting Reboot and dump vmcore via kexec...
[ OK ] Listening on Docker Socket for the API.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
Starting Save/Restore Sound Card State...
[ OK ] Started Job spooling tools.
[ OK ] Started Periodic Command Scheduler.
[ OK ] Started D-Bus System Message Bus.
Starting Print notice about GPLv3 packages...
Starting IPv6 Packet Filtering Framework...
Starting IPv4 Packet Filtering Framework...
[ OK ] Started irqbalance daemon.
Starting rc.pvr.service...
Starting startwlanap...
Starting startwlansta......
Starting Login Service...
[ OK ] Started TEE Supplicant.
[ OK ] Started File System Check on /dev/mmcblk1p1.
[ OK ] Started Save/Restore Sound Card State.
[ OK ] Started IPv6 Packet Filtering Framework.
[ 8.786327] wlcore: wl18xx HW: 183x or 180x, PG 2.2 (ROM 0x11)
[ OK ] Started IPv4 Packet Filtering Framework.
[ 8.799044] wlcore: loaded
[ OK ] Started Reboot and dump vmcore via kexec.
[ OK ] Started startwlanap.
[ OK ] Started startwlansta.
[ OK ] Reached target Network (Pre).
[ OK ] Reached target Sound Card.
Mounting /run/media/mmcblk1p1...
Starting Network Service...
Starting Load/Save RF Kill Switch Status...
[ OK ] Mounted /run/media/mmcblk1p1.
[ OK ] Started Load/Save RF Kill Switch Status.
[ OK ] Started Network Service....
Starting Wait for Network to be Configured...
Starting Network Name Resolution...
[ 9.986426] wlcore: using inverted interrupt logic: 2
[ OK ] Started Login Service.te...
[ 10.049780] wlcore: PHY firmware version: Rev 8.2.0.0.245
[ 10.157436] wlcore: firmware booted (Rev 8.9.0.0.86)
[ 10.259008] am65-cpsw-nuss 8000000.ethernet eth1: PHY [8000f00.mdio:01] driver [TI DP83867] (irq=POLL)
[ 10.259131] am65-cpsw-nuss 8000000.ethernet eth1: configuring for phy/rgmii-rxid link mode
[ 10.223841] startwlansta.sh[715]: Wi-Fi user configuration file missing, exit
[ 10.371190] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [TI DP83867] (irq=POLL)
[ 10.371234] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
[ OK ] Started Network Name Resolution.
[ OK ] Reached target Network.
[ OK ] Reached target Host and Network Name Lookups.
Starting Avahi mDNS/DNS-SD Stack...
Starting Enable and configure wl18xx bluetooth stack...
[ OK ] Started NFS status monitor for NFSv2/3 locking..
Starting Simple Network Ma…ent Protocol (SNMP) Daemon....
Starting Permit User Sessions...
[ OK ] Started Permit User Sessions.
[ OK ] Started Getty on tty1.
[ OK ] Started Serial Getty on ttyS2.
[ OK ] Reached target Login Prompts.
[ 10.663688] startwlanap.sh[783]: adding wlan1 interface
Starting Synchronize System and HW clocks...
[ OK ] Started Enable and configure wl18xx bluetooth stack.
[ OK ] Started Avahi mDNS/DNS-SD Stack.
[ OK ] Started Synchronize System and HW clocks.
[ 10.827229] startwlanap.sh[795]: Configuration file: /usr/share/wl18xx/hostapd.conf
[ 10.893825] startwlanap.sh[795]: wlan1: interface state UNINITIALIZED->COUNTRY_UPDATE
[ OK ] Started rc.pvr.service.e...
Starting weston.service...
[ 10.973969] startwlanap.sh[795]: Using interface wlan1 with hwaddr 20:d7:78:b8:fd:88 and ssid "AM62xSK-AP_78b8fd"
[ 11.055748] IPv6: ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
[ 11.056893] startwlanap.sh[795]: wlan1: interface state COUNTRY_UPDATE->ENABLED
[ 11.057399] startwlanap.sh[795]: wlan1: AP-ENABLED
[ OK ] Started Simple Network Man…ement Protocol (SNMP) Daemon..
[ OK ] Started File System Check on /dev/mmcblk0.
Mounting /run/media/mmcblk0...
