Part Number: TDA4VM-Q1
Dear TI Experts
I am trying to debug CPSW0_9G on linux side, and below issue was reported after system booting. I am not sure whether the dts configuration is correct or not, could you help check my issue? (the full log and dts file, please refer to the attachments)
the ethtool eth0 as following displayed:
Thank you
Have a nice day~3730.log.txt
// SPDX-License-Identifier: GPL-2.0
* Copyright (C) 2019 Texas Instruments Incorporated - https://www.ti.com/
/dts-v1/;
#include "k3-j721e-som-p0.dtsi"
#include <dt-bindings/gpio/gpio.h>
#include <dt-bindings/input/input.h>
#include <dt-bindings/net/ti-dp83867.h>
#include <dt-bindings/phy/phy-cadence.h>
chosen {
stdout-path = "serial2:115200n8";
bootargs = "console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000";
gpio_keys: gpio-keys {
compatible = "gpio-keys";
autorepeat;
pinctrl-names = "default";
pinctrl-0 = <&sw10_button_pins_default &sw11_button_pins_default>;
sw10: sw10 {
label = "GPIO Key USER1";
linux,code = <BTN_0>;
gpios = <&main_gpio0 0 GPIO_ACTIVE_LOW>;
sw11: sw11 {
label = "GPIO Key USER2";
linux,code = <BTN_1>;
gpios = <&wkup_gpio0 7 GPIO_ACTIVE_LOW>;
evm_12v0: fixedregulator-evm12v0 {
/* main supply */
compatible = "regulator-fixed";
regulator-name = "evm_12v0";
regulator-min-microvolt = <12000000>;
regulator-max-microvolt = <12000000>;
regulator-always-on;
regulator-boot-on;
vsys_3v3: fixedregulator-vsys3v3 {
/* Output of LMS140 */
regulator-name = "vsys_3v3";
regulator-min-microvolt = <3300000>;
regulator-max-microvolt = <3300000>;
vin-supply = <&evm_12v0>;
regulator-boot-on;
vsys_5v0: fixedregulator-vsys5v0 {
/* Output of LM5140 */
regulator-name = "vsys_5v0";
regulator-min-microvolt = <5000000>;
regulator-max-microvolt = <5000000>;
regulator-boot-on;
vdd_mmc1: fixedregulator-sd {
regulator-name = "vdd_mmc1";
regulator-boot-on;
enable-active-high;
vin-supply = <&vsys_3v3>;
gpio = <&exp2 2 GPIO_ACTIVE_HIGH>;
vdd_sd_dv_alt: gpio-regulator-TLV71033 {
compatible = "regulator-gpio";
pinctrl-0 = <&vdd_sd_dv_alt_pins_default>;
regulator-name = "tlv71033";
regulator-min-microvolt = <1800000>;
regulator-boot-on;
vin-supply = <&vsys_5v0>;
gpios = <&main_gpio0 117 GPIO_ACTIVE_HIGH>;
states = <1800000 0x0>,
<3300000 0x1>;
sound0: sound@0 {
compatible = "ti,j721e-cpb-audio";
model = "j721e-cpb";
ti,cpb-mcasp = <&mcasp10>;
ti,cpb-codec = <&pcm3168a_1>;
clocks = <&k3_clks 184 1>,
<&k3_clks 184 2>, <&k3_clks 184 4>,
<&k3_clks 157 371>,
<&k3_clks 157 400>, <&k3_clks 157 401>;
clock-names = "cpb-mcasp-auxclk",
"cpb-mcasp-auxclk-48000", "cpb-mcasp-auxclk-44100",
"cpb-codec-scki",
"cpb-codec-scki-48000", "cpb-codec-scki-44100";
