AM62A7: SysConfig Global MCAN settings wrong number conversion
Part Number: AM62A7
in the SysConfig tool the values for the global settings are wrong converted in the generated code. (discrepancy between decimal and hex)
  • Hi Alexander,
    Thank you for your query.
    I have taken your inputs. Please allow some time to revert back.
    Tushar
  • Hi Alexander,
    Apologies for the delayed response.
    The mcan config template file didn't contain the code to convert the decimal value to hex value. Please update the mcan_config.c.xdt file with the below code.
        let module = system.modules['/drivers/mcan/mcan'];
     * MCAN
    /* MCASP Default Bit timing Parameters */
    MCAN_BitTimingParams gMcanBitTimingDefaultParams =
        .nomRatePrescalar   = 0x`module.$static.nomRatePrescalar.toString(16).toUpperCase()`U,
        .nomTimeSeg1        = 0x`module.$static.nomTimeSeg1.toString(16).toUpperCase()`U,
        .nomTimeSeg2        = 0x`module.$static.nomTimeSeg2.toString(16).toUpperCase()`U,
        .nomSynchJumpWidth  = 0x`module.$static.nomSynchJumpWidth.toString(16).toUpperCase()`U,
        .dataRatePrescalar  = 0x`module.$static.dataRatePrescalar.toString(16).toUpperCase()`U,
        .dataTimeSeg1       = 0x`module.$static.dataTimeSeg1.toString(16).toUpperCase()`U,
        .dataTimeSeg2       = 0x`module.$static.dataTimeSeg2.toString(16).toUpperCase()`U,
        .dataSynchJumpWidth = 0x`module.$static.dataSynchJumpWidth.toString(16).toUpperCase()`U,
    The mcan_config.c.xdt file is located at path {MCU+SDK}/source/drivers/.meta/mcan/templates. After updating the file restart the sysconfig tool and it will work fine. Please let me know if this solution works for you.
    Thanks & Regards,
    Tushar