[ 11.413433] ext2 filesystem being mounted at /run/media/mmcblk0 supports timestamps until 2038 (0x7fffffff)
[ OK ] Mounted /run/media/mmcblk0.
NOTICE: This file system contains the following GPLv3 packages:
autoconf
bash-dev
bash
bc
binutils
cifs-utils
coreutils-stdbuf
coreutils
cpio
cpp-symlinks
cpp
dosfstools
elfutils
g++-symlinks
g++
gawk
gcc-symlinks
gcc
gdb
gdbserver
gettext
glmark2
gstreamer1.0-libav
gzip
hidapi
less
libasm1
libbfd
libdw1
libelf1
libgdbm-compat4
libgdbm-dev
libgdbm6
libgettextlib
libgettextsrc
libgmp10
libidn2-0
libmpc3
libmpfr6
libreadline-dev
libreadline8
libunistring2
m4-dev
m4
make
nettle
parted
tar
which
If you do not wish to distribute GPLv3 components please remove
the above packages prior to distribution. This can be done using
the opkg remove command. i.e.:
opkg remove <package>
Where <package> is the name printed in the list above
NOTE: If the package is a dependency of another package you
will be notified of the dependent packages. You should
use the --force-removal-of-dependent-packages option to
also remove the dependent packages as well
[ OK ] Started Print notice about GPLv3 packages.
[ OK ] Started weston.service.
Starting telnetd.service...
[ OK ] Started telnetd.service.
Starting hmi_demo.service...
Starting LSB: Expand Rootfs of boot device...
[ OK ] Started LSB: Expand Rootfs of boot device.
[ 14.880016] PVR_K: 994: RGX Firmware image 'rgx.fw.33.15.11.3' loaded
[ 14.910425] PVR_K: 994: Shader binary image 'rgx.sh.33.15.11.3' loaded
[ OK ] Started hmi_demo.service.
Stopping hmi_demo.service...
[ OK ] Stopped hmi_demo.service.
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project am62xx-evm ttyS2
Arago 2021.09 am62xx-evm ttyS2
am62xx-evm login: [ 130.720374] Initializing XFRM netlink socket
[ 131.821895] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 131.827750] Bridge firewalling registered
[ 132.780258] process 'docker/tmp/qemu-check599299324/check' started with executable stack
am62xx-evm login:
am62xx-evm login:
am62xx-evm login:
am62xx-evm login: root
root@am62xx-evm:~# 4;157R
-sh: 4: command not found
-sh: 157R: command not found
root@am62xx-evm:~#
root@am62xx-evm:~#
root@am62xx-evm:~#
root@am62xx-evm:~#
root@am62xx-evm:~#
root@am62xx-evm:~#
root@am62xx-evm:~# cd /sys/class/gpio/
root@am62xx-evm:/sys/class/gpio# ls
export gpiochip311 gpiochip486 unexport
gpiochip287 gpiochip399 gpiochip510
root@am62xx-evm:/sys/class/gpio# echo 502 > export
export gpiochip287 gpiochip399 gpiochip510
gpio502 gpiochip311 gpiochip486 unexport
root@am62xx-evm:/sys/class/gpio# cd gpio502
root@am62xx-evm:/sys/class/gpio/gpio502# ls
active_low device direction edge power subsystem uevent value
root@am62xx-evm:/sys/class/gpio/gpio502# ls -la
total 0
drwxr-xr-x 3 root root 0 Feb 24 05:01 .
drwxr-xr-x 3 root root 0 Feb 24 05:01 ..