cpsw9g_virt_mac: main_r5fss_cpsw9g_virt_mac0 {
compatible = "ti,j721e-cpsw-virt-mac";
dma-coherent;
ti,psil-base = <0x4a00>;
ti,remote-name = "mpu_1_0_ethswitch-device-0";
dmas = <&main_udmap 0xca00>,
<&main_udmap 0xca01>,
<&main_udmap 0xca02>,
<&main_udmap 0xca03>,
<&main_udmap 0xca04>,
<&main_udmap 0xca05>,
<&main_udmap 0xca06>,
<&main_udmap 0xca07>,
<&main_udmap 0x4a00>;
dma-names = "tx0", "tx1", "tx2", "tx3",
"tx4", "tx5", "tx6", "tx7",
"rx";
virt_emac_port {
ti,label = "virt-port";
/* local-mac-address = [0 0 0 0 0 0]; */
cpsw9g_virt_maconly: main-r5fss-cpsw9g-virt-mac1 {
dma-coherent;
ti,remote-name = "mpu_1_0_ethmac-device-1";
"rx";
virt_emac_port {
transceiver1: can-phy0 {
compatible = "ti,tcan1043";
#phy-cells = <0>;
max-bitrate = <5000000>;
pinctrl-0 = <&mcu_mcan0_gpio_pins_default>;
standby-gpios = <&wkup_gpio0 54 GPIO_ACTIVE_LOW>;
enable-gpios = <&wkup_gpio0 0 GPIO_ACTIVE_HIGH>;
transceiver2: can-phy1 {
compatible = "ti,tcan1042";
#phy-cells = <0>;
pinctrl-0 = <&mcu_mcan1_gpio_pins_default>;
standby-gpios = <&wkup_gpio0 2 GPIO_ACTIVE_HIGH>;
transceiver3: can-phy2 {
#phy-cells = <0>;
standby-gpios = <&exp2 7 GPIO_ACTIVE_LOW>;
enable-gpios = <&exp2 6 GPIO_ACTIVE_HIGH>;
transceiver4: can-phy3 {
#phy-cells = <0>;
pinctrl-0 = <&main_mcan2_gpio_pins_default>;
standby-gpios = <&main_gpio0 127 GPIO_ACTIVE_HIGH>;
dp_pwr_3v3: fixedregulator-dp-prw {
regulator-name = "dp-pwr";
gpio = <&exp4 0 0>; /* P0 - DP0_PWR_SW_EN */
enable-active-high;
/* Always on for now, until dp-connector driver can handle this */
dp0: connector {
compatible = "dp-connector";
label = "DP0";
type = "full-size";
dp-pwr-supply = <&dp_pwr_3v3>;
port {
dp_connector_in: endpoint {
remote-endpoint = <&dp0_out>;
&main_pmx0 {
sw10_button_pins_default: sw10-button-pins-default {
pinctrl-single,pins = <
J721E_IOPAD(0x0, PIN_INPUT, 7) /* (AC18) EXTINTn.GPIO0_0 */
main_mmc1_pins_default: main-mmc1-pins-default {
J721E_IOPAD(0x254, PIN_INPUT, 0) /* (R29) MMC1_CMD */
J721E_IOPAD(0x250, PIN_INPUT, 0) /* (P25) MMC1_CLK */
J721E_IOPAD(0x2ac, PIN_INPUT, 0) /* (P25) MMC1_CLKLB */
J721E_IOPAD(0x24c, PIN_INPUT, 0) /* (R24) MMC1_DAT0 */
J721E_IOPAD(0x248, PIN_INPUT, 0) /* (P24) MMC1_DAT1 */
J721E_IOPAD(0x244, PIN_INPUT, 0) /* (R25) MMC1_DAT2 */
J721E_IOPAD(0x240, PIN_INPUT, 0) /* (R26) MMC1_DAT3 */
J721E_IOPAD(0x258, PIN_INPUT, 0) /* (P23) MMC1_SDCD */
J721E_IOPAD(0x25c, PIN_INPUT, 0) /* (R28) MMC1_SDWP */
vdd_sd_dv_alt_pins_default: vdd-sd-dv-alt-pins-default {
J721E_IOPAD(0x1d8, PIN_INPUT, 7) /* (W4) SPI1_CS1.GPIO0_117 */
main_usbss0_pins_default: main-usbss0-pins-default {
