We fix 80.06 sdk to our board, startup normal; but when we try to use reboot command to reboot device, it will halt after print "Restarting system" message.The current has decreased from 90mA to 10mA.
boot mod is .
Pull down the mcu_resetz and reset_reqz, they are also similar issue.
This is the print message on debug COM:
U-Boot SPL 2021.01-g62a9e51344 (Jun 19 2023 - 01:47:42 +0000) Model: Texas Instruments K3 J721E SoC EEPROM not available at 0x50, trying to read at 0x51 Reading on-board EEPROM at 0x51 failed 1 Board: J721EX-PM1-SOM rev E2 SYSFW ABI: 3.1 (firmware rev 0x0008 '8.6.3--v08.06.03 (Chill Capybar') EEPROM not available at 0x50, trying to read at 0x51 Reading on-board EEPROM at 0x51 failed 1 i2c_write: error waiting for data ACK (status=0x116) read error from device: 41c864bc register: x! Trying to boot from MMC1 init_env from device 17 not supported! Starting ATF on ARM64 core... NOTICE: BL31: v2.8(release):v2.8-226-g2fcd408bb3-dirty NOTICE: BL31: Built : 04:11:16, May 9 2023 I/TC: I/TC: OP-TEE version: 3.20.0 (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10))) #1 Tue May 9 04:18:47 UTC 2023 aarch64 I/TC: WARNING: This OP-TEE configuration might be insecure! I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html I/TC: Primary CPU initializing I/TC: SYSFW ABI: 3.1 (firmware rev 0x0008 '8.6.3--v08.06.03 (Chill Capybar') I/TC: HUK Initialized I/TC: Activated SA2UL device I/TC: Fixing SA2UL firewall owner for GP device I/TC: Enabled firewalls for SA2UL TRNG device I/TC: SA2UL TRNG initialized I/TC: SA2UL Drivers initialized I/TC: Primary CPU switching to normal world boot U-Boot SPL 2021.01-g62a9e51344 (Jun 19 2023 - 01:34:52 +0000) Model: Texas Instruments K3 J721E SoC SYSFW ABI: 3.1 (firmware rev 0x0008 '8.6.3--v08.06.03 (Chill Capybar') Trying to boot from MMC1 U-Boot 2021.01-g62a9e51344 (Jun 19 2023 - 01:34:52 +0000) SoC: J721E SR1.1 GP Model: Texas Instruments K3 J721E SoC DRAM: 4 GiB Flash: 0 Bytes MMC: sdhci@4f80000: 0, sdhci@4fb0000: 1 Loading Environment from MMC... OK In: serial@2800000 Out: serial@2800000 Err: serial@2800000 am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA00101 cpsw_ver: 0x6BA80100 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000 cdns,sierra serdes@5000000: PHY not found 0x7364 vs 0x0 Sierra init failed:-22 Net: am65_cpsw_nuss_port ethernet@46000000port@1: Port 1 speed froced to 1000Mbit eth0: ethernet@46000000port@1 Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0(part 0) is current device SD/MMC found on device 0 Failed to load 'boot.scr' ** Unrecognized filesystem type ** k3_r5f_rproc r5f@41000000: Core 1 is already in use. No rproc commands work k3_r5f_rproc r5f@41400000: Core 2 is already in use. No rproc commands work Failed to load '/lib/firmware/j7-main-r5f0_0-fw' Failed to load '/lib/firmware/j7-main-r5f0_1-fw' Failed to load '/lib/firmware/j7-main-r5f1_0-fw' Failed to load '/lib/firmware/j7-main-r5f1_1-fw' Failed to load '/lib/firmware/j7-c66_0-fw' Failed to load '/lib/firmware/j7-c66_1-fw' Failed to load '/lib/firmware/j7-c71_0-fw' 19079680 bytes read in 109 ms (166.9 MiB/s) 110830 bytes read in 9 ms (11.7 MiB/s) 11785 bytes read in 8 ms (1.4 MiB/s) ## Flattened Device Tree blob at 88000000 Booting using the fdt blob at 0x88000000 Loading Device Tree to 000000008fee1000, end 000000008fffffff ... OK Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080] [ 0.000000] Linux version 5.10.162-g80de1415dec4-dirty (yst@EcoSoft) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #2 SMP PREEMPT Sat Aug 19 11:03:04 CST 2023 [ 0.000000] Machine model: Texas Instruments J721E SK [ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '') [ 0.000000] printk: bootconsole [ns16550a0] enabled [ 0.000000] efi: UEFI not found. [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a0100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 31 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a6100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a8000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a8100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a9000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a9100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a9100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 96 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@ac000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b2000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@b2000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b2100000, size 95 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c71-memory@b2100000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000d8000000, size 192 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@d8000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000e4000000, size 8 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-queues@e4000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000e4800000, size 24 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-buffers@e4800000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 624 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created CMA memory pool at 0x00000008a7000000, size 512 MiB [ 0.000000] OF: reserved mem: initialized node linux-cma-buffers@8a7000000, compatible id shared-dma-pool [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal [mem 0x0000000100000000-0x00000008ffffffff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000080000000-0x000000009e7fffff] [ 0.000000] node 0: [mem 0x000000009e800000-0x00000000b7ffffff] [ 0.000000] node 0: [mem 0x00000000b8000000-0x00000000d7ffffff] [ 0.000000] node 0: [mem 0x00000000d8000000-0x00000000e5ffffff] [ 0.000000] node 0: [mem 0x00000000e6000000-0x00000000ffffffff] [ 0.000000] node 0: [mem 0x0000000880000000-0x00000008a6ffffff] [ 0.000000] node 0: [mem 0x00000008a7000000-0x00000008ffffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff] [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: Trusted OS migration not required [ 0.000000] psci: SMC Calling Convention v1.2 [ 0.000000] percpu: Embedded 22 pages/cpu s50392 r8192 d31528 u90112 [ 0.000000] Detected PIPT I-cache on CPU0 