-rw-r--r-- 1 root root 4096 Feb 24 05:01 active_low
lrwxrwxrwx 1 root root 0 Feb 24 05:01 device -> ../../../gpiochip1
-rw-r--r-- 1 root root 4096 Feb 24 05:01 direction
-rw-r--r-- 1 root root 4096 Feb 24 05:01 edge
drwxr-xr-x 2 root root 0 Feb 24 05:01 power
lrwxrwxrwx 1 root root 0 Feb 24 05:01 subsystem -> ../../../../../../../../class/gpio
-rw-r--r-- 1 root root 4096 Feb 24 05:01 uevent
-rw-r--r-- 1 root root 4096 Feb 24 05:01 value
root@am62xx-evm:/sys/class/gpio/gpio502# cat direction
in
root@am62xx-evm:/sys/class/gpio/gpio502# cat active_low
0
root@am62xx-evm:/sys/class/gpio/gpio502# cat value
0
root@am62xx-evm:/sys/class/gpio/gpio502# echo out > direction
out
root@am62xx-evm:/sys/class/gpio/gpio502# echo 1 > value
0
root@am62xx-evm:/sys/class/gpio/gpio502# echo 1 > active_low
1
root@am62xx-evm:/sys/class/gpio/gpio502# cd ../
root@am62xx-evm:/sys/class/gpio# echo 410 > export
root@am62xx-evm:/sys/class/gpio# cd gpio410
root@am62xx-evm:/sys/class/gpio/gpio410# ls -la
total 0
drwxr-xr-x 3 root root 0 Feb 24 05:03 .
drwxr-xr-x 3 root root 0 Feb 24 05:03 ..
-rw-r--r-- 1 root root 4096 Feb 24 05:03 active_low
lrwxrwxrwx 1 root root 0 Feb 24 05:03 device -> ../../../gpiochip2
-rw-r--r-- 1 root root 4096 Feb 24 05:03 direction
-rw-r--r-- 1 root root 4096 Feb 24 05:03 edge
drwxr-xr-x 2 root root 0 Feb 24 05:03 power
lrwxrwxrwx 1 root root 0 Feb 24 05:03 subsystem -> ../../../../../../../class/gpio
-rw-r--r-- 1 root root 4096 Feb 24 05:03 uevent
-rw-r--r-- 1 root root 4096 Feb 24 05:03 value
root@am62xx-evm:/sys/class/gpio/gpio410# cat value
0
root@am62xx-evm:/sys/class/gpio/gpio410# cat direction
in
root@am62xx-evm:/sys/class/gpio/gpio410# cat active_low
0
root@am62xx-evm:/sys/class/gpio/gpio410# echo out direction
out direction
root@am62xx-evm:/sys/class/gpio/gpio410# echo out > direction
out
0
root@am62xx-evm:/sys/class/gpio/gpio410# echo 1 > active_low
1
root@am62xx-evm:/sys/class/gpio# ls -la
total 0
drwxr-xr-x 2 root root 0 Feb 24 04:52 .
drwxr-xr-x 69 root root 0 Feb 24 04:52 ..
--w------- 1 root root 4096 Feb 24 05:03 export
lrwxrwxrwx 1 root root 0 Feb 24 05:03 gpio410 -> ../../devices/platform/bus@f0000/600000.gpio/gpiochip2/gpio/gpio410
lrwxrwxrwx 1 root root 0 Feb 24 05:01 gpio502 -> ../../devices/platform/bus@f0000/bus@f0000:bus@4000000/4201000.gpio/gpiochip1/gpio/gpio502
lrwxrwxrwx 1 root root 0 Feb 24 04:52 gpiochip287 -> ../../devices/platform/bus@f0000/20010000.i2c/i2c-1/1-0022/gpio/gpiochip287
lrwxrwxrwx 1 root root 0 Feb 24 04:52 gpiochip311 -> ../../devices/platform/bus@f0000/601000.gpio/gpio/gpiochip311
lrwxrwxrwx 1 root root 0 Feb 24 04:52 gpiochip399 -> ../../devices/platform/bus@f0000/600000.gpio/gpio/gpiochip399
lrwxrwxrwx 1 root root 0 Feb 24 04:52 gpiochip486 -> ../../devices/platform/bus@f0000/bus@f0000:bus@4000000/4201000.gpio/gpio/gpiochip486
lrwxrwxrwx 1 root root 0 Feb 24 04:52 gpiochip510 -> ../../devices/platform/bus@f0000/3b000000.memory-controller/gpio/gpiochip510
--w------- 1 root root 4096 Feb 24 04:52 unexport
On above test from SW side we are able to change signal for those two GPIO's , But not from HW side.
We are not able to see any changes on Oscilloscope. Not able to see High and low signal on Oscilloscope for those GPIO's.
Is that the correct way or we are controlling wrong way?
If we are doing right way then why signal not changing on Oscillscope for AM62x SK?
FYI... on Oscilloscope we are able to see only LOW signal. not getting as HIGH even when we changed to high with above commands.
Suraj.