J721E_IOPAD(0x290, PIN_OUTPUT, 0) /* (U6) USB0_DRVVBUS */
J721E_IOPAD(0x210, PIN_INPUT, 7) /* (W3) MCAN1_RX.GPIO1_3 */
main_usbss1_pins_default: main-usbss1-pins-default {
J721E_IOPAD(0x214, PIN_OUTPUT, 4) /* (V4) MCAN1_TX.USB1_DRVVBUS */
dp0_pins_default: dp0-pins-default {
J721E_IOPAD(0x1c4, PIN_INPUT, 5) /* SPI0_CS1.DP0_HPD */
main_i2c1_exp4_pins_default: main-i2c1-exp4-pins-default {
J721E_IOPAD(0x230, PIN_INPUT, 7) /* (U2) ECAP0_IN_APWM_OUT.GPIO1_11 */
main_i2c0_pins_default: main-i2c0-pins-default {
J721E_IOPAD(0x220, PIN_INPUT_PULLUP, 0) /* (AC5) I2C0_SCL */
J721E_IOPAD(0x224, PIN_INPUT_PULLUP, 0) /* (AA5) I2C0_SDA */
main_i2c1_pins_default: main-i2c1-pins-default {
J721E_IOPAD(0x228, PIN_INPUT_PULLUP, 0) /* (Y6) I2C1_SCL */
J721E_IOPAD(0x22c, PIN_INPUT_PULLUP, 0) /* (AA6) I2C1_SDA */
main_i2c2_pins_default: main-i2c2-pins-default {
J721E_IOPAD(0x1c8, PIN_INPUT_PULLUP, 2) /* (AB5) SPI0_CLK.I2C2_SCL */
J721E_IOPAD(0x1cc, PIN_INPUT_PULLUP, 2) /* (AA1) SPI0_D0.I2C2_SDA */
main_i2c3_pins_default: main-i2c3-pins-default {
J721E_IOPAD(0x270, PIN_INPUT_PULLUP, 4) /* (T26) MMC2_CLK.I2C3_SCL */
J721E_IOPAD(0x274, PIN_INPUT_PULLUP, 4) /* (T25) MMC2_CMD.I2C3_SDA */
pru_icssg0_pru1_pins_default: mypru_icssg0_pru1_pins_default {
J721E_IOPAD(0xf8, PIN_INPUT, 1) /* (AB29) PRG0_PRU0_GPO18.PRG0_PRU0_GPI18 */
main_i2c6_pins_default: main-i2c6-pins-default {
J721E_IOPAD(0x1d0, PIN_INPUT_PULLUP, 2) /* (AA3) SPI0_D1.I2C6_SCL */
J721E_IOPAD(0x1e4, PIN_INPUT_PULLUP, 2) /* (Y2) SPI1_D1.I2C6_SDA */
mcasp10_pins_default: mcasp10-pins-default {
J721E_IOPAD(0x158, PIN_OUTPUT_PULLDOWN, 12) /* (U23) RGMII5_TX_CTL.MCASP10_ACLKX */
J721E_IOPAD(0x15c, PIN_OUTPUT_PULLDOWN, 12) /* (U26) RGMII5_RX_CTL.MCASP10_AFSX */
J721E_IOPAD(0x160, PIN_OUTPUT_PULLDOWN, 12) /* (V28) RGMII5_TD3.MCASP10_AXR0 */
J721E_IOPAD(0x164, PIN_OUTPUT_PULLDOWN, 12) /* (V29) RGMII5_TD2.MCASP10_AXR1 */
J721E_IOPAD(0x170, PIN_OUTPUT_PULLDOWN, 12) /* (U29) RGMII5_TXC.MCASP10_AXR2 */
J721E_IOPAD(0x174, PIN_OUTPUT_PULLDOWN, 12) /* (U25) RGMII5_RXC.MCASP10_AXR3 */
J721E_IOPAD(0x198, PIN_INPUT_PULLDOWN, 12) /* (V25) RGMII6_TD1.MCASP10_AXR4 */
J721E_IOPAD(0x19c, PIN_INPUT_PULLDOWN, 12) /* (W27) RGMII6_TD0.MCASP10_AXR5 */
J721E_IOPAD(0x1a0, PIN_INPUT_PULLDOWN, 12) /* (W29) RGMII6_TXC.MCASP10_AXR6 */
audi_ext_refclk2_pins_default: audi-ext-refclk2-pins-default {
J721E_IOPAD(0x1a4, PIN_OUTPUT, 3) /* (W26) RGMII6_RXC.AUDIO_EXT_REFCLK2 */
main_mcan0_pins_default: main-mcan0-pins-default {
J721E_IOPAD(0x208, PIN_INPUT, 0) /* (W5) MCAN0_RX */
J721E_IOPAD(0x20c, PIN_OUTPUT, 0) /* (W6) MCAN0_TX */
main_mcan2_pins_default: main-mcan2-pins-default {