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] CPU features: detected: EL2 vector hardening [ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923 [ 0.000000] CPU features: detected: Spectre-BHB [ 0.000000] CPU features: detected: ARM erratum 1742098 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1032192 [ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),1m(ospi.sysfw),256k(ospi.env.backup),57088k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),1m(hbmc.sysfw),-@8m(hbmc.rootfs) earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),1m(ospi.sysfw),256k(ospi.env.backup),57088k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),1m(hbmc.sysfw),-@8m(hbmc.rootfs) root=PARTUUID=d6935b4a-f357-0242-9b9a-dfc731e208a6 rw rootfstype=ext4 rootwait [ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) [ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] software IO TLB: mapped [mem 0x00000000fbfff000-0x00000000fffff000] (64MB) [ 0.000000] Memory: 1696376K/4194304K available (11200K kernel code, 1160K rwdata, 4304K rodata, 1856K init, 433K bss, 1973640K reserved, 524288K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] Tracing variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 960 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] GICv3: Distributor has no Range Selector support [ 0.000000] GICv3: 16 PPIs implemented [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000 [ 0.000000] ITS [mem 0x01820000-0x0182ffff] [ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS [ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19 [ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @8c7800000 (flat, esz 8, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GICv3: using LPI property table @0x00000008c7030000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008c7040000 [ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns [ 0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns [ 0.008406] Console: colour dummy device 80x25 [ 0.012966] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000) [ 0.023637] pid_max: default: 32768 minimum: 301 [ 0.028393] LSM: Security Framework initializing [ 0.033147] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.040723] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.049539] rcu: Hierarchical SRCU implementation. [ 0.054596] Platform MSI: msi-controller@1820000 domain created [ 0.060846] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created [ 0.070152] EFI services will not be available. [ 0.074869] smp: Bringing up secondary CPUs ... I/TC: Secondary CPU 1 initializing I/TC: Secondary CPU 1 switching to normal world boot [ 0.088103] Detected PIPT I-cache on CPU1 [ 0.088127] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000 [ 0.088138] GICv3: CPU1: using allocated LPI pending table @0x00000008c7050000 [ 0.088171] CPU1: Booted secondary processor 0x0000000001 [0x411fd080] [ 0.088220] smp: Brought up 1 node, 2 CPUs [ 0.117566] SMP: Total of 2 processors activated. [ 0.122371] CPU features: detected: 32-bit EL0 Support [ 0.127625] CPU features: detected: CRC32 instructions [ 0.141643] CPU: All CPU(s) started at EL2 [ 0.145838] alternatives: patching kernel code [ 0.150846] devtmpfs: initialized [ 0.159995] KASLR disabled due to lack of seed [ 0.164638] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.174602] futex hash table entries: 512 (order: 3, 32768 bytes, linear) [ 0.187635] pinctrl core: initialized pinctrl subsystem [ 0.193287] DMI not present or invalid. [ 0.197524] NET: Registered protocol family 16 [ 0.202907] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations [ 0.210207] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 0.218208] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 0.226513] thermal_sys: Registered thermal governor 'step_wise' [ 0.226515] thermal_sys: Registered thermal governor 'power_allocator' [ 0.233093] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.246727] ASID allocator initialised with 65536 entries [ 0.268707] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages [ 0.275563] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages [ 0.282413] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [ 0.289260] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages [ 0.296717] cryptd: max_cpu_qlen set to 1000 [ 0.302690] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected [ 0.311498] vsys_3v3: supplied by vusb-main5v0 [ 0.316518] iommu: Default domain type: Translated [ 0.321663] SCSI subsystem initialized [ 0.325754] mc: Linux media interface: v0.10 [ 0.330125] videodev: Linux video capture interface: v2.00 [ 0.335752] pps_core: LinuxPPS API ver. 1 registered [ 0.340822] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.350162] PTP clock support registered [ 0.354183] EDAC MC: Ver: 3.0.0 [ 0.357958] FPGA manager framework [ 0.361470] Advanced Linux Sound Architecture Driver Initialized. [ 0.368097] clocksource: Switched to clocksource arch_sys_counter [ 0.374428] VFS: Disk quotas dquot_6.6.0 [ 0.378459] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 0.388109] Carveout Heap: Exported 512 MiB at 0x00000000b8000000 [ 0.394397] NET: Registered protocol family 2 [ 0.399121] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear) [ 0.407700] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear) [ 0.416460] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear) [ 0.424661] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear) [ 0.432454] TCP: Hash tables configured (established 32768 bind 32768) [ 0.439241] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear) [ 0.446133] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear) [ 0.453531] NET: Registered protocol family 1 [ 0.458248] RPC: Registered named UNIX socket transport module. [ 0.464303] RPC: Registered udp transport module. [ 0.469119] RPC: Registered tcp transport module. [ 0.473922] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.480504] NET: Registered protocol family 44 [ 0.485052] PCI: CLS 0 bytes, default 64 [ 0.489444] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available [ 0.499877] Initialise system trusted keyrings [ 0.504516] workingset: timestamp_bits=46 max_order=20 bucket_order=0 [ 0.512627] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.518829] NFS: Registering the id_resolver key type [ 0.524011] Key type id_resolver registered [ 0.528282] Key type id_legacy registered [ 0.532400] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.539248] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [ 0.546885] 9p: Installing v9fs 9p2000 file system support [ 0.572103] Key type asymmetric registered [ 0.576289] Asymmetric key parser 'x509' registered [ 0.581287] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243) [ 0.588846] io scheduler mq-deadline registered [ 0.593472] io scheduler kyber registered [ 0.599103] pinctrl-single 4301c000.pinctrl: 94 pins, size 376 [ 0.605287] pinctrl-single 11c000.pinctrl: 173 pins, size 692 [ 0.614291] ti-pat 31010000.pat: Found PAT Rev 1.0 with 16384 pages [ 0.620725] debugfs: Directory '31010000.pat' with parent 'regmap' already present! [ 0.628712] ti-pat 31011000.pat: Found PAT Rev 1.0 with 16384 pages [ 0.635134] debugfs: Directory '31011000.pat' with parent 'regmap' already present! [ 0.643080] ti-pat 31012000.pat: Found PAT Rev 1.0 with 16384 pages [ 0.649498] debugfs: Directory '31012000.pat' with parent 'regmap' already present! [ 0.657425] ti-pat 31013000.pat: Found PAT Rev 1.0 with 2048 pages [ 0.663750] debugfs: Directory '31013000.pat' with parent 'regmap' already present! [ 0.671695] ti-pat 31014000.pat: Found PAT Rev 1.0 with 2048 pages [ 0.678020] debugfs: Directory '31014000.pat' with parent 'regmap' already present! [ 0.687717] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled [ 0.695983] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf) [ 0.704157] arm-smmu-v3 36600000.iommu: allocated 65536 entries for cmdq [ 0.711266] arm-smmu-v3 36600000.iommu: allocated 32768 entries for evtq [ 0.719710] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs [ 0.732879] brd: module loaded [ 0.739258] loop: module loaded [ 0.743065] megasas: 07.714.04.00-rc1 [ 0.748807] tun: Universal TUN/TAP device driver, 1.6 [ 0.754260] igbvf: Intel(R) Gigabit Virtual Function Network Driver [ 0.760665] igbvf: Copyright (c) 2009 - 2012 Intel Corporation. [ 0.766735] sky2: driver version 1.30 [ 0.771096] VFIO - User Level meta-driver version: 0.3 [ 0.776942] i2c /dev entries driver [ 0.781418] sdhci: Secure Digital Host Controller Interface driver [ 0.787734] sdhci: Copyright(c) Pierre Ossman [ 0.792387] sdhci-pltfm: SDHCI platform and OF driver helper [ 0.798770] ledtrig-cpu: registered to indicate activity on CPUs [ 0.805085] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 0.812453] optee: probing for conduit method. I/TC: Reserved shared memory is enabled I/TC: Dynamic shared memory is enabled I/TC: Normal World virtualization support is disabled I/TC: Asynchronous notifications are disabled [ 0.817006] optee: revision 3.20 (8e74d476) [ 0.833404] optee: dynamic shared memory is enabled [ 0.842864] optee: initialized driver [ 0.847876] NET: Registered protocol family 17 [ 0.852499] 9pnet: Installing 9P2000 support [ 0.856895] Key type dns_resolver registered [ 0.861377] Loading compiled-in X.509 certificates [ 0.874613] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0008 '8.6.3--v08.06.03 (Chill Capybar') [ 0.927084] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz [ 0.933183] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz [ 0.939247] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz [ 0.968143] pca954x 3-0071: probe failed [ 0.972180] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz [ 1.002717] tps6594x-rtc tps6594x-rtc.1.auto: registered as rtc0 [ 1.009557] tps6594x-rtc tps6594x-rtc.1.auto: setting system clock to 2000-01-01T00:00:00 UTC (946684800) [ 1.019368] omap_i2c 2010000.i2c: bus 4 rev0.12 at 400 kHz [ 1.048144] pca954x 5-0070: probe failed [ 1.052177] omap_i2c 2030000.i2c: bus 5 rev0.12 at 400 kHz [ 1.058263] omap_i2c 2050000.i2c: bus 6 rev0.12 at 400 kHz [ 1.064698] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created [ 1.074671] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created [ 1.083481] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created [ 1.093336] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created [ 1.113364] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges: [ 1.121058] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000 [ 1.129336] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000 [ 1.137612] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 1.146478] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges: [ 1.154156] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000 [ 1.162431] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000 [ 1.170710] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 1.179983] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235 [ 1.189862] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled [ 1.196621] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64 [ 1.205625] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211 [ 1.215774] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled [ 1.222533] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64 [ 1.230509] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 15, base_baud = 6000000) is a 8250 [ 1.239919] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 27, base_baud = 3000000) is a 8250 [ 1.248667] printk: console [ttyS2] enabled [ 1.248667] printk: console [ttyS2] enabled [ 1.257107] printk: bootconsole [ns16550a0] disabled [ 1.257107] printk: bootconsole [ns16550a0] disabled [ 1.267606] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 28, base_baud = 3000000) is a 8250 [ 1.276587] 2820000.serial: ttyS4 at MMIO 0x2820000 (irq = 29, base_baud = 3000000) is a 8250 [ 1.289876] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode [ 1.336101] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 1.343742] davinci_mdio 46000f00.mdio: no live phy, scanning all [ 1.361587] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver unknown [ 1.369596] davinci_mdio 46000f00.mdio: phy[1]: device 46000f00.mdio:01, driver unknown [ 1.377580] davinci_mdio 