VLIB Error Codes
Where I can found the VLIB error codes? All the VLIB functions returns a integer with the error status, but the documentations doesnt say anything about them.
Thank you very much.
    I don't believe this question is related to BIOS.
    Judah
  • Weber,
    I agree this data should be provided in the documentation. I will file a request so that this can be fixed in a future release. In the meantime here is the data you are looking for
    VLIB_NO_ERROR = 0,
    VLIB_ERR_INPUT_INVALID = 1,
    VLIB_ERR_INPUT_NEGATIVE = 2,
    VLIB_ERR_INPUT_EXCEEDED_RANGE = 3,
    VLIB_ERR_MEMORY_EXCEEDED_BOUNDARY = 4,
    VLIB_ERR_MEMORY_ALLOCATION_FAILURE = 5,
    VLIB_ERR_MEMORY_POINTER_NULL = 6,
    VLIB_ERR_DMA_FAILURE = 7,
    VLIB_ERR_FILE_OPEN_FAILURE = 8,
    VLIB_ERR_FILE_READ_FAILURE = 9,
    VLIB_ERR_FILE_WRITE_FAILURE = 10,
    VLIB_ERR_FILE_CLOSE_FAILURE = 11,
    VLIB_ERR_FILE_FORMAT_FAILURE = 12,
    VLIB_WARNING_LOW_MEMORY = 13
    You can find this in the VLIB header file VLIB_prototypes.h. Hope this helps and thanks once again for the feedback.
    Rahul
  • Someone else moved it to BIOS forum.