J721E_IOPAD(0x01f0, PIN_INPUT, 3) /* (AC2) MCAN2_RX.GPIO0_123 */
J721E_IOPAD(0x01f4, PIN_OUTPUT, 3) /* (AB1) MCAN2_TX.GPIO0_124 */
main_mcan2_gpio_pins_default: main-mcan2-gpio-pins-default {
J721E_IOPAD(0x200, PIN_INPUT, 7) /* (AC4) UART1_CTSn.GPIO0_127 */
rgmii5_pins_default: rgmii5-pins-default {
J721E_IOPAD(0x184, PIN_INPUT, 0) /* (T23) RGMII5_RD0 */
J721E_IOPAD(0x180, PIN_INPUT, 0) /* (R23) RGMII5_RD1 */
J721E_IOPAD(0x17c, PIN_INPUT, 0) /* (U24) RGMII5_RD2 */
J721E_IOPAD(0x178, PIN_INPUT, 0) /* (U27) RGMII5_RD3 */
J721E_IOPAD(0x174, PIN_INPUT, 0) /* (U25) RGMII5_RXC */
J721E_IOPAD(0x15c, PIN_INPUT, 0) /* (U26) RGMII5_RX_CTL */
J721E_IOPAD(0x16c, PIN_OUTPUT, 0) /* (U28) RGMII5_TD0 */
J721E_IOPAD(0x168, PIN_OUTPUT, 0) /* (V27) RGMII5_TD1 */
J721E_IOPAD(0x164, PIN_OUTPUT, 0) /* (V29) RGMII5_TD2 */
J721E_IOPAD(0x160, PIN_OUTPUT, 0) /* (V28) RGMII5_TD3 */
J721E_IOPAD(0x170, PIN_OUTPUT, 0) /* (U29) RGMII5_TXC */
J721E_IOPAD(0x158, PIN_OUTPUT, 0) /* (U23) RGMII5_TX_CTL */
main_mdio0_pins_default: main-mdio0-pins-default {
J721E_IOPAD(0x1bc, PIN_OUTPUT, 0) /* (V24) MDIO0_MDC */
J721E_IOPAD(0x1b8, PIN_INPUT, 0) /* (V26) MDIO0_MDIO */
&wkup_pmx0 {
sw11_button_pins_default: sw11-button-pins-default {
J721E_WKUP_IOPAD(0xcc, PIN_INPUT, 7) /* (G28) WKUP_GPIO0_7 */
mcu_fss0_ospi1_pins_default: mcu-fss0-ospi1-pins-default {
J721E_WKUP_IOPAD(0x34, PIN_OUTPUT, 0) /* (F22) MCU_OSPI1_CLK */
J721E_WKUP_IOPAD(0x50, PIN_OUTPUT, 0) /* (C22) MCU_OSPI1_CSn0 */
J721E_WKUP_IOPAD(0x40, PIN_INPUT, 0) /* (D22) MCU_OSPI1_D0 */
J721E_WKUP_IOPAD(0x44, PIN_INPUT, 0) /* (G22) MCU_OSPI1_D1 */
J721E_WKUP_IOPAD(0x48, PIN_INPUT, 0) /* (D23) MCU_OSPI1_D2 */
J721E_WKUP_IOPAD(0x4c, PIN_INPUT, 0) /* (C23) MCU_OSPI1_D3 */
J721E_WKUP_IOPAD(0x3c, PIN_INPUT, 0) /* (B23) MCU_OSPI1_DQS */
J721E_WKUP_IOPAD(0x38, PIN_INPUT, 0) /* (A23) MCU_OSPI1_LBCLKO */
mcu_cpsw_pins_default: mcu-cpsw-pins-default {
J721E_WKUP_IOPAD(0x0058, PIN_OUTPUT, 0) /* MCU_RGMII1_TX_CTL */
J721E_WKUP_IOPAD(0x005c, PIN_INPUT, 0) /* MCU_RGMII1_RX_CTL */
J721E_WKUP_IOPAD(0x0060, PIN_OUTPUT, 0) /* MCU_RGMII1_TD3 */
J721E_WKUP_IOPAD(0x0064, PIN_OUTPUT, 0) /* MCU_RGMII1_TD2 */
J721E_WKUP_IOPAD(0x0068, PIN_OUTPUT, 0) /* MCU_RGMII1_TD1 */
J721E_WKUP_IOPAD(0x006c, PIN_OUTPUT, 0) /* MCU_RGMII1_TD0 */
J721E_WKUP_IOPAD(0x0078, PIN_INPUT, 0) /* MCU_RGMII1_RD3 */
J721E_WKUP_IOPAD(0x007c, PIN_INPUT, 0) /* MCU_RGMII1_RD2 */
J721E_WKUP_IOPAD(0x0080, PIN_INPUT, 0) /* MCU_RGMII1_RD1 */
J721E_WKUP_IOPAD(0x0084, PIN_INPUT, 0) /* MCU_RGMII1_RD0 */
J721E_WKUP_IOPAD(0x0070, PIN_OUTPUT, 0) /* MCU_RGMII1_TXC */
J721E_WKUP_IOPAD(0x0074, PIN_INPUT, 0) /* MCU_RGMII1_RXC */
mcu_mdio_pins_default: mcu-mdio1-pins-default {