46000f00.mdio: phy[2]: device 46000f00.mdio:02, driver unknown [ 1.385564] davinci_mdio 46000f00.mdio: phy[3]: device 46000f00.mdio:03, driver unknown [ 1.393549] davinci_mdio 46000f00.mdio: phy[4]: device 46000f00.mdio:04, driver unknown [ 1.401533] davinci_mdio 46000f00.mdio: phy[5]: device 46000f00.mdio:05, driver unknown [ 1.409517] davinci_mdio 46000f00.mdio: phy[6]: device 46000f00.mdio:06, driver unknown [ 1.417503] davinci_mdio 46000f00.mdio: phy[7]: device 46000f00.mdio:07, driver unknown [ 1.425487] davinci_mdio 46000f00.mdio: phy[8]: device 46000f00.mdio:08, driver unknown [ 1.433472] davinci_mdio 46000f00.mdio: phy[9]: device 46000f00.mdio:09, driver unknown [ 1.441455] davinci_mdio 46000f00.mdio: phy[10]: device 46000f00.mdio:0a, driver unknown [ 1.449525] davinci_mdio 46000f00.mdio: phy[11]: device 46000f00.mdio:0b, driver unknown [ 1.457596] davinci_mdio 46000f00.mdio: phy[12]: device 46000f00.mdio:0c, driver unknown [ 1.465671] davinci_mdio 46000f00.mdio: phy[13]: device 46000f00.mdio:0d, driver unknown [ 1.473748] davinci_mdio 46000f00.mdio: phy[14]: device 46000f00.mdio:0e, driver unknown [ 1.481846] davinci_mdio 46000f00.mdio: phy[15]: device 46000f00.mdio:0f, driver unknown [ 1.489917] davinci_mdio 46000f00.mdio: phy[16]: device 46000f00.mdio:10, driver unknown [ 1.497989] davinci_mdio 46000f00.mdio: phy[17]: device 46000f00.mdio:11, driver unknown [ 1.506058] davinci_mdio 46000f00.mdio: phy[18]: device 46000f00.mdio:12, driver unknown [ 1.514129] davinci_mdio 46000f00.mdio: phy[19]: device 46000f00.mdio:13, driver unknown [ 1.522199] davinci_mdio 46000f00.mdio: phy[20]: device 46000f00.mdio:14, driver unknown [ 1.530270] davinci_mdio 46000f00.mdio: phy[21]: device 46000f00.mdio:15, driver unknown [ 1.538341] davinci_mdio 46000f00.mdio: phy[22]: device 46000f00.mdio:16, driver unknown [ 1.546413] davinci_mdio 46000f00.mdio: phy[23]: device 46000f00.mdio:17, driver unknown [ 1.554484] davinci_mdio 46000f00.mdio: phy[24]: device 46000f00.mdio:18, driver unknown [ 1.562555] davinci_mdio 46000f00.mdio: phy[25]: device 46000f00.mdio:19, driver unknown [ 1.570627] davinci_mdio 46000f00.mdio: phy[26]: device 46000f00.mdio:1a, driver unknown [ 1.578697] davinci_mdio 46000f00.mdio: phy[27]: device 46000f00.mdio:1b, driver unknown [ 1.586771] davinci_mdio 46000f00.mdio: phy[28]: device 46000f00.mdio:1c, driver unknown [ 1.594882] davinci_mdio 46000f00.mdio: phy[29]: device 46000f00.mdio:1d, driver unknown [ 1.602953] davinci_mdio 46000f00.mdio: phy[30]: device 46000f00.mdio:1e, driver unknown [ 1.611026] davinci_mdio 46000f00.mdio: phy[31]: device 46000f00.mdio:1f, driver unknown [ 1.619164] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000 [ 1.632009] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4 [ 1.639216] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64 [ 1.645544] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0 [ 1.656336] davinci_mdio c000f00.mdio: Configuring MDIO in manual mode [ 1.700100] davinci_mdio c000f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 1.707656] davinci_mdio c000f00.mdio: no live phy, scanning all [ 1.725740] davinci_mdio c000f00.mdio: phy[0]: device c000f00.mdio:00, driver unknown [ 1.733567] davinci_mdio c000f00.mdio: phy[1]: device c000f00.mdio:01, driver unknown [ 1.741396] davinci_mdio c000f00.mdio: phy[2]: device c000f00.mdio:02, driver unknown [ 1.749208] davinci_mdio c000f00.mdio: phy[3]: device c000f00.mdio:03, driver unknown [ 1.757020] davinci_mdio c000f00.mdio: phy[4]: device c000f00.mdio:04, driver unknown [ 1.764831] davinci_mdio c000f00.mdio: phy[5]: device c000f00.mdio:05, driver unknown [ 1.772643] davinci_mdio c000f00.mdio: phy[6]: device c000f00.mdio:06, driver unknown [ 1.780457] davinci_mdio c000f00.mdio: phy[7]: device c000f00.mdio:07, driver unknown [ 1.788271] davinci_mdio c000f00.mdio: phy[8]: device c000f00.mdio:08, driver unknown [ 1.796082] davinci_mdio c000f00.mdio: phy[9]: device c000f00.mdio:09, driver unknown [ 1.803894] davinci_mdio c000f00.mdio: phy[10]: device c000f00.mdio:0a, driver unknown [ 1.811791] davinci_mdio c000f00.mdio: phy[11]: device c000f00.mdio:0b, driver unknown [ 1.819689] davinci_mdio c000f00.mdio: phy[12]: device c000f00.mdio:0c, driver unknown [ 1.827587] davinci_mdio c000f00.mdio: phy[13]: device c000f00.mdio:0d, driver unknown [ 1.835485] davinci_mdio c000f00.mdio: phy[14]: device c000f00.mdio:0e, driver unknown [ 1.843385] davinci_mdio c000f00.mdio: phy[15]: device c000f00.mdio:0f, driver unknown [ 1.851287] davinci_mdio c000f00.mdio: phy[16]: device c000f00.mdio:10, driver unknown [ 1.859189] davinci_mdio c000f00.mdio: phy[17]: device c000f00.mdio:11, driver unknown [ 1.867158] davinci_mdio c000f00.mdio: phy[18]: device c000f00.mdio:12, driver unknown [ 1.875060] davinci_mdio c000f00.mdio: phy[19]: device c000f00.mdio:13, driver unknown [ 1.882957] davinci_mdio c000f00.mdio: phy[20]: device c000f00.mdio:14, driver unknown [ 1.890856] davinci_mdio c000f00.mdio: phy[21]: device c000f00.mdio:15, driver unknown [ 1.898753] davinci_mdio c000f00.mdio: phy[22]: device c000f00.mdio:16, driver unknown [ 1.906650] davinci_mdio c000f00.mdio: phy[23]: device c000f00.mdio:17, driver unknown [ 1.914550] davinci_mdio c000f00.mdio: phy[24]: device c000f00.mdio:18, driver unknown [ 1.922447] davinci_mdio c000f00.mdio: phy[25]: device c000f00.mdio:19, driver unknown [ 1.930346] davinci_mdio c000f00.mdio: phy[26]: device c000f00.mdio:1a, driver unknown [ 1.938244] davinci_mdio c000f00.mdio: phy[27]: device c000f00.mdio:1b, driver unknown [ 1.946141] davinci_mdio c000f00.mdio: phy[28]: device c000f00.mdio:1c, driver unknown [ 1.954038] davinci_mdio c000f00.mdio: phy[29]: device c000f00.mdio:1d, driver unknown [ 1.961935] davinci_mdio c000f00.mdio: phy[30]: device c000f00.mdio:1e, driver unknown [ 1.969832] davinci_mdio c000f00.mdio: phy[31]: device c000f00.mdio:1f, driver unknown [ 1.977797] am65-cpsw-nuss c000000.ethernet: initializing am65 cpsw nuss version 0x6BA01901, cpsw version 0x6BA80101 Ports: 9 quirks:00000000 [ 1.990480] am65-cpsw-nuss c000000.ethernet: /bus@100000/ethernet@c000000/ethernet-ports/port@1 error retrieving port phy: -19 [ 