J721E_WKUP_IOPAD(0x008c, PIN_OUTPUT, 0) /* MCU_MDIO0_MDC */
J721E_WKUP_IOPAD(0x0088, PIN_INPUT, 0) /* MCU_MDIO0_MDIO */
mcu_mcan0_pins_default: mcu-mcan0-pins-default {
J721E_WKUP_IOPAD(0xac, PIN_INPUT, 0) /* (C29) MCU_MCAN0_RX */
J721E_WKUP_IOPAD(0xa8, PIN_OUTPUT, 0) /* (D29) MCU_MCAN0_TX */
mcu_mcan0_gpio_pins_default: mcu-mcan0-gpio-pins-default {
J721E_WKUP_IOPAD(0xb0, PIN_INPUT, 7) /* (F26) WKUP_GPIO0_0 */
J721E_WKUP_IOPAD(0x98, PIN_INPUT, 7) /* (E28) MCU_SPI0_D1.WKUP_GPIO0_54 */
mcu_mcan1_pins_default: mcu-mcan1-pins-default {
J721E_WKUP_IOPAD(0xc4, PIN_INPUT, 0) /* (G24) WKUP_GPIO0_5.MCU_MCAN1_RX */
J721E_WKUP_IOPAD(0xc0, PIN_OUTPUT, 0) /* (G25) WKUP_GPIO0_4.MCU_MCAN1_TX */
mcu_mcan1_gpio_pins_default: mcu-mcan1-gpio-pins-default {
J721E_WKUP_IOPAD(0xb8, PIN_INPUT, 7) /* (F28) WKUP_GPIO0_2 */
&wkup_uart0 {
/* Wakeup UART is used by System firmware */
status = "reserved";
&main_uart0 {
power-domains = <&k3_pds 146 TI_SCI_PD_SHARED>;
&main_uart3 {
/* UART not brought out */
status = "disabled";
&main_uart5 {
&main_uart6 {
&main_uart7 {
&main_uart8 {
&main_uart9 {
&main_gpio2 {
&main_gpio3 {
&main_gpio4 {
&main_gpio5 {
&main_gpio6 {
&main_gpio7 {
&wkup_gpio1 {
&main_sdhci0 {
/* eMMC */
non-removable;
ti,driver-strength-ohm = <50>;
disable-wp;
&main_sdhci1 {
/* SD/MMC */
ti,otap-del-sel-sd-hs;
ti,otap-del-sel-sdr12;
ti,otap-del-sel-sdr25;
ti,otap-del-sel-sdr50;
ti,otap-del-sel-ddr50;
ti,itap-del-sel-legacy;
ti,itap-del-sel-sd-hs;
ti,itap-del-sel-sdr12;
ti,itap-del-sel-sdr25;
ti,itap-del-sel-ddr50;
sdhci-caps-mask;
pinctrl-0 = <&main_mmc1_pins_default>;
disable-wp;
&main_sdhci2 {
/* Unused */
&usb_serdes_mux {
idle-states = <1>, <0>; /* USB0 to SERDES3, USB1 to SERDES1 */
&serdes_ln_ctrl {
idle-states = <J721E_SERDES0_LANE0_PCIE0_LANE0>, <J721E_SERDES0_LANE1_QSGMII_LANE2>,
<J721E_SERDES1_LANE0_PCIE1_LANE0>, <J721E_SERDES1_LANE1_PCIE1_LANE1>,
<J721E_SERDES2_LANE0_PCIE2_LANE0>, <J721E_SERDES2_LANE1_PCIE2_LANE1>,
<J721E_SERDES3_LANE0_USB3_0_SWAP>, <J721E_SERDES3_LANE1_USB3_0>,
<J721E_SERDES4_LANE0_EDP_LANE0>, <J721E_SERDES4_LANE1_EDP_LANE1>,
<J721E_SERDES4_LANE2_EDP_LANE2>, <J721E_SERDES4_LANE3_EDP_LANE3>;
&serdes_wiz3 {
typec-dir-gpios = <&main_gpio1 3 GPIO_ACTIVE_HIGH>;
typec-dir-debounce-ms = <700>; /* TUSB321, tCCB_DEFAULT 133 ms */
&serdes3 {
serdes3_usb_link: phy@0 {
reg = <0>;
cdns,num-lanes = <2>;
#phy-cells = <0>;
cdns,phy-type = <PHY_TYPE_USB3>;
resets = <&serdes_wiz3 1>, <&serdes_wiz3 2>;
&usbss0 {
pinctrl-0 = <&main_usbss0_pins_default>;
ti,vbus-divider;
&usb0 {
dr_mode = "otg";
maximum-speed = "super-speed";
phys = <&serdes3_usb_link>;
phy-names = "cdns3,usb3-phy";
&usbss1 {
pinctrl-0 = <&main_usbss1_pins_default>;
ti,usb2-only;
&usb1 {
dr_mode = "host";
maximum-speed = "high-speed";
&ospi1 {
pinctrl-0 = <&mcu_fss0_ospi1_pins_default>;
flash@0{
compatible = "jedec,spi-nor";
reg = <0x0>;
spi-tx-bus-width = <1>;
spi-rx-bus-width = <4>;
spi-max-frequency = <40000000>;
cdns,tshsl-ns = <60>;
cdns,tsd2d-ns = <60>;
cdns,tchsh-ns = <60>;
cdns,tslch-ns = <60>;
cdns,read-delay = <2>;
#address-cells = <1>;
#size-cells = <1>;
&tscadc0 {
adc {
ti,adc-channels = <0 1 2 3 4 5 6 7>;
&tscadc1 {
adc {
&main_i2c0 {
pinctrl-0 = <&main_i2c0_pins_default>;
clock-frequency = <400000>;
exp1: gpio@20 {
compatible = "ti,tca6416";
reg = <0x20>;
gpio-controller;
#gpio-cells = <2>;
exp2: gpio@22 {
compatible = "ti,tca6424";
reg = <0x22>;
gpio-controller;
#gpio-cells = <2>;
p08-hog {
/* P10 - PM_I2C_CTRL_OE */
gpio-hog;
gpios = <8 GPIO_ACTIVE_HIGH>;
output-high;
line-name = "CTRL_PM_I2C_OE";
p09-hog {
/* P11 - MCASP/TRACE_MUX_S0 */
gpio-hog;
gpios = <9 GPIO_ACTIVE_HIGH>;
output-low;
line-name = "MCASP/TRACE_MUX_S0";
p10-hog {
/* P12 - MCASP/TRACE_MUX_S1 */
gpio-hog;
gpios = <10 GPIO_ACTIVE_HIGH>;
output-high;
line-name = "MCASP/TRACE_MUX_S1";
&main_i2c1 {
pinctrl-0 = <&main_i2c1_pins_default>;
exp4: gpio@20 {
compatible = "ti,tca6408";
reg = <0x20>;
gpio-controller;
#gpio-cells = <2>;
pinctrl-0 = <&main_i2c1_exp4_pins_default>;
interrupt-parent = <&main_gpio1>;
interrupts = <11 IRQ_TYPE_EDGE_FALLING>;
interrupt-controller;
#interrupt-cells = <2>;
&main_i2c2 {
pinctrl-0 = <&main_i2c2_pins_default>;
ina226@40 {
compatible = "ti,ina226";
reg = <0x40>;
shunt-resistor = <10000>;
ina226@41 {
reg = <0x41>;
ina226@42 {
reg = <0x42>;
ina226@43 {
reg = <0x43>;
ina226@44 {
reg = <0x44>;
ina226@45 {
reg = <0x45>;
shunt-resistor = <5000>;
ina226@46 {
reg = <0x46>;
ina226@47 {
reg = <0x47>;
ina226@48 {
reg = <0x48>;
ina226@49 {
reg = <0x49>;
ina226@4a {
reg = <0x4a>;
ina226@4b {
reg = <0x4b>;
ina226@4c {
reg = <0x4c>;
ina226@4d {
reg = <0x4d>;
ina226@4e {
reg = <0x4e>;
ina226@4f {
reg = <0x4f>;
&k3_clks {
/* Confiure AUDIO_EXT_REFCLK2 pin as output */
pinctrl-0 = <&audi_ext_refclk2_pins_default>;
&main_i2c3 {
pinctrl-0 = <&main_i2c3_pins_default>;
exp3: gpio@20 {
reg = <0x20>;
gpio-controller;
#gpio-cells = <2>;
pcm3168a_1: audio-codec@44 {
compatible = "ti,pcm3168a";
reg = <0x44>;
#sound-dai-cells = <1>;
reset-gpios = <&exp3 0 GPIO_ACTIVE_LOW>;
/* C_AUDIO_REFCLK2 -> RGMII6_RXC (W26) */
clocks = <&k3_clks 157 371>;
clock-names = "scki";
/* HSDIV3_16FFT_MAIN_4_HSDIVOUT2_CLK -> REFCLK2 */
assigned-clocks = <&k3_clks 157 371>;
assigned-clock-parents = <&k3_clks 157 400>;
assigned-clock-rates = <24576000>; /* for 48KHz */
VDD1-supply = <&vsys_3v3>;
VDD2-supply = <&vsys_3v3>;
VCCAD1-supply = <&vsys_5v0>;
VCCAD2-supply = <&vsys_5v0>;
VCCDA1-supply = <&vsys_5v0>;
VCCDA2-supply = <&vsys_5v0>;
max96722_1: gmsl-deserializer@52 {
compatible = "maxim,max96722";
reg = <0x52>;
enable-gpios = <&exp3 0 GPIO_ACTIVE_HIGH>;
ports {
#size-cells = <0>;
port@4 {
reg = <4>;
max96712_out0: endpoint {
clock-lanes = <0>;
data-lanes = <1 2 3 4>;
remote-endpoint = <&csi40_in>;
&main_i2c6 {
pinctrl-0 = <&main_i2c6_pins_default>;
exp5: gpio@20 {
reg = <0x20>;
gpio-controller;
#gpio-cells = <2>;
&mcu_cpsw {
pinctrl-0 = <&mcu_cpsw_pins_default &mcu_mdio_pins_default>;
&davinci_mdio {
phy0: ethernet-phy@0 {
reg = <0>;
ti,rx-internal-delay = <DP83867_RGMIIDCTL_2_00_NS>;
ti,fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_4_B_NIB>;
&cpsw_port1 {
phy-mode = "rgmii-rxid";
phy-handle = <&phy0>;
&dss {
* These clock assignments are chosen to enable the following outputs:
* VP0 - DisplayPort SST
* VP1 - DPI0
* VP2 - DSI
* VP3 - DPI1
assigned-clocks = <&k3_clks 152 1>,
<&k3_clks 152 4>,
<&k3_clks 152 9>,
<&k3_clks 152 13>;
assigned-clock-parents = <&k3_clks 152 2>, /* PLL16_HSDIV0 */
<&k3_clks 152 6>, /* PLL19_HSDIV0 */
<&k3_clks 152 11>, /* PLL18_HSDIV0 */
<&k3_clks 152 18>; /* PLL23_HSDIV0 */
&dss_ports {
port@0 {
reg = <0>;
dpi0_out: endpoint {
remote-endpoint = <&dp0_in>;
&mhdp {
pinctrl-0 = <&dp0_pins_default>;
&dp0_ports {
#size-cells = <0>;
port@0 {
reg = <0>;
dp0_in: endpoint {
remote-endpoint = <&dpi0_out>;
port@4 {
reg = <4>;
dp0_out: endpoint {
remote-endpoint = <&dp_connector_in>;
&mcasp0 {
&mcasp1 {
&mcasp2 {
&mcasp3 {
&mcasp4 {
&mcasp5 {
&mcasp6 {
&mcasp7 {
&mcasp8 {
&mcasp9 {
&mcasp10 {
#sound-dai-cells = <0>;
pinctrl-0 = <&mcasp10_pins_default>;
op-mode = <0>; /* MCASP_IIS_MODE */
tdm-slots = <2>;
auxclk-fs-ratio = <256>;
serial-dir = < /* 0: INACTIVE, 1: TX, 2: RX */
1 1 1 1
2 2 2 0
tx-num-evt = <0>;
rx-num-evt = <0>;
&mcasp11 {
&cmn_refclk1 {
clock-frequency = <100000000>;
&wiz0_pll1_refclk {
assigned-clocks = <&wiz0_pll1_refclk>;
assigned-clock-parents = <&cmn_refclk1>;
&wiz0_refclk_dig {
assigned-clocks = <&wiz0_refclk_dig>;
&wiz1_pll1_refclk {
assigned-clocks = <&wiz1_pll1_refclk>;
&wiz1_refclk_dig {
assigned-clocks = <&wiz1_refclk_dig>;
&wiz2_pll1_refclk {
assigned-clocks = <&wiz2_pll1_refclk>;
&wiz2_refclk_dig {
assigned-clocks = <&wiz2_refclk_dig>;
&cmn_refclk1 {
&serdes0 {
assigned-clocks = <&serdes0 CDNS_SIERRA_PLL_CMNLC>, <&serdes0 CDNS_SIERRA_PLL_CMNLC1>;
assigned-clock-parents = <&wiz0_pll1_refclk>, <&wiz0_pll1_refclk>;
serdes0_pcie_link: phy@0 {