2.003681] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0 [ 2.113577] mmc0: CQHCI version 5.10 [ 2.122551] vdd_mmc1: supplied by vsys_3v3 [ 2.127275] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100 [ 2.134143] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100 [ 2.140991] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100 [ 2.147811] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100 [ 2.154607] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100 [ 2.158050] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit [ 2.171919] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges: [ 2.179409] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000 [ 2.187494] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000 [ 2.195575] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 2.238008] mmc0: Command Queue Engine enabled [ 2.242453] mmc0: new DDR MMC card at address 0001 [ 2.247512] mmcblk0: mmc0:0001 CJUD4R 59.6 GiB [ 2.252108] mmcblk0boot0: mmc0:0001 CJUD4R partition 1 31.9 MiB [ 2.258088] mmcblk0boot1: mmc0:0001 CJUD4R partition 2 31.9 MiB [ 2.264066] mmcblk0rpmb: mmc0:0001 CJUD4R partition 3 4.00 MiB, chardev (237:0) [ 2.273304] mmcblk0: p1 [ 3.206334] j721e-pcie 2900000.pcie: PCI host bridge to bus 0000:00 [ 3.212603] pci_bus 0000:00: root bus resource [bus 00-ff] [ 3.218076] pci_bus 0000:00: root bus resource [io 0x0000-0xffff] (bus address [0x10001000-0x10010fff]) [ 3.227535] pci_bus 0000:00: root bus resource [mem 0x10011000-0x17ffffff] [ 3.234419] pci 0000:00:00.0: [104c:b00d] type 01 class 0x060400 [ 3.240413] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits [ 3.250108] pci 0000:00:00.0: supports D1 [ 3.254106] pci 0000:00:00.0: PME# supported from D0 D1 D3hot [ 3.262012] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 3.271917] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01 [ 3.278531] pci 0000:00:00.0: PCI bridge to [bus 01] [ 3.283714] pcieport 0000:00:00.0: PME: Signaling with IRQ 504 [ 3.290055] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges: [ 3.297539] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000 [ 3.305621] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000 [ 3.313701] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 4.324518] j721e-pcie 2910000.pcie: PCI host bridge to bus 0001:00 [ 4.330781] pci_bus 0001:00: root bus resource [bus 00-ff] [ 4.336257] pci_bus 0001:00: root bus resource [io 0x10000-0x1ffff] (bus address [0x18001000-0x18010fff]) [ 4.345889] pci_bus 0001:00: root bus resource [mem 0x18011000-0x1fffffff] [ 4.352767] pci 0001:00:00.0: [104c:b00d] type 01 class 0x060400 [ 4.358759] pci_bus 0001:00: 2-byte config write to 0001:00:00.0 offset 0x4 may corrupt adjacent RW1C bits [ 4.368453] pci 0001:00:00.0: supports D1 [ 4.372451] pci 0001:00:00.0: PME# supported from D0 D1 D3hot [ 4.380250] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 4.390150] pci_bus 0001:01: busn_res: [bus 01-ff] end is updated to 01 [ 4.396760] pci 0001:00:00.0: PCI bridge to [bus 01] [ 4.401929] pcieport 0001:00:00.0: PME: Signaling with IRQ 506 [ 4.408607] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8) [ 4.419181] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16) [ 4.431067] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode [ 4.476108] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 4.483751] davinci_mdio 46000f00.mdio: no live phy, scanning all [ 4.501611] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver unknown [ 4.509622] davinci_mdio 46000f00.mdio: phy[1]: device 46000f00.mdio:01, driver unknown [ 4.517607] davinci_mdio 46000f00.mdio: phy[2]: device 46000f00.mdio:02, driver unknown [ 4.525592] davinci_mdio 46000f00.mdio: phy[3]: device 46000f00.mdio:03, driver unknown [ 4.533575] davinci_mdio 46000f00.mdio: phy[4]: device 46000f00.mdio:04, driver unknown [ 4.541563] davinci_mdio 46000f00.mdio: phy[5]: device 46000f00.mdio:05, driver unknown [ 4.549547] davinci_mdio 46000f00.mdio: phy[6]: device 46000f00.mdio:06, driver unknown [ 4.557534] davinci_mdio 46000f00.mdio: phy[7]: device 46000f00.mdio:07, driver unknown [ 4.565518] davinci_mdio 46000f00.mdio: phy[8]: device 46000f00.mdio:08, driver unknown [ 4.573502] davinci_mdio 46000f00.mdio: phy[9]: device 46000f00.mdio:09, driver unknown [ 4.581486] davinci_mdio 46000f00.mdio: phy[10]: device 46000f00.mdio:0a, driver unknown [ 4.589560] davinci_mdio 46000f00.mdio: phy[11]: device 46000f00.mdio:0b, driver unknown [ 4.597632] davinci_mdio 46000f00.mdio: phy[12]: device 46000f00.mdio:0c, driver unknown [ 4.605704] davinci_mdio 46000f00.mdio: phy[13]: device 46000f00.mdio:0d, driver unknown [ 4.613781] davinci_mdio 46000f00.mdio: phy[14]: device 46000f00.mdio:0e, driver unknown [ 4.621917] davinci_mdio 46000f00.mdio: phy[15]: device 46000f00.mdio:0f, driver unknown [ 4.630000] davinci_mdio 46000f00.mdio: phy[16]: device 46000f00.mdio:10, driver unknown [ 4.638071] davinci_mdio 46000f00.mdio: phy[17]: device 46000f00.mdio:11, driver unknown [ 4.646144] davinci_mdio 46000f00.mdio: phy[18]: device 46000f00.mdio:12, driver unknown [ 4.654215] davinci_mdio 46000f00.mdio: phy[19]: device 46000f00.mdio:13, driver unknown [ 4.662285] davinci_mdio 46000f00.mdio: phy[20]: device 46000f00.mdio:14, driver unknown [ 4.670356] davinci_mdio 46000f00.mdio: phy[21]: device 46000f00.mdio:15, driver unknown [ 4.678427] davinci_mdio 46000f00.mdio: phy[22]: device 46000f00.mdio:16, driver unknown [ 4.686498] davinci_mdio 46000f00.mdio: phy[23]: device 46000f00.mdio:17, driver unknown [ 4.694569] davinci_mdio 46000f00.mdio: phy[24]: device 46000f00.mdio:18, driver unknown [ 4.702639] davinci_mdio 46000f00.mdio: phy[25]: device 46000f00.mdio:19, driver unknown [ 4.710709] davinci_mdio 46000f00.mdio: phy[26]: device 46000f00.mdio:1a, driver unknown [ 4.718780] davinci_mdio 46000f00.mdio: phy[27]: device 46000f00.mdio:1b, driver unknown [ 4.726852] davinci_mdio 46000f00.mdio: phy[28]: device 46000f00.mdio:1c, driver unknown [ 4.734926] davinci_mdio 46000f00.mdio: phy[29]: device 46000f00.mdio:1d, driver unknown [ 4.743004] davinci_mdio 46000f00.mdio: phy[30]: device 46000f00.mdio:1e, driver unknown [ 4.751077] davinci_mdio 46000f00.mdio: phy[31]: device 46000f00.mdio:1f, driver unknown [ 4.759215] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000 [ 4.772057] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4 [ 4.779264] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64 [ 4.785566] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0 [ 4.796122] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48 [ 4.804714] debugfs: Directory 'pd:27' with parent 'pm_genpd' already present! [ 4.812024] debugfs: Directory 'pd:26' with parent 'pm_genpd' already present! [ 4.812141] mmc1: CQHCI version 5.10 [ 4.820399] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present! [ 4.830118] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present! [ 4.837426] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present! [ 4.844738] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present! [ 4.863806] ALSA device list: [ 4.866778] No soundcards found. [ 6.340213] sdhci-am654 4fb0000.mmc: Power on failed [ 6.375784] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit [ 6.399108] EXT4-fs (mmcblk0p1): recovery complete [ 6.404769] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null) [ 6.412877] VFS: Mounted root (ext4 filesystem) on device 179:1. [ 6.419107] devtmpfs: mounted [ 6.422860] Freeing unused kernel memory: 1856K [ 6.427482] Run /sbin/init as init process [ 6.522387] systemd[1]: System time before build time, advancing clock. [ 6.543786] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid) [ 6.565542] systemd[1]: Detected architecture arm64. Welcome to Arago 2021.09! [ 6.596396] systemd[1]: Set hostname to <tda4vm-sk>. [ 6.716546] systemd[1]: Binding to IPv6 address not available since kernel does not support IPv6. [ 6.725480] systemd[1]: Binding to IPv6 address not available since kernel does not support IPv6. [ 6.734839] systemd[1]: /etc/systemd/system/rc-local.service:11: Support for option SysVStartPriority= has been removed and it is ignored [ 6.785698] random: systemd: uninitialized urandom read (16 bytes read) [ 6.793671] systemd[1]: Created slice system-getty.slice. [ OK ] Created slice system-getty.slice. [ 6.816179] random: systemd: uninitialized urandom read (16 bytes read) [ 6.823302] systemd[1]: Created slice system-serial\x2dgetty.slice. [ OK ] Created slice system-serial\x2dgetty.slice. [ 6.844168] random: systemd: uninitialized urandom read (16 bytes read) [ 6.851204] systemd[1]: Created slice User and Session Slice. [ OK ] Created slice User and Session Slice. [ 6.872285] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [ OK ] Started Dispatch Password …ts to Console Directory Watch. [ 6.896224] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ OK ] Started Forward Password R…uests to Wall Directory Watch. [ 6.920211] systemd[1]: Reached target Paths. [ OK ] Reached target Paths. [ 6.940157] systemd[1]: Reached target Remote File Systems. [ OK ] Reached target Remote File Systems. [ 6.960151] systemd[1]: Reached target Slices. [ OK ] Reached target Slices. [ 6.980151] systemd[1]: Reached target Swap. [ OK ] Reached target Swap. [ 7.004891] systemd[1]: Listening on RPCbind Server Activation Socket. [ OK ] Listening on RPCbind Server Activation Socket. [ 7.028239] systemd[1]: Reached target RPC Port Mapper. [ OK ] Reached target RPC Port Mapper. [ 7.050157] systemd[1]: Listening on Process Core Dump Socket. [ OK ] Listening on Process Core Dump Socket. [ 7.072302] systemd[1]: Listening on initctl Compatibility Named Pipe. [ OK ] Listening on initctl Compatibility Named Pipe. [ 7.097569] systemd[1]: Condition check resulted in Journal Audit Socket being skipped. [ 7.105905] systemd[1]: Listening on Journal Socket (/dev/log). [ OK ] Listening on Journal Socket (/dev/log). [ 7.128408] systemd[1]: Listening on Journal Socket. [ OK ] Listening on Journal Socket. [ 7.148445] systemd[1]: Listening on Network Service Netlink Socket. [ OK ] Listening on Network Service Netlink Socket. [ 7.172379] systemd[1]: Listening on udev Control Socket. [ OK ] Listening on udev Control Socket. [ 7.192292] systemd[1]: Listening on udev Kernel Socket. [ OK ] Listening on udev Kernel Socket. [ 7.214134] systemd[1]: Mounting Huge Pages File System... Mounting Huge Pages File System... [ 7.238097] systemd[1]: Mounting POSIX Message Queue File System... Mounting POSIX Message Queue File System... [ 7.262132] systemd[1]: Mounting Kernel Debug File System... Mounting Kernel Debug File System... [ 7.286305] systemd[1]: Mounting Temporary Directory (/tmp)... Mounting Temporary Directory (/tmp)... [ 7.308316] systemd[1]: Condition check resulted in Create list of static device nodes for the current kernel being skipped. [ 7.323845] systemd[1]: Starting Start psplash boot splash screen... Starting Start psplash boot splash screen... [ 7.346379] systemd[1]: Starting RPC Bind... Starting RPC Bind... [ 7.364422] systemd[1]: Condition check resulted in File System Check on Root Device being skipped. [ 7.376342] systemd[1]: Starting Journal Service... Starting Journal Service... [ 7.399027] systemd[1]: Starting Load Kernel Modules... Starting Load Kernel Modules... [ 7.413593] systemd[1]: Starting Remount Root and Kernel File Systems... Starting Remount Root and Kernel File Systems... [ 7.434524] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null) [ 7.442307] systemd[1]: Starting udev Coldplug all Devices... Starting udev Coldplug all Devices... [ 7.466981] systemd[1]: Started RPC Bind. [ OK ] Started RPC Bind. [ 7.484516] systemd[1]: Started Journal Service. [ OK ] Started Journal Service. [ OK ] Mounted Huge Pages File System. [ OK ] Mounted POSIX Message Queue File System. [ OK ] Mounted Kernel Debug File System. [ OK ] Mounted Temporary Directory (/tmp). [FAILED] Failed to start Start psplash boot splash screen. See 'systemctl status psplash-start.service' for details. [DEPEND] Dependency failed for Star…progress communication helper. [FAILED] Failed to start Load Kernel Modules. See 'systemctl status systemd-modules-load.service' for details. [ OK ] Started Remount Root and Kernel File Systems. Mounting Kernel Configuration File System... Starting Flush Journal to Persistent Storage... [ 