reg = <0>;
cdns,num-lanes = <1>;
#phy-cells = <0>;
cdns,phy-type = <PHY_TYPE_PCIE>;
resets = <&serdes_wiz0 1>;
serdes0_qsgmii_link: phy@1 {
reg = <1>;
#phy-cells = <0>;
cdns,phy-type = <PHY_TYPE_QSGMII>;
resets = <&serdes_wiz0 2>;
&serdes1 {
assigned-clocks = <&serdes1 CDNS_SIERRA_PLL_CMNLC>;
assigned-clock-parents = <&wiz1_pll1_refclk>;
serdes1_pcie_link: phy@0 {
reg = <0>;
#phy-cells = <0>;
resets = <&serdes_wiz1 1>, <&serdes_wiz1 2>;
&serdes2 {
assigned-clocks = <&serdes2 CDNS_SIERRA_PLL_CMNLC>;
assigned-clock-parents = <&wiz2_pll1_refclk>;
serdes2_pcie_link: phy@0 {
reg = <0>;
#phy-cells = <0>;
resets = <&serdes_wiz2 1>, <&serdes_wiz2 2>;
&cpsw9g_mdio {
phy5: ethernet-phy@0 {
reg = <0>;
// ti,rx-internal-delay = <DP83867_RGMIIDCTL_2_00_NS>;
// ti,fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_4_B_NIB>;
&cpsw0_port1 {
&cpsw0_port2 {
&cpsw0_port3 {
&cpsw0_port4 {
&cpsw0_port5 {
ti,syscon-efuse = <&scm_conf 0x4054>;
mac-address = [00 00 00 00 00 00];
phys = <&cpsw0_phy_gmii_sel 1>;
phy-handle = <&phy5>;
status = "okay";
&cpsw0_port6 {
&cpsw0_port7 {
&cpsw0_port8 {
&cpsw0 {
* Disable cpsw0 since cpsw9g_virt_mac is the default Ethernet
* controller. cpsw0 is enabled with overlay for native
* Ethernet driver support.
pinctrl-0 = <&rgmii5_pins_default &main_mdio0_pins_default>;
status = "okay";
&pcie0_rc {
reset-gpios = <&exp1 6 GPIO_ACTIVE_HIGH>;
phys = <&serdes0_pcie_link>;
phy-names = "pcie-phy";
num-lanes = <1>;
&pcie1_rc {
reset-gpios = <&exp1 2 GPIO_ACTIVE_HIGH>;
phys = <&serdes1_pcie_link>;
num-lanes = <2>;
&pcie2_rc {
reset-gpios = <&exp2 20 GPIO_ACTIVE_HIGH>;
phys = <&serdes2_pcie_link>;
num-lanes = <2>;
&pcie0_ep {
num-lanes = <1>;
&pcie1_ep {
num-lanes = <2>;
&pcie2_ep {
num-lanes = <2>;
&pcie3_rc {
&pcie3_ep {
/* uart2 assigned to cpsw9g eth-switch fw running on remote CPU core */
&main_uart2 {
&mcu_mcan0 {
pinctrl-0 = <&mcu_mcan0_pins_default>;
phys = <&transceiver1>;
&mcu_mcan1 {
pinctrl-0 = <&mcu_mcan1_pins_default>;
phys = <&transceiver2>;
&main_mcan0 {
pinctrl-0 = <&main_mcan0_pins_default>;
phys = <&transceiver3>;
&main_mcan1 {
&main_mcan2 {
pinctrl-0 = <&main_mcan2_pins_default>;
phys = <&transceiver4>;
&main_mcan3 {
&main_mcan4 {
&main_mcan5 {
&main_mcan6 {
&main_mcan7 {
&main_mcan8 {
&main_mcan9 {
&main_mcan10 {
&main_mcan11 {
&main_mcan12 {
&main_mcan13 {
&csi0_port0 {
status = "okay";
csi40_in: endpoint {
clock-lanes = <0>;
remote-endpoint = <&max96712_out0>;
&csi0_port1 {
&csi0_port2 {
&csi0_port3 {
&csi0_port4 {
&main_ehrpwm0 {
&main_ehrpwm1 {
&main_ehrpwm2 {
&main_ehrpwm3 {
&main_ehrpwm4 {
&main_ehrpwm5 {
&ti_csi2rx0 {
status = "okay";