7.707743] systemd-journald[273]: Received client request to flush runtime journal. Starting Apply Kernel Variables... Starting Create Static Device Nodes in /dev... [ OK ] Mounted Kernel Configuration File System. [ OK ] Started Flush Journal to Persistent Storage. [ OK ] Started Apply Kernel Variables. [ OK ] Started Create Static Device Nodes in /dev. [ 7.816667] random: systemd: uninitialized urandom read (16 bytes read) [ OK ] Reached target Local File Systems (Pre). [ 7.840244] random: systemd: uninitialized urandom read (16 bytes read) Mounting /media/ram... [ 7.849825] random: systemd-journal: uninitialized urandom read (16 bytes read) Mounting /var/volatile... Starting udev Kernel Device Manager... [ OK ] Started udev Coldplug all Devices. [ OK ] Mounted /media/ram. [ OK ] Started udev Kernel Device Manager. [ OK ] Mounted /var/volatile. Starting Load/Save Random Seed... [ OK ] Reached target Local File Systems. Starting Create Volatile Files and Directories... [ OK ] Started Create Volatile Files and Directories. Starting Network Time Synchronization... Starting Update UTMP about System Boot/Shutdown... [ OK ] Started Update UTMP about System Boot/Shutdown. [ OK ] Started Network Time Synchronization. [ OK ] Reached target System Initialization. [ OK ] Started Daily Cleanup of Temporary Directories. [ OK ] Reached target System Time Set. [ OK ] Reached target System Time Synchronized. [ OK ] Reached target Timers. [ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket. [ OK ] Listening on D-Bus System Message Bus Socket. [ OK ] Listening on dropbear.socket. [ OK ] Reached target Sockets. [ OK ] Reached target Basic System. [ OK ] Started D-Bus System Message Bus. Starting Print notice about GPLv3 packages... Starting set host name as per compatible name... Starting IPv6 Packet Filtering Framework... Starting IPv4 Packet Filtering Framework... Starting Update pmic regis…fety feature on power rails... Starting /etc/rc.local Compatibility... Starting rc.pvr.service... Starting startwlanap... Starting startwlansta... Starting Login Service... [ OK ] Started TEE Supplicant. Starting Update weston ini… based on the platform name... [ OK ] Started IPv6 Packet Filtering Framework. [ OK ] Started IPv4 Packet Filtering Framework. [ OK ] Started rc.pvr.service. [ OK ] Started startwlanap. [ OK ] Started startwlansta. [FAILED] Failed to start Update pmi…safety feature on power rails. See 'systemctl status pmic-fix.service' for details. [ OK ] Reached target Network (Pre). Starting Network Manager... Starting Network Service... [ OK ] Stopped Update pmic regist…safety feature on power rails. Starting Update pmic regis…fety feature on power rails... [ OK ] Started Network Service. [ 8.807998] am65-cpsw-nuss 46000000.ethernet eth0: configuring for fixed/rgmii-id link mode [ 8.808532] am65-cpsw-nuss 46000000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off [ 8.828429] random: NetworkManager: uninitialized urandom read (16 bytes read) Starting Wait for Network to be Configured[ 8.896724] random: systemd: uninitialized urandom read (16 bytes read) ... Starting Network Name Resolution... [FAILED] Failed to start Update pmi…safety feature on power rails. See 'systemctl status pmic-fix.s[ 8.943947] random: systemd: uninitialized urandom read (16 bytes read) ervice' for details. [ OK ] Started Network Manager. [ OK ] Started Login Service. Starting Network Manager Wait Online... Starting Hostname Service... [ OK ] Stopped Update pmic regist…safety feature on power rails. Starting Update pmic regis…fety feature on power rails... [FAILED] Failed to start Update pmi…safety feature on power rails. See 'systemctl status pmic-fix.service' for details. *************************************************************** *************************************************************** NOTICE: This file system contains the following GPLv3 packages: [ OK ] Stopped Update pmic regist…safety feature on power rails. Starting Update pmic regis…fety feature on power rails... bash-dev bash cifs-utils dnsmasq dosfstools gdb less libdw1 libelf1 libgdbm-compat4 libgdbm-dev libgdbm6 libgmp10 libidn2-0 libreadline-dev libreadline8 libunistring2 m4-dev m4 nettle parted [ OK ] Started Network Name Resolution. [ OK ] Reached target Network. [ OK ] Reached target Host and Network Name Lookups. Starting Avahi mDNS/DNS-SD Stack... If you do not wish to distribute GPLv3 components please remove the above packages prior to distribution. This can be done using the opkg remove command. i.e.: opkg remove <package> Where <package> is the name printed in the list above NOTE: If the package is a dependency of another package you will be notified of the dependent packages. You should use the --force-removal-of-dependent-packages option to also remove the dependent packages as well *************************************************************** *************************************************************** Starting DNS forwarder and DHCP server... [ OK ] Started NFS status monitor for NFSv2/3 locking.. Starting Permit User Sessions... [ OK ] Started Print notice about GPLv3 packages. [ OK ] Started Permit User Sessions. [ OK ] Started Hostname Service. [ OK ] Started Avahi mDNS/DNS-SD Stack. [FAILED] Failed to start Update pmi…safety feature on power rails. See 'systemctl status pmic-fix.service' for details. Starting Network Manager Script Dispatcher Service... [ OK ] Started DNS forwarder and DHCP server. [ OK ] Started Network Manager Script Dispatcher Service. [ OK ] Stopped Update pmic regist…safety feature on power rails. Starting Update pmic regis…fety feature on power rails... [ 9.672132] random: crng init done [ 9.675534] random: 173 urandom warning(s) missed due to ratelimiting [ OK ] Started Load/Save Random Seed. [FAILED] Failed to start Update pmi…safety feature on power rails. See 'systemctl status pmic-fix.service' for details. [ OK ] Stopped Update pmic regist…safety feature on power rails. [FAILED] Failed to start Update pmi…safety feature on power rails. See 'systemctl status pmic-fix.service' for details. [ OK ] Started Network Manager Wait Online. [ OK ] Started set host name as per compatible name. [ OK ] Started Update weston ini …ge based on the platform name. Starting weston.service... Error: device 'enp1s0' not compatible with connection 'default'. [FAILED] Failed to start /etc/rc.local Compatibility. See 'systemctl status rc-local.service' for details. [ OK ] Started Getty on tty1. [ OK ] Started Serial Getty on ttyS2. [ OK ] Started Serial Getty on ttyS3. [ OK ] Reached target Login Prompts. Starting Synchronize System and HW clocks... [ OK ] Started Synchronize System and HW clocks. [ OK ] Started weston.service. Starting DEMO... Starting telnetd.service... [ OK ] Started telnetd.service. Starting LSB: network connection manager... [ OK ] Started LSB: network connection manager. [ OK ] Started DEMO. _____ _____ _ _ | _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_ | | _| .'| . | . | | __| _| . | | | -_| _| _| |__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_| |___| |___| Arago Project tda4vm-sk ttyS2 Arago 2021.09 tda4vm-sk ttyS2 tda4vm-sk login: root -sh: echo: write error: Device or resource busy root@tda4vm-sk:~# reboot Stopping Session c1 of user root. [ OK ] Stopped target RPC Port Mapper. [ OK ] Stopped target Timers. [ OK ] Stopped Daily Cleanup of Temporary Directories. Stopping NFS status monitor for NFSv2/3 locking.... Stopping Hostname Service... Stopping Load/Save Random Seed... [ OK ] Stopped target Login Prompts. Stopping Avahi mDNS/DNS-SD Stack... [ OK ] Stopped DEMO. Stopping DNS forwarder and DHCP server... Stopping Getty on tty1... [ OK ] Stopped set host name as per compatible name. Stopping Serial Getty on ttyS2... Stopping Serial Getty on ttyS3... [ OK ] Stopped startwlanap. [ OK ] Stopped startwlansta. Stopping TEE Supplicant... [ OK ] Stopped target System Time Synchronized. [ OK ] Stopped target System Time Set. [ OK ] Stopped Network Manager Wait Online. Stopping LSB: network connection manager... [ OK ] Stopped TEE Supplicant. [ OK ] Stopped Wait for Network to be Configured. [ OK ] Stopped Hostname Service. [ OK ] Stopped Avahi mDNS/DNS-SD Stack. [ OK ] Stopped NFS status monitor for NFSv2/3 locking.. [ OK ] Stopped Getty on tty1. [ OK ] Stopped Serial Getty on ttyS2. [ OK ] Stopped Serial Getty on ttyS3. [ OK ] Stopped Load/Save Random Seed. [ OK ] Stopped DNS forwarder and DHCP server. [ OK ] Stopped LSB: network connection manager. [ OK ] Stopped Session c1 of user root. [ OK ] Removed slice system-getty.slice. [ OK ] Removed slice system-serial\x2dgetty.slice. [ OK ] Stopped target Host and Network Name Lookups. Stopping Login Service... Stopping telnetd.service... Stopping User Manager for UID 0... [ OK ] Stopped User Manager for UID 0. [ OK ] Stopped telnetd.service. Stopping User Runtime Directory /run/user/0... Stopping weston.service... [ OK ] Unmounted /run/user/0. [ OK ] Stopped Login Service. [ OK ] Stopped User Runtime Directory /run/user/0. [ OK ] Stopped weston.service. [ OK ] Removed slice User Slice of UID 0. Stopping rc.pvr.service... Stopping Permit User Sessions... [ OK ] Stopped Update weston ini …ge based on the platform name. [ OK ] Stopped rc.pvr.service. [ OK ] Stopped Permit User Sessions. [ OK ] Stopped target Network. [ OK ] Stopped target Remote File Systems. Stopping Network Manager... Stopping Network Name Resolution... [ OK ] Stopped Network Manager. [ OK ] Stopped Network Name Resolution. Stopping D-Bus System Message Bus... Stopping Network Service... [ OK ] Stopped D-Bus System Message Bus. [ OK ] Stopped Network Service. [ OK ] Stopped target Network (Pre). [ OK ] Stopped IPv6 Packet Filtering Framework. [ OK ] Stopped IPv4 Packet Filtering Framework. [ OK ] Stopped target Basic System. [ OK ] Stopped target Paths. [ OK ] Stopped Dispatch Password …ts to Console Directory Watch. [ OK ] Stopped Forward Password R…uests to Wall Directory Watch. [ OK ] Stopped target Slices. [ OK ] Removed slice User and Session Slice. [ OK ] Stopped target Sockets. [ OK ] Closed Avahi mDNS/DNS-SD Stack Activation Socket. [ OK ] Closed D-Bus System Message Bus Socket. [ OK ] Closed dropbear.socket. [ OK ] Stopped target System Initialization. [ OK ] Stopped Apply Kernel Variables. Stopping Network Time Synchronization... Stopping Update UTMP about System Boot/Shutdown... [ OK ] Stopped Network Time Synchronization. [ OK ] Stopped Update UTMP about System Boot/Shutdown. [ OK ] Stopped Create Volatile Files and Directories. [ OK ] Stopped target Local File Systems. Unmounting /media/ram... Unmounting Temporary Directory (/tmp)... Unmounting /var/volatile... [ OK ] Unmounted /media/ram. [ OK ] Unmounted Temporary Directory (/tmp). [ OK ] Unmounted /var/volatile. [ OK ] Stopped target Local File Systems (Pre). [ OK ] Stopped target Swap. [ OK ] Reached target Unmount All Filesystems. [ OK ] Stopped Remount Root and Kernel File Systems. [ OK ] Stopped Create Static Device Nodes in /dev. [ OK ] Reached target Shutdown. [ OK ] Reached target Final Step. [ OK ] Started Reboot. [ OK ] Reached target Reboot. [ 34.658077] systemd-shutdown[1]: Syncing filesystems and block devices. [ 34.669689] systemd-shutdown[1]: Sending SIGTERM to remaining processes... [ 34.680129] systemd-journald[273]: Received SIGTERM from PID 1 (systemd-shutdow). [ 34.694441] systemd-shutdown[1]: Sending SIGKILL to remaining processes... [ 34.705624] systemd-shutdown[1]: Unmounting file systems. [ 34.712344] [860]: Remounting '/' read-only in with options '(null)'. [ 34.727183] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null) [ 34.734926] systemd-shutdown[1]: All filesystems unmounted. [ 34.740552] systemd-shutdown[1]: Deactivating swaps. [ 34.745654] systemd-shutdown[1]: All swaps deactivated. [ 34.750878] systemd-shutdown[1]: Detaching loop devices. [ 34.757719] systemd-shutdown[1]: All loop devices detached. [ 34.763289] systemd-shutdown[1]: Detaching DM devices. [ 34.768517] systemd-shutdown[1]: All DM devices detached. [ 34.773907] systemd-shutdown[1]: All filesystems, swaps, loop devices and DM devices detached. [ 34.785930] systemd-shutdown[1]: Syncing filesystems and block devices. [ 34.792786] systemd-shutdown[1]: Rebooting. [ 34.810656] reboot: Restarting system
Our hardware refer to SK-TDA4VM